[FOSS-GPS] FOSS-GPS Digest, Vol 111, Issue 5
atanu santra
bubunhhh at gmail.com
Fri Mar 15 08:18:23 PDT 2019
Yes, you can obtain cm level of accuracy using static ppp.
Use final orbit and clk files from IGS data centers and observation,
navigation files of your base receiver.
On Fri, Mar 15, 2019 at 2:07 PM <foss-gps-request at lists.osgeo.org> wrote:
> Send FOSS-GPS mailing list submissions to
> foss-gps at lists.osgeo.org
> To subscribe or unsubscribe via the World Wide Web, visit
> https://lists.osgeo.org/mailman/listinfo/foss-gps
> or, via email, send a message with subject or body 'help' to
> You can reach the person managing the list at
> foss-gps-owner at lists.osgeo.org
> When replying, please edit your Subject line so it is more specific
> than "Re: Contents of FOSS-GPS digest..."
> Today's Topics:
> 1. Re: FOSS-GPS Digest, Vol 111, Issue 3 (Иван Рыкин)
> Message: 1
> Date: Fri, 15 Mar 2019 11:37:40 +0300
> From: Иван Рыкин <vanya-t-mac at mail.ru>
> To: Open Source GPS-related discussion and support
> <foss-gps at lists.osgeo.org>
> Subject: Re: [FOSS-GPS] FOSS-GPS Digest, Vol 111, Issue 3
> Message-ID: <1552639060.787776180 at f512.i.mail.ru>
> Content-Type: text/plain; charset="utf-8"
> If I want to get the precise coordinates of base up to 10 sm accuracy, I
> need to use only ppp mode?
> >Четверг, 14 марта 2019, 22:23 +03:00 от atanu santra <bubunhhh at gmail.com
> >1. If you want to get a fix coordinate of your base you can use 'OPUS' or
> 'AUSPOS' online services.
> >2. If you get position of your base using differential or rtk method use
> nearest igs station observation file and associate navigation file.
> >You may also use broadcast ehemerides or final ephemeris for more precise
> solution.
> >3. Or you may use static ppp using final ephemeris, clk and antenna files
> etc.
> >>Today's Topics:
> >> 1. Rtklib post process (atanu santra)
> >>Message: 1
> >>Date: Fri, 15 Mar 2019 00:16:19 +0530
> >>From: atanu santra < bubunhhh at gmail.com >
> >>To: foss-gps at lists.osgeo.org
> >>Subject: [FOSS-GPS] Rtklib post process
> >>Message-ID:
> CADLYUbiAmg0NtTx+vYP58Tgpwxvo_zFd7KXOd30-RMPO8g8XZw at mail.gmail.com >
> >>Dear Colleague,
> >>1. a) If you want to do differential GNSS, please do the following :
> >> run the rtkpost > enter the .o and .n file of Base and only .o file of
> >>rover as input> select dgnss in processing option> execute.
> >>b) If the data of Base is of same day as rover and of 24 hrs then you
> will
> >>get the dgnss solution, no issue will be arisen.
> >>c) yes you can use final ephemeris of constellations but the observation
> >>files should be of same day.
> >>2. If you want to do ppp for single receiver then you need final
> >>ehemerides, clk file, erp, antx file etc.
> >>Best regards
> >>> Today's Topics:
> >>> 1. RTK_LIB_postprocessing (Иван Рыкин)
> >>> Message: 1
> >>> Date: Wed, 13 Mar 2019 15:55:53 +0300
> >>> From: Иван Рыкин < vanya-t-mac at mail.ru >
> >>> Subject: [FOSS-GPS] RTK_LIB_postprocessing
> >>> Message-ID: < 1552481753.530901690 at f495.i.mail.ru >
> >>> Hi,
> >>> I am a student of SPBU. I am learning RTKlib
> >>> how to equalize (postprocess) gnss base (2 hours observation) using
> >>> reference station (24 hours observation). Rinex data available GPS
> >>> and GLONASS.
> >>> There are some questions:
> >>> 1. What kind of data I need use for reference station, only
> >>> navigation (.g and .n) and observation (.o or .d) ?
> >>> 2 - What kind of data I need use for gnss base, only
> navigation
> >>> (.g and .n) or observation (.o or .d) files too
> >>> 3. What kind of data I need use for reference station
> >>> and gnss base, only observation (.o or .d) files and as a navigation
> files
> >>> only final ephemerides
> >>> 4 - if we use final ephemerides we must use ppp-static or static?
> >>> 5 - why is the difference between output data if we use , is it
> normal ?
> >>> 6 - if my base is 10Hz, it means that every data must be 10Hz for
> getting
> >>> the precise XYZ? Data from the Reference station and for example UAV
> must
> >>> be the same 10Hz?
> >>> thank you for answering these questions.
> >>> -------------- next part --------------
> >>> An HTML attachment was scrubbed...
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment.html
> >>> A non-text attachment was scrubbed...
> >>> Type: image/png
> >>> Desc: not available
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment.png
> >>> Type: image/png
> >>> Desc: not available
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0001.png
> >>> Type: image/png
> >>> Desc: not available
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0002.png
> >>> Type: image/png
> >>> Desc: not available
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0003.png
> >>> Type: image/png
> >>> Desc: not available
> >>> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190313/e04b079b/attachment-0004.png
> >>> Subject: Digest Footer
> >>> _______________________________________________
> >>> FOSS-GPS at lists.osgeo.org
> >>> End of FOSS-GPS Digest, Vol 111, Issue 1
> >>URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190315/316ba191/attachment-0001.html
> >>End of FOSS-GPS Digest, Vol 111, Issue 3
> >This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> >Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your
> subscription
> >For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
> URL: <
> http://lists.osgeo.org/pipermail/foss-gps/attachments/20190315/7e44ea33/attachment.html
> End of FOSS-GPS Digest, Vol 111, Issue 5
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20190315/c15b3298/attachment.html>
More information about the FOSS-GPS
