[FOSS-GPS] Single-Frequency PPP in RTKLIB
Dimitris Psychas
psxdimitris at hotmail.com
Sun May 24 15:11:10 PDT 2015
No. In particular, when I use multiple GNSS systems, I get much better performance compared to GPS-only PPP, using dual frequency observation data.
I thought the same, that the L2 observations from iono products are not produced correctly. But how could I fix it ? Do you have tried something like this ? I just used RTKCONV to remove the L2 frequency observations, and then I use IONEX TEC files as Ionosphere Correction in RTKPOST in order to establish the single-frequency PPP.
Date: Sun, 24 May 2015 17:19:05 -0300
To: foss-gps at lists.osgeo.org
Subject: Re: [FOSS-GPS] Single-Frequency PPP in RTKLIB
Do you get similar worse performance for GNSS compared to GPS when you process your original RINEX file containing dual-frequency measurements?If not, then there's something wrong in the way you're producing synthetic L2 observations from iono products.-F.
This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150525/5542d87d/attachment.html>
More information about the FOSS-GPS
