[FOSS-GPS] Recommended receivers for precise fixed relative measurements
Danny Miller dannym at austin.rr.com
Thu Sep 10 13:54:01 PDT 2015
Bullet-shaped, is that the helical?
What I saw as a problem was the helicals are designed to accept signal
from all directions.  This helps get a basic fix for consumer use, where
the cellphone may be physically left on its side or kept in any other
orientation.
However, for RTK, there are increased problems with multipath, a signal
reflected off something so the pseudorange distance seen is off by that
extra distance.  If there's a metal building 25ft behind you and the
satellite is in front, it gets a signal 50ft later than it should be
which blends in with the correct direct path.
An antenna ideally would be guaranteed to be oriented a particular way
and have barriers to physically obscure reception of anything but the
sky-facing direction, like a choke-ring antenna.  Most multipath
approaches the antenna from the side and a choke ring will attenuate
signals from the side so much that it is not seen on the output cable.
But if a choke ring antenna was on a cellphone, if it was held in a
different orientation 90 deg off, it would primarily receive the
multipath and attenuate out the direct-path signal.
Danny
On 9/10/2015 3:33 PM, Model A wrote:
> For the best accuracy I have found that a good quality antenna makes all the
> difference.   I am using a couple of L1/L2 GPS antennas that I bought used
> on eBay for under $100 each.   My system uses L1 only.   I have also tried
> some bullet shaped L1 GPS Timing antennas that were used on cell phone
> towers, they worked just as good.   More information will follow within a
> few week’s time.
> View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Recommended-receivers-for-precise-fixed-relative-measurements-tp7573283p7573284.html
> Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
