[FOSS-GPS] uBlox EVK-6N and RTKLIB 2.4.2
HAOCHLI lihaochen0428 at gmail.com
Tue Apr 19 20:57:57 PDT 2016
Hi to all,
I'm a newcomer in GNSS area.
Recently, I'm trying to use RTKNAVI to communicate with my uBlox EVK-6N.
In uCenter, I did the following
-> Message View -> disable NMEA and enable UBX
-> Message Vie -> UBX -> CFG -> PRT(Ports)->Target: 3-USB
-> Configuration View -> RXM-RAW & RXM-SFRB -> USB on
-> Send all above to receiver.
-> Connect with RTKNAVI
However, no GPS info was recorded, only the following appears.
I'd like to know if my device is supported by RTKNAVI........
Thanks in advance!
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7573473/1.png>
<http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/file/n7573473/2.png>
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/uBlox-EVK-6N-and-RTKLIB-2-4-2-tp7573473.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS mailing list
