[FOSS-GPS] Recommended receivers for precise fixed relative measurements
Felipe G. Nievinski
fgnievinski at gmail.com
Thu Sep 10 15:47:35 PDT 2015
US$200 for a pair of carrier phase outputting GPS receivers? Pretty much
the only option is NavSpark's NS-RAW module with an external antenna
logging data via USB. If it's a one-time job, you might consider renting a
pair from your local surveying shop.
F.
On Sep 10, 2015 4:00 PM, <foss-gps-request at lists.osgeo.org> wrote:
> Send FOSS-GPS mailing list submissions to
> foss-gps at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> http://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> foss-gps-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
> 1. Recommended receivers for precise fixed relative measurements
> (Stewart Nelson)
> Message: 1
> Date: Wed, 9 Sep 2015 13:37:26 -0700
> From: Stewart Nelson <voip at heyitsmail.com>
> To: foss-gps at lists.osgeo.org
> Subject: [FOSS-GPS] Recommended receivers for precise fixed relative
> measurements
> Message-ID: <55F09886.3030303 at heyitsmail.com>
> Content-Type: text/plain; charset=utf-8; format=flowed
> I'd like to measure several points on a small (~ 70 m X 140 m) property,
> with 5 cm or better accuracy, relative to a reference receiver in the
> center of the field.
> Can you please recommend suitable USB-powered receivers, compatible with
> RTKLIB or other free or inexpensive software? They must be readily
> available (in stock in US) and if possible under $200 for the pair,
> including external antennas if required.
> There is good Wi-Fi Internet coverage over the property. The laptops
> that will power the receivers can boot to Windows 10 or Ubuntu 14.04.
> If needed, the receiver pair can be left several minutes at each
> location to be measured. Though absolute positions are not required,
> there is a recent survey marker whose coordinates could be entered.
> I see some really inexpensive units that get good reviews (though not
> for precision use), e.g. GlobalSat BU-353-S4 at ~$30 each delivered.
> However, it appears that RTKLIB can't read the SiRF binary format, and
> its NEMA output doesn't include carrier phase info. What accuracy could
> be expected from hardware like this?
> Thanks,
> Stewart
> FOSS-GPS at lists.osgeo.org
> End of FOSS-GPS Digest, Vol 80, Issue 6
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20150910/184f4bb5/attachment.html>
More information about the FOSS-GPS
