[FOSS-GPS] RTKlib help pls
drwho
drwho at infidigm.net
Tue Nov 19 18:07:07 PST 2019
I let rtkrcv run for a while. I briefly was in fixed mode with 8
satellites. Tomorrow night I'll head to the county where I usually get
10 satellites.
On 2019-11-19 8:59 p.m., drwho wrote:
> My setup is two OemStar receivers. One is connected via serial port,
> the other is through a relay server and a 3g modem. I removed the IP
> address of my server from the file and replaced it with ip_of_server.
> The OemStars only support gps + glonass (pos1-navsys=5). I think
> these are the only changes from the stock conf file.
> On 2019-11-19 8:45 p.m., Bud Asterisk wrote:
>> I can take mine outside tomorrow if the weather holds and see how
>> long it takes. IIRC it was 4 birds in the sky and took a minute. I
>> should have taken better notes on my trials and tribulations to get
>> it working since I am still learning lots. I know at some point I had
>> to set an approx start location for the base station otherwise it
>> would never get to FIX from FLOAT. Even though conceptually it
>> should. My $0.02 is to use RTKNAVI first till you can get a FIX as it
>> is much easier to see what is going on. And then take your working
>> conf and use rtkrcv.
>> Oh also I used 2 pots from the kitchen as ground planes under the
>> antenna. Need to get to WMT for something cheap this weekend.
>> Can you post your *.conf file you used?
>> On Tue, Nov 19, 2019 at 8:38 PM drwho <drwho at infidigm.net
>> <mailto:drwho at infidigm.net>> wrote:
>> I gave rtkrcv a try from https://github.com/rtklibexplorer/RTKLIB
>> demo5 branch and voila, I get a float solution now! No more no
>> double-differenced residual after 7 weeks of struggling! Thank
>> you so much for pointing out rtklibexplorer. Now onto getting a
>> fixed solution. Any idea about how many valid satellites are
>> required for a fixed solution? I'm getting 7 right now in the
>> city, overcast....
>> # of satellites rover : 11
>> # of satellites base : 10
>> # of valid satellites : 7
>> 2019/11/20 01:37:22.00 G07 1 23543275.469 0.000
>> 123720746.574 0.000 2914.1 0.0 37 064 0
>> 2019/11/20 01:37:22.00 G08 1 22171781.133 0.000
>> 116513507.383 0.000 3244.9 0.0 45 0 0 0
>> 2019/11/20 01:37:22.00 G09 1 21126139.602 0.000
>> 111018592.926 0.000 448.3 0.0 38 064 0
>> 2019/11/20 01:37:22.00 G16 1 20963946.320 0.000
>> 110166281.117 0.000 -2187.3 0.0 46 0 0 0
>> 2019/11/20 01:37:22.00 G21 1 25155113.438 0.000
>> 132191029.602 0.000 141.0 0.0 31 064 0
>> 2019/11/20 01:37:22.00 G23 1 20989052.875 0.000
>> 110298206.492 0.000 -1256.4 0.0 35 0 0 0
>> 2019/11/20 01:37:22.00 G26 1 22904042.680 0.000
>> 120361516.371 0.000 -2944.8 0.0 46 064 0
>> 2019/11/20 01:37:22.00 G27 1 20758214.352 0.000
>> 109085174.746 0.000 1349.3 0.0 47 064 0
>> 2019/11/20 01:37:22.00 R14 1 20121058.617 0.000
>> 107256576.695 0.000 -1320.0 0.0 44 0 0 0
>> 2019/11/20 01:37:22.00 R15 1 20369659.602 0.000
>> 108849285.676 0.000 1616.6 0.0 38 0 0 0
>> 2019/11/20 01:37:22.00 R23 1 21825182.789 0.000
>> 116750015.395 0.000 -1661.8 0.0 46 0 0 0
>> 2019/11/20 01:37:22.00 G08 2 22171770.695 0.000
>> 116513422.930 0.000 3245.4 0.0 30 064 0
>> 2019/11/20 01:37:22.00 G09 2 21126127.297 0.000
>> 111018526.246 0.000 448.2 0.0 39 0 0 0
>> 2019/11/20 01:37:22.00 G16 2 20963933.781 0.000
>> 110166180.230 0.000 -2187.4 0.0 47 0 0 0
>> 2019/11/20 01:37:22.00 G21 2 25155108.125 0.000
>> 132190973.727 0.000 140.0 0.0 42 0 0 0
>> 2019/11/20 01:37:22.00 G23 2 20989045.883 0.000
>> 110298167.875 0.000 -1256.6 0.0 36 0 0 0
>> 2019/11/20 01:37:22.00 G26 2 22904033.281 0.000
>> 120361469.652 0.000 -2944.8 0.0 44 064 0
>> 2019/11/20 01:37:22.00 G27 2 20758202.812 0.000
>> 109085095.344 0.000 1349.2 0.0 48 0 0 0
>> 2019/11/20 01:37:22.00 R05 2 20871721.062 0.000
>> 111571326.961 0.000 -1165.9 0.0 33 0 0 0
>> 2019/11/20 01:37:22.00 R14 2 20121049.281 0.000
>> 107256486.191 0.000 -1319.6 0.0 47 064 0
>> 2019/11/20 01:37:22.00 R24 2 20960371.930 0.000
>> 112084524.137 0.000 1858.1 0.0 40 064 0
>> Jon
>> On 2019-11-19 5:13 p.m., Bud Asterisk wrote:
>>> OK gang.....good news!
>>> I used the latest source for rtkrcv from rtklibexplorer's repo
>>> and compiled it on my google cloud instance. Also used my conf
>>> file I had working in rtknavi since it had been tweaked for me.
>>> Here is my setup. 2 CSG M8T boards, each connected to a
>>> Raspberry Pi Zero W. They have str2str compiled and streaming
>>> the data to the google VM of rtkrcv. Attached is a screencapture
>>> of 3 terminals, 2 of the PI and one of the rtksrv output stream
>>> of the rover location. Sorry I blacked out the IP and location
>>> info for security reasons. Right now the antennas are in my
>>> window facing south so it is only a float solution that comes
>>> and and goes. Not sure it attachments will make it through the
>>> list....
>>> Bud
>>> Oh here is a cut and paste of the output stream. IP and location
>>> info has been fudged
>>> 2019/11/19 22:12:40.000 21.134425586 -42.963204887 452.7045
>>> 2 4 0.2230 0.1686 0.5208 -0.1212 -0.1373 -0.1447
>>> 1.00 0.0
>>> Right after the elevation of 452 you can see the "2" as solution
>>> type which is enumated as float.
>>> On Tue, Nov 19, 2019 at 9:13 AM drwho <drwho at infidigm.net
>>> On 2019-11-19 8:35 a.m., Bud Asterisk wrote:
>>> > I will try the CUI code from here:
>>> > Is this what you are using as well? His binaries on
>>> windows work for
>>> > me to get FIX.
>>> The rtkrcv I have been using is from
>>> https://github.com/tomojitakasu/RTKLIB.git
>>> branch = 2.4.3b33
>>> http://www.rtklib.com/ points to this git repo.
>>> I'll try the rtkrcv from rtklibexplorer tonight
>>> Jon
>>> This message is sent to you from FOSS-GPS at lists.osgeo.org
>>> <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>>> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to
>>> manage your subscription
>>> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
>>> This message is sent to you fromFOSS-GPS at lists.osgeo.org <mailto:FOSS-GPS at lists.osgeo.org> mailing list.
>>> Visithttps://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
>>> For more information, checkhttp://wiki.osgeo.org/wiki/FOSS-GPS
>> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage
>> your subscription
>> This message is sent to you fromFOSS-GPS at lists.osgeo.org mailing list.
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
URL: <http://lists.osgeo.org/pipermail/foss-gps/attachments/20191119/f2a565af/attachment-0001.html>
% (x/y/z-ecef=WGS84,Q=1:fix,2:float,3:sbas,4:dgps,5:single,6:ppp,ns=# of satellites)
% GPST x-ecef(m) y-ecef(m) z-ecef(m) Q ns sdx(m) sdy(m) sdz(m) sdxy(m) sdyz(m) sdzx(m) age(s) ratio vx(m/s) vy(m/s) vz(m/s) sdvx sdvy sdvz sdvxy sdvyz sdvzx
2080 265489.000 888518.9970 -4517274.8318 4399526.3893 2 4 9.5991 5.4365 5.5752 -4.9380 -4.3078 -3.4396 0.00 0.0 -0.03125 0.02896 -0.03250 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265490.000 888519.0337 -4517274.8392 4399526.3799 2 4 6.9974 3.9808 4.1045 -3.5339 -3.1835 -2.5657 0.00 0.0 0.00247 0.01129 0.02161 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265491.000 888519.1823 -4517274.8944 4399526.4464 2 4 5.7757 3.2906 3.3998 -2.8961 -2.6402 -2.1361 0.00 0.0 0.02032 -0.02668 0.04430 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265492.000 888524.0074 -4517276.2255 4399525.8857 2 5 1.9567 2.5745 2.9008 -0.6857 -2.4664 -0.7997 0.00 0.0 0.01380 0.01023 -0.00092 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265493.000 888525.2900 -4517276.6003 4399525.7375 2 5 1.5018 2.2977 2.6041 -0.3533 -2.2225 -0.6564 0.00 0.0 0.00972 0.00912 0.03333 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265494.000 888525.5566 -4517276.6775 4399525.7401 2 5 1.2665 2.0982 2.3833 -0.1321 -2.0373 -0.5757 0.00 0.0 0.00143 0.12979 -0.18554 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265495.000 888527.2206 -4517277.3409 4399526.5069 2 5 2.0298 2.0854 2.4888 -1.1216 -2.1100 1.3084 0.00 0.0 -0.00590 0.06262 -0.07115 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265496.000 888527.4187 -4517277.4485 4399526.7407 2 4 1.5388 1.9003 2.3065 -0.7660 -1.9192 0.9324 0.00 0.0 0.00735 0.00599 0.01812 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265497.000 888527.7027 -4517277.5890 4399527.0017 2 4 1.2907 1.7744 2.1902 -0.5822 -1.7946 0.7420 0.00 0.0 -0.00272 0.04760 -0.02822 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265498.000 888527.8001 -4517277.6526 4399527.1551 2 4 1.1343 1.6756 2.1011 -0.4655 -1.6987 0.6234 0.00 0.0 -0.00514 0.02344 -0.06458 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265499.000 888527.8133 -4517277.6427 4399527.2300 2 6 0.9958 1.5916 2.0268 -0.4083 -1.6185 0.5545 0.00 0.0 -0.00877 -0.03133 0.04507 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265500.000 888527.8163 -4517277.6418 4399527.2937 2 6 0.9029 1.5199 1.9629 -0.3637 -1.5502 0.5039 0.00 0.0 -0.01217 -0.05444 0.05807 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265501.000 888527.8620 -4517277.6637 4399527.3884 2 6 0.8319 1.4574 1.9068 -0.3302 -1.4907 0.4658 0.00 0.0 -0.02926 -0.02343 -0.00955 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265502.000 888527.8633 -4517277.6701 4399527.4457 2 6 0.7755 1.4022 1.8567 -0.3041 -1.4382 0.4360 0.00 0.0 -0.03979 -0.04454 0.06662 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265503.000 888527.8812 -4517277.6892 4399527.5145 2 6 0.7292 1.3529 1.8115 -0.2830 -1.3913 0.4119 0.00 0.0 -0.06168 -0.04625 0.09832 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265504.000 888527.9032 -4517277.7215 4399527.6073 2 6 0.6903 1.3086 1.7703 -0.2657 -1.3490 0.3919 0.00 0.0 0.01623 0.04063 -0.04894 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265505.000 888527.8242 -4517277.5360 4399526.7841 2 7 0.6553 1.2652 1.6805 -0.2424 -1.2961 0.3469 0.00 0.0 -0.01275 0.00341 -0.03580 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265506.000 888527.8364 -4517277.5728 4399526.8852 2 7 0.6254 1.2262 1.6083 -0.2240 -1.2506 0.3132 0.00 0.0 -0.00791 -0.00175 0.05793 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265507.000 888527.8160 -4517277.4992 4399526.5240 2 7 0.5993 1.1907 1.5433 -0.2084 -1.2097 0.2836 0.00 0.0 -0.02037 0.01593 -0.04311 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265508.000 888527.8554 -4517277.5348 4399526.5867 2 7 0.5763 1.1583 1.4866 -0.1952 -1.1730 0.2591 0.00 0.0 -0.00351 0.01896 -0.00625 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265509.000 888527.8827 -4517277.5522 4399526.5787 2 7 0.5558 1.1284 1.4375 -0.1842 -1.1398 0.2392 0.00 0.0 0.01634 -0.04238 0.13706 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265510.000 888527.9104 -4517277.5709 4399526.5531 2 7 0.5375 1.1008 1.3932 -0.1746 -1.1095 0.2221 0.00 0.0 -0.00542 0.01658 -0.03616 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265511.000 888527.9288 -4517277.5730 4399526.4503 2 7 0.5208 1.0750 1.3529 -0.1663 -1.0815 0.2073 0.00 0.0 -0.03506 -0.04343 -0.00140 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265512.000 888527.9510 -4517277.5854 4399526.4170 2 7 0.5056 1.0510 1.3160 -0.1590 -1.0555 0.1943 0.00 0.0 -0.01030 -0.01072 -0.03369 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265513.000 888527.9927 -4517277.6195 4399526.4466 2 7 0.4917 1.0285 1.2820 -0.1526 -1.0313 0.1829 0.00 0.0 0.01873 0.03333 0.00233 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265514.000 888528.0155 -4517277.6308 4399526.4027 2 7 0.4789 1.0073 1.2504 -0.1469 -1.0087 0.1728 0.00 0.0 0.02936 0.09062 -0.14770 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265515.000 888528.0379 -4517277.6404 4399526.3636 2 7 0.4670 0.9873 1.2211 -0.1419 -0.9874 0.1639 0.00 0.0 0.01122 0.07685 -0.07960 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265516.000 888528.0722 -4517277.6446 4399526.3240 2 7 0.4560 0.9683 1.1936 -0.1374 -0.9674 0.1559 0.00 0.0 0.03340 0.06868 -0.08174 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265517.000 888528.1004 -4517277.6762 4399526.3300 2 7 0.4457 0.9504 1.1678 -0.1334 -0.9484 0.1489 0.00 0.0 0.01056 -0.08106 0.08851 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265518.000 888528.1232 -4517277.6723 4399526.2793 2 7 0.4361 0.9333 1.1435 -0.1299 -0.9304 0.1427 0.00 0.0 -0.02303 -0.01180 0.02010 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265519.000 888528.1461 -4517277.7182 4399526.3302 2 7 0.4271 0.9170 1.1205 -0.1268 -0.9133 0.1371 0.00 0.0 -0.01453 0.05413 -0.02590 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265520.000 888528.1739 -4517277.7155 4399526.2624 2 7 0.4186 0.9015 1.0988 -0.1240 -0.8970 0.1322 0.00 0.0 -0.02531 0.01767 -0.00647 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265521.000 888528.2109 -4517277.7627 4399526.3465 2 6 0.4107 0.8879 1.0893 -0.1221 -0.8852 0.1323 0.00 0.0 -0.00126 -0.03843 0.04445 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265522.000 888528.2323 -4517277.7781 4399526.3707 2 6 0.4033 0.8748 1.0788 -0.1203 -0.8733 0.1325 0.00 0.0 0.00363 -0.01211 -0.01795 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265523.000 888528.2510 -4517277.7978 4399526.4274 2 7 0.3961 0.8618 1.0599 -0.1174 -0.8597 0.1272 0.00 0.0 -0.00750 0.03745 -0.04767 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265524.000 888528.2732 -4517277.8219 4399526.4514 2 7 0.3894 0.8493 1.0422 -0.1148 -0.8467 0.1225 0.00 0.0 0.02133 0.01156 0.00734 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265525.000 888528.2980 -4517277.8409 4399526.4422 2 7 0.3829 0.8374 1.0255 -0.1123 -0.8345 0.1181 0.00 0.0 -0.02780 -0.00735 -0.02338 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265526.000 888528.2923 -4517277.8330 4399526.3974 2 6 0.3813 0.8265 1.0096 -0.1179 -0.8229 0.1169 0.00 0.0 0.01189 -0.04080 0.04690 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265527.000 888528.3034 -4517277.8544 4399526.4330 2 5 0.3800 0.8166 1.0023 -0.1252 -0.8141 0.1255 0.00 0.0 0.00081 -0.00178 0.00075 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265528.000 888528.3093 -4517277.8619 4399526.4377 2 5 0.3788 0.8071 0.9947 -0.1315 -0.8054 0.1324 0.00 0.0 0.02019 -0.00167 -0.00140 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265529.000 888528.3083 -4517277.8741 4399526.4472 2 5 0.3775 0.7979 0.9874 -0.1372 -0.7971 0.1386 0.00 0.0 0.00875 -0.01735 -0.01403 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265530.000 888528.3048 -4517277.8661 4399526.3901 2 6 0.3758 0.7886 0.9730 -0.1402 -0.7868 0.1357 0.00 0.0 -0.02498 -0.03746 0.06773 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265531.000 888528.2918 -4517277.8595 4399526.3689 2 6 0.3741 0.7795 0.9594 -0.1430 -0.7770 0.1332 0.00 0.0 -0.02166 0.01203 -0.01132 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265532.000 888528.3089 -4517277.8803 4399526.4080 2 6 0.3724 0.7707 0.9462 -0.1454 -0.7674 0.1304 0.00 0.0 0.01451 -0.01566 0.04920 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265533.000 888528.3222 -4517277.8977 4399526.4821 2 6 0.3708 0.7623 0.9337 -0.1478 -0.7582 0.1281 0.00 0.0 -0.01234 -0.03265 0.03176 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265534.000 888528.3283 -4517277.9208 4399526.5290 2 6 0.3692 0.7541 0.9216 -0.1500 -0.7494 0.1260 0.00 0.0 -0.01006 -0.08122 0.08668 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265535.000 888528.3454 -4517277.9401 4399526.5973 2 6 0.3676 0.7462 0.9101 -0.1521 -0.7408 0.1242 0.00 0.0 0.01739 -0.01486 0.00846 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265536.000 888528.3566 -4517277.9557 4399526.6225 2 6 0.3661 0.7385 0.8989 -0.1541 -0.7325 0.1225 0.00 0.0 -0.02964 0.02875 -0.02846 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265537.000 888528.3631 -4517277.9687 4399526.6385 2 6 0.3647 0.7311 0.8881 -0.1559 -0.7245 0.1210 0.00 0.0 -0.01600 -0.01771 -0.00065 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265538.000 888528.3670 -4517277.9743 4399526.6562 2 6 0.3632 0.7238 0.8777 -0.1577 -0.7167 0.1196 0.00 0.0 0.00148 0.00263 0.00435 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265539.000 888528.3835 -4517277.9891 4399526.6762 2 6 0.3618 0.7168 0.8676 -0.1593 -0.7091 0.1184 0.00 0.0 -0.01133 0.01322 -0.03290 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265540.000 888528.3870 -4517277.9894 4399526.6802 2 6 0.3604 0.7099 0.8578 -0.1609 -0.7017 0.1173 0.00 0.0 -0.01372 0.02332 -0.05412 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265541.000 888528.3975 -4517278.0187 4399526.7369 2 6 0.3591 0.7033 0.8483 -0.1624 -0.6945 0.1163 0.00 0.0 -0.00510 0.00555 0.03811 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265542.000 888528.4048 -4517278.0299 4399526.7585 2 6 0.3577 0.6968 0.8390 -0.1638 -0.6875 0.1155 0.00 0.0 0.00448 0.00856 0.04608 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265543.000 888528.4027 -4517278.0566 4399526.8042 2 6 0.3564 0.6905 0.8300 -0.1652 -0.6807 0.1148 0.00 0.0 -0.04380 -0.04313 0.03720 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265544.000 888528.4163 -4517278.0658 4399526.8168 2 6 0.3551 0.6843 0.8212 -0.1665 -0.6740 0.1142 0.00 0.0 0.01139 0.06444 -0.08652 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265545.000 888528.4217 -4517278.0795 4399526.8340 2 6 0.3538 0.6782 0.8126 -0.1677 -0.6675 0.1137 0.00 0.0 -0.00924 -0.05884 0.00523 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265546.000 888528.4294 -4517278.0985 4399526.8610 2 6 0.3525 0.6723 0.8042 -0.1689 -0.6611 0.1133 0.00 0.0 -0.00398 0.01593 -0.02074 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265547.000 888528.4378 -4517278.1190 4399526.8852 2 6 0.3513 0.6666 0.7961 -0.1701 -0.6549 0.1130 0.00 0.0 0.00994 0.00857 -0.02284 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265548.000 888528.4516 -4517278.1559 4399526.9709 2 6 0.3501 0.6609 0.7880 -0.1712 -0.6487 0.1128 0.00 0.0 -0.01527 0.00397 0.07570 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265549.000 888528.4611 -4517278.1821 4399527.0123 2 6 0.3488 0.6554 0.7802 -0.1722 -0.6427 0.1127 0.00 0.0 -0.00400 0.07321 -0.03865 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265550.000 888528.4737 -4517278.2187 4399527.0920 2 6 0.3476 0.6500 0.7725 -0.1733 -0.6368 0.1126 0.00 0.0 0.00088 0.03114 -0.02758 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265551.000 888528.4832 -4517278.2623 4399527.1778 2 6 0.3465 0.6447 0.7650 -0.1743 -0.6310 0.1127 0.00 0.0 0.00070 0.04704 -0.04478 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265552.000 888528.4986 -4517278.3098 4399527.2808 2 6 0.3453 0.6395 0.7576 -0.1752 -0.6253 0.1129 0.00 0.0 -0.00037 -0.00056 -0.00451 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265553.000 888528.5074 -4517278.3578 4399527.3691 2 6 0.3441 0.6344 0.7503 -0.1762 -0.6198 0.1131 0.00 0.0 0.03950 -0.02317 0.02922 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265554.000 888528.5178 -4517278.4022 4399527.4567 2 6 0.3430 0.6294 0.7431 -0.1771 -0.6143 0.1134 0.00 0.0 -0.01621 -0.04424 0.08804 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265555.000 888528.5573 -4517278.4679 4399527.5902 2 7 0.3411 0.6243 0.7355 -0.1772 -0.6086 0.1107 0.00 0.0 0.00049 -0.04571 0.02298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265556.000 888528.5958 -4517278.5233 4399527.7008 2 7 0.3394 0.6194 0.7281 -0.1774 -0.6030 0.1088 0.00 0.0 0.01405 0.00996 0.02250 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265557.000 888528.6274 -4517278.5971 4399527.8721 2 7 0.3377 0.6145 0.7208 -0.1776 -0.5975 0.1071 0.00 0.0 0.00786 0.07469 -0.10796 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265558.000 888528.6354 -4517278.6544 4399527.9686 2 6 0.3367 0.6099 0.7142 -0.1787 -0.5924 0.1083 0.00 0.0 -0.00782 -0.03098 0.06715 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265559.000 888528.6497 -4517278.6887 4399528.0314 2 6 0.3357 0.6053 0.7077 -0.1795 -0.5873 0.1091 0.00 0.0 0.01653 0.02665 -0.02298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265560.000 888528.6537 -4517278.7264 4399528.1007 2 6 0.3346 0.6008 0.7012 -0.1804 -0.5823 0.1100 0.00 0.0 -0.01294 -0.03518 0.02506 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265561.000 888528.6576 -4517278.7534 4399528.1491 2 6 0.3335 0.5964 0.6949 -0.1812 -0.5774 0.1109 0.00 0.0 -0.00468 0.00977 -0.03199 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265562.000 888528.6729 -4517278.8001 4399528.2380 2 6 0.3325 0.5921 0.6886 -0.1820 -0.5726 0.1119 0.00 0.0 0.01190 0.00423 -0.02425 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265563.000 888528.6694 -4517278.7979 4399528.2368 2 6 0.3314 0.5889 0.6865 -0.1829 -0.5702 0.1134 0.00 0.0 0.01125 -0.07546 0.11266 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265564.000 888528.6907 -4517278.8220 4399528.2546 2 5 0.3307 0.5855 0.6840 -0.1836 -0.5672 0.1155 0.00 0.0 0.02224 0.04825 -0.04196 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265565.000 888528.6841 -4517278.8201 4399528.2319 2 6 0.3297 0.5819 0.6795 -0.1838 -0.5636 0.1149 0.00 0.0 -0.01631 -0.05674 0.05816 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265566.000 888528.6865 -4517278.8254 4399528.2029 2 6 0.3287 0.5784 0.6746 -0.1838 -0.5599 0.1138 0.00 0.0 -0.00626 0.03269 -0.01954 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265567.000 888528.7011 -4517278.8431 4399528.2542 2 6 0.3278 0.5750 0.6707 -0.1841 -0.5566 0.1140 0.00 0.0 0.00365 0.02056 -0.00910 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265568.000 888528.7163 -4517278.8625 4399528.2712 2 6 0.3269 0.5717 0.6664 -0.1843 -0.5532 0.1135 0.00 0.0 -0.00463 -0.01165 0.01122 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265569.000 888528.7138 -4517278.8635 4399528.2451 2 6 0.3260 0.5683 0.6618 -0.1843 -0.5497 0.1124 0.00 0.0 0.01384 0.01527 -0.03819 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265570.000 888528.7266 -4517278.8772 4399528.2308 2 6 0.3250 0.5650 0.6576 -0.1843 -0.5463 0.1117 0.00 0.0 0.00065 0.03467 -0.02580 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265571.000 888528.7555 -4517278.8944 4399528.2601 2 8 0.3201 0.5610 0.6530 -0.1803 -0.5428 0.1088 0.00 0.0 0.05680 -0.10835 0.13827 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265572.000 888528.7440 -4517278.8879 4399528.2729 2 8 0.3154 0.5572 0.6485 -0.1766 -0.5393 0.1061 0.00 0.0 -0.01239 -0.01902 -0.00499 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265573.000 888528.7627 -4517278.9266 4399528.3359 2 9 0.3095 0.5523 0.6423 -0.1760 -0.5343 0.1102 0.00 0.0 0.00418 -0.02846 0.05356 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265574.000 888528.8068 -4517278.9218 4399528.3325 2 9 0.3042 0.5476 0.6364 -0.1757 -0.5294 0.1133 0.00 0.0 0.01453 0.01183 0.00759 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265575.000 888528.8878 -4517278.8690 4399528.2836 2 8 0.2994 0.5433 0.6332 -0.1749 -0.5255 0.1138 0.00 0.0 -0.00109 -0.04225 0.07903 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265576.000 888528.9755 -4517278.8165 4399528.2395 2 8 0.2948 0.5391 0.6298 -0.1741 -0.5216 0.1143 0.00 0.0 0.00894 -0.02501 0.03736 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265577.000 888529.0714 -4517278.7325 4399528.1319 2 8 0.2904 0.5347 0.6259 -0.1734 -0.5174 0.1153 0.00 0.0 0.00066 -0.03096 0.02469 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265578.000 888529.0817 -4517278.7603 4399528.1654 2 7 0.2873 0.5312 0.6229 -0.1707 -0.5141 0.1126 0.00 0.0 -0.01205 0.02193 -0.04377 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265579.000 888529.0946 -4517278.7898 4399528.2079 2 7 0.2843 0.5276 0.6198 -0.1680 -0.5108 0.1099 0.00 3.6 -0.00473 -0.00126 -0.00146 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265580.000 888529.1160 -4517278.8124 4399528.2271 2 7 0.2814 0.5241 0.6167 -0.1654 -0.5074 0.1073 0.00 2.2 -0.01215 0.06438 -0.01884 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265581.000 888529.1316 -4517278.8329 4399528.2437 2 7 0.2786 0.5205 0.6134 -0.1628 -0.5039 0.1046 0.00 1.5 -0.00056 -0.01182 -0.01003 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265582.000 888529.1485 -4517278.8783 4399528.3028 2 7 0.2758 0.5168 0.6099 -0.1603 -0.5003 0.1019 0.00 1.0 0.06805 -0.02284 0.02031 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265583.000 888529.1653 -4517278.9102 4399528.3322 2 7 0.2732 0.5132 0.6063 -0.1578 -0.4966 0.0992 0.00 1.4 -0.00123 0.09159 -0.10794 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265584.000 888529.1835 -4517278.9407 4399528.3603 2 7 0.2706 0.5094 0.6026 -0.1553 -0.4929 0.0965 0.00 1.8 -0.02740 0.03515 -0.06037 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265585.000 888529.1980 -4517278.9603 4399528.3686 2 6 0.2682 0.5063 0.6004 -0.1526 -0.4901 0.0927 0.00 1.6 0.00307 0.03014 -0.03956 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265586.000 888529.2039 -4517278.9825 4399528.3864 2 4 0.2665 0.5037 0.5997 -0.1510 -0.4883 0.0927 0.00 1.4 0.00452 0.00487 0.03272 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265587.000 888529.1998 -4517278.9971 4399528.3874 2 4 0.2647 0.5011 0.5981 -0.1491 -0.4863 0.0913 0.00 1.2 0.02269 -0.01004 -0.00327 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265588.000 888529.1982 -4517279.0088 4399528.3079 2 5 0.2630 0.4986 0.5951 -0.1472 -0.4840 0.0900 0.00 1.1 0.01893 -0.03504 0.03744 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265589.000 888529.2070 -4517279.0200 4399528.2712 2 5 0.2613 0.4960 0.5918 -0.1453 -0.4816 0.0884 0.00 1.4 0.01626 -0.05820 0.09315 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265590.000 888529.2054 -4517279.0300 4399528.2134 2 5 0.2596 0.4936 0.5893 -0.1436 -0.4795 0.0872 0.00 3.0 -0.00647 -0.02365 0.03206 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265591.000 888529.2026 -4517279.0445 4399528.2110 2 5 0.2580 0.4911 0.5864 -0.1418 -0.4773 0.0859 0.00 2.7 0.03053 -0.03905 0.07541 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265592.000 888529.1980 -4517279.0521 4399528.1787 2 5 0.2564 0.4887 0.5836 -0.1401 -0.4752 0.0847 0.00 2.3 0.02157 0.06989 -0.06158 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265593.000 888529.1933 -4517279.0715 4399528.1886 2 5 0.2548 0.4863 0.5805 -0.1384 -0.4730 0.0832 0.00 1.7 0.00286 -0.01934 0.03171 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265594.000 888529.1880 -4517279.0815 4399528.1800 2 4 0.2533 0.4840 0.5795 -0.1368 -0.4712 0.0822 0.00 1.8 -0.01025 -0.02305 0.03944 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265595.000 888529.1746 -4517279.0916 4399528.1762 2 4 0.2518 0.4818 0.5780 -0.1352 -0.4693 0.0811 0.00 1.4 -0.00072 -0.01121 -0.01337 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265596.000 888529.1683 -4517279.1030 4399528.1842 2 4 0.2503 0.4795 0.5766 -0.1337 -0.4675 0.0801 0.00 1.1 0.00344 -0.02416 0.04215 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265597.000 888529.1577 -4517279.1103 4399528.1761 2 4 0.2489 0.4773 0.5753 -0.1321 -0.4657 0.0791 0.00 1.1 0.01493 0.00583 -0.03085 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265598.000 888529.1464 -4517279.1269 4399528.1831 2 4 0.2475 0.4752 0.5739 -0.1307 -0.4639 0.0781 0.00 1.2 -0.00067 0.04663 -0.02964 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265599.000 888529.1266 -4517279.1326 4399528.1725 2 4 0.2461 0.4730 0.5725 -0.1292 -0.4622 0.0771 0.00 1.1 -0.02117 0.02334 -0.02827 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265600.000 888529.1261 -4517279.1480 4399528.1856 2 4 0.2447 0.4709 0.5712 -0.1278 -0.4605 0.0762 0.00 1.0 0.00036 -0.00121 -0.00780 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265601.000 888529.1051 -4517279.1544 4399528.1908 2 4 0.2434 0.4689 0.5699 -0.1264 -0.4588 0.0753 0.00 1.1 0.00514 -0.04132 0.08564 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265602.000 888529.0959 -4517279.1597 4399528.1757 2 5 0.2420 0.4668 0.5673 -0.1250 -0.4569 0.0743 0.00 1.3 0.00056 -0.04423 0.05956 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265603.000 888529.0812 -4517279.1592 4399528.1152 2 5 0.2407 0.4647 0.5648 -0.1237 -0.4550 0.0733 0.00 1.5 0.00100 0.02676 0.01348 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265604.000 888529.0706 -4517279.1670 4399528.1066 2 4 0.2394 0.4628 0.5635 -0.1224 -0.4533 0.0725 0.00 1.2 -0.01216 -0.02903 0.04709 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265605.000 888529.0551 -4517279.1741 4399528.1150 2 4 0.2382 0.4608 0.5623 -0.1211 -0.4517 0.0717 0.00 1.4 -0.00038 -0.03760 0.03303 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265608.000 888518.2163 -4517274.8413 4399522.0274 2 4 4.6529 1.9264 2.6343 -2.9517 -2.2403 3.4596 0.00 0.0 0.00000 0.02024 -0.00509 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265609.000 888518.8771 -4517275.1292 4399522.4061 2 4 4.6529 1.9257 2.6337 -2.9514 -2.2396 3.4594 0.00 0.0 -0.00933 0.01036 -0.02099 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265610.000 888527.8122 -4517278.7546 4399527.4227 2 4 4.6529 1.9249 2.6331 -2.9511 -2.2390 3.4592 0.00 0.0 -0.01642 0.03118 -0.00560 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265611.000 888534.5726 -4517281.5015 4399531.2270 2 5 4.4722 1.8703 2.5834 -2.8498 -2.1854 3.3575 0.00 0.0 0.02849 -0.03539 -0.00959 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265613.000 888530.4572 -4517279.8588 4399528.9279 2 6 1.7056 0.8137 1.1023 -1.0783 -0.9176 1.2713 0.00 0.0 -0.00565 0.03268 -0.05108 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265614.000 888529.9962 -4517279.6703 4399528.6634 2 7 1.2712 0.6698 0.8911 -0.7994 -0.7368 0.9385 0.00 0.0 0.02647 -0.05177 0.07780 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265615.000 888529.9428 -4517279.6566 4399528.6531 2 7 1.0300 0.5969 0.7848 -0.6437 -0.6444 0.7540 0.00 0.0 -0.01111 0.01032 -0.05850 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265616.000 888529.4360 -4517279.4641 4399528.3744 2 4 0.9418 0.5708 0.7498 -0.5859 -0.6124 0.6878 0.00 0.0 0.00002 -0.01571 0.00233 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265617.000 888529.2544 -4517279.3991 4399528.2657 2 4 0.8730 0.5511 0.7234 -0.5407 -0.5880 0.6360 0.00 0.0 0.00680 0.02051 -0.00976 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265618.000 888529.2071 -4517279.3943 4399528.2418 2 4 0.8174 0.5354 0.7026 -0.5040 -0.5688 0.5940 0.00 0.0 -0.02781 0.01414 -0.05119 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265619.000 888529.0896 -4517279.3557 4399528.1668 2 4 0.7713 0.5227 0.6858 -0.4734 -0.5532 0.5592 0.00 0.0 0.01511 0.01511 0.03593 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265620.000 888528.9844 -4517279.3249 4399528.1065 2 4 0.7322 0.5120 0.6719 -0.4475 -0.5401 0.5296 0.00 0.0 -0.00961 0.00507 -0.04714 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265621.000 888529.0224 -4517279.3307 4399528.1000 2 6 0.6903 0.5020 0.6587 -0.4212 -0.5278 0.4993 0.00 0.0 0.00327 -0.00014 -0.00010 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265622.000 888528.9825 -4517279.3179 4399528.0749 2 6 0.6565 0.4937 0.6479 -0.3998 -0.5177 0.4746 0.00 0.0 -0.01972 -0.06449 0.14333 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265623.000 888528.8763 -4517279.2838 4399528.0047 2 4 0.6319 0.4870 0.6395 -0.3832 -0.5096 0.4558 0.00 0.0 0.02516 0.03429 -0.04562 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265624.000 888528.9236 -4517279.3214 4399528.1163 2 5 0.6081 0.4804 0.6291 -0.3668 -0.5010 0.4357 0.00 0.0 0.00089 0.02183 -0.03292 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265625.000 888528.9585 -4517279.3568 4399528.2115 2 5 0.5869 0.4746 0.6198 -0.3522 -0.4934 0.4177 0.00 0.0 -0.03321 -0.00439 0.02192 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265626.000 888528.8575 -4517279.3205 4399528.0982 2 5 0.5681 0.4693 0.6114 -0.3392 -0.4867 0.4020 0.00 0.0 0.01250 -0.00158 0.02046 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265627.000 888528.8703 -4517279.3409 4399528.1231 2 5 0.5508 0.4645 0.6040 -0.3272 -0.4806 0.3872 0.00 0.0 -0.00995 -0.02525 0.02709 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265628.000 888528.8846 -4517279.3529 4399528.1280 2 4 0.5361 0.4604 0.5994 -0.3171 -0.4759 0.3760 0.00 0.0 0.00143 0.02129 -0.02036 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265629.000 888528.9197 -4517279.3742 4399528.1327 2 4 0.5225 0.4566 0.5951 -0.3078 -0.4716 0.3657 0.00 0.0 0.01066 0.01146 0.01174 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265630.000 888528.9594 -4517279.4015 4399528.1525 2 4 0.5099 0.4530 0.5911 -0.2992 -0.4676 0.3562 0.00 0.0 -0.00271 -0.02411 0.04477 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265631.000 888529.0123 -4517279.4324 4399528.1752 2 4 0.4982 0.4496 0.5874 -0.2912 -0.4638 0.3473 0.00 0.0 0.02578 -0.05638 0.11321 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265632.000 888529.0687 -4517279.4630 4399528.1923 2 4 0.4872 0.4464 0.5840 -0.2836 -0.4603 0.3390 0.00 0.0 -0.00582 -0.00230 -0.01120 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265633.000 888529.1204 -4517279.4897 4399528.2059 2 4 0.4770 0.4434 0.5807 -0.2766 -0.4569 0.3312 0.00 0.0 -0.02566 0.02146 -0.09983 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265634.000 888529.1942 -4517279.5275 4399528.2312 2 4 0.4674 0.4405 0.5777 -0.2699 -0.4538 0.3239 0.00 2.2 -0.01521 -0.00106 -0.02472 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265635.000 888529.2000 -4517279.5532 4399528.2484 2 6 0.4559 0.4377 0.5746 -0.2631 -0.4507 0.3161 0.00 1.9 0.00624 -0.02889 0.01880 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265636.000 888529.2268 -4517279.5905 4399528.2746 2 6 0.4458 0.4351 0.5718 -0.2569 -0.4478 0.3091 0.00 1.5 0.00334 -0.03101 0.03524 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265637.000 888529.2528 -4517279.6236 4399528.2982 2 6 0.4363 0.4325 0.5692 -0.2510 -0.4450 0.3025 0.00 1.1 0.00783 -0.05070 0.09295 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265638.000 888529.2808 -4517279.6572 4399528.3200 2 7 0.4269 0.4299 0.5648 -0.2450 -0.4418 0.2946 0.00 1.0 -0.00663 0.02391 -0.03911 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265639.000 888529.3192 -4517279.6918 4399528.3475 2 7 0.4182 0.4274 0.5604 -0.2394 -0.4387 0.2875 0.00 1.2 -0.00325 0.03230 -0.05430 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265640.000 888529.3594 -4517279.7200 4399528.3647 2 7 0.4098 0.4251 0.5568 -0.2341 -0.4358 0.2806 0.00 1.2 -0.01711 0.00551 -0.00702 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265641.000 888529.4456 -4517279.7789 4399528.4314 2 7 0.4010 0.4228 0.5532 -0.2286 -0.4331 0.2741 0.00 0.0 0.00652 -0.00531 -0.02369 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265642.000 888529.4343 -4517279.7836 4399528.4397 2 6 0.3986 0.4213 0.5499 -0.2275 -0.4311 0.2710 0.00 0.0 -0.01550 0.03261 -0.02672 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265643.000 888529.3970 -4517279.7861 4399528.4159 2 6 0.3963 0.4199 0.5475 -0.2264 -0.4294 0.2684 0.00 0.0 -0.01199 -0.01307 -0.01422 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265644.000 888529.3812 -4517279.7882 4399528.4017 2 6 0.3941 0.4185 0.5443 -0.2253 -0.4275 0.2655 0.00 0.0 -0.00260 -0.01245 -0.00056 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265645.000 888529.3580 -4517279.7962 4399528.4170 2 6 0.3919 0.4172 0.5420 -0.2243 -0.4259 0.2630 0.00 0.0 0.00841 0.02960 -0.00473 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265646.000 888529.3339 -4517279.7988 4399528.4064 2 5 0.3907 0.4161 0.5413 -0.2243 -0.4250 0.2628 0.00 0.0 -0.00635 -0.08426 0.13583 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265647.000 888529.3093 -4517279.8011 4399528.3940 2 5 0.3896 0.4150 0.5405 -0.2242 -0.4241 0.2627 0.00 0.0 0.01933 -0.00290 0.01881 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265648.000 888529.2800 -4517279.8028 4399528.3845 2 5 0.3884 0.4139 0.5397 -0.2241 -0.4231 0.2625 0.00 0.0 -0.00403 -0.00851 -0.01857 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265649.000 888529.2371 -4517279.7927 4399528.3519 2 5 0.3873 0.4129 0.5390 -0.2240 -0.4222 0.2623 0.00 0.0 -0.01174 -0.01091 0.01857 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265650.000 888529.1989 -4517279.7831 4399528.3221 2 5 0.3862 0.4118 0.5382 -0.2240 -0.4213 0.2621 0.00 0.0 -0.00840 0.02007 -0.03446 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265651.000 888529.1738 -4517279.7988 4399528.3249 2 5 0.3851 0.4108 0.5375 -0.2239 -0.4204 0.2619 0.00 0.0 0.01418 0.00005 -0.02429 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265652.000 888529.1319 -4517279.8005 4399528.3162 2 5 0.3840 0.4097 0.5368 -0.2238 -0.4196 0.2617 0.00 0.0 -0.01915 0.03630 -0.04682 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265653.000 888529.0950 -4517279.7957 4399528.2918 2 5 0.3829 0.4087 0.5360 -0.2237 -0.4187 0.2615 0.00 0.0 0.00770 -0.03377 0.07565 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265654.000 888529.0767 -4517279.8021 4399528.2885 2 5 0.3818 0.4077 0.5353 -0.2236 -0.4178 0.2613 0.00 0.0 0.00659 0.03224 -0.06340 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265655.000 888529.0438 -4517279.8054 4399528.2756 2 5 0.3808 0.4067 0.5346 -0.2235 -0.4169 0.2610 0.00 0.0 0.00053 -0.02976 0.03897 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265656.000 888529.0021 -4517279.7965 4399528.2595 2 5 0.3797 0.4057 0.5339 -0.2233 -0.4161 0.2608 0.00 0.0 0.00564 -0.03007 0.03597 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265657.000 888529.1050 -4517279.8103 4399528.3074 2 6 0.3760 0.4047 0.5325 -0.2228 -0.4151 0.2584 0.00 4.2 -0.01901 0.00325 0.01804 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265658.000 888529.1600 -4517279.8165 4399528.3532 2 6 0.3724 0.4036 0.5307 -0.2221 -0.4139 0.2556 0.00 2.4 -0.01806 -0.02218 0.01211 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265659.000 888529.2181 -4517279.8151 4399528.3898 2 6 0.3691 0.4025 0.5291 -0.2215 -0.4128 0.2532 0.00 1.1 -0.00331 -0.02760 -0.04005 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265660.000 888529.3382 -4517279.8589 4399528.4712 2 7 0.3616 0.4004 0.5269 -0.2173 -0.4107 0.2479 0.00 1.9 -0.01245 -0.06101 0.04792 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265661.000 888529.4114 -4517279.8739 4399528.5244 2 7 0.3554 0.3985 0.5247 -0.2139 -0.4088 0.2433 0.00 1.4 0.00465 0.03624 -0.05596 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265662.000 888529.4596 -4517279.8738 4399528.5584 2 7 0.3495 0.3967 0.5225 -0.2107 -0.4069 0.2389 0.00 1.4 -0.00263 -0.03553 0.03307 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265663.000 888529.5033 -4517279.8776 4399528.6073 2 7 0.3433 0.3947 0.5203 -0.2072 -0.4049 0.2343 0.00 1.3 -0.01067 0.01440 -0.03218 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265664.000 888529.5246 -4517279.8718 4399528.6466 2 7 0.3379 0.3929 0.5181 -0.2042 -0.4030 0.2302 0.00 1.1 0.00157 0.05076 -0.01806 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265665.000 888529.5568 -4517279.8806 4399528.7025 2 7 0.3329 0.3910 0.5158 -0.2014 -0.4011 0.2264 0.00 1.1 0.01224 0.02966 0.03644 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265666.000 888529.5770 -4517279.8654 4399528.6945 2 7 0.3281 0.3891 0.5134 -0.1988 -0.3991 0.2226 0.00 1.3 0.00282 -0.10317 0.05565 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265667.000 888529.5931 -4517279.8731 4399528.7736 2 7 0.3235 0.3872 0.5109 -0.1962 -0.3970 0.2190 0.00 1.1 0.02765 0.16221 -0.03690 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265668.000 888529.5898 -4517279.8832 4399528.8174 2 6 0.3183 0.3854 0.5088 -0.1940 -0.3951 0.2158 0.00 1.3 0.01322 0.05780 -0.01052 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265669.000 888529.5571 -4517279.8783 4399528.8359 2 6 0.3134 0.3835 0.5063 -0.1920 -0.3929 0.2129 0.00 1.7 0.00803 0.03644 -0.05183 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265670.000 888529.5506 -4517279.8983 4399528.9036 2 5 0.3106 0.3821 0.5044 -0.1917 -0.3913 0.2110 0.00 3.2 0.00728 0.01642 -0.04755 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265671.000 888529.5116 -4517279.9066 4399528.9425 2 7 0.3071 0.3810 0.5029 -0.1914 -0.3901 0.2095 0.00 2.9 -0.01208 -0.09304 0.11020 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265672.000 888529.4594 -4517279.9209 4399528.9978 2 7 0.3039 0.3799 0.5015 -0.1911 -0.3890 0.2080 0.00 2.5 0.01515 -0.02336 0.02454 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265673.000 888529.4139 -4517279.9498 4399529.0709 2 7 0.3007 0.3788 0.5000 -0.1908 -0.3878 0.2067 0.00 1.4 -0.01135 -0.09045 0.04544 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265674.000 888529.3539 -4517279.9560 4399529.1105 2 7 0.2977 0.3777 0.4985 -0.1905 -0.3866 0.2053 0.00 1.3 0.00430 -0.05957 0.05506 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265675.000 888529.3125 -4517279.9526 4399529.1303 2 7 0.2948 0.3766 0.4969 -0.1902 -0.3854 0.2040 0.00 1.3 0.00450 -0.05992 0.02584 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265676.000 888529.2682 -4517279.9658 4399529.1800 2 7 0.2920 0.3754 0.4952 -0.1899 -0.3841 0.2027 0.00 1.1 0.00889 0.02446 -0.02950 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265677.000 888529.2196 -4517279.9808 4399529.2303 2 7 0.2893 0.3742 0.4935 -0.1895 -0.3827 0.2014 0.00 1.1 0.02078 0.00895 -0.03362 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265678.000 888529.1802 -4517279.9937 4399529.2753 2 7 0.2866 0.3730 0.4917 -0.1892 -0.3813 0.2001 0.00 1.4 -0.03277 -0.05543 -0.00178 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265679.000 888529.1294 -4517280.0288 4399529.3774 2 7 0.2841 0.3717 0.4897 -0.1888 -0.3797 0.1988 0.00 1.6 -0.00131 -0.01184 0.16685 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265680.000 888529.1664 -4517280.0399 4399529.3943 2 6 0.2828 0.3705 0.4881 -0.1882 -0.3784 0.1969 0.00 2.7 0.01379 -0.08460 0.11403 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265681.000 888529.2338 -4517280.0460 4399529.4161 2 4 0.2820 0.3696 0.4878 -0.1874 -0.3776 0.1945 0.00 1.8 -0.00044 0.21220 -0.11906 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265685.000 888520.3537 -4517276.5276 4399524.4377 2 5 4.2660 1.7352 2.4223 -2.6934 -2.0410 3.1843 0.00 0.0 0.01107 -0.05550 0.08201 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265686.000 888519.9416 -4517276.3695 4399524.2088 2 5 3.2779 1.3540 1.8884 -2.0719 -1.5873 2.4491 0.00 0.0 0.00509 0.00228 -0.07229 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265687.000 888539.5104 -4517284.1454 4399535.0776 2 4 4.6706 1.8813 2.6079 -2.9393 -2.2066 3.4620 0.00 0.0 -0.00933 -0.07701 0.07810 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265688.000 888532.7547 -4517281.4498 4399531.2967 2 5 2.7502 1.1497 1.5820 -1.7373 -1.3348 2.0393 0.00 0.0 -0.02304 -0.03521 0.01505 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265689.000 888533.3683 -4517281.6741 4399531.5899 2 5 2.0435 0.8866 1.2052 -1.2931 -1.0158 1.5080 0.00 0.0 -0.01348 -0.04119 -0.01892 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265690.000 888533.3103 -4517281.6515 4399531.5580 2 5 1.6845 0.7573 1.0178 -1.0675 -0.8569 1.2361 0.00 0.0 0.03618 0.00196 0.02515 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265691.000 888532.9147 -4517281.4923 4399531.3284 2 5 1.4681 0.6818 0.9073 -0.9317 -0.7632 1.0715 0.00 0.0 -0.05016 0.02863 -0.08081 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265692.000 888533.0208 -4517281.5372 4399531.3782 2 5 1.3198 0.6315 0.8331 -0.8387 -0.7001 0.9580 0.00 0.0 -0.02453 0.06087 -0.04203 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265693.000 888531.8150 -4517281.0566 4399530.6954 2 5 2.7490 1.1467 1.5789 -1.7356 -1.3319 2.0379 0.00 0.0 -0.00892 -0.06643 0.08124 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265694.000 888531.3682 -4517280.8824 4399530.4520 2 4 2.0990 0.9061 1.2366 -1.3287 -1.0413 1.5527 0.00 0.0 -0.00858 -0.03132 0.02569 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265695.000 888529.9301 -4517280.3415 4399529.6969 2 6 1.2895 0.6203 0.8446 -0.8201 -0.6984 0.9569 0.00 0.0 0.00934 0.05540 -0.01804 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265696.000 888529.5759 -4517280.2158 4399529.5415 2 6 1.0267 0.5355 0.7277 -0.6551 -0.5948 0.7630 0.00 0.0 0.03704 0.00034 0.08105 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265697.000 888529.0280 -4517280.0336 4399529.2842 2 6 0.8960 0.4962 0.6728 -0.5737 -0.5461 0.6664 0.00 0.0 0.00754 0.01505 0.00624 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265698.000 888528.4866 -4517279.8298 4399529.0128 2 6 0.8052 0.4701 0.6364 -0.5174 -0.5136 0.5992 0.00 0.0 -0.00012 0.00268 0.01492 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265699.000 888528.2069 -4517279.7456 4399528.9070 2 6 0.7239 0.4478 0.6067 -0.4669 -0.4861 0.5398 0.00 0.0 0.01051 0.00620 0.00707 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265700.000 888528.0656 -4517279.7071 4399528.8446 2 6 0.6735 0.4343 0.5879 -0.4358 -0.4693 0.5026 0.00 0.0 0.00408 0.02076 0.01016 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265701.000 888527.8970 -4517279.6616 4399528.7901 2 6 0.6298 0.4232 0.5727 -0.4092 -0.4555 0.4708 0.00 0.0 -0.06248 -0.00294 0.00923 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265702.000 888528.0177 -4517279.7113 4399528.8795 2 5 0.6027 0.4153 0.5617 -0.3914 -0.4457 0.4493 0.00 0.0 -0.02261 0.01292 0.00677 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265703.000 888528.1162 -4517279.7539 4399528.9550 2 5 0.5788 0.4083 0.5521 -0.3757 -0.4370 0.4302 0.00 0.0 0.00988 0.04408 -0.00636 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265704.000 888528.2148 -4517279.7977 4399529.0187 2 5 0.5575 0.4021 0.5436 -0.3616 -0.4293 0.4131 0.00 0.0 0.03005 -0.01348 -0.03185 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265705.000 888528.2834 -4517279.8122 4399529.0403 2 5 0.5384 0.3965 0.5359 -0.3489 -0.4224 0.3977 0.00 1.5 -0.02683 -0.02789 0.01532 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265706.000 888528.3549 -4517279.8422 4399529.1028 2 5 0.5211 0.3914 0.5288 -0.3374 -0.4160 0.3836 0.00 2.2 0.00031 -0.05627 0.11271 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265707.000 888528.4244 -4517279.8644 4399529.1325 2 5 0.5054 0.3867 0.5222 -0.3269 -0.4101 0.3707 0.00 3.3 -0.01138 0.08887 -0.04024 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265708.000 888528.4869 -4517279.8818 4399529.1707 2 5 0.4910 0.3823 0.5160 -0.3172 -0.4046 0.3588 0.00 4.6 0.01948 0.00638 0.00339 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265709.000 888528.8770 -4517280.1180 4399529.5315 1 5 0.0073 0.0184 0.0303 -0.0017 -0.0220 -0.0052 0.00 5.9 -0.00857 -0.08422 0.10187 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265710.000 888528.8801 -4517280.1208 4399529.5494 1 5 0.0073 0.0185 0.0303 -0.0018 -0.0220 -0.0052 0.00 8.2 0.01969 -0.00503 0.02176 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265711.000 888528.8823 -4517280.1166 4399529.5312 1 5 0.0072 0.0184 0.0303 -0.0016 -0.0220 -0.0052 0.00 12.4 0.00005 0.04725 -0.02155 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265712.000 888528.8789 -4517280.1201 4399529.5176 1 5 0.0072 0.0184 0.0303 -0.0018 -0.0220 -0.0052 0.00 6.2 -0.02378 -0.04222 -0.05212 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265713.000 888528.5582 -4517279.8963 4399529.2580 2 6 0.4302 0.3629 0.4879 -0.2768 -0.3800 0.3086 0.00 4.7 0.03026 -0.00006 -0.01660 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265714.000 888528.4579 -4517279.9028 4399529.3020 2 6 0.4188 0.3593 0.4824 -0.2697 -0.3753 0.2997 0.00 4.2 -0.01664 -0.00002 0.00115 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265715.000 888528.3768 -4517279.8935 4399529.2987 2 6 0.4081 0.3558 0.4770 -0.2631 -0.3708 0.2914 0.00 2.7 -0.01790 -0.01493 0.04691 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265716.000 888528.3339 -4517279.8882 4399529.2892 2 6 0.3982 0.3535 0.4761 -0.2575 -0.3687 0.2848 0.00 1.9 0.01807 0.05035 -0.04969 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265717.000 888528.1918 -4517279.8519 4399529.2426 2 5 0.3893 0.3512 0.4739 -0.2524 -0.3662 0.2793 0.00 1.1 0.01146 -0.05135 0.06595 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265718.000 888528.0963 -4517279.8499 4399529.2241 2 5 0.3814 0.3492 0.4720 -0.2479 -0.3642 0.2742 0.00 1.4 0.01420 -0.02449 0.03378 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265719.000 888528.1123 -4517279.8773 4399529.2664 2 7 0.3715 0.3469 0.4692 -0.2420 -0.3615 0.2670 0.00 1.5 0.04880 -0.03627 0.09504 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265720.000 888528.0783 -4517279.8976 4399529.2840 2 7 0.3630 0.3448 0.4667 -0.2369 -0.3590 0.2609 0.00 1.1 -0.05193 0.03230 -0.02439 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265721.000 888528.0542 -4517279.9089 4399529.2661 2 8 0.3549 0.3427 0.4634 -0.2321 -0.3564 0.2548 0.00 1.0 0.01709 -0.00006 0.01678 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265722.000 888527.9469 -4517279.8747 4399529.1954 2 6 0.3489 0.3410 0.4607 -0.2286 -0.3543 0.2509 0.00 1.3 -0.01113 -0.00217 0.03901 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265723.000 888527.8674 -4517279.8734 4399529.1838 2 5 0.3432 0.3394 0.4597 -0.2253 -0.3529 0.2472 0.00 1.6 -0.00947 0.01533 -0.01446 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265724.000 888527.7904 -4517279.8711 4399529.1722 2 5 0.3378 0.3379 0.4582 -0.2221 -0.3512 0.2436 0.00 1.3 0.01738 -0.03475 0.02418 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265725.000 888527.8168 -4517279.9117 4399529.2217 2 7 0.3312 0.3361 0.4561 -0.2182 -0.3491 0.2387 0.00 1.6 -0.02027 -0.00642 -0.04331 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265726.000 888527.8292 -4517279.9367 4399529.2638 2 7 0.3250 0.3344 0.4538 -0.2145 -0.3471 0.2341 0.00 2.0 0.05027 -0.05895 0.08306 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265727.000 888527.8462 -4517279.9614 4399529.2765 2 7 0.3192 0.3327 0.4516 -0.2110 -0.3451 0.2297 0.00 2.3 0.04453 -0.05433 0.04641 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265728.000 888527.9102 -4517279.9855 4399529.3265 2 5 0.3184 0.3317 0.4505 -0.2100 -0.3439 0.2280 0.00 0.0 0.01868 -0.01030 0.01502 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265729.000 888527.9773 -4517280.0146 4399529.3854 2 5 0.3172 0.3310 0.4496 -0.2091 -0.3430 0.2267 0.00 0.0 -0.02812 -0.01349 0.02485 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265730.000 888528.0572 -4517280.0547 4399529.4369 2 5 0.3161 0.3302 0.4487 -0.2083 -0.3422 0.2253 0.00 0.0 -0.02607 0.03683 -0.05571 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265731.000 888528.1282 -4517280.0830 4399529.4852 2 5 0.3149 0.3295 0.4479 -0.2074 -0.3414 0.2240 0.00 0.0 -0.01419 0.04350 -0.02605 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265732.000 888528.1176 -4517280.1025 4399529.5253 2 6 0.3113 0.3287 0.4469 -0.2060 -0.3405 0.2219 0.00 0.0 -0.00022 -0.01869 0.01767 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265733.000 888528.0798 -4517280.1121 4399529.5438 2 6 0.3079 0.3279 0.4459 -0.2047 -0.3395 0.2200 0.00 0.0 0.03560 -0.00398 0.04249 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265734.000 888528.0715 -4517280.1299 4399529.5634 2 6 0.3047 0.3271 0.4449 -0.2034 -0.3386 0.2181 0.00 0.0 -0.01135 -0.02396 -0.00438 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265735.000 888528.0527 -4517280.0912 4399529.4960 1 8 0.0100 0.0210 0.0367 -0.0116 -0.0240 0.0121 0.00 5.8 -0.03082 0.00418 0.02363 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265736.000 888528.0576 -4517280.1531 4399529.6701 2 8 0.2936 0.3241 0.4414 -0.1968 -0.3355 0.2099 0.00 2.8 0.04105 -0.05686 0.07881 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265737.000 888528.0971 -4517280.1683 4399529.7285 2 7 0.2905 0.3233 0.4400 -0.1955 -0.3345 0.2075 0.00 1.5 -0.02823 0.04419 0.04645 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265738.000 888528.1561 -4517280.1965 4399529.7862 2 7 0.2874 0.3225 0.4387 -0.1943 -0.3335 0.2052 0.00 1.2 0.08827 -0.03285 0.01320 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265739.000 888528.1823 -4517280.2069 4399529.8176 2 8 0.2845 0.3216 0.4366 -0.1930 -0.3322 0.2028 0.00 1.5 0.07840 -0.10858 0.15578 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265740.000 888528.2233 -4517280.2296 4399529.8736 2 8 0.2816 0.3207 0.4344 -0.1918 -0.3308 0.2005 0.00 1.1 -0.00787 0.01852 -0.03252 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265741.000 888528.2089 -4517280.2222 4399529.8769 2 6 0.2797 0.3202 0.4340 -0.1914 -0.3304 0.1995 0.00 1.6 -0.04266 -0.03573 0.06336 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265742.000 888528.2048 -4517280.2480 4399529.9519 2 6 0.2777 0.3195 0.4320 -0.1907 -0.3292 0.1980 0.00 1.5 -0.00067 -0.00819 0.02298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265743.000 888528.1948 -4517280.2489 4399529.9685 2 5 0.2758 0.3189 0.4310 -0.1901 -0.3286 0.1968 0.00 1.9 0.01456 -0.07521 0.03919 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265744.000 888528.1508 -4517280.2561 4399529.9861 2 4 0.2743 0.3184 0.4312 -0.1897 -0.3283 0.1963 0.00 1.4 0.01891 -0.08951 0.12302 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265745.000 888528.1240 -4517280.2366 4399529.9450 2 4 0.2728 0.3179 0.4308 -0.1893 -0.3278 0.1958 0.00 1.2 -0.01602 -0.03342 0.02988 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265750.000 888521.2743 -4517277.5659 4399526.2085 2 4 2.3499 0.9745 1.3658 -1.4792 -1.1409 1.7506 0.00 0.0 -0.00983 -0.06176 0.09450 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265751.000 888521.3532 -4517277.6000 4399526.2382 2 4 1.7271 0.7477 1.0453 -1.0919 -0.8673 1.2901 0.00 0.0 0.04980 0.14794 -0.19209 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265752.000 888522.3080 -4517277.9812 4399526.7699 2 4 1.4299 0.6437 0.8983 -0.9078 -0.7409 1.0708 0.00 0.0 0.01798 -0.00639 0.01781 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265753.000 888522.5657 -4517278.0842 4399526.9085 2 4 2.3496 0.9733 1.3647 -1.4784 -1.1398 1.7500 0.00 0.0 0.00789 0.03435 -0.00302 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265754.000 888521.6354 -4517277.7263 4399526.4063 2 4 1.7269 0.7465 1.0443 -1.0913 -0.8662 1.2895 0.00 0.0 0.01197 0.01031 -0.01011 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265755.000 888521.9776 -4517277.8601 4399526.5942 2 4 1.4297 0.6425 0.8973 -0.9073 -0.7398 1.0703 0.00 0.0 0.00851 0.02200 -0.04311 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265756.000 888523.6037 -4517278.5323 4399527.5146 2 5 1.1047 0.5294 0.7410 -0.7022 -0.6026 0.8286 0.00 0.0 0.00065 -0.00600 0.01946 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265757.000 888523.6393 -4517278.5596 4399527.5470 2 5 0.9550 0.4803 0.6729 -0.6083 -0.5424 0.7174 0.00 0.0 0.00137 0.02720 -0.00711 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265758.000 888523.6677 -4517278.5808 4399527.5726 2 5 0.8533 0.4483 0.6286 -0.5446 -0.5028 0.6419 0.00 0.0 -0.00252 -0.06929 0.10285 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265759.000 888523.8237 -4517278.6564 4399527.6731 2 5 0.7665 0.4218 0.5926 -0.4900 -0.4702 0.5777 0.00 0.0 0.01174 0.04186 -0.10230 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265760.000 888523.7971 -4517278.6523 4399527.6642 2 5 0.7108 0.4056 0.5703 -0.4553 -0.4499 0.5365 0.00 0.0 0.00748 0.04706 -0.06288 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265761.000 888523.8197 -4517278.6572 4399527.6724 2 5 0.6658 0.3928 0.5528 -0.4273 -0.4339 0.5032 0.00 0.0 0.00716 0.00952 0.01936 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265762.000 888523.8472 -4517278.6903 4399527.7094 2 5 0.6284 0.3823 0.5386 -0.4040 -0.4209 0.4755 0.00 0.0 -0.02283 -0.03403 0.04869 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265763.000 888523.8899 -4517278.7206 4399527.7466 2 5 0.5966 0.3737 0.5269 -0.3843 -0.4101 0.4520 0.00 0.0 -0.00327 -0.04537 0.05655 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265764.000 888523.9161 -4517278.7408 4399527.7723 2 5 0.5691 0.3663 0.5169 -0.3672 -0.4008 0.4317 0.00 1.1 0.01909 -0.01570 0.01298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265765.000 888523.9335 -4517278.7635 4399527.7923 2 5 0.5452 0.3599 0.5082 -0.3523 -0.3928 0.4140 0.00 1.0 -0.01265 -0.00906 0.05618 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265766.000 888523.9839 -4517278.7877 4399527.8249 2 5 0.5239 0.3542 0.5007 -0.3392 -0.3858 0.3982 0.00 1.0 0.01141 -0.03055 0.03922 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265767.000 888523.9972 -4517278.8024 4399527.8294 2 5 0.5050 0.3492 0.4939 -0.3274 -0.3795 0.3841 0.00 1.4 -0.01545 0.01871 -0.01784 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265768.000 888524.0199 -4517278.8131 4399527.8473 2 5 0.4879 0.3447 0.4878 -0.3168 -0.3738 0.3713 0.00 1.3 0.02264 -0.03540 0.05816 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265769.000 888524.0366 -4517278.8300 4399527.8622 2 5 0.4724 0.3406 0.4822 -0.3071 -0.3687 0.3597 0.00 1.6 0.02621 0.05800 -0.10328 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265770.000 888524.0522 -4517278.8394 4399527.8774 2 5 0.4583 0.3369 0.4770 -0.2983 -0.3639 0.3490 0.00 1.5 0.01281 0.01079 -0.01057 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265771.000 888524.3673 -4517278.9765 4399528.0908 2 7 0.4410 0.3323 0.4702 -0.2873 -0.3579 0.3352 0.00 1.3 0.05081 -0.06248 0.05945 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265772.000 888524.5364 -4517279.0520 4399528.2193 2 7 0.4265 0.3284 0.4643 -0.2781 -0.3527 0.3236 0.00 1.1 -0.01532 0.00144 -0.01697 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265773.000 888524.5152 -4517279.0501 4399528.2295 2 5 0.4160 0.3256 0.4604 -0.2714 -0.3491 0.3156 0.00 1.1 0.00593 0.02226 -0.02866 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265774.000 888524.4935 -4517279.0453 4399528.2289 2 5 0.4061 0.3228 0.4564 -0.2652 -0.3455 0.3079 0.00 1.1 0.01811 -0.01065 0.01188 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265775.000 888524.6320 -4517279.0973 4399528.3256 2 7 0.3944 0.3195 0.4514 -0.2576 -0.3411 0.2983 0.00 1.2 0.02130 0.05911 -0.03867 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265776.000 888524.7369 -4517279.1487 4399528.4218 2 7 0.3838 0.3165 0.4465 -0.2508 -0.3370 0.2895 0.00 1.3 0.00936 -0.01993 0.00462 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265777.000 888524.8616 -4517279.1989 4399528.5037 2 6 0.3775 0.3149 0.4440 -0.2472 -0.3347 0.2845 0.00 1.1 -0.01868 0.01981 -0.05191 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265778.000 888524.8684 -4517279.2052 4399528.5177 2 4 0.3734 0.3141 0.4430 -0.2454 -0.3337 0.2820 0.00 1.1 0.04222 -0.04312 0.03753 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265779.000 888524.8460 -4517279.2032 4399528.5232 2 6 0.3687 0.3132 0.4419 -0.2433 -0.3327 0.2792 0.00 1.1 -0.02431 0.07568 -0.07370 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265780.000 888524.8469 -4517279.2042 4399528.5207 2 6 0.3641 0.3124 0.4409 -0.2412 -0.3317 0.2765 0.00 1.1 0.01043 -0.03114 0.05137 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265781.000 888524.9655 -4517279.2631 4399528.5917 2 7 0.3557 0.3103 0.4386 -0.2361 -0.3294 0.2707 0.00 1.1 0.00480 -0.00177 -0.01755 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265782.000 888525.0053 -4517279.2832 4399528.6164 2 7 0.3489 0.3085 0.4367 -0.2320 -0.3274 0.2660 0.00 1.0 0.00736 0.01838 -0.06874 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265783.000 888525.0267 -4517279.2932 4399528.6276 2 7 0.3415 0.3068 0.4348 -0.2276 -0.3254 0.2610 0.00 1.1 -0.01589 0.03114 0.00968 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265784.000 888525.0482 -4517279.3084 4399528.6516 2 7 0.3354 0.3052 0.4331 -0.2240 -0.3236 0.2568 0.00 1.1 -0.00891 -0.01477 0.01522 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265785.000 888525.0502 -4517279.3068 4399528.6486 2 7 0.3297 0.3037 0.4315 -0.2207 -0.3219 0.2528 0.00 1.1 -0.00122 0.01988 -0.04458 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265786.000 888525.0540 -4517279.3098 4399528.6499 2 7 0.3243 0.3023 0.4299 -0.2175 -0.3203 0.2490 0.00 1.2 0.00157 -0.04283 0.04847 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265787.000 888525.0583 -4517279.3049 4399528.6447 2 7 0.3191 0.3009 0.4284 -0.2144 -0.3188 0.2454 0.00 1.1 -0.00020 -0.05210 0.06633 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265788.000 888525.0497 -4517279.2877 4399528.6332 2 7 0.3142 0.2996 0.4268 -0.2115 -0.3173 0.2420 0.00 1.0 -0.00878 -0.01639 0.00705 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265789.000 888525.0521 -4517279.2784 4399528.6353 2 7 0.3094 0.2983 0.4252 -0.2087 -0.3157 0.2386 0.00 1.1 0.01614 -0.00465 0.00359 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265790.000 888525.0562 -4517279.2797 4399528.6437 2 7 0.3049 0.2970 0.4236 -0.2060 -0.3142 0.2354 0.00 1.1 0.02990 -0.01943 0.03329 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265791.000 888525.0532 -4517279.2758 4399528.6300 2 7 0.3006 0.2958 0.4220 -0.2034 -0.3127 0.2322 0.00 1.1 -0.04152 -0.03858 0.03770 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265792.000 888525.0602 -4517279.2624 4399528.6149 2 7 0.2964 0.2945 0.4204 -0.2009 -0.3112 0.2292 0.00 1.1 -0.00641 0.00854 -0.03677 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265793.000 888525.0559 -4517279.2677 4399528.6227 2 7 0.2924 0.2933 0.4186 -0.1985 -0.3096 0.2262 0.00 1.1 0.00625 0.00302 -0.01342 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265794.000 888525.0623 -4517279.2463 4399528.6076 2 7 0.2885 0.2920 0.4169 -0.1961 -0.3081 0.2232 0.00 1.1 -0.00853 -0.00058 -0.01671 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265795.000 888525.0747 -4517279.2582 4399528.6363 2 7 0.2848 0.2908 0.4150 -0.1938 -0.3065 0.2204 0.00 1.1 0.00397 0.01499 -0.01934 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265796.000 888525.0849 -4517279.2555 4399528.6577 2 7 0.2812 0.2895 0.4131 -0.1915 -0.3048 0.2175 0.00 1.1 -0.00501 -0.01965 -0.00354 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265797.000 888525.1046 -4517279.2859 4399528.7116 2 7 0.2777 0.2883 0.4110 -0.1893 -0.3032 0.2147 0.00 1.0 0.00819 -0.04014 0.05047 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265798.000 888525.1162 -4517279.2907 4399528.7411 2 7 0.2744 0.2870 0.4089 -0.1872 -0.3015 0.2120 0.00 1.1 0.01497 0.03343 -0.05387 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265799.000 888525.1244 -4517279.2988 4399528.7704 2 7 0.2711 0.2857 0.4067 -0.1850 -0.2997 0.2092 0.00 1.1 0.02469 -0.01577 0.01011 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265800.000 888525.1933 -4517279.3154 4399528.8668 2 8 0.2677 0.2844 0.4041 -0.1829 -0.2978 0.2061 0.00 1.1 -0.01806 0.00022 -0.06602 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265801.000 888525.2585 -4517279.3373 4399528.9747 2 8 0.2643 0.2831 0.4014 -0.1808 -0.2959 0.2030 0.00 1.1 -0.00394 0.00643 0.00212 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265802.000 888525.2933 -4517279.3474 4399529.0664 2 8 0.2612 0.2818 0.3982 -0.1787 -0.2939 0.1999 0.00 1.4 0.01736 -0.00886 0.01767 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265803.000 888525.3340 -4517279.3591 4399529.1385 2 8 0.2582 0.2804 0.3951 -0.1767 -0.2918 0.1970 0.00 1.2 0.01583 0.02539 0.01869 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265804.000 888525.3642 -4517279.3595 4399529.1983 2 8 0.2553 0.2790 0.3920 -0.1747 -0.2897 0.1940 0.00 1.1 -0.01931 -0.02563 -0.04980 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265805.000 888525.4064 -4517279.3704 4399529.2914 2 8 0.2524 0.2776 0.3888 -0.1728 -0.2875 0.1911 0.00 1.0 -0.00448 0.03105 -0.02931 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265806.000 888525.4432 -4517279.3720 4399529.3684 2 8 0.2497 0.2762 0.3855 -0.1709 -0.2853 0.1882 0.00 1.2 -0.00039 0.05253 -0.03582 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265807.000 888525.4805 -4517279.3892 4399529.4831 2 8 0.2470 0.2748 0.3821 -0.1690 -0.2830 0.1854 0.00 1.4 0.01446 -0.00946 0.06733 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265808.000 888525.5323 -4517279.3972 4399529.5103 2 7 0.2452 0.2737 0.3796 -0.1679 -0.2812 0.1832 0.00 1.8 -0.02535 0.03861 -0.07651 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265809.000 888525.5908 -4517279.4084 4399529.5782 2 7 0.2436 0.2730 0.3776 -0.1672 -0.2799 0.1816 0.00 1.9 0.00654 0.01684 0.03850 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265810.000 888525.6374 -4517279.4067 4399529.6066 2 7 0.2420 0.2722 0.3756 -0.1665 -0.2787 0.1801 0.00 1.8 0.00318 0.05727 -0.03867 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265811.000 888525.6987 -4517279.4133 4399529.6686 2 7 0.2404 0.2715 0.3734 -0.1657 -0.2774 0.1785 0.00 1.4 0.02367 0.01409 -0.01055 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265812.000 888525.7435 -4517279.4139 4399529.6969 2 7 0.2388 0.2707 0.3712 -0.1650 -0.2760 0.1769 0.00 1.2 0.00185 -0.00131 -0.01384 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265813.000 888525.7931 -4517279.4185 4399529.7370 2 7 0.2373 0.2699 0.3689 -0.1643 -0.2746 0.1754 0.00 2.1 0.00198 -0.00196 -0.00656 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265814.000 888525.8373 -4517279.4100 4399529.7662 2 7 0.2358 0.2691 0.3666 -0.1635 -0.2732 0.1738 0.00 2.7 -0.01657 -0.04711 0.04347 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265815.000 888525.8918 -4517279.4120 4399529.7926 2 7 0.2343 0.2682 0.3642 -0.1628 -0.2717 0.1722 0.00 3.6 -0.00645 -0.00896 -0.04452 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265816.000 888525.9237 -4517279.3978 4399529.8140 2 7 0.2329 0.2673 0.3617 -0.1621 -0.2702 0.1707 0.00 4.0 -0.00173 -0.02744 0.01190 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265817.000 888525.9721 -4517279.3854 4399529.8126 2 7 0.2315 0.2665 0.3592 -0.1614 -0.2686 0.1691 0.00 4.5 0.00580 -0.03665 0.03381 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265818.000 888526.0076 -4517279.3763 4399529.8425 2 7 0.2301 0.2656 0.3566 -0.1607 -0.2670 0.1676 0.00 3.9 -0.01760 0.05041 -0.07986 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265819.000 888526.0548 -4517279.3805 4399529.8900 2 7 0.2287 0.2646 0.3539 -0.1599 -0.2654 0.1660 0.00 3.1 -0.00152 -0.02946 0.07215 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265820.000 888526.1003 -4517279.3786 4399529.9220 2 7 0.2274 0.2637 0.3511 -0.1592 -0.2637 0.1645 0.00 2.2 0.01639 0.01831 0.01391 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265821.000 888526.1267 -4517279.3755 4399529.9529 2 7 0.2261 0.2627 0.3483 -0.1585 -0.2619 0.1630 0.00 1.7 -0.00587 -0.01717 -0.00169 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265822.000 888526.1760 -4517279.3692 4399529.9814 2 7 0.2248 0.2617 0.3455 -0.1578 -0.2602 0.1614 0.00 1.2 0.00877 -0.00928 0.02068 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265823.000 888526.2173 -4517279.3666 4399530.0037 2 7 0.2235 0.2607 0.3425 -0.1571 -0.2584 0.1599 0.00 1.2 -0.01175 0.00554 -0.00102 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265824.000 888526.2630 -4517279.3673 4399530.0472 2 7 0.2223 0.2597 0.3396 -0.1564 -0.2565 0.1584 0.00 1.6 0.00538 0.04107 -0.09355 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265825.000 888526.2847 -4517279.3506 4399530.0464 2 7 0.2211 0.2587 0.3365 -0.1557 -0.2547 0.1569 0.00 1.7 0.00927 -0.02934 -0.03548 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265826.000 888526.3304 -4517279.3560 4399530.0931 2 7 0.2199 0.2576 0.3335 -0.1550 -0.2528 0.1554 0.00 1.5 0.00360 0.03699 -0.00482 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265827.000 888526.3677 -4517279.3337 4399530.0761 2 7 0.2187 0.2566 0.3304 -0.1543 -0.2508 0.1539 0.00 1.1 0.01237 -0.02907 0.02614 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265828.000 888526.4036 -4517279.3330 4399530.1306 2 7 0.2175 0.2555 0.3272 -0.1536 -0.2489 0.1524 0.00 1.2 0.01764 0.11451 -0.02338 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265829.000 888526.4307 -4517279.3107 4399530.1172 2 7 0.2164 0.2544 0.3240 -0.1530 -0.2469 0.1509 0.00 1.8 -0.00038 0.05248 -0.04192 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265830.000 888526.4652 -4517279.2925 4399530.1322 2 7 0.2153 0.2533 0.3208 -0.1523 -0.2449 0.1495 0.00 2.8 -0.01701 0.02629 -0.03938 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265831.000 888526.4976 -4517279.2918 4399530.1741 2 7 0.2142 0.2522 0.3176 -0.1516 -0.2429 0.1480 0.00 4.1 0.01034 -0.02914 0.06785 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265832.000 888526.6128 -4517279.3963 4399530.4995 1 7 0.0089 0.0198 0.0264 -0.0106 -0.0204 0.0088 0.00 5.9 0.01348 0.06131 -0.00884 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265833.000 888526.6056 -4517279.3951 4399530.5205 1 7 0.0088 0.0198 0.0264 -0.0106 -0.0204 0.0089 0.00 7.0 -0.01166 -0.02983 -0.07102 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265834.000 888526.6130 -4517279.3973 4399530.5077 1 7 0.0089 0.0198 0.0264 -0.0106 -0.0204 0.0088 0.00 7.4 0.00650 0.01848 0.03140 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265835.000 888526.6071 -4517279.3948 4399530.5122 1 7 0.0089 0.0198 0.0264 -0.0105 -0.0204 0.0088 0.00 5.8 -0.00376 -0.00885 0.04552 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265836.000 888526.6386 -4517279.1850 4399530.1685 2 7 0.2089 0.2466 0.3011 -0.1485 -0.2326 0.1411 0.00 3.4 -0.02921 -0.04750 -0.02486 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265837.000 888526.6667 -4517279.1674 4399530.1966 2 7 0.2080 0.2455 0.2977 -0.1479 -0.2305 0.1397 0.00 2.6 0.02074 -0.01791 0.08624 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265838.000 888526.6904 -4517279.1413 4399530.1778 2 7 0.2070 0.2444 0.2944 -0.1473 -0.2284 0.1384 0.00 1.8 0.01762 0.04653 -0.05263 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265839.000 888526.7083 -4517279.1204 4399530.1833 2 7 0.2060 0.2433 0.2910 -0.1467 -0.2264 0.1371 0.00 1.4 -0.01754 -0.07920 0.05833 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265840.000 888526.7256 -4517279.0831 4399530.1416 2 7 0.2051 0.2421 0.2877 -0.1461 -0.2243 0.1358 0.00 1.0 0.00388 -0.03851 0.03596 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265841.000 888526.7497 -4517279.0708 4399530.1509 2 7 0.2042 0.2410 0.2844 -0.1455 -0.2222 0.1345 0.00 1.1 0.01394 -0.02231 0.06002 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265842.000 888526.7594 -4517279.0335 4399530.1235 2 7 0.2032 0.2399 0.2811 -0.1450 -0.2202 0.1333 0.00 1.1 0.00791 -0.02993 0.02015 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265843.000 888526.7802 -4517279.0182 4399530.1159 2 7 0.2023 0.2388 0.2778 -0.1444 -0.2181 0.1321 0.00 1.0 -0.02112 -0.05200 -0.00666 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265844.000 888526.8001 -4517279.0056 4399530.1326 2 7 0.2015 0.2376 0.2745 -0.1439 -0.2160 0.1309 0.00 1.0 -0.00410 0.02185 0.03131 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265845.000 888526.8080 -4517278.9778 4399530.1050 2 7 0.2006 0.2365 0.2712 -0.1434 -0.2140 0.1297 0.00 1.0 0.02573 -0.02828 0.03126 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265846.000 888526.8218 -4517278.9490 4399530.0672 2 7 0.1997 0.2354 0.2680 -0.1428 -0.2120 0.1285 0.00 1.0 0.00226 0.01655 -0.02959 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265847.000 888526.8344 -4517278.9179 4399530.0408 2 7 0.1989 0.2343 0.2648 -0.1423 -0.2100 0.1274 0.00 1.0 0.02273 -0.06027 0.06512 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265848.000 888526.8407 -4517278.8912 4399530.0191 2 7 0.1981 0.2332 0.2616 -0.1418 -0.2080 0.1262 0.00 1.0 0.00391 0.04150 -0.04190 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265849.000 888526.8603 -4517278.8742 4399530.0129 2 7 0.1972 0.2321 0.2584 -0.1413 -0.2060 0.1251 0.00 1.0 0.01326 -0.02041 0.03199 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265850.000 888526.8708 -4517278.8495 4399529.9986 2 7 0.1964 0.2311 0.2552 -0.1409 -0.2040 0.1241 0.00 1.0 0.01851 -0.00438 0.04561 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265851.000 888526.9059 -4517278.8351 4399529.9863 2 8 0.1955 0.2300 0.2520 -0.1403 -0.2020 0.1228 0.00 1.1 0.01318 -0.03822 0.02510 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265852.000 888526.9340 -4517278.8202 4399529.9772 2 8 0.1946 0.2288 0.2487 -0.1397 -0.1999 0.1215 0.00 1.3 0.01320 -0.01419 -0.03505 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265853.000 888526.9675 -4517278.8039 4399529.9732 2 8 0.1937 0.2277 0.2455 -0.1392 -0.1979 0.1203 0.00 1.5 0.03493 -0.05135 0.07321 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265854.000 888526.9965 -4517278.7802 4399529.9538 2 8 0.1928 0.2266 0.2424 -0.1386 -0.1960 0.1192 0.00 1.6 -0.00797 0.00002 0.02400 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265855.000 888527.0292 -4517278.7560 4399529.9239 2 8 0.1920 0.2256 0.2394 -0.1381 -0.1941 0.1181 0.00 1.6 0.00623 -0.02338 -0.02639 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265856.000 888527.0506 -4517278.7343 4399529.9223 2 9 0.1905 0.2242 0.2363 -0.1370 -0.1920 0.1166 0.00 1.7 -0.00255 -0.00378 -0.01520 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265857.000 888527.0743 -4517278.7109 4399529.9196 2 9 0.1893 0.2229 0.2333 -0.1360 -0.1900 0.1152 0.00 1.6 -0.01413 0.00331 -0.07572 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265858.000 888527.0799 -4517278.6836 4399529.9171 2 9 0.1881 0.2216 0.2303 -0.1351 -0.1880 0.1139 0.00 1.6 -0.01088 0.01880 -0.04495 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265859.000 888527.0748 -4517278.6373 4399529.8591 2 9 0.1869 0.2204 0.2273 -0.1342 -0.1861 0.1126 0.00 1.5 -0.01322 0.02203 -0.06567 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265860.000 888527.0725 -4517278.5943 4399529.8521 2 9 0.1857 0.2192 0.2244 -0.1333 -0.1842 0.1114 0.00 1.4 0.01357 0.06966 -0.06570 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265861.000 888527.0681 -4517278.5604 4399529.8294 2 9 0.1845 0.2181 0.2216 -0.1325 -0.1823 0.1101 0.00 3.4 0.01442 -0.02427 0.00298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265862.000 888527.0621 -4517278.5249 4399529.8125 2 9 0.1833 0.2168 0.2188 -0.1316 -0.1804 0.1089 0.00 3.5 0.03248 -0.01453 0.02172 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265863.000 888527.0660 -4517278.4785 4399529.7869 2 9 0.1822 0.2156 0.2160 -0.1308 -0.1786 0.1078 0.00 2.9 0.00439 0.00093 -0.02041 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265864.000 888527.0618 -4517278.4598 4399529.8026 2 9 0.1811 0.2145 0.2133 -0.1300 -0.1768 0.1067 0.00 2.6 0.07878 -0.11018 0.20076 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265865.000 888527.0648 -4517278.4008 4399529.7443 2 9 0.1801 0.2133 0.2106 -0.1292 -0.1751 0.1056 0.00 2.0 0.03328 0.15345 -0.14215 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265866.000 888527.0616 -4517278.3976 4399529.7703 2 9 0.1790 0.2122 0.2080 -0.1285 -0.1733 0.1046 0.00 1.9 -0.00721 -0.04939 0.05396 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265867.000 888527.0634 -4517278.3662 4399529.7588 2 9 0.1780 0.2111 0.2054 -0.1277 -0.1716 0.1036 0.00 1.8 -0.02588 -0.02530 0.07237 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265868.000 888527.0596 -4517278.3461 4399529.7596 2 9 0.1770 0.2100 0.2028 -0.1270 -0.1700 0.1026 0.00 1.6 0.00224 -0.04540 0.06254 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265869.000 888527.0494 -4517278.3207 4399529.7383 2 8 0.1762 0.2091 0.2007 -0.1265 -0.1686 0.1020 0.00 1.5 -0.00387 0.02154 0.00419 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265870.000 888527.0394 -4517278.2939 4399529.7428 2 8 0.1753 0.2080 0.1983 -0.1259 -0.1670 0.1011 0.00 1.3 0.00952 0.03924 0.03608 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265871.000 888527.0285 -4517278.2777 4399529.7444 2 8 0.1745 0.2070 0.1959 -0.1253 -0.1654 0.1003 0.00 1.1 0.02198 0.00339 0.03887 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265872.000 888527.0150 -4517278.2535 4399529.7402 2 8 0.1736 0.2059 0.1935 -0.1247 -0.1639 0.0995 0.00 1.0 0.01926 0.03663 0.01465 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265873.000 888527.0200 -4517278.2416 4399529.7528 2 9 0.1727 0.2049 0.1911 -0.1240 -0.1623 0.0986 0.00 1.1 -0.01495 0.01105 0.03766 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265874.000 888527.0277 -4517278.2101 4399529.7432 2 9 0.1718 0.2039 0.1886 -0.1234 -0.1607 0.0977 0.00 1.2 0.00830 0.01854 0.00917 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265875.000 888527.0297 -4517278.1983 4399529.7506 2 9 0.1709 0.2028 0.1862 -0.1228 -0.1591 0.0969 0.00 1.2 0.01539 -0.02863 0.03794 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265876.000 888527.0254 -4517278.1669 4399529.7403 2 9 0.1701 0.2018 0.1839 -0.1222 -0.1576 0.0960 0.00 1.3 -0.01500 0.01245 -0.05757 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265877.000 888527.0370 -4517278.1258 4399529.6881 2 8 0.1692 0.2010 0.1834 -0.1216 -0.1568 0.0953 0.00 1.3 0.05308 -0.04233 -0.03831 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265878.000 888527.0386 -4517278.1124 4399529.7026 2 8 0.1684 0.2000 0.1819 -0.1211 -0.1555 0.0946 0.00 1.3 -0.02777 -0.00639 0.01036 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265879.000 888527.0484 -4517278.0651 4399529.6529 2 8 0.1676 0.1990 0.1804 -0.1205 -0.1542 0.0940 0.00 1.3 0.00243 -0.05517 -0.00053 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265880.000 888527.0487 -4517278.0628 4399529.6908 2 7 0.1668 0.1987 0.1830 -0.1200 -0.1549 0.0935 0.00 1.2 -0.01248 -0.06384 0.05269 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265881.000 888527.0555 -4517278.0436 4399529.6859 2 7 0.1661 0.1983 0.1826 -0.1195 -0.1545 0.0930 0.00 1.5 -0.01701 0.02703 -0.05042 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265882.000 888527.0634 -4517278.0445 4399529.7038 2 7 0.1653 0.1979 0.1823 -0.1190 -0.1541 0.0924 0.00 1.6 0.01354 -0.05919 0.06469 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265883.000 888527.0736 -4517278.0304 4399529.6919 2 7 0.1646 0.1975 0.1819 -0.1185 -0.1538 0.0919 0.00 1.7 0.01145 0.01703 -0.03912 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265884.000 888527.0844 -4517277.9976 4399529.6802 2 7 0.1638 0.1970 0.1816 -0.1180 -0.1534 0.0913 0.00 2.3 0.03012 0.00244 0.03249 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265885.000 888527.0824 -4517278.0117 4399529.6974 2 8 0.1631 0.1966 0.1812 -0.1175 -0.1530 0.0908 0.00 2.4 -0.01412 -0.00191 0.03168 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265886.000 888527.0874 -4517278.0105 4399529.7125 2 7 0.1623 0.1962 0.1808 -0.1170 -0.1526 0.0903 0.00 2.3 0.00144 -0.04809 0.04808 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265887.000 888527.0968 -4517277.9977 4399529.7040 2 7 0.1616 0.1958 0.1804 -0.1165 -0.1523 0.0897 0.00 2.5 0.00279 0.03290 -0.01640 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265888.000 888527.1062 -4517277.9959 4399529.7126 2 7 0.1609 0.1954 0.1799 -0.1160 -0.1519 0.0892 0.00 2.7 0.03834 0.04357 -0.03413 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265889.000 888527.1112 -4517278.0023 4399529.7326 2 7 0.1602 0.1950 0.1795 -0.1155 -0.1515 0.0887 0.00 2.6 0.01458 -0.05425 0.06754 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265890.000 888527.1146 -4517277.9914 4399529.7355 2 7 0.1595 0.1945 0.1791 -0.1150 -0.1511 0.0881 0.00 2.6 0.00413 0.00066 0.00591 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265891.000 888527.1214 -4517277.9879 4399529.7386 2 8 0.1588 0.1941 0.1786 -0.1145 -0.1506 0.0876 0.00 2.7 -0.00542 -0.01229 0.01896 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265892.000 888527.1339 -4517277.9862 4399529.7396 2 7 0.1584 0.1938 0.1780 -0.1144 -0.1501 0.0871 0.00 1.1 0.01762 0.00809 0.01275 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265893.000 888527.1464 -4517277.9988 4399529.7626 2 7 0.1580 0.1936 0.1779 -0.1142 -0.1499 0.0869 0.00 1.0 0.03704 0.02451 -0.02707 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265894.000 888527.1565 -4517277.9864 4399529.7297 2 7 0.1576 0.1934 0.1777 -0.1141 -0.1498 0.0867 0.00 1.1 -0.00829 0.01680 -0.05292 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265895.000 888527.1626 -4517277.9932 4399529.7572 2 7 0.1572 0.1932 0.1776 -0.1139 -0.1496 0.0865 0.00 1.3 0.00064 -0.00396 0.02878 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265896.000 888527.1725 -4517278.0028 4399529.7632 2 7 0.1568 0.1929 0.1775 -0.1138 -0.1495 0.0863 0.00 1.4 -0.01361 -0.01926 0.00100 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265897.000 888527.1863 -4517277.9990 4399529.7637 2 7 0.1564 0.1927 0.1774 -0.1136 -0.1493 0.0861 0.00 1.5 0.00594 -0.09185 0.10068 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265898.000 888527.1912 -4517277.9890 4399529.7523 2 7 0.1560 0.1925 0.1773 -0.1134 -0.1492 0.0859 0.00 1.4 -0.10030 0.05648 -0.12399 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265899.000 888527.2080 -4517278.0026 4399529.7881 2 7 0.1557 0.1922 0.1772 -0.1132 -0.1490 0.0857 0.00 1.4 0.04537 -0.02093 0.09375 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265900.000 888527.2174 -4517277.9978 4399529.7840 2 7 0.1553 0.1920 0.1771 -0.1131 -0.1489 0.0855 0.00 1.4 0.00630 -0.05289 0.10853 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265901.000 888527.2043 -4517277.9844 4399529.7585 2 6 0.1551 0.1923 0.1792 -0.1133 -0.1501 0.0864 0.00 1.5 -0.00768 -0.01535 0.04192 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265902.000 888527.2110 -4517277.9819 4399529.7471 2 6 0.1547 0.1922 0.1791 -0.1133 -0.1500 0.0863 0.00 1.5 -0.00801 -0.02237 0.03640 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265903.000 888527.2245 -4517277.9797 4399529.7559 2 6 0.1544 0.1920 0.1791 -0.1132 -0.1499 0.0862 0.00 1.5 0.00434 0.03445 -0.00897 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265904.000 888527.2215 -4517277.9705 4399529.7453 2 6 0.1541 0.1919 0.1790 -0.1131 -0.1498 0.0862 0.00 1.5 0.01344 0.00082 0.01245 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265905.000 888527.2304 -4517277.9706 4399529.7491 2 7 0.1538 0.1917 0.1789 -0.1130 -0.1497 0.0860 0.00 1.5 -0.01891 -0.00830 -0.01339 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265906.000 888527.2413 -4517277.9705 4399529.7390 2 6 0.1535 0.1916 0.1788 -0.1129 -0.1497 0.0859 0.00 1.5 -0.00947 -0.03371 0.01406 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265907.000 888527.2469 -4517277.9676 4399529.7543 2 6 0.1532 0.1915 0.1788 -0.1128 -0.1496 0.0858 0.00 1.3 0.00315 -0.06737 0.06141 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265908.000 888527.2570 -4517277.9696 4399529.7517 2 6 0.1529 0.1913 0.1787 -0.1127 -0.1495 0.0857 0.00 1.2 -0.01969 0.00520 -0.00191 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265909.000 888527.2725 -4517277.9751 4399529.7898 2 7 0.1525 0.1912 0.1786 -0.1126 -0.1494 0.0856 0.00 1.1 -0.01106 0.01218 0.00343 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265910.000 888527.2790 -4517277.9714 4399529.7821 2 7 0.1522 0.1909 0.1775 -0.1124 -0.1488 0.0851 0.00 1.0 -0.00090 0.01450 -0.01334 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265911.000 888527.2885 -4517277.9711 4399529.7864 2 6 0.1518 0.1907 0.1779 -0.1123 -0.1487 0.0846 0.00 1.1 -0.02682 0.05415 -0.08346 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265912.000 888527.2870 -4517277.9597 4399529.7680 2 4 0.1517 0.1907 0.1787 -0.1123 -0.1491 0.0850 0.00 1.2 -0.01067 -0.00940 -0.00514 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265913.000 888527.2999 -4517277.9606 4399529.7779 2 4 0.1514 0.1906 0.1786 -0.1123 -0.1490 0.0849 0.00 1.3 0.00038 0.00658 -0.01305 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265914.000 888527.3048 -4517277.9576 4399529.7820 2 4 0.1512 0.1904 0.1786 -0.1122 -0.1489 0.0848 0.00 1.4 0.01074 0.03094 0.00289 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265915.000 888527.2976 -4517277.9480 4399529.7895 2 8 0.1505 0.1901 0.1785 -0.1118 -0.1487 0.0844 0.00 1.6 0.01388 0.02072 -0.00768 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265916.000 888527.3057 -4517277.9421 4399529.7759 2 8 0.1498 0.1897 0.1774 -0.1112 -0.1481 0.0838 0.00 1.1 -0.02986 0.01248 -0.02644 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265917.000 888527.2974 -4517277.9398 4399529.7919 2 7 0.1493 0.1894 0.1782 -0.1108 -0.1482 0.0837 0.00 1.3 0.03300 -0.02937 0.06687 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265918.000 888527.2889 -4517277.9217 4399529.7757 2 7 0.1488 0.1891 0.1781 -0.1105 -0.1480 0.0834 0.00 1.1 0.00788 -0.02218 0.02759 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265919.000 888527.2915 -4517277.9152 4399529.7707 2 7 0.1482 0.1888 0.1780 -0.1101 -0.1478 0.0832 0.00 1.1 -0.01618 0.00975 0.00170 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265920.000 888527.2940 -4517277.8973 4399529.7610 2 7 0.1478 0.1886 0.1779 -0.1098 -0.1477 0.0829 0.00 1.2 -0.00040 0.01842 -0.02272 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265921.000 888527.2941 -4517277.8974 4399529.7657 2 8 0.1472 0.1883 0.1778 -0.1095 -0.1475 0.0826 0.00 1.1 -0.01333 0.01644 0.03925 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265922.000 888527.2908 -4517277.8828 4399529.7573 2 8 0.1467 0.1880 0.1768 -0.1091 -0.1470 0.0822 0.00 1.2 0.02847 0.00444 0.02787 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265923.000 888527.2873 -4517277.8746 4399529.7469 2 7 0.1463 0.1878 0.1764 -0.1086 -0.1467 0.0818 0.00 1.5 -0.01798 -0.00772 -0.01752 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265924.000 888527.2750 -4517277.8672 4399529.7517 2 4 0.1461 0.1877 0.1778 -0.1083 -0.1471 0.0819 0.00 1.6 -0.00016 -0.00414 0.00850 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265925.000 888527.2663 -4517277.8569 4399529.7395 2 4 0.1458 0.1874 0.1778 -0.1080 -0.1469 0.0817 0.00 1.8 -0.03024 0.00926 -0.01693 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265926.000 888527.2496 -4517277.8417 4399529.7227 2 4 0.1455 0.1872 0.1778 -0.1077 -0.1468 0.0815 0.00 1.9 0.01092 -0.03487 0.01212 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265927.000 888527.2466 -4517277.8428 4399529.7361 2 4 0.1452 0.1870 0.1778 -0.1075 -0.1467 0.0813 0.00 2.0 -0.05052 0.00728 -0.00925 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265947.000 888522.8130 -4517276.1687 4399527.3682 2 4 2.3338 0.8975 1.2613 -1.4343 -1.0573 1.7074 0.00 0.0 0.02251 0.02505 -0.01904 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265948.000 888526.7535 -4517277.6459 4399529.4763 2 4 1.7153 0.6716 0.9353 -1.0561 -0.7837 1.2554 0.00 0.0 -0.00712 0.01008 -0.03277 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265949.000 888527.5433 -4517277.9431 4399529.8969 2 4 1.4199 0.5657 0.7811 -0.8757 -0.6541 1.0397 0.00 0.0 -0.00355 -0.01643 0.01528 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265950.000 888528.3489 -4517278.2477 4399530.3327 2 4 1.2384 0.5017 0.6871 -0.7651 -0.5752 0.9072 0.00 0.0 -0.00912 -0.02248 0.03481 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265951.000 888528.7873 -4517278.4119 4399530.5683 2 6 1.8688 0.7259 1.0140 -1.1488 -0.8497 1.3662 0.00 0.0 -0.00339 -0.01434 -0.00797 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265952.000 888529.4880 -4517278.6767 4399530.9493 2 4 1.5031 0.5942 0.8229 -0.9256 -0.6892 1.0994 0.00 0.0 -0.00340 0.01373 0.02214 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265953.000 888529.3113 -4517278.6078 4399530.8550 2 6 1.2561 0.5069 0.6952 -0.7751 -0.5818 0.9193 0.00 0.0 0.01472 -0.02006 0.04066 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265954.000 888529.3785 -4517278.6325 4399530.8855 2 6 1.1014 0.4532 0.6160 -0.6811 -0.5152 0.8066 0.00 0.0 0.00026 -0.01738 0.00846 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265955.000 888529.4933 -4517278.6766 4399530.9492 2 7 0.9677 0.4076 0.5477 -0.5997 -0.4578 0.7088 0.00 0.0 -0.01249 0.02063 -0.05187 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265956.000 888529.4760 -4517278.6677 4399530.9539 2 6 0.8916 0.3823 0.5097 -0.5537 -0.4257 0.6534 0.00 0.0 -0.03447 0.03257 -0.05945 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265957.000 888529.5180 -4517278.6798 4399530.9557 2 6 0.8310 0.3625 0.4797 -0.5171 -0.4004 0.6094 0.00 0.0 -0.01495 0.02326 -0.00823 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265958.000 888529.5063 -4517278.6711 4399530.9553 2 6 0.7813 0.3465 0.4553 -0.4871 -0.3798 0.5733 0.00 0.0 0.00664 -0.01654 0.05678 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265959.000 888529.5675 -4517278.6932 4399530.9826 2 4 0.7467 0.3356 0.4386 -0.4663 -0.3656 0.5481 0.00 0.0 0.01318 -0.02045 0.03830 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265960.000 888529.5833 -4517278.6971 4399531.0046 2 4 0.7164 0.3261 0.4239 -0.4481 -0.3533 0.5261 0.00 0.0 0.02112 -0.02435 0.07437 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265961.000 888529.5004 -4517278.6636 4399530.9458 2 6 0.6768 0.3137 0.4046 -0.4242 -0.3370 0.4970 0.00 1.1 0.03646 -0.00790 0.07995 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265962.000 888529.4267 -4517278.6293 4399530.8992 2 6 0.6439 0.3035 0.3884 -0.4044 -0.3234 0.4729 0.00 1.0 -0.00276 -0.00938 0.03945 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265963.000 888529.3313 -4517278.5961 4399530.8601 2 6 0.6154 0.2948 0.3747 -0.3872 -0.3118 0.4519 0.00 1.1 -0.00051 -0.03979 0.03680 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265964.000 888529.2680 -4517278.5741 4399530.8176 2 6 0.5903 0.2873 0.3627 -0.3722 -0.3018 0.4336 0.00 1.1 -0.00096 0.04235 -0.03646 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265965.000 888529.1899 -4517278.5434 4399530.7770 2 6 0.5682 0.2808 0.3523 -0.3589 -0.2929 0.4173 0.00 1.1 0.00176 0.00132 0.04174 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265966.000 888529.1786 -4517278.5345 4399530.7610 2 7 0.5437 0.2739 0.3406 -0.3445 -0.2833 0.3992 0.00 1.1 -0.02261 0.07399 -0.13636 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265967.000 888529.1602 -4517278.5268 4399530.7735 2 7 0.5234 0.2681 0.3308 -0.3325 -0.2753 0.3842 0.00 1.1 0.00478 0.04008 0.04549 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265968.000 888529.1412 -4517278.5168 4399530.7383 2 5 0.5101 0.2646 0.3247 -0.3248 -0.2704 0.3745 0.00 1.2 0.01167 0.03777 -0.02480 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265969.000 888529.0747 -4517278.4875 4399530.7016 2 5 0.4967 0.2611 0.3196 -0.3171 -0.2656 0.3648 0.00 1.1 0.00532 -0.02814 0.14031 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265970.000 888529.0386 -4517278.4780 4399530.6922 2 4 0.4876 0.2586 0.3157 -0.3117 -0.2622 0.3582 0.00 1.0 -0.00937 -0.01798 -0.02506 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265971.000 888528.9550 -4517278.4439 4399530.6447 2 6 0.4748 0.2551 0.3100 -0.3041 -0.2573 0.3488 0.00 1.2 0.00187 -0.08778 0.02104 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265972.000 888528.9097 -4517278.4257 4399530.6207 2 6 0.4631 0.2518 0.3044 -0.2971 -0.2527 0.3402 0.00 1.2 0.00915 -0.02217 0.03351 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265973.000 888528.8892 -4517278.4155 4399530.6060 2 7 0.4497 0.2483 0.2982 -0.2893 -0.2476 0.3302 0.00 1.1 0.01598 -0.01009 -0.04339 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265974.000 888528.8754 -4517278.4104 4399530.6221 2 7 0.4382 0.2452 0.2926 -0.2826 -0.2432 0.3216 0.00 1.1 -0.04206 0.11428 -0.07934 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265975.000 888528.8600 -4517278.4076 4399530.6095 2 5 0.4298 0.2432 0.2900 -0.2779 -0.2406 0.3156 0.00 2.5 0.00295 0.00650 -0.09662 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265976.000 888528.8681 -4517278.4067 4399530.6119 2 5 0.4224 0.2414 0.2861 -0.2736 -0.2377 0.3101 0.00 1.3 -0.01395 0.06147 -0.08106 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265977.000 888528.8879 -4517278.4198 4399530.6324 2 5 0.4154 0.2396 0.2828 -0.2697 -0.2352 0.3049 0.00 1.2 0.02528 0.02999 0.00744 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265978.000 888528.8931 -4517278.4179 4399530.6345 2 5 0.4087 0.2379 0.2798 -0.2659 -0.2327 0.3000 0.00 1.4 0.04439 0.02705 0.00449 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265979.000 888528.9019 -4517278.4266 4399530.6628 2 5 0.4024 0.2364 0.2770 -0.2623 -0.2305 0.2953 0.00 1.7 -0.00261 0.00246 0.00804 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265980.000 888528.9173 -4517278.4283 4399530.6449 2 5 0.3964 0.2349 0.2743 -0.2589 -0.2283 0.2909 0.00 1.8 -0.00607 -0.00361 -0.00056 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265981.000 888528.9265 -4517278.4404 4399530.6914 2 5 0.3906 0.2334 0.2718 -0.2556 -0.2262 0.2866 0.00 2.0 0.01227 0.05134 0.00843 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265982.000 888528.9381 -4517278.4398 4399530.6812 2 5 0.3851 0.2321 0.2694 -0.2525 -0.2243 0.2826 0.00 1.9 0.00837 0.03108 -0.02613 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265983.000 888528.9406 -4517278.4392 4399530.6895 2 5 0.3798 0.2308 0.2672 -0.2495 -0.2224 0.2787 0.00 1.5 -0.01320 0.00050 -0.00182 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265984.000 888528.9544 -4517278.4503 4399530.7150 2 5 0.3748 0.2296 0.2650 -0.2466 -0.2206 0.2749 0.00 1.0 0.00699 0.00857 0.05794 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265985.000 888528.9518 -4517278.4461 4399530.7092 2 5 0.3699 0.2284 0.2629 -0.2439 -0.2189 0.2713 0.00 1.2 0.00916 -0.02740 -0.02188 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265986.000 888528.9490 -4517278.4456 4399530.7062 2 5 0.3652 0.2272 0.2609 -0.2413 -0.2173 0.2679 0.00 1.4 -0.02428 0.02157 -0.04200 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265987.000 888528.9556 -4517278.4466 4399530.6965 2 5 0.3607 0.2261 0.2590 -0.2387 -0.2157 0.2646 0.00 1.4 -0.01568 -0.01024 -0.00026 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265988.000 888528.9462 -4517278.4460 4399530.7102 2 4 0.3573 0.2254 0.2595 -0.2368 -0.2151 0.2623 0.00 1.2 0.00861 0.00946 -0.02390 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265989.000 888528.9181 -4517278.4378 4399530.6974 2 4 0.3539 0.2245 0.2583 -0.2349 -0.2139 0.2599 0.00 1.2 -0.01133 -0.09237 0.13846 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265991.000 888528.7933 -4517278.3891 4399530.6116 2 6 1.8656 0.7179 1.0056 -1.1420 -0.8417 1.3593 0.00 0.0 -0.00511 0.01623 -0.04400 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265992.000 888528.7756 -4517278.3878 4399530.6232 2 6 1.3884 0.5472 0.7573 -0.8517 -0.6333 1.0117 0.00 0.0 -0.02812 0.00172 -0.05013 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265993.000 888528.5494 -4517278.3038 4399530.4936 2 6 1.1347 0.4588 0.6272 -0.6976 -0.5239 0.8269 0.00 0.0 -0.03170 -0.00138 -0.06286 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265994.000 888528.2669 -4517278.2092 4399530.3684 2 6 0.9962 0.4116 0.5569 -0.6137 -0.4648 0.7260 0.00 0.0 0.00298 -0.07126 0.07257 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265995.000 888528.4148 -4517278.2594 4399530.4267 2 6 0.8986 0.3790 0.5078 -0.5547 -0.4235 0.6549 0.00 0.0 0.04712 -0.06747 0.07985 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265996.000 888528.4887 -4517278.2886 4399530.4706 2 6 0.8250 0.3549 0.4713 -0.5103 -0.3927 0.6014 0.00 0.0 -0.00064 0.03818 -0.07172 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265997.000 888528.5339 -4517278.3133 4399530.5128 2 6 0.7671 0.3363 0.4428 -0.4754 -0.3687 0.5591 0.00 0.0 0.00849 -0.00394 0.03627 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265998.000 888528.5365 -4517278.3122 4399530.5150 2 6 0.7199 0.3213 0.4198 -0.4470 -0.3493 0.5247 0.00 0.0 0.00385 -0.02858 0.01193 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 265999.000 888528.5389 -4517278.3184 4399530.5153 2 6 0.6804 0.3091 0.4008 -0.4233 -0.3332 0.4960 0.00 1.0 -0.00093 -0.06675 0.10112 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266000.000 888528.5554 -4517278.3242 4399530.5227 2 6 0.6469 0.2988 0.3848 -0.4032 -0.3196 0.4716 0.00 1.0 0.00288 0.02614 0.01980 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266001.000 888528.4451 -4517278.2828 4399530.4588 2 4 0.6269 0.2931 0.3763 -0.3915 -0.3122 0.4574 0.00 1.0 0.01560 0.00073 0.03876 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266002.000 888528.3394 -4517278.2425 4399530.4010 2 4 0.6086 0.2877 0.3679 -0.3807 -0.3050 0.4442 0.00 1.0 0.01263 0.01273 -0.02622 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266003.000 888528.2423 -4517278.2179 4399530.3677 2 4 0.5919 0.2828 0.3602 -0.3708 -0.2985 0.4321 0.00 1.0 0.05569 -0.00483 0.12155 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266004.000 888528.1662 -4517278.1792 4399530.3127 2 4 0.5765 0.2783 0.3532 -0.3617 -0.2925 0.4210 0.00 1.0 -0.01607 0.00926 -0.03363 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266005.000 888528.1766 -4517278.1864 4399530.3080 2 6 0.5549 0.2720 0.3433 -0.3488 -0.2841 0.4053 0.00 1.0 0.01172 0.01958 -0.09746 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266006.000 888528.0964 -4517278.1487 4399530.2718 2 4 0.5422 0.2684 0.3376 -0.3413 -0.2792 0.3961 0.00 1.0 0.00771 -0.01574 0.07850 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266007.000 888528.0340 -4517278.1349 4399530.2446 2 4 0.5303 0.2651 0.3323 -0.3343 -0.2747 0.3876 0.00 1.0 0.00988 0.00269 0.01744 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266008.000 888527.9836 -4517278.1201 4399530.2214 2 4 0.5191 0.2620 0.3274 -0.3278 -0.2705 0.3795 0.00 1.0 0.02004 -0.02600 0.09131 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266009.000 888527.9205 -4517278.0942 4399530.1814 2 4 0.5087 0.2590 0.3229 -0.3216 -0.2666 0.3720 0.00 1.1 0.02038 -0.02044 0.10295 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266010.000 888527.8716 -4517278.0763 4399530.1487 2 4 0.4988 0.2563 0.3186 -0.3159 -0.2629 0.3649 0.00 1.0 -0.00630 0.00301 0.00035 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266011.000 888527.8256 -4517278.0636 4399530.1329 2 4 0.4896 0.2538 0.3145 -0.3105 -0.2594 0.3583 0.00 1.0 0.01208 -0.06964 0.11135 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266012.000 888527.7946 -4517278.0535 4399530.1137 2 4 0.4808 0.2514 0.3108 -0.3053 -0.2562 0.3519 0.00 1.0 -0.02606 0.03133 -0.07022 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266013.000 888527.7547 -4517278.0366 4399530.0972 2 4 0.4725 0.2492 0.3072 -0.3005 -0.2531 0.3460 0.00 1.1 -0.03509 0.00304 -0.07754 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266014.000 888527.7336 -4517278.0315 4399530.0962 2 4 0.4646 0.2470 0.3039 -0.2959 -0.2502 0.3403 0.00 1.1 0.03876 -0.05708 0.05044 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266015.000 888527.7044 -4517278.0216 4399530.0814 2 4 0.4570 0.2450 0.3007 -0.2915 -0.2474 0.3349 0.00 1.1 0.01244 0.00149 0.01048 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266016.000 888527.6763 -4517278.0105 4399530.0604 2 4 0.4499 0.2431 0.2977 -0.2873 -0.2448 0.3298 0.00 1.1 0.00601 0.01420 0.01555 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266017.000 888527.0229 -4517277.7304 4399529.7251 2 7 0.4316 0.2377 0.2897 -0.2759 -0.2376 0.3163 0.00 1.0 -0.02565 -0.01005 0.00208 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266018.000 888527.1425 -4517277.7752 4399529.7846 2 6 0.4227 0.2353 0.2855 -0.2707 -0.2341 0.3097 0.00 1.0 0.01020 -0.00436 0.02988 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266019.000 888527.2451 -4517277.8146 4399529.8478 2 6 0.4144 0.2331 0.2818 -0.2658 -0.2310 0.3036 0.00 1.0 -0.00672 -0.05657 0.12707 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266020.000 888527.3115 -4517277.8502 4399529.8920 2 6 0.4066 0.2310 0.2784 -0.2612 -0.2281 0.2978 0.00 1.1 0.03669 0.00070 0.00122 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266021.000 888527.2896 -4517277.8436 4399529.8814 2 4 0.4016 0.2299 0.2771 -0.2584 -0.2267 0.2944 0.00 1.1 -0.02138 -0.07879 0.10907 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266022.000 888527.2962 -4517277.8467 4399529.8765 2 4 0.3967 0.2287 0.2751 -0.2556 -0.2250 0.2909 0.00 1.1 -0.03283 0.09549 -0.12176 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266023.000 888527.2915 -4517277.8421 4399529.8665 2 4 0.3920 0.2275 0.2733 -0.2530 -0.2234 0.2876 0.00 1.1 -0.00439 0.02773 0.00374 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266024.000 888527.2843 -4517277.8422 4399529.8601 2 4 0.3875 0.2264 0.2715 -0.2504 -0.2218 0.2844 0.00 1.1 -0.00060 0.00714 0.07248 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266025.000 888527.2746 -4517277.8370 4399529.8518 2 4 0.3832 0.2253 0.2698 -0.2479 -0.2203 0.2812 0.00 1.1 -0.00345 0.04715 -0.05801 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266026.000 888527.2836 -4517277.8413 4399529.8531 2 4 0.3790 0.2242 0.2681 -0.2455 -0.2189 0.2782 0.00 1.1 0.01758 0.05771 -0.04949 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266027.000 888527.2704 -4517277.8378 4399529.8478 2 4 0.3749 0.2232 0.2665 -0.2432 -0.2175 0.2753 0.00 1.1 0.02033 0.05167 0.01260 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266028.000 888527.2763 -4517277.8419 4399529.8579 2 4 0.3709 0.2222 0.2650 -0.2409 -0.2161 0.2725 0.00 1.1 0.02306 0.00531 -0.08544 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266029.000 888527.2634 -4517277.8384 4399529.8528 2 4 0.3671 0.2213 0.2635 -0.2388 -0.2148 0.2698 0.00 1.0 0.01461 -0.05190 0.06947 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266030.000 888527.2746 -4517277.8431 4399529.8613 2 4 0.3634 0.2204 0.2621 -0.2367 -0.2135 0.2671 0.00 1.0 0.01588 0.05701 -0.04037 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266031.000 888527.2751 -4517277.8465 4399529.8665 2 4 0.3598 0.2195 0.2607 -0.2346 -0.2123 0.2646 0.00 1.0 0.00113 -0.00421 -0.01688 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266032.000 888527.2763 -4517277.8450 4399529.8485 2 4 0.3564 0.2186 0.2594 -0.2327 -0.2111 0.2621 0.00 1.0 -0.01257 0.02612 -0.01744 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266033.000 888527.2713 -4517277.8430 4399529.8519 2 4 0.3530 0.2178 0.2581 -0.2307 -0.2100 0.2597 0.00 1.0 0.01839 -0.07275 0.04963 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266034.000 888527.2803 -4517277.8510 4399529.8595 2 4 0.3497 0.2170 0.2569 -0.2289 -0.2089 0.2573 0.00 1.0 -0.01523 -0.00899 -0.02386 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266035.000 888527.2776 -4517277.8479 4399529.8368 2 4 0.3465 0.2162 0.2557 -0.2271 -0.2078 0.2550 0.00 1.0 -0.03273 0.01500 0.00699 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266036.000 888527.2874 -4517277.8521 4399529.8469 2 4 0.3434 0.2155 0.2545 -0.2253 -0.2068 0.2528 0.00 1.0 0.06260 -0.04033 0.05856 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266037.000 888527.2897 -4517277.8540 4399529.8431 2 4 0.3404 0.2147 0.2534 -0.2236 -0.2058 0.2506 0.00 1.1 -0.01772 0.09586 -0.08420 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266038.000 888527.2718 -4517277.8476 4399529.8358 2 4 0.3375 0.2140 0.2523 -0.2220 -0.2048 0.2485 0.00 1.1 -0.00369 -0.04848 0.01142 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266039.000 888527.2749 -4517277.8500 4399529.8412 2 4 0.3346 0.2133 0.2512 -0.2204 -0.2038 0.2465 0.00 1.1 0.00193 -0.01510 0.01348 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266043.000 888531.8795 -4517279.5542 4399532.2703 2 6 1.8617 0.7081 0.9948 -1.1337 -0.8316 1.3504 0.00 0.0 0.00551 -0.03216 0.03652 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266044.000 888531.8633 -4517279.5502 4399532.2677 2 6 1.3858 0.5393 0.7494 -0.8455 -0.6255 1.0052 0.00 0.0 -0.02218 -0.00031 0.01997 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266045.000 888531.4577 -4517279.4053 4399532.0602 2 6 1.1526 0.4584 0.6306 -0.7046 -0.5257 0.8360 0.00 0.0 0.00188 -0.03247 0.06829 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266046.000 888531.5048 -4517279.4270 4399532.1013 2 6 1.0078 0.4093 0.5576 -0.6173 -0.4643 0.7310 0.00 0.0 0.07862 -0.06833 0.20934 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266047.000 888527.8544 -4517278.0785 4399530.1642 2 4 2.3268 0.8755 1.2368 -1.4157 -1.0343 1.6880 0.00 0.0 0.00182 0.03308 0.03289 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266048.000 888527.5074 -4517277.9541 4399529.9824 2 4 1.7104 0.6542 0.9173 -1.0423 -0.7663 1.2412 0.00 0.0 -0.01002 0.03221 0.01760 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266049.000 888527.4272 -4517277.9229 4399529.9459 2 4 1.4159 0.5502 0.7660 -0.8641 -0.6392 1.0278 0.00 0.0 0.01635 -0.03952 0.07916 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266050.000 888527.6618 -4517278.0090 4399530.0548 2 4 1.2349 0.4873 0.6739 -0.7549 -0.5618 0.8967 0.00 0.0 0.01468 0.02841 -0.01534 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266051.000 888527.7319 -4517278.0339 4399530.0939 2 4 1.1094 0.4442 0.6105 -0.6792 -0.5084 0.8058 0.00 0.0 -0.00320 0.01094 0.00909 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266052.000 888527.9174 -4517278.1084 4399530.1986 2 4 1.0158 0.4126 0.5637 -0.6228 -0.4689 0.7381 0.00 0.0 0.02242 0.02268 -0.00517 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266053.000 888528.0182 -4517278.1448 4399530.2473 2 4 0.9425 0.3882 0.5273 -0.5788 -0.4382 0.6850 0.00 0.0 0.04310 0.01550 0.01805 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266054.000 888528.0277 -4517278.1478 4399530.2507 2 4 0.8832 0.3687 0.4980 -0.5432 -0.4135 0.6421 0.00 0.0 0.01620 -0.00469 -0.00734 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266055.000 888528.0610 -4517278.1627 4399530.2652 2 4 0.8338 0.3526 0.4739 -0.5136 -0.3931 0.6064 0.00 0.0 0.03166 -0.06178 0.04308 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266056.000 888528.0660 -4517278.1624 4399530.2679 2 4 0.7919 0.3392 0.4536 -0.4885 -0.3759 0.5761 0.00 0.0 -0.01235 -0.04756 0.03311 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266057.000 888528.0416 -4517278.1517 4399530.2514 2 4 0.7558 0.3277 0.4362 -0.4669 -0.3612 0.5500 0.00 0.0 -0.02243 0.03117 -0.07108 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266058.000 888528.0058 -4517278.1395 4399530.2288 2 4 0.7242 0.3178 0.4211 -0.4481 -0.3484 0.5271 0.00 0.0 0.03203 -0.03445 0.05178 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266059.000 888527.9853 -4517278.1293 4399530.2150 2 4 0.6963 0.3092 0.4079 -0.4314 -0.3371 0.5070 0.00 1.0 -0.00025 -0.00324 -0.00479 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266060.000 888527.9768 -4517278.1259 4399530.2047 2 4 0.6714 0.3015 0.3962 -0.4166 -0.3271 0.4890 0.00 1.1 -0.03201 -0.03195 0.06020 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266061.000 888528.2703 -4517278.2359 4399530.3613 2 6 0.6354 0.2904 0.3790 -0.3950 -0.3125 0.4627 0.00 1.0 -0.01473 -0.06561 -0.00552 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266062.000 888528.4170 -4517278.2926 4399530.4430 2 6 0.6078 0.2820 0.3656 -0.3785 -0.3013 0.4425 0.00 1.0 -0.00163 0.01886 -0.05507 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266063.000 888528.5919 -4517278.3569 4399530.5214 2 6 0.5835 0.2748 0.3542 -0.3640 -0.2916 0.4247 0.00 1.1 -0.03721 0.02331 -0.06557 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266064.000 888528.7220 -4517278.4040 4399530.5942 2 6 0.5619 0.2684 0.3442 -0.3511 -0.2831 0.4090 0.00 1.1 0.01510 -0.01271 0.02582 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266065.000 888528.8434 -4517278.4615 4399530.6741 2 6 0.5426 0.2628 0.3353 -0.3396 -0.2755 0.3949 0.00 1.0 0.04587 -0.00317 0.05921 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266066.000 888528.9511 -4517278.4998 4399530.7220 2 6 0.5251 0.2578 0.3273 -0.3293 -0.2687 0.3822 0.00 1.1 0.02379 -0.04911 0.04149 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266067.000 888529.0624 -4517278.5468 4399530.8053 2 6 0.5093 0.2532 0.3201 -0.3199 -0.2625 0.3706 0.00 1.0 -0.00296 -0.02462 0.10463 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266068.000 888529.1622 -4517278.5888 4399530.8457 2 6 0.4948 0.2492 0.3136 -0.3113 -0.2569 0.3600 0.00 1.1 -0.02144 -0.01286 -0.03101 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266069.000 888529.2514 -4517278.6205 4399530.8952 2 6 0.4815 0.2454 0.3077 -0.3034 -0.2518 0.3503 0.00 1.0 -0.00474 -0.08523 0.01817 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266070.000 888529.3386 -4517278.6495 4399530.9338 2 6 0.4692 0.2421 0.3023 -0.2962 -0.2472 0.3413 0.00 1.1 -0.01170 0.05333 -0.00298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266071.000 888529.4117 -4517278.6806 4399530.9828 2 6 0.4578 0.2389 0.2973 -0.2895 -0.2429 0.3330 0.00 1.1 -0.00537 -0.03368 -0.01424 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266072.000 888529.4901 -4517278.7138 4399531.0263 2 6 0.4472 0.2361 0.2927 -0.2832 -0.2389 0.3253 0.00 1.0 0.03241 0.00762 0.05089 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266073.000 888529.5504 -4517278.7405 4399531.0703 2 6 0.4373 0.2334 0.2885 -0.2774 -0.2352 0.3180 0.00 1.1 0.02901 -0.05396 0.08749 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266074.000 888529.6063 -4517278.7593 4399531.0902 2 6 0.4281 0.2309 0.2845 -0.2720 -0.2318 0.3113 0.00 1.1 -0.00350 0.00811 0.00722 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266075.000 888529.6597 -4517278.7836 4399531.1246 2 6 0.4194 0.2286 0.2808 -0.2669 -0.2286 0.3049 0.00 1.0 0.03003 -0.04469 0.06410 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266076.000 888529.7064 -4517278.7964 4399531.1381 2 6 0.4112 0.2265 0.2774 -0.2621 -0.2256 0.2989 0.00 1.1 -0.00929 0.01398 -0.01329 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266077.000 888529.7406 -4517278.8082 4399531.1611 2 6 0.4035 0.2244 0.2742 -0.2575 -0.2227 0.2933 0.00 1.2 -0.03487 0.09771 -0.09165 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266078.000 888529.7933 -4517278.8376 4399531.1958 2 6 0.3962 0.2225 0.2711 -0.2533 -0.2201 0.2880 0.00 1.1 -0.02077 -0.03057 -0.00557 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266079.000 888529.8364 -4517278.8542 4399531.2209 2 6 0.3893 0.2207 0.2683 -0.2492 -0.2176 0.2829 0.00 1.0 0.01640 0.02078 -0.00368 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266080.000 888529.8765 -4517278.8650 4399531.2304 2 6 0.3827 0.2191 0.2656 -0.2454 -0.2152 0.2781 0.00 1.0 0.01903 -0.00323 0.00581 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266081.000 888529.9043 -4517278.8767 4399531.2481 2 6 0.3765 0.2175 0.2630 -0.2418 -0.2130 0.2735 0.00 1.1 0.03933 -0.02129 0.05625 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266082.000 888529.9445 -4517278.8888 4399531.2679 2 6 0.3706 0.2159 0.2606 -0.2383 -0.2108 0.2692 0.00 1.2 0.00960 -0.00578 0.02018 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266083.000 888529.9758 -4517278.8905 4399531.2741 2 6 0.3649 0.2145 0.2584 -0.2350 -0.2088 0.2650 0.00 1.2 0.02255 0.01901 0.05941 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266084.000 888530.0152 -4517278.9207 4399531.3140 2 6 0.3595 0.2131 0.2562 -0.2318 -0.2069 0.2611 0.00 1.1 -0.00499 -0.02274 -0.06660 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266085.000 888530.0504 -4517278.9176 4399531.3122 2 6 0.3543 0.2118 0.2541 -0.2288 -0.2050 0.2573 0.00 1.0 0.04196 -0.02006 -0.01829 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266086.000 888530.0202 -4517278.9227 4399531.3166 2 4 0.3511 0.2113 0.2541 -0.2272 -0.2046 0.2554 0.00 1.1 -0.00178 -0.05154 0.03879 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266087.000 888529.9936 -4517278.9142 4399531.3149 2 4 0.3478 0.2105 0.2529 -0.2253 -0.2036 0.2531 0.00 1.2 0.02605 -0.01361 0.08691 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266088.000 888529.9720 -4517278.9033 4399531.2887 2 4 0.3447 0.2098 0.2517 -0.2236 -0.2025 0.2508 0.00 1.2 -0.00994 0.02816 0.04324 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266089.000 888529.9447 -4517278.8950 4399531.2804 2 4 0.3416 0.2090 0.2506 -0.2218 -0.2015 0.2487 0.00 1.2 -0.00026 0.01641 -0.00444 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266090.000 888529.9243 -4517278.8887 4399531.2615 2 4 0.3386 0.2083 0.2495 -0.2202 -0.2005 0.2465 0.00 1.1 0.03568 -0.00622 0.01883 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266091.000 888529.9022 -4517278.8805 4399531.2550 2 4 0.3357 0.2076 0.2485 -0.2185 -0.1995 0.2445 0.00 1.1 -0.01379 0.01046 -0.02765 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266092.000 888529.8795 -4517278.8741 4399531.2314 2 4 0.3329 0.2069 0.2474 -0.2169 -0.1986 0.2425 0.00 1.0 0.00520 -0.01354 0.01020 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266093.000 888529.8625 -4517278.8662 4399531.2091 2 4 0.3301 0.2062 0.2464 -0.2154 -0.1977 0.2405 0.00 1.0 -0.00213 -0.03092 0.04405 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266094.000 888529.8462 -4517278.8628 4399531.1967 2 4 0.3274 0.2056 0.2455 -0.2139 -0.1968 0.2386 0.00 1.1 0.02450 0.02802 -0.04430 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266095.000 888529.8283 -4517278.8553 4399531.1818 2 4 0.3248 0.2050 0.2445 -0.2124 -0.1960 0.2367 0.00 1.2 -0.03859 0.03911 -0.05867 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266096.000 888529.8070 -4517278.8503 4399531.1783 2 4 0.3223 0.2044 0.2436 -0.2110 -0.1951 0.2349 0.00 1.2 0.00064 -0.03759 0.04877 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266097.000 888529.7905 -4517278.8405 4399531.1209 2 4 0.3198 0.2038 0.2427 -0.2096 -0.1943 0.2331 0.00 1.3 -0.05663 0.02510 -0.02190 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266098.000 888529.7890 -4517278.8438 4399531.1294 2 4 0.3173 0.2032 0.2419 -0.2082 -0.1935 0.2314 0.00 1.3 -0.00604 -0.00573 -0.00930 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266099.000 888529.7723 -4517278.8343 4399531.1225 2 4 0.3149 0.2026 0.2410 -0.2069 -0.1927 0.2297 0.00 1.3 -0.00509 0.02285 -0.05387 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266100.000 888529.7594 -4517278.8307 4399531.1022 2 4 0.3126 0.2020 0.2402 -0.2056 -0.1920 0.2280 0.00 1.3 -0.00515 -0.02596 0.00986 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266101.000 888529.7523 -4517278.8263 4399531.0933 2 4 0.3103 0.2015 0.2394 -0.2043 -0.1912 0.2264 0.00 1.3 -0.00558 -0.01239 -0.01476 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266102.000 888529.7424 -4517278.8277 4399531.0879 2 4 0.3081 0.2010 0.2386 -0.2031 -0.1905 0.2248 0.00 1.2 -0.00179 0.00924 0.00861 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266103.000 888529.7895 -4517278.8468 4399531.1116 2 6 0.3045 0.2001 0.2372 -0.2010 -0.1893 0.2222 0.00 1.3 0.00059 -0.02486 0.01015 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266104.000 888529.8125 -4517278.8504 4399531.1058 2 6 0.3014 0.1993 0.2356 -0.1992 -0.1880 0.2197 0.00 1.2 0.02263 -0.02464 0.01162 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266105.000 888529.8349 -4517278.8610 4399531.1110 2 6 0.2984 0.1985 0.2343 -0.1975 -0.1868 0.2175 0.00 1.1 -0.01994 0.00204 -0.04433 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266106.000 888529.8649 -4517278.8768 4399531.1331 2 6 0.2955 0.1978 0.2331 -0.1958 -0.1858 0.2153 0.00 1.0 0.01056 0.00069 0.05687 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266107.000 888529.8925 -4517278.8880 4399531.1391 2 6 0.2926 0.1971 0.2320 -0.1942 -0.1848 0.2132 0.00 1.1 -0.00647 -0.07204 0.12238 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266108.000 888529.8834 -4517278.8867 4399531.1259 2 4 0.2908 0.1968 0.2322 -0.1932 -0.1847 0.2121 0.00 1.0 0.02346 -0.04102 0.01584 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266109.000 888529.8702 -4517278.8815 4399531.1255 2 4 0.2890 0.1964 0.2316 -0.1922 -0.1841 0.2108 0.00 1.0 -0.02642 0.01075 -0.05530 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266110.000 888529.8563 -4517278.8790 4399531.1068 2 4 0.2872 0.1960 0.2310 -0.1913 -0.1835 0.2095 0.00 1.1 -0.01367 -0.02782 0.02770 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266111.000 888529.8998 -4517278.8975 4399531.1298 2 6 0.2845 0.1953 0.2300 -0.1897 -0.1826 0.2075 0.00 1.1 -0.00196 0.00198 -0.01258 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266112.000 888529.9254 -4517278.9095 4399531.1376 2 6 0.2820 0.1946 0.2286 -0.1882 -0.1815 0.2055 0.00 1.2 0.01124 -0.02985 0.05172 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266113.000 888529.9438 -4517278.9184 4399531.1576 2 6 0.2795 0.1940 0.2275 -0.1868 -0.1806 0.2036 0.00 1.2 -0.01298 0.03096 -0.00287 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266114.000 888529.9620 -4517278.9288 4399531.1631 2 6 0.2771 0.1934 0.2265 -0.1855 -0.1797 0.2018 0.00 1.3 -0.00382 0.01838 -0.02908 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266115.000 888529.9803 -4517278.9389 4399531.1841 2 6 0.2748 0.1928 0.2256 -0.1841 -0.1789 0.2001 0.00 1.3 0.02233 -0.05711 0.04256 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266116.000 888529.9655 -4517278.9308 4399531.1573 2 4 0.2733 0.1926 0.2260 -0.1834 -0.1789 0.1993 0.00 1.3 -0.03518 0.01215 -0.05528 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266117.000 888529.9412 -4517278.9264 4399531.1428 2 4 0.2718 0.1923 0.2255 -0.1826 -0.1784 0.1982 0.00 1.2 0.00476 -0.01036 0.07117 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266118.000 888529.9202 -4517278.9130 4399531.1196 2 4 0.2703 0.1919 0.2251 -0.1818 -0.1779 0.1971 0.00 1.1 -0.00750 -0.02829 -0.02568 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266119.000 888529.9069 -4517278.9118 4399531.1045 2 4 0.2689 0.1916 0.2246 -0.1810 -0.1775 0.1961 0.00 1.1 -0.00528 0.02346 -0.01572 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266120.000 888529.8872 -4517278.9087 4399531.0938 2 4 0.2675 0.1912 0.2241 -0.1802 -0.1770 0.1951 0.00 1.0 -0.00729 0.00311 -0.02177 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266121.000 888529.9059 -4517278.9191 4399531.1183 2 6 0.2651 0.1907 0.2233 -0.1788 -0.1762 0.1933 0.00 1.0 0.01606 -0.00096 0.04809 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266122.000 888529.9220 -4517278.9296 4399531.1167 2 6 0.2631 0.1901 0.2220 -0.1776 -0.1753 0.1917 0.00 1.1 -0.02312 0.00685 -0.00896 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266123.000 888529.9295 -4517278.9361 4399531.1179 2 6 0.2611 0.1896 0.2211 -0.1765 -0.1746 0.1901 0.00 1.1 0.01914 -0.05148 0.06838 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266124.000 888529.9413 -4517278.9408 4399531.1128 2 6 0.2592 0.1891 0.2203 -0.1754 -0.1739 0.1887 0.00 1.1 0.00543 -0.00078 0.01376 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266125.000 888529.9546 -4517278.9491 4399531.1244 2 6 0.2573 0.1886 0.2196 -0.1743 -0.1732 0.1872 0.00 1.2 0.02775 -0.01901 0.05495 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266126.000 888529.9524 -4517278.9507 4399531.1185 2 6 0.2554 0.1882 0.2189 -0.1733 -0.1726 0.1858 0.00 1.1 0.02996 0.01026 0.05917 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266127.000 888529.9482 -4517278.9475 4399531.1209 2 6 0.2536 0.1877 0.2183 -0.1723 -0.1719 0.1845 0.00 1.1 -0.02278 0.02255 -0.04686 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266128.000 888529.9472 -4517278.9539 4399531.1283 2 6 0.2519 0.1873 0.2176 -0.1713 -0.1713 0.1831 0.00 1.1 0.02744 -0.06042 0.09485 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266129.000 888529.9493 -4517278.9589 4399531.1283 2 6 0.2501 0.1869 0.2170 -0.1703 -0.1708 0.1818 0.00 1.0 -0.04589 0.02106 -0.05118 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266130.000 888529.9426 -4517278.9662 4399531.1385 2 6 0.2484 0.1865 0.2164 -0.1693 -0.1702 0.1805 0.00 1.1 0.00768 -0.02561 0.02720 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266131.000 888529.9486 -4517278.9682 4399531.1205 2 6 0.2468 0.1861 0.2158 -0.1684 -0.1696 0.1793 0.00 1.1 0.02273 -0.04112 0.07098 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266132.000 888529.9497 -4517278.9686 4399531.1204 2 6 0.2451 0.1857 0.2153 -0.1674 -0.1691 0.1780 0.00 1.1 -0.00188 -0.00126 0.02382 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266133.000 888529.9465 -4517278.9769 4399531.1280 2 6 0.2435 0.1853 0.2147 -0.1665 -0.1685 0.1768 0.00 1.2 -0.01790 0.00726 -0.01320 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266134.000 888529.9403 -4517278.9768 4399531.1206 2 6 0.2420 0.1849 0.2142 -0.1657 -0.1680 0.1757 0.00 1.2 -0.02089 -0.00356 0.01738 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266135.000 888529.9366 -4517278.9822 4399531.1208 2 6 0.2404 0.1845 0.2136 -0.1648 -0.1675 0.1745 0.00 1.2 -0.03014 -0.04063 0.02125 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266136.000 888529.9363 -4517278.9900 4399531.1293 2 6 0.2389 0.1841 0.2131 -0.1639 -0.1670 0.1733 0.00 1.3 0.01085 0.02518 -0.13810 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266137.000 888529.9272 -4517278.9875 4399531.1167 2 6 0.2375 0.1837 0.2126 -0.1631 -0.1665 0.1722 0.00 1.3 0.03039 0.00666 0.02539 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266138.000 888529.9206 -4517278.9929 4399531.1051 2 6 0.2360 0.1834 0.2121 -0.1623 -0.1660 0.1711 0.00 1.4 0.02689 -0.02162 0.03884 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266139.000 888529.9194 -4517278.9965 4399531.1040 2 6 0.2346 0.1830 0.2116 -0.1615 -0.1655 0.1700 0.00 1.4 0.01864 0.02421 -0.00006 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266140.000 888529.9078 -4517278.9950 4399531.0915 2 6 0.2332 0.1827 0.2111 -0.1607 -0.1650 0.1690 0.00 1.5 0.01856 -0.00340 0.06669 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266141.000 888529.8957 -4517278.9913 4399531.0699 2 6 0.2318 0.1823 0.2107 -0.1599 -0.1646 0.1679 0.00 1.4 -0.02004 -0.00460 -0.00866 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266142.000 888529.8811 -4517278.9940 4399531.0813 2 6 0.2305 0.1820 0.2102 -0.1591 -0.1641 0.1669 0.00 1.4 0.01579 -0.05347 0.07248 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266143.000 888529.8688 -4517278.9923 4399531.0735 2 6 0.2291 0.1816 0.2098 -0.1584 -0.1637 0.1659 0.00 1.3 0.01539 0.00563 0.03562 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266144.000 888529.8545 -4517278.9944 4399531.0545 2 6 0.2278 0.1813 0.2093 -0.1576 -0.1632 0.1649 0.00 1.2 -0.00912 -0.03488 0.03301 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266145.000 888529.8516 -4517279.0161 4399531.0775 2 6 0.2265 0.1810 0.2089 -0.1569 -0.1628 0.1639 0.00 1.1 0.01646 -0.02814 0.02630 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266146.000 888529.8282 -4517279.0092 4399531.0623 2 6 0.2253 0.1806 0.2085 -0.1562 -0.1624 0.1630 0.00 1.0 0.01060 -0.03271 0.03644 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266147.000 888529.8208 -4517279.0062 4399531.0431 2 6 0.2240 0.1803 0.2081 -0.1555 -0.1620 0.1620 0.00 1.1 0.02203 -0.01505 0.03152 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266148.000 888529.8088 -4517279.0091 4399531.0425 2 6 0.2228 0.1800 0.2077 -0.1548 -0.1616 0.1611 0.00 1.2 0.03364 -0.07240 0.13491 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266149.000 888529.7957 -4517279.0112 4399531.0308 2 6 0.2216 0.1796 0.2073 -0.1541 -0.1612 0.1602 0.00 1.3 -0.00521 0.03003 -0.03492 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266150.000 888529.7871 -4517279.0177 4399531.0324 2 6 0.2204 0.1793 0.2069 -0.1534 -0.1608 0.1593 0.00 1.5 0.04541 -0.01016 0.04097 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266151.000 888529.7683 -4517279.0117 4399531.0089 2 6 0.2193 0.1790 0.2065 -0.1527 -0.1604 0.1584 0.00 1.8 -0.02393 0.04547 -0.10084 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266152.000 888529.7304 -4517278.9971 4399530.9708 2 4 0.2186 0.1791 0.2076 -0.1526 -0.1609 0.1584 0.00 2.2 0.00658 0.00655 0.02418 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266153.000 888529.6966 -4517278.9924 4399530.9632 2 4 0.2179 0.1789 0.2074 -0.1522 -0.1607 0.1579 0.00 1.7 -0.00299 -0.00231 0.00646 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266154.000 888529.6618 -4517278.9830 4399530.9313 2 4 0.2171 0.1787 0.2072 -0.1518 -0.1604 0.1573 0.00 1.3 0.02137 -0.01576 0.05819 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266155.000 888529.6234 -4517278.9754 4399530.9170 2 4 0.2164 0.1785 0.2070 -0.1514 -0.1602 0.1568 0.00 1.1 -0.00868 -0.03359 0.01628 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266156.000 888529.5917 -4517278.9801 4399530.9324 2 4 0.2157 0.1784 0.2068 -0.1510 -0.1600 0.1563 0.00 1.5 -0.01464 0.00752 0.00962 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266157.000 888529.5717 -4517278.9644 4399530.8811 2 4 0.2149 0.1782 0.2066 -0.1506 -0.1598 0.1558 0.00 2.0 0.02470 -0.01436 0.00132 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266158.000 888529.5299 -4517278.9565 4399530.8758 2 4 0.2142 0.1780 0.2064 -0.1502 -0.1595 0.1553 0.00 2.2 0.01899 -0.04165 0.04237 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266159.000 888529.5012 -4517278.9514 4399530.8506 2 4 0.2135 0.1778 0.2062 -0.1499 -0.1593 0.1548 0.00 1.7 -0.00967 -0.02477 0.04858 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266160.000 888529.4646 -4517278.9394 4399530.8377 2 4 0.2128 0.1776 0.2060 -0.1495 -0.1591 0.1543 0.00 1.2 -0.03220 -0.04815 0.02410 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266161.000 888529.4316 -4517278.9342 4399530.8295 2 4 0.2121 0.1774 0.2058 -0.1491 -0.1589 0.1538 0.00 1.1 -0.00183 -0.00384 0.01054 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266162.000 888529.3961 -4517278.9221 4399530.7860 2 4 0.2114 0.1772 0.2056 -0.1488 -0.1587 0.1533 0.00 1.6 0.01131 -0.00900 0.00456 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266163.000 888529.3733 -4517278.9234 4399530.7851 2 4 0.2108 0.1770 0.2054 -0.1484 -0.1584 0.1528 0.00 2.0 0.02811 -0.03147 0.07047 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266164.000 888529.3331 -4517278.9215 4399530.7689 2 4 0.2101 0.1769 0.2052 -0.1481 -0.1582 0.1523 0.00 2.0 -0.00017 0.01222 -0.02005 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266165.000 888529.3090 -4517278.9090 4399530.7539 2 4 0.2094 0.1767 0.2050 -0.1477 -0.1580 0.1519 0.00 1.6 -0.00588 0.01930 -0.04525 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266166.000 888529.2753 -4517278.9086 4399530.7421 2 4 0.2088 0.1765 0.2048 -0.1474 -0.1578 0.1514 0.00 1.2 -0.01750 0.01212 -0.01441 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266167.000 888529.2470 -4517278.8938 4399530.7142 2 4 0.2081 0.1763 0.2047 -0.1470 -0.1576 0.1509 0.00 1.2 0.00188 0.05114 -0.01751 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266168.000 888529.2145 -4517278.8919 4399530.7138 2 4 0.2075 0.1761 0.2045 -0.1467 -0.1574 0.1505 0.00 1.5 0.00056 -0.03565 0.03926 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266169.000 888529.1851 -4517278.8881 4399530.6840 2 4 0.2069 0.1760 0.2043 -0.1463 -0.1572 0.1500 0.00 1.9 0.00898 0.00575 0.05257 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266170.000 888529.1536 -4517278.8803 4399530.6712 2 4 0.2062 0.1758 0.2041 -0.1460 -0.1570 0.1495 0.00 1.9 0.00812 -0.02539 0.02533 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266171.000 888529.1246 -4517278.8698 4399530.6581 2 4 0.2056 0.1756 0.2040 -0.1457 -0.1568 0.1491 0.00 1.5 0.00204 -0.00171 -0.00096 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266172.000 888529.0896 -4517278.8619 4399530.6336 2 4 0.2050 0.1754 0.2038 -0.1453 -0.1566 0.1486 0.00 1.2 0.00994 0.00453 0.03335 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266173.000 888529.0607 -4517278.8561 4399530.6240 2 4 0.2044 0.1753 0.2036 -0.1450 -0.1564 0.1482 0.00 1.1 -0.01582 -0.04155 0.01137 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266174.000 888529.0307 -4517278.8488 4399530.5978 2 4 0.2038 0.1751 0.2034 -0.1447 -0.1562 0.1478 0.00 1.4 0.02677 0.00999 0.02387 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266175.000 888529.0063 -4517278.8475 4399530.5957 2 4 0.2032 0.1749 0.2033 -0.1444 -0.1560 0.1473 0.00 1.6 0.03997 0.04827 0.02380 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266176.000 888528.9721 -4517278.8393 4399530.5638 2 4 0.2026 0.1748 0.2031 -0.1441 -0.1558 0.1469 0.00 1.8 -0.03634 0.02663 -0.03232 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266177.000 888528.9067 -4517278.8145 4399530.5418 2 5 0.2012 0.1743 0.2028 -0.1432 -0.1553 0.1460 0.00 1.2 -0.00579 0.00201 0.04664 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266178.000 888528.8319 -4517278.7796 4399530.4947 2 5 0.2001 0.1738 0.2025 -0.1423 -0.1550 0.1452 0.00 1.3 -0.00333 0.00808 -0.00211 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266179.000 888528.7718 -4517278.7563 4399530.4573 2 5 0.1989 0.1735 0.2021 -0.1415 -0.1545 0.1443 0.00 1.2 -0.00022 -0.01181 0.04041 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266180.000 888528.7051 -4517278.7278 4399530.4277 2 5 0.1976 0.1731 0.2018 -0.1407 -0.1540 0.1434 0.00 1.3 -0.00516 -0.01418 0.02806 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266181.000 888528.6804 -4517278.7222 4399530.4107 2 4 0.1971 0.1729 0.2016 -0.1404 -0.1539 0.1430 0.00 1.1 -0.00432 0.01927 -0.04814 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266182.000 888528.6527 -4517278.7141 4399530.3877 2 4 0.1965 0.1728 0.2015 -0.1401 -0.1537 0.1426 0.00 1.2 -0.00712 0.02460 -0.03231 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266183.000 888528.6295 -4517278.7117 4399530.3740 2 4 0.1960 0.1726 0.2014 -0.1398 -0.1535 0.1422 0.00 1.4 0.00114 0.01303 0.00485 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266184.000 888528.6041 -4517278.7128 4399530.3716 2 4 0.1955 0.1725 0.2012 -0.1396 -0.1533 0.1418 0.00 1.6 0.00761 -0.01682 0.03001 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266185.000 888528.5692 -4517278.6998 4399530.3479 2 4 0.1950 0.1723 0.2011 -0.1393 -0.1532 0.1414 0.00 1.8 0.00997 0.02089 0.00531 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266186.000 888528.5493 -4517278.7022 4399530.3376 2 4 0.1944 0.1721 0.2009 -0.1390 -0.1530 0.1410 0.00 1.5 -0.03110 -0.03924 0.03990 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266187.000 888528.5217 -4517278.6978 4399530.3307 2 4 0.1939 0.1720 0.2008 -0.1387 -0.1528 0.1406 0.00 1.3 -0.01708 -0.05580 0.00013 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266188.000 888528.4948 -4517278.6916 4399530.3181 2 4 0.1934 0.1718 0.2006 -0.1385 -0.1526 0.1403 0.00 1.1 0.00313 -0.02425 0.02223 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266189.000 888528.4714 -4517278.6868 4399530.2983 2 4 0.1929 0.1717 0.2005 -0.1382 -0.1525 0.1399 0.00 1.1 0.01978 -0.00089 0.05591 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266190.000 888528.4455 -4517278.6791 4399530.2711 2 4 0.1924 0.1715 0.2004 -0.1379 -0.1523 0.1395 0.00 1.3 -0.02353 0.00916 0.01265 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266191.000 888528.4279 -4517278.6777 4399530.2613 2 4 0.1919 0.1714 0.2002 -0.1377 -0.1521 0.1392 0.00 1.4 0.03959 0.06621 -0.03326 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266192.000 888528.3953 -4517278.6728 4399530.2447 2 4 0.1914 0.1712 0.2001 -0.1374 -0.1520 0.1388 0.00 1.6 -0.01186 -0.05765 0.03695 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266193.000 888528.3760 -4517278.6696 4399530.2297 2 4 0.1909 0.1711 0.2000 -0.1372 -0.1518 0.1384 0.00 1.5 0.00682 0.00917 0.06370 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266194.000 888528.3573 -4517278.6702 4399530.2283 2 4 0.1904 0.1709 0.1998 -0.1369 -0.1516 0.1381 0.00 1.3 0.01665 0.05445 -0.00723 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266195.000 888528.3374 -4517278.6743 4399530.2332 2 4 0.1899 0.1708 0.1997 -0.1367 -0.1515 0.1377 0.00 1.2 0.00683 -0.06601 0.00746 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266196.000 888528.3067 -4517278.6572 4399530.1950 2 4 0.1894 0.1707 0.1996 -0.1364 -0.1513 0.1374 0.00 1.0 -0.01363 0.02194 -0.03097 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266197.000 888528.2840 -4517278.6595 4399530.1941 2 5 0.1889 0.1705 0.1994 -0.1361 -0.1512 0.1370 0.00 1.1 -0.00058 -0.01830 0.03368 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266198.000 888528.2671 -4517278.6582 4399530.1826 2 5 0.1884 0.1704 0.1991 -0.1359 -0.1510 0.1366 0.00 1.2 0.00921 -0.00222 0.02059 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266199.000 888528.2394 -4517278.6499 4399530.1615 2 5 0.1880 0.1702 0.1976 -0.1357 -0.1505 0.1363 0.00 1.2 0.00123 0.03475 -0.04536 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266200.000 888528.2115 -4517278.6498 4399530.1534 2 5 0.1875 0.1700 0.1969 -0.1354 -0.1503 0.1359 0.00 1.1 -0.01002 -0.03123 0.05347 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266201.000 888528.1924 -4517278.6498 4399530.1338 2 5 0.1870 0.1699 0.1965 -0.1352 -0.1501 0.1356 0.00 1.0 0.00164 -0.00619 0.01382 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266202.000 888528.1666 -4517278.6411 4399530.1198 2 5 0.1866 0.1697 0.1962 -0.1349 -0.1499 0.1352 0.00 1.1 -0.00590 -0.03521 0.02060 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266203.000 888528.1473 -4517278.6412 4399530.0993 2 5 0.1861 0.1696 0.1959 -0.1347 -0.1497 0.1349 0.00 1.2 0.00813 0.01234 0.04619 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266204.000 888528.1202 -4517278.6362 4399530.0910 2 5 0.1856 0.1694 0.1956 -0.1345 -0.1496 0.1345 0.00 1.1 -0.00163 0.03810 0.00398 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266205.000 888528.0927 -4517278.6317 4399530.0761 2 5 0.1852 0.1693 0.1954 -0.1342 -0.1494 0.1342 0.00 1.0 0.00359 -0.03954 0.08871 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266206.000 888528.0080 -4517278.5944 4399530.0314 2 6 0.1842 0.1689 0.1951 -0.1335 -0.1491 0.1335 0.00 1.2 -0.00586 0.04702 -0.05149 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266207.000 888527.9556 -4517278.5675 4399529.9914 2 6 0.1833 0.1685 0.1948 -0.1328 -0.1487 0.1329 0.00 1.2 -0.02098 -0.03677 -0.00488 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266208.000 888527.9159 -4517278.5557 4399529.9752 2 6 0.1824 0.1681 0.1945 -0.1322 -0.1484 0.1323 0.00 1.2 0.01830 -0.01395 0.05328 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266209.000 888527.8752 -4517278.5382 4399529.9425 2 6 0.1816 0.1680 0.1942 -0.1317 -0.1482 0.1317 0.00 2.7 -0.01255 0.00662 -0.00230 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266210.000 888527.8469 -4517278.5305 4399529.9187 2 6 0.1807 0.1675 0.1940 -0.1311 -0.1478 0.1311 0.00 3.1 0.00363 -0.03545 0.02161 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266211.000 888527.8179 -4517278.5255 4399529.8950 2 6 0.1799 0.1672 0.1937 -0.1305 -0.1475 0.1305 0.00 3.4 -0.00318 -0.03896 0.04444 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266212.000 888527.7932 -4517278.5219 4399529.8963 2 6 0.1791 0.1669 0.1935 -0.1299 -0.1473 0.1299 0.00 3.6 -0.01293 0.00201 -0.00074 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266213.000 888527.7752 -4517278.5186 4399529.8736 2 6 0.1783 0.1666 0.1932 -0.1294 -0.1470 0.1294 0.00 3.4 0.01125 -0.00074 0.01810 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266214.000 888527.7544 -4517278.5220 4399529.8509 2 6 0.1775 0.1663 0.1930 -0.1289 -0.1467 0.1289 0.00 3.3 0.00513 0.00358 -0.00413 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266215.000 888527.7417 -4517278.5162 4399529.8394 2 5 0.1768 0.1661 0.1953 -0.1283 -0.1471 0.1282 0.00 1.5 0.01687 -0.01334 0.04372 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266216.000 888527.7259 -4517278.5110 4399529.8426 2 5 0.1761 0.1659 0.1951 -0.1278 -0.1468 0.1276 0.00 1.5 -0.01756 0.08625 -0.14970 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266217.000 888527.7018 -4517278.5082 4399529.8335 2 5 0.1753 0.1656 0.1949 -0.1273 -0.1466 0.1271 0.00 1.5 -0.00023 0.00289 0.02740 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266218.000 888527.6866 -4517278.5047 4399529.8279 2 5 0.1746 0.1653 0.1947 -0.1268 -0.1463 0.1266 0.00 1.2 0.00635 0.04944 -0.03027 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266219.000 888527.6723 -4517278.5098 4399529.8202 2 5 0.1739 0.1651 0.1945 -0.1264 -0.1460 0.1260 0.00 1.2 0.02005 -0.03003 0.04870 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266220.000 888527.6509 -4517278.5026 4399529.7993 2 5 0.1732 0.1648 0.1942 -0.1259 -0.1457 0.1255 0.00 1.1 -0.02299 0.01456 -0.01207 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266221.000 888527.6232 -4517278.4936 4399529.7774 2 5 0.1725 0.1645 0.1940 -0.1254 -0.1455 0.1250 0.00 1.0 -0.01454 -0.01395 0.01763 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266222.000 888527.6128 -4517278.4975 4399529.7823 2 5 0.1718 0.1643 0.1937 -0.1249 -0.1452 0.1244 0.00 1.1 -0.00619 -0.02537 0.00565 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266223.000 888527.5892 -4517278.4843 4399529.7663 2 5 0.1711 0.1640 0.1935 -0.1245 -0.1449 0.1239 0.00 1.2 -0.00442 0.02807 0.04730 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266224.000 888527.5678 -4517278.4823 4399529.7594 2 5 0.1704 0.1637 0.1932 -0.1240 -0.1446 0.1234 0.00 1.2 -0.00466 0.02342 -0.02004 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266225.000 888527.5459 -4517278.4775 4399529.7578 2 5 0.1698 0.1635 0.1929 -0.1235 -0.1443 0.1228 0.00 1.2 0.00799 0.01367 0.03459 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266226.000 888527.5248 -4517278.4671 4399529.7347 2 5 0.1691 0.1632 0.1926 -0.1230 -0.1440 0.1223 0.00 1.3 -0.01842 0.01816 -0.00748 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266227.000 888527.5069 -4517278.4641 4399529.7360 2 5 0.1684 0.1629 0.1923 -0.1226 -0.1437 0.1218 0.00 1.3 -0.01502 0.03442 -0.00143 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266228.000 888527.4866 -4517278.4682 4399529.7373 2 5 0.1678 0.1627 0.1920 -0.1221 -0.1434 0.1212 0.00 1.2 -0.01597 -0.02874 0.03515 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266229.000 888527.4703 -4517278.4651 4399529.7272 2 5 0.1671 0.1624 0.1917 -0.1217 -0.1431 0.1207 0.00 1.1 0.02260 0.02117 0.06014 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266230.000 888527.4536 -4517278.4663 4399529.7130 2 5 0.1665 0.1621 0.1913 -0.1212 -0.1427 0.1201 0.00 1.0 -0.00393 -0.03445 0.00550 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266231.000 888527.4329 -4517278.4516 4399529.6938 2 5 0.1659 0.1619 0.1910 -0.1208 -0.1424 0.1196 0.00 1.1 0.02025 -0.00446 0.01707 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266232.000 888527.4171 -4517278.4350 4399529.6788 2 6 0.1652 0.1616 0.1905 -0.1203 -0.1420 0.1189 0.00 1.1 -0.02270 -0.03814 -0.04692 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266233.000 888527.4171 -4517278.4340 4399529.6760 2 6 0.1645 0.1613 0.1901 -0.1198 -0.1417 0.1183 0.00 1.1 0.01589 -0.03518 0.00127 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266234.000 888527.4047 -4517278.4321 4399529.6746 2 6 0.1638 0.1610 0.1896 -0.1194 -0.1413 0.1177 0.00 1.6 -0.00666 0.00858 0.04136 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266235.000 888527.3924 -4517278.4290 4399529.6838 2 6 0.1632 0.1607 0.1878 -0.1189 -0.1406 0.1170 0.00 1.6 0.00054 -0.05332 0.04684 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266236.000 888527.3771 -4517278.4184 4399529.6637 2 6 0.1626 0.1604 0.1869 -0.1185 -0.1401 0.1164 0.00 1.5 -0.04546 0.02611 -0.05764 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266237.000 888527.3733 -4517278.4196 4399529.6878 2 6 0.1619 0.1601 0.1861 -0.1180 -0.1397 0.1157 0.00 1.5 0.02514 0.02463 0.00383 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266238.000 888527.3599 -4517278.4193 4399529.7161 2 6 0.1613 0.1598 0.1855 -0.1176 -0.1392 0.1151 0.00 1.6 -0.01741 -0.07909 0.08706 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266239.000 888527.3536 -4517278.4118 4399529.7016 2 6 0.1607 0.1595 0.1848 -0.1171 -0.1388 0.1145 0.00 1.6 0.00843 0.03639 0.01830 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266240.000 888527.3433 -4517278.4041 4399529.6906 2 6 0.1601 0.1592 0.1842 -0.1167 -0.1384 0.1138 0.00 1.5 -0.00529 -0.09666 0.05264 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266241.000 888527.3221 -4517278.3942 4399529.6690 2 5 0.1595 0.1591 0.1861 -0.1163 -0.1386 0.1134 0.00 1.1 -0.00103 -0.02315 0.04484 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266242.000 888527.3096 -4517278.3895 4399529.6630 2 5 0.1589 0.1588 0.1855 -0.1158 -0.1382 0.1128 0.00 1.0 -0.00880 -0.08116 0.01005 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266243.000 888527.3077 -4517278.3850 4399529.6629 2 5 0.1585 0.1586 0.1856 -0.1156 -0.1377 0.1120 0.00 2.2 0.00491 0.04673 -0.06587 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266244.000 888527.3220 -4517278.3928 4399529.6905 2 5 0.1582 0.1585 0.1854 -0.1155 -0.1375 0.1117 0.00 2.3 0.03787 0.03096 0.03155 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266245.000 888527.3185 -4517278.3946 4399529.7108 2 6 0.1575 0.1583 0.1853 -0.1150 -0.1373 0.1112 0.00 2.2 0.01495 -0.02185 0.06245 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266246.000 888527.3142 -4517278.3824 4399529.7039 2 6 0.1569 0.1580 0.1851 -0.1146 -0.1371 0.1107 0.00 1.6 -0.06701 -0.04860 -0.02700 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266247.000 888527.3093 -4517278.3819 4399529.7263 2 6 0.1563 0.1577 0.1835 -0.1141 -0.1366 0.1102 0.00 1.6 0.00784 0.00728 0.02484 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266248.000 888527.3046 -4517278.3670 4399529.6880 2 6 0.1557 0.1574 0.1829 -0.1137 -0.1363 0.1098 0.00 1.8 -0.01719 0.02499 -0.03992 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266249.000 888527.2981 -4517278.3705 4399529.7380 2 6 0.1552 0.1572 0.1825 -0.1134 -0.1361 0.1094 0.00 2.0 -0.01801 -0.02638 0.04523 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266250.000 888527.3033 -4517278.3710 4399529.7307 2 6 0.1547 0.1570 0.1821 -0.1130 -0.1359 0.1090 0.00 1.9 -0.00834 -0.01250 0.01320 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266251.000 888527.3088 -4517278.3718 4399529.7375 2 6 0.1542 0.1568 0.1818 -0.1127 -0.1357 0.1086 0.00 2.0 0.02151 0.03380 0.05048 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266252.000 888527.2976 -4517278.3619 4399529.7264 2 5 0.1537 0.1567 0.1841 -0.1124 -0.1362 0.1084 0.00 1.2 0.00615 -0.00768 0.00454 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266253.000 888527.2823 -4517278.3596 4399529.7321 2 5 0.1532 0.1565 0.1840 -0.1121 -0.1360 0.1081 0.00 1.3 0.02608 -0.01807 0.05108 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266254.000 888527.2767 -4517278.3532 4399529.7208 2 6 0.1527 0.1563 0.1838 -0.1118 -0.1358 0.1076 0.00 1.3 0.01068 0.06748 -0.00008 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266255.000 888527.2717 -4517278.3461 4399529.6861 2 6 0.1522 0.1561 0.1822 -0.1114 -0.1353 0.1072 0.00 1.3 -0.03158 -0.04139 -0.03202 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266256.000 888527.2620 -4517278.3429 4399529.7295 2 6 0.1517 0.1559 0.1834 -0.1111 -0.1354 0.1068 0.00 1.3 0.00960 0.00271 0.02160 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266257.000 888527.2533 -4517278.3380 4399529.7281 2 5 0.1512 0.1557 0.1833 -0.1108 -0.1353 0.1065 0.00 1.2 0.00649 -0.04852 0.04930 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266258.000 888527.2472 -4517278.3362 4399529.7153 2 5 0.1508 0.1555 0.1831 -0.1105 -0.1351 0.1062 0.00 1.1 0.01765 -0.00902 0.04115 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266259.000 888527.2353 -4517278.3319 4399529.6996 2 5 0.1503 0.1554 0.1829 -0.1102 -0.1349 0.1058 0.00 1.0 -0.02103 0.04399 -0.05460 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266260.000 888527.2254 -4517278.3254 4399529.7097 2 5 0.1498 0.1552 0.1828 -0.1099 -0.1347 0.1055 0.00 1.0 -0.00145 0.03273 0.00001 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266261.000 888527.2158 -4517278.3241 4399529.7167 2 5 0.1494 0.1550 0.1826 -0.1095 -0.1345 0.1051 0.00 1.0 -0.01303 -0.05892 0.01650 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266262.000 888527.2167 -4517278.3305 4399529.7126 2 5 0.1489 0.1548 0.1824 -0.1092 -0.1343 0.1047 0.00 1.1 0.00546 -0.06170 0.06250 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266263.000 888527.2095 -4517278.3257 4399529.7240 2 5 0.1485 0.1546 0.1822 -0.1089 -0.1341 0.1044 0.00 1.1 0.00876 0.00757 0.02952 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266264.000 888527.2058 -4517278.3324 4399529.7219 2 5 0.1481 0.1544 0.1819 -0.1086 -0.1338 0.1040 0.00 1.1 0.01046 -0.01959 0.02238 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266265.000 888527.1993 -4517278.3293 4399529.7403 2 5 0.1476 0.1542 0.1817 -0.1083 -0.1336 0.1037 0.00 1.1 -0.00937 -0.00610 -0.00349 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266266.000 888527.1973 -4517278.3354 4399529.7402 2 5 0.1472 0.1540 0.1815 -0.1080 -0.1334 0.1033 0.00 1.1 0.00995 0.08215 -0.03212 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266267.000 888527.1917 -4517278.3322 4399529.7382 2 5 0.1467 0.1538 0.1812 -0.1077 -0.1331 0.1029 0.00 1.1 0.00925 0.03427 -0.05567 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266268.000 888527.1846 -4517278.3347 4399529.7368 2 5 0.1463 0.1536 0.1810 -0.1074 -0.1329 0.1025 0.00 1.1 0.00453 0.06113 -0.01114 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266269.000 888527.1812 -4517278.3362 4399529.7473 2 5 0.1459 0.1534 0.1807 -0.1071 -0.1327 0.1022 0.00 1.1 0.02023 -0.04923 0.05862 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266270.000 888527.1826 -4517278.3462 4399529.7671 2 5 0.1455 0.1532 0.1804 -0.1068 -0.1324 0.1018 0.00 1.0 0.00565 -0.06862 0.07839 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266271.000 888527.1729 -4517278.3396 4399529.7639 2 5 0.1450 0.1530 0.1801 -0.1065 -0.1321 0.1014 0.00 1.0 0.01245 0.01736 0.00764 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266272.000 888527.1695 -4517278.3401 4399529.7710 2 5 0.1446 0.1528 0.1797 -0.1062 -0.1319 0.1010 0.00 1.0 -0.00198 0.02747 -0.02638 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266273.000 888527.1639 -4517278.3402 4399529.7681 2 5 0.1442 0.1526 0.1794 -0.1058 -0.1316 0.1006 0.00 1.0 -0.01639 0.01393 -0.00658 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266274.000 888527.1621 -4517278.3419 4399529.7617 2 5 0.1438 0.1523 0.1790 -0.1055 -0.1313 0.1002 0.00 1.0 -0.01243 0.01648 0.01279 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266275.000 888527.1554 -4517278.3400 4399529.7710 2 5 0.1434 0.1521 0.1787 -0.1052 -0.1310 0.0998 0.00 1.0 -0.03275 0.03802 -0.05095 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266276.000 888527.1567 -4517278.3414 4399529.7837 2 5 0.1430 0.1519 0.1783 -0.1049 -0.1307 0.0994 0.00 1.0 -0.00552 0.01116 0.00177 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266277.000 888527.1514 -4517278.3422 4399529.7799 2 5 0.1425 0.1517 0.1779 -0.1046 -0.1304 0.0990 0.00 1.0 0.01234 0.00515 -0.00602 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266278.000 888527.1412 -4517278.3359 4399529.7797 2 5 0.1421 0.1515 0.1774 -0.1043 -0.1300 0.0985 0.00 1.0 -0.01946 0.03896 -0.02247 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266279.000 888527.1395 -4517278.3346 4399529.7893 2 5 0.1417 0.1512 0.1770 -0.1040 -0.1297 0.0981 0.00 1.0 -0.02085 0.04934 -0.05885 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266280.000 888527.1404 -4517278.3455 4399529.8193 2 5 0.1413 0.1510 0.1765 -0.1037 -0.1294 0.0977 0.00 1.0 0.01869 -0.00305 0.00476 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266281.000 888527.1358 -4517278.3411 4399529.7897 2 5 0.1409 0.1508 0.1761 -0.1034 -0.1290 0.0972 0.00 1.0 -0.00232 0.00265 -0.04990 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266282.000 888527.1264 -4517278.3354 4399529.7867 2 5 0.1405 0.1506 0.1756 -0.1030 -0.1287 0.0968 0.00 1.1 -0.00887 0.03706 -0.03218 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266283.000 888527.1448 -4517278.3405 4399529.7832 2 8 0.1400 0.1503 0.1750 -0.1027 -0.1283 0.0962 0.00 1.1 0.00175 0.01599 0.00150 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266284.000 888527.1542 -4517278.3453 4399529.7935 2 8 0.1395 0.1499 0.1727 -0.1023 -0.1274 0.0956 0.00 1.1 0.02393 0.00831 0.04289 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266285.000 888527.1691 -4517278.3504 4399529.8007 2 8 0.1390 0.1497 0.1715 -0.1019 -0.1268 0.0951 0.00 1.1 0.01190 -0.01010 -0.03984 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266286.000 888527.1743 -4517278.3563 4399529.8014 2 8 0.1385 0.1494 0.1706 -0.1015 -0.1263 0.0945 0.00 1.2 -0.01230 -0.03488 0.01847 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266287.000 888527.1842 -4517278.3491 4399529.7860 2 8 0.1381 0.1491 0.1712 -0.1011 -0.1262 0.0938 0.00 1.0 0.08399 -0.06624 0.13410 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266288.000 888527.1879 -4517278.3489 4399529.7650 2 8 0.1376 0.1488 0.1695 -0.1008 -0.1255 0.0933 0.00 1.0 0.01194 -0.00250 0.03864 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266289.000 888527.1993 -4517278.3490 4399529.7742 2 8 0.1371 0.1486 0.1685 -0.1004 -0.1250 0.0928 0.00 1.1 0.07242 -0.07464 0.11963 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266290.000 888527.2009 -4517278.3538 4399529.7783 2 8 0.1366 0.1483 0.1676 -0.1000 -0.1245 0.0923 0.00 1.0 0.02504 -0.05607 0.08316 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266291.000 888527.1962 -4517278.3418 4399529.7535 2 6 0.1363 0.1481 0.1670 -0.0998 -0.1242 0.0920 0.00 1.0 0.00957 -0.00331 0.04560 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266292.000 888527.1897 -4517278.3356 4399529.7340 2 6 0.1359 0.1479 0.1691 -0.0994 -0.1245 0.0915 0.00 1.5 0.00531 0.03917 -0.01919 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266293.000 888527.1855 -4517278.3334 4399529.7227 2 5 0.1356 0.1477 0.1684 -0.0991 -0.1241 0.0910 0.00 1.6 0.00504 -0.06102 0.04371 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266294.000 888527.1700 -4517278.3135 4399529.6826 2 5 0.1352 0.1474 0.1677 -0.0988 -0.1236 0.0905 0.00 1.6 -0.02261 0.02965 -0.06531 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266295.000 888527.1685 -4517278.3144 4399529.7092 2 5 0.1348 0.1472 0.1670 -0.0985 -0.1232 0.0900 0.00 1.6 -0.01792 0.01631 -0.00142 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266296.000 888527.1582 -4517278.3001 4399529.6384 2 5 0.1345 0.1469 0.1663 -0.0982 -0.1227 0.0895 0.00 1.6 -0.01047 -0.03002 0.03641 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266297.000 888527.1436 -4517278.2867 4399529.6430 2 5 0.1341 0.1467 0.1656 -0.0979 -0.1222 0.0890 0.00 1.6 -0.01968 0.01605 -0.03082 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266298.000 888527.1400 -4517278.2811 4399529.6143 2 6 0.1337 0.1464 0.1648 -0.0976 -0.1217 0.0885 0.00 1.7 -0.00888 0.03888 0.01372 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266299.000 888527.1323 -4517278.2704 4399529.6237 2 6 0.1334 0.1461 0.1640 -0.0972 -0.1212 0.0880 0.00 1.4 -0.00025 0.03137 -0.02037 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266300.000 888527.1323 -4517278.2646 4399529.6145 2 6 0.1330 0.1458 0.1614 -0.0969 -0.1203 0.0875 0.00 1.1 -0.02005 0.00839 -0.02606 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266301.000 888527.1213 -4517278.2574 4399529.6099 2 5 0.1327 0.1456 0.1624 -0.0966 -0.1202 0.0869 0.00 1.8 0.00110 0.00419 0.05122 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266302.000 888527.1201 -4517278.2538 4399529.6291 2 5 0.1323 0.1453 0.1615 -0.0963 -0.1197 0.0864 0.00 1.8 0.03468 0.01659 0.03295 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266303.000 888527.1134 -4517278.2503 4399529.6333 2 5 0.1320 0.1450 0.1607 -0.0960 -0.1192 0.0859 0.00 1.9 0.01378 -0.02906 0.06767 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266304.000 888527.1075 -4517278.2436 4399529.6074 2 5 0.1316 0.1448 0.1599 -0.0957 -0.1187 0.0854 0.00 1.9 -0.04455 0.06020 -0.11436 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266305.000 888527.1016 -4517278.2409 4399529.6625 2 7 0.1312 0.1445 0.1590 -0.0954 -0.1181 0.0848 0.00 1.9 0.00371 0.00117 -0.01903 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266306.000 888527.0962 -4517278.2444 4399529.6558 2 7 0.1308 0.1442 0.1578 -0.0951 -0.1174 0.0844 0.00 2.0 0.00048 -0.01124 -0.01290 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266307.000 888527.0980 -4517278.2434 4399529.7149 2 7 0.1305 0.1439 0.1568 -0.0947 -0.1168 0.0839 0.00 2.0 0.02719 -0.00949 0.05961 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266308.000 888527.0939 -4517278.2405 4399529.6700 2 7 0.1301 0.1436 0.1558 -0.0944 -0.1163 0.0833 0.00 2.0 -0.02682 0.04715 -0.04560 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266309.000 888527.0965 -4517278.2406 4399529.7405 2 7 0.1297 0.1433 0.1549 -0.0941 -0.1157 0.0828 0.00 2.0 0.03435 0.00588 0.07844 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266310.000 888527.0844 -4517278.2308 4399529.6995 2 7 0.1294 0.1431 0.1539 -0.0938 -0.1151 0.0823 0.00 2.0 -0.03708 0.02965 -0.04442 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266311.000 888527.0784 -4517278.2334 4399529.7257 2 7 0.1290 0.1428 0.1530 -0.0935 -0.1146 0.0817 0.00 2.0 0.01336 -0.01195 0.00150 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266312.000 888527.0762 -4517278.2281 4399529.7394 2 7 0.1286 0.1425 0.1520 -0.0932 -0.1140 0.0812 0.00 2.0 -0.00902 0.00832 -0.02748 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266313.000 888527.0746 -4517278.2288 4399529.7517 2 7 0.1283 0.1423 0.1511 -0.0929 -0.1134 0.0807 0.00 1.9 0.03373 -0.01166 0.06622 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266314.000 888527.0722 -4517278.2260 4399529.7352 2 7 0.1279 0.1420 0.1501 -0.0926 -0.1129 0.0801 0.00 1.8 -0.00612 -0.00851 -0.03667 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266315.000 888527.0718 -4517278.2255 4399529.7609 2 7 0.1276 0.1417 0.1492 -0.0923 -0.1123 0.0796 0.00 1.7 0.01144 -0.01615 0.02419 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266316.000 888527.0740 -4517278.2261 4399529.7797 2 8 0.1272 0.1414 0.1482 -0.0920 -0.1117 0.0791 0.00 1.6 0.00285 -0.03911 0.06188 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266317.000 888527.0772 -4517278.2378 4399529.8016 2 8 0.1269 0.1411 0.1472 -0.0916 -0.1112 0.0785 0.00 1.5 0.00082 0.01604 -0.00511 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266318.000 888527.0737 -4517278.2341 4399529.7923 2 8 0.1265 0.1408 0.1447 -0.0913 -0.1102 0.0780 0.00 1.4 0.01673 -0.02326 0.09408 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266319.000 888527.0730 -4517278.2327 4399529.7830 2 8 0.1262 0.1405 0.1432 -0.0910 -0.1096 0.0774 0.00 1.3 -0.00240 0.00012 0.00113 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266320.000 888527.0682 -4517278.2290 4399529.7755 2 8 0.1258 0.1402 0.1419 -0.0907 -0.1089 0.0769 0.00 1.0 -0.02126 -0.01493 -0.05036 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266321.000 888527.0635 -4517278.2243 4399529.7717 2 8 0.1255 0.1400 0.1408 -0.0904 -0.1084 0.0764 0.00 1.1 -0.00542 0.00962 0.00493 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266322.000 888527.0642 -4517278.2235 4399529.7780 2 8 0.1252 0.1397 0.1397 -0.0901 -0.1078 0.0759 0.00 1.1 -0.00535 0.01617 0.00081 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266323.000 888527.0617 -4517278.2240 4399529.7678 2 6 0.1248 0.1394 0.1388 -0.0898 -0.1073 0.0753 0.00 1.1 0.02853 -0.03456 0.03447 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266324.000 888527.0610 -4517278.2163 4399529.7669 2 6 0.1245 0.1392 0.1377 -0.0895 -0.1067 0.0748 0.00 1.1 0.00139 0.01365 -0.00673 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266325.000 888527.0541 -4517278.2078 4399529.7427 2 6 0.1243 0.1389 0.1372 -0.0893 -0.1060 0.0740 0.00 1.1 0.00027 0.03813 -0.00843 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266326.000 888527.0646 -4517278.2277 4399529.7521 2 5 0.1242 0.1389 0.1372 -0.0892 -0.1060 0.0739 0.00 1.6 0.00693 -0.05198 0.05502 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266327.000 888527.0762 -4517278.2193 4399529.7474 2 7 0.1240 0.1388 0.1372 -0.0892 -0.1059 0.0738 0.00 1.8 0.00946 -0.04229 0.05143 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266328.000 888527.0771 -4517278.2224 4399529.7624 2 7 0.1238 0.1387 0.1371 -0.0892 -0.1059 0.0738 0.00 2.1 -0.00314 0.08980 -0.08078 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266329.000 888527.0831 -4517278.2197 4399529.7565 2 7 0.1237 0.1387 0.1371 -0.0891 -0.1059 0.0737 0.00 2.2 -0.00628 0.04072 -0.04043 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266330.000 888527.0919 -4517278.2243 4399529.7523 2 7 0.1235 0.1386 0.1371 -0.0891 -0.1058 0.0737 0.00 2.3 0.01787 -0.05298 0.07532 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266331.000 888527.1096 -4517278.2308 4399529.7464 2 8 0.1232 0.1385 0.1370 -0.0889 -0.1058 0.0735 0.00 3.0 -0.01660 0.00590 -0.04953 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266332.000 888527.1036 -4517278.2229 4399529.7502 2 8 0.1228 0.1382 0.1369 -0.0885 -0.1056 0.0733 0.00 3.1 0.02546 0.02823 0.03022 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266333.000 888527.1037 -4517278.2244 4399529.7445 2 8 0.1225 0.1380 0.1369 -0.0883 -0.1055 0.0731 0.00 3.9 -0.04857 0.10205 -0.16717 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266334.000 888527.1675 -4517278.2054 4399529.6726 1 8 0.0073 0.0163 0.0209 -0.0078 -0.0166 0.0077 0.00 5.1 -0.02012 0.05278 -0.03180 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266335.000 888527.1705 -4517278.2114 4399529.6590 1 8 0.0094 0.0185 0.0215 -0.0107 -0.0178 0.0094 0.00 10.6 -0.07560 0.05800 -0.19478 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266336.000 888527.1751 -4517278.2083 4399529.6931 1 8 0.0079 0.0171 0.0211 -0.0089 -0.0170 0.0083 0.00 10.6 0.07057 -0.01370 0.09184 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266337.000 888527.1701 -4517278.2144 4399529.6933 1 8 0.0075 0.0166 0.0210 -0.0082 -0.0167 0.0079 0.00 16.4 0.02705 -0.04195 0.04012 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266338.000 888527.1753 -4517278.2012 4399529.6779 1 8 0.0074 0.0163 0.0209 -0.0079 -0.0166 0.0077 0.00 20.0 -0.00232 -0.02702 0.00645 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266339.000 888527.1766 -4517278.2062 4399529.6910 1 6 0.0073 0.0163 0.0213 -0.0073 -0.0168 0.0071 0.00 22.4 0.07316 -0.03271 0.13024 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266340.000 888527.1689 -4517278.2071 4399529.6617 1 6 0.0073 0.0162 0.0213 -0.0072 -0.0167 0.0070 0.00 20.4 -0.04819 0.05481 -0.09398 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266341.000 888527.1682 -4517278.2089 4399529.6611 1 6 0.0071 0.0161 0.0213 -0.0070 -0.0167 0.0070 0.00 11.7 -0.04597 0.03182 -0.02195 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266342.000 888527.1690 -4517278.2139 4399529.6840 1 6 0.0071 0.0161 0.0213 -0.0069 -0.0167 0.0070 0.00 7.9 0.04391 -0.07016 0.15290 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266343.000 888527.1580 -4517278.2075 4399529.7407 2 6 0.1199 0.1368 0.1366 -0.0866 -0.1050 0.0718 0.00 4.4 -0.05783 0.00282 -0.09127 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266344.000 888527.1816 -4517278.2120 4399529.7925 2 6 0.1197 0.1366 0.1365 -0.0864 -0.1049 0.0717 0.00 4.8 0.05552 0.01000 0.14856 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266345.000 888527.1823 -4517278.2114 4399529.7760 2 6 0.1195 0.1365 0.1365 -0.0863 -0.1049 0.0716 0.00 1.9 0.01645 -0.04725 0.05547 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266346.000 888527.2015 -4517278.2172 4399529.7759 2 6 0.1192 0.1364 0.1364 -0.0861 -0.1048 0.0714 0.00 1.9 -0.03697 -0.01500 -0.01582 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266347.000 888527.2049 -4517278.2180 4399529.7699 2 6 0.1190 0.1363 0.1364 -0.0860 -0.1047 0.0713 0.00 1.7 -0.05140 -0.01356 -0.04867 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266348.000 888527.2142 -4517278.2086 4399529.7645 2 6 0.1188 0.1362 0.1363 -0.0858 -0.1047 0.0712 0.00 1.6 -0.02556 -0.01926 0.00023 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266349.000 888527.2317 -4517278.2045 4399529.7743 2 6 0.1185 0.1361 0.1362 -0.0857 -0.1046 0.0711 0.00 1.5 0.06467 0.00340 0.11067 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266350.000 888527.2478 -4517278.2171 4399529.7975 2 6 0.1183 0.1360 0.1362 -0.0855 -0.1046 0.0709 0.00 1.4 -0.01171 -0.00174 0.02127 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266351.000 888527.2547 -4517278.2090 4399529.7807 2 6 0.1181 0.1359 0.1361 -0.0854 -0.1045 0.0708 0.00 1.3 -0.03590 0.02774 -0.06598 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266352.000 888527.2670 -4517278.2152 4399529.8157 2 6 0.1179 0.1357 0.1360 -0.0852 -0.1044 0.0707 0.00 1.3 -0.00771 -0.05835 0.07009 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266353.000 888527.2845 -4517278.2197 4399529.8269 2 6 0.1176 0.1356 0.1359 -0.0851 -0.1043 0.0705 0.00 1.2 -0.03308 0.06434 -0.14393 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266354.000 888527.2922 -4517278.2193 4399529.8193 2 6 0.1174 0.1355 0.1358 -0.0850 -0.1043 0.0704 0.00 1.2 -0.02217 0.06865 -0.04098 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266355.000 888527.3159 -4517278.2245 4399529.8330 2 6 0.1172 0.1354 0.1357 -0.0848 -0.1042 0.0703 0.00 1.2 0.02392 -0.02758 0.04320 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266356.000 888527.3255 -4517278.2234 4399529.8272 2 6 0.1170 0.1353 0.1356 -0.0847 -0.1041 0.0701 0.00 1.0 0.00420 0.01497 -0.04355 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266357.000 888527.3287 -4517278.2294 4399529.8219 2 6 0.1168 0.1351 0.1355 -0.0845 -0.1040 0.0700 0.00 1.1 -0.02756 -0.00053 -0.03487 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266358.000 888527.3505 -4517278.2375 4399529.8410 2 6 0.1165 0.1350 0.1354 -0.0844 -0.1039 0.0698 0.00 1.1 -0.00312 0.01938 0.00279 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266359.000 888527.3650 -4517278.2412 4399529.8903 2 5 0.1163 0.1351 0.1391 -0.0842 -0.1047 0.0693 0.00 1.0 -0.01191 0.04796 -0.08048 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266360.000 888527.3821 -4517278.2498 4399529.9277 2 5 0.1161 0.1349 0.1389 -0.0840 -0.1046 0.0692 0.00 1.1 -0.02182 0.04648 -0.02116 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266361.000 888527.3913 -4517278.2507 4399529.9018 2 6 0.1159 0.1348 0.1388 -0.0839 -0.1045 0.0690 0.00 1.2 -0.03084 0.00158 -0.08330 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266362.000 888527.4080 -4517278.2587 4399529.9184 2 6 0.1157 0.1346 0.1365 -0.0837 -0.1038 0.0689 0.00 1.3 -0.07892 0.09343 -0.15070 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266363.000 888527.4267 -4517278.2682 4399529.9385 2 6 0.1155 0.1345 0.1357 -0.0836 -0.1035 0.0687 0.00 1.3 -0.00850 0.03452 -0.03310 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266364.000 888527.4359 -4517278.2723 4399529.9444 2 6 0.1153 0.1343 0.1351 -0.0835 -0.1033 0.0686 0.00 1.3 -0.00938 -0.03738 0.05883 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266365.000 888527.4503 -4517278.2711 4399529.9514 2 6 0.1151 0.1343 0.1381 -0.0833 -0.1041 0.0684 0.00 1.1 -0.01957 0.03502 -0.04426 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266366.000 888527.4721 -4517278.2830 4399529.9632 2 6 0.1149 0.1341 0.1358 -0.0832 -0.1034 0.0683 0.00 1.2 -0.00182 -0.01050 -0.00916 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266367.000 888527.4818 -4517278.2885 4399529.9554 2 6 0.1147 0.1340 0.1349 -0.0830 -0.1031 0.0681 0.00 1.4 0.00168 -0.00349 0.00900 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266368.000 888527.4964 -4517278.2926 4399529.9649 2 6 0.1145 0.1338 0.1343 -0.0829 -0.1028 0.0680 0.00 1.5 0.00131 -0.00518 0.01737 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266369.000 888527.5149 -4517278.3060 4399529.9871 2 6 0.1143 0.1337 0.1339 -0.0828 -0.1026 0.0678 0.00 1.6 -0.02672 0.00045 -0.02584 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266370.000 888527.5312 -4517278.3087 4399529.9831 2 6 0.1141 0.1336 0.1336 -0.0826 -0.1025 0.0677 0.00 1.4 -0.00501 -0.01030 0.00293 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266371.000 888527.5510 -4517278.3140 4399529.9983 2 6 0.1139 0.1334 0.1332 -0.0825 -0.1023 0.0675 0.00 1.2 0.06494 -0.01237 0.12239 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266372.000 888527.5684 -4517278.3228 4399530.0034 2 6 0.1137 0.1333 0.1329 -0.0823 -0.1021 0.0673 0.00 1.1 -0.00290 0.00977 0.02401 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266373.000 888527.5786 -4517278.3266 4399530.0132 2 6 0.1135 0.1332 0.1326 -0.0822 -0.1020 0.0672 0.00 1.0 0.02062 0.02322 0.00852 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266374.000 888527.5967 -4517278.3334 4399530.0039 2 6 0.1133 0.1330 0.1323 -0.0820 -0.1018 0.0670 0.00 1.1 -0.00683 0.01451 -0.02492 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266375.000 888527.6141 -4517278.3386 4399530.0169 2 6 0.1131 0.1329 0.1320 -0.0819 -0.1016 0.0668 0.00 1.1 0.01723 0.02553 0.05498 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266376.000 888527.6245 -4517278.3511 4399530.0223 2 6 0.1129 0.1327 0.1317 -0.0818 -0.1015 0.0667 0.00 1.2 0.00328 -0.03922 -0.00907 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266377.000 888527.6588 -4517278.3695 4399530.0380 2 6 0.1127 0.1326 0.1314 -0.0816 -0.1013 0.0665 0.00 1.1 -0.01155 0.04512 -0.00868 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266378.000 888527.6705 -4517278.3697 4399530.0566 2 6 0.1125 0.1325 0.1311 -0.0815 -0.1011 0.0663 0.00 1.2 0.03880 -0.00937 0.10806 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266379.000 888527.6950 -4517278.3900 4399530.0527 2 5 0.1126 0.1325 0.1309 -0.0817 -0.1008 0.0660 0.00 1.5 0.00769 0.03118 0.03104 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266380.000 888527.7011 -4517278.3934 4399530.0564 2 5 0.1125 0.1325 0.1309 -0.0816 -0.1008 0.0659 0.00 1.7 -0.00006 0.00957 -0.01261 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266381.000 888527.7171 -4517278.4162 4399530.0664 2 6 0.1123 0.1323 0.1308 -0.0815 -0.1007 0.0658 0.00 1.7 -0.02408 -0.03112 0.03320 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266382.000 888527.7424 -4517278.4127 4399530.0520 2 6 0.1120 0.1321 0.1308 -0.0812 -0.1006 0.0656 0.00 1.9 -0.02093 0.04434 -0.06449 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266383.000 888527.7664 -4517278.4309 4399530.0701 2 6 0.1119 0.1321 0.1308 -0.0812 -0.1006 0.0656 0.00 1.0 -0.01560 0.03017 0.02929 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266384.000 888527.7838 -4517278.4421 4399530.0593 2 6 0.1116 0.1319 0.1307 -0.0809 -0.1005 0.0654 0.00 1.0 -0.03150 0.04886 -0.06539 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266385.000 888527.8021 -4517278.4463 4399530.0600 2 5 0.1116 0.1320 0.1307 -0.0811 -0.1006 0.0654 0.00 2.7 0.00316 -0.02490 0.05054 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266386.000 888527.8106 -4517278.4474 4399530.0610 2 5 0.1115 0.1319 0.1307 -0.0811 -0.1005 0.0654 0.00 2.8 0.01434 0.00609 0.02282 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266387.000 888527.8244 -4517278.4539 4399530.0609 2 5 0.1114 0.1319 0.1307 -0.0811 -0.1005 0.0653 0.00 2.7 0.00914 0.02219 -0.00287 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266388.000 888527.8377 -4517278.4574 4399530.0558 2 5 0.1113 0.1318 0.1307 -0.0810 -0.1005 0.0653 0.00 2.4 0.01764 0.00494 0.05492 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266389.000 888527.8406 -4517278.4573 4399530.0634 2 5 0.1112 0.1318 0.1307 -0.0810 -0.1005 0.0652 0.00 2.1 0.00733 0.03678 0.02243 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266390.000 888527.8464 -4517278.4587 4399530.0586 2 5 0.1112 0.1317 0.1306 -0.0810 -0.1004 0.0652 0.00 1.7 0.01183 0.00282 0.06313 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266391.000 888527.8536 -4517278.4612 4399530.0558 2 5 0.1111 0.1317 0.1306 -0.0810 -0.1004 0.0651 0.00 1.4 -0.02703 -0.01067 0.01899 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266392.000 888527.8668 -4517278.4697 4399530.0622 2 5 0.1110 0.1316 0.1306 -0.0810 -0.1004 0.0650 0.00 1.2 -0.03813 0.05124 -0.06907 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266393.000 888527.8726 -4517278.4730 4399530.0640 2 5 0.1109 0.1316 0.1306 -0.0809 -0.1004 0.0650 0.00 1.1 -0.02414 0.01579 -0.04086 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266394.000 888527.8800 -4517278.4745 4399530.0615 2 5 0.1108 0.1315 0.1306 -0.0809 -0.1003 0.0649 0.00 1.1 -0.00552 -0.03593 0.01433 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266395.000 888527.8947 -4517278.4837 4399530.0659 2 5 0.1107 0.1315 0.1305 -0.0809 -0.1003 0.0649 0.00 1.2 -0.00527 -0.04760 0.08042 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266396.000 888527.9087 -4517278.4844 4399530.0557 2 5 0.1106 0.1314 0.1305 -0.0809 -0.1003 0.0648 0.00 1.2 0.00507 0.03991 0.00883 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266397.000 888527.9150 -4517278.4877 4399530.0605 2 5 0.1105 0.1313 0.1305 -0.0808 -0.1003 0.0648 0.00 1.3 0.00176 -0.02655 0.01194 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266398.000 888527.9238 -4517278.4891 4399530.0503 2 5 0.1105 0.1313 0.1305 -0.0808 -0.1002 0.0647 0.00 1.4 -0.01172 0.02832 0.04997 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266399.000 888527.9420 -4517278.4970 4399530.0568 2 5 0.1104 0.1312 0.1305 -0.0808 -0.1002 0.0647 0.00 1.5 0.01065 0.00102 0.02497 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266400.000 888527.9458 -4517278.5018 4399530.0547 2 5 0.1103 0.1312 0.1304 -0.0808 -0.1002 0.0646 0.00 1.5 -0.00502 -0.00833 0.01775 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266401.000 888527.9561 -4517278.5015 4399530.0283 2 5 0.1102 0.1311 0.1304 -0.0808 -0.1002 0.0645 0.00 1.1 0.01999 -0.03791 0.00211 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266402.000 888527.9718 -4517278.5112 4399530.0530 2 5 0.1101 0.1311 0.1304 -0.0807 -0.1001 0.0645 0.00 1.1 0.01870 -0.03683 0.07781 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266403.000 888527.9787 -4517278.5121 4399530.0393 2 5 0.1100 0.1310 0.1304 -0.0807 -0.1001 0.0644 0.00 1.1 0.00560 -0.00327 0.02891 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266404.000 888527.9807 -4517278.5180 4399530.0546 2 5 0.1099 0.1310 0.1304 -0.0807 -0.1001 0.0644 0.00 1.0 -0.04044 -0.00555 -0.00715 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266405.000 888528.0002 -4517278.5175 4399530.0350 2 5 0.1098 0.1309 0.1303 -0.0807 -0.1001 0.0643 0.00 1.0 -0.00740 0.02769 -0.08212 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266406.000 888528.0035 -4517278.5254 4399530.0408 2 5 0.1097 0.1309 0.1303 -0.0806 -0.1000 0.0642 0.00 1.1 -0.00435 -0.03552 0.03328 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266407.000 888528.0131 -4517278.5314 4399530.0478 2 5 0.1097 0.1308 0.1303 -0.0806 -0.1000 0.0642 0.00 1.2 -0.04044 0.04151 -0.09277 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266408.000 888528.0235 -4517278.5319 4399530.0470 2 5 0.1096 0.1308 0.1303 -0.0806 -0.1000 0.0641 0.00 1.3 -0.00442 0.02690 -0.01639 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266409.000 888528.0422 -4517278.5433 4399530.0490 2 6 0.1094 0.1307 0.1303 -0.0805 -0.0999 0.0640 0.00 1.2 0.00281 0.02727 -0.01334 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266410.000 888528.0703 -4517278.5680 4399530.0523 2 6 0.1091 0.1304 0.1302 -0.0801 -0.0998 0.0638 0.00 1.0 -0.00334 0.00723 -0.01220 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266411.000 888528.0955 -4517278.5753 4399530.0552 2 6 0.1088 0.1302 0.1302 -0.0799 -0.0997 0.0637 0.00 1.0 0.01423 0.00531 -0.03664 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266412.000 888528.1093 -4517278.5899 4399530.0726 2 6 0.1086 0.1301 0.1302 -0.0798 -0.0997 0.0636 0.00 1.0 -0.03665 -0.03093 0.00686 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266413.000 888528.1296 -4517278.6158 4399530.0761 2 6 0.1086 0.1303 0.1302 -0.0800 -0.0998 0.0636 0.00 1.3 -0.06214 -0.07777 0.03125 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266414.000 888528.1462 -4517278.6190 4399530.0607 2 5 0.1085 0.1302 0.1301 -0.0799 -0.0997 0.0636 0.00 1.5 0.00217 0.03153 0.01358 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266415.000 888528.1659 -4517278.6186 4399530.0686 2 5 0.1085 0.1302 0.1301 -0.0799 -0.0997 0.0635 0.00 1.7 0.03667 -0.00900 0.05693 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266416.000 888528.1657 -4517278.6298 4399530.0684 2 5 0.1084 0.1301 0.1301 -0.0799 -0.0997 0.0635 0.00 1.8 0.02104 0.00210 0.07104 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266417.000 888528.1811 -4517278.6311 4399530.0656 2 5 0.1083 0.1300 0.1301 -0.0799 -0.0997 0.0634 0.00 1.9 0.01378 -0.04117 0.03972 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266418.000 888528.2000 -4517278.6349 4399530.0512 2 5 0.1082 0.1300 0.1301 -0.0799 -0.0996 0.0633 0.00 1.9 0.04814 0.06902 0.03103 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266419.000 888528.2002 -4517278.6483 4399530.0535 2 6 0.1080 0.1299 0.1300 -0.0797 -0.0996 0.0632 0.00 1.9 -0.02388 0.02294 -0.03121 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266420.000 888528.2251 -4517278.6633 4399530.0464 2 6 0.1078 0.1298 0.1300 -0.0796 -0.0995 0.0631 0.00 1.8 -0.00291 -0.06890 0.06061 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266421.000 888528.2464 -4517278.6820 4399530.0575 2 6 0.1075 0.1295 0.1300 -0.0792 -0.0994 0.0629 0.00 1.4 -0.03496 0.03676 -0.13509 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266422.000 888528.2810 -4517278.6995 4399530.0604 2 6 0.1073 0.1294 0.1299 -0.0791 -0.0993 0.0628 0.00 1.2 0.03802 0.00105 0.04321 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266423.000 888528.3053 -4517278.7110 4399530.0776 2 6 0.1071 0.1293 0.1299 -0.0789 -0.0993 0.0627 0.00 1.1 -0.03774 0.00701 0.00151 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266424.000 888528.3260 -4517278.7205 4399530.0607 2 6 0.1069 0.1292 0.1299 -0.0788 -0.0992 0.0626 0.00 1.0 0.00799 0.03510 0.00787 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266425.000 888528.3408 -4517278.7349 4399530.0472 2 6 0.1067 0.1291 0.1299 -0.0787 -0.0992 0.0625 0.00 1.0 -0.01449 -0.00609 -0.00905 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266426.000 888528.3689 -4517278.7525 4399530.0773 2 7 0.1065 0.1290 0.1298 -0.0785 -0.0992 0.0624 0.00 1.1 0.06840 0.00454 0.13823 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266427.000 888528.3811 -4517278.7641 4399530.0669 2 7 0.1064 0.1289 0.1296 -0.0784 -0.0991 0.0623 0.00 1.1 0.00307 -0.01016 -0.01693 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266428.000 888528.4074 -4517278.7808 4399530.0837 2 7 0.1062 0.1288 0.1295 -0.0783 -0.0990 0.0621 0.00 1.1 -0.02500 0.04276 -0.05882 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266429.000 888528.4259 -4517278.7963 4399530.0983 2 7 0.1060 0.1287 0.1295 -0.0782 -0.0990 0.0620 0.00 1.1 0.00191 -0.04377 0.07478 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266430.000 888528.4434 -4517278.8168 4399530.1092 2 7 0.1058 0.1286 0.1294 -0.0781 -0.0989 0.0619 0.00 1.0 0.00165 -0.00333 0.03722 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266431.000 888528.4571 -4517278.8309 4399530.1105 2 7 0.1056 0.1285 0.1296 -0.0780 -0.0990 0.0619 0.00 1.3 -0.02924 -0.00544 -0.01809 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266432.000 888528.4689 -4517278.8337 4399530.0863 2 6 0.1057 0.1287 0.1294 -0.0783 -0.0989 0.0618 0.00 1.6 -0.00055 0.02004 -0.02840 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266433.000 888528.4762 -4517278.8388 4399530.0909 2 6 0.1056 0.1286 0.1293 -0.0783 -0.0989 0.0617 0.00 1.8 -0.00621 -0.00150 -0.02515 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266434.000 888528.4789 -4517278.8490 4399530.1030 2 6 0.1055 0.1285 0.1292 -0.0782 -0.0988 0.0616 0.00 1.9 0.01780 -0.01402 0.04216 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266435.000 888528.4934 -4517278.8572 4399530.0941 2 6 0.1054 0.1285 0.1292 -0.0782 -0.0988 0.0615 0.00 1.9 0.01841 -0.01387 -0.07509 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266436.000 888528.4799 -4517278.8490 4399530.0927 2 6 0.1053 0.1284 0.1291 -0.0782 -0.0987 0.0614 0.00 1.9 -0.01698 -0.03247 0.05191 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266437.000 888528.4950 -4517278.8536 4399530.0694 2 6 0.1052 0.1284 0.1291 -0.0781 -0.0987 0.0613 0.00 1.9 -0.00550 0.10272 -0.20551 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266438.000 888528.4985 -4517278.8700 4399530.1018 2 6 0.1051 0.1283 0.1290 -0.0781 -0.0987 0.0612 0.00 1.8 -0.03693 0.00804 -0.11300 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266439.000 888528.5125 -4517278.8677 4399530.0855 2 6 0.1050 0.1282 0.1290 -0.0781 -0.0986 0.0611 0.00 1.7 0.01314 -0.04100 0.00653 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266440.000 888528.5250 -4517278.8809 4399530.0782 2 6 0.1049 0.1282 0.1289 -0.0780 -0.0986 0.0610 0.00 1.6 0.05249 0.04756 -0.05744 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266441.000 888528.5224 -4517278.8797 4399530.0719 2 6 0.1048 0.1281 0.1288 -0.0780 -0.0985 0.0609 0.00 1.5 -0.04756 0.03245 -0.18978 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266442.000 888528.5279 -4517278.8905 4399530.0997 2 6 0.1047 0.1281 0.1288 -0.0780 -0.0985 0.0608 0.00 1.4 0.02861 0.05987 0.01783 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266443.000 888528.5292 -4517278.8877 4399530.0964 2 6 0.1046 0.1280 0.1287 -0.0779 -0.0984 0.0607 0.00 1.3 -0.01789 -0.01625 0.01011 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266444.000 888528.5320 -4517278.8877 4399530.0728 2 6 0.1045 0.1279 0.1287 -0.0779 -0.0984 0.0606 0.00 1.3 -0.00361 0.03173 -0.01798 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266445.000 888528.5366 -4517278.8955 4399530.0964 2 6 0.1044 0.1279 0.1286 -0.0779 -0.0983 0.0605 0.00 1.2 0.00439 -0.06801 0.06192 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266446.000 888528.5424 -4517278.8997 4399530.0836 2 6 0.1043 0.1278 0.1285 -0.0778 -0.0982 0.0604 0.00 1.2 -0.01847 -0.04739 -0.04988 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266447.000 888528.5410 -4517278.9072 4399530.1055 2 6 0.1042 0.1277 0.1284 -0.0778 -0.0982 0.0602 0.00 1.1 -0.00926 0.05478 0.01996 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266448.000 888528.5523 -4517278.9199 4399530.1098 2 6 0.1041 0.1276 0.1284 -0.0777 -0.0981 0.0601 0.00 1.0 0.00693 -0.02122 0.05982 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266449.000 888528.5706 -4517278.9284 4399530.1001 2 6 0.1040 0.1276 0.1283 -0.0777 -0.0980 0.0600 0.00 1.1 0.01399 0.04399 -0.00424 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266450.000 888528.5700 -4517278.9344 4399530.1070 2 6 0.1039 0.1275 0.1282 -0.0777 -0.0979 0.0599 0.00 1.1 -0.00089 -0.00765 0.02536 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266451.000 888528.5537 -4517278.9333 4399530.1140 2 6 0.1038 0.1274 0.1281 -0.0776 -0.0979 0.0598 0.00 1.2 -0.03571 0.03048 -0.10350 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266452.000 888528.5761 -4517278.9487 4399530.1130 2 6 0.1037 0.1273 0.1280 -0.0776 -0.0978 0.0597 0.00 1.2 0.00465 -0.01829 0.01056 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266453.000 888528.5606 -4517278.9420 4399530.1112 2 6 0.1036 0.1272 0.1279 -0.0775 -0.0977 0.0595 0.00 1.3 -0.02933 -0.03366 -0.02061 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266454.000 888528.5756 -4517278.9554 4399530.1266 2 6 0.1035 0.1271 0.1278 -0.0775 -0.0976 0.0594 0.00 1.3 0.07071 -0.03943 0.07957 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266455.000 888528.5706 -4517278.9600 4399530.1158 2 6 0.1034 0.1271 0.1277 -0.0774 -0.0975 0.0593 0.00 1.3 -0.00210 -0.01168 -0.02895 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266456.000 888528.5760 -4517278.9602 4399530.1282 2 5 0.1034 0.1270 0.1278 -0.0775 -0.0972 0.0588 0.00 1.4 0.01195 0.05094 -0.00394 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266457.000 888528.5757 -4517278.9642 4399530.1195 2 5 0.1033 0.1270 0.1277 -0.0775 -0.0972 0.0587 0.00 1.5 -0.01662 -0.03987 -0.02481 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266458.000 888528.5740 -4517278.9648 4399530.1456 2 5 0.1033 0.1269 0.1277 -0.0775 -0.0971 0.0586 0.00 1.5 0.00350 -0.00802 -0.00576 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266459.000 888528.5747 -4517278.9666 4399530.1366 2 6 0.1031 0.1268 0.1276 -0.0774 -0.0970 0.0585 0.00 1.5 -0.05863 -0.10646 0.00236 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266460.000 888528.5853 -4517278.9755 4399530.1206 2 6 0.1028 0.1266 0.1275 -0.0771 -0.0970 0.0585 0.00 1.7 -0.05398 0.01187 -0.21891 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266461.000 888528.5933 -4517278.9905 4399530.1767 2 6 0.1028 0.1266 0.1274 -0.0772 -0.0969 0.0583 0.00 1.3 0.00241 0.00080 -0.00843 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266462.000 888528.6002 -4517278.9947 4399530.1484 2 5 0.1025 0.1266 0.1322 -0.0769 -0.0981 0.0579 0.00 1.1 -0.02565 0.04266 -0.07996 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266463.000 888528.6017 -4517278.9973 4399530.1503 2 5 0.1023 0.1265 0.1321 -0.0767 -0.0981 0.0579 0.00 1.1 -0.01445 0.06005 -0.03000 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266464.000 888528.5990 -4517279.0018 4399530.1799 2 4 0.1025 0.1266 0.1325 -0.0770 -0.0978 0.0573 0.00 2.0 -0.00070 -0.02479 0.01998 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266465.000 888528.6470 -4517278.9904 4399530.2278 2 5 0.1021 0.1265 0.1322 -0.0771 -0.0978 0.0567 0.00 1.0 0.00024 0.03578 0.00777 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266466.000 888528.6384 -4517278.9902 4399530.2074 2 5 0.1021 0.1264 0.1322 -0.0771 -0.0978 0.0567 0.00 1.0 -0.03908 0.01706 -0.01813 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266467.000 888528.6453 -4517278.9925 4399530.2060 2 5 0.1020 0.1264 0.1322 -0.0770 -0.0977 0.0566 0.00 1.5 0.00418 0.03124 0.00046 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266468.000 888528.6439 -4517278.9939 4399530.2081 2 4 0.1019 0.1264 0.1322 -0.0770 -0.0977 0.0565 0.00 1.1 0.00684 0.00412 0.03644 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266469.000 888528.6402 -4517278.9954 4399530.1932 2 5 0.1019 0.1263 0.1322 -0.0770 -0.0977 0.0565 0.00 1.1 -0.02658 -0.07884 0.04690 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266470.000 888528.6462 -4517278.9976 4399530.1969 2 5 0.1018 0.1262 0.1298 -0.0770 -0.0973 0.0569 0.00 1.2 0.00038 -0.07457 0.08896 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266471.000 888528.6476 -4517279.0022 4399530.1927 2 5 0.1017 0.1262 0.1290 -0.0770 -0.0972 0.0570 0.00 1.3 -0.01695 -0.01706 0.00093 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266472.000 888528.6396 -4517278.9978 4399530.1825 2 6 0.1016 0.1261 0.1286 -0.0770 -0.0971 0.0571 0.00 1.4 -0.03798 -0.00882 -0.01819 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266473.000 888528.6483 -4517279.0087 4399530.2096 2 6 0.1016 0.1261 0.1321 -0.0769 -0.0975 0.0562 0.00 1.2 0.02943 0.03951 0.03754 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266474.000 888528.6500 -4517279.0148 4399530.1904 2 6 0.1015 0.1260 0.1295 -0.0769 -0.0971 0.0565 0.00 1.5 -0.00695 0.02069 -0.03114 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266475.000 888528.6401 -4517279.0150 4399530.2046 2 7 0.1014 0.1260 0.1289 -0.0769 -0.0971 0.0567 0.00 1.0 -0.03552 0.02386 -0.02980 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266476.000 888528.6343 -4517279.0176 4399530.2071 2 8 0.1012 0.1258 0.1283 -0.0767 -0.0969 0.0565 0.00 1.0 -0.02997 -0.00493 -0.02959 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266477.000 888528.6379 -4517279.0211 4399530.2003 2 8 0.1009 0.1256 0.1280 -0.0764 -0.0968 0.0564 0.00 1.1 0.03453 -0.00586 0.01619 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266478.000 888528.6426 -4517279.0284 4399530.2000 2 8 0.1007 0.1254 0.1278 -0.0762 -0.0967 0.0563 0.00 1.2 0.05042 -0.01131 0.08270 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266479.000 888528.6473 -4517279.0339 4399530.1861 2 9 0.1006 0.1255 0.1276 -0.0763 -0.0966 0.0562 0.00 1.2 0.10810 -0.00923 0.08867 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266480.000 888528.6524 -4517279.0463 4399530.1972 2 9 0.1003 0.1253 0.1275 -0.0760 -0.0965 0.0561 0.00 1.2 0.04751 -0.05004 0.08885 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266481.000 888528.6433 -4517279.0436 4399530.1802 2 7 0.1002 0.1252 0.1274 -0.0760 -0.0966 0.0562 0.00 1.0 0.01114 -0.00580 -0.02003 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266482.000 888528.6556 -4517279.0549 4399530.1846 2 6 0.1003 0.1253 0.1273 -0.0762 -0.0966 0.0561 0.00 1.3 0.02144 0.01547 0.04876 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266483.000 888528.6464 -4517279.0529 4399530.1838 2 8 0.1002 0.1253 0.1272 -0.0762 -0.0965 0.0560 0.00 1.4 0.05124 -0.01334 0.10523 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266484.000 888528.6260 -4517279.0525 4399530.1911 2 8 0.1001 0.1252 0.1270 -0.0761 -0.0964 0.0558 0.00 1.2 0.02098 -0.09597 0.09247 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266485.000 888528.6365 -4517279.0507 4399530.1724 2 8 0.1000 0.1251 0.1269 -0.0760 -0.0963 0.0557 0.00 1.0 0.01385 -0.04329 0.08036 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266486.000 888528.6268 -4517279.0480 4399530.1799 2 8 0.0999 0.1250 0.1268 -0.0760 -0.0962 0.0555 0.00 1.1 0.00421 0.03999 -0.05145 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266487.000 888528.6370 -4517279.0563 4399530.1668 2 6 0.0999 0.1251 0.1268 -0.0761 -0.0963 0.0556 0.00 1.2 0.05911 0.02263 0.08178 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266488.000 888528.6302 -4517279.0554 4399530.1788 2 6 0.0998 0.1250 0.1267 -0.0761 -0.0963 0.0556 0.00 1.2 0.00258 0.03384 0.01283 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266489.000 888528.6260 -4517279.0579 4399530.1777 2 6 0.0998 0.1249 0.1267 -0.0760 -0.0962 0.0555 0.00 1.2 -0.00417 -0.01506 0.02963 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266490.000 888528.6288 -4517279.0603 4399530.1575 2 6 0.0997 0.1249 0.1266 -0.0760 -0.0962 0.0554 0.00 1.2 0.04425 0.00823 0.01805 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266491.000 888528.6316 -4517279.0685 4399530.1722 2 6 0.0996 0.1248 0.1265 -0.0760 -0.0961 0.0553 0.00 1.3 -0.01763 0.00063 -0.02232 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266492.000 888528.6155 -4517279.0695 4399530.1827 2 5 0.0996 0.1249 0.1269 -0.0761 -0.0963 0.0556 0.00 2.5 0.00948 0.01668 0.02092 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266493.000 888528.6143 -4517279.0684 4399530.1748 2 5 0.0995 0.1248 0.1269 -0.0760 -0.0963 0.0555 0.00 2.6 0.00035 -0.01676 0.06406 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266494.000 888528.6181 -4517279.0772 4399530.1820 2 5 0.0995 0.1248 0.1269 -0.0760 -0.0963 0.0555 0.00 2.7 0.01900 0.01445 0.01566 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266495.000 888528.6126 -4517279.0731 4399530.1761 2 5 0.0994 0.1247 0.1269 -0.0760 -0.0962 0.0554 0.00 2.9 0.01628 0.02936 0.00866 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266496.000 888528.6055 -4517279.0754 4399530.1658 2 6 0.0994 0.1247 0.1268 -0.0760 -0.0962 0.0554 0.00 3.1 -0.00572 -0.06151 0.01924 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266497.000 888528.6116 -4517279.0827 4399530.1833 2 6 0.0993 0.1246 0.1268 -0.0760 -0.0962 0.0553 0.00 1.4 0.05195 -0.05870 0.12365 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266498.000 888528.6061 -4517279.0817 4399530.1604 2 6 0.0992 0.1246 0.1266 -0.0759 -0.0961 0.0551 0.00 1.2 -0.01745 -0.01147 -0.03372 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266499.000 888528.6032 -4517279.0819 4399530.1699 2 6 0.0991 0.1245 0.1265 -0.0759 -0.0960 0.0550 0.00 1.2 0.00353 -0.01361 0.08681 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266500.000 888528.5958 -4517279.0803 4399530.1706 2 6 0.0991 0.1244 0.1264 -0.0759 -0.0960 0.0549 0.00 1.0 -0.03610 -0.02154 -0.05193 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266501.000 888528.5871 -4517279.0832 4399530.1716 2 6 0.0990 0.1244 0.1263 -0.0759 -0.0959 0.0548 0.00 1.0 0.01798 0.02608 0.06559 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266502.000 888528.5856 -4517279.0889 4399530.1759 2 6 0.0989 0.1243 0.1263 -0.0758 -0.0959 0.0548 0.00 1.1 0.03940 -0.01562 0.10691 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266503.000 888528.5674 -4517279.0852 4399530.1682 2 6 0.0989 0.1243 0.1262 -0.0758 -0.0958 0.0547 0.00 1.2 0.00914 0.00913 0.12613 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266504.000 888528.5683 -4517279.0902 4399530.1624 2 6 0.0988 0.1242 0.1262 -0.0758 -0.0958 0.0546 0.00 1.2 -0.03555 0.00520 -0.01476 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266505.000 888528.5689 -4517279.0866 4399530.1576 2 6 0.0987 0.1242 0.1261 -0.0758 -0.0958 0.0545 0.00 1.1 -0.02394 -0.00704 -0.03520 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266506.000 888528.5730 -4517279.1015 4399530.1637 2 6 0.0987 0.1241 0.1260 -0.0757 -0.0957 0.0544 0.00 1.2 0.00192 0.01602 -0.03342 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266507.000 888528.5623 -4517279.1009 4399530.1549 2 6 0.0986 0.1241 0.1260 -0.0757 -0.0957 0.0544 0.00 1.3 -0.01318 -0.00979 0.05771 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266508.000 888528.5756 -4517279.1043 4399530.1411 2 6 0.0985 0.1240 0.1259 -0.0757 -0.0956 0.0543 0.00 1.3 -0.02387 0.10969 -0.19257 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266509.000 888528.5659 -4517279.1063 4399530.1443 2 5 0.0985 0.1240 0.1264 -0.0757 -0.0958 0.0545 0.00 2.5 -0.05117 0.00835 -0.01712 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266510.000 888528.5575 -4517279.1081 4399530.1507 2 5 0.0985 0.1240 0.1263 -0.0757 -0.0958 0.0545 0.00 2.2 0.00183 0.06725 -0.06506 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266511.000 888528.5611 -4517279.1089 4399530.1420 2 5 0.0984 0.1239 0.1263 -0.0757 -0.0958 0.0544 0.00 2.1 -0.01004 0.03498 -0.03025 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266512.000 888528.5500 -4517279.1121 4399530.1555 2 6 0.0983 0.1239 0.1263 -0.0757 -0.0957 0.0544 0.00 1.9 -0.00552 -0.04843 0.07860 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266513.000 888528.5022 -4517279.1568 4399530.0844 1 5 0.0279 0.0190 0.0247 -0.0156 -0.0154 -0.0163 0.00 7.2 -0.00277 -0.03359 0.02091 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266514.000 888528.4982 -4517279.1530 4399530.0877 1 5 0.0270 0.0189 0.0247 -0.0151 -0.0155 -0.0161 0.00 8.1 -0.03352 -0.01363 -0.08611 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266515.000 888528.5387 -4517279.1676 4399530.0782 1 5 0.0517 0.0226 0.0259 -0.0279 -0.0120 -0.0244 0.00 9.1 -0.01512 0.03215 -0.01415 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266516.000 888528.5469 -4517279.1675 4399530.0640 1 5 0.0394 0.0205 0.0252 -0.0215 -0.0141 -0.0201 0.00 10.0 0.02382 0.02216 0.11925 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266517.000 888528.5185 -4517279.1626 4399530.0873 1 5 0.0343 0.0198 0.0250 -0.0189 -0.0148 -0.0184 0.00 11.0 0.00957 0.00333 0.05136 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266518.000 888528.5311 -4517279.1608 4399530.0678 1 5 0.0315 0.0194 0.0249 -0.0174 -0.0151 -0.0175 0.00 12.5 -0.02096 0.00156 0.00186 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266519.000 888528.5304 -4517279.1666 4399530.0678 1 6 0.0297 0.0192 0.0248 -0.0165 -0.0152 -0.0169 0.00 15.5 -0.02268 -0.02556 -0.02647 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266520.000 888528.5277 -4517279.1666 4399530.0682 1 6 0.0253 0.0189 0.0227 -0.0152 -0.0159 -0.0121 0.00 19.1 -0.02102 -0.01416 0.03110 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266521.000 888528.5407 -4517279.1677 4399530.0555 1 6 0.0274 0.0189 0.0248 -0.0153 -0.0154 -0.0163 0.00 23.0 -0.06139 -0.05135 -0.08815 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266522.000 888528.5483 -4517279.1689 4399530.0577 1 6 0.0233 0.0187 0.0227 -0.0143 -0.0160 -0.0114 0.00 29.2 0.04352 -0.01377 0.01919 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266523.000 888528.5343 -4517279.1633 4399530.0521 1 6 0.0214 0.0187 0.0219 -0.0137 -0.0162 -0.0091 0.00 37.3 0.05353 -0.01405 0.07347 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266524.000 888528.5369 -4517279.1669 4399530.0608 1 6 0.0201 0.0186 0.0215 -0.0133 -0.0163 -0.0076 0.00 46.3 0.00450 0.00224 0.00476 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266525.000 888528.5393 -4517279.1699 4399530.0736 1 6 0.0192 0.0185 0.0213 -0.0130 -0.0164 -0.0064 0.00 59.5 0.00880 0.00657 0.05057 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266526.000 888528.5369 -4517279.1692 4399530.0735 1 7 0.0185 0.0185 0.0211 -0.0127 -0.0164 -0.0054 0.00 70.0 -0.01910 0.01466 0.09414 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266527.000 888528.5428 -4517279.1642 4399530.0392 1 7 0.0178 0.0185 0.0210 -0.0125 -0.0165 -0.0045 0.00 79.0 -0.00600 -0.01976 -0.02368 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266528.000 888528.5351 -4517279.1652 4399530.0494 1 7 0.0165 0.0174 0.0209 -0.0110 -0.0163 -0.0044 0.00 71.5 -0.01800 -0.04429 -0.03413 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266529.000 888528.5329 -4517279.1711 4399530.0623 1 7 0.0158 0.0170 0.0208 -0.0104 -0.0163 -0.0041 0.00 53.7 -0.00298 -0.04220 0.03167 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266530.000 888528.5335 -4517279.1707 4399530.0665 1 6 0.0157 0.0175 0.0224 -0.0089 -0.0176 -0.0070 0.00 41.5 -0.02835 0.02245 -0.00558 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266531.000 888528.5291 -4517279.1696 4399530.0711 1 6 0.0152 0.0175 0.0223 -0.0085 -0.0176 -0.0066 0.00 31.7 -0.01651 0.04024 -0.01438 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266532.000 888528.5226 -4517279.1694 4399530.0711 1 6 0.0149 0.0174 0.0223 -0.0084 -0.0176 -0.0062 0.00 27.1 -0.02325 -0.01304 0.03569 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266533.000 888528.5298 -4517279.1677 4399530.0744 1 6 0.0145 0.0174 0.0222 -0.0081 -0.0177 -0.0059 0.00 22.8 -0.01391 -0.00669 -0.01551 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266534.000 888528.5270 -4517279.1694 4399530.0675 1 6 0.0141 0.0174 0.0222 -0.0080 -0.0177 -0.0057 0.00 19.0 0.02502 -0.03369 0.04019 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266535.000 888528.5255 -4517279.1635 4399530.0620 1 6 0.0139 0.0174 0.0222 -0.0078 -0.0177 -0.0054 0.00 15.7 -0.00183 0.03444 0.02348 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266536.000 888528.5221 -4517279.1659 4399530.0714 1 6 0.0136 0.0173 0.0222 -0.0076 -0.0177 -0.0052 0.00 13.0 -0.02785 0.00902 -0.03479 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266537.000 888528.5177 -4517279.1690 4399530.0792 1 6 0.0133 0.0173 0.0221 -0.0075 -0.0177 -0.0050 0.00 10.8 -0.00649 -0.01038 -0.00288 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266538.000 888528.5227 -4517279.1653 4399530.0700 1 6 0.0131 0.0173 0.0221 -0.0074 -0.0178 -0.0048 0.00 8.8 0.02448 -0.04918 0.07613 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266539.000 888528.5121 -4517279.1655 4399530.0763 1 8 0.0129 0.0173 0.0221 -0.0073 -0.0178 -0.0046 0.00 8.0 0.03398 0.01660 0.08511 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266540.000 888528.5126 -4517279.1695 4399530.0813 1 8 0.0125 0.0172 0.0219 -0.0071 -0.0177 -0.0051 0.00 7.1 -0.03108 0.00881 -0.01734 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266541.000 888528.5161 -4517279.1686 4399530.0722 1 8 0.0122 0.0172 0.0219 -0.0068 -0.0177 -0.0050 0.00 6.4 -0.00105 -0.01547 0.03469 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266542.000 888528.5197 -4517279.1663 4399530.0706 1 6 0.0124 0.0173 0.0221 -0.0071 -0.0178 -0.0042 0.00 5.5 0.00098 0.03120 0.03690 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266543.000 888528.3628 -4517279.0615 4399530.0434 2 6 0.0971 0.1215 0.1243 -0.0739 -0.0942 0.0514 0.00 4.8 0.01246 0.00903 0.02967 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266544.000 888528.3550 -4517279.0616 4399530.0554 2 6 0.0970 0.1214 0.1242 -0.0738 -0.0941 0.0513 0.00 4.2 0.01245 0.00878 0.05992 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266545.000 888528.3397 -4517279.0515 4399530.0431 2 8 0.0969 0.1212 0.1240 -0.0737 -0.0940 0.0512 0.00 1.3 0.01087 0.02409 -0.00566 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266546.000 888528.3402 -4517279.0486 4399530.0281 2 6 0.0967 0.1211 0.1238 -0.0736 -0.0938 0.0511 0.00 1.3 0.06262 0.03610 -0.10237 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266547.000 888528.3291 -4517279.0444 4399530.0392 2 6 0.0966 0.1210 0.1236 -0.0735 -0.0937 0.0510 0.00 1.3 0.07057 -0.04896 -0.00763 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266548.000 888528.3258 -4517279.0412 4399530.0338 2 6 0.0965 0.1209 0.1235 -0.0734 -0.0935 0.0509 0.00 1.4 0.00733 -0.01924 0.04186 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266549.000 888528.3156 -4517279.0432 4399530.0448 2 6 0.0964 0.1207 0.1233 -0.0732 -0.0934 0.0508 0.00 1.4 -0.02320 0.00815 0.00300 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266550.000 888528.3224 -4517279.0497 4399530.0491 2 6 0.0963 0.1206 0.1230 -0.0731 -0.0932 0.0506 0.00 1.4 0.03549 -0.00246 0.00799 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266551.000 888528.3136 -4517279.0398 4399530.0388 2 6 0.0962 0.1204 0.1228 -0.0730 -0.0930 0.0505 0.00 1.4 0.02708 -0.02498 0.05151 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266552.000 888528.3064 -4517279.0433 4399530.0529 2 6 0.0961 0.1203 0.1226 -0.0729 -0.0929 0.0504 0.00 1.4 0.01637 -0.02516 0.07501 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266553.000 888528.3055 -4517279.0444 4399530.0628 2 8 0.0960 0.1201 0.1223 -0.0728 -0.0927 0.0502 0.00 1.4 0.00663 0.00574 0.06227 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266554.000 888528.2954 -4517279.0434 4399530.0660 2 8 0.0959 0.1199 0.1219 -0.0727 -0.0924 0.0502 0.00 1.5 0.00513 0.00891 0.01583 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266555.000 888528.2891 -4517279.0420 4399530.0690 2 8 0.0958 0.1198 0.1216 -0.0726 -0.0921 0.0501 0.00 1.5 -0.03683 -0.03561 0.00769 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266556.000 888528.2900 -4517279.0463 4399530.0779 2 8 0.0957 0.1196 0.1213 -0.0725 -0.0919 0.0499 0.00 1.5 0.01164 -0.04086 0.08369 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266557.000 888528.2802 -4517279.0443 4399530.0872 2 10 0.0955 0.1194 0.1210 -0.0724 -0.0916 0.0498 0.00 1.4 0.01074 0.09391 -0.01540 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266558.000 888528.2794 -4517279.0427 4399530.0789 2 10 0.0953 0.1192 0.1205 -0.0722 -0.0913 0.0495 0.00 1.4 0.00461 0.05301 -0.08257 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266559.000 888528.2762 -4517279.0432 4399530.0907 2 10 0.0952 0.1189 0.1200 -0.0721 -0.0909 0.0494 0.00 1.4 0.01071 0.00729 0.03738 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266560.000 888528.2584 -4517279.0362 4399530.0921 2 10 0.0950 0.1187 0.1197 -0.0720 -0.0906 0.0492 0.00 1.4 -0.05413 0.02632 -0.04031 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266561.000 888528.2606 -4517279.0419 4399530.0892 2 9 0.0949 0.1186 0.1195 -0.0719 -0.0904 0.0492 0.00 1.4 0.03036 0.06238 0.07078 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266562.000 888528.2496 -4517279.0592 4399530.1403 2 9 0.0947 0.1184 0.1191 -0.0718 -0.0902 0.0490 0.00 1.4 0.00001 0.03410 -0.05227 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266563.000 888528.2439 -4517279.0580 4399530.1422 2 9 0.0946 0.1182 0.1188 -0.0717 -0.0899 0.0488 0.00 1.4 -0.01935 0.00745 0.00287 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266564.000 888528.2446 -4517279.0668 4399530.1479 2 9 0.0945 0.1180 0.1184 -0.0715 -0.0895 0.0487 0.00 1.4 -0.01663 0.04633 -0.10885 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266565.000 888528.2437 -4517279.0734 4399530.1632 2 10 0.0943 0.1178 0.1180 -0.0714 -0.0892 0.0485 0.00 1.4 -0.04931 0.03144 -0.14538 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266566.000 888528.2448 -4517279.0838 4399530.1924 2 10 0.0941 0.1176 0.1174 -0.0712 -0.0888 0.0481 0.00 1.4 -0.04510 0.05725 -0.11106 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266567.000 888528.2466 -4517279.1035 4399530.2185 2 10 0.0940 0.1173 0.1169 -0.0710 -0.0884 0.0479 0.00 1.4 0.01639 0.04730 0.02145 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266568.000 888528.2480 -4517279.1213 4399530.2534 2 10 0.0939 0.1171 0.1164 -0.0709 -0.0880 0.0476 0.00 1.4 0.02299 0.03874 -0.00789 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266569.000 888528.2466 -4517279.1208 4399530.2712 2 10 0.0937 0.1169 0.1159 -0.0707 -0.0877 0.0474 0.00 1.3 -0.01438 -0.00208 0.02141 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266570.000 888528.2530 -4517279.1555 4399530.3232 2 10 0.0936 0.1167 0.1154 -0.0706 -0.0873 0.0471 0.00 1.3 -0.01056 -0.02795 0.05030 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266571.000 888528.2484 -4517279.1624 4399530.3296 2 10 0.0934 0.1164 0.1149 -0.0704 -0.0869 0.0469 0.00 1.3 -0.02776 0.12626 -0.07649 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266572.000 888528.2639 -4517279.1794 4399530.3395 2 9 0.0935 0.1163 0.1145 -0.0705 -0.0864 0.0463 0.00 1.4 -0.06116 0.05897 -0.07001 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266573.000 888528.2710 -4517279.2004 4399530.3642 2 9 0.0934 0.1161 0.1141 -0.0704 -0.0861 0.0461 0.00 1.5 -0.06660 -0.01531 -0.03248 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266574.000 888528.2770 -4517279.2068 4399530.3739 2 9 0.0933 0.1160 0.1137 -0.0703 -0.0858 0.0459 0.00 1.5 -0.00208 0.05406 -0.01547 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266575.000 888528.2830 -4517279.2216 4399530.3917 2 9 0.0932 0.1158 0.1133 -0.0702 -0.0854 0.0456 0.00 1.5 -0.01579 0.02261 -0.01860 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266576.000 888528.2842 -4517279.2278 4399530.4073 2 8 0.0931 0.1157 0.1135 -0.0701 -0.0854 0.0453 0.00 1.5 -0.00966 0.05505 -0.04991 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266577.000 888528.2924 -4517279.2379 4399530.4144 2 8 0.0930 0.1156 0.1131 -0.0700 -0.0851 0.0451 0.00 1.5 -0.01078 0.01319 -0.11457 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266578.000 888528.2941 -4517279.2479 4399530.4295 2 8 0.0929 0.1154 0.1128 -0.0699 -0.0848 0.0448 0.00 1.5 -0.02444 0.06556 -0.05082 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266579.000 888528.2967 -4517279.2555 4399530.4366 2 9 0.0928 0.1152 0.1124 -0.0698 -0.0845 0.0446 0.00 1.5 0.01063 -0.00665 -0.00073 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266580.000 888528.2999 -4517279.2858 4399530.4865 2 9 0.0927 0.1150 0.1119 -0.0698 -0.0841 0.0445 0.00 1.5 -0.05536 0.00448 -0.00211 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266581.000 888528.3050 -4517279.2976 4399530.5071 2 9 0.0926 0.1148 0.1115 -0.0697 -0.0838 0.0443 0.00 1.5 -0.03045 -0.01370 0.00886 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266582.000 888528.3144 -4517279.3032 4399530.5108 2 9 0.0925 0.1146 0.1111 -0.0696 -0.0835 0.0441 0.00 1.5 0.03181 0.00593 0.01438 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266583.000 888528.3128 -4517279.3107 4399530.5168 2 10 0.0924 0.1144 0.1107 -0.0694 -0.0832 0.0438 0.00 1.5 -0.01280 -0.07827 0.05314 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266584.000 888528.3199 -4517279.3154 4399530.5247 2 10 0.0921 0.1141 0.1103 -0.0691 -0.0828 0.0436 0.00 1.5 0.01428 0.02078 -0.01371 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266585.000 888528.3211 -4517279.3294 4399530.5456 2 10 0.0920 0.1138 0.1099 -0.0689 -0.0825 0.0434 0.00 1.5 0.00437 0.01861 -0.03955 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266586.000 888528.3221 -4517279.3237 4399530.5434 2 10 0.0918 0.1136 0.1095 -0.0687 -0.0822 0.0432 0.00 1.5 0.08392 -0.08208 0.18181 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266587.000 888528.3234 -4517279.3392 4399530.5565 2 10 0.0918 0.1136 0.1091 -0.0688 -0.0819 0.0430 0.00 1.5 -0.00407 -0.01836 -0.01392 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266588.000 888528.3187 -4517279.3404 4399530.5699 2 10 0.0915 0.1132 0.1088 -0.0685 -0.0816 0.0427 0.00 1.4 -0.01771 0.04446 -0.02246 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266589.000 888528.3164 -4517279.3442 4399530.5723 2 10 0.0913 0.1130 0.1084 -0.0683 -0.0812 0.0425 0.00 1.3 0.00553 -0.02455 0.02685 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266590.000 888528.3193 -4517279.3483 4399530.5779 2 10 0.0912 0.1127 0.1080 -0.0681 -0.0809 0.0423 0.00 1.2 0.01090 -0.01005 0.05105 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266591.000 888528.3116 -4517279.3542 4399530.5900 2 10 0.0910 0.1125 0.1076 -0.0679 -0.0806 0.0420 0.00 1.1 0.02846 -0.00559 0.08928 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266592.000 888528.3200 -4517279.3606 4399530.5957 2 9 0.0909 0.1124 0.1074 -0.0679 -0.0805 0.0421 0.00 1.0 0.00513 0.01869 -0.02134 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266593.000 888528.3135 -4517279.3655 4399530.6172 2 9 0.0908 0.1122 0.1070 -0.0678 -0.0802 0.0419 0.00 1.0 -0.05791 0.03466 -0.02786 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266594.000 888528.3108 -4517279.3735 4399530.6258 2 9 0.0909 0.1123 0.1066 -0.0680 -0.0799 0.0418 0.00 1.2 -0.00272 -0.03190 0.06131 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266595.000 888528.3197 -4517279.3849 4399530.6429 2 9 0.0908 0.1121 0.1062 -0.0679 -0.0795 0.0416 0.00 1.2 0.04443 0.00008 0.05917 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266596.000 888528.3302 -4517279.3998 4399530.6419 2 9 0.0907 0.1118 0.1056 -0.0677 -0.0790 0.0411 0.00 1.2 -0.04019 0.01906 -0.11234 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266597.000 888528.3298 -4517279.4057 4399530.6568 2 9 0.0906 0.1116 0.1052 -0.0676 -0.0786 0.0408 0.00 1.1 -0.06096 0.04565 -0.02809 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266598.000 888528.3349 -4517279.4264 4399530.6798 2 9 0.0905 0.1113 0.1047 -0.0675 -0.0782 0.0405 0.00 1.1 -0.02234 -0.06598 0.01216 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266599.000 888528.3473 -4517279.4419 4399530.6954 2 9 0.0904 0.1111 0.1043 -0.0674 -0.0779 0.0403 0.00 1.1 -0.00324 -0.02341 0.07337 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266600.000 888528.3514 -4517279.4497 4399530.7045 2 9 0.0903 0.1109 0.1039 -0.0673 -0.0775 0.0400 0.00 1.0 0.01578 0.03827 -0.04344 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266601.000 888528.3524 -4517279.4583 4399530.7100 2 9 0.0902 0.1107 0.1034 -0.0672 -0.0771 0.0397 0.00 1.0 0.03010 -0.01555 0.03742 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266602.000 888528.3572 -4517279.4728 4399530.7391 2 9 0.0901 0.1105 0.1030 -0.0671 -0.0767 0.0395 0.00 1.0 -0.00938 0.00523 0.02641 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266603.000 888528.3651 -4517279.4842 4399530.7385 2 9 0.0900 0.1103 0.1026 -0.0670 -0.0764 0.0392 0.00 1.0 0.02548 -0.03925 0.05530 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266604.000 888528.3598 -4517279.4823 4399530.7356 2 8 0.0899 0.1102 0.1027 -0.0668 -0.0763 0.0388 0.00 1.1 -0.03192 0.06954 -0.08276 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266605.000 888528.3767 -4517279.5077 4399530.7609 2 8 0.0898 0.1100 0.1023 -0.0667 -0.0759 0.0385 0.00 1.1 0.01344 -0.07213 0.15137 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266606.000 888528.3728 -4517279.5124 4399530.7645 2 8 0.0898 0.1098 0.1018 -0.0666 -0.0755 0.0382 0.00 1.1 0.03515 -0.05479 0.02053 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266607.000 888528.3861 -4517279.5360 4399530.7850 2 9 0.0897 0.1096 0.1014 -0.0665 -0.0752 0.0380 0.00 1.1 -0.05180 0.09502 -0.06888 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266608.000 888528.3839 -4517279.5438 4399530.8068 2 9 0.0896 0.1094 0.1008 -0.0664 -0.0747 0.0378 0.00 1.1 0.03792 -0.05382 0.04734 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266609.000 888528.3825 -4517279.5517 4399530.8103 2 9 0.0895 0.1091 0.1003 -0.0663 -0.0743 0.0376 0.00 1.1 0.02680 -0.00409 0.00936 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266610.000 888528.3932 -4517279.5733 4399530.8339 2 9 0.0894 0.1089 0.0999 -0.0662 -0.0739 0.0374 0.00 1.1 -0.00445 0.03854 -0.01094 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266611.000 888528.3854 -4517279.5714 4399530.8364 2 8 0.0894 0.1089 0.0997 -0.0664 -0.0738 0.0375 0.00 1.1 0.01364 -0.05327 0.06983 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266612.000 888528.3874 -4517279.5823 4399530.8538 2 9 0.0892 0.1087 0.0993 -0.0662 -0.0734 0.0373 0.00 1.1 0.01710 -0.02499 0.00107 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266613.000 888528.3791 -4517279.5779 4399530.8523 2 9 0.0890 0.1083 0.0988 -0.0658 -0.0730 0.0369 0.00 1.1 0.04463 -0.00392 0.06585 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266614.000 888528.3809 -4517279.5867 4399530.8707 2 8 0.0890 0.1082 0.0984 -0.0660 -0.0726 0.0368 0.00 1.1 0.04516 -0.01076 0.01205 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266615.000 888528.3809 -4517279.5994 4399530.8846 2 8 0.0890 0.1080 0.0980 -0.0659 -0.0722 0.0365 0.00 1.1 -0.01067 0.00902 -0.02528 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266616.000 888528.3829 -4517279.6051 4399530.8963 2 9 0.0888 0.1078 0.0976 -0.0657 -0.0719 0.0363 0.00 1.1 0.00386 0.01771 0.01397 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266617.000 888528.3819 -4517279.6179 4399530.9096 2 9 0.0887 0.1075 0.0972 -0.0655 -0.0715 0.0361 0.00 1.0 0.03437 -0.00639 0.01260 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266618.000 888528.3810 -4517279.6274 4399530.9231 2 9 0.0885 0.1071 0.0967 -0.0652 -0.0710 0.0357 0.00 1.0 0.01891 -0.01626 -0.03388 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266619.000 888528.3762 -4517279.6336 4399530.9449 2 8 0.0885 0.1071 0.0963 -0.0653 -0.0707 0.0356 0.00 1.1 -0.02519 -0.02130 0.06350 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266620.000 888528.3867 -4517279.6475 4399530.9484 2 8 0.0884 0.1069 0.0959 -0.0652 -0.0703 0.0353 0.00 1.0 0.02010 -0.00640 0.05461 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266621.000 888528.3858 -4517279.6633 4399530.9639 2 8 0.0883 0.1067 0.0954 -0.0651 -0.0699 0.0351 0.00 1.0 0.01570 -0.05002 0.08666 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266622.000 888528.3915 -4517279.6627 4399530.9503 2 8 0.0882 0.1065 0.0950 -0.0650 -0.0695 0.0348 0.00 1.0 -0.02279 0.04475 -0.01312 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266623.000 888528.4008 -4517279.6801 4399530.9635 2 8 0.0882 0.1063 0.0945 -0.0649 -0.0691 0.0346 0.00 1.0 -0.01903 0.02413 0.00761 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266624.000 888528.3952 -4517279.6931 4399530.9937 2 8 0.0881 0.1061 0.0941 -0.0648 -0.0687 0.0343 0.00 1.0 0.02308 -0.05677 0.03136 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266625.000 888528.3914 -4517279.6947 4399531.0005 2 8 0.0880 0.1058 0.0937 -0.0647 -0.0683 0.0341 0.00 1.0 -0.00456 -0.00149 0.00755 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266626.000 888528.3914 -4517279.6958 4399530.9938 2 8 0.0879 0.1056 0.0932 -0.0647 -0.0679 0.0338 0.00 1.0 0.01298 -0.08129 0.07648 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266627.000 888528.4029 -4517279.7030 4399530.9800 2 8 0.0879 0.1054 0.0928 -0.0646 -0.0674 0.0336 0.00 1.0 -0.01536 -0.00245 -0.03312 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266628.000 888528.3959 -4517279.7055 4399530.9902 2 8 0.0878 0.1052 0.0923 -0.0645 -0.0670 0.0333 0.00 1.0 -0.03522 -0.00482 0.01639 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266629.000 888528.4015 -4517279.7275 4399531.0188 2 8 0.0877 0.1050 0.0919 -0.0644 -0.0666 0.0331 0.00 1.0 -0.02026 -0.01504 0.01074 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266630.000 888528.3987 -4517279.7248 4399531.0267 2 7 0.0878 0.1051 0.0914 -0.0646 -0.0662 0.0328 0.00 1.6 0.00263 -0.02254 -0.00858 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266631.000 888528.4065 -4517279.7333 4399531.0376 2 7 0.0877 0.1051 0.0913 -0.0646 -0.0661 0.0328 0.00 1.6 0.02452 -0.00223 -0.02860 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266632.000 888528.4020 -4517279.7302 4399531.0279 2 7 0.0877 0.1050 0.0912 -0.0647 -0.0660 0.0328 0.00 1.6 0.00706 -0.00168 -0.02865 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266633.000 888528.4101 -4517279.7361 4399531.0356 2 7 0.0876 0.1049 0.0911 -0.0647 -0.0659 0.0328 0.00 1.6 0.00880 0.03385 0.01784 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266634.000 888528.4138 -4517279.7407 4399531.0339 2 7 0.0876 0.1049 0.0909 -0.0647 -0.0658 0.0328 0.00 1.5 0.00023 -0.02920 0.09106 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266635.000 888528.4123 -4517279.7368 4399531.0295 2 7 0.0875 0.1048 0.0908 -0.0647 -0.0657 0.0328 0.00 1.5 -0.01693 -0.03121 0.08652 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266636.000 888528.4068 -4517279.7393 4399531.0473 2 7 0.0875 0.1048 0.0907 -0.0647 -0.0656 0.0328 0.00 1.5 0.00393 0.04824 -0.06588 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266637.000 888528.4118 -4517279.7471 4399531.0619 2 7 0.0874 0.1047 0.0906 -0.0647 -0.0655 0.0328 0.00 1.5 0.02244 -0.01585 0.01664 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266638.000 888528.4064 -4517279.7449 4399531.0680 2 7 0.0874 0.1047 0.0905 -0.0647 -0.0654 0.0328 0.00 1.4 0.00415 0.00724 -0.00111 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266639.000 888528.4036 -4517279.7567 4399531.0837 2 7 0.0873 0.1046 0.0903 -0.0647 -0.0654 0.0328 0.00 1.4 0.04669 0.03692 0.02825 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266640.000 888528.4087 -4517279.7613 4399531.0705 2 7 0.0873 0.1045 0.0902 -0.0647 -0.0653 0.0328 0.00 1.4 -0.06815 -0.01464 -0.01508 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266641.000 888528.4125 -4517279.7589 4399531.0762 2 8 0.0872 0.1045 0.0901 -0.0648 -0.0652 0.0329 0.00 1.4 -0.01526 -0.02689 0.03413 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266642.000 888528.4122 -4517279.7666 4399531.0843 2 8 0.0872 0.1044 0.0900 -0.0648 -0.0651 0.0329 0.00 1.2 -0.03610 0.06760 -0.07533 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266643.000 888528.4187 -4517279.7651 4399531.0827 2 8 0.0871 0.1043 0.0897 -0.0647 -0.0651 0.0331 0.00 1.4 -0.01276 -0.05842 0.03157 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266644.000 888528.4170 -4517279.7658 4399531.0899 2 8 0.0870 0.1043 0.0895 -0.0647 -0.0650 0.0332 0.00 1.4 0.01133 0.06456 -0.02584 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266645.000 888528.4161 -4517279.7731 4399531.0969 2 8 0.0870 0.1042 0.0893 -0.0647 -0.0649 0.0333 0.00 1.1 0.01670 0.00878 0.13094 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266646.000 888528.4180 -4517279.7793 4399531.1064 2 6 0.0871 0.1041 0.0894 -0.0647 -0.0648 0.0329 0.00 1.1 -0.02637 -0.00035 -0.03957 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266647.000 888528.4240 -4517279.7846 4399531.1093 2 6 0.0870 0.1041 0.0893 -0.0648 -0.0647 0.0329 0.00 1.2 0.02709 -0.01366 0.09701 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266648.000 888528.4157 -4517279.7825 4399531.1159 2 6 0.0870 0.1040 0.0891 -0.0648 -0.0647 0.0329 0.00 1.2 0.03287 -0.03582 0.09278 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266649.000 888528.4227 -4517279.7916 4399531.1151 2 8 0.0869 0.1040 0.0890 -0.0648 -0.0646 0.0329 0.00 1.3 0.02461 0.01973 -0.03248 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266650.000 888528.4239 -4517279.8023 4399531.1328 2 8 0.0868 0.1039 0.0888 -0.0648 -0.0644 0.0331 0.00 1.3 0.00897 0.00338 0.02819 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266651.000 888528.4247 -4517279.8030 4399531.1247 2 8 0.0868 0.1038 0.0886 -0.0648 -0.0643 0.0332 0.00 1.3 0.00910 -0.00126 0.02354 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266652.000 888528.4253 -4517279.8059 4399531.1306 2 8 0.0867 0.1038 0.0885 -0.0648 -0.0642 0.0333 0.00 1.3 0.01743 0.00558 -0.00835 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266653.000 888528.4200 -4517279.8138 4399531.1473 2 8 0.0867 0.1037 0.0884 -0.0648 -0.0641 0.0333 0.00 1.3 -0.03666 0.01097 -0.02036 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266654.000 888528.4418 -4517279.8187 4399531.1402 2 8 0.0866 0.1036 0.0882 -0.0649 -0.0640 0.0333 0.00 1.3 0.00926 0.03047 0.04521 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266655.000 888528.4292 -4517279.8245 4399531.1622 2 8 0.0866 0.1036 0.0881 -0.0649 -0.0639 0.0333 0.00 1.3 -0.05898 0.00274 -0.06565 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266656.000 888528.4371 -4517279.8310 4399531.1577 2 8 0.0865 0.1035 0.0879 -0.0649 -0.0638 0.0334 0.00 1.3 0.00336 -0.00051 0.03172 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266657.000 888528.4386 -4517279.8308 4399531.1490 2 8 0.0864 0.1035 0.0878 -0.0649 -0.0637 0.0334 0.00 1.4 -0.01918 -0.02482 -0.02435 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266658.000 888528.4416 -4517279.8382 4399531.1567 2 8 0.0864 0.1034 0.0876 -0.0649 -0.0636 0.0334 0.00 1.4 -0.00453 0.01822 0.01579 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266659.000 888528.4307 -4517279.8381 4399531.1757 2 8 0.0863 0.1033 0.0875 -0.0649 -0.0635 0.0335 0.00 1.4 -0.02786 0.04024 0.03825 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266660.000 888528.4396 -4517279.8556 4399531.1795 2 8 0.0863 0.1033 0.0873 -0.0649 -0.0634 0.0335 0.00 1.3 -0.03928 0.06621 -0.05604 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266661.000 888528.4355 -4517279.8440 4399531.1709 2 8 0.0862 0.1032 0.0872 -0.0649 -0.0633 0.0335 0.00 1.4 -0.00490 0.00118 0.08680 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266662.000 888528.4458 -4517279.8530 4399531.1687 2 6 0.0863 0.1031 0.0872 -0.0649 -0.0632 0.0332 0.00 1.4 0.04877 0.03555 -0.00237 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266663.000 888528.4351 -4517279.8597 4399531.1964 2 6 0.0862 0.1031 0.0871 -0.0649 -0.0631 0.0332 0.00 1.4 -0.02590 0.03097 -0.03000 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266664.000 888528.4367 -4517279.8688 4399531.2004 2 6 0.0862 0.1030 0.0869 -0.0649 -0.0629 0.0332 0.00 1.4 0.00917 0.01637 0.08005 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266665.000 888528.4417 -4517279.8797 4399531.2071 2 8 0.0861 0.1029 0.0868 -0.0649 -0.0628 0.0332 0.00 1.4 -0.02380 0.01166 -0.06162 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266666.000 888528.4479 -4517279.8803 4399531.2005 2 8 0.0860 0.1029 0.0865 -0.0650 -0.0627 0.0334 0.00 1.4 -0.01407 0.08146 -0.10535 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266667.000 888528.4455 -4517279.8861 4399531.2153 2 8 0.0860 0.1028 0.0864 -0.0650 -0.0625 0.0335 0.00 1.4 -0.01957 0.00048 0.03194 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266668.000 888528.4550 -4517279.8958 4399531.2229 2 8 0.0859 0.1027 0.0862 -0.0650 -0.0624 0.0335 0.00 1.3 0.04540 0.00538 0.02774 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266669.000 888528.4448 -4517279.9029 4399531.2327 2 6 0.0859 0.1027 0.0862 -0.0650 -0.0623 0.0333 0.00 1.3 -0.02282 0.00040 0.04753 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266670.000 888528.4485 -4517279.9121 4399531.2399 2 6 0.0859 0.1026 0.0860 -0.0650 -0.0622 0.0333 0.00 1.3 -0.05021 0.05886 -0.08694 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266671.000 888528.4470 -4517279.9188 4399531.2524 2 6 0.0859 0.1025 0.0858 -0.0650 -0.0621 0.0333 0.00 1.3 0.00799 -0.07757 0.04327 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266672.000 888528.4473 -4517279.9194 4399531.2434 2 6 0.0858 0.1024 0.0857 -0.0650 -0.0619 0.0333 0.00 1.3 0.00275 0.02509 0.01381 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266673.000 888528.4449 -4517279.9294 4399531.2638 2 6 0.0858 0.1024 0.0855 -0.0650 -0.0618 0.0333 0.00 1.3 -0.04261 0.06111 -0.04509 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266674.000 888528.4614 -4517279.9287 4399531.2380 2 6 0.0857 0.1023 0.0853 -0.0650 -0.0616 0.0333 0.00 1.3 0.02644 0.02486 0.01324 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266675.000 888528.4639 -4517279.9431 4399531.2509 2 6 0.0857 0.1022 0.0852 -0.0650 -0.0615 0.0333 0.00 1.3 0.03473 -0.01284 0.04261 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266676.000 888528.4538 -4517279.9360 4399531.2603 2 6 0.0857 0.1021 0.0850 -0.0650 -0.0614 0.0333 0.00 1.3 0.00462 0.00228 0.01020 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266677.000 888528.4548 -4517279.9393 4399531.2520 2 6 0.0856 0.1021 0.0848 -0.0650 -0.0612 0.0333 0.00 1.3 -0.03334 0.03863 -0.06001 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266678.000 888528.4509 -4517279.9463 4399531.2757 2 6 0.0856 0.1020 0.0846 -0.0650 -0.0611 0.0333 0.00 1.3 -0.00071 0.04095 0.05026 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266679.000 888528.4612 -4517279.9559 4399531.2683 2 6 0.0855 0.1019 0.0845 -0.0650 -0.0609 0.0333 0.00 1.3 0.00779 -0.01430 0.01466 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266680.000 888528.4680 -4517279.9682 4399531.2790 2 6 0.0855 0.1018 0.0843 -0.0651 -0.0608 0.0333 0.00 1.3 0.05159 -0.02384 0.07853 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266681.000 888528.4731 -4517279.9658 4399531.2723 2 6 0.0854 0.1017 0.0841 -0.0651 -0.0606 0.0333 0.00 1.3 0.07180 0.00859 -0.00958 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266682.000 888528.4634 -4517279.9698 4399531.2855 2 6 0.0854 0.1017 0.0839 -0.0651 -0.0604 0.0333 0.00 1.3 -0.02245 -0.00027 -0.03696 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266683.000 888528.4740 -4517279.9742 4399531.2770 2 6 0.0854 0.1016 0.0837 -0.0651 -0.0603 0.0333 0.00 1.3 0.01512 -0.01901 0.03062 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266684.000 888528.4787 -4517279.9767 4399531.2807 2 6 0.0853 0.1015 0.0835 -0.0651 -0.0601 0.0333 0.00 1.3 0.03549 0.00485 0.05171 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266685.000 888528.4813 -4517279.9841 4399531.2807 2 6 0.0853 0.1014 0.0833 -0.0651 -0.0600 0.0333 0.00 1.4 0.03521 0.02270 -0.03474 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266686.000 888528.4738 -4517279.9805 4399531.2783 2 6 0.0852 0.1013 0.0831 -0.0651 -0.0598 0.0333 0.00 1.4 0.04686 -0.02985 0.01980 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266687.000 888528.4847 -4517279.9800 4399531.2682 2 6 0.0852 0.1012 0.0829 -0.0651 -0.0596 0.0333 0.00 1.4 -0.06704 0.04282 -0.21069 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266688.000 888528.4741 -4517279.9838 4399531.2924 2 6 0.0851 0.1011 0.0827 -0.0651 -0.0594 0.0333 0.00 1.4 0.00192 -0.03039 0.02770 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266689.000 888528.4773 -4517279.9900 4399531.2949 2 6 0.0851 0.1010 0.0825 -0.0651 -0.0593 0.0333 0.00 1.4 -0.02825 0.02809 -0.04076 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266690.000 888528.4792 -4517279.9933 4399531.2973 2 6 0.0850 0.1010 0.0823 -0.0651 -0.0591 0.0333 0.00 1.4 0.04179 0.00868 -0.03216 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266691.000 888528.4858 -4517279.9941 4399531.2805 2 6 0.0850 0.1009 0.0821 -0.0651 -0.0589 0.0333 0.00 1.4 -0.07459 -0.00106 -0.13585 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266692.000 888528.4883 -4517279.9964 4399531.2902 2 6 0.0850 0.1008 0.0819 -0.0651 -0.0587 0.0333 0.00 1.4 0.04279 0.03855 -0.00546 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266693.000 888528.4818 -4517280.0025 4399531.2972 2 6 0.0849 0.1007 0.0817 -0.0651 -0.0586 0.0333 0.00 1.4 -0.01749 -0.00928 0.00328 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266694.000 888528.4862 -4517280.0044 4399531.2901 2 6 0.0849 0.1006 0.0815 -0.0651 -0.0584 0.0332 0.00 1.4 -0.02529 -0.06592 0.01820 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266695.000 888528.4919 -4517280.0089 4399531.2998 2 6 0.0848 0.1005 0.0813 -0.0651 -0.0582 0.0332 0.00 1.4 0.02030 0.02239 0.04858 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266696.000 888528.4885 -4517280.0019 4399531.2975 2 6 0.0848 0.1004 0.0811 -0.0651 -0.0580 0.0332 0.00 1.5 0.01195 0.01018 0.06635 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266697.000 888528.4958 -4517280.0162 4399531.3002 2 6 0.0847 0.1003 0.0809 -0.0651 -0.0578 0.0332 0.00 1.5 -0.03445 0.01560 -0.03759 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266698.000 888528.5007 -4517280.0144 4399531.2893 2 6 0.0847 0.1002 0.0807 -0.0650 -0.0576 0.0332 0.00 1.5 0.07389 -0.09746 0.11504 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266699.000 888528.4992 -4517280.0193 4399531.2920 2 6 0.0846 0.1001 0.0804 -0.0650 -0.0574 0.0332 0.00 1.5 -0.00245 -0.04235 0.04686 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266700.000 888528.5147 -4517280.0184 4399531.2839 2 6 0.0846 0.1000 0.0802 -0.0650 -0.0572 0.0331 0.00 1.5 0.06017 -0.01160 0.07485 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266701.000 888528.5096 -4517280.0234 4399531.2879 2 6 0.0871 0.0999 0.0829 -0.0649 -0.0573 0.0254 0.00 1.3 0.01082 -0.00114 0.03068 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266702.000 888528.5006 -4517280.0222 4399531.3023 2 5 0.0870 0.0999 0.0829 -0.0648 -0.0572 0.0253 0.00 1.3 -0.01028 0.01115 -0.01102 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266703.000 888528.5151 -4517280.0321 4399531.3031 2 5 0.0870 0.0999 0.0829 -0.0648 -0.0572 0.0252 0.00 1.3 -0.04267 0.05311 -0.04749 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266704.000 888528.5043 -4517280.0294 4399531.3021 2 5 0.0870 0.0999 0.0829 -0.0648 -0.0572 0.0250 0.00 1.3 -0.00859 0.00490 0.02492 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266705.000 888528.4981 -4517280.0286 4399531.3062 2 5 0.0870 0.0998 0.0829 -0.0648 -0.0572 0.0249 0.00 1.3 -0.00465 -0.04429 0.02932 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266706.000 888528.4901 -4517280.0305 4399531.3127 2 5 0.0870 0.0998 0.0829 -0.0648 -0.0572 0.0248 0.00 1.3 0.00251 -0.00506 0.05782 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266707.000 888528.5021 -4517280.0327 4399531.3023 2 5 0.0869 0.0998 0.0829 -0.0648 -0.0572 0.0247 0.00 1.3 -0.00356 0.02122 0.04623 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266708.000 888528.4971 -4517280.0334 4399531.3079 2 5 0.0869 0.0997 0.0829 -0.0647 -0.0572 0.0246 0.00 1.3 0.00325 -0.02784 0.03904 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266709.000 888528.5065 -4517280.0389 4399531.3085 2 5 0.0869 0.0997 0.0829 -0.0647 -0.0572 0.0244 0.00 1.3 0.04565 0.00933 -0.01029 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266710.000 888528.5086 -4517280.0416 4399531.3034 2 6 0.0869 0.0997 0.0829 -0.0647 -0.0571 0.0243 0.00 1.3 0.02612 -0.01970 -0.02084 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266711.000 888528.5101 -4517280.0460 4399531.3084 2 7 0.0855 0.0996 0.0821 -0.0644 -0.0573 0.0274 0.00 1.3 -0.08288 0.02034 -0.08008 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266712.000 888528.5055 -4517280.0382 4399531.3113 2 7 0.0849 0.0993 0.0818 -0.0640 -0.0574 0.0284 0.00 1.3 -0.01274 0.00943 -0.00235 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266713.000 888528.5204 -4517280.0544 4399531.3076 2 7 0.0866 0.0994 0.0829 -0.0644 -0.0571 0.0240 0.00 1.4 -0.07551 0.07487 -0.13758 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266714.000 888528.5175 -4517280.0474 4399531.3110 2 7 0.0851 0.0992 0.0821 -0.0639 -0.0573 0.0271 0.00 1.3 0.00772 0.00427 -0.02132 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266715.000 888528.5202 -4517280.0494 4399531.3044 2 7 0.0845 0.0991 0.0818 -0.0637 -0.0573 0.0281 0.00 1.2 -0.02542 0.04446 -0.06366 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266716.000 888528.5259 -4517280.0461 4399531.3048 2 7 0.0842 0.0990 0.0817 -0.0635 -0.0573 0.0285 0.00 1.2 0.00213 -0.03495 0.01153 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266717.000 888528.5413 -4517280.0606 4399531.2964 2 7 0.0839 0.0989 0.0816 -0.0634 -0.0573 0.0287 0.00 1.2 -0.00250 0.02466 -0.00117 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266718.000 888528.5413 -4517280.0630 4399531.3089 2 7 0.0838 0.0988 0.0815 -0.0633 -0.0573 0.0288 0.00 1.2 -0.03716 -0.01078 -0.04061 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266719.000 888528.5320 -4517280.0632 4399531.3278 2 7 0.0836 0.0988 0.0815 -0.0632 -0.0573 0.0289 0.00 1.1 0.01526 -0.02498 0.01295 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266720.000 888528.5262 -4517280.0518 4399531.3158 2 7 0.0834 0.0987 0.0814 -0.0631 -0.0573 0.0289 0.00 1.1 0.00086 0.01298 -0.02377 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266721.000 888528.5405 -4517280.0559 4399531.3232 2 7 0.0833 0.0986 0.0814 -0.0630 -0.0573 0.0289 0.00 1.1 0.05169 0.01466 0.01167 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266722.000 888528.5395 -4517280.0603 4399531.3183 2 7 0.0832 0.0986 0.0813 -0.0629 -0.0573 0.0289 0.00 1.1 -0.00326 0.00085 0.01531 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266723.000 888528.5383 -4517280.0572 4399531.3254 2 7 0.0831 0.0985 0.0813 -0.0629 -0.0572 0.0288 0.00 1.1 0.01508 0.01721 0.03765 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266724.000 888528.5399 -4517280.0674 4399531.3336 2 7 0.0829 0.0984 0.0812 -0.0628 -0.0572 0.0288 0.00 1.1 -0.01123 -0.00834 0.00570 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266725.000 888528.5402 -4517280.0616 4399531.3297 2 7 0.0828 0.0984 0.0812 -0.0627 -0.0572 0.0288 0.00 1.1 -0.03020 0.00982 0.01578 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266726.000 888528.5456 -4517280.0578 4399531.3332 2 7 0.0827 0.0983 0.0811 -0.0626 -0.0572 0.0287 0.00 1.1 0.00194 0.04084 -0.02655 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266727.000 888528.5455 -4517280.0653 4399531.3305 2 7 0.0826 0.0982 0.0811 -0.0625 -0.0571 0.0286 0.00 1.1 -0.03409 0.01487 -0.03202 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266728.000 888528.5494 -4517280.0616 4399531.3285 2 7 0.0825 0.0981 0.0810 -0.0624 -0.0571 0.0286 0.00 1.1 0.02078 -0.01878 0.01418 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266729.000 888528.5491 -4517280.0615 4399531.3286 2 7 0.0824 0.0981 0.0810 -0.0623 -0.0571 0.0285 0.00 1.1 0.00097 0.06862 -0.08252 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266730.000 888528.5502 -4517280.0643 4399531.3328 2 7 0.0823 0.0980 0.0809 -0.0623 -0.0570 0.0284 0.00 1.2 0.02351 -0.03663 0.07382 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266731.000 888528.5578 -4517280.0682 4399531.3379 2 7 0.0822 0.0979 0.0809 -0.0621 -0.0570 0.0283 0.00 1.2 -0.01540 0.06837 -0.09408 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266732.000 888528.5558 -4517280.0718 4399531.3542 2 7 0.0821 0.0978 0.0808 -0.0621 -0.0569 0.0282 0.00 1.2 -0.03402 0.02949 0.03956 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266733.000 888528.5572 -4517280.0675 4399531.3371 2 7 0.0820 0.0978 0.0808 -0.0620 -0.0569 0.0281 0.00 1.2 -0.00292 -0.01578 -0.01410 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266734.000 888528.5632 -4517280.0737 4399531.3434 2 7 0.0819 0.0977 0.0807 -0.0619 -0.0568 0.0280 0.00 1.2 -0.00920 0.02414 -0.04507 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266735.000 888528.5596 -4517280.0702 4399531.3458 2 7 0.0818 0.0976 0.0806 -0.0618 -0.0568 0.0280 0.00 1.2 0.02569 -0.04554 0.04041 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266736.000 888528.5645 -4517280.0762 4399531.3448 2 7 0.0817 0.0975 0.0806 -0.0617 -0.0567 0.0278 0.00 1.3 -0.06303 -0.01089 -0.11298 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266737.000 888528.5647 -4517280.0714 4399531.3473 2 7 0.0816 0.0975 0.0805 -0.0616 -0.0567 0.0277 0.00 1.3 -0.01817 0.01580 -0.00806 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266738.000 888528.5650 -4517280.0694 4399531.3490 2 7 0.0815 0.0974 0.0804 -0.0615 -0.0566 0.0276 0.00 1.3 0.01932 -0.04658 0.03633 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266739.000 888528.5679 -4517280.0669 4399531.3419 2 7 0.0813 0.0973 0.0803 -0.0614 -0.0565 0.0275 0.00 1.4 -0.00969 0.00073 0.00209 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266740.000 888528.5737 -4517280.0675 4399531.3539 2 7 0.0813 0.0972 0.0802 -0.0614 -0.0565 0.0274 0.00 1.3 0.00094 0.01658 0.06584 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266741.000 888528.5781 -4517280.0732 4399531.3548 2 7 0.0812 0.0971 0.0801 -0.0613 -0.0564 0.0272 0.00 1.3 -0.05367 0.04956 -0.08621 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266742.000 888528.5851 -4517280.0773 4399531.3652 2 7 0.0811 0.0970 0.0801 -0.0612 -0.0563 0.0271 0.00 1.3 0.01272 -0.02606 0.03143 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266743.000 888528.5846 -4517280.0734 4399531.3700 2 7 0.0810 0.0970 0.0800 -0.0611 -0.0562 0.0270 0.00 1.3 -0.02198 0.01472 0.02801 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266744.000 888528.5866 -4517280.0814 4399531.3738 2 7 0.0808 0.0969 0.0799 -0.0610 -0.0562 0.0269 0.00 1.3 -0.00847 0.00230 -0.02111 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266745.000 888528.5896 -4517280.0793 4399531.3751 2 7 0.0808 0.0968 0.0797 -0.0609 -0.0561 0.0268 0.00 1.3 -0.00867 -0.00685 -0.00751 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266746.000 888528.5949 -4517280.0841 4399531.3828 2 7 0.0807 0.0967 0.0796 -0.0608 -0.0560 0.0266 0.00 1.3 0.01928 0.00386 0.03347 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266747.000 888528.5950 -4517280.0834 4399531.3810 2 7 0.0806 0.0966 0.0795 -0.0607 -0.0559 0.0265 0.00 1.3 -0.01286 -0.03464 0.01431 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266748.000 888528.6012 -4517280.0863 4399531.3896 2 7 0.0805 0.0965 0.0794 -0.0606 -0.0558 0.0263 0.00 1.3 -0.01112 -0.05823 0.03220 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266749.000 888528.6021 -4517280.0875 4399531.3949 2 7 0.0803 0.0964 0.0793 -0.0605 -0.0557 0.0262 0.00 1.3 0.00950 0.01043 0.01087 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266750.000 888528.6046 -4517280.0793 4399531.3879 2 7 0.0803 0.0963 0.0791 -0.0604 -0.0556 0.0261 0.00 1.3 -0.02605 -0.00269 -0.04691 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266751.000 888528.6100 -4517280.0852 4399531.3978 2 7 0.0801 0.0962 0.0790 -0.0603 -0.0555 0.0259 0.00 1.2 0.02043 0.00231 0.05761 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266752.000 888528.6171 -4517280.0911 4399531.4072 2 7 0.0801 0.0961 0.0788 -0.0602 -0.0554 0.0258 0.00 1.2 0.04705 -0.01944 0.01084 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266753.000 888528.6210 -4517280.0891 4399531.3990 2 7 0.0799 0.0960 0.0787 -0.0601 -0.0553 0.0256 0.00 1.2 0.00834 0.00356 -0.02260 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266754.000 888528.6262 -4517280.0938 4399531.4125 2 7 0.0799 0.0960 0.0785 -0.0600 -0.0552 0.0255 0.00 1.2 -0.00891 -0.03202 -0.02091 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266755.000 888528.6279 -4517280.0910 4399531.4061 2 7 0.0798 0.0959 0.0784 -0.0599 -0.0550 0.0253 0.00 1.2 -0.02149 0.03529 -0.03540 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266756.000 888528.6384 -4517280.1021 4399531.4172 2 7 0.0797 0.0958 0.0782 -0.0598 -0.0549 0.0251 0.00 1.2 0.01040 -0.01374 0.03884 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266757.000 888528.6386 -4517280.0983 4399531.4215 2 7 0.0796 0.0956 0.0780 -0.0597 -0.0548 0.0249 0.00 1.2 0.01029 -0.01401 0.03151 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266758.000 888528.6480 -4517280.1068 4399531.4330 2 7 0.0795 0.0956 0.0779 -0.0596 -0.0547 0.0248 0.00 1.1 -0.05776 0.00236 -0.05788 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266759.000 888528.6515 -4517280.1089 4399531.4338 2 7 0.0794 0.0954 0.0777 -0.0595 -0.0545 0.0246 0.00 1.1 -0.04102 -0.00298 -0.06834 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266760.000 888528.6591 -4517280.1139 4399531.4495 2 7 0.0793 0.0953 0.0775 -0.0594 -0.0544 0.0245 0.00 1.1 -0.03794 0.02711 -0.05546 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266761.000 888528.6643 -4517280.1130 4399531.4586 2 7 0.0791 0.0952 0.0773 -0.0593 -0.0542 0.0243 0.00 1.1 -0.01225 0.02160 0.07625 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266762.000 888528.6723 -4517280.1202 4399531.4634 2 7 0.0790 0.0951 0.0771 -0.0592 -0.0541 0.0241 0.00 1.1 -0.02118 0.01875 -0.08280 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266763.000 888528.6791 -4517280.1300 4399531.4794 2 7 0.0789 0.0950 0.0769 -0.0591 -0.0540 0.0239 0.00 1.1 0.00444 0.01634 0.02197 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266764.000 888528.6890 -4517280.1355 4399531.4856 2 7 0.0788 0.0949 0.0767 -0.0590 -0.0538 0.0238 0.00 1.1 0.03898 -0.00659 0.08638 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266765.000 888528.6930 -4517280.1358 4399531.4891 2 7 0.0788 0.0948 0.0765 -0.0589 -0.0537 0.0236 0.00 1.1 0.00409 0.00835 0.02241 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266766.000 888528.6992 -4517280.1448 4399531.5010 2 7 0.0787 0.0947 0.0763 -0.0588 -0.0535 0.0234 0.00 1.1 -0.03988 0.04004 -0.06006 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266767.000 888528.7113 -4517280.1515 4399531.5073 2 7 0.0786 0.0946 0.0761 -0.0587 -0.0533 0.0232 0.00 1.0 -0.00768 -0.00976 -0.03398 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266768.000 888528.7164 -4517280.1569 4399531.5169 2 7 0.0785 0.0945 0.0759 -0.0586 -0.0532 0.0230 0.00 1.0 -0.00029 -0.00901 0.03101 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266769.000 888528.7272 -4517280.1639 4399531.5277 2 7 0.0784 0.0944 0.0756 -0.0585 -0.0530 0.0228 0.00 1.0 -0.00352 0.00000 0.02697 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266770.000 888528.7306 -4517280.1685 4399531.5303 2 7 0.0782 0.0942 0.0754 -0.0583 -0.0528 0.0226 0.00 1.0 -0.01695 0.00713 -0.01005 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266771.000 888528.7438 -4517280.1761 4399531.5531 2 7 0.0782 0.0941 0.0752 -0.0582 -0.0527 0.0225 0.00 1.0 -0.02105 0.01178 0.00648 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266772.000 888528.7468 -4517280.1777 4399531.5534 2 7 0.0781 0.0940 0.0749 -0.0581 -0.0525 0.0223 0.00 1.0 -0.04073 0.00818 -0.02859 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266773.000 888528.7564 -4517280.1839 4399531.5686 2 7 0.0780 0.0939 0.0747 -0.0580 -0.0523 0.0221 0.00 1.0 0.01666 0.04548 0.03139 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266774.000 888528.7675 -4517280.1908 4399531.5707 2 7 0.0779 0.0938 0.0744 -0.0579 -0.0521 0.0218 0.00 1.0 -0.02949 0.01108 -0.04114 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266775.000 888528.7796 -4517280.2095 4399531.6012 2 7 0.0778 0.0937 0.0742 -0.0578 -0.0519 0.0216 0.00 1.0 0.01559 -0.00978 0.05131 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266776.000 888528.7858 -4517280.2152 4399531.6112 2 7 0.0777 0.0935 0.0739 -0.0577 -0.0517 0.0214 0.00 1.0 -0.01352 0.03324 0.00768 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266777.000 888528.7956 -4517280.2249 4399531.6171 2 7 0.0776 0.0934 0.0736 -0.0576 -0.0516 0.0212 0.00 1.0 -0.00383 -0.04720 0.06874 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266778.000 888528.8076 -4517280.2304 4399531.6252 2 7 0.0775 0.0933 0.0734 -0.0575 -0.0514 0.0210 0.00 1.0 0.00363 -0.03870 0.00053 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266779.000 888528.8171 -4517280.2444 4399531.6426 2 7 0.0774 0.0932 0.0731 -0.0574 -0.0512 0.0208 0.00 1.0 0.05016 -0.04146 0.09982 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266780.000 888528.8272 -4517280.2578 4399531.6539 2 7 0.0773 0.0931 0.0728 -0.0573 -0.0510 0.0206 0.00 1.0 -0.02476 0.01560 -0.02947 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266781.000 888528.8420 -4517280.2624 4399531.6567 2 7 0.0772 0.0929 0.0725 -0.0572 -0.0508 0.0204 0.00 1.0 0.02240 -0.02862 -0.03486 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266782.000 888528.8530 -4517280.2717 4399531.6681 2 7 0.0771 0.0928 0.0722 -0.0571 -0.0506 0.0201 0.00 1.0 -0.02668 0.02637 0.00102 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266783.000 888528.8581 -4517280.2812 4399531.6732 2 7 0.0770 0.0927 0.0720 -0.0569 -0.0504 0.0200 0.00 1.0 -0.01083 0.03777 -0.05720 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266784.000 888528.8698 -4517280.2935 4399531.6850 2 7 0.0769 0.0926 0.0717 -0.0568 -0.0502 0.0197 0.00 1.1 0.00113 -0.00596 0.05957 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266785.000 888528.8790 -4517280.3053 4399531.6944 2 7 0.0768 0.0924 0.0714 -0.0567 -0.0499 0.0196 0.00 1.1 0.00092 0.00781 0.03156 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266786.000 888528.8913 -4517280.3112 4399531.6986 2 7 0.0767 0.0923 0.0711 -0.0566 -0.0497 0.0193 0.00 1.1 -0.01321 0.03156 -0.04819 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266787.000 888528.8981 -4517280.3270 4399531.7177 2 7 0.0766 0.0922 0.0708 -0.0565 -0.0495 0.0191 0.00 1.1 -0.04247 0.02299 -0.05407 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266788.000 888528.9058 -4517280.3277 4399531.7176 2 7 0.0765 0.0921 0.0705 -0.0564 -0.0493 0.0189 0.00 1.1 0.02046 -0.04198 0.05796 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266789.000 888528.9151 -4517280.3334 4399531.7204 2 7 0.0764 0.0919 0.0701 -0.0563 -0.0491 0.0186 0.00 1.1 -0.02512 0.00440 -0.00062 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266790.000 888528.9231 -4517280.3390 4399531.7260 2 7 0.0763 0.0918 0.0698 -0.0562 -0.0489 0.0184 0.00 1.1 -0.00035 0.02140 0.02337 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266791.000 888528.9340 -4517280.3468 4399531.7320 2 7 0.0762 0.0917 0.0695 -0.0561 -0.0487 0.0182 0.00 1.1 0.00446 -0.00376 0.01960 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266792.000 888528.9480 -4517280.3527 4399531.7353 2 7 0.0761 0.0915 0.0692 -0.0560 -0.0484 0.0180 0.00 1.1 0.03104 -0.00408 0.01268 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266793.000 888528.9552 -4517280.3625 4399531.7403 2 7 0.0760 0.0914 0.0689 -0.0559 -0.0482 0.0177 0.00 1.1 -0.00830 0.02374 -0.05232 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266794.000 888528.9639 -4517280.3681 4399531.7489 2 7 0.0759 0.0913 0.0686 -0.0558 -0.0480 0.0176 0.00 1.1 -0.00585 -0.06063 0.07610 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266795.000 888528.9782 -4517280.3744 4399531.7457 2 7 0.0758 0.0911 0.0682 -0.0556 -0.0478 0.0173 0.00 1.1 -0.01225 -0.00463 0.01076 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266796.000 888528.9900 -4517280.3755 4399531.7641 2 7 0.0757 0.0910 0.0679 -0.0555 -0.0476 0.0171 0.00 1.1 0.05968 -0.04902 0.06982 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266797.000 888528.9932 -4517280.3820 4399531.7659 2 7 0.0756 0.0909 0.0676 -0.0554 -0.0473 0.0169 0.00 1.1 0.02591 -0.01904 -0.02202 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266798.000 888529.0079 -4517280.3866 4399531.7692 2 7 0.0755 0.0908 0.0673 -0.0553 -0.0471 0.0167 0.00 1.1 0.00791 -0.02451 0.02118 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266799.000 888529.0181 -4517280.4006 4399531.7799 2 7 0.0754 0.0906 0.0669 -0.0552 -0.0469 0.0165 0.00 1.1 -0.00079 0.05465 0.00604 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266800.000 888529.0260 -4517280.4082 4399531.7812 2 7 0.0753 0.0905 0.0666 -0.0551 -0.0466 0.0162 0.00 1.1 0.00689 -0.04109 -0.03427 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266801.000 888529.0370 -4517280.4115 4399531.7809 2 7 0.0752 0.0904 0.0663 -0.0550 -0.0464 0.0160 0.00 1.1 0.02783 0.04431 -0.02705 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266802.000 888529.0451 -4517280.4148 4399531.7787 2 7 0.0751 0.0902 0.0659 -0.0549 -0.0462 0.0158 0.00 1.1 -0.02732 0.05602 -0.08793 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266803.000 888529.0626 -4517280.4150 4399531.7688 2 7 0.0750 0.0901 0.0656 -0.0548 -0.0460 0.0155 0.00 1.1 0.03914 -0.02078 0.06283 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266804.000 888529.0700 -4517280.4210 4399531.7735 2 7 0.0749 0.0900 0.0653 -0.0547 -0.0457 0.0153 0.00 1.1 0.02521 0.00330 -0.01221 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266805.000 888529.0774 -4517280.4284 4399531.7728 2 7 0.0748 0.0898 0.0649 -0.0546 -0.0455 0.0151 0.00 1.1 0.02312 0.00268 0.00803 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266806.000 888529.0904 -4517280.4312 4399531.7718 2 7 0.0747 0.0897 0.0646 -0.0545 -0.0453 0.0148 0.00 1.1 0.00807 -0.00704 0.06360 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266807.000 888529.1051 -4517280.4355 4399531.7651 2 7 0.0747 0.0896 0.0642 -0.0544 -0.0451 0.0146 0.00 1.1 0.00031 -0.02866 -0.01001 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266808.000 888529.1125 -4517280.4403 4399531.7648 2 7 0.0746 0.0894 0.0639 -0.0543 -0.0448 0.0144 0.00 1.1 0.00369 0.06021 -0.01671 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266809.000 888529.1247 -4517280.4442 4399531.7587 2 7 0.0745 0.0893 0.0636 -0.0542 -0.0446 0.0142 0.00 1.1 -0.00790 0.04355 -0.04116 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266810.000 888529.1264 -4517280.4476 4399531.7490 2 7 0.0743 0.0892 0.0632 -0.0540 -0.0444 0.0140 0.00 1.1 -0.01035 0.01200 -0.07942 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266811.000 888529.1395 -4517280.4445 4399531.7443 2 7 0.0743 0.0890 0.0629 -0.0539 -0.0441 0.0137 0.00 1.1 -0.05692 -0.00598 -0.07525 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266812.000 888529.1467 -4517280.4595 4399531.7519 2 7 0.0742 0.0889 0.0625 -0.0538 -0.0439 0.0135 0.00 1.1 -0.02252 -0.01677 0.00505 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266813.000 888529.1622 -4517280.4604 4399531.7476 2 7 0.0741 0.0888 0.0622 -0.0537 -0.0437 0.0133 0.00 1.1 0.05848 -0.00779 0.08595 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266814.000 888529.1699 -4517280.4652 4399531.7475 2 7 0.0740 0.0886 0.0619 -0.0536 -0.0435 0.0131 0.00 1.1 0.01047 0.01523 -0.01997 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266815.000 888529.1780 -4517280.4797 4399531.7514 2 7 0.0738 0.0885 0.0615 -0.0535 -0.0432 0.0129 0.00 1.1 0.00016 0.00501 -0.00719 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266816.000 888529.1871 -4517280.4870 4399531.7547 2 7 0.0738 0.0884 0.0612 -0.0534 -0.0430 0.0126 0.00 1.1 -0.02691 0.00914 0.00536 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266817.000 888529.2010 -4517280.4903 4399531.7493 2 7 0.0737 0.0882 0.0608 -0.0533 -0.0428 0.0124 0.00 1.1 -0.03822 0.00785 -0.15746 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266818.000 888529.2175 -4517280.4953 4399531.7519 2 7 0.0736 0.0881 0.0605 -0.0532 -0.0425 0.0122 0.00 1.1 0.02289 0.01810 0.01970 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266819.000 888529.2225 -4517280.4931 4399531.7485 2 7 0.0735 0.0880 0.0602 -0.0531 -0.0423 0.0119 0.00 1.1 -0.00564 0.01291 0.01715 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266820.000 888529.2350 -4517280.4993 4399531.7384 2 7 0.0734 0.0878 0.0598 -0.0530 -0.0421 0.0117 0.00 1.1 -0.02472 0.00619 -0.03402 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266821.000 888529.2432 -4517280.5099 4399531.7485 2 7 0.0733 0.0877 0.0595 -0.0529 -0.0419 0.0115 0.00 1.1 -0.02506 0.02894 0.00488 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266822.000 888529.2534 -4517280.5183 4399531.7539 2 7 0.0732 0.0876 0.0592 -0.0528 -0.0417 0.0113 0.00 1.1 0.01851 0.02198 0.05687 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266823.000 888529.2648 -4517280.5264 4399531.7593 2 7 0.0731 0.0874 0.0588 -0.0527 -0.0414 0.0111 0.00 1.1 -0.03018 0.01499 -0.11389 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266824.000 888529.2772 -4517280.5354 4399531.7605 2 7 0.0730 0.0873 0.0585 -0.0526 -0.0412 0.0109 0.00 1.1 -0.01810 -0.01572 -0.04102 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266825.000 888529.2831 -4517280.5409 4399531.7692 2 7 0.0729 0.0872 0.0582 -0.0525 -0.0410 0.0106 0.00 1.1 -0.00243 -0.03556 0.04447 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266826.000 888529.2880 -4517280.5506 4399531.7671 2 7 0.0730 0.0871 0.0578 -0.0522 -0.0408 0.0103 0.00 1.3 -0.00482 0.00431 -0.05026 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266827.000 888529.2933 -4517280.5561 4399531.7867 2 6 0.0729 0.0870 0.0575 -0.0521 -0.0406 0.0100 0.00 1.3 -0.01198 0.05150 0.03414 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266828.000 888529.2981 -4517280.5732 4399531.8024 2 6 0.0728 0.0869 0.0572 -0.0520 -0.0403 0.0096 0.00 1.3 0.01747 -0.01853 -0.00156 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266829.000 888529.3020 -4517280.5846 4399531.7920 2 8 0.0727 0.0867 0.0569 -0.0519 -0.0401 0.0092 0.00 1.2 0.04739 -0.01955 0.05940 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266830.000 888529.3091 -4517280.5865 4399531.7914 2 8 0.0727 0.0866 0.0565 -0.0519 -0.0397 0.0090 0.00 1.3 0.01116 -0.03230 -0.02242 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266831.000 888529.3156 -4517280.5943 4399531.7974 2 8 0.0726 0.0864 0.0561 -0.0518 -0.0394 0.0087 0.00 1.2 -0.04357 0.00443 -0.08735 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266832.000 888529.3249 -4517280.6097 4399531.8161 2 8 0.0725 0.0863 0.0558 -0.0517 -0.0392 0.0084 0.00 1.2 -0.04937 -0.02902 -0.09187 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266833.000 888529.3291 -4517280.6150 4399531.8139 2 8 0.0725 0.0862 0.0555 -0.0516 -0.0389 0.0080 0.00 1.2 -0.00002 -0.03166 -0.02515 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266834.000 888529.3391 -4517280.6284 4399531.8302 2 8 0.0724 0.0860 0.0552 -0.0515 -0.0387 0.0076 0.00 1.1 0.05269 -0.02044 0.08468 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266835.000 888529.3399 -4517280.6258 4399531.8264 2 8 0.0723 0.0859 0.0549 -0.0514 -0.0385 0.0071 0.00 1.1 0.07485 0.05530 0.16531 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266836.000 888529.3508 -4517280.6416 4399531.8261 2 9 0.0722 0.0858 0.0546 -0.0513 -0.0382 0.0066 0.00 1.1 -0.01265 -0.03103 -0.04729 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266837.000 888529.3580 -4517280.6472 4399531.8429 2 9 0.0722 0.0856 0.0543 -0.0513 -0.0381 0.0057 0.00 1.1 0.01439 -0.04381 0.13398 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266838.000 888529.3630 -4517280.6482 4399531.8366 2 9 0.0721 0.0855 0.0539 -0.0512 -0.0379 0.0050 0.00 1.0 -0.01629 -0.00723 -0.00610 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266839.000 888529.3691 -4517280.6566 4399531.8478 2 9 0.0720 0.0854 0.0537 -0.0510 -0.0376 0.0049 0.00 1.1 -0.01932 -0.02960 0.04402 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266840.000 888529.3737 -4517280.6659 4399531.8523 2 9 0.0720 0.0852 0.0534 -0.0510 -0.0375 0.0037 0.00 1.3 0.00554 0.04016 0.02144 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266841.000 888529.3839 -4517280.6736 4399531.8641 2 9 0.0719 0.0851 0.0531 -0.0509 -0.0373 0.0026 0.00 1.5 0.00361 0.05088 0.03625 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266842.000 888529.3903 -4517280.6790 4399531.8719 2 9 0.0718 0.0849 0.0528 -0.0508 -0.0371 0.0006 0.00 1.6 -0.00854 0.03432 -0.01195 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266843.000 888529.3998 -4517280.6944 4399531.8835 2 7 0.0718 0.0849 0.0529 -0.0507 -0.0372 -0.0040 0.00 1.8 -0.00555 0.02713 -0.02831 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266844.000 888529.4018 -4517280.6983 4399531.8968 2 7 0.0717 0.0848 0.0526 -0.0506 -0.0370 -0.0048 0.00 1.9 -0.02206 0.00476 -0.03051 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
2080 266845.000 888529.4092 -4517280.7015 4399531.8929 2 7 0.0716 0.0846 0.0523 -0.0506 -0.0368 -0.0054 0.00 2.0 -0.01756 -0.01349 0.04373 0.00000 0.00000 0.00000 0.00000 0.00000 0.00000
More information about the FOSS-GPS
