[fusion-commits] r1435 - sandbox/aboudreault/widgets
svn_fusion at osgeo.org
Fri Jul 4 13:43:40 EDT 2008
Author: aboudreault
Date: 2008-07-04 13:43:39 -0400 (Fri, 04 Jul 2008)
New Revision: 1435
sandbox/aboudreault/widgets/Legend.js
sandbox/aboudreault/widgets/SelectionPanel.js
* Removing unuseful code in SelectionPanel
* Modifying Legend to support Renderer pattern to make differents behaviors
Modified: sandbox/aboudreault/widgets/Legend.js
--- sandbox/aboudreault/widgets/Legend.js 2008-07-04 14:30:12 UTC (rev 1434)
+++ sandbox/aboudreault/widgets/Legend.js 2008-07-04 17:43:39 UTC (rev 1435)
@@ -23,64 +23,215 @@
* DEALINGS IN THE SOFTWARE.
* Class: Fusion.Widget.Legend
- * Displays a legend of all the layers in the map as a collapsable tree.
- * ShowRootFolder (boolean, optional)
+ * A widget to display a legend of all layers.
- * This controls whether the tree will have a single root node that
- * contains the name of the map as its label. By default, the root
- * node does not appear. Set to "true" or "1" to make the root node
- * appear.
- * RootFolderIcon: (string, optional)
- * The url to an image to use for the root folder. This only has an
- * affect if ShowRootFolder is set to show the root folder.
- * LayerThemeIcon: (string, optional)
- * The url to an image to use for layers that are currently themed.
- * DisabledLayerIcon: (string, optional)
- * The url to an image to use for layers that are out of scale.
Fusion.Widget.Legend = OpenLayers.Class(Fusion.Widget, {
- currentNode: null,
- bIsDrawn: false,
- targetFolder: null,
- initialize : function(widgetTag) {
- this.defLayerDWFIcon = 'images/icons/legend-DWF.png';
- this.defLayerRasterIcon = 'images/icons/legend-raster.png';
- this.defLayerThemeIcon = 'images/icons/legend-theme.png';
- this.defDisabledLayerIcon = 'images/icons/legend-layer.png';
- this.defRootFolderIcon = 'images/icons/legend-map.png';
- this.defLayerInfoIcon = 'images/icons/tree_layer_info.png';
- this.defGroupInfoIcon = 'images/icons/tree_group_info.png';
- this.bIncludeVisToggle = true;
+ * Constant: defaultLayerDWFIcon
+ * {String} The default image for DWF layer
+ defaultLayerDWFIcon: 'images/icons/legend-DWF.png',
+ * Constant: defaultLayerRasterIcon
+ * {String} The default image for Raster layer
+ defaultLayerRasterIcon: 'images/icons/legend-raster.png',
+ * Constant: defaultLayerThemeIcon
+ * {String} The default image for layers that are currently themed.
+ defaultLayerThemeIcon: 'images/icons/legend-theme.png',
+ * Constant: defaultDisabledLayerIcon
+ * {String} The default image for layers that are out of scale.
+ defaultDisabledLayerIcon: 'images/icons/legend-layer.png',
+ * Constant: defaultRootFolderIcon
+ * {String} The default image for the root folder
+ defaultRootFolderIcon: 'images/icons/legend-map.png',
+ * Constant: defaultLayerInfoIcon
+ * {String} The default image for layer info
+ defaultLayerInfoIcon: 'images/icons/tree_layer_info.png',
+ * Constant: defaultGroupInfoIcon
+ * {String} The default image for groupd info
+ defaultGroupInfoIcon: 'images/icons/tree_group_info.png',
+ initialize : function(widgetTag) {
//console.log('Legend.initialize');
Fusion.Widget.prototype.initialize.apply(this, [widgetTag, true]);
+ // TODO: maybe it's a good idea to do a function like Fusion.Widget.BindRenderer.. for limit the code
+ // duplication if we plan to apply this pattern to others widgets
var json = widgetTag.extension;
+ if (json.LegendRenderer)
+ var renderer = eval(json.LegendRenderer[0]);
+ if (renderer && renderer.prototype.CLASS_NAME
+ && renderer.prototype.CLASS_NAME == "Fusion.Widget.Legend.LegendRenderer") {
+ this.renderer = new renderer(this, widgetTag);
+ } else if (typeof renderer == "function") {
+ var renderFunction = renderer;
+ this.renderer = new Fusion.Widget.Legend.LegendRenderer(this);
+ this.renderer.mapLoaded = renderFunction;
+ this.renderer.mapReloaded = renderFunction;
+ this.renderer.mapLoading = false;
+ } else {
+ this.renderer = new Fusion.Widget.Legend.LegendRendererDefault(this, widgetTag);
+ } else {
+ if (this.renderer.mapReloaded)
+ this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED,
+ OpenLayers.Function.bind(this.renderer.mapReloaded, this.renderer));
+ if (this.renderer.mapLoading)
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADING,
+ OpenLayers.Function.bind(this.renderer.mapLoading,this.renderer));
+ if (this.renderer.mapLoaded)
+ this.getMap().registerForEvent(Fusion.Event.MAP_LOADED,
+ OpenLayers.Function.bind(this.renderer.mapLoaded, this.renderer));
+/* Class: Fusion.Widget.Legend.LegendRenderer
+ * This is a class designed to help users to create their own renderer
+ * for customize the legend.
+Fusion.Widget.Legend.LegendRenderer = OpenLayers.Class(
+ * Property: layerRoot
+ * {Groups} The groups of all layers.
+ layerRoot: null,
+ initialize: function(legend) {
+ this.oLegend = legend;
+ this.layerRoot = this.getMap().layerRoot;
+ * Method: renderLegend
+ * Abstract method that have the main purpose to draw the legend. This method
+ * should be implemented by all concrete class.
+ renderLegend: function() {},
+ * Method: mapLoading
+ * Abstract method that handle the event: Fusion.Event.MAP_LOADING. This method
+ * is optional.
+ mapLoading: function() {},
+ * Method: mapLoaded
+ * Abstract method that handle the event: Fusion.Event.MAP_LOADED. This method
+ * occur only at the first load of the map and should be implemented by all concrete class.
+ mapLoaded: function() {},
+ * Method: mapReloaded
+ * Abstract method that handle the event: Fusion.Event.MAP_RELOADED. This method
+ mapReloaded: function() {},
+ * Method: getMap
+ * Helper method to obtains the map.
+ * Returns:
+ * {<Fusion.Maps>} The map that uses the SelectionPanel Widget.
+ getMap: function() {
+ return this.oLegend.getMap();
+ CLASS_NAME: "Fusion.Widget.Legend.LegendRenderer",
+/* Class: Fusion.Widget.Legend.LegendRendererDefault
+ * This class provide a default legend as a collapsable tree.
+Fusion.Widget.Legend.LegendRendererDefault = OpenLayers.Class(Fusion.Widget.Legend.LegendRenderer,
+ * Property: showRootFolder
+ * {Boolean} This controls whether the tree will have a single root node that
+ * contains the name of the map as its label. By default, the root node does
+ * not appear. Set to "true" or "1" to make the root node appear.
+ showRootFolder: false,
+ * Property: currentNode
+ * {Jx.TreeNode} The current selected node.
+ currentNode: null,
+ * Property: bIsDrawn
+ * {Boolean} Determine if the map is drawn.
+ bIsDrawn: false,
+ * Property: targetFolder
+ * {Jx.TreeFolder} The current TreeFolder that the mouse will interact with.
+ targetFolder: null,
+ * Property: bIncludeVisToggle
+ * {Boolean} Determine if non-visible layer must be draw in the legend.
+ bIncludeVisToggle: true,
+ initialize : function(legend, widgetTag) {
+ Fusion.Widget.Legend.LegendRenderer.prototype.initialize.apply(this, [legend]);
+ var json = widgetTag.extension;
+ this.imgLayerDWFIcon = json.LayerDWFIcon ? json.LayerDWFIcon[0] : this.oLegend.defaultLayerDWFIcon;
+ this.imgLayerRasterIcon = json.LayerRasterIcon ? json.LayerRasterIcon[0] : this.oLegend.defaultLayerRasterIcon;
+ this.imgLayerThemeIcon = json.LayerThemeIcon ? json.LayerThemeIcon[0] : this.oLegend.defaultLayerThemeIcon;
+ this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.oLegend.defaultDisabledLayerIcon;
+ this.imgLayerInfoIcon = json.LayerInfoIcon ? json.LayerInfoIcon[0] : this.oLegend.defaultLayerInfoIcon;
+ this.imgGroupInfoIcon = json.GroupInfoIcon ? json.GroupInfoIcon[0] : this.oLegend.defaultGroupInfoIcon;
- this.imgLayerDWFIcon = json.LayerDWFIcon ? json.LayerDWFIcon[0] : this.defLayerDWFIcon;
- this.imgLayerRasterIcon = json.LayerRasterIcon ? json.LayerRasterIcon[0] : this.defLayerRasterIcon;
- this.imgLayerThemeIcon = json.LayerThemeIcon ? json.LayerThemeIcon[0] : this.defLayerThemeIcon;
- this.imgDisabledLayerIcon = json.DisabledLayerIcon ? json.DisabledLayerIcon[0] : this.defDisabledLayerIcon;
- this.imgLayerInfoIcon = json.LayerInfoIcon ? json.LayerInfoIcon[0] : this.defLayerInfoIcon;
- this.imgGroupInfoIcon = json.GroupInfoIcon ? json.GroupInfoIcon[0] : this.defGroupInfoIcon;
//not used?
//this.layerInfoURL = json.LayerInfoURL ? json.LayerInfoURL[0] : '';
this.selectedLayer = null;
- this.oTree = new Jx.Tree(this.domObj);
+ this.oTree = new Jx.Tree(this.oLegend.domObj);
this.hideInvisibleLayers = (json.HideInvisibleLayers && json.HideInvisibleLayers[0]) == 'true' ? true : false;
@@ -119,11 +270,6 @@
this.oRoot = this.oTree;
this.extentsChangedWatcher = this.update.bind(this);
- this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded, this));
- this.getMap().registerForEvent(Fusion.Event.MAP_RELOADED, OpenLayers.Function.bind(this.draw, this));
- this.getMap().registerForEvent(Fusion.Event.MAP_LOADING, OpenLayers.Function.bind(this.mapLoading, this));
expandAll: function() {
@@ -181,9 +327,12 @@
this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.extentsChangedWatcher);
- this.draw();
+ this.renderLegend();
+ renderLegend();
* the map state has become invalid in some way (layer added, removed,
* ect). For now, we just re-request the map state from the server
@@ -202,16 +351,16 @@
* @param r Object the reponse xhr object
- draw: function(r) {
+ renderLegend: function(r) {
this.bIsDrawn = false;
this.clear();
- var map = this.getMap();
if (this.showRootFolder) {
- this.oRoot.setName(map.getMapTitle());
+ this.oRoot.setName(this.getMap().getMapTitle());
- var startGroup = map.layerRoot;
+ var startGroup = this.layerRoot;
if (!this.showMapFolder) {
- startGroup = map.layerRoot.groups[0];
+ startGroup = this.layerRoot.groups[0];
if (!startGroup.legend) {
startGroup.legend = {};
Modified: sandbox/aboudreault/widgets/SelectionPanel.js
--- sandbox/aboudreault/widgets/SelectionPanel.js 2008-07-04 14:30:12 UTC (rev 1434)
+++ sandbox/aboudreault/widgets/SelectionPanel.js 2008-07-04 17:43:39 UTC (rev 1435)
@@ -30,7 +30,6 @@
Fusion.Widget.SelectionPanel = OpenLayers.Class(Fusion.Widget,
@@ -180,7 +179,7 @@
return this.getPage(selectionLayer, startIndex, endIndex);
- return this.getPage(selectionLayer, false, false);
+ return this.getPage(selectionLayer);
@@ -210,7 +209,7 @@
this.aiCurrentIndex[layerName] = endIndex;
@@ -269,7 +268,7 @@
clearSelection: function() {},
- CLASS_NAME: "Fusion.Widget.SelectionPanel.SelectionRenderer",
+ CLASS_NAME: "Fusion.Widget.SelectionPanel.SelectionRenderer"
/* Class: Fusion.Widget.SelectionPanel.SelectionRendererDefault
More information about the fusion-commits
