[FOSS-GPS] RTKlib help pls
drwho
drwho at infidigm.net
Mon Nov 18 16:17:29 PST 2019
Hi Bud,
I had to set the execution permission on both rtkstart.sh and rtkshut.sh
If you cd to RTKLIB/app/rtkrcv/gcc
then type ls -l *.sh
-rwxr--r-- 1 drwho drwho 61 Nov 12 13:51 rtkshut.sh
-rwxr--r-- 1 drwho drwho 58 Nov 12 13:51 rtkstart.sh
(these are mine after the execution flag has been set)
To set the execution flag, type
chmod u+x rtkshut.sh
and then again for rtkshut.sh
I also recommend you use the 2.4.3 branch of rtklib as a run into a
couple of bugs in 2.4.2.
git checkout rtklib_2.4.3
Please let me know if you are able to get a solution with any mode other
than single. When I try kinematic, I get the error no
double-differenced residual. I also don't get any valid Glonass
satellites. no ephemeris is found for them.
Jon
On 2019-11-18 6:16 p.m., Bud Asterisk wrote:
> Hi folks,
> I have been playing with the RTKlib packages for a few months now.
> Current setup is 2 CSG M8T receivers. Each connected to a Raspberry Pi
> Zero W. The pi run str2str that I compiled on the pi. These connect to
> RTKNAVI on my laptop without issue, all over wifi. Have 2 cell phones
> ready to handle the data connection so I can take it out into the
> wild! No problems at this point.
> I want to use RTKRCV which I have compiled on a linux machine. Am able
> to make config changes but the tool is telling me to restart after I
> make a config change. Here is what I am doing:
> rtkrcv> help rtkrcv ver.2.4.2start : start rtk serverstop : stop rtk
> serverrestart : restart rtk seversolution [cycle] : show
> solutionstatus [cycle] : show rtk statussatellite [-n] [cycle]: show
> satellite statusobserv [-n] [cycle] : show observation datanavidata
> [cycle] : show navigation datastream [cycle] : show stream statuserror
> : show error/warning messagesoption [opt] : show option(s)set opt
> [val] : set optionload [file] : load options from filesave [file] :
> save options to filelog [file|off] : start/stop log to filehelp|?
> [path] : print helpexit : exit and logout consoleshutdown : shutdown
> rtk server!command [arg...]: execute command in shellrtkrcv> restart
> sh: 1: ./rtkstart.sh: not foundcommand exec error: ./rtkstart.sh
> (32512)rtk server start errorrtkrcv> start sh: 1: ./rtkstart.sh: not
> foundcommand exec error: ./rtkstart.sh (32512)rtk server start
> errorrtkrcv> stop rtk server stoprtkrcv> start sh: 1: ./rtkstart.sh:
> not foundcommand exec error: ./rtkstart.sh (32512)rtk server start
> errorrtkrcv> It cant seem to find the start or restart commands....any
> wisdom? I only did the compile of rtkrcv and no others.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191118/014824f8/attachment.html>
More information about the FOSS-GPS
