[FOSS-GPS] RTKLIB RTKCONV RTKPOST
macSam
mike.mcloughlin at rockmate.com
Tue Jul 28 11:26:55 PDT 2015
I am using 2 of u-blox NEO-6P. One as a base station, the other as a rover.
I use RTKCONV to create the RINEX files.
The base station creates .obs and .nav files
The rover creates seperate .obs, .nav, .hnav, .nav and .sbs files.
RTKPOST:
% program : RTKPOST ver.2.4.2
% inp file : E:\results\150728ar.obs ROVER data
% inp file : E:\results\150728b.obs BASE Data
% inp file : E:\results\150728ar.nav
% inp file : E:\results\150728ar.sbs
% obs start : 2015/07/28 16:07:08.0 GPST (week1855 230828.0s)
% obs end : 2015/07/28 16:15:24.0 GPST (week1855 231324.0s)
% pos mode : dgps
% freqs : L1+L2
% solution : combined
% elev mask : 15.0 deg
% dynamics : off
% tidecorr : off
% ionos opt : off
% tropo opt : off
% ephemeris : broadcast+sbas
% navi sys : gps sbas
% antenna1 : ( 0.0000 0.0000 0.0000)
% antenna2 : ( 0.0000 0.0000 0.0000)
% ref pos : 0.0000 0.0000 21384.6857
I have SBAS switched on in both GPS's.
The results that I get shows the quality number 3 - SBAS.
It seems to be ignoring the DGPS - why? Any help gratefully appreciated.
If I do not have sbas readings I only get .obs and .nav files. ( The base
station is in a bad position and cannot get SBAS - but RTKPOST only asks for
the .obs file of the base station)
MacSam
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/RTKLIB-RTKCONV-RTKPOST-tp7573249.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
