[fusion-commits] r1456 - in trunk: MapGuide lib widgets
svn_fusion at osgeo.org
Tue Aug 12 15:58:28 EDT 2008
Author: madair
Date: 2008-08-12 15:58:27 -0400 (Tue, 12 Aug 2008)
New Revision: 1456
trunk/MapGuide/MapGuide.js
trunk/lib/Map.js
trunk/widgets/Select.js
trunk/widgets/SelectPolygon.js
trunk/widgets/SelectRadius.js
closes #101: restore computed properties to query;
selection widgets can now add a <ComputeMetadata>true</ComputeMetadata> element in their extension
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-08-12 19:03:25 UTC (rev 1455)
+++ trunk/MapGuide/MapGuide.js 2008-08-12 19:58:27 UTC (rev 1456)
@@ -790,6 +790,7 @@
'mapname': this._sMapname,
'session': this.getSessionID(),
'spatialfilter': options.geometry || '',
+ 'computed': options.computed || '',
'queryHiddenLayers': options.queryHiddenLayers || '',
'maxfeatures': options.maxFeatures || 0, //zero means select all features
'layers': options.layers || '',
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2008-08-12 19:03:25 UTC (rev 1455)
+++ trunk/lib/Map.js 2008-08-12 19:58:27 UTC (rev 1456)
@@ -1132,6 +1132,19 @@
this.aElements[i][j] = o[layerName].values[i][j];
+ //loop over all features in the metadata array
+ for (var i=0; i<o[layerName].metadata.length; i++) {
+ var featureMetadata = o[layerName].metadata[i];
+ var dim = featureMetadata[0]; //nothing to do with this one
+ var bbox = featureMetadata[1];
+ var center = featureMetadata[2];
+ var area = featureMetadata[3];
+ var length = featureMetadata[4];
+ this.area += parseFloat(area);
+ this.distance += parseFloat(length);
var iElement=0;
while(oValueCollection)
Modified: trunk/widgets/Select.js
--- trunk/widgets/Select.js 2008-08-12 19:03:25 UTC (rev 1455)
+++ trunk/widgets/Select.js 2008-08-12 19:58:27 UTC (rev 1456)
@@ -64,6 +64,10 @@
(json.QueryActiveLayer[0] == 'true' ||
json.QueryActiveLayer[0] == '1')) ? true : false;
+ this.bComputeMetadata = (json.ComputeMetadata &&
+ (json.ComputeMetadata[0] == 'true' ||
+ json.ComputeMetadata[0] == '1')) ? true : false;
if (this.bActiveOnly) {
this.getMap().registerForEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, OpenLayers.Function.bind(this.enable, this));
@@ -162,6 +166,7 @@
options.geometry = 'POLYGON(('+ sMin.x + ' ' + sMin.y + ', ' + sMax.x + ' ' + sMin.y + ', ' + sMax.x + ' ' + sMax.y + ', ' + sMin.x + ' ' + sMax.y + ', ' + sMin.x + ' ' + sMin.y + '))';
options.selectionType = this.selectionType;
options.maxFeatures = this.maxFeatures;
+ options.computed = this.bComputeMetadata;
var layer = this.getMap().getActiveLayer();
Modified: trunk/widgets/SelectPolygon.js
--- trunk/widgets/SelectPolygon.js 2008-08-12 19:03:25 UTC (rev 1455)
+++ trunk/widgets/SelectPolygon.js 2008-08-12 19:58:27 UTC (rev 1456)
@@ -50,6 +50,10 @@
if (json.Tolerance && (parseInt(json.Tolerance[0]) > 0)) {
nTolerance = parseInt(json.Tolerance[0]);
this.polygon = new Fusion.Tool.Canvas.Polygon();
@@ -184,6 +188,7 @@
var options = {};
options.geometry = wkt;
options.selectionType = "inside";
Modified: trunk/widgets/SelectRadius.js
--- trunk/widgets/SelectRadius.js 2008-08-12 19:03:25 UTC (rev 1455)
+++ trunk/widgets/SelectRadius.js 2008-08-12 19:58:27 UTC (rev 1456)
@@ -55,7 +55,11 @@
this.defaultRadius = json.DefaultRadius ? parseInt(json.DefaultRadius[0]) : this.defaultRadius;
var container = json.RadiusTooltipContainer ? json.RadiusTooltipContainer[0] : '';
if (container != '') {
this.radiusTip = $(container);
@@ -248,6 +252,7 @@
var options = {};
More information about the fusion-commits
