[FOSS-GPS] foxtrotgps: Source code for features for manual track editing
Jochen Peters jochen.peters at uni-duesseldorf.de
Mon Jun 1 13:01:39 PDT 2020
Hi everyone,
These are my first attempts with bazaar and launchpad, but this way you can see how I improvised the described procedure of creating track files by hand and a distance measurement:
https://bazaar.launchpad.net/~deadlockz/+junk/jochen/revision/325
You are welcome to adopt the change if you also think it makes sense for other users.
kindly regards,
Jochen
Am Mon, 1 Jun 2020 16:47:03 +0200
schrieb Jochen Peters <jochen.peters at uni-duesseldorf.de>:
> Hello, everyone,
> I use foxtrotgps to measure the tracks I have driven - without gps
> data. Although foxtrotgps has this function, but there is no
> possibility to save it. I would also like to be able to load these
> tracks with a distance measurement. For this I have implemented the
> following ideas in the code:
> - with the distance measurement the coordinates are attached to the
> content of the clipboard instead of being exchanged
> - these coordinates are not appended to the clipboard with "lat -
> lon", but with "lat,lon,distance distunit".
> - when loading tracks, the distance per coordinate is calculated and
> (additively) output in the console with g_printf().
> These small adjustments make it possible for me to measure tracks
> with foxtrotgpsby hand and save it as track via clipboard in a text
> file. Furthermore I can read these files afterwards with foxtrotgps
> (and other lists with coordinates) and have the track measured
> (distance).
> Since I'm not sure if this changed behaviour of foxtrotgps is also
> desired by other users, I don't know if (and how) I should transmit
> these changes with Bazaar.
> So at this point I wanted to ask how I should proceed and whether
> there is any interest at these changes.
> kindly regards
> Jochen
> This message is sent to you from FOSS-GPS at lists.osgeo.org mailing
> list. Visit https://lists.osgeo.org/mailman/listinfo/foss-gps to
> manage your subscription For more information, check
> http://wiki.osgeo.org/wiki/FOSS-GPS
More information about the FOSS-GPS mailing list
