[FOSS-GPS] FOSS-GPS Digest, Vol 110, Issue 1
atanu santra bubunhhh at gmail.com
Wed Nov 7 09:56:13 PST 2018
You can use 'strsvr ' of rtklib program package.
On Wed, 7 Nov 2018 1:30 am , <foss-gps-request at lists.osgeo.org> wrote:
> Send FOSS-GPS mailing list submissions to
>         foss-gps at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
>         https://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
>         foss-gps-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
>    1. Re: Online NTRIP caster (dskumher)
>    2. Re: Online NTRIP caster (ivial98)
>    3. Re: Online NTRIP caster (DavidKelley at ITSware.net)
> Message: 1
> Date: Mon, 5 Nov 2018 23:13:52 -0700 (MST)
> From: dskumher <dskumher1968 at gmail.com>
> To: foss-gps at lists.osgeo.org
> Subject: Re: [FOSS-GPS] Online NTRIP caster
> Message-ID: <1541484832297-0.post at n2.nabble.com>
> Content-Type: text/plain; charset=us-ascii
> I have a query regarding using youcors caster.My GNSS receiver acting as
> base
> does not have software to configure it as a NTRIP server.How can I
> send/upload the base serial correction stream to the youcors caster ? The
> youcors software itself does not have any provision to connect to NTRIP
> server serial stream, as I think.Can anybody please advise ?
> Sent from:
> http://open-source-gps-related-discussion-and-support.1099874.n2.nabble.com/
> Message: 2
> Date: Tue, 6 Nov 2018 00:02:41 -0700 (MST)
> From: ivial98 <ilyavialkov at gmail.com>
> Message-ID: <1541487761063-0.post at n2.nabble.com>
> Hi
> The only way is to use external NTRIP server for now. You can connect your
> receiver with PC via serial port and send data to YouCORS by RTKLIB or
> GNSSSurfer.
> YouCORS 2.0 will be released in early 2019 and it will have the support of
> direct incoming TCP connections.
> Ilya
> Sent from:
> Message: 3
> Date: Tue, 6 Nov 2018 08:19:55 -0700 (MST)
> From: "DavidKelley at ITSware.net" <DavidKelley at ITSware.net>
> Message-ID: <1541517595625-0.post at n2.nabble.com>
> Sounds like your older GNSS has a serial port but no NTRIP Server built in.
> Do you have a spare PC you can use? As Ilya states, use one of the free
> tools such as RTKLIB on a PC for this. (A free copy of SNIP NTRIP Caster is
> very good for this as well, there are hundreds of professional Caster
> networks that use secondary copies of SNIP to connect such older
> machines).
> If you will use the RTKLIB (in fact the *StrSrv* tool), suggest you
> download
> the newest 'b30' release from RTLexplorer,
> http://rtkexplorer.com/downloads/rtklib-code/  He has implemented an
> improvement that makes sure the GNSS is in fact sending data before
> connections occur.  That is a minor bug that RTKLIB code has had for a long
> time.  You can find connection setup details on the RTKLIB site, the SNIP
> /KB site, or in the manual to connect to any NTRIP Caster you need.
> Sent from:
> Subject: Digest Footer
> FOSS-GPS at lists.osgeo.org
> End of FOSS-GPS Digest, Vol 110, Issue 1
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20181107/442b4134/attachment.html>
More information about the FOSS-GPS mailing list
