[FOSS-GPS] Ublox NEO-M8N no GLONASS in RTKRCV
julio menezes
yjmenezes at yahoo.com.br
Wed May 13 13:41:54 PDT 2015
Stefan Weber,
Em qua, 13/5/15, Stefan Weber BFH <webes14 at bfh.ch> escreveu:
Assunto: [FOSS-GPS] Ublox NEO-M8N no GLONASS in RTKRCV
Para: foss-gps at lists.osgeo.org
Data: Quarta-feira, 13 de Maio de 2015, 15:25
Hello everyone
I am trying to get a Ublox NEO-M8N working with rtkrcv on
linux.
Connected over USB, I like to get GPS and GLONASS working in
Single mode
and later in kinematic mode.
I set the "pos1-navsys =5 #
(1:gps+2:sbas+4:glo+8:gal+16:qzs+32:comp)"
for GPS and GLONASS, but I only get GPS Satellites.
I used on the same time, with the same antenna, at the same
place a
second Ublox NEO-M8N also connected over USB on a
WIN7 PC with RTKNAVI, and there I got with similar settings
GPS and
GLONASS Satellites.
check your linux devices
there are some wrong settings, try fix this lines, check devices, serial baudrate, receiver cmd..:
Rover
inpstr1-type =serial
inpstr1-path =ttyACM0:230400:8:n:1:off
inpstr1-format =ubx #
outstr1-type =serial
outstr1-path =ttyUSB0:115200:8:n:1:off
outstr1-format =nmea # (0:llh,1:xyz,2:enu,3:nmea)
pos1-posmode =single #
file-cmdfile1 =../data/ubx_m8n_glo_raw_1hz.cmd
Base
inpstr2-type =serial #
inpstr2-path =ttyUSB2:115200:8:n:1:off
inpstr2-format =rtcm3 # ubx
i hope it helps.
[]s
julio menezes
file-cmdfile2 =
More information about the FOSS-GPS
