[fusion-commits] r1361 - trunk/MapServer/php
svn_fusion at osgeo.org
Mon Apr 7 11:49:45 EDT 2008
Author: aboudreault
Date: 2008-04-07 11:49:45 -0400 (Mon, 07 Apr 2008)
New Revision: 1361
trunk/MapServer/php/Query.php
closes #24: setting displayed attributes on query
Modified: trunk/MapServer/php/Query.php
--- trunk/MapServer/php/Query.php 2008-04-07 15:30:46 UTC (rev 1360)
+++ trunk/MapServer/php/Query.php 2008-04-07 15:49:45 UTC (rev 1361)
@@ -81,8 +81,8 @@
$oMap->loadquery(getSessionSavePath()."query.qry");
-$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
+$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
$bAllLayers = false;
$nLayers = count($layers);
$nSelections = 0;
@@ -102,8 +102,9 @@
$oLayer->set('tolerance', 0);
if ($oLayer->type == MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
- $oLayer->type == MS_LAYER_CIRCLE || $oLayer->type == MS_LAYER_CHART)
- continue;
+ $oLayer->type == MS_LAYER_CIRCLE || $oLayer->type == MS_LAYER_CHART) {
+ continue;
if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
@@ -123,8 +124,7 @@
header('Content-type: text/x-json');
header('X-JSON: true');
-if ($result->hasSelection)
+if ($result->hasSelection) {
$oMap->savequery(getSessionSavePath()."query.qry");
$result->queryFile = getSessionSavePath()."query.qry";
@@ -139,15 +139,13 @@
$bFirstElement = 1;
$nLayers = $oMap->numlayers;
- for ($i=0; $i<$nLayers; $i++)
+ for ($i=0; $i<$nLayers; $i++) {
$oLayer = $oMap->GetLayer($i);
$numResults = $oLayer->getNumResults();
- if ($numResults == 0)
+ if ($numResults == 0){
continue;
$oLayer->open();
$layerName = $oLayer->name != "" ? $oLayer->name : "Layer_".$i;
array_push($properties->layers, $layerName);
@@ -169,21 +167,70 @@
$oRes = $oLayer->getResult(0);
$oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
$selFields = array();
- while ( list($key,$val) = each($oShape->values) )
- array_push($selFields, $key);
+ if (isset($_SESSION[$mapName][$layerName]['query_items'])) {
+ $aQueryItems = $_SESSION[$mapName][$layerName]['query_items'];
+ } else {
+ //token separator (for parsing displayed attributes on a query)
+ $tokenSeparator = ",";
+ // checking if metadata "query_include_items" is set
+ $metadataItems = $oLayer->getMetaData('query_include_items');
+ if ( ($metadataItems == "") || ($metadataItems == "all") ) {
+ while ( list($key,$val) = each($oShape->values) ) {
+ $aQueryItems[$key] = NULL;
+ } else {
+ $token = strtok($metadataItems, $tokenSeparator);
+ while ($token !== false) {
+ $aQueryItems[trim($token)] = NULL;
+ $token = strtok($tokenSeparator);
+ // checking if metadata "query_exclude_items" is set
+ $metadataItems = $oLayer->getMetaData('query_exclude_items');
+ if ($metadataItems != "") {
+ if (array_key_exists($token, $aQueryItems)) {
+ unset($aQueryItems[$token]);
+ // get all alias
+ while ( list($key,$val) = each($aQueryItems) ) {
+ $keyAlias = $oLayer->getMetaData("query_".$key."_alias");
+ trim($keyAlias);
+ if ($keyAlias != "") {
+ $aQueryItems[$key] = $keyAlias;
+ $_SESSION[$mapName][$layerName]['query_items'] = $aQueryItems;
+ $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
+ if (array_key_exists($key, $aQueryItems)) {
+ array_push($selFields, $key);
- array_push($properties->$layerName->propertynames, $key);
- //TODO : we should define away to give alias to field names
- array_push($properties->$layerName->propertyvalues, $key);
+ //we check if an alias if provided
+ if (isset($aQueryItems[$key]) && ($aQueryItems[$key] != "")){
+ $key = $aQueryItems[$key];
- //TODO we do not know the types of the attributes in MS. Just output 0
- //we shouls possibly use OGR to get the attributes
- array_push($properties->$layerName->propertytypes, 0);
+ array_push($properties->$layerName->propertynames, $key);
+ //TODO : we should define away to give alias to field names
+ array_push($properties->$layerName->propertyvalues, $key);
+ //TODO we do not know the types of the attributes in MS. Just output 0
+ //we shouls possibly use OGR to get the attributes
+ array_push($properties->$layerName->propertytypes, 0);
- for ($iRes=0; $iRes < $numResults; $iRes++)
+ for ($iRes=0; $iRes < $numResults; $iRes++) {
$properties->$layerName->values[$iRes] = array();
$properties->$layerName->metadata[$iRes] = array();
@@ -195,25 +242,26 @@
$maxx = $oShape->bounds->maxx;
$maxy = $oShape->bounds->maxy;
- if ($bFirstElement)
+ if ($bFirstElement) {
$bFirstElement = 0;
$totalminx = $minx;
$totalminy = $miny;
$totalmaxx = $maxx;
$totalmaxy = $maxy;
+ } else {
+ if ($totalminx > $minx) {
+ $totalminx = $minx;
+ if ($totalminy > $miny) {
+ $totalminy = $miny;
+ if ($totalmaxx < $maxx) {
+ $totalmaxx = $maxx;
+ if ($totalmaxy < $maxy) {
+ $totalmaxy = $maxy;
- else
- if ($totalminx > $minx)
- $totalminx = $minx;
- if ($totalminy > $miny)
- $totalminy = $miny;
- if ($totalmaxx < $maxx)
- $totalmaxx = $maxx;
- if ($totalmaxy < $maxy)
- $totalmaxy = $maxy;
//metadata : TODO dimension, area, length and distance are not set
$dimension = 0;
@@ -229,8 +277,7 @@
array_push($properties->$layerName->metadata[$iRes], $length);
//field values
- for($iField=0; $iField < count($selFields); $iField++)
+ for($iField=0; $iField < count($selFields); $iField++) {
$value = $oShape->values[$selFields[$iField]];
//$value = preg_replace( "/\r?\n/", "<br>", $value );
$value = str_replace("'", "\'", $value);
More information about the fusion-commits
