[fusion-commits] r1466 - trunk/widgets
svn_fusion at osgeo.org
Fri Aug 22 11:10:15 EDT 2008
Author: aboudreault
Date: 2008-08-22 11:10:15 -0400 (Fri, 22 Aug 2008)
New Revision: 1466
trunk/widgets/SelectionPanel.js
Added renderer capability to SelectionPanel (#71)
Modified: trunk/widgets/SelectionPanel.js
--- trunk/widgets/SelectionPanel.js 2008-08-22 13:09:32 UTC (rev 1465)
+++ trunk/widgets/SelectionPanel.js 2008-08-22 15:10:15 UTC (rev 1466)
@@ -30,40 +30,272 @@
Fusion.Widget.SelectionPanel = OpenLayers.Class(Fusion.Widget,
+ * Property: previousIcon
+ * {String} The default image for Previous page button.
+ previousIcon: 'images/icon_back.gif',
+ * Property: nextIcon
+ nextIcon: 'images/icon_forward.gif',
initialize : function(widgetTag) {
//console.log('SelectionPanel.initialize');
Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
- this.defPrevTaskIcon = 'images/icon_back.gif';
- this.defNextTaskIcon = 'images/icon_forward.gif';
var json = widgetTag.extension;
+ if (json.PreviousImageUrl) this.previousIcon = json.PreviousImageUrl;
+ if (json.NextImageUrl) this.nextIcon = json.NextImageUrl;
+ this.iResultsPerPage = json.ResultsPerPage ? json.ResultsPerPage[0] : 0;
+ this.iResultsPerPage = parseInt(this.iResultsPerPage);
+ if (isNaN(this.iResultsPerPage) || (this.iResultsPerPage < 0))
+ this.iResultsPerPage = 0;
+ if (json.SelectionRenderer)
+ var renderer = eval(json.SelectionRenderer[0]);
+ if (renderer && renderer.prototype.CLASS_NAME && renderer.prototype.CLASS_NAME == "Fusion.Widget.SelectionPanel.SelectionRenderer") {
+ this.renderer = new renderer(this);
+ } else if (typeof renderer == "function") {
+ var renderFunction = renderer;
+ this.renderer = new Fusion.Widget.SelectionPanel.SelectionRenderer(this);
+ this.renderer.updateSelection = function() {
+ this.getMap().getSelection(
+ OpenLayers.Function.bind(renderFunction));
+ this.renderer.clearSelection = false;
+ } else {
+ this.renderer = new Fusion.Widget.SelectionPanel.SelectionRendererDefault(this);
+ } else {
+ this.iResultsPerPage = null; // handled by the renderer
- this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
- OpenLayers.Function.bind(this.updateSelection, this));
- this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
- OpenLayers.Function.bind(this.clearSelection, this));
+ if (this.renderer.updateSelection) {
+ this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
+ OpenLayers.Function.bind(this.renderer.updateSelection, this.renderer));
+ if (this.renderer.clearSelection) {
+ this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
+ OpenLayers.Function.bind(this.renderer.clearSelection, this.renderer));
+/* Class: Fusion.Widget.SelectionPanel.SelectionRenderer
+ * This is a class designed to help users to create their own renderer
+ * for customize display results.
+Fusion.Widget.SelectionPanel.SelectionRenderer = OpenLayers.Class(
+ * Property: oSelectionPanel
+ * {<Fusion.Widget.SelectionPanel>} The parent widget that uses
+ * the renderer.
+ oSelection: null,
+ * Property: aiCurrentIndex
+ * {Array(int)} The index of the current position for pagination.
+ aiCurrentIndex: null,
+ * Property: iResultsPerPage
+ * {int} The number of results per page for pagination.
+ iResultsPerPage: 0,
+ /* Constructor: Fusion.Widget.SelectionPanel.SelectionRenderer
+ * Constructor for a new <Fusion.Widget.SelectionPanel.SelectionRenderer> instance.
+ * Parameters:
+ * selectionPanel - {<Fusion.Widget.SelectionPanel>} The parent widget that uses
+ * the renderer.
+ initialize: function(selectionPanel) {
+ this.oSelectionPanel = selectionPanel;
+ this.iResultsPerPage = selectionPanel.iResultsPerPage;
+ this.aiCurrentIndex = new Array();
+ * Method: updateSelectionObject
+ * Helper method to update the aiCurrentIndex array for pagination.
+ updatePageIndexes: function() {
+ var nLayers = this.oSelection.getNumLayers();
+ for (var i=0; i<nLayers; i++) {
+ this.aiCurrentIndex[this.oSelection.getLayer(i).getName()] = 0;
+ * Method: getNextPage
+ * Get the next batches of features. Wrapper of the getPage() method.
+ * This method calcul the startIndex/endIndex of the next batch.
+ * Parameters:
+ * selectionLayer - {<Fusion.SelectionObject.Layer>} The layer that contains
+ * the set of features.
+ * Returns:
+ * {Array(Array)} An array of all features with their properties.
+ getNextPage: function(selectionLayer) {
+ if (selectionLayer && (this.iResultsPerPage != 0)) {
+ var layerName = selectionLayer.getName();
+ if (this.aiCurrentIndex[layerName] >= selectionLayer.getNumElements()) {
+ this.aiCurrentIndex[layerName] = this.aiCurrentIndex[layerName] - this.iResultsPerPage;
+ var iTotalElement = selectionLayer.getNumElements();
+ var startIndex = this.aiCurrentIndex[layerName];
+ var endIndex = startIndex + this.iResultsPerPage;
+ if (endIndex >= iTotalElement) {
+ endIndex = iTotalElement;
+ if (startIndex < 0) {
+ startIndex = 0;
+ this.aiCurrentIndex[layerName] = endIndex;
+ // if the last page doesn't contains "iResultsPerPage" elements. Fix the current index for the next getPreviousPage() call.
+ var diff = (endIndex - startIndex);
+ if ( diff != this.iResultsPerPage) {
+ this.aiCurrentIndex[layerName] = this.aiCurrentIndex[layerName] + (this.iResultsPerPage - diff);
+ return this.getPage(selectionLayer, startIndex, endIndex);
+ return this.getPage(selectionLayer);
+ * Method: getPreviousPage
+ * Get the previous batches of features. Wrapper of the getPage() method.
+ * This method calcul the startIndex/endIndex of the previous batch.
+ * Parameters:
+ * Returns:
+ getPreviousPage: function(selectionLayer) {
+ if (selectionLayer && (this.aiCurrentIndex[layerName] != 0) && (this.iResultsPerPage != 0)) {
+ var startIndex = this.aiCurrentIndex[layerName] - (this.iResultsPerPage * 2);
+ var endIndex = this.aiCurrentIndex[layerName] - this.iResultsPerPage;
+ startIndex = 0;
+ endIndex = (iTotalElement < this.iResultsPerPage) ? iTotalElement : this.iResultsPerPage;
+ * Method: getMap
+ * Helper method to obtains the map.
+ * Returns:
+ * {<Fusion.Maps>} The map that uses the SelectionPanel Widget.
+ getMap: function() {
+ return this.oSelectionPanel.getMap();
+ * Method: getPage
+ * Get a batches of features in a selection.
+ * Parameters:
+ * startIndex - {int} The index of the first element.
+ * endIndex - {int} The index of the last element.
+ * Returns:
+ getPage: function(selectionLayer, startIndex, endIndex) {
+ var page = false;
+ if (selectionLayer) {
+ page = new Array();
+ startIndex = startIndex ? startIndex : 0;
+ endIndex = endIndex ? endIndex : selectionLayer.getNumElements();
+ var propNames = selectionLayer.getPropertyNames();
+ var index =0;
+ for (var i=startIndex; i<endIndex; i++, index++) {
+ page[index] = new Array();
+ for (var j=0; j<propNames.length; j++) {
+ page[index][j] = selectionLayer.getElementValue(i, j);
+ return page;
+ * Abstract method that handle the event: Fusion.Event.MAP_SELECTION_ON. This method
+ * should be implemented by all concrete class.
+ updateSelection: function() {},
+ * Method: clearSelection
+ * Abstract method that handle the event: Fusion.Event.MAP_SELECTION_OFF. This method
+ clearSelection: function() {},
+ CLASS_NAME: "Fusion.Widget.SelectionPanel.SelectionRenderer"
+/* Class: Fusion.Widget.SelectionPanel.SelectionRendererDefault
+ * This class provide a default behavior for the selection panel.
+Fusion.Widget.SelectionPanel.SelectionRendererDefault = OpenLayers.Class(Fusion.Widget.SelectionPanel.SelectionRenderer,
+ initialize : function(selectionPanel) {
+ Fusion.Widget.SelectionPanel.SelectionRenderer.prototype.initialize.apply(this, [selectionPanel]);
var d = document.createElement('div');
this.toolbar = document.createElement('div');
this.toolbar.className = 'selectionPanelToolbar';
this.layerList = document.createElement('select');
this.layerList.className = 'layerSelector';
this.toolbar.appendChild(this.layerList);
- Event.observe(this.layerList, 'change',
- OpenLayers.Function.bind(this.renderSelectionFeatures, this));
+ Event.observe(this.layerList, 'change',
+ OpenLayers.Function.bind(this.renderSelectionFeatures, this));
this.featureList = document.createElement('select');
this.featureList.className = 'featureSelector';
this.toolbar.appendChild(this.featureList);
- Event.observe(this.featureList, 'change',
- OpenLayers.Function.bind(this.renderFeature, this));
+ Event.observe(this.featureList, 'change',
+ OpenLayers.Function.bind(this.renderFeature, this));
this.featureDiv = document.createElement('div');
this.featureDiv.className = 'selectionPanelContent';
@@ -72,11 +304,15 @@
d.appendChild(this.toolbar);
d.appendChild(this.featureDiv);
- Fusion.addWidgetStyleSheet(widgetTag.location + 'SelectionPanel/SelectionPanel.css');
- this.domObj.appendChild(d);
+ Fusion.addWidgetStyleSheet(this.oSelectionPanel.getLocation() + 'SelectionPanel/SelectionPanel.css');
+ this.oSelectionPanel.domObj.appendChild(d);
+ OpenLayers.Function.bind(this.renderSelectionLayers, this));
this.layerList.options.length = 0;
this.featureList.options.length = 0;
@@ -84,13 +320,7 @@
Element.addClassName(this.featureDiv, 'noSelection');
this.featureDiv.innerHTML = OpenLayers.i18n('noSelection');
- updateSelection: function() {
- //console.log('update selection');
- this.getMap().getSelection(
- OpenLayers.Function.bind(this.renderSelectionLayers, this));
renderSelectionLayers: function(oSelection) {
//TODO: this just gets the first map, we need them all
this.oSelection = null;
@@ -98,9 +328,11 @@
this.oSelection = oSelection[mapName];
break;
if (!this.oSelection) {
return;
//clear the layer list select box of any previous selections
Element.removeClassName(this.featureDiv, 'noSelection');
while (this.layerList.length>0) {
@@ -124,14 +356,16 @@
this.layerList.selectedIndex = 0;
this.renderSelectionFeatures();
renderSelectionFeatures: function() {
var layerIdx = this.layerList.selectedIndex;
+ var layerObj = this.oSelection.getLayer(layerIdx);
//clear the feature list select box of any previous selections
while (this.featureList.length>0) {
this.featureList.remove(this.featureList.options[0]);
- var layerObj = this.oSelection.getLayer(layerIdx);
var nElements = layerObj.getNumElements();
for (var i=0; i<nElements; i++) {
var opt = new Option(i+1, i);
@@ -140,14 +374,14 @@
this.featureList.selectedIndex = 0;
this.renderFeature();
renderFeature: function() {
var featureIdx = this.featureList.selectedIndex;
var nProperties = layerObj.getNumProperties();
var aNames = layerObj.getPropertyNames();
var table = document.createElement('table');
var thead = document.createElement('thead');
@@ -160,7 +394,7 @@
tr.appendChild(th);
thead.appendChild(tr);
table.appendChild(thead);
var tbody = document.createElement('tbody');
table.appendChild(tbody);
for (var i=0; i<nProperties; i++) {
@@ -180,3 +414,140 @@
this.featureDiv.appendChild(table);
+// This could be removed from this file if we want to keep only ONE default renderer.
+/* Class: Fusion.Widget.SelectionPanel.SelectionRendererHorizontal
+ * This class provide a alternate behavior for the selection panel.
+ * Generate a table which have one feature per row.
+Fusion.Widget.SelectionPanel.SelectionRendererHorizontal = OpenLayers.Class(Fusion.Widget.SelectionPanel.SelectionRenderer,
+ var d = document.createElement('div');
+ this.featureDiv = document.createElement('div');
+ this.featureDiv.innerHTML = 'No Selection';
+ Element.addClassName(this.featureDiv, 'noSelection');
+ d.appendChild(this.featureDiv);
+ if (this.iResultsPerPage != 0) {
+ this.previousButton = document.createElement('img');
+ this.previousButton.src = this.oSelectionPanel.previousIcon;
+ this.previousButton.style.position = "absolute";
+ this.previousButton.style.left = "0px";
+ this.previousButton.style.padding = "3px";
+ Event.observe(this.previousButton, 'click',
+ OpenLayers.Function.bind(this.renderLayers, this, 'prev'));
+ this.nextButton = document.createElement('img');
+ this.nextButton.src = this.oSelectionPanel.nextIcon;
+ this.nextButton.style.position = "absolute";
+ this.nextButton.style.right = "0px";
+ this.nextButton.style.padding = "3px";
+ Event.observe(this.nextButton, 'click',
+ OpenLayers.Function.bind(this.renderLayers, this, 'next'));
+ d.appendChild(this.previousButton);
+ d.appendChild(this.nextButton);
+ Element.addClassName(this.featureDiv, 'selectionPanelContent');
+ OpenLayers.Function.bind(this.renderSelection, this));
+ this.oSelection = null;
+ this.featureDiv.innerHTML = OpenLayers.i18n('noSelection');
+ renderSelection: function(oSelection) {
+ //TODO: this just gets the first map, we need them all
+ for (var mapName in oSelection) {
+ this.oSelection = oSelection[mapName];
+ break;
+ this.updatePageIndexes();
+ this.renderLayers("next");
+ renderLayers: function(renderingPage) {
+ if (!this.oSelection) {
+ return;
+ Element.removeClassName(this.featureDiv, 'noSelection');
+ this.featureDiv.innerHTML = '';
+ var table = document.createElement('table');
+ table.style.borderLeft = "1px solid #CCCCCC";
+ table.style.marginBottom = "10px";
+ var layerObj = this.oSelection.getLayer(i);
+ var aNames = layerObj.getPropertyNames();
+ //find the legend label from the Map layer objects
+ var mapLayers = this.getMap().aMaps[0].aLayers; //TODO: allow multiple maps
+ var labelName = layerObj.getName();
+ for (var j=0; j<mapLayers.length; ++j) {
+ if (mapLayers[j].layerName == labelName) {
+ labelName = mapLayers[j].legendLabel;
+ break;
+ var thead = document.createElement('thead');
+ var tr = document.createElement('tr');
+ var th = document.createElement('th');
+ th.innerHTML = labelName;
+ th.colSpan=aNames.length;
+ th.style.textAlign = "center";
+ tr.appendChild(th);
+ thead.appendChild(tr);
+ tr = document.createElement('tr');
+ for (var j=0; j<aNames.length; j++) {
+ th = document.createElement('th');
+ th.innerHTML = aNames[j];
+ table.appendChild(thead);
+ var tbody = document.createElement('tbody');
+ var page = (renderingPage == 'next') ? this.getNextPage(layerObj): this.getPreviousPage(layerObj);
+ this.renderFeatures(page,tbody);
+ table.appendChild(tbody);
+ this.featureDiv.appendChild(table);
+ renderFeatures: function(page, dom) {
+ if (!page)
+ return;
+ for (var i=0; i<page.length; i++) {
+ if (i%2) {
+ Element.addClassName(tr, 'oddRow');
+ for (var j=0; j<page[i].length; j++) {
+ var td = document.createElement('td');
+ td.innerHTML = page[i][j];
+ tr.appendChild(td);
+ dom.appendChild(tr);
More information about the fusion-commits
