[FOSS-GPS] Reading rtkrcv under GNU/Linux rtklib: PPP-static precision mode
xeee
fabiomonteiro3 at hotmail.com
Thu Mar 3 13:05:50 PST 2016
Hey,
The problem in rtklib 2.4.3 are the makefiles, you just need to add the
dependency of some files in 3 or 4 makefiles.
It's easy to understand and correct it, as it says which files are missing
when you run the make.
For that results I wasn't using any corrections in the "inpstr3-type". It
was just GPS+SBAS with a normal configuration file with the broadcasted
corrections.
pos1-tidecorr =on # (0:off,1:on)
pos1-ionoopt =brdc #
(0:off,1:brdc,2:sbas,3:dual-freq,4:est-stec,5:ionex-tec,6:qzs-brdc,7:qzs-lex,8:vtec_sf,9:vtec_ef,10:gtec)
pos1-tropopt =saas #
(0:off,1:saas,2:sbas,3:est-ztd,4:est-ztdgrad)
pos1-sateph =brdc #
(0:brdc,1:precise,2:brdc+sbas,3:brdc+ssrapc,4:brdc+ssrcom)
View this message in context: http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/Reading-rtkrcv-under-GNU-Linux-rtklib-PPP-static-precision-mode-tp7573416p7573425.html
Sent from the Open Source GPS-related discussion and support mailing list archive at Nabble.com.
More information about the FOSS-GPS
