[fusion-commits] r1726 - branches/fusion2-mg21
svn_fusion at osgeo.org
Thu Dec 18 18:29:31 EST 2008
Author: chrisclaydon
Date: 2008-12-18 18:29:31 -0500 (Thu, 18 Dec 2008)
New Revision: 1726
branches/fusion2-mg21/build.xml
Fixed accidentally reverted build number
Modified: branches/fusion2-mg21/build.xml
--- branches/fusion2-mg21/build.xml 2008-12-18 22:46:17 UTC (rev 1725)
+++ branches/fusion2-mg21/build.xml 2008-12-18 23:29:31 UTC (rev 1726)
@@ -43,7 +43,7 @@
<property file="build.properties"/>
<property file="${user.home}/build.properties"/>
- <property file="default.properties"/>
+ <property file="default.properties"/>
<!-- ==================== File and Directory Names ======================== -->
@@ -74,7 +74,7 @@
<property environment="env"/>
<property name="app.name" value="fusion"/>
<property name="app.path" value="/${app.name}"/>
- <property name="app.version" value="1.1.x"/>
+ <property name="app.version" value="2.0.x"/>
<property name="build.home" value="${basedir}/build"/>
<property name="deploy.home" value="${basedir}/../${app.name}"/>
<property name="dist.home" value="${basedir}/dist"/>
@@ -85,7 +85,7 @@
Use property values to define the locations of external libraries on which
- your application will depend.
+ your application will depend.
<property name="YUIcompressor" value="${basedir}/utils/yuicompressor-2.3.6.jar"/>
@@ -116,16 +116,16 @@
<copy file="config_dist.json" tofile="${build.home}/config.json"/>
<!-- Copy static content -->
<copy todir="${build.home}">
- <fileset dir="${basedir}"
+ <fileset dir="${basedir}"
includes="configHeader.json
- layers/**
- common/**
+ layers/**
+ common/**
containerinfo/**
- docs/**
- ext/**
- lib/**
- templates/**
- text/**
+ docs/**
+ ext/**
+ lib/**
+ templates/**
+ text/**
widgets/**"
excludes="selenium/**"
@@ -135,33 +135,33 @@
<!-- ==================== Documentation =================================== -->
<target description="Create documentation" name="docs" depends="prepare">
<delete dir="${build.home}/docs/NaturalDocs"/>
<mkdir dir="${build.home}/docs"/>
<mkdir dir="${build.home}/docs/NaturalDocs"/>
<echo message="Generating documentation"/>
<exec executable="cmd" os="Windows Vista, Windows XP" dir="${build.home}">
<arg value="/c"/>
- <arg value="NaturalDocs.bat"/>
+ <arg value="NaturalDocs.bat"/>
<arg value="-i ./"/>
<arg value="-o html ./docs"/>
<arg value="-p ./docs/NaturalDocs"/>
<arg value="-xi ./scriptaculous"/>
<arg value="-xi ./lib"/>
<arg value="-r"/>
<arg line="/c perl C:\Progra~1\NaturalDocs\NaturalDocs -i ./lib -i ./widgets -o html ./docs/NaturalDocs -p ./docs/NaturalDocs -r"/>
</exec>
</target>
<target description="Create documentation" name="widgetInfo" depends="prepare">
<delete dir="${build.home}/docs/widgetinfo"/>
<mkdir dir="${build.home}/docs/widgetinfo"/>
- <xslt basedir="${basedir}/widgets/widgetinfo"
+ <xslt basedir="${basedir}/widgets/widgetinfo"
destdir="${build.home}/docs/widgetinfo"
- style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
+ style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
excludes="WidgetInfoTemplate.xml widgetInfo.xsl"/>
</target>
@@ -169,21 +169,21 @@
<target description="convert AppDef to JSON" name="appDef2Json" if="appDef">
<echo message="converting ${appDef} to JSON"/>
<delete dir="${build.home}/appDefFileset.xml"/>
<!-- generate the list of files for this Application and load as a property -->
- <xslt in="${appDef}"
+ <xslt in="${appDef}"
out="${build.home}/appDefFileset.xml"
style="${basedir}/parseAppDef.xsl">
<param name="buildHome" expression="${build.home}"/>
</xslt>
<xmlproperty file="${build.home}/appDefFileset.xml"/>
<!-- convert the application definition file to JSON -->
- <exec executable="php" os="Windows Vista, Windows XP"
+ <exec executable="php" os="Windows Vista, Windows XP"
output="${build.home}/appDef.json">
<arg line="common\php\Xml2JSON.php --file='${appDef}'"/>
</exec>
</target>
<!-- =================== single file build ================================== -->
@@ -191,30 +191,30 @@
<echo message="preparing single file build"/>
</target>
<!-- =================== concat build ================================== -->
<target description="concatenate core files into a single file" name="concat" depends="prepare">
<echo message="concatenating core files"/>
<delete file="${buildOutput}.js"/>
<!-- Fusion looks for it's own script name to set paths for other widgets
so replace the value to look for with the sfName used to create the file-->
<!-- merge everything into a single file -->
<concat destfile="${buildOutput}.js" outputencoding="UTF-8">
- <filelist dir="${build.home}/lib"
+ <filelist dir="${build.home}/lib"
files=" SingleFile.js
fusion.js
OpenLayers/OpenLayers.js
jxlib.uncompressed.js
excanvas/excanvas.js
- Error.js
+ Error.js
EventMgr.js
ApplicationDefinition.js
- MGBroker.js
- Widget.js
- CanvasTool.js
- RectTool.js
+ MGBroker.js
+ Widget.js
+ CanvasTool.js
+ RectTool.js
Search.js
Map.js"
@@ -222,7 +222,7 @@
<filelist dir="${build.home}" files="configHeader.json config.json"/>
<filelist dir="${build.home}/layers" files="Layers.js"/>
</concat>
<replace file="${buildOutput}.js" token="lib/fusion" value="lib/${sfName}"/>
<copy file="${buildOutput}.js" todir="${basedir}/lib"/>
</target>
@@ -230,7 +230,7 @@
<!-- =================== concat all support files (no appdef supplied) ================================== -->
<target description="concatenate core files into a single file" name="concatNoAppDef" unless="appDef">
<echo message="concatenating all widget and map layer files"/>
<concat destfile="${buildOutput}.js" outputencoding="UTF-8" append="true">
<fileset dir="${build.home}/widgets" includes="**/*.js"/>
@@ -241,14 +241,14 @@
<!-- =================== concat support files included in AppDef ================================== -->
<target description="concatenate core files into a single file" name="concatWithAppDef" depends="appDef2Json" if="appDef">
<echo message="preparing single file build for ${appDef}"/>
<filelist dir="${build.home}" files="${AppDef.Maps}"/>
<filelist dir="${build.home}" files="${AppDef.Widgets}"/>
<filelist dir="${build.home}" files="appDef.json"/>
</concat>
</target>
@@ -261,20 +261,20 @@
<arg value="${buildOutput}.js"/>
</java>
<copy file="${buildOutput}-compressed.js" todir="${basedir}/lib"/>
</target>
<!-- =================== concat all CSS files ================================== -->
<target description="concatenate CSS files into a single file" name="concatCSS" depends="prepare">
<echo message="concatenating all CSS files"/>
<echo message="merging with ${cssFiles}"/>
<concat destfile="${cssOutput}.css">
<filelist files="${cssFiles}"/>
<fileset dir="${build.home}/widgets" includes="**/*.css" excludes="**/*scalebar*"/>
</concat>
<java jar="${YUIcompressor}" fork="true"
output="${cssOutput}-compressed.css">
<arg value="${cssOutput}.css"/>
@@ -284,13 +284,13 @@
<!-- =================== concat and compress a list of CSS files ================================== -->
<target description="concatenate and compress CSS files into a single file" name="compressCSS" if="cssFiles">
<echo message="merging ${cssFiles}"/>
</concat>
@@ -325,7 +325,7 @@
<target name="dist" description="Create binary distribution" depends="clean,docs,compress">
<echo message="Creating distribution archive"/>
<mkdir dir="${dist.home}"/>
@@ -333,15 +333,15 @@
<zip destfile="${dist.home}/${app.name}-${app.version}.zip" update="true">
<zipfileset dir="${build.home}" prefix="${app.name}"/>
</zip>
<!-- create tar file -->
<tar destfile="${dist.home}/${app.name}-${app.version}.tar">
<tarfileset dir="${build.home}" prefix="${app.name}"/>
</tar>
<gzip src="${dist.home}/${app.name}-${app.version}.tar" destfile="${dist.home}/${app.name}-${app.version}.tar.gz"/>
<!--tar destfile=""/-->
</target>
<!-- ==================== Clean Target ==================================== -->
More information about the fusion-commits
