[fusion-commits] r1464 - in trunk: MapGuide MapServer lib
svn_fusion at osgeo.org
Thu Aug 21 16:42:11 EDT 2008
Author: madair
Date: 2008-08-21 16:42:10 -0400 (Thu, 21 Aug 2008)
New Revision: 1464
trunk/MapGuide/MapGuide.js
trunk/MapServer/MapServer.js
trunk/lib/Map.js
closes #108: fullExtents now sets the map to max extent; initial map load is done using initialExtents
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-08-21 18:40:34 UTC (rev 1463)
+++ trunk/MapGuide/MapGuide.js 2008-08-21 20:42:10 UTC (rev 1464)
@@ -311,8 +311,8 @@
if (this.bIsMapWidgetLayer) {
this.mapWidget.addMap(this);
this.mapWidget.oMapOL.setBaseLayer(this.oLayerOL);
- this.mapWidget._oInitialExtents = null;
- this.mapWidget.fullExtents();
+ var initialExtent = this.mapWidget.setInitialExtents();
+ this.mapWidget.setExtents(initialExtent);
this.mapWidget.triggerEvent(Fusion.Event.MAP_LOADED);
} else {
this.triggerEvent(Fusion.Event.MAP_LOADED);
@@ -792,7 +792,7 @@
'session': this.getSessionID(),
'spatialfilter': options.geometry || '',
'computed': options.computed || '',
- 'queryHiddenLayers': options.queryHiddenLayers || '',
+ 'queryHiddenLayers': options.queryHiddenLayers || 'false',
'maxfeatures': options.maxFeatures || 0, //zero means select all features
'layers': options.layers || '',
'variant': options.selectionType || this.selectionType
@@ -1204,7 +1204,7 @@
getLegendImageURL: function(fScale, layer) {
var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
- url += "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
+ url += "?OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
url += "&VERSION=1.0.0&SCALE=" + fScale;
url += "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId);
url += "&THEMECATEGORY=" + this.categoryIndex;
Modified: trunk/MapServer/MapServer.js
--- trunk/MapServer/MapServer.js 2008-08-21 18:40:34 UTC (rev 1463)
+++ trunk/MapServer/MapServer.js 2008-08-21 20:42:10 UTC (rev 1464)
@@ -164,7 +164,7 @@
loadMap: function(mapfile, options) {
while (this.mapWidget.isBusy()) {
this.mapWidget._removeWorker();
this.bMapLoaded = false;
//console.log('loadMap: ' + resourceId);
/* don't do anything if the map is already loaded? */
@@ -290,8 +290,8 @@
this.mapWidget.oMapOL.units = this.oLayerOL.units;
} else {
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2008-08-21 18:40:34 UTC (rev 1463)
+++ trunk/lib/Map.js 2008-08-21 20:42:10 UTC (rev 1464)
@@ -59,7 +59,6 @@
_fScale : -1,
_nDpi : 96,
_oCurrentExtents: null,
- _oInitialExtents: null,
maxExtent: new OpenLayers.Bounds(),
_nWorkers: 0,
oContextMenu: null,
@@ -503,8 +502,6 @@
this._nHeight = d.height;
if (this._oCurrentExtents) {
this.setExtents(this._oCurrentExtents);
- } else if (this._oInitialExtents) {
- this.setExtents(this._oInitialExtents);
this.triggerEvent(Fusion.Event.MAP_RESIZED, this);
@@ -518,7 +515,7 @@
this.oMapOL.setCenter(this.oMapOL.getCenter(), this.oMapOL.getZoom(), false, true);
- setExtents : function(oExtents) {
+ setExtents: function(oExtents) {
if (!oExtents) {
Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
OpenLayers.i18n('nullExtents')));
@@ -532,42 +529,55 @@
this.aMaps[i].oLayerOL.params.ts = (new Date()).getTime();
this.oMapOL.zoomToExtent(oExtents);
+ this._oCurrentExtents = this.oMapOL.getExtent();
- fullExtents : function() {
- //determine the initialExtents
- if (!this._oInitialExtents) {
- var bbox = Fusion.getQueryParam("extent"); //set as min x,y, max x,y
- if (bbox) {
- this._oInitialExtents = new OpenLayers.Bounds.fromArray(bbox.split(","));
- } else if (this.mapGroup.initialView) {
- var iv = this.mapGroup.getInitialView();
- if (iv.x) {
- this._oInitialExtents = this.getExtentFromPoint(iv.x, iv.y, iv.scale);
- } else if (iv.minX) {
- this._oInitialExtents = new OpenLayers.Bounds(iv.minX, iv.minY, iv.maxX, iv.maxY);
- if (!this._oInitialExtents.intersectsBounds(this.maxExtent)) {
- Fusion.reportError("AppDef initial view is outside map maxExtent, resetting initialView to maxExtent");
- this._oInitialExtents = this.maxExtent;
- } else {
- var viewSize = this.oMapOL.getSize();
- var oExtents = this.oMapOL.getMaxExtent();
- var center = oExtents.getCenterLonLat();
- var initRes = Math.max( oExtents.getWidth() / viewSize.w,
- oExtents.getHeight() / viewSize.h);
- var w_deg = viewSize.w * initRes/2;
- var h_deg = viewSize.h * initRes/2;
- this._oInitialExtents = new OpenLayers.Bounds(center.lon - w_deg,
- center.lat - h_deg,
- center.lon + w_deg,
- center.lat + h_deg);
+ * determine the initialExtents of the map from (in order of precedence):
+ * 1. a URL query parameter called 'extent'
+ * 2. an <InitialView> specified in the MapGroup in AppDef
+ * 3. the maxExtent as specified by the LoadMap call (default)
+ setInitialExtents: function() {
+ var initialExtents;
+ var bbox = Fusion.getQueryParam("extent"); //set as min x,y, max x,y
+ if (bbox) {
+ initialExtents = new OpenLayers.Bounds.fromArray(bbox.split(","));
+ } else if (this.mapGroup.initialView) {
+ var iv = this.mapGroup.getInitialView();
+ if (iv.x) {
+ initialExtents = this.getExtentFromPoint(iv.x, iv.y, iv.scale);
+ } else if (iv.minX) {
+ initialExtents = new OpenLayers.Bounds(iv.minX, iv.minY, iv.maxX, iv.maxY);
+ if (!initialExtents.intersectsBounds(this.maxExtent)) {
+ Fusion.reportError("AppDef initial view is outside map maxExtent, resetting initialView to maxExtent");
+ initialExtents = this.maxExtent;
+ } else {
+ var viewSize = this.oMapOL.getSize();
+ var oExtents = this.oMapOL.getMaxExtent();
+ var center = oExtents.getCenterLonLat();
+ var initRes = Math.max( oExtents.getWidth() / viewSize.w,
+ oExtents.getHeight() / viewSize.h);
+ var w_deg = viewSize.w * initRes/2;
+ var h_deg = viewSize.h * initRes/2;
+ initialExtents = new OpenLayers.Bounds(center.lon - w_deg,
+ center.lat - h_deg,
+ center.lon + w_deg,
+ center.lat + h_deg);
+ return initialExtents;
+ * sets the extent of the map to the max as returned by loadMap
+ fullExtents: function() {
+ var extents = this.maxExtent;
+ this.setExtents(extents);
isMapLoaded: function() {
return (this._oCurrentExtents) ? true : false;
@@ -703,13 +713,22 @@
setViewOptions: function(data) {
+ this.setWidgetParam('Units', data);
+ * initializes all widgets with a parameter and value at runtime
+ setWidgetParam: function(param, data) {
for (var i=0; i<Fusion.applicationDefinition.widgetSets.length; ++i) {
var widgetSet = Fusion.applicationDefinition.widgetSets[i];
for (var j=0; j<widgetSet.widgetInstances.length; ++j) {
var widget = widgetSet.widgetInstances[j];
for (var k=0; k<widget.paramRegister.length; ++k) {
- if (widget.paramRegister[k] == 'Units') {
- widget.setParameter('Units', data);
+ if (widget.paramRegister[k] == param) {
+ widget.setParameter(param, data);
@@ -751,14 +770,6 @@
- * returns initial extents
- getInitialExtents : function(){
- return this._oInitialExtents;
* Function: getExtentFromPoint
* returns the Extent of the map given a center point and a scale (optional)
More information about the fusion-commits
