[FOSS-GPS] Beidou sattelites reception in RTKNAVI
Stéphane Péneau
stephane.peneau at wanadoo.fr
Sat Aug 27 10:44:21 PDT 2016
I see Beidou satellites with my navspark NS-HP in RTKLIB, but not the
egnos (sbas).
Perhaps it has something to do with the input format not fully recognized.
Stf
Le 27/08/2016 à 12:22, Dhirendra Singh a écrit :
> I am using NV08C-CSM latest hardware version 5 which has 2 optional
> firmwares, GPS + GLONASS & GPS + BEIDOU
> I am using GPS+BEIDOU firmware. The problem is that when I choose
> GPS,BEIDOU & SBAS from RTKNAVI options,only GPS satellites are chosen
> & seen. Beidou sattelites are not seen & taken into account for the
> solution. SBAS sattelites are also not seen( only letter "G"is seen in
> the RTKNAVI window) . There is not such problem with GLONASS
> sattelites. Can anyone provide solution to this problem ? When I use
> Hemisphere A100 smart antenna (which is a GPS+SBAS receiver ) , both
> GPS & SBAS sattelites are seen ( letter "GS" is seen in the RTKNAVI
> window). I am using RTKLIB 2.4.2 patch 11 software version.
> With regards,
> Dhirendra singh,
> INDIA.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20160827/480726a9/attachment.html>
More information about the FOSS-GPS
