[FOSS-GPS] Program to create survey-like map?
John Ackermann N8UR jra at febo.com
Mon Aug 24 13:29:06 PDT 2020
Thanks, Jochen!
I am not familiar with foxtrotgps but will look at it.  I think it may
be overkill for my needs but maybe not.  One thing is that I'm talking
about small distances -- spacing of <50 meters between points, usually.
I probably have the Python code available to fairly easily read a list
of lat/lon and calculate distance/bearing between each pair.  What I
don't have is the knowledge to then plot that onto a sheet to a sheet to
create what looks like a survey map with boundaries and markers.
John
On 8/24/20 3:16 PM, Jochen Peters wrote:
> Hi John,
> I had a similar problem: I couldn't find a program with which I could load and display tracks including distances. In my case I had the additional problem that I wanted to draw and save these tracks myself.
> I then looked at the code of foxtrotgps and made a few changes:
> - when loading lat/lon lists the distances per waypoint are displayed on the terminal
> - when measuring a multi-point distance, each point with distance is copied to the clipboard (instead of only the last point)
> The first point would be interesting for you, even if no bearing is calculated. Unfortunately I didn't get any feedback from foss-gps if these additional functions are wanted and so I never made an attempt to get this change applied to "the original foxtrotgps".
> If you can program by yourself, you can have a look at my changes. So when loading tacks you might be able to quickly add the desired calculations by yourself:
> https://bazaar.launchpad.net/~deadlockz/+junk/jochen/revision/325
> kind regards
> Jochen
> Am Mon, 24 Aug 2020 14:32:30 -0400
> schrieb John Ackermann N8UR <jra at febo.com>:
>> Hi --
>> I'm looking for a program that would input multiple lat/lon positions
>> and plot them, showing bearing and distance between the various
>> points. Does such a thing exist?
>> Thanks!
>> John
>> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
>> list. Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to
>> manage your subscription For more information, check
>> http://wiki.osgeo.org/wiki/FOSS-GPS
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing list.
> Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to manage your subscription
> For more information, check http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
