[fusion-commits] r1728 - branches/fusion-1.1/MapGuide
svn_fusion at osgeo.org
Fri Dec 19 12:52:06 EST 2008
Author: madair
Date: 2008-12-19 12:52:06 -0500 (Fri, 19 Dec 2008)
New Revision: 1728
branches/fusion-1.1/MapGuide/MapGuide.js
re #183: add iamge format as MapGuide extension parameter
Modified: branches/fusion-1.1/MapGuide/MapGuide.js
--- branches/fusion-1.1/MapGuide/MapGuide.js 2008-12-18 23:46:16 UTC (rev 1727)
+++ branches/fusion-1.1/MapGuide/MapGuide.js 2008-12-19 17:52:06 UTC (rev 1728)
@@ -44,14 +44,16 @@
oSelection: null,
bDisplayInLegend: true, //TODO: set this in AppDef?
bExpandInLegend: true, //TODO: set this in AppDef?
- bMapLoaded : false,
- bIsMapWidgetLayer : true, //Setthis to false for overview map layers
+ bMapLoaded: false,
+ bIsMapWidgetLayer: true, //Setthis to false for overview map layers
bLayersReversed: false, //MGOS returns layers top-most layer first
//the resource id of the current MapDefinition
_sResourceId: null,
+ //request params
clientAgent: 'Fusion Viewer',
+ defaultFormat: 'PNG',
initialize : function(map, mapTag, isMapWidgetLayer) {
// console.log('MapGuide.initialize');
@@ -71,6 +73,7 @@
var extension = mapTag.extension; //TBD: this belongs in layer tag?
this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
this.ratio = extension.MapRatio ? extension.MapRatio[0] : 1.0;
+ this.imageFormat = extension.ImageFormat ? extension.ImageFormat[0] : this.defaultFormat;
//add in the handler for CTRL-click actions for the map, not an overviewmap
if (this.bIsMapWidgetLayer) {
@@ -509,6 +512,7 @@
params = { //single tile params
session: this.getSessionID(),
mapName: this._sMapname,
+ format: this.imageFormat,
clientagent: this.clientAgent
params.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
More information about the fusion-commits
