[FOSS-GPS] information
Francesco Mancino
mancinofrancesco85 at hotmail.it
Mon Oct 10 17:55:40 PDT 2016
David,
thanks for your suggestions. My main problem is the lack of a specific HW ( receiver and antenna ), so I've decided to operate in a Post Processing mode. Here, I have another problem : I've not RINEX files of local observations taken by a rover. So I'm thinking to use RINEX observation data of a network station like rover static data and correct them with NRTK-VRS technique. Please, give me a feedback about my idea.
Thanks in advance.
FM
Da: FOSS-GPS <foss-gps-bounces at lists.osgeo.org> per conto di David Kelley <DavidKelley at ITSware.net>
Inviato: mercoledì 21 settembre 2016 01.00
A: foss-gps at lists.osgeo.org
Oggetto: Re: [FOSS-GPS] information
Francesco Mancino:
You do not need to send NMEA from it, you probably need to send RTCM to it. You probably can not do classical RTK with it.
If you are planning to use a DGPS corrections (not RTK), then it is likely the GNSS chip itself will do the navigation filter for you (in other words it is not externally done with RTKLIB and RTKnavi). If that is your chosen path, seek for a local RTCM2.x data stream (local meaning <50km or so) and figure out how to send that data directly to you GNSS.
I am not familiar with the "Emtac BT GPS receiver" but a quick web search tells me that is uses the older SiRF Star II LP chip set and therefore it seems to use only WAAS/EGNOS corrections. You need to research that point first and foremost to be sure that it can accept DGPS from other sources. As far as I am aware you will not get code and carrier from it, so there is not means to do an RTK style navigation solution. RTKLIB can do a DGPS navigation solution, if you can get raw code from it.
Regards DC Kelley
On 9/18/2016 5:34 PM, Francesco Mancino wrote:
I'm using an Emtac BT GPS receiver to acquire gps signals but RTKNAVI does not support NMEA0183 format as Rover input stream. Please can you give me any suggestions to realize an input stream ( for a DGPS application ) without changing the receiver?
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20161011/d807a074/attachment.html>
More information about the FOSS-GPS
