[FOSS-GPS] rtklib / rnx2rtkp gps/glonass
Greger Burman gb at moroco.se
Mon Nov 23 08:15:02 PST 2015
Hello CptStubbs!
Sorry I did not see your message until now. The short answer is that I have
not had any success with including GLONASS so far. I will revisit this
topic when I have the chance to test with a different antenna that is
better for GLONASS.
I have learned a couple of things regarding the settings that I did not
know before. I don't remember where I found this info, if may have been
right here in FOSS-GPS.
1. RTKLIB p11 in required, so make sure you don't have an older version.
2. For best result ambiguity resolution should only use GPS, not GLONASS. I
believe this had to do with GLONASS time not being as accurate as GPS time
keeping. Options -> Settings2 -> Integer AR: GPS:ON, GLO:OFF
Let me know how you get on.
cheers
2015-10-05 20:33 GMT+02:00 CptStubbs <joshuastubbs at me.com>:
> Hej Greger!
> Have you had any luck in finding out why the position is better with GPS
> only? I'm having similar problems. Any findings are appreciated!
> Best regards,
> CptStubbs
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/rtklib-rnx2rtkp-gps-glonass-tp7573251p7573305.html
> Sent from the Open Source GPS-related discussion and support mailing list
> archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
Greger Buman
MoRoCo AB
+46702623081
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20151123/ae2b5f69/attachment.html>
More information about the FOSS-GPS mailing list
