[FOSS-GPS] [RTKLib - RTKPOST] Problems with base station coordinates (bug?)
Mattia De Agostino mattia.deagostino at gmail.com
Tue Dec 1 08:53:15 PST 2015
Hello everyone,
I'm using the post-processing module RTKPOST of RTKLib software (ver. 2.4.2,
patch 11) with dual frequency GNSS RINEX files, and I noticed a small
problem regarding the settings of the base station coordinates in static
mode.
In the "Positions" > "Base Station" window, when I select the "RINEX Header
Position" coordinates (that in my files are the precise coordinates of the
base station in ETRS89 reference system), the software sums these two RINEX
fields:
"APPROX POSITION XYZ"  + "ANTENNA: DELTA H/E/N"
Unfortunately, if I also use antenna PCV ANTEX files, the "ANTENNA: DELTA
H/E/N" values are added again during the processing, so my final rover
position has an offset equal to the "ANTENNA: DELTA H/E/N" values.
Since usually the "ANTENNA: DELTA H/E/N" values are equal to zero, this
problem is difficult to be found. But our antennas have a small offset (few
cms) due to a SCIGN leveling mount like this one:
https://www.unavco.org/projects/project-support/gnss-support/permanent-station/equipment/mounts/scignmount.html
The solution of my problem is to manually insert the XYZ coordinates of the
base station. But I find very useful the "RINEX Header position" option...
Did I do something wrong?
Do you have the same problem?
If you confirm my problem, I will wrote to the software developer to report
the bug.
Thanks,
Mattia
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLib-RTKPOST-Problems-with-base-station-coordinates-bug-tp7573355.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
