[FOSS-GPS] Reading rtkrcv under GNU/Linux rtklib: PPP-static precision mode
Jean-Michel Pouré jm at poure.com
Thu Mar 3 12:15:23 PST 2016
Le jeudi 03 mars 2016 à 10:59 -0700, xeee a écrit :
> You have examples of configuration files in the folder ./app/rtkrcv/
> Maybe its better if you change those files instead of using one with
> only the commands you have.
> I only started using rtklib in January so I'm also still new to this
> In my last PPP solution I got the pos xyz float std (m) rover :
> 0.024,
> 0.011, 0.021, so you still have room to improve.
These are very good results for PPP.
What kind of correction are you using?
The PPP configuration file includes an ntrip correction:
inpstr3-type       =ntripcli
inpstr3-path       =user:password at www.igs-ip.net:2101/CLK31
Are you using ntrip to achieve such a result?
Kind regards,
Jean-Michel
More information about the FOSS-GPS mailing list
