[FOSS-GPS] uBlox NEO-M8T and RTKlib
Damjan Gerl
damjan at damjan.net
Tue Mar 22 15:52:43 PDT 2016
22.03.2016 - 11:45 - arwooldridge at googlemail.com:
> Hi, try the start-up command files in the data folder of rtk2.4.3b8.
Thank you. I check and I have this commands:
ubx_m8t_bds_raw_1hz.cmd
ubx_m8t_bds_raw_5hz.cmd
ubx_m8t_glo_raw_1hz.cmd
ubx_m8t_glo_raw_5hz.cmd
ubx_raw_1hz.cmd
ubx_raw_5hz.cmd
ubx_raw_10hz.cmd
What I must use for gps+glo? I have 1s correction from station, so it is
better to use 1hz or 5hz (or 10)?
Thank you
Damjan
> if they don't work, set up m8t in ucenter and save to flash.
> in options/ position/base position, set to rtcm antenna position.
> Regards Anthony
> Sent from my HTC
> ----- Reply message -----
> From: "Damjan Gerl" <damjan at damjan.net>
> To: <foss-gps at lists.osgeo.org>
> Subject: [FOSS-GPS] uBlox NEO-M8T and RTKlib
> Date: Mon, Mar 21, 2016 21:27
> Hi to all!
> I'm new here, so I ask if there is someone that can help on configuring
> a M8T module (what string is needed?) to work with RTKlib? And how to
> configure RTKlib to deal with that module. Or maybe you can direct me to
> some webpages/guides where I can find some help?
> I have a Neo M8T module with fw 2.30 and try to use rtklib v2.4.3b8. I
> have a d-gps station 10 km away from my location and want to use the
> data from this station to correct the data from uBlox module (in
> real-time and/or post-process)...
> Thank you in advace
> Damjan G.
More information about the FOSS-GPS
