[FOSS-GPS] post-processing in RTKLib
julio menezes
yjmenezes at yahoo.com.br
Mon Jan 19 03:51:52 PST 2015
Dear Antonella Marisco,
Em seg, 19/1/15, Antonella Marsico <antonella.marsico at uniba.it> escreveu:
Assunto: [FOSS-GPS] post-processing in RTKLib
Para: foss-gps at lists.osgeo.org
Data: Segunda-feira, 19 de Janeiro de 2015, 8:11
Hello
everybody,I'm new in RTKLib... I collected data in
static mode and I need to correct measures using data from
an antenna of GNSS network. I used the RTKPOST in both
Static and DGPS mode. I need the coordinates
(lat/long/height or X/Y/Z) of one point
>From reference station you will need:
a) Rinex Observation and Navigation data
b) reference position Lat/Lon/Height ( geometric and orthometric if available )
c) antenna height
Your location:
a) occupation time, depends receiver capabilities ( L1 or L1+L2 ... ) and reference distance.
b) antenna height
the static technic is ok for you.
you must:
a) select static and frequencies, gps+glonass or just gps ( rtkpost panel )
b ) type the base station position ( rtkpost panel )
c) other minor settings, let the default
regards,
julio menezes
More information about the FOSS-GPS
