[fusion-commits] r1386 - in trunk: . lib/OpenLayers
svn_fusion at osgeo.org
Fri Apr 25 15:15:52 EDT 2008
Author: madair
Date: 2008-04-25 15:15:52 -0400 (Fri, 25 Apr 2008)
New Revision: 1386
trunk/build.xml
trunk/lib/OpenLayers/OpenLayers.js
trunk/parseAppDef.xsl
re #53: file clean up
Modified: trunk/build.xml
--- trunk/build.xml 2008-04-25 18:44:42 UTC (rev 1385)
+++ trunk/build.xml 2008-04-25 19:15:52 UTC (rev 1386)
@@ -162,8 +162,7 @@
</exec>
</target>
- <target description="Create documentation" name="docs2" depends="prepare">
+ <target description="Create documentation" name="widgetInfo" depends="prepare">
<delete dir="${build.home}/docs/widgetinfo"/>
<mkdir dir="${build.home}/docs/widgetinfo"/>
<xslt basedir="${basedir}/widgets/widgetinfo"
@@ -171,16 +170,14 @@
style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
excludes="WidgetInfoTemplate.xml widgetInfo.xsl"/>
</target>
<!-- =================== single file build ================================== -->
<target description="single file build" name="singleFile" depends="prepare">
<echo message="preparing single file build for ${appDef}"/>
<delete dir="${build.home}/lib/fusionSF.js"/>
<delete dir="${build.home}/appDefFileset.xml"/>
- <!-- generate the list of fiels for this Application and load as a property -->
+ <!-- generate the list of files for this Application and load as a property -->
<xslt in="${appDef}"
out="${build.home}/appDefFileset.xml"
style="${basedir}/parseAppDef.xsl">
@@ -217,13 +214,12 @@
Search.js
Map.js"
- <!--fileset dir="${build.home}/MapGuide" includes="*.js" excludesfile="MapGuide/MapGuideViewerApi.js"/>
- <fileset dir="${build.home}/MapServer" includes="*.js"/-->
<fileset dir="${build.home}/text" includes="**/*.json"/>
<filelist dir="${build.home}" files="${AppDef.Maps}"/>
<filelist dir="${build.home}" files="${AppDef.Widgets}"/>
<filelist dir="${build.home}" files="appDef.json configHeader.json config.json"/>
</concat>
<echo message="compressing..."/>
<java jar="${YUIcompressor}" fork="true"
output="${build.home}/lib/fusionSF-compressed.js">
@@ -260,8 +256,12 @@
<fileset dir="${build.home}/widgets" includes="*.js **/*.js" excludes="Recenter.js"/>
</concat>
- <exec executable="jsmin.exe" os="Windows Vista, Windows XP"
- input="${build.home}/lib/fusion-combined.js" output="${build.home}/lib/fusion-compressed.js"/>
+ <java jar="${YUIcompressor}" fork="true"
+ output="${build.home}/lib/fusionSF-compressed.js">
+ <arg value="${build.home}/lib/fusionSF.js"/>
+ </java>
+ <!--exec executable="jsmin.exe" os="Windows Vista, Windows XP"
+ input="${build.home}/lib/fusion-combined.js" output="${build.home}/lib/fusion-compressed.js"/-->
</target>
<!-- ==================== Deploy ========================================== -->
Modified: trunk/lib/OpenLayers/OpenLayers.js
--- trunk/lib/OpenLayers/OpenLayers.js 2008-04-25 18:44:42 UTC (rev 1385)
+++ trunk/lib/OpenLayers/OpenLayers.js 2008-04-25 19:15:52 UTC (rev 1386)
@@ -43,487 +43,15613 @@
-var OpenLayers={singleFile:true};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);window.OpenLayers={_scriptName:(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js",_getScriptLocation:function(){var scriptLocation="";var scriptName=OpenLayers._scriptName;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);var pathLength=src.lastIndexOf('?');if(pathLength<0){pathLength=src.length;}
-if((index>-1)&&(index+scriptName.length==pathLength)){scriptLocation=src.slice(0,pathLength-scriptName.length);break;}}}
-return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
-var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0;i<jsfiles.length;i++){if(docWrite){allScriptTags[i]="<script src='"+host+jsfiles[i]+"'></script>";}else{var s=document.createElement("script");s.src=host+jsfiles[i];var h=document.getElementsByTagName("head").length?document.getElementsByTagName("head")[0]:document.body;h.appendChild(s);}}
-if(docWrite){document.write(allScriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="$Revision$";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s*(.*?)\s*$/,"$1");},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1;i<oStringList.length;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
-return camelizedString;},format:function(template,context,args){if(!context){context=window;}
-var tokens=template.split("${");var item,last,replacement;for(var i=1;i<tokens.length;i++){item=tokens[i];last=item.indexOf("}");if(last>0){replacement=context[item.substring(0,last)];if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
-tokens[i]=replacement+item.substring(++last);}else{tokens[i]="${"+item;}}
-return tokens.join("");}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
-if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
-if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
-if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
-OpenLayers.Number={decimalSeparator:".",thousandsSeparator:",",limitSigDigs:function(num,sig){var fig=0;if(sig>0){fig=parseFloat(num.toPrecision(sig));}
-return fig;},format:function(num,dec,tsep,dsep){dec=(typeof dec!="undefined")?dec:0;tsep=(typeof tsep!="undefined")?tsep:OpenLayers.Number.thousandsSeparator;dsep=(typeof dsep!="undefined")?dsep:OpenLayers.Number.decimalSeparator;if(dec!=null){num=parseFloat(num.toFixed(dec));}
-var parts=num.toString().split(".");if(parts.length==1&&dec==null){dec=0;}
-var integer=parts[0];if(tsep){var thousands=/(-?[0-9]+)([0-9]{3})/;while(thousands.test(integer)){integer=integer.replace(thousands,"$1"+tsep+"$2");}}
-var str;if(dec==0){str=integer;}else{var rem=parts.length>1?parts[1]:"0";if(dec!=null){rem=rem+new Array(dec-rem.length+1).join("0");}
-str=integer+dsep+rem;}
-return str;}};if(!Number.prototype.limitSigDigs){Number.prototype.limitSigDigs=function(sig){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.limitSigDigs'}));return OpenLayers.Number.limitSigDigs(this,sig);};}
-OpenLayers.Function={bind:function(func,object){var args=Array.prototype.slice.apply(arguments,[2]);return function(){var newArgs=args.concat(Array.prototype.slice.apply(arguments,[0]));return func.apply(object,newArgs);};},bindAsEventListener:function(func,object){return function(event){return func.call(object,event||window.event);};}};if(!Function.prototype.bind){Function.prototype.bind=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bind'}));Array.prototype.unshift.apply(arguments,[this]);return OpenLayers.Function.bind.apply(null,arguments);};}
-if(!Function.prototype.bindAsEventListener){Function.prototype.bindAsEventListener=function(object){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.bindAsEventListener'}));return OpenLayers.Function.bindAsEventListener(this,object);};}
-OpenLayers.Array={filter:function(array,callback,caller){var selected=[];if(Array.prototype.filter){selected=array.filter(callback,caller);}else{var len=array.length;if(typeof callback!="function"){throw new TypeError();}
-for(var i=0;i<len;i++){if(i in array){var val=array[i];if(callback.call(caller,val,i,array)){selected.push(val);}}}}
-return selected;}};OpenLayers.Class=function(){var Class=function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};var extended={};var parent;for(var i=0;i<arguments.length;++i){if(typeof arguments[i]=="function"){parent=arguments[i].prototype;}else{parent=arguments[i];}
-OpenLayers.Util.extend(extended,parent);}
-Class.prototype=extended;return Class;};OpenLayers.Class.isPrototype=function(){};OpenLayers.Class.create=function(){return function(){if(arguments&&arguments[0]!=OpenLayers.Class.isPrototype){this.initialize.apply(this,arguments);}};};OpenLayers.Class.inherit=function(){var superClass=arguments[0];var proto=new superClass(OpenLayers.Class.isPrototype);for(var i=1;i<arguments.length;i++){if(typeof arguments[i]=="function"){var mixin=arguments[i];arguments[i]=new mixin(OpenLayers.Class.isPrototype);}
-OpenLayers.Util.extend(proto,arguments[i]);}
-return proto;};OpenLayers.Util={};OpenLayers.Util.getElement=function(){var elements=[];for(var i=0;i<arguments.length;i++){var element=arguments[i];if(typeof element=='string'){element=document.getElementById(element);}
-if(arguments.length==1){return element;}
-elements.push(element);}
-return elements;};if($==null){var $=OpenLayers.Util.getElement;}
-OpenLayers.Util.extend=function(destination,source){if(destination&&source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
-var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
-return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
-return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj){return i;}}
-return-1;};OpenLayers.Util.modifyDOMElement=function(element,id,px,sz,position,border,overflow,opacity){if(id){element.id=id;}
-if(px){element.style.left=px.x+"px";element.style.top=px.y+"px";}
-if(sz){element.style.width=sz.w+"px";element.style.height=sz.h+"px";}
-if(position){element.style.position=position;}
-if(border){element.style.border=border;}
-if(overflow){element.style.overflow=overflow;}
-if(parseFloat(opacity)>=0.0&&parseFloat(opacity)<1.0){element.style.filter='alpha(opacity='+(opacity*100)+')';element.style.opacity=opacity;}else if(parseFloat(opacity)==1.0){element.style.filter='';element.style.opacity='';}};OpenLayers.Util.createDiv=function(id,px,sz,imgURL,position,border,overflow,opacity){var dom=document.createElement('div');if(imgURL){dom.style.backgroundImage='url('+imgURL+')';}
-if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
-if(!position){position="absolute";}
-OpenLayers.Util.modifyDOMElement(dom,id,px,sz,position,border,overflow,opacity);return dom;};OpenLayers.Util.createImage=function(id,px,sz,imgURL,position,border,opacity,delayDisplay){var image=document.createElement("img");if(!id){id=OpenLayers.Util.createUniqueID("OpenLayersDiv");}
-if(!position){position="relative";}
-OpenLayers.Util.modifyDOMElement(image,id,px,sz,position,border,null,opacity);if(delayDisplay){image.style.display="none";OpenLayers.Event.observe(image,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,image));OpenLayers.Event.observe(image,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,image));}
-image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
-return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.backgroundColor=null;this.style.display="";}};OpenLayers.Util.onImageLoadErrorColor="pink";OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.src=this.src;}else{this.style.backgroundColor=OpenLayers.Util.onImageLoadErrorColor;}
-this.style.display="";};OpenLayers.Util.alphaHack=function(){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
-return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,null,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
-OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){div.style.display="inline-block";if(sizing==null){sizing="scale";}
-div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
-img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
-OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
-return uObject;};OpenLayers.Util.applyDefaults=function(to,from){var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
-if(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
-return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];for(var itemIndex=0;itemIndex<value.length;itemIndex++){encodedItemArray.push(encodeURIComponent(value[itemIndex]));}
-encodedValue=encodedItemArray.join(",");}
-else{encodedValue=encodeURIComponent(value);}
-paramsArray.push(encodeURIComponent(key)+"="+encodedValue);}}
-return paramsArray.join("&");};OpenLayers.ImgPath='';OpenLayers.Util.getImagesLocation=function(){return OpenLayers.ImgPath||(OpenLayers._getScriptLocation()+"img/");};OpenLayers.Util.Try=function(){var returnValue=null;for(var i=0;i<arguments.length;i++){var lambda=arguments[i];try{returnValue=lambda();break;}catch(e){}}
-return returnValue;};OpenLayers.Util.getNodes=function(p,tagName){var nodes=OpenLayers.Util.Try(function(){return OpenLayers.Util._getNodes(p.documentElement.childNodes,tagName);},function(){return OpenLayers.Util._getNodes(p.childNodes,tagName);});return nodes;};OpenLayers.Util._getNodes=function(nodes,tagName){var retArray=[];for(var i=0;i<nodes.length;i++){if(nodes[i].nodeName==tagName){retArray.push(nodes[i]);}}
-return retArray;};OpenLayers.Util.getTagText=function(parent,item,index){var result=OpenLayers.Util.getNodes(parent,item);if(result&&(result.length>0))
-{if(!index){index=0;}
-if(result[index].childNodes.length>1){return result.childNodes[1].nodeValue;}
-else if(result[index].childNodes.length==1){return result[index].firstChild.nodeValue;}}else{return"";}};OpenLayers.Util.getXmlNodeValue=function(node){var val=null;OpenLayers.Util.Try(function(){val=node.text;if(!val){val=node.textContent;}
-if(!val){val=node.firstChild.nodeValue;}},function(){val=node.textContent;});return val;};OpenLayers.Util.mouseLeft=function(evt,div){var target=(evt.relatedTarget)?evt.relatedTarget:evt.toElement;while(target!=div&&target!=null){target=target.parentNode;}
-return(target!=div);};OpenLayers.Util.rad=function(x){return x*Math.PI/180;};OpenLayers.Util.distVincenty=function(p1,p2){var a=6378137,b=6356752.3142,f=1/298.257223563;var L=OpenLayers.Util.rad(p2.lon-p1.lon);var U1=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p1.lat)));var U2=Math.atan((1-f)*Math.tan(OpenLayers.Util.rad(p2.lat)));var sinU1=Math.sin(U1),cosU1=Math.cos(U1);var sinU2=Math.sin(U2),cosU2=Math.cos(U2);var lambda=L,lambdaP=2*Math.PI;var iterLimit=20;while(Math.abs(lambda-lambdaP)>1e-12&&--iterLimit>0){var sinLambda=Math.sin(lambda),cosLambda=Math.cos(lambda);var sinSigma=Math.sqrt((cosU2*sinLambda)*(cosU2*sinLambda)+
-(cosU1*sinU2-sinU1*cosU2*cosLambda)*(cosU1*sinU2-sinU1*cosU2*cosLambda));if(sinSigma==0){return 0;}
-var cosSigma=sinU1*sinU2+cosU1*cosU2*cosLambda;var sigma=Math.atan2(sinSigma,cosSigma);var alpha=Math.asin(cosU1*cosU2*sinLambda/sinSigma);var cosSqAlpha=Math.cos(alpha)*Math.cos(alpha);var cos2SigmaM=cosSigma-2*sinU1*sinU2/cosSqAlpha;var C=f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));lambdaP=lambda;lambda=L+(1-C)*f*Math.sin(alpha)*(sigma+C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));}
-if(iterLimit==0){return NaN;}
-var uSq=cosSqAlpha*(a*a-b*b)/(b*b);var A=1+uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));var B=uSq/1024*(256+uSq*(-128+uSq*(74-47*uSq)));var deltaSigma=B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
-B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));var s=b*A*(sigma-deltaSigma);var d=s.toFixed(3)/1000;return d;};OpenLayers.Util.getParameters=function(url){url=url||window.location.href;var paramsString="";if(OpenLayers.String.contains(url,'?')){var start=url.indexOf('?')+1;var end=OpenLayers.String.contains(url,"#")?url.indexOf('#'):url.length;paramsString=url.substring(start,end);}
-var parameters={};var pairs=paramsString.split(/[&;]/);for(var i=0;i<pairs.length;++i){var keyValue=pairs[i].split('=');if(keyValue[0]){var key=decodeURIComponent(keyValue[0]);var value=keyValue[1]||'';value=value.split(",");for(var j=0;j<value.length;j++){value[j]=decodeURIComponent(value[j]);}
-if(value.length==1){value=value[0];}
-parameters[key]=value;}}
-return parameters;};OpenLayers.Util.getArgs=function(url){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.Util.getParameters'}));return OpenLayers.Util.getParameters(url);};OpenLayers.Util.lastSeqID=0;OpenLayers.Util.createUniqueID=function(prefix){if(prefix==null){prefix="id_";}
-OpenLayers.Util.lastSeqID+=1;return prefix+OpenLayers.Util.lastSeqID;};OpenLayers.INCHES_PER_UNIT={'inches':1.0,'ft':12.0,'mi':63360.0,'m':39.3701,'km':39370.1,'dd':4374754,'yd':36};OpenLayers.INCHES_PER_UNIT["in"]=OpenLayers.INCHES_PER_UNIT.inches;OpenLayers.INCHES_PER_UNIT["degrees"]=OpenLayers.INCHES_PER_UNIT.dd;OpenLayers.INCHES_PER_UNIT["nmi"]=1852*OpenLayers.INCHES_PER_UNIT.m;OpenLayers.DOTS_PER_INCH=72;OpenLayers.Util.normalizeScale=function(scale){var normScale=(scale>1.0)?(1.0/scale):scale;return normScale;};OpenLayers.Util.getResolutionFromScale=function(scale,units){if(units==null){units="degrees";}
-var normScale=OpenLayers.Util.normalizeScale(scale);var resolution=1/(normScale*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH);return resolution;};OpenLayers.Util.getScaleFromResolution=function(resolution,units){if(units==null){units="degrees";}
-var scale=resolution*OpenLayers.INCHES_PER_UNIT[units]*OpenLayers.DOTS_PER_INCH;return scale;};OpenLayers.Util.safeStopPropagation=function(evt){OpenLayers.Event.stop(evt,true);};OpenLayers.Util.pagePosition=function(forElement){var valueT=0,valueL=0;var element=forElement;var child=forElement;while(element){if(element==document.body){if(child&&child.style&&OpenLayers.Element.getStyle(child,'position')=='absolute'){break;}}
-valueT+=element.offsetTop||0;valueL+=element.offsetLeft||0;child=element;try{element=element.offsetParent;}catch(e){OpenLayers.Console.error(OpenLayers.i18n("pagePositionFailed",{'elemId':element.id}));break;}}
-element=forElement;while(element){valueT-=element.scrollTop||0;valueL-=element.scrollLeft||0;element=element.parentNode;}
-return[valueL,valueT];};OpenLayers.Util.isEquivalentUrl=function(url1,url2,options){options=options||{};OpenLayers.Util.applyDefaults(options,{ignoreCase:true,ignorePort80:true,ignoreHash:true});var urlObj1=OpenLayers.Util.createUrlObject(url1,options);var urlObj2=OpenLayers.Util.createUrlObject(url2,options);for(var key in urlObj1){if(options.test){alert(key+"\n1:"+urlObj1[key]+"\n2:"+urlObj2[key]);}
-var val1=urlObj1[key];var val2=urlObj2[key];switch(key){case"args":break;case"host":case"port":case"protocol":if((val1=="")||(val2=="")){break;}
-default:if((key!="args")&&(urlObj1[key]!=urlObj2[key])){return false;}
-break;}}
-for(var key in urlObj1.args){if(urlObj1.args[key]!=urlObj2.args[key]){return false;}
-delete urlObj2.args[key];}
-for(var key in urlObj2.args){return false;}
-return true;};OpenLayers.Util.createUrlObject=function(url,options){options=options||{};var urlObject={};if(options.ignoreCase){url=url.toLowerCase();}
-var a=document.createElement('a');a.href=url;urlObject.host=a.host;var port=a.port;if(port.length<=0){var newHostLength=urlObject.host.length-(port.length);urlObject.host=urlObject.host.substring(0,newHostLength);}
-urlObject.protocol=a.protocol;urlObject.port=((port=="80")&&(options.ignorePort80))?"":port;urlObject.hash=(options.ignoreHash)?"":a.hash;var queryString=a.search;if(!queryString){var qMark=url.indexOf("?");queryString=(qMark!=-1)?url.substr(qMark):"";}
-urlObject.args=OpenLayers.Util.getParameters(queryString);if(((urlObject.protocol=="file:")&&(url.indexOf("file:")!=-1))||((urlObject.protocol!="file:")&&(urlObject.host!=""))){urlObject.pathname=a.pathname;var qIndex=urlObject.pathname.indexOf("?");if(qIndex!=-1){urlObject.pathname=urlObject.pathname.substring(0,qIndex);}}else{var relStr=OpenLayers.Util.removeTail(url);var backs=0;do{var index=relStr.indexOf("../");if(index==0){backs++;relStr=relStr.substr(3);}else if(index>=0){var prevChunk=relStr.substr(0,index-1);var slash=prevChunk.indexOf("/");prevChunk=(slash!=-1)?prevChunk.substr(0,slash+1):"";var postChunk=relStr.substr(index+3);relStr=prevChunk+postChunk;}}while(index!=-1)
-var windowAnchor=document.createElement("a");var windowUrl=window.location.href;if(options.ignoreCase){windowUrl=windowUrl.toLowerCase();}
-windowAnchor.href=windowUrl;urlObject.protocol=windowAnchor.protocol;var splitter=(windowAnchor.pathname.indexOf("/")!=-1)?"/":"\\";var dirs=windowAnchor.pathname.split(splitter);dirs.pop();while((backs>0)&&(dirs.length>0)){dirs.pop();backs--;}
-relStr=dirs.join("/")+"/"+relStr;urlObject.pathname=relStr;}
-if((urlObject.protocol=="file:")||(urlObject.protocol=="")){urlObject.host="localhost";}
-return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
-return head;};OpenLayers.Util.getBrowserName=function(){var browserName="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){browserName="opera";}else if(ua.indexOf("msie")!=-1){browserName="msie";}else if(ua.indexOf("safari")!=-1){browserName="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){browserName="firefox";}else{browserName="mozilla";}}
-return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w=h=null;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=container.style.width=size.w;}else if(size.h){h=container.style.height=size.h;}}
-var content=document.createElement("div");content.innerHTML=contentHTML;container.appendChild(content);document.body.appendChild(container);if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
-if(!h){h=parseInt(content.scrollHeight);}
-container.removeChild(content);document.body.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
-return scrollbarWidth;};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){var success=(onComplete)?OpenLayers.Function.bind(onComplete,caller):OpenLayers.nullHandler;var failure=(onFailure)?OpenLayers.Function.bind(onFailure,caller):OpenLayers.nullHandler;var request=new OpenLayers.Ajax.Request(uri,{method:'get',parameters:params,onComplete:success,onFailure:failure});return request.transport;};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
-this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
-this.transport=OpenLayers.Ajax.getTransport();this.request(url);},request:function(url){this.url=url;this.method=this.options.method;var params=OpenLayers.Util.extend({},this.options.parameters);if(this.method!='get'&&this.method!='post'){params['_method']=this.method;this.method='post';}
-this.parameters=params;if(params=OpenLayers.Util.getParameterString(params)){if(this.method=='get'){this.url+=((this.url.indexOf('?')>-1)?'&':'?')+params;}else if(/Konqueror|Safari|KHTML/.test(navigator.userAgent)){params+='&_=';}}
-try{var response=new OpenLayers.Ajax.Response(this);if(this.options.onCreate){this.options.onCreate(response);}
-OpenLayers.Ajax.Responders.dispatch('onCreate',this,response);this.transport.open(this.method.toUpperCase(),this.url,this.options.asynchronous);if(this.options.asynchronous){window.setTimeout(OpenLayers.Function.bind(this.respondToReadyState,this,1),10);}
-this.transport.onreadystatechange=OpenLayers.Function.bind(this.onStateChange,this);this.setRequestHeaders();this.body=this.method=='post'?(this.options.postBody||params):null;this.transport.send(this.body);if(!this.options.asynchronous&&this.transport.overrideMimeType){this.onStateChange();}}catch(e){this.dispatchException(e);}},onStateChange:function(){var readyState=this.transport.readyState;if(readyState>1&&!((readyState==4)&&this._complete)){this.respondToReadyState(this.transport.readyState);}},setRequestHeaders:function(){var headers={'X-Requested-With':'XMLHttpRequest','Accept':'text/javascript, text/html, application/xml, text/xml, */*','OpenLayers':true};if(this.method=='post'){headers['Content-type']=this.options.contentType+
-(this.options.encoding?'; charset='+this.options.encoding:'');if(this.transport.overrideMimeType&&(navigator.userAgent.match(/Gecko\/(\d{4})/)||[0,2005])[1]<2005){headers['Connection']='close';}}
-if(typeof this.options.requestHeaders=='object'){var extras=this.options.requestHeaders;if(typeof extras.push=='function'){for(var i=0,length=extras.length;i<length;i+=2){headers[extras[i]]=extras[i+1];}}else{for(var i in extras){headers[i]=pair[i];}}}
-for(var name in headers){this.transport.setRequestHeader(name,headers[name]);}},success:function(){var status=this.getStatus();return!status||(status>=200&&status<300);},getStatus:function(){try{return this.transport.status||0;}catch(e){return 0;}},respondToReadyState:function(readyState){var state=OpenLayers.Ajax.Request.Events[readyState];var response=new OpenLayers.Ajax.Response(this);if(state=='Complete'){try{this._complete=true;(this.options['on'+response.status]||this.options['on'+(this.success()?'Success':'Failure')]||OpenLayers.Ajax.emptyFunction)(response);}catch(e){this.dispatchException(e);}
-var contentType=response.getHeader('Content-type');}
-try{(this.options['on'+state]||OpenLayers.Ajax.emptyFunction)(response);OpenLayers.Ajax.Responders.dispatch('on'+state,this,response);}catch(e){this.dispatchException(e);}
-if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
-if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
-if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
-return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
-if(bottom!=null){this.bottom=parseFloat(bottom);}
-if(right!=null){this.right=parseFloat(right);}
-if(top!=null){this.top=parseFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
-return equals;},toString:function(){return("left-bottom=("+this.left+","+this.bottom+")"
-+" right-top=("+this.right+","+this.top+")");},toArray:function(){return[this.left,this.bottom,this.right,this.top];},toBBOX:function(decimal){if(decimal==null){decimal=6;}
-var mult=Math.pow(10,decimal);var bbox=Math.round(this.left*mult)/mult+","+
-Math.round(this.bottom*mult)/mult+","+
-Math.round(this.right*mult)/mult+","+
-Math.round(this.top*mult)/mult;return bbox;},toGeometry:function(){return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(this.left,this.bottom),new OpenLayers.Geometry.Point(this.right,this.bottom),new OpenLayers.Geometry.Point(this.right,this.top),new OpenLayers.Geometry.Point(this.left,this.top)])]);},getWidth:function(){return(this.right-this.left);},getHeight:function(){return(this.top-this.bottom);},getSize:function(){return new OpenLayers.Size(this.getWidth(),this.getHeight());},getCenterPixel:function(){return new OpenLayers.Pixel((this.left+this.right)/2,(this.bottom+this.top)/2);},getCenterLonLat:function(){return new OpenLayers.LonLat((this.left+this.right)/2,(this.bottom+this.top)/2);},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("boundsAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.Bounds(this.left+x,this.bottom+y,this.right+x,this.top+y);},extend:function(object){var bounds=null;if(object){switch(object.CLASS_NAME){case"OpenLayers.LonLat":bounds=new OpenLayers.Bounds(object.lon,object.lat,object.lon,object.lat);break;case"OpenLayers.Geometry.Point":bounds=new OpenLayers.Bounds(object.x,object.y,object.x,object.y);break;case"OpenLayers.Bounds":bounds=object;break;}
-if(bounds){if((this.left==null)||(bounds.left<this.left)){this.left=bounds.left;}
-if((this.bottom==null)||(bounds.bottom<this.bottom)){this.bottom=bounds.bottom;}
-if((this.right==null)||(bounds.right>this.right)){this.right=bounds.right;}
-if((this.top==null)||(bounds.top>this.top)){this.top=bounds.top;}}}},containsLonLat:function(ll,inclusive){return this.contains(ll.lon,ll.lat,inclusive);},containsPixel:function(px,inclusive){return this.contains(px.x,px.y,inclusive);},contains:function(x,y,inclusive){if(inclusive==null){inclusive=true;}
-var contains=false;if(inclusive){contains=((x>=this.left)&&(x<=this.right)&&(y>=this.bottom)&&(y<=this.top));}else{contains=((x>this.left)&&(x<this.right)&&(y>this.bottom)&&(y<this.top));}
-return contains;},intersectsBounds:function(bounds,inclusive){if(inclusive==null){inclusive=true;}
-var inBottom=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.bottom>this.bottom)&&(bounds.bottom<this.top))||((this.bottom>bounds.bottom)&&(this.bottom<bounds.top)));var inTop=(bounds.bottom==this.bottom&&bounds.top==this.top)?true:(((bounds.top>this.bottom)&&(bounds.top<this.top))||((this.top>bounds.bottom)&&(this.top<bounds.top)));var inRight=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.right>this.left)&&(bounds.right<this.right))||((this.right>bounds.left)&&(this.right<bounds.right)));var inLeft=(bounds.right==this.right&&bounds.left==this.left)?true:(((bounds.left>this.left)&&(bounds.left<this.right))||((this.left>bounds.left)&&(this.left<bounds.right)));return(this.containsBounds(bounds,true,inclusive)||bounds.containsBounds(this,true,inclusive)||((inTop||inBottom)&&(inLeft||inRight)));},containsBounds:function(bounds,partial,inclusive){if(partial==null){partial=false;}
-if(inclusive==null){inclusive=true;}
-var inLeft;var inTop;var inRight;var inBottom;if(inclusive){inLeft=(bounds.left>=this.left)&&(bounds.left<=this.right);inTop=(bounds.top>=this.bottom)&&(bounds.top<=this.top);inRight=(bounds.right>=this.left)&&(bounds.right<=this.right);inBottom=(bounds.bottom>=this.bottom)&&(bounds.bottom<=this.top);}else{inLeft=(bounds.left>this.left)&&(bounds.left<this.right);inTop=(bounds.top>this.bottom)&&(bounds.top<this.top);inRight=(bounds.right>this.left)&&(bounds.right<this.right);inBottom=(bounds.bottom>this.bottom)&&(bounds.bottom<this.top);}
-return(partial)?(inTop||inBottom)&&(inLeft||inRight):(inTop&&inLeft&&inBottom&&inRight);},determineQuadrant:function(lonlat){var quadrant="";var center=this.getCenterLonLat();quadrant+=(lonlat.lat<center.lat)?"b":"t";quadrant+=(lonlat.lon<center.lon)?"l":"r";return quadrant;},transform:function(source,dest){var ll=OpenLayers.Projection.transform({'x':this.left,'y':this.bottom},source,dest);var lr=OpenLayers.Projection.transform({'x':this.right,'y':this.bottom},source,dest);var ul=OpenLayers.Projection.transform({'x':this.left,'y':this.top},source,dest);var ur=OpenLayers.Projection.transform({'x':this.right,'y':this.top},source,dest);this.left=Math.min(ll.x,ul.x);this.bottom=Math.min(ll.y,lr.y);this.right=Math.max(lr.x,ur.x);this.top=Math.max(ul.y,ur.y);return this;},wrapDateLine:function(maxExtent,options){options=options||{};var leftTolerance=options.leftTolerance||0;var rightTolerance=options.rightTolerance||0;var newBounds=this.clone();if(maxExtent){while(newBounds.left<maxExtent.left&&(newBounds.right-rightTolerance)<=maxExtent.left){newBounds=newBounds.add(maxExtent.getWidth(),0);}
-while((newBounds.left+leftTolerance)>=maxExtent.right&&newBounds.right>maxExtent.right){newBounds=newBounds.add(-maxExtent.getWidth(),0);}}
-return newBounds;},CLASS_NAME:"OpenLayers.Bounds"});OpenLayers.Bounds.fromString=function(str){var bounds=str.split(",");return OpenLayers.Bounds.fromArray(bounds);};OpenLayers.Bounds.fromArray=function(bbox){return new OpenLayers.Bounds(parseFloat(bbox[0]),parseFloat(bbox[1]),parseFloat(bbox[2]),parseFloat(bbox[3]));};OpenLayers.Bounds.fromSize=function(size){return new OpenLayers.Bounds(0,size.h,size.w,0);};OpenLayers.Bounds.oppositeQuadrant=function(quadrant){var opp="";opp+=(quadrant.charAt(0)=='t')?'b':'t';opp+=(quadrant.charAt(1)=='l')?'r':'l';return opp;};OpenLayers.Element={visible:function(element){return OpenLayers.Util.getElement(element).style.display!='none';},toggle:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);var display=OpenLayers.Element.visible(element)?'hide':'show';OpenLayers.Element[display](element);}},hide:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='none';}},show:function(){for(var i=0;i<arguments.length;i++){var element=OpenLayers.Util.getElement(arguments[i]);element.style.display='';}},remove:function(element){element=OpenLayers.Util.getElement(element);element.parentNode.removeChild(element);},getHeight:function(element){element=OpenLayers.Util.getElement(element);return element.offsetHeight;},getDimensions:function(element){element=OpenLayers.Util.getElement(element);if(OpenLayers.Element.getStyle(element,'display')!='none'){return{width:element.offsetWidth,height:element.offsetHeight};}
-var els=element.style;var originalVisibility=els.visibility;var originalPosition=els.position;els.visibility='hidden';els.position='absolute';els.display='';var originalWidth=element.clientWidth;var originalHeight=element.clientHeight;els.display='none';els.position=originalPosition;els.visibility=originalVisibility;return{width:originalWidth,height:originalHeight};},getStyle:function(element,style){element=OpenLayers.Util.getElement(element);var value=element.style[OpenLayers.String.camelize(style)];if(!value){if(document.defaultView&&document.defaultView.getComputedStyle){var css=document.defaultView.getComputedStyle(element,null);value=css?css.getPropertyValue(style):null;}else if(element.currentStyle){value=element.currentStyle[OpenLayers.String.camelize(style)];}}
-var positions=['left','top','right','bottom'];if(window.opera&&(OpenLayers.Util.indexOf(positions,style)!=-1)&&(OpenLayers.Element.getStyle(element,'position')=='static')){value='auto';}
-return value=='auto'?null:value;}};OpenLayers.LonLat=OpenLayers.Class({lon:0.0,lat:0.0,initialize:function(lon,lat){this.lon=parseFloat(lon);this.lat=parseFloat(lat);},toString:function(){return("lon="+this.lon+",lat="+this.lat);},toShortString:function(){return(this.lon+", "+this.lat);},clone:function(){return new OpenLayers.LonLat(this.lon,this.lat);},add:function(lon,lat){if((lon==null)||(lat==null)){var msg=OpenLayers.i18n("lonlatAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.LonLat(this.lon+lon,this.lat+lat);},equals:function(ll){var equals=false;if(ll!=null){equals=((this.lon==ll.lon&&this.lat==ll.lat)||(isNaN(this.lon)&&isNaN(this.lat)&&isNaN(ll.lon)&&isNaN(ll.lat)));}
-return equals;},transform:function(source,dest){var point=OpenLayers.Projection.transform({'x':this.lon,'y':this.lat},source,dest);this.lon=point.x;this.lat=point.y;return this;},wrapDateLine:function(maxExtent){var newLonLat=this.clone();if(maxExtent){while(newLonLat.lon<maxExtent.left){newLonLat.lon+=maxExtent.getWidth();}
-while(newLonLat.lon>maxExtent.right){newLonLat.lon-=maxExtent.getWidth();}}
-return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(parseFloat(pair[0]),parseFloat(pair[1]));};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
-return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
-return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
-return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();this.events=null;}
-this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
-if(this.handlers){for(var key in this.handlers){if(this.handlers.hasOwnProperty(key)&&typeof this.handlers[key].destroy=="function"){this.handlers[key].destroy();}}
-this.handlers=null;}
-if(this.map){this.map.removeControl(this);this.map=null;}},setMap:function(map){this.map=map;if(this.handler){this.handler.setMap(map);}},draw:function(px){if(this.div==null){this.div=OpenLayers.Util.createDiv(this.id);this.div.className=this.displayClass;if(!this.allowSelection){this.div.className+=" olControlNoSelect";this.div.setAttribute("unselectable","on",0);this.div.onselectstart=function(){return(false);};}
-if(this.title!=""){this.div.title=this.title;}}
-if(px!=null){this.position=px.clone();}
-this.moveTo(this.position);return this.div;},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},activate:function(){if(this.active){return false;}
-if(this.handler){this.handler.activate();}
-this.active=true;this.events.triggerEvent("activate");return true;},deactivate:function(){if(this.active){if(this.handler){this.handler.deactivate();}
-this.active=false;this.events.triggerEvent("deactivate");return true;}
-return false;},CLASS_NAME:"OpenLayers.Control"});OpenLayers.Control.TYPE_BUTTON=1;OpenLayers.Control.TYPE_TOGGLE=2;OpenLayers.Control.TYPE_TOOL=3;OpenLayers.Icon=OpenLayers.Class({url:null,size:null,offset:null,calculateOffset:null,imageDiv:null,px:null,initialize:function(url,size,offset,calculateOffset){this.url=url;this.size=(size)?size:new OpenLayers.Size(20,20);this.offset=offset?offset:new OpenLayers.Pixel(-(this.size.w/2),-(this.size.h/2));this.calculateOffset=calculateOffset;var id=OpenLayers.Util.createUniqueID("OL_Icon_");this.imageDiv=OpenLayers.Util.createAlphaImageDiv(id);},destroy:function(){OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);this.imageDiv.innerHTML="";this.imageDiv=null;},clone:function(){return new OpenLayers.Icon(this.url,this.size,this.offset,this.calculateOffset);},setSize:function(size){if(size!=null){this.size=size;}
-this.draw();},setUrl:function(url){if(url!=null){this.url=url;}
-this.draw();},draw:function(px){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,this.size,this.url,"absolute");this.moveTo(px);return this.imageDiv;},setOpacity:function(opacity){OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,null,null,null,null,null,null,opacity);},moveTo:function(px){if(px!=null){this.px=px;}
-if(this.imageDiv!=null){if(this.px==null){this.display(false);}else{if(this.calculateOffset){this.offset=this.calculateOffset(this.size);}
-var offsetPx=this.px.offset(this.offset);OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,null,offsetPx);}}},display:function(display){this.imageDiv.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Icon"});OpenLayers.Lang={code:null,defaultCode:"en",getCode:function(){if(!OpenLayers.Lang.code){OpenLayers.Lang.setCode();}
-return OpenLayers.Lang.code;},setCode:function(code){var lang;if(!code){code=(OpenLayers.Util.getBrowserName()=="msie")?navigator.userLanguage:navigator.language;}
-var parts=code.split('-');parts[0]=parts[0].toLowerCase();if(typeof OpenLayers.Lang[parts[0]]=="object"){lang=parts[0];}
-if(parts[1]){var testLang=parts[0]+'-'+parts[1].toUpperCase();if(typeof OpenLayers.Lang[testLang]=="object"){lang=testLang;}}
-if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
-OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
-if(context){message=OpenLayers.String.format(message,context);}
-return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
-if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
-this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
-if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
-window.clearInterval(this.interval);this.interval=null;this.playing=false;},play:function(){var value={};for(var i in this.begin){var b=this.begin[i];var f=this.finish[i];if(b==null||f==null||isNaN(b)||isNaN(f)){OpenLayers.Console.error('invalid value for Tween');}
-var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
-this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
-if(this.time>this.duration){if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);this.playing=false;}
-window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){var args=OpenLayers.Util.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
-if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
-this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
-this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numdigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
-OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
-this.redraw();return this.div;},redraw:function(evt){var lonLat;if(evt==null){lonLat=new OpenLayers.LonLat(0,0);}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
-{this.lastXy=evt.xy;return;}
-lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
-if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
-this.lastXy=evt.xy;}
-var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numdigits);var newHtml=this.prefix+
-lonLat.lon.toFixed(digits)+
-this.separator+
-lonLat.lat.toFixed(digits)+
-this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
-this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_PanZoom_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;btn.slideFactor=this.slideFactor;this.buttons.push(btn);return btn;},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-switch(this.action){case"panup":this.map.pan(0,-this.slideFactor);break;case"pandown":this.map.pan(0,this.slideFactor);break;case"panleft":this.map.pan(-this.slideFactor,0);break;case"panright":this.map.pan(this.slideFactor,0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
-OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
-this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
-this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
-return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
-var curMapUnits=this.map.units;var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
-var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
-if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
-return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
-if(!this.observers){this.observers={};}
-if(!element._eventCacheID){var idPrefix="eventCacheID_";if(element.id){idPrefix=element.id+"_"+idPrefix;}
-element._eventCacheID=OpenLayers.Util.createUniqueID(idPrefix);}
-var cacheID=element._eventCacheID;if(!this.observers[cacheID]){this.observers[cacheID]=[];}
-this.observers[cacheID].push({'element':element,'name':name,'observer':observer,'useCapture':useCapture});if(element.addEventListener){element.addEventListener(name,observer,useCapture);}else if(element.attachEvent){element.attachEvent('on'+name,observer);}},stopObservingElement:function(elementParam){var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;this._removeElementObservers(OpenLayers.Event.observers[cacheID]);},_removeElementObservers:function(elementObservers){if(elementObservers){for(var i=elementObservers.length-1;i>=0;i--){var entry=elementObservers[i];var args=new Array(entry.element,entry.name,entry.observer,entry.useCapture);var removed=OpenLayers.Event.stopObserving.apply(this,args);}}},stopObserving:function(elementParam,name,observer,useCapture){useCapture=useCapture||false;var element=OpenLayers.Util.getElement(elementParam);var cacheID=element._eventCacheID;if(name=='keypress'){if(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.detachEvent){name='keydown';}}
-var foundEntry=false;var elementObservers=OpenLayers.Event.observers[cacheID];if(elementObservers){var i=0;while(!foundEntry&&i<elementObservers.length){var cacheEntry=elementObservers[i];if((cacheEntry.name==name)&&(cacheEntry.observer==observer)&&(cacheEntry.useCapture==useCapture)){elementObservers.splice(i,1);if(elementObservers.length==0){delete OpenLayers.Event.observers[cacheID];}
-foundEntry=true;break;}
-i++;}}
-if(foundEntry){if(element.removeEventListener){element.removeEventListener(name,observer,useCapture);}else if(element&&element.detachEvent){element.detachEvent('on'+name,observer);}}
-return foundEntry;},unloadCache:function(){if(OpenLayers.Event&&OpenLayers.Event.observers){for(var cacheID in OpenLayers.Event.observers){var elementObservers=OpenLayers.Event.observers[cacheID];OpenLayers.Event._removeElementObservers.apply(this,[elementObservers]);}
-OpenLayers.Event.observers=false;}},CLASS_NAME:"OpenLayers.Event"};OpenLayers.Event.observe(window,'unload',OpenLayers.Event.unloadCache,false);if(window.Event){OpenLayers.Util.applyDefaults(window.Event,OpenLayers.Event);}else{var Event=OpenLayers.Event;}
-OpenLayers.Events=OpenLayers.Class({BROWSER_EVENTS:["mouseover","mouseout","mousedown","mouseup","mousemove","click","dblclick","resize","focus","blur"],listeners:null,object:null,element:null,eventTypes:null,eventHandler:null,fallThrough:null,initialize:function(object,element,eventTypes,fallThrough){this.object=object;this.element=element;this.eventTypes=eventTypes;this.fallThrough=fallThrough;this.listeners={};this.eventHandler=OpenLayers.Function.bindAsEventListener(this.handleBrowserEvent,this);if(this.eventTypes!=null){for(var i=0;i<this.eventTypes.length;i++){this.addEventType(this.eventTypes[i]);}}
-if(this.element!=null){this.attachToElement(element);}},destroy:function(){if(this.element){OpenLayers.Event.stopObservingElement(this.element);}
-this.element=null;this.listeners=null;this.object=null;this.eventTypes=null;this.fallThrough=null;this.eventHandler=null;},addEventType:function(eventName){if(!this.listeners[eventName]){this.listeners[eventName]=[];}},attachToElement:function(element){for(var i=0;i<this.BROWSER_EVENTS.length;i++){var eventType=this.BROWSER_EVENTS[i];this.addEventType(eventType);OpenLayers.Event.observe(element,eventType,this.eventHandler);}
-OpenLayers.Event.observe(element,"dragstart",OpenLayers.Event.stop);},on:function(object){for(var type in object){if(type!="scope"){this.register(type,object.scope,object[type]);}}},register:function(type,obj,func){if(func!=null&&((this.eventTypes&&OpenLayers.Util.indexOf(this.eventTypes,type)!=-1)||OpenLayers.Util.indexOf(this.BROWSER_EVENTS,type)!=-1)){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){listeners.push({obj:obj,func:func});}}},registerPriority:function(type,obj,func){if(func!=null){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){listeners.unshift({obj:obj,func:func});}}},un:function(object){for(var type in object){if(type!="scope"){this.unregister(type,object.scope,object[type]);}}},unregister:function(type,obj,func){if(obj==null){obj=this.object;}
-var listeners=this.listeners[type];if(listeners!=null){for(var i=0;i<listeners.length;i++){if(listeners[i].obj==obj&&listeners[i].func==func){listeners.splice(i,1);break;}}}},remove:function(type){if(this.listeners[type]!=null){this.listeners[type]=[];}},triggerEvent:function(type,evt){if(evt==null){evt={};}
-evt.object=this.object;evt.element=this.element;if(!evt.type){evt.type=type;}
-var listeners=(this.listeners[type])?this.listeners[type].slice():null;if((listeners!=null)&&(listeners.length>0)){var continueChain;for(var i=0;i<listeners.length;i++){var callback=listeners[i];continueChain=callback.func.apply(callback.obj,[evt]);if((continueChain!=undefined)&&(continueChain==false)){break;}}
-if(!this.fallThrough){OpenLayers.Event.stop(evt,true);}}
-return continueChain;},handleBrowserEvent:function(evt){evt.xy=this.getMousePosition(evt);this.triggerEvent(evt.type,evt);},getMousePosition:function(evt){if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);this.element.offsets[0]+=(document.documentElement.scrollLeft||document.body.scrollLeft);this.element.offsets[1]+=(document.documentElement.scrollTop||document.body.scrollTop);}
-return new OpenLayers.Pixel((evt.clientX+(document.documentElement.scrollLeft||document.body.scrollLeft))-this.element.offsets[0]
--(document.documentElement.clientLeft||0),(evt.clientY+(document.documentElement.scrollTop||document.body.scrollTop))-this.element.offsets[1]
--(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was either not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
-OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
-this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));var drawTile=(withinMaxExtent||this.layer.displayOutsideMaxExtent);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
-this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
-this.shouldDraw=drawTile;this.clear();return drawTile;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
-this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
-OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
-var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
-this.active=true;return true;},deactivate:function(){if(!this.active){return false;}
-var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.unregister(events[i],this[events[i]]);}}
-this.active=false;return true;},callback:function(name,args){if(name&&this.callbacks[name]){this.callbacks[name].apply(this.control,args);}},register:function(name,method){this.map.events.registerPriority(name,this,method);this.map.events.registerPriority(name,this,this.setEvent);},unregister:function(name,method){this.map.events.unregister(name,this,method);this.map.events.unregister(name,this,this.setEvent);},setEvent:function(evt){this.evt=evt;return true;},destroy:function(){this.deactivate();this.control=this.map=null;},CLASS_NAME:"OpenLayers.Handler"});OpenLayers.Handler.MOD_NONE=0;OpenLayers.Handler.MOD_SHIFT=1;OpenLayers.Handler.MOD_CTRL=2;OpenLayers.Handler.MOD_ALT=4;OpenLayers.Map=OpenLayers.Class({Z_INDEX_BASE:{BaseLayer:100,Overlay:325,Popup:750,Control:1000},EVENT_TYPES:["preaddlayer","addlayer","removelayer","changelayer","movestart","move","moveend","zoomend","popupopen","popupclose","addmarker","removemarker","clearmarkers","mouseover","mouseout","mousemove","dragstart","drag","dragend","changebaselayer"],id:null,fractionalZoom:false,events:null,div:null,dragging:false,size:null,viewPortDiv:null,layerContainerOrigin:null,layerContainerDiv:null,layers:null,controls:null,popups:null,baseLayer:null,center:null,resolution:null,zoom:0,viewRequestID:0,tileSize:null,projection:"EPSG:4326",units:'degrees',resolutions:null,maxResolution:1.40625,minResolution:null,maxScale:null,minScale:null,maxExtent:null,minExtent:null,restrictedExtent:null,numZoomLevels:16,theme:null,displayProjection:null,fallThrough:true,panTween:null,eventListeners:null,panMethod:OpenLayers.Easing.Expo.easeOut,paddingForPopups:null,initialize:function(div,options){this.tileSize=new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,OpenLayers.Map.TILE_HEIGHT);this.maxExtent=new OpenLayers.Bounds(-180,-90,180,90);this.paddingForPopups=new OpenLayers.Bounds(15,15,15,15);this.theme=OpenLayers._getScriptLocation()+'theme/default/style.css';OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID("OpenLayers.Map_");this.div=OpenLayers.Util.getElement(div);var id=this.div.id+"_OpenLayers_ViewPort";this.viewPortDiv=OpenLayers.Util.createDiv(id,null,null,null,"relative",null,"hidden");this.viewPortDiv.style.width="100%";this.viewPortDiv.style.height="100%";this.viewPortDiv.className="olMapViewport";this.div.appendChild(this.viewPortDiv);id=this.div.id+"_OpenLayers_Container";this.layerContainerDiv=OpenLayers.Util.createDiv(id);this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;this.viewPortDiv.appendChild(this.layerContainerDiv);this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES,this.fallThrough);this.updateSize();if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
-this.events.register("movestart",this,this.updateSize);if(OpenLayers.String.contains(navigator.appName,"Microsoft")){this.events.register("resize",this,this.updateSize);}else{this.updateSizeDestroy=OpenLayers.Function.bind(this.updateSize,this);OpenLayers.Event.observe(window,'resize',this.updateSizeDestroy);}
-if(this.theme){var addNode=true;var nodes=document.getElementsByTagName('link');for(var i=0;i<nodes.length;++i){if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,this.theme)){addNode=false;break;}}
-if(addNode){var cssNode=document.createElement('link');cssNode.setAttribute('rel','stylesheet');cssNode.setAttribute('type','text/css');cssNode.setAttribute('href',this.theme);document.getElementsByTagName('head')[0].appendChild(cssNode);}}
-this.layers=[];if(this.controls==null){if(OpenLayers.Control!=null){this.controls=[new OpenLayers.Control.Navigation(),new OpenLayers.Control.PanZoom(),new OpenLayers.Control.ArgParser(),new OpenLayers.Control.Attribution()];}else{this.controls=[];}}
-for(var i=0;i<this.controls.length;i++){this.addControlToMap(this.controls[i]);}
-this.popups=[];this.unloadDestroy=OpenLayers.Function.bind(this.destroy,this);OpenLayers.Event.observe(window,'unload',this.unloadDestroy);},unloadDestroy:null,updateSizeDestroy:null,destroy:function(){if(!this.unloadDestroy){return false;}
-OpenLayers.Event.stopObserving(window,'unload',this.unloadDestroy);this.unloadDestroy=null;if(this.updateSizeDestroy){OpenLayers.Event.stopObserving(window,'resize',this.updateSizeDestroy);}else{this.events.unregister("resize",this,this.updateSize);}
-this.paddingForPopups=null;if(this.controls!=null){for(var i=this.controls.length-1;i>=0;--i){this.controls[i].destroy();}
-this.controls=null;}
-if(this.layers!=null){for(var i=this.layers.length-1;i>=0;--i){this.layers[i].destroy(false);}
-this.layers=null;}
-if(this.viewPortDiv){this.div.removeChild(this.viewPortDiv);}
-this.viewPortDiv=null;if(this.eventListeners){this.events.un(this.eventListeners);this.eventListeners=null;}
-this.events.destroy();this.events=null;},setOptions:function(options){OpenLayers.Util.extend(this,options);},getTileSize:function(){return this.tileSize;},getBy:function(array,property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this[array],function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getLayersBy:function(property,match){return this.getBy("layers",property,match);},getLayersByName:function(match){return this.getLayersBy("name",match);},getLayersByClass:function(match){return this.getLayersBy("CLASS_NAME",match);},getControlsBy:function(property,match){return this.getBy("controls",property,match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},getLayer:function(id){var foundLayer=null;for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(layer.id==id){foundLayer=layer;break;}}
-return foundLayer;},setLayerZIndex:function(layer,zIdx){layer.setZIndex(this.Z_INDEX_BASE[layer.isBaseLayer?'BaseLayer':'Overlay']
-+zIdx*5);},resetLayersZIndex:function(){for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];this.setLayerZIndex(layer,i);}},addLayer:function(layer){for(var i=0;i<this.layers.length;i++){if(this.layers[i]==layer){var msg=OpenLayers.i18n('layerAlreadyAdded',{'layerName':layer.name});OpenLayers.Console.warn(msg);return false;}}
-this.events.triggerEvent("preaddlayer",{layer:layer});layer.div.className="olLayerDiv";layer.div.style.overflow="";this.setLayerZIndex(layer,this.layers.length);if(layer.isFixed){this.viewPortDiv.appendChild(layer.div);}else{this.layerContainerDiv.appendChild(layer.div);}
-this.layers.push(layer);layer.setMap(this);if(layer.isBaseLayer){if(this.baseLayer==null){this.setBaseLayer(layer);}else{layer.setVisibility(false);}}else{layer.redraw();}
-this.events.triggerEvent("addlayer",{layer:layer});},addLayers:function(layers){for(var i=0;i<layers.length;i++){this.addLayer(layers[i]);}},removeLayer:function(layer,setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(layer.isFixed){this.viewPortDiv.removeChild(layer.div);}else{this.layerContainerDiv.removeChild(layer.div);}
-OpenLayers.Util.removeItem(this.layers,layer);layer.removeMap(this);layer.map=null;if(this.baseLayer==layer){this.baseLayer=null;if(setNewBaseLayer){for(var i=0;i<this.layers.length;i++){var iLayer=this.layers[i];if(iLayer.isBaseLayer){this.setBaseLayer(iLayer);break;}}}}
-this.resetLayersZIndex();this.events.triggerEvent("removelayer",{layer:layer});},getNumLayers:function(){return this.layers.length;},getLayerIndex:function(layer){return OpenLayers.Util.indexOf(this.layers,layer);},setLayerIndex:function(layer,idx){var base=this.getLayerIndex(layer);if(idx<0){idx=0;}else if(idx>this.layers.length){idx=this.layers.length;}
-if(base!=idx){this.layers.splice(base,1);this.layers.splice(idx,0,layer);for(var i=0;i<this.layers.length;i++){this.setLayerZIndex(this.layers[i],i);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"order"});}},raiseLayer:function(layer,delta){var idx=this.getLayerIndex(layer)+delta;this.setLayerIndex(layer,idx);},setBaseLayer:function(newBaseLayer){var oldExtent=null;if(this.baseLayer){oldExtent=this.baseLayer.getExtent();}
-if(newBaseLayer!=this.baseLayer){if(OpenLayers.Util.indexOf(this.layers,newBaseLayer)!=-1){if(this.baseLayer!=null){this.baseLayer.setVisibility(false);}
-this.baseLayer=newBaseLayer;this.viewRequestID++;this.baseLayer.visibility=true;var center=this.getCenter();if(center!=null){var newCenter=(oldExtent)?oldExtent.getCenterLonLat():center;var newZoom=(oldExtent)?this.getZoomForExtent(oldExtent,true):this.getZoomForResolution(this.resolution,true);this.setCenter(newCenter,newZoom,false,true);}
-this.events.triggerEvent("changebaselayer",{layer:this.baseLayer});}}},addControl:function(control,px){this.controls.push(control);this.addControlToMap(control,px);},addControlToMap:function(control,px){control.outsideViewport=(control.div!=null);if(this.displayProjection&&!control.displayProjection){control.displayProjection=this.displayProjection;}
-control.setMap(this);var div=control.draw(px);if(div){if(!control.outsideViewport){div.style.zIndex=this.Z_INDEX_BASE['Control']+
-this.controls.length;this.viewPortDiv.appendChild(div);}}},getControl:function(id){var returnControl=null;for(var i=0;i<this.controls.length;i++){var control=this.controls[i];if(control.id==id){returnControl=control;break;}}
-return returnControl;},removeControl:function(control){if((control)&&(control==this.getControl(control.id))){if(control.div&&(control.div.parentNode==this.viewPortDiv)){this.viewPortDiv.removeChild(control.div);}
-OpenLayers.Util.removeItem(this.controls,control);}},addPopup:function(popup,exclusive){if(exclusive){for(var i=this.popups.length-1;i>=0;--i){this.removePopup(this.popups[i]);}}
-popup.map=this;this.popups.push(popup);var popupDiv=popup.draw();if(popupDiv){popupDiv.style.zIndex=this.Z_INDEX_BASE['Popup']+
-this.popups.length;this.layerContainerDiv.appendChild(popupDiv);}},removePopup:function(popup){OpenLayers.Util.removeItem(this.popups,popup);if(popup.div){try{this.layerContainerDiv.removeChild(popup.div);}
-catch(e){}}
-popup.map=null;},getSize:function(){var size=null;if(this.size!=null){size=this.size.clone();}
-return size;},updateSize:function(){this.events.element.offsets=null;var newSize=this.getCurrentSize();var oldSize=this.getSize();if(oldSize==null){this.size=oldSize=newSize;}
-if(!newSize.equals(oldSize)){this.size=newSize;for(var i=0;i<this.layers.length;i++){this.layers[i].onMapResize();}
-if(this.baseLayer!=null){var center=new OpenLayers.Pixel(newSize.w/2,newSize.h/2);var centerLL=this.getLonLatFromViewPortPx(center);var zoom=this.getZoom();this.zoom=null;this.setCenter(this.getCenter(),zoom);}}},getCurrentSize:function(){var size=new OpenLayers.Size(this.div.clientWidth,this.div.clientHeight);if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){var dim=OpenLayers.Element.getDimensions(this.div);size.w=dim.width;size.h=dim.height;}
-if(size.w==0&&size.h==0||isNaN(size.w)&&isNaN(size.h)){size.w=parseInt(this.div.style.width);size.h=parseInt(this.div.style.height);}
-return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
-if(resolution==null){resolution=this.getResolution();}
-if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
-return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){if(!options){options={};}
-OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCenter();var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
-var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
-if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
-if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
-if(zoom==null){zoom=this.getZoom();}
-var resolution=this.getResolutionForZoom(zoom);var extent=this.calculateBounds(lonlat,resolution);if(!this.restrictedExtent.containsBounds(extent)){var maxCenter=this.restrictedExtent.getCenterLonLat();if(extent.getWidth()>this.restrictedExtent.getWidth()){lonlat=new OpenLayers.LonLat(maxCenter.lon,lonlat.lat);}else if(extent.left<this.restrictedExtent.left){lonlat=lonlat.add(this.restrictedExtent.left-
-extent.left,0);}else if(extent.right>this.restrictedExtent.right){lonlat=lonlat.add(this.restrictedExtent.right-
-extent.right,0);}
-if(extent.getHeight()>this.restrictedExtent.getHeight()){lonlat=new OpenLayers.LonLat(lonlat.lon,maxCenter.lat);}else if(extent.bottom<this.restrictedExtent.bottom){lonlat=lonlat.add(0,this.restrictedExtent.bottom-
-extent.bottom);}
-else if(extent.top>this.restrictedExtent.top){lonlat=lonlat.add(0,this.restrictedExtent.top-
-extent.top);}}}
-var zoomChanged=forceZoomChange||((this.isValidZoomLevel(zoom))&&(zoom!=this.getZoom()));var centerChanged=(this.isValidLonLat(lonlat))&&(!lonlat.equals(this.center));if(zoomChanged||centerChanged||!dragging){if(!this.dragging&&!noEvent){this.events.triggerEvent("movestart");}
-if(centerChanged){if((!zoomChanged)&&(this.center)){this.centerLayerContainer(lonlat);}
-this.center=lonlat.clone();}
-if((zoomChanged)||(this.layerContainerOrigin==null)){this.layerContainerOrigin=this.center.clone();this.layerContainerDiv.style.left="0px";this.layerContainerDiv.style.top="0px";}
-if(zoomChanged){this.zoom=zoom;this.resolution=this.getResolutionForZoom(zoom);this.viewRequestID++;}
-var bounds=this.getExtent();this.baseLayer.moveTo(bounds,zoomChanged,dragging);bounds=this.baseLayer.getExtent();for(var i=0;i<this.layers.length;i++){var layer=this.layers[i];if(!layer.isBaseLayer){var inRange=layer.calculateInRange();if(layer.inRange!=inRange){layer.inRange=inRange;if(!inRange){layer.display(false);}
-this.events.triggerEvent("changelayer",{layer:layer,property:"visibility"});}
-if(inRange&&layer.visibility){layer.moveTo(bounds,zoomChanged,dragging);}}}
-if(zoomChanged){for(var i=0;i<this.popups.length;i++){this.popups[i].updatePosition();}}
-this.events.triggerEvent("move");if(zoomChanged){this.events.triggerEvent("zoomend");}}
-if(!dragging&&!noEvent){this.events.triggerEvent("moveend");}
-this.dragging=!!dragging;},centerLayerContainer:function(lonlat){var originPx=this.getViewPortPxFromLonLat(this.layerContainerOrigin);var newPx=this.getViewPortPxFromLonLat(lonlat);if((originPx!=null)&&(newPx!=null)){this.layerContainerDiv.style.left=Math.round(originPx.x-newPx.x)+"px";this.layerContainerDiv.style.top=Math.round(originPx.y-newPx.y)+"px";}},isValidZoomLevel:function(zoomLevel){return((zoomLevel!=null)&&(zoomLevel>=0)&&(zoomLevel<this.getNumZoomLevels()));},isValidLonLat:function(lonlat){var valid=false;if(lonlat!=null){var maxExtent=this.getMaxExtent();valid=maxExtent.containsLonLat(lonlat);}
-return valid;},getProjection:function(){var projection=this.getProjectionObject();return projection?projection.getCode():null;},getProjectionObject:function(){var projection=null;if(this.baseLayer!=null){projection=this.baseLayer.projection;}
-return projection;},getMaxResolution:function(){var maxResolution=null;if(this.baseLayer!=null){maxResolution=this.baseLayer.maxResolution;}
-return maxResolution;},getMaxExtent:function(){var maxExtent=null;if(this.baseLayer!=null){maxExtent=this.baseLayer.maxExtent;}
-return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
-return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
-return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}
-return resolution;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
-return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
-return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
-return zoom;},zoomTo:function(zoom){if(this.isValidZoomLevel(zoom)){this.setCenter(null,zoom);}},zoomIn:function(){this.zoomTo(this.getZoom()+1);},zoomOut:function(){this.zoomTo(this.getZoom()-1);},zoomToExtent:function(bounds){var center=bounds.getCenterLonLat();if(this.baseLayer.wrapDateLine){var maxExtent=this.getMaxExtent();bounds=bounds.clone();while(bounds.right<bounds.left){bounds.right+=maxExtent.getWidth();}
-center=bounds.getCenterLonLat().wrapDateLine(maxExtent);}
-this.setCenter(center,this.getZoomForExtent(bounds));},zoomToMaxExtent:function(){this.zoomToExtent(this.getMaxExtent());},zoomToScale:function(scale){var res=OpenLayers.Util.getResolutionFromScale(scale,this.baseLayer.units);var size=this.getSize();var w_deg=size.w*res;var h_deg=size.h*res;var center=this.getCenter();var extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);this.zoomToExtent(extent);},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(this.baseLayer!=null){lonlat=this.baseLayer.getLonLatFromViewPortPx(viewPortPx);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(this.baseLayer!=null){px=this.baseLayer.getViewPortPxFromLonLat(lonlat);}
-return px;},getLonLatFromPixel:function(px){return this.getLonLatFromViewPortPx(px);},getPixelFromLonLat:function(lonlat){var px=this.getViewPortPxFromLonLat(lonlat);px.x=Math.round(px.x);px.y=Math.round(px.y);return px;},getViewPortPxFromLayerPx:function(layerPx){var viewPortPx=null;if(layerPx!=null){var dX=parseInt(this.layerContainerDiv.style.left);var dY=parseInt(this.layerContainerDiv.style.top);viewPortPx=layerPx.add(dX,dY);}
-return viewPortPx;},getLayerPxFromViewPortPx:function(viewPortPx){var layerPx=null;if(viewPortPx!=null){var dX=-parseInt(this.layerContainerDiv.style.left);var dY=-parseInt(this.layerContainerDiv.style.top);layerPx=viewPortPx.add(dX,dY);if(isNaN(layerPx.x)||isNaN(layerPx.y)){layerPx=null;}}
-return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
-this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
-this.lonlat=this.map.getLonLatFromLayerPx(px);},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
-if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}}
-this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
-this.frame=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
-obj=OpenLayers.Tile.prototype.clone.apply(this,[obj]);obj.imgDiv=null;return obj;},draw:function(){if(this.layer!=this.layer.map.baseLayer&&this.layer.reproject){this.bounds=this.getBoundsFromBaseLayer(this.position);}
-if(!OpenLayers.Tile.prototype.draw.apply(this,arguments)){return false;}
-if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-return this.renderTile();},renderTile:function(){if(this.imgDiv==null){this.initImgDiv();}
-this.imgDiv.viewRequestID=this.layer.map.viewRequestID;this.url=this.layer.getURL(this.bounds);OpenLayers.Util.modifyDOMElement(this.frame,null,this.position,this.size);var imageSize=this.layer.getImageSize();if(this.layerAlphaHack){OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,null,null,imageSize,this.url);}else{OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,imageSize);this.imgDiv.src=this.url;}
-return true;},clear:function(){if(this.imgDiv){this.hide();if(OpenLayers.Tile.Image.useBlankTile){this.imgDiv.src=OpenLayers.Util.getImagesLocation()+"blank.gif";}}},initImgDiv:function(){var offset=this.layer.imageOffset;var size=this.layer.getImageSize();if(this.layerAlphaHack){this.imgDiv=OpenLayers.Util.createAlphaImageDiv(null,offset,size,null,"relative",null,null,null,true);}else{this.imgDiv=OpenLayers.Util.createImage(null,offset,size,null,"relative",null,null,true);}
-this.imgDiv.className='olTileImage';this.frame.style.zIndex=this.isBackBuffer?0:1;this.frame.appendChild(this.imgDiv);this.layer.div.appendChild(this.frame);if(this.layer.opacity!=null){OpenLayers.Util.modifyDOMElement(this.imgDiv,null,null,null,null,null,null,this.layer.opacity);}
-this.imgDiv.map=this.layer.map;var onload=function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("loadend");}};if(this.layerAlphaHack){OpenLayers.Event.observe(this.imgDiv.childNodes[0],'load',OpenLayers.Function.bind(onload,this));}else{OpenLayers.Event.observe(this.imgDiv,'load',OpenLayers.Function.bind(onload,this));}
-var onerror=function(){if(this.imgDiv._attempts>OpenLayers.IMAGE_RELOAD_ATTEMPTS){onload.call(this);}};OpenLayers.Event.observe(this.imgDiv,"error",OpenLayers.Function.bind(onerror,this));},checkImgURL:function(){if(this.layer){var loaded=this.layerAlphaHack?this.imgDiv.firstChild.src:this.imgDiv.src;if(!OpenLayers.Util.isEquivalentUrl(loaded,this.url)){this.hide();}}},startTransition:function(){if(!this.backBufferTile||!this.backBufferTile.imgDiv){return;}
-var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
-if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
-OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
-this.handlers.click.destroy();this.mapDiv.removeChild(this.extentRectangle);this.extentRectangle=null;this.rectEvents.destroy();this.rectEvents=null;this.ovmap.destroy();this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
-if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
-this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
-this.element=document.createElement('div');this.element.className=this.displayClass+'Element';this.element.style.display='none';this.mapDiv=document.createElement('div');this.mapDiv.style.width=this.size.w+'px';this.mapDiv.style.height=this.size.h+'px';this.mapDiv.style.position='relative';this.mapDiv.style.overflow='hidden';this.mapDiv.id=OpenLayers.Util.createUniqueID('overviewMap');this.extentRectangle=document.createElement('div');this.extentRectangle.style.position='absolute';this.extentRectangle.style.zIndex=1000;this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.mapDiv.appendChild(this.extentRectangle);this.element.appendChild(this.mapDiv);this.div.appendChild(this.element);if(!this.outsideViewport){this.div.className+=" "+this.displayClass+'Container';var imgLocation=OpenLayers.Util.getImagesLocation();var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv(this.displayClass+'MaximizeButton',null,new OpenLayers.Size(18,18),img,'absolute');this.maximizeDiv.style.display='none';this.maximizeDiv.className=this.displayClass+'MaximizeButton';OpenLayers.Event.observe(this.maximizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv('OpenLayers_Control_minimizeDiv',null,new OpenLayers.Size(18,18),img,'absolute');this.minimizeDiv.style.display='none';this.minimizeDiv.className=this.displayClass+'MinimizeButton';OpenLayers.Event.observe(this.minimizeDiv,'click',OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);var eventsToStop=['dblclick','mousedown'];for(var i=0;i<eventsToStop.length;i++){OpenLayers.Event.observe(this.maximizeDiv,eventsToStop[i],OpenLayers.Event.stop);OpenLayers.Event.observe(this.minimizeDiv,eventsToStop[i],OpenLayers.Event.stop);}
-this.minimizeControl();}else{this.element.style.display='';}
-if(this.map.getExtent()){this.update();}
-this.map.events.register('moveend',this,this.update);return this.div;},baseLayerDraw:function(){this.draw();this.map.events.unregister("changebaselayer",this,this.baseLayerDraw);},rectDrag:function(px){var deltaX=this.handlers.drag.last.x-px.x;var deltaY=this.handlers.drag.last.y-px.y;if(deltaX!=0||deltaY!=0){var rectTop=this.rectPxBounds.top;var rectLeft=this.rectPxBounds.left;var rectHeight=Math.abs(this.rectPxBounds.getHeight());var rectWidth=this.rectPxBounds.getWidth();var newTop=Math.max(0,(rectTop-deltaY));newTop=Math.min(newTop,this.ovmap.size.h-this.hComp-rectHeight);var newLeft=Math.max(0,(rectLeft-deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-this.wComp-rectWidth);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+rectHeight,newLeft+rectWidth,newTop));}},mapDivClick:function(evt){var pxCenter=this.rectPxBounds.getCenterPixel();var deltaX=evt.xy.x-pxCenter.x;var deltaY=evt.xy.y-pxCenter.y;var top=this.rectPxBounds.top;var left=this.rectPxBounds.left;var height=Math.abs(this.rectPxBounds.getHeight());var width=this.rectPxBounds.getWidth();var newTop=Math.max(0,(top+deltaY));newTop=Math.min(newTop,this.ovmap.size.h-height);var newLeft=Math.max(0,(left+deltaX));newLeft=Math.min(newLeft,this.ovmap.size.w-width);this.setRectPxBounds(new OpenLayers.Bounds(newLeft,newTop+height,newLeft+width,newTop));this.updateMapToRect();},maximizeControl:function(e){this.element.style.display='';this.showToggle(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.element.style.display='none';this.showToggle(true);if(e!=null){OpenLayers.Event.stop(e);}},showToggle:function(minimize){this.maximizeDiv.style.display=minimize?'':'none';this.minimizeDiv.style.display=minimize?'none':'';},update:function(){if(this.ovmap==null){this.createMap();}
-if(!this.isSuitableOverview()){this.updateOverview();}
-this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
-this.ovmap.setCenter(this.map.center,this.ovmap.getZoomForResolution(targetRes));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.units!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
-var pxBounds=this.getRectBoundsFromMapBounds(this.map.getExtent());if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
-this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
-this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
-return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat)));}
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
-this.clearTimer();}
-return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
-return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
-Math.pow(this.down.y-evt.xy.y,2));if(dpx>this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.timerId=null;if(evt){this.callback('click',[evt]);}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();this.down=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Click"});OpenLayers.Handler.Drag=OpenLayers.Class(OpenLayers.Handler,{started:false,stopDown:true,dragging:false,last:null,start:null,oldOnselectstart:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},down:function(evt){},move:function(evt){},up:function(evt){},out:function(evt){},mousedown:function(evt){var propagate=true;this.dragging=false;if(this.checkModifiers(evt)&&OpenLayers.Event.isLeftClick(evt)){this.started=true;this.start=evt.xy;this.last=evt.xy;this.map.div.style.cursor="move";this.down(evt);this.callback("down",[evt.xy]);OpenLayers.Event.stop(evt);if(!this.oldOnselectstart){this.oldOnselectstart=(document.onselectstart)?document.onselectstart:function(){return true;};document.onselectstart=function(){return false;};}
-propagate=!this.stopDown;}else{this.started=false;this.start=null;this.last=null;}
-return propagate;},mousemove:function(evt){if(this.started){if(evt.xy.x!=this.last.x||evt.xy.y!=this.last.y){this.dragging=true;this.move(evt);this.callback("move",[evt.xy]);if(!this.oldOnselectstart){this.oldOnselectstart=document.onselectstart;document.onselectstart=function(){return false;};}
-this.last=evt.xy;}}
-return true;},mouseup:function(evt){if(this.started){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.up(evt);this.callback("up",[evt.xy]);if(dragged){this.callback("done",[evt.xy]);}
-document.onselectstart=this.oldOnselectstart;}
-return true;},mouseout:function(evt){if(this.started&&OpenLayers.Util.mouseLeft(evt,this.map.div)){var dragged=(this.start!=this.last);this.started=false;this.dragging=false;this.map.div.style.cursor="";this.out(evt);this.callback("out",[]);if(dragged){this.callback("done",[evt.xy]);}
-if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}
-return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
-var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
-overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
-if(!overLayerDiv){for(var i=0;i<this.map.layers.length;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
-overMapDiv=(elem==this.map.div);elem=elem.parentNode;}
-if(!overScrollableDiv&&overMapDiv){if(overLayerDiv){this.wheelZoom(e);}
-OpenLayers.Event.stop(e);}},wheelZoom:function(e){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-if(delta){if(this.mousePosition){e.xy=this.mousePosition;}
-if(!e.xy){e.xy=this.map.getPixelFromLonLat(this.map.getCenter());}
-if(delta<0){this.callback("down",[e,delta]);}else{this.callback("up",[e,delta]);}}},mousemove:function(evt){this.mousePosition=evt.xy;},activate:function(evt){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.observe(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.observe(window,"mousewheel",wheelListener);OpenLayers.Event.observe(document,"mousewheel",wheelListener);return true;}else{return false;}},deactivate:function(evt){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){var wheelListener=this.wheelListener;OpenLayers.Event.stopObserving(window,"DOMMouseScroll",wheelListener);OpenLayers.Event.stopObserving(window,"mousewheel",wheelListener);OpenLayers.Event.stopObserving(document,"mousewheel",wheelListener);return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.MouseWheel"});OpenLayers.Layer=OpenLayers.Class({id:null,name:null,div:null,opacity:null,EVENT_TYPES:["loadstart","loadend","loadcancel","visibilitychanged"],events:null,map:null,isBaseLayer:false,alpha:false,displayInLayerSwitcher:true,visibility:true,attribution:null,inRange:false,imageSize:null,imageOffset:null,options:null,eventListeners:null,gutter:0,projection:null,units:null,scales:null,resolutions:null,maxExtent:null,minExtent:null,maxResolution:null,minResolution:null,numZoomLevels:null,minScale:null,maxScale:null,displayOutsideMaxExtent:false,wrapDateLine:false,transitionEffect:null,SUPPORTED_TRANSITIONS:['resize'],initialize:function(name,options){this.addOptions(options);this.name=name;if(this.id==null){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.div=OpenLayers.Util.createDiv(this.id);this.div.style.width="100%";this.div.style.height="100%";this.events=new OpenLayers.Events(this,this.div,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}}
-if(this.wrapDateLine){this.displayOutsideMaxExtent=true;}},destroy:function(setNewBaseLayer){if(setNewBaseLayer==null){setNewBaseLayer=true;}
-if(this.map!=null){this.map.removeLayer(this,setNewBaseLayer);}
-this.projection=null;this.map=null;this.name=null;this.div=null;this.options=null;if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
-this.events.destroy();}
-this.eventListeners=null;this.events=null;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer(this.name,this.options);}
-OpenLayers.Util.applyDefaults(obj,this);obj.map=null;return obj;},setName:function(newName){if(newName!=this.name){this.name=newName;if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"name"});}}},addOptions:function(newOptions){if(this.options==null){this.options={};}
-OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},onMapResize:function(){},redraw:function(){var redrawn=false;if(this.map){this.inRange=this.calculateInRange();var extent=this.getExtent();if(extent&&this.inRange&&this.visibility){this.moveTo(extent,true,false);redrawn=true;}}
-return redrawn;},moveTo:function(bounds,zoomChanged,dragging){var display=this.visibility;if(!this.isBaseLayer){display=display&&this.inRange;}
-this.display(display);},setMap:function(map){if(this.map==null){this.map=map;this.maxExtent=this.maxExtent||this.map.maxExtent;this.projection=this.projection||this.map.projection;if(this.projection&&typeof this.projection=="string"){this.projection=new OpenLayers.Projection(this.projection);}
-this.units=this.projection.getUnits()||this.units||this.map.units;this.initResolutions();if(!this.isBaseLayer){this.inRange=this.calculateInRange();var show=((this.visibility)&&(this.inRange));this.div.style.display=show?"":"none";}
-this.setTileSize();}},removeMap:function(map){},getImageSize:function(){return(this.imageSize||this.tileSize);},setTileSize:function(size){var tileSize=(size)?size:((this.tileSize)?this.tileSize:this.map.getTileSize());this.tileSize=tileSize;if(this.gutter){this.imageOffset=new OpenLayers.Pixel(-this.gutter,-this.gutter);this.imageSize=new OpenLayers.Size(tileSize.w+(2*this.gutter),tileSize.h+(2*this.gutter));}},getVisibility:function(){return this.visibility;},setVisibility:function(visibility){if(visibility!=this.visibility){this.visibility=visibility;this.display(visibility);this.redraw();if(this.map!=null){this.map.events.triggerEvent("changelayer",{layer:this,property:"visibility"});}
-this.events.triggerEvent("visibilitychanged");}},display:function(display){var inRange=this.calculateInRange();if(display!=(this.div.style.display!="none")){this.div.style.display=(display&&inRange)?"block":"none";}},calculateInRange:function(){var inRange=false;if(this.map){var resolution=this.map.getResolution();inRange=((resolution>=this.minResolution)&&(resolution<=this.maxResolution));}
-return inRange;},setIsBaseLayer:function(isBaseLayer){if(isBaseLayer!=this.isBaseLayer){this.isBaseLayer=isBaseLayer;if(this.map!=null){this.map.events.triggerEvent("changebaselayer",{layer:this});}}},initResolutions:function(){var props=new Array('projection','units','scales','resolutions','maxScale','minScale','maxResolution','minResolution','minExtent','maxExtent','numZoomLevels','maxZoomLevel');var confProps={};for(var i=0;i<props.length;i++){var property=props[i];confProps[property]=this.options[property]||this.map[property];}
-if(this.options.minScale!=null&&this.options.maxScale!=null&&this.options.scales==null){confProps.scales=null;}
-if(this.options.minResolution!=null&&this.options.maxResolution!=null&&this.options.resolutions==null){confProps.resolutions=null;}
-if((!confProps.numZoomLevels)&&(confProps.maxZoomLevel)){confProps.numZoomLevels=confProps.maxZoomLevel+1;}
-if((confProps.scales!=null)||(confProps.resolutions!=null)){if(confProps.scales!=null){confProps.resolutions=[];for(var i=0;i<confProps.scales.length;i++){var scale=confProps.scales[i];confProps.resolutions[i]=OpenLayers.Util.getResolutionFromScale(scale,confProps.units);}}
-confProps.numZoomLevels=confProps.resolutions.length;}else{if(confProps.minScale){confProps.maxResolution=OpenLayers.Util.getResolutionFromScale(confProps.minScale,confProps.units);}else if(confProps.maxResolution=="auto"){var viewSize=this.map.getSize();var wRes=confProps.maxExtent.getWidth()/viewSize.w;var hRes=confProps.maxExtent.getHeight()/viewSize.h;confProps.maxResolution=Math.max(wRes,hRes);}
-if(confProps.maxScale!=null){confProps.minResolution=OpenLayers.Util.getResolutionFromScale(confProps.maxScale,confProps.units);}else if((confProps.minResolution=="auto")&&(confProps.minExtent!=null)){var viewSize=this.map.getSize();var wRes=confProps.minExtent.getWidth()/viewSize.w;var hRes=confProps.minExtent.getHeight()/viewSize.h;confProps.minResolution=Math.max(wRes,hRes);}
-if(confProps.minResolution!=null&&this.options.numZoomLevels==undefined){var ratio=confProps.maxResolution/confProps.minResolution;confProps.numZoomLevels=Math.floor(Math.log(ratio)/Math.log(2))+1;}
-confProps.resolutions=new Array(confProps.numZoomLevels);var base=2;if(typeof confProps.minResolution=="number"&&confProps.numZoomLevels>1){base=Math.pow((confProps.maxResolution/confProps.minResolution),(1/(confProps.numZoomLevels-1)));}
-for(var i=0;i<confProps.numZoomLevels;i++){var res=confProps.maxResolution/Math.pow(base,i);confProps.resolutions[i]=res;}}
-confProps.resolutions.sort(function(a,b){return(b-a);});this.resolutions=confProps.resolutions;this.maxResolution=confProps.resolutions[0];var lastIndex=confProps.resolutions.length-1;this.minResolution=confProps.resolutions[lastIndex];this.scales=[];for(var i=0;i<confProps.resolutions.length;i++){this.scales[i]=OpenLayers.Util.getScaleFromResolution(confProps.resolutions[i],confProps.units);}
-this.minScale=this.scales[0];this.maxScale=this.scales[this.scales.length-1];this.numZoomLevels=confProps.numZoomLevels;},getResolution:function(){var zoom=this.map.getZoom();return this.getResolutionForZoom(zoom);},getExtent:function(){return this.map.calculateBounds();},getZoomForExtent:function(extent,closest){var viewSize=this.map.getSize();var idealResolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);return this.getZoomForResolution(idealResolution,closest);},getDataExtent:function(){},getResolutionForZoom:function(zoom){zoom=Math.max(0,Math.min(zoom,this.resolutions.length-1));var resolution;if(this.map.fractionalZoom){var low=Math.floor(zoom);var high=Math.ceil(zoom);resolution=this.resolutions[high]+
-((zoom-low)*(this.resolutions[low]-this.resolutions[high]));}else{resolution=this.resolutions[Math.round(zoom)];}
-return resolution;},getZoomForResolution:function(resolution,closest){var zoom;if(this.map.fractionalZoom){var lowZoom=0;var highZoom=this.resolutions.length-1;var highRes=this.resolutions[lowZoom];var lowRes=this.resolutions[highZoom];var res;for(var i=0;i<this.resolutions.length;++i){res=this.resolutions[i];if(res>=resolution){highRes=res;lowZoom=i;}
-if(res<=resolution){lowRes=res;highZoom=i;break;}}
-var dRes=highRes-lowRes;if(dRes>0){zoom=lowZoom+((resolution-lowRes)/dRes);}else{zoom=lowZoom;}}else{var diff;var minDiff=Number.POSITIVE_INFINITY;for(var i=0;i<this.resolutions.length;i++){if(closest){diff=Math.abs(this.resolutions[i]-resolution);if(diff>minDiff){break;}
-minDiff=diff;}else{if(this.resolutions[i]<resolution){break;}}}
-zoom=Math.max(0,i-1);}
-return zoom;},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if(viewPortPx!=null){var size=this.map.getSize();var center=this.map.getCenter();if(center){var res=this.map.getResolution();var delta_x=viewPortPx.x-(size.w/2);var delta_y=viewPortPx.y-(size.h/2);lonlat=new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);if(this.wrapDateLine){lonlat=lonlat.wrapDateLine(this.maxExtent);}}}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var px=null;if(lonlat!=null){var resolution=this.map.getResolution();var extent=this.map.getExtent();px=new OpenLayers.Pixel((1/resolution*(lonlat.lon-extent.left)),(1/resolution*(extent.top-lonlat.lat)));}
-return px;},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.div.childNodes.length;++i){var element=this.div.childNodes[i].firstChild;OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);}}},setZIndex:function(zIndex){this.div.style.zIndex=zIndex;},adjustBounds:function(bounds){if(this.gutter){var mapGutter=this.gutter*this.map.getResolution();bounds=new OpenLayers.Bounds(bounds.left-mapGutter,bounds.bottom-mapGutter,bounds.right+mapGutter,bounds.top+mapGutter);}
-if(this.wrapDateLine){var wrappingOptions={'rightTolerance':this.getResolution()};bounds=bounds.wrapDateLine(this.maxExtent,wrappingOptions);}
-return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
-if(!width){width=2;}
-this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
-return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var deltaX=Math.abs(this.dragHandler.start.x-xy.x);var deltaY=Math.abs(this.dragHandler.start.y-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(xy.x<this.dragHandler.start.x){this.zoomBox.style.left=xy.x+"px";}
-if(xy.y<this.dragHandler.start.y){this.zoomBox.style.top=xy.y+"px";}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);return this.redraw();},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0;i<paramString.length;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
-return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize().clone();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
-OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this,[size]);},getGridBounds:function(){var msg="The getGridBounds() function is deprecated. It will be "+"removed in 3.0. Please use getTilesBounds() instead.";OpenLayers.Console.warn(msg);return this.getTilesBounds();},getTilesBounds:function(){var bounds=null;if(this.grid.length){var bottom=this.grid.length-1;var bottomLeftTile=this.grid[bottom][0];var right=this.grid[0].length-1;var topRightTile=this.grid[0][right];bounds=new OpenLayers.Bounds(bottomLeftTile.bounds.left,bottomLeftTile.bounds.bottom,topRightTile.bounds.right,topRightTile.bounds.top);}
-return bounds;},initSingleTile:function(bounds){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var px=this.map.getLayerPxFromLonLat(ul);if(!this.grid.length){this.grid[0]=[];}
-var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
-this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
-Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
-Math.max(1,2*this.buffer);var extent=this.map.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
-tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
-tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols)
-tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows)
-this.removeExcessTiles(rowidx,colidx);this.spiralTileLoad();},spiralTileLoad:function(){var tileQueue=[];var directions=["right","down","left","up"];var iRow=0;var iCell=-1;var direction=OpenLayers.Util.indexOf(directions,"right");var directionsTried=0;while(directionsTried<directions.length){var testRow=iRow;var testCell=iCell;switch(directions[direction]){case"right":testCell++;break;case"down":testRow++;break;case"left":testCell--;break;case"up":testRow--;break;}
-var tile=null;if((testRow<this.grid.length)&&(testRow>=0)&&(testCell<this.grid[0].length)&&(testCell>=0)){tile=this.grid[testRow][testCell];}
-if((tile!=null)&&(!tile.queued)){tileQueue.unshift(tile);tile.queued=true;directionsTried=0;iRow=testRow;iCell=testCell;}else{direction=(direction+1)%4;directionsTried++;}}
-for(var i=0;i<tileQueue.length;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
-this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0;i<modelRow.length;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
-if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0;i<this.grid.length;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.map.getMaxExtent();var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
-maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
-this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
-this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
-this.handlers.click.activate();this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){this.handlers.click=new OpenLayers.Handler.Click(this,{'dblclick':this.defaultDblClick},{'double':true,'stopDouble':true});this.dragPan=new OpenLayers.Control.DragPan({map:this.map});this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:OpenLayers.Handler.MOD_SHIFT});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown});this.activate();},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},wheelChange:function(evt,deltaZ){var newZoom=this.map.getZoom()+deltaZ;if(!this.map.isValidZoomLevel(newZoom)){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
-if(this.singleTile){OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';getVisParams=OpenLayers.Util.extend(getVisParams,params);new OpenLayers.Ajax.Request(this.url,{parameters:getVisParams,method:'get',asynchronous:false});}
-url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}
-return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
-var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getArgs(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
-var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);if(arguments.length>0){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}
-if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
-paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
-if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});
\ No newline at end of file
+ OpenLayers/SingleFile.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+var OpenLayers = {
+ singleFile: true
+ OpenLayers.js
+ * @requires OpenLayers/BaseTypes.js
+ * @requires OpenLayers/Lang/en.js
+(function() {
+ * Before creating the OpenLayers namespace, check to see if
+ * OpenLayers.singleFile is true. This occurs if the
+ * OpenLayers/SingleFile.js script is included before this one - as is the
+ * case with single file builds.
+ var singleFile = (typeof OpenLayers == "object" && OpenLayers.singleFile);
+ * Namespace: OpenLayers
+ * The OpenLayers object provides a namespace for all things OpenLayers
+ window.OpenLayers = {
+ * Property: _scriptName
+ * {String} Relative path of this script.
+ _scriptName: (!singleFile) ? "lib/OpenLayers.js" : "OpenLayers.js",
+ * Function: _getScriptLocation
+ * Return the path to this script.
+ * Returns:
+ * {String} Path to this script
+ _getScriptLocation: function () {
+ var scriptLocation = "";
+ var scriptName = OpenLayers._scriptName;
+ var scripts = document.getElementsByTagName('script');
+ for (var i = 0; i < scripts.length; i++) {
+ var src = scripts[i].getAttribute('src');
+ if (src) {
+ var index = src.lastIndexOf(scriptName);
+ // set path length for src up to a query string
+ var pathLength = src.lastIndexOf('?');
+ if (pathLength < 0) {
+ pathLength = src.length;
+ // is it found, at the end of the URL?
+ if ((index > -1) && (index + scriptName.length == pathLength)) {
+ scriptLocation = src.slice(0, pathLength - scriptName.length);
+ break;
+ return scriptLocation;
+ * OpenLayers.singleFile is a flag indicating this file is being included
+ * in a Single File Library build of the OpenLayers Library.
+ * When we are *not* part of a SFL build we dynamically include the
+ * OpenLayers library code.
+ * When we *are* part of a SFL build we do not dynamically include the
+ * OpenLayers library code as it will be appended at the end of this file.
+ if(!singleFile) {
+ var jsfiles = new Array(
+ "OpenLayers/Util.js",
+ "OpenLayers/BaseTypes.js",
+ "OpenLayers/BaseTypes/Class.js",
+ "OpenLayers/BaseTypes/Bounds.js",
+ "OpenLayers/BaseTypes/Element.js",
+ "OpenLayers/BaseTypes/LonLat.js",
+ "OpenLayers/BaseTypes/Pixel.js",
+ "OpenLayers/BaseTypes/Size.js",
+ "OpenLayers/Console.js",
+ "OpenLayers/Tween.js",
+ "Rico/Corner.js",
+ "Rico/Color.js",
+ "OpenLayers/Ajax.js",
+ "OpenLayers/Events.js",
+ "OpenLayers/Projection.js",
+ "OpenLayers/Map.js",
+ "OpenLayers/Layer.js",
+ "OpenLayers/Icon.js",
+ "OpenLayers/Marker.js",
+ "OpenLayers/Marker/Box.js",
+ "OpenLayers/Popup.js",
+ "OpenLayers/Tile.js",
+ "OpenLayers/Tile/Image.js",
+ "OpenLayers/Tile/WFS.js",
+ "OpenLayers/Layer/Image.js",
+ "OpenLayers/Layer/SphericalMercator.js",
+ "OpenLayers/Layer/EventPane.js",
+ "OpenLayers/Layer/FixedZoomLevels.js",
+ "OpenLayers/Layer/Google.js",
+ "OpenLayers/Layer/VirtualEarth.js",
+ "OpenLayers/Layer/Yahoo.js",
+ "OpenLayers/Layer/HTTPRequest.js",
+ "OpenLayers/Layer/Grid.js",
+ "OpenLayers/Layer/MapGuide.js",
+ "OpenLayers/Layer/MapServer.js",
+ "OpenLayers/Layer/MapServer/Untiled.js",
+ "OpenLayers/Layer/KaMap.js",
+ "OpenLayers/Layer/MultiMap.js",
+ "OpenLayers/Layer/Markers.js",
+ "OpenLayers/Layer/Text.js",
+ "OpenLayers/Layer/WorldWind.js",
+ "OpenLayers/Layer/WMS.js",
+ "OpenLayers/Layer/WMS/Untiled.js",
+ "OpenLayers/Layer/GeoRSS.js",
+ "OpenLayers/Layer/Boxes.js",
+ "OpenLayers/Layer/TMS.js",
+ "OpenLayers/Layer/TileCache.js",
+ "OpenLayers/Popup/Anchored.js",
+ "OpenLayers/Popup/AnchoredBubble.js",
+ "OpenLayers/Popup/Framed.js",
+ "OpenLayers/Popup/FramedCloud.js",
+ "OpenLayers/Feature.js",
+ "OpenLayers/Feature/Vector.js",
+ "OpenLayers/Feature/WFS.js",
+ "OpenLayers/Handler.js",
+ "OpenLayers/Handler/Click.js",
+ "OpenLayers/Handler/Hover.js",
+ "OpenLayers/Handler/Point.js",
+ "OpenLayers/Handler/Path.js",
+ "OpenLayers/Handler/Polygon.js",
+ "OpenLayers/Handler/Feature.js",
+ "OpenLayers/Handler/Drag.js",
+ "OpenLayers/Handler/RegularPolygon.js",
+ "OpenLayers/Handler/Box.js",
+ "OpenLayers/Handler/MouseWheel.js",
+ "OpenLayers/Handler/Keyboard.js",
+ "OpenLayers/Control.js",
+ "OpenLayers/Control/Attribution.js",
+ "OpenLayers/Control/Button.js",
+ "OpenLayers/Control/ZoomBox.js",
+ "OpenLayers/Control/ZoomToMaxExtent.js",
+ "OpenLayers/Control/DragPan.js",
+ "OpenLayers/Control/Navigation.js",
+ "OpenLayers/Control/MouseDefaults.js",
+ "OpenLayers/Control/MousePosition.js",
+ "OpenLayers/Control/OverviewMap.js",
+ "OpenLayers/Control/KeyboardDefaults.js",
+ "OpenLayers/Control/PanZoom.js",
+ "OpenLayers/Control/PanZoomBar.js",
+ "OpenLayers/Control/ArgParser.js",
+ "OpenLayers/Control/Permalink.js",
+ "OpenLayers/Control/Scale.js",
+ "OpenLayers/Control/ScaleLine.js",
+ "OpenLayers/Control/LayerSwitcher.js",
+ "OpenLayers/Control/DrawFeature.js",
+ "OpenLayers/Control/DragFeature.js",
+ "OpenLayers/Control/ModifyFeature.js",
+ "OpenLayers/Control/Panel.js",
+ "OpenLayers/Control/SelectFeature.js",
+ "OpenLayers/Control/NavigationHistory.js",
+ "OpenLayers/Geometry.js",
+ "OpenLayers/Geometry/Rectangle.js",
+ "OpenLayers/Geometry/Collection.js",
+ "OpenLayers/Geometry/Point.js",
+ "OpenLayers/Geometry/MultiPoint.js",
+ "OpenLayers/Geometry/Curve.js",
+ "OpenLayers/Geometry/LineString.js",
+ "OpenLayers/Geometry/LinearRing.js",
+ "OpenLayers/Geometry/Polygon.js",
+ "OpenLayers/Geometry/MultiLineString.js",
+ "OpenLayers/Geometry/MultiPolygon.js",
+ "OpenLayers/Geometry/Surface.js",
+ "OpenLayers/Renderer.js",
+ "OpenLayers/Renderer/Elements.js",
+ "OpenLayers/Renderer/SVG.js",
+ "OpenLayers/Renderer/VML.js",
+ "OpenLayers/Layer/Vector.js",
+ "OpenLayers/Layer/PointTrack.js",
+ "OpenLayers/Layer/GML.js",
+ "OpenLayers/Style.js",
+ "OpenLayers/StyleMap.js",
+ "OpenLayers/Rule.js",
+ "OpenLayers/Filter.js",
+ "OpenLayers/Filter/FeatureId.js",
+ "OpenLayers/Filter/Logical.js",
+ "OpenLayers/Filter/Comparison.js",
+ "OpenLayers/Format.js",
+ "OpenLayers/Format/XML.js",
+ "OpenLayers/Format/GML.js",
+ "OpenLayers/Format/KML.js",
+ "OpenLayers/Format/GeoRSS.js",
+ "OpenLayers/Format/WFS.js",
+ "OpenLayers/Format/WKT.js",
+ "OpenLayers/Format/OSM.js",
+ "OpenLayers/Format/SLD.js",
+ "OpenLayers/Format/SLD/v1.js",
+ "OpenLayers/Format/SLD/v1_0_0.js",
+ "OpenLayers/Format/Text.js",
+ "OpenLayers/Format/JSON.js",
+ "OpenLayers/Format/GeoJSON.js",
+ "OpenLayers/Format/WMC.js",
+ "OpenLayers/Format/WMC/v1.js",
+ "OpenLayers/Format/WMC/v1_0_0.js",
+ "OpenLayers/Format/WMC/v1_1_0.js",
+ "OpenLayers/Layer/WFS.js",
+ "OpenLayers/Control/MouseToolbar.js",
+ "OpenLayers/Control/NavToolbar.js",
+ "OpenLayers/Control/EditingToolbar.js",
+ "OpenLayers/Lang.js",
+ "OpenLayers/Lang/en.js"
+ ); // etc.
+ var agent = navigator.userAgent;
+ var docWrite = (agent.match("MSIE") || agent.match("Safari"));
+ if(docWrite) {
+ var allScriptTags = new Array(jsfiles.length);
+ var host = OpenLayers._getScriptLocation() + "lib/";
+ for (var i = 0; i < jsfiles.length; i++) {
+ if (docWrite) {
+ allScriptTags[i] = "<script src='" + host + jsfiles[i] +
+ "'></script>";
+ } else {
+ var s = document.createElement("script");
+ s.src = host + jsfiles[i];
+ var h = document.getElementsByTagName("head").length ?
+ document.getElementsByTagName("head")[0] :
+ document.body;
+ h.appendChild(s);
+ if (docWrite) {
+ document.write(allScriptTags.join(""));
+ * Constant: VERSION_NUMBER
+OpenLayers.VERSION_NUMBER="$Revision$";
+ OpenLayers/BaseTypes.js
+ * @requires OpenLayers/BaseTypes/Class.js
+ * @requires OpenLayers/BaseTypes/LonLat.js
+ * @requires OpenLayers/BaseTypes/Size.js
+ * @requires OpenLayers/BaseTypes/Pixel.js
+ * @requires OpenLayers/BaseTypes/Bounds.js
+ * @requires OpenLayers/BaseTypes/Element.js
+ * Header: OpenLayers Base Types
+ * OpenLayers custom string, number and function functions are described here.
+ * Namespace: OpenLayers.String
+ * Contains convenience functions for string manipulation.
+OpenLayers.String = {
+ * APIFunction: startsWith
+ * Test whether a string starts with another string.
+ * Parameters:
+ * str - {String} The string to test.
+ * sub - {Sring} The substring to look for.
+ * Returns:
+ * {Boolean} The first string starts with the second.
+ startsWith: function(str, sub) {
+ return (str.indexOf(sub) == 0);
+ * APIFunction: contains
+ * Test whether a string contains another string.
+ * Parameters:
+ * sub - {String} The substring to look for.
+ * Returns:
+ * {Boolean} The first string contains the second.
+ contains: function(str, sub) {
+ return (str.indexOf(sub) != -1);
+ * APIFunction: trim
+ * Removes leading and trailing whitespace characters from a string.
+ * Parameters:
+ * str - {String} The (potentially) space padded string. This string is not
+ * modified.
+ * Returns:
+ * {String} A trimmed version of the string with all leading and
+ * trailing spaces removed.
+ trim: function(str) {
+ return str.replace(/^\s*(.*?)\s*$/, "$1");
+ * APIFunction: camelize
+ * Camel-case a hyphenated string.
+ * Ex. "chicken-head" becomes "chickenHead", and
+ * "-chicken-head" becomes "ChickenHead".
+ * Parameters:
+ * str - {String} The string to be camelized. The original is not modified.
+ * Returns:
+ * {String} The string, camelized
+ camelize: function(str) {
+ var oStringList = str.split('-');
+ var camelizedString = oStringList[0];
+ for (var i = 1; i < oStringList.length; i++) {
+ var s = oStringList[i];
+ camelizedString += s.charAt(0).toUpperCase() + s.substring(1);
+ return camelizedString;
+ * APIFunction: format
+ * Given a string with tokens in the form ${token}, return a string
+ * with tokens replaced with properties from the given context
+ * object. Represent a literal "${" by doubling it, e.g. "${${".
+ * Parameters:
+ * template - {String} A string with tokens to be replaced. A template
+ * has the form "literal ${token}" where the token will be replaced
+ * by the value of context["token"].
+ * context - {Object} An optional object with properties corresponding
+ * to the tokens in the format string. If no context is sent, the
+ * window object will be used.
+ * args - {Array} Optional arguments to pass to any functions found in
+ * the context. If a context property is a function, the token
+ * will be replaced by the return from the function called with
+ * these arguments.
+ * Returns:
+ * {String} A string with tokens replaced from the context object.
+ format: function(template, context, args) {
+ if(!context) {
+ context = window;
+ var tokens = template.split("${");
+ var item, last, replacement;
+ for(var i=1; i<tokens.length; i++) {
+ item = tokens[i];
+ last = item.indexOf("}");
+ if(last > 0) {
+ replacement = context[item.substring(0, last)];
+ if(typeof replacement == "function") {
+ replacement = args ?
+ replacement.apply(null, args) :
+ replacement();
+ tokens[i] = replacement + item.substring(++last);
+ } else {
+ tokens[i] = "${" + item;
+ return tokens.join("");
+if (!String.prototype.startsWith) {
+ * APIMethod: String.startsWith
+ * *Deprecated*. Whether or not a string starts with another string.
+ * Parameters:
+ * sStart - {Sring} The string we're testing for.
+ * Returns:
+ * {Boolean} Whether or not this string starts with the string passed in.
+ String.prototype.startsWith = function(sStart) {
+ OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",
+ {'newMethod':'OpenLayers.String.startsWith'}));
+ return OpenLayers.String.startsWith(this, sStart);
+if (!String.prototype.contains) {
+ * APIMethod: String.contains
+ * *Deprecated*. Whether or not a string contains another string.
+ * Parameters:
+ * str - {String} The string that we're testing for.
+ * Returns:
+ * {Boolean} Whether or not this string contains with the string passed in.
+ String.prototype.contains = function(str) {
+ {'newMethod':'OpenLayers.String.contains'}));
+ return OpenLayers.String.contains(this, str);
+if (!String.prototype.trim) {
+ * APIMethod: String.trim
+ * *Deprecated*. Removes leading and trailing whitespace characters from a string.
+ * Returns:
+ * {String} A trimmed version of the string - all leading and
+ String.prototype.trim = function() {
+ {'newMethod':'OpenLayers.String.trim'}));
+ return OpenLayers.String.trim(this);
+if (!String.prototype.camelize) {
+ * APIMethod: String.camelize
+ * *Deprecated*. Camel-case a hyphenated string.
+ * Returns:
+ String.prototype.camelize = function() {
+ {'newMethod':'OpenLayers.String.camelize'}));
+ return OpenLayers.String.camelize(this);
+ * Namespace: OpenLayers.Number
+ * Contains convenience functions for manipulating numbers.
+OpenLayers.Number = {
+ * Property: decimalSeparator
+ * Decimal separator to use when formatting numbers.
+ decimalSeparator: ".",
+ * Property: thousandsSeparator
+ * Thousands separator to use when formatting numbers.
+ thousandsSeparator: ",",
+ * APIFunction: limitSigDigs
+ * Limit the number of significant digits on a float.
+ * Parameters:
+ * num - {Float}
+ * sig - {Integer}
+ * Returns:
+ * {Float} The number, rounded to the specified number of significant
+ * digits.
+ limitSigDigs: function(num, sig) {
+ var fig = 0;
+ if (sig > 0) {
+ fig = parseFloat(num.toPrecision(sig));
+ return fig;
+ * Formats a number for output.
+ * Parameters:
+ * num - {Float}
+ * dec - {Integer} Number of decimal places to round to.
+ * Defaults to 0. Set to null to leave decimal places unchanged.
+ * tsep - {String} Thousands separator.
+ * Default is ",".
+ * dsep - {String} Decimal separator.
+ * Default is ".".
+ * Returns:
+ * {String} A string representing the formatted number.
+ format: function(num, dec, tsep, dsep) {
+ dec = (typeof dec != "undefined") ? dec : 0;
+ tsep = (typeof tsep != "undefined") ? tsep :
+ OpenLayers.Number.thousandsSeparator;
+ dsep = (typeof dsep != "undefined") ? dsep :
+ OpenLayers.Number.decimalSeparator;
+ if (dec != null) {
+ num = parseFloat(num.toFixed(dec));
+ var parts = num.toString().split(".");
+ if (parts.length == 1 && dec == null) {
+ // integer where we do not want to touch the decimals
+ dec = 0;
+ var integer = parts[0];
+ if (tsep) {
+ var thousands = /(-?[0-9]+)([0-9]{3})/;
+ while(thousands.test(integer)) {
+ integer = integer.replace(thousands, "$1" + tsep + "$2");
+ var str;
+ if (dec == 0) {
+ str = integer;
+ } else {
+ var rem = parts.length > 1 ? parts[1] : "0";
+ rem = rem + new Array(dec - rem.length + 1).join("0");
+ str = integer + dsep + rem;
+ return str;
+if (!Number.prototype.limitSigDigs) {
+ * APIMethod: Number.limitSigDigs
+ * *Deprecated*. Limit the number of significant digits on an integer. Does *not*
+ * work with floats!
+ * Parameters:
+ * sig - {Integer}
+ * Returns:
+ * {Integer} The number, rounded to the specified number of significant digits.
+ * If null, 0, or negative value passed in, returns 0
+ Number.prototype.limitSigDigs = function(sig) {
+ {'newMethod':'OpenLayers.String.limitSigDigs'}));
+ return OpenLayers.Number.limitSigDigs(this, sig);
+ * Namespace: OpenLayers.Function
+ * Contains convenience functions for function manipulation.
+OpenLayers.Function = {
+ * APIFunction: bind
+ * Bind a function to an object. Method to easily create closures with
+ * 'this' altered.
+ * Parameters:
+ * func - {Function} Input function.
+ * object - {Object} The object to bind to the input function (as this).
+ * Returns:
+ * {Function} A closure with 'this' set to the passed in object.
+ bind: function(func, object) {
+ // create a reference to all arguments past the second one
+ var args = Array.prototype.slice.apply(arguments, [2]);
+ return function() {
+ // Push on any additional arguments from the actual function call.
+ // These will come after those sent to the bind call.
+ var newArgs = args.concat(
+ Array.prototype.slice.apply(arguments, [0])
+ return func.apply(object, newArgs);
+ * APIFunction: bindAsEventListener
+ * Bind a function to an object, and configure it to receive the event
+ * object as first parameter when called.
+ * Parameters:
+ * func - {Function} Input function to serve as an event listener.
+ * object - {Object} A reference to this.
+ * Returns:
+ * {Function}
+ bindAsEventListener: function(func, object) {
+ return function(event) {
+ return func.call(object, event || window.event);
+if (!Function.prototype.bind) {
+ * APIMethod: Function.bind
+ * *Deprecated*. Bind a function to an object.
+ * Method to easily create closures with 'this' altered.
+ * Parameters:
+ * object - {Object} the this parameter
+ * Returns:
+ * {Function} A closure with 'this' altered to the first
+ * argument.
+ Function.prototype.bind = function() {
+ {'newMethod':'OpenLayers.String.bind'}));
+ // new function takes the same arguments with this function up front
+ Array.prototype.unshift.apply(arguments, [this]);
+ return OpenLayers.Function.bind.apply(null, arguments);
+if (!Function.prototype.bindAsEventListener) {
+ * APIMethod: Function.bindAsEventListener
+ * *Deprecated*. Bind a function to an object, and configure it to receive the
+ * event object as first parameter when called.
+ * Parameters:
+ * Returns:
+ * {Function}
+ Function.prototype.bindAsEventListener = function(object) {
+ {'newMethod':'OpenLayers.String.bindAsEventListener'}));
+ return OpenLayers.Function.bindAsEventListener(this, object);
+ * Namespace: OpenLayers.Array
+ * Contains convenience functions for array manipulation.
+OpenLayers.Array = {
+ * APIMethod: filter
+ * Filter an array. Provides the functionality of the
+ * Array.prototype.filter extension to the ECMA-262 standard. Where
+ * available, Array.prototype.filter will be used.
+ * Based on well known example from http://developer.mozilla.org/en/docs/Core_JavaScript_1.5_Reference:Objects:Array:filter
+ * Parameters:
+ * array - {Array} The array to be filtered. This array is not mutated.
+ * Elements added to this array by the callback will not be visited.
+ * callback - {Function} A function that is called for each element in
+ * the array. If this function returns true, the element will be
+ * included in the return. The function will be called with three
+ * arguments: the element in the array, the index of that element, and
+ * the array itself. If the optional caller parameter is specified
+ * the callback will be called with this set to caller.
+ * caller - {Object} Optional object to be set as this when the callback
+ * is called.
+ * Returns:
+ * {Array} An array of elements from the passed in array for which the
+ * callback returns true.
+ filter: function(array, callback, caller) {
+ var selected = [];
+ if (Array.prototype.filter) {
+ selected = array.filter(callback, caller);
+ } else {
+ var len = array.length;
+ if (typeof callback != "function") {
+ throw new TypeError();
+ for(var i=0; i<len; i++) {
+ if (i in array) {
+ var val = array[i];
+ if (callback.call(caller, val, i, array)) {
+ selected.push(val);
+ return selected;
+ OpenLayers/BaseTypes/Class.js
+ * Constructor: OpenLayers.Class
+ * Base class used to construct all other classes. Includes support for
+ * multiple inheritance.
+ * This constructor is new in OpenLayers 2.5. At OpenLayers 3.0, the old
+ * syntax for creating classes and dealing with inheritance
+ * will be removed.
+ * To create a new OpenLayers-style class, use the following syntax:
+ * > var MyClass = OpenLayers.Class(prototype);
+ * To create a new OpenLayers-style class with multiple inheritance, use the
+ * following syntax:
+ * > var MyClass = OpenLayers.Class(Class1, Class2, prototype);
+OpenLayers.Class = function() {
+ var Class = function() {
+ * This following condition can be removed at 3.0 - this is only for
+ * backwards compatibility while the Class.inherit method is still
+ * in use. So at 3.0, the following three lines would be replaced with
+ * simply:
+ * this.initialize.apply(this, arguments);
+ if (arguments && arguments[0] != OpenLayers.Class.isPrototype) {
+ this.initialize.apply(this, arguments);
+ var extended = {};
+ var parent;
+ for(var i=0; i<arguments.length; ++i) {
+ if(typeof arguments[i] == "function") {
+ // get the prototype of the superclass
+ parent = arguments[i].prototype;
+ } else {
+ // in this case we're extending with the prototype
+ parent = arguments[i];
+ OpenLayers.Util.extend(extended, parent);
+ Class.prototype = extended;
+ return Class;
+ * Property: isPrototype
+ * *Deprecated*. This is no longer needed and will be removed at 3.0.
+OpenLayers.Class.isPrototype = function () {};
+ * APIFunction: OpenLayers.create
+ * *Deprecated*. Old method to create an OpenLayers style class. Use the
+ * <OpenLayers.Class> constructor instead.
+ * Returns:
+ * An OpenLayers class
+OpenLayers.Class.create = function() {
+ * APIFunction: inherit
+ * *Deprecated*. Old method to inherit from one or more OpenLayers style
+ * classes. Use the <OpenLayers.Class> constructor instead.
+ * Parameters:
+ * class - One or more classes can be provided as arguments
+ * Returns:
+ * An object prototype
+OpenLayers.Class.inherit = function () {
+ var superClass = arguments[0];
+ var proto = new superClass(OpenLayers.Class.isPrototype);
+ for (var i = 1; i < arguments.length; i++) {
+ if (typeof arguments[i] == "function") {
+ var mixin = arguments[i];
+ arguments[i] = new mixin(OpenLayers.Class.isPrototype);
+ OpenLayers.Util.extend(proto, arguments[i]);
+ return proto;
+ OpenLayers/Util.js
+ * Namespace: Util
+OpenLayers.Util = {};
+ * Function: getElement
+ * This is the old $() from prototype
+OpenLayers.Util.getElement = function() {
+ var elements = [];
+ for (var i = 0; i < arguments.length; i++) {
+ var element = arguments[i];
+ if (typeof element == 'string') {
+ element = document.getElementById(element);
+ if (arguments.length == 1) {
+ return element;
+ elements.push(element);
+ return elements;
+ * Maintain $() from prototype
+if ($ == null) {
+ var $ = OpenLayers.Util.getElement;
+ * APIFunction: extend
+ * Copy all properties of a source object to a destination object. Modifies
+ * the passed in destination object. Any properties on the source object
+ * that are set to undefined will not be (re)set on the destination object.
+ * Parameters:
+ * destination - {Object} The object that will be modified
+ * source - {Object} The object with properties to be set on the destination
+ * Returns:
+ * {Object} The destination object.
+OpenLayers.Util.extend = function(destination, source) {
+ if(destination && source) {
+ for(var property in source) {
+ var value = source[property];
+ if(value !== undefined) {
+ destination[property] = value;
+ * IE doesn't include the toString property when iterating over an object's
+ * properties with the for(property in object) syntax. Explicitly check if
+ * the source has its own toString property.
+ * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
+ * prototype object" when calling hawOwnProperty if the source object
+ * is an instance of window.Event.
+ var sourceIsEvt = typeof window.Event == "function"
+ && source instanceof window.Event;
+ if(!sourceIsEvt
+ && source.hasOwnProperty && source.hasOwnProperty('toString')) {
+ destination.toString = source.toString;
+ return destination;
+ * Function: removeItem
+ * Remove an object from an array. Iterates through the array
+ * to find the item, then removes it.
+ * Parameters:
+ * array - {Array}
+ * item - {Object}
+ * Return
+ * {Array} A reference to the array
+OpenLayers.Util.removeItem = function(array, item) {
+ for(var i = array.length - 1; i >= 0; i--) {
+ if(array[i] == item) {
+ array.splice(i,1);
+ //break;more than once??
+ return array;
+ * Function: clearArray
+ * *Deprecated*. This function will disappear in 3.0.
+ * Please use "array.length = 0" instead.
+ * Parameters:
+ * array - {Array}
+OpenLayers.Util.clearArray = function(array) {
+ OpenLayers.i18n(
+ "methodDeprecated", {'newMethod': 'array = []'}
+ array.length = 0;
+ * Function: indexOf
+ * Seems to exist already in FF, but not in MOZ.
+ * Parameters:
+ * array - {Array}
+ * obj - {Object}
+ * Returns:
+ * {Integer} The index at, which the object was found in the array.
+ * If not found, returns -1.
+OpenLayers.Util.indexOf = function(array, obj) {
+ for(var i=0; i < array.length; i++) {
+ if (array[i] == obj) {
+ return i;
+ return -1;
+ * Function: modifyDOMElement
+ * Modifies many properties of a DOM element all at once. Passing in
+ * null to an individual parameter will avoid setting the attribute.
+ * Parameters:
+ * id - {String} The element id attribute to set.
+ * px - {<OpenLayers.Pixel>} The left and top style position.
+ * sz - {<OpenLayers.Size>} The width and height style attributes.
+ * position - {String} The position attribute. eg: absolute,
+ * relative, etc.
+ * border - {String} The style.border attribute. eg:
+ * solid black 2px
+ * overflow - {String} The style.overview attribute.
+ * opacity - {Float} Fractional value (0.0 - 1.0)
+OpenLayers.Util.modifyDOMElement = function(element, id, px, sz, position,
+ border, overflow, opacity) {
+ if (id) {
+ element.id = id;
+ if (px) {
+ element.style.left = px.x + "px";
+ element.style.top = px.y + "px";
+ if (sz) {
+ element.style.width = sz.w + "px";
+ element.style.height = sz.h + "px";
+ if (position) {
+ element.style.position = position;
+ if (border) {
+ element.style.border = border;
+ if (overflow) {
+ element.style.overflow = overflow;
+ if (parseFloat(opacity) >= 0.0 && parseFloat(opacity) < 1.0) {
+ element.style.filter = 'alpha(opacity=' + (opacity * 100) + ')';
+ element.style.opacity = opacity;
+ } else if (parseFloat(opacity) == 1.0) {
+ element.style.filter = '';
+ element.style.opacity = '';
+ * Function: createDiv
+ * Creates a new div and optionally set some standard attributes.
+ * Null may be passed to each parameter if you do not wish to
+ * set a particular attribute.
+ * Note - zIndex is NOT set on the resulting div.
+ * Parameters:
+ * id - {String} An identifier for this element. If no id is
+ * passed an identifier will be created
+ * automatically.
+ * px - {<OpenLayers.Pixel>} The element left and top position.
+ * sz - {<OpenLayers.Size>} The element width and height.
+ * imgURL - {String} A url pointing to an image to use as a
+ * background image.
+ * position - {String} The style.position value. eg: absolute,
+ * relative etc.
+ * border - {String} The the style.border value.
+ * eg: 2px solid black
+ * overflow - {String} The style.overflow value. Eg. hidden
+ * Returns:
+ * {DOMElement} A DOM Div created with the specified attributes.
+OpenLayers.Util.createDiv = function(id, px, sz, imgURL, position,
+ var dom = document.createElement('div');
+ if (imgURL) {
+ dom.style.backgroundImage = 'url(' + imgURL + ')';
+ //set generic properties
+ if (!id) {
+ id = OpenLayers.Util.createUniqueID("OpenLayersDiv");
+ if (!position) {
+ position = "absolute";
+ OpenLayers.Util.modifyDOMElement(dom, id, px, sz, position,
+ border, overflow, opacity);
+ return dom;
+ * Function: createImage
+ * Creates an img element with specific attribute values.
+ * Parameters:
+ * id - {String} The id field for the img. If none assigned one will be
+ * automatically generated.
+ * px - {<OpenLayers.Pixel>} The left and top positions.
+ * sz - {<OpenLayers.Size>} The style.width and style.height values.
+ * imgURL - {String} The url to use as the image source.
+ * border - {String} The border to place around the image.
+ * delayDisplay - {Boolean} If true waits until the image has been
+ * loaded.
+ * Returns:
+ * {DOMElement} A DOM Image created with the specified attributes.
+OpenLayers.Util.createImage = function(id, px, sz, imgURL, position, border,
+ opacity, delayDisplay) {
+ var image = document.createElement("img");
+ if (!id) {
+ if (!position) {
+ position = "relative";
+ OpenLayers.Util.modifyDOMElement(image, id, px, sz, position,
+ border, null, opacity);
+ if(delayDisplay) {
+ image.style.display = "none";
+ OpenLayers.Event.observe(image, "load",
+ OpenLayers.Function.bind(OpenLayers.Util.onImageLoad, image));
+ OpenLayers.Event.observe(image, "error",
+ OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError, image));
+ //set special properties
+ image.style.alt = id;
+ image.galleryImg = "no";
+ if (imgURL) {
+ image.src = imgURL;
+ return image;
+ * Function: setOpacity
+ * *Deprecated*. This function has been deprecated. Instead, please use
+ * <OpenLayers.Util.modifyDOMElement>
+ * or
+ * <OpenLayers.Util.modifyAlphaImageDiv>
+ * Set the opacity of a DOM Element
+ * Note that for this function to work in IE, elements must "have layout"
+ * according to:
+ * http://msdn.microsoft.com/workshop/author/dhtml/reference/properties/haslayout.asp
+ * Parameters:
+ * element - {DOMElement} Set the opacity on this DOM element
+ * opacity - {Float} Opacity value (0.0 - 1.0)
+OpenLayers.Util.setOpacity = function(element, opacity) {
+ OpenLayers.Util.modifyDOMElement(element, null, null, null,
+ null, null, null, opacity);
+ * Function: onImageLoad
+ * Bound to image load events. For all images created with <createImage> or
+ * <createAlphaImageDiv>, this function will be bound to the load event.
+OpenLayers.Util.onImageLoad = function() {
+ // The complex check here is to solve issues described in #480.
+ // Every time a map view changes, it increments the 'viewRequestID'
+ // property. As the requests for the images for the new map view are sent
+ // out, they are tagged with this unique viewRequestID.
+ // If an image has no viewRequestID property set, we display it regardless,
+ // but if it does have a viewRequestID property, we check that it matches
+ // the viewRequestID set on the map.
+ // If the viewRequestID on the map has changed, that means that the user
+ // has changed the map view since this specific request was sent out, and
+ // therefore this tile does not need to be displayed (so we do not execute
+ // this code that turns its display on).
+ if (!this.viewRequestID ||
+ (this.map && this.viewRequestID == this.map.viewRequestID)) {
+ this.style.backgroundColor = null;
+ this.style.display = "";
+ * Property: onImageLoadErrorColor
+ * {String} The color tiles with load errors will turn.
+ * Default is "pink"
+OpenLayers.Util.onImageLoadErrorColor = "pink";
+ * Property: IMAGE_RELOAD_ATTEMPTS
+ * {Integer} How many times should we try to reload an image before giving up?
+ * Default is 0
+OpenLayers.IMAGE_RELOAD_ATTEMPTS = 0;
+ * Function: onImageLoadError
+OpenLayers.Util.onImageLoadError = function() {
+ this._attempts = (this._attempts) ? (this._attempts + 1) : 1;
+ if(this._attempts <= OpenLayers.IMAGE_RELOAD_ATTEMPTS) {
+ this.src = this.src;
+ } else {
+ this.style.backgroundColor = OpenLayers.Util.onImageLoadErrorColor;
+ * Function: alphaHack
+ * Checks whether it's necessary (and possible) to use the png alpha
+ * hack which allows alpha transparency for png images under Internet
+ * Explorer.
+ * Returns:
+ * {Boolean} true if alpha has is necessary and possible, false otherwise.
+OpenLayers.Util.alphaHack = function() {
+ var arVersion = navigator.appVersion.split("MSIE");
+ var version = parseFloat(arVersion[1]);
+ var filter = false;
+ // IEs4Lin dies when trying to access document.body.filters, because
+ // the property is there, but requires a DLL that can't be provided. This
+ // means that we need to wrap this in a try/catch so that this can
+ // continue.
+ try {
+ filter = !!(document.body.filters);
+ } catch (e) {
+ return ( filter &&
+ (version >= 5.5) && (version < 7) );
+ * Function: modifyAlphaImageDiv
+ * div - {DOMElement} Div containing Alpha-adjusted Image
+ * id - {String}
+ * sizing {String} 'crop', 'scale', or 'image'. Default is "scale"
+OpenLayers.Util.modifyAlphaImageDiv = function(div, id, px, sz, imgURL,
+ position, border, sizing,
+ opacity) {
+ OpenLayers.Util.modifyDOMElement(div, id, px, sz,
+ var img = div.childNodes[0];
+ if (imgURL) {
+ img.src = imgURL;
+ OpenLayers.Util.modifyDOMElement(img, div.id + "_innerImage", null, sz,
+ "relative", border);
+ if (OpenLayers.Util.alphaHack()) {
+ div.style.display = "inline-block";
+ if (sizing == null) {
+ sizing = "scale";
+ div.style.filter = "progid:DXImageTransform.Microsoft" +
+ ".AlphaImageLoader(src='" + img.src + "', " +
+ "sizingMethod='" + sizing + "')";
+ if (parseFloat(div.style.opacity) >= 0.0 &&
+ parseFloat(div.style.opacity) < 1.0) {
+ div.style.filter += " alpha(opacity=" + div.style.opacity * 100 + ")";
+ img.style.filter = "alpha(opacity=0)";
+ * Function: createAlphaImageDiv
+ * id - {String}
+ * delayDisplay{Boolean}
+ * Returns:
+ * {DOMElement} A DOM Div created with a DOM Image inside it. If the hack is
+ * needed for transparency in IE, it is added.
+OpenLayers.Util.createAlphaImageDiv = function(id, px, sz, imgURL,
+ var div = OpenLayers.Util.createDiv();
+ var img = OpenLayers.Util.createImage(null, null, null, null, null, null,
+ null, false);
+ div.appendChild(img);
+ if (delayDisplay) {
+ img.style.display = "none";
+ OpenLayers.Event.observe(img, "load",
+ OpenLayers.Function.bind(OpenLayers.Util.onImageLoad, div));
+ OpenLayers.Event.observe(img, "error",
+ OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError, div));
+ OpenLayers.Util.modifyAlphaImageDiv(div, id, px, sz, imgURL, position,
+ border, sizing, opacity);
+ return div;
+ * Function: upperCaseObject
+ * Creates a new hashtable and copies over all the keys from the
+ * passed-in object, but storing them under an uppercased
+ * version of the key at which they were stored.
+ * Parameters:
+ * Returns:
+ * {Object} A new Object with all the same keys but uppercased
+OpenLayers.Util.upperCaseObject = function (object) {
+ var uObject = {};
+ for (var key in object) {
+ uObject[key.toUpperCase()] = object[key];
+ return uObject;
+ * Function: applyDefaults
+ * Takes an object and copies any properties that don't exist from
+ * another properties, by analogy with OpenLayers.Util.extend() from
+ * Prototype.js.
+ * Parameters:
+ * to - {Object} The destination object.
+ * from - {Object} The source object. Any properties of this object that
+ * are undefined in the to object will be set on the to object.
+ * Returns:
+ * {Object} A reference to the to object. Note that the to argument is modified
+ * in place and returned by this function.
+OpenLayers.Util.applyDefaults = function (to, from) {
+ * prototype object" when calling hawOwnProperty if the source object is an
+ * instance of window.Event.
+ var fromIsEvt = typeof window.Event == "function"
+ && from instanceof window.Event;
+ for (var key in from) {
+ if (to[key] === undefined ||
+ (!fromIsEvt && from.hasOwnProperty
+ && from.hasOwnProperty(key) && !to.hasOwnProperty(key))) {
+ to[key] = from[key];
+ if(!fromIsEvt && from.hasOwnProperty
+ && from.hasOwnProperty('toString') && !to.hasOwnProperty('toString')) {
+ to.toString = from.toString;
+ return to;
+ * Function: getParameterString
+ * Parameters:
+ * params - {Object}
+ * Returns:
+ * {String} A concatenation of the properties of an object in
+ * http parameter notation.
+ * (ex. <i>"key1=value1&key2=value2&key3=value3"</i>)
+ * If a parameter is actually a list, that parameter will then
+ * be set to a comma-seperated list of values (foo,bar) instead
+ * of being URL escaped (foo%3Abar).
+OpenLayers.Util.getParameterString = function(params) {
+ var paramsArray = [];
+ for (var key in params) {
+ var value = params[key];
+ if ((value != null) && (typeof value != 'function')) {
+ var encodedValue;
+ if (typeof value == 'object' && value.constructor == Array) {
+ /* value is an array; encode items and separate with "," */
+ var encodedItemArray = [];
+ for (var itemIndex=0; itemIndex<value.length; itemIndex++) {
+ encodedItemArray.push(encodeURIComponent(value[itemIndex]));
+ encodedValue = encodedItemArray.join(",");
+ else {
+ /* value is a string; simply encode */
+ encodedValue = encodeURIComponent(value);
+ paramsArray.push(encodeURIComponent(key) + "=" + encodedValue);
+ return paramsArray.join("&");
+ * Property: ImgPath
+ * {String} Default is ''.
+OpenLayers.ImgPath = '';
+ * Function: getImagesLocation
+ * Returns:
+ * {String} The fully formatted image location string
+OpenLayers.Util.getImagesLocation = function() {
+ return OpenLayers.ImgPath || (OpenLayers._getScriptLocation() + "img/");
+ * Function: Try
+ * Execute functions until one of them doesn't throw an error.
+ * Capitalized because "try" is a reserved word in JavaScript.
+ * Taken directly from OpenLayers.Util.Try()
+ * Parameters:
+ * [*] - {Function} Any number of parameters may be passed to Try()
+ * It will attempt to execute each of them until one of them
+ * successfully executes.
+ * If none executes successfully, returns null.
+ * Returns:
+ * {*} The value returned by the first successfully executed function.
+OpenLayers.Util.Try = function() {
+ var returnValue = null;
+ var lambda = arguments[i];
+ try {
+ returnValue = lambda();
+ break;
+ } catch (e) {}
+ return returnValue;
+ * Function: getNodes
+ * These could/should be made namespace aware?
+ * Parameters:
+ * p - {}
+ * tagName - {String}
+ * Returns:
+ * {Array}
+OpenLayers.Util.getNodes=function(p, tagName) {
+ var nodes = OpenLayers.Util.Try(
+ function () {
+ return OpenLayers.Util._getNodes(p.documentElement.childNodes,
+ tagName);
+ function () {
+ return OpenLayers.Util._getNodes(p.childNodes, tagName);
+ return nodes;
+ * Function: _getNodes
+ * Parameters:
+ * nodes - {Array}
+ * Returns:
+ * {Array}
+OpenLayers.Util._getNodes=function(nodes, tagName) {
+ var retArray = [];
+ for (var i=0;i<nodes.length;i++) {
+ if (nodes[i].nodeName==tagName) {
+ retArray.push(nodes[i]);
+ return retArray;
+ * Function: getTagText
+ * Parameters:
+ * parent - {}
+ * item - {String}
+ * index - {Integer}
+ * Returns:
+ * {String}
+OpenLayers.Util.getTagText = function (parent, item, index) {
+ var result = OpenLayers.Util.getNodes(parent, item);
+ if (result && (result.length > 0))
+ if (!index) {
+ index=0;
+ if (result[index].childNodes.length > 1) {
+ return result.childNodes[1].nodeValue;
+ else if (result[index].childNodes.length == 1) {
+ return result[index].firstChild.nodeValue;
+ } else {
+ return "";
+ * Function: getXmlNodeValue
+ * Parameters:
+ * node - {XMLNode}
+ * Returns:
+ * {String} The text value of the given node, without breaking in firefox or IE
+OpenLayers.Util.getXmlNodeValue = function(node) {
+ var val = null;
+ OpenLayers.Util.Try(
+ function() {
+ val = node.text;
+ if (!val) {
+ val = node.textContent;
+ if (!val) {
+ val = node.firstChild.nodeValue;
+ function() {
+ return val;
+ * Function: mouseLeft
+ * Parameters:
+ * evt - {Event}
+ * div - {HTMLDivElement}
+ * Returns:
+ * {Boolean}
+OpenLayers.Util.mouseLeft = function (evt, div) {
+ // start with the element to which the mouse has moved
+ var target = (evt.relatedTarget) ? evt.relatedTarget : evt.toElement;
+ // walk up the DOM tree.
+ while (target != div && target != null) {
+ target = target.parentNode;
+ // if the target we stop at isn't the div, then we've left the div.
+ return (target != div);
+ * Function: rad
+ * Parameters:
+ * x - {Float}
+ * Returns:
+ * {Float}
+OpenLayers.Util.rad = function(x) {return x*Math.PI/180;};
+ * Function: distVincenty
+ * Parameters:
+ * p1 - {<OpenLayers.LonLat>} (or any object with both .lat, .lon properties)
+ * p2 - {<OpenLayers.LonLat>} (or any object with both .lat, .lon properties)
+ * Returns:
+ * {Float}
+OpenLayers.Util.distVincenty=function(p1, p2) {
+ var a = 6378137, b = 6356752.3142, f = 1/298.257223563;
+ var L = OpenLayers.Util.rad(p2.lon - p1.lon);
+ var U1 = Math.atan((1-f) * Math.tan(OpenLayers.Util.rad(p1.lat)));
+ var U2 = Math.atan((1-f) * Math.tan(OpenLayers.Util.rad(p2.lat)));
+ var sinU1 = Math.sin(U1), cosU1 = Math.cos(U1);
+ var sinU2 = Math.sin(U2), cosU2 = Math.cos(U2);
+ var lambda = L, lambdaP = 2*Math.PI;
+ var iterLimit = 20;
+ while (Math.abs(lambda-lambdaP) > 1e-12 && --iterLimit>0) {
+ var sinLambda = Math.sin(lambda), cosLambda = Math.cos(lambda);
+ var sinSigma = Math.sqrt((cosU2*sinLambda) * (cosU2*sinLambda) +
+ (cosU1*sinU2-sinU1*cosU2*cosLambda) * (cosU1*sinU2-sinU1*cosU2*cosLambda));
+ if (sinSigma==0) {
+ return 0; // co-incident points
+ var cosSigma = sinU1*sinU2 + cosU1*cosU2*cosLambda;
+ var sigma = Math.atan2(sinSigma, cosSigma);
+ var alpha = Math.asin(cosU1 * cosU2 * sinLambda / sinSigma);
+ var cosSqAlpha = Math.cos(alpha) * Math.cos(alpha);
+ var cos2SigmaM = cosSigma - 2*sinU1*sinU2/cosSqAlpha;
+ var C = f/16*cosSqAlpha*(4+f*(4-3*cosSqAlpha));
+ lambdaP = lambda;
+ lambda = L + (1-C) * f * Math.sin(alpha) *
+ (sigma + C*sinSigma*(cos2SigmaM+C*cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)));
+ if (iterLimit==0) {
+ return NaN; // formula failed to converge
+ var uSq = cosSqAlpha * (a*a - b*b) / (b*b);
+ var A = 1 + uSq/16384*(4096+uSq*(-768+uSq*(320-175*uSq)));
+ var B = uSq/1024 * (256+uSq*(-128+uSq*(74-47*uSq)));
+ var deltaSigma = B*sinSigma*(cos2SigmaM+B/4*(cosSigma*(-1+2*cos2SigmaM*cos2SigmaM)-
+ B/6*cos2SigmaM*(-3+4*sinSigma*sinSigma)*(-3+4*cos2SigmaM*cos2SigmaM)));
+ var s = b*A*(sigma-deltaSigma);
+ var d = s.toFixed(3)/1000; // round to 1mm precision
+ return d;
+ * Function: getParameters
+ * Parse the parameters from a URL or from the current page itself into a
+ * JavaScript Object. Note that parameter values with commas are separated
+ * out into an Array.
+ * Parameters:
+ * url - {String} Optional url used to extract the query string.
+ * If null, query string is taken from page location.
+ * Returns:
+ * {Object} An object of key/value pairs from the query string.
+OpenLayers.Util.getParameters = function(url) {
+ // if no url specified, take it from the location bar
+ url = url || window.location.href;
+ //parse out parameters portion of url string
+ var paramsString = "";
+ if (OpenLayers.String.contains(url, '?')) {
+ var start = url.indexOf('?') + 1;
+ var end = OpenLayers.String.contains(url, "#") ?
+ url.indexOf('#') : url.length;
+ paramsString = url.substring(start, end);
+ var parameters = {};
+ var pairs = paramsString.split(/[&;]/);
+ for(var i = 0; i < pairs.length; ++i) {
+ var keyValue = pairs[i].split('=');
+ if (keyValue[0]) {
+ var key = decodeURIComponent(keyValue[0]);
+ var value = keyValue[1] || ''; //empty string if no value
+ //decode individual values
+ value = value.split(",");
+ for(var j=0; j < value.length; j++) {
+ value[j] = decodeURIComponent(value[j]);
+ //if there's only one value, do not return as array
+ if (value.length == 1) {
+ value = value[0];
+ parameters[key] = value;
+ return parameters;
+ * Function: getArgs
+ * *Deprecated*. Will be removed in 3.0. Please use instead
+ * <OpenLayers.Util.getParameters>
+ * Parameters:
+ * Returns:
+OpenLayers.Util.getArgs = function(url) {
+ OpenLayers.i18n(
+ "methodDeprecated", {'newMethod': 'OpenLayers.Util.getParameters'}
+ return OpenLayers.Util.getParameters(url);
+ * Property: lastSeqID
+ * {Integer} The ever-incrementing count variable.
+ * Used for generating unique ids.
+OpenLayers.Util.lastSeqID = 0;
+ * Function: createUniqueID
+ * Create a unique identifier for this session. Each time this function
+ * is called, a counter is incremented. The return will be the optional
+ * prefix (defaults to "id_") appended with the counter value.
+ * Parameters:
+ * prefix {String} Optionsal string to prefix unique id. Default is "id_".
+ * Returns:
+ * {String} A unique id string, built on the passed in prefix.
+OpenLayers.Util.createUniqueID = function(prefix) {
+ if (prefix == null) {
+ prefix = "id_";
+ OpenLayers.Util.lastSeqID += 1;
+ return prefix + OpenLayers.Util.lastSeqID;
+ * Constant: INCHES_PER_UNIT
+ * {Object} Constant inches per unit -- borrowed from MapServer mapscale.c
+ * derivation of nautical miles from http://en.wikipedia.org/wiki/Nautical_mile
+OpenLayers.INCHES_PER_UNIT = {
+ 'inches': 1.0,
+ 'ft': 12.0,
+ 'mi': 63360.0,
+ 'm': 39.3701,
+ 'km': 39370.1,
+ 'dd': 4374754,
+ 'yd': 36
+OpenLayers.INCHES_PER_UNIT["in"]= OpenLayers.INCHES_PER_UNIT.inches;
+OpenLayers.INCHES_PER_UNIT["degrees"] = OpenLayers.INCHES_PER_UNIT.dd;
+OpenLayers.INCHES_PER_UNIT["nmi"] = 1852 * OpenLayers.INCHES_PER_UNIT.m;
+ * Constant: DOTS_PER_INCH
+ * {Integer} 72 (A sensible default)
+OpenLayers.DOTS_PER_INCH = 72;
+ * Function: normalzeScale
+ * Parameters:
+ * scale - {float}
+ * Returns:
+ * {Float} A normalized scale value, in 1 / X format.
+ * This means that if a value less than one ( already 1/x) is passed
+ * in, it just returns scale directly. Otherwise, it returns
+ * 1 / scale
+OpenLayers.Util.normalizeScale = function (scale) {
+ var normScale = (scale > 1.0) ? (1.0 / scale)
+ : scale;
+ return normScale;
+ * Function: getResolutionFromScale
+ * Parameters:
+ * scale - {Float}
+ * units - {String} Index into OpenLayers.INCHES_PER_UNIT hashtable.
+ * Default is degrees
+ * Returns:
+ * {Float} The corresponding resolution given passed-in scale and unit
+ * parameters.
+OpenLayers.Util.getResolutionFromScale = function (scale, units) {
+ if (units == null) {
+ units = "degrees";
+ var normScale = OpenLayers.Util.normalizeScale(scale);
+ var resolution = 1 / (normScale * OpenLayers.INCHES_PER_UNIT[units]
+ * OpenLayers.DOTS_PER_INCH);
+ return resolution;
+ * Function: getScaleFromResolution
+ * Parameters:
+ * resolution - {Float}
+ * Returns:
+ * {Float} The corresponding scale given passed-in resolution and unit
+ * parameters.
+OpenLayers.Util.getScaleFromResolution = function (resolution, units) {
+ var scale = resolution * OpenLayers.INCHES_PER_UNIT[units] *
+ OpenLayers.DOTS_PER_INCH;
+ return scale;
+ * Function: safeStopPropagation
+ * *Deprecated*. This function has been deprecated. Please use directly
+ * <OpenLayers.Event.stop> passing 'true' as the 2nd
+ * argument (preventDefault)
+ * Safely stop the propagation of an event *without* preventing
+ * the default browser action from occurring.
+ * Parameter:
+ * evt - {Event}
+OpenLayers.Util.safeStopPropagation = function(evt) {
+ OpenLayers.Event.stop(evt, true);
+ * Function: pagePositon
+ * Calculates the position of an element on the page.
+ * Parameters:
+ * forElement - {DOMElement}
+ * Returns:
+ * {Array} two item array, L value then T value.
+OpenLayers.Util.pagePosition = function(forElement) {
+ var valueT = 0, valueL = 0;
+ var element = forElement;
+ var child = forElement;
+ while(element) {
+ if(element == document.body) {
+ // FIXME: IE, when passed 'window' as the forElement, treats it as
+ // equal to document.body, but window.style fails, so getStyle
+ // fails, so we are paranoid and check this here. This check should
+ // probably move into element.getStyle in 2.6.
+ if(child && child.style &&
+ OpenLayers.Element.getStyle(child, 'position') == 'absolute') {
+ break;
+ valueT += element.offsetTop || 0;
+ valueL += element.offsetLeft || 0;
+ child = element;
+ try {
+ // wrapping this in a try/catch because IE chokes on the offsetParent
+ element = element.offsetParent;
+ } catch(e) {
+ OpenLayers.Console.error(OpenLayers.i18n(
+ "pagePositionFailed",{'elemId':element.id}));
+ break;
+ element = forElement;
+ while(element) {
+ valueT -= element.scrollTop || 0;
+ valueL -= element.scrollLeft || 0;
+ element = element.parentNode;
+ return [valueL, valueT];
+ * Function: isEquivalentUrl
+ * Test two URLs for equivalence.
+ * Setting 'ignoreCase' allows for case-independent comparison.
+ * Comparison is based on:
+ * - Protocol
+ * - Host (evaluated without the port)
+ * - Port (set 'ignorePort80' to ignore "80" values)
+ * - Hash ( set 'ignoreHash' to disable)
+ * - Pathname (for relative <-> absolute comparison)
+ * - Arguments (so they can be out of order)
+ * Parameters:
+ * url1 - {String}
+ * url2 - {String}
+ * options - {Object} Allows for customization of comparison:
+ * 'ignoreCase' - Default is True
+ * 'ignorePort80' - Default is True
+ * 'ignoreHash' - Default is True
+ * Returns:
+ * {Boolean} Whether or not the two URLs are equivalent
+OpenLayers.Util.isEquivalentUrl = function(url1, url2, options) {
+ options = options || {};
+ OpenLayers.Util.applyDefaults(options, {
+ ignoreCase: true,
+ ignorePort80: true,
+ ignoreHash: true
+ var urlObj1 = OpenLayers.Util.createUrlObject(url1, options);
+ var urlObj2 = OpenLayers.Util.createUrlObject(url2, options);
+ //compare all keys (host, port, etc)
+ for(var key in urlObj1) {
+ if (options.test) {
+ alert(key + "\n1:" + urlObj1[key] + "\n2:" + urlObj2[key]);
+ var val1 = urlObj1[key];
+ var val2 = urlObj2[key];
+ switch(key) {
+ case "args":
+ //do nothing, they'll be treated below
+ break;
+ case "host":
+ case "port":
+ case "protocol":
+ if ((val1 == "") || (val2 == "")) {
+ //these will be blank for relative urls, so no need to
+ // compare them here -- call break.
+ break;
+ // otherwise continue with default compare
+ default:
+ if ( (key != "args") && (urlObj1[key] != urlObj2[key]) ) {
+ return false;
+ break;
+ // compare search args - irrespective of order
+ for(var key in urlObj1.args) {
+ if(urlObj1.args[key] != urlObj2.args[key]) {
+ return false;
+ delete urlObj2.args[key];
+ // urlObj2 shouldn't have any args left
+ for(var key in urlObj2.args) {
+ return false;
+ return true;
+ * Function: createUrlObject
+ * Parameters:
+ * url - {String}
+ * options - {Object} A hash of options. Can be one of:
+ * ignoreCase: lowercase url,
+ * ignorePort80: don't include explicit port if port is 80,
+ * ignoreHash: Don't include part of url after the hash (#).
+ * Returns:
+ * {Object} An object with separate url, a, port, host, and args parsed out
+ * and ready for comparison
+OpenLayers.Util.createUrlObject = function(url, options) {
+ var urlObject = {};
+ if (options.ignoreCase) {
+ url = url.toLowerCase();
+ var a = document.createElement('a');
+ a.href = url;
+ //host (without port)
+ urlObject.host = a.host;
+ var port = a.port;
+ if (port.length <= 0) {
+ var newHostLength = urlObject.host.length - (port.length);
+ urlObject.host = urlObject.host.substring(0, newHostLength);
+ //protocol
+ urlObject.protocol = a.protocol;
+ //port
+ urlObject.port = ((port == "80") && (options.ignorePort80)) ? "" : port;
+ //hash
+ urlObject.hash = (options.ignoreHash) ? "" : a.hash;
+ //args
+ var queryString = a.search;
+ if (!queryString) {
+ var qMark = url.indexOf("?");
+ queryString = (qMark != -1) ? url.substr(qMark) : "";
+ urlObject.args = OpenLayers.Util.getParameters(queryString);
+ //pathname (this part allows for relative <-> absolute comparison)
+ if ( ((urlObject.protocol == "file:") && (url.indexOf("file:") != -1)) ||
+ ((urlObject.protocol != "file:") && (urlObject.host != "")) ) {
+ urlObject.pathname = a.pathname;
+ //Test to see if the pathname includes the arguments (Opera)
+ var qIndex = urlObject.pathname.indexOf("?");
+ if (qIndex != -1) {
+ urlObject.pathname = urlObject.pathname.substring(0, qIndex);
+ } else {
+ var relStr = OpenLayers.Util.removeTail(url);
+ var backs = 0;
+ do {
+ var index = relStr.indexOf("../");
+ if (index == 0) {
+ backs++;
+ relStr = relStr.substr(3);
+ } else if (index >= 0) {
+ var prevChunk = relStr.substr(0,index - 1);
+ var slash = prevChunk.indexOf("/");
+ prevChunk = (slash != -1) ? prevChunk.substr(0, slash +1)
+ var postChunk = relStr.substr(index + 3);
+ relStr = prevChunk + postChunk;
+ } while(index != -1)
+ var windowAnchor = document.createElement("a");
+ var windowUrl = window.location.href;
+ windowUrl = windowUrl.toLowerCase();
+ windowAnchor.href = windowUrl;
+ //set protocol of window
+ urlObject.protocol = windowAnchor.protocol;
+ var splitter = (windowAnchor.pathname.indexOf("/") != -1) ? "/" : "\\";
+ var dirs = windowAnchor.pathname.split(splitter);
+ dirs.pop(); //remove filename
+ while ((backs > 0) && (dirs.length > 0)) {
+ dirs.pop();
+ backs--;
+ relStr = dirs.join("/") + "/"+ relStr;
+ urlObject.pathname = relStr;
+ if ((urlObject.protocol == "file:") || (urlObject.protocol == "")) {
+ urlObject.host = "localhost";
+ return urlObject;
+ * Function: removeTail
+ * Takes a url and removes everything after the ? and #
+ * Parameters:
+ * url - {String} The url to process
+ * Returns:
+ * {String} The string with all queryString and Hash removed
+OpenLayers.Util.removeTail = function(url) {
+ var head = null;
+ var hashMark = url.indexOf("#");
+ if (qMark == -1) {
+ head = (hashMark != -1) ? url.substr(0,hashMark) : url;
+ } else {
+ head = (hashMark != -1) ? url.substr(0,Math.min(qMark, hashMark))
+ : url.substr(0, qMark);
+ return head;
+ * Function: getBrowserName
+ * Returns:
+ * {String} A string which specifies which is the current
+ * browser in which we are running.
+ * Currently-supported browser detection and codes:
+ * * 'opera' -- Opera
+ * * 'msie' -- Internet Explorer
+ * * 'safari' -- Safari
+ * * 'firefox' -- FireFox
+ * * 'mozilla' -- Mozilla
+ * If we are unable to property identify the browser, we
+ * return an empty string.
+OpenLayers.Util.getBrowserName = function() {
+ var browserName = "";
+ var ua = navigator.userAgent.toLowerCase();
+ if ( ua.indexOf( "opera" ) != -1 ) {
+ browserName = "opera";
+ } else if ( ua.indexOf( "msie" ) != -1 ) {
+ browserName = "msie";
+ } else if ( ua.indexOf( "safari" ) != -1 ) {
+ browserName = "safari";
+ } else if ( ua.indexOf( "mozilla" ) != -1 ) {
+ if ( ua.indexOf( "firefox" ) != -1 ) {
+ browserName = "firefox";
+ } else {
+ browserName = "mozilla";
+ return browserName;
+ * Method: getRenderedDimensions
+ * Renders the contentHTML offscreen to determine actual dimensions for
+ * popup sizing. As we need layout to determine dimensions the content
+ * is rendered -9999px to the left and absolute to ensure the
+ * scrollbars do not flicker
+ * Parameters:
+ * size - {<OpenLayers.Size>} If either the 'w' or 'h' properties is
+ * specified, we fix that dimension of the div to be measured. This is
+ * useful in the case where we have a limit in one dimension and must
+ * therefore meaure the flow in the other dimension.
+ * Returns:
+ * {OpenLayers.Size}
+OpenLayers.Util.getRenderedDimensions = function(contentHTML, size) {
+ var w = h = null;
+ // create temp container div with restricted size
+ var container = document.createElement("div");
+ container.style.overflow= "";
+ container.style.position = "absolute";
+ container.style.left = "-9999px";
+ //fix a dimension, if specified.
+ if (size) {
+ if (size.w) {
+ w = container.style.width = size.w;
+ } else if (size.h) {
+ h = container.style.height = size.h;
+ // create temp content div and assign content
+ var content = document.createElement("div");
+ content.innerHTML = contentHTML;
+ // add content to restricted container
+ container.appendChild(content);
+ // append container to body for rendering
+ document.body.appendChild(container);
+ // calculate scroll width of content and add corners and shadow width
+ if (!w) {
+ w = parseInt(content.scrollWidth);
+ // update container width to allow height to adjust
+ container.style.width = w + "px";
+ // capture height and add shadow and corner image widths
+ if (!h) {
+ h = parseInt(content.scrollHeight);
+ // remove elements
+ container.removeChild(content);
+ document.body.removeChild(container);
+ return new OpenLayers.Size(w, h);
+ * APIFunction: getScrollbarWidth
+ * This function has been modified by the OpenLayers from the original version,
+ * written by Matthew Eernisse and released under the Apache 2
+ * license here:
+ * http://www.fleegix.org/articles/2006/05/30/getting-the-scrollbar-width-in-pixels
+ * It has been modified simply to cache its value, since it is physically
+ * impossible that this code could ever run in more than one browser at
+ * once.
+ * Returns:
+ * {Integer}
+OpenLayers.Util.getScrollbarWidth = function() {
+ var scrollbarWidth = OpenLayers.Util._scrollbarWidth;
+ if (scrollbarWidth == null) {
+ var scr = null;
+ var inn = null;
+ var wNoScroll = 0;
+ var wScroll = 0;
+ // Outer scrolling div
+ scr = document.createElement('div');
+ scr.style.position = 'absolute';
+ scr.style.top = '-1000px';
+ scr.style.left = '-1000px';
+ scr.style.width = '100px';
+ scr.style.height = '50px';
+ // Start with no scrollbar
+ scr.style.overflow = 'hidden';
+ // Inner content div
+ inn = document.createElement('div');
+ inn.style.width = '100%';
+ inn.style.height = '200px';
+ // Put the inner div in the scrolling div
+ scr.appendChild(inn);
+ // Append the scrolling div to the doc
+ document.body.appendChild(scr);
+ // Width of the inner div sans scrollbar
+ wNoScroll = inn.offsetWidth;
+ // Add the scrollbar
+ scr.style.overflow = 'scroll';
+ // Width of the inner div width scrollbar
+ wScroll = inn.offsetWidth;
+ // Remove the scrolling div from the doc
+ document.body.removeChild(document.body.lastChild);
+ // Pixel width of the scroller
+ OpenLayers.Util._scrollbarWidth = (wNoScroll - wScroll);
+ scrollbarWidth = OpenLayers.Util._scrollbarWidth;
+ return scrollbarWidth;
+ OpenLayers/Ajax.js
+OpenLayers.ProxyHost = "";
+//OpenLayers.ProxyHost = "examples/proxy.cgi?url=";
+ * Ajax reader for OpenLayers
+ * @uri url to do remote XML http get
+ * @param {String} 'get' format params (x=y&a=b...)
+ * @who object to handle callbacks for this request
+ * @complete the function to be called on success
+ * @failure the function to be called on failure
+ * example usage from a caller:
+ * caps: function(request) {
+ * -blah-
+ * OpenLayers.loadURL(url,params,this,caps);
+ * Notice the above example does not provide an error handler; a default empty
+ * handler is provided which merely logs the error if a failure handler is not
+ * supplied
+* @param {} request
+OpenLayers.nullHandler = function(request) {
+ alert(OpenLayers.i18n("unhandledRequest", {'statusText':request.statusText}));
+ * Function: loadURL
+ * Background load a document.
+ * Parameters:
+ * uri - {String} URI of source doc
+ * params - {String} Params on get (doesnt seem to work)
+ * caller - {Object} object which gets callbacks
+ * onComplete - {Function} Optional callback for success. The callback
+ * will be called with this set to caller and will receive the request
+ * object as an argument.
+ * onFailure - {Function} Optional callback for failure. In the event of
+ * a failure, the callback will be called with this set to caller and will
+ * receive the request object as an argument.
+ * Returns:
+ * {XMLHttpRequest} The request object. To abort loading, call
+ * request.abort().
+OpenLayers.loadURL = function(uri, params, caller,
+ onComplete, onFailure) {
+ var success = (onComplete) ? OpenLayers.Function.bind(onComplete, caller)
+ : OpenLayers.nullHandler;
+ var failure = (onFailure) ? OpenLayers.Function.bind(onFailure, caller)
+ // from prototype.js
+ var request = new OpenLayers.Ajax.Request(
+ uri,
+ method: 'get',
+ parameters: params,
+ onComplete: success,
+ onFailure: failure
+ return request.transport;
+ * Function: parseXMLString
+ * Parse XML into a doc structure
+ * Parameters:
+ * text - {String}
+ * Returns:
+ * {?} Parsed AJAX Responsev
+OpenLayers.parseXMLString = function(text) {
+ //MS sucks, if the server is bad it dies
+ var index = text.indexOf('<');
+ if (index > 0) {
+ text = text.substring(index);
+ var ajaxResponse = OpenLayers.Util.Try(
+ function() {
+ var xmldom = new ActiveXObject('Microsoft.XMLDOM');
+ xmldom.loadXML(text);
+ return xmldom;
+ function() {
+ return new DOMParser().parseFromString(text, 'text/xml');
+ function() {
+ var req = new XMLHttpRequest();
+ req.open("GET", "data:" + "text/xml" +
+ ";charset=utf-8," + encodeURIComponent(text), false);
+ if (req.overrideMimeType) {
+ req.overrideMimeType("text/xml");
+ req.send(null);
+ return req.responseXML;
+ return ajaxResponse;
+ * Namespace: OpenLayers.Ajax
+OpenLayers.Ajax = {
+ * Method: emptyFunction
+ emptyFunction: function () {},
+ * Method: getTransport
+ * Returns:
+ * {Object} Transport mechanism for whichever browser we're in, or false if
+ * none available.
+ getTransport: function() {
+ return OpenLayers.Util.Try(
+ function() {return new XMLHttpRequest();},
+ function() {return new ActiveXObject('Msxml2.XMLHTTP');},
+ function() {return new ActiveXObject('Microsoft.XMLHTTP');}
+ ) || false;
+ * Property: activeRequestCount
+ * {Integer}
+ activeRequestCount: 0
+ * Namespace: OpenLayers.Ajax.Responders
+ * {Object}
+OpenLayers.Ajax.Responders = {
+ * Property: responders
+ * {Array}
+ responders: [],
+ * Method: register
+ * Parameters:
+ * responderToAdd - {?}
+ register: function(responderToAdd) {
+ for (var i = 0; i < this.responders.length; i++){
+ if (responderToAdd == this.responders[i]){
+ return;
+ this.responders.push(responderToAdd);
+ * Method: unregister
+ * Parameters:
+ * responderToRemove - {?}
+ unregister: function(responderToRemove) {
+ OpenLayers.Util.removeItem(this.reponders, responderToRemove);
+ * Method: dispatch
+ * Parameters:
+ * callback - {?}
+ * request - {?}
+ * transport - {?}
+ dispatch: function(callback, request, transport) {
+ var responder;
+ for (var i = 0; i < this.responders.length; i++) {
+ responder = this.responders[i];
+ if (responder[callback] &&
+ typeof responder[callback] == 'function') {
+ try {
+ responder[callback].apply(responder,
+ [request, transport]);
+ } catch (e) {}
+OpenLayers.Ajax.Responders.register({
+ * Function: onCreate
+ onCreate: function() {
+ OpenLayers.Ajax.activeRequestCount++;
+ * Function: onComplete
+ onComplete: function() {
+ OpenLayers.Ajax.activeRequestCount--;
+ * Class: OpenLayers.Ajax.Base
+OpenLayers.Ajax.Base = OpenLayers.Class({
+ * Constructor: OpenLayers.Ajax.Base
+ * Parameters:
+ initialize: function(options) {
+ this.options = {
+ method: 'post',
+ asynchronous: true,
+ contentType: 'application/xml',
+ parameters: ''
+ OpenLayers.Util.extend(this.options, options || {});
+ this.options.method = this.options.method.toLowerCase();
+ if (typeof this.options.parameters == 'string') {
+ this.options.parameters =
+ OpenLayers.Util.getParameters(this.options.parameters);
+ * Class: OpenLayers.Ajax.Request
+ * Inherit:
+ * - <OpenLayers.Ajax.Base>
+OpenLayers.Ajax.Request = OpenLayers.Class(OpenLayers.Ajax.Base, {
+ * Property: _complete
+ * {Boolean}
+ _complete: false,
+ * Constructor: OpenLayers.Ajax.Request
+ * Parameters:
+ * url - {String}
+ initialize: function(url, options) {
+ OpenLayers.Ajax.Base.prototype.initialize.apply(this, [options]);
+ if (OpenLayers.ProxyHost && OpenLayers.String.startsWith(url, "http")) {
+ url = OpenLayers.ProxyHost + encodeURIComponent(url);
+ this.transport = OpenLayers.Ajax.getTransport();
+ this.request(url);
+ * Method: request
+ * Parameters:
+ * url - {String}
+ request: function(url) {
+ this.url = url;
+ this.method = this.options.method;
+ var params = OpenLayers.Util.extend({}, this.options.parameters);
+ if (this.method != 'get' && this.method != 'post') {
+ // simulate other verbs over post
+ params['_method'] = this.method;
+ this.method = 'post';
+ this.parameters = params;
+ if (params = OpenLayers.Util.getParameterString(params)) {
+ // when GET, append parameters to URL
+ if (this.method == 'get') {
+ this.url += ((this.url.indexOf('?') > -1) ? '&' : '?') + params;
+ } else if (/Konqueror|Safari|KHTML/.test(navigator.userAgent)) {
+ params += '&_=';
+ try {
+ var response = new OpenLayers.Ajax.Response(this);
+ if (this.options.onCreate) {
+ this.options.onCreate(response);
+ OpenLayers.Ajax.Responders.dispatch('onCreate',
+ this,
+ response);
+ this.transport.open(this.method.toUpperCase(),
+ this.url,
+ this.options.asynchronous);
+ if (this.options.asynchronous) {
+ window.setTimeout(
+ OpenLayers.Function.bind(this.respondToReadyState, this, 1),
+ 10);
+ this.transport.onreadystatechange =
+ OpenLayers.Function.bind(this.onStateChange, this);
+ this.setRequestHeaders();
+ this.body = this.method == 'post' ?
+ (this.options.postBody || params) : null;
+ this.transport.send(this.body);
+ // Force Firefox to handle ready state 4 for synchronous requests
+ if (!this.options.asynchronous &&
+ this.transport.overrideMimeType) {
+ this.onStateChange();
+ } catch (e) {
+ this.dispatchException(e);
+ * Method: onStateChange
+ onStateChange: function() {
+ var readyState = this.transport.readyState;
+ if (readyState > 1 && !((readyState == 4) && this._complete)) {
+ this.respondToReadyState(this.transport.readyState);
+ * Method: setRequestHeaders
+ setRequestHeaders: function() {
+ var headers = {
+ 'X-Requested-With': 'XMLHttpRequest',
+ 'Accept': 'text/javascript, text/html, application/xml, text/xml, */*',
+ 'OpenLayers': true
+ if (this.method == 'post') {
+ headers['Content-type'] = this.options.contentType +
+ (this.options.encoding ? '; charset=' + this.options.encoding : '');
+ /* Force "Connection: close" for older Mozilla browsers to work
+ * around a bug where XMLHttpRequest sends an incorrect
+ * Content-length header. See Mozilla Bugzilla #246651.
+ if (this.transport.overrideMimeType &&
+ (navigator.userAgent.match(/Gecko\/(\d{4})/) || [0,2005])[1] < 2005) {
+ headers['Connection'] = 'close';
+ // user-defined headers
+ if (typeof this.options.requestHeaders == 'object') {
+ var extras = this.options.requestHeaders;
+ if (typeof extras.push == 'function') {
+ for (var i = 0, length = extras.length; i < length; i += 2) {
+ headers[extras[i]] = extras[i+1];
+ } else {
+ for (var i in extras) {
+ headers[i] = pair[i];
+ for (var name in headers) {
+ this.transport.setRequestHeader(name, headers[name]);
+ * Method: success
+ * Returns:
+ * {Boolean} -
+ success: function() {
+ var status = this.getStatus();
+ return !status || (status >=200 && status < 300);
+ * Method: getStatus
+ * Returns:
+ * {Integer} - Status
+ getStatus: function() {
+ try {
+ return this.transport.status || 0;
+ } catch (e) {
+ return 0;
+ * Method: respondToReadyState
+ * Parameters:
+ * readyState - {?}
+ respondToReadyState: function(readyState) {
+ var state = OpenLayers.Ajax.Request.Events[readyState];
+ if (state == 'Complete') {
+ try {
+ this._complete = true;
+ (this.options['on' + response.status] ||
+ this.options['on' + (this.success() ? 'Success' : 'Failure')] ||
+ OpenLayers.Ajax.emptyFunction)(response);
+ } catch (e) {
+ var contentType = response.getHeader('Content-type');
+ try {
+ (this.options['on' + state] ||
+ OpenLayers.Ajax.Responders.dispatch('on' + state,
+ this,
+ response);
+ } catch (e) {
+ // avoid memory leak in MSIE: clean up
+ this.transport.onreadystatechange = OpenLayers.Ajax.emptyFunction;
+ * Method: getHeader
+ * Parameters:
+ * name - {String} Header name
+ * Returns:
+ * {?} - response header for the given name
+ getHeader: function(name) {
+ try {
+ return this.transport.getResponseHeader(name);
+ } catch (e) {
+ return null;
+ * Method: dispatchException
+ * If the optional onException function is set, execute it
+ * and then dispatch the call to any other listener registered
+ * for onException.
+ * If no optional onException function is set, we suspect that
+ * the user may have also not used
+ * OpenLayers.Ajax.Responders.register to register a listener
+ * for the onException call. To make sure that something
+ * gets done with this exception, only dispatch the call if there
+ * are listeners.
+ * If you explicitly want to swallow exceptions, set
+ * request.options.onException to an empty function (function(){})
+ * or register an empty function with <OpenLayers.Ajax.Responders>
+ * Parameters:
+ * exception - {?}
+ dispatchException: function(exception) {
+ var handler = this.options.onException;
+ if(handler) {
+ // call options.onException and alert any other listeners
+ handler(this, exception);
+ OpenLayers.Ajax.Responders.dispatch('onException', this, exception);
+ } else {
+ // check if there are any other listeners
+ var listener = false;
+ var responders = OpenLayers.Ajax.Responders.responders;
+ for (var i = 0; i < responders.length; i++) {
+ if(responders[i].onException) {
+ listener = true;
+ break;
+ if(listener) {
+ // call all listeners
+ } else {
+ // let the exception through
+ throw exception;
+ * Property: Events
+ * {Array(String)}
+OpenLayers.Ajax.Request.Events =
+ ['Uninitialized', 'Loading', 'Loaded', 'Interactive', 'Complete'];
+ * Class: OpenLayers.Ajax.Response
+OpenLayers.Ajax.Response = OpenLayers.Class({
+ * Property: status
+ * {Integer}
+ status: 0,
+ * Property: statusText
+ * {String}
+ statusText: '',
+ * Constructor: OpenLayers.Ajax.Response
+ * Parameters:
+ * request - {Object}
+ initialize: function(request) {
+ this.request = request;
+ var transport = this.transport = request.transport,
+ readyState = this.readyState = transport.readyState;
+ if ((readyState > 2 &&
+ !(!!(window.attachEvent && !window.opera))) ||
+ readyState == 4) {
+ this.status = this.getStatus();
+ this.statusText = this.getStatusText();
+ this.responseText = transport.responseText == null ?
+ '' : String(transport.responseText);
+ if(readyState == 4) {
+ var xml = transport.responseXML;
+ this.responseXML = xml === undefined ? null : xml;
+ getStatus: OpenLayers.Ajax.Request.prototype.getStatus,
+ * Method: getStatustext
+ * Returns:
+ * {String} - statusText
+ getStatusText: function() {
+ try {
+ return this.transport.statusText || '';
+ } catch (e) {
+ return '';
+ getHeader: OpenLayers.Ajax.Request.prototype.getHeader,
+ * Method: getResponseHeader
+ * Returns:
+ * {?} - response header for given name
+ getResponseHeader: function(name) {
+ * Function: getElementsByTagNameNS
+ * Parameters:
+ * parentnode - {?}
+ * nsuri - {?}
+ * nsprefix - {?}
+ * tagname - {?}
+ * Returns:
+OpenLayers.Ajax.getElementsByTagNameNS = function(parentnode, nsuri,
+ nsprefix, tagname) {
+ var elem = null;
+ if (parentnode.getElementsByTagNameNS) {
+ elem = parentnode.getElementsByTagNameNS(nsuri, tagname);
+ } else {
+ elem = parentnode.getElementsByTagName(nsprefix + ':' + tagname);
+ return elem;
+ * Function: serializeXMLToString
+ * Wrapper function around XMLSerializer, which doesn't exist/work in
+ * IE/Safari. We need to come up with a way to serialize in those browser:
+ * for now, these browsers will just fail. #535, #536
+ * Parameters:
+ * xmldom {XMLNode} xml dom to serialize
+ * Returns:
+OpenLayers.Ajax.serializeXMLToString = function(xmldom) {
+ var serializer = new XMLSerializer();
+ var data = serializer.serializeToString(xmldom);
+ return data;
+ OpenLayers/Console.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * Namespace: OpenLayers.Console
+ * The OpenLayers.Console namespace is used for debugging and error logging.
+ * If the Firebug Lite (../Firebug/firebug.js) is included before this script,
+ * calls to OpenLayers.Console methods will get redirected to window.console.
+ * This makes use of the Firebug extension where available and allows for
+ * cross-browser debugging Firebug style.
+ * Note:
+ * Note that behavior will differ with the Firebug extention and Firebug Lite.
+ * Most notably, the Firebug Lite console does not currently allow for
+ * hyperlinks to code or for clicking on object to explore their properties.
+OpenLayers.Console = {
+ * Create empty functions for all console methods. The real value of these
+ * properties will be set if Firebug Lite (../Firebug/firebug.js script) is
+ * included. We explicitly require the Firebug Lite script to trigger
+ * functionality of the OpenLayers.Console methods.
+ * APIFunction: log
+ * Log an object in the console. The Firebug Lite console logs string
+ * representation of objects. Given multiple arguments, they will
+ * be cast to strings and logged with a space delimiter. If the first
+ * argument is a string with printf-like formatting, subsequent arguments
+ * will be used in string substitution. Any additional arguments (beyond
+ * the number substituted in a format string) will be appended in a space-
+ * delimited line.
+ * Parameters:
+ log: function() {},
+ * APIFunction: debug
+ * Writes a message to the console, including a hyperlink to the line
+ * where it was called.
+ * May be called with multiple arguments as with OpenLayers.Console.log().
+ * Parameters:
+ debug: function() {},
+ * APIFunction: info
+ * Writes a message to the console with the visual "info" icon and color
+ * coding and a hyperlink to the line where it was called.
+ * Parameters:
+ info: function() {},
+ * APIFunction: warn
+ * Writes a message to the console with the visual "warning" icon and
+ * color coding and a hyperlink to the line where it was called.
+ * Parameters:
+ warn: function() {},
+ * APIFunction: error
+ * Writes a message to the console with the visual "error" icon and color
+ * Parameters:
+ error: function() {},
+ * APIFunction: assert
+ * Tests that an expression is true. If not, it will write a message to
+ * the console and throw an exception.
+ * Parameters:
+ assert: function() {},
+ * APIFunction: dir
+ * Prints an interactive listing of all properties of the object. This
+ * looks identical to the view that you would see in the DOM tab.
+ * Parameters:
+ dir: function() {},
+ * APIFunction: dirxml
+ * Prints the XML source tree of an HTML or XML element. This looks
+ * identical to the view that you would see in the HTML tab. You can click
+ * on any node to inspect it in the HTML tab.
+ * Parameters:
+ dirxml: function() {},
+ * APIFunction: trace
+ * Prints an interactive stack trace of JavaScript execution at the point
+ * where it is called. The stack trace details the functions on the stack,
+ * as well as the values that were passed as arguments to each function.
+ * You can click each function to take you to its source in the Script tab,
+ * and click each argument value to inspect it in the DOM or HTML tabs.
+ trace: function() {},
+ * APIFunction: group
+ * Writes a message to the console and opens a nested block to indent all
+ * future messages sent to the console. Call OpenLayers.Console.groupEnd()
+ * to close the block.
+ * Parameters:
+ group: function() {},
+ * APIFunction: groupEnd
+ * Closes the most recently opened block created by a call to
+ * OpenLayers.Console.group
+ groupEnd: function() {},
+ * APIFunction: time
+ * Creates a new timer under the given name. Call
+ * OpenLayers.Console.timeEnd(name)
+ * with the same name to stop the timer and print the time elapsed.
+ * Parameters:
+ * name - {String}
+ time: function() {},
+ * APIFunction: timeEnd
+ * Stops a timer created by a call to OpenLayers.Console.time(name) and
+ * writes the time elapsed.
+ * Parameters:
+ * name - {String}
+ timeEnd: function() {},
+ * APIFunction: profile
+ * Turns on the JavaScript profiler. The optional argument title would
+ * contain the text to be printed in the header of the profile report.
+ * This function is not currently implemented in Firebug Lite.
+ * Parameters:
+ * title - {String} Optional title for the profiler
+ profile: function() {},
+ * APIFunction: profileEnd
+ * Turns off the JavaScript profiler and prints its report.
+ profileEnd: function() {},
+ * APIFunction: count
+ * Writes the number of times that the line of code where count was called
+ * was executed. The optional argument title will print a message in
+ * addition to the number of the count.
+ * Parameters:
+ * title - {String} Optional title to be printed with count
+ count: function() {},
+ CLASS_NAME: "OpenLayers.Console"
+ * Execute an anonymous function to extend the OpenLayers.Console namespace
+ * if the firebug.js script is included. This closure is used so that the
+ * "scripts" and "i" variables don't pollute the global namespace.
+(function() {
+ * If Firebug Lite is included (before this script), re-route all
+ * OpenLayers.Console calls to the console object.
+ if(window.console) {
+ var scripts = document.getElementsByTagName("script");
+ for(var i=0; i<scripts.length; ++i) {
+ if(scripts[i].src.indexOf("firebug.js") != -1) {
+ OpenLayers.Util.extend(OpenLayers.Console, console);
+ break;
+ OpenLayers/BaseTypes/Size.js
+ * Class: OpenLayers.Size
+ * Instances of this class represent a width/height pair
+OpenLayers.Size = OpenLayers.Class({
+ * APIProperty: w
+ * {Number} width
+ w: 0.0,
+ * APIProperty: h
+ * {Number} height
+ h: 0.0,
+ * Constructor: OpenLayers.Size
+ * Create an instance of OpenLayers.Size
+ * Parameters:
+ * w - {Number} width
+ * h - {Number} height
+ initialize: function(w, h) {
+ this.w = parseFloat(w);
+ this.h = parseFloat(h);
+ * Method: toString
+ * Return the string representation of a size object
+ * Returns:
+ * {String} The string representation of OpenLayers.Size object.
+ * (ex. <i>"w=55,h=66"</i>)
+ toString:function() {
+ return ("w=" + this.w + ",h=" + this.h);
+ * APIMethod: clone
+ * Create a clone of this size object
+ * Returns:
+ * {<OpenLayers.Size>} A new OpenLayers.Size object with the same w and h
+ * values
+ clone:function() {
+ return new OpenLayers.Size(this.w, this.h);
+ * APIMethod: equals
+ * Determine where this size is equal to another
+ * Parameters:
+ * Returns:
+ * {Boolean} The passed in size has the same h and w properties as this one.
+ * Note that if sz passed in is null, returns false.
+ equals:function(sz) {
+ var equals = false;
+ if (sz != null) {
+ equals = ((this.w == sz.w && this.h == sz.h) ||
+ (isNaN(this.w) && isNaN(this.h) && isNaN(sz.w) && isNaN(sz.h)));
+ return equals;
+ CLASS_NAME: "OpenLayers.Size"
+ OpenLayers/BaseTypes/Bounds.js
+ * Class: OpenLayers.Bounds
+ * Instances of this class represent bounding boxes. Data stored as left,
+ * bottom, right, top floats. All values are initialized to null, however,
+ * you should make sure you set them before using the bounds for anything.
+ * Possible use case:
+ * > bounds = new OpenLayers.Bounds();
+ * > bounds.extend(new OpenLayers.LonLat(4,5));
+ * > bounds.extend(new OpenLayers.LonLat(5,6));
+ * > bounds.toBBOX(); // returns 4,5,5,6
+OpenLayers.Bounds = OpenLayers.Class({
+ * Property: left
+ * {Number} Minimum horizontal coordinate.
+ left: null,
+ * Property: bottom
+ * {Number} Minimum vertical coordinate.
+ bottom: null,
+ * Property: right
+ * {Number} Maximum horizontal coordinate.
+ right: null,
+ * Property: top
+ * {Number} Maximum vertical coordinate.
+ top: null,
+ * Constructor: OpenLayers.Bounds
+ * Construct a new bounds object.
+ * Parameters:
+ * left - {Number} The left bounds of the box. Note that for width
+ * calculations, this is assumed to be less than the right value.
+ * bottom - {Number} The bottom bounds of the box. Note that for height
+ * calculations, this is assumed to be more than the top value.
+ * right - {Number} The right bounds.
+ * top - {Number} The top bounds.
+ initialize: function(left, bottom, right, top) {
+ if (left != null) {
+ this.left = parseFloat(left);
+ if (bottom != null) {
+ this.bottom = parseFloat(bottom);
+ if (right != null) {
+ this.right = parseFloat(right);
+ if (top != null) {
+ this.top = parseFloat(top);
+ * Method: clone
+ * Create a cloned instance of this bounds.
+ * Returns:
+ * {<OpenLayers.Bounds>} A fresh copy of the bounds
+ return new OpenLayers.Bounds(this.left, this.bottom,
+ this.right, this.top);
+ * Method: equals
+ * Test a two bounds for equivalence.
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>}
+ * Returns:
+ * {Boolean} The passed-in bounds object has the same left,
+ * right, top, bottom components as this. Note that if bounds
+ * passed in is null, returns false.
+ equals:function(bounds) {
+ if (bounds != null) {
+ equals = ((this.left == bounds.left) &&
+ (this.right == bounds.right) &&
+ (this.top == bounds.top) &&
+ (this.bottom == bounds.bottom));
+ return equals;
+ * APIMethod: toString
+ * Returns:
+ * {String} String representation of bounds object.
+ * (ex.<i>"left-bottom=(5,42) right-top=(10,45)"</i>)
+ return ( "left-bottom=(" + this.left + "," + this.bottom + ")"
+ + " right-top=(" + this.right + "," + this.top + ")" );
+ * APIMethod: toArray
+ * Returns:
+ * {Array} array of left, bottom, right, top
+ toArray: function() {
+ return [this.left, this.bottom, this.right, this.top];
+ * APIMethod: toBBOX
+ * Parameters:
+ * decimal - {Integer} How many significant digits in the bbox coords?
+ * Default is 6
+ * Returns:
+ * {String} Simple String representation of bounds object.
+ * (ex. <i>"5,42,10,45"</i>)
+ toBBOX:function(decimal) {
+ if (decimal== null) {
+ decimal = 6;
+ var mult = Math.pow(10, decimal);
+ var bbox = Math.round(this.left * mult) / mult + "," +
+ Math.round(this.bottom * mult) / mult + "," +
+ Math.round(this.right * mult) / mult + "," +
+ Math.round(this.top * mult) / mult;
+ return bbox;
+ * APIMethod: toGeometry
+ * Create a new polygon geometry based on this bounds.
+ * Returns:
+ * {<OpenLayers.Geometry.Polygon>} A new polygon with the coordinates
+ * of this bounds.
+ toGeometry: function() {
+ return new OpenLayers.Geometry.Polygon([
+ new OpenLayers.Geometry.LinearRing([
+ new OpenLayers.Geometry.Point(this.left, this.bottom),
+ new OpenLayers.Geometry.Point(this.right, this.bottom),
+ new OpenLayers.Geometry.Point(this.right, this.top),
+ new OpenLayers.Geometry.Point(this.left, this.top)
+ * APIMethod: getWidth
+ * Returns:
+ * {Float} The width of the bounds
+ getWidth:function() {
+ return (this.right - this.left);
+ * APIMethod: getHeight
+ * Returns:
+ * {Float} The height of the bounds (top minus bottom).
+ getHeight:function() {
+ return (this.top - this.bottom);
+ * APIMethod: getSize
+ * Returns:
+ * {<OpenLayers.Size>} The size of the box.
+ getSize:function() {
+ return new OpenLayers.Size(this.getWidth(), this.getHeight());
+ * APIMethod: getCenterPixel
+ * Returns:
+ * {<OpenLayers.Pixel>} The center of the bounds in pixel space.
+ getCenterPixel:function() {
+ return new OpenLayers.Pixel( (this.left + this.right) / 2,
+ (this.bottom + this.top) / 2);
+ * APIMethod: getCenterLonLat
+ * Returns:
+ * {<OpenLayers.LonLat>} The center of the bounds in map space.
+ getCenterLonLat:function() {
+ return new OpenLayers.LonLat( (this.left + this.right) / 2,
+ * APIMethod: add
+ * Parameters:
+ * x - {Float}
+ * y - {Float}
+ * Returns:
+ * {<OpenLayers.Bounds>} A new bounds whose coordinates are the same as
+ * this, but shifted by the passed-in x and y values.
+ add:function(x, y) {
+ if ( (x == null) || (y == null) ) {
+ var msg = OpenLayers.i18n("boundsAddError");
+ OpenLayers.Console.error(msg);
+ return null;
+ return new OpenLayers.Bounds(this.left + x, this.bottom + y,
+ this.right + x, this.top + y);
+ * APIMethod: extend
+ * Extend the bounds to include the point, lonlat, or bounds specified.
+ * Note, this function assumes that left < right and bottom < top.
+ * Parameters:
+ * object - {Object} Can be LonLat, Point, or Bounds
+ extend:function(object) {
+ var bounds = null;
+ if (object) {
+ switch(object.CLASS_NAME) {
+ case "OpenLayers.LonLat":
+ bounds = new OpenLayers.Bounds(object.lon, object.lat,
+ object.lon, object.lat);
+ break;
+ case "OpenLayers.Geometry.Point":
+ bounds = new OpenLayers.Bounds(object.x, object.y,
+ object.x, object.y);
+ break;
+ case "OpenLayers.Bounds":
+ bounds = object;
+ break;
+ if (bounds) {
+ if ( (this.left == null) || (bounds.left < this.left)) {
+ this.left = bounds.left;
+ if ( (this.bottom == null) || (bounds.bottom < this.bottom) ) {
+ this.bottom = bounds.bottom;
+ if ( (this.right == null) || (bounds.right > this.right) ) {
+ this.right = bounds.right;
+ if ( (this.top == null) || (bounds.top > this.top) ) {
+ this.top = bounds.top;
+ * APIMethod: containsLonLat
+ * Parameters:
+ * ll - {<OpenLayers.LonLat>}
+ * inclusive - {Boolean} Whether or not to include the border.
+ * Default is true.
+ * Returns:
+ * {Boolean} The passed-in lonlat is within this bounds.
+ containsLonLat:function(ll, inclusive) {
+ return this.contains(ll.lon, ll.lat, inclusive);
+ * APIMethod: containsPixel
+ * Parameters:
+ * inclusive - {Boolean} Whether or not to include the border. Default is
+ * true.
+ * Returns:
+ * {Boolean} The passed-in pixel is within this bounds.
+ containsPixel:function(px, inclusive) {
+ return this.contains(px.x, px.y, inclusive);
+ * Parameters:
+ * x - {Float}
+ * y - {Float}
+ * true.
+ * Returns:
+ * {Boolean} Whether or not the passed-in coordinates are within this
+ * bounds.
+ contains:function(x, y, inclusive) {
+ //set default
+ if (inclusive == null) {
+ inclusive = true;
+ var contains = false;
+ if (inclusive) {
+ contains = ((x >= this.left) && (x <= this.right) &&
+ (y >= this.bottom) && (y <= this.top));
+ } else {
+ contains = ((x > this.left) && (x < this.right) &&
+ (y > this.bottom) && (y < this.top));
+ return contains;
+ * APIMethod: intersectsBounds
+ * Parameters:
+ * is true.
+ * Returns:
+ * {Boolean} The passed-in OpenLayers.Bounds object intersects this bounds.
+ * Simple math just check if either contains the other, allowing for
+ * partial.
+ intersectsBounds:function(bounds, inclusive) {
+ inclusive = true;
+ var inBottom = (bounds.bottom == this.bottom && bounds.top == this.top) ?
+ true : (((bounds.bottom > this.bottom) && (bounds.bottom < this.top)) ||
+ ((this.bottom > bounds.bottom) && (this.bottom < bounds.top)));
+ var inTop = (bounds.bottom == this.bottom && bounds.top == this.top) ?
+ true : (((bounds.top > this.bottom) && (bounds.top < this.top)) ||
+ ((this.top > bounds.bottom) && (this.top < bounds.top)));
+ var inRight = (bounds.right == this.right && bounds.left == this.left) ?
+ true : (((bounds.right > this.left) && (bounds.right < this.right)) ||
+ ((this.right > bounds.left) && (this.right < bounds.right)));
+ var inLeft = (bounds.right == this.right && bounds.left == this.left) ?
+ true : (((bounds.left > this.left) && (bounds.left < this.right)) ||
+ ((this.left > bounds.left) && (this.left < bounds.right)));
+ return (this.containsBounds(bounds, true, inclusive) ||
+ bounds.containsBounds(this, true, inclusive) ||
+ ((inTop || inBottom ) && (inLeft || inRight )));
+ * APIMethod: containsBounds
+ * partial - {Boolean} If true, only part of passed-in bounds needs be
+ * within this bounds. If false, the entire passed-in bounds must be
+ * within. Default is false
+ * true.
+ * Returns:
+ * {Boolean} The passed-in bounds object is contained within this bounds.
+ containsBounds:function(bounds, partial, inclusive) {
+ //set defaults
+ if (partial == null) {
+ partial = false;
+ inclusive = true;
+ var inLeft;
+ var inTop;
+ var inRight;
+ var inBottom;
+ if (inclusive) {
+ inLeft = (bounds.left >= this.left) && (bounds.left <= this.right);
+ inTop = (bounds.top >= this.bottom) && (bounds.top <= this.top);
+ inRight= (bounds.right >= this.left) && (bounds.right <= this.right);
+ inBottom = (bounds.bottom >= this.bottom) && (bounds.bottom <= this.top);
+ } else {
+ inLeft = (bounds.left > this.left) && (bounds.left < this.right);
+ inTop = (bounds.top > this.bottom) && (bounds.top < this.top);
+ inRight= (bounds.right > this.left) && (bounds.right < this.right);
+ inBottom = (bounds.bottom > this.bottom) && (bounds.bottom < this.top);
+ return (partial) ? (inTop || inBottom ) && (inLeft || inRight )
+ : (inTop && inLeft && inBottom && inRight);
+ * APIMethod: determineQuadrant
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>}
+ * Returns:
+ * {String} The quadrant ("br" "tr" "tl" "bl") of the bounds in which the
+ * coordinate lies.
+ determineQuadrant: function(lonlat) {
+ var quadrant = "";
+ var center = this.getCenterLonLat();
+ quadrant += (lonlat.lat < center.lat) ? "b" : "t";
+ quadrant += (lonlat.lon < center.lon) ? "l" : "r";
+ return quadrant;
+ * APIMethod: transform
+ * Transform the Bounds object from source to dest.
+ * Parameters:
+ * source - {<OpenLayers.Projection>} Source projection.
+ * dest - {<OpenLayers.Projection>} Destination projection.
+ * Returns:
+ * {<OpenLayers.Bounds>} Itself, for use in chaining operations.
+ transform: function(source, dest) {
+ var ll = OpenLayers.Projection.transform(
+ {'x': this.left, 'y': this.bottom}, source, dest);
+ var lr = OpenLayers.Projection.transform(
+ {'x': this.right, 'y': this.bottom}, source, dest);
+ var ul = OpenLayers.Projection.transform(
+ {'x': this.left, 'y': this.top}, source, dest);
+ var ur = OpenLayers.Projection.transform(
+ {'x': this.right, 'y': this.top}, source, dest);
+ this.left = Math.min(ll.x, ul.x);
+ this.bottom = Math.min(ll.y, lr.y);
+ this.right = Math.max(lr.x, ur.x);
+ this.top = Math.max(ul.y, ur.y);
+ return this;
+ * APIMethod: wrapDateLine
+ * Parameters:
+ * maxExtent - {<OpenLayers.Bounds>}
+ * options - {Object} Some possible options are:
+ * leftTolerance - {float} Allow for a margin of error
+ * with the 'left' value of this
+ * bound.
+ * Default is 0.
+ * rightTolerance - {float} Allow for a margin of error
+ * with the 'right' value of
+ * this bound.
+ * Default is 0.
+ * Returns:
+ * {<OpenLayers.Bounds>} A copy of this bounds, but wrapped around the
+ * "dateline" (as specified by the borders of
+ * maxExtent). Note that this function only returns
+ * a different bounds value if this bounds is
+ * *entirely* outside of the maxExtent. If this
+ * bounds straddles the dateline (is part in/part
+ * out of maxExtent), the returned bounds will be
+ * merely a copy of this one.
+ wrapDateLine: function(maxExtent, options) {
+ var leftTolerance = options.leftTolerance || 0;
+ var rightTolerance = options.rightTolerance || 0;
+ var newBounds = this.clone();
+ if (maxExtent) {
+ //shift right?
+ while ( newBounds.left < maxExtent.left &&
+ (newBounds.right - rightTolerance) <= maxExtent.left ) {
+ newBounds = newBounds.add(maxExtent.getWidth(), 0);
+ //shift left?
+ while ( (newBounds.left + leftTolerance) >= maxExtent.right &&
+ newBounds.right > maxExtent.right ) {
+ newBounds = newBounds.add(-maxExtent.getWidth(), 0);
+ return newBounds;
+ CLASS_NAME: "OpenLayers.Bounds"
+ * APIFunction: fromString
+ * Alternative constructor that builds a new OpenLayers.Bounds from a
+ * parameter string
+ * Parameters:
+ * str - {String}Comma-separated bounds string. (ex. <i>"5,42,10,45"</i>)
+ * Returns:
+ * {<OpenLayers.Bounds>} New bounds object built from the
+ * passed-in String.
+OpenLayers.Bounds.fromString = function(str) {
+ var bounds = str.split(",");
+ return OpenLayers.Bounds.fromArray(bounds);
+ * APIFunction: fromArray
+ * from an array
+ * Parameters:
+ * bbox - {Array(Float)} Array of bounds values (ex. <i>[5,42,10,45]</i>)
+ * Returns:
+ * {<OpenLayers.Bounds>} New bounds object built from the passed-in Array.
+OpenLayers.Bounds.fromArray = function(bbox) {
+ return new OpenLayers.Bounds(parseFloat(bbox[0]),
+ parseFloat(bbox[1]),
+ parseFloat(bbox[2]),
+ parseFloat(bbox[3]));
+ * APIFunction: fromSize
+ * from a size
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Bounds>} New bounds object built from the passed-in size.
+OpenLayers.Bounds.fromSize = function(size) {
+ return new OpenLayers.Bounds(0,
+ size.h,
+ size.w,
+ 0);
+ * Function: oppositeQuadrant
+ * Get the opposite quadrant for a given quadrant string.
+ * Parameters:
+ * quadrant - {String} two character quadrant shortstring
+ * Returns:
+ * {String} The opposing quadrant ("br" "tr" "tl" "bl"). For Example, if
+ * you pass in "bl" it returns "tr", if you pass in "br" it
+ * returns "tl", etc.
+OpenLayers.Bounds.oppositeQuadrant = function(quadrant) {
+ var opp = "";
+ opp += (quadrant.charAt(0) == 't') ? 'b' : 't';
+ opp += (quadrant.charAt(1) == 'l') ? 'r' : 'l';
+ return opp;
+ OpenLayers/BaseTypes/Element.js
+ * Namespace: OpenLayers.Element
+OpenLayers.Element = {
+ * APIFunction: visible
+ * Parameters:
+ * element - {DOMElement}
+ * Returns:
+ * {Boolean} Is the element visible?
+ visible: function(element) {
+ return OpenLayers.Util.getElement(element).style.display != 'none';
+ * APIFunction: toggle
+ * Toggle the visibility of element(s) passed in
+ * Parameters:
+ * element - {DOMElement} Actually user can pass any number of elements
+ toggle: function() {
+ for (var i = 0; i < arguments.length; i++) {
+ var element = OpenLayers.Util.getElement(arguments[i]);
+ var display = OpenLayers.Element.visible(element) ? 'hide'
+ : 'show';
+ OpenLayers.Element[display](element);
+ * APIFunction: hide
+ * Hide element(s) passed in
+ * Parameters:
+ hide: function() {
+ element.style.display = 'none';
+ * APIFunction: show
+ * Show element(s) passed in
+ * Parameters:
+ show: function() {
+ element.style.display = '';
+ * APIFunction: remove
+ * Remove the specified element from the DOM.
+ * Parameters:
+ remove: function(element) {
+ element = OpenLayers.Util.getElement(element);
+ element.parentNode.removeChild(element);
+ * APIFunction: getHeight
+ * Parameters:
+ * Returns:
+ * {Integer} The offset height of the element passed in
+ getHeight: function(element) {
+ return element.offsetHeight;
+ * APIFunction: getDimensions
+ * Parameters:
+ * Returns:
+ * {Object} Object with 'width' and 'height' properties which are the
+ * dimensions of the element passed in.
+ getDimensions: function(element) {
+ if (OpenLayers.Element.getStyle(element, 'display') != 'none') {
+ return {width: element.offsetWidth, height: element.offsetHeight};
+ // All *Width and *Height properties give 0 on elements with display none,
+ // so enable the element temporarily
+ var els = element.style;
+ var originalVisibility = els.visibility;
+ var originalPosition = els.position;
+ els.visibility = 'hidden';
+ els.position = 'absolute';
+ els.display = '';
+ var originalWidth = element.clientWidth;
+ var originalHeight = element.clientHeight;
+ els.display = 'none';
+ els.position = originalPosition;
+ els.visibility = originalVisibility;
+ return {width: originalWidth, height: originalHeight};
+ * APIFunction: getStyle
+ * Parameters:
+ * style - {?}
+ * Returns:
+ getStyle: function(element, style) {
+ var value = element.style[OpenLayers.String.camelize(style)];
+ if (!value) {
+ if (document.defaultView &&
+ document.defaultView.getComputedStyle) {
+ var css = document.defaultView.getComputedStyle(element, null);
+ value = css ? css.getPropertyValue(style) : null;
+ } else if (element.currentStyle) {
+ value = element.currentStyle[OpenLayers.String.camelize(style)];
+ var positions = ['left', 'top', 'right', 'bottom'];
+ if (window.opera &&
+ (OpenLayers.Util.indexOf(positions,style) != -1) &&
+ (OpenLayers.Element.getStyle(element, 'position') == 'static')) {
+ value = 'auto';
+ return value == 'auto' ? null : value;
+ OpenLayers/BaseTypes/LonLat.js
+ * Class: OpenLayers.LonLat
+ * This class represents a longitude and latitude pair
+OpenLayers.LonLat = OpenLayers.Class({
+ * APIProperty: lon
+ * {Float} The x-axis coodinate in map units
+ lon: 0.0,
+ * APIProperty: lat
+ * {Float} The y-axis coordinate in map units
+ lat: 0.0,
+ * Constructor: OpenLayers.LonLat
+ * Create a new map location.
+ * Parameters:
+ * lon - {Number} The x-axis coordinate in map units. If your map is in
+ * a geographic projection, this will be the Longitude. Otherwise,
+ * it will be the x coordinate of the map location in your map units.
+ * lat - {Number} The y-axis coordinate in map units. If your map is in
+ * a geographic projection, this will be the Latitude. Otherwise,
+ * it will be the y coordinate of the map location in your map units.
+ initialize: function(lon, lat) {
+ this.lon = parseFloat(lon);
+ this.lat = parseFloat(lat);
+ * Return a readable string version of the lonlat
+ * Returns:
+ * {String} String representation of OpenLayers.LonLat object.
+ * (ex. <i>"lon=5,lat=42"</i>)
+ return ("lon=" + this.lon + ",lat=" + this.lat);
+ * APIMethod: toShortString
+ * Returns:
+ * {String} Shortened String representation of OpenLayers.LonLat object.
+ * (ex. <i>"5, 42"</i>)
+ toShortString:function() {
+ return (this.lon + ", " + this.lat);
+ * Returns:
+ * {<OpenLayers.LonLat>} New OpenLayers.LonLat object with the same lon
+ * and lat values
+ return new OpenLayers.LonLat(this.lon, this.lat);
+ * APIMethod: add
+ * Parameters:
+ * lon - {Float}
+ * lat - {Float}
+ * Returns:
+ * {<OpenLayers.LonLat>} A new OpenLayers.LonLat object with the lon and
+ * lat passed-in added to this's.
+ add:function(lon, lat) {
+ if ( (lon == null) || (lat == null) ) {
+ var msg = OpenLayers.i18n("lonlatAddError");
+ return null;
+ return new OpenLayers.LonLat(this.lon + lon, this.lat + lat);
+ * Parameters:
+ * Returns:
+ * {Boolean} Boolean value indicating whether the passed-in
+ * <OpenLayers.LonLat> object has the same lon and lat
+ * components as this.
+ * Note: if ll passed in is null, returns false
+ equals:function(ll) {
+ if (ll != null) {
+ equals = ((this.lon == ll.lon && this.lat == ll.lat) ||
+ (isNaN(this.lon) && isNaN(this.lat) && isNaN(ll.lon) && isNaN(ll.lat)));
+ return equals;
+ * Transform the LonLat object from source to dest.
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.LonLat>} Itself, for use in chaining operations.
+ var point = OpenLayers.Projection.transform(
+ {'x': this.lon, 'y': this.lat}, source, dest);
+ this.lon = point.x;
+ this.lat = point.y;
+ return this;
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.LonLat>} A copy of this lonlat, but wrapped around the
+ * maxExtent)
+ wrapDateLine: function(maxExtent) {
+ var newLonLat = this.clone();
+ if (maxExtent) {
+ //shift right?
+ while (newLonLat.lon < maxExtent.left) {
+ newLonLat.lon += maxExtent.getWidth();
+ //shift left?
+ while (newLonLat.lon > maxExtent.right) {
+ newLonLat.lon -= maxExtent.getWidth();
+ return newLonLat;
+ CLASS_NAME: "OpenLayers.LonLat"
+ * Function: fromString
+ * Alternative constructor that builds a new <OpenLayers.LonLat> from a
+ * Parameters:
+ * str - {String} Comma-separated Lon,Lat coordinate string.
+ * (ex. <i>"5,40"</i>)
+ * Returns:
+ * {<OpenLayers.LonLat>} New <OpenLayers.LonLat> object built from the
+OpenLayers.LonLat.fromString = function(str) {
+ var pair = str.split(",");
+ return new OpenLayers.LonLat(parseFloat(pair[0]),
+ parseFloat(pair[1]));
+ OpenLayers/BaseTypes/Pixel.js
+ * Class: OpenLayers.Pixel
+ * This class represents a screen coordinate, in x and y coordinates
+OpenLayers.Pixel = OpenLayers.Class({
+ * APIProperty: x
+ * {Number} The x coordinate
+ x: 0.0,
+ * APIProperty: y
+ * {Number} The y coordinate
+ y: 0.0,
+ * Constructor: OpenLayers.Pixel
+ * Create a new OpenLayers.Pixel instance
+ * Parameters:
+ * x - {Number} The x coordinate
+ * y - {Number} The y coordinate
+ * Returns:
+ * An instance of OpenLayers.Pixel
+ initialize: function(x, y) {
+ this.x = parseFloat(x);
+ this.y = parseFloat(y);
+ * Cast this object into a string
+ * Returns:
+ * {String} The string representation of Pixel. ex: "x=200.4,y=242.2"
+ return ("x=" + this.x + ",y=" + this.y);
+ * Return a clone of this pixel object
+ * Returns:
+ * {<OpenLayers.Pixel>} A clone pixel
+ return new OpenLayers.Pixel(this.x, this.y);
+ * Determine whether one pixel is equivalent to another
+ * Parameters:
+ * px - {<OpenLayers.Pixel>}
+ * Returns:
+ * {Boolean} The point passed in as parameter is equal to this. Note that
+ * if px passed in is null, returns false.
+ equals:function(px) {
+ if (px != null) {
+ equals = ((this.x == px.x && this.y == px.y) ||
+ (isNaN(this.x) && isNaN(this.y) && isNaN(px.x) && isNaN(px.y)));
+ return equals;
+ * APIMethod: add
+ * Parameters:
+ * x - {Integer}
+ * y - {Integer}
+ * Returns:
+ * {<OpenLayers.Pixel>} A new Pixel with this pixel's x&y augmented by the
+ * values passed in.
+ var msg = OpenLayers.i18n("pixelAddError");
+ return null;
+ return new OpenLayers.Pixel(this.x + x, this.y + y);
+ * APIMethod: offset
+ * Parameters
+ * Returns:
+ * x&y values of the pixel passed in.
+ offset:function(px) {
+ var newPx = this.clone();
+ if (px) {
+ newPx = this.add(px.x, px.y);
+ return newPx;
+ CLASS_NAME: "OpenLayers.Pixel"
+ OpenLayers/Control.js
+ * Class: OpenLayers.Control
+ * Controls affect the display or behavior of the map. They allow everything
+ * from panning and zooming to displaying a scale indicator. Controls by
+ * default are added to the map they are contained within however it is
+ * possible to add a control to an external div by passing the div in the
+ * options parameter.
+ * Example:
+ * The following example shows how to add many of the common controls
+ * to a map.
+ * > var map = new OpenLayers.Map('map', { controls: [] });
+ * > map.addControl(new OpenLayers.Control.PanZoomBar());
+ * > map.addControl(new OpenLayers.Control.MouseToolbar());
+ * > map.addControl(new OpenLayers.Control.LayerSwitcher({'ascending':false}));
+ * > map.addControl(new OpenLayers.Control.Permalink());
+ * > map.addControl(new OpenLayers.Control.Permalink('permalink'));
+ * > map.addControl(new OpenLayers.Control.MousePosition());
+ * > map.addControl(new OpenLayers.Control.OverviewMap());
+ * > map.addControl(new OpenLayers.Control.KeyboardDefaults());
+ * The next code fragment is a quick example of how to intercept
+ * shift-mouse click to display the extent of the bounding box
+ * dragged out by the user. Usually controls are not created
+ * in exactly this manner. See the source for a more complete
+ * example:
+ * > var control = new OpenLayers.Control();
+ * > OpenLayers.Util.extend(control, {
+ * > draw: function () {
+ * > // this Handler.Box will intercept the shift-mousedown
+ * > // before Control.MouseDefault gets to see it
+ * > this.box = new OpenLayers.Handler.Box( control,
+ * > {"done": this.notice},
+ * > {keyMask: OpenLayers.Handler.MOD_SHIFT});
+ * > this.box.activate();
+ * > notice: function (bounds) {
+ * > alert(bounds);
+ * > map.addControl(control);
+OpenLayers.Control = OpenLayers.Class({
+ * Property: id
+ * {String}
+ id: null,
+ * Property: map
+ * {<OpenLayers.Map>} this gets set in the addControl() function in
+ * OpenLayers.Map
+ map: null,
+ * Property: div
+ * {DOMElement}
+ div: null,
+ * Property: type
+ * {OpenLayers.Control.TYPES} Controls can have a 'type'. The type
+ * determines the type of interactions which are possible with them when
+ * they are placed into a toolbar.
+ type: null,
+ * Property: allowSelection
+ * {Boolean} By deafault, controls do not allow selection, because
+ * it may interfere with map dragging. If this is true, OpenLayers
+ * will not prevent selection of the control.
+ * Default is false.
+ allowSelection: false,
+ * Property: displayClass
+ * {string} This property is used for CSS related to the drawing of the
+ * Control.
+ displayClass: "",
+ * Property: title
+ * {string} This property is used for showing a tooltip over the
+ * Control.
+ title: "",
+ * {Boolean} The control is active.
+ active: null,
+ * Property: handler
+ * {<OpenLayers.Handler>} null
+ handler: null,
+ * APIProperty: eventListeners
+ * {Object} If set as an option at construction, the eventListeners
+ * object will be registered with <OpenLayers.Events.on>. Object
+ * structure must be a listeners object as shown in the example for
+ * the events.on method.
+ eventListeners: null,
+ * Property: events
+ * {<OpenLayers.Events>} Events instance for triggering control specific
+ * events.
+ events: null,
+ * Constant: EVENT_TYPES
+ * {Array(String)} Supported application event types. Register a listener
+ * for a particular event with the following syntax:
+ * (code)
+ * control.events.register(type, obj, listener);
+ * (end)
+ * Listeners will be called with a reference to an event object. The
+ * properties of this event depends on exactly what happened.
+ * All event objects have at least the following properties:
+ * - *object* {Object} A reference to control.events.object (a reference
+ * to the control).
+ * - *element* {DOMElement} A reference to control.events.element (which
+ * will be null unless documented otherwise).
+ * Supported map event types:
+ * - *activate* Triggered when activated.
+ * - *deactivate* Triggered when deactivated.
+ EVENT_TYPES: ["activate", "deactivate"],
+ * Constructor: OpenLayers.Control
+ * Create an OpenLayers Control. The options passed as a parameter
+ * directly extend the control. For example passing the following:
+ * > var control = new OpenLayers.Control({div: myDiv});
+ * Overrides the default div attribute value of null.
+ * Parameters:
+ initialize: function (options) {
+ // We do this before the extend so that instances can override
+ // className in options.
+ this.displayClass =
+ this.CLASS_NAME.replace("OpenLayers.", "ol").replace(/\./g, "");
+ OpenLayers.Util.extend(this, options);
+ this.events = new OpenLayers.Events(this, null, this.EVENT_TYPES);
+ if(this.eventListeners instanceof Object) {
+ this.events.on(this.eventListeners);
+ this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
+ * Method: destroy
+ * The destroy method is used to perform any clean up before the control
+ * is dereferenced. Typically this is where event listeners are removed
+ * to prevent memory leaks.
+ destroy: function () {
+ if(this.events) {
+ if(this.eventListeners) {
+ this.events.un(this.eventListeners);
+ this.events.destroy();
+ this.events = null;
+ this.eventListeners = null;
+ // eliminate circular references
+ if (this.handler) {
+ this.handler.destroy();
+ this.handler = null;
+ if(this.handlers) {
+ for(var key in this.handlers) {
+ if(this.handlers.hasOwnProperty(key) &&
+ typeof this.handlers[key].destroy == "function") {
+ this.handlers[key].destroy();
+ this.handlers = null;
+ if (this.map) {
+ this.map.removeControl(this);
+ this.map = null;
+ * Method: setMap
+ * Set the map property for the control. This is done through an accessor
+ * so that subclasses can override this and take special action once
+ * they have their map variable set.
+ * Parameters:
+ * map - {<OpenLayers.Map>}
+ setMap: function(map) {
+ this.map = map;
+ this.handler.setMap(map);
+ * Method: draw
+ * The draw method is called when the control is ready to be displayed
+ * on the page. If a div has not been created one is created. Controls
+ * with a visual component will almost always want to override this method
+ * to customize the look of control.
+ * Parameters:
+ * px - {<OpenLayers.Pixel>} The top-left pixel position of the control
+ * or null.
+ * Returns:
+ * {DOMElement} A reference to the DIV DOMElement containing the control
+ draw: function (px) {
+ if (this.div == null) {
+ this.div = OpenLayers.Util.createDiv(this.id);
+ this.div.className = this.displayClass;
+ if (!this.allowSelection) {
+ this.div.className += " olControlNoSelect";
+ this.div.setAttribute("unselectable", "on", 0);
+ this.div.onselectstart = function() { return(false); };
+ if (this.title != "") {
+ this.div.title = this.title;
+ if (px != null) {
+ this.position = px.clone();
+ this.moveTo(this.position);
+ return this.div;
+ * Method: moveTo
+ * Sets the left and top style attributes to the passed in pixel
+ * coordinates.
+ * Parameters:
+ moveTo: function (px) {
+ if ((px != null) && (this.div != null)) {
+ this.div.style.left = px.x + "px";
+ this.div.style.top = px.y + "px";
+ * Method: activate
+ * Explicitly activates a control and it's associated
+ * handler if one has been set. Controls can be
+ * deactivated by calling the deactivate() method.
+ * Returns:
+ * {Boolean} True if the control was successfully activated or
+ * false if the control was already active.
+ activate: function () {
+ if (this.active) {
+ return false;
+ this.handler.activate();
+ this.active = true;
+ this.events.triggerEvent("activate");
+ return true;
+ * Method: deactivate
+ * Deactivates a control and it's associated handler if any. The exact
+ * effect of this depends on the control itself.
+ * Returns:
+ * {Boolean} True if the control was effectively deactivated or false
+ * if the control was already inactive.
+ deactivate: function () {
+ this.handler.deactivate();
+ this.active = false;
+ this.events.triggerEvent("deactivate");
+ return true;
+ return false;
+ CLASS_NAME: "OpenLayers.Control"
+OpenLayers.Control.TYPE_BUTTON = 1;
+OpenLayers.Control.TYPE_TOGGLE = 2;
+OpenLayers.Control.TYPE_TOOL = 3;
+ OpenLayers/Icon.js
+ * Class: OpenLayers.Icon
+ * The icon represents a graphical icon on the screen. Typically used in
+ * conjunction with a <OpenLayers.Marker> to represent markers on a screen.
+ * An icon has a url, size and position. It also contains an offset which
+ * allows the center point to be represented correctly. This can be
+ * provided either as a fixed offset or a function provided to calculate
+ * the desired offset.
+OpenLayers.Icon = OpenLayers.Class({
+ * Property: url
+ * {String} image url
+ url: null,
+ * Property: size
+ size: null,
+ * Property: offset
+ * {<OpenLayers.Pixel>} distance in pixels to offset the image when being rendered
+ offset: null,
+ * Property: calculateOffset
+ * {<OpenLayers.Pixel>} Function to calculate the offset (based on the size)
+ calculateOffset: null,
+ * Property: imageDiv
+ * {DOMElement}
+ imageDiv: null,
+ * Property: px
+ px: null,
+ * Constructor: OpenLayers.Icon
+ * Creates an icon, which is an image tag in a div.
+ * url - {String}
+ * offset - {<OpenLayers.Pixel>}
+ * calculateOffset - {Function}
+ initialize: function(url, size, offset, calculateOffset) {
+ this.url = url;
+ this.size = (size) ? size : new OpenLayers.Size(20,20);
+ this.offset = offset ? offset : new OpenLayers.Pixel(-(this.size.w/2), -(this.size.h/2));
+ this.calculateOffset = calculateOffset;
+ var id = OpenLayers.Util.createUniqueID("OL_Icon_");
+ this.imageDiv = OpenLayers.Util.createAlphaImageDiv(id);
+ * Method: destroy
+ * Nullify references and remove event listeners to prevent circular
+ * references and memory leaks
+ destroy: function() {
+ OpenLayers.Event.stopObservingElement(this.imageDiv.firstChild);
+ this.imageDiv.innerHTML = "";
+ this.imageDiv = null;
+ * Method: clone
+ * Returns:
+ * {<OpenLayers.Icon>} A fresh copy of the icon.
+ clone: function() {
+ return new OpenLayers.Icon(this.url,
+ this.size,
+ this.offset,
+ this.calculateOffset);
+ * Method: setSize
+ * Parameters:
+ setSize: function(size) {
+ if (size != null) {
+ this.size = size;
+ this.draw();
+ * Method: setUrl
+ * Parameters:
+ * url - {String}
+ setUrl: function(url) {
+ if (url != null) {
+ this.url = url;
+ this.draw();
+ * Method: draw
+ * Move the div to the given pixel.
+ * Parameters:
+ * Returns:
+ * {DOMElement} A new DOM Image of this icon set at the location passed-in
+ draw: function(px) {
+ OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv,
+ null,
+ null,
+ this.size,
+ this.url,
+ "absolute");
+ this.moveTo(px);
+ return this.imageDiv;
+ * Method: setOpacity
+ * Change the icon's opacity
+ * Parameters:
+ * opacity - {float}
+ setOpacity: function(opacity) {
+ OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv, null, null, null,
+ null, null, null, null, opacity);
+ * Method: moveTo
+ * move icon to passed in px.
+ * Parameters:
+ //if no px passed in, use stored location
+ if (px != null) {
+ this.px = px;
+ if (this.imageDiv != null) {
+ if (this.px == null) {
+ this.display(false);
+ } else {
+ if (this.calculateOffset) {
+ this.offset = this.calculateOffset(this.size);
+ var offsetPx = this.px.offset(this.offset);
+ OpenLayers.Util.modifyAlphaImageDiv(this.imageDiv, null, offsetPx);
+ * Method: display
+ * Hide or show the icon
+ * Parameters:
+ * display - {Boolean}
+ display: function(display) {
+ this.imageDiv.style.display = (display) ? "" : "none";
+ CLASS_NAME: "OpenLayers.Icon"
+ OpenLayers/Lang.js
+ * Namespace: OpenLayers.Lang
+ * Internationalization namespace. Contains dictionaries in various languages
+ * and methods to set and get the current language.
+OpenLayers.Lang = {
+ * Property: code
+ * {String} Current language code to use in OpenLayers. Use the
+ * <setCode> method to set this value and the <getCode> method to
+ * retrieve it.
+ code: null,
+ * APIProperty: defaultCode
+ * {String} Default language to use when a specific language can't be
+ * found. Default is "en".
+ defaultCode: "en",
+ * APIFunction: getCode
+ * Get the current language code.
+ * Returns:
+ * The current language code.
+ getCode: function() {
+ if(!OpenLayers.Lang.code) {
+ OpenLayers.Lang.setCode();
+ return OpenLayers.Lang.code;
+ * APIFunction: setCode
+ * Set the language code for string translation. This code is used by
+ * the <OpenLayers.Lang.translate> method.
+ * Parameters-
+ * code - {String} These codes follow the IETF recommendations at
+ * http://www.ietf.org/rfc/rfc3066.txt. If no value is set, the
+ * browser's language setting will be tested. If no <OpenLayers.Lang>
+ * dictionary exists for the code, the <OpenLayers.String.defaultLang>
+ * will be used.
+ setCode: function(code) {
+ var lang;
+ if(!code) {
+ code = (OpenLayers.Util.getBrowserName() == "msie") ?
+ navigator.userLanguage : navigator.language;
+ var parts = code.split('-');
+ parts[0] = parts[0].toLowerCase();
+ if(typeof OpenLayers.Lang[parts[0]] == "object") {
+ lang = parts[0];
+ // check for regional extensions
+ if(parts[1]) {
+ var testLang = parts[0] + '-' + parts[1].toUpperCase();
+ if(typeof OpenLayers.Lang[testLang] == "object") {
+ lang = testLang;
+ if(!lang) {
+ OpenLayers.Console.warn(
+ 'Failed to find OpenLayers.Lang.' + parts.join("-") +
+ ' dictionary, falling back to default language'
+ lang = OpenLayers.Lang.defaultCode;
+ OpenLayers.Lang.code = lang;
+ * APIMethod: translate
+ * Looks up a key from a dictionary based on the current language string.
+ * The value of <getCode> will be used to determine the appropriate
+ * dictionary. Dictionaries are stored in <OpenLayers.Lang>.
+ * Parameters:
+ * key - {String} The key for an i18n string value in the dictionary.
+ * context - {Object} Optional context to be used with
+ * <OpenLayers.String.format>.
+ * Returns:
+ * {String} A internationalized string.
+ translate: function(key, context) {
+ var dictionary = OpenLayers.Lang[OpenLayers.Lang.getCode()];
+ var message = dictionary[key];
+ if(!message) {
+ // Message not found, fall back to message key
+ message = key;
+ if(context) {
+ message = OpenLayers.String.format(message, context);
+ return message;
+ * APIMethod: OpenLayers.i18n
+ * Alias for <OpenLayers.Lang.translate>. Looks up a key from a dictionary
+ * based on the current language string. The value of
+ * <OpenLayers.Lang.getCode> will be used to determine the appropriate
+ * Parameters:
+ * Returns:
+OpenLayers.i18n = OpenLayers.Lang.translate;
+ OpenLayers/Tween.js
+ * Namespace: OpenLayers.Tween
+OpenLayers.Tween = OpenLayers.Class({
+ * Constant: INTERVAL
+ * {int} Interval in milliseconds between 2 steps
+ INTERVAL: 10,
+ * APIProperty: easing
+ * {<OpenLayers.Easing>(Function)} Easing equation used for the animation
+ * Defaultly set to OpenLayers.Easing.Expo.easeOut
+ easing: null,
+ * APIProperty: begin
+ * {Object} Values to start the animation with
+ begin: null,
+ * APIProperty: finish
+ * {Object} Values to finish the animation with
+ finish: null,
+ * APIProperty: duration
+ * {int} duration of the tween (number of steps)
+ duration: null,
+ * APIProperty: callbacks
+ * {Object} An object with start, eachStep and done properties whose values
+ * are functions to be call during the animation. They are passed the
+ * current computed value as argument.
+ callbacks: null,
+ * Property: time
+ * {int} Step counter
+ time: null,
+ * Property: interval
+ * {int} Interval id returned by window.setInterval
+ interval: null,
+ * Property: playing
+ * {Boolean} Tells if the easing is currently playing
+ playing: false,
+ * Constructor: OpenLayers.Tween
+ * Creates a Tween.
+ * Parameters:
+ * easing - {<OpenLayers.Easing>(Function)} easing function method to use
+ initialize: function(easing) {
+ this.easing = (easing) ? easing : OpenLayers.Easing.Expo.easeOut;
+ * APIMethod: start
+ * Plays the Tween, and calls the callback method on each step
+ * Parameters:
+ * begin - {Object} values to start the animation with
+ * finish - {Object} values to finish the animation with
+ * duration - {int} duration of the tween (number of steps)
+ * options - {Object} hash of options (for example callbacks (start, eachStep, done))
+ start: function(begin, finish, duration, options) {
+ this.playing = true;
+ this.begin = begin;
+ this.finish = finish;
+ this.duration = duration;
+ this.callbacks = options.callbacks;
+ this.time = 0;
+ if (this.interval) {
+ window.clearInterval(this.interval);
+ this.interval = null;
+ if (this.callbacks && this.callbacks.start) {
+ this.callbacks.start.call(this, this.begin);
+ this.interval = window.setInterval(
+ OpenLayers.Function.bind(this.play, this), this.INTERVAL);
+ * APIMethod: stop
+ * Stops the Tween, and calls the done callback
+ * Doesn't do anything if animation is already finished
+ stop: function() {
+ if (!this.playing) {
+ return;
+ if (this.callbacks && this.callbacks.done) {
+ this.callbacks.done.call(this, this.finish);
+ this.playing = false;
+ * Method: play
+ * Calls the appropriate easing method
+ play: function() {
+ var value = {};
+ for (var i in this.begin) {
+ var b = this.begin[i];
+ var f = this.finish[i];
+ if (b == null || f == null || isNaN(b) || isNaN(f)) {
+ OpenLayers.Console.error('invalid value for Tween');
+ var c = f - b;
+ value[i] = this.easing.apply(this, [this.time, b, c, this.duration]);
+ this.time++;
+ if (this.callbacks && this.callbacks.eachStep) {
+ this.callbacks.eachStep.call(this, value);
+ if (this.time > this.duration) {
+ * Create empty functions for all easing methods.
+ CLASS_NAME: "OpenLayers.Tween"
+ * Namespace: OpenLayers.Easing
+ * Credits:
+ * Easing Equations by Robert Penner, <http://www.robertpenner.com/easing/>
+OpenLayers.Easing = {
+ CLASS_NAME: "OpenLayers.Easing"
+ * Namespace: OpenLayers.Easing.Linear
+OpenLayers.Easing.Linear = {
+ * Function: easeIn
+ * Parameters:
+ * t - {Float} time
+ * b - {Float} beginning position
+ * c - {Float} total change
+ * d - {Float} duration of the transition
+ easeIn: function(t, b, c, d) {
+ return c*t/d + b;
+ * Function: easeOut
+ * Parameters:
+ easeOut: function(t, b, c, d) {
+ return c*t/d + b;
+ * Function: easeInOut
+ * Parameters:
+ easeInOut: function(t, b, c, d) {
+ return c*t/d + b;
+ CLASS_NAME: "OpenLayers.Easing.Linear"
+ * Namespace: OpenLayers.Easing.Expo
+OpenLayers.Easing.Expo = {
+ * Parameters:
+ return (t==0) ? b : c * Math.pow(2, 10 * (t/d - 1)) + b;
+ * Parameters:
+ return (t==d) ? b+c : c * (-Math.pow(2, -10 * t/d) + 1) + b;
+ * Parameters:
+ if (t==0) return b;
+ if (t==d) return b+c;
+ if ((t/=d/2) < 1) return c/2 * Math.pow(2, 10 * (t - 1)) + b;
+ return c/2 * (-Math.pow(2, -10 * --t) + 2) + b;
+ CLASS_NAME: "OpenLayers.Easing.Expo"
+ * Namespace: OpenLayers.Easing.Quad
+OpenLayers.Easing.Quad = {
+ * Parameters:
+ return c*(t/=d)*t + b;
+ * Parameters:
+ return -c *(t/=d)*(t-2) + b;
+ * Parameters:
+ if ((t/=d/2) < 1) return c/2*t*t + b;
+ return -c/2 * ((--t)*(t-2) - 1) + b;
+ CLASS_NAME: "OpenLayers.Easing.Quad"
+ OpenLayers/Control/ArgParser.js
+ * @requires OpenLayers/Control.js
+ * Class: OpenLayers.Control.ArgParser
+ * Inherits from:
+ * - <OpenLayers.Control>
+OpenLayers.Control.ArgParser = OpenLayers.Class(OpenLayers.Control, {
+ * Parameter: center
+ center: null,
+ * Parameter: zoom
+ * {int}
+ zoom: null,
+ * Parameter: layers
+ * {Array(<OpenLayers.Layer>)}
+ layers: null,
+ * APIProperty: displayProjection
+ * {<OpenLayers.Projection>} Requires proj4js support.
+ * Projection used when reading the coordinates from the URL. This will
+ * reproject the map coordinates from the URL into the map's
+ * projection.
+ * If you are using this functionality, be aware that any permalink
+ * which is added to the map will determine the coordinate type which
+ * is read from the URL, which means you should not add permalinks with
+ * different displayProjections to the same map.
+ displayProjection: null,
+ * Constructor: OpenLayers.Control.ArgParser
+ * Parameters:
+ OpenLayers.Control.prototype.initialize.apply(this, arguments);
+ * Method: setMap
+ * Parameters:
+ OpenLayers.Control.prototype.setMap.apply(this, arguments);
+ //make sure we dont already have an arg parser attached
+ for(var i=0; i< this.map.controls.length; i++) {
+ var control = this.map.controls[i];
+ if ( (control != this) &&
+ (control.CLASS_NAME == "OpenLayers.Control.ArgParser") ) {
+ // If a second argparser is added to the map, then we
+ // override the displayProjection to be the one added to the
+ // map.
+ if (control.displayProjection != this.displayProjection) {
+ this.displayProjection = control.displayProjection;
+ break;
+ if (i == this.map.controls.length) {
+ var args = OpenLayers.Util.getParameters();
+ // Be careful to set layer first, to not trigger unnecessary layer loads
+ if (args.layers) {
+ this.layers = args.layers;
+ // when we add a new layer, set its visibility
+ this.map.events.register('addlayer', this,
+ this.configureLayers);
+ this.configureLayers();
+ if (args.lat && args.lon) {
+ this.center = new OpenLayers.LonLat(parseFloat(args.lon),
+ parseFloat(args.lat));
+ if (args.zoom) {
+ this.zoom = parseInt(args.zoom);
+ // when we add a new baselayer to see when we can set the center
+ this.map.events.register('changebaselayer', this,
+ this.setCenter);
+ this.setCenter();
+ * Method: setCenter
+ * As soon as a baseLayer has been loaded, we center and zoom
+ * ...and remove the handler.
+ setCenter: function() {
+ if (this.map.baseLayer) {
+ //dont need to listen for this one anymore
+ this.map.events.unregister('changebaselayer', this,
+ this.setCenter);
+ if (this.displayProjection) {
+ this.center.transform(this.displayProjection,
+ this.map.getProjectionObject());
+ this.map.setCenter(this.center, this.zoom);
+ * Method: configureLayers
+ * As soon as all the layers are loaded, cycle through them and
+ * hide or show them.
+ configureLayers: function() {
+ if (this.layers.length == this.map.layers.length) {
+ this.map.events.unregister('addlayer', this, this.configureLayers);
+ for(var i=0; i < this.layers.length; i++) {
+ var layer = this.map.layers[i];
+ var c = this.layers.charAt(i);
+ if (c == "B") {
+ this.map.setBaseLayer(layer);
+ } else if ( (c == "T") || (c == "F") ) {
+ layer.setVisibility(c == "T");
+ CLASS_NAME: "OpenLayers.Control.ArgParser"
+ OpenLayers/Control/MousePosition.js
+ * Class: OpenLayers.Control.MousePosition
+OpenLayers.Control.MousePosition = OpenLayers.Class(OpenLayers.Control, {
+ * Property: element
+ * {DOMElement}
+ element: null,
+ * APIProperty: prefix
+ * {String}
+ prefix: '',
+ * APIProperty: separator
+ * {String}
+ separator: ', ',
+ * APIProperty: suffix
+ * {String}
+ suffix: '',
+ * APIProperty: numDigits
+ * {Integer}
+ numdigits: 5,
+ * APIProperty: granularity
+ * {Integer}
+ granularity: 10,
+ * Property: lastXy
+ lastXy: null,
+ * {<OpenLayers.Projection>} A projection that the
+ * mousecontrol will display.
+ * Constructor: OpenLayers.Control.MousePosition
+ * Parameters:
+ * options - {DOMElement} Options for control.
+ initialize: function(options) {
+ * Method: destroy
+ if (this.map) {
+ this.map.events.unregister('mousemove', this, this.redraw);
+ OpenLayers.Control.prototype.destroy.apply(this, arguments);
+ * Method: draw
+ * {DOMElement}
+ draw: function() {
+ OpenLayers.Control.prototype.draw.apply(this, arguments);
+ if (!this.element) {
+ this.div.left = "";
+ this.div.top = "";
+ this.element = this.div;
+ this.redraw();
+ return this.div;
+ * Method: redraw
+ redraw: function(evt) {
+ var lonLat;
+ if (evt == null) {
+ lonLat = new OpenLayers.LonLat(0, 0);
+ } else {
+ if (this.lastXy == null ||
+ Math.abs(evt.xy.x - this.lastXy.x) > this.granularity ||
+ Math.abs(evt.xy.y - this.lastXy.y) > this.granularity)
+ this.lastXy = evt.xy;
+ return;
+ lonLat = this.map.getLonLatFromPixel(evt.xy);
+ if (!lonLat) {
+ // map has not yet been properly initialized
+ return;
+ lonLat.transform(this.map.getProjectionObject(),
+ this.displayProjection );
+ var newHtml = this.formatOutput(lonLat);
+ if (newHtml != this.element.innerHTML) {
+ this.element.innerHTML = newHtml;
+ * Method: formatOutput
+ * Override to provide custom display output
+ * Parameters:
+ * lonLat - {<OpenLayers.LonLat>} Location to display
+ formatOutput: function(lonLat) {
+ var digits = parseInt(this.numdigits);
+ var newHtml =
+ this.prefix +
+ lonLat.lon.toFixed(digits) +
+ this.separator +
+ lonLat.lat.toFixed(digits) +
+ this.suffix;
+ return newHtml;
+ * Method: setMap
+ setMap: function() {
+ this.map.events.register( 'mousemove', this, this.redraw);
+ CLASS_NAME: "OpenLayers.Control.MousePosition"
+ OpenLayers/Control/PanZoom.js
+ * Class: OpenLayers.Control.PanZoom
+ * Inherits from:
+OpenLayers.Control.PanZoom = OpenLayers.Class(OpenLayers.Control, {
+ * APIProperty: slideFactor
+ * {Integer} Number of pixels by which we'll pan the map in any direction
+ * on clicking the arrow buttons.
+ slideFactor: 50,
+ * Property: buttons
+ * {Array(DOMElement)} Array of Button Divs
+ buttons: null,
+ * Property: position
+ position: null,
+ * Constructor: OpenLayers.Control.PanZoom
+ * Parameters:
+ this.position = new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,
+ OpenLayers.Control.PanZoom.Y);
+ * APIMethod: destroy
+ while(this.buttons.length) {
+ var btn = this.buttons.shift();
+ btn.map = null;
+ OpenLayers.Event.stopObservingElement(btn);
+ this.buttons = null;
+ this.position = null;
+ * Method: draw
+ * Parameters:
+ * Returns:
+ * {DOMElement} A reference to the container div for the PanZoom control.
+ // initialize our internal div
+ px = this.position;
+ // place the controls
+ this.buttons = [];
+ var sz = new OpenLayers.Size(18,18);
+ var centered = new OpenLayers.Pixel(px.x+sz.w/2, px.y);
+ this._addButton("panup", "north-mini.png", centered, sz);
+ px.y = centered.y+sz.h;
+ this._addButton("panleft", "west-mini.png", px, sz);
+ this._addButton("panright", "east-mini.png", px.add(sz.w, 0), sz);
+ this._addButton("pandown", "south-mini.png",
+ centered.add(0, sz.h*2), sz);
+ this._addButton("zoomin", "zoom-plus-mini.png",
+ centered.add(0, sz.h*3+5), sz);
+ this._addButton("zoomworld", "zoom-world-mini.png",
+ centered.add(0, sz.h*4+5), sz);
+ this._addButton("zoomout", "zoom-minus-mini.png",
+ centered.add(0, sz.h*5+5), sz);
+ return this.div;
+ * Method: _addButton
+ * Parameters:
+ * id - {String}
+ * img - {String}
+ * xy - {<OpenLayers.Pixel>}
+ * sz - {<OpenLayers.Size>}
+ * Returns:
+ * {DOMElement} A Div (an alphaImageDiv, to be precise) that contains the
+ * image of the button, and has all the proper event handlers set.
+ _addButton:function(id, img, xy, sz) {
+ var imgLocation = OpenLayers.Util.getImagesLocation() + img;
+ var btn = OpenLayers.Util.createAlphaImageDiv(
+ "OpenLayers_Control_PanZoom_" + id,
+ xy, sz, imgLocation, "absolute");
+ //we want to add the outer div
+ this.div.appendChild(btn);
+ OpenLayers.Event.observe(btn, "mousedown",
+ OpenLayers.Function.bindAsEventListener(this.buttonDown, btn));
+ OpenLayers.Event.observe(btn, "dblclick",
+ OpenLayers.Function.bindAsEventListener(this.doubleClick, btn));
+ OpenLayers.Event.observe(btn, "click",
+ btn.action = id;
+ btn.map = this.map;
+ btn.slideFactor = this.slideFactor;
+ //we want to remember/reference the outer div
+ this.buttons.push(btn);
+ return btn;
+ * Method: doubleClick
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Boolean}
+ doubleClick: function (evt) {
+ OpenLayers.Event.stop(evt);
+ return false;
+ * Method: buttonDown
+ * Parameters:
+ * evt - {Event}
+ buttonDown: function (evt) {
+ if (!OpenLayers.Event.isLeftClick(evt)) {
+ return;
+ switch (this.action) {
+ case "panup":
+ this.map.pan(0, -this.slideFactor);
+ break;
+ case "pandown":
+ this.map.pan(0, this.slideFactor);
+ break;
+ case "panleft":
+ this.map.pan(-this.slideFactor, 0);
+ break;
+ case "panright":
+ this.map.pan(this.slideFactor, 0);
+ break;
+ case "zoomin":
+ this.map.zoomIn();
+ break;
+ case "zoomout":
+ this.map.zoomOut();
+ break;
+ case "zoomworld":
+ this.map.zoomToMaxExtent();
+ break;
+ CLASS_NAME: "OpenLayers.Control.PanZoom"
+ * Constant: X
+ * {Integer}
+OpenLayers.Control.PanZoom.X = 4;
+ * Constant: Y
+ * {Integer}
+OpenLayers.Control.PanZoom.Y = 4;
+ OpenLayers/Control/ScaleLine.js
+/* Copyright (c) 2006-2007 MetaCarta, Inc., published under a modified BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
+ * for the full text of the license. */
+ * Class: OpenLayers.Control.ScaleLine
+ * Display a small line indicator representing the current map scale on the map.
+ * Inherits from:
+ * Is a very close copy of:
+ * - <OpenLayers.Control.Scale>
+OpenLayers.Control.ScaleLine = OpenLayers.Class(OpenLayers.Control, {
+ * Property: maxWidth
+ * {Integer} Maximum width of the scale line in pixels. Default is 100.
+ maxWidth: 100,
+ * Property: topOutUnits
+ * {String} Units for zoomed out on top bar. Default is km.
+ topOutUnits: "km",
+ * Property: topInUnits
+ * {String} Units for zoomed in on top bar. Default is m.
+ topInUnits: "m",
+ * Property: bottomOutUnits
+ * {String} Units for zoomed out on bottom bar. Default is mi.
+ bottomOutUnits: "mi",
+ * Property: bottomInUnits
+ * {String} Units for zoomed in on bottom bar. Default is ft.
+ bottomInUnits: "ft",
+ * Property: eTop
+ * {DOMElement}
+ eTop: null,
+ * Property: eBottom
+ * {DOMElement}
+ eBottom:null,
+ * Constructor: OpenLayers.ScaleLine
+ * Create a new scale line control.
+ * Parameters:
+ * options - {Object} An optional object whose properties will be used
+ * to extend the control.
+ OpenLayers.Control.prototype.initialize.apply(this, [options]);
+ * Method: draw
+ * Returns:
+ * {DOMElement}
+ if (!this.eTop) {
+ this.div.style.display = "block";
+ this.div.style.position = "absolute";
+ // stick in the top bar
+ this.eTop = document.createElement("div");
+ this.eTop.className = this.displayClass + "Top";
+ var theLen = this.topInUnits.length;
+ this.div.appendChild(this.eTop);
+ if((this.topOutUnits == "") || (this.topInUnits == "")) {
+ this.eTop.style.visibility = "hidden";
+ } else {
+ this.eTop.style.visibility = "visible";
+ // and the bottom bar
+ this.eBottom = document.createElement("div");
+ this.eBottom.className = this.displayClass + "Bottom";
+ this.div.appendChild(this.eBottom);
+ if((this.bottomOutUnits == "") || (this.bottomInUnits == "")) {
+ this.eBottom.style.visibility = "hidden";
+ } else {
+ this.eBottom.style.visibility = "visible";
+ this.map.events.register('moveend', this, this.update);
+ this.update();
+ return this.div;
+ * Method: getBarLen
+ * Given a number, round it down to the nearest 1,2,5 times a power of 10.
+ * That seems a fairly useful set of number groups to use.
+ * Parameters:
+ * maxLen - {float} the number we're rounding down from
+ * Returns:
+ * {Float} the rounded number (less than or equal to maxLen)
+ getBarLen: function(maxLen) {
+ // nearest power of 10 lower than maxLen
+ var digits = parseInt(Math.log(maxLen) / Math.log(10));
+ var pow10 = Math.pow(10, digits);
+ // ok, find first character
+ var firstChar = parseInt(maxLen / pow10);
+ // right, put it into the correct bracket
+ var barLen;
+ if(firstChar > 5) {
+ barLen = 5;
+ } else if(firstChar > 2) {
+ barLen = 2;
+ } else {
+ barLen = 1;
+ // scale it up the correct power of 10
+ return barLen * pow10;
+ * Method: update
+ * Update the size of the bars, and the labels they contain.
+ update: function() {
+ var res = this.map.getResolution();
+ if (!res) {
+ return;
+ var curMapUnits = this.map.units;
+ var inches = OpenLayers.INCHES_PER_UNIT;
+ // convert maxWidth to map units
+ var maxSizeData = this.maxWidth * res * inches[curMapUnits];
+ // decide whether to use large or small scale units
+ var topUnits;
+ var bottomUnits;
+ if(maxSizeData > 100000) {
+ topUnits = this.topOutUnits;
+ bottomUnits = this.bottomOutUnits;
+ } else {
+ topUnits = this.topInUnits;
+ bottomUnits = this.bottomInUnits;
+ // and to map units units
+ var topMax = maxSizeData / inches[topUnits];
+ var bottomMax = maxSizeData / inches[bottomUnits];
+ // now trim this down to useful block length
+ var topRounded = this.getBarLen(topMax);
+ var bottomRounded = this.getBarLen(bottomMax);
+ // and back to display units
+ topMax = topRounded / inches[curMapUnits] * inches[topUnits];
+ bottomMax = bottomRounded / inches[curMapUnits] * inches[bottomUnits];
+ // and to pixel units
+ var topPx = topMax / res;
+ var bottomPx = bottomMax / res;
+ // now set the pixel widths
+ this.eTop.style.width = Math.round(topPx) + "px";
+ this.eBottom.style.width = Math.round(bottomPx) + "px";
+ // and the values inside them
+ this.eTop.innerHTML = topRounded + " " + topUnits;
+ this.eBottom.innerHTML = bottomRounded + " " + bottomUnits ;
+ CLASS_NAME: "OpenLayers.Control.ScaleLine"
+ OpenLayers/Events.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Util.js
+ * Namespace: OpenLayers.Event
+ * Utility functions for event handling.
+OpenLayers.Event = {
+ * Property: observers
+ * {Object} A hashtable cache of the event observers. Keyed by
+ * element._eventCacheID
+ observers: false,
+ * Constant: KEY_BACKSPACE
+ * {int}
+ KEY_BACKSPACE: 8,
+ * Constant: KEY_TAB
+ * {int}
+ KEY_TAB: 9,
+ * Constant: KEY_RETURN
+ * {int}
+ KEY_RETURN: 13,
+ * Constant: KEY_ESC
+ * {int}
+ KEY_ESC: 27,
+ * Constant: KEY_LEFT
+ * {int}
+ KEY_LEFT: 37,
+ * Constant: KEY_UP
+ * {int}
+ KEY_UP: 38,
+ * Constant: KEY_RIGHT
+ * {int}
+ KEY_RIGHT: 39,
+ * Constant: KEY_DOWN
+ * {int}
+ KEY_DOWN: 40,
+ * Constant: KEY_DELETE
+ * {int}
+ KEY_DELETE: 46,
+ * Method: element
+ * Cross browser event element detection.
+ * Parameters:
+ * event - {Event}
+ * Returns:
+ * {DOMElement} The element that caused the event
+ element: function(event) {
+ return event.target || event.srcElement;
+ * Method: isLeftClick
+ * Determine whether event was caused by a left click.
+ * Parameters:
+ * event - {Event}
+ * Returns:
+ * {Boolean}
+ isLeftClick: function(event) {
+ return (((event.which) && (event.which == 1)) ||
+ ((event.button) && (event.button == 1)));
+ * Method: stop
+ * Stops an event from propagating.
+ * Parameters:
+ * event - {Event}
+ * allowDefault - {Boolean} If true, we stop the event chain but
+ * still allow the default browser
+ * behaviour (text selection, radio-button
+ * clicking, etc)
+ * Default false
+ stop: function(event, allowDefault) {
+ if (!allowDefault) {
+ if (event.preventDefault) {
+ event.preventDefault();
+ } else {
+ event.returnValue = false;
+ if (event.stopPropagation) {
+ event.stopPropagation();
+ } else {
+ event.cancelBubble = true;
+ * Method: findElement
+ * Parameters:
+ * event - {Event}
+ * tagName - {String}
+ * Returns:
+ * {DOMElement} The first node with the given tagName, starting from the
+ * node the event was triggered on and traversing the DOM upwards
+ findElement: function(event, tagName) {
+ var element = OpenLayers.Event.element(event);
+ while (element.parentNode && (!element.tagName ||
+ (element.tagName.toUpperCase() != tagName.toUpperCase()))){
+ element = element.parentNode;
+ return element;
+ * Method: observe
+ * Parameters:
+ * elementParam - {DOMElement || String}
+ * name - {String}
+ * observer - {function}
+ * useCapture - {Boolean}
+ observe: function(elementParam, name, observer, useCapture) {
+ var element = OpenLayers.Util.getElement(elementParam);
+ useCapture = useCapture || false;
+ if (name == 'keypress' &&
+ (navigator.appVersion.match(/Konqueror|Safari|KHTML/)
+ || element.attachEvent)) {
+ name = 'keydown';
+ //if observers cache has not yet been created, create it
+ if (!this.observers) {
+ this.observers = {};
+ //if not already assigned, make a new unique cache ID
+ if (!element._eventCacheID) {
+ var idPrefix = "eventCacheID_";
+ if (element.id) {
+ idPrefix = element.id + "_" + idPrefix;
+ element._eventCacheID = OpenLayers.Util.createUniqueID(idPrefix);
+ var cacheID = element._eventCacheID;
+ //if there is not yet a hash entry for this element, add one
+ if (!this.observers[cacheID]) {
+ this.observers[cacheID] = [];
+ //add a new observer to this element's list
+ this.observers[cacheID].push({
+ 'element': element,
+ 'name': name,
+ 'observer': observer,
+ 'useCapture': useCapture
+ //add the actual browser event listener
+ if (element.addEventListener) {
+ element.addEventListener(name, observer, useCapture);
+ } else if (element.attachEvent) {
+ element.attachEvent('on' + name, observer);
+ * Method: stopObservingElement
+ * Given the id of an element to stop observing, cycle through the
+ * element's cached observers, calling stopObserving on each one,
+ * skipping those entries which can no longer be removed.
+ * parameters:
+ stopObservingElement: function(elementParam) {
+ this._removeElementObservers(OpenLayers.Event.observers[cacheID]);
+ * Method: _removeElementObservers
+ * Parameters:
+ * elementObservers - {Array(Object)} Array of (element, name,
+ * observer, usecapture) objects,
+ * taken directly from hashtable
+ _removeElementObservers: function(elementObservers) {
+ if (elementObservers) {
+ for(var i = elementObservers.length-1; i >= 0; i--) {
+ var entry = elementObservers[i];
+ var args = new Array(entry.element,
+ entry.name,
+ entry.observer,
+ entry.useCapture);
+ var removed = OpenLayers.Event.stopObserving.apply(this, args);
+ * Parameters:
+ * name - {String}
+ * Returns:
+ * {Boolean} Whether or not the event observer was removed
+ stopObserving: function(elementParam, name, observer, useCapture) {
+ if (name == 'keypress') {
+ if ( navigator.appVersion.match(/Konqueror|Safari|KHTML/) ||
+ element.detachEvent) {
+ name = 'keydown';
+ // find element's entry in this.observers cache and remove it
+ var foundEntry = false;
+ var elementObservers = OpenLayers.Event.observers[cacheID];
+ // find the specific event type in the element's list
+ var i=0;
+ while(!foundEntry && i < elementObservers.length) {
+ var cacheEntry = elementObservers[i];
+ if ((cacheEntry.name == name) &&
+ (cacheEntry.observer == observer) &&
+ (cacheEntry.useCapture == useCapture)) {
+ elementObservers.splice(i, 1);
+ if (elementObservers.length == 0) {
+ delete OpenLayers.Event.observers[cacheID];
+ foundEntry = true;
+ break;
+ i++;
+ //actually remove the event listener from browser
+ if (foundEntry) {
+ if (element.removeEventListener) {
+ element.removeEventListener(name, observer, useCapture);
+ } else if (element && element.detachEvent) {
+ element.detachEvent('on' + name, observer);
+ return foundEntry;
+ * Method: unloadCache
+ * Cycle through all the element entries in the events cache and call
+ * stopObservingElement on each.
+ unloadCache: function() {
+ // check for OpenLayers.Event before checking for observers, because
+ // OpenLayers.Event may be undefined in IE if no map instance was
+ // created
+ if (OpenLayers.Event && OpenLayers.Event.observers) {
+ for (var cacheID in OpenLayers.Event.observers) {
+ OpenLayers.Event._removeElementObservers.apply(this,
+ [elementObservers]);
+ OpenLayers.Event.observers = false;
+ CLASS_NAME: "OpenLayers.Event"
+/* prevent memory leaks in IE */
+OpenLayers.Event.observe(window, 'unload', OpenLayers.Event.unloadCache, false);
+// FIXME: Remove this in 3.0. In 3.0, Event.stop will no longer be provided
+// by OpenLayers.
+if (window.Event) {
+ OpenLayers.Util.applyDefaults(window.Event, OpenLayers.Event);
+} else {
+ var Event = OpenLayers.Event;
+ * Class: OpenLayers.Events
+OpenLayers.Events = OpenLayers.Class({
+ * Constant: BROWSER_EVENTS
+ * {Array(String)} supported events
+ BROWSER_EVENTS: [
+ "mouseover", "mouseout",
+ "mousedown", "mouseup", "mousemove",
+ "click", "dblclick",
+ "resize", "focus", "blur"
+ * Property: listeners
+ * {Object} Hashtable of Array(Function): events listener functions
+ listeners: null,
+ * Property: object
+ * {Object} the code object issuing application events
+ object: null,
+ * {DOMElement} the DOM element receiving browser events
+ element: null,
+ * Property: eventTypes
+ * {Array(String)} list of support application events
+ eventTypes: null,
+ * Property: eventHandler
+ * {Function} bound event handler attached to elements
+ eventHandler: null,
+ * APIProperty: fallThrough
+ * {Boolean}
+ fallThrough: null,
+ * Constructor: OpenLayers.Events
+ * Construct an OpenLayers.Events object.
+ * Parameters:
+ * object - {Object} The js object to which this Events object is being
+ * added element - {DOMElement} A dom element to respond to browser events
+ * eventTypes - {Array(String)} Array of custom application events
+ * fallThrough - {Boolean} Allow events to fall through after these have
+ * been handled?
+ initialize: function (object, element, eventTypes, fallThrough) {
+ this.object = object;
+ this.element = element;
+ this.eventTypes = eventTypes;
+ this.fallThrough = fallThrough;
+ this.listeners = {};
+ // keep a bound copy of handleBrowserEvent() so that we can
+ // pass the same function to both Event.observe() and .stopObserving()
+ this.eventHandler = OpenLayers.Function.bindAsEventListener(
+ this.handleBrowserEvent, this
+ // if eventTypes is specified, create a listeners list for each
+ // custom application event.
+ if (this.eventTypes != null) {
+ for (var i = 0; i < this.eventTypes.length; i++) {
+ this.addEventType(this.eventTypes[i]);
+ // if a dom element is specified, add a listeners list
+ // for browser events on the element and register them
+ if (this.element != null) {
+ this.attachToElement(element);
+ if (this.element) {
+ OpenLayers.Event.stopObservingElement(this.element);
+ this.element = null;
+ this.listeners = null;
+ this.object = null;
+ this.eventTypes = null;
+ this.fallThrough = null;
+ this.eventHandler = null;
+ * APIMethod: addEventType
+ * Add a new event type to this events object.
+ * If the event type has already been added, do nothing.
+ * Parameters:
+ * eventName - {String}
+ addEventType: function(eventName) {
+ if (!this.listeners[eventName]) {
+ this.listeners[eventName] = [];
+ * Method: attachToElement
+ * Parameters:
+ * element - {HTMLDOMElement} a DOM element to attach browser events to
+ attachToElement: function (element) {
+ for (var i = 0; i < this.BROWSER_EVENTS.length; i++) {
+ var eventType = this.BROWSER_EVENTS[i];
+ // every browser event has a corresponding application event
+ // (whether it's listened for or not).
+ this.addEventType(eventType);
+ // use Prototype to register the event cross-browser
+ OpenLayers.Event.observe(element, eventType, this.eventHandler);
+ // disable dragstart in IE so that mousedown/move/up works normally
+ OpenLayers.Event.observe(element, "dragstart", OpenLayers.Event.stop);
+ * Method: on
+ * Convenience method for registering listeners with a common scope.
+ * Example use:
+ * (code)
+ * events.on({
+ * "loadstart": loadStartListener,
+ * "loadend": loadEndListener,
+ * scope: object
+ * (end)
+ on: function(object) {
+ for(var type in object) {
+ if(type != "scope") {
+ this.register(type, object.scope, object[type]);
+ * APIMethod: register
+ * Register an event on the events object.
+ * When the event is triggered, the 'func' function will be called, in the
+ * context of 'obj'. Imagine we were to register an event, specifying an
+ * OpenLayers.Bounds Object as 'obj'. When the event is triggered, the
+ * context in the callback function will be our Bounds object. This means
+ * that within our callback function, we can access the properties and
+ * methods of the Bounds object through the "this" variable. So our
+ * callback could execute something like:
+ * : leftStr = "Left: " + this.left;
+ * or
+ * : centerStr = "Center: " + this.getCenterLonLat();
+ * Parameters:
+ * type - {String} Name of the event to register
+ * obj - {Object} The object to bind the context to for the callback#.
+ * If no object is specified, default is the Events's
+ * 'object' property.
+ * func - {Function} The callback function. If no callback is
+ * specified, this function does nothing.
+ register: function (type, obj, func) {
+ if (func != null &&
+ ((this.eventTypes && OpenLayers.Util.indexOf(this.eventTypes, type) != -1) ||
+ OpenLayers.Util.indexOf(this.BROWSER_EVENTS, type) != -1)) {
+ if (obj == null) {
+ obj = this.object;
+ var listeners = this.listeners[type];
+ if (listeners != null) {
+ listeners.push( {obj: obj, func: func} );
+ * APIMethod: registerPriority
+ * Same as register() but adds the new listener to the *front* of the
+ * events queue instead of to the end.
+ * TODO: get rid of this in 3.0 - Decide whether listeners should be
+ * called in the order they were registered or in reverse order.
+ * Parameters:
+ registerPriority: function (type, obj, func) {
+ if (func != null) {
+ listeners.unshift( {obj: obj, func: func} );
+ * Method: un
+ * Convenience method for unregistering listeners with a common scope.
+ * Example use:
+ * (code)
+ * events.un({
+ * scope: object
+ * (end)
+ un: function(object) {
+ this.unregister(type, object.scope, object[type]);
+ * APIMethod: unregister
+ * Parameters:
+ * type - {String}
+ * obj - {Object} If none specified, defaults to this.object
+ unregister: function (type, obj, func) {
+ for (var i = 0; i < listeners.length; i++) {
+ if (listeners[i].obj == obj && listeners[i].func == func) {
+ listeners.splice(i, 1);
+ break;
+ * Method: remove
+ * Remove all listeners for a given event type. If type is not registered,
+ * does nothing.
+ * Parameters:
+ * type - {String}
+ remove: function(type) {
+ if (this.listeners[type] != null) {
+ this.listeners[type] = [];
+ * APIMethod: triggerEvent
+ * Trigger a specified registered event.
+ * Parameters:
+ * type - {String}
+ * evt - {Event}
+ * Returns:
+ * {Boolean} The last listener return. If a listener returns false, the
+ * chain of listeners will stop getting called.
+ triggerEvent: function (type, evt) {
+ // prep evt object with object & div references
+ evt = {};
+ evt.object = this.object;
+ evt.element = this.element;
+ if(!evt.type) {
+ evt.type = type;
+ // execute all callbacks registered for specified type
+ // get a clone of the listeners array to
+ // allow for splicing during callbacks
+ var listeners = (this.listeners[type]) ?
+ this.listeners[type].slice() : null;
+ if ((listeners != null) && (listeners.length > 0)) {
+ var continueChain;
+ var callback = listeners[i];
+ // bind the context to callback.obj
+ continueChain = callback.func.apply(callback.obj, [evt]);
+ if ((continueChain != undefined) && (continueChain == false)) {
+ // if callback returns false, execute no more callbacks.
+ break;
+ // don't fall through to other DOM elements
+ if (!this.fallThrough) {
+ OpenLayers.Event.stop(evt, true);
+ return continueChain;
+ * Method: handleBrowserEvent
+ * Basically just a wrapper to the triggerEvent() function, but takes
+ * care to set a property 'xy' on the event with the current mouse
+ * position.
+ * Parameters:
+ * evt - {Event}
+ handleBrowserEvent: function (evt) {
+ evt.xy = this.getMousePosition(evt);
+ this.triggerEvent(evt.type, evt);
+ * Method: getMousePosition
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {<OpenLayers.Pixel>} The current xy coordinate of the mouse, adjusted
+ * for offsets
+ getMousePosition: function (evt) {
+ if (!this.element.offsets) {
+ this.element.offsets = OpenLayers.Util.pagePosition(this.element);
+ this.element.offsets[0] += (document.documentElement.scrollLeft
+ || document.body.scrollLeft);
+ this.element.offsets[1] += (document.documentElement.scrollTop
+ || document.body.scrollTop);
+ (evt.clientX + (document.documentElement.scrollLeft
+ || document.body.scrollLeft)) - this.element.offsets[0]
+ - (document.documentElement.clientLeft || 0),
+ (evt.clientY + (document.documentElement.scrollTop
+ || document.body.scrollTop)) - this.element.offsets[1]
+ - (document.documentElement.clientTop || 0)
+ CLASS_NAME: "OpenLayers.Events"
+ OpenLayers/Lang/en.js
+ * @requires OpenLayers/Lang.js
+ * Namespace: OpenLayers.Lang["en"]
+ * Dictionary for English. Keys for entries are used in calls to
+ * <OpenLayers.Lang.translate>. Entry bodies are normal strings or
+ * strings formatted for use with <OpenLayers.String.format> calls.
+OpenLayers.Lang.en = {
+ 'unhandledRequest': "Unhandled request return ${statusText}",
+ 'permalink': "Permalink",
+ 'overlays': "Overlays",
+ 'baseLayer': "Base Layer",
+ 'sameProjection':
+ "The overview map only works when it is in the same projection as the main map",
+ 'readNotImplemented': "Read not implemented.",
+ 'writeNotImplemented': "Write not implemented.",
+ 'noFID': "Can't update a feature for which there is no FID.",
+ 'errorLoadingGML': "Error in loading GML file ${url}",
+ 'browserNotSupported':
+ "Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",
+ 'componentShouldBe': "addFeatures : component should be an ${geomType}",
+ // console message
+ 'getFeatureError':
+ "getFeatureFromEvent called on layer with no renderer. This usually means you " +
+ "destroyed a layer, but not some handler which is associated with it.",
+ 'minZoomLevelError':
+ "The minZoomLevel property is only intended for use " +
+ "with the FixedZoomLevels-descendent layers. That this " +
+ "wfs layer checks for minZoomLevel is a relic of the" +
+ "past. We cannot, however, remove it without possibly " +
+ "breaking OL based applications that may depend on it." +
+ " Therefore we are deprecating it -- the minZoomLevel " +
+ "check below will be removed at 3.0. Please instead " +
+ "use min/max resolution setting as described here: " +
+ "http://trac.openlayers.org/wiki/SettingZoomLevels",
+ 'commitSuccess': "WFS Transaction: SUCCESS ${response}",
+ 'commitFailed': "WFS Transaction: FAILED ${response}",
+ 'googleWarning':
+ "The Google Layer was unable to load correctly.<br><br>" +
+ "To get rid of this message, select a new BaseLayer " +
+ "in the layer switcher in the upper-right corner.<br><br>" +
+ "Most likely, this is because the Google Maps library " +
+ "script was either not included, or does not contain the " +
+ "correct API key for your site.<br><br>" +
+ "Developers: For help getting this working correctly, " +
+ "<a href='http://trac.openlayers.org/wiki/Google' " +
+ "target='_blank'>click here</a>",
+ 'getLayerWarning':
+ "The ${layerType} Layer was unable to load correctly.<br><br>" +
+ "Most likely, this is because the ${layerLib} library " +
+ "script was either not correctly included.<br><br>" +
+ "<a href='http://trac.openlayers.org/wiki/${layerLib}' " +
+ 'scale': "Scale = 1 : ${scaleDenom}",
+ 'layerAlreadyAdded':
+ "You tried to add the layer: ${layerName} to the map, but it has already been added",
+ 'reprojectDeprecated':
+ "You are using the 'reproject' option " +
+ "on the ${layerName} layer. This option is deprecated: " +
+ "its use was designed to support displaying data over commercial " +
+ "basemaps, but that functionality should now be achieved by using " +
+ "Spherical Mercator support. More information is available from " +
+ "http://trac.openlayers.org/wiki/SphericalMercator.",
+ 'methodDeprecated':
+ "This method has been deprecated and will be removed in 3.0. " +
+ "Please use ${newMethod} instead.",
+ 'boundsAddError': "You must pass both x and y values to the add function.",
+ 'lonlatAddError': "You must pass both lon and lat values to the add function.",
+ 'pixelAddError': "You must pass both x and y values to the add function.",
+ 'unsupportedGeometryType': "Unsupported geometry type: ${geomType}",
+ 'pagePositionFailed':
+ "OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",
+ 'end': ''
+ OpenLayers/Projection.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under a modified BSD license.
+ * Class: OpenLayers.Projection
+ * Class for coordinate transforms between coordinate systems.
+ * Depends on the proj4js library. If proj4js is not available,
+ * then this is just an empty stub.
+OpenLayers.Projection = OpenLayers.Class({
+ * Property: proj
+ * {Object} Proj4js.Proj instance.
+ proj: null,
+ * Property: projCode
+ * {String}
+ projCode: null,
+ * Constructor: OpenLayers.Projection
+ * This class offers several methods for interacting with a wrapped
+ * pro4js projection object.
+ * Parameters:
+ * options - {Object} An optional object with properties to set on the
+ * format
+ * Returns:
+ * {<OpenLayers.Projection>} A projection object.
+ initialize: function(projCode, options) {
+ this.projCode = projCode;
+ if (window.Proj4js) {
+ this.proj = new Proj4js.Proj(projCode);
+ * APIMethod: getCode
+ * Get the string SRS code.
+ * Returns:
+ * {String} The SRS code.
+ return this.proj ? this.proj.srsCode : this.projCode;
+ * APIMethod: getUnits
+ * Get the units string for the projection -- returns null if
+ * proj4js is not available.
+ * Returns:
+ * {String} The units abbreviation.
+ getUnits: function() {
+ return this.proj ? this.proj.units : null;
+ * Method: toString
+ * Convert projection to string (getCode wrapper).
+ * Returns:
+ * {String} The projection code.
+ toString: function() {
+ return this.getCode();
+ * Method: equals
+ * Test equality of two projection instances. Determines equality based
+ * soley on the projection code.
+ * Returns:
+ * {Boolean} The two projections are equivalent.
+ equals: function(projection) {
+ if (projection && projection.getCode) {
+ return this.getCode() == projection.getCode();
+ } else {
+ return false;
+ /* Method: destroy
+ * Destroy projection object.
+ delete this.proj;
+ delete this.projCode;
+ CLASS_NAME: "OpenLayers.Projection"
+ * Property: transforms
+ * Transforms is an object, with from properties, each of which may
+ * have a to property. This allows you to define projections without
+ * requiring support for proj4js to be included.
+ * This object has keys which correspond to a 'source' projection object. The
+ * keys should be strings, corresponding to the projection.getCode() value.
+ * Each source projection object should have a set of destination projection
+ * keys included in the object.
+ * Each value in the destination object should be a transformation function,
+ * where the function is expected to be passed an object with a .x and a .y
+ * property. The function should return the object, with the .x and .y
+ * transformed according to the transformation function.
+ * Note - Properties on this object should not be set directly. To add a
+ * transform method to this object, use the <addTransform> method. For an
+ * example of usage, see the OpenLayers.Layer.SphericalMercator file.
+OpenLayers.Projection.transforms = {};
+ * APIMethod: addTransform
+ * Set a custom transform method between two projections. Use this method in
+ * cases where the proj4js lib is not available or where custom projections
+ * need to be handled.
+ * Parameters:
+ * from - {String} The code for the source projection
+ * to - {String} the code for the destination projection
+ * method - {Function} A function that takes a point as an argument and
+ * transforms that point from the source to the destination projection
+ * in place. The original point should be modified.
+OpenLayers.Projection.addTransform = function(from, to, method) {
+ if(!OpenLayers.Projection.transforms[from]) {
+ OpenLayers.Projection.transforms[from] = {};
+ OpenLayers.Projection.transforms[from][to] = method;
+ * APIMethod: transform
+ * Transform a point coordinate from one projection to another. Note that
+ * the input point is transformed in place.
+ * Parameters:
+ * point - {{OpenLayers.Geometry.Point> | Object} An object with x and y
+ * properties representing coordinates in those dimensions.
+ * sourceProj - {OpenLayers.Projection} Source map coordinate system
+ * destProj - {OpenLayers.Projection} Destination map coordinate system
+ * Returns:
+ * point - {object} A transformed coordinate. The original point is modified.
+OpenLayers.Projection.transform = function(point, source, dest) {
+ if (source.proj && dest.proj) {
+ point = Proj4js.transform(source.proj, dest.proj, point);
+ } else if (source && dest &&
+ OpenLayers.Projection.transforms[source.getCode()] &&
+ OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]) {
+ OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);
+ return point;
+ OpenLayers/Tile.js
+ * Class: OpenLayers.Tile
+ * This is a class designed to designate a single tile, however
+ * it is explicitly designed to do relatively little. Tiles store
+ * information about themselves -- such as the URL that they are related
+ * to, and their size - but do not add themselves to the layer div
+ * automatically, for example. Create a new tile with the
+ * <OpenLayers.Tile> constructor, or a subclass.
+ * TBD 3.0 - remove reference to url in above paragraph
+OpenLayers.Tile = OpenLayers.Class({
+ EVENT_TYPES: [ "loadstart", "loadend", "reload", "unload"],
+ * APIProperty: events
+ * {<OpenLayers.Events>} An events object that handles all
+ * events on the tile.
+ events: null,
+ * Property: id
+ * {String} null
+ id: null,
+ * Property: layer
+ * {<OpenLayers.Layer>} layer the tile is attached to
+ layer: null,
+ * Property: url
+ * {String} url of the request.
+ * TBD 3.0
+ * Deprecated. The base tile class does not need an url. This should be
+ * handled in subclasses. Does not belong here.
+ url: null,
+ * APIProperty: bounds
+ * {<OpenLayers.Bounds>} null
+ bounds: null,
+ * Property: size
+ * {<OpenLayers.Size>} null
+ size: null,
+ * {<OpenLayers.Pixel>} Top Left pixel of the tile
+ position: null,
+ * Property: isLoading
+ * {Boolean} Is the tile loading?
+ isLoading: false,
+ * Property: isBackBuffer
+ * {Boolean} Is this tile a back buffer tile?
+ isBackBuffer: false,
+ * Property: lastRatio
+ * {Float} Used in transition code only. This is the previous ratio
+ * of the back buffer tile resolution to the map resolution. Compared
+ * with the current ratio to determine if zooming occurred.
+ lastRatio: 1,
+ * Property: isFirstDraw
+ * {Boolean} Is this the first time the tile is being drawn?
+ * This is used to force resetBackBuffer to synchronize
+ * the backBufferTile with the foreground tile the first time
+ * the foreground tile loads so that if the user zooms
+ * before the layer has fully loaded, the backBufferTile for
+ * tiles that have been loaded can be used.
+ isFirstDraw: true,
+ * Property: backBufferTile
+ * {<OpenLayers.Tile>} A clone of the tile used to create transition
+ * effects when the tile is moved or changes resolution.
+ backBufferTile: null,
+ /** TBD 3.0 -- remove 'url' from the list of parameters to the constructor.
+ * there is no need for the base tile class to have a url.
+ * Constructor: OpenLayers.Tile
+ * Constructor for a new <OpenLayers.Tile> instance.
+ * Parameters:
+ * layer - {<OpenLayers.Layer>} layer that the tile will go in.
+ * position - {<OpenLayers.Pixel>}
+ * bounds - {<OpenLayers.Bounds>}
+ * url - {<String>}
+ * size - {<OpenLayers.Size>}
+ initialize: function(layer, position, bounds, url, size) {
+ this.layer = layer;
+ this.position = position.clone();
+ this.bounds = bounds.clone();
+ this.url = url;
+ this.size = size.clone();
+ //give the tile a unique id based on its BBOX.
+ this.id = OpenLayers.Util.createUniqueID("Tile_");
+ * Method: unload
+ * Call immediately before destroying if you are listening to tile
+ * events, so that counters are properly handled if tile is still
+ * loading at destroy-time. Will only fire an event if the tile is
+ * still loading.
+ unload: function() {
+ if (this.isLoading) {
+ this.isLoading = false;
+ this.events.triggerEvent("unload");
+ * Nullify references to prevent circular references and memory leaks.
+ destroy:function() {
+ if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,
+ this.layer.transitionEffect) != -1) {
+ this.layer.events.unregister("loadend", this, this.resetBackBuffer);
+ this.events.unregister('loadend', this, this.resetBackBuffer);
+ } else {
+ this.events.unregister('loadend', this, this.showTile);
+ this.layer = null;
+ this.bounds = null;
+ this.size = null;
+ /* clean up the backBufferTile if it exists */
+ if (this.backBufferTile) {
+ this.backBufferTile.destroy();
+ this.backBufferTile = null;
+ * Method: clone
+ * Parameters:
+ * obj - {<OpenLayers.Tile>} The tile to be cloned
+ * Returns:
+ * {<OpenLayers.Tile>} An exact clone of this <OpenLayers.Tile>
+ clone: function (obj) {
+ obj = new OpenLayers.Tile(this.layer,
+ this.position,
+ this.bounds,
+ this.url,
+ this.size);
+ // catch any randomly tagged-on properties
+ OpenLayers.Util.applyDefaults(obj, this);
+ return obj;
+ * Method: draw
+ * Clear whatever is currently in the tile, then return whether or not
+ * it should actually be re-drawn.
+ * Returns:
+ * {Boolean} Whether or not the tile should actually be drawn. Note that
+ * this is not really the best way of doing things, but such is
+ * the way the code has been developed. Subclasses call this and
+ * depend on the return to know if they should draw or not.
+ var maxExtent = this.layer.maxExtent;
+ var withinMaxExtent = (maxExtent &&
+ this.bounds.intersectsBounds(maxExtent, false));
+ // The only case where we *wouldn't* want to draw the tile is if the
+ // tile is outside its layer's maxExtent.
+ var drawTile = (withinMaxExtent || this.layer.displayOutsideMaxExtent);
+ if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS, this.layer.transitionEffect) != -1) {
+ if (drawTile) {
+ //we use a clone of this tile to create a double buffer for visual
+ //continuity. The backBufferTile is used to create transition
+ //effects while the tile in the grid is repositioned and redrawn
+ if (!this.backBufferTile) {
+ this.backBufferTile = this.clone();
+ this.backBufferTile.hide();
+ // this is important. It allows the backBuffer to place itself
+ // appropriately in the DOM. The Image subclass needs to put
+ // the backBufferTile behind the main tile so the tiles can
+ // load over top and display as soon as they are loaded.
+ this.backBufferTile.isBackBuffer = true;
+ // potentially end any transition effects when the tile loads
+ this.events.register('loadend', this, this.resetBackBuffer);
+ // clear transition back buffer tile only after all tiles in
+ // this layer have loaded to avoid visual glitches
+ this.layer.events.register("loadend", this, this.resetBackBuffer);
+ // run any transition effects
+ this.startTransition();
+ } else {
+ // if we aren't going to draw the tile, then the backBuffer should
+ // be hidden too!
+ this.backBufferTile.clear();
+ } else {
+ if (drawTile && this.isFirstDraw) {
+ this.events.register('loadend', this, this.showTile);
+ this.isFirstDraw = false;
+ this.shouldDraw = drawTile;
+ //clear tile's contents and mark as not drawn
+ this.clear();
+ return drawTile;
+ * Method: moveTo
+ * Reposition the tile.
+ * Parameters:
+ * redraw - {Boolean} Call draw method on tile after moving.
+ * Default is true
+ moveTo: function (bounds, position, redraw) {
+ if (redraw == null) {
+ redraw = true;
+ if (redraw) {
+ this.draw();
+ * Method: clear
+ * Clear the tile of any bounds/position-related data so that it can
+ * be reused in a new location. To be implemented by subclasses.
+ clear: function() {
+ // to be implemented by subclasses
+ * Method: getBoundsFromBaseLayer
+ * Take the pixel locations of the corner of the tile, and pass them to
+ * the base layer and ask for the location of those pixels, so that
+ * displaying tiles over Google works fine.
+ * Parameters:
+ * Returns:
+ getBoundsFromBaseLayer: function(position) {
+ var msg = OpenLayers.i18n('reprojectDeprecated',
+ {'layerName':this.layer.name});
+ OpenLayers.Console.warn(msg);
+ var topLeft = this.layer.map.getLonLatFromLayerPx(position);
+ var bottomRightPx = position.clone();
+ bottomRightPx.x += this.size.w;
+ bottomRightPx.y += this.size.h;
+ var bottomRight = this.layer.map.getLonLatFromLayerPx(bottomRightPx);
+ // Handle the case where the base layer wraps around the date line.
+ // Google does this, and it breaks WMS servers to request bounds in
+ // that fashion.
+ if (topLeft.lon > bottomRight.lon) {
+ if (topLeft.lon < 0) {
+ topLeft.lon = -180 - (topLeft.lon+180);
+ } else {
+ bottomRight.lon = 180+bottomRight.lon+180;
+ var bounds = new OpenLayers.Bounds(topLeft.lon,
+ bottomRight.lat,
+ bottomRight.lon,
+ topLeft.lat);
+ return bounds;
+ * Method: startTransition
+ * Prepare the tile for a transition effect. To be
+ * implemented by subclasses.
+ startTransition: function() {},
+ * Method: resetBackBuffer
+ * Triggered by two different events, layer loadend, and tile loadend.
+ * In any of these cases, we check to see if we can hide the
+ * backBufferTile yet and update its parameters to match the
+ * foreground tile.
+ * Basic logic:
+ * - If the backBufferTile hasn't been drawn yet, reset it
+ * - If layer is still loading, show foreground tile but don't hide
+ * the backBufferTile yet
+ * - If layer is done loading, reset backBuffer tile and show
+ * foreground tile
+ resetBackBuffer: function() {
+ this.showTile();
+ if (this.backBufferTile &&
+ (this.isFirstDraw || !this.layer.numLoadingTiles)) {
+ // check to see if the backBufferTile is within the max extents
+ // before rendering it
+ if (withinMaxExtent) {
+ this.backBufferTile.position = this.position;
+ this.backBufferTile.bounds = this.bounds;
+ this.backBufferTile.size = this.size;
+ this.backBufferTile.imageSize = this.layer.imageSize || this.size;
+ this.backBufferTile.imageOffset = this.layer.imageOffset;
+ this.backBufferTile.resolution = this.layer.getResolution();
+ this.backBufferTile.renderTile();
+ * Method: showTile
+ * Show the tile only if it should be drawn.
+ showTile: function() {
+ if (this.shouldDraw) {
+ this.show();
+ * Method: show
+ * Show the tile. To be implemented by subclasses.
+ show: function() { },
+ * Method: hide
+ * Hide the tile. To be implemented by subclasses.
+ hide: function() { },
+ CLASS_NAME: "OpenLayers.Tile"
+ OpenLayers/Handler.js
+ * @requires OpenLayers/Events.js
+ * Class: OpenLayers.Handler
+ * Base class to construct a higher-level handler for event sequences. All
+ * handlers have activate and deactivate methods. In addition, they have
+ * methods named like browser events. When a handler is activated, any
+ * additional methods named like a browser event is registered as a
+ * listener for the corresponding event. When a handler is deactivated,
+ * those same methods are unregistered as event listeners.
+ * Handlers also typically have a callbacks object with keys named like
+ * the abstracted events or event sequences that they are in charge of
+ * handling. The controls that wrap handlers define the methods that
+ * correspond to these abstract events - so instead of listening for
+ * individual browser events, they only listen for the abstract events
+ * defined by the handler.
+ * Handlers are created by controls, which ultimately have the responsibility
+ * of making changes to the the state of the application. Handlers
+ * themselves may make temporary changes, but in general are expected to
+ * return the application in the same state that they found it.
+OpenLayers.Handler = OpenLayers.Class({
+ * Property: id
+ * {String}
+ id: null,
+ * APIProperty: control
+ * {<OpenLayers.Control>}. The control that initialized this handler. The
+ * control is assumed to have a valid map property - that map is used
+ * in the handler's own setMap method.
+ control: null,
+ * Property: map
+ * {<OpenLayers.Map>}
+ map: null,
+ * APIProperty: keyMask
+ * {Integer} Use bitwise operators and one or more of the OpenLayers.Handler
+ * constants to construct a keyMask. The keyMask is used by
+ * <checkModifiers>. If the keyMask matches the combination of keys
+ * down on an event, checkModifiers returns true.
+ * Example:
+ * (code)
+ * // handler only responds if the Shift key is down
+ * handler.keyMask = OpenLayers.Handler.MOD_SHIFT;
+ * // handler only responds if Ctrl-Shift is down
+ * handler.keyMask = OpenLayers.Handler.MOD_SHIFT |
+ * OpenLayers.Handler.MOD_CTRL;
+ * (end)
+ keyMask: null,
+ * Property: active
+ * {Boolean}
+ active: false,
+ * Property: evt
+ * {Event} This property references the last event handled by the handler.
+ * Note that this property is not part of the stable API. Use of the
+ * evt property should be restricted to controls in the library
+ * or other applications that are willing to update with changes to
+ * the OpenLayers code.
+ evt: null,
+ * Constructor: OpenLayers.Handler
+ * Construct a handler.
+ * Parameters:
+ * control - {<OpenLayers.Control>} The control that initialized this
+ * handler. The control is assumed to have a valid map property; that
+ * map is used in the handler's own setMap method.
+ * callbacks - {Object} An object whose properties correspond to abstracted
+ * events or sequences of browser events. The values for these
+ * properties are functions defined by the control that get called by
+ * the handler.
+ * options - {Object} An optional object whose properties will be set on
+ * the handler.
+ initialize: function(control, callbacks, options) {
+ OpenLayers.Util.extend(this, options);
+ this.control = control;
+ this.callbacks = callbacks;
+ if (control.map) {
+ this.setMap(control.map);
+ this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
+ * Method: setMap
+ setMap: function (map) {
+ this.map = map;
+ * Method: checkModifiers
+ * Check the keyMask on the handler. If no <keyMask> is set, this always
+ * returns true. If a <keyMask> is set and it matches the combination
+ * of keys down on an event, this returns true.
+ * Returns:
+ * {Boolean} The keyMask matches the keys down on an event.
+ checkModifiers: function (evt) {
+ if(this.keyMask == null) {
+ return true;
+ /* calculate the keyboard modifier mask for this event */
+ var keyModifiers =
+ (evt.shiftKey ? OpenLayers.Handler.MOD_SHIFT : 0) |
+ (evt.ctrlKey ? OpenLayers.Handler.MOD_CTRL : 0) |
+ (evt.altKey ? OpenLayers.Handler.MOD_ALT : 0);
+ /* if it differs from the handler object's key mask,
+ bail out of the event handler */
+ return (keyModifiers == this.keyMask);
+ * APIMethod: activate
+ * Turn on the handler. Returns false if the handler was already active.
+ * Returns:
+ * {Boolean} The handler was activated.
+ activate: function() {
+ if(this.active) {
+ return false;
+ // register for event handlers defined on this class.
+ var events = OpenLayers.Events.prototype.BROWSER_EVENTS;
+ for (var i = 0; i < events.length; i++) {
+ if (this[events[i]]) {
+ this.register(events[i], this[events[i]]);
+ this.active = true;
+ return true;
+ * APIMethod: deactivate
+ * Turn off the handler. Returns false if the handler was already inactive.
+ * Returns:
+ * {Boolean} The handler was deactivated.
+ deactivate: function() {
+ if(!this.active) {
+ return false;
+ // unregister event handlers defined on this class.
+ this.unregister(events[i], this[events[i]]);
+ this.active = false;
+ return true;
+ * Method: callback
+ * Trigger the control's named callback with the given arguments
+ * Parameters:
+ * name - {String} The key for the callback that is one of the properties
+ * of the handler's callbacks object.
+ * args - {Array(*)} An array of arguments (any type) with which to call
+ * the callback (defined by the control).
+ callback: function (name, args) {
+ if (name && this.callbacks[name]) {
+ this.callbacks[name].apply(this.control, args);
+ * Method: register
+ * register an event on the map
+ register: function (name, method) {
+ // TODO: deal with registerPriority in 3.0
+ this.map.events.registerPriority(name, this, method);
+ this.map.events.registerPriority(name, this, this.setEvent);
+ * Method: unregister
+ * unregister an event from the map
+ unregister: function (name, method) {
+ this.map.events.unregister(name, this, method);
+ this.map.events.unregister(name, this, this.setEvent);
+ * Method: setEvent
+ * With each registered browser event, the handler sets its own evt
+ * property. This property can be accessed by controls if needed
+ * to get more information about the event that the handler is
+ * processing.
+ * This allows modifier keys on the event to be checked (alt, shift,
+ * and ctrl cannot be checked with the keyboard handler). For a
+ * control to determine which modifier keys are associated with the
+ * event that a handler is currently processing, it should access
+ * (code)handler.evt.altKey || handler.evt.shiftKey ||
+ * handler.evt.ctrlKey(end).
+ * Parameters:
+ * evt - {Event} The browser event.
+ setEvent: function(evt) {
+ this.evt = evt;
+ return true;
+ * Method: destroy
+ * Deconstruct the handler.
+ destroy: function () {
+ // unregister event listeners
+ this.deactivate();
+ // eliminate circular references
+ this.control = this.map = null;
+ CLASS_NAME: "OpenLayers.Handler"
+ * Constant: OpenLayers.Handler.MOD_NONE
+ * If set as the <keyMask>, <checkModifiers> returns false if any key is down.
+OpenLayers.Handler.MOD_NONE = 0;
+ * Constant: OpenLayers.Handler.MOD_SHIFT
+ * If set as the <keyMask>, <checkModifiers> returns false if Shift is down.
+OpenLayers.Handler.MOD_SHIFT = 1;
+ * Constant: OpenLayers.Handler.MOD_CTRL
+ * If set as the <keyMask>, <checkModifiers> returns false if Ctrl is down.
+OpenLayers.Handler.MOD_CTRL = 2;
+ * Constant: OpenLayers.Handler.MOD_ALT
+ * If set as the <keyMask>, <checkModifiers> returns false if Alt is down.
+OpenLayers.Handler.MOD_ALT = 4;
+ OpenLayers/Map.js
+ * @requires OpenLayers/Tween.js
+ * Class: OpenLayers.Map
+ * Instances of OpenLayers.Map are interactive maps embedded in a web page.
+ * Create a new map with the <OpenLayers.Map> constructor.
+ * On their own maps do not provide much functionality. To extend a map
+ * it's necessary to add controls (<OpenLayers.Control>) and
+ * layers (<OpenLayers.Layer>) to the map.
+OpenLayers.Map = OpenLayers.Class({
+ * Constant: Z_INDEX_BASE
+ * {Object} Base z-indexes for different classes of thing
+ Z_INDEX_BASE: { BaseLayer: 100, Overlay: 325, Popup: 750, Control: 1000 },
+ * Constant: EVENT_TYPES
+ * {Array(String)} Supported application event types. Register a listener
+ * for a particular event with the following syntax:
+ * (code)
+ * map.events.register(type, obj, listener);
+ * (end)
+ * Listeners will be called with a reference to an event object. The
+ * properties of this event depends on exactly what happened.
+ * All event objects have at least the following properties:
+ * - *object* {Object} A reference to map.events.object.
+ * - *element* {DOMElement} A reference to map.events.element.
+ * Browser events have the following additional properties:
+ * - *xy* {<OpenLayers.Pixel>} The pixel location of the event (relative
+ * to the the map viewport).
+ * - other properties that come with browser events
+ * Supported map event types:
+ * - *preaddlayer* triggered before a layer has been added. The event
+ * object will include a *layer* property that references the layer
+ * to be added.
+ * - *addlayer* triggered after a layer has been added. The event object
+ * will include a *layer* property that references the added layer.
+ * - *removelayer* triggered after a layer has been removed. The event
+ * object will include a *layer* property that references the removed
+ * layer.
+ * - *changelayer* triggered after a layer name change, order change, or
+ * visibility change (due to resolution thresholds). Listeners will
+ * receive an event object with *layer* and *property* properties. The
+ * *layer* property will be a reference to the changed layer. The
+ * *property* property will be a key to the changed property (name,
+ * visibility, or order).
+ * - *movestart* triggered after the start of a drag, pan, or zoom
+ * - *move* triggered after each drag, pan, or zoom
+ * - *moveend* triggered after a drag, pan, or zoom completes
+ * - *popupopen* triggered after a popup opens
+ * - *popupclose* triggered after a popup opens
+ * - *addmarker* triggered after a marker has been added
+ * - *removemarker* triggered after a marker has been removed
+ * - *clearmarkers* triggered after markers have been cleared
+ * - *mouseover* triggered after mouseover the map
+ * - *mouseout* triggered after mouseout the map
+ * - *mousemove* triggered after mousemove the map
+ * - *dragstart* triggered after the start of a drag
+ * - *drag* triggered after a drag
+ * - *dragend* triggered after the end of a drag
+ * - *changebaselayer* triggered after the base layer changes
+ EVENT_TYPES: [
+ "preaddlayer", "addlayer", "removelayer", "changelayer", "movestart",
+ "move", "moveend", "zoomend", "popupopen", "popupclose",
+ "addmarker", "removemarker", "clearmarkers", "mouseover",
+ "mouseout", "mousemove", "dragstart", "drag", "dragend",
+ "changebaselayer"],
+ * Property: id
+ * {String} Unique identifier for the map
+ id: null,
+ * Property: fractionalZoom
+ * {Boolean} For a base layer that supports it, allow the map resolution
+ * to be set to a value between one of the values in the resolutions
+ * array. Default is false.
+ * When fractionalZoom is set to true, it is possible to zoom to
+ * an arbitrary extent. This requires a base layer from a source
+ * that supports requests for arbitrary extents (i.e. not cached
+ * tiles on a regular lattice). This means that fractionalZoom
+ * will not work with commercial layers (Google, Yahoo, VE), layers
+ * using TileCache, or any other pre-cached data sources.
+ * If you are using fractionalZoom, then you should also use
+ * <getResolutionForZoom> instead of layer.resolutions[zoom] as the
+ * former works for non-integer zoom levels.
+ fractionalZoom: false,
+ * events on the map
+ events: null,
+ * APIProperty: div
+ * {DOMElement} The element that contains the map
+ div: null,
+ * Property: dragging
+ * {Boolean} The map is currently being dragged.
+ dragging: false,
+ * Property: size
+ * {<OpenLayers.Size>} Size of the main div (this.div)
+ size: null,
+ * Property: viewPortDiv
+ * {HTMLDivElement} The element that represents the map viewport
+ viewPortDiv: null,
+ * Property: layerContainerOrigin
+ * {<OpenLayers.LonLat>} The lonlat at which the later container was
+ * re-initialized (on-zoom)
+ layerContainerOrigin: null,
+ * Property: layerContainerDiv
+ * {HTMLDivElement} The element that contains the layers.
+ layerContainerDiv: null,
+ * APIProperty: layers
+ * {Array(<OpenLayers.Layer>)} Ordered list of layers in the map
+ layers: null,
+ * Property: controls
+ * {Array(<OpenLayers.Control>)} List of controls associated with the map
+ controls: null,
+ * Property: popups
+ * {Array(<OpenLayers.Popup>)} List of popups associated with the map
+ popups: null,
+ * APIProperty: baseLayer
+ * {<OpenLayers.Layer>} The currently selected base layer. This determines
+ * min/max zoom level, projection, etc.
+ baseLayer: null,
+ * Property: center
+ * {<OpenLayers.LonLat>} The current center of the map
+ center: null,
+ * Property: resolution
+ * {Float} The resolution of the map.
+ resolution: null,
+ * Property: zoom
+ * {Integer} The current zoom level of the map
+ zoom: 0,
+ * Property: viewRequestID
+ * {String} Used to store a unique identifier that changes when the map
+ * view changes. viewRequestID should be used when adding data
+ * asynchronously to the map: viewRequestID is incremented when
+ * you initiate your request (right now during changing of
+ * baselayers and changing of zooms). It is stored here in the
+ * map and also in the data that will be coming back
+ * asynchronously. Before displaying this data on request
+ * completion, we check that the viewRequestID of the data is
+ * still the same as that of the map. Fix for #480
+ viewRequestID: 0,
+ // Options
+ * APIProperty: tileSize
+ * {<OpenLayers.Size>} Set in the map options to override the default tile
+ * size for this map.
+ tileSize: null,
+ * APIProperty: projection
+ * {String} Set in the map options to override the default projection
+ * string this map - also set maxExtent, maxResolution, and
+ * units if appropriate.
+ projection: "EPSG:4326",
+ * APIProperty: units
+ * {String} The map units. Defaults to 'degrees'. Possible values are
+ * 'degrees' (or 'dd'), 'm', 'ft', 'km', 'mi', 'inches'.
+ units: 'degrees',
+ * APIProperty: resolutions
+ * {Array(Float)} A list of map resolutions (map units per pixel) in
+ * descending order. If this is not set in the layer constructor, it
+ * will be set based on other resolution related properties
+ * (maxExtent, maxResolution, maxScale, etc.).
+ resolutions: null,
+ * APIProperty: maxResolution
+ * {Float} Default max is 360 deg / 256 px, which corresponds to
+ * zoom level 0 on gmaps. Specify a different value in the map
+ * options if you are not using a geographic projection and
+ * displaying the whole world.
+ maxResolution: 1.40625,
+ * APIProperty: minResolution
+ * {Float}
+ minResolution: null,
+ * APIProperty: maxScale
+ * {Float}
+ maxScale: null,
+ * APIProperty: minScale
+ * {Float}
+ minScale: null,
+ * APIProperty: maxExtent
+ * {<OpenLayers.Bounds>} The maximum extent for the map. Defaults to the
+ * whole world in decimal degrees
+ * (-180, -90, 180, 90). Specify a different
+ * extent in the map options if you are not using a
+ * geographic projection and displaying the whole
+ * world.
+ maxExtent: null,
+ * APIProperty: minExtent
+ minExtent: null,
+ * APIProperty: restrictedExtent
+ * {<OpenLayers.Bounds>} Limit map navigation to this extent where possible.
+ * If a non-null restrictedExtent is set, panning will be restricted
+ * to the given bounds. In addition, zooming to a resolution that
+ * displays more than the restricted extent will center the map
+ * on the restricted extent. If you wish to limit the zoom level
+ * or resolution, use maxResolution.
+ restrictedExtent: null,
+ * APIProperty: numZoomLevels
+ * {Integer} Number of zoom levels for the map. Defaults to 16. Set a
+ * different value in the map options if needed.
+ numZoomLevels: 16,
+ * APIProperty: theme
+ * {String} Relative path to a CSS file from which to load theme styles.
+ * Specify null in the map options (e.g. {theme: null}) if you
+ * want to get cascading style declarations - by putting links to
+ * stylesheets or style declarations directly in your page.
+ theme: null,
+ * APIProperty: displayProjection
+ * {<OpenLayers.Projection>} Requires proj4js support.Projection used by
+ * several controls to display data to user. If this property is set,
+ * it will be set on any control which has a null displayProjection
+ * property at the time the control is added to the map.
+ displayProjection: null,
+ * {Boolean} Should OpenLayers allow events on the map to fall through to
+ * other elements on the page, or should it swallow them? (#457)
+ * Default is to fall through.
+ fallThrough: true,
+ * Property: panTween
+ * {OpenLayers.Tween} Animated panning tween object, see panTo()
+ panTween: null,
+ * APIProperty: eventListeners
+ * {Object} If set as an option at construction, the eventListeners
+ * object will be registered with <OpenLayers.Events.on>. Object
+ * structure must be a listeners object as shown in the example for
+ * the events.on method.
+ eventListeners: null,
+ * Property: panMethod
+ * {Function} The Easing function to be used for tweening. Default is
+ * OpenLayers.Easing.Expo.easeOut. Setting this to 'null' turns off
+ * animated panning.
+ panMethod: OpenLayers.Easing.Expo.easeOut,
+ * Property: paddingForPopups
+ * {<OpenLayers.Bounds>} Outside margin of the popup. Used to prevent
+ * the popup from getting too close to the map border.
+ paddingForPopups : null,
+ * Constructor: OpenLayers.Map
+ * Constructor for a new OpenLayers.Map instance.
+ * Parameters:
+ * div - {String} Id of an element in your page that will contain the map.
+ * options - {Object} Optional object with properties to tag onto the map.
+ * Examples:
+ * (code)
+ * // create a map with default options in an element with the id "map1"
+ * var map = new OpenLayers.Map("map1");
+ * // create a map with non-default options in an element with id "map2"
+ * var options = {
+ * maxExtent: new OpenLayers.Bounds(-200000, -200000, 200000, 200000),
+ * maxResolution: 156543,
+ * units: 'm',
+ * projection: "EPSG:41001"
+ * var map = new OpenLayers.Map("map2", options);
+ * (end)
+ initialize: function (div, options) {
+ // Simple-type defaults are set in class definition.
+ // Now set complex-type defaults
+ this.tileSize = new OpenLayers.Size(OpenLayers.Map.TILE_WIDTH,
+ OpenLayers.Map.TILE_HEIGHT);
+ this.maxExtent = new OpenLayers.Bounds(-180, -90, 180, 90);
+ this.paddingForPopups = new OpenLayers.Bounds(15, 15, 15, 15);
+ this.theme = OpenLayers._getScriptLocation() +
+ 'theme/default/style.css';
+ // now override default options
+ this.id = OpenLayers.Util.createUniqueID("OpenLayers.Map_");
+ this.div = OpenLayers.Util.getElement(div);
+ // the viewPortDiv is the outermost div we modify
+ var id = this.div.id + "_OpenLayers_ViewPort";
+ this.viewPortDiv = OpenLayers.Util.createDiv(id, null, null, null,
+ "relative", null,
+ "hidden");
+ this.viewPortDiv.style.width = "100%";
+ this.viewPortDiv.style.height = "100%";
+ this.viewPortDiv.className = "olMapViewport";
+ this.div.appendChild(this.viewPortDiv);
+ // the layerContainerDiv is the one that holds all the layers
+ id = this.div.id + "_OpenLayers_Container";
+ this.layerContainerDiv = OpenLayers.Util.createDiv(id);
+ this.layerContainerDiv.style.zIndex=this.Z_INDEX_BASE['Popup']-1;
+ this.viewPortDiv.appendChild(this.layerContainerDiv);
+ this.events = new OpenLayers.Events(this,
+ this.div,
+ this.EVENT_TYPES,
+ this.fallThrough);
+ this.updateSize();
+ if(this.eventListeners instanceof Object) {
+ this.events.on(this.eventListeners);
+ // update the map size and location before the map moves
+ this.events.register("movestart", this, this.updateSize);
+ // Because Mozilla does not support the "resize" event for elements
+ // other than "window", we need to put a hack here.
+ if (OpenLayers.String.contains(navigator.appName, "Microsoft")) {
+ // If IE, register the resize on the div
+ this.events.register("resize", this, this.updateSize);
+ } else {
+ // Else updateSize on catching the window's resize
+ // Note that this is ok, as updateSize() does nothing if the
+ // map's size has not actually changed.
+ this.updateSizeDestroy = OpenLayers.Function.bind(this.updateSize,
+ this);
+ OpenLayers.Event.observe(window, 'resize',
+ this.updateSizeDestroy);
+ // only append link stylesheet if the theme property is set
+ if(this.theme) {
+ // check existing links for equivalent url
+ var addNode = true;
+ var nodes = document.getElementsByTagName('link');
+ for(var i=0; i<nodes.length; ++i) {
+ if(OpenLayers.Util.isEquivalentUrl(nodes.item(i).href,
+ this.theme)) {
+ addNode = false;
+ break;
+ // only add a new node if one with an equivalent url hasn't already
+ // been added
+ if(addNode) {
+ var cssNode = document.createElement('link');
+ cssNode.setAttribute('rel', 'stylesheet');
+ cssNode.setAttribute('type', 'text/css');
+ cssNode.setAttribute('href', this.theme);
+ document.getElementsByTagName('head')[0].appendChild(cssNode);
+ this.layers = [];
+ if (this.controls == null) {
+ if (OpenLayers.Control != null) { // running full or lite?
+ this.controls = [ new OpenLayers.Control.Navigation(),
+ new OpenLayers.Control.PanZoom(),
+ new OpenLayers.Control.ArgParser(),
+ new OpenLayers.Control.Attribution()
+ } else {
+ this.controls = [];
+ for(var i=0; i < this.controls.length; i++) {
+ this.addControlToMap(this.controls[i]);
+ this.popups = [];
+ this.unloadDestroy = OpenLayers.Function.bind(this.destroy, this);
+ // always call map.destroy()
+ OpenLayers.Event.observe(window, 'unload', this.unloadDestroy);
+ * Method: unloadDestroy
+ * Function that is called to destroy the map on page unload. stored here
+ * so that if map is manually destroyed, we can unregister this.
+ unloadDestroy: null,
+ * Method: updateSizeDestroy
+ * When the map is destroyed, we need to stop listening to updateSize
+ * events: this method stores the function we need to unregister in
+ * non-IE browsers.
+ updateSizeDestroy: null,
+ * APIMethod: destroy
+ * Destroy this map
+ // if unloadDestroy is null, we've already been destroyed
+ if (!this.unloadDestroy) {
+ return false;
+ // map has been destroyed. dont do it again!
+ OpenLayers.Event.stopObserving(window, 'unload', this.unloadDestroy);
+ this.unloadDestroy = null;
+ if (this.updateSizeDestroy) {
+ OpenLayers.Event.stopObserving(window, 'resize',
+ } else {
+ this.events.unregister("resize", this, this.updateSize);
+ this.paddingForPopups = null;
+ if (this.controls != null) {
+ for (var i = this.controls.length - 1; i>=0; --i) {
+ this.controls[i].destroy();
+ this.controls = null;
+ if (this.layers != null) {
+ for (var i = this.layers.length - 1; i>=0; --i) {
+ //pass 'false' to destroy so that map wont try to set a new
+ // baselayer after each baselayer is removed
+ this.layers[i].destroy(false);
+ this.layers = null;
+ if (this.viewPortDiv) {
+ this.div.removeChild(this.viewPortDiv);
+ this.viewPortDiv = null;
+ if(this.eventListeners) {
+ this.events.un(this.eventListeners);
+ this.eventListeners = null;
+ this.events.destroy();
+ this.events = null;
+ * APIMethod: setOptions
+ * Change the map options
+ * Parameters:
+ * options - {Object} Hashtable of options to tag to the map
+ setOptions: function(options) {
+ * APIMethod: getTileSize
+ * Get the tile size for the map
+ * Returns:
+ getTileSize: function() {
+ return this.tileSize;
+ * APIMethod: getBy
+ * Get a list of objects given a property and a match item.
+ * Parameters:
+ * array - {String} A property on the map whose value is an array.
+ * property - {String} A property on each item of the given array.
+ * match - {String | Object} A string to match. Can also be a regular
+ * expression literal or object. In addition, it can be any object
+ * with a method named test. For reqular expressions or other, if
+ * match.test(map[array][i][property]) evaluates to true, the item will
+ * be included in the array returned. If no items are found, an empty
+ * array is returned.
+ * Returns:
+ * {Array} An array of items where the given property matches the given
+ * criteria.
+ getBy: function(array, property, match) {
+ var test = (typeof match.test == "function");
+ var found = OpenLayers.Array.filter(this[array], function(item) {
+ return item[property] == match || (test && match.test(item[property]));
+ return found;
+ * APIMethod: getLayersBy
+ * Get a list of layers with properties matching the given criteria.
+ * Parameter:
+ * property - {String} A layer property to be matched.
+ * match.test(layer[property]) evaluates to true, the layer will be
+ * included in the array returned. If no layers are found, an empty
+ * Returns:
+ * {Array(<OpenLayers.Layer>)} A list of layers matching the given criteria.
+ * An empty array is returned if no matches are found.
+ getLayersBy: function(property, match) {
+ return this.getBy("layers", property, match);
+ * APIMethod: getLayersByName
+ * Get a list of layers with names matching the given name.
+ * Parameter:
+ * match - {String | Object} A layer name. The name can also be a regular
+ * name.test(layer.name) evaluates to true, the layer will be included
+ * in the list of layers returned. If no layers are found, an empty
+ * Returns:
+ * {Array(<OpenLayers.Layer>)} A list of layers matching the given name.
+ getLayersByName: function(match) {
+ return this.getLayersBy("name", match);
+ * APIMethod: getLayersByClass
+ * Get a list of layers of a given class (CLASS_NAME).
+ * Parameter:
+ * match - {String | Object} A layer class name. The match can also be a
+ * regular expression literal or object. In addition, it can be any
+ * object with a method named test. For reqular expressions or other,
+ * if type.test(layer.CLASS_NAME) evaluates to true, the layer will
+ * be included in the list of layers returned. If no layers are
+ * found, an empty array is returned.
+ * Returns:
+ * {Array(<OpenLayers.Layer>)} A list of layers matching the given class.
+ getLayersByClass: function(match) {
+ return this.getLayersBy("CLASS_NAME", match);
+ * APIMethod: getControlsBy
+ * Get a list of controls with properties matching the given criteria.
+ * Parameter:
+ * property - {String} A control property to be matched.
+ * Returns:
+ * {Array(<OpenLayers.Control>)} A list of controls matching the given
+ * criteria. An empty array is returned if no matches are found.
+ getControlsBy: function(property, match) {
+ return this.getBy("controls", property, match);
+ * APIMethod: getControlsByClass
+ * Get a list of controls of a given class (CLASS_NAME).
+ * Parameter:
+ * match - {String | Object} A control class name. The match can also be a
+ * if type.test(control.CLASS_NAME) evaluates to true, the control will
+ * be included in the list of controls returned. If no controls are
+ * Returns:
+ * {Array(<OpenLayers.Control>)} A list of controls matching the given class.
+ getControlsByClass: function(match) {
+ return this.getControlsBy("CLASS_NAME", match);
+ /* Layer Functions */
+ /* The following functions deal with adding and */
+ /* removing Layers to and from the Map */
+ * Get a layer based on its id
+ * Parameter:
+ * id - {String} A layer id
+ * Returns:
+ * {<OpenLayers.Layer>} The Layer with the corresponding id from the map's
+ * layer collection, or null if not found.
+ getLayer: function(id) {
+ var foundLayer = null;
+ for (var i = 0; i < this.layers.length; i++) {
+ var layer = this.layers[i];
+ if (layer.id == id) {
+ foundLayer = layer;
+ break;
+ return foundLayer;
+ * Method: setLayerZIndex
+ * Parameters:
+ * zIdx - {int}
+ setLayerZIndex: function (layer, zIdx) {
+ layer.setZIndex(
+ this.Z_INDEX_BASE[layer.isBaseLayer ? 'BaseLayer' : 'Overlay']
+ + zIdx * 5 );
+ * Method: resetLayersZIndex
+ * Reset each layer's z-index based on layer's array index
+ resetLayersZIndex: function() {
+ this.setLayerZIndex(layer, i);
+ * APIMethod: addLayer
+ * Parameters:
+ addLayer: function (layer) {
+ for(var i=0; i < this.layers.length; i++) {
+ if (this.layers[i] == layer) {
+ var msg = OpenLayers.i18n('layerAlreadyAdded',
+ {'layerName':layer.name});
+ return false;
+ this.events.triggerEvent("preaddlayer", {layer: layer});
+ layer.div.className = "olLayerDiv";
+ layer.div.style.overflow = "";
+ this.setLayerZIndex(layer, this.layers.length);
+ if (layer.isFixed) {
+ this.viewPortDiv.appendChild(layer.div);
+ } else {
+ this.layerContainerDiv.appendChild(layer.div);
+ this.layers.push(layer);
+ layer.setMap(this);
+ if (layer.isBaseLayer) {
+ if (this.baseLayer == null) {
+ // set the first baselaye we add as the baselayer
+ this.setBaseLayer(layer);
+ } else {
+ layer.setVisibility(false);
+ } else {
+ layer.redraw();
+ this.events.triggerEvent("addlayer", {layer: layer});
+ * APIMethod: addLayers
+ * Parameters:
+ * layers - {Array(<OpenLayers.Layer>)}
+ addLayers: function (layers) {
+ for (var i = 0; i < layers.length; i++) {
+ this.addLayer(layers[i]);
+ * APIMethod: removeLayer
+ * Removes a layer from the map by removing its visual element (the
+ * layer.div property), then removing it from the map's internal list
+ * of layers, setting the layer's map property to null.
+ * a "removelayer" event is triggered.
+ * very worthy of mention is that simply removing a layer from a map
+ * will not cause the removal of any popups which may have been created
+ * by the layer. this is due to the fact that it was decided at some
+ * point that popups would not belong to layers. thus there is no way
+ * for us to know here to which layer the popup belongs.
+ * A simple solution to this is simply to call destroy() on the layer.
+ * the default OpenLayers.Layer class's destroy() function
+ * automatically takes care to remove itself from whatever map it has
+ * been attached to.
+ * The correct solution is for the layer itself to register an
+ * event-handler on "removelayer" and when it is called, if it
+ * recognizes itself as the layer being removed, then it cycles through
+ * its own personal list of popups, removing them from the map.
+ * Parameters:
+ * setNewBaseLayer - {Boolean} Default is true
+ removeLayer: function(layer, setNewBaseLayer) {
+ if (setNewBaseLayer == null) {
+ setNewBaseLayer = true;
+ this.viewPortDiv.removeChild(layer.div);
+ } else {
+ this.layerContainerDiv.removeChild(layer.div);
+ OpenLayers.Util.removeItem(this.layers, layer);
+ layer.removeMap(this);
+ layer.map = null;
+ // if we removed the base layer, need to set a new one
+ if(this.baseLayer == layer) {
+ this.baseLayer = null;
+ if(setNewBaseLayer) {
+ var iLayer = this.layers[i];
+ if (iLayer.isBaseLayer) {
+ this.setBaseLayer(iLayer);
+ break;
+ this.resetLayersZIndex();
+ this.events.triggerEvent("removelayer", {layer: layer});
+ * APIMethod: getNumLayers
+ * Returns:
+ * {Int} The number of layers attached to the map.
+ getNumLayers: function () {
+ return this.layers.length;
+ * APIMethod: getLayerIndex
+ * Parameters:
+ * Returns:
+ * {Integer} The current (zero-based) index of the given layer in the map's
+ * layer stack. Returns -1 if the layer isn't on the map.
+ getLayerIndex: function (layer) {
+ return OpenLayers.Util.indexOf(this.layers, layer);
+ * APIMethod: setLayerIndex
+ * Move the given layer to the specified (zero-based) index in the layer
+ * list, changing its z-index in the map display. Use
+ * map.getLayerIndex() to find out the current index of a layer. Note
+ * that this cannot (or at least should not) be effectively used to
+ * raise base layers above overlays.
+ * Parameters:
+ * idx - {int}
+ setLayerIndex: function (layer, idx) {
+ var base = this.getLayerIndex(layer);
+ if (idx < 0) {
+ idx = 0;
+ } else if (idx > this.layers.length) {
+ idx = this.layers.length;
+ if (base != idx) {
+ this.layers.splice(base, 1);
+ this.layers.splice(idx, 0, layer);
+ this.setLayerZIndex(this.layers[i], i);
+ this.events.triggerEvent("changelayer", {
+ layer: layer, property: "order"
+ * APIMethod: raiseLayer
+ * Change the index of the given layer by delta. If delta is positive,
+ * the layer is moved up the map's layer stack; if delta is negative,
+ * the layer is moved down. Again, note that this cannot (or at least
+ * should not) be effectively used to raise base layers above overlays.
+ * Paremeters:
+ * idx - {int}
+ raiseLayer: function (layer, delta) {
+ var idx = this.getLayerIndex(layer) + delta;
+ this.setLayerIndex(layer, idx);
+ * APIMethod: setBaseLayer
+ * Allows user to specify one of the currently-loaded layers as the Map's
+ * new base layer.
+ * Parameters:
+ * newBaseLayer - {<OpenLayers.Layer>}
+ setBaseLayer: function(newBaseLayer) {
+ var oldExtent = null;
+ if (this.baseLayer) {
+ oldExtent = this.baseLayer.getExtent();
+ if (newBaseLayer != this.baseLayer) {
+ // is newBaseLayer an already loaded layer?m
+ if (OpenLayers.Util.indexOf(this.layers, newBaseLayer) != -1) {
+ // make the old base layer invisible
+ if (this.baseLayer != null) {
+ this.baseLayer.setVisibility(false);
+ // set new baselayer
+ this.baseLayer = newBaseLayer;
+ // Increment viewRequestID since the baseLayer is
+ // changing. This is used by tiles to check if they should
+ // draw themselves.
+ this.viewRequestID++;
+ this.baseLayer.visibility = true;
+ //redraw all layers
+ var center = this.getCenter();
+ if (center != null) {
+ //either get the center from the old Extent or just from
+ // the current center of the map.
+ var newCenter = (oldExtent)
+ ? oldExtent.getCenterLonLat()
+ : center;
+ //the new zoom will either come from the old Extent or
+ // from the current resolution of the map
+ var newZoom = (oldExtent)
+ ? this.getZoomForExtent(oldExtent, true)
+ : this.getZoomForResolution(this.resolution, true);
+ // zoom and force zoom change
+ this.setCenter(newCenter, newZoom, false, true);
+ this.events.triggerEvent("changebaselayer", {
+ layer: this.baseLayer
+ /* Control Functions */
+ /* removing Controls to and from the Map */
+ * APIMethod: addControl
+ * Parameters:
+ * px - {<OpenLayers.Pixel>}
+ addControl: function (control, px) {
+ this.controls.push(control);
+ this.addControlToMap(control, px);
+ * Method: addControlToMap
+ * Parameters:
+ addControlToMap: function (control, px) {
+ // If a control doesn't have a div at this point, it belongs in the
+ // viewport.
+ control.outsideViewport = (control.div != null);
+ // If the map has a displayProjection, and the control doesn't, set
+ // the display projection.
+ if (this.displayProjection && !control.displayProjection) {
+ control.displayProjection = this.displayProjection;
+ control.setMap(this);
+ var div = control.draw(px);
+ if (div) {
+ if(!control.outsideViewport) {
+ div.style.zIndex = this.Z_INDEX_BASE['Control'] +
+ this.controls.length;
+ this.viewPortDiv.appendChild( div );
+ * Parameters:
+ * id - {String} ID of the control to return.
+ * Returns:
+ * {<OpenLayers.Control>} The control from the map's list of controls
+ * which has a matching 'id'. If none found,
+ * returns null.
+ getControl: function (id) {
+ var returnControl = null;
+ var control = this.controls[i];
+ if (control.id == id) {
+ returnControl = control;
+ break;
+ return returnControl;
+ * APIMethod: removeControl
+ * Remove a control from the map. Removes the control both from the map
+ * object's internal array of controls, as well as from the map's
+ * viewPort (assuming the control was not added outsideViewport)
+ * Parameters:
+ * control - {<OpenLayers.Control>} The control to remove.
+ removeControl: function (control) {
+ //make sure control is non-null and actually part of our map
+ if ( (control) && (control == this.getControl(control.id)) ) {
+ if (control.div && (control.div.parentNode == this.viewPortDiv)) {
+ this.viewPortDiv.removeChild(control.div);
+ OpenLayers.Util.removeItem(this.controls, control);
+ /* Popup Functions */
+ /* removing Popups to and from the Map */
+ * APIMethod: addPopup
+ * Parameters:
+ * popup - {<OpenLayers.Popup>}
+ * exclusive - {Boolean} If true, closes all other popups first
+ addPopup: function(popup, exclusive) {
+ if (exclusive) {
+ //remove all other popups from screen
+ for (var i = this.popups.length - 1; i >= 0; --i) {
+ this.removePopup(this.popups[i]);
+ popup.map = this;
+ this.popups.push(popup);
+ var popupDiv = popup.draw();
+ if (popupDiv) {
+ popupDiv.style.zIndex = this.Z_INDEX_BASE['Popup'] +
+ this.popups.length;
+ this.layerContainerDiv.appendChild(popupDiv);
+ * APIMethod: removePopup
+ * Parameters:
+ removePopup: function(popup) {
+ OpenLayers.Util.removeItem(this.popups, popup);
+ if (popup.div) {
+ try { this.layerContainerDiv.removeChild(popup.div); }
+ catch (e) { } // Popups sometimes apparently get disconnected
+ // from the layerContainerDiv, and cause complaints.
+ popup.map = null;
+ /* Container Div Functions */
+ /* The following functions deal with the access to */
+ /* and maintenance of the size of the container div */
+ * APIMethod: getSize
+ * Returns:
+ * {<OpenLayers.Size>} An <OpenLayers.Size> object that represents the
+ * size, in pixels, of the div into which OpenLayers
+ * has been loaded.
+ * Note - A clone() of this locally cached variable is
+ * returned, so as not to allow users to modify it.
+ getSize: function () {
+ var size = null;
+ if (this.size != null) {
+ size = this.size.clone();
+ return size;
+ * APIMethod: updateSize
+ * This function should be called by any external code which dynamically
+ * changes the size of the map div (because mozilla wont let us catch
+ * the "onresize" for an element)
+ updateSize: function() {
+ // the div might have moved on the page, also
+ this.events.element.offsets = null;
+ var newSize = this.getCurrentSize();
+ var oldSize = this.getSize();
+ if (oldSize == null) {
+ this.size = oldSize = newSize;
+ if (!newSize.equals(oldSize)) {
+ // store the new size
+ this.size = newSize;
+ //notify layers of mapresize
+ this.layers[i].onMapResize();
+ var center = new OpenLayers.Pixel(newSize.w /2, newSize.h / 2);
+ var centerLL = this.getLonLatFromViewPortPx(center);
+ var zoom = this.getZoom();
+ this.zoom = null;
+ this.setCenter(this.getCenter(), zoom);
+ * Method: getCurrentSize
+ * Returns:
+ * {<OpenLayers.Size>} A new <OpenLayers.Size> object with the dimensions
+ * of the map div
+ getCurrentSize: function() {
+ var size = new OpenLayers.Size(this.div.clientWidth,
+ this.div.clientHeight);
+ // Workaround for the fact that hidden elements return 0 for size.
+ if (size.w == 0 && size.h == 0 || isNaN(size.w) && isNaN(size.h)) {
+ var dim = OpenLayers.Element.getDimensions(this.div);
+ size.w = dim.width;
+ size.h = dim.height;
+ size.w = parseInt(this.div.style.width);
+ size.h = parseInt(this.div.style.height);
+ return size;
+ * Method: calculateBounds
+ * Parameters:
+ * center - {<OpenLayers.LonLat>} Default is this.getCenter()
+ * resolution - {float} Default is this.getResolution()
+ * Returns:
+ * {<OpenLayers.Bounds>} A bounds based on resolution, center, and
+ * current mapsize.
+ calculateBounds: function(center, resolution) {
+ var extent = null;
+ if (center == null) {
+ center = this.getCenter();
+ if (resolution == null) {
+ resolution = this.getResolution();
+ if ((center != null) && (resolution != null)) {
+ var size = this.getSize();
+ var w_deg = size.w * resolution;
+ var h_deg = size.h * resolution;
+ extent = new OpenLayers.Bounds(center.lon - w_deg / 2,
+ center.lat - h_deg / 2,
+ center.lon + w_deg / 2,
+ center.lat + h_deg / 2);
+ return extent;
+ /* Zoom, Center, Pan Functions */
+ /* The following functions handle the validation, */
+ /* getting and setting of the Zoom Level and Center */
+ /* as well as the panning of the Map */
+ * APIMethod: getCenter
+ * Returns:
+ getCenter: function () {
+ return this.center;
+ * APIMethod: getZoom
+ * Returns:
+ * {Integer}
+ getZoom: function () {
+ return this.zoom;
+ * APIMethod: pan
+ * Allows user to pan by a value of screen pixels
+ * Parameters:
+ * dx - {Integer}
+ * dy - {Integer}
+ * options - {Object} Options to configure panning:
+ * - *animate* {Boolean} Use panTo instead of setCenter. Default is true.
+ * - *dragging* {Boolean} Call setCenter with dragging true. Default is
+ * false.
+ pan: function(dx, dy, options) {
+ // this should be pushed to applyDefaults and extend
+ if (!options) {
+ options = {};
+ OpenLayers.Util.applyDefaults(options, {
+ animate: true,
+ dragging: false
+ // getCenter
+ var centerPx = this.getViewPortPxFromLonLat(this.getCenter());
+ // adjust
+ var newCenterPx = centerPx.add(dx, dy);
+ // only call setCenter if not dragging or there has been a change
+ if (!options.dragging || !newCenterPx.equals(centerPx)) {
+ var newCenterLonLat = this.getLonLatFromViewPortPx(newCenterPx);
+ if (options.animate) {
+ this.panTo(newCenterLonLat);
+ } else {
+ this.setCenter(newCenterLonLat, null, options.dragging);
+ * APIMethod: panTo
+ * Allows user to pan to a new lonlat
+ * If the new lonlat is in the current extent the map will slide smoothly
+ * Parameters:
+ * lonlat - {<OpenLayers.Lonlat>}
+ panTo: function(lonlat) {
+ if (this.panMethod && this.getExtent().containsLonLat(lonlat)) {
+ if (!this.panTween) {
+ this.panTween = new OpenLayers.Tween(this.panMethod);
+ var from = {
+ lon: center.lon,
+ lat: center.lat
+ var to = {
+ lon: lonlat.lon,
+ lat: lonlat.lat
+ this.panTween.start(from, to, 50, {
+ callbacks: {
+ start: OpenLayers.Function.bind(function(lonlat) {
+ this.events.triggerEvent("movestart");
+ }, this),
+ eachStep: OpenLayers.Function.bind(function(lonlat) {
+ lonlat = new OpenLayers.LonLat(lonlat.lon, lonlat.lat);
+ this.moveTo(lonlat, this.zoom, {
+ 'dragging': true,
+ 'noEvent': true
+ }, this),
+ done: OpenLayers.Function.bind(function(lonlat) {
+ 'noEvent': true
+ this.events.triggerEvent("moveend");
+ }, this)
+ } else {
+ this.setCenter(lonlat);
+ * APIMethod: setCenter
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>}
+ * zoom - {Integer}
+ * dragging - {Boolean} Specifies whether or not to trigger
+ * movestart/end events
+ * forceZoomChange - {Boolean} Specifies whether or not to trigger zoom
+ * change events (needed on baseLayer change)
+ * TBD: reconsider forceZoomChange in 3.0
+ setCenter: function(lonlat, zoom, dragging, forceZoomChange) {
+ this.moveTo(lonlat, zoom, {
+ 'dragging': dragging,
+ 'forceZoomChange': forceZoomChange,
+ 'caller': 'setCenter'
+ * Method: moveTo
+ * Parameters:
+ moveTo: function(lonlat, zoom, options) {
+ if (!options) {
+ options = {};
+ // dragging is false by default
+ var dragging = options.dragging;
+ // forceZoomChange is false by default
+ var forceZoomChange = options.forceZoomChange;
+ // noEvent is false by default
+ var noEvent = options.noEvent;
+ if (this.panTween && options.caller == "setCenter") {
+ this.panTween.stop();
+ if (!this.center && !this.isValidLonLat(lonlat)) {
+ lonlat = this.maxExtent.getCenterLonLat();
+ if(this.restrictedExtent != null) {
+ // In 3.0, decide if we want to change interpretation of maxExtent.
+ if(lonlat == null) {
+ lonlat = this.getCenter();
+ if(zoom == null) {
+ zoom = this.getZoom();
+ var resolution = this.getResolutionForZoom(zoom);
+ var extent = this.calculateBounds(lonlat, resolution);
+ if(!this.restrictedExtent.containsBounds(extent)) {
+ var maxCenter = this.restrictedExtent.getCenterLonLat();
+ if(extent.getWidth() > this.restrictedExtent.getWidth()) {
+ lonlat = new OpenLayers.LonLat(maxCenter.lon, lonlat.lat);
+ } else if(extent.left < this.restrictedExtent.left) {
+ lonlat = lonlat.add(this.restrictedExtent.left -
+ extent.left, 0);
+ } else if(extent.right > this.restrictedExtent.right) {
+ lonlat = lonlat.add(this.restrictedExtent.right -
+ extent.right, 0);
+ if(extent.getHeight() > this.restrictedExtent.getHeight()) {
+ lonlat = new OpenLayers.LonLat(lonlat.lon, maxCenter.lat);
+ } else if(extent.bottom < this.restrictedExtent.bottom) {
+ lonlat = lonlat.add(0, this.restrictedExtent.bottom -
+ extent.bottom);
+ else if(extent.top > this.restrictedExtent.top) {
+ lonlat = lonlat.add(0, this.restrictedExtent.top -
+ extent.top);
+ var zoomChanged = forceZoomChange || (
+ (this.isValidZoomLevel(zoom)) &&
+ (zoom != this.getZoom()) );
+ var centerChanged = (this.isValidLonLat(lonlat)) &&
+ (!lonlat.equals(this.center));
+ // if neither center nor zoom will change, no need to do anything
+ if (zoomChanged || centerChanged || !dragging) {
+ if (!this.dragging && !noEvent) {
+ if (centerChanged) {
+ if ((!zoomChanged) && (this.center)) {
+ // if zoom hasnt changed, just slide layerContainer
+ // (must be done before setting this.center to new value)
+ this.centerLayerContainer(lonlat);
+ this.center = lonlat.clone();
+ // (re)set the layerContainerDiv's location
+ if ((zoomChanged) || (this.layerContainerOrigin == null)) {
+ this.layerContainerOrigin = this.center.clone();
+ this.layerContainerDiv.style.left = "0px";
+ this.layerContainerDiv.style.top = "0px";
+ if (zoomChanged) {
+ this.zoom = zoom;
+ this.resolution = this.getResolutionForZoom(zoom);
+ // zoom level has changed, increment viewRequestID.
+ var bounds = this.getExtent();
+ //send the move call to the baselayer and all the overlays
+ this.baseLayer.moveTo(bounds, zoomChanged, dragging);
+ bounds = this.baseLayer.getExtent();
+ if (!layer.isBaseLayer) {
+ var inRange = layer.calculateInRange();
+ if (layer.inRange != inRange) {
+ // the inRange property has changed. If the layer is
+ // no longer in range, we turn it off right away. If
+ // the layer is no longer out of range, the moveTo
+ // call below will turn on the layer.
+ layer.inRange = inRange;
+ if (!inRange) {
+ layer.display(false);
+ layer: layer, property: "visibility"
+ if (inRange && layer.visibility) {
+ layer.moveTo(bounds, zoomChanged, dragging);
+ //redraw popups
+ for (var i = 0; i < this.popups.length; i++) {
+ this.popups[i].updatePosition();
+ this.events.triggerEvent("move");
+ if (zoomChanged) { this.events.triggerEvent("zoomend"); }
+ // even if nothing was done, we want to notify of this
+ if (!dragging && !noEvent) {
+ // Store the map dragging state for later use
+ this.dragging = !!dragging;
+ * Method: centerLayerContainer
+ * This function takes care to recenter the layerContainerDiv.
+ * Parameters:
+ centerLayerContainer: function (lonlat) {
+ var originPx = this.getViewPortPxFromLonLat(this.layerContainerOrigin);
+ var newPx = this.getViewPortPxFromLonLat(lonlat);
+ if ((originPx != null) && (newPx != null)) {
+ this.layerContainerDiv.style.left = Math.round(originPx.x - newPx.x) + "px";
+ this.layerContainerDiv.style.top = Math.round(originPx.y - newPx.y) + "px";
+ * Method: isValidZoomLevel
+ * Parameters:
+ * zoomLevel - {Integer}
+ * Returns:
+ * {Boolean} Whether or not the zoom level passed in is non-null and
+ * within the min/max range of zoom levels.
+ isValidZoomLevel: function(zoomLevel) {
+ return ( (zoomLevel != null) &&
+ (zoomLevel >= 0) &&
+ (zoomLevel < this.getNumZoomLevels()) );
+ * Method: isValidLonLat
+ * Parameters:
+ * Returns:
+ * {Boolean} Whether or not the lonlat passed in is non-null and within
+ * the maxExtent bounds
+ isValidLonLat: function(lonlat) {
+ var valid = false;
+ if (lonlat != null) {
+ var maxExtent = this.getMaxExtent();
+ valid = maxExtent.containsLonLat(lonlat);
+ return valid;
+ /* Layer Options */
+ /* Accessor functions to Layer Options parameters */
+ * APIMethod: getProjection
+ * This method returns a string representing the projection. In
+ * the case of projection support, this will be the srsCode which
+ * is loaded -- otherwise it will simply be the string value that
+ * was passed to the projection at startup.
+ * FIXME: In 3.0, we will remove getProjectionObject, and instead
+ * return a Projection object from this function.
+ * Returns:
+ * {String} The Projection string from the base layer or null.
+ getProjection: function() {
+ var projection = this.getProjectionObject();
+ return projection ? projection.getCode() : null;
+ * APIMethod: getProjectionObject
+ * Returns the projection obect from the baselayer.
+ * Returns:
+ * {<OpenLayers.Projection>} The Projection of the base layer.
+ getProjectionObject: function() {
+ var projection = null;
+ projection = this.baseLayer.projection;
+ return projection;
+ * APIMethod: getMaxResolution
+ * Returns:
+ * {String} The Map's Maximum Resolution
+ getMaxResolution: function() {
+ var maxResolution = null;
+ maxResolution = this.baseLayer.maxResolution;
+ return maxResolution;
+ * APIMethod: getMaxExtent
+ * Returns:
+ getMaxExtent: function () {
+ var maxExtent = null;
+ maxExtent = this.baseLayer.maxExtent;
+ return maxExtent;
+ * APIMethod: getNumZoomLevels
+ * Returns:
+ * {Integer} The total number of zoom levels that can be displayed by the
+ * current baseLayer.
+ getNumZoomLevels: function() {
+ var numZoomLevels = null;
+ numZoomLevels = this.baseLayer.numZoomLevels;
+ return numZoomLevels;
+ /* Baselayer Functions */
+ /* The following functions, all publicly exposed */
+ /* in the API?, are all merely wrappers to the */
+ /* the same calls on whatever layer is set as */
+ /* the current base layer */
+ * APIMethod: getExtent
+ * Returns:
+ * {<OpenLayers.Bounds>} A Bounds object which represents the lon/lat
+ * bounds of the current viewPort.
+ * If no baselayer is set, returns null.
+ getExtent: function () {
+ extent = this.baseLayer.getExtent();
+ return extent;
+ * APIMethod: getResolution
+ * Returns:
+ * {Float} The current resolution of the map.
+ getResolution: function () {
+ var resolution = null;
+ resolution = this.baseLayer.getResolution();
+ return resolution;
+ * APIMethod: getScale
+ * Returns:
+ * {Float} The current scale denominator of the map.
+ getScale: function () {
+ var scale = null;
+ var res = this.getResolution();
+ var units = this.baseLayer.units;
+ scale = OpenLayers.Util.getScaleFromResolution(res, units);
+ return scale;
+ * APIMethod: getZoomForExtent
+ * Parameters:
+ * closest - {Boolean} Find the zoom level that most closely fits the
+ * specified bounds. Note that this may result in a zoom that does
+ * not exactly contain the entire extent.
+ * Default is false.
+ * Returns:
+ * {Integer} A suitable zoom level for the specified bounds.
+ getZoomForExtent: function (bounds, closest) {
+ var zoom = null;
+ zoom = this.baseLayer.getZoomForExtent(bounds, closest);
+ return zoom;
+ * APIMethod: getResolutionForZoom
+ * Parameter:
+ * zoom - {Float}
+ * Returns:
+ * {Float} A suitable resolution for the specified zoom. If no baselayer
+ * is set, returns null.
+ getResolutionForZoom: function(zoom) {
+ if(this.baseLayer) {
+ resolution = this.baseLayer.getResolutionForZoom(zoom);
+ * APIMethod: getZoomForResolution
+ * Parameter:
+ * resolution - {Float}
+ * closest - {Boolean} Find the zoom level that corresponds to the absolute
+ * closest resolution, which may result in a zoom whose corresponding
+ * resolution is actually smaller than we would have desired (if this
+ * is being called from a getZoomForExtent() call, then this means that
+ * the returned zoom index might not actually contain the entire
+ * extent specified... but it'll be close).
+ * Returns:
+ * {Integer} A suitable zoom level for the specified resolution.
+ getZoomForResolution: function(resolution, closest) {
+ var zoom = null;
+ zoom = this.baseLayer.getZoomForResolution(resolution, closest);
+ return zoom;
+ /* Zooming Functions */
+ /* in the API, are all merely wrappers to the */
+ /* the setCenter() function */
+ * APIMethod: zoomTo
+ * Zoom to a specific zoom level
+ * Parameters:
+ zoomTo: function(zoom) {
+ if (this.isValidZoomLevel(zoom)) {
+ this.setCenter(null, zoom);
+ * APIMethod: zoomIn
+ * Parameters:
+ * zoom - {int}
+ zoomIn: function() {
+ this.zoomTo(this.getZoom() + 1);
+ * APIMethod: zoomOut
+ * Parameters:
+ * zoom - {int}
+ zoomOut: function() {
+ this.zoomTo(this.getZoom() - 1);
+ * APIMethod: zoomToExtent
+ * Zoom to the passed in bounds, recenter
+ * Parameters:
+ zoomToExtent: function(bounds) {
+ var center = bounds.getCenterLonLat();
+ if (this.baseLayer.wrapDateLine) {
+ //fix straddling bounds (in the case of a bbox that straddles the
+ // dateline, it's left and right boundaries will appear backwards.
+ // we fix this by allowing a right value that is greater than the
+ // max value at the dateline -- this allows us to pass a valid
+ // bounds to calculate zoom)
+ bounds = bounds.clone();
+ while (bounds.right < bounds.left) {
+ bounds.right += maxExtent.getWidth();
+ //if the bounds was straddling (see above), then the center point
+ // we got from it was wrong. So we take our new bounds and ask it
+ // for the center. Because our new bounds is at least partially
+ // outside the bounds of maxExtent, the new calculated center
+ // might also be. We don't want to pass a bad center value to
+ // setCenter, so we have it wrap itself across the date line.
+ center = bounds.getCenterLonLat().wrapDateLine(maxExtent);
+ this.setCenter(center, this.getZoomForExtent(bounds));
+ * APIMethod: zoomToMaxExtent
+ * Zoom to the full extent and recenter.
+ zoomToMaxExtent: function() {
+ this.zoomToExtent(this.getMaxExtent());
+ * APIMethod: zoomToScale
+ * Zoom to a specified scale
+ * Parameters:
+ * scale - {float}
+ zoomToScale: function(scale) {
+ var res = OpenLayers.Util.getResolutionFromScale(scale,
+ this.baseLayer.units);
+ var w_deg = size.w * res;
+ var h_deg = size.h * res;
+ var extent = new OpenLayers.Bounds(center.lon - w_deg / 2,
+ this.zoomToExtent(extent);
+ /* Translation Functions */
+ /* The following functions translate between */
+ /* LonLat, LayerPx, and ViewPortPx */
+ // TRANSLATION: LonLat <-> ViewPortPx
+ * Method: getLonLatFromViewPortPx
+ * Parameters:
+ * viewPortPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat which is the passed-in view
+ * port <OpenLayers.Pixel>, translated into lon/lat
+ * by the current base layer.
+ getLonLatFromViewPortPx: function (viewPortPx) {
+ var lonlat = null;
+ lonlat = this.baseLayer.getLonLatFromViewPortPx(viewPortPx);
+ return lonlat;
+ * APIMethod: getViewPortPxFromLonLat
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Pixel>} An OpenLayers.Pixel which is the passed-in
+ * <OpenLayers.LonLat>, translated into view port
+ * pixels by the current base layer.
+ getViewPortPxFromLonLat: function (lonlat) {
+ var px = null;
+ px = this.baseLayer.getViewPortPxFromLonLat(lonlat);
+ return px;
+ // CONVENIENCE TRANSLATION FUNCTIONS FOR API
+ * APIMethod: getLonLatFromPixel
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat corresponding to the given
+ * OpenLayers.Pixel, translated into lon/lat by the
+ * current base layer
+ getLonLatFromPixel: function (px) {
+ return this.getLonLatFromViewPortPx(px);
+ * APIMethod: getPixelFromLonLat
+ * Returns a pixel location given a map location. The map location is
+ * translated to an integer pixel location (in viewport pixel
+ * coordinates) by the current base layer.
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>} A map location.
+ * Returns:
+ * {<OpenLayers.Pixel>} An OpenLayers.Pixel corresponding to the
+ * <OpenLayers.LonLat> translated into view port pixels by the current
+ * base layer.
+ getPixelFromLonLat: function (lonlat) {
+ var px = this.getViewPortPxFromLonLat(lonlat);
+ px.x = Math.round(px.x);
+ px.y = Math.round(px.y);
+ return px;
+ // TRANSLATION: ViewPortPx <-> LayerPx
+ * APIMethod: getViewPortPxFromLayerPx
+ * Parameters:
+ * layerPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.Pixel>} Layer Pixel translated into ViewPort Pixel
+ * coordinates
+ getViewPortPxFromLayerPx:function(layerPx) {
+ var viewPortPx = null;
+ if (layerPx != null) {
+ var dX = parseInt(this.layerContainerDiv.style.left);
+ var dY = parseInt(this.layerContainerDiv.style.top);
+ viewPortPx = layerPx.add(dX, dY);
+ return viewPortPx;
+ * APIMethod: getLayerPxFromViewPortPx
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Pixel>} ViewPort Pixel translated into Layer Pixel
+ * coordinates
+ getLayerPxFromViewPortPx:function(viewPortPx) {
+ var layerPx = null;
+ if (viewPortPx != null) {
+ var dX = -parseInt(this.layerContainerDiv.style.left);
+ var dY = -parseInt(this.layerContainerDiv.style.top);
+ layerPx = viewPortPx.add(dX, dY);
+ if (isNaN(layerPx.x) || isNaN(layerPx.y)) {
+ layerPx = null;
+ return layerPx;
+ // TRANSLATION: LonLat <-> LayerPx
+ * Method: getLonLatFromLayerPx
+ * Parameters:
+ * Returns:
+ getLonLatFromLayerPx: function (px) {
+ //adjust for displacement of layerContainerDiv
+ px = this.getViewPortPxFromLayerPx(px);
+ * APIMethod: getLayerPxFromLonLat
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>} lonlat
+ * Returns:
+ * <OpenLayers.LonLat>, translated into layer pixels
+ getLayerPxFromLonLat: function (lonlat) {
+ var px = this.getPixelFromLonLat(lonlat);
+ return this.getLayerPxFromViewPortPx(px);
+ CLASS_NAME: "OpenLayers.Map"
+ * Constant: TILE_WIDTH
+ * {Integer} 256 Default tile width (unless otherwise specified)
+OpenLayers.Map.TILE_WIDTH = 256;
+ * Constant: TILE_HEIGHT
+ * {Integer} 256 Default tile height (unless otherwise specified)
+OpenLayers.Map.TILE_HEIGHT = 256;
+ OpenLayers/Marker.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Icon.js
+ * Class: OpenLayers.Marker
+ * Instances of OpenLayers.Marker are a combination of a
+ * <OpenLayers.LonLat> and an <OpenLayers.Icon>.
+ * Markers are generally added to a special layer called
+ * <OpenLayers.Layer.Markers>.
+ * Example:
+ * (code)
+ * var markers = new OpenLayers.Layer.Markers( "Markers" );
+ * map.addLayer(markers);
+ * var size = new OpenLayers.Size(10,17);
+ * var offset = new OpenLayers.Pixel(-(size.w/2), -size.h);
+ * var icon = new OpenLayers.Icon('http://boston.openguides.org/markers/AQUA.png',size,offset);
+ * markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0),icon));
+ * markers.addMarker(new OpenLayers.Marker(new OpenLayers.LonLat(0,0),icon.clone()));
+ * (end)
+ * Note that if you pass an icon into the Marker constructor, it will take
+ * that icon and use it. This means that you should not share icons between
+ * markers -- you use them once, but you should clone() for any additional
+ * markers using that same icon.
+OpenLayers.Marker = OpenLayers.Class({
+ * Property: icon
+ * {<OpenLayers.Icon>} The icon used by this marker.
+ icon: null,
+ * Property: lonlat
+ * {<OpenLayers.LonLat>} location of object
+ lonlat: null,
+ * Property: events
+ * {<OpenLayers.Events>} the event handler.
+ events: null,
+ * Property: map
+ * {<OpenLayers.Map>} the map this marker is attached to
+ map: null,
+ * Constructor: OpenLayers.Marker
+ * Paraemeters:
+ * icon - {<OpenLayers.Icon>} the icon for this marker
+ * lonlat - {<OpenLayers.LonLat>} the position of this marker
+ initialize: function(lonlat, icon) {
+ this.lonlat = lonlat;
+ var newIcon = (icon) ? icon : OpenLayers.Marker.defaultIcon();
+ if (this.icon == null) {
+ this.icon = newIcon;
+ } else {
+ this.icon.url = newIcon.url;
+ this.icon.size = newIcon.size;
+ this.icon.offset = newIcon.offset;
+ this.icon.calculateOffset = newIcon.calculateOffset;
+ this.events = new OpenLayers.Events(this, this.icon.imageDiv, null);
+ * Destroy the marker. You must first remove the marker from any
+ * layer which it has been added to, or you will get buggy behavior.
+ * (This can not be done within the marker since the marker does not
+ * know which layer it is attached to.)
+ destroy: function() {
+ this.map = null;
+ if (this.icon != null) {
+ this.icon.destroy();
+ this.icon = null;
+ * Method: draw
+ * Calls draw on the icon, and returns that output.
+ * Parameters:
+ * Returns:
+ * {DOMElement} A new DOM Image with this marker's icon set at the
+ * location passed-in
+ draw: function(px) {
+ return this.icon.draw(px);
+ * Method: moveTo
+ * Move the marker to the new location.
+ * Parameters:
+ * px - {<OpenLayers.Pixel>} the pixel position to move to
+ moveTo: function (px) {
+ if ((px != null) && (this.icon != null)) {
+ this.icon.moveTo(px);
+ this.lonlat = this.map.getLonLatFromLayerPx(px);
+ * Method: onScreen
+ * Returns:
+ * {Boolean} Whether or not the marker is currently visible on screen.
+ onScreen:function() {
+ var onScreen = false;
+ if (this.map) {
+ var screenBounds = this.map.getExtent();
+ onScreen = screenBounds.containsLonLat(this.lonlat);
+ return onScreen;
+ * Method: inflate
+ * Englarges the markers icon by the specified ratio.
+ * Parameters:
+ * inflate - {float} the ratio to enlarge the marker by (passing 2
+ * will double the size).
+ inflate: function(inflate) {
+ if (this.icon) {
+ var newSize = new OpenLayers.Size(this.icon.size.w * inflate,
+ this.icon.size.h * inflate);
+ this.icon.setSize(newSize);
+ * Method: setOpacity
+ * Change the opacity of the marker by changin the opacity of
+ * its icon
+ * Parameters:
+ * opacity - {float} Specified as fraction (0.4, etc)
+ setOpacity: function(opacity) {
+ this.icon.setOpacity(opacity);
+ * Method: setUrl
+ * Change URL of the Icon Image.
+ * url - {String}
+ setUrl: function(url) {
+ this.icon.setUrl(url);
+ * Method: display
+ * Hide or show the icon
+ * display - {Boolean}
+ display: function(display) {
+ this.icon.display(display);
+ CLASS_NAME: "OpenLayers.Marker"
+ * Function: defaultIcon
+ * Creates a default <OpenLayers.Icon>.
+ * Returns:
+ * {<OpenLayers.Icon>} A default OpenLayers.Icon to use for a marker
+OpenLayers.Marker.defaultIcon = function() {
+ var url = OpenLayers.Util.getImagesLocation() + "marker.png";
+ var size = new OpenLayers.Size(21, 25);
+ var calculateOffset = function(size) {
+ return new OpenLayers.Pixel(-(size.w/2), -size.h);
+ return new OpenLayers.Icon(url, size, null, calculateOffset);
+ OpenLayers/Tile/Image.js
+ * @requires OpenLayers/Tile.js
+ * Class: OpenLayers.Tile.Image
+ * Instances of OpenLayers.Tile.Image are used to manage the image tiles
+ * used by various layers. Create a new image tile with the
+ * <OpenLayers.Tile.Image> constructor.
+ * Inherits from:
+ * - <OpenLayers.Tile>
+OpenLayers.Tile.Image = OpenLayers.Class(OpenLayers.Tile, {
+ * Property: url
+ * {String} The URL of the image being requested. No default. Filled in by
+ * layer.getURL() function.
+ url: null,
+ * Property: imgDiv
+ * {DOMElement} The div element which wraps the image.
+ imgDiv: null,
+ * Property: frame
+ * {DOMElement} The image element is appended to the frame. Any gutter on
+ * the image will be hidden behind the frame.
+ frame: null,
+ * Property: layerAlphaHack
+ * {Boolean} True if the png alpha hack needs to be applied on the layer's div.
+ layerAlphaHack: null,
+ /** TBD 3.0 - reorder the parameters to the init function to remove
+ * URL. the getUrl() function on the layer gets called on
+ * each draw(), so no need to specify it here.
+ * Constructor: OpenLayers.Tile.Image
+ * Constructor for a new <OpenLayers.Tile.Image> instance.
+ * Parameters:
+ * layer - {<OpenLayers.Layer>} layer that the tile will go in.
+ * position - {<OpenLayers.Pixel>}
+ * bounds - {<OpenLayers.Bounds>}
+ * url - {<String>} Deprecated. Remove me in 3.0.
+ * size - {<OpenLayers.Size>}
+ initialize: function(layer, position, bounds, url, size) {
+ OpenLayers.Tile.prototype.initialize.apply(this, arguments);
+ this.url = url; //deprecated remove me
+ this.frame = document.createElement('div');
+ this.frame.style.overflow = 'hidden';
+ this.frame.style.position = 'absolute';
+ this.layerAlphaHack = this.layer.alpha && OpenLayers.Util.alphaHack();
+ * nullify references to prevent circular references and memory leaks
+ if (this.imgDiv != null) {
+ if (this.layerAlphaHack) {
+ OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);
+ } else {
+ OpenLayers.Event.stopObservingElement(this.imgDiv.id);
+ if (this.imgDiv.parentNode == this.frame) {
+ this.frame.removeChild(this.imgDiv);
+ this.imgDiv.map = null;
+ this.imgDiv = null;
+ if ((this.frame != null) && (this.frame.parentNode == this.layer.div)) {
+ this.layer.div.removeChild(this.frame);
+ this.frame = null;
+ OpenLayers.Tile.prototype.destroy.apply(this, arguments);
+ * Method: clone
+ * Parameters:
+ * obj - {<OpenLayers.Tile.Image>} The tile to be cloned
+ * Returns:
+ * {<OpenLayers.Tile.Image>} An exact clone of this <OpenLayers.Tile.Image>
+ clone: function (obj) {
+ if (obj == null) {
+ obj = new OpenLayers.Tile.Image(this.layer,
+ this.position,
+ this.bounds,
+ this.url,
+ this.size);
+ //pick up properties from superclass
+ obj = OpenLayers.Tile.prototype.clone.apply(this, [obj]);
+ //dont want to directly copy the image div
+ obj.imgDiv = null;
+ return obj;
+ * Method: draw
+ * Check that a tile should be drawn, and draw it.
+ * Returns:
+ * {Boolean} Always returns true.
+ draw: function() {
+ if (this.layer != this.layer.map.baseLayer && this.layer.reproject) {
+ this.bounds = this.getBoundsFromBaseLayer(this.position);
+ if (!OpenLayers.Tile.prototype.draw.apply(this, arguments)) {
+ return false;
+ if (this.isLoading) {
+ //if we're already loading, send 'reload' instead of 'loadstart'.
+ this.events.triggerEvent("reload");
+ } else {
+ this.isLoading = true;
+ this.events.triggerEvent("loadstart");
+ return this.renderTile();
+ * Method: renderTile
+ * Internal function to actually initialize the image tile,
+ * position it correctly, and set its url.
+ renderTile: function() {
+ if (this.imgDiv == null) {
+ this.initImgDiv();
+ this.imgDiv.viewRequestID = this.layer.map.viewRequestID;
+ this.url = this.layer.getURL(this.bounds);
+ // position the frame
+ OpenLayers.Util.modifyDOMElement(this.frame,
+ null, this.position, this.size);
+ var imageSize = this.layer.getImageSize();
+ OpenLayers.Util.modifyAlphaImageDiv(this.imgDiv,
+ null, null, imageSize, this.url);
+ } else {
+ OpenLayers.Util.modifyDOMElement(this.imgDiv,
+ null, null, imageSize) ;
+ this.imgDiv.src = this.url;
+ return true;
+ * Method: clear
+ * Clear the tile of any bounds/position-related data so that it can
+ * be reused in a new location.
+ clear: function() {
+ if(this.imgDiv) {
+ this.hide();
+ if (OpenLayers.Tile.Image.useBlankTile) {
+ this.imgDiv.src = OpenLayers.Util.getImagesLocation() + "blank.gif";
+ * Method: initImgDiv
+ * Creates the imgDiv property on the tile.
+ initImgDiv: function() {
+ var offset = this.layer.imageOffset;
+ var size = this.layer.getImageSize();
+ this.imgDiv = OpenLayers.Util.createAlphaImageDiv(null,
+ offset,
+ size,
+ null,
+ "relative",
+ null,
+ null,
+ null,
+ true);
+ } else {
+ this.imgDiv = OpenLayers.Util.createImage(null,
+ offset,
+ size,
+ null,
+ "relative",
+ null,
+ null,
+ true);
+ this.imgDiv.className = 'olTileImage';
+ /* checkImgURL used to be used to called as a work around, but it
+ ended up hiding problems instead of solving them and broke things
+ like relative URLs. See discussion on the dev list:
+ http://openlayers.org/pipermail/dev/2007-January/000205.html
+ OpenLayers.Event.observe( this.imgDiv, "load",
+ OpenLayers.Function.bind(this.checkImgURL, this) );
+ this.frame.style.zIndex = this.isBackBuffer ? 0 : 1;
+ this.frame.appendChild(this.imgDiv);
+ this.layer.div.appendChild(this.frame);
+ if(this.layer.opacity != null) {
+ OpenLayers.Util.modifyDOMElement(this.imgDiv, null, null, null,
+ null, null, null,
+ this.layer.opacity);
+ // we need this reference to check back the viewRequestID
+ this.imgDiv.map = this.layer.map;
+ //bind a listener to the onload of the image div so that we
+ // can register when a tile has finished loading.
+ var onload = function() {
+ //normally isLoading should always be true here but there are some
+ // right funky conditions where loading and then reloading a tile
+ // with the same url *really*fast*. this check prevents sending
+ // a 'loadend' if the msg has already been sent
+ this.isLoading = false;
+ this.events.triggerEvent("loadend");
+ OpenLayers.Event.observe(this.imgDiv.childNodes[0], 'load',
+ OpenLayers.Function.bind(onload, this));
+ } else {
+ OpenLayers.Event.observe(this.imgDiv, 'load',
+ // Bind a listener to the onerror of the image div so that we
+ // can registere when a tile has finished loading with errors.
+ var onerror = function() {
+ // If we have gone through all image reload attempts, it is time
+ // to realize that we are done with this image. Since
+ // OpenLayers.Util.onImageLoadError already has taken care about
+ // the error, we can continue as if the image was loaded
+ // successfully.
+ if (this.imgDiv._attempts > OpenLayers.IMAGE_RELOAD_ATTEMPTS) {
+ onload.call(this);
+ OpenLayers.Event.observe(this.imgDiv, "error",
+ OpenLayers.Function.bind(onerror, this));
+ * Method: checkImgURL
+ * Make sure that the image that just loaded is the one this tile is meant
+ * to display, since panning/zooming might have changed the tile's URL in
+ * the meantime. If the tile URL did change before the image loaded, set
+ * the imgDiv display to 'none', as either (a) it will be reset to visible
+ * when the new URL loads in the image, or (b) we don't want to display
+ * this tile after all because its new bounds are outside our maxExtent.
+ * This function should no longer be neccesary with the improvements to
+ * Grid.js in OpenLayers 2.3. The lack of a good isEquivilantURL function
+ * caused problems in 2.2, but it's possible that with the improved
+ * isEquivilant URL function, this might be neccesary at some point.
+ * See discussion in the thread at
+ * http://openlayers.org/pipermail/dev/2007-January/000205.html
+ checkImgURL: function () {
+ // Sometimes our image will load after it has already been removed
+ // from the map, in which case this check is not needed.
+ if (this.layer) {
+ var loaded = this.layerAlphaHack ? this.imgDiv.firstChild.src : this.imgDiv.src;
+ if (!OpenLayers.Util.isEquivalentUrl(loaded, this.url)) {
+ this.hide();
+ * Method: startTransition
+ * This method is invoked on tiles that are backBuffers for tiles in the
+ * grid. The grid tile is about to be cleared and a new tile source
+ * loaded. This is where the transition effect needs to be started
+ * to provide visual continuity.
+ startTransition: function() {
+ // backBufferTile has to be valid and ready to use
+ if (!this.backBufferTile || !this.backBufferTile.imgDiv) {
+ return;
+ // calculate the ratio of change between the current resolution of the
+ // backBufferTile and the layer. If several animations happen in a
+ // row, then the backBufferTile will scale itself appropriately for
+ // each request.
+ var ratio = 1;
+ if (this.backBufferTile.resolution) {
+ ratio = this.backBufferTile.resolution / this.layer.getResolution();
+ // if the ratio is not the same as it was last time (i.e. we are
+ // zooming), then we need to adjust the backBuffer tile
+ if (ratio != this.lastRatio) {
+ if (this.layer.transitionEffect == 'resize') {
+ // In this case, we can just immediately resize the
+ // backBufferTile.
+ var upperLeft = new OpenLayers.LonLat(
+ this.backBufferTile.bounds.left,
+ this.backBufferTile.bounds.top
+ this.backBufferTile.size.w * ratio,
+ this.backBufferTile.size.h * ratio
+ var px = this.layer.map.getLayerPxFromLonLat(upperLeft);
+ OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,
+ null, px, size);
+ var imageSize = this.backBufferTile.imageSize;
+ imageSize = new OpenLayers.Size(imageSize.w * ratio,
+ imageSize.h * ratio);
+ var imageOffset = this.backBufferTile.imageOffset;
+ if(imageOffset) {
+ imageOffset = new OpenLayers.Pixel(
+ imageOffset.x * ratio, imageOffset.y * ratio
+ this.backBufferTile.imgDiv, null, imageOffset, imageSize
+ this.backBufferTile.show();
+ } else {
+ // default effect is just to leave the existing tile
+ // until the new one loads if this is a singleTile and
+ // there was no change in resolution. Otherwise we
+ // don't bother to show the backBufferTile at all
+ if (this.layer.singleTile) {
+ } else {
+ this.backBufferTile.hide();
+ this.lastRatio = ratio;
+ * Method: show
+ * Show the tile by showing its frame.
+ show: function() {
+ this.frame.style.display = '';
+ // Force a reflow on gecko based browsers to actually show the element
+ // before continuing execution.
+ if (OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,
+ this.layer.transitionEffect) != -1) {
+ if (navigator.userAgent.toLowerCase().indexOf("gecko") != -1) {
+ this.frame.scrollLeft = this.frame.scrollLeft;
+ * Method: hide
+ * Hide the tile by hiding its frame.
+ hide: function() {
+ this.frame.style.display = 'none';
+ CLASS_NAME: "OpenLayers.Tile.Image"
+OpenLayers.Tile.Image.useBlankTile = (
+ OpenLayers.Util.getBrowserName() == "safari" ||
+ OpenLayers.Util.getBrowserName() == "opera");
+ OpenLayers/Control/OverviewMap.js
+ * @requires OpenLayers/Control.js
+ * @requires OpenLayers/BaseTypes.js
+ * @requires OpenLayers/Events.js
+ * Class: OpenLayers.Control.OverviewMap
+ * Create an overview map to display the extent of your main map and provide
+ * additional navigation control. Create a new overview map with the
+ * <OpenLayers.Control.OverviewMap> constructor.
+ * Inerits from:
+ * - <OpenLayers.Control>
+OpenLayers.Control.OverviewMap = OpenLayers.Class(OpenLayers.Control, {
+ * Property: element
+ * {DOMElement} The DOM element that contains the overview map
+ element: null,
+ * APIProperty: ovmap
+ * {<OpenLayers.Map>} A reference to the overview map itself.
+ ovmap: null,
+ * APIProperty: size
+ * {<OpenLayers.Size>} The overvew map size in pixels. Note that this is
+ * the size of the map itself - the element that contains the map (default
+ * class name olControlOverviewMapElement) may have padding or other style
+ * attributes added via CSS.
+ size: new OpenLayers.Size(180, 90),
+ * APIProperty: layers
+ * {Array(<OpenLayers.Layer>)} Ordered list of layers in the overview map.
+ * If none are sent at construction, the base layer for the main map is used.
+ layers: null,
+ * APIProperty: minRectSize
+ * {Integer} The minimum width or height (in pixels) of the extent
+ * rectangle on the overview map. When the extent rectangle reaches
+ * this size, it will be replaced depending on the value of the
+ * <minRectDisplayClass> property. Default is 15 pixels.
+ minRectSize: 15,
+ * APIProperty: minRectDisplayClass
+ * {String} Replacement style class name for the extent rectangle when
+ * <minRectSize> is reached. This string will be suffixed on to the
+ * displayClass. Default is "RectReplacement".
+ * Example CSS declaration:
+ * (code)
+ * .olControlOverviewMapRectReplacement {
+ * overflow: hidden;
+ * cursor: move;
+ * background-image: url("img/overview_replacement.gif");
+ * background-repeat: no-repeat;
+ * background-position: center;
+ * (end)
+ minRectDisplayClass: "RectReplacement",
+ * APIProperty: minRatio
+ * {Float} The ratio of the overview map resolution to the main map
+ * resolution at which to zoom farther out on the overview map.
+ minRatio: 8,
+ * APIProperty: maxRatio
+ * resolution at which to zoom farther in on the overview map.
+ maxRatio: 32,
+ * APIProperty: mapOptions
+ * {Object} An object containing any non-default properties to be sent to
+ * the overview map's map constructor. These should include any non-default
+ * options that the main map was constructed with.
+ mapOptions: null,
+ * Property: handlers
+ * {Object}
+ handlers: null,
+ * Constructor: OpenLayers.Control.OverviewMap
+ * Create a new overview map
+ * Parameters:
+ * object - {Object} Properties of this object will be set on the overview
+ * map object. Note, to set options on the map object contained in this
+ * control, set <mapOptions> as one of the options properties.
+ initialize: function(options) {
+ this.layers = [];
+ this.handlers = {};
+ OpenLayers.Control.prototype.initialize.apply(this, [options]);
+ * Deconstruct the control
+ if (!this.mapDiv) { // we've already been destroyed
+ return;
+ this.handlers.click.destroy();
+ this.mapDiv.removeChild(this.extentRectangle);
+ this.extentRectangle = null;
+ this.rectEvents.destroy();
+ this.rectEvents = null;
+ this.ovmap.destroy();
+ this.ovmap = null;
+ this.element.removeChild(this.mapDiv);
+ this.mapDiv = null;
+ this.div.removeChild(this.element);
+ this.element = null;
+ if (this.maximizeDiv) {
+ OpenLayers.Event.stopObservingElement(this.maximizeDiv);
+ this.div.removeChild(this.maximizeDiv);
+ this.maximizeDiv = null;
+ if (this.minimizeDiv) {
+ OpenLayers.Event.stopObservingElement(this.minimizeDiv);
+ this.div.removeChild(this.minimizeDiv);
+ this.minimizeDiv = null;
+ this.map.events.un({
+ "moveend": this.update,
+ "changebaselayer": this.baseLayerDraw,
+ scope: this
+ OpenLayers.Control.prototype.destroy.apply(this, arguments);
+ * Method: draw
+ * Render the control in the browser.
+ OpenLayers.Control.prototype.draw.apply(this, arguments);
+ if(!(this.layers.length > 0)) {
+ if (this.map.baseLayer) {
+ var layer = this.map.baseLayer.clone();
+ this.layers = [layer];
+ } else {
+ this.map.events.register("changebaselayer", this, this.baseLayerDraw);
+ return this.div;
+ // create overview map DOM elements
+ this.element = document.createElement('div');
+ this.element.className = this.displayClass + 'Element';
+ this.element.style.display = 'none';
+ this.mapDiv = document.createElement('div');
+ this.mapDiv.style.width = this.size.w + 'px';
+ this.mapDiv.style.height = this.size.h + 'px';
+ this.mapDiv.style.position = 'relative';
+ this.mapDiv.style.overflow = 'hidden';
+ this.mapDiv.id = OpenLayers.Util.createUniqueID('overviewMap');
+ this.extentRectangle = document.createElement('div');
+ this.extentRectangle.style.position = 'absolute';
+ this.extentRectangle.style.zIndex = 1000; //HACK
+ this.extentRectangle.className = this.displayClass+'ExtentRectangle';
+ this.mapDiv.appendChild(this.extentRectangle);
+ this.element.appendChild(this.mapDiv);
+ this.div.appendChild(this.element);
+ // Optionally add min/max buttons if the control will go in the
+ // map viewport.
+ if(!this.outsideViewport) {
+ this.div.className += " " + this.displayClass + 'Container';
+ var imgLocation = OpenLayers.Util.getImagesLocation();
+ // maximize button div
+ var img = imgLocation + 'layer-switcher-maximize.png';
+ this.maximizeDiv = OpenLayers.Util.createAlphaImageDiv(
+ this.displayClass + 'MaximizeButton',
+ null,
+ new OpenLayers.Size(18,18),
+ img,
+ 'absolute');
+ this.maximizeDiv.style.display = 'none';
+ this.maximizeDiv.className = this.displayClass + 'MaximizeButton';
+ OpenLayers.Event.observe(this.maximizeDiv, 'click',
+ OpenLayers.Function.bindAsEventListener(this.maximizeControl,
+ this)
+ this.div.appendChild(this.maximizeDiv);
+ // minimize button div
+ var img = imgLocation + 'layer-switcher-minimize.png';
+ this.minimizeDiv = OpenLayers.Util.createAlphaImageDiv(
+ 'OpenLayers_Control_minimizeDiv',
+ null,
+ img,
+ 'absolute');
+ this.minimizeDiv.style.display = 'none';
+ this.minimizeDiv.className = this.displayClass + 'MinimizeButton';
+ OpenLayers.Event.observe(this.minimizeDiv, 'click',
+ OpenLayers.Function.bindAsEventListener(this.minimizeControl,
+ this)
+ this.div.appendChild(this.minimizeDiv);
+ var eventsToStop = ['dblclick','mousedown'];
+ for (var i = 0; i < eventsToStop.length; i++) {
+ eventsToStop[i],
+ OpenLayers.Event.stop);
+ eventsToStop[i],
+ this.minimizeControl();
+ } else {
+ // show the overview map
+ this.element.style.display = '';
+ if(this.map.getExtent()) {
+ this.update();
+ this.map.events.register('moveend', this, this.update);
+ return this.div;
+ * Method: baseLayerDraw
+ * Draw the base layer - called if unable to complete in the initial draw
+ baseLayerDraw: function() {
+ this.draw();
+ this.map.events.unregister("changebaselayer", this, this.baseLayerDraw);
+ * Method: rectDrag
+ * Handle extent rectangle drag
+ * Parameters:
+ * px - {<OpenLayers.Pixel>} The pixel location of the drag.
+ rectDrag: function(px) {
+ var deltaX = this.handlers.drag.last.x - px.x;
+ var deltaY = this.handlers.drag.last.y - px.y;
+ if(deltaX != 0 || deltaY != 0) {
+ var rectTop = this.rectPxBounds.top;
+ var rectLeft = this.rectPxBounds.left;
+ var rectHeight = Math.abs(this.rectPxBounds.getHeight());
+ var rectWidth = this.rectPxBounds.getWidth();
+ // don't allow dragging off of parent element
+ var newTop = Math.max(0, (rectTop - deltaY));
+ newTop = Math.min(newTop,
+ this.ovmap.size.h - this.hComp - rectHeight);
+ var newLeft = Math.max(0, (rectLeft - deltaX));
+ newLeft = Math.min(newLeft,
+ this.ovmap.size.w - this.wComp - rectWidth);
+ this.setRectPxBounds(new OpenLayers.Bounds(newLeft,
+ newTop + rectHeight,
+ newLeft + rectWidth,
+ newTop));
+ * Method: mapDivClick
+ * Handle browser events
+ * Parameters:
+ * evt - {<OpenLayers.Event>} evt
+ mapDivClick: function(evt) {
+ var pxCenter = this.rectPxBounds.getCenterPixel();
+ var deltaX = evt.xy.x - pxCenter.x;
+ var deltaY = evt.xy.y - pxCenter.y;
+ var top = this.rectPxBounds.top;
+ var left = this.rectPxBounds.left;
+ var height = Math.abs(this.rectPxBounds.getHeight());
+ var width = this.rectPxBounds.getWidth();
+ var newTop = Math.max(0, (top + deltaY));
+ newTop = Math.min(newTop, this.ovmap.size.h - height);
+ var newLeft = Math.max(0, (left + deltaX));
+ newLeft = Math.min(newLeft, this.ovmap.size.w - width);
+ newTop + height,
+ newLeft + width,
+ newTop));
+ this.updateMapToRect();
+ * Method: maximizeControl
+ * Unhide the control. Called when the control is in the map viewport.
+ * Parameters:
+ * e - {<OpenLayers.Event>}
+ maximizeControl: function(e) {
+ this.showToggle(false);
+ if (e != null) {
+ OpenLayers.Event.stop(e);
+ * Method: minimizeControl
+ * Hide all the contents of the control, shrink the size,
+ * add the maximize icon
+ * Parameters:
+ minimizeControl: function(e) {
+ this.showToggle(true);
+ if (e != null) {
+ * Method: showToggle
+ * Hide/Show the toggle depending on whether the control is minimized
+ * Parameters:
+ * minimize - {Boolean}
+ showToggle: function(minimize) {
+ this.maximizeDiv.style.display = minimize ? '' : 'none';
+ this.minimizeDiv.style.display = minimize ? 'none' : '';
+ * Method: update
+ * Update the overview map after layers move.
+ update: function() {
+ if(this.ovmap == null) {
+ this.createMap();
+ if(!this.isSuitableOverview()) {
+ this.updateOverview();
+ // update extent rectangle
+ this.updateRectToMap();
+ * Method: isSuitableOverview
+ * Determines if the overview map is suitable given the extent and
+ * resolution of the main map.
+ isSuitableOverview: function() {
+ var mapExtent = this.map.getExtent();
+ var maxExtent = this.map.maxExtent;
+ var testExtent = new OpenLayers.Bounds(
+ Math.max(mapExtent.left, maxExtent.left),
+ Math.max(mapExtent.bottom, maxExtent.bottom),
+ Math.min(mapExtent.right, maxExtent.right),
+ Math.min(mapExtent.top, maxExtent.top));
+ var resRatio = this.ovmap.getResolution() / this.map.getResolution();
+ return ((resRatio > this.minRatio) &&
+ (resRatio <= this.maxRatio) &&
+ (this.ovmap.getExtent().containsBounds(testExtent)));
+ * Method updateOverview
+ * Called by <update> if <isSuitableOverview> returns true
+ updateOverview: function() {
+ var mapRes = this.map.getResolution();
+ var targetRes = this.ovmap.getResolution();
+ var resRatio = targetRes / mapRes;
+ if(resRatio > this.maxRatio) {
+ // zoom in overview map
+ targetRes = this.minRatio * mapRes;
+ } else if(resRatio <= this.minRatio) {
+ // zoom out overview map
+ targetRes = this.maxRatio * mapRes;
+ this.ovmap.setCenter(this.map.center,
+ this.ovmap.getZoomForResolution(targetRes));
+ * Method: createMap
+ * Construct the map that this control contains
+ createMap: function() {
+ // create the overview map
+ var options = OpenLayers.Util.extend(
+ {controls: [], maxResolution: 'auto',
+ fallThrough: false}, this.mapOptions);
+ this.ovmap = new OpenLayers.Map(this.mapDiv, options);
+ // prevent ovmap from being destroyed when the page unloads, because
+ // the OverviewMap control has to do this (and does it).
+ OpenLayers.Event.stopObserving(window, 'unload', this.ovmap.unloadDestroy);
+ this.ovmap.addLayers(this.layers);
+ this.ovmap.zoomToMaxExtent();
+ // check extent rectangle border width
+ this.wComp = parseInt(OpenLayers.Element.getStyle(this.extentRectangle,
+ 'border-left-width')) +
+ parseInt(OpenLayers.Element.getStyle(this.extentRectangle,
+ 'border-right-width'));
+ this.wComp = (this.wComp) ? this.wComp : 2;
+ this.hComp = parseInt(OpenLayers.Element.getStyle(this.extentRectangle,
+ 'border-top-width')) +
+ 'border-bottom-width'));
+ this.hComp = (this.hComp) ? this.hComp : 2;
+ this.handlers.drag = new OpenLayers.Handler.Drag(
+ this, {move: this.rectDrag, done: this.updateMapToRect},
+ {map: this.ovmap}
+ this.handlers.click = new OpenLayers.Handler.Click(
+ this, {
+ "click": this.mapDivClick
+ "single": true, "double": false,
+ "stopSingle": true, "stopDouble": true,
+ "pixelTolerance": 1,
+ map: this.ovmap
+ this.handlers.click.activate();
+ this.rectEvents = new OpenLayers.Events(this, this.extentRectangle,
+ null, true);
+ this.rectEvents.register("mouseover", this, function(e) {
+ if(!this.handlers.drag.active && !this.map.dragging) {
+ this.handlers.drag.activate();
+ this.rectEvents.register("mouseout", this, function(e) {
+ if(!this.handlers.drag.dragging) {
+ this.handlers.drag.deactivate();
+ * Method: updateRectToMap
+ * Updates the extent rectangle position and size to match the map extent
+ updateRectToMap: function() {
+ // The base layer for overview map needs to be in the same projection
+ // as the base layer for the main map. This should be made more robust.
+ if(this.map.units != 'degrees') {
+ if(this.ovmap.getProjection() && (this.map.getProjection() != this.ovmap.getProjection())) {
+ alert(OpenLayers.i18n("sameProjection"));
+ var pxBounds = this.getRectBoundsFromMapBounds(this.map.getExtent());
+ if (pxBounds) {
+ this.setRectPxBounds(pxBounds);
+ * Method: updateMapToRect
+ * Updates the map extent to match the extent rectangle position and size
+ updateMapToRect: function() {
+ var lonLatBounds = this.getMapBoundsFromRectBounds(this.rectPxBounds);
+ this.map.panTo(lonLatBounds.getCenterLonLat());
+ * Method: setRectPxBounds
+ * Set extent rectangle pixel bounds.
+ * Parameters:
+ * pxBounds - {<OpenLayers.Bounds>}
+ setRectPxBounds: function(pxBounds) {
+ var top = Math.max(pxBounds.top, 0);
+ var left = Math.max(pxBounds.left, 0);
+ var bottom = Math.min(pxBounds.top + Math.abs(pxBounds.getHeight()),
+ this.ovmap.size.h - this.hComp);
+ var right = Math.min(pxBounds.left + pxBounds.getWidth(),
+ this.ovmap.size.w - this.wComp);
+ var width = Math.max(right - left, 0);
+ var height = Math.max(bottom - top, 0);
+ if(width < this.minRectSize || height < this.minRectSize) {
+ this.extentRectangle.className = this.displayClass +
+ this.minRectDisplayClass;
+ var rLeft = left + (width / 2) - (this.minRectSize / 2);
+ var rTop = top + (height / 2) - (this.minRectSize / 2);
+ this.extentRectangle.style.top = Math.round(rTop) + 'px';
+ this.extentRectangle.style.left = Math.round(rLeft) + 'px';
+ this.extentRectangle.style.height = this.minRectSize + 'px';
+ this.extentRectangle.style.width = this.minRectSize + 'px';
+ } else {
+ 'ExtentRectangle';
+ this.extentRectangle.style.top = Math.round(top) + 'px';
+ this.extentRectangle.style.left = Math.round(left) + 'px';
+ this.extentRectangle.style.height = Math.round(height) + 'px';
+ this.extentRectangle.style.width = Math.round(width) + 'px';
+ this.rectPxBounds = new OpenLayers.Bounds(
+ Math.round(left), Math.round(bottom),
+ Math.round(right), Math.round(top)
+ * Method: getRectBoundsFromMapBounds
+ * Get the rect bounds from the map bounds.
+ * Parameters:
+ * lonLatBounds - {<OpenLayers.Bounds>}
+ * Returns:
+ * {<OpenLayers.Bounds>}A bounds which is the passed-in map lon/lat extent
+ * translated into pixel bounds for the overview map
+ getRectBoundsFromMapBounds: function(lonLatBounds) {
+ var leftBottomLonLat = new OpenLayers.LonLat(lonLatBounds.left,
+ lonLatBounds.bottom);
+ var rightTopLonLat = new OpenLayers.LonLat(lonLatBounds.right,
+ lonLatBounds.top);
+ var leftBottomPx = this.getOverviewPxFromLonLat(leftBottomLonLat);
+ var rightTopPx = this.getOverviewPxFromLonLat(rightTopLonLat);
+ var bounds = null;
+ if (leftBottomPx && rightTopPx) {
+ bounds = new OpenLayers.Bounds(leftBottomPx.x, leftBottomPx.y,
+ rightTopPx.x, rightTopPx.y);
+ return bounds;
+ * Method: getMapBoundsFromRectBounds
+ * Get the map bounds from the rect bounds.
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Bounds>} Bounds which is the passed-in overview rect bounds
+ * translated into lon/lat bounds for the overview map
+ getMapBoundsFromRectBounds: function(pxBounds) {
+ var leftBottomPx = new OpenLayers.Pixel(pxBounds.left,
+ pxBounds.bottom);
+ var rightTopPx = new OpenLayers.Pixel(pxBounds.right,
+ pxBounds.top);
+ var leftBottomLonLat = this.getLonLatFromOverviewPx(leftBottomPx);
+ var rightTopLonLat = this.getLonLatFromOverviewPx(rightTopPx);
+ return new OpenLayers.Bounds(leftBottomLonLat.lon, leftBottomLonLat.lat,
+ rightTopLonLat.lon, rightTopLonLat.lat);
+ * Method: getLonLatFromOverviewPx
+ * Get a map location from a pixel location
+ * Parameters:
+ * overviewMapPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.LonLat>} Location which is the passed-in overview map
+ * OpenLayers.Pixel, translated into lon/lat by the overview map
+ getLonLatFromOverviewPx: function(overviewMapPx) {
+ var size = this.ovmap.size;
+ var res = this.ovmap.getResolution();
+ var center = this.ovmap.getExtent().getCenterLonLat();
+ var delta_x = overviewMapPx.x - (size.w / 2);
+ var delta_y = overviewMapPx.y - (size.h / 2);
+ return new OpenLayers.LonLat(center.lon + delta_x * res ,
+ center.lat - delta_y * res);
+ * Method: getOverviewPxFromLonLat
+ * Get a pixel location from a map location
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Pixel>} Location which is the passed-in OpenLayers.LonLat,
+ * translated into overview map pixels
+ getOverviewPxFromLonLat: function(lonlat) {
+ var extent = this.ovmap.getExtent();
+ var px = null;
+ if (extent) {
+ px = new OpenLayers.Pixel(
+ Math.round(1/res * (lonlat.lon - extent.left)),
+ Math.round(1/res * (extent.top - lonlat.lat)));
+ return px;
+ CLASS_NAME: 'OpenLayers.Control.OverviewMap'
+ OpenLayers/Handler/Click.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the clear BSD license.
+ * See http://svn.openlayers.org/trunk/openlayers/license.txt
+ * for the full text of the license. */
+ * @requires OpenLayers/Handler.js
+ * Class: OpenLayers.Handler.Click
+ * A handler for mouse clicks. The intention of this handler is to give
+ * controls more flexibility with handling clicks. Browsers trigger
+ * click events twice for a double-click. In addition, the mousedown,
+ * mousemove, mouseup sequence fires a click event. With this handler,
+ * controls can decide whether to ignore clicks associated with a double
+ * click. By setting a <pixelTolerance>, controls can also ignore clicks
+ * that include a drag. Create a new instance with the
+ * <OpenLayers.Handler.Click> constructor.
+ * Inherits from:
+ * - <OpenLayers.Handler>
+OpenLayers.Handler.Click = OpenLayers.Class(OpenLayers.Handler, {
+ * APIProperty: delay
+ * {Number} Number of milliseconds between clicks before the event is
+ * considered a double-click.
+ delay: 300,
+ * APIProperty: single
+ * {Boolean} Handle single clicks. Default is true. If false, clicks
+ * will not be reported. If true, single-clicks will be reported.
+ single: true,
+ * APIProperty: double
+ * {Boolean} Handle double-clicks. Default is false.
+ 'double': false,
+ * APIProperty: pixelTolerance
+ * {Number} Maximum number of pixels between mouseup and mousedown for an
+ * event to be considered a click. Default is 0. If set to an
+ * integer value, clicks with a drag greater than the value will be
+ * ignored. This property can only be set when the handler is
+ * constructed.
+ pixelTolerance: 0,
+ * APIProperty: stopSingle
+ * {Boolean} Stop other listeners from being notified of clicks. Default
+ * is false. If true, any click listeners registered before this one
+ * will not be notified of *any* click event (associated with double
+ * or single clicks).
+ stopSingle: false,
+ * APIProperty: stopDouble
+ * {Boolean} Stop other listeners from being notified of double-clicks.
+ * Default is false. If true, any click listeners registered before
+ * this one will not be notified of *any* double-click events.
+ * The one caveat with stopDouble is that given a map with two click
+ * handlers, one with stopDouble true and the other with stopSingle
+ * true, the stopSingle handler should be activated last to get
+ * uniform cross-browser performance. Since IE triggers one click
+ * with a dblclick and FF triggers two, if a stopSingle handler is
+ * activated first, all it gets in IE is a single click when the
+ * second handler stops propagation on the dblclick.
+ stopDouble: false,
+ * Property: timerId
+ * {Number} The id of the timeout waiting to clear the <delayedCall>.
+ timerId: null,
+ * Property: down
+ * {<OpenLayers.Pixel>} The pixel location of the last mousedown.
+ down: null,
+ * Constructor: OpenLayers.Handler.Click
+ * Create a new click handler.
+ * Parameters:
+ * control - {<OpenLayers.Control>} The control that is making use of
+ * this handler. If a handler is being used without a control, the
+ * handler's setMap method must be overridden to deal properly with
+ * the map.
+ * callbacks - {Object} An object with keys corresponding to callbacks
+ * that will be called by the handler. The callbacks should
+ * expect to recieve a single argument, the click event.
+ * Callbacks for 'click' and 'dblclick' are supported.
+ * options - {Object} Optional object whose properties will be set on the
+ * handler.
+ initialize: function(control, callbacks, options) {
+ OpenLayers.Handler.prototype.initialize.apply(this, arguments);
+ // optionally register for mouseup and mousedown
+ if(this.pixelTolerance != null) {
+ this.mousedown = function(evt) {
+ this.down = evt.xy;
+ return true;
+ * Method: mousedown
+ * Handle mousedown. Only registered as a listener if pixelTolerance is
+ * a non-zero value at construction.
+ * Returns:
+ * {Boolean} Continue propagating this event.
+ mousedown: null,
+ * Method: dblclick
+ * Handle dblclick. For a dblclick, we get two clicks in some browsers
+ * (FF) and one in others (IE). So we need to always register for
+ * dblclick to properly handle single clicks.
+ * Returns:
+ dblclick: function(evt) {
+ if(this.passesTolerance(evt)) {
+ if(this["double"]) {
+ this.callback('dblclick', [evt]);
+ this.clearTimer();
+ return !this.stopDouble;
+ * Method: click
+ * Handle click.
+ * Returns:
+ click: function(evt) {
+ if(this.timerId != null) {
+ // already received a click
+ } else {
+ // set the timer, send evt only if single is true
+ //use a clone of the event object because it will no longer
+ //be a valid event object in IE in the timer callback
+ var clickEvent = this.single ?
+ OpenLayers.Util.extend({}, evt) : null;
+ this.timerId = window.setTimeout(
+ OpenLayers.Function.bind(this.delayedCall, this, clickEvent),
+ this.delay
+ return !this.stopSingle;
+ * Method: passesTolerance
+ * Determine whether the event is within the optional pixel tolerance. Note
+ * that the pixel tolerance check only works if mousedown events get to
+ * the listeners registered here. If they are stopped by other elements,
+ * the <pixelTolerance> will have no effect here (this method will always
+ * return true).
+ * Returns:
+ * {Boolean} The click is within the pixel tolerance (if specified).
+ passesTolerance: function(evt) {
+ var passes = true;
+ if(this.pixelTolerance != null && this.down) {
+ var dpx = Math.sqrt(
+ Math.pow(this.down.x - evt.xy.x, 2) +
+ Math.pow(this.down.y - evt.xy.y, 2)
+ if(dpx > this.pixelTolerance) {
+ passes = false;
+ return passes;
+ * Method: clearTimer
+ * Clear the timer and set <timerId> to null.
+ clearTimer: function() {
+ window.clearTimeout(this.timerId);
+ this.timerId = null;
+ * Method: delayedCall
+ * Sets <timerId> to null. And optionally triggers the click callback if
+ * evt is set.
+ delayedCall: function(evt) {
+ if(evt) {
+ this.callback('click', [evt]);
+ * APIMethod: deactivate
+ * Deactivate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully deactivated.
+ deactivate: function() {
+ var deactivated = false;
+ if(OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
+ this.down = null;
+ deactivated = true;
+ return deactivated;
+ CLASS_NAME: "OpenLayers.Handler.Click"
+ OpenLayers/Handler/Drag.js
+ * Class: OpenLayers.Handler.Drag
+ * The drag handler is used to deal with sequences of browser events related
+ * to dragging. The handler is used by controls that want to know when
+ * a drag sequence begins, when a drag is happening, and when it has
+ * finished.
+ * Controls that use the drag handler typically construct it with callbacks
+ * for 'down', 'move', and 'done'. Callbacks for these keys are called
+ * when the drag begins, with each move, and when the drag is done. In
+ * addition, controls can have callbacks keyed to 'up' and 'out' if they
+ * care to differentiate between the types of events that correspond with
+ * the end of a drag sequence. If no drag actually occurs (no mouse move)
+ * the 'down' and 'up' callbacks will be called, but not the 'done'
+ * callback.
+ * Create a new drag handler with the <OpenLayers.Handler.Drag> constructor.
+ * Inherits from:
+OpenLayers.Handler.Drag = OpenLayers.Class(OpenLayers.Handler, {
+ * Property: started
+ * {Boolean} When a mousedown event is received, we want to record it, but
+ * not set 'dragging' until the mouse moves after starting.
+ started: false,
+ * Property: stopDown
+ * {Boolean} Stop propagation of mousedown events from getting to listeners
+ * on the same element. Default is true.
+ stopDown: true,
+ * Property: dragging
+ * {Boolean}
+ dragging: false,
+ * Property: last
+ * {<OpenLayers.Pixel>} The last pixel location of the drag.
+ last: null,
+ * Property: start
+ * {<OpenLayers.Pixel>} The first pixel location of the drag.
+ start: null,
+ * Property: oldOnselectstart
+ * {Function}
+ oldOnselectstart: null,
+ * Constructor: OpenLayers.Handler.Drag
+ * Returns OpenLayers.Handler.Drag
+ * Parameters:
+ * handlers setMap method must be overridden to deal properly with
+ * the map.
+ * callbacks - {Object} An object containing a single function to be
+ * called when the drag operation is finished. The callback should
+ * expect to recieve a single argument, the pixel location of the event.
+ * Callbacks for 'move' and 'done' are supported. You can also speficy
+ * callbacks for 'down', 'up', and 'out' to respond to those events.
+ * The four methods below (down, move, up, and out) are used by subclasses
+ * to do their own processing related to these mouse events.
+ * Method: down
+ * This method is called during the handling of the mouse down event.
+ * Subclasses can do their own processing here.
+ * Parameters:
+ * evt - {Event} The mouse down event
+ down: function(evt) {
+ * Method: move
+ * This method is called during the handling of the mouse move event.
+ * Parameters:
+ * evt - {Event} The mouse move event
+ move: function(evt) {
+ * Method: up
+ * This method is called during the handling of the mouse up event.
+ * Parameters:
+ * evt - {Event} The mouse up event
+ up: function(evt) {
+ * Method: out
+ * This method is called during the handling of the mouse out event.
+ * Parameters:
+ * evt - {Event} The mouse out event
+ out: function(evt) {
+ * The methods below are part of the magic of event handling. Because
+ * they are named like browser events, they are registered as listeners
+ * for the events they represent.
+ * Handle mousedown events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ * {Boolean} Let the event propagate.
+ mousedown: function (evt) {
+ var propagate = true;
+ this.dragging = false;
+ if (this.checkModifiers(evt) && OpenLayers.Event.isLeftClick(evt)) {
+ this.started = true;
+ this.start = evt.xy;
+ this.last = evt.xy;
+ // TBD replace with CSS classes
+ this.map.div.style.cursor = "move";
+ this.down(evt);
+ this.callback("down", [evt.xy]);
+ OpenLayers.Event.stop(evt);
+ if(!this.oldOnselectstart) {
+ this.oldOnselectstart = (document.onselectstart) ? document.onselectstart : function() { return true; };
+ document.onselectstart = function() {return false;};
+ propagate = !this.stopDown;
+ } else {
+ this.started = false;
+ this.start = null;
+ this.last = null;
+ return propagate;
+ * Method: mousemove
+ * Handle mousemove events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ mousemove: function (evt) {
+ if (this.started) {
+ if(evt.xy.x != this.last.x || evt.xy.y != this.last.y) {
+ this.dragging = true;
+ this.move(evt);
+ this.callback("move", [evt.xy]);
+ this.oldOnselectstart = document.onselectstart;
+ return true;
+ * Method: mouseup
+ * Handle mouseup events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ mouseup: function (evt) {
+ var dragged = (this.start != this.last);
+ this.map.div.style.cursor = "";
+ this.up(evt);
+ this.callback("up", [evt.xy]);
+ if(dragged) {
+ this.callback("done", [evt.xy]);
+ document.onselectstart = this.oldOnselectstart;
+ return true;
+ * Method: mouseout
+ * Handle mouseout events
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ mouseout: function (evt) {
+ if (this.started && OpenLayers.Util.mouseLeft(evt, this.map.div)) {
+ this.out(evt);
+ this.callback("out", []);
+ if(dragged) {
+ if(document.onselectstart) {
+ return true;
+ * Method: click
+ * The drag handler captures the click event. If something else registers
+ * for clicks on the same element, its listener will not be called
+ * after a drag.
+ * Parameters:
+ * evt - {Event}
+ * Returns:
+ click: function (evt) {
+ // let the click event propagate only if the mouse moved
+ return (this.start == this.last);
+ * Method: activate
+ * Activate the handler.
+ * Returns:
+ * {Boolean} The handler was successfully activated.
+ activate: function() {
+ var activated = false;
+ if(OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
+ activated = true;
+ return activated;
+ * Method: deactivate
+ * Returns:
+ this.last = null;
+ CLASS_NAME: "OpenLayers.Handler.Drag"
+ OpenLayers/Handler/MouseWheel.js
+ * Class: OpenLayers.Handler.MouseWheel
+ * Handler for wheel up/down events.
+ * Inherits from:
+OpenLayers.Handler.MouseWheel = OpenLayers.Class(OpenLayers.Handler, {
+ * Property: wheelListener
+ * {function}
+ wheelListener: null,
+ * Property: mousePosition
+ * {<OpenLayers.Pixel>} mousePosition is necessary because
+ * evt.clientX/Y is buggy in Moz on wheel events, so we cache and use the
+ * value from the last mousemove.
+ mousePosition: null,
+ * Constructor: OpenLayers.Handler.MouseWheel
+ * Parameters:
+ * The callback should expect to recieve a single
+ * argument, the point geometry.
+ this.wheelListener = OpenLayers.Function.bindAsEventListener(
+ this.onWheelEvent, this
+ * Method: destroy
+ OpenLayers.Handler.prototype.destroy.apply(this, arguments);
+ this.wheelListener = null;
+ * Mouse ScrollWheel code thanks to http://adomas.org/javascript-mouse-wheel/
+ * Method: onWheelEvent
+ * Catch the wheel event and handle it xbrowserly
+ * Parameters:
+ * e - {Event}
+ onWheelEvent: function(e){
+ // make sure we have a map and check keyboard modifiers
+ if (!this.map || !this.checkModifiers(e)) {
+ return;
+ // Ride up the element's DOM hierarchy to determine if it or any of
+ // its ancestors was:
+ // * specifically marked as scrollable
+ // * one of our layer divs
+ // * the map div
+ var overScrollableDiv = false;
+ var overLayerDiv = false;
+ var overMapDiv = false;
+ var elem = OpenLayers.Event.element(e);
+ while((elem != null) && !overMapDiv && !overScrollableDiv) {
+ if (!overScrollableDiv) {
+ try {
+ if (elem.currentStyle) {
+ overflow = elem.currentStyle["overflow"];
+ } else {
+ var style =
+ document.defaultView.getComputedStyle(elem, null);
+ var overflow = style.getPropertyValue("overflow");
+ overScrollableDiv = ( overflow &&
+ (overflow == "auto") || (overflow == "scroll") );
+ } catch(err) {
+ //sometimes when scrolling in a popup, this causes
+ // obscure browser error
+ if (!overLayerDiv) {
+ for(var i=0; i < this.map.layers.length; i++) {
+ // Are we in the layer div? Note that we have two cases
+ // here: one is to catch EventPane layers, which have a
+ // pane above the layer (layer.pane)
+ if (elem == this.map.layers[i].div
+ || elem == this.map.layers[i].pane) {
+ overLayerDiv = true;
+ break;
+ overMapDiv = (elem == this.map.div);
+ elem = elem.parentNode;
+ // Logic below is the following:
+ // If we are over a scrollable div or not over the map div:
+ // * do nothing (let the browser handle scrolling)
+ // otherwise
+ // If we are over the layer div:
+ // * zoom/in out
+ // then
+ // * kill event (so as not to also scroll the page after zooming)
+ // otherwise
+ // Kill the event (dont scroll the page if we wheel over the
+ // layerswitcher or the pan/zoom control)
+ if (!overScrollableDiv && overMapDiv) {
+ if (overLayerDiv) {
+ this.wheelZoom(e);
+ * Method: wheelZoom
+ * Given the wheel event, we carry out the appropriate zooming in or out,
+ * based on the 'wheelDelta' or 'detail' property of the event.
+ * Parameters:
+ * e - {Event}
+ wheelZoom: function(e) {
+ var delta = 0;
+ if (!e) {
+ e = window.event;
+ if (e.wheelDelta) {
+ delta = e.wheelDelta/120;
+ if (window.opera && window.opera.version() < 9.2) {
+ delta = -delta;
+ } else if (e.detail) {
+ delta = -e.detail / 3;
+ if (delta) {
+ // add the mouse position to the event because mozilla has
+ // a bug with clientX and clientY (see
+ // https://bugzilla.mozilla.org/show_bug.cgi?id=352179)
+ // getLonLatFromViewPortPx(e) returns wrong values
+ if (this.mousePosition) {
+ e.xy = this.mousePosition;
+ if (!e.xy) {
+ // If the mouse hasn't moved over the map yet, then
+ // we don't have a mouse position (in FF), so we just
+ // act as if the mouse was at the center of the map.
+ // Note that we can tell we are in the map -- and
+ // this.map is ensured to be true above.
+ e.xy = this.map.getPixelFromLonLat(
+ this.map.getCenter()
+ if (delta < 0) {
+ this.callback("down", [e, delta]);
+ } else {
+ this.callback("up", [e, delta]);
+ * Update the stored mousePosition on every move.
+ * Parameters:
+ * evt - {Event} The browser event
+ * Returns:
+ * {Boolean} Allow event propagation
+ this.mousePosition = evt.xy;
+ activate: function (evt) {
+ if (OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
+ //register mousewheel events specifically on the window and document
+ var wheelListener = this.wheelListener;
+ OpenLayers.Event.observe(window, "DOMMouseScroll", wheelListener);
+ OpenLayers.Event.observe(window, "mousewheel", wheelListener);
+ OpenLayers.Event.observe(document, "mousewheel", wheelListener);
+ return true;
+ } else {
+ return false;
+ deactivate: function (evt) {
+ if (OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
+ // unregister mousewheel events specifically on the window and document
+ OpenLayers.Event.stopObserving(window, "DOMMouseScroll", wheelListener);
+ OpenLayers.Event.stopObserving(window, "mousewheel", wheelListener);
+ OpenLayers.Event.stopObserving(document, "mousewheel", wheelListener);
+ return true;
+ } else {
+ return false;
+ CLASS_NAME: "OpenLayers.Handler.MouseWheel"
+ OpenLayers/Layer.js
+ * @requires OpenLayers/Map.js
+ * @requires OpenLayers/Projection.js
+ * Class: OpenLayers.Layer
+OpenLayers.Layer = OpenLayers.Class({
+ * APIProperty: id
+ * {String}
+ id: null,
+ * APIProperty: name
+ * {String}
+ name: null,
+ * APIProperty: div
+ * {DOMElement}
+ div: null,
+ * Property: opacity
+ * {Float} The layer's opacity. Float number between 0.0 and 1.0.
+ opacity: null,
+ * Constant: EVENT_TYPES
+ * {Array(String)} Supported application event types. Register a listener
+ * for a particular event with the following syntax:
+ * (code)
+ * layer.events.register(type, obj, listener);
+ * (end)
+ * Listeners will be called with a reference to an event object. The
+ * properties of this event depends on exactly what happened.
+ * All event objects have at least the following properties:
+ * - *object* {Object} A reference to layer.events.object.
+ * - *element* {DOMElement} A reference to layer.events.element.
+ * Supported map event types:
+ * - *loadstart* Triggered when layer loading starts.
+ * - *loadend* Triggered when layer loading ends.
+ * - *loadcancel* Triggered when layer loading is canceled.
+ * - *visibilitychanged* Triggered when layer visibility is changed.
+ EVENT_TYPES: ["loadstart", "loadend", "loadcancel", "visibilitychanged"],
+ * APIProperty: events
+ events: null,
+ * {<OpenLayers.Map>} This variable is set when the layer is added to
+ * the map, via the accessor function setMap().
+ map: null,
+ * APIProperty: isBaseLayer
+ * {Boolean} Whether or not the layer is a base layer. This should be set
+ * individually by all subclasses. Default is false
+ isBaseLayer: false,
+ * Property: alpha
+ * {Boolean} The layer's images have an alpha channel. Default is false.
+ alpha: false,
+ * APIProperty: displayInLayerSwitcher
+ * {Boolean} Display the layer's name in the layer switcher. Default is
+ * true.
+ displayInLayerSwitcher: true,
+ * APIProperty: visibility
+ * {Boolean} The layer should be displayed in the map. Default is true.
+ visibility: true,
+ * APIProperty: attribution
+ * {String} Attribution string, displayed when an
+ * <OpenLayers.Control.Attribution> has been added to the map.
+ attribution: null,
+ * Property: inRange
+ * {Boolean} The current map resolution is within the layer's min/max
+ * range. This is set in <OpenLayers.Map.setCenter> whenever the zoom
+ * changes.
+ inRange: false,
+ * Propery: imageSize
+ * {<OpenLayers.Size>} For layers with a gutter, the image is larger than
+ * the tile by twice the gutter in each dimension.
+ imageSize: null,
+ * Property: imageOffset
+ * {<OpenLayers.Pixel>} For layers with a gutter, the image offset
+ * represents displacement due to the gutter.
+ imageOffset: null,
+ // OPTIONS
+ * Property: options
+ * {Object} An optional object whose properties will be set on the layer.
+ * Any of the layer properties can be set as a property of the options
+ * object and sent to the constructor when the layer is created.
+ options: null,
+ * APIProperty: eventListeners
+ * {Object} If set as an option at construction, the eventListeners
+ * object will be registered with <OpenLayers.Events.on>. Object
+ * structure must be a listeners object as shown in the example for
+ * the events.on method.
+ eventListeners: null,
+ * APIProperty: gutter
+ * {Integer} Determines the width (in pixels) of the gutter around image
+ * tiles to ignore. By setting this property to a non-zero value,
+ * images will be requested that are wider and taller than the tile
+ * size by a value of 2 x gutter. This allows artifacts of rendering
+ * at tile edges to be ignored. Set a gutter value that is equal to
+ * half the size of the widest symbol that needs to be displayed.
+ * Defaults to zero. Non-tiled layers always have zero gutter.
+ gutter: 0,
+ * APIProperty: projection
+ * {<OpenLayers.Projection>} or {<String>} Set in the layer options to
+ * override the default projection string this layer - also set maxExtent,
+ * maxResolution, and units if appropriate. Can be either a string or
+ * an <OpenLayers.Projection> object when created -- will be converted
+ * to an object when setMap is called if a string is passed.
+ projection: null,
+ * APIProperty: units
+ * {String} The layer map units. Defaults to 'degrees'. Possible values
+ * are 'degrees' (or 'dd'), 'm', 'ft', 'km', 'mi', 'inches'.
+ units: null,
+ * APIProperty: scales
+ * {Array} An array of map scales in descending order. The values in the
+ * array correspond to the map scale denominator. Note that these
+ * values only make sense if the display (monitor) resolution of the
+ * client is correctly guessed by whomever is configuring the
+ * application. In addition, the units property must also be set.
+ * Use <resolutions> instead wherever possible.
+ scales: null,
+ * APIProperty: resolutions
+ * {Array} A list of map resolutions (map units per pixel) in descending
+ * order. If this is not set in the layer constructor, it will be set
+ * based on other resolution related properties (maxExtent,
+ * maxResolution, maxScale, etc.).
+ resolutions: null,
+ * APIProperty: maxExtent
+ * {<OpenLayers.Bounds>} The center of these bounds will not stray outside
+ * of the viewport extent during panning. In addition, if
+ * <displayOutsideMaxExtent> is set to false, data will not be
+ * requested that falls completely outside of these bounds.
+ maxExtent: null,
+ * APIProperty: minExtent
+ minExtent: null,
+ * APIProperty: maxResolution
+ * {Float} Default max is 360 deg / 256 px, which corresponds to
+ * zoom level 0 on gmaps. Specify a different value in the layer
+ * options if you are not using a geographic projection and
+ * displaying the whole world.
+ maxResolution: null,
+ * APIProperty: minResolution
+ * {Float}
+ minResolution: null,
+ * APIProperty: numZoomLevels
+ * {Integer}
+ numZoomLevels: null,
+ * APIProperty: minScale
+ * {Float}
+ minScale: null,
+ * APIProperty: maxScale
+ * {Float}
+ maxScale: null,
+ * APIProperty: displayOutsideMaxExtent
+ * {Boolean} Request map tiles that are completely outside of the max
+ * extent for this layer. Defaults to false.
+ displayOutsideMaxExtent: false,
+ * APIProperty: wrapDateLine
+ * {Boolean} #487 for more info.
+ wrapDateLine: false,
+ * APIProperty: transitionEffect
+ * {String} The transition effect to use when the map is panned or
+ * zoomed.
+ * There are currently two supported values:
+ * - *null* No transition effect (the default).
+ * - *resize* Existing tiles are resized on zoom to provide a visual
+ * effect of the zoom having taken place immediately. As the
+ * new tiles become available, they are drawn over top of the
+ * resized tiles.
+ transitionEffect: null,
+ * Property: SUPPORTED_TRANSITIONS
+ * {Array} An immutable (that means don't change it!) list of supported
+ * transitionEffect values.
+ SUPPORTED_TRANSITIONS: ['resize'],
+ * Constructor: OpenLayers.Layer
+ * Parameters:
+ * name - {String} The layer name
+ * options - {Object} Hashtable of extra options to tag onto the layer
+ initialize: function(name, options) {
+ this.addOptions(options);
+ this.name = name;
+ if (this.id == null) {
+ this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
+ this.div = OpenLayers.Util.createDiv(this.id);
+ this.div.style.width = "100%";
+ this.div.style.height = "100%";
+ this.events = new OpenLayers.Events(this, this.div,
+ this.EVENT_TYPES);
+ if(this.eventListeners instanceof Object) {
+ this.events.on(this.eventListeners);
+ if (this.wrapDateLine) {
+ this.displayOutsideMaxExtent = true;
+ * Method: destroy
+ * Destroy is a destructor: this is to alleviate cyclic references which
+ * the Javascript garbage cleaner can not take care of on its own.
+ * Parameters:
+ * setNewBaseLayer - {Boolean} Set a new base layer when this layer has
+ * been destroyed. Default is true.
+ destroy: function(setNewBaseLayer) {
+ if (setNewBaseLayer == null) {
+ setNewBaseLayer = true;
+ if (this.map != null) {
+ this.map.removeLayer(this, setNewBaseLayer);
+ this.projection = null;
+ this.map = null;
+ this.name = null;
+ this.div = null;
+ this.options = null;
+ if (this.events) {
+ if(this.eventListeners) {
+ this.events.un(this.eventListeners);
+ this.events.destroy();
+ this.eventListeners = null;
+ this.events = null;
+ * Method: clone
+ * Parameters:
+ * obj - {<OpenLayers.Layer>} The layer to be cloned
+ * Returns:
+ * {<OpenLayers.Layer>} An exact clone of this <OpenLayers.Layer>
+ obj = new OpenLayers.Layer(this.name, this.options);
+ // catch any randomly tagged-on properties
+ OpenLayers.Util.applyDefaults(obj, this);
+ // a cloned layer should never have its map property set
+ // because it has not been added to a map yet.
+ obj.map = null;
+ return obj;
+ * APIMethod: setName
+ * Sets the new layer name for this layer. Can trigger a changelayer event
+ * on the map.
+ * Parameters:
+ * newName - {String} The new name.
+ setName: function(newName) {
+ if (newName != this.name) {
+ this.name = newName;
+ this.map.events.triggerEvent("changelayer", {
+ layer: this,
+ property: "name"
+ * APIMethod: addOptions
+ * Parameters:
+ * newOptions - {Object}
+ addOptions: function (newOptions) {
+ if (this.options == null) {
+ this.options = {};
+ // update our copy for clone
+ OpenLayers.Util.extend(this.options, newOptions);
+ // add new options to this
+ OpenLayers.Util.extend(this, newOptions);
+ * APIMethod: onMapResize
+ * This function can be implemented by subclasses
+ onMapResize: function() {
+ //this function can be implemented by subclasses
+ * APIMethod: redraw
+ * Redraws the layer. Returns true if the layer was redrawn, false if not.
+ * Returns:
+ * {Boolean} The layer was redrawn.
+ redraw: function() {
+ var redrawn = false;
+ if (this.map) {
+ // min/max Range may have changed
+ this.inRange = this.calculateInRange();
+ // map's center might not yet be set
+ var extent = this.getExtent();
+ if (extent && this.inRange && this.visibility) {
+ this.moveTo(extent, true, false);
+ redrawn = true;
+ return redrawn;
+ * Method: moveTo
+ * Parameters:
+ * bound - {<OpenLayers.Bounds>}
+ * zoomChanged - {Boolean} Tells when zoom has changed, as layers have to
+ * do some init work in that case.
+ * dragging - {Boolean}
+ moveTo:function(bounds, zoomChanged, dragging) {
+ var display = this.visibility;
+ if (!this.isBaseLayer) {
+ display = display && this.inRange;
+ this.display(display);
+ * Method: setMap
+ * Set the map property for the layer. This is done through an accessor
+ * so that subclasses can override this and take special action once
+ * they have their map variable set.
+ * Here we take care to bring over any of the necessary default
+ * properties from the map.
+ * Parameters:
+ * map - {<OpenLayers.Map>}
+ setMap: function(map) {
+ if (this.map == null) {
+ this.map = map;
+ // grab some essential layer data from the map if it hasn't already
+ // been set
+ this.maxExtent = this.maxExtent || this.map.maxExtent;
+ this.projection = this.projection || this.map.projection;
+ if (this.projection && typeof this.projection == "string") {
+ this.projection = new OpenLayers.Projection(this.projection);
+ // Check the projection to see if we can get units -- if not, refer
+ // to properties.
+ this.units = this.projection.getUnits() ||
+ this.units || this.map.units;
+ this.initResolutions();
+ var show = ((this.visibility) && (this.inRange));
+ this.div.style.display = show ? "" : "none";
+ // deal with gutters
+ this.setTileSize();
+ * APIMethod: removeMap
+ * Just as setMap() allows each layer the possibility to take a
+ * personalized action on being added to the map, removeMap() allows
+ * each layer to take a personalized action on being removed from it.
+ * For now, this will be mostly unused, except for the EventPane layer,
+ * which needs this hook so that it can remove the special invisible
+ * pane.
+ * Parameters:
+ removeMap: function(map) {
+ //to be overridden by subclasses
+ * APIMethod: getImageSize
+ * Returns:
+ * {<OpenLayers.Size>} The size that the image should be, taking into
+ * account gutters.
+ getImageSize: function() {
+ return (this.imageSize || this.tileSize);
+ * APIMethod: setTileSize
+ * Set the tile size based on the map size. This also sets layer.imageSize
+ * and layer.imageOffset for use by Tile.Image.
+ * Parameters:
+ setTileSize: function(size) {
+ var tileSize = (size) ? size :
+ ((this.tileSize) ? this.tileSize :
+ this.map.getTileSize());
+ this.tileSize = tileSize;
+ if(this.gutter) {
+ // layers with gutters need non-null tile sizes
+ //if(tileSize == null) {
+ // OpenLayers.console.error("Error in layer.setMap() for " +
+ // this.name + ": layers with " +
+ // "gutters need non-null tile sizes");
+ this.imageOffset = new OpenLayers.Pixel(-this.gutter,
+ -this.gutter);
+ this.imageSize = new OpenLayers.Size(tileSize.w + (2*this.gutter),
+ tileSize.h + (2*this.gutter));
+ * APIMethod: getVisibility
+ * Returns:
+ * {Boolean} The layer should be displayed (if in range).
+ getVisibility: function() {
+ return this.visibility;
+ * APIMethod: setVisibility
+ * Set the visibility flag for the layer and hide/show & redraw
+ * accordingly. Fire event unless otherwise specified
+ * Note that visibility is no longer simply whether or not the layer's
+ * style.display is set to "block". Now we store a 'visibility' state
+ * property on the layer class, this allows us to remember whether or
+ * not we *desire* for a layer to be visible. In the case where the
+ * map's resolution is out of the layer's range, this desire may be
+ * subverted.
+ * Parameters:
+ * visible - {Boolean} Whether or not to display the layer (if in range)
+ setVisibility: function(visibility) {
+ if (visibility != this.visibility) {
+ this.visibility = visibility;
+ this.display(visibility);
+ this.redraw();
+ layer: this,
+ property: "visibility"
+ this.events.triggerEvent("visibilitychanged");
+ * APIMethod: display
+ * Hide or show the Layer
+ * Parameters:
+ * display - {Boolean}
+ display: function(display) {
+ var inRange = this.calculateInRange();
+ if (display != (this.div.style.display != "none")) {
+ this.div.style.display = (display && inRange) ? "block" : "none";
+ * Method: calculateInRange
+ * Returns:
+ * {Boolean} The layer is displayable at the current map's current
+ * resolution.
+ calculateInRange: function() {
+ var inRange = false;
+ if (this.map) {
+ var resolution = this.map.getResolution();
+ inRange = ( (resolution >= this.minResolution) &&
+ (resolution <= this.maxResolution) );
+ return inRange;
+ * APIMethod: setIsBaseLayer
+ * Parameters:
+ * isBaseLayer - {Boolean}
+ setIsBaseLayer: function(isBaseLayer) {
+ if (isBaseLayer != this.isBaseLayer) {
+ this.isBaseLayer = isBaseLayer;
+ this.map.events.triggerEvent("changebaselayer", {
+ layer: this
+ /* Baselayer Functions */
+ * Method: initResolutions
+ * This method's responsibility is to set up the 'resolutions' array
+ * for the layer -- this array is what the layer will use to interface
+ * between the zoom levels of the map and the resolution display
+ * of the layer.
+ * The user has several options that determine how the array is set up.
+ * For a detailed explanation, see the following wiki from the
+ * openlayers.org homepage:
+ * http://trac.openlayers.org/wiki/SettingZoomLevels
+ initResolutions: function() {
+ // These are the relevant options which are used for calculating
+ // resolutions information.
+ var props = new Array(
+ 'projection', 'units',
+ 'scales', 'resolutions',
+ 'maxScale', 'minScale',
+ 'maxResolution', 'minResolution',
+ 'minExtent', 'maxExtent',
+ 'numZoomLevels', 'maxZoomLevel'
+ // First we create a new object where we will store all of the
+ // resolution-related properties that we find in either the layer's
+ // 'options' array or from the map.
+ var confProps = {};
+ for(var i=0; i < props.length; i++) {
+ var property = props[i];
+ confProps[property] = this.options[property] || this.map[property];
+ // Do not use the scales/resolutions at the map level if
+ // minScale/minResolution and maxScale/maxResolution are
+ // specified at the layer level
+ if (this.options.minScale != null &&
+ this.options.maxScale != null &&
+ this.options.scales == null) {
+ confProps.scales = null;
+ if (this.options.minResolution != null &&
+ this.options.maxResolution != null &&
+ this.options.resolutions == null) {
+ confProps.resolutions = null;
+ // If numZoomLevels hasn't been set and the maxZoomLevel *has*,
+ // then use maxZoomLevel to calculate numZoomLevels
+ if ( (!confProps.numZoomLevels) && (confProps.maxZoomLevel) ) {
+ confProps.numZoomLevels = confProps.maxZoomLevel + 1;
+ // First off, we take whatever hodge-podge of values we have and
+ // calculate/distill them down into a resolutions[] array
+ if ((confProps.scales != null) || (confProps.resolutions != null)) {
+ //preset levels
+ if (confProps.scales != null) {
+ confProps.resolutions = [];
+ for(var i = 0; i < confProps.scales.length; i++) {
+ var scale = confProps.scales[i];
+ confProps.resolutions[i] =
+ OpenLayers.Util.getResolutionFromScale(scale,
+ confProps.units);
+ confProps.numZoomLevels = confProps.resolutions.length;
+ } else {
+ //maxResolution and numZoomLevels based calculation
+ // determine maxResolution
+ if (confProps.minScale) {
+ confProps.maxResolution =
+ OpenLayers.Util.getResolutionFromScale(confProps.minScale,
+ confProps.units);
+ } else if (confProps.maxResolution == "auto") {
+ var viewSize = this.map.getSize();
+ var wRes = confProps.maxExtent.getWidth() / viewSize.w;
+ var hRes = confProps.maxExtent.getHeight()/ viewSize.h;
+ confProps.maxResolution = Math.max(wRes, hRes);
+ // determine minResolution
+ if (confProps.maxScale != null) {
+ confProps.minResolution =
+ OpenLayers.Util.getResolutionFromScale(confProps.maxScale,
+ confProps.units);
+ } else if ( (confProps.minResolution == "auto") &&
+ (confProps.minExtent != null) ) {
+ var wRes = confProps.minExtent.getWidth() / viewSize.w;
+ var hRes = confProps.minExtent.getHeight()/ viewSize.h;
+ confProps.minResolution = Math.max(wRes, hRes);
+ // determine numZoomLevels if not already set on the layer
+ // this gives numZoomLevels assuming approximately base 2 scaling
+ if (confProps.minResolution != null &&
+ this.options.numZoomLevels == undefined) {
+ var ratio = confProps.maxResolution / confProps.minResolution;
+ Math.floor(Math.log(ratio) / Math.log(2)) + 1;
+ // now we have numZoomLevels and maxResolution,
+ // we can populate the resolutions array
+ confProps.resolutions = new Array(confProps.numZoomLevels);
+ var base = 2;
+ if(typeof confProps.minResolution == "number" &&
+ confProps.numZoomLevels > 1) {
+ * If maxResolution and minResolution are set (or related
+ * scale properties), we calculate the base for exponential
+ * scaling that starts at maxResolution and ends at
+ * minResolution in numZoomLevels steps.
+ base = Math.pow(
+ (confProps.maxResolution / confProps.minResolution),
+ (1 / (confProps.numZoomLevels - 1))
+ for (var i=0; i < confProps.numZoomLevels; i++) {
+ var res = confProps.maxResolution / Math.pow(base, i);
+ confProps.resolutions[i] = res;
+ //sort resolutions array ascendingly
+ confProps.resolutions.sort( function(a, b) { return(b-a); } );
+ // now set our newly calculated values back to the layer
+ // Note: We specifically do *not* set them to layer.options, which we
+ // will preserve as it was when we added this layer to the map.
+ // this way cloned layers reset themselves to new map div
+ // dimensions)
+ this.resolutions = confProps.resolutions;
+ this.maxResolution = confProps.resolutions[0];
+ var lastIndex = confProps.resolutions.length - 1;
+ this.minResolution = confProps.resolutions[lastIndex];
+ this.scales = [];
+ for(var i = 0; i < confProps.resolutions.length; i++) {
+ this.scales[i] =
+ OpenLayers.Util.getScaleFromResolution(confProps.resolutions[i],
+ confProps.units);
+ this.minScale = this.scales[0];
+ this.maxScale = this.scales[this.scales.length - 1];
+ this.numZoomLevels = confProps.numZoomLevels;
+ * APIMethod: getResolution
+ * Returns:
+ * {Float} The currently selected resolution of the map, taken from the
+ * resolutions array, indexed by current zoom level.
+ getResolution: function() {
+ var zoom = this.map.getZoom();
+ return this.getResolutionForZoom(zoom);
+ * APIMethod: getExtent
+ * Returns:
+ * {<OpenLayers.Bounds>} A Bounds object which represents the lon/lat
+ * bounds of the current viewPort.
+ getExtent: function() {
+ // just use stock map calculateBounds function -- passing no arguments
+ // means it will user map's current center & resolution
+ return this.map.calculateBounds();
+ * APIMethod: getZoomForExtent
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>}
+ * closest - {Boolean} Find the zoom level that most closely fits the
+ * specified bounds. Note that this may result in a zoom that does
+ * not exactly contain the entire extent.
+ * Returns:
+ * {Integer} The index of the zoomLevel (entry in the resolutions array)
+ * for the passed-in extent. We do this by calculating the ideal
+ * resolution for the given extent (based on the map size) and then
+ * calling getZoomForResolution(), passing along the 'closest'
+ * parameter.
+ getZoomForExtent: function(extent, closest) {
+ var idealResolution = Math.max( extent.getWidth() / viewSize.w,
+ extent.getHeight() / viewSize.h );
+ return this.getZoomForResolution(idealResolution, closest);
+ * Method: getDataExtent
+ * Calculates the max extent which includes all of the data for the layer.
+ * This function is to be implemented by subclasses.
+ * Returns:
+ getDataExtent: function () {
+ //to be implemented by subclasses
+ * APIMethod: getResolutionForZoom
+ * Parameter:
+ * zoom - {Float}
+ * Returns:
+ * {Float} A suitable resolution for the specified zoom.
+ getResolutionForZoom: function(zoom) {
+ zoom = Math.max(0, Math.min(zoom, this.resolutions.length - 1));
+ var resolution;
+ if(this.map.fractionalZoom) {
+ var low = Math.floor(zoom);
+ var high = Math.ceil(zoom);
+ resolution = this.resolutions[high] +
+ ((zoom-low) * (this.resolutions[low]-this.resolutions[high]));
+ } else {
+ resolution = this.resolutions[Math.round(zoom)];
+ return resolution;
+ * APIMethod: getZoomForResolution
+ * Parameters:
+ * resolution - {Float}
+ * closest - {Boolean} Find the zoom level that corresponds to the absolute
+ * closest resolution, which may result in a zoom whose corresponding
+ * resolution is actually smaller than we would have desired (if this
+ * is being called from a getZoomForExtent() call, then this means that
+ * the returned zoom index might not actually contain the entire
+ * extent specified... but it'll be close).
+ * Returns:
+ * that corresponds to the best fit resolution given the passed in
+ * value and the 'closest' specification.
+ getZoomForResolution: function(resolution, closest) {
+ var zoom;
+ var lowZoom = 0;
+ var highZoom = this.resolutions.length - 1;
+ var highRes = this.resolutions[lowZoom];
+ var lowRes = this.resolutions[highZoom];
+ var res;
+ for(var i=0; i<this.resolutions.length; ++i) {
+ res = this.resolutions[i];
+ if(res >= resolution) {
+ highRes = res;
+ lowZoom = i;
+ if(res <= resolution) {
+ lowRes = res;
+ highZoom = i;
+ break;
+ var dRes = highRes - lowRes;
+ if(dRes > 0) {
+ zoom = lowZoom + ((resolution - lowRes) / dRes);
+ } else {
+ zoom = lowZoom;
+ } else {
+ var diff;
+ var minDiff = Number.POSITIVE_INFINITY;
+ for(var i=0; i < this.resolutions.length; i++) {
+ if (closest) {
+ diff = Math.abs(this.resolutions[i] - resolution);
+ if (diff > minDiff) {
+ break;
+ minDiff = diff;
+ } else {
+ if (this.resolutions[i] < resolution) {
+ break;
+ zoom = Math.max(0, i-1);
+ return zoom;
+ * APIMethod: getLonLatFromViewPortPx
+ * Parameters:
+ * viewPortPx - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.LonLat>} An OpenLayers.LonLat which is the passed-in
+ * view port <OpenLayers.Pixel>, translated into lon/lat by the layer.
+ getLonLatFromViewPortPx: function (viewPortPx) {
+ var lonlat = null;
+ if (viewPortPx != null) {
+ var size = this.map.getSize();
+ var center = this.map.getCenter();
+ if (center) {
+ var res = this.map.getResolution();
+ var delta_x = viewPortPx.x - (size.w / 2);
+ var delta_y = viewPortPx.y - (size.h / 2);
+ lonlat = new OpenLayers.LonLat(center.lon + delta_x * res ,
+ lonlat = lonlat.wrapDateLine(this.maxExtent);
+ } // else { DEBUG STATEMENT }
+ return lonlat;
+ * APIMethod: getViewPortPxFromLonLat
+ * Returns a pixel location given a map location. This method will return
+ * fractional pixel values.
+ * Parameters:
+ * lonlat - {<OpenLayers.LonLat>}
+ * Returns:
+ * {<OpenLayers.Pixel>} An <OpenLayers.Pixel> which is the passed-in
+ * <OpenLayers.LonLat>,translated into view port pixels.
+ getViewPortPxFromLonLat: function (lonlat) {
+ var px = null;
+ if (lonlat != null) {
+ var extent = this.map.getExtent();
+ (1/resolution * (lonlat.lon - extent.left)),
+ (1/resolution * (extent.top - lonlat.lat))
+ return px;
+ * APIMethod: setOpacity
+ * Sets the opacity for the entire layer (all images)
+ * Parameter:
+ * opacity - {Float}
+ setOpacity: function(opacity) {
+ if (opacity != this.opacity) {
+ this.opacity = opacity;
+ for(var i=0; i<this.div.childNodes.length; ++i) {
+ var element = this.div.childNodes[i].firstChild;
+ OpenLayers.Util.modifyDOMElement(element, null, null, null,
+ null, null, null, opacity);
+ * Method: setZIndex
+ * Parameters:
+ * zIndex - {Integer}
+ setZIndex: function (zIndex) {
+ this.div.style.zIndex = zIndex;
+ * Method: adjustBounds
+ * This function will take a bounds, and if wrapDateLine option is set
+ * on the layer, it will return a bounds which is wrapped around the
+ * world. We do not wrap for bounds which *cross* the
+ * maxExtent.left/right, only bounds which are entirely to the left
+ * or entirely to the right.
+ * Parameters:
+ adjustBounds: function (bounds) {
+ if (this.gutter) {
+ // Adjust the extent of a bounds in map units by the
+ // layer's gutter in pixels.
+ var mapGutter = this.gutter * this.map.getResolution();
+ bounds = new OpenLayers.Bounds(bounds.left - mapGutter,
+ bounds.bottom - mapGutter,
+ bounds.right + mapGutter,
+ bounds.top + mapGutter);
+ // wrap around the date line, within the limits of rounding error
+ var wrappingOptions = {
+ 'rightTolerance':this.getResolution()
+ bounds = bounds.wrapDateLine(this.maxExtent, wrappingOptions);
+ return bounds;
+ CLASS_NAME: "OpenLayers.Layer"
+ OpenLayers/Marker/Box.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * @requires OpenLayers/Marker.js
+ * Class: OpenLayers.Marker.Box
+ * Inherits from:
+ * - <OpenLayers.Marker>
+OpenLayers.Marker.Box = OpenLayers.Class(OpenLayers.Marker, {
+ * Property: bounds
+ bounds: null,
+ * Property: div
+ * {DOMElement}
+ div: null,
+ * Constructor: OpenLayers.Marker.Box
+ * Parameters:
+ * borderColor - {String}
+ * borderWidth - {int}
+ initialize: function(bounds, borderColor, borderWidth) {
+ this.bounds = bounds;
+ this.div = OpenLayers.Util.createDiv();
+ this.div.style.overflow = 'hidden';
+ this.events = new OpenLayers.Events(this, this.div, null);
+ this.setBorder(borderColor, borderWidth);
+ * Method: destroy
+ destroy: function() {
+ this.bounds = null;
+ this.div = null;
+ OpenLayers.Marker.prototype.destroy.apply(this, arguments);
+ * Method: setBorder
+ * Allow the user to change the box's color and border width
+ * Parameters:
+ * color - {String} Default is "red"
+ * width - {int} Default is 2
+ setBorder: function (color, width) {
+ if (!color) {
+ color = "red";
+ if (!width) {
+ width = 2;
+ this.div.style.border = width + "px solid " + color;
+ * Method: draw
+ * Parameters:
+ * sz - {<OpenLayers.Size>}
+ * Returns:
+ * {DOMElement} A new DOM Image with this marker´s icon set at the
+ * location passed-in
+ draw: function(px, sz) {
+ OpenLayers.Util.modifyDOMElement(this.div, null, px, sz);
+ return this.div;
+ * Method: onScreen
+ * Rreturn:
+ * {Boolean} Whether or not the marker is currently visible on screen.
+ onScreen:function() {
+ var onScreen = false;
+ if (this.map) {
+ var screenBounds = this.map.getExtent();
+ onScreen = screenBounds.containsBounds(this.bounds, true, true);
+ return onScreen;
+ * Method: display
+ * Hide or show the icon
+ * Parameters:
+ this.div.style.display = (display) ? "" : "none";
+ CLASS_NAME: "OpenLayers.Marker.Box"
+ OpenLayers/Control/DragPan.js
+ * @requires OpenLayers/Control.js
+ * @requires OpenLayers/Handler/Drag.js
+ * Class: OpenLayers.Control.DragPan
+ * DragPan control.
+ * Inherits from:
+ * - <OpenLayers.Control>
+OpenLayers.Control.DragPan = OpenLayers.Class(OpenLayers.Control, {
+ * Property: type
+ * {OpenLayers.Control.TYPES}
+ type: OpenLayers.Control.TYPE_TOOL,
+ * Property: panned
+ * {Boolean} The map moved.
+ panned: false,
+ * Method: draw
+ * Creates a Drag handler, using <panMap> and
+ * <panMapDone> as callbacks.
+ draw: function() {
+ this.handler = new OpenLayers.Handler.Drag(this,
+ {"move": this.panMap, "done": this.panMapDone});
+ * Method: panMap
+ * Parameters:
+ * xy - {<OpenLayers.Pixel>} Pixel of the mouse position
+ panMap: function(xy) {
+ this.panned = true;
+ this.map.pan(
+ this.handler.last.x - xy.x,
+ this.handler.last.y - xy.y,
+ {dragging: this.handler.dragging, animate: false}
+ * Method: panMapDone
+ * Finish the panning operation. Only call setCenter (through <panMap>)
+ * if the map has actually been moved.
+ * Parameters:
+ panMapDone: function(xy) {
+ if(this.panned) {
+ this.panMap(xy);
+ this.panned = false;
+ CLASS_NAME: "OpenLayers.Control.DragPan"
+ OpenLayers/Handler/Box.js
+ * Class: OpenLayers.Handler.Box
+ * Handler for dragging a rectangle across the map. Box is displayed
+ * on mouse down, moves on mouse move, and is finished on mouse up.
+ * Inherits from:
+OpenLayers.Handler.Box = OpenLayers.Class(OpenLayers.Handler, {
+ * Property: dragHandler
+ * {<OpenLayers.Handler.Drag>}
+ dragHandler: null,
+ * APIProperty: boxDivClassName
+ * {String} The CSS class to use for drawing the box. Default is
+ * olHandlerBoxZoomBox
+ boxDivClassName: 'olHandlerBoxZoomBox',
+ * Constructor: OpenLayers.Handler.Box
+ * Parameters:
+ var callbacks = {
+ "down": this.startBox,
+ "move": this.moveBox,
+ "out": this.removeBox,
+ "up": this.endBox
+ this.dragHandler = new OpenLayers.Handler.Drag(
+ this, callbacks, {keyMask: this.keyMask});
+ * Method: setMap
+ setMap: function (map) {
+ OpenLayers.Handler.prototype.setMap.apply(this, arguments);
+ if (this.dragHandler) {
+ this.dragHandler.setMap(map);
+ * Method: startBox
+ * Parameters:
+ * evt - {Event}
+ startBox: function (xy) {
+ this.zoomBox = OpenLayers.Util.createDiv('zoomBox',
+ this.dragHandler.start);
+ this.zoomBox.className = this.boxDivClassName;
+ this.zoomBox.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
+ this.map.viewPortDiv.appendChild(this.zoomBox);
+ // TBD: use CSS classes instead
+ this.map.div.style.cursor = "crosshair";
+ * Method: moveBox
+ moveBox: function (xy) {
+ var deltaX = Math.abs(this.dragHandler.start.x - xy.x);
+ var deltaY = Math.abs(this.dragHandler.start.y - xy.y);
+ this.zoomBox.style.width = Math.max(1, deltaX) + "px";
+ this.zoomBox.style.height = Math.max(1, deltaY) + "px";
+ if (xy.x < this.dragHandler.start.x) {
+ this.zoomBox.style.left = xy.x+"px";
+ if (xy.y < this.dragHandler.start.y) {
+ this.zoomBox.style.top = xy.y+"px";
+ * Method: endBox
+ endBox: function(end) {
+ var result;
+ if (Math.abs(this.dragHandler.start.x - end.x) > 5 ||
+ Math.abs(this.dragHandler.start.y - end.y) > 5) {
+ var start = this.dragHandler.start;
+ var top = Math.min(start.y, end.y);
+ var bottom = Math.max(start.y, end.y);
+ var left = Math.min(start.x, end.x);
+ var right = Math.max(start.x, end.x);
+ result = new OpenLayers.Bounds(left, bottom, right, top);
+ } else {
+ result = this.dragHandler.start.clone(); // i.e. OL.Pixel
+ this.removeBox();
+ this.callback("done", [result]);
+ * Method: removeBox
+ * Remove the zoombox from the screen and nullify our reference to it.
+ removeBox: function() {
+ this.map.viewPortDiv.removeChild(this.zoomBox);
+ this.zoomBox = null;
+ activate: function () {
+ this.dragHandler.activate();
+ return true;
+ } else {
+ return false;
+ deactivate: function () {
+ this.dragHandler.deactivate();
+ return true;
+ } else {
+ return false;
+ CLASS_NAME: "OpenLayers.Handler.Box"
+ OpenLayers/Layer/HTTPRequest.js
+ * @requires OpenLayers/Layer.js
+ * Class: OpenLayers.Layer.HTTPRequest
+ * Inherits from:
+ * - <OpenLayers.Layer>
+OpenLayers.Layer.HTTPRequest = OpenLayers.Class(OpenLayers.Layer, {
+ * Constant: URL_HASH_FACTOR
+ * {Float} Used to hash URL param strings for multi-WMS server selection.
+ * Set to the Golden Ratio per Knuth's recommendation.
+ URL_HASH_FACTOR: (Math.sqrt(5) - 1) / 2,
+ * Property: url
+ * {Array(String) or String} This is either an array of url strings or
+ * a single url string.
+ url: null,
+ * Property: params
+ * {Object} Hashtable of key/value parameters
+ params: null,
+ * APIProperty: reproject
+ * *Deprecated*. See http://trac.openlayers.org/wiki/SpatialMercator
+ * for information on the replacement for this functionality.
+ * {Boolean} Whether layer should reproject itself based on base layer
+ * locations. This allows reprojection onto commercial layers.
+ * Default is false: Most layers can't reproject, but layers
+ * which can create non-square geographic pixels can, like WMS.
+ reproject: false,
+ * Constructor: OpenLayers.Layer.HTTPRequest
+ * Parameters:
+ * name - {String}
+ * url - {Array(String) or String}
+ * params - {Object}
+ initialize: function(name, url, params, options) {
+ var newArguments = arguments;
+ newArguments = [name, options];
+ OpenLayers.Layer.prototype.initialize.apply(this, newArguments);
+ this.url = url;
+ this.params = OpenLayers.Util.extend( {}, params);
+ * APIMethod: destroy
+ this.url = null;
+ this.params = null;
+ OpenLayers.Layer.prototype.destroy.apply(this, arguments);
+ * APIMethod: clone
+ * Parameters:
+ * obj - {Object}
+ * Returns:
+ * {<OpenLayers.Layer.HTTPRequest>} An exact clone of this
+ * <OpenLayers.Layer.HTTPRequest>
+ clone: function (obj) {
+ if (obj == null) {
+ obj = new OpenLayers.Layer.HTTPRequest(this.name,
+ this.url,
+ this.params,
+ this.options);
+ //get all additions from superclasses
+ obj = OpenLayers.Layer.prototype.clone.apply(this, [obj]);
+ // copy/set any non-init, non-simple values here
+ return obj;
+ * APIMethod: setUrl
+ * Parameters:
+ * newUrl - {String}
+ setUrl: function(newUrl) {
+ this.url = newUrl;
+ * APIMethod: mergeNewParams
+ * Parameters:
+ * newParams - {Object}
+ * Returns:
+ * redrawn: {Boolean} whether the layer was actually redrawn.
+ mergeNewParams:function(newParams) {
+ this.params = OpenLayers.Util.extend(this.params, newParams);
+ return this.redraw();
+ * Parameters:
+ * force - {Boolean} Force redraw by adding random parameter.
+ * Returns:
+ redraw: function(force) {
+ if (force) {
+ return this.mergeNewParams({"_olSalt": Math.random()});
+ } else {
+ return OpenLayers.Layer.prototype.redraw.apply(this, []);
+ * Method: selectUrl
+ * selectUrl() implements the standard floating-point multiplicative
+ * hash function described by Knuth, and hashes the contents of the
+ * given param string into a float between 0 and 1. This float is then
+ * scaled to the size of the provided urls array, and used to select
+ * a URL.
+ * Parameters:
+ * paramString - {String}
+ * urls - {Array(String)}
+ * Returns:
+ * {String} An entry from the urls array, deterministically selected based
+ * on the paramString.
+ selectUrl: function(paramString, urls) {
+ var product = 1;
+ for (var i = 0; i < paramString.length; i++) {
+ product *= paramString.charCodeAt(i) * this.URL_HASH_FACTOR;
+ product -= Math.floor(product);
+ return urls[Math.floor(product * urls.length)];
+ * Method: getFullRequestString
+ * Combine url with layer's params and these newParams.
+ * does checking on the serverPath variable, allowing for cases when it
+ * is supplied with trailing ? or &, as well as cases where not.
+ * return in formatted string like this:
+ * "server?key1=value1&key2=value2&key3=value3"
+ * WARNING: The altUrl parameter is deprecated and will be removed in 3.0.
+ * Parameters:
+ * altUrl - {String} Use this as the url instead of the layer's url
+ * Returns:
+ * {String}
+ getFullRequestString:function(newParams, altUrl) {
+ // if not altUrl passed in, use layer's url
+ var url = altUrl || this.url;
+ // create a new params hashtable with all the layer params and the
+ // new params together. then convert to string
+ var allParams = OpenLayers.Util.extend({}, this.params);
+ allParams = OpenLayers.Util.extend(allParams, newParams);
+ var paramsString = OpenLayers.Util.getParameterString(allParams);
+ // if url is not a string, it should be an array of strings,
+ // in which case we will deterministically select one of them in
+ // order to evenly distribute requests to different urls.
+ if (url instanceof Array) {
+ url = this.selectUrl(paramsString, url);
+ // ignore parameters that are already in the url search string
+ var urlParams =
+ OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));
+ for(var key in allParams) {
+ if(key.toUpperCase() in urlParams) {
+ delete allParams[key];
+ paramsString = OpenLayers.Util.getParameterString(allParams);
+ // requestString always starts with url
+ var requestString = url;
+ if (paramsString != "") {
+ var lastServerChar = url.charAt(url.length - 1);
+ if ((lastServerChar == "&") || (lastServerChar == "?")) {
+ requestString += paramsString;
+ } else {
+ if (url.indexOf('?') == -1) {
+ //serverPath has no ? -- add one
+ requestString += '?' + paramsString;
+ } else {
+ //serverPath contains ?, so must already have
+ // paramsString at the end
+ requestString += '&' + paramsString;
+ return requestString;
+ CLASS_NAME: "OpenLayers.Layer.HTTPRequest"
+ OpenLayers/Control/ZoomBox.js
+ * @requires OpenLayers/Handler/Box.js
+ * Class: OpenLayers.Control.ZoomBox
+ * Inherits from:
+OpenLayers.Control.ZoomBox = OpenLayers.Class(OpenLayers.Control, {
+ * Property: type
+ * {OpenLayers.Control.TYPE}
+ * Property: out
+ * {Boolean} Should the control be used for zooming out?
+ out: false,
+ * Method: draw
+ this.handler = new OpenLayers.Handler.Box( this,
+ {done: this.zoomBox}, {keyMask: this.keyMask} );
+ * Method: zoomBox
+ * Parameters:
+ * position - {<OpenLayers.Bounds>} or {<OpenLayers.Pixel>}
+ zoomBox: function (position) {
+ if (position instanceof OpenLayers.Bounds) {
+ if (!this.out) {
+ var minXY = this.map.getLonLatFromPixel(
+ new OpenLayers.Pixel(position.left, position.bottom));
+ var maxXY = this.map.getLonLatFromPixel(
+ new OpenLayers.Pixel(position.right, position.top));
+ var bounds = new OpenLayers.Bounds(minXY.lon, minXY.lat,
+ maxXY.lon, maxXY.lat);
+ } else {
+ var pixWidth = Math.abs(position.right-position.left);
+ var pixHeight = Math.abs(position.top-position.bottom);
+ var zoomFactor = Math.min((this.map.size.h / pixHeight),
+ (this.map.size.w / pixWidth));
+ var center = this.map.getLonLatFromPixel(
+ position.getCenterPixel());
+ var xmin = center.lon - (extent.getWidth()/2)*zoomFactor;
+ var xmax = center.lon + (extent.getWidth()/2)*zoomFactor;
+ var ymin = center.lat - (extent.getHeight()/2)*zoomFactor;
+ var ymax = center.lat + (extent.getHeight()/2)*zoomFactor;
+ var bounds = new OpenLayers.Bounds(xmin, ymin, xmax, ymax);
+ this.map.zoomToExtent(bounds);
+ } else { // it's a pixel
+ if (!this.out) {
+ this.map.setCenter(this.map.getLonLatFromPixel(position),
+ this.map.getZoom() + 1);
+ } else {
+ this.map.getZoom() - 1);
+ CLASS_NAME: "OpenLayers.Control.ZoomBox"
+ OpenLayers/Layer/Grid.js
+ * @requires OpenLayers/Layer/HTTPRequest.js
+ * Class: OpenLayers.Layer.Grid
+ * Base class for layers that use a lattice of tiles. Create a new grid
+ * layer with the <OpenLayers.Layer.Grid> constructor.
+ * Inherits from:
+ * - <OpenLayers.Layer.HTTPRequest>
+OpenLayers.Layer.Grid = OpenLayers.Class(OpenLayers.Layer.HTTPRequest, {
+ * APIProperty: tileSize
+ tileSize: null,
+ * Property: grid
+ * {Array(Array(<OpenLayers.Tile>))} This is an array of rows, each row is
+ * an array of tiles.
+ grid: null,
+ * APIProperty: singleTile
+ * {Boolean} Moves the layer into single-tile mode, meaning that one tile
+ * will be loaded. The tile's size will be determined by the 'ratio'
+ * property. When the tile is dragged such that it does not cover the
+ * entire viewport, it is reloaded.
+ singleTile: false,
+ /** APIProperty: ratio
+ * {Float} Used only when in single-tile mode, this specifies the
+ * ratio of the size of the single tile to the size of the map.
+ ratio: 1.5,
+ * APIProperty: buffer
+ * {Integer} Used only when in gridded mode, this specifies the number of
+ * extra rows and colums of tiles on each side which will
+ * surround the minimum grid tiles to cover the map.
+ buffer: 2,
+ * APIProperty: numLoadingTiles
+ * {Integer} How many tiles are still loading?
+ numLoadingTiles: 0,
+ * Constructor: OpenLayers.Layer.Grid
+ * Create a new grid layer
+ * Parameters:
+ * name - {String}
+ * url - {String}
+ OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,
+ arguments);
+ //grid layers will trigger 'tileloaded' when each new tile is
+ // loaded, as a means of progress update to listeners.
+ // listeners can access 'numLoadingTiles' if they wish to keep track
+ // of the loading progress
+ this.events.addEventType("tileloaded");
+ this.grid = [];
+ * Deconstruct the layer and clear the grid.
+ this.clearGrid();
+ this.grid = null;
+ this.tileSize = null;
+ OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this, arguments);
+ * Method: clearGrid
+ * Go through and remove all tiles from the grid, calling
+ * destroy() on each of them to kill circular references
+ clearGrid:function() {
+ if (this.grid) {
+ for(var iRow=0; iRow < this.grid.length; iRow++) {
+ var row = this.grid[iRow];
+ for(var iCol=0; iCol < row.length; iCol++) {
+ var tile = row[iCol];
+ this.removeTileMonitoringHooks(tile);
+ tile.destroy();
+ this.grid = [];
+ * Create a clone of this layer
+ * Parameters:
+ * obj - {Object} Is this ever used?
+ * Returns:
+ * {<OpenLayers.Layer.Grid>} An exact clone of this OpenLayers.Layer.Grid
+ obj = new OpenLayers.Layer.Grid(this.name,
+ this.url,
+ this.params,
+ this.options);
+ obj = OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this, [obj]);
+ if (this.tileSize != null) {
+ obj.tileSize = this.tileSize.clone();
+ // we do not want to copy reference to grid, so we make a new array
+ obj.grid = [];
+ return obj;
+ * Method: moveTo
+ * This function is called whenever the map is moved. All the moving
+ * of actual 'tiles' is done by the map, but moveTo's role is to accept
+ * a bounds and make sure the data that that bounds requires is pre-loaded.
+ * Parameters:
+ OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this, arguments);
+ bounds = bounds || this.map.getExtent();
+ if (bounds != null) {
+ // if grid is empty or zoom has changed, we *must* re-tile
+ var forceReTile = !this.grid.length || zoomChanged;
+ // total bounds of the tiles
+ var tilesBounds = this.getTilesBounds();
+ if (this.singleTile) {
+ // We want to redraw whenever even the slightest part of the
+ // current bounds is not contained by our tile.
+ // (thus, we do not specify partial -- its default is false)
+ if ( forceReTile ||
+ (!dragging && !tilesBounds.containsBounds(bounds))) {
+ this.initSingleTile(bounds);
+ } else {
+ // if the bounds have changed such that they are not even
+ // *partially* contained by our tiles (IE user has
+ // programmatically panned to the other side of the earth)
+ // then we want to reTile (thus, partial true).
+ if (forceReTile || !tilesBounds.containsBounds(bounds, true)) {
+ this.initGriddedTiles(bounds);
+ } else {
+ //we might have to shift our buffer tiles
+ this.moveGriddedTiles(bounds);
+ * Check if we are in singleTile mode and if so, set the size as a ratio
+ * of the map size (as specified by the layer's 'ratio' property).
+ * Parameters:
+ * size - {<OpenLayers.Size>}
+ size = this.map.getSize().clone();
+ size.h = parseInt(size.h * this.ratio);
+ size.w = parseInt(size.w * this.ratio);
+ OpenLayers.Layer.HTTPRequest.prototype.setTileSize.apply(this, [size]);
+ * Method: getGridBounds
+ * Deprecated. This function will be removed in 3.0. Please use
+ * getTilesBounds() instead.
+ * Returns:
+ * {<OpenLayers.Bounds>} A Bounds object representing the bounds of all the
+ * currently loaded tiles (including those partially or not at all seen
+ * onscreen)
+ getGridBounds: function() {
+ var msg = "The getGridBounds() function is deprecated. It will be " +
+ "removed in 3.0. Please use getTilesBounds() instead.";
+ OpenLayers.Console.warn(msg);
+ return this.getTilesBounds();
+ * APIMethod: getTilesBounds
+ * Return the bounds of the tile grid.
+ * Returns:
+ * onscreen).
+ getTilesBounds: function() {
+ var bounds = null;
+ if (this.grid.length) {
+ var bottom = this.grid.length - 1;
+ var bottomLeftTile = this.grid[bottom][0];
+ var right = this.grid[0].length - 1;
+ var topRightTile = this.grid[0][right];
+ bounds = new OpenLayers.Bounds(bottomLeftTile.bounds.left,
+ bottomLeftTile.bounds.bottom,
+ topRightTile.bounds.right,
+ topRightTile.bounds.top);
+ return bounds;
+ * Method: initSingleTile
+ * Parameters:
+ initSingleTile: function(bounds) {
+ //determine new tile bounds
+ var center = bounds.getCenterLonLat();
+ var tileWidth = bounds.getWidth() * this.ratio;
+ var tileHeight = bounds.getHeight() * this.ratio;
+ var tileBounds =
+ new OpenLayers.Bounds(center.lon - (tileWidth/2),
+ center.lat - (tileHeight/2),
+ center.lon + (tileWidth/2),
+ center.lat + (tileHeight/2));
+ var ul = new OpenLayers.LonLat(tileBounds.left, tileBounds.top);
+ var px = this.map.getLayerPxFromLonLat(ul);
+ if (!this.grid.length) {
+ this.grid[0] = [];
+ var tile = this.grid[0][0];
+ if (!tile) {
+ tile = this.addTile(tileBounds, px);
+ this.addTileMonitoringHooks(tile);
+ tile.draw();
+ this.grid[0][0] = tile;
+ } else {
+ tile.moveTo(tileBounds, px);
+ //remove all but our single tile
+ this.removeExcessTiles(1,1);
+ * Method: calculateGridLayout
+ * Generate parameters for the grid layout. This
+ * Parameters:
+ * bounds - {<OpenLayers.Bound>}
+ * extent - {<OpenLayers.Bounds>}
+ * resolution - {Number}
+ * Returns:
+ * Object containing properties tilelon, tilelat, tileoffsetlat,
+ * tileoffsetlat, tileoffsetx, tileoffsety
+ calculateGridLayout: function(bounds, extent, resolution) {
+ var tilelon = resolution * this.tileSize.w;
+ var tilelat = resolution * this.tileSize.h;
+ var offsetlon = bounds.left - extent.left;
+ var tilecol = Math.floor(offsetlon/tilelon) - this.buffer;
+ var tilecolremain = offsetlon/tilelon - tilecol;
+ var tileoffsetx = -tilecolremain * this.tileSize.w;
+ var tileoffsetlon = extent.left + tilecol * tilelon;
+ var offsetlat = bounds.top - (extent.bottom + tilelat);
+ var tilerow = Math.ceil(offsetlat/tilelat) + this.buffer;
+ var tilerowremain = tilerow - offsetlat/tilelat;
+ var tileoffsety = -tilerowremain * this.tileSize.h;
+ var tileoffsetlat = extent.bottom + tilerow * tilelat;
+ return {
+ tilelon: tilelon, tilelat: tilelat,
+ tileoffsetlon: tileoffsetlon, tileoffsetlat: tileoffsetlat,
+ tileoffsetx: tileoffsetx, tileoffsety: tileoffsety
+ * Method: initGriddedTiles
+ * Parameters:
+ initGriddedTiles:function(bounds) {
+ // work out mininum number of rows and columns; this is the number of
+ // tiles required to cover the viewport plus at least one for panning
+ var minRows = Math.ceil(viewSize.h/this.tileSize.h) +
+ Math.max(1, 2 * this.buffer);
+ var minCols = Math.ceil(viewSize.w/this.tileSize.w) +
+ var extent = this.map.getMaxExtent();
+ var tileLayout = this.calculateGridLayout(bounds, extent, resolution);
+ var tileoffsetx = Math.round(tileLayout.tileoffsetx); // heaven help us
+ var tileoffsety = Math.round(tileLayout.tileoffsety);
+ var tileoffsetlon = tileLayout.tileoffsetlon;
+ var tileoffsetlat = tileLayout.tileoffsetlat;
+ var tilelon = tileLayout.tilelon;
+ var tilelat = tileLayout.tilelat;
+ this.origin = new OpenLayers.Pixel(tileoffsetx, tileoffsety);
+ var startX = tileoffsetx;
+ var startLon = tileoffsetlon;
+ var rowidx = 0;
+ var layerContainerDivLeft = parseInt(this.map.layerContainerDiv.style.left);
+ var layerContainerDivTop = parseInt(this.map.layerContainerDiv.style.top);
+ do {
+ var row = this.grid[rowidx++];
+ if (!row) {
+ row = [];
+ this.grid.push(row);
+ tileoffsetlon = startLon;
+ tileoffsetx = startX;
+ var colidx = 0;
+ do {
+ var tileBounds =
+ new OpenLayers.Bounds(tileoffsetlon,
+ tileoffsetlat,
+ tileoffsetlon + tilelon,
+ tileoffsetlat + tilelat);
+ var x = tileoffsetx;
+ x -= layerContainerDivLeft;
+ var y = tileoffsety;
+ y -= layerContainerDivTop;
+ var px = new OpenLayers.Pixel(x, y);
+ var tile = row[colidx++];
+ if (!tile) {
+ row.push(tile);
+ } else {
+ tile.moveTo(tileBounds, px, false);
+ tileoffsetlon += tilelon;
+ tileoffsetx += this.tileSize.w;
+ } while ((tileoffsetlon <= bounds.right + tilelon * this.buffer)
+ || colidx < minCols)
+ tileoffsetlat -= tilelat;
+ tileoffsety += this.tileSize.h;
+ } while((tileoffsetlat >= bounds.bottom - tilelat * this.buffer)
+ || rowidx < minRows)
+ //shave off exceess rows and colums
+ this.removeExcessTiles(rowidx, colidx);
+ //now actually draw the tiles
+ this.spiralTileLoad();
+ * Method: spiralTileLoad
+ * Starts at the top right corner of the grid and proceeds in a spiral
+ * towards the center, adding tiles one at a time to the beginning of a
+ * queue.
+ * Once all the grid's tiles have been added to the queue, we go back
+ * and iterate through the queue (thus reversing the spiral order from
+ * outside-in to inside-out), calling draw() on each tile.
+ spiralTileLoad: function() {
+ var tileQueue = [];
+ var directions = ["right", "down", "left", "up"];
+ var iRow = 0;
+ var iCell = -1;
+ var direction = OpenLayers.Util.indexOf(directions, "right");
+ var directionsTried = 0;
+ while( directionsTried < directions.length) {
+ var testRow = iRow;
+ var testCell = iCell;
+ switch (directions[direction]) {
+ case "right":
+ testCell++;
+ break;
+ case "down":
+ testRow++;
+ break;
+ case "left":
+ testCell--;
+ break;
+ case "up":
+ testRow--;
+ break;
+ // if the test grid coordinates are within the bounds of the
+ // grid, get a reference to the tile.
+ var tile = null;
+ if ((testRow < this.grid.length) && (testRow >= 0) &&
+ (testCell < this.grid[0].length) && (testCell >= 0)) {
+ tile = this.grid[testRow][testCell];
+ if ((tile != null) && (!tile.queued)) {
+ //add tile to beginning of queue, mark it as queued.
+ tileQueue.unshift(tile);
+ tile.queued = true;
+ //restart the directions counter and take on the new coords
+ directionsTried = 0;
+ iRow = testRow;
+ iCell = testCell;
+ } else {
+ //need to try to load a tile in a different direction
+ direction = (direction + 1) % 4;
+ directionsTried++;
+ // now we go through and draw the tiles in forward order
+ for(var i=0; i < tileQueue.length; i++) {
+ var tile = tileQueue[i];
+ tile.draw();
+ //mark tile as unqueued for the next time (since tiles are reused)
+ tile.queued = false;
+ * APIMethod: addTile
+ * Gives subclasses of Grid the opportunity to create an
+ * OpenLayer.Tile of their choosing. The implementer should initialize
+ * the new tile and take whatever steps necessary to display it.
+ * Parameters
+ * position - {<OpenLayers.Pixel>}
+ * Returns:
+ * {<OpenLayers.Tile>} The added OpenLayers.Tile
+ addTile:function(bounds, position) {
+ // Should be implemented by subclasses
+ * Method: addTileMonitoringHooks
+ * This function takes a tile as input and adds the appropriate hooks to
+ * the tile so that the layer can keep track of the loading tiles.
+ * Parameters:
+ * tile - {<OpenLayers.Tile>}
+ addTileMonitoringHooks: function(tile) {
+ tile.onLoadStart = function() {
+ //if that was first tile then trigger a 'loadstart' on the layer
+ if (this.numLoadingTiles == 0) {
+ this.events.triggerEvent("loadstart");
+ this.numLoadingTiles++;
+ tile.events.register("loadstart", this, tile.onLoadStart);
+ tile.onLoadEnd = function() {
+ this.numLoadingTiles--;
+ this.events.triggerEvent("tileloaded");
+ //if that was the last tile, then trigger a 'loadend' on the layer
+ this.events.triggerEvent("loadend");
+ tile.events.register("loadend", this, tile.onLoadEnd);
+ tile.events.register("unload", this, tile.onLoadEnd);
+ * Method: removeTileMonitoringHooks
+ * This function takes a tile as input and removes the tile hooks
+ * that were added in addTileMonitoringHooks()
+ * Parameters:
+ removeTileMonitoringHooks: function(tile) {
+ tile.unload();
+ tile.events.un({
+ "loadstart": tile.onLoadStart,
+ "loadend": tile.onLoadEnd,
+ "unload": tile.onLoadEnd,
+ scope: this
+ * Method: moveGriddedTiles
+ * Parameters:
+ moveGriddedTiles: function(bounds) {
+ var buffer = this.buffer || 1;
+ while (true) {
+ var tlLayer = this.grid[0][0].position;
+ var tlViewPort =
+ this.map.getViewPortPxFromLayerPx(tlLayer);
+ if (tlViewPort.x > -this.tileSize.w * (buffer - 1)) {
+ this.shiftColumn(true);
+ } else if (tlViewPort.x < -this.tileSize.w * buffer) {
+ this.shiftColumn(false);
+ } else if (tlViewPort.y > -this.tileSize.h * (buffer - 1)) {
+ this.shiftRow(true);
+ } else if (tlViewPort.y < -this.tileSize.h * buffer) {
+ this.shiftRow(false);
+ } else {
+ break;
+ * Method: shiftRow
+ * Shifty grid work
+ * Parameters:
+ * prepend - {Boolean} if true, prepend to beginning.
+ * if false, then append to end
+ shiftRow:function(prepend) {
+ var modelRowIndex = (prepend) ? 0 : (this.grid.length - 1);
+ var grid = this.grid;
+ var modelRow = grid[modelRowIndex];
+ var deltaY = (prepend) ? -this.tileSize.h : this.tileSize.h;
+ var deltaLat = resolution * -deltaY;
+ var row = (prepend) ? grid.pop() : grid.shift();
+ for (var i=0; i < modelRow.length; i++) {
+ var modelTile = modelRow[i];
+ var bounds = modelTile.bounds.clone();
+ var position = modelTile.position.clone();
+ bounds.bottom = bounds.bottom + deltaLat;
+ bounds.top = bounds.top + deltaLat;
+ position.y = position.y + deltaY;
+ row[i].moveTo(bounds, position);
+ if (prepend) {
+ grid.unshift(row);
+ } else {
+ grid.push(row);
+ * Method: shiftColumn
+ * Shift grid work in the other dimension
+ * Parameters:
+ shiftColumn: function(prepend) {
+ var deltaX = (prepend) ? -this.tileSize.w : this.tileSize.w;
+ var deltaLon = resolution * deltaX;
+ for (var i=0; i<this.grid.length; i++) {
+ var row = this.grid[i];
+ var modelTileIndex = (prepend) ? 0 : (row.length - 1);
+ var modelTile = row[modelTileIndex];
+ bounds.left = bounds.left + deltaLon;
+ bounds.right = bounds.right + deltaLon;
+ position.x = position.x + deltaX;
+ var tile = prepend ? this.grid[i].pop() : this.grid[i].shift();
+ tile.moveTo(bounds, position);
+ if (prepend) {
+ row.unshift(tile);
+ } else {
+ row.push(tile);
+ * Method: removeExcessTiles
+ * When the size of the map or the buffer changes, we may need to
+ * remove some excess rows and columns.
+ * Parameters:
+ * rows - {Integer} Maximum number of rows we want our grid to have.
+ * colums - {Integer} Maximum number of columns we want our grid to have.
+ removeExcessTiles: function(rows, columns) {
+ // remove extra rows
+ while (this.grid.length > rows) {
+ var row = this.grid.pop();
+ for (var i=0, l=row.length; i<l; i++) {
+ var tile = row[i];
+ tile.destroy();
+ // remove extra columns
+ while (this.grid[0].length > columns) {
+ for (var i=0, l=this.grid.length; i<l; i++) {
+ var tile = row.pop();
+ tile.destroy();
+ * Method: onMapResize
+ * For singleTile layers, this will set a new tile size according to the
+ * dimensions of the map pane.
+ this.clearGrid();
+ * APIMethod: getTileBounds
+ * Returns The tile bounds for a layer given a pixel location.
+ * Parameters:
+ * viewPortPx - {<OpenLayers.Pixel>} The location in the viewport.
+ * Returns:
+ * {<OpenLayers.Bounds>} Bounds of the tile at the given pixel location.
+ getTileBounds: function(viewPortPx) {
+ var maxExtent = this.map.getMaxExtent();
+ var resolution = this.getResolution();
+ var tileMapWidth = resolution * this.tileSize.w;
+ var tileMapHeight = resolution * this.tileSize.h;
+ var mapPoint = this.getLonLatFromViewPortPx(viewPortPx);
+ var tileLeft = maxExtent.left + (tileMapWidth *
+ Math.floor((mapPoint.lon -
+ maxExtent.left) /
+ tileMapWidth));
+ var tileBottom = maxExtent.bottom + (tileMapHeight *
+ Math.floor((mapPoint.lat -
+ maxExtent.bottom) /
+ tileMapHeight));
+ return new OpenLayers.Bounds(tileLeft, tileBottom,
+ tileLeft + tileMapWidth,
+ tileBottom + tileMapHeight);
+ CLASS_NAME: "OpenLayers.Layer.Grid"
+ OpenLayers/Control/Navigation.js
+ * @requires OpenLayers/Control/ZoomBox.js
+ * @requires OpenLayers/Control/DragPan.js
+ * @requires OpenLayers/Handler/MouseWheel.js
+ * @requires OpenLayers/Handler/Click.js
+ * Class: OpenLayers.Control.Navigation
+ * The navigation control handles map browsing with mouse events (dragging,
+ * double-clicking, and scrolling the wheel). Create a new navigation
+ * control with the <OpenLayers.Control.Navigation> control.
+ * Note that this control is added to the map by default (if no controls
+ * array is sent in the options object to the <OpenLayers.Map>
+ * constructor).
+ * Inherits:
+OpenLayers.Control.Navigation = OpenLayers.Class(OpenLayers.Control, {
+ * Property: dragPan
+ * {<OpenLayers.Control.DragPan>}
+ dragPan: null,
+ * Property: zoomBox
+ * {<OpenLayers.Control.ZoomBox>}
+ zoomBox: null,
+ * APIProperty: zoomWheelEnabled
+ * {Boolean} Whether the mousewheel should zoom the map
+ zoomWheelEnabled: true,
+ * Constructor: OpenLayers.Control.Navigation
+ * Create a new navigation control
+ * Parameters:
+ * options - {Object} An optional object whose properties will be set on
+ * the control
+ initialize: function(options) {
+ this.handlers = {};
+ OpenLayers.Control.prototype.initialize.apply(this, arguments);
+ * Method: destroy
+ * The destroy method is used to perform any clean up before the control
+ * is dereferenced. Typically this is where event listeners are removed
+ * to prevent memory leaks.
+ this.deactivate();
+ if (this.dragPan) {
+ this.dragPan.destroy();
+ this.dragPan = null;
+ if (this.zoomBox) {
+ this.zoomBox.destroy();
+ OpenLayers.Control.prototype.destroy.apply(this,arguments);
+ * Method: activate
+ activate: function() {
+ this.dragPan.activate();
+ if (this.zoomWheelEnabled) {
+ this.handlers.wheel.activate();
+ this.handlers.click.activate();
+ this.zoomBox.activate();
+ return OpenLayers.Control.prototype.activate.apply(this,arguments);
+ * Method: deactivate
+ deactivate: function() {
+ this.zoomBox.deactivate();
+ this.dragPan.deactivate();
+ this.handlers.click.deactivate();
+ this.handlers.wheel.deactivate();
+ return OpenLayers.Control.prototype.deactivate.apply(this,arguments);
+ * Method: draw
+ this.handlers.click = new OpenLayers.Handler.Click(this,
+ { 'dblclick': this.defaultDblClick },
+ 'double': true,
+ 'stopDouble': true
+ this.dragPan = new OpenLayers.Control.DragPan({map: this.map});
+ this.zoomBox = new OpenLayers.Control.ZoomBox(
+ {map: this.map, keyMask: OpenLayers.Handler.MOD_SHIFT});
+ this.dragPan.draw();
+ this.zoomBox.draw();
+ this.handlers.wheel = new OpenLayers.Handler.MouseWheel(
+ this, {"up" : this.wheelUp,
+ "down": this.wheelDown} );
+ this.activate();
+ * Method: defaultDblClick
+ * Parameters:
+ * evt - {Event}
+ defaultDblClick: function (evt) {
+ var newCenter = this.map.getLonLatFromViewPortPx( evt.xy );
+ this.map.setCenter(newCenter, this.map.zoom + 1);
+ * Method: wheelChange
+ * Parameters:
+ * evt - {Event}
+ * deltaZ - {Integer}
+ wheelChange: function(evt, deltaZ) {
+ var newZoom = this.map.getZoom() + deltaZ;
+ if (!this.map.isValidZoomLevel(newZoom)) {
+ return;
+ var deltaX = size.w/2 - evt.xy.x;
+ var deltaY = evt.xy.y - size.h/2;
+ var newRes = this.map.baseLayer.getResolutionForZoom(newZoom);
+ var zoomPoint = this.map.getLonLatFromPixel(evt.xy);
+ var newCenter = new OpenLayers.LonLat(
+ zoomPoint.lon + deltaX * newRes,
+ zoomPoint.lat + deltaY * newRes );
+ this.map.setCenter( newCenter, newZoom );
+ * Method: wheelUp
+ * User spun scroll wheel up
+ * Parameters:
+ * evt - {Event}
+ wheelUp: function(evt) {
+ this.wheelChange(evt, 1);
+ * Method: wheelDown
+ * User spun scroll wheel down
+ * Parameters:
+ * evt - {Event}
+ wheelDown: function(evt) {
+ this.wheelChange(evt, -1);
+ * Method: disableZoomWheel
+ disableZoomWheel : function() {
+ this.zoomWheelEnabled = false;
+ * Method: enableZoomWheel
+ enableZoomWheel : function() {
+ this.zoomWheelEnabled = true;
+ if (this.active) {
+ CLASS_NAME: "OpenLayers.Control.Navigation"
+ OpenLayers/Layer/MapGuide.js
+ * licence. See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * @requires OpenLayers/Ajax.js
+ * @requires OpenLayers/Layer/Grid.js
+ * Class: OpenLayers.Layer.MapGuide
+ * Instances of OpenLayers.Layer.MapGuide are used to display
+ * data from a MapGuide OS instance.
+ * Inherits from:
+ * - <OpenLayers.Layer.Grid>
+OpenLayers.Layer.MapGuide = OpenLayers.Class(OpenLayers.Layer.Grid, {
+ * {Boolean} Treat this layer as a base layer. Default is true.
+ isBaseLayer: true,
+ * {Boolean} use tile server or request single tile image. Note that using
+ * singleTile *and* isBaseLayer false is *not recommend*: it uses synchronous
+ * XMLHttpRequests to load tiles, and this will *lock up users browsers*
+ * during requests.
+ * Constant: TILE_PARAMS
+ * {Object} Hashtable of default parameter key/value pairs for tiled layer
+ TILE_PARAMS: {
+ operation: 'GETTILEIMAGE',
+ version: '1.2.0'
+ * Constant: SINGLE_TILE_PARAMS
+ * {Object} Hashtable of default parameter key/value pairs for untiled layer
+ SINGLE_TILE_PARAMS: {
+ operation: 'GETMAPIMAGE',
+ format: 'PNG',
+ locale: 'en',
+ clip: '1',
+ version: '1.0.0'
+ * Property: defaultSize
+ * {<OpenLayers.Size>} Tile size as produced by MapGuide server
+ defaultSize: new OpenLayers.Size(300,300),
+ * Constructor: OpenLayers.Layer.MapGuide
+ * Create a new Mapguide layer, either tiled or untiled.
+ * For tiled layers, the 'groupName' and 'mapDefnition' options
+ * must be specified as options.
+ * For untiled layers, specify either combination of 'mapName' and
+ * 'session', or 'mapDefinition' and 'locale'.
+ * Parameters:
+ * name - {String} Name of the layer displayed in the interface
+ * url - {String} Location of the MapGuide mapagent executable
+ * (e.g. http://localhost:8008/mapguide/mapagent/mapagent.fcgi)
+ * params - {Object} hashtable of additional parameters to use. Some
+ * parameters may require additional code on the serer. The ones that
+ * you may want to use are:
+ * - mapDefinition - {String} The MapGuide resource definition
+ * (e.g. Library://Samples/Gmap/Maps/gmapTiled.MapDefinition)
+ * - locale - Locale setting
+ * (for untiled overlays layers only)
+ * - mapName - {String} Name of the map as stored in the MapGuide session.
+ * (for untiled layers with a session parameter only)
+ * - session - { String} MapGuide session ID
+ * - basemaplayergroupname - {String} GroupName for tiled MapGuide layers only
+ * - format - Image format to be returned (for untiled overlay layers only)
+ * - showLayers - {String} A comma separated list of GUID's for the
+ * layers to display eg: 'cvc-xcv34,453-345-345sdf'.
+ * - hideLayers - {String} A comma separated list of GUID's for the
+ * layers to hide eg: 'cvc-xcv34,453-345-345sdf'.
+ * - showGroups - {String} A comma separated list of GUID's for the
+ * groups to display eg: 'cvc-xcv34,453-345-345sdf'.
+ * - hideGroups - {String} A comma separated list of GUID's for the
+ * groups to hide eg: 'cvc-xcv34,453-345-345sdf'
+ * - selectionXml - {String} A selection xml string Some server plumbing
+ * is required to read such a value.
+ * options - {Ojbect} Hashtable of extra options to tag onto the layer;
+ * will vary depending if tiled or untiled maps are being requested
+ OpenLayers.Layer.Grid.prototype.initialize.apply(this, arguments);
+ // unless explicitly set in options, if the layer is transparent,
+ // it will be an overlay
+ if (options == null || options.isBaseLayer == null) {
+ this.isBaseLayer = ((this.transparent != "true") &&
+ (this.transparent != true));
+ //initialize for untiled layers
+ this.params,
+ this.SINGLE_TILE_PARAMS
+ } else {
+ //initialize for tiled layers
+ this.params,
+ this.TILE_PARAMS
+ this.setTileSize(this.defaultSize);
+ * Method: clone
+ * Returns:
+ * {<OpenLayers.Layer.MapGuide>} An exact clone of this layer
+ obj = new OpenLayers.Layer.MapGuide(this.name,
+ this.url,
+ this.params,
+ this.options);
+ obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]);
+ return obj;
+ * Method: addTile
+ * Creates a tile, initializes it, and adds it to the layer div.
+ * Parameters:
+ * Returns:
+ * {<OpenLayers.Tile.Image>} The added OpenLayers.Tile.Image
+ addTile:function(bounds,position) {
+ return new OpenLayers.Tile.Image(this, position, bounds,
+ null, this.tileSize);
+ * Method: getURL
+ * Return a query string for this layer
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>} A bounds representing the bbox
+ * for the request
+ * Returns:
+ * {String} A string with the layer's url and parameters and also
+ * the passed-in bounds and appropriate tile size specified
+ * as parameters.
+ getURL: function (bounds) {
+ var url;
+ var mapSize = this.map.getCurrentSize();
+ //set up the call for GETMAPIMAGE or GETDYNAMICMAPOVERLAY
+ var params = {};
+ params.setdisplaydpi = OpenLayers.DOTS_PER_INCH;
+ params.setdisplayheight = mapSize.h*this.ratio;
+ params.setdisplaywidth = mapSize.w*this.ratio;
+ params.setviewcenterx = center.lon;
+ params.setviewcentery = center.lat;
+ params.setviewscale = this.map.getScale();
+ // in this case the main image operation is remapped to this
+ this.params.operation = "GETDYNAMICMAPOVERLAYIMAGE";
+ //but we first need to call GETVISIBLEMAPEXTENT to set the extent
+ var getVisParams = {};
+ getVisParams.operation = "GETVISIBLEMAPEXTENT";
+ getVisParams.version = "1.0.0";
+ getVisParams.session = this.params.session;
+ getVisParams.mapName = this.params.mapName;
+ getVisParams.format = 'text/xml';
+ getVisParams = OpenLayers.Util.extend(getVisParams, params);
+ new OpenLayers.Ajax.Request(this.url,
+ { parameters: getVisParams,
+ method: 'get',
+ asynchronous: false //must be synchronous call to return control here
+ //construct the full URL
+ url = this.getFullRequestString( params );
+ } else {
+ //tiled version
+ var currentRes = this.map.getResolution();
+ var colidx = Math.floor((bounds.left-this.maxExtent.left)/currentRes);
+ colidx = Math.round(colidx/this.tileSize.w);
+ var rowidx = Math.floor((this.maxExtent.top-bounds.top)/currentRes);
+ rowidx = Math.round(rowidx/this.tileSize.h);
+ tilecol: colidx,
+ tilerow: rowidx,
+ scaleindex: this.resolutions.length - this.map.zoom - 1
+ return url;
+ * getFullRequestString on MapGuide layers is special, because we
+ * do a regular expression replace on ',' in parameters to '+'.
+ * This is why it is subclassed here.
+ * Parameters:
+ * altUrl - {String} Alternative base URL to use.
+ * Returns:
+ * {String} A string with the layer's url appropriately encoded for MapGuide
+ // use layer's url unless altUrl passed in
+ var url = (altUrl == null) ? this.url : altUrl;
+ // in which case we will randomly select one of them in order
+ // to evenly distribute requests to different urls.
+ if (typeof url == "object") {
+ url = url[Math.floor(Math.random()*url.length)];
+ var urlParams = OpenLayers.Util.upperCaseObject(
+ OpenLayers.Util.getArgs(url));
+ /* MapGuide needs '+' seperating things like bounds/height/width.
+ Since typically this is URL encoded, we use a slight hack: we
+ depend on the list-like functionality of getParameterString to
+ leave ',' only in the case of list items (since otherwise it is
+ encoded) then do a regular expression replace on the , characters
+ to '+' */
+ paramsString = paramsString.replace(/,/g, "+");
+ } else {
+ } else {
+ //serverPath contains ?, so must already have paramsString at the end
+ * Parameters:
+ * Returns:
+ var offsetlat = extent.top - bounds.top + tilelat;
+ var tilerow = Math.floor(offsetlat/tilelat) - this.buffer;
+ var tileoffsety = tilerowremain * this.tileSize.h;
+ var tileoffsetlat = extent.top - tilelat*tilerow;
+ return {
+ CLASS_NAME: "OpenLayers.Layer.MapGuide"
+ OpenLayers/Layer/MapServer.js
+ * Class: OpenLayers.Layer.MapServer
+ * Instances of OpenLayers.Layer.MapServer are used to display
+ * data from a MapServer CGI instance.
+ * Inherits from:
+OpenLayers.Layer.MapServer = OpenLayers.Class(OpenLayers.Layer.Grid, {
+ * Constant: DEFAULT_PARAMS
+ DEFAULT_PARAMS: {
+ mode: "map",
+ map_imagetype: "png"
+ * Constructor: OpenLayers.Layer.MapServer
+ * Create a new MapServer layer object
+ * Parameters:
+ * name - {String} A name for the layer
+ * url - {String} Base url for the MapServer CGI
+ * (e.g. http://www2.dmsolutions.ca/cgi-bin/mapserv)
+ * params - {Object} An object with key/value pairs representing the
+ * GetMap query string parameters and parameter values.
+ var newArguments = [];
+ newArguments.push(name, url, params, options);
+ OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
+ if (arguments.length > 0) {
+ OpenLayers.Util.applyDefaults(
+ this.params,
+ this.DEFAULT_PARAMS
+ this.isBaseLayer = ((this.params.transparent != "true") &&
+ (this.params.transparent != true));
+ * Method: clone
+ * Returns:
+ * {<OpenLayers.Layer.MapServer>} An exact clone of this layer
+ obj = new OpenLayers.Layer.MapServer(this.name,
+ this.url,
+ this.params,
+ this.options);
+ return obj;
+ * Method: addTile
+ * Parameters:
+ * Returns:
+ * Method: getURL
+ * Parameters:
+ * for the request
+ * Returns:
+ * as parameters.
+ bounds = this.adjustBounds(bounds);
+ // Make a list, so that getFullRequestString uses literal ","
+ var extent = [bounds.left, bounds. bottom, bounds.right, bounds.top];
+ var imageSize = this.getImageSize();
+ // make lists, so that literal ','s are used
+ var url = this.getFullRequestString(
+ {mapext: extent,
+ imgext: extent,
+ map_size: [imageSize.w, imageSize.h],
+ imgx: imageSize.w / 2,
+ imgy: imageSize.h / 2,
+ imgxy: [imageSize.w, imageSize.h]
+ return url;
+ * combine the layer's url with its params and these newParams.
+ * Parameter:
+ * newParams - {Object} New parameters that should be added to the
+ * request string.
+ * altUrl - {String} (optional) Replace the URL in the full request
+ * string with the provided URL.
+ * Returns:
+ * {String} A string with the layer's url and parameters embedded in it.
+ OpenLayers.Util.getParameters(url));
+ // MapServer needs '+' seperating things like bounds/height/width.
+ // Since typically this is URL encoded, we use a slight hack: we
+ // depend on the list-like functionality of getParameterString to
+ // leave ',' only in the case of list items (since otherwise it is
+ // encoded) then do a regular expression replace on the , characters
+ // to '+'
+ } else {
+ } else {
+ CLASS_NAME: "OpenLayers.Layer.MapServer"
+ OpenLayers/Layer/WMS.js
+ * @requires OpenLayers/Tile/Image.js
+ * Class: OpenLayers.Layer.WMS
+ * Instances of OpenLayers.Layer.WMS are used to display data from OGC Web
+ * Mapping Services. Create a new WMS layer with the <OpenLayers.Layer.WMS>
+ * constructor.
+ * Inherits from:
+OpenLayers.Layer.WMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
+ DEFAULT_PARAMS: { service: "WMS",
+ version: "1.1.1",
+ request: "GetMap",
+ styles: "",
+ exceptions: "application/vnd.ogc.se_inimage",
+ format: "image/jpeg"
+ * Property: reproject
+ * *Deprecated*. See http://trac.openlayers.org/wiki/SphericalMercator
+ * {Boolean} Try to reproject this layer if its coordinate reference system
+ * is different than that of the base layer. Default is true.
+ * Set this in the layer options. Should be set to false in
+ * most cases.
+ reproject: false,
+ * APIProperty: isBaseLayer
+ * {Boolean} Default is true for WMS layer
+ * APIProperty: encodeBBOX
+ * {Boolean} Should the BBOX commas be encoded? The WMS spec says 'no',
+ * but some services want it that way. Default false.
+ encodeBBOX: false,
+ * Constructor: OpenLayers.Layer.WMS
+ * Create a new WMS layer object
+ * Example:
+ * (code)
+ * var wms = new OpenLayers.Layer.WMS("NASA Global Mosaic",
+ * "http://wms.jpl.nasa.gov/wms.cgi",
+ * {layers: "modis,global_mosaic"});
+ * (end)
+ * Parameters:
+ * url - {String} Base url for the WMS
+ * (e.g. http://wms.jpl.nasa.gov/wms.cgi)
+ //uppercase params
+ params = OpenLayers.Util.upperCaseObject(params);
+ this.params,
+ OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS)
+ //layer is transparent
+ if (this.params.TRANSPARENT &&
+ this.params.TRANSPARENT.toString().toLowerCase() == "true") {
+ // unless explicitly set in options, make layer an overlay
+ if ( (options == null) || (!options.isBaseLayer) ) {
+ this.isBaseLayer = false;
+ // jpegs can never be transparent, so intelligently switch the
+ // format, depending on teh browser's capabilities
+ if (this.params.FORMAT == "image/jpeg") {
+ this.params.FORMAT = OpenLayers.Util.alphaHack() ? "image/gif"
+ : "image/png";
+ * Method: destroy
+ * Destroy this layer
+ // for now, nothing special to do here.
+ OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
+ * Method: clone
+ * Returns:
+ * {<OpenLayers.Layer.WMS>} An exact clone of this layer
+ obj = new OpenLayers.Layer.WMS(this.name,
+ this.url,
+ this.params,
+ this.options);
+ return obj;
+ * Method: getURL
+ * Return a GetMap query string for this layer
+ * Parameters:
+ * bounds - {<OpenLayers.Bounds>} A bounds representing the bbox for the
+ * request.
+ * Returns:
+ * {String} A string with the layer's url and parameters and also the
+ * passed-in bounds and appropriate tile size specified as
+ * parameters.
+ var newParams = {
+ 'BBOX': this.encodeBBOX ? bounds.toBBOX() : bounds.toArray(),
+ 'WIDTH': imageSize.w,
+ 'HEIGHT': imageSize.h
+ var requestString = this.getFullRequestString(newParams);
+ * Method: addTile
+ * addTile creates a tile, initializes it, and adds it to the layer div.
+ * Parameters:
+ * Returns:
+ * Catch changeParams and uppercase the new params to be merged in
+ * before calling changeParams on the super class.
+ * Once params have been changed, we will need to re-init our tiles.
+ * Parameters:
+ * newParams - {Object} Hashtable of new params to use
+ var upperParams = OpenLayers.Util.upperCaseObject(newParams);
+ var newArguments = [upperParams];
+ return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,
+ newArguments);
+ * Combine the layer's url with its params and these newParams.
+ * Add the SRS parameter from projection -- this is probably
+ * more eloquently done via a setProjection() method, but this
+ * works for now and always.
+ * Parameters:
+ * Returns:
+ * {String}
+ var projectionCode = this.map.getProjection();
+ this.params.SRS = (projectionCode == "none") ? null : projectionCode;
+ return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(
+ this, arguments);
+ CLASS_NAME: "OpenLayers.Layer.WMS"
Modified: trunk/parseAppDef.xsl
--- trunk/parseAppDef.xsl 2008-04-25 18:44:42 UTC (rev 1385)
+++ trunk/parseAppDef.xsl 2008-04-25 19:15:52 UTC (rev 1386)
@@ -1,11 +1,10 @@
<?xml version="1.0" encoding="ISO-8859-1"?>
-Description: Autogenerate widget documetation from widgetInfo files
+Description: Generates a list of widget and map files required for a single file build of Fusion
$Id$
$Name$
<xsl:stylesheet version="1.0"
xmlns:xsl="http://www.w3.org/1999/XSL/Transform"
xmlns:xs="http://www.w3.org/2001/XMLSchema"
@@ -16,14 +15,6 @@
<xsl:param name="buildHome">./build</xsl:param>
<!-- Root node. -->
- <xsl:template match="/xxApplicationDefinition">
- <filelist id="fusionAppWidgets" dir="{$buildHome}/widget">
- <xsl:attribute name="files">
- <xsl:apply-templates select="WidgetSet"/>
- </xsl:attribute>
- </filelist>
- </xsl:template>
<xsl:template match="/ApplicationDefinition">
<xsl:variable name="widgetFileList">
@@ -47,7 +38,7 @@
</AppDef>
</xsl:template>
- <xsl:template match="Container"/>
+ <xsl:template match="Container"/> <!-- empty templates to suppress output -->
<xsl:template match="MapWidget"/>
<xsl:template match="Widget">
@@ -61,8 +52,11 @@
</xsl:variable>
<xsl:value-of select="$loc"/>/<xsl:value-of select="Type"/>.js
</xsl:template>
- <xsl:template match="MapGroup/Map"><xsl:value-of select="Type"/>/<xsl:value-of select="Type"/>.js </xsl:template>
+ <xsl:template match="MapGroup/Map">
+ <xsl:value-of select="Type"/>/<xsl:value-of select="Type"/>.js
+ </xsl:template>
<xsl:template name="removeDuplicates"> <!-- tokenize a string -->
<xsl:param name="str"/> <!-- String to process -->
<xsl:param name="sep"/> <!-- Legal separator character -->
More information about the fusion-commits
