[fusion-commits] r1722 - in trunk: . widgets
svn_fusion at osgeo.org
Thu Dec 18 15:28:52 EST 2008
Author: pagameba
Date: 2008-12-18 15:28:52 -0500 (Thu, 18 Dec 2008)
New Revision: 1722
trunk/build.xml
trunk/widgets/Legend.js
trunk/widgets/Maptip.js
Fixes #196. Position maptip slightly further away from the cursor and hide it on mouse down so it doesn't interfere with other tools as much.
Modified: trunk/build.xml
--- trunk/build.xml 2008-12-18 19:51:54 UTC (rev 1721)
+++ trunk/build.xml 2008-12-18 20:28:52 UTC (rev 1722)
@@ -76,7 +76,7 @@
<property name="app.path" value="/${app.name}"/>
<property name="app.version" value="1.1.x"/>
<property name="build.home" value="${basedir}/build"/>
- <property name="deploy.home" value="${env.HTDOCS}/${app.name}"/>
+ <property name="deploy.home" value="${basedir}/../${app.name}"/>
<property name="dist.home" value="${basedir}/dist"/>
<property name="docs.home" value="${build.home}/docs"/>
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2008-12-18 19:51:54 UTC (rev 1721)
+++ trunk/widgets/Legend.js 2008-12-18 20:28:52 UTC (rev 1722)
@@ -332,6 +332,16 @@
if (item instanceof Jx.TreeFolder) {
this.recurseTree(op, item);
item[op]();
+ if (item.domObj) {
+ var p = $(item.domObj).getPrevious();
+ if (p) {
+ item.domObj.dispose();
+ $(item.domObj).inject(p, 'before');
+ } else {
+ p = $(item.domObj).getParent();
+ $(item.domObj).inject(p, 'top');
Modified: trunk/widgets/Maptip.js
--- trunk/widgets/Maptip.js 2008-12-18 19:51:54 UTC (rev 1721)
+++ trunk/widgets/Maptip.js 2008-12-18 20:28:52 UTC (rev 1722)
@@ -56,7 +56,7 @@
aLayers: null,
bOverTip: false,
sWinFeatures: 'menubar=no,location=no,resizable=no,status=no',
- offset: new OpenLayers.Pixel(2,2),
+ offset: new OpenLayers.Pixel(0,20),
initializeWidget: function(widgetTag) {
var json = widgetTag.extension;
@@ -100,6 +100,7 @@
document.getElementsByTagName('BODY')[0].appendChild(this.domObj);
this.getMap().observeEvent('mousemove', OpenLayers.Function.bind(this.mouseMove, this));
+ this.getMap().observeEvent('mousedown', OpenLayers.Function.bind(this._hide, this));
this.getMap().observeEvent('mouseout', OpenLayers.Function.bind(this.mouseOut, this));
More information about the fusion-commits
