[FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
anthony wooldridge arwooldridge at googlemail.com
Wed Jun 22 06:56:14 PDT 2016
Thanks, I can confirm that C++ Builder 10.1 does correctly compile and
make rtklib2.4.3b8, but not yet b12 due to the linker errors.
I would be interested if anyone else can verify this or which C++
builder versions are affected. It would rule out if there are any
missing .lib or .obj files in b12, otherwise I am stuck for a solution
short of rebuilding all the project files from scratch.
Anthony
On 21/06/2016 09:40, Tomoji Takasu wrote:
>> Thanks I had the same problem now fixed, compiles OK but now get
>> linker error:
>> c:\program files
>> (x86)\embarcadero\studio\18.0\Bin\CodeGear.Cpp.Targets(3517,5): error
>> : Error: Unresolved external '__fastcall
>> Vcl::Controls::TWinControl::GetDeviceContext(void *&)' referenced
>> from C:\RTKLIB ARW
>> FORK\RTKLIB-RTKLIB_2.4.3B12\APP\RTKNAVI\RELEASE_BUILD\NAVIMAIN.OBJ
>> and two other similar unresolved external errors
>> fixed three fabs long double/ float ambiguity errors by changing to
>> fabsl
>> Using C++ builder 10.1 Berlin.
> Thanks for useful info.
> I used C++ builder XE2 starter (32bit) and have no
> problem.
> Some modification may be needed for 10.1 Berlin.
> Tomoji TAKASU
> From: "anthony wooldridge" <arwooldridge at googlemail.com>
> Sent: Tuesday, June 21, 2016 5:34 PM
> To: "Open Source GPS-related discussion and support"
> <foss-gps at lists.osgeo.org>
> Subject: Re: [FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
>> linker error:
>> c:\program files
>> from C:\RTKLIB ARW
>> fabsl
>> Regards
>> Anthony
>> On 21/06/2016 05:44, Tomoji Takasu wrote:
>>>> Where is file markdlg.h?
>>>> i not found
>>> Thanks. It is fixed in 2.4.3 b12.
>>> Tomoji TAKASU
>>> From: "cocute" <cocute at gmail.com>
>>> Sent: Monday, June 20, 2016 9:37 PM
>>> To: <foss-gps at lists.osgeo.org>
>>> Subject: [FOSS-GPS] How to compile new RTKLIB 2.4.3 B11?
>>>> y have this error:
>>>> [bcc32 Error] navimain.cpp(35): E2209 Unable to open include file
>>>> 'markdlg.h'
>>>> i not found
>>>> Thanks
>>>> View this message in context:
>>>> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/How-to-compile-new-RTKLIB-2-4-3-B11-tp7573495.html
>>>> Sent from the Open Source GPS-related discussion and support
>>>> mailing list archive at Nabble.com.
>>>> _______________________________________________
>>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>>>> list.
>>>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>>>> your subscription
>>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
>>> your subscription
>> Visit http://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
>> subscription
> subscription
More information about the FOSS-GPS mailing list
