[FOSS-GPS] R: Re: R: post-processing in RTKLib (solved)
David Kelley DavidKelley at ITSware.net
Wed Apr 29 17:39:25 PDT 2015
Francesco
I looked at the manual one more time. Duh.   See page 13, point 12.
There is it right in front of me in the dialog to setup the input stream
(see figure 3.2-3). Mid screen are the words "*Transmit NMEA GPGAA to
Base Station*" Select the drop down item "Latitude/Longitude" and enter
your gross position (try to get with 5km or so) and it will work.   I
just used 34.13  -117.83 as that was the value in the caster table for
Padova3, use LL near to your own work.   Try that and you should be fine.
Seems to work in RTKLIB fine now once I changed the above settings. But
before I found the that input line, earlier today I tried the log-on on
credentials you supplied with our in house tools, with Alberdin
InspectRTCM, with Lefebure NTRIP Caster.  Each of these also worked fine
and sent back good data.   Did not get to try it with RtkGPS on an
Android tablet but as I see on my phone where the developer has moved
the RTKLIB widget to enter data to sent the user position when it
connects to the remote stream, it should work just as you have noted it
worked for you.
Regards,   David Kelley
On 4/28/2015 8:29 AM, checco68 wrote:
> Dear All
>   I am able to collect fix position using the rtk+ on android but if I use
> the same settings in the rtklib (windows) the NTRIP connection doesn't work
> so maybe there is some bug int rtklib ?
> Francesco
And
> Hy David
> The account provided byhttp://147.162.229.63/Web/index.php  allows me to use
> this mountpoint (MAX3, IMAX2 e NRT3) but with this mountpoint I receive the
> timeout error message
> PS the distance between my location and the  base staion is about 7 km
> Francesco
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150429/d49171bd/attachment.html>
More information about the FOSS-GPS mailing list
