[FOSS-GPS] IF raw data sampling
Burak a
aykenar.burak at gmail.com
Mon Mar 20 06:55:56 PDT 2017
Hello All,
I am new to the GPS and this community. I want to implement a GPS-SDR and
do the acquisition phase in FPGA. According to the my first glance I found
out SoftGNSS by Mr. Akos, MATLAB code.
In his implementation, he had 3-bit digital data fed through the processor
but not I-Q demodulated in the implementation of parallel code phase
acquisition algorithm. In his implementation, the input data is multiplied
by sinus signal to achieve I, cosine signal to achieve Q and then they
forwarded to the FFT block. However, there are a lot of COTS GPS front-end
ICs and they have 1/2 bit I and Q signals.
But for a GPS front-end I already have I and Q signals. So, what should I
do with those I and Q data? Should I multiply both of them with sine and
then feed through the FFT block? Does it make sense?
Thanks in advance,
*Mehmet Burak AYKENAR*
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20170320/c211fb80/attachment.html>
More information about the FOSS-GPS
