[FOSS-GPS] Sometimes RTKNAVI Solution box change to white and blocks
dskumher
dskumher1968 at gmail.com
Sat Aug 27 10:33:11 PDT 2016
This happens when full solution has not been reached ,may be due to poor
satellite reception. The remedy may be to first have single base & rover
solution,till then keep AR option off in settings 2. Then stop & exclude
poor satellites, still keeping AR option off. After 5 min. set AR option
either to continuous or fix & hold. Then problem of solution box becoming
white may be solved. It is my perception.Hope it will work.
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Sometimes-RTKNAVI-Solution-box-change-to-white-and-blocks-tp7573469p7573521.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
