[fusion-commits] r1442 - in sandbox/olcore: . common/php jx/lib layers layers/MapGuide layers/MapGuide/php layers/MapServer layers/MapServer/php lib lib/OpenLayers templates/mapguide/standard widgets widgets/BufferPanel widgets/Print widgets/Search widgets/SelectWithin
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue Jul 22 11:00:32 EDT 2008
Author: madair
Date: 2008-07-22 11:00:30 -0400 (Tue, 22 Jul 2008)
New Revision: 1442
Added:
   sandbox/olcore/configHeader.json
   sandbox/olcore/lib/EventMgr.js
   sandbox/olcore/lib/SingleFile.js
   sandbox/olcore/parseAppDef.xsl
   sandbox/olcore/build.xml
   sandbox/olcore/common/php/Utilities.php
   sandbox/olcore/common/php/Xml2JSON.php
   sandbox/olcore/config.json
   sandbox/olcore/fusion.cfg
   sandbox/olcore/jx/lib/jx_combined.css
   sandbox/olcore/jx/lib/jx_combined.js
   sandbox/olcore/jx/lib/jx_compressed.js
   sandbox/olcore/layers/Layers.js
   sandbox/olcore/layers/MapGuide/MapGuide.js
   sandbox/olcore/layers/MapGuide/php/Buffer.php
   sandbox/olcore/layers/MapGuide/php/Common.php
   sandbox/olcore/layers/MapGuide/php/CreateSession.php
   sandbox/olcore/layers/MapGuide/php/Query.php
   sandbox/olcore/layers/MapGuide/php/SaveMap.php
   sandbox/olcore/layers/MapGuide/php/Utilities.php
   sandbox/olcore/layers/MapServer/MapServer.js
   sandbox/olcore/layers/MapServer/php/CreateSession.php
   sandbox/olcore/layers/MapServer/php/LegendIcon.php
   sandbox/olcore/layers/MapServer/php/LoadMap.php
   sandbox/olcore/layers/MapServer/php/Measure.php
   sandbox/olcore/layers/MapServer/php/Query.php
   sandbox/olcore/layers/MapServer/php/SetLayers.php
   sandbox/olcore/lib/ApplicationDefinition.js
   sandbox/olcore/lib/MGBroker.js
   sandbox/olcore/lib/Map.js
   sandbox/olcore/lib/OpenLayers/OpenLayers.js
   sandbox/olcore/lib/OpenLayers/OpenLayersCompressed.js
   sandbox/olcore/lib/OpenLayers/OpenLayersUncompressed.js
   sandbox/olcore/lib/fusion.js
   sandbox/olcore/templates/mapguide/standard/ApplicationDefinition.xml
   sandbox/olcore/templates/mapguide/standard/index.html
   sandbox/olcore/widgets/BufferPanel/Buffer.php
   sandbox/olcore/widgets/CenterSelection.js
   sandbox/olcore/widgets/ColorPicker.js
   sandbox/olcore/widgets/CursorPosition.js
   sandbox/olcore/widgets/MapMenu.js
   sandbox/olcore/widgets/Maptip.js
   sandbox/olcore/widgets/Measure.js
   sandbox/olcore/widgets/Navigator.js
   sandbox/olcore/widgets/OverviewMap.js
   sandbox/olcore/widgets/PanOnClick.js
   sandbox/olcore/widgets/PanQuery.js
   sandbox/olcore/widgets/Print/printablepage.templ
   sandbox/olcore/widgets/SaveMap.js
   sandbox/olcore/widgets/ScalebarDual.js
   sandbox/olcore/widgets/Search/Search.php
   sandbox/olcore/widgets/SelectRadius.js
   sandbox/olcore/widgets/SelectRadiusValue.js
   sandbox/olcore/widgets/SelectWithin/SelectWithin.php
   sandbox/olcore/widgets/ViewOptions.js
   sandbox/olcore/widgets/ViewSize.js
merged with trunk at rev. 1438
Modified: sandbox/olcore/build.xml
--- sandbox/olcore/build.xml	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/build.xml	2008-07-22 15:00:30 UTC (rev 1442)
@@ -89,6 +89,7 @@
   <property name="jx-lib"  value="jx"/>
+  <property name="YUIcompressor"  value="C:\YUI\yuicompressor-2.3.5\build\yuicompressor-2.3.5.jar"/>
 <!-- ==================== Prepare Target ================================== -->
@@ -113,6 +114,7 @@
     <copy todir="${build.home}">
       <fileset dir="${basedir}"
             includes="config.json
+                      configHeader.json
                       MapGuide/**
                       MapServer/**
                       common/**
@@ -120,8 +122,6 @@
                       docs/**
                       ext/**
                       lib/**
-                      redist/**
-                      samples/**
                       templates/**
                       text/**
                       widgets/**"
@@ -161,8 +161,7 @@
     </exec>
   </target>
-  <target description="Create documentation" name="docs2" depends="prepare">
+  <target description="Create documentation" name="widgetInfo" depends="prepare">
     <delete dir="${build.home}/docs/widgetinfo"/>
     <mkdir dir="${build.home}/docs/widgetinfo"/>
     <xslt basedir="${basedir}/widgets/widgetinfo"
@@ -170,8 +169,70 @@
           style="${basedir}/widgets/widgetinfo/widgetInfo.xsl"
           excludes="WidgetInfoTemplate.xml widgetInfo.xsl"/>
   </target>
+<!-- =================== prepare AppDef for single file build ================================== -->
+  <target description="convert AppDef to JSON" name="appDef2Json" if="appDef">
+    <echo message="converting ${appDef} to JSON"/>
+    <delete dir="${build.home}/appDefFileset.xml"/>
+    <!-- generate the list of files for this Application and load as a property -->
+    <xslt in="${appDef}"
+          out="${build.home}/appDefFileset.xml"
+          style="${basedir}/parseAppDef.xsl">
+      <param name="buildHome" expression="${build.home}"/>
+    </xslt>
+    <xmlproperty file="${build.home}/appDefFileset.xml"/>
+    <!-- convert the application definition file to JSON -->
+    <exec executable="php" os="Windows Vista, Windows XP"
+              output="${build.home}/appDef.json">
+        <arg line="common\php\Xml2JSON.php --file='${appDef}'"/>
+    </exec>
+  </target>
+<!-- =================== single file build ================================== -->
+  <target description="single file build" name="singleFile" depends="clean,prepare,appDef2Json">
+    <echo message="preparing single file build for ${appDef}"/>
+    <delete dir="${build.home}/lib/fusionSF.js"/>
+    <!-- merge everything into a single file -->
+    <concat destfile="${build.home}/lib/fusionSF.js" outputencoding="UTF-8">
+        <filelist dir="${build.home}/lib"
+                  files=" SingleFile.js
+                          fusion.js
+                          OpenLayers/OpenLayers.js
+                          ../jx/lib/jx_combined.js
+                          excanvas/excanvas.js
+                          Error.js
+                          EventMgr.js
+                          ApplicationDefinition.js
+                          MGBroker.js
+                          Widget.js
+                          ButtonBase.js
+                          MenuBase.js
+                          ButtonTool.js
+                          CanvasTool.js
+                          ClickTool.js
+                          RectTool.js
+                          Search.js
+                          Map.js"
+        <fileset dir="${build.home}/text" includes="**/*.json"/>
+        <filelist dir="${build.home}" files="${AppDef.Maps}"/>
+        <filelist dir="${build.home}" files="${AppDef.Widgets}"/>
+        <filelist dir="${build.home}" files="appDef.json configHeader.json config.json"/>
+    </concat>
+    <echo message="compressing..."/>
+    <java jar="${YUIcompressor}" fork="true"
+          output="${build.home}/lib/fusionSF-compressed.js">
+        <arg value="${build.home}/lib/fusionSF.js"/>
+    </java>
+    <!--exec executable="jsmin.exe" os="Windows Vista, Windows XP"
+      input="${build.home}/lib/fusionSF.js" output="${build.home}/lib/fusionSF-compressed.js"/-->
+  </target>
 <!-- =================== Compress Target ================================== -->
@@ -179,8 +240,8 @@
     <echo message="Concatenating into -lib version"/>
     <concat destfile="${build.home}/lib/fusion-combined.js" outputencoding="UTF-8">
-        files=" utils.js
-                Error.js
+        files=" Error.js
+                EventMgr.js
                 MGBroker.js
                 Widget.js
@@ -199,8 +260,12 @@
         <fileset dir="${build.home}/widgets" includes="*.js **/*.js" excludes="Recenter.js"/>
     </concat>
-    <exec executable="jsmin.exe" os="Windows Vista, Windows XP"
-      input="${build.home}/lib/fusion-combined.js" output="${build.home}/lib/fusion-compressed.js"/>
+    </java>
+      input="${build.home}/lib/fusion-combined.js" output="${build.home}/lib/fusion-compressed.js"/-->
   </target>
 <!-- ==================== Deploy ========================================== -->
Modified: sandbox/olcore/common/php/Utilities.php
--- sandbox/olcore/common/php/Utilities.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/common/php/Utilities.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -241,4 +241,47 @@
     return $szResult;
+function arguments($argv) {
+    $_ARG = array();
+    foreach ($argv as $arg) {
+        if (ereg('--[a-zA-Z0-9]*=.*',$arg)) {
+            $str = split("=",$arg); $arg = '';
+            $key = ereg_replace("--",'',$str[0]);
+            for ( $i = 1; $i < count($str); $i++ ) {
+                $arg .= $str[$i];
+                        $_ARG[$key] = $arg;
+        } elseif(ereg('-[a-zA-Z0-9]',$arg)) {
+            $arg = ereg_replace("-",'',$arg);
+            $_ARG[$arg] = 'true';
+    return $_ARG;
+function loadFusionConfig() {
+    /* json decode only in PHP 5.2 and later */
+    if (function_exists('json_decode')) {
+        $configFile = realpath(dirname(__FILE__)."/../../config.json");
+        if (file_exists($configFile)) {
+            $configStr = file_get_contents($configFile);
+            /* replace single quotes with double quotes */
+            $configStr = str_replace("'", '"', $configStr);
+            /* get rid of new lines, it just complicates things */
+            $configStr = str_replace("\n", '', $configStr);
+            /* get rid of embedded comments */
+            $configStr = preg_replace("/\/\*.*\*\//U", "", $configStr);
+            /* the regex after this one can't handle http: as a value, so mangle it. */
+            $configStr = preg_replace("/http:/U", "http_", $configStr);
+            /* quote unquoted attribute names */
+            $configStr = preg_replace("/[^\"]{1}(\w*):/U", "\"$1\":", $configStr);
+            /* decode the whole thing */
+            $_SESSION['fusionConfig'] = json_decode($configStr, false);
+        } else {
+          echo "config file not found";
\ No newline at end of file
Modified: sandbox/olcore/common/php/Xml2JSON.php
--- sandbox/olcore/common/php/Xml2JSON.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/common/php/Xml2JSON.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -30,15 +30,32 @@
 if (isset($_FILES['xml'])) {
     $xml = file_get_contents($_FILES['xml']['tmp_name']);
-} else {
+} elseif (isset($_SERVER['HTTP_HOST'])) {
     $REQUEST_VARS = array_merge($_GET, $_POST);
     if (!isset($REQUEST_VARS['xml'])) {
         die('xml not set');
+    header('Content-type: text/plain');
+    header('X-JSON: true');
     $xml = rawurldecode ($REQUEST_VARS['xml']);
     $xml = str_replace('\"', '"', $xml);
+    $xml = str_replace('&quot;', "'", $xml);
+} elseif (isset($argv)) {
+    $cliArgs = arguments($argv);
+    if (isset($cliArgs['obj'])) {
+        $jsObject = $cliArgs['obj'];
+    } else {
+        $jsObject = "Fusion.appDefJson";
+    if (isset($cliArgs['file'])) {
+        $xml = file_get_contents($cliArgs['file']);
+        if (!$xml) {
+            die('file not found:'.$cliArgs['file']);
+        echo $jsObject."=";
+} else {
+    die('no XML input');
 //print_r($xml);
 $document = DOMDocument::loadXML($xml);
@@ -46,8 +63,5 @@
     die ('/* invalid xml document:'.$xml.' */');
 $root = $document->documentElement;
-header('Content-type: text/plain');
-header('X-JSON: true');
-echo '{"' . $root->tagName . '":' . xml2json($root) . '}';
+echo '{"' . $root->tagName . '":' . xml2json($root) . '};';
Modified: sandbox/olcore/config.json
--- sandbox/olcore/config.json	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/config.json	2008-07-22 15:00:30 UTC (rev 1442)
@@ -1,21 +1,21 @@
 /* This is the fusion configuration file.  Adjust as necessary. */
-    /* The general section contains settings that are general to
+    /* The general section contains settings that are general to
        fusion as a whole. */
     "general": {
-	    /* PHP is the default and only script language supported.
+	    /* PHP is the default and only script language supported.
 	       Don"t change this. */
 	    "scriptLanguage": "php",
 	    /* A directory on this system that fusion can use for
 	       temporary files. */
 	    "temporaryDirectory": "/tmp"
-    /* The MapGuide section is required if you are installing
+    /* The MapGuide section is required if you are installing
        fusion for MapGuide. */
     "mapguide": {
-	    /* The WebTierURL is the url to mapguide, it should start
-	       with http and end with /mapguide.  If you have installed
+	    /* The WebTierURL is the url to mapguide, it should start
+	       with http and end with /mapguide.  If you have installed
 	       fusion inside the www directory of MapGuide, then you can
 	       leave this empty as it will be automatically calculated. */
            "webTierUrl": ""
@@ -24,11 +24,14 @@
        for MapServer. */
    "mapserver": {
 	    /* The URL of the mapserver CGI that you want to use.  */
-	    "cgi": "/cgi-bin/mapserv",
+	    "cgi": "http://127.0.0.1/cgi-bin/mapserv.exe",
 	    /* The file system path to where mapserver should put
 	        web-accessible temporary images. */
 	    "imagePath": "/tmp/ms_tmp",
 	    /* The URL to the image path configured above. */
-	    "imageUrl": "http://localhost/tmp/ms_tmp"
+	    "imageUrl": "http://localhost/tmp/ms_tmp",
+	    /* The file system path to where mapserver should put
+	        web-accessible temporary legend images. */
+	    "legendIconCacheDir":"/tmp/ms_tmp"
Copied: sandbox/olcore/configHeader.json (from rev 1438, trunk/configHeader.json)
--- sandbox/olcore/configHeader.json	                        (rev 0)
+++ sandbox/olcore/configHeader.json	2008-07-22 15:00:30 UTC (rev 1442)
@@ -0,0 +1 @@
+Fusion.configuration=
Modified: sandbox/olcore/fusion.cfg
--- sandbox/olcore/fusion.cfg	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/fusion.cfg	2008-07-22 15:00:30 UTC (rev 1442)
@@ -4,10 +4,11 @@
 [first]
 OpenLayers/SingleFile.js
 OpenLayers.js
+OpenLayers/BaseTypes.js
+OpenLayers/BaseTypes/Class.js
 OpenLayers/Util.js
+OpenLayers/Ajax.js
 OpenLayers/Console.js
-OpenLayers/BaseTypes.js
-OpenLayers/BaseTypes/Class.js
 OpenLayers/BaseTypes/Size.js
 OpenLayers/BaseTypes/Bounds.js
 OpenLayers/BaseTypes/Element.js
@@ -31,6 +32,12 @@
 OpenLayers/Control/Navigation.js
 OpenLayers/Control/PanZoom.js
 OpenLayers/Control/ArgParser.js
+OpenLayers/Control/DragPan.js
+OpenLayers/Control/MousePosition.js
+OpenLayers/Control/ScaleLine.js
+OpenLayers/Handler/Box.js
+OpenLayers/Handler/Click.js
+OpenLayers/Handler/MouseWheel.js
 OpenLayers/Projection.js
 OpenLayers/Marker.js
 OpenLayers/Icon.js
Modified: sandbox/olcore/jx/lib/jx_combined.css
--- sandbox/olcore/jx/lib/jx_combined.css	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/jx/lib/jx_combined.css	2008-07-22 15:00:30 UTC (rev 1442)
@@ -249,7 +249,7 @@
     height: 20px;
  * @project         Jx
- * @revision        $Id: dialog.css 512 2008-03-07 21:15:45Z pspencer $
+ * @revision        $Id: dialog.css 498 2008-02-15 16:09:17Z fwarnock $
  * @author          Fred Warnock (fwarnock at dmsolutions.ca)
  * @copyright       &copy; 2006 DM Solutions Group Inc.
@@ -702,7 +702,7 @@
  * @project         Jx
- * @revision        $Id: picker.css 516 2008-03-10 23:21:04Z pspencer $
+ * @revision        $Id: picker.css 515 2008-03-10 23:19:15Z pspencer $
@@ -811,7 +811,7 @@
  * @project         Jx
- * @revision        $Id: tabs.css 512 2008-03-07 21:15:45Z pspencer $
+ * @revision        $Id: tabs.css 486 2008-02-13 22:17:45Z fwarnock $
Modified: sandbox/olcore/jx/lib/jx_combined.js
--- sandbox/olcore/jx/lib/jx_combined.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/jx/lib/jx_combined.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -5797,7 +5797,7 @@
     this.event = null;
- * $Id: jxcore.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxcore.js 527 2008-07-02 18:04:01Z pspencer $
  * Title: Jx Core
@@ -5842,15 +5842,17 @@
 /* firebug console supressor for IE/Safari/Opera */
-if (!("console" in window) || !("firebug" in console)) {
-    var names = ["log", "debug", "info", "warn", "error", "assert", "dir", "dirxml",
-    "group", "groupEnd", "time", "timeEnd", "count", "trace", "profile", "profileEnd"];
+Event.observe(window, 'load', function() {
+    if (!("console" in window) || !("firebug" in window.console)) {
+        var names = ["log", "debug", "info", "warn", "error", "assert", "dir", "dirxml",
+        "group", "groupEnd", "time", "timeEnd", "count", "trace", "profile", "profileEnd"];
-    window.console = {};
-    for (var i = 0; i < names.length; ++i) {
-        window.console[names[i]] = function() {};
+        window.console = {};
+        for (var i = 0; i < names.length; ++i) {
+            window.console[names[i]] = function() {};
 /* inspired by extjs, removes css image flicker and related problems in IE 6 */
 var ua = navigator.userAgent.toLowerCase();
 var isIE = ua.indexOf("msie") > -1,
@@ -6784,7 +6786,7 @@
- * $Id: jxbutton.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxbutton.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Button
@@ -7355,7 +7357,7 @@
- * $Id: jxcolor.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxcolor.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Color
@@ -7980,7 +7982,7 @@
- * $Id: jxdialog.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxdialog.js 524 2008-05-07 19:49:03Z madair $
  * Title: Jx.Dialog
@@ -8254,6 +8256,8 @@
                 $(options.parentObj).appendChild(this.blanket);
             } else {
                 document.body.appendChild(this.blanket);
+                var temp = new Jx.Layout(this.blanket);
+                temp.resize();
@@ -8838,7 +8842,7 @@
 Object.extend(Jx.Dialog.prototype, Jx.UniqueId.prototype);
 Object.extend(Jx.Dialog.prototype, Jx.ContentLoader.prototype);/**
- * $Id: jxgrid.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxgrid.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Grid
@@ -9768,7 +9772,7 @@
         return {row:row,column:col};
- * $Id: jxlayout.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxlayout.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Layout
@@ -10235,7 +10239,7 @@
- * $Id: jxmenu.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxmenu.js 508 2008-02-28 20:57:12Z pspencer $
  * Title: Jx.Menu
@@ -10956,7 +10960,7 @@
         Jx.Menu.prototype.show.apply(this, [e]);
- * $Id: jxpanel.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxpanel.js 504 2008-02-21 01:18:50Z pspencer $
  * Title: Jx.Panel
@@ -11395,7 +11399,7 @@
 Object.extend(Jx.Panel.prototype, Jx.UniqueId.prototype);
 Object.extend(Jx.Panel.prototype, Jx.ContentLoader.prototype);/**
- * $Id: jxpicker.js 516 2008-03-10 23:21:04Z pspencer $
+ * $Id: jxpicker.js 515 2008-03-10 23:19:15Z pspencer $
  * Title: Jx.Picker
@@ -11733,7 +11737,7 @@
 Object.extend(Jx.Picker.prototype, Jx.Listener.prototype);/**
- * $Id: jxsplitter.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxsplitter.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Splitter
@@ -12484,7 +12488,7 @@
- * $Id: jxtab.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxtab.js 526 2008-06-24 12:56:56Z pspencer $
  * Title: Jx.Tab
@@ -12744,12 +12748,15 @@
     initialize : function(name, options) {
         this.sl = [];
         options = options || {};
+        if (!options.label) {
+            options.label = name;
         this.name = name;
         this.content = document.createElement('div');
         this.content.className = 'tabContent';
         this.loadContent(this.content, options);
         var a = new Jx.Action(this.clicked.bind(this));
-        var b = new Jx.Button(a, {label: name});
+        var b = new Jx.Button(a, options);
         this.domObj = b.domA;
         // rename the element from jxButton to jxTab
         // Element.removeClassName(this.domObj, 'jxButton');
@@ -12881,7 +12888,7 @@
 Object.extend(Jx.TabBox.prototype, Jx.Listener.prototype);
- * $Id: jxtoolbar.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxtoolbar.js 503 2008-02-18 22:54:09Z pspencer $
  * Title: Jx.Toolbar
@@ -13166,7 +13173,7 @@
- * $Id: jxtree.js 512 2008-03-07 21:15:45Z pspencer $
+ * $Id: jxtree.js 505 2008-02-21 02:32:39Z pspencer $
  * Title: Jx.Tree
Modified: sandbox/olcore/jx/lib/jx_compressed.js
--- sandbox/olcore/jx/lib/jx_compressed.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/jx/lib/jx_compressed.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -399,8 +399,7 @@
 Event.stop(event);}},update:function(event){if(this.active){if(!this.dragging)this.dragging=true;this.draw(event);if(navigator.appVersion.indexOf('AppleWebKit')>0)window.scrollBy(0,0);Event.stop(event);}},draw:function(event){var pointer=[Event.pointerX(event),Event.pointerY(event)];var offsets=Position.cumulativeOffset(this.track);pointer[0]-=this.offsetX+offsets[0];pointer[1]-=this.offsetY+offsets[1];this.event=event;this.setValue(this.translateToValue(this.isVertical()?pointer[1]:pointer[0]));if(this.initialized&&this.options.onSlide)
 this.options.onSlide(this.values.length>1?this.values:this.value,this);},endDrag:function(event){if(this.active&&this.dragging){this.finishDrag(event,true);Event.stop(event);}
 this.active=false;this.dragging=false;},finishDrag:function(event,success){this.active=false;this.dragging=false;this.updateFinished();},updateFinished:function(){if(this.initialized&&this.options.onChange)
-this.options.onChange(this.values.length>1?this.values:this.value,this);this.event=null;}};if(!("console"in window)||!("firebug"in console)){var names=["log","debug","info","warn","error","assert","dir","dirxml","group","groupEnd","time","timeEnd","count","trace","profile","profileEnd"];window.console={};for(var i=0;i<names.length;++i){window.console[names[i]]=function(){};}}
-var ua=navigator.userAgent.toLowerCase();var isIE=ua.indexOf("msie")>-1,isIE7=ua.indexOf("msie 7")>-1;if(isIE&&!isIE7){try{document.execCommand("BackgroundImageCache",false,true);}catch(e){}}
+this.options.onChange(this.values.length>1?this.values:this.value,this);this.event=null;}};Event.observe(window,'load',function(){if(!("console"in window)||!("firebug"in window.console)){var names=["log","debug","info","warn","error","assert","dir","dirxml","group","groupEnd","time","timeEnd","count","trace","profile","profileEnd"];window.console={};for(var i=0;i<names.length;++i){window.console[names[i]]=function(){};}}});var ua=navigator.userAgent.toLowerCase();var isIE=ua.indexOf("msie")>-1,isIE7=ua.indexOf("msie 7")>-1;if(isIE&&!isIE7){try{document.execCommand("BackgroundImageCache",false,true);}catch(e){}}
 if(typeof Jx=='undefined'){var Jx={};Jx.COMBINED_CSS=true;var aScripts=document.getElementsByTagName('SCRIPT');for(var i=0;i<aScripts.length;i++){var s=aScripts[i].src;var n=s.indexOf('lib/jx');if(n!=-1){Jx.baseURL=s.substring(0,n);break;}}}
 Jx.importRules={};Jx.importRulesIE={};Jx.addStyleSheet=function(styleSheet,ieOnly){if(ieOnly){this.importRulesIE[styleSheet]=styleSheet;}else{this.importRules[styleSheet]=styleSheet;}};Jx.addStyleSheet('reset.css');Jx.applyPNGFilter=function(o){var t=Jx.baseURL+"images/a_pixel.png";if(o.src!=t){var s=o.src;o.src=t;o.runtimeStyle.filter="progid:DXImageTransform.Microsoft.AlphaImageLoader(src='"+s+"',sizingMethod='scale')";}};Jx.imgQueue=[];Jx.imgLoaded={};Jx.imagesLoading=0;Jx.addToImgQueue=function(obj){if(Jx.imgLoaded[obj.src]){obj.domElement.src=obj.src;}else{Jx.imgQueue.push(obj);Jx.imgLoaded[obj.src]=true;}
 Jx.checkImgQueue();};Jx.checkImgQueue=function(){while(Jx.imagesLoading<2&&Jx.imgQueue.length>0){Jx.loadNextImg();}};Jx.loadNextImg=function(){var obj=Jx.imgQueue.shift();if(obj){++Jx.imagesLoading;obj.domElement.onload=function(){--Jx.imagesLoading;Jx.checkImgQueue();};obj.domElement.onerror=function(){--Jx.imagesLoading;Jx.checkImgQueue();};obj.domElement.src=obj.src;}};Jx.Listener=Class.create();Jx.Listener.prototype={addListener:function(list,obj){list.push(obj);},removeListener:function(list,obj){for(var i=0;i<list.length;i++){if(list[i]==obj){list.splice(i,1);break;}}},processEvent:function(list,fnName,obj){list.each(function(o){if(o[fnName]){o[fnName](obj);}});}};Jx.UniqueId=Class.create();Jx.UniqueId.prototype={uniqueIdRefs:null,initUniqueId:function(){this.uniqueIdRefs=[];},deregisterIds:function(){this.uniqueIdRefs.length=0;},registerIds:function(aIds,domObj){if(aIds.indexOf(domObj.id)!=-1){this.uniqueIdRefs[domObj.id]=domObj;}
@@ -444,7 +443,7 @@
 if(options.onOpen){this.onOpen=options.onOpen;}
 if(options.onContentLoaded){this.onContentLoaded=options.onContentLoaded;}
 this.imageBaseUrl=options.imageBaseUrl||Jx.baseURL+"/images/";if(this.imageBaseUrl.slice(-1)!='/'){this.imageBaseUrl+='/';}
-this.modal=typeof options.modal=='undefined'?true:options.modal;var w=options.width||250;var h=options.height||250;var b=(typeof options.bottom!='undefined')?options.bottom:null;var r=(typeof options.right!='undefined')?options.right:null;var t=(typeof options.top!='undefined')?options.top:(b!=null?null:0);var l=(typeof options.left!='undefined')?options.left:(r!=null?null:0);this.blanket=document.createElement('div');this.blanket.className='jxDialogModal';this.blanket.style.display='none';if(!window.opera&&this.modal){var iframe=document.createElement('iframe');iframe.className='jxDialogShim';iframe.scrolling='no';iframe.frameborder=0;this.blanket.appendChild(iframe);if(options.parentObj){$(options.parentObj).appendChild(this.blanket);}else{document.body.appendChild(this.blanket);}}
+this.modal=typeof options.modal=='undefined'?true:options.modal;var w=options.width||250;var h=options.height||250;var b=(typeof options.bottom!='undefined')?options.bottom:null;var r=(typeof options.right!='undefined')?options.right:null;var t=(typeof options.top!='undefined')?options.top:(b!=null?null:0);var l=(typeof options.left!='undefined')?options.left:(r!=null?null:0);this.blanket=document.createElement('div');this.blanket.className='jxDialogModal';this.blanket.style.display='none';if(!window.opera&&this.modal){var iframe=document.createElement('iframe');iframe.className='jxDialogShim';iframe.scrolling='no';iframe.frameborder=0;this.blanket.appendChild(iframe);if(options.parentObj){$(options.parentObj).appendChild(this.blanket);}else{document.body.appendChild(this.blanket);var temp=new Jx.Layout(this.blanket);temp.resize();}}
 this.dragHandle=document.createElement('div');this.dragHandle.innerHTML=options.title||'&nbsp;';this.dragHandle.style.width='100%';var domObj=document.createElement('div');domObj.className='jxDialogContainer';this.domObj=domObj;if(options.id){domObj.id=options.id;}
 var dialogObj=document.createElement('div');dialogObj.className='jxDialog';this.innerDialogObj=dialogObj;var titleObj=document.createElement('div');titleObj.className='jxDialogTitle';this.title=titleObj;titleObj.appendChild(this.dragHandle);titleObj.style.visibility='hidden';document.getElementsByTagName('BODY')[0].appendChild(titleObj);this.titleHeight=Element.getBorderBoxSize(titleObj).height;document.getElementsByTagName('BODY')[0].removeChild(titleObj);titleObj.style.visibility='';var contentObj=document.createElement('div');contentObj.className='jxDialogContent';this.content=contentObj;domObj.appendChild(dialogObj);dialogObj.appendChild(titleObj);dialogObj.appendChild(contentObj);new Jx.Layout(dialogObj,{width:w,height:h});new Jx.Layout(titleObj,{top:0,left:0,right:0,bottom:null,height:this.titleHeight,width:null});this.actionHeight=0;if(options.buttons){var actionObj=document.createElement('div');actionObj.className='jxDialogAction';actionObj.style.visibility='hidden';document.getElementsByTagName('BODY')[0].appendChild(actionObj);this.actionHeight=parseInt(Element.getStyle(actionObj,'height'));document.getElementsByTagName('BODY')[0].removeChild(actionObj);actionObj.style.visibility='';dialogObj.appendChild(actionObj);new Jx.Layout(actionObj,{top:null,left:0,right:0,bottom:0,height:this.actionHeight,width:null});this.action=actionObj;this.setButtons(options.buttons);}
 new Jx.Layout(contentObj,{top:this.titleHeight,left:0,right:0,bottom:this.actionHeight});var atag=document.createElement('a');atag.href='javascript:void(0)';atag.className='jxDialogCloseButton';atag.onclick=this.close.bindAsEventListener(this);var close=document.createElement('img');if(options.closeImg){close.src=options.closeImg;}
@@ -603,7 +602,8 @@
 this.element.jxLayout.resize(newSize);this.splitter.sizeChanged();},sizeChanged:function(){var size=Element.getBorderBoxSize(this.element);if(this.layout=='vertical'){if(size.height==this.minimumSize){Element.addClassName(this.snapper,'jxSnapClosed');Element.removeClassName(this.snapper,'jxSnapOpened');}else{Element.addClassName(this.snapper,'jxSnapOpened');Element.removeClassName(this.snapper,'jxSnapClosed');}}else{if(size.width==this.minimumSize){Element.addClassName(this.snapper,'jxSnapClosed');Element.removeClassName(this.snapper,'jxSnapOpened');}else{Element.addClassName(this.snapper,'jxSnapOpened');Element.removeClassName(this.snapper,'jxSnapClosed');}}}};Jx.addStyleSheet('tab/tabs.css');Jx.addStyleSheet('tabs/tabs_ie.css',true);Jx.TabSet=Class.create();Jx.TabSet.prototype={domObj:null,sl:null,initialize:function(domObj){this.domObj=$(domObj);if(!Element.hasClassName(this.domObj,'jxTabSetContainer')){Element.addClassName(this.domObj,'jxTabSetContainer');}
 this.sl=[];},sizeChanged:function(){this.resizeTabBox();},resizeTabBox:function(){var parentSize=Element.getContentBoxSize(this.domObj.parentNode);Element.setBorderBoxSize(this.domObj,{width:parentSize.width,height:parentSize.height});for(var i=0;i<this.domObj.childNodes.length;i++){if(this.domObj.childNodes[i].nodeType==3){continue;}
 Element.setBorderBoxSize(this.domObj.childNodes[i],{height:parentSize.height});if(this.domObj.childNodes[i].resize){this.domObj.childNodes[i].resize({forceResize:true});}}},add:function(){for(var i=0;i<arguments.length;i++){var tab=arguments[i];tab.addSelectionListener(this);this.domObj.appendChild(tab.content);if(!this.activeTab){this.setActiveTab(tab);}}},remove:function(tab){},setActiveTab:function(tab){if(this.activeTab){Element.removeClassName(this.activeTab.domObj,'tabActive');Element.removeClassName(this.activeTab.content,'tabContentActive');}
-this.activeTab=tab;Element.addClassName(this.activeTab.domObj,'tabActive');Element.addClassName(this.activeTab.content,'tabContentActive');if(this.activeTab.content.resize){this.activeTab.content.resize({forceResize:true});}},selectionChanged:function(tab){this.setActiveTab(tab);this.processEvent(this.sl,'selectionChanged',tab);},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.TabSet.prototype,Jx.Listener.prototype);Jx.Tab=Class.create();Jx.Tab.prototype={domObj:null,content:null,name:null,sl:null,initialize:function(name,options){this.sl=[];options=options||{};this.name=name;this.content=document.createElement('div');this.content.className='tabContent';this.loadContent(this.content,options);var a=new Jx.Action(this.clicked.bind(this));var b=new Jx.Button(a,{label:name});this.domObj=b.domA;Element.addClassName(this.domObj,'jxTab');new Jx.Layout(this.content,options);},clicked:function(){this.processEvent(this.sl,'selectionChanged',this);this.domObj.childNodes[0].blur();},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.Tab.prototype,Jx.Listener.prototype);Object.extend(Jx.Tab.prototype,Jx.ContentLoader.prototype);Jx.TabBox=Class.create();Jx.TabBox.prototype={tabBar:null,tabSet:null,initialize:function(domObj,position){var parent=$(domObj);position=position||'top';var tabBarDiv=document.createElement('div');parent.appendChild(tabBarDiv);this.tabBar=new Jx.Toolbar(tabBarDiv,position);this.tabSet=new Jx.TabSet(parent);switch(position){case'top':Element.addClassName(parent,'jxTabBoxTop');break;case'bottom':Element.addClassName(parent,'jxTabBoxBottom');break;case'left':Element.addClassName(parent,'jxTabBoxLeft');Element.addClassName(tabBarDiv,'verticalToolbar');break;case'right':Element.addClassName(parent,'jxTabBoxRight');Element.addClassName(tabBarDiv,'verticalToolbar');break;}
+this.activeTab=tab;Element.addClassName(this.activeTab.domObj,'tabActive');Element.addClassName(this.activeTab.content,'tabContentActive');if(this.activeTab.content.resize){this.activeTab.content.resize({forceResize:true});}},selectionChanged:function(tab){this.setActiveTab(tab);this.processEvent(this.sl,'selectionChanged',tab);},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.TabSet.prototype,Jx.Listener.prototype);Jx.Tab=Class.create();Jx.Tab.prototype={domObj:null,content:null,name:null,sl:null,initialize:function(name,options){this.sl=[];options=options||{};if(!options.label){options.label=name;}
+this.name=name;this.content=document.createElement('div');this.content.className='tabContent';this.loadContent(this.content,options);var a=new Jx.Action(this.clicked.bind(this));var b=new Jx.Button(a,options);this.domObj=b.domA;Element.addClassName(this.domObj,'jxTab');new Jx.Layout(this.content,options);},clicked:function(){this.processEvent(this.sl,'selectionChanged',this);this.domObj.childNodes[0].blur();},addSelectionListener:function(obj){this.addListener(this.sl,obj);},removeSelectionListener:function(obj){this.removeListener(this.sl,obj);}};Object.extend(Jx.Tab.prototype,Jx.Listener.prototype);Object.extend(Jx.Tab.prototype,Jx.ContentLoader.prototype);Jx.TabBox=Class.create();Jx.TabBox.prototype={tabBar:null,tabSet:null,initialize:function(domObj,position){var parent=$(domObj);position=position||'top';var tabBarDiv=document.createElement('div');parent.appendChild(tabBarDiv);this.tabBar=new Jx.Toolbar(tabBarDiv,position);this.tabSet=new Jx.TabSet(parent);switch(position){case'top':Element.addClassName(parent,'jxTabBoxTop');break;case'bottom':Element.addClassName(parent,'jxTabBoxBottom');break;case'left':Element.addClassName(parent,'jxTabBoxLeft');Element.addClassName(tabBarDiv,'verticalToolbar');break;case'right':Element.addClassName(parent,'jxTabBoxRight');Element.addClassName(tabBarDiv,'verticalToolbar');break;}
 this.sl=[];},sizeChanged:function(){this.tabSet.sizeChanged();},add:function(){this.tabBar.add.apply(this.tabBar,arguments);this.tabSet.add.apply(this.tabSet,arguments);},remove:function(tab){}};Object.extend(Jx.TabBox.prototype,Jx.Listener.prototype);Jx.addStyleSheet('toolbar/toolbar.css');Jx.addStyleSheet('button/button.css');Jx.Toolbar=Class.create();Jx.Toolbar.prototype={items:null,domObj:null,isActive:false,initialize:function(domObj,position){var parent=$(domObj);this.domObj=document.createElement('ul');Element.addClassName(this.domObj,'jxToolbar');if(!Element.hasClassName(parent,'jxToolbarContainer')){Element.addClassName(parent,'jxToolbarContainer');parent.appendChild(this.domObj);var clearer=document.createElement('div');clearer.className='jxClearer';parent.appendChild(clearer);}else{parent.insertBefore(this.domObj,parent.lastChild);}
 switch(position){case'top':Element.addClassName(parent,'jxBarTop');break;case'right':Element.addClassName(parent,'jxBarRight');break;case'bottom':Element.addClassName(parent,'jxBarBottom');break;case'left':Element.addClassName(parent,'jxBarLeft');break;default:Element.addClassName(parent,'jxBarTop');}
 this.deactivateWatcher=this.deactivate.bindAsEventListener(this);},add:function(){for(var i=0;i<arguments.length;i++){var thing=arguments[i];thing.toolbar=this;if(thing.domObj){thing=thing.domObj;}
Modified: sandbox/olcore/layers/Layers.js
--- sandbox/olcore/layers/Layers.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/Layers.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -32,9 +32,8 @@
 Fusion.Event.MAP_LAYER_TOGGLED = Fusion.Event.lastEventId++;
 Fusion.Layers = OpenLayers.Class(Fusion.Lib.EventMgr, {
-    session: null,
     bSingleTile: null,
-    bIsBaseLayer: true,     //TODO: set this in AppDef?
+    bIsBaseLayer: false,     //TODO: set this in AppDef?
     sActiveLayer: null,
     selectionType: 'INTERSECTS',
     bSelectionOn: false,
@@ -65,6 +64,7 @@
         this.bSingleTile = mapTag.singleTile; //this is set in thhe AppDef.Map class
+        this.bIsBaseLayer = mapTag.isBaseLayer; //this is set in thhe AppDef.Map class
         this.extension = mapTag.extension;
         this.selectionType = this.extension.SelectionType ? this.extension.SelectionType[0] : 'INTERSECTS';
@@ -83,9 +83,8 @@
         this.layerRoot = new Fusion.Layers.Group(rootOpts,this);
-        var sid = Fusion.sessionId;
-        if (sid) {
-            this.session = sid;
+        if (mapTag.sid) {
+            this.session[0] = mapTag.sid;
             this.mapSessionCreated();
         } else {
             this.createSession();
@@ -93,7 +92,22 @@
     createSession: function() {
-        if (!this.session) {
+        if (!this.session[0]) {
+            this.session[0] = this;
+            var sl = Fusion.getScriptLanguage();
+            var scriptURL = 'layers/' + this.arch + '/' + sl + '/CreateSession.' + sl;
+            var options = {onComplete: this.createSessionCB.bind(this)};
+            Fusion.ajaxRequest(scriptURL,options);
+        if (this.session[0].arch) {
+            this.session[0].registerForEvent(Fusion.Event.MAP_SESSION_CREATED, this.mapSessionCreated.bind(this));
+        } else {
+            this.mapSessionCreated();
+    xxxcreateSession: function() {
+        if (!this.sessionReady() ) {
             this.registerForEvent(Fusion.Event.MAP_SESSION_CREATED,
                 OpenLayers.Function.bind(this.mapSessionCreated, this));
@@ -109,24 +123,25 @@
         if (xhr.status == 200) {
             var o;
             eval('o='+xhr.responseText);
-            this.session = o.sessionId;
+            this.session[0] = o.sessionId;
             this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
+            window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
     mapSessionCreated: function() {
         if (this.sMapResourceId != '') {
+            //window.setTimeout(OpenLayers.Function.bind(this.loadMap, this, this.sMapResourceId), 1);
             this.loadMap(this.sMapResourceId);
-        window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
     sessionReady: function() {
-        return (typeof this.session == 'string');
+        return (typeof this.session[0] == 'string');
     getSessionID: function() {
-        return this.session;
+        return this.session[0];
     getMapName: function() {
@@ -218,10 +233,10 @@
             //set projection units and code if supplied
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
-            //this.units = 'degrees';
-            //this.projection = this.WKT[o.projectionWKT];
-            this.units = 'm';
-            this.projection = 'EPSG:42304';
+            this.units = 'degrees';
+            this.projection = 'EPSG:4326';//this.WKT[o.projectionWKT];
+            //this.units = 'm';
+            //this.projection = 'EPSG:42304';
             //add in scales array if supplied
             if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
@@ -231,12 +246,12 @@
             var layerOptions = {
               units : this.units,
               projection: this.projection,
-              isBaseLayer : this.bIsBaseLayer,
               singleTile : this.bSingleTile,
               maxExtent : this._oMaxExtent,
               maxResolution : 'auto',
               ratio : this.ratio,
-              transitionEffect : 'resize'
+              //transitionEffect : 'resize'
+              temp: null
@@ -257,6 +272,7 @@
             this.oLayerOL = this.createOLLayer(this._sMapname, layerOptions);
+            this.oLayerOL.setVisibility(true);
             this.oLayerOL.events.register("loadstart", this, this.loadStart);
             this.oLayerOL.events.register("loadend", this, this.loadEnd);
             this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
@@ -264,9 +280,11 @@
             //this is to distinguish between a regular map and an overview map
             if (this.bIsMapWidgetLayer) {
               this.mapWidget.addMap(this);
-              this.mapWidget.oMapOL.setBaseLayer(this.oLayerOL);
-              this.mapWidget._oInitialExtents = null;
-              this.mapWidget.fullExtents();
+              if (this.mapWidget.oMapOL.baseLayer == this.oLayerOL) {
+                  //this.mapWidget.oMapOL.setBaseLayer(this.oLayerOL);
+                  //this.mapWidget._oInitialExtents = null;
+                  //this.mapWidget.fullExtents();
             this.triggerEvent(Fusion.Event.MAP_LOADED);
         } else {
@@ -387,13 +405,13 @@
-    groupToggle: function(eventId, layer, visible) {
-        this.processLayerEvents(layer, visible);
+    groupToggle: function(eventId, group, visible) {
+        this.processGroupEvents(group, visible);
         this.drawMap();
     layerToggle: function(eventId, layer, visible) {
-        this.processGroupEvents(layer, visible);
+        this.processLayerEvents(layer, visible);
         this.drawMap();
Modified: sandbox/olcore/layers/MapGuide/MapGuide.js
--- sandbox/olcore/layers/MapGuide/MapGuide.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/MapGuide.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -31,8 +31,14 @@
 Fusion.Layers.MapGuide = OpenLayers.Class(Fusion.Layers, {
     //the resource id of the current MapDefinition
+    session: [null],
     _sResourceId: null,
     arch: 'MapGuide',
+    aShowLayers: null,
+    aHideLayers: null,
+    aShowGroups: null,
+    aHideGroups: null,
+    aRefreshLayers: null,
     WKT: {                    //lookup table of MGOS WKT to EPSG codes
       "GEOGCS[\"WGS84 Lat/Long's, Degrees, -180 ==> +180\",DATUM[\"D_WGS_1984\",SPHEROID[\"World_Geodetic_System_of_1984\",6378137,298.257222932867]],PRIMEM[\"Greenwich\",0],UNIT[\"Degree\",0.017453292519943295]]": 'WGS84'    //used in Sheboygan example
@@ -42,6 +48,13 @@
         // console.log('MapGuide.initialize');
         Fusion.Layers.prototype.initialize.apply(this, arguments);
+        var options = mapTag.extension;
+        this.aShowLayers = options.showlayers || [];
+        this.aHideLayers = options.hidelayers || [];
+        this.aShowGroups = options.showgroups || [];
+        this.aHideGroups = options.hidegroups || [];
+        this.aRefreshLayers = options.refreshlayers || [];
         this.mapInfo = mapTag.mapInfo;
         //add in the handler for CTRL-click actions for the map, not an overviewmap
@@ -64,7 +77,23 @@
-    loadMapParams: function() {
+    getMapParams: function() {
+        var params;
+        if (this.getMapName()) {
+            params = {
+                'mapname': this.getMapName(),
+                'session': this.getSessionID()
+        } else {
+            params = {
+                'mapid': this.sMapResourceId,
+        return params;
+    xxxloadMapParams: function() {
         return {'mapid': this.sMapResourceId, "session": this.getSessionID()};
@@ -73,7 +102,7 @@
         return {'mapname': this._sMapname, 'session': this.getSessionID()};
-    reorderLayersParams: function(aLayerIndex) {
+    xxxreorderLayersParams: function(aLayerIndex) {
         return {
             'session': this.getSessionID(),
@@ -81,7 +110,7 @@
-    mapLayersReset: function(aLayerIndex,r) {
+    xxxxmapLayersReset: function(aLayerIndex,r) {
       if (r.status == 200) {
         var o;
         eval('o='+r.responseText);
@@ -109,30 +138,9 @@
      * Returns an OpenLayers MapGuide layer object
-    createOLLayer: function(layerName, projCode, bIsBaseLayer, bSingleTile, bFractionalZoom) {
-      var layerOptions = {
-        units : this.units,
-        projection: projCode,
-        isBaseLayer : bIsBaseLayer,
-        maxExtent : this._oMaxExtent,
-        maxResolution : 'auto',
-        ratio : this.ratio,
-      //add in scales array if supplied
-      if (this.scales && this.scales.length>0) {
-        layerOptions.scales = this.scales;
-      if (this.maxScale != Infinity) {
-        layerOptions.minScale = this.maxScale;    //OL interpretation of min/max scale is reversed from Fusion
-      layerOptions.maxScale = this.minScale;
-      layerOptions.singleTile = bSingleTile;
+    createOLLayer: function(layerName, layerOptions) {
       var params = {};
-      if ( bSingleTile ) {
+      if ( layerOptions.singleTile ) {
         params = {        //single tile params
           session : this.getSessionID(),
           mapName : this._sMapname
@@ -142,9 +150,6 @@
         params.showGroups = this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null;
         params.hideGroups = this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null;
         params.refreshLayers = this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null;
-        if (bIsBaseLayer) {
-          this.mapWidget.oMapOL.setOptions({'fractionalZoom':true});
       } else {
         params = {      //tiled version
@@ -157,8 +162,35 @@
       var oLayerOL = new OpenLayers.Layer.MapGuide( layerName, url, params, layerOptions );
       return oLayerOL;
-    setSelection: function (selText, zoomTo) {
+    drawMap: function() {
+        if (!this.bMapLoaded) {
+            return;
+        var newParams = {
+          showLayers : this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null,
+          hideLayers : this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null,
+          showGroups : this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null,
+          hideGroups : this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null,
+          refreshLayers : this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null
+        this.aShowLayers = [];
+        this.aHideLayers = [];
+        this.aShowGroups = [];
+        this.aHideGroups = [];
+        this.aRefreshLayers = [];
+        this.oLayerOL.mergeNewParams(newParams);
+        this.oLayerOL.params.showLayers = null;
+        this.oLayerOL.params.hideLayers = null;
+        this.oLayerOL.params.showGroups = null;
+        this.oLayerOL.params.hideGroups = null;
+        this.oLayerOL.params.refreshLayers = null;
+        if (this.queryLayer) this.queryLayer.redraw();
+    xxxsetSelection: function (selText, zoomTo) {
       this.mapWidget._addWorker();
       var setSelectionScript = this.arch + '/' + sl  + '/SetSelection.' + sl;
@@ -194,7 +226,7 @@
      *         six elements for layer 2 starting at index 6). If it is not
      *        given, all the elemsnts will be returned.
-    getSelection : function(userFunc, layers, startcount) {
+    xxxxgetSelection : function(userFunc, layers, startcount) {
       /*for now always go back to server to fetch selection */
@@ -220,7 +252,7 @@
        Call back function when selection is cleared
-    selectionCleared : function()
+    xxxxselectionCleared : function()
         //clear the selection count for the layers
         for (var j=0; j<this.aLayers.length; ++j) {
@@ -239,7 +271,7 @@
        Utility function to clear current selection
-    clearSelection : function() {
+    xxxxclearSelection : function() {
       if (this.hasSelection()) {
           var s = this.arch + '/' + Fusion.getScriptLanguage() + "/ClearSelection." + Fusion.getScriptLanguage() ;
           var options = {
@@ -254,7 +286,7 @@
        removes the queryLayer from the map
-    removeQueryLayer : function() {
+    xxxremoveQueryLayer : function() {
       if (this.queryLayer) {
         this.queryLayer.destroy();
         this.queryLayer = null;
@@ -265,7 +297,7 @@
        Call back function when slect functions are called (eg queryRect)
-    processQueryResults : function(zoomTo, r) {
+    xxxprocessQueryResults : function(zoomTo, r) {
         this.mapWidget._removeWorker();
         if (r.responseText) {   //TODO: make the equivalent change to MapServer.js
             var oNode;
@@ -309,7 +341,7 @@
        Do a query on the map
-    query : function(options) {
+    xxxquery : function(options) {
@@ -345,7 +377,7 @@
         Fusion.ajaxRequest(loadmapScript, ajaxOptions);
-    processLayerEvents: function(layer, isEnabling) {
+    xxxxprocessLayerEvents: function(layer, isEnabling) {
         if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
             var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
             var events = isEnabling ? layerEvent.onEnable : layerEvent.onDisable;
@@ -375,7 +407,7 @@
-    processGroupEvents: function(group, isEnabling) {
+    xxxxprocessGroupEvents: function(group, isEnabling) {
         if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
             var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
             var events = isEnabling ? groupEvent.onEnable : groupEvent.onDisable;
@@ -405,15 +437,27 @@
-    showLayer: function( layer, noDraw ) {
-        this.processLayerEvents(layer, true);
-        this.aShowLayers.push(layer.uniqueId);
-        if (!noDraw) {
-            this.drawMap();
+        if (visible) {
+            this.aShowGroups.push(group.uniqueId);
+        } else {
+            this.aHideGroups.push(group.uniqueId);
+        this.drawMap();
-    hideLayer: function( layer, noDraw ) {
+    layerToggle: function( eventId, layer, visible) {
+        if (visible) {
+            this.aShowLayers.push(layer.uniqueId);
+        } else {
+            this.aHideLayers.push(layer.uniqueId);
+        this.drawMap();
+    xxxhideLayer: function( layer, noDraw ) {
         this.processLayerEvents(layer, false);
         if (!noDraw) {
@@ -421,7 +465,7 @@
-    showGroup: function( group, noDraw ) {
+    xxxshowGroup: function( group, noDraw ) {
         this.processGroupEvents(group, true);
         if (group.groupName == 'layerRoot') {
@@ -432,7 +476,7 @@
-    hideGroup: function( group, noDraw ) {
+    xxxhideGroup: function( group, noDraw ) {
         this.processGroupEvents(group, false);
             this.oLayerOL.setVisibility(false);
@@ -443,7 +487,7 @@
-    refreshLayer: function( layer ) {
+    xxxrefreshLayer: function( layer ) {
         this.aRefreshLayers.push(layer.uniqueId);
         this.drawMap();
@@ -453,11 +497,11 @@
-    loadStart: function() {
+    xxxloadStart: function() {
-    loadEnd: function() {
+    xxxloadEnd: function() {
@@ -500,14 +544,14 @@
             var o;
-            var h = o['FeatureInformation']['Hyperlink'][0];
-            if (h != '') {
-                window.open(h, "");
+            var h = o['FeatureInformation']['Hyperlink'];
+            if (h) {
+                window.open(h[0], "");
-    pingServer: function() {
+    xxxpingServer: function() {
         var s = 'maps/' + this.arch + '/' + Fusion.getScriptLanguage() + "/Common." + Fusion.getScriptLanguage() ;
         var params = {};
         params.parameters = {'session': this.getSessionID()};
@@ -534,205 +578,9 @@
         return null;
-* Class: Fusion.Layers.MapGuide.Group
-* Implements the map layer groups for MapGuide services
-Fusion.Layers.MapGuide.Group = OpenLayers.Class(Fusion.Widget.Map.Group, {
-    oMap: null,
-    initialize: function(o, oMap) {
-        this.uniqueId = o.uniqueId;
-        Fusion.Widget.Map.Group.prototype.initialize.apply(this, [o.groupName]);
-        this.oMap = oMap;
-        this.groupName = o.groupName;
-        this.legendLabel = o.legendLabel;
-        this.parentUniqueId = o.parentUniqueId;
-        this.groupType = o.groupType;
-        this.displayInLegend = o.displayInLegend;
-        this.expandInLegend = o.expandInLegend;
-        this.visible = o.visible;
-        this.actuallyVisible = o.actuallyVisible;
-    show: function(noDraw) {
-        if (this.visible) {
-            return;
-        this.oMap.showGroup(this, noDraw ? true : false);
-        this.visible = true;
-        if (this.legend && this.legend.checkBox) {
-            this.legend.checkBox.checked = true;
-    hide: function(noDraw) {
-        if (!this.visible) {
-            return;
-        this.oMap.hideGroup(this, noDraw ? true : false);
-        this.visible = false;
-            this.legend.checkBox.checked = false;
-    isVisible: function() {
-        return this.visible;
-* Implements individual map legend layers for MapGuide services
-Fusion.Layers.MapGuide.Layer = OpenLayers.Class(Fusion.Widget.Map.Layer, {
-    scaleRanges: null,
-    oMap: null,
-        Fusion.Widget.Map.Layer.prototype.initialize.apply(this, [o.layerName]);
-        this.oMap = oMap;
-        this.layerName = o.layerName;
-        this.resourceId = o.resourceId;
-        this.selectable = o.selectable;
-        this.selectedFeatureCount = 0;
-        this.layerTypes = [].concat(o.layerTypes);
-        this.editable = o.editable;
-        //determine the layer type so that the correct icon can be displayed in the legend
-        this.layerType = null;
-        if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) {   //raster layers
-          this.layerType = Fusion.Constant.LAYER_RASTER_TYPE;
-        } else if (this.supportsType(Fusion.Constant.LAYER_DWF_TYPE)) {  //DWF layers
-          this.layerType = Fusion.Constant.LAYER_DWF_TYPE;
-        this.parentGroup = o.parentGroup;
-        this.scaleRanges = [];
-        this.minScale = 1.0e10;
-        this.maxScale = 0;
-        for (var i=0; i<o.scaleRanges.length; i++) {
-          var scaleRange = new Fusion.Layers.MapGuide.ScaleRange(o.scaleRanges[i],
-                                this.layerType);
-          this.scaleRanges.push(scaleRange);
-          this.minScale = Math.min(this.minScale, scaleRange.minScale);
-          this.maxScale = Math.max(this.maxScale, scaleRange.maxScale);
-    supportsType: function(type) {
-        for (var i=0; i<this.layerTypes.length; i++) {
-            if (this.layerTypes[i] == type) {
-                return true;
-        return false;
-    getScaleRange: function(fScale) {
-        for (var i=0; i<this.scaleRanges.length; i++) {
-            if (this.scaleRanges[i].contains(fScale)) {
-                return this.scaleRanges[i];
-        return null;
-            return;
-        this.oMap.showLayer(this, noDraw ? true : false);
-        this.set('visible', true);
-            return;
-        this.oMap.hideLayer(this, noDraw ? true : false);
-        this.set('visible',false);
-* Implements a scale range object for MapGuide services
-Fusion.Layers.MapGuide.ScaleRange = OpenLayers.Class({
-    styles: null,
-    initialize: function(o, layerType) {
-        this.minScale = o.minScale;
-        this.maxScale = o.maxScale;
-        if (this.maxScale == 'infinity') {
-          this.maxScale = Infinity;
-        this.styles = [];
-        if (!o.styles) {
-          var styleItem = new Fusion.Layers.MapGuide.StyleItem({legendLabel:'DWF'}, layerType);
-          this.styles.push(styleItem);
-          return;
-        var staticIcon = o.styles.length>1 ? false : layerType;
-        for (var i=0; i<o.styles.length; i++) {
-            var styleItem = new Fusion.Layers.MapGuide.StyleItem(o.styles[i], staticIcon);
-    contains: function(fScale) {
-        return fScale >= this.minScale && fScale <= this.maxScale;
-* Implements the legend style items to get a legend icon from the server
-Fusion.Layers.MapGuide.StyleItem = OpenLayers.Class({
-    initialize: function(o, staticIcon) {
-        this.filter = o.filter;
-        this.geometryType = o.geometryType;
-        if (this.geometryType == '') {
-            this.geometryType = -1;
-        this.categoryIndex = o.categoryIndex;
-        if (this.categoryindex == '') {
-            this.categoryindex = -1;
-        this.staticIcon = staticIcon;
-    getLegendImageURL: function(fScale, layer) {
+    getLegendImageURL: function(fScale, layer, style) {
         var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
-        return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType;
+        return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + style.categoryIndex + "&TYPE=" + style.geometryType;
Modified: sandbox/olcore/layers/MapGuide/php/Buffer.php
--- sandbox/olcore/layers/MapGuide/php/Buffer.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/Buffer.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -158,12 +158,10 @@
             $layerSrsWkt = $spatialContext->GetCoordinateSystemWkt();
             /* skip this layer if the srs is empty */
             if($layerSrsWkt == "") {
-                $excludedLayers ++;
                 continue;
         } else {
             /* skip this layer if there is no spatial context at all */
             continue;
@@ -182,7 +180,6 @@
         if(($arbitraryDsSrs != $arbitraryMapSrs) || ($arbitraryDsSrs && ($dsSrsUnits != $mapSrsUnits)))
             continue;
@@ -191,15 +188,19 @@
         $dist = $layerCs->ConvertMetersToCoordinateSystemUnits($distance);
         // calculate great circle unless data source srs is arbitrary
+        $verMajor = subStr(GetSiteVersion(), 0,1);
         if(!$arbitraryDsSrs) {
-            $measure = new MgCoordinateSystemMeasure($layerCs);
+            if ($verMajor == '1') {
+              $measure = new MgCoordinateSystemMeasure($layerCs);
+            } else {
+              $measure = $layerCs->GetMeasure();
         } else {
             $measure = null;
         // create a SRS transformer if necessary.
         if($layerSrsWkt != $srsDefMap) {
-            $verMajor = subStr(GetSiteVersion(), 0,1);
               $srsXform = new MgCoordinateSystemTransform($layerCs, $srsMap);
             } else {
Modified: sandbox/olcore/layers/MapGuide/php/Common.php
--- sandbox/olcore/layers/MapGuide/php/Common.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/Common.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -74,6 +74,8 @@
         $username = isset($_REQUEST['username']) ? $_REQUEST['username'] : 'Anonymous';
         $password = isset($_REQUEST['password']) ? $_REQUEST['password'] : '';
         $user = new MgUserInformation($username, $password);
+        $user->SetClientIp(GetClientIp());
+        $user->SetClientAgent(GetClientAgent());
         $siteConnection = new MgSiteConnection();
         $siteConnection->Open($user);
     } else {
@@ -90,9 +92,13 @@
         /* current user is re-authenticating or not? */
         if (isset($_REQUEST['username']) && isset($_REQUEST['password'])) {
             $user = new MgUserInformation($_REQUEST['username'], $_REQUEST['password']);
             $user->SetMgSessionId($sessionID);
         } else {
             $user = new MgUserInformation($sessionID);
         /* open a connection to the site.  This will generate exceptions if the user
@@ -118,7 +124,6 @@
     echo "</Exception>";
     exit;
 } catch (MgUserNotFoundException $unfe) {
-    header("HTTP/1.0 500 Internal Server Error");
     header('Content-type: text/xml');
     echo "<Exception>";
     echo "<Type>User Not Found</Type>";
@@ -256,5 +261,29 @@
     return $numberString;
+function GetClientIp()
+    $clientIp = '';
+    if (array_key_exists('HTTP_CLIENT_IP', $_SERVER)
+        && strcasecmp($_SERVER['HTTP_CLIENT_IP'], 'unknown') != 0)
+        $clientIp = $_SERVER['HTTP_CLIENT_IP'];
+    else if (array_key_exists('HTTP_X_FORWARDED_FOR', $_SERVER)
+        && strcasecmp($_SERVER['HTTP_X_FORWARDED_FOR'], 'unknown') != 0)
+        $clientIp = $_SERVER['HTTP_X_FORWARDED_FOR'];
+    else if (array_key_exists('REMOTE_ADDR', $_SERVER))
+        $clientIp = $_SERVER['REMOTE_ADDR'];
+    return $clientIp;
+function GetClientAgent()
+    return "Fusion Viewer";
Modified: sandbox/olcore/layers/MapGuide/php/CreateSession.php
--- sandbox/olcore/layers/MapGuide/php/CreateSession.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/CreateSession.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -44,8 +44,10 @@
     echo var2json($result);
     /* start a php session in the web tier as well, using same session id */
-    session_start($sessionId);
+    session_id(str_replace('_', '-', $sessionId));
+    session_start();
     $_SESSION['username'] = $username;
+    loadFusionConfig();
 } catch (MgException $e) {
      echo "ERROR: " . $e->GetMessage() . "n";
Modified: sandbox/olcore/layers/MapGuide/php/Query.php
--- sandbox/olcore/layers/MapGuide/php/Query.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/Query.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -115,6 +115,7 @@
             $className = $layerObj->GetFeatureClassName();
             if (!$layerObj->GetSelectable() || !$layerObj->IsVisible() ||
+                $className=='RedlineSchema:Redline' ||
                 !$className || $className=='rasters:RasterType' ||$className=='') {
                 continue;
Modified: sandbox/olcore/layers/MapGuide/php/SaveMap.php
--- sandbox/olcore/layers/MapGuide/php/SaveMap.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/SaveMap.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -29,9 +29,14 @@
 include('Common.php');
-$format = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
-$layout = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
-$scale  = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : null;
+$format     = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
+$layout     = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
+$scale      = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : null;
+$imgWidth   = isset($_REQUEST['width']) ? $_REQUEST['width'] : null;
+$imgHeight  = isset($_REQUEST['height']) ? $_REQUEST['height'] : null;
+$pageHeight = isset($_REQUEST['pageheight']) ? $_REQUEST['pageheight'] : 11;
+$pageWidth  = isset($_REQUEST['pagewidth']) ? $_REQUEST['pagewidth'] : 8.5;
+$aMargins = isset($_REQUEST['margins']) ? explode(',',$_REQUEST['margins']) : array(0,0,0,0);
 try
@@ -43,44 +48,41 @@
     $selection = new MgSelection($map);
     $selection->Open($resourceService, $mapName);
+    //compute center
+    $extent = $map->GetMapExtent();
+    $centerX = $extent->GetLowerLeftCoordinate()->GetX() + ($extent->GetWidth())/2;
+    $centerY = $extent->GetLowerLeftCoordinate()->GetY() + ($extent->GetHeight())/2;
+    $geomFactory = new MgGeometryFactory();
+    $center = $geomFactory->CreateCoordinateXY($centerX, $centerY);
     if ($format == 'DWF') {
-        $extent = $map->GetMapExtent();
         $oLayout = null;
         if ($layout) {
             $layoutId = new MgResourceIdentifier($layout);
             $layoutId->Validate();
             $oLayout = new MgLayout($layoutId,'Map', 'meters');
-        $oPlotSpec = new MgPlotSpecification(8.5,11,MgPageUnitsType::Inches);
+        $oPlotSpec = new MgPlotSpecification($pageWidth,$pageHeight,MgPageUnitsType::Inches,
+                                            $aMargins[0],
+                                            $aMargins[1],
+                                            $aMargins[2],
+                                            $aMargins[3]
         $dwfVersion = new MgDwfVersion('6.01','1.2');
         if ($scale) {
-            //compute center point and plot with the passed scale
-            $centerX = $extent->GetLowerLeftCoordinate()->GetX() + ($extent->GetWidth())/2;
-            $centerY = $extent->GetLowerLeftCoordinate()->GetY() + ($extent->GetHeight())/2;
-            $geomFactory = new MgGeometryFactory();
-            $center = $geomFactory->CreateCoordinateXY($centerX, $centerY);
+            //plot with the passed scale
-            //echo $centerX.", ".$centerY;exit;
-            //$metersPerUnit = $map->GetMetersPerUnit();
             $coordSysFactory = new MgCoordinateSystemFactory();
             $coordSystem = $coordSysFactory->Create($map->GetMapSRS());
             $metersPerUnit = $coordSystem->ConvertCoordinateSystemUnitsToMeters(1.0);
             $metersPerPixel = 1.0/(100.0 / 2.54 * $map->GetDisplayDpi());
-            //echo $metersPerPixel; exit;
             $height = $map->GetDisplayHeight();
             $width = $map->GetDisplayWidth();
             $mapWidth = $scale * $width * $metersPerPixel/$metersPerUnit;
             $mapHeight = $scale * $height * $metersPerPixel/$metersPerUnit;
-            //echo $mapWidth.", ".$mapHeight;exit;
-            // $lowerLeft = $geomFactory->CreateCoordinateXY($center->GetX() - 0.5*$mapWidth,
-            //                                               $center->GetY() - 0.5*$mapHeight);
-            // $topRight = $geomFactory->CreateCoordinateXY($center->GetX() + 0.5*$mapWidth,
-            //                                               $center->GetY() + 0.5*$mapHeight);
             $extent = new MgEnvelope(
                                       $center->GetY() - 0.5*$mapHeight,
@@ -113,8 +115,18 @@
                                               $dwfVersion);
     } else {
-        $oImg = $renderingService->RenderMap($map, $selection, $format);
+        //render as an image
+        if (isset($imgHeight) && isset($imgWidth)) {
+            $scale = $map->GetViewScale();
+            $oImg = $renderingService->RenderMap($map, $selection,
+                                                 $center, $scale,
+                                                 $imgWidth, $imgHeight,
+                                                 new MgColor(255,255,255),
+                                                 $format);
+        }else{
+            $oImg = $renderingService->RenderMap($map, $selection, $format);
@@ -124,16 +136,8 @@
   exit;
+header("Cache-Control: no-store, no-cache, must-revalidate");  // HTTP/1.1
 header("Expires: Mon, 26 Jul 1997 05:00:00 GMT");    // Date in the past
-header("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT");
-                                             // always modified
-header("Cache-Control: no-store, no-cache, must-revalidate");  // HTTP/1.1
-header("Cache-Control: post-check=0, pre-check=0", false);
-header("Pragma: no-cache");                          // HTTP/1.0
-header( "Content-type: application/octet-stream" );
-header( "Content-Disposition: attachment; filename=$mapName.png" );
 header( "Content-type: image/$format" );
 header( "Content-disposition: attachment; filename=$mapName.$format" );
Modified: sandbox/olcore/layers/MapGuide/php/Utilities.php
--- sandbox/olcore/layers/MapGuide/php/Utilities.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapGuide/php/Utilities.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -868,7 +868,7 @@
             $value =  GetPropertyValueFromFeatReader($featureReader,
                                                      $properties->$layerName->propertytypes[$j],
                                                      $propname);
-            $value = htmlentities($value);
+            $value = htmlentities($value, ENT_COMPAT, 'UTF-8');
             $value = addslashes($value);
             $value = preg_replace( "/\r?\n/", "<br>", $value );
             array_push($properties->$layerName->values[$properties->$layerName->numelements], $value);
Modified: sandbox/olcore/layers/MapServer/MapServer.js
--- sandbox/olcore/layers/MapServer/MapServer.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/MapServer.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -31,6 +31,7 @@
 Fusion.Event.MAP_LAYER_ORDER_CHANGED = Fusion.Event.lastEventId++;
 Fusion.Layers.MapServer = OpenLayers.Class(Fusion.Layers, {
+    session: [null],
     arch: 'MapServer',
     mapMetadataKeys: null,
     layerMetadataKeys: null,
Modified: sandbox/olcore/layers/MapServer/php/CreateSession.php
--- sandbox/olcore/layers/MapServer/php/CreateSession.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/CreateSession.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -34,6 +34,7 @@
 initializeSession( "sid", "", "" );
 $sessionId = session_id();
+loadFusionConfig();
 header('Content-type: text/x-json');
Modified: sandbox/olcore/layers/MapServer/php/LegendIcon.php
--- sandbox/olcore/layers/MapServer/php/LegendIcon.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/LegendIcon.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -25,7 +25,7 @@
- * Purpose: Draw a legend icon
+ * Purpose: Draw a legend icon
 include(dirname(__FILE__).'/Common.php');
@@ -37,46 +37,61 @@
 $legendIconCacheFile = "";
 if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
-    /* json decode only in PHP 5.2 and later */
-    if (function_exists('json_decode')) {
-        $configFile = realpath(dirname(__FILE__)."/../../config.json");
-        if (file_exists($configFile)) {
-            $configStr = file_get_contents($configFile);
-            /* replace single quotes with double quotes */
-            $configStr = str_replace("'", '"', $configStr);
-            /* get rid of new lines, it just complicates things */
-            $configStr = str_replace("\n", '', $configStr);
-            /* get rid of embedded comments */
-            $configStr = preg_replace("/\/\*.*\*\//U", "", $configStr);
-            /* the regex after this one can't handle http: as a value, so mangle it. */
-            $configStr = preg_replace("/http:/U", "http_", $configStr);
-            /* quote unquoted attribute names */
-            $configStr = preg_replace("/[^\"]{1}(\w*):/U", "\"$1\":", $configStr);
-            /* decode the whole thing */
-            $configObj = json_decode($configStr, false);
-            /* if the legendIconCache dir is set */
-            if (isset($configObj->mapserver->legendIconCacheDir)) {
-              $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
-              $cacheLegendIcons = true;
-              $str = file_get_contents($_SESSION['maps'][$mapName]);
-              /* create a unique location for the map icons based on
-               * the content of the of map file.  If the content changes
-               * then the icons should be rebuilt anyway
-              $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
-              if (!is_dir($legendIconCacheDir)) {
-                mkdir($legendIconCacheDir);
-              /* TODO: can we figure out what the content type is? */
-              $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
-              /* if the icon exists, return it */
-              if (file_exists($legendIconCacheFile)) {
-                  header('Content-type: image/png');
-                  readfile($legendIconCacheFile);
-                  exit;
+      $configObj = $_SESSION['fusionConfig'];
+      /* if the legendIconCache dir is set */
+      if (isset($configObj->mapserver->legendIconCacheDir)) {
+        $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
+        // check for closing '/'
+        $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
+        if ( substr( $legendIconCacheDir, -1 ) != '/' )
+            $legendIconCacheDir .= '/';
+        $cacheLegendIcons = true;
+        $str = file_get_contents($_SESSION['maps'][$mapName]);
+        /* create a unique location for the map icons based on
+         * the content of the of map file.  If the content changes
+         * then the icons should be rebuilt anyway
+        $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
+        if (!is_dir($legendIconCacheDir)) {
+          mkdir($legendIconCacheDir);
+        /* TODO: can we figure out what the content type is? */
+        $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
+        /* if the icon exists, return it */
+        if (file_exists($legendIconCacheFile)) {
+            header('Content-type: image/png');
+            $etag = '"' . md5_file($legendIconCacheFile) . '"';
+            header ("ETag: " . $etag );
+            $cache_time = mktime(0, 0, 0, 1, 1, 2004);
+            $expires = 3600 * 256;
+            header("last-modified: " . gmdate("D, d M Y H:i:s",$cache_time) . " GMT");
+            $inm = split(',', getenv("HTTP_IF_NONE_MATCH"));
+            $send_body = true;
+            foreach ($inm as $i) {
+            	  if (trim($i) == $etag || trim($i) == $cache_time) {
+            		    header ("HTTP/1.0 304 Not Modified");
+            		    $send_body = false;
+            //last modified test
+            if(getenv("HTTP_IF_MODIFIED_SINCE") == gmdate("D, d M Y H:i:s",$cache_time). " GMT") {
+            //more headers
+            header("Expires: " . gmdate("D, d M Y H:i:s",$cache_time+$expires) . " GMT");
+            header("Cache-Control: max-age=$expires, must-revalidate");
+            //header('Content-Length: ' . strlen($body));
+            //if we're not cacheing
+            if ($send_body) {
+                readfile($legendIconCacheFile);
+            exit;
@@ -85,16 +100,22 @@
     $oClass = $oLayer->getClass($REQUEST_VARS['classindex']);
     $width = $oMap->legend->keysizex;
     $height = $oMap->legend->keysizey;
-    if ($width <=0)
-      $width = 16;
-    if ($height <=0)
-      $height = 16;
+    if ($width <=0) {
+        $width = 16;
+    if ($height <=0) {
+        $height = 16;
     $oImg = $oClass->createLegendIcon($width, $height);
     if ($cacheLegendIcons) {
         $oImg->saveImage($legendIconCacheFile);
     } else {
       $oImg->saveImage("");
Modified: sandbox/olcore/layers/MapServer/php/LoadMap.php
--- sandbox/olcore/layers/MapServer/php/LoadMap.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/LoadMap.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -144,23 +144,38 @@
     $mapObj->layers = array();
     for ($i=0;$i<$oMap->numlayers;$i++)
-         $layer=$oMap->GetLayer($i);
-         $layerObj = NULL;
+        $layer=$oMap->getLayer($i);
+        $layerObj = NULL;
-         $layerObj->metadata = NULL;
-         if (isset($_REQUEST['layer_metadata'])) {
-             $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
-             foreach($layerMetadataKeys as $key) {
-                 $layerObj->metadata->$key = $layer->getMetadata($key);
+        $layerObj->metadata = NULL;
+        if (isset($_REQUEST['layer_metadata'])) {
+            $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
+            foreach($layerMetadataKeys as $key) {
+                $layerObj->metadata->$key = $layer->getMetadata($key);
+        //$extent = $layer->getExtent();
+        $layerObj->extent = NULL;
+        $layerObj->extent->minx = NULL;
+        $layerObj->extent->maxx = NULL;
+        $layerObj->extent->miny = NULL;
+        $layerObj->extent->maxy = NULL;
+         // only proceed if extent is valid
+        if( isset($GLOBALS["extent"]) )
+            $layerObj->extent->minx = $extent->minx;
+            $layerObj->extent->maxx = $extent->maxx;
+            $layerObj->extent->miny = $extent->miny;
+            $layerObj->extent->maxy = $extent->maxy;
          $layerObj->propertyMappings = '';
          $layerObj->uniqueId = $i;
          $layerObj->layerName = $layer->name;
          switch($layer->type) {
              case MS_LAYER_POINT:
-             case MS_LAYER_ANNOTATION:
                 $type = 0;
                 break;
              case MS_LAYER_LINE:
@@ -172,6 +187,9 @@
              case MS_LAYER_RASTER:
                 $type = 4;
                 break;
+             case MS_LAYER_ANNOTATION:
+                $type = 8;
+                break;
              default:
                 $type = 0;
Modified: sandbox/olcore/layers/MapServer/php/Measure.php
--- sandbox/olcore/layers/MapServer/php/Measure.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/Measure.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -48,19 +48,14 @@
         $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
-    $shapeObj = ms_newShapeObj(MS_SHAPE_LINE);
-    $lineObj = ms_newLineObj();
-    $lineObj->addXY($x1,$y1);
-    $lineObj->addXY($x2,$y2);
-    $shapeObj->add($lineObj);
     if ($oMap->units == MS_DD)
       /*this already returns a meter*/
       $distance = distHaversine($x1,$y1, $x2,$y2);
     else
-      $distance = $shapeObj->getLength($shapeObj);
-      /*convert to meter*/
-      $distance = GetMetersPerUnit($oMap->units)*$distance;
+        $distance = sqrt (pow(($x2 - $x1),2) + pow(($y2 - $y1),2));
+        /*convert to meter*/
+        $distance = GetMetersPerUnit($oMap->units)*$distance;
Modified: sandbox/olcore/layers/MapServer/php/Query.php
--- sandbox/olcore/layers/MapServer/php/Query.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/Query.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -81,8 +81,8 @@
     $oMap->loadquery(getSessionSavePath()."query.qry");
-$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
+$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
 $bAllLayers = false;
 $nLayers = count($layers);
 $nSelections = 0;
@@ -102,8 +102,9 @@
     $oLayer->set('tolerance', 0);
     if ($oLayer->type ==  MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
-        $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART)
-      continue;
+        $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART) {
+        continue;
     if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
@@ -123,8 +124,7 @@
-if ($result->hasSelection)
+if ($result->hasSelection) {
     $oMap->savequery(getSessionSavePath()."query.qry");
     $result->queryFile = getSessionSavePath()."query.qry";
@@ -139,15 +139,13 @@
     $bFirstElement = 1;
     $nLayers = $oMap->numlayers;
-    for ($i=0; $i<$nLayers; $i++)
+    for ($i=0; $i<$nLayers; $i++) {
         $oLayer = $oMap->GetLayer($i);
         $numResults = $oLayer->getNumResults();
-        if ($numResults == 0)
+        if ($numResults == 0){
           continue;
         $oLayer->open();
         $layerName = $oLayer->name != "" ? $oLayer->name : "Layer_".$i;
         array_push($properties->layers, $layerName);
@@ -169,21 +167,70 @@
         $oRes = $oLayer->getResult(0);
         $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
         $selFields = array();
-        while ( list($key,$val) = each($oShape->values) )
-            array_push($selFields, $key);
+        if (isset($_SESSION[$mapName][$layerName]['query_items'])) {
+            $aQueryItems = $_SESSION[$mapName][$layerName]['query_items'];
+        } else {
+            //token separator (for parsing displayed attributes on a query)
+            $tokenSeparator = ",";
+            // checking if metadata "query_include_items" is set
+            $metadataItems = $oLayer->getMetaData('query_include_items');
+            if ( ($metadataItems == "") || ($metadataItems == "all") ) {
+                while ( list($key,$val) = each($oShape->values) ) {
+                    $aQueryItems[$key]  = NULL;
+            } else {
+              $token = strtok($metadataItems, $tokenSeparator);
+              while ($token !== false) {
+                  $aQueryItems[trim($token)] = NULL;
+                  $token = strtok($tokenSeparator);
+            // checking if metadata "query_exclude_items" is set
+            $metadataItems = $oLayer->getMetaData('query_exclude_items');
+            if ($metadataItems != "") {
+                    if (array_key_exists($token, $aQueryItems)) {
+                        unset($aQueryItems[$token]);
+            // get all alias
+            while ( list($key,$val) = each($aQueryItems) ) {
+                $keyAlias = $oLayer->getMetaData("query_".$key."_alias");
+                trim($keyAlias);
+                if ($keyAlias != "") {
+                    $aQueryItems[$key] = $keyAlias;
+            $_SESSION[$mapName][$layerName]['query_items'] = $aQueryItems;
+        $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
+            if (array_key_exists($key, $aQueryItems)) {
+                array_push($selFields, $key);
-            array_push($properties->$layerName->propertynames, $key);
-            //TODO : we should define away to give alias to field names
-            array_push($properties->$layerName->propertyvalues, $key);
+                //we check if an alias if provided
+                if (isset($aQueryItems[$key]) && ($aQueryItems[$key] != "")){
+                    $key = $aQueryItems[$key];
-            //TODO we do not know the types of the attributes in MS. Just output 0
-            //we shouls possibly use OGR to get the attributes
-            array_push($properties->$layerName->propertytypes, 0);
+                array_push($properties->$layerName->propertynames, $key);
+                //TODO : we should define away to give alias to field names
+                array_push($properties->$layerName->propertyvalues, $key);
+                //TODO we do not know the types of the attributes in MS. Just output 0
+                //we shouls possibly use OGR to get the attributes
+                array_push($properties->$layerName->propertytypes, 0);
-        for ($iRes=0; $iRes < $numResults; $iRes++)
+        for ($iRes=0; $iRes < $numResults; $iRes++) {
             $properties->$layerName->values[$iRes] = array();
             $properties->$layerName->metadata[$iRes] = array();
@@ -195,25 +242,26 @@
             $maxx =  $oShape->bounds->maxx;
             $maxy =  $oShape->bounds->maxy;
-            if ($bFirstElement)
+            if ($bFirstElement) {
                 $bFirstElement = 0;
                 $totalminx =  $minx;
                 $totalminy =  $miny;
                 $totalmaxx =  $maxx;
                 $totalmaxy =  $maxy;
+            } else {
+                if ($totalminx > $minx) {
+                    $totalminx = $minx;
+                if ($totalminy > $miny) {
+                    $totalminy = $miny;
+                if ($totalmaxx < $maxx) {
+                    $totalmaxx = $maxx;
+                if ($totalmaxy < $maxy) {
+                    $totalmaxy = $maxy;
-            else
-                if ($totalminx > $minx)
-                  $totalminx = $minx;
-                if ($totalminy > $miny)
-                  $totalminy = $miny;
-                if ($totalmaxx < $maxx)
-                  $totalmaxx = $maxx;
-                if ($totalmaxy < $maxy)
-                  $totalmaxy = $maxy;
             //metadata : TODO dimension, area, length and distance are not set
             $dimension = 0;
@@ -229,8 +277,7 @@
             array_push($properties->$layerName->metadata[$iRes], $length);
             //field values
-            for($iField=0; $iField < count($selFields); $iField++)
+            for($iField=0; $iField < count($selFields); $iField++) {
                 $value = $oShape->values[$selFields[$iField]];
                 //$value = preg_replace( "/\r?\n/", "<br>", $value );
                 $value = str_replace("'", "\'", $value);
Modified: sandbox/olcore/layers/MapServer/php/SetLayers.php
--- sandbox/olcore/layers/MapServer/php/SetLayers.php	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/layers/MapServer/php/SetLayers.php	2008-07-22 15:00:30 UTC (rev 1442)
@@ -1,76 +1,80 @@
-<?php
- * SetLayers
- * $Id$
- * Copyright (c) 2007, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
- * Purpose: Set the layers that are in the current Map in the session
-/* set up the session */
-include ("Common.php");
-include ("Utilities.php");
-if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
-    $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
-/* the name of the layer in the map to query */
-if ($_REQUEST['layerindex'] != '') {
-	$layers = explode(',',$_REQUEST['layerindex']);
-} else {
-	$layers = array();
-$currentLayers = $oMap->getlayersdrawingorder();
-if (count($currentLayers) != count($layers) ) {
-	for ($i=0; $i<count($layers); $i++) {
-		if ($i != $layers[$i]) {
-			$layer = $oMap->getLayer($i);
-			$tmp = $layer->set('status', 'MS_DELETE');
-			if ($tmp >= 0) {
-				$res = true;
-			} else {
-				$res = false;
-			break;
-		$res = false;
-} else {
-	$res = $oMap->setlayersdrawingorder($layers);
-header('Content-type: text/x-json');
-header('X-JSON: true');
-if ($res) {
-	$oMap->save($_SESSION['maps'][$mapName]);
-	$currentLayers = $oMap->getlayersdrawingorder();
-    echo "{success: true, layerindex: [".implode(",",$currentLayers)."]}";
-} else {
-    echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
+<?php
+ * SetLayers
+ * $Id$
+ * Copyright (c) 2007, DM Solutions Group Inc.
+ * Permission is hereby granted, free of charge, to any person obtaining a
+ * copy of this software and associated documentation files (the "Software"),
+ * to deal in the Software without restriction, including without limitation
+ * the rights to use, copy, modify, merge, publish, distribute, sublicense,
+ * and/or sell copies of the Software, and to permit persons to whom the
+ * Software is furnished to do so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included
+ * in all copies or substantial portions of the Software.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT.  IN NO EVENT SHALL
+ * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
+ * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
+ * DEALINGS IN THE SOFTWARE.
+ * Purpose: Set the layers that are in the current Map in the session
+/* set up the session */
+include ("Common.php");
+include ("Utilities.php");
+header('Content-type: text/x-json');
+header('X-JSON: true');
+if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
+    $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+/* the name of the layer in the map to query */
+if ($_REQUEST['layerindex'] != '') {
+	$layers = explode(',',$_REQUEST['layerindex']);
+} else {
+	$layers = array();
+$currentLayers = $oMap->getlayersdrawingorder();
+if (count($currentLayers) != count($layers) ) {
+  echo "/* removing layers ";
+	for ($i=0; $i<count($layers); $i++) {
+		if ($i != $layers[$i]) {
+		  echo $i." ";
+			$layer = $oMap->getLayer($i);
+			$tmp = $layer->set('status', MS_DELETE);
+			if ($tmp >= 0) {
+				$res = true;
+			} else {
+				$res = false;
+			break;
+		$res = false;
+		echo "*/";
+} else {
+  echo "/* reordering layers */";
+	$res = $oMap->setlayersdrawingorder($layers);
+if ($res) {
+	$oMap->save($_SESSION['maps'][$mapName]);
+	$currentLayers = $oMap->getlayersdrawingorder();
+    echo "{success: true, layerindex: [".implode(",",$currentLayers)."]}";
+} else {
+    echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
Modified: sandbox/olcore/lib/ApplicationDefinition.js
--- sandbox/olcore/lib/ApplicationDefinition.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/ApplicationDefinition.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -124,7 +124,12 @@
         if ( (this.applicationDefinition.match('Library://') == null) &&
              (this.applicationDefinition.match('Session:') == null) ) {
-            Fusion.getXmlAsJson(this.applicationDefinition, OpenLayers.Function.bind(this.parseAppDef, this));
+            if (Fusion.appDefJson) {
+                this.parseAppDef(Fusion.appDefJson);
+            } else {
+                Fusion.getXmlAsJson(this.applicationDefinition,
+                              OpenLayers.Function.bind(this.getAppDefCB, this));
         } else {
             //TODO: request as JSON format
             if (!this.sessionId) {
@@ -146,9 +151,16 @@
       r.parameters.session = this.sessionId;
       this.oBroker.dispatchRequest(r,
             OpenLayers.Function.bind(Fusion.xml2json, this,
-                  OpenLayers.Function.bind(this.parseAppDef, this)));
+                  OpenLayers.Function.bind(this.getAppDefCB, this)));
+    getAppDefCB: function(xhr) {
+        var o;
+        eval("o="+xhr.responseText);
+        this.parseAppDef(o);
+        Fusion.setLoadState(Fusion.LOAD_WIDGETS);
      * Function: parseAppDef
@@ -158,10 +170,8 @@
      * the XmlHttpRequest object
-     parseAppDef: function(xhr) {
-        var o;
-        eval("o="+xhr.responseText);
-        var appDef = o.ApplicationDefinition;
+    parseAppDef: function(json) {
+        var appDef = json.ApplicationDefinition;
         /* Set the application title */
         if (appDef.Title) {
@@ -221,7 +231,6 @@
-        Fusion.setLoadState(Fusion.LOAD_WIDGETS);
@@ -484,6 +493,10 @@
             var b = jsonNode.SingleTile[0].toLowerCase();
             this.singleTile = (b == "true") ? true : false;
+        if (jsonNode.IsBaseLayer) {
+            var b = jsonNode.IsBaseLayer[0].toLowerCase();
+            this.isBaseLayer = (b == "true") ? true : false;
         if (jsonNode.Extension) {
             this.extension = jsonNode.Extension[0];
         } else {
@@ -718,7 +731,7 @@
             this.createWidgets(widgetSet, container);
         if (container && container.domObj.jxLayout) {
-            container.domObj.jxLayout.resize();
+            container.domObj.jxLayout.resize({forceResize: true});
Copied: sandbox/olcore/lib/EventMgr.js (from rev 1438, trunk/lib/EventMgr.js)
--- sandbox/olcore/lib/EventMgr.js	                        (rev 0)
+++ sandbox/olcore/lib/EventMgr.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -0,0 +1,127 @@
+ * Class: Fusion.Lib.EventMgr
+ * an internal class for managing generic events.  Classes that wish to
+ * publish and trigger events that other objects can listen for need to
+ * inherit from Fusion.Lib.EventMgr.
+ * To publish an event, call registerEventID with some unique numeric or
+ * string value.  Other objects can then call registerForEvent with the
+ * eventID and a function to call when the event is triggered.
+ * To trigger an event, call triggerEvent with the eventID and any additional
+ * arguments that should be passed to listeners.
+Fusion.Lib.EventMgr = OpenLayers.Class({
+    /* an array of eventIDs and associated listener functions */
+    events : null,
+    initialize: function() { if (!this.events) {this.events = []; }},
+     * Method: destroy
+    destroy: function() {
+       this.events = [];
+     * register an event ID so that others can use it.  This should really
+     * only be called by 'this' object.
+     * @param eventID the event ID to register
+    registerEventID : function( eventID ) {
+        if (!this.events) {this.events = []; }
+        if (!eventID) {
+            Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
+                          OpenLayers.i18n('regsiterEventError')));
+        var ev = new String(eventID);
+        if (!this.events[eventID]) {
+            this.events[eventID] = [];
+     * register for receiving a callback when an event happens. If you
+     * want the callback to be a method on an instance of some object,
+     * use the OpenLayers.Function.bind() function as in:
+     * otherObj.registerForEvent(SOME_EVENT, OpenLayers.Function.bind(this.callback,this));
+     * @param eventID the event ID to register for
+     * @param f the function to call when the event happens.
+    registerForEvent : function(eventID, f) {
+        this.events[eventID].push(f);
+     * deregister a callback function when you no longer want to
+     * recieve it.  Note that if you used bind() when registering,
+     * you need to pass EXACTLY THE SAME FUNCTION when
+     * deregistering.  Typically, this means you need to assign the
+     * result of bind() to an instance variable and pass that instance
+     * variable to both registerForEvent and deregisterForEvent.
+     * For instance:
+     * this.callbackFn = OpenLayers.Function.bind(this.callback, this);
+     * otherObj.registerForEvent(SOME_EVENT, this.callbackFn);
+     * otherObj.deregisterForEvent(SOME_EVENT, this.callbackFn);
+     * @param eventID the event ID to deregister
+     * @param f the function that used when registering.
+    deregisterForEvent : function( eventID, f ) {
+        var bResult = false;
+        if (!this.events[eventID]){
+            return false;
+        for (var i=0;i<this.events[eventID].length;i++) {
+            if (this.events[eventID][i]== f) {
+                this.events[eventID].splice(i,1);
+                bResult = true;
+        return bResult;
+     * trigger an event and call all registered listener functions.
+     * This is intended to be called by 'this'.  The eventID param
+     * is mandatory.  Any additional arguments will be passed to the
+     * listener function.
+     * @param eventID the event ID to trigger
+    triggerEvent : function( eventID ) {
+        if (!this.events || !this.events[eventID]) {
+            return false;
+        for (var i=0; i<this.events[eventID].length; i++) {
+            this.events[eventID][i].apply(null, arguments);
+        return true;
+//window.Fusion = OpenLayers.Class(Fusion.Lib.EventMgr, Fusion.prototype);
+//OpenLayers.Util.extend(Fusion, Fusion.Lib.EventMgr.prototype);
+Fusion.events = [];
+Fusion.registerEventID = Fusion.Lib.EventMgr.prototype.registerEventID;
+Fusion.registerForEvent = Fusion.Lib.EventMgr.prototype.registerForEvent;
+Fusion.triggerEvent = Fusion.Lib.EventMgr.prototype.triggerEvent;
+Fusion.Event.FUSION_INITIALIZED = Fusion.Event.lastEventId++;
+Fusion.Event.FUSION_ERROR = Fusion.Event.lastEventId++;
+Fusion.registerEventID(Fusion.Event.FUSION_INITIALIZED);
+Fusion.registerEventID(Fusion.Event.FUSION_ERROR);
Modified: sandbox/olcore/lib/MGBroker.js
--- sandbox/olcore/lib/MGBroker.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/MGBroker.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -142,7 +142,7 @@
     initializeRequest : function() {
         this.options = { method:'post' };
-        this.parameters = { version : '1.0.0', locale : Fusion.locale };
+        this.parameters = { version : '1.0.0', locale : Fusion.locale, clientagent : 'Fusion Viewer' };
@@ -567,11 +567,13 @@
      * @param maxFeatures {integer} number of maximum results (-1 to indicate no maximum)
      * @param selectionPersist {boolean} save the selection (valid values are 0 and 1)
      * @param selectionVariant {String} indicates the spatial operation. Valid values are 'INTERSECTS', ...
-     *@param layerNames {String} comma separated list of layer names to include in the query
+     * @param layerNames {String} comma separated list of layer names to include in the query
+     * @param layerAttributeFilter {integer} bitmask determining layer selection behaviour (1=visible layers,
+     *          2=selectable layers, 4=layers with tooltips)
      * @return {Object} an instance of Fusion.Lib.MGRequest.MGQueryMapFeatures
-    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames )
+    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames, layerAttributeFilter )
         this.initializeRequest();
         this.setParams( {
@@ -582,7 +584,8 @@
             maxFeatures: maxFeatures,
             persist: persist,
             selectionVariant: selectionVariant,
-            layerNames: layerNames
+            layerNames: layerNames,
+            layerAttributeFilter: layerAttributeFilter
@@ -614,4 +617,4 @@
             featureSet: features
\ No newline at end of file
Modified: sandbox/olcore/lib/Map.js
--- sandbox/olcore/lib/Map.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/Map.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -68,7 +68,7 @@
     aMaps: null,
     layerRoot: null,
     singleTile: true,
-    bFractionalZoom: true,  //TODO: set this in AppDef?
+    fractionalZoom: true,  //TODO: set this in AppDef?
      * construct a new view Fusion.Widget.Map class.
@@ -76,6 +76,7 @@
     initialize : function(widgetTag, mapGroup, widgetSet) {
         this.widgetTag = widgetTag;
         var name = widgetTag.name;
+        this.aMaps = [];
         this.widgetSet = widgetSet;
         this._nCellSize = -1;
@@ -96,11 +97,18 @@
           this.fractionalZoom = widgetTag.extension.FractionalZoom[0]=='false'?false:true;
+        var scalesArray = null;
+        if (widgetTag.extension.Scales) {
+          scalesArray = widgetTag.extension.Scales[0].split(',');
+          this.fractionalZoom = false;
         OpenLayers.DOTS_PER_INCH = this._nDpi;
         if (!this.oMapOL) {
             var options = {
                 controls: [],
                 fallThrough: true,
+                scales: scalesArray,
                 fractionalZoom: this.fractionalZoom
             if (widgetTag.extension.ConstrainMapExtent) {
@@ -108,11 +116,9 @@
             this.oMapOL = new OpenLayers.Map(this._sDomObj, options );
-        if (this.bIsBaseLayer) {
-          this.mapWidget.oMapOL.setOptions({});
         this.oMapOL.viewPortDiv.style.position = 'absolute';  //not the top level container so set it to absolute
+        this.oMapOL.viewPortDiv.style.zIndex = 0;   //must explicitly set the z-index for FF3
         //add in the handler for mouse wheel actions
         var useMouseWheel = true;
@@ -129,19 +135,7 @@
         //create the 'Map' layer widgets defined in the MapGroup
-        this.aMaps = [];
-        this.mapGroup = mapGroup;
-        this.mapLoadCounter = 0;
-        for (var i=0; i<mapGroup.maps.length; ++i) {
-          var mapTag = mapGroup.maps[i];
-          if (Fusion.Layers[mapTag.type]) {
-              this.aMaps[i] = eval("new Fusion.Layers."+mapTag.type+"(this,mapTag)");
-              this.layerRoot.addGroup(this.aMaps[i].layerRoot);
-          } else {
-              //TODO: we can add more OpenLayers layers ...
+        this.loadMapGroup(mapGroup);
         $(name).widget = this;
         this.registerEventID(Fusion.Event.MAP_EXTENTS_CHANGED);
@@ -155,6 +149,8 @@
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
+        this.registerForEvent(Fusion.Event.MAP_LOADED, OpenLayers.Function.bind(this.mapLoaded,this));
         //register for OL map extent change events
         this.oMapOL.events.register('moveend', this, this.mapExtentsChanged);
@@ -166,6 +162,10 @@
         this.bFetchingSelection = false;
+    mapLoaded: function() {
+      this.setViewOptions(this.getUnits());
     setMenu: function() {
         if (this.widgetTag.extension.MenuContainer) {
             var contextMenu = new Jx.ContextMenu();
@@ -174,9 +174,7 @@
                 container.createWidgets(this.widgetSet, contextMenu);
                 this.setContextMenu(contextMenu);
     loadMapGroup: function(mapGroup) {
@@ -186,6 +184,7 @@
         //clear any existing selection
+        this.mapLoadCounter = 0;
         this.clearSelection();
@@ -196,15 +195,12 @@
         this.aMaps = [];
-        this.layerRoot = new Fusion.Widget.Map.Group();
+        this.layerRoot.clear();
-          } else {
@@ -291,11 +287,6 @@
     addMap: function(map) {
-        if (!map.bSingleTile) {
-            this.singleTile = false;
-        this.projection = map.projection;
         //if bRestrictExtent is null, use the default OL behaviour with somewhat restricted map navigation
         //if bRestrictExtent is set to true, map navigation is limited to the map extent
         //if bRestrictExtent is set to false, map navigation is not restricted at all
@@ -306,7 +297,20 @@
             this.oMapOL.restrictedExtent = false;
+        if (this.oMapOL.baseLayer) {
+            var newOptions = {
+              transparent: true,
+              isBaseLayer: false
+            map.oLayerOL.addOptions(newOptions);
+            map.oLayerOL.setVisibility(true);
+        } else {
+            this.projection = map.projection;
+            map.oLayerOL.setIsBaseLayer(true);
         this.oMapOL.addLayer(map.oLayerOL);
+        console.log('layer added:'+map.oLayerOL.name);
         map.registerForEvent(Fusion.Event.MAP_LOADED,
                 OpenLayers.Function.bind(this.mapLoadHandler, this));
         map.registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
@@ -340,7 +344,7 @@
-     * Function: selectionHandler
+     * Function: mapLoadHandler
      * handle selection events from maps and republish for
      * widgets as appropriate
@@ -348,6 +352,8 @@
     mapLoadHandler: function() {
         ++this.mapLoadCounter;
         if (this.mapLoadCounter == this.aMaps.length) {
+            this._oInitialExtents = null;
+            this.fullExtents();
@@ -581,30 +587,38 @@
     zoom : function(fX, fY, nFactor) {
         //do this differntly with OL code??
-        var extent = this.oMapOL.getExtent();
-        var fDeltaX = extent.right - extent.left;
-        var fDeltaY = extent.top - extent.bottom;
-        var fMinX,fMaxX,fMinY,fMaxY;
         if (nFactor == 1 || nFactor == 0) {
             /*recenter*/
-            fMinX = fX - (fDeltaX/2);
-            fMaxX = fX + (fDeltaX/2);
-            fMinY = fY - (fDeltaY/2);
-            fMaxY = fY + (fDeltaY/2);
-        } else if (nFactor > 0) {
-            /*zoomin*/
-            fMinX = fX - (fDeltaX/2 / nFactor);
-            fMaxX = fX + (fDeltaX/2 / nFactor);
-            fMinY = fY - (fDeltaY/2 / nFactor);
-            fMaxY = fY + (fDeltaY/2 / nFactor);
-        } else if (nFactor < 0) {
-            /*zoomout*/
-            fMinX = fX - ((fDeltaX/2) * Math.abs(nFactor));
-            fMaxX = fX + ((fDeltaX/2) * Math.abs(nFactor));
-            fMinY = fY - ((fDeltaY/2) * Math.abs(nFactor));
-            fMaxY = fY + ((fDeltaY/2) * Math.abs(nFactor));
-        this.setExtents(new OpenLayers.Bounds(fMinX, fMinY, fMaxX, fMaxY));
+            this.oMapOL.panTo(new OpenLayers.LonLat(fX, fY));
+        } else {
+            var extent = this.oMapOL.getExtent();
+            if (this.fractionalZoom) {
+                var fDeltaX = extent.right - extent.left;
+                var fDeltaY = extent.top - extent.bottom;
+                var fMinX,fMaxX,fMinY,fMaxY;
+                if (nFactor > 0) {
+                    /*zoomin*/
+                    fMinX = fX - (fDeltaX/2 / nFactor);
+                    fMaxX = fX + (fDeltaX/2 / nFactor);
+                    fMinY = fY - (fDeltaY/2 / nFactor);
+                    fMaxY = fY + (fDeltaY/2 / nFactor);
+                } else if (nFactor < 0) {
+                    /*zoomout*/
+                    fMinX = fX - ((fDeltaX/2) * Math.abs(nFactor));
+                    fMaxX = fX + ((fDeltaX/2) * Math.abs(nFactor));
+                    fMinY = fY - ((fDeltaY/2) * Math.abs(nFactor));
+                    fMaxY = fY + ((fDeltaY/2) * Math.abs(nFactor));
+                this.setExtents(new OpenLayers.Bounds(fMinX, fMinY, fMaxX, fMaxY));
+            } else {
+                var currentZoomLevel = this.oMapOL.getZoom();
+                if (nFactor > 1) {
+                    this.oMapOL.zoomTo(currentZoomLevel+1);
+                } else if (nFactor < 1) {
+                    this.oMapOL.zoomTo(currentZoomLevel-1);
     zoomToScale: function(fScale) {
@@ -666,8 +680,57 @@
         return (nPixels*resolution);
+     * initializes the meters per unit values when a new map is loaded.  Some systems make different
+     * assumptions for the conversion of degrees to meters so this makes sure both Fusion and
+     * OpenLayers are using the same value.
+     * @param metersPerUnit the value returned by LoadMap.php for meters per unit
+    setMetersPerUnit: function(metersPerUnit) {
+        if (this._fMetersperunit < 0) {
+            Fusion.initUnits(metersPerUnit);
+            this._fMetersperunit = metersPerUnit;
+        } else {
+            if (metersPerUnit != this._fMetersperunit) {
+                                    'meters per unit value already set'));
+     * returns the meters per unit value
+     * @return metersPerUnit the value as set when the map initialized
+    getMetersPerUnit: function() {
+        return this._fMetersperunit;
+     * initializes all widgets with the map units after the map has loaded
+    setViewOptions: function(data) {
+      for (var i=0; i<Fusion.applicationDefinition.widgetSets.length; ++i) {
+        var widgetSet = Fusion.applicationDefinition.widgetSets[i];
+        for (var j=0; j<widgetSet.widgetInstances.length; ++j) {
+          var widget = widgetSet.widgetInstances[j];
+          for (var k=0; k<widget.paramRegister.length; ++k) {
+            if (widget.paramRegister[k] == 'Units') {
+              widget.setParameter('Units', data);
      * convert geographic into pixels.
      * @param fGeo float distance in geographic units
@@ -731,7 +794,7 @@
     getScale : function() {
-    return Math.round(this.oMapOL.getScale());
+        return this.oMapOL.getScale();
     getResolution : function() {
@@ -868,7 +931,7 @@
  * Utility class to hold slection information
-var GxSelectionObject = OpenLayers.Class({
+Fusion.SelectionObject = OpenLayers.Class({
     aLayers : null,
     initialize: function(o)
@@ -887,7 +950,7 @@
             this.nLayers =  o.layers.length;
             for (var i=0; i<o.layers.length; i++)
-                this.aLayers[i] = new GxSelectionObjectLayer(o, o.layers[i]);
+                this.aLayers[i] = new Fusion.SelectionObject.Layer(o, o.layers[i]);
@@ -941,7 +1004,7 @@
-var GxSelectionObjectLayer = OpenLayers.Class({
+Fusion.SelectionObject.Layer = OpenLayers.Class({
     sName: null,
     nElements: null,
     aElements: null,
Modified: sandbox/olcore/lib/OpenLayers/OpenLayers.js
--- sandbox/olcore/lib/OpenLayers/OpenLayers.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/OpenLayers/OpenLayers.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -43,15 +43,24 @@
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
 var OpenLayers={singleFile:true};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);window.OpenLayers={_scriptName:(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js",_getScriptLocation:function(){var scriptLocation="";var scriptName=OpenLayers._scriptName;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);var pathLength=src.lastIndexOf('?');if(pathLength<0){pathLength=src.length;}
 if((index>-1)&&(index+scriptName.length==pathLength)){scriptLocation=src.slice(0,pathLength-scriptName.length);break;}}}
-return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
+return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Request.js","OpenLayers/Request/XMLHttpRequest.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
 var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0;i<jsfiles.length;i++){if(docWrite){allScriptTags[i]="<script src='"+host+jsfiles[i]+"'></script>";}else{var s=document.createElement("script");s.src=host+jsfiles[i];var h=document.getElementsByTagName("head").length?document.getElementsByTagName("head")[0]:document.body;h.appendChild(s);}}
 if(docWrite){document.write(allScriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="$Revision$";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s*(.*?)\s*$/,"$1");},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1;i<oStringList.length;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
 return camelizedString;},format:function(template,context,args){if(!context){context=window;}
 var tokens=template.split("${");var item,last,replacement;for(var i=1;i<tokens.length;i++){item=tokens[i];last=item.indexOf("}");if(last>0){replacement=context[item.substring(0,last)];if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
 tokens[i]=replacement+item.substring(++last);}else{tokens[i]="${"+item;}}
-return tokens.join("");}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+return tokens.join("");},numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
 if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
 if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
 if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
@@ -74,7 +83,7 @@
 if(arguments.length==1){return element;}
 elements.push(element);}
 return elements;};if($==null){var $=OpenLayers.Util.getElement;}
-OpenLayers.Util.extend=function(destination,source){if(destination&&source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
 var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
 return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
 return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj){return i;}}
@@ -93,12 +102,13 @@
 image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
 return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.backgroundColor=null;this.style.display="";}};OpenLayers.Util.onImageLoadErrorColor="pink";OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.src=this.src;}else{this.style.backgroundColor=OpenLayers.Util.onImageLoadErrorColor;}
 this.style.display="";};OpenLayers.Util.alphaHack=function(){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
-return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,null,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
-OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){div.style.display="inline-block";if(sizing==null){sizing="scale";}
+return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,position,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){if(div.style.display!="none"){div.style.display="inline-block";}
+if(sizing==null){sizing="scale";}
 div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
 img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
 OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
-return uObject;};OpenLayers.Util.applyDefaults=function(to,from){var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){to=to||{};var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
 if(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
 return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];for(var itemIndex=0;itemIndex<value.length;itemIndex++){encodedItemArray.push(encodeURIComponent(value[itemIndex]));}
 encodedValue=encodedItemArray.join(",");}
@@ -143,33 +153,13 @@
 if((urlObject.protocol=="file:")||(urlObject.protocol=="")){urlObject.host="localhost";}
 return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
 return head;};OpenLayers.Util.getBrowserName=function(){var browserName="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){browserName="opera";}else if(ua.indexOf("msie")!=-1){browserName="msie";}else if(ua.indexOf("safari")!=-1){browserName="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){browserName="firefox";}else{browserName="mozilla";}}
-return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w=h=null;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=container.style.width=size.w;}else if(size.h){h=container.style.height=size.h;}}
+return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w,h;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=size.w;container.style.width=w+"px";}else if(size.h){h=size.h
+container.style.height=h+"px";}}
 var content=document.createElement("div");content.innerHTML=contentHTML;container.appendChild(content);document.body.appendChild(container);if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
 if(!h){h=parseInt(content.scrollHeight);}
 container.removeChild(content);document.body.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
-return scrollbarWidth;};OpenLayers.Rico=new Object();OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
-var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
-this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColor){if(this.options.border){this._renderBorder(e,bgColor);}
-if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
-if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
-el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
-el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
-else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
-if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
-this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
-if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
-if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
-return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
-if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
-if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
-return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
-else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
-else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
-else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
-else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
-if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
-var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
-return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){var success=(onComplete)?OpenLayers.Function.bind(onComplete,caller):OpenLayers.nullHandler;var failure=(onFailure)?OpenLayers.Function.bind(onFailure,caller):OpenLayers.nullHandler;var request=new OpenLayers.Ajax.Request(uri,{method:'get',parameters:params,onComplete:success,onFailure:failure});return request.transport;};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+return scrollbarWidth;};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){if(typeof params=='string'){params=OpenLayers.Util.getParameters(params);}
+var success=(onComplete)?onComplete:OpenLayers.nullHandler;var failure=(onFailure)?onFailure:OpenLayers.nullHandler;return OpenLayers.Request.GET({url:uri,params:params,success:success,failure:failure,scope:caller});};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
 var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
 req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
 this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
@@ -186,7 +176,8 @@
 if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
 if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
 if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
+return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
 if(bottom!=null){this.bottom=parseFloat(bottom);}
 if(right!=null){this.right=parseFloat(right);}
 if(top!=null){this.top=parseFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
@@ -218,8 +209,7 @@
 return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(parseFloat(pair[0]),parseFloat(pair[1]));};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
 return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
 return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
-return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
-return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
 this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
 this.events.destroy();this.events=null;}
 this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
@@ -243,43 +233,16 @@
 if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
 OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
 if(context){message=OpenLayers.String.format(message,context);}
-return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,size:null,contentHTML:"",backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,padding:0,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,map:null,initialize:function(id,lonlat,size,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
-this.id=id;this.lonlat=lonlat;this.size=(size!=null)?size:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
-this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className='olPopup';var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.size.clone(),null,"relative");this.contentDiv.className='olPopupContent';this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
-this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
-this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
-this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
-if(OpenLayers.Util.getBrowserName()=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
-this.moveTo(px);if(!this.autoSize){this.setSize(this.size);}
-this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
-return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){OpenLayers.Element.show(this.div);if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){OpenLayers.Element.hide(this.div);},setSize:function(size){this.size=size;var contentSize=this.size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.Util.getBrowserName()=="msie"){contentSize.w+=contentDivPadding.left+contentDivPadding.right;contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
-if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
-if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
-if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
-if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
-if(this.autoSize){var realSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML);var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML,fixedSize);var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
-newSize=this.getSafeContentSize(clippedSize);}}
-this.setSize(newSize);}
-if(this.contentDiv!=null){this.contentDiv.innerHTML=this.contentHTML;}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
-if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
-if(this.map&&this.map.size){var maxY=this.map.size.h-
-this.map.paddingForPopups.top-
-this.map.paddingForPopups.bottom-
-hPadding;var maxX=this.map.size.w-
-this.map.paddingForPopups.left-
-this.map.paddingForPopups.right-
-wPadding;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
-return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){this.div.style.display="none";document.body.appendChild(this.div);contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;document.body.removeChild(this.div);this.div.style.display="";}
-return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
-if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
-if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
-if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Renderer=OpenLayers.Class({container:null,extent:null,size:null,resolution:null,map:null,initialize:function(containerID){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent){this.extent=extent.clone();this.resolution=null;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
-if(feature.geometry){this.drawGeometry(feature.geometry,style,feature.id);}},drawGeometry:function(geometry,style,featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=0;i<features.length;++i){this.eraseGeometry(features[i].geometry);}},eraseGeometry:function(geometry){},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=config.url;if(config.params){url+="?"+OpenLayers.Util.getParameterString(config.params);}
+if(config.proxy&&(url.indexOf("http")==0)){url=config.proxy+encodeURIComponent(url);}
+request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
+var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
+var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
+request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){complete(request);if(success&&request.status>=200&&request.status<300){success(request);}
+if(failure&&(request.status<200||request.status>=300)){failure(request);}}}
+request.send(config.data);return request;},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
 if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
 this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
 if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
@@ -287,110 +250,31 @@
 var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
 this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
 if(this.time>this.duration){if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);this.playing=false;}
-window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
-shortHexCode.charAt(i));}}
-if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
-var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),"backgroundColor","background-color");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
-if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
-if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
-else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
-else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
-else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
-return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
-var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
-brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
-if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
-hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
-return{h:hue,s:saturation,b:brightness};};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
 break;}}
 if(i==this.map.controls.length){var args=OpenLayers.Util.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
 if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
 this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
-this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){attributions.push(layer.attribution);}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{activeColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[];},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();if(!this.outsideViewport){this.minimizeControl();}
-this.redraw();return this.div;},clearLayersArray:function(layersType){var layers=this[layersType+"Layers"];if(layers){for(var i=0;i<layers.length;i++){var layer=layers[i];OpenLayers.Event.stopObservingElement(layer.inputElem);OpenLayers.Event.stopObservingElement(layer.labelSpan);}}
-this[layersType+"LayersDiv"].innerHTML="";this[layersType+"Layers"]=[];},checkRedraw:function(){var redraw=false;if(!this.layerStates.length||(this.map.layers.length!=this.layerStates.length)){redraw=true;}else{for(var i=0;i<this.layerStates.length;i++){var layerState=this.layerStates[i];var layer=this.map.layers[i];if((layerState.name!=layer.name)||(layerState.inRange!=layer.inRange)||(layerState.id!=layer.id)||(layerState.visibility!=layer.visibility)){redraw=true;break;}}}
-return redraw;},redraw:function(){if(!this.checkRedraw()){return this.div;}
-this.clearLayersArray("base");this.clearLayersArray("data");var containsOverlays=false;var containsBaseLayers=false;this.layerStates=new Array(this.map.layers.length);for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];this.layerStates[i]={'name':layer.name,'visibility':layer.visibility,'inRange':layer.inRange,'id':layer.id};}
-var layers=this.map.layers.slice();if(!this.ascending){layers.reverse();}
-for(var i=0;i<layers.length;i++){var layer=layers[i];var baseLayer=layer.isBaseLayer;if(layer.displayInLayerSwitcher){if(baseLayer){containsBaseLayers=true;}else{containsOverlays=true;}
-var checked=(baseLayer)?(layer==this.map.baseLayer):layer.getVisibility();var inputElem=document.createElement("input");inputElem.id="input_"+layer.name;inputElem.name=(baseLayer)?"baseLayers":layer.name;inputElem.type=(baseLayer)?"radio":"checkbox";inputElem.value=layer.name;inputElem.checked=checked;inputElem.defaultChecked=checked;if(!baseLayer&&!layer.inRange){inputElem.disabled=true;}
-var context={'inputElem':inputElem,'layer':layer,'layerSwitcher':this};OpenLayers.Event.observe(inputElem,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var labelSpan=document.createElement("span");if(!baseLayer&&!layer.inRange){labelSpan.style.color="gray";}
-labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
-this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
-OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0;i<this.baseLayers.length;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
-for(var i=0;i<this.dataLayers.length;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="20em";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){this.div.style.position="absolute";this.div.style.top="25px";this.div.style.right="0px";this.div.style.left="";this.div.style.fontFamily="sans-serif";this.div.style.fontWeight="bold";this.div.style.marginTop="3px";this.div.style.marginLeft="3px";this.div.style.marginBottom="3px";this.div.style.fontSize="smaller";this.div.style.color="white";this.div.style.backgroundColor="transparent";OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layersDiv=document.createElement("div");this.layersDiv.id="layersDiv";this.layersDiv.style.paddingTop="5px";this.layersDiv.style.paddingLeft="10px";this.layersDiv.style.paddingBottom="5px";this.layersDiv.style.paddingRight="75px";this.layersDiv.style.backgroundColor=this.activeColor;this.layersDiv.style.width="100%";this.layersDiv.style.height="100%";this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");this.baseLbl.style.marginTop="3px";this.baseLbl.style.marginLeft="3px";this.baseLbl.style.marginBottom="3px";this.baseLayersDiv=document.createElement("div");this.baseLayersDiv.style.paddingLeft="10px";this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");this.dataLbl.style.marginTop="3px";this.dataLbl.style.marginLeft="3px";this.dataLbl.style.marginBottom="3px";this.dataLayersDiv=document.createElement("div");this.dataLayersDiv.style.paddingLeft="10px";if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);}
-this.div.appendChild(this.layersDiv);OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.activeColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");this.maximizeDiv.style.top="5px";this.maximizeDiv.style.right="0px";this.maximizeDiv.style.left="";this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");this.minimizeDiv.style.top="5px";this.minimizeDiv.style.right="0px";this.minimizeDiv.style.left="";this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
-this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();}
-this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
-this.removeZoomBox();}},removeZoomBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
-elem=elem.parentNode;}
-if(inMap){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
-OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numdigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
+this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
 this.redraw();return this.div;},redraw:function(evt){var lonLat;if(evt==null){lonLat=new OpenLayers.LonLat(0,0);}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
 {this.lastXy=evt.xy;return;}
 lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
 if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
 this.lastXy=evt.xy;}
-var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numdigits);var newHtml=this.prefix+
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
 lonLat.lon.toFixed(digits)+
 this.separator+
 lonLat.lat.toFixed(digits)+
-this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,activateOnDraw:true,clearOnDeactivate:false,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.registry=OpenLayers.Util.extend({"moveend":function(){return{center:this.map.getCenter(),resolution:this.map.getResolution()};}},this.registry);this.clear();var previousOptions={trigger:OpenLayers.Function.bind(this.previousTrigger,this),displayClass:this.displayClass+"Previous"};OpenLayers.Util.extend(previousOptions,this.previousOptions);this.previous=new OpenLayers.Control.Button(previousOptions);var nextOptions={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+"Next"};OpenLayers.Util.extend(nextOptions,this.nextOptions);this.next=new OpenLayers.Control.Button(nextOptions);},onPreviousChange:function(state,length){if(state&&!this.previous.active){this.previous.activate();}else if(!state&&this.previous.active){this.previous.deactivate();}},onNextChange:function(state,length){if(state&&!this.next.active){this.next.activate();}else if(!state&&this.next.active){this.next.deactivate();}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var prop in this){this[prop]=null;}},setMap:function(map){this.map=map;this.next.setMap(map);this.previous.setMap(map);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw();if(this.activateOnDraw){this.activate();}},previousTrigger:function(){var current=this.previousStack.shift();var state=this.previousStack.shift();if(state!=undefined){this.nextStack.unshift(current);this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}else{this.previousStack.unshift(current);}
-return state;},nextTrigger:function(){var state=this.nextStack.shift();if(state!=undefined){this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-return state;},clear:function(){this.previousStack=[];this.nextStack=[];},restore:function(state){var zoom=this.map.getZoomForResolution(state.resolution);this.map.setCenter(state.center,zoom);},setListeners:function(){this.listeners={};for(var type in this.registry){this.listeners[type]=OpenLayers.Function.bind(function(){if(!this.restoring){var state=this.registry[type].apply(this,arguments);this.previousStack.unshift(state);if(this.previousStack.length>1){this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-if(this.previousStack.length>(this.limit+1)){this.previousStack.pop();}
-if(this.nextStack.length>0){this.nextStack=[];this.onNextChange(null,0);}}
-return true;},this);}},activate:function(){var activated=false;if(this.map){if(OpenLayers.Control.prototype.activate.apply(this)){if(this.listeners==null){this.setListeners();}
-for(var type in this.listeners){this.map.events.register(type,this,this.listeners[type]);}
-activated=true;if(this.previousStack.length==0){this.initStack();}}}
-return activated;},initStack:function(){if(this.map.getCenter()){this.listeners.moveend();}},deactivate:function(){var deactivated=false;if(this.map){if(OpenLayers.Control.prototype.deactivate.apply(this)){for(var type in this.listeners){this.map.events.unregister(type,this,this.listeners[type]);}
-if(this.clearOnDeactivate){this.clear();}
-deactivated=true;}}
-return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
+this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
 this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_PanZoom_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;btn.slideFactor=this.slideFactor;this.buttons.push(btn);return btn;},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
 switch(this.action){case"panup":this.map.pan(0,-this.slideFactor);break;case"pandown":this.map.pan(0,this.slideFactor);break;case"panleft":this.map.pan(-this.slideFactor,0);break;case"panright":this.map.pan(this.slideFactor,0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
-OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,defaultControl:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){if(this.controls[i]==this.defaultControl){this.controls[i].activate();}}
-this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){this.controls[i].deactivate();}
-return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);for(var i=0;i<this.controls.length;i++){this.map.addControl(this.controls[i]);this.controls[i].deactivate();this.controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.activate();return this.div;},redraw:function(){this.div.innerHTML="";if(this.active){for(var i=0;i<this.controls.length;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
-this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
-if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
-if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
-return;}
-for(var i=0;i<this.controls.length;i++){if(this.controls[i]!=control){if(this.controls[i].type!=OpenLayers.Control.TYPE_TOGGLE){this.controls[i].deactivate();}}}
-control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
-this.controls=this.controls.concat(controls);for(var i=0;i<controls.length;i++){var element=document.createElement("div");var textNode=document.createTextNode(" ");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
-OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
-if(this.map){for(var i=0;i<controls.length;i++){this.map.addControl(controls[i]);controls[i].deactivate();controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.redraw();}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{element:null,base:'',displayProjection:null,initialize:function(element,base,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
-this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if(control.CLASS_NAME=="OpenLayers.Control.ArgParser"){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){this.map.addControl(new OpenLayers.Control.ArgParser({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
-this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});return this.div;},updateLink:function(){var center=this.map.getCenter();if(!center){return;}
-var params=OpenLayers.Util.getParameters(this.base);params.zoom=this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
-params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;params.layers='';for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}
-var href=this.base;if(href.indexOf('?')!=-1){href=href.substring(0,href.indexOf('?'));}
-href+='?'+OpenLayers.Util.getParameterString(params);this.element.href=href;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
-this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale=this.map.getScale();if(!scale){return;}
-if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
 this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
 this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
 return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
-var curMapUnits=this.map.units;var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
-var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+var curMapUnits=this.map.getUnits();var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
+var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
 if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
 return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
 if(!this.observers){this.observers={};}
@@ -417,90 +301,41 @@
 return continueChain;},handleBrowserEvent:function(evt){evt.xy=this.getMousePosition(evt);this.triggerEvent(evt.type,evt);},getMousePosition:function(evt){if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);this.element.offsets[0]+=(document.documentElement.scrollLeft||document.body.scrollLeft);this.element.offsets[1]+=(document.documentElement.scrollTop||document.body.scrollTop);}
 return new OpenLayers.Pixel((evt.clientX+(document.documentElement.scrollLeft||document.body.scrollLeft))-this.element.offsets[0]
 -(document.documentElement.clientLeft||0),(evt.clientY+(document.documentElement.scrollTop||document.body.scrollTop))-this.element.offsets[1]
--(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Format=OpenLayers.Class({externalProjection:null,internalProjection:null,initialize:function(options){OpenLayers.Util.extend(this,options);},read:function(data){alert(OpenLayers.i18n("readNotImplemented"));},write:function(object){alert(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was either not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,anchor:null,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=new Array(id,lonlat,size,contentHTML,closeBox,closeBoxCallback);OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePosition!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(size){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-this.size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-this.size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+-(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
 OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,xmlns:null,minimumSymbolizer:{strokeLinecap:"round",strokeOpacity:1,fillOpacity:1,pointRadius:0},initialize:function(containerID){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot();this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){if(this.root){while(this.root.childNodes.length>0){this.root.removeChild(this.root.firstChild);}}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
-return;};if(style.display!="none"){var nodeType=this.getNodeType(geometry,style);var node=this.nodeFactory(geometry.id,nodeType);node._featureId=featureId;node._geometryClass=geometry.CLASS_NAME;node._style=style;node=this.drawGeometryNode(node,geometry);if(node.parentNode!=this.root){this.root.appendChild(node);}
-this.postDraw(node);}else{node=OpenLayers.Util.getElement(geometry.id);if(node){node.parentNode.removeChild(node);}}},drawGeometryNode:function(node,geometry,style){style=style||node._style;OpenLayers.Util.applyDefaults(style,this.minimumSymbolizer);var options={'isFilled':true,'isStroked':!!style.strokeWidth};switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":this.drawRectangle(node,geometry);break;default:break;}
-node._style=style;node._options=options;return this.setStyle(node,style,options,geometry);},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},getFeatureIdFromEvent:function(evt){var node=evt.target||evt.srcElement;return node._featureId;},eraseGeometry:function(geometry){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.eraseGeometry(geometry.components[i]);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){element.parentNode.removeChild(element);}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
-return node;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
+return point;};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera;function cXMLHttpRequest(){this._object=oXMLHttpRequest?new oXMLHttpRequest:new window.ActiveXObject('Microsoft.XMLHTTP');};if(bGecko&&oXMLHttpRequest.wrapped)
+cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText="";cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText="";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){this._async=bAsync;var oRequest=this,nState=this.readyState;if(bIE){var fOnUnload=function(){if(oRequest._object.readyState!=cXMLHttpRequest.DONE)
+fCleanTransport(oRequest);};if(bAsync)
+window.attachEvent("onunload",fOnUnload);}
+this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
+return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
+if(oRequest.readyState==cXMLHttpRequest.DONE){fCleanTransport(oRequest);if(bIE&&bAsync)
+window.detachEvent("onunload",fOnUnload);}
+if(nState!=oRequest.readyState)
+fReadyStateChange(oRequest);nState=oRequest.readyState;};if(cXMLHttpRequest.onopen)
+cXMLHttpRequest.onopen.apply(this,arguments);this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);if(!bAsync&&bGecko){this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
+cXMLHttpRequest.onsend.apply(this,arguments);if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!this._headers["Content-Type"])
+this._object.setRequestHeader("Content-Type","application/xml");}
+this._object.send(vData);if(bGecko&&!this._async){this.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(this);while(this.readyState<cXMLHttpRequest.DONE){this.readyState++;fReadyStateChange(this);if(this._aborted)
+return;}}};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
+cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
+this._aborted=true;this._object.abort();fCleanTransport(this);};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
+this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(oRequest.onreadystatechange)
+oRequest.onreadystatechange.apply(oRequest);if(cXMLHttpRequest.onreadystatechange)
+cXMLHttpRequest.onreadystatechange.apply(oRequest);};function fGetDocument(oRequest){var oDocument=oRequest.responseXML;if(bIE&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new ActiveXObject('Microsoft.XMLDOM');oDocument.loadXML(oRequest.responseText);}
+if(oDocument)
+if((bIE&&oDocument.parseError!=0)||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
+return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
+try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
+try{oRequest.status=oRequest._object.status;}catch(e){}
+try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;delete oRequest._headers;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
 this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
 OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));var drawTile=(withinMaxExtent||this.layer.displayOutsideMaxExtent);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
 this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
 this.shouldDraw=drawTile;this.clear();return drawTile;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
 this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
-if(direction){this.direction=direction;}
-this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
-OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
-OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
-this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
-this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
-if(this.mode=="measure"&&mode!="measure"){for(var i=0;i<this.measureDivs.length;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
-this.measureDivs=[];this.measureStart=null;}
-this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
-switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
-break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
-this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoomBarDiv:null,divEvents:null,zoomWorldIcon:false,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this.div.removeChild(this.slider);this.slider=null;this.sliderEvents.destroy();this.sliderEvents=null;this.div.removeChild(this.zoombarDiv);this.zoomBarDiv=null;this.divEvents.destroy();this.divEvents=null;this.map.events.un({"zoomend":this.moveZoomBar,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.div.innerHTML="";}
-this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
-this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
-this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id="OpenLayers_Control_PanZoomBar_Slider"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true);this.sliderEvents.on({"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id="OpenLayers_Control_PanZoomBar"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h;}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
-this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true);this.divEvents.on({"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var y=evt.xy.y;var top=OpenLayers.Util.pagePosition(evt.object)[1];var levels=(y-top)/this.zoomStopHeight;if(!this.map.fractionalZoom){levels=Math.floor(levels);}
-var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.map.events.on({"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";}
-this.mouseDragStart=evt.xy.clone();OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomStart){this.div.style.cursor="";this.map.events.un({"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var deltaY=this.zoomStart.y-evt.xy.y;var zoomLevel=this.map.zoom;if(this.map.fractionalZoom){zoomLevel+=deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=Math.round(deltaY/this.zoomStopHeight);}
-this.map.zoomTo(zoomLevel);this.moveZoomBar();this.mouseDragStart=null;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(json,filter){try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){var object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
-return filter(k,v);}
-object=walk('',object);}
-return object;}}catch(e){}
-return null;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){json=this.serialize[type].apply(this,[value]);}
-return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
-return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
-if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
-if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
-var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0;i<array.length;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),json);}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
-c=b.charCodeAt();return'\\u00'+
-Math.floor(c/16).toString(16)+
-(c%16).toString(16);})+'"';}
-return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
-return'"'+date.getFullYear()+'-'+
-format(date.getMonth()+1)+'-'+
-format(date.getDate())+'T'+
-format(date.getHours())+':'+
-format(date.getMinutes())+':'+
-format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
-OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
-xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
-doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
-return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
-return element;},createTextNode:function(text){var node;if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
-return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0;i<allNodes.length;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
-return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0;i<attributes.length;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
-return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
-return attributeValue;},getChildValue:function(node,def){var value;try{value=node.firstChild.nodeValue;}catch(e){value=(def!=undefined)?def:"";}
-return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
-child=child.nextSibling;}
-if(value==""&&def!=undefined){value=def;}
-return value;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
-return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
 OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
 var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
@@ -549,9 +384,9 @@
 return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
 if(resolution==null){resolution=this.getResolution();}
 if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
-return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){if(!options){options={};}
-OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCenter();var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCenter();if(lonlat.lon==center.lon&&lonlat.lat==center.lat){return;}
+var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
 var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
 if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
 if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
@@ -581,7 +416,8 @@
 return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
 return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
 return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}
-return resolution;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
 return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
 return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
 return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
@@ -594,61 +430,7 @@
 return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
 this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
 this.lonlat=this.map.getLonLatFromLayerPx(px);},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
-this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
-this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
-block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
-block.div=null;}
-this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
-this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
-this.padding.top+"px";}
-this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
-var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
-if(this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=w+'px';block.div.style.height=h+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",MAX_PIXEL:15000,localResolution:null,initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y){return(x>=-this.MAX_PIXEL&&x<=this.MAX_PIXEL&&y>=-this.MAX_PIXEL&&y<=this.MAX_PIXEL);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(!this.localResolution||resolution!=this.localResolution){this.left=-extent.left/resolution;this.top=extent.top/resolution;}
-var left=0;var top=0;if(this.localResolution&&resolution==this.localResolution){left=(this.left)-(-extent.left/resolution);top=(this.top)-(extent.top/resolution);}
-this.localResolution=resolution;var extentString=left+" "+top+" "+
-extent.getWidth()/resolution+" "+extent.getHeight()/resolution;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"image":"circle";break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
-return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){if(style.externalGraphic){var x=parseFloat(node.getAttributeNS(null,"cx"));var y=parseFloat(node.getAttributeNS(null,"cy"));if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(x+xOffset).toFixed());node.setAttributeNS(null,"y",(y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS("http://www.w3.org/1999/xlink","href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);}else{node.setAttributeNS(null,"r",style.pointRadius);}}
-if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
-if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap);}else{node.setAttributeNS(null,"stroke","none");}
-if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
-if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
-return node;},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
-return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","g");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);}else{node.setAttributeNS(null,"cx","");node.setAttributeNS(null,"cy","");node.setAttributeNS(null,"r",0);}},drawLineString:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawLinearRing:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawPolygon:function(node,geometry){var d="";var draw=true;for(var j=0;j<geometry.components.length;j++){var linearRing=geometry.components[j];d+=" M";for(var i=0;i<linearRing.components.length;i++){var component=this.getShortString(linearRing.components[i]);if(component){d+=" "+component;}else{draw=false;}}}
-d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");}else{node.setAttributeNS(null,"d","");}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);}else{node.setAttributeNS(null,"x","");node.setAttributeNS(null,"y","");node.setAttributeNS(null,"width",0);node.setAttributeNS(null,"height",0);}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0;i<geometry.components.length;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" "+component;}}
-d+=" Z";if(draw){node.setAttributeNS(null,"d",d);}else{node.setAttributeNS(null,"d","");}},getComponentsString:function(components){var strings=[];for(var i=0;i<components.length;i++){var component=this.getShortString(components[i]);if(component){strings.push(component);}}
-return strings.join(",");},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",initialize:function(containerID){if(!this.supported()){return;}
-if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var org=extent.left/resolution+" "+
-extent.top/resolution;this.root.setAttribute("coordorigin",org);var size=extent.getWidth()/resolution+" "+
--extent.getHeight()/resolution;this.root.setAttribute("coordsize",size);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.style.width=this.size.w;this.rendererRoot.style.height=this.size.h;this.root.style.width=this.size.w;this.root.style.height=this.size.h;},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"olv:rect":"olv:oval";break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
-return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;if(node._geometryClass=="OpenLayers.Geometry.Point"){if(style.externalGraphic){var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=((geometry.x/resolution)+xOffset).toFixed();node.style.top=((geometry.y/resolution)-(yOffset+height)).toFixed();node.style.width=width;node.style.height=height;style.fillColor="none";options.isStroked=false;}else{this.drawCircle(node,geometry,style.pointRadius);}}
-if(options.isFilled){node.setAttribute("fillcolor",style.fillColor);}else{node.setAttribute("filled","false");}
-var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
-fill.setAttribute("opacity",style.fillOpacity);if(node._geometryClass=="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.setAttribute("opacity",style.graphicOpacity);}
-fill.setAttribute("src",style.externalGraphic);fill.setAttribute("type","frame");node.style.flip="y";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
-if(fill.parentNode!=node){node.appendChild(fill);}}
-if(options.isStroked){node.setAttribute("strokecolor",style.strokeColor);node.setAttribute("strokeweight",style.strokeWidth+"px");}else{node.setAttribute("stroked","false");}
-var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){if(stroke){node.removeChild(stroke);}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
-stroke.setAttribute("opacity",style.strokeOpacity);stroke.setAttribute("endcap",!style.strokeLinecap||style.strokeLinecap=='butt'?'flat':style.strokeLinecap);}
-if(style.cursor!=null){node.style.cursor=style.cursor;}
-return node;},postDraw:function(node){var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.getAttribute("fillcolor")!=fillColor){node.setAttribute("fillcolor",fillColor);}
-if(strokeColor=="none"&&node.getAttribute("strokecolor")!=strokeColor){node.setAttribute("strokecolor",strokeColor);}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution).toFixed(),(bbox.bottom/resolution).toFixed(),(bbox.right/resolution).toFixed(),(bbox.top/resolution).toFixed());node.style.left=scaledBox.left;node.style.top=scaledBox.top;node.style.width=scaledBox.getWidth();node.style.height=scaledBox.getHeight();node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},createNode:function(type,id){var node=document.createElement(type);if(id){node.setAttribute('id',id);}
-node.setAttribute('unselectable','on',0);node.onselectstart=function(){return(false);};return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
-var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
-return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","olv:group");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(geometry.x/resolution).toFixed()-radius;node.style.top=(geometry.y/resolution).toFixed()-radius;var diameter=radius*2;node.style.width=diameter;node.style.height=diameter;}},drawLineString:function(node,geometry){this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution);y=(comp.y/resolution);parts[i]=" "+x.toFixed()+","+y.toFixed()+" l ";}
-var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var linearRing,i,comp,x,y;for(var j=0;j<geometry.components.length;j++){linearRing=geometry.components[j];path.push("m");for(i=0;i<linearRing.components.length;i++){comp=linearRing.components[i];x=comp.x/resolution;y=comp.y/resolution;path.push(" "+x.toFixed()+","+y.toFixed());if(i==0){path.push(" l");}}
-path.push(" x ");}
-path.push("e");node.path=path.join("");},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=geometry.x/resolution;node.style.top=geometry.y/resolution;node.style.width=geometry.width/resolution;node.style.height=geometry.height/resolution;},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0;i<geometry.components.length;i++){comp=geometry.components[i];x=comp.x/resolution;y=comp.y/resolution;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
-path.push(" "+x+","+y);}
-path.push(" x e");node.path=path.join("");},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
+return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
 if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}}
 this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
 this.frame=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
@@ -664,12 +446,7 @@
 var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
 if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
 OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
-this.request=OpenLayers.loadURL(this.url,null,this,success);},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(request.responseText);}
-if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var resultFeatures=OpenLayers.Ajax.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","gml","featureMember");this.addResults(resultFeatures);}}
-if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
+this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
 this.handlers.click.destroy();this.mapDiv.removeChild(this.extentRectangle);this.extentRectangle=null;this.rectEvents.destroy();this.rectEvents=null;this.ovmap.destroy();this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
 if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
 this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
@@ -681,44 +458,12 @@
 this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
 this.ovmap.setCenter(this.map.center,this.ovmap.getZoomForResolution(targetRes));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
 parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.units!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.getUnits()!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
 var pxBounds=this.getRectBoundsFromMapBounds(this.map.getExtent());if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
 this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
 this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
 return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat)));}
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
-this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
-if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
-return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){var id=this.id+"_popup";var anchor=(this.marker)?this.marker.icon:null;if(!this.popup){this.popup=new this.popupClass(id,this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
-if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
-this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.Format.WMC=OpenLayers.Class({defaultVersion:"1.1.0",version:null,layerOptions:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+
-version;}
-this.parser=new format(this.options);}
-var context=this.parser.read(data,options);var map;if(options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{map=this.contextToMap(context,options.map);}}else{map=context;}
-return map;},contextToMap:function(context,id){var map=new OpenLayers.Map(id,{maxExtent:context.maxExtent,projection:context.projection});map.addLayers(context.layers);map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(context.layers);return map;},write:function(obj,options){if(obj.CLASS_NAME=="OpenLayers.Map"){obj=this.mapToContext(obj);}
-var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMS capabilities parser for version "+
-version;}
-var wmc=this.parser.write(obj,options);return wmc;},mapToContext:function(map){var context={bounds:map.getExtent(),maxExtent:map.maxExtent,projection:map.projection,layers:map.layers,size:map.getSize()};return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
-return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layers=[];this.runChildNodes(context,node);},read_wmc_Layer:function(context,node){var layerInfo={params:{},options:{visibility:(node.getAttribute("hidden")!="1")},queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[]};this.runChildNodes(layerInfo,node);layerInfo.params.layers=layerInfo.name;layerInfo.options.maxExtent=layerInfo.maxExtent;var layer=this.getLayerFromInfo(layerInfo);context.layers.push(layer);},getLayerFromInfo:function(layerInfo){var options=layerInfo.options;if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
-var layer=new OpenLayers.Layer.WMS(layerInfo.title,layerInfo.href,layerInfo.params,options);return layer;},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerInfo,node){layerInfo.options.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerInfo,node){layerInfo.params.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerInfo,node){layerInfo.options.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerInfo,node){layerInfo.options.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerInfo,node){layerInfo.options.singleTile=(this.getChildValue(node)=="true");},read_ol_isBaseLayer:function(layerInfo,node){layerInfo.options.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerInfo,node){layerInfo.options.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerInfo,node){layerInfo.params.version=node.getAttribute("version");this.runChildNodes(layerInfo,node);},read_wmc_FormatList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Format:function(layerInfo,node){var format=this.getChildValue(node);layerInfo.formats.push(format);if(node.getAttribute("current")=="1"){layerInfo.params.format=format;}},read_wmc_StyleList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Style:function(layerInfo,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){if(style.href){layerInfo.params.sld=style.href;}else if(style.body){layerInfo.params.sld_body=style.body;}else{layerInfo.params.styles=style.name;}}
-layerInfo.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LatLonBoundingBox:function(layer,node){layer.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height')};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(legend,links[0]);}
-style.legend=legend;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS(this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
-if(attributes){this.setAttributes(node,attributes);}
-return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
-var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));node.appendChild(this.write_ol_MapExtension(context));return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);}
-return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");var layer;for(var i=0;i<context.layers.length;++i){layer=context.layers[i];if(layer instanceof OpenLayers.Layer.WMS){list.appendChild(this.write_wmc_Layer(layer));}}
-return list;},write_wmc_Layer:function(layer){var node=this.createElementDefaultNS("Layer",null,{queryable:"1",hidden:layer.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(layer));node.appendChild(this.createElementDefaultNS("Name",layer.params["LAYERS"]));node.appendChild(this.createElementDefaultNS("Title",layer.name));node.appendChild(this.write_wmc_FormatList(layer));node.appendChild(this.write_wmc_StyleList(layer));node.appendChild(this.write_wmc_LayerExtension(layer));return node;},write_wmc_LayerExtension:function(layer){var node=this.createElementDefaultNS("Extension");var bounds=layer.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);var param=layer.params["TRANSPARENT"];if(param){var trans=this.createElementNS(this.namespaces.ol,"ol:transparent");trans.appendChild(this.createTextNode(param));node.appendChild(trans);}
-var properties=["numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0;i<properties.length;++i){child=this.createOLPropertyNode(layer,properties[i]);if(child){node.appendChild(child);}}
-return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
-return node;},write_wmc_Server:function(layer){var node=this.createElementDefaultNS("Server");this.setAttributes(node,{service:"OGC:WMS",version:layer.params["VERSION"]});node.appendChild(this.write_wmc_OnlineResource(layer.url));return node;},write_wmc_FormatList:function(layer){var node=this.createElementDefaultNS("FormatList");node.appendChild(this.createElementDefaultNS("Format",layer.params["FORMAT"],{current:"1"}));return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var style=this.createElementDefaultNS("Style",null,{current:"1"});if(layer.params["SLD"]){var sld=this.createElementDefaultNS("SLD");var link=this.write_wmc_OnlineResource(layer.params["SLD"]);sld.appendChild(link);style.appendChild(sld);}else if(layer.params["SLD_BODY"]){var sld=this.createElementDefaultNS("SLD");var body=layer.params["SLD_BODY"];var doc=OpenLayers.Format.XML.prototype.read.apply(this,[body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
-sld.appendChild(imported);style.appendChild(sld);}else{var name=layer.params["STYLES"]?layer.params["STYLES"]:this.defaultStyleName;style.appendChild(this.createElementDefaultNS("Name",name));style.appendChild(this.createElementDefaultNS("Title",this.defaultStyleTitle));}
-node.appendChild(style);return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
+return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
 this.clearTimer();}
 return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
 return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
@@ -734,22 +479,7 @@
 if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}
 return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickoutTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:true,layerIndex:null,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){this.triggerCallback(type,'out',[this.lastFeature]);this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
-this.lastFeature=this.feature;handled=true;}else{if(previouslyIn&&inNew||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(previouslyIn||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}}
-return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&mode=='out'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickoutTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.layerIndex=this.layer.div.style.zIndex;this.layer.div.style.zIndex=this.map.Z_INDEX_BASE['Popup']-1;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.layer&&this.layer.div){this.layer.div.style.zIndex=this.layerIndex;}
-this.feature=null;this.lastFeature=null;this.down=null;this.up=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
-return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
-return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
-Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keypress","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.observe(window,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.stopObserving(window,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt.charCode||evt.keyCode]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
 var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
 overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
 if(!overLayerDiv){for(var i=0;i<this.map.layers.length;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
@@ -797,103 +527,14 @@
 return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
 if(!width){width=2;}
 this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
-return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(676,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,80,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-668)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-668)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(600,660),initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className="olFramedCloudPopupContent";},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks)),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();this.over=true;this.map.div.style.cursor="move";}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();this.feature=null;this.map.div.style.cursor="default";}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();this.map.div.style.cursor="default";this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keypress":this.defaultKeyPress});this.activate();},defaultKeyPress:function(code){switch(code){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:this.map.zoomIn();break;case 45:this.map.zoomOut();break;case 107:this.map.zoomIn();break;case 109:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,state:null,style:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
-this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry.clone(),this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
-return onScreen;},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
-return atPoint;},destroyPopup:function(){},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"yellow",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"yellow",strokeOpacity:1,strokeLinecap:"round",strokeWidth:4,hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""}};OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
-OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerInfo,node){layerInfo.options.maxScale=this.getChildValue(node);},read_sld_MaxScaleDenominator:function(layerInfo,node){layerInfo.options.minScale=this.getChildValue(node);},write_wmc_Layer:function(layer){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[layer]);if(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(layer.maxScale.toPrecision(10)));node.insertBefore(minSD,node.childNodes[3]);}
-if(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(layer.minScale.toPrecision(10)));node.insertBefore(maxSD,node.childNodes[4]);}
-return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var deltaX=Math.abs(this.dragHandler.start.x-xy.x);var deltaY=Math.abs(this.dragHandler.start.y-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(xy.x<this.dragHandler.start.x){this.zoomBox.style.left=xy.x+"px";}
-if(xy.y<this.dragHandler.start.y){this.zoomBox.style.top=xy.y+"px";}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:new Object();},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options={displayInLayerSwitcher:false};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
-this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
-if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
-this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
-this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
-this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
-this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,dx,dy,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
-for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){this.layer.renderer.clear();this.layer.destroyFeatures();},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.Util.getBrowserName()=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
-this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);this.pane=null;}
-OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
-return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
-return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
-return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
-return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
-return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0;i<props.length;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
-if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
-var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(this.numZoomLevels!=null){this.numZoomLevels=Math.min(this.numZoomLevels,limitZoomLevels);}else{if(this.maxZoomLevel!=null){var zoomDiff=this.maxZoomLevel-this.minZoomLevel+1;this.numZoomLevels=Math.min(zoomDiff,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}}
-this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
-this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
-return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
-return zoom;},CLASS_NAME:"FixedZoomLevels.js"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
+return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);return this.redraw();},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0;i<paramString.length;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
 return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.tile.destroy();this.tile=null;}
-OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.options);}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
-OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
-this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.markers.length;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged||!this.drawn){for(var i=0;i<this.markers.length;i++){this.drawMarker(this.markers[i]);}
-this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
-if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);if((marker.icon!=null)&&(marker.icon.imageDiv!=null)&&(marker.icon.imageDiv.parentNode==this.div)){this.div.removeChild(marker.icon.imageDiv);marker.drawn=false;}}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{var markerImg=marker.draw(px);if(!marker.drawn){this.div.appendChild(markerImg);marker.drawn=true;}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0;i<this.markers.length;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
-return extent;},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.0339;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
-this.units="m";this.projection="EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};OpenLayers.Projection.addTransform("EPSG:4326","EPSG:900913",OpenLayers.Layer.SphericalMercator.projectForward);OpenLayers.Projection.addTransform("EPSG:900913","EPSG:4326",OpenLayers.Layer.SphericalMercator.projectInverse);OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature},this.callbacks);this.layer=layer;this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);this.layer.addFeatures([feature]);this.featureAdded(feature);},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,onSelect:function(){},onUnselect:function(){},geometryTypes:null,layer:null,callbacks:null,selectStyle:null,renderIntent:"select",handler:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.callbacks=OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.callbacks);var handlerOptions={geometryTypes:this.geometryTypes};this.handler=new OpenLayers.Handler.Feature(this,layer,this.callbacks,handlerOptions);},unselectAll:function(options){var feature;for(var i=this.layer.selectedFeatures.length-1;i>=0;--i){feature=this.layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||this.handler.evt[this.multipleKey];},toggleSelect:function(){return this.toggle||this.handler.evt[this.toggleKey];},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){if(this.hover&&(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)==-1)){this.select(feature);}},outFeature:function(feature){if(this.hover){this.unselect(feature);}},select:function(feature){this.layer.selectedFeatures.push(feature);var selectStyle=this.selectStyle||this.renderIntent;this.layer.drawFeature(feature,selectStyle);this.layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect(feature);},unselect:function(feature){this.layer.drawFeature(feature,"default");OpenLayers.Util.removeItem(this.layer.selectedFeatures,feature);this.layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect(feature);},setMap:function(map){this.handler.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
-if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&typeof features=="object"){for(var i=0;i<features.length;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
-return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
-var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
-for(var i=0;i<collection.length;++i){if(isCollection&&i>0){pieces.push(',');}
-geometry=collection[i].geometry;type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-data=this.extract[type].apply(this,[geometry]);pieces.push(type.toUpperCase()+'('+data+')');}
-if(isCollection){pieces.push(')');}
-return pieces.join('');},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
-return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[polygon.components[i]])+')');}
-return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push('('+
-this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
-return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<lines.length;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<rings.length;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0;i<polygons.length;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0;i<wktArray.length;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
-return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData);this.loaded=true;}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
-if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
-catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
-if(name){this.setName(name);}}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0;i<features.length;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
-var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
-contentHTML+=title;if(link){contentHTML+='</a>';}
-contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
-var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
-this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
-if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257],type:null,sphericalMercator:false,dragObject:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.addContainerPxFunction();if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{this.mapObject=new GMap2(this.div);if(typeof this.mapObject.getDragObject=="function"){this.dragObject=this.mapObject.getDragObject();}else{this.dragPanMapObject=null;}
-var poweredBy=this.div.lastChild;this.div.removeChild(poweredBy);this.pane.appendChild(poweredBy);poweredBy.className="olLayerGooglePoweredBy gmnoprint";poweredBy.style.left="";poweredBy.style.bottom="";var termsOfUse=this.div.lastChild;this.div.removeChild(termsOfUse);this.pane.appendChild(termsOfUse);termsOfUse.className="olLayerGoogleCopyright";termsOfUse.style.right="";termsOfUse.style.bottom="";}catch(e){OpenLayers.Console.error(e);}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);if(this.type!=null){this.map.events.register("moveend",this,this.setMapType);}},setMapType:function(){if(this.mapObject.getCenter()!=null){if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)==-1){this.mapObject.addMapType(this.type);}
-this.mapObject.setMapType(this.type);this.map.events.unregister("moveend",this,this.setMapType);}},onMapResize:function(){this.mapObject.checkResize();},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
-olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
-return olBounds;},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
-return moBounds;},addContainerPxFunction:function(){if((typeof GMap2!="undefined")&&!GMap2.prototype.fromLatLngToContainerPixel){GMap2.prototype.fromLatLngToContainerPixel=function(gLatLng){var gPoint=this.fromLatLngToDivPixel(gLatLng);var div=this.getContainer().firstChild.firstChild;gPoint.x+=div.offsetLeft;gPoint.y+=div.offsetTop;return gPoint;};}},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
 obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize().clone();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
@@ -902,7 +543,7 @@
 var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
 this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
 Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
-Math.max(1,2*this.buffer);var extent=this.map.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+Math.max(1,2*this.buffer);var extent=this.maxExtent;var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
 tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
 tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols)
 tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows)
@@ -912,471 +553,23 @@
 for(var i=0;i<tileQueue.length;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
 this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0;i<modelRow.length;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
 if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0;i<this.grid.length;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.map.getMaxExtent();var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
 maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unshift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
-return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData,onFail);this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var parser=new OpenLayers.Format.Text(options);features=parser.read(text);for(var i=0;i<features.length;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
-if(feature.style.graphicXOffset&&feature.style.graphicYOffset){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
-if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
-if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
-data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
-this.addMarker(marker);}
-if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w;veDiv.style.height=sz.h;this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
-if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",function(){return true;});}catch(e){}
-this.mapObject.HideDashboard();}
-if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:15,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
-this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
-return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lonlat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Style=OpenLayers.Class({name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,propertyStyles:null,initialize:function(style,options){this.rules=[];this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);OpenLayers.Util.extend(this,options);},destroy:function(){for(var i=0;i<this.rules.length;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0;i<rules.length;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0;i<elseRules.length;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}else{style.display="";}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=this.context||feature.attributes||feature.data;for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0;i<rules.length;i++){var symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){this.rules=this.rules.concat(rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0;i<prefixes.length;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon'];OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,mode:null,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer());this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,100];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle};this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);this.layer.events.on({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature){control.dragVertex.apply(control,[feature]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keypress:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer.events.un({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});this.layer=null;this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.selectControl.activate()&&this.handlers.keyboard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices);this.layer.removeFeatures(this.virtualVertices);this.vertices=[];this.dragControl.deactivate();if(this.feature&&this.feature.geometry){this.selectControl.unselect.apply(this.selectControl,[this.feature]);}
-this.selectControl.deactivate();this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},selectFeature:function(object){this.feature=object.feature;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);this.layer.events.triggerEvent("beforefeaturemodified",{feature:this.feature});},unselectFeature:function(object){this.layer.removeFeatures(this.vertices);this.vertices=[];this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(object.feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:object.feature});},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex){if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices);this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices);this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices);this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if((this.mode&OpenLayers.Control.ModifyFeature.RESHAPE)){this.collectVertices();}}},handleKeypress:function(code){if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.selectControl.renderIntent);this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0;i<geometry.components.length-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.vertices,{silent:true});this.layer.addFeatures(this.virtualVertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));geometry.resize(l1/l0,originGeometry);}};this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
 this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
 this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
 this.handlers.click.activate();this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){this.handlers.click=new OpenLayers.Handler.Click(this,{'dblclick':this.defaultDblClick},{'double':true,'stopDouble':true});this.dragPan=new OpenLayers.Control.DragPan({map:this.map});this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:OpenLayers.Handler.MOD_SHIFT});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown});this.activate();},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},wheelChange:function(evt,deltaZ){var newZoom=this.map.getZoom()+deltaZ;if(!this.map.isValidZoomLevel(newZoom)){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
-return this.bounds;},calculateBounds:function(){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
-return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,point){var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
-return intersection;};OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
 if(this.singleTile){OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';getVisParams=OpenLayers.Util.extend(getVisParams,params);new OpenLayers.Ajax.Request(this.url,{parameters:getVisParams,method:'get',asynchronous:false});}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams=OpenLayers.Util.extend(getVisParams,params);getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';url=this.getFullRequestString(getVisParams);OpenLayers.Request.GET({url:url,async:false});}
 url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}
 return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
 var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getArgs(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);if(arguments.length>0){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}
-if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
+return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.map.getZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-return url+path;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,format:'image/png',initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.map.zoom;function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
-return zeros.join('').substring(0,length-number.length)+number;}
-var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
 if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Rule=OpenLayers.Class({id:null,name:'default',title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.symbolizer={};OpenLayers.Util.extend(this,options);},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-return context;},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);break;}}}
-OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
-this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
-if(!this.styles[intent]){intent="default";}
-feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
-return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:case OpenLayers.Filter.Comparison.LESS_THAN:case OpenLayers.Filter.Comparison.GREATER_THAN:case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return this.binaryCompare(context,this.property,this.value);case OpenLayers.Filter.Comparison.BETWEEN:var result=context[this.property]>=this.lowerBoundary;result=result&&context[this.property]<=this.upperBoundary;return result;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");return regexp.test(context[this.property]);}},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar,"g"),"\\");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},binaryCompare:function(context,property,value){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:return context[property]==value;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:return context[property]!=value;case OpenLayers.Filter.Comparison.LESS_THAN:return context[property]<value;case OpenLayers.Filter.Comparison.GREATER_THAN:return context[property]>value;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:return context[property]<=value;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return context[property]>=value;}},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0;i<this.fids.length;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
-return false;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Logical.AND:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==false){return false;}}
-return true;case OpenLayers.Filter.Logical.OR:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==true){return true;}}
-return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0;i<this.components.length;i++){geometry.addComponent(this.components[i].clone());}
-OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0;i<this.components.length;i++){strings.push(this.components[i].toShortString());}
-return strings.join(",");},calculateBounds:function(){this.bounds=null;if(this.components&&this.components.length>0){this.setBounds(this.components[0].getBounds());for(var i=1;i<this.components.length;i++){this.extendBounds(this.components[i].getBounds());}}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=0;i<components.length;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
-component.parent=this;this.clearBounds();added=true;}}
-return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0;i<this.components.length;i++){length+=this.components[i].getLength();}
-return length;},getArea:function(){var area=0.0;for(var i=0;i<this.components.length;i++){area+=this.components[i].getArea();}
-return area;},move:function(x,y){for(var i=0;i<this.components.length;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0;i<this.components.length;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
-return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},intersects:function(geometry){var intersect=false;for(var i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(point){var distance=0.0;if((this.x!=null)&&(this.y!=null)&&(point!=null)&&(point.x!=null)&&(point.y!=null)){var dx2=Math.pow(this.x-point.x,2);var dy2=Math.pow(this.y-point.y,2);distance=Math.sqrt(dx2+dy2);}
-return distance;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
-return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
-return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);}
-return this;},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","featureadded","featuresadded","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified"],isBaseLayer:false,isFixed:false,isVector:true,features:null,selectedFeatures:null,reportError:true,style:null,styleMap:null,renderers:['SVG','VML'],renderer:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
-if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
-if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
-this.features=[];this.selectedFeatures=[];},destroy:function(){OpenLayers.Layer.prototype.destroy.apply(this,arguments);this.destroyFeatures();this.features=null;this.selectedFeatures=null;if(this.renderer){this.renderer.destroy();}
-this.renderer=null;this.geometryType=null;this.drawn=null;},assignRenderer:function(){for(var i=0;i<this.renderers.length;i++){var rendererClass=OpenLayers.Renderer[this.renderers[i]];if(rendererClass&&rendererClass.prototype.supported()){this.renderer=new rendererClass(this.div);break;}}},displayError:function(){if(this.reportError){alert(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(!dragging){this.renderer.root.style.visibility="hidden";if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.div.scrollLeft=this.div.scrollLeft;}
-this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();this.renderer.setExtent(extent);this.renderer.root.style.visibility="visible";}
-if(!this.drawn||zoomChanged){this.drawn=true;for(var i=0;i<this.features.length;i++){var feature=this.features[i];this.drawFeature(feature);}}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
-var notify=!options||!options.silent;for(var i=0;i<features.length;i++){var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
-this.features.push(feature);feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){this.events.triggerEvent("beforefeatureadded",{feature:feature});this.preFeatureInsert(feature);}
-if(this.drawn){this.drawFeature(feature);}
-if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
-if(notify){this.events.triggerEvent("featuresadded",{features:features});}},removeFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=features.length-1;i>=0;i--){var feature=features[i];this.features=OpenLayers.Util.removeItem(this.features,feature);if(feature.geometry){this.renderer.eraseGeometry(feature.geometry);}
-if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}}},destroyFeatures:function(features){var all=(features==undefined);if(all){features=this.features;this.selectedFeatures=[];}
-this.eraseFeatures(features);var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(!all){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
-feature.destroy();}},drawFeature:function(feature,style){if(typeof style!="object"){var renderIntent=typeof style=="string"?style:feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-this.renderer.drawFeature(feature,style);},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
-var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureById:function(featureId){var feature=null;for(var i=0;i<this.features.length;++i){if(this.features[i].id==featureId){feature=this.features[i];break;}}
-return feature;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-var sld=this.parser.read(data);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style={};var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
-attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon')
-style['externalGraphic']=vals[valIndex];else if(columns[valIndex]=='iconSize'){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}}}
-if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
-return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1;i<this.components.length;i++){area-=Math.abs(this.components[i].getArea());}}
-return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
-break;}}}}}
-return contained;},intersects:function(geometry){var intersect=false;var i;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-if(!intersect){for(i=0;i<geometry.components.length;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0;i<geometry.components.length;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
-if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0;i<ring.components.length;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
-var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,drawing:false,mouseDown:false,lastDown:null,lastUp:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options={displayInLayerSwitcher:false,calculateInRange:function(){return true;}};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(){this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-if(this.drawing){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);}
-this.layer=null;return true;},destroyFeature:function(){if(this.point){this.point.destroy();}
-this.point=null;},finalize:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("done",[this.geometryClone()]);this.destroyFeature();},cancel:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("cancel",[this.geometryClone()]);this.destroyFeature();},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.point.geometry.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
-if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
-if(this.lastDown==null){this.createFeature();}
-this.lastDown=evt.xy;this.drawing=true;var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.drawFeature();return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.point.geometry.clearBounds();this.drawFeature();}
-return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadGML();}},loadGML:function(){if(!this.loaded){var results=OpenLayers.loadURL(this.url,null,this,this.requestSuccess,this.requestFailure);this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.events.triggerEvent("loadstart");this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){alert(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
-var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0;i<pointFeatures.length;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
-if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
-startPoint=endPoint;}
-this.addFeatures(lines);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
-if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
-OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
-OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
-if(this.params&&this.params.typename&&!this.options.typename){this.options.typename=this.params.typename;}
-if(!this.options.geometry_column){this.options.geometry_column="the_geom";}
-this.params=params;OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.url=url;},destroy:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);}
-if(this.tile){this.tile.destroy();}
-this.tile=null;this.ratio=null;this.featureClass=null;this.format=null;if(this.formatObject&&this.formatObject.destroy){this.formatObject.destroy();}
-this.formatObject=null;this.formatOptions=null;this.vectorMode=null;this.encodeBBOX=null;this.extractAttributes=null;},setMap:function(map){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);var options={'extractAttributes':this.extractAttributes};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.formatObject=this.format?new this.format(options):new OpenLayers.Format.GML(options);}else{OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments);}},moveTo:function(bounds,zoomChanged,dragging){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);}
-if(dragging){return false;}
-if(zoomChanged){if(this.vectorMode){this.renderer.clear();}}
-if(this.options.minZoomLevel){OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));if(this.map.getZoom()<this.options.minZoomLevel){return null;}}
-if(bounds==null){bounds=this.map.getExtent();}
-var firstRendering=(this.tile==null);var outOfBounds=(!firstRendering&&!this.tile.bounds.containsBounds(bounds));if(zoomChanged||firstRendering||(!dragging&&outOfBounds)){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var tileSize=this.map.getSize();tileSize.w=tileSize.w*this.ratio;tileSize.h=tileSize.h*this.ratio;var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var pos=this.map.getLayerPxFromLonLat(ul);var url=this.getFullRequestString();var params={BBOX:this.encodeBBOX?tileBounds.toBBOX():tileBounds.toArray()};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var projectedBounds=tileBounds.clone();projectedBounds.transform(this.map.getProjectionObject(),this.projection);params.BBOX=this.encodeBBOX?projectedBounds.toBBOX():projectedBounds.toArray();}
-url+="&"+OpenLayers.Util.getParameterString(params);if(!this.tile){this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}else{if(this.vectorMode){this.destroyFeatures();this.renderer.clear();}else{this.clearMarkers();}
-this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}}},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("loadstart");}};tile.events.register("loadstart",tile,tile.onLoadStart);tile.onLoadEnd=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("tileloaded");this.layer.events.triggerEvent("loadend");}};tile.events.register("loadend",tile,tile.onLoadEnd);tile.events.register("unload",tile,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:tile});},onMapResize:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,arguments);}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.options);}
-if(this.vectorMode){obj=OpenLayers.Layer.Vector.prototype.clone.apply(this,[obj]);}else{obj=OpenLayers.Layer.Markers.prototype.clone.apply(this,[obj]);}
-return obj;},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},commit:function(){if(!this.writer){var options={};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.writer=new OpenLayers.Format.WFS(options,this);}
-var data=this.writer.write(this.features);var url=this.url;var success=OpenLayers.Function.bind(this.commitSuccess,this);var failure=OpenLayers.Function.bind(this.commitFailure,this);new OpenLayers.Ajax.Request(url,{method:'post',postBody:data,onComplete:success,onFailure:failure});},commitSuccess:function(request){var response=request.responseText;if(response.indexOf('SUCCESS')!=-1){this.commitReport(OpenLayers.i18n("commitSuccess",{'response':response}));for(var i=0;i<this.features.length;i++){this.features[i].state=null;}}else if(response.indexOf('FAILED')!=-1||response.indexOf('Exception')!=-1){this.commitReport(OpenLayers.i18n("commitFailed",{'response':response}));}},commitFailure:function(request){},commitReport:function(string,response){alert(string);},refresh:function(){if(this.tile){if(this.vectorMode){this.renderer.clear();this.features.length=0;}else{this.clearMarkers();this.markers.length=0;}
-this.tile.draw();}},CLASS_NAME:"OpenLayers.Layer.WFS"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,pointRadius:6},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var sld={namedLayers:{}};this.readChildNodes(data,sld);return sld;},readers:{"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=node.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0;i<layer.userStyles.length;++i){layer.userStyles[i].layerName=layer.name;}
-sld.namedLayers[layer.name]=layer;},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildName(node.firstChild));},"UserStyle":function(node,layer){var style=new OpenLayers.Style(this.defaultSymbolizer);this.readChildNodes(node,style);layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){var obj={rules:[]};this.readChildNodes(node,obj);style.rules=obj.rules;},"Rule":function(node,obj){var rule=new OpenLayers.Rule();this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=this.getChildValue(node);},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=this.getChildValue(node);},"LineSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Line"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Line"]=symbolizer;},"PolygonSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Polygon"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Polygon"]=symbolizer;},"PointSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Point"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Point"]=symbolizer;},"Stroke":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){var graphic={};this.readChildNodes(node,graphic);var properties=["strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0;i<properties.length;++i){prop=properties[i];value=graphic[prop];if(value!=undefined){symbolizer[prop]=value;}}
-if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
-if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size;}
-if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.getChildValue(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.getChildValue(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.getChildValue(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}},"ogc":{"Filter":function(node,rule){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){rule.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){rule.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=this.getChildValue(node);},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=this.readOgcExpression(node);},"UpperBoundary":function(node,filter){filter.upperBoundary=this.readOgcExpression(node);}}},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(!value){value=this.getChildValue(node);}
-return value;},cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","fill":"fillColor","fill-opacity":"fillOpacity"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
-return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
-return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:{"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});if(sld.name){this.writeNode(root,"Name",sld.name);}
-if(sld.title){this.writeNode(root,"Title",sld.title);}
-if(sld.description){this.writeNode(root,"Abstract",sld.description);}
-for(var name in sld.namedLayers){this.writeNode(root,"NamedLayer",sld.namedLayers[name]);}
-return root;},"Name":function(name){return this.createElementNSPlus("Name",{value:name});},"Title":function(title){return this.createElementNSPlus("Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("NamedLayer");this.writeNode(node,"Name",layer.name);if(layer.namedStyles){for(var i=0;i<layer.namedStyles.length;++i){this.writeNode(node,"NamedStyle",layer.namedStyles[i]);}}
-if(layer.userStyles){for(var i=0;i<layer.userStyles.length;++i){this.writeNode(node,"UserStyle",layer.userStyles[i]);}}
-return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("NamedStyle");this.writeNode(node,"Name",name);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("UserStyle");if(style.name){this.writeNode(node,"Name",style.name);}
-if(style.title){this.writeNode(node,"Title",style.title);}
-if(style.description){this.writeNode(node,"Abstract",style.description);}
-if(style.isDefault){this.writeNode(node,"IsDefault",style.isDefault);}
-this.writeNode(node,"FeatureTypeStyle",style);return node;},"IsDefault":function(bool){return this.createElementNSPlus("IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("FeatureTypeStyle");for(var i=0;i<style.rules.length;++i){this.writeNode(node,"Rule",style.rules[i]);}
-return node;},"Rule":function(rule){var node=this.createElementNSPlus("Rule");if(rule.name){this.writeNode(node,"Name",rule.name);}
-if(rule.title){this.writeNode(node,"Title",rule.title);}
-if(rule.description){this.writeNode(node,"Abstract",rule.description);}
-if(rule.elseFilter){this.writeNode(node,"ElseFilter");}else if(rule.filter){this.writeNode(node,"ogc:Filter",rule.filter);}
-if(rule.minScaleDenominator!=undefined){this.writeNode(node,"MinScaleDenominator",rule.minScaleDenominator);}
-if(rule.maxScaleDenominator!=undefined){this.writeNode(node,"MaxScaleDenominator",rule.maxScaleDenominator);}
-var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;var type,symbolizer;for(var i=0;i<types.length;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(node,type+"Symbolizer",symbolizer);}}
-return node;},"ElseFilter":function(){return this.createElementNSPlus("ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("LineSymbolizer");this.writeNode(node,"Stroke",symbolizer);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeColor"});}
-if(symbolizer.strokeOpacity!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"});}
-if(symbolizer.strokeWidth!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeWidth"});}
-return node;},"CssParameter":function(obj){return this.createElementNSPlus("CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PolygonSymbolizer");this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("Fill");if(symbolizer.fillColor){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillColor"});}
-if(symbolizer.fillOpacity){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillOpacity"});}
-return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PointSymbolizer");this.writeNode(node,"Graphic",symbolizer);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode(node,"ExternalGraphic",symbolizer);}else if(symbolizer.graphicName){this.writeNode(node,"Mark",symbolizer);}
-if(symbolizer.graphicOpacity!=undefined){this.writeNode(node,"Opacity",symbolizer.graphicOpacity);}
-if(symbolizer.pointRadius!=undefined){this.writeNode(node,"Size",symbolizer.pointRadius);}
-if(symbolizer.rotation!=undefined){this.writeNode(node,"Rotation",symbolizer.rotation);}
-return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("ExternalGraphic");this.writeNode(node,"OnlineResource",symbolizer.externalGraphic);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode(node,"Format",format);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("Mark");this.writeNode(node,"WellKnownName",symbolizer.graphicName);this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"WellKnownName":function(name){return this.createElementNSPlus("WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("Format",{value:format});}},"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");var sub=filter.CLASS_NAME.split(".").pop();if(sub=="FeatureId"){for(var i=0;i<filter.fids.length;++i){this.writeNode(node,"FeatureId",filter.fids[i]);}}else{this.writeNode(node,this.getFilterType(filter),filter);}
-return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];this.writeNode(node,this.getFilterType(childFilter),childFilter);return node;},"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"LowerBoundary",filter);this.writeNode(node,"UpperBoundary",filter);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.regex2value());return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeNode(node,"Literal",filter.lowerBoundary);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode(node,"Literal",filter.upperBoundary);return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"SLD writing not supported for rule type: "+filter.type;}
-return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike"},getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{var gotPrefix=false;for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){gotPrefix=true;break;}}
-if(!gotPrefix){prefix=null;}}
-return prefix;},readChildNodes:function(node,obj){var children=node.childNodes;var child,group,reader,prefix,local;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){prefix=this.getNamespacePrefix(child.namespaceURI);local=child.nodeName.split(":").pop();group=this.readers[prefix];if(group){reader=group[local];if(reader){reader.apply(this,[child,obj]);}}}}},writeNode:function(parent,name,obj){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{prefix=this.getNamespacePrefix(parent.namespaceURI);local=name;}
-var child=this.writers[prefix][local].apply(this,[obj]);parent.appendChild(child);return child;},createElementNSPlus:function(name,options){options=options||{};var loc=name.indexOf(":");var uri=options.uri||this.namespaces[options.prefix];if(!uri){loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
-if(!uri){uri=this.namespaces[this.defaultPrefix];}
-var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
-if(options.value){node.appendChild(this.createTextNode(options.value));}
-return node;},setAttributes:function(node,obj){var value,loc,alias,uri;for(var name in obj){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}},CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1;i<this.components.length;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
-return length;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
-var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0;i<segs1.length;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0;j<segs2.length;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
-if(seg2.x2<seg1x1){continue;}
-seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
-if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
-if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
-return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg);for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
-function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
-return segments.sort(byX1);},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
-return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
-childNode=childNode.nextSibling;}
-feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
-if(coords.length==2){coords[2]=null;}
-if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
-else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
-return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
-if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
-var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
-return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
-return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
-return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
-return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
-return envelope;}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}
-break;}
-return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
-return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
-return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
-return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
-return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
-return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var points=(geometry.components)?geometry.components:[geometry];var parts=[];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}
-var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
-if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
-break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
-break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
-break;case"FeatureCollection":for(var i=0;i<obj.features.length;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;}}
-return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
-obj.type);}else{valid=true;}
-break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
-obj.type+" to "+type);}}
-return valid;},parseFeature:function(obj){var feature,geometry,attributes;attributes=(obj.properties)?obj.properties:{};try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
-feature=new OpenLayers.Feature.Vector(geometry,attributes);if(obj.id){feature.fid=obj.id;}
-return feature;},parseGeometry:function(obj){var geometry;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
-var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
-if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
-try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
-if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},parseCoords:{"point":function(array){if(array.length!=2){throw"Only 2D points are supported: "+array;}
-return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-lines.push(l);}
-return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
-return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
-polys.push(p);}
-return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
-geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
-return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"OGC","properties":{"urn":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"EPSG","properties":{"code":code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
-return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array;},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
-return array;},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
-return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
-return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
-return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
-var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(line[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(polygon[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
-var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}
-if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.featureDescription));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
-var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;try{value=this.getElementsByTagNameNS(node,nsuri,name)[0].firstChild.nodeValue;}catch(e){value=(def==undefined)?"":def;}
-return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
-var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0;i<features.length;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
-for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
-var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
-featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
-return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
-var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
-path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.styles={};this.fetched={};var options={depth:this.maxDepth,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0;i<types.length;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
-switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
-break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
-break;case"placemark":this.parseFeatures(nodes,options);break;}}
-return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
-var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0;i<nodes.length;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=new OpenLayers.Ajax.Request(href,{method:'get',asynchronous:false});if(request&&request.transport){return request.transport.responseText;}},parseStyles:function(nodes,options){for(var i=0;i<nodes.length;i++){var style=this.parseStyle(nodes[i]);if(style){styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle"];var type,nodeList,geometry,parser;for(var i=0;i<types.length;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
-switch(type.toLowerCase()){case"linestyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["strokeOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["strokeColor"]="#"+r+g+b;}
-var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
-case"polystyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["fillOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["fillColor"]="#"+r+g+b;}
-break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
-w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
-if(h){height=parseInt(h)*scale;}
-var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
-+palette+"/icon"+pos+file_extension;}
-style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
-var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
-else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
-else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
-var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
-else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
-else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
-style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
-break;default:}}
-if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
-var id=node.getAttribute("id");if(id&&style){style.id=id;}
-return style;},parseStyleMaps:function(nodes,options){for(var i=0;i<nodes.length;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0;j<pairs.length;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
-if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=new Array(nodes.length);for(var i=0;i<nodes.length;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl);}
-var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend({},feature.style);OpenLayers.Util.extend(feature.style,inlineStyle);}}
-features[i]=feature;}else{throw"Bad Placemark: "+i;}}
-this.features=this.features.concat(features);},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
-return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
-var style=this.styles[styleUrl];return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
-var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
-point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
-return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
-points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
-pointList[i];}}
-if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
-return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
-return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
-return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1||grandchildren.length==3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 3:default:grandchild=grandchildren[1];break;}
-if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0;i<features.length;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
-kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);var folder=this.createElementNS(this.kmlns,"Folder");folder.appendChild(folderName);folder.appendChild(folderDesc);return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=(feature.attributes.name)?feature.attributes.name:feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=(feature.attributes.description)?feature.attributes.description:this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
-return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
-return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0;i<geometry.components.length;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
-layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
-layer_defaults.areaTags=area;OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
-var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
-var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
-for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
-tags=result[0];}else{tags=this.getTags(node.node);}
-var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
-feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
-node.node=null;}
-return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
-return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
-return_ways.push(way_object);}
-return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
-return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
-if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
-return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
-this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
-return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
-if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
-this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
-this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
-var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
-this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
-this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
-if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
-var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0;i<this.components.length-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length-1;++i){this.components[i].resize(scale,origin,ratio);}},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length-1;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
-area=-sum/2.0;}
-return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
-var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
-continue;}
-cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
-if(cx<=px){continue;}
-if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
-if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
-var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0;i<geometry.components.length;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(){this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString());this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);if(this.line){this.line.destroy();}
-this.line=null;},addPoint:function(){this.line.geometry.addComponent(this.point.geometry.clone(),this.line.geometry.components.length);this.callback("point",[this.point.geometry]);},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(){var index=this.line.geometry.components.length-1;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.line.geometry.clone();},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
-if(this.lastDown==null){this.createFeature();}
-this.mouseDown=true;this.lastDown=evt.xy;var lonlat=this.control.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint();}
-this.drawFeature();this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if(this.mouseDown&&this.freehandMode(evt)){this.addPoint();}else{this.modifyFeature();}
-this.drawFeature();}
-return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.finalize();}else{if(this.lastUp==null){this.addPoint();}
-this.lastUp=evt.xy;}
-return false;}
-return true;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
-if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
-if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));}
-var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.layerName);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
-valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
-var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.layerName);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon());this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing());this.polygon.geometry.addComponent(this.line.geometry);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);if(this.polygon){this.polygon.destroy();}
-this.polygon=null;},modifyFeature:function(){var index=this.line.geometry.components.length-2;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.polygon.geometry.clone();},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];for(var i=0;i<controls.length;i++){controls[i].featureAdded=function(feature){feature.state=OpenLayers.State.INSERT;};}
-this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});
\ No newline at end of file
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});
Modified: sandbox/olcore/lib/OpenLayers/OpenLayersCompressed.js
--- sandbox/olcore/lib/OpenLayers/OpenLayersCompressed.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/OpenLayers/OpenLayersCompressed.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -43,15 +43,24 @@
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
 var OpenLayers={singleFile:true};(function(){var singleFile=(typeof OpenLayers=="object"&&OpenLayers.singleFile);window.OpenLayers={_scriptName:(!singleFile)?"lib/OpenLayers.js":"OpenLayers.js",_getScriptLocation:function(){var scriptLocation="";var scriptName=OpenLayers._scriptName;var scripts=document.getElementsByTagName('script');for(var i=0;i<scripts.length;i++){var src=scripts[i].getAttribute('src');if(src){var index=src.lastIndexOf(scriptName);var pathLength=src.lastIndexOf('?');if(pathLength<0){pathLength=src.length;}
 if((index>-1)&&(index+scriptName.length==pathLength)){scriptLocation=src.slice(0,pathLength-scriptName.length);break;}}}
-return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
+return scriptLocation;}};if(!singleFile){var jsfiles=new Array("OpenLayers/Util.js","OpenLayers/BaseTypes.js","OpenLayers/BaseTypes/Class.js","OpenLayers/BaseTypes/Bounds.js","OpenLayers/BaseTypes/Element.js","OpenLayers/BaseTypes/LonLat.js","OpenLayers/BaseTypes/Pixel.js","OpenLayers/BaseTypes/Size.js","OpenLayers/Console.js","OpenLayers/Tween.js","Rico/Corner.js","Rico/Color.js","OpenLayers/Ajax.js","OpenLayers/Request.js","OpenLayers/Request/XMLHttpRequest.js","OpenLayers/Events.js","OpenLayers/Projection.js","OpenLayers/Map.js","OpenLayers/Layer.js","OpenLayers/Icon.js","OpenLayers/Marker.js","OpenLayers/Marker/Box.js","OpenLayers/Popup.js","OpenLayers/Tile.js","OpenLayers/Tile/Image.js","OpenLayers/Tile/WFS.js","OpenLayers/Layer/Image.js","OpenLayers/Layer/SphericalMercator.js","OpenLayers/Layer/EventPane.js","OpenLayers/Layer/FixedZoomLevels.js","OpenLayers/Layer/Google.js","OpenLayers/Layer/VirtualEarth.js","OpenLayers/Layer/Yahoo.js","OpenLayers/Layer/HTTPRequest.js","OpenLayers/Layer/Grid.js","OpenLayers/Layer/MapGuide.js","OpenLayers/Layer/MapServer.js","OpenLayers/Layer/MapServer/Untiled.js","OpenLayers/Layer/KaMap.js","OpenLayers/Layer/MultiMap.js","OpenLayers/Layer/Markers.js","OpenLayers/Layer/Text.js","OpenLayers/Layer/WorldWind.js","OpenLayers/Layer/WMS.js","OpenLayers/Layer/WMS/Untiled.js","OpenLayers/Layer/GeoRSS.js","OpenLayers/Layer/Boxes.js","OpenLayers/Layer/TMS.js","OpenLayers/Layer/TileCache.js","OpenLayers/Popup/Anchored.js","OpenLayers/Popup/AnchoredBubble.js","OpenLayers/Popup/Framed.js","OpenLayers/Popup/FramedCloud.js","OpenLayers/Feature.js","OpenLayers/Feature/Vector.js","OpenLayers/Feature/WFS.js","OpenLayers/Handler.js","OpenLayers/Handler/Click.js","OpenLayers/Handler/Hover.js","OpenLayers/Handler/Point.js","OpenLayers/Handler/Path.js","OpenLayers/Handler/Polygon.js","OpenLayers/Handler/Feature.js","OpenLayers/Handler/Drag.js","OpenLayers/Handler/RegularPolygon.js","OpenLayers/Handler/Box.js","OpenLayers/Handler/MouseWheel.js","OpenLayers/Handler/Keyboard.js","OpenLayers/Control.js","OpenLayers/Control/Attribution.js","OpenLayers/Control/Button.js","OpenLayers/Control/ZoomBox.js","OpenLayers/Control/ZoomToMaxExtent.js","OpenLayers/Control/DragPan.js","OpenLayers/Control/Navigation.js","OpenLayers/Control/MouseDefaults.js","OpenLayers/Control/MousePosition.js","OpenLayers/Control/OverviewMap.js","OpenLayers/Control/KeyboardDefaults.js","OpenLayers/Control/PanZoom.js","OpenLayers/Control/PanZoomBar.js","OpenLayers/Control/ArgParser.js","OpenLayers/Control/Permalink.js","OpenLayers/Control/Scale.js","OpenLayers/Control/ScaleLine.js","OpenLayers/Control/LayerSwitcher.js","OpenLayers/Control/DrawFeature.js","OpenLayers/Control/DragFeature.js","OpenLayers/Control/ModifyFeature.js","OpenLayers/Control/Panel.js","OpenLayers/Control/SelectFeature.js","OpenLayers/Control/NavigationHistory.js","OpenLayers/Geometry.js","OpenLayers/Geometry/Rectangle.js","OpenLayers/Geometry/Collection.js","OpenLayers/Geometry/Point.js","OpenLayers/Geometry/MultiPoint.js","OpenLayers/Geometry/Curve.js","OpenLayers/Geometry/LineString.js","OpenLayers/Geometry/LinearRing.js","OpenLayers/Geometry/Polygon.js","OpenLayers/Geometry/MultiLineString.js","OpenLayers/Geometry/MultiPolygon.js","OpenLayers/Geometry/Surface.js","OpenLayers/Renderer.js","OpenLayers/Renderer/Elements.js","OpenLayers/Renderer/SVG.js","OpenLayers/Renderer/VML.js","OpenLayers/Layer/Vector.js","OpenLayers/Layer/PointTrack.js","OpenLayers/Layer/GML.js","OpenLayers/Style.js","OpenLayers/StyleMap.js","OpenLayers/Rule.js","OpenLayers/Filter.js","OpenLayers/Filter/FeatureId.js","OpenLayers/Filter/Logical.js","OpenLayers/Filter/Comparison.js","OpenLayers/Format.js","OpenLayers/Format/XML.js","OpenLayers/Format/GML.js","OpenLayers/Format/KML.js","OpenLayers/Format/GeoRSS.js","OpenLayers/Format/WFS.js","OpenLayers/Format/WKT.js","OpenLayers/Format/OSM.js","OpenLayers/Format/SLD.js","OpenLayers/Format/SLD/v1.js","OpenLayers/Format/SLD/v1_0_0.js","OpenLayers/Format/Text.js","OpenLayers/Format/JSON.js","OpenLayers/Format/GeoJSON.js","OpenLayers/Format/WMC.js","OpenLayers/Format/WMC/v1.js","OpenLayers/Format/WMC/v1_0_0.js","OpenLayers/Format/WMC/v1_1_0.js","OpenLayers/Layer/WFS.js","OpenLayers/Control/MouseToolbar.js","OpenLayers/Control/NavToolbar.js","OpenLayers/Control/EditingToolbar.js","OpenLayers/Lang.js","OpenLayers/Lang/en.js");var agent=navigator.userAgent;var docWrite=(agent.match("MSIE")||agent.match("Safari"));if(docWrite){var allScriptTags=new Array(jsfiles.length);}
 var host=OpenLayers._getScriptLocation()+"lib/";for(var i=0;i<jsfiles.length;i++){if(docWrite){allScriptTags[i]="<script src='"+host+jsfiles[i]+"'></script>";}else{var s=document.createElement("script");s.src=host+jsfiles[i];var h=document.getElementsByTagName("head").length?document.getElementsByTagName("head")[0]:document.body;h.appendChild(s);}}
 if(docWrite){document.write(allScriptTags.join(""));}}})();OpenLayers.VERSION_NUMBER="$Revision$";OpenLayers.String={startsWith:function(str,sub){return(str.indexOf(sub)==0);},contains:function(str,sub){return(str.indexOf(sub)!=-1);},trim:function(str){return str.replace(/^\s*(.*?)\s*$/,"$1");},camelize:function(str){var oStringList=str.split('-');var camelizedString=oStringList[0];for(var i=1;i<oStringList.length;i++){var s=oStringList[i];camelizedString+=s.charAt(0).toUpperCase()+s.substring(1);}
 return camelizedString;},format:function(template,context,args){if(!context){context=window;}
 var tokens=template.split("${");var item,last,replacement;for(var i=1;i<tokens.length;i++){item=tokens[i];last=item.indexOf("}");if(last>0){replacement=context[item.substring(0,last)];if(typeof replacement=="function"){replacement=args?replacement.apply(null,args):replacement();}
 tokens[i]=replacement+item.substring(++last);}else{tokens[i]="${"+item;}}
-return tokens.join("");}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
+return tokens.join("");},numberRegEx:/^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,isNumeric:function(value){return OpenLayers.String.numberRegEx.test(value);}};if(!String.prototype.startsWith){String.prototype.startsWith=function(sStart){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.startsWith'}));return OpenLayers.String.startsWith(this,sStart);};}
 if(!String.prototype.contains){String.prototype.contains=function(str){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.contains'}));return OpenLayers.String.contains(this,str);};}
 if(!String.prototype.trim){String.prototype.trim=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.trim'}));return OpenLayers.String.trim(this);};}
 if(!String.prototype.camelize){String.prototype.camelize=function(){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'OpenLayers.String.camelize'}));return OpenLayers.String.camelize(this);};}
@@ -74,7 +83,7 @@
 if(arguments.length==1){return element;}
 elements.push(element);}
 return elements;};if($==null){var $=OpenLayers.Util.getElement;}
-OpenLayers.Util.extend=function(destination,source){if(destination&&source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
+OpenLayers.Util.extend=function(destination,source){destination=destination||{};if(source){for(var property in source){var value=source[property];if(value!==undefined){destination[property]=value;}}
 var sourceIsEvt=typeof window.Event=="function"&&source instanceof window.Event;if(!sourceIsEvt&&source.hasOwnProperty&&source.hasOwnProperty('toString')){destination.toString=source.toString;}}
 return destination;};OpenLayers.Util.removeItem=function(array,item){for(var i=array.length-1;i>=0;i--){if(array[i]==item){array.splice(i,1);}}
 return array;};OpenLayers.Util.clearArray=function(array){OpenLayers.Console.warn(OpenLayers.i18n("methodDeprecated",{'newMethod':'array = []'}));array.length=0;};OpenLayers.Util.indexOf=function(array,obj){for(var i=0;i<array.length;i++){if(array[i]==obj){return i;}}
@@ -93,12 +102,13 @@
 image.style.alt=id;image.galleryImg="no";if(imgURL){image.src=imgURL;}
 return image;};OpenLayers.Util.setOpacity=function(element,opacity){OpenLayers.Util.modifyDOMElement(element,null,null,null,null,null,null,opacity);};OpenLayers.Util.onImageLoad=function(){if(!this.viewRequestID||(this.map&&this.viewRequestID==this.map.viewRequestID)){this.style.backgroundColor=null;this.style.display="";}};OpenLayers.Util.onImageLoadErrorColor="pink";OpenLayers.IMAGE_RELOAD_ATTEMPTS=0;OpenLayers.Util.onImageLoadError=function(){this._attempts=(this._attempts)?(this._attempts+1):1;if(this._attempts<=OpenLayers.IMAGE_RELOAD_ATTEMPTS){this.src=this.src;}else{this.style.backgroundColor=OpenLayers.Util.onImageLoadErrorColor;}
 this.style.display="";};OpenLayers.Util.alphaHack=function(){var arVersion=navigator.appVersion.split("MSIE");var version=parseFloat(arVersion[1]);var filter=false;try{filter=!!(document.body.filters);}catch(e){}
-return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,null,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
-OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){div.style.display="inline-block";if(sizing==null){sizing="scale";}
+return(filter&&(version>=5.5)&&(version<7));};OpenLayers.Util.modifyAlphaImageDiv=function(div,id,px,sz,imgURL,position,border,sizing,opacity){OpenLayers.Util.modifyDOMElement(div,id,px,sz,position,null,null,opacity);var img=div.childNodes[0];if(imgURL){img.src=imgURL;}
+OpenLayers.Util.modifyDOMElement(img,div.id+"_innerImage",null,sz,"relative",border);if(OpenLayers.Util.alphaHack()){if(div.style.display!="none"){div.style.display="inline-block";}
+if(sizing==null){sizing="scale";}
 div.style.filter="progid:DXImageTransform.Microsoft"+".AlphaImageLoader(src='"+img.src+"', "+"sizingMethod='"+sizing+"')";if(parseFloat(div.style.opacity)>=0.0&&parseFloat(div.style.opacity)<1.0){div.style.filter+=" alpha(opacity="+div.style.opacity*100+")";}
 img.style.filter="alpha(opacity=0)";}};OpenLayers.Util.createAlphaImageDiv=function(id,px,sz,imgURL,position,border,sizing,opacity,delayDisplay){var div=OpenLayers.Util.createDiv();var img=OpenLayers.Util.createImage(null,null,null,null,null,null,null,false);div.appendChild(img);if(delayDisplay){img.style.display="none";OpenLayers.Event.observe(img,"load",OpenLayers.Function.bind(OpenLayers.Util.onImageLoad,div));OpenLayers.Event.observe(img,"error",OpenLayers.Function.bind(OpenLayers.Util.onImageLoadError,div));}
 OpenLayers.Util.modifyAlphaImageDiv(div,id,px,sz,imgURL,position,border,sizing,opacity);return div;};OpenLayers.Util.upperCaseObject=function(object){var uObject={};for(var key in object){uObject[key.toUpperCase()]=object[key];}
-return uObject;};OpenLayers.Util.applyDefaults=function(to,from){var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
+return uObject;};OpenLayers.Util.applyDefaults=function(to,from){to=to||{};var fromIsEvt=typeof window.Event=="function"&&from instanceof window.Event;for(var key in from){if(to[key]===undefined||(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty(key)&&!to.hasOwnProperty(key))){to[key]=from[key];}}
 if(!fromIsEvt&&from.hasOwnProperty&&from.hasOwnProperty('toString')&&!to.hasOwnProperty('toString')){to.toString=from.toString;}
 return to;};OpenLayers.Util.getParameterString=function(params){var paramsArray=[];for(var key in params){var value=params[key];if((value!=null)&&(typeof value!='function')){var encodedValue;if(typeof value=='object'&&value.constructor==Array){var encodedItemArray=[];for(var itemIndex=0;itemIndex<value.length;itemIndex++){encodedItemArray.push(encodeURIComponent(value[itemIndex]));}
 encodedValue=encodedItemArray.join(",");}
@@ -143,33 +153,13 @@
 if((urlObject.protocol=="file:")||(urlObject.protocol=="")){urlObject.host="localhost";}
 return urlObject;};OpenLayers.Util.removeTail=function(url){var head=null;var qMark=url.indexOf("?");var hashMark=url.indexOf("#");if(qMark==-1){head=(hashMark!=-1)?url.substr(0,hashMark):url;}else{head=(hashMark!=-1)?url.substr(0,Math.min(qMark,hashMark)):url.substr(0,qMark);}
 return head;};OpenLayers.Util.getBrowserName=function(){var browserName="";var ua=navigator.userAgent.toLowerCase();if(ua.indexOf("opera")!=-1){browserName="opera";}else if(ua.indexOf("msie")!=-1){browserName="msie";}else if(ua.indexOf("safari")!=-1){browserName="safari";}else if(ua.indexOf("mozilla")!=-1){if(ua.indexOf("firefox")!=-1){browserName="firefox";}else{browserName="mozilla";}}
-return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w=h=null;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=container.style.width=size.w;}else if(size.h){h=container.style.height=size.h;}}
+return browserName;};OpenLayers.Util.getRenderedDimensions=function(contentHTML,size){var w,h;var container=document.createElement("div");container.style.overflow="";container.style.position="absolute";container.style.left="-9999px";if(size){if(size.w){w=size.w;container.style.width=w+"px";}else if(size.h){h=size.h
+container.style.height=h+"px";}}
 var content=document.createElement("div");content.innerHTML=contentHTML;container.appendChild(content);document.body.appendChild(container);if(!w){w=parseInt(content.scrollWidth);container.style.width=w+"px";}
 if(!h){h=parseInt(content.scrollHeight);}
 container.removeChild(content);document.body.removeChild(container);return new OpenLayers.Size(w,h);};OpenLayers.Util.getScrollbarWidth=function(){var scrollbarWidth=OpenLayers.Util._scrollbarWidth;if(scrollbarWidth==null){var scr=null;var inn=null;var wNoScroll=0;var wScroll=0;scr=document.createElement('div');scr.style.position='absolute';scr.style.top='-1000px';scr.style.left='-1000px';scr.style.width='100px';scr.style.height='50px';scr.style.overflow='hidden';inn=document.createElement('div');inn.style.width='100%';inn.style.height='200px';scr.appendChild(inn);document.body.appendChild(scr);wNoScroll=inn.offsetWidth;scr.style.overflow='scroll';wScroll=inn.offsetWidth;document.body.removeChild(document.body.lastChild);OpenLayers.Util._scrollbarWidth=(wNoScroll-wScroll);scrollbarWidth=OpenLayers.Util._scrollbarWidth;}
-return scrollbarWidth;};OpenLayers.Rico=new Object();OpenLayers.Rico.Corner={round:function(e,options){e=OpenLayers.Util.getElement(e);this._setOptions(options);var color=this.options.color;if(this.options.color=="fromElement"){color=this._background(e);}
-var bgColor=this.options.bgColor;if(this.options.bgColor=="fromParent"){bgColor=this._background(e.offsetParent);}
-this._roundCornersImpl(e,color,bgColor);},changeColor:function(theDiv,newColor){theDiv.style.backgroundColor=newColor;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.backgroundColor=newColor;}},changeOpacity:function(theDiv,newOpacity){var mozillaOpacity=newOpacity;var ieOpacity='alpha(opacity='+newOpacity*100+')';theDiv.style.opacity=mozillaOpacity;theDiv.style.filter=ieOpacity;var spanElements=theDiv.parentNode.getElementsByTagName("span");for(var currIdx=0;currIdx<spanElements.length;currIdx++){spanElements[currIdx].style.opacity=mozillaOpacity;spanElements[currIdx].style.filter=ieOpacity;}},reRound:function(theDiv,options){var topRico=theDiv.parentNode.childNodes[0];var bottomRico=theDiv.parentNode.childNodes[2];theDiv.parentNode.removeChild(topRico);theDiv.parentNode.removeChild(bottomRico);this.round(theDiv.parentNode,options);},_roundCornersImpl:function(e,color,bgColor){if(this.options.border){this._renderBorder(e,bgColor);}
-if(this._isTopRounded()){this._roundTopCorners(e,color,bgColor);}
-if(this._isBottomRounded()){this._roundBottomCorners(e,color,bgColor);}},_renderBorder:function(el,bgColor){var borderValue="1px solid "+this._borderColor(bgColor);var borderL="border-left: "+borderValue;var borderR="border-right: "+borderValue;var style="style='"+borderL+";"+borderR+"'";el.innerHTML="<div "+style+">"+el.innerHTML+"</div>";},_roundTopCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=0;i<this.options.numSlices;i++){corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));}
-el.style.paddingTop=0;el.insertBefore(corner,el.firstChild);},_roundBottomCorners:function(el,color,bgColor){var corner=this._createCorner(bgColor);for(var i=(this.options.numSlices-1);i>=0;i--){corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));}
-el.style.paddingBottom=0;el.appendChild(corner);},_createCorner:function(bgColor){var corner=document.createElement("div");corner.style.backgroundColor=(this._isTransparent()?"transparent":bgColor);return corner;},_createCornerSlice:function(color,bgColor,n,position){var slice=document.createElement("span");var inStyle=slice.style;inStyle.backgroundColor=color;inStyle.display="block";inStyle.height="1px";inStyle.overflow="hidden";inStyle.fontSize="1px";var borderColor=this._borderColor(color,bgColor);if(this.options.border&&n==0){inStyle.borderTopStyle="solid";inStyle.borderTopWidth="1px";inStyle.borderLeftWidth="0px";inStyle.borderRightWidth="0px";inStyle.borderBottomWidth="0px";inStyle.height="0px";inStyle.borderColor=borderColor;}
-else if(borderColor){inStyle.borderColor=borderColor;inStyle.borderStyle="solid";inStyle.borderWidth="0px 1px";}
-if(!this.options.compact&&(n==(this.options.numSlices-1))){inStyle.height="2px";}
-this._setMargin(slice,n,position);this._setBorder(slice,n,position);return slice;},_setOptions:function(options){this.options={corners:"all",color:"fromElement",bgColor:"fromParent",blend:true,border:false,compact:false};OpenLayers.Util.extend(this.options,options||{});this.options.numSlices=this.options.compact?2:4;if(this._isTransparent()){this.options.blend=false;}},_whichSideTop:function(){if(this._hasString(this.options.corners,"all","top")){return"";}
-if(this.options.corners.indexOf("tl")>=0&&this.options.corners.indexOf("tr")>=0){return"";}
-if(this.options.corners.indexOf("tl")>=0){return"left";}else if(this.options.corners.indexOf("tr")>=0){return"right";}
-return"";},_whichSideBottom:function(){if(this._hasString(this.options.corners,"all","bottom")){return"";}
-if(this.options.corners.indexOf("bl")>=0&&this.options.corners.indexOf("br")>=0){return"";}
-if(this.options.corners.indexOf("bl")>=0){return"left";}else if(this.options.corners.indexOf("br")>=0){return"right";}
-return"";},_borderColor:function(color,bgColor){if(color=="transparent"){return bgColor;}else if(this.options.border){return this.options.border;}else if(this.options.blend){return this._blend(bgColor,color);}else{return"";}},_setMargin:function(el,n,corners){var marginSize=this._marginSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.marginLeft=marginSize+"px";el.style.marginRight="0px";}
-else if(whichSide=="right"){el.style.marginRight=marginSize+"px";el.style.marginLeft="0px";}
-else{el.style.marginLeft=marginSize+"px";el.style.marginRight=marginSize+"px";}},_setBorder:function(el,n,corners){var borderSize=this._borderSize(n);var whichSide=corners=="top"?this._whichSideTop():this._whichSideBottom();if(whichSide=="left"){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth="0px";}
-else if(whichSide=="right"){el.style.borderRightWidth=borderSize+"px";el.style.borderLeftWidth="0px";}
-else{el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}
-if(this.options.border!=false){el.style.borderLeftWidth=borderSize+"px";el.style.borderRightWidth=borderSize+"px";}},_marginSize:function(n){if(this._isTransparent()){return 0;}
-var marginSizes=[5,3,2,1];var blendedMarginSizes=[3,2,1,0];var compactMarginSizes=[2,1];var smBlendedMarginSizes=[1,0];if(this.options.compact&&this.options.blend){return smBlendedMarginSizes[n];}else if(this.options.compact){return compactMarginSizes[n];}else if(this.options.blend){return blendedMarginSizes[n];}else{return marginSizes[n];}},_borderSize:function(n){var transparentBorderSizes=[5,3,2,1];var blendedBorderSizes=[2,1,1,1];var compactBorderSizes=[1,0];var actualBorderSizes=[0,2,0,0];if(this.options.compact&&(this.options.blend||this._isTransparent())){return 1;}else if(this.options.compact){return compactBorderSizes[n];}else if(this.options.blend){return blendedBorderSizes[n];}else if(this.options.border){return actualBorderSizes[n];}else if(this._isTransparent()){return transparentBorderSizes[n];}
-return 0;},_hasString:function(str){for(var i=1;i<arguments.length;i++)if(str.indexOf(arguments[i])>=0){return true;}return false;},_blend:function(c1,c2){var cc1=OpenLayers.Rico.Color.createFromHex(c1);cc1.blend(OpenLayers.Rico.Color.createFromHex(c2));return cc1;},_background:function(el){try{return OpenLayers.Rico.Color.createColorFromBackground(el).asHex();}catch(err){return"#ffffff";}},_isTransparent:function(){return this.options.color=="transparent";},_isTopRounded:function(){return this._hasString(this.options.corners,"all","top","tl","tr");},_isBottomRounded:function(){return this._hasString(this.options.corners,"all","bottom","bl","br");},_hasSingleTextChild:function(el){return el.childNodes.length==1&&el.childNodes[0].nodeType==3;}};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){var success=(onComplete)?OpenLayers.Function.bind(onComplete,caller):OpenLayers.nullHandler;var failure=(onFailure)?OpenLayers.Function.bind(onFailure,caller):OpenLayers.nullHandler;var request=new OpenLayers.Ajax.Request(uri,{method:'get',parameters:params,onComplete:success,onFailure:failure});return request.transport;};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
+return scrollbarWidth;};OpenLayers.ProxyHost="";OpenLayers.nullHandler=function(request){alert(OpenLayers.i18n("unhandledRequest",{'statusText':request.statusText}));};OpenLayers.loadURL=function(uri,params,caller,onComplete,onFailure){if(typeof params=='string'){params=OpenLayers.Util.getParameters(params);}
+var success=(onComplete)?onComplete:OpenLayers.nullHandler;var failure=(onFailure)?onFailure:OpenLayers.nullHandler;return OpenLayers.Request.GET({url:uri,params:params,success:success,failure:failure,scope:caller});};OpenLayers.parseXMLString=function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
 var ajaxResponse=OpenLayers.Util.Try(function(){var xmldom=new ActiveXObject('Microsoft.XMLDOM');xmldom.loadXML(text);return xmldom;},function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
 req.send(null);return req.responseXML;});return ajaxResponse;};OpenLayers.Ajax={emptyFunction:function(){},getTransport:function(){return OpenLayers.Util.Try(function(){return new XMLHttpRequest();},function(){return new ActiveXObject('Msxml2.XMLHTTP');},function(){return new ActiveXObject('Microsoft.XMLHTTP');})||false;},activeRequestCount:0};OpenLayers.Ajax.Responders={responders:[],register:function(responderToAdd){for(var i=0;i<this.responders.length;i++){if(responderToAdd==this.responders[i]){return;}}
 this.responders.push(responderToAdd);},unregister:function(responderToRemove){OpenLayers.Util.removeItem(this.reponders,responderToRemove);},dispatch:function(callback,request,transport){var responder;for(var i=0;i<this.responders.length;i++){responder=this.responders[i];if(responder[callback]&&typeof responder[callback]=='function'){try{responder[callback].apply(responder,[request,transport]);}catch(e){}}}}};OpenLayers.Ajax.Responders.register({onCreate:function(){OpenLayers.Ajax.activeRequestCount++;},onComplete:function(){OpenLayers.Ajax.activeRequestCount--;}});OpenLayers.Ajax.Base=OpenLayers.Class({initialize:function(options){this.options={method:'post',asynchronous:true,contentType:'application/xml',parameters:''};OpenLayers.Util.extend(this.options,options||{});this.options.method=this.options.method.toLowerCase();if(typeof this.options.parameters=='string'){this.options.parameters=OpenLayers.Util.getParameters(this.options.parameters);}}});OpenLayers.Ajax.Request=OpenLayers.Class(OpenLayers.Ajax.Base,{_complete:false,initialize:function(url,options){OpenLayers.Ajax.Base.prototype.initialize.apply(this,[options]);if(OpenLayers.ProxyHost&&OpenLayers.String.startsWith(url,"http")){url=OpenLayers.ProxyHost+encodeURIComponent(url);}
@@ -186,7 +176,8 @@
 if(state=='Complete'){this.transport.onreadystatechange=OpenLayers.Ajax.emptyFunction;}},getHeader:function(name){try{return this.transport.getResponseHeader(name);}catch(e){return null;}},dispatchException:function(exception){var handler=this.options.onException;if(handler){handler(this,exception);OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{var listener=false;var responders=OpenLayers.Ajax.Responders.responders;for(var i=0;i<responders.length;i++){if(responders[i].onException){listener=true;break;}}
 if(listener){OpenLayers.Ajax.Responders.dispatch('onException',this,exception);}else{throw exception;}}}});OpenLayers.Ajax.Request.Events=['Uninitialized','Loading','Loaded','Interactive','Complete'];OpenLayers.Ajax.Response=OpenLayers.Class({status:0,statusText:'',initialize:function(request){this.request=request;var transport=this.transport=request.transport,readyState=this.readyState=transport.readyState;if((readyState>2&&!(!!(window.attachEvent&&!window.opera)))||readyState==4){this.status=this.getStatus();this.statusText=this.getStatusText();this.responseText=transport.responseText==null?'':String(transport.responseText);}
 if(readyState==4){var xml=transport.responseXML;this.responseXML=xml===undefined?null:xml;}},getStatus:OpenLayers.Ajax.Request.prototype.getStatus,getStatusText:function(){try{return this.transport.statusText||'';}catch(e){return'';}},getHeader:OpenLayers.Ajax.Request.prototype.getHeader,getResponseHeader:function(name){return this.transport.getResponseHeader(name);}});OpenLayers.Ajax.getElementsByTagNameNS=function(parentnode,nsuri,nsprefix,tagname){var elem=null;if(parentnode.getElementsByTagNameNS){elem=parentnode.getElementsByTagNameNS(nsuri,tagname);}else{elem=parentnode.getElementsByTagName(nsprefix+':'+tagname);}
-return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
+return elem;};OpenLayers.Ajax.serializeXMLToString=function(xmldom){var serializer=new XMLSerializer();var data=serializer.serializeToString(xmldom);return data;};OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
+return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Bounds=OpenLayers.Class({left:null,bottom:null,right:null,top:null,initialize:function(left,bottom,right,top){if(left!=null){this.left=parseFloat(left);}
 if(bottom!=null){this.bottom=parseFloat(bottom);}
 if(right!=null){this.right=parseFloat(right);}
 if(top!=null){this.top=parseFloat(top);}},clone:function(){return new OpenLayers.Bounds(this.left,this.bottom,this.right,this.top);},equals:function(bounds){var equals=false;if(bounds!=null){equals=((this.left==bounds.left)&&(this.right==bounds.right)&&(this.top==bounds.top)&&(this.bottom==bounds.bottom));}
@@ -218,8 +209,7 @@
 return newLonLat;},CLASS_NAME:"OpenLayers.LonLat"});OpenLayers.LonLat.fromString=function(str){var pair=str.split(",");return new OpenLayers.LonLat(parseFloat(pair[0]),parseFloat(pair[1]));};OpenLayers.Pixel=OpenLayers.Class({x:0.0,y:0.0,initialize:function(x,y){this.x=parseFloat(x);this.y=parseFloat(y);},toString:function(){return("x="+this.x+",y="+this.y);},clone:function(){return new OpenLayers.Pixel(this.x,this.y);},equals:function(px){var equals=false;if(px!=null){equals=((this.x==px.x&&this.y==px.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(px.x)&&isNaN(px.y)));}
 return equals;},add:function(x,y){if((x==null)||(y==null)){var msg=OpenLayers.i18n("pixelAddError");OpenLayers.Console.error(msg);return null;}
 return new OpenLayers.Pixel(this.x+x,this.y+y);},offset:function(px){var newPx=this.clone();if(px){newPx=this.add(px.x,px.y);}
-return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Size=OpenLayers.Class({w:0.0,h:0.0,initialize:function(w,h){this.w=parseFloat(w);this.h=parseFloat(h);},toString:function(){return("w="+this.w+",h="+this.h);},clone:function(){return new OpenLayers.Size(this.w,this.h);},equals:function(sz){var equals=false;if(sz!=null){equals=((this.w==sz.w&&this.h==sz.h)||(isNaN(this.w)&&isNaN(this.h)&&isNaN(sz.w)&&isNaN(sz.h)));}
-return equals;},CLASS_NAME:"OpenLayers.Size"});OpenLayers.Console={log:function(){},debug:function(){},info:function(){},warn:function(){},error:function(){},assert:function(){},dir:function(){},dirxml:function(){},trace:function(){},group:function(){},groupEnd:function(){},time:function(){},timeEnd:function(){},profile:function(){},profileEnd:function(){},count:function(){},CLASS_NAME:"OpenLayers.Console"};(function(){if(window.console){var scripts=document.getElementsByTagName("script");for(var i=0;i<scripts.length;++i){if(scripts[i].src.indexOf("firebug.js")!=-1){OpenLayers.Util.extend(OpenLayers.Console,console);break;}}}})();OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
+return newPx;},CLASS_NAME:"OpenLayers.Pixel"});OpenLayers.Control=OpenLayers.Class({id:null,map:null,div:null,type:null,allowSelection:false,displayClass:"",title:"",active:null,handler:null,eventListeners:null,events:null,EVENT_TYPES:["activate","deactivate"],initialize:function(options){this.displayClass=this.CLASS_NAME.replace("OpenLayers.","ol").replace(/\./g,"");OpenLayers.Util.extend(this,options);this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);if(this.eventListeners instanceof Object){this.events.on(this.eventListeners);}
 this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if(this.events){if(this.eventListeners){this.events.un(this.eventListeners);}
 this.events.destroy();this.events=null;}
 this.eventListeners=null;if(this.handler){this.handler.destroy();this.handler=null;}
@@ -243,43 +233,16 @@
 if(!lang){OpenLayers.Console.warn('Failed to find OpenLayers.Lang.'+parts.join("-")+' dictionary, falling back to default language');lang=OpenLayers.Lang.defaultCode;}
 OpenLayers.Lang.code=lang;},translate:function(key,context){var dictionary=OpenLayers.Lang[OpenLayers.Lang.getCode()];var message=dictionary[key];if(!message){message=key;}
 if(context){message=OpenLayers.String.format(message,context);}
-return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Popup=OpenLayers.Class({events:null,id:"",lonlat:null,div:null,size:null,contentHTML:"",backgroundColor:"",opacity:"",border:"",contentDiv:null,groupDiv:null,closeDiv:null,autoSize:false,minSize:null,maxSize:null,padding:0,fixPadding:function(){if(typeof this.padding=="number"){this.padding=new OpenLayers.Bounds(this.padding,this.padding,this.padding,this.padding);}},panMapIfOutOfView:false,map:null,initialize:function(id,lonlat,size,contentHTML,closeBox,closeBoxCallback){if(id==null){id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");}
-this.id=id;this.lonlat=lonlat;this.size=(size!=null)?size:new OpenLayers.Size(OpenLayers.Popup.WIDTH,OpenLayers.Popup.HEIGHT);if(contentHTML!=null){this.contentHTML=contentHTML;}
-this.backgroundColor=OpenLayers.Popup.COLOR;this.opacity=OpenLayers.Popup.OPACITY;this.border=OpenLayers.Popup.BORDER;this.div=OpenLayers.Util.createDiv(this.id,null,null,null,null,null,"hidden");this.div.className='olPopup';var groupDivId=this.id+"_GroupDiv";this.groupDiv=OpenLayers.Util.createDiv(groupDivId,null,null,null,"relative",null,"hidden");var id=this.div.id+"_contentDiv";this.contentDiv=OpenLayers.Util.createDiv(id,null,this.size.clone(),null,"relative");this.contentDiv.className='olPopupContent';this.groupDiv.appendChild(this.contentDiv);this.div.appendChild(this.groupDiv);if(closeBox){this.addCloseBox(closeBoxCallback);}
-this.registerEvents();},destroy:function(){this.id=null;this.lonlat=null;this.size=null;this.contentHTML=null;this.backgroundColor=null;this.opacity=null;this.border=null;this.events.destroy();this.events=null;if(this.closeDiv){OpenLayers.Event.stopObservingElement(this.closeDiv);this.groupDiv.removeChild(this.closeDiv);}
-this.closeDiv=null;this.div.removeChild(this.groupDiv);this.groupDiv=null;if(this.map!=null){this.map.removePopup(this);}
-this.map=null;this.div=null;this.autoSize=null;this.minSize=null;this.maxSize=null;this.padding=null;this.panMapIfOutOfView=null;},draw:function(px){if(px==null){if((this.lonlat!=null)&&(this.map!=null)){px=this.map.getLayerPxFromLonLat(this.lonlat);}}
-if(OpenLayers.Util.getBrowserName()=='firefox'){this.map.events.register("movestart",this,function(){var style=document.defaultView.getComputedStyle(this.contentDiv,null);var currentOverflow=style.getPropertyValue("overflow");if(currentOverflow!="hidden"){this.contentDiv._oldOverflow=currentOverflow;this.contentDiv.style.overflow="hidden";}});this.map.events.register("moveend",this,function(){var oldOverflow=this.contentDiv._oldOverflow;if(oldOverflow){this.contentDiv.style.overflow=oldOverflow;this.contentDiv._oldOverflow=null;}});}
-this.moveTo(px);if(!this.autoSize){this.setSize(this.size);}
-this.setBackgroundColor();this.setOpacity();this.setBorder();this.setContentHTML();if(this.panMapIfOutOfView){this.panIntoView();}
-return this.div;},updatePosition:function(){if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);if(px){this.moveTo(px);}}},moveTo:function(px){if((px!=null)&&(this.div!=null)){this.div.style.left=px.x+"px";this.div.style.top=px.y+"px";}},visible:function(){return OpenLayers.Element.visible(this.div);},toggle:function(){if(this.visible()){this.hide();}else{this.show();}},show:function(){OpenLayers.Element.show(this.div);if(this.panMapIfOutOfView){this.panIntoView();}},hide:function(){OpenLayers.Element.hide(this.div);},setSize:function(size){this.size=size;var contentSize=this.size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-this.size.w+=wPadding;this.size.h+=hPadding;if(OpenLayers.Util.getBrowserName()=="msie"){contentSize.w+=contentDivPadding.left+contentDivPadding.right;contentSize.h+=contentDivPadding.bottom+contentDivPadding.top;}
-if(this.div!=null){this.div.style.width=this.size.w+"px";this.div.style.height=this.size.h+"px";}
-if(this.contentDiv!=null){this.contentDiv.style.width=contentSize.w+"px";this.contentDiv.style.height=contentSize.h+"px";}},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){this.div.style.backgroundColor=this.backgroundColor;}},setOpacity:function(opacity){if(opacity!=undefined){this.opacity=opacity;}
-if(this.div!=null){this.div.style.opacity=this.opacity;this.div.style.filter='alpha(opacity='+this.opacity*100+')';}},setBorder:function(border){if(border!=undefined){this.border=border;}
-if(this.div!=null){this.div.style.border=this.border;}},setContentHTML:function(contentHTML){if(contentHTML!=null){this.contentHTML=contentHTML;}
-if(this.autoSize){var realSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML);var safeSize=this.getSafeContentSize(realSize);var newSize=null;if(safeSize.equals(realSize)){newSize=realSize;}else{var fixedSize=new OpenLayers.Size();fixedSize.w=(safeSize.w<realSize.w)?safeSize.w:null;fixedSize.h=(safeSize.h<realSize.h)?safeSize.h:null;if(fixedSize.w&&fixedSize.h){newSize=safeSize;}else{var clippedSize=OpenLayers.Util.getRenderedDimensions(this.contentHTML,fixedSize);var currentOverflow=OpenLayers.Element.getStyle(this.contentDiv,"overflow");if((currentOverflow!="hidden")&&(clippedSize.equals(safeSize))){var scrollBar=OpenLayers.Util.getScrollbarWidth();if(fixedSize.w){clippedSize.h+=scrollBar;}else{clippedSize.w+=scrollBar;}}
-newSize=this.getSafeContentSize(clippedSize);}}
-this.setSize(newSize);}
-if(this.contentDiv!=null){this.contentDiv.innerHTML=this.contentHTML;}},getSafeContentSize:function(size){var safeContentSize=size.clone();var contentDivPadding=this.getContentDivPadding();var wPadding=contentDivPadding.left+contentDivPadding.right;var hPadding=contentDivPadding.top+contentDivPadding.bottom;this.fixPadding();wPadding+=this.padding.left+this.padding.right;hPadding+=this.padding.top+this.padding.bottom;if(this.closeDiv){var closeDivWidth=parseInt(this.closeDiv.style.width);wPadding+=closeDivWidth+contentDivPadding.right;}
-if(this.minSize){safeContentSize.w=Math.max(safeContentSize.w,(this.minSize.w-wPadding));safeContentSize.h=Math.max(safeContentSize.h,(this.minSize.h-hPadding));}
-if(this.maxSize){safeContentSize.w=Math.min(safeContentSize.w,(this.maxSize.w-wPadding));safeContentSize.h=Math.min(safeContentSize.h,(this.maxSize.h-hPadding));}
-if(this.map&&this.map.size){var maxY=this.map.size.h-
-this.map.paddingForPopups.top-
-this.map.paddingForPopups.bottom-
-hPadding;var maxX=this.map.size.w-
-this.map.paddingForPopups.left-
-this.map.paddingForPopups.right-
-wPadding;safeContentSize.w=Math.min(safeContentSize.w,maxX);safeContentSize.h=Math.min(safeContentSize.h,maxY);}
-return safeContentSize;},getContentDivPadding:function(){var contentDivPadding=this._contentDivPadding;if(!contentDivPadding){this.div.style.display="none";document.body.appendChild(this.div);contentDivPadding=new OpenLayers.Bounds(OpenLayers.Element.getStyle(this.contentDiv,"padding-left"),OpenLayers.Element.getStyle(this.contentDiv,"padding-bottom"),OpenLayers.Element.getStyle(this.contentDiv,"padding-right"),OpenLayers.Element.getStyle(this.contentDiv,"padding-top"));this._contentDivPadding=contentDivPadding;document.body.removeChild(this.div);this.div.style.display="";}
-return contentDivPadding;},addCloseBox:function(callback){this.closeDiv=OpenLayers.Util.createDiv(this.id+"_close",null,new OpenLayers.Size(17,17));this.closeDiv.className="olPopupCloseBox";var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+"px";this.closeDiv.style.top=contentDivPadding.top+"px";this.groupDiv.appendChild(this.closeDiv);var closePopup=callback||function(e){this.hide();OpenLayers.Event.stop(e);};OpenLayers.Event.observe(this.closeDiv,"click",OpenLayers.Function.bindAsEventListener(closePopup,this));},panIntoView:function(){var mapSize=this.map.getSize();var origTL=this.map.getViewPortPxFromLayerPx(new OpenLayers.Pixel(parseInt(this.div.style.left),parseInt(this.div.style.top)));var newTL=origTL.clone();if(origTL.x<this.map.paddingForPopups.left){newTL.x=this.map.paddingForPopups.left;}else
-if((origTL.x+this.size.w)>(mapSize.w-this.map.paddingForPopups.right)){newTL.x=mapSize.w-this.map.paddingForPopups.right-this.size.w;}
-if(origTL.y<this.map.paddingForPopups.top){newTL.y=this.map.paddingForPopups.top;}else
-if((origTL.y+this.size.h)>(mapSize.h-this.map.paddingForPopups.bottom)){newTL.y=mapSize.h-this.map.paddingForPopups.bottom-this.size.h;}
-var dx=origTL.x-newTL.x;var dy=origTL.y-newTL.y;this.map.pan(dx,dy);},registerEvents:function(){this.events=new OpenLayers.Events(this,this.div,null,true);this.events.on({"mousedown":this.onmousedown,"mousemove":this.onmousemove,"mouseup":this.onmouseup,"click":this.onclick,"mouseout":this.onmouseout,"dblclick":this.ondblclick,scope:this});},onmousedown:function(evt){this.mousedown=true;OpenLayers.Event.stop(evt,true);},onmousemove:function(evt){if(this.mousedown){OpenLayers.Event.stop(evt,true);}},onmouseup:function(evt){if(this.mousedown){this.mousedown=false;OpenLayers.Event.stop(evt,true);}},onclick:function(evt){OpenLayers.Event.stop(evt,true);},onmouseout:function(evt){this.mousedown=false;},ondblclick:function(evt){OpenLayers.Event.stop(evt,true);},CLASS_NAME:"OpenLayers.Popup"});OpenLayers.Popup.WIDTH=200;OpenLayers.Popup.HEIGHT=200;OpenLayers.Popup.COLOR="white";OpenLayers.Popup.OPACITY=1;OpenLayers.Popup.BORDER="0px";OpenLayers.Renderer=OpenLayers.Class({container:null,extent:null,size:null,resolution:null,map:null,initialize:function(containerID){this.container=OpenLayers.Util.getElement(containerID);},destroy:function(){this.container=null;this.extent=null;this.size=null;this.resolution=null;this.map=null;},supported:function(){return false;},setExtent:function(extent){this.extent=extent.clone();this.resolution=null;},setSize:function(size){this.size=size.clone();this.resolution=null;},getResolution:function(){this.resolution=this.resolution||this.map.getResolution();return this.resolution;},drawFeature:function(feature,style){if(style==null){style=feature.style;}
-if(feature.geometry){this.drawGeometry(feature.geometry,style,feature.id);}},drawGeometry:function(geometry,style,featureId){},clear:function(){},getFeatureIdFromEvent:function(evt){},eraseFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=0;i<features.length;++i){this.eraseGeometry(features[i].geometry);}},eraseGeometry:function(geometry){},CLASS_NAME:"OpenLayers.Renderer"});OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
+return message;}};OpenLayers.i18n=OpenLayers.Lang.translate;OpenLayers.Request={DEFAULT_CONFIG:{method:"GET",url:window.location.href,async:true,user:undefined,password:undefined,params:null,proxy:OpenLayers.ProxyHost,headers:{},data:null,callback:function(){},success:null,failure:null,scope:null},issue:function(config){var defaultConfig=OpenLayers.Util.extend(this.DEFAULT_CONFIG,{proxy:OpenLayers.ProxyHost});config=OpenLayers.Util.applyDefaults(config,defaultConfig);var request=new OpenLayers.Request.XMLHttpRequest();var url=config.url;if(config.params){url+="?"+OpenLayers.Util.getParameterString(config.params);}
+if(config.proxy&&(url.indexOf("http")==0)){url=config.proxy+encodeURIComponent(url);}
+request.open(config.method,url,config.async,config.user,config.password);for(var header in config.headers){request.setRequestHeader(header,config.headers[header]);}
+var complete=(config.scope)?OpenLayers.Function.bind(config.callback,config.scope):config.callback;var success;if(config.success){success=(config.scope)?OpenLayers.Function.bind(config.success,config.scope):config.success;}
+var failure;if(config.failure){failure=(config.scope)?OpenLayers.Function.bind(config.failure,config.scope):config.failure;}
+request.onreadystatechange=function(){if(request.readyState==OpenLayers.Request.XMLHttpRequest.DONE){complete(request);if(success&&request.status>=200&&request.status<300){success(request);}
+if(failure&&(request.status<200||request.status>=300)){failure(request);}}}
+request.send(config.data);return request;},GET:function(config){config=OpenLayers.Util.extend(config,{method:"GET"});return OpenLayers.Request.issue(config);},POST:function(config){config=OpenLayers.Util.extend(config,{method:"POST"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},PUT:function(config){config=OpenLayers.Util.extend(config,{method:"PUT"});config.headers=config.headers?config.headers:{};if(!("CONTENT-TYPE"in OpenLayers.Util.upperCaseObject(config.headers))){config.headers["Content-Type"]="application/xml";}
+return OpenLayers.Request.issue(config);},DELETE:function(config){config=OpenLayers.Util.extend(config,{method:"DELETE"});return OpenLayers.Request.issue(config);},HEAD:function(config){config=OpenLayers.Util.extend(config,{method:"HEAD"});return OpenLayers.Request.issue(config);},OPTIONS:function(config){config=OpenLayers.Util.extend(config,{method:"OPTIONS"});return OpenLayers.Request.issue(config);}};OpenLayers.Tween=OpenLayers.Class({INTERVAL:10,easing:null,begin:null,finish:null,duration:null,callbacks:null,time:null,interval:null,playing:false,initialize:function(easing){this.easing=(easing)?easing:OpenLayers.Easing.Expo.easeOut;},start:function(begin,finish,duration,options){this.playing=true;this.begin=begin;this.finish=finish;this.duration=duration;this.callbacks=options.callbacks;this.time=0;if(this.interval){window.clearInterval(this.interval);this.interval=null;}
 if(this.callbacks&&this.callbacks.start){this.callbacks.start.call(this,this.begin);}
 this.interval=window.setInterval(OpenLayers.Function.bind(this.play,this),this.INTERVAL);},stop:function(){if(!this.playing){return;}
 if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);}
@@ -287,110 +250,31 @@
 var c=f-b;value[i]=this.easing.apply(this,[this.time,b,c,this.duration]);}
 this.time++;if(this.callbacks&&this.callbacks.eachStep){this.callbacks.eachStep.call(this,value);}
 if(this.time>this.duration){if(this.callbacks&&this.callbacks.done){this.callbacks.done.call(this,this.finish);this.playing=false;}
-window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Rico.Color=OpenLayers.Class({initialize:function(red,green,blue){this.rgb={r:red,g:green,b:blue};},setRed:function(r){this.rgb.r=r;},setGreen:function(g){this.rgb.g=g;},setBlue:function(b){this.rgb.b=b;},setHue:function(h){var hsb=this.asHSB();hsb.h=h;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setSaturation:function(s){var hsb=this.asHSB();hsb.s=s;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},setBrightness:function(b){var hsb=this.asHSB();hsb.b=b;this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,hsb.b);},darken:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.max(hsb.b-percent,0));},brighten:function(percent){var hsb=this.asHSB();this.rgb=OpenLayers.Rico.Color.HSBtoRGB(hsb.h,hsb.s,Math.min(hsb.b+percent,1));},blend:function(other){this.rgb.r=Math.floor((this.rgb.r+other.rgb.r)/2);this.rgb.g=Math.floor((this.rgb.g+other.rgb.g)/2);this.rgb.b=Math.floor((this.rgb.b+other.rgb.b)/2);},isBright:function(){var hsb=this.asHSB();return this.asHSB().b>0.5;},isDark:function(){return!this.isBright();},asRGB:function(){return"rgb("+this.rgb.r+","+this.rgb.g+","+this.rgb.b+")";},asHex:function(){return"#"+this.rgb.r.toColorPart()+this.rgb.g.toColorPart()+this.rgb.b.toColorPart();},asHSB:function(){return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r,this.rgb.g,this.rgb.b);},toString:function(){return this.asHex();}});OpenLayers.Rico.Color.createFromHex=function(hexCode){if(hexCode.length==4){var shortHexCode=hexCode;var hexCode='#';for(var i=1;i<4;i++){hexCode+=(shortHexCode.charAt(i)+
-shortHexCode.charAt(i));}}
-if(hexCode.indexOf('#')==0){hexCode=hexCode.substring(1);}
-var red=hexCode.substring(0,2);var green=hexCode.substring(2,4);var blue=hexCode.substring(4,6);return new OpenLayers.Rico.Color(parseInt(red,16),parseInt(green,16),parseInt(blue,16));};OpenLayers.Rico.Color.createColorFromBackground=function(elem){var actualColor=RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),"backgroundColor","background-color");if(actualColor=="transparent"&&elem.parentNode){return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);}
-if(actualColor==null){return new OpenLayers.Rico.Color(255,255,255);}
-if(actualColor.indexOf("rgb(")==0){var colors=actualColor.substring(4,actualColor.length-1);var colorArray=colors.split(",");return new OpenLayers.Rico.Color(parseInt(colorArray[0]),parseInt(colorArray[1]),parseInt(colorArray[2]));}
-else if(actualColor.indexOf("#")==0){return OpenLayers.Rico.Color.createFromHex(actualColor);}
-else{return new OpenLayers.Rico.Color(255,255,255);}};OpenLayers.Rico.Color.HSBtoRGB=function(hue,saturation,brightness){var red=0;var green=0;var blue=0;if(saturation==0){red=parseInt(brightness*255.0+0.5);green=red;blue=red;}
-else{var h=(hue-Math.floor(hue))*6.0;var f=h-Math.floor(h);var p=brightness*(1.0-saturation);var q=brightness*(1.0-saturation*f);var t=brightness*(1.0-(saturation*(1.0-f)));switch(parseInt(h)){case 0:red=(brightness*255.0+0.5);green=(t*255.0+0.5);blue=(p*255.0+0.5);break;case 1:red=(q*255.0+0.5);green=(brightness*255.0+0.5);blue=(p*255.0+0.5);break;case 2:red=(p*255.0+0.5);green=(brightness*255.0+0.5);blue=(t*255.0+0.5);break;case 3:red=(p*255.0+0.5);green=(q*255.0+0.5);blue=(brightness*255.0+0.5);break;case 4:red=(t*255.0+0.5);green=(p*255.0+0.5);blue=(brightness*255.0+0.5);break;case 5:red=(brightness*255.0+0.5);green=(p*255.0+0.5);blue=(q*255.0+0.5);break;}}
-return{r:parseInt(red),g:parseInt(green),b:parseInt(blue)};};OpenLayers.Rico.Color.RGBtoHSB=function(r,g,b){var hue;var saturation;var brightness;var cmax=(r>g)?r:g;if(b>cmax){cmax=b;}
-var cmin=(r<g)?r:g;if(b<cmin){cmin=b;}
-brightness=cmax/255.0;if(cmax!=0){saturation=(cmax-cmin)/cmax;}else{saturation=0;}
-if(saturation==0){hue=0;}else{var redc=(cmax-r)/(cmax-cmin);var greenc=(cmax-g)/(cmax-cmin);var bluec=(cmax-b)/(cmax-cmin);if(r==cmax){hue=bluec-greenc;}else if(g==cmax){hue=2.0+redc-bluec;}else{hue=4.0+greenc-redc;}
-hue=hue/6.0;if(hue<0){hue=hue+1.0;}}
-return{h:hue,s:saturation,b:brightness};};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
+window.clearInterval(this.interval);this.interval=null;}},CLASS_NAME:"OpenLayers.Tween"});OpenLayers.Easing={CLASS_NAME:"OpenLayers.Easing"};OpenLayers.Easing.Linear={easeIn:function(t,b,c,d){return c*t/d+b;},easeOut:function(t,b,c,d){return c*t/d+b;},easeInOut:function(t,b,c,d){return c*t/d+b;},CLASS_NAME:"OpenLayers.Easing.Linear"};OpenLayers.Easing.Expo={easeIn:function(t,b,c,d){return(t==0)?b:c*Math.pow(2,10*(t/d-1))+b;},easeOut:function(t,b,c,d){return(t==d)?b+c:c*(-Math.pow(2,-10*t/d)+1)+b;},easeInOut:function(t,b,c,d){if(t==0)return b;if(t==d)return b+c;if((t/=d/2)<1)return c/2*Math.pow(2,10*(t-1))+b;return c/2*(-Math.pow(2,-10*--t)+2)+b;},CLASS_NAME:"OpenLayers.Easing.Expo"};OpenLayers.Easing.Quad={easeIn:function(t,b,c,d){return c*(t/=d)*t+b;},easeOut:function(t,b,c,d){return-c*(t/=d)*(t-2)+b;},easeInOut:function(t,b,c,d){if((t/=d/2)<1)return c/2*t*t+b;return-c/2*((--t)*(t-2)-1)+b;},CLASS_NAME:"OpenLayers.Easing.Quad"};OpenLayers.Control.ArgParser=OpenLayers.Class(OpenLayers.Control,{center:null,zoom:null,layers:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if((control!=this)&&(control.CLASS_NAME=="OpenLayers.Control.ArgParser")){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
 break;}}
 if(i==this.map.controls.length){var args=OpenLayers.Util.getParameters();if(args.layers){this.layers=args.layers;this.map.events.register('addlayer',this,this.configureLayers);this.configureLayers();}
 if(args.lat&&args.lon){this.center=new OpenLayers.LonLat(parseFloat(args.lon),parseFloat(args.lat));if(args.zoom){this.zoom=parseInt(args.zoom);}
 this.map.events.register('changebaselayer',this,this.setCenter);this.setCenter();}}},setCenter:function(){if(this.map.baseLayer){this.map.events.unregister('changebaselayer',this,this.setCenter);if(this.displayProjection){this.center.transform(this.displayProjection,this.map.getProjectionObject());}
-this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.Attribution=OpenLayers.Class(OpenLayers.Control,{separator:", ",initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.map.events.un({"removelayer":this.updateAttribution,"addlayer":this.updateAttribution,"changelayer":this.updateAttribution,"changebaselayer":this.updateAttribution,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.map.events.on({'changebaselayer':this.updateAttribution,'changelayer':this.updateAttribution,'addlayer':this.updateAttribution,'removelayer':this.updateAttribution,scope:this});this.updateAttribution();return this.div;},updateAttribution:function(){var attributions=[];if(this.map&&this.map.layers){for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.attribution&&layer.getVisibility()){attributions.push(layer.attribution);}}
-this.div.innerHTML=attributions.join(this.separator);}},CLASS_NAME:"OpenLayers.Control.Attribution"});OpenLayers.Control.Button=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){},CLASS_NAME:"OpenLayers.Control.Button"});OpenLayers.Control.LayerSwitcher=OpenLayers.Class(OpenLayers.Control,{activeColor:"darkblue",layerStates:null,layersDiv:null,baseLayersDiv:null,baseLayers:null,dataLbl:null,dataLayersDiv:null,dataLayers:null,minimizeDiv:null,maximizeDiv:null,ascending:true,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.layerStates=[];},destroy:function(){OpenLayers.Event.stopObservingElement(this.div);OpenLayers.Event.stopObservingElement(this.minimizeDiv);OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.clearLayersArray("base");this.clearLayersArray("data");this.map.events.un({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.on({"addlayer":this.redraw,"changelayer":this.redraw,"removelayer":this.redraw,"changebaselayer":this.redraw,scope:this});},draw:function(){OpenLayers.Control.prototype.draw.apply(this);this.loadContents();if(!this.outsideViewport){this.minimizeControl();}
-this.redraw();return this.div;},clearLayersArray:function(layersType){var layers=this[layersType+"Layers"];if(layers){for(var i=0;i<layers.length;i++){var layer=layers[i];OpenLayers.Event.stopObservingElement(layer.inputElem);OpenLayers.Event.stopObservingElement(layer.labelSpan);}}
-this[layersType+"LayersDiv"].innerHTML="";this[layersType+"Layers"]=[];},checkRedraw:function(){var redraw=false;if(!this.layerStates.length||(this.map.layers.length!=this.layerStates.length)){redraw=true;}else{for(var i=0;i<this.layerStates.length;i++){var layerState=this.layerStates[i];var layer=this.map.layers[i];if((layerState.name!=layer.name)||(layerState.inRange!=layer.inRange)||(layerState.id!=layer.id)||(layerState.visibility!=layer.visibility)){redraw=true;break;}}}
-return redraw;},redraw:function(){if(!this.checkRedraw()){return this.div;}
-this.clearLayersArray("base");this.clearLayersArray("data");var containsOverlays=false;var containsBaseLayers=false;this.layerStates=new Array(this.map.layers.length);for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];this.layerStates[i]={'name':layer.name,'visibility':layer.visibility,'inRange':layer.inRange,'id':layer.id};}
-var layers=this.map.layers.slice();if(!this.ascending){layers.reverse();}
-for(var i=0;i<layers.length;i++){var layer=layers[i];var baseLayer=layer.isBaseLayer;if(layer.displayInLayerSwitcher){if(baseLayer){containsBaseLayers=true;}else{containsOverlays=true;}
-var checked=(baseLayer)?(layer==this.map.baseLayer):layer.getVisibility();var inputElem=document.createElement("input");inputElem.id="input_"+layer.name;inputElem.name=(baseLayer)?"baseLayers":layer.name;inputElem.type=(baseLayer)?"radio":"checkbox";inputElem.value=layer.name;inputElem.checked=checked;inputElem.defaultChecked=checked;if(!baseLayer&&!layer.inRange){inputElem.disabled=true;}
-var context={'inputElem':inputElem,'layer':layer,'layerSwitcher':this};OpenLayers.Event.observe(inputElem,"mouseup",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var labelSpan=document.createElement("span");if(!baseLayer&&!layer.inRange){labelSpan.style.color="gray";}
-labelSpan.innerHTML=layer.name;labelSpan.style.verticalAlign=(baseLayer)?"bottom":"baseline";OpenLayers.Event.observe(labelSpan,"click",OpenLayers.Function.bindAsEventListener(this.onInputClick,context));var br=document.createElement("br");var groupArray=(baseLayer)?this.baseLayers:this.dataLayers;groupArray.push({'layer':layer,'inputElem':inputElem,'labelSpan':labelSpan});var groupDiv=(baseLayer)?this.baseLayersDiv:this.dataLayersDiv;groupDiv.appendChild(inputElem);groupDiv.appendChild(labelSpan);groupDiv.appendChild(br);}}
-this.dataLbl.style.display=(containsOverlays)?"":"none";this.baseLbl.style.display=(containsBaseLayers)?"":"none";return this.div;},onInputClick:function(e){if(!this.inputElem.disabled){if(this.inputElem.type=="radio"){this.inputElem.checked=true;this.layer.map.setBaseLayer(this.layer);}else{this.inputElem.checked=!this.inputElem.checked;this.layerSwitcher.updateMap();}}
-OpenLayers.Event.stop(e);},onLayerClick:function(e){this.updateMap();},updateMap:function(){for(var i=0;i<this.baseLayers.length;i++){var layerEntry=this.baseLayers[i];if(layerEntry.inputElem.checked){this.map.setBaseLayer(layerEntry.layer,false);}}
-for(var i=0;i<this.dataLayers.length;i++){var layerEntry=this.dataLayers[i];layerEntry.layer.setVisibility(layerEntry.inputElem.checked);}},maximizeControl:function(e){this.div.style.width="20em";this.div.style.height="";this.showControls(false);if(e!=null){OpenLayers.Event.stop(e);}},minimizeControl:function(e){this.div.style.width="0px";this.div.style.height="0px";this.showControls(true);if(e!=null){OpenLayers.Event.stop(e);}},showControls:function(minimize){this.maximizeDiv.style.display=minimize?"":"none";this.minimizeDiv.style.display=minimize?"none":"";this.layersDiv.style.display=minimize?"none":"";},loadContents:function(){this.div.style.position="absolute";this.div.style.top="25px";this.div.style.right="0px";this.div.style.left="";this.div.style.fontFamily="sans-serif";this.div.style.fontWeight="bold";this.div.style.marginTop="3px";this.div.style.marginLeft="3px";this.div.style.marginBottom="3px";this.div.style.fontSize="smaller";this.div.style.color="white";this.div.style.backgroundColor="transparent";OpenLayers.Event.observe(this.div,"mouseup",OpenLayers.Function.bindAsEventListener(this.mouseUp,this));OpenLayers.Event.observe(this.div,"click",this.ignoreEvent);OpenLayers.Event.observe(this.div,"mousedown",OpenLayers.Function.bindAsEventListener(this.mouseDown,this));OpenLayers.Event.observe(this.div,"dblclick",this.ignoreEvent);this.layersDiv=document.createElement("div");this.layersDiv.id="layersDiv";this.layersDiv.style.paddingTop="5px";this.layersDiv.style.paddingLeft="10px";this.layersDiv.style.paddingBottom="5px";this.layersDiv.style.paddingRight="75px";this.layersDiv.style.backgroundColor=this.activeColor;this.layersDiv.style.width="100%";this.layersDiv.style.height="100%";this.baseLbl=document.createElement("div");this.baseLbl.innerHTML=OpenLayers.i18n("baseLayer");this.baseLbl.style.marginTop="3px";this.baseLbl.style.marginLeft="3px";this.baseLbl.style.marginBottom="3px";this.baseLayersDiv=document.createElement("div");this.baseLayersDiv.style.paddingLeft="10px";this.dataLbl=document.createElement("div");this.dataLbl.innerHTML=OpenLayers.i18n("overlays");this.dataLbl.style.marginTop="3px";this.dataLbl.style.marginLeft="3px";this.dataLbl.style.marginBottom="3px";this.dataLayersDiv=document.createElement("div");this.dataLayersDiv.style.paddingLeft="10px";if(this.ascending){this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);}else{this.layersDiv.appendChild(this.dataLbl);this.layersDiv.appendChild(this.dataLayersDiv);this.layersDiv.appendChild(this.baseLbl);this.layersDiv.appendChild(this.baseLayersDiv);}
-this.div.appendChild(this.layersDiv);OpenLayers.Rico.Corner.round(this.div,{corners:"tl bl",bgColor:"transparent",color:this.activeColor,blend:false});OpenLayers.Rico.Corner.changeOpacity(this.layersDiv,0.75);var imgLocation=OpenLayers.Util.getImagesLocation();var sz=new OpenLayers.Size(18,18);var img=imgLocation+'layer-switcher-maximize.png';this.maximizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MaximizeDiv",null,sz,img,"absolute");this.maximizeDiv.style.top="5px";this.maximizeDiv.style.right="0px";this.maximizeDiv.style.left="";this.maximizeDiv.style.display="none";OpenLayers.Event.observe(this.maximizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.maximizeControl,this));this.div.appendChild(this.maximizeDiv);var img=imgLocation+'layer-switcher-minimize.png';var sz=new OpenLayers.Size(18,18);this.minimizeDiv=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MinimizeDiv",null,sz,img,"absolute");this.minimizeDiv.style.top="5px";this.minimizeDiv.style.right="0px";this.minimizeDiv.style.left="";this.minimizeDiv.style.display="none";OpenLayers.Event.observe(this.minimizeDiv,"click",OpenLayers.Function.bindAsEventListener(this.minimizeControl,this));this.div.appendChild(this.minimizeDiv);},ignoreEvent:function(evt){OpenLayers.Event.stop(evt);},mouseDown:function(evt){this.isMouseDown=true;this.ignoreEvent(evt);},mouseUp:function(evt){if(this.isMouseDown){this.isMouseDown=false;this.ignoreEvent(evt);}},CLASS_NAME:"OpenLayers.Control.LayerSwitcher"});OpenLayers.Control.MouseDefaults=OpenLayers.Class(OpenLayers.Control,{performedDrag:false,wheelObserver:null,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;this.map.events.un({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});OpenLayers.Event.stopObserving(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.stopObserving(window,"mousewheel",this.wheelObserver);OpenLayers.Event.stopObserving(document,"mousewheel",this.wheelObserver);this.wheelObserver=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.map.events.on({"click":this.defaultClick,"dblclick":this.defaultDblClick,"mousedown":this.defaultMouseDown,"mouseup":this.defaultMouseUp,"mousemove":this.defaultMouseMove,"mouseout":this.defaultMouseOut,scope:this});this.registerWheelEvents();},registerWheelEvents:function(){this.wheelObserver=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);OpenLayers.Event.observe(window,"DOMMouseScroll",this.wheelObserver);OpenLayers.Event.observe(window,"mousewheel",this.wheelObserver);OpenLayers.Event.observe(document,"mousewheel",this.wheelObserver);},defaultClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var notAfterDrag=!this.performedDrag;this.performedDrag=false;return notAfterDrag;},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;if(evt.shiftKey){this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},defaultMouseMove:function(evt){this.mousePosition=evt.xy.clone();if(this.mouseDragStart!=null){if(this.zoomBox){var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-if(evt.xy.y<this.mouseDragStart.y){this.zoomBox.style.top=evt.xy.y+"px";}}else{var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();this.map.div.style.cursor="move";}
-this.performedDrag=true;}},defaultMouseUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomBox){this.zoomBoxEnd(evt);}else{if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();}
-this.mouseDragStart=null;}},defaultWheelUp:function(evt){if(this.map.getZoom()<=this.map.getNumZoomLevels()){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()+1);}},defaultWheelDown:function(evt){if(this.map.getZoom()>0){this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),this.map.getZoom()-1);}},zoomBoxEnd:function(evt){if(this.mouseDragStart!=null){if(Math.abs(this.mouseDragStart.x-evt.xy.x)>5||Math.abs(this.mouseDragStart.y-evt.xy.y)>5){var start=this.map.getLonLatFromViewPortPx(this.mouseDragStart);var end=this.map.getLonLatFromViewPortPx(evt.xy);var top=Math.max(start.lat,end.lat);var bottom=Math.min(start.lat,end.lat);var left=Math.min(start.lon,end.lon);var right=Math.max(start.lon,end.lon);var bounds=new OpenLayers.Bounds(left,bottom,right,top);this.map.zoomToExtent(bounds);}else{var end=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(new OpenLayers.LonLat((end.lon),(end.lat)),this.map.getZoom()+1);}
-this.removeZoomBox();}},removeZoomBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},onWheelEvent:function(e){var inMap=false;var elem=OpenLayers.Event.element(e);while(elem!=null){if(this.map&&elem==this.map.div){inMap=true;break;}
-elem=elem.parentNode;}
-if(inMap){var delta=0;if(!e){e=window.event;}
-if(e.wheelDelta){delta=e.wheelDelta/120;if(window.opera&&window.opera.version()<9.2){delta=-delta;}}else if(e.detail){delta=-e.detail/3;}
-if(delta){e.xy=this.mousePosition;if(delta<0){this.defaultWheelDown(e);}else{this.defaultWheelUp(e);}}
-OpenLayers.Event.stop(e);}},CLASS_NAME:"OpenLayers.Control.MouseDefaults"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numdigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
+this.map.setCenter(this.center,this.zoom);}},configureLayers:function(){if(this.layers.length==this.map.layers.length){this.map.events.unregister('addlayer',this,this.configureLayers);for(var i=0;i<this.layers.length;i++){var layer=this.map.layers[i];var c=this.layers.charAt(i);if(c=="B"){this.map.setBaseLayer(layer);}else if((c=="T")||(c=="F")){layer.setVisibility(c=="T");}}}},CLASS_NAME:"OpenLayers.Control.ArgParser"});OpenLayers.Control.MousePosition=OpenLayers.Class(OpenLayers.Control,{element:null,prefix:'',separator:', ',suffix:'',numDigits:5,granularity:10,lastXy:null,displayProjection:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.map){this.map.events.unregister('mousemove',this,this.redraw);}
 OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.div.left="";this.div.top="";this.element=this.div;}
 this.redraw();return this.div;},redraw:function(evt){var lonLat;if(evt==null){lonLat=new OpenLayers.LonLat(0,0);}else{if(this.lastXy==null||Math.abs(evt.xy.x-this.lastXy.x)>this.granularity||Math.abs(evt.xy.y-this.lastXy.y)>this.granularity)
 {this.lastXy=evt.xy;return;}
 lonLat=this.map.getLonLatFromPixel(evt.xy);if(!lonLat){return;}
 if(this.displayProjection){lonLat.transform(this.map.getProjectionObject(),this.displayProjection);}
 this.lastXy=evt.xy;}
-var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numdigits);var newHtml=this.prefix+
+var newHtml=this.formatOutput(lonLat);if(newHtml!=this.element.innerHTML){this.element.innerHTML=newHtml;}},formatOutput:function(lonLat){var digits=parseInt(this.numDigits);var newHtml=this.prefix+
 lonLat.lon.toFixed(digits)+
 this.separator+
 lonLat.lat.toFixed(digits)+
-this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.NavigationHistory=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOGGLE,previous:null,previousOptions:null,next:null,nextOptions:null,limit:50,activateOnDraw:true,clearOnDeactivate:false,registry:null,nextStack:null,previousStack:null,listeners:null,restoring:false,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.registry=OpenLayers.Util.extend({"moveend":function(){return{center:this.map.getCenter(),resolution:this.map.getResolution()};}},this.registry);this.clear();var previousOptions={trigger:OpenLayers.Function.bind(this.previousTrigger,this),displayClass:this.displayClass+"Previous"};OpenLayers.Util.extend(previousOptions,this.previousOptions);this.previous=new OpenLayers.Control.Button(previousOptions);var nextOptions={trigger:OpenLayers.Function.bind(this.nextTrigger,this),displayClass:this.displayClass+"Next"};OpenLayers.Util.extend(nextOptions,this.nextOptions);this.next=new OpenLayers.Control.Button(nextOptions);},onPreviousChange:function(state,length){if(state&&!this.previous.active){this.previous.activate();}else if(!state&&this.previous.active){this.previous.deactivate();}},onNextChange:function(state,length){if(state&&!this.next.active){this.next.activate();}else if(!state&&this.next.active){this.next.deactivate();}},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this);this.previous.destroy();this.next.destroy();this.deactivate();for(var prop in this){this[prop]=null;}},setMap:function(map){this.map=map;this.next.setMap(map);this.previous.setMap(map);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);this.next.draw();this.previous.draw();if(this.activateOnDraw){this.activate();}},previousTrigger:function(){var current=this.previousStack.shift();var state=this.previousStack.shift();if(state!=undefined){this.nextStack.unshift(current);this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}else{this.previousStack.unshift(current);}
-return state;},nextTrigger:function(){var state=this.nextStack.shift();if(state!=undefined){this.previousStack.unshift(state);this.restoring=true;this.restore(state);this.restoring=false;this.onNextChange(this.nextStack[0],this.nextStack.length);this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-return state;},clear:function(){this.previousStack=[];this.nextStack=[];},restore:function(state){var zoom=this.map.getZoomForResolution(state.resolution);this.map.setCenter(state.center,zoom);},setListeners:function(){this.listeners={};for(var type in this.registry){this.listeners[type]=OpenLayers.Function.bind(function(){if(!this.restoring){var state=this.registry[type].apply(this,arguments);this.previousStack.unshift(state);if(this.previousStack.length>1){this.onPreviousChange(this.previousStack[1],this.previousStack.length-1);}
-if(this.previousStack.length>(this.limit+1)){this.previousStack.pop();}
-if(this.nextStack.length>0){this.nextStack=[];this.onNextChange(null,0);}}
-return true;},this);}},activate:function(){var activated=false;if(this.map){if(OpenLayers.Control.prototype.activate.apply(this)){if(this.listeners==null){this.setListeners();}
-for(var type in this.listeners){this.map.events.register(type,this,this.listeners[type]);}
-activated=true;if(this.previousStack.length==0){this.initStack();}}}
-return activated;},initStack:function(){if(this.map.getCenter()){this.listeners.moveend();}},deactivate:function(){var deactivated=false;if(this.map){if(OpenLayers.Control.prototype.deactivate.apply(this)){for(var type in this.listeners){this.map.events.unregister(type,this,this.listeners[type]);}
-if(this.clearOnDeactivate){this.clear();}
-deactivated=true;}}
-return deactivated;},CLASS_NAME:"OpenLayers.Control.NavigationHistory"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
+this.suffix;return newHtml;},setMap:function(){OpenLayers.Control.prototype.setMap.apply(this,arguments);this.map.events.register('mousemove',this,this.redraw);},CLASS_NAME:"OpenLayers.Control.MousePosition"});OpenLayers.Control.PanZoom=OpenLayers.Class(OpenLayers.Control,{slideFactor:50,buttons:null,position:null,initialize:function(options){this.position=new OpenLayers.Pixel(OpenLayers.Control.PanZoom.X,OpenLayers.Control.PanZoom.Y);OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);while(this.buttons.length){var btn=this.buttons.shift();btn.map=null;OpenLayers.Event.stopObservingElement(btn);}
 this.buttons=null;this.position=null;},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position;this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);this._addButton("panright","east-mini.png",px.add(sz.w,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);this._addButton("zoomworld","zoom-world-mini.png",centered.add(0,sz.h*4+5),sz);this._addButton("zoomout","zoom-minus-mini.png",centered.add(0,sz.h*5+5),sz);return this.div;},_addButton:function(id,img,xy,sz){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_PanZoom_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);OpenLayers.Event.observe(btn,"mousedown",OpenLayers.Function.bindAsEventListener(this.buttonDown,btn));OpenLayers.Event.observe(btn,"dblclick",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));OpenLayers.Event.observe(btn,"click",OpenLayers.Function.bindAsEventListener(this.doubleClick,btn));btn.action=id;btn.map=this.map;btn.slideFactor=this.slideFactor;this.buttons.push(btn);return btn;},doubleClick:function(evt){OpenLayers.Event.stop(evt);return false;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
 switch(this.action){case"panup":this.map.pan(0,-this.slideFactor);break;case"pandown":this.map.pan(0,this.slideFactor);break;case"panleft":this.map.pan(-this.slideFactor,0);break;case"panright":this.map.pan(this.slideFactor,0);break;case"zoomin":this.map.zoomIn();break;case"zoomout":this.map.zoomOut();break;case"zoomworld":this.map.zoomToMaxExtent();break;}
-OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.Panel=OpenLayers.Class(OpenLayers.Control,{controls:null,defaultControl:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.controls=[];},destroy:function(){OpenLayers.Control.prototype.destroy.apply(this,arguments);for(var i=this.controls.length-1;i>=0;i--){if(this.controls[i].events){this.controls[i].events.un({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);this.controls[i].panel_div=null;}},activate:function(){if(OpenLayers.Control.prototype.activate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){if(this.controls[i]==this.defaultControl){this.controls[i].activate();}}
-this.redraw();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.controls.length;i++){this.controls[i].deactivate();}
-return true;}else{return false;}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);for(var i=0;i<this.controls.length;i++){this.map.addControl(this.controls[i]);this.controls[i].deactivate();this.controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.activate();return this.div;},redraw:function(){this.div.innerHTML="";if(this.active){for(var i=0;i<this.controls.length;i++){var element=this.controls[i].panel_div;if(this.controls[i].active){element.className=this.controls[i].displayClass+"ItemActive";}else{element.className=this.controls[i].displayClass+"ItemInactive";}
-this.div.appendChild(element);}}},activateControl:function(control){if(!this.active){return false;}
-if(control.type==OpenLayers.Control.TYPE_BUTTON){control.trigger();return;}
-if(control.type==OpenLayers.Control.TYPE_TOGGLE){if(control.active){control.deactivate();}else{control.activate();}
-return;}
-for(var i=0;i<this.controls.length;i++){if(this.controls[i]!=control){if(this.controls[i].type!=OpenLayers.Control.TYPE_TOGGLE){this.controls[i].deactivate();}}}
-control.activate();},addControls:function(controls){if(!(controls instanceof Array)){controls=[controls];}
-this.controls=this.controls.concat(controls);for(var i=0;i<controls.length;i++){var element=document.createElement("div");var textNode=document.createTextNode(" ");controls[i].panel_div=element;if(controls[i].title!=""){controls[i].panel_div.title=controls[i].title;}
-OpenLayers.Event.observe(controls[i].panel_div,"click",OpenLayers.Function.bind(this.onClick,this,controls[i]));OpenLayers.Event.observe(controls[i].panel_div,"mousedown",OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));}
-if(this.map){for(var i=0;i<controls.length;i++){this.map.addControl(controls[i]);controls[i].deactivate();controls[i].events.on({"activate":this.redraw,"deactivate":this.redraw,scope:this});}
-this.redraw();}},onClick:function(ctrl,evt){OpenLayers.Event.stop(evt?evt:window.event);this.activateControl(ctrl);},getControlsBy:function(property,match){var test=(typeof match.test=="function");var found=OpenLayers.Array.filter(this.controls,function(item){return item[property]==match||(test&&match.test(item[property]));});return found;},getControlsByName:function(match){return this.getControlsBy("name",match);},getControlsByClass:function(match){return this.getControlsBy("CLASS_NAME",match);},CLASS_NAME:"OpenLayers.Control.Panel"});OpenLayers.Control.Permalink=OpenLayers.Class(OpenLayers.Control,{element:null,base:'',displayProjection:null,initialize:function(element,base,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);this.base=base||document.location.href;},destroy:function(){if(this.element.parentNode==this.div){this.div.removeChild(this.element);}
-this.element=null;this.map.events.unregister('moveend',this,this.updateLink);OpenLayers.Control.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.prototype.setMap.apply(this,arguments);for(var i=0;i<this.map.controls.length;i++){var control=this.map.controls[i];if(control.CLASS_NAME=="OpenLayers.Control.ArgParser"){if(control.displayProjection!=this.displayProjection){this.displayProjection=control.displayProjection;}
-break;}}
-if(i==this.map.controls.length){this.map.addControl(new OpenLayers.Control.ArgParser({'displayProjection':this.displayProjection}));}},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("a");this.element.innerHTML=OpenLayers.i18n("permalink");this.element.href="";this.div.appendChild(this.element);}
-this.map.events.on({'moveend':this.updateLink,'changelayer':this.updateLink,'changebaselayer':this.updateLink,scope:this});return this.div;},updateLink:function(){var center=this.map.getCenter();if(!center){return;}
-var params=OpenLayers.Util.getParameters(this.base);params.zoom=this.map.getZoom();var lat=center.lat;var lon=center.lon;if(this.displayProjection){var mapPosition=OpenLayers.Projection.transform({x:lon,y:lat},this.map.getProjectionObject(),this.displayProjection);lon=mapPosition.x;lat=mapPosition.y;}
-params.lat=Math.round(lat*100000)/100000;params.lon=Math.round(lon*100000)/100000;params.layers='';for(var i=0;i<this.map.layers.length;i++){var layer=this.map.layers[i];if(layer.isBaseLayer){params.layers+=(layer==this.map.baseLayer)?"B":"0";}else{params.layers+=(layer.getVisibility())?"T":"F";}}
-var href=this.base;if(href.indexOf('?')!=-1){href=href.substring(0,href.indexOf('?'));}
-href+='?'+OpenLayers.Util.getParameterString(params);this.element.href=href;},CLASS_NAME:"OpenLayers.Control.Permalink"});OpenLayers.Control.Scale=OpenLayers.Class(OpenLayers.Control,{element:null,initialize:function(element,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.element=OpenLayers.Util.getElement(element);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.element){this.element=document.createElement("div");this.div.appendChild(this.element);}
-this.map.events.register('moveend',this,this.updateScale);this.updateScale();return this.div;},updateScale:function(){var scale=this.map.getScale();if(!scale){return;}
-if(scale>=9500&&scale<=950000){scale=Math.round(scale/1000)+"K";}else if(scale>=950000){scale=Math.round(scale/1000000)+"M";}else{scale=Math.round(scale);}
-this.element.innerHTML=OpenLayers.i18n("scale",{'scaleDenom':scale});},CLASS_NAME:"OpenLayers.Control.Scale"});OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
+OpenLayers.Event.stop(evt);},CLASS_NAME:"OpenLayers.Control.PanZoom"});OpenLayers.Control.PanZoom.X=4;OpenLayers.Control.PanZoom.Y=4;OpenLayers.Control.ScaleLine=OpenLayers.Class(OpenLayers.Control,{maxWidth:100,topOutUnits:"km",topInUnits:"m",bottomOutUnits:"mi",bottomInUnits:"ft",eTop:null,eBottom:null,initialize:function(options){OpenLayers.Control.prototype.initialize.apply(this,[options]);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!this.eTop){this.div.style.display="block";this.div.style.position="absolute";this.eTop=document.createElement("div");this.eTop.className=this.displayClass+"Top";var theLen=this.topInUnits.length;this.div.appendChild(this.eTop);if((this.topOutUnits=="")||(this.topInUnits=="")){this.eTop.style.visibility="hidden";}else{this.eTop.style.visibility="visible";}
 this.eBottom=document.createElement("div");this.eBottom.className=this.displayClass+"Bottom";this.div.appendChild(this.eBottom);if((this.bottomOutUnits=="")||(this.bottomInUnits=="")){this.eBottom.style.visibility="hidden";}else{this.eBottom.style.visibility="visible";}}
 this.map.events.register('moveend',this,this.update);this.update();return this.div;},getBarLen:function(maxLen){var digits=parseInt(Math.log(maxLen)/Math.log(10));var pow10=Math.pow(10,digits);var firstChar=parseInt(maxLen/pow10);var barLen;if(firstChar>5){barLen=5;}else if(firstChar>2){barLen=2;}else{barLen=1;}
 return barLen*pow10;},update:function(){var res=this.map.getResolution();if(!res){return;}
-var curMapUnits=this.map.units;var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
-var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Control.ZoomToMaxExtent=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_BUTTON,trigger:function(){if(this.map){this.map.zoomToMaxExtent();}},CLASS_NAME:"OpenLayers.Control.ZoomToMaxExtent"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
+var curMapUnits=this.map.getUnits();var inches=OpenLayers.INCHES_PER_UNIT;var maxSizeData=this.maxWidth*res*inches[curMapUnits];var topUnits;var bottomUnits;if(maxSizeData>100000){topUnits=this.topOutUnits;bottomUnits=this.bottomOutUnits;}else{topUnits=this.topInUnits;bottomUnits=this.bottomInUnits;}
+var topMax=maxSizeData/inches[topUnits];var bottomMax=maxSizeData/inches[bottomUnits];var topRounded=this.getBarLen(topMax);var bottomRounded=this.getBarLen(bottomMax);topMax=topRounded/inches[curMapUnits]*inches[topUnits];bottomMax=bottomRounded/inches[curMapUnits]*inches[bottomUnits];var topPx=topMax/res;var bottomPx=bottomMax/res;this.eTop.style.width=Math.round(topPx)+"px";this.eBottom.style.width=Math.round(bottomPx)+"px";this.eTop.innerHTML=topRounded+" "+topUnits;this.eBottom.innerHTML=bottomRounded+" "+bottomUnits;},CLASS_NAME:"OpenLayers.Control.ScaleLine"});OpenLayers.Event={observers:false,KEY_BACKSPACE:8,KEY_TAB:9,KEY_RETURN:13,KEY_ESC:27,KEY_LEFT:37,KEY_UP:38,KEY_RIGHT:39,KEY_DOWN:40,KEY_DELETE:46,element:function(event){return event.target||event.srcElement;},isLeftClick:function(event){return(((event.which)&&(event.which==1))||((event.button)&&(event.button==1)));},stop:function(event,allowDefault){if(!allowDefault){if(event.preventDefault){event.preventDefault();}else{event.returnValue=false;}}
 if(event.stopPropagation){event.stopPropagation();}else{event.cancelBubble=true;}},findElement:function(event,tagName){var element=OpenLayers.Event.element(event);while(element.parentNode&&(!element.tagName||(element.tagName.toUpperCase()!=tagName.toUpperCase()))){element=element.parentNode;}
 return element;},observe:function(elementParam,name,observer,useCapture){var element=OpenLayers.Util.getElement(elementParam);useCapture=useCapture||false;if(name=='keypress'&&(navigator.appVersion.match(/Konqueror|Safari|KHTML/)||element.attachEvent)){name='keydown';}
 if(!this.observers){this.observers={};}
@@ -417,90 +301,41 @@
 return continueChain;},handleBrowserEvent:function(evt){evt.xy=this.getMousePosition(evt);this.triggerEvent(evt.type,evt);},getMousePosition:function(evt){if(!this.element.offsets){this.element.offsets=OpenLayers.Util.pagePosition(this.element);this.element.offsets[0]+=(document.documentElement.scrollLeft||document.body.scrollLeft);this.element.offsets[1]+=(document.documentElement.scrollTop||document.body.scrollTop);}
 return new OpenLayers.Pixel((evt.clientX+(document.documentElement.scrollLeft||document.body.scrollLeft))-this.element.offsets[0]
 -(document.documentElement.clientLeft||0),(evt.clientY+(document.documentElement.scrollTop||document.body.scrollTop))-this.element.offsets[1]
--(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Format=OpenLayers.Class({externalProjection:null,internalProjection:null,initialize:function(options){OpenLayers.Util.extend(this,options);},read:function(data){alert(OpenLayers.i18n("readNotImplemented"));},write:function(object){alert(OpenLayers.i18n("writeNotImplemented"));},CLASS_NAME:"OpenLayers.Format"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was either not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Popup.Anchored=OpenLayers.Class(OpenLayers.Popup,{relativePosition:null,anchor:null,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){var newArguments=new Array(id,lonlat,size,contentHTML,closeBox,closeBoxCallback);OpenLayers.Popup.prototype.initialize.apply(this,newArguments);this.anchor=(anchor!=null)?anchor:{size:new OpenLayers.Size(0,0),offset:new OpenLayers.Pixel(0,0)};},destroy:function(){this.anchor=null;this.relativePosition=null;OpenLayers.Popup.prototype.destroy.apply(this,arguments);},show:function(){this.updatePosition();OpenLayers.Popup.prototype.show.apply(this,arguments);},moveTo:function(px){var oldRelativePosition=this.relativePosition;this.relativePosition=this.calculateRelativePosition(px);var newPx=this.calculateNewPx(px);var newArguments=new Array(newPx);OpenLayers.Popup.prototype.moveTo.apply(this,newArguments);if(this.relativePosition!=oldRelativePosition){this.updateRelativePosition();}},setSize:function(size){OpenLayers.Popup.prototype.setSize.apply(this,arguments);if((this.lonlat)&&(this.map)){var px=this.map.getLayerPxFromLonLat(this.lonlat);this.moveTo(px);}},calculateRelativePosition:function(px){var lonlat=this.map.getLonLatFromLayerPx(px);var extent=this.map.getExtent();var quadrant=extent.determineQuadrant(lonlat);return OpenLayers.Bounds.oppositeQuadrant(quadrant);},updateRelativePosition:function(){},calculateNewPx:function(px){var newPx=px.offset(this.anchor.offset);var top=(this.relativePosition.charAt(0)=='t');newPx.y+=(top)?-this.size.h:this.anchor.size.h;var left=(this.relativePosition.charAt(1)=='l');newPx.x+=(left)?-this.size.w:this.anchor.size.w;return newPx;},CLASS_NAME:"OpenLayers.Popup.Anchored"});OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
+-(document.documentElement.clientTop||0));},CLASS_NAME:"OpenLayers.Events"});OpenLayers.Lang.en={'unhandledRequest':"Unhandled request return ${statusText}",'permalink':"Permalink",'overlays':"Overlays",'baseLayer':"Base Layer",'sameProjection':"The overview map only works when it is in the same projection as the main map",'readNotImplemented':"Read not implemented.",'writeNotImplemented':"Write not implemented.",'noFID':"Can't update a feature for which there is no FID.",'errorLoadingGML':"Error in loading GML file ${url}",'browserNotSupported':"Your browser does not support vector rendering. Currently supported renderers are:\n${renderers}",'componentShouldBe':"addFeatures : component should be an ${geomType}",'getFeatureError':"getFeatureFromEvent called on layer with no renderer. This usually means you "+"destroyed a layer, but not some handler which is associated with it.",'minZoomLevelError':"The minZoomLevel property is only intended for use "+"with the FixedZoomLevels-descendent layers. That this "+"wfs layer checks for minZoomLevel is a relic of the"+"past. We cannot, however, remove it without possibly "+"breaking OL based applications that may depend on it."+" Therefore we are deprecating it -- the minZoomLevel "+"check below will be removed at 3.0. Please instead "+"use min/max resolution setting as described here: "+"http://trac.openlayers.org/wiki/SettingZoomLevels",'commitSuccess':"WFS Transaction: SUCCESS ${response}",'commitFailed':"WFS Transaction: FAILED ${response}",'googleWarning':"The Google Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the Google Maps library "+"script was either not included, or does not contain the "+"correct API key for your site.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/Google' "+"target='_blank'>click here</a>",'getLayerWarning':"The ${layerType} Layer was unable to load correctly.<br><br>"+"To get rid of this message, select a new BaseLayer "+"in the layer switcher in the upper-right corner.<br><br>"+"Most likely, this is because the ${layerLib} library "+"script was not correctly included.<br><br>"+"Developers: For help getting this working correctly, "+"<a href='http://trac.openlayers.org/wiki/${layerLib}' "+"target='_blank'>click here</a>",'scale':"Scale = 1 : ${scaleDenom}",'layerAlreadyAdded':"You tried to add the layer: ${layerName} to the map, but it has already been added",'reprojectDeprecated':"You are using the 'reproject' option "+"on the ${layerName} layer. This option is deprecated: "+"its use was designed to support displaying data over commercial "+"basemaps, but that functionality should now be achieved by using "+"Spherical Mercator support. More information is available from "+"http://trac.openlayers.org/wiki/SphericalMercator.",'methodDeprecated':"This method has been deprecated and will be removed in 3.0. "+"Please use ${newMethod} instead.",'boundsAddError':"You must pass both x and y values to the add function.",'lonlatAddError':"You must pass both lon and lat values to the add function.",'pixelAddError':"You must pass both x and y values to the add function.",'unsupportedGeometryType':"Unsupported geometry type: ${geomType}",'pagePositionFailed':"OpenLayers.Util.pagePosition failed: element with id ${elemId} may be misplaced.",'end':''};OpenLayers.Projection=OpenLayers.Class({proj:null,projCode:null,initialize:function(projCode,options){OpenLayers.Util.extend(this,options);this.projCode=projCode;if(window.Proj4js){this.proj=new Proj4js.Proj(projCode);}},getCode:function(){return this.proj?this.proj.srsCode:this.projCode;},getUnits:function(){return this.proj?this.proj.units:null;},toString:function(){return this.getCode();},equals:function(projection){if(projection&&projection.getCode){return this.getCode()==projection.getCode();}else{return false;}},destroy:function(){delete this.proj;delete this.projCode;},CLASS_NAME:"OpenLayers.Projection"});OpenLayers.Projection.transforms={};OpenLayers.Projection.addTransform=function(from,to,method){if(!OpenLayers.Projection.transforms[from]){OpenLayers.Projection.transforms[from]={};}
 OpenLayers.Projection.transforms[from][to]=method;};OpenLayers.Projection.transform=function(point,source,dest){if(source.proj&&dest.proj){point=Proj4js.transform(source.proj,dest.proj,point);}else if(source&&dest&&OpenLayers.Projection.transforms[source.getCode()]&&OpenLayers.Projection.transforms[source.getCode()][dest.getCode()]){OpenLayers.Projection.transforms[source.getCode()][dest.getCode()](point);}
-return point;};OpenLayers.Renderer.Elements=OpenLayers.Class(OpenLayers.Renderer,{rendererRoot:null,root:null,xmlns:null,minimumSymbolizer:{strokeLinecap:"round",strokeOpacity:1,fillOpacity:1,pointRadius:0},initialize:function(containerID){OpenLayers.Renderer.prototype.initialize.apply(this,arguments);this.rendererRoot=this.createRenderRoot();this.root=this.createRoot();this.rendererRoot.appendChild(this.root);this.container.appendChild(this.rendererRoot);},destroy:function(){this.clear();this.rendererRoot=null;this.root=null;this.xmlns=null;OpenLayers.Renderer.prototype.destroy.apply(this,arguments);},clear:function(){if(this.root){while(this.root.childNodes.length>0){this.root.removeChild(this.root.firstChild);}}},getNodeType:function(geometry,style){},drawGeometry:function(geometry,style,featureId){var className=geometry.CLASS_NAME;if((className=="OpenLayers.Geometry.Collection")||(className=="OpenLayers.Geometry.MultiPoint")||(className=="OpenLayers.Geometry.MultiLineString")||(className=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.drawGeometry(geometry.components[i],style,featureId);}
-return;};if(style.display!="none"){var nodeType=this.getNodeType(geometry,style);var node=this.nodeFactory(geometry.id,nodeType);node._featureId=featureId;node._geometryClass=geometry.CLASS_NAME;node._style=style;node=this.drawGeometryNode(node,geometry);if(node.parentNode!=this.root){this.root.appendChild(node);}
-this.postDraw(node);}else{node=OpenLayers.Util.getElement(geometry.id);if(node){node.parentNode.removeChild(node);}}},drawGeometryNode:function(node,geometry,style){style=style||node._style;OpenLayers.Util.applyDefaults(style,this.minimumSymbolizer);var options={'isFilled':true,'isStroked':!!style.strokeWidth};switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":this.drawPoint(node,geometry);break;case"OpenLayers.Geometry.LineString":options.isFilled=false;this.drawLineString(node,geometry);break;case"OpenLayers.Geometry.LinearRing":this.drawLinearRing(node,geometry);break;case"OpenLayers.Geometry.Polygon":this.drawPolygon(node,geometry);break;case"OpenLayers.Geometry.Surface":this.drawSurface(node,geometry);break;case"OpenLayers.Geometry.Rectangle":this.drawRectangle(node,geometry);break;default:break;}
-node._style=style;node._options=options;return this.setStyle(node,style,options,geometry);},postDraw:function(node){},drawPoint:function(node,geometry){},drawLineString:function(node,geometry){},drawLinearRing:function(node,geometry){},drawPolygon:function(node,geometry){},drawRectangle:function(node,geometry){},drawCircle:function(node,geometry){},drawSurface:function(node,geometry){},getFeatureIdFromEvent:function(evt){var node=evt.target||evt.srcElement;return node._featureId;},eraseGeometry:function(geometry){if((geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPoint")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiLineString")||(geometry.CLASS_NAME=="OpenLayers.Geometry.MultiPolygon")){for(var i=0;i<geometry.components.length;i++){this.eraseGeometry(geometry.components[i]);}}else{var element=OpenLayers.Util.getElement(geometry.id);if(element&&element.parentNode){element.parentNode.removeChild(element);}}},nodeFactory:function(id,type){var node=OpenLayers.Util.getElement(id);if(node){if(!this.nodeTypeCompare(node,type)){node.parentNode.removeChild(node);node=this.nodeFactory(id,type);}}else{node=this.createNode(type,id);}
-return node;},CLASS_NAME:"OpenLayers.Renderer.Elements"});OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
+return point;};(function(){var oXMLHttpRequest=window.XMLHttpRequest;var bGecko=!!window.controllers,bIE=window.document.all&&!window.opera;function cXMLHttpRequest(){this._object=oXMLHttpRequest?new oXMLHttpRequest:new window.ActiveXObject('Microsoft.XMLHTTP');};if(bGecko&&oXMLHttpRequest.wrapped)
+cXMLHttpRequest.wrapped=oXMLHttpRequest.wrapped;cXMLHttpRequest.UNSENT=0;cXMLHttpRequest.OPENED=1;cXMLHttpRequest.HEADERS_RECEIVED=2;cXMLHttpRequest.LOADING=3;cXMLHttpRequest.DONE=4;cXMLHttpRequest.prototype.readyState=cXMLHttpRequest.UNSENT;cXMLHttpRequest.prototype.responseText="";cXMLHttpRequest.prototype.responseXML=null;cXMLHttpRequest.prototype.status=0;cXMLHttpRequest.prototype.statusText="";cXMLHttpRequest.prototype.onreadystatechange=null;cXMLHttpRequest.onreadystatechange=null;cXMLHttpRequest.onopen=null;cXMLHttpRequest.onsend=null;cXMLHttpRequest.onabort=null;cXMLHttpRequest.prototype.open=function(sMethod,sUrl,bAsync,sUser,sPassword){this._async=bAsync;var oRequest=this,nState=this.readyState;if(bIE){var fOnUnload=function(){if(oRequest._object.readyState!=cXMLHttpRequest.DONE)
+fCleanTransport(oRequest);};if(bAsync)
+window.attachEvent("onunload",fOnUnload);}
+this._object.onreadystatechange=function(){if(bGecko&&!bAsync)
+return;oRequest.readyState=oRequest._object.readyState;fSynchronizeValues(oRequest);if(oRequest._aborted){oRequest.readyState=cXMLHttpRequest.UNSENT;return;}
+if(oRequest.readyState==cXMLHttpRequest.DONE){fCleanTransport(oRequest);if(bIE&&bAsync)
+window.detachEvent("onunload",fOnUnload);}
+if(nState!=oRequest.readyState)
+fReadyStateChange(oRequest);nState=oRequest.readyState;};if(cXMLHttpRequest.onopen)
+cXMLHttpRequest.onopen.apply(this,arguments);this._object.open(sMethod,sUrl,bAsync,sUser,sPassword);if(!bAsync&&bGecko){this.readyState=cXMLHttpRequest.OPENED;fReadyStateChange(this);}};cXMLHttpRequest.prototype.send=function(vData){if(cXMLHttpRequest.onsend)
+cXMLHttpRequest.onsend.apply(this,arguments);if(vData&&vData.nodeType){vData=window.XMLSerializer?new window.XMLSerializer().serializeToString(vData):vData.xml;if(!this._headers["Content-Type"])
+this._object.setRequestHeader("Content-Type","application/xml");}
+this._object.send(vData);if(bGecko&&!this._async){this.readyState=cXMLHttpRequest.OPENED;fSynchronizeValues(this);while(this.readyState<cXMLHttpRequest.DONE){this.readyState++;fReadyStateChange(this);if(this._aborted)
+return;}}};cXMLHttpRequest.prototype.abort=function(){if(cXMLHttpRequest.onabort)
+cXMLHttpRequest.onabort.apply(this,arguments);if(this.readyState>cXMLHttpRequest.UNSENT)
+this._aborted=true;this._object.abort();fCleanTransport(this);};cXMLHttpRequest.prototype.getAllResponseHeaders=function(){return this._object.getAllResponseHeaders();};cXMLHttpRequest.prototype.getResponseHeader=function(sName){return this._object.getResponseHeader(sName);};cXMLHttpRequest.prototype.setRequestHeader=function(sName,sValue){if(!this._headers)
+this._headers={};this._headers[sName]=sValue;return this._object.setRequestHeader(sName,sValue);};cXMLHttpRequest.prototype.toString=function(){return'['+"object"+' '+"XMLHttpRequest"+']';};cXMLHttpRequest.toString=function(){return'['+"XMLHttpRequest"+']';};function fReadyStateChange(oRequest){if(oRequest.onreadystatechange)
+oRequest.onreadystatechange.apply(oRequest);if(cXMLHttpRequest.onreadystatechange)
+cXMLHttpRequest.onreadystatechange.apply(oRequest);};function fGetDocument(oRequest){var oDocument=oRequest.responseXML;if(bIE&&oDocument&&!oDocument.documentElement&&oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)){oDocument=new ActiveXObject('Microsoft.XMLDOM');oDocument.loadXML(oRequest.responseText);}
+if(oDocument)
+if((bIE&&oDocument.parseError!=0)||(oDocument.documentElement&&oDocument.documentElement.tagName=="parsererror"))
+return null;return oDocument;};function fSynchronizeValues(oRequest){try{oRequest.responseText=oRequest._object.responseText;}catch(e){}
+try{oRequest.responseXML=fGetDocument(oRequest._object);}catch(e){}
+try{oRequest.status=oRequest._object.status;}catch(e){}
+try{oRequest.statusText=oRequest._object.statusText;}catch(e){}};function fCleanTransport(oRequest){oRequest._object.onreadystatechange=new window.Function;delete oRequest._headers;};if(!window.Function.prototype.apply){window.Function.prototype.apply=function(oRequest,oArguments){if(!oArguments)
+oArguments=[];oRequest.__func=this;oRequest.__func(oArguments[0],oArguments[1],oArguments[2],oArguments[3],oArguments[4]);delete oRequest.__func;};};OpenLayers.Request.XMLHttpRequest=cXMLHttpRequest;})();OpenLayers.Tile=OpenLayers.Class({EVENT_TYPES:["loadstart","loadend","reload","unload"],events:null,id:null,layer:null,url:null,bounds:null,size:null,position:null,isLoading:false,isBackBuffer:false,lastRatio:1,isFirstDraw:true,backBufferTile:null,initialize:function(layer,position,bounds,url,size){this.layer=layer;this.position=position.clone();this.bounds=bounds.clone();this.url=url;this.size=size.clone();this.id=OpenLayers.Util.createUniqueID("Tile_");this.events=new OpenLayers.Events(this,null,this.EVENT_TYPES);},unload:function(){if(this.isLoading){this.isLoading=false;this.events.triggerEvent("unload");}},destroy:function(){if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){this.layer.events.unregister("loadend",this,this.resetBackBuffer);this.events.unregister('loadend',this,this.resetBackBuffer);}else{this.events.unregister('loadend',this,this.showTile);}
 this.layer=null;this.bounds=null;this.size=null;this.position=null;this.events.destroy();this.events=null;if(this.backBufferTile){this.backBufferTile.destroy();this.backBufferTile=null;}},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile(this.layer,this.position,this.bounds,this.url,this.size);}
 OpenLayers.Util.applyDefaults(obj,this);return obj;},draw:function(){var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));var drawTile=(withinMaxExtent||this.layer.displayOutsideMaxExtent);if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(drawTile){if(!this.backBufferTile){this.backBufferTile=this.clone();this.backBufferTile.hide();this.backBufferTile.isBackBuffer=true;this.events.register('loadend',this,this.resetBackBuffer);this.layer.events.register("loadend",this,this.resetBackBuffer);}
 this.startTransition();}else{if(this.backBufferTile){this.backBufferTile.clear();}}}else{if(drawTile&&this.isFirstDraw){this.events.register('loadend',this,this.showTile);this.isFirstDraw=false;}}
 this.shouldDraw=drawTile;this.clear();return drawTile;},moveTo:function(bounds,position,redraw){if(redraw==null){redraw=true;}
 this.bounds=bounds.clone();this.position=position.clone();if(redraw){this.draw();}},clear:function(){},getBoundsFromBaseLayer:function(position){var msg=OpenLayers.i18n('reprojectDeprecated',{'layerName':this.layer.name});OpenLayers.Console.warn(msg);var topLeft=this.layer.map.getLonLatFromLayerPx(position);var bottomRightPx=position.clone();bottomRightPx.x+=this.size.w;bottomRightPx.y+=this.size.h;var bottomRight=this.layer.map.getLonLatFromLayerPx(bottomRightPx);if(topLeft.lon>bottomRight.lon){if(topLeft.lon<0){topLeft.lon=-180-(topLeft.lon+180);}else{bottomRight.lon=180+bottomRight.lon+180;}}
-var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Control.MouseToolbar=OpenLayers.Class(OpenLayers.Control.MouseDefaults,{mode:null,buttons:null,direction:"vertical",buttonClicked:null,initialize:function(position,direction){OpenLayers.Control.prototype.initialize.apply(this,arguments);this.position=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,OpenLayers.Control.MouseToolbar.Y);if(position){this.position=position;}
-if(direction){this.direction=direction;}
-this.measureDivs=[];},destroy:function(){for(var btnId in this.buttons){var btn=this.buttons[btnId];btn.map=null;btn.events.destroy();}
-OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);OpenLayers.Control.MouseDefaults.prototype.draw.apply(this,arguments);this.buttons={};var sz=new OpenLayers.Size(28,28);var centered=new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);this._addButton("zoombox","drag-rectangle-off.png","drag-rectangle-on.png",centered,sz,"Shift->Drag to zoom to area");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this._addButton("pan","panning-hand-off.png","panning-hand-on.png",centered,sz,"Drag the map to pan.");centered=centered.add((this.direction=="vertical"?0:sz.w),(this.direction=="vertical"?sz.h:0));this.switchModeTo("pan");return this.div;},_addButton:function(id,img,activeImg,xy,sz,title){var imgLocation=OpenLayers.Util.getImagesLocation()+img;var activeImgLocation=OpenLayers.Util.getImagesLocation()+activeImg;var btn=OpenLayers.Util.createAlphaImageDiv("OpenLayers_Control_MouseToolbar_"+id,xy,sz,imgLocation,"absolute");this.div.appendChild(btn);btn.imgLocation=imgLocation;btn.activeImgLocation=activeImgLocation;btn.events=new OpenLayers.Events(this,btn,null,true);btn.events.on({"mousedown":this.buttonDown,"mouseup":this.buttonUp,"dblclick":OpenLayers.Event.stop,scope:this});btn.action=id;btn.title=title;btn.alt=title;btn.map=this.map;this.buttons[id]=btn;return btn;},buttonDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.buttonClicked=evt.element.action;OpenLayers.Event.stop(evt);},buttonUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.buttonClicked!=null){if(this.buttonClicked==evt.element.action){this.switchModeTo(evt.element.action);}
-OpenLayers.Event.stop(evt);this.buttonClicked=null;}},defaultDblClick:function(evt){this.switchModeTo("pan");this.performedDrag=false;var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);OpenLayers.Event.stop(evt);return false;},defaultMouseDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.mouseDragStart=evt.xy.clone();this.performedDrag=false;this.startViaKeyboard=false;if(evt.shiftKey&&this.mode!="zoombox"){this.switchModeTo("zoombox");this.startViaKeyboard=true;}else if(evt.altKey&&this.mode!="measure"){this.switchModeTo("measure");}else if(!this.mode){this.switchModeTo("pan");}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.mouseDragStart,null,null,"absolute","2px solid red");this.zoomBox.style.backgroundColor="white";this.zoomBox.style.filter="alpha(opacity=50)";this.zoomBox.style.opacity="0.50";this.zoomBox.style.fontSize="1px";this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.performedDrag=true;break;case"measure":var distance="";if(this.measureStart){var measureEnd=this.map.getLonLatFromViewPortPx(this.mouseDragStart);distance=OpenLayers.Util.distVincenty(this.measureStart,measureEnd);distance=Math.round(distance*100)/100;distance=distance+"km";this.measureStartBox=this.measureBox;}
-this.measureStart=this.map.getLonLatFromViewPortPx(this.mouseDragStart);;this.measureBox=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),-2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBox.style.width="4px";this.measureBox.style.height="4px";this.measureBox.style.fontSize="1px";this.measureBox.style.backgroundColor="red";this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);if(distance){this.measureBoxDistance=OpenLayers.Util.createDiv(null,this.mouseDragStart.add(-2-parseInt(this.map.layerContainerDiv.style.left),2-parseInt(this.map.layerContainerDiv.style.top)),null,null,"absolute");this.measureBoxDistance.innerHTML=distance;this.measureBoxDistance.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBoxDistance);this.measureDivs.push(this.measureBoxDistance);}
-this.measureBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.layerContainerDiv.appendChild(this.measureBox);this.measureDivs.push(this.measureBox);break;default:this.map.div.style.cursor="move";break;}
-document.onselectstart=function(){return false;};OpenLayers.Event.stop(evt);},switchModeTo:function(mode){if(mode!=this.mode){if(this.mode&&this.buttons[this.mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode],null,null,null,this.buttons[this.mode].imgLocation);}
-if(this.mode=="measure"&&mode!="measure"){for(var i=0;i<this.measureDivs.length;i++){if(this.measureDivs[i]){this.map.layerContainerDiv.removeChild(this.measureDivs[i]);}}
-this.measureDivs=[];this.measureStart=null;}
-this.mode=mode;if(this.buttons[mode]){OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode],null,null,null,this.buttons[mode].activeImgLocation);}
-switch(this.mode){case"zoombox":this.map.div.style.cursor="crosshair";break;default:this.map.div.style.cursor="";break;}}},leaveMode:function(){this.switchModeTo("pan");},defaultMouseMove:function(evt){if(this.mouseDragStart!=null){switch(this.mode){case"zoombox":var deltaX=Math.abs(this.mouseDragStart.x-evt.xy.x);var deltaY=Math.abs(this.mouseDragStart.y-evt.xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(evt.xy.x<this.mouseDragStart.x){this.zoomBox.style.left=evt.xy.x+"px";}
-break;default:var deltaX=this.mouseDragStart.x-evt.xy.x;var deltaY=this.mouseDragStart.y-evt.xy.y;var size=this.map.getSize();var newXY=new OpenLayers.Pixel(size.w/2+deltaX,size.h/2+deltaY);var newCenter=this.map.getLonLatFromViewPortPx(newXY);this.map.setCenter(newCenter,null,true);this.mouseDragStart=evt.xy.clone();}
-switch(this.mode){case"zoombox":this.zoomBoxEnd(evt);if(this.startViaKeyboard){this.leaveMode();}
-break;case"pan":if(this.performedDrag){this.map.setCenter(this.map.center);}}
-document.onselectstart=null;this.mouseDragStart=null;this.map.div.style.cursor="default";},defaultMouseOut:function(evt){if(this.mouseDragStart!=null&&OpenLayers.Util.mouseLeft(evt,this.map.div)){if(this.zoomBox){this.removeZoomBox();if(this.startViaKeyboard){this.leaveMode();}}
-this.mouseDragStart=null;this.map.div.style.cursor="default";}},defaultClick:function(evt){if(this.performedDrag){this.performedDrag=false;return false;}},CLASS_NAME:"OpenLayers.Control.MouseToolbar"});OpenLayers.Control.MouseToolbar.X=6;OpenLayers.Control.MouseToolbar.Y=300;OpenLayers.Control.PanZoomBar=OpenLayers.Class(OpenLayers.Control.PanZoom,{zoomStopWidth:18,zoomStopHeight:11,slider:null,sliderEvents:null,zoomBarDiv:null,divEvents:null,zoomWorldIcon:false,initialize:function(){OpenLayers.Control.PanZoom.prototype.initialize.apply(this,arguments);},destroy:function(){this.div.removeChild(this.slider);this.slider=null;this.sliderEvents.destroy();this.sliderEvents=null;this.div.removeChild(this.zoombarDiv);this.zoomBarDiv=null;this.divEvents.destroy();this.divEvents=null;this.map.events.un({"zoomend":this.moveZoomBar,"changebaselayer":this.redraw,scope:this});OpenLayers.Control.PanZoom.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Control.PanZoom.prototype.setMap.apply(this,arguments);this.map.events.register("changebaselayer",this,this.redraw);},redraw:function(){if(this.div!=null){this.div.innerHTML="";}
-this.draw();},draw:function(px){OpenLayers.Control.prototype.draw.apply(this,arguments);px=this.position.clone();this.buttons=[];var sz=new OpenLayers.Size(18,18);var centered=new OpenLayers.Pixel(px.x+sz.w/2,px.y);var wposition=sz.w;if(this.zoomWorldIcon){centered=new OpenLayers.Pixel(px.x+sz.w,px.y);}
-this._addButton("panup","north-mini.png",centered,sz);px.y=centered.y+sz.h;this._addButton("panleft","west-mini.png",px,sz);if(this.zoomWorldIcon){this._addButton("zoomworld","zoom-world-mini.png",px.add(sz.w,0),sz);wposition*=2;}
-this._addButton("panright","east-mini.png",px.add(wposition,0),sz);this._addButton("pandown","south-mini.png",centered.add(0,sz.h*2),sz);this._addButton("zoomin","zoom-plus-mini.png",centered.add(0,sz.h*3+5),sz);centered=this._addZoomBar(centered.add(0,sz.h*4+5));this._addButton("zoomout","zoom-minus-mini.png",centered,sz);return this.div;},_addZoomBar:function(centered){var imgLocation=OpenLayers.Util.getImagesLocation();var id="OpenLayers_Control_PanZoomBar_Slider"+this.map.id;var zoomsToEnd=this.map.getNumZoomLevels()-1-this.map.getZoom();var slider=OpenLayers.Util.createAlphaImageDiv(id,centered.add(-1,zoomsToEnd*this.zoomStopHeight),new OpenLayers.Size(20,9),imgLocation+"slider.png","absolute");this.slider=slider;this.sliderEvents=new OpenLayers.Events(this,slider,null,true);this.sliderEvents.on({"mousedown":this.zoomBarDown,"mousemove":this.zoomBarDrag,"mouseup":this.zoomBarUp,"dblclick":this.doubleClick,"click":this.doubleClick});var sz=new OpenLayers.Size();sz.h=this.zoomStopHeight*this.map.getNumZoomLevels();sz.w=this.zoomStopWidth;var div=null;if(OpenLayers.Util.alphaHack()){var id="OpenLayers_Control_PanZoomBar"+this.map.id;div=OpenLayers.Util.createAlphaImageDiv(id,centered,new OpenLayers.Size(sz.w,this.zoomStopHeight),imgLocation+"zoombar.png","absolute",null,"crop");div.style.height=sz.h;}else{div=OpenLayers.Util.createDiv('OpenLayers_Control_PanZoomBar_Zoombar'+this.map.id,centered,sz,imgLocation+"zoombar.png");}
-this.zoombarDiv=div;this.divEvents=new OpenLayers.Events(this,div,null,true);this.divEvents.on({"mousedown":this.divClick,"mousemove":this.passEventToSlider,"dblclick":this.doubleClick,"click":this.doubleClick});this.div.appendChild(div);this.startTop=parseInt(div.style.top);this.div.appendChild(slider);this.map.events.register("zoomend",this,this.moveZoomBar);centered=centered.add(0,this.zoomStopHeight*this.map.getNumZoomLevels());return centered;},passEventToSlider:function(evt){this.sliderEvents.handleBrowserEvent(evt);},divClick:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-var y=evt.xy.y;var top=OpenLayers.Util.pagePosition(evt.object)[1];var levels=(y-top)/this.zoomStopHeight;if(!this.map.fractionalZoom){levels=Math.floor(levels);}
-var zoom=(this.map.getNumZoomLevels()-1)-levels;zoom=Math.min(Math.max(zoom,0),this.map.getNumZoomLevels()-1);this.map.zoomTo(zoom);OpenLayers.Event.stop(evt);},zoomBarDown:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-this.map.events.on({"mousemove":this.passEventToSlider,"mouseup":this.passEventToSlider,scope:this});this.mouseDragStart=evt.xy.clone();this.zoomStart=evt.xy.clone();this.div.style.cursor="move";this.zoombarDiv.offsets=null;OpenLayers.Event.stop(evt);},zoomBarDrag:function(evt){if(this.mouseDragStart!=null){var deltaY=this.mouseDragStart.y-evt.xy.y;var offsets=OpenLayers.Util.pagePosition(this.zoombarDiv);if((evt.clientY-offsets[1])>0&&(evt.clientY-offsets[1])<parseInt(this.zoombarDiv.style.height)-2){var newTop=parseInt(this.slider.style.top)-deltaY;this.slider.style.top=newTop+"px";}
-this.mouseDragStart=evt.xy.clone();OpenLayers.Event.stop(evt);}},zoomBarUp:function(evt){if(!OpenLayers.Event.isLeftClick(evt)){return;}
-if(this.zoomStart){this.div.style.cursor="";this.map.events.un({"mouseup":this.passEventToSlider,"mousemove":this.passEventToSlider,scope:this});var deltaY=this.zoomStart.y-evt.xy.y;var zoomLevel=this.map.zoom;if(this.map.fractionalZoom){zoomLevel+=deltaY/this.zoomStopHeight;zoomLevel=Math.min(Math.max(zoomLevel,0),this.map.getNumZoomLevels()-1);}else{zoomLevel+=Math.round(deltaY/this.zoomStopHeight);}
-this.map.zoomTo(zoomLevel);this.moveZoomBar();this.mouseDragStart=null;OpenLayers.Event.stop(evt);}},moveZoomBar:function(){var newTop=((this.map.getNumZoomLevels()-1)-this.map.getZoom())*this.zoomStopHeight+this.startTop+1;this.slider.style.top=newTop+"px";},CLASS_NAME:"OpenLayers.Control.PanZoomBar"});OpenLayers.Format.JSON=OpenLayers.Class(OpenLayers.Format,{indent:"    ",space:" ",newline:"\n",level:0,pretty:false,initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(json,filter){try{if(/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g,'@').replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g,']').replace(/(?:^|:|,)(?:\s*\[)+/g,''))){var object=eval('('+json+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
-return filter(k,v);}
-object=walk('',object);}
-return object;}}catch(e){}
-return null;},write:function(value,pretty){this.pretty=!!pretty;var json=null;var type=typeof value;if(this.serialize[type]){json=this.serialize[type].apply(this,[value]);}
-return json;},writeIndent:function(){var pieces=[];if(this.pretty){for(var i=0;i<this.level;++i){pieces.push(this.indent);}}
-return pieces.join('');},writeNewline:function(){return(this.pretty)?this.newline:'';},writeSpace:function(){return(this.pretty)?this.space:'';},serialize:{'object':function(object){if(object==null){return"null";}
-if(object.constructor==Date){return this.serialize.date.apply(this,[object]);}
-if(object.constructor==Array){return this.serialize.array.apply(this,[object]);}
-var pieces=['{'];this.level+=1;var key,keyJSON,valueJSON;var addComma=false;for(key in object){if(object.hasOwnProperty(key)){keyJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[key,this.pretty]);valueJSON=OpenLayers.Format.JSON.prototype.write.apply(this,[object[key],this.pretty]);if(keyJSON!=null&&valueJSON!=null){if(addComma){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),keyJSON,':',this.writeSpace(),valueJSON);addComma=true;}}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),'}');return pieces.join('');},'array':function(array){var json;var pieces=['['];this.level+=1;for(var i=0;i<array.length;++i){json=OpenLayers.Format.JSON.prototype.write.apply(this,[array[i],this.pretty]);if(json!=null){if(i>0){pieces.push(',');}
-pieces.push(this.writeNewline(),this.writeIndent(),json);}}
-this.level-=1;pieces.push(this.writeNewline(),this.writeIndent(),']');return pieces.join('');},'string':function(string){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(string)){return'"'+string.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
-c=b.charCodeAt();return'\\u00'+
-Math.floor(c/16).toString(16)+
-(c%16).toString(16);})+'"';}
-return'"'+string+'"';},'number':function(number){return isFinite(number)?String(number):"null";},'boolean':function(bool){return String(bool);},'date':function(date){function format(number){return(number<10)?'0'+number:number;}
-return'"'+date.getFullYear()+'-'+
-format(date.getMonth()+1)+'-'+
-format(date.getDate())+'T'+
-format(date.getHours())+':'+
-format(date.getMinutes())+':'+
-format(date.getSeconds())+'"';}},CLASS_NAME:"OpenLayers.Format.JSON"});OpenLayers.Format.XML=OpenLayers.Class(OpenLayers.Format,{xmldom:null,initialize:function(options){if(window.ActiveXObject){this.xmldom=new ActiveXObject("Microsoft.XMLDOM");}
-OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var index=text.indexOf('<');if(index>0){text=text.substring(index);}
-var node=OpenLayers.Util.Try(OpenLayers.Function.bind((function(){var xmldom;if(window.ActiveXObject&&!this.xmldom){xmldom=new ActiveXObject("Microsoft.XMLDOM");}else{xmldom=this.xmldom;}
-xmldom.loadXML(text);return xmldom;}),this),function(){return new DOMParser().parseFromString(text,'text/xml');},function(){var req=new XMLHttpRequest();req.open("GET","data:"+"text/xml"+";charset=utf-8,"+encodeURIComponent(text),false);if(req.overrideMimeType){req.overrideMimeType("text/xml");}
-req.send(null);return req.responseXML;});return node;},write:function(node){var data;if(this.xmldom){data=node.xml;}else{var serializer=new XMLSerializer();if(node.nodeType==1){var doc=document.implementation.createDocument("","",null);if(doc.importNode){node=doc.importNode(node,true);}
-doc.appendChild(node);data=serializer.serializeToString(doc);}else{data=serializer.serializeToString(node);}}
-return data;},createElementNS:function(uri,name){var element;if(this.xmldom){if(typeof uri=="string"){element=this.xmldom.createNode(1,name,uri);}else{element=this.xmldom.createNode(1,name,"");}}else{element=document.createElementNS(uri,name);}
-return element;},createTextNode:function(text){var node;if(this.xmldom){node=this.xmldom.createTextNode(text);}else{node=document.createTextNode(text);}
-return node;},getElementsByTagNameNS:function(node,uri,name){var elements=[];if(node.getElementsByTagNameNS){elements=node.getElementsByTagNameNS(uri,name);}else{var allNodes=node.getElementsByTagName("*");var potentialNode,fullName;for(var i=0;i<allNodes.length;++i){potentialNode=allNodes[i];fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if((name=="*")||(fullName==potentialNode.nodeName)){if((uri=="*")||(uri==potentialNode.namespaceURI)){elements.push(potentialNode);}}}}
-return elements;},getAttributeNodeNS:function(node,uri,name){var attributeNode=null;if(node.getAttributeNodeNS){attributeNode=node.getAttributeNodeNS(uri,name);}else{var attributes=node.attributes;var potentialNode,fullName;for(var i=0;i<attributes.length;++i){potentialNode=attributes[i];if(potentialNode.namespaceURI==uri){fullName=(potentialNode.prefix)?(potentialNode.prefix+":"+name):name;if(fullName==potentialNode.nodeName){attributeNode=potentialNode;break;}}}}
-return attributeNode;},getAttributeNS:function(node,uri,name){var attributeValue="";if(node.getAttributeNS){attributeValue=node.getAttributeNS(uri,name)||"";}else{var attributeNode=this.getAttributeNodeNS(node,uri,name);if(attributeNode){attributeValue=attributeNode.nodeValue;}}
-return attributeValue;},getChildValue:function(node,def){var value;try{value=node.firstChild.nodeValue;}catch(e){value=(def!=undefined)?def:"";}
-return value;},concatChildValues:function(node,def){var value="";var child=node.firstChild;var childValue;while(child){childValue=child.nodeValue;if(childValue){value+=childValue;}
-child=child.nextSibling;}
-if(value==""&&def!=undefined){value=def;}
-return value;},hasAttributeNS:function(node,uri,name){var found=false;if(node.hasAttributeNS){found=node.hasAttributeNS(uri,name);}else{found=!!this.getAttributeNodeNS(node,uri,name);}
-return found;},setAttributeNS:function(node,uri,name,value){if(node.setAttributeNS){node.setAttributeNS(uri,name,value);}else{if(this.xmldom){if(uri){var attribute=node.ownerDocument.createNode(2,name,uri);attribute.nodeValue=value;node.setAttributeNode(attribute);}else{node.setAttribute(name,value);}}else{throw"setAttributeNS not implemented";}}},CLASS_NAME:"OpenLayers.Format.XML"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
+var bounds=new OpenLayers.Bounds(topLeft.lon,bottomRight.lat,bottomRight.lon,topLeft.lat);return bounds;},startTransition:function(){},resetBackBuffer:function(){this.showTile();if(this.backBufferTile&&(this.isFirstDraw||!this.layer.numLoadingTiles)){this.isFirstDraw=false;var maxExtent=this.layer.maxExtent;var withinMaxExtent=(maxExtent&&this.bounds.intersectsBounds(maxExtent,false));if(withinMaxExtent){this.backBufferTile.position=this.position;this.backBufferTile.bounds=this.bounds;this.backBufferTile.size=this.size;this.backBufferTile.imageSize=this.layer.imageSize||this.size;this.backBufferTile.imageOffset=this.layer.imageOffset;this.backBufferTile.resolution=this.layer.getResolution();this.backBufferTile.renderTile();}}},showTile:function(){if(this.shouldDraw){this.show();}},show:function(){},hide:function(){},CLASS_NAME:"OpenLayers.Tile"});OpenLayers.Handler=OpenLayers.Class({id:null,control:null,map:null,keyMask:null,active:false,evt:null,initialize:function(control,callbacks,options){OpenLayers.Util.extend(this,options);this.control=control;this.callbacks=callbacks;if(control.map){this.setMap(control.map);}
 OpenLayers.Util.extend(this,options);this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},setMap:function(map){this.map=map;},checkModifiers:function(evt){if(this.keyMask==null){return true;}
 var keyModifiers=(evt.shiftKey?OpenLayers.Handler.MOD_SHIFT:0)|(evt.ctrlKey?OpenLayers.Handler.MOD_CTRL:0)|(evt.altKey?OpenLayers.Handler.MOD_ALT:0);return(keyModifiers==this.keyMask);},activate:function(){if(this.active){return false;}
 var events=OpenLayers.Events.prototype.BROWSER_EVENTS;for(var i=0;i<events.length;i++){if(this[events[i]]){this.register(events[i],this[events[i]]);}}
@@ -549,9 +384,9 @@
 return size;},calculateBounds:function(center,resolution){var extent=null;if(center==null){center=this.getCenter();}
 if(resolution==null){resolution=this.getResolution();}
 if((center!=null)&&(resolution!=null)){var size=this.getSize();var w_deg=size.w*resolution;var h_deg=size.h*resolution;extent=new OpenLayers.Bounds(center.lon-w_deg/2,center.lat-h_deg/2,center.lon+w_deg/2,center.lat+h_deg/2);}
-return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){if(!options){options={};}
-OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
-var center=this.getCenter();var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
+return extent;},getCenter:function(){return this.center;},getZoom:function(){return this.zoom;},pan:function(dx,dy,options){options=OpenLayers.Util.applyDefaults(options,{animate:true,dragging:false});var centerPx=this.getViewPortPxFromLonLat(this.getCenter());var newCenterPx=centerPx.add(dx,dy);if(!options.dragging||!newCenterPx.equals(centerPx)){var newCenterLonLat=this.getLonLatFromViewPortPx(newCenterPx);if(options.animate){this.panTo(newCenterLonLat);}else{this.setCenter(newCenterLonLat,null,options.dragging);}}},panTo:function(lonlat){if(this.panMethod&&this.getExtent().containsLonLat(lonlat)){if(!this.panTween){this.panTween=new OpenLayers.Tween(this.panMethod);}
+var center=this.getCenter();if(lonlat.lon==center.lon&&lonlat.lat==center.lat){return;}
+var from={lon:center.lon,lat:center.lat};var to={lon:lonlat.lon,lat:lonlat.lat};this.panTween.start(from,to,50,{callbacks:{start:OpenLayers.Function.bind(function(lonlat){this.events.triggerEvent("movestart");},this),eachStep:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'dragging':true,'noEvent':true});},this),done:OpenLayers.Function.bind(function(lonlat){lonlat=new OpenLayers.LonLat(lonlat.lon,lonlat.lat);this.moveTo(lonlat,this.zoom,{'noEvent':true});this.events.triggerEvent("moveend");},this)}});}else{this.setCenter(lonlat);}},setCenter:function(lonlat,zoom,dragging,forceZoomChange){this.moveTo(lonlat,zoom,{'dragging':dragging,'forceZoomChange':forceZoomChange,'caller':'setCenter'});},moveTo:function(lonlat,zoom,options){if(!options){options={};}
 var dragging=options.dragging;var forceZoomChange=options.forceZoomChange;var noEvent=options.noEvent;if(this.panTween&&options.caller=="setCenter"){this.panTween.stop();}
 if(!this.center&&!this.isValidLonLat(lonlat)){lonlat=this.maxExtent.getCenterLonLat();}
 if(this.restrictedExtent!=null){if(lonlat==null){lonlat=this.getCenter();}
@@ -581,7 +416,8 @@
 return maxExtent;},getNumZoomLevels:function(){var numZoomLevels=null;if(this.baseLayer!=null){numZoomLevels=this.baseLayer.numZoomLevels;}
 return numZoomLevels;},getExtent:function(){var extent=null;if(this.baseLayer!=null){extent=this.baseLayer.getExtent();}
 return extent;},getResolution:function(){var resolution=null;if(this.baseLayer!=null){resolution=this.baseLayer.getResolution();}
-return resolution;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
+return resolution;},getUnits:function(){var units=null;if(this.baseLayer!=null){units=this.baseLayer.units;}
+return units;},getScale:function(){var scale=null;if(this.baseLayer!=null){var res=this.getResolution();var units=this.baseLayer.units;scale=OpenLayers.Util.getScaleFromResolution(res,units);}
 return scale;},getZoomForExtent:function(bounds,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForExtent(bounds,closest);}
 return zoom;},getResolutionForZoom:function(zoom){var resolution=null;if(this.baseLayer){resolution=this.baseLayer.getResolutionForZoom(zoom);}
 return resolution;},getZoomForResolution:function(resolution,closest){var zoom=null;if(this.baseLayer!=null){zoom=this.baseLayer.getZoomForResolution(resolution,closest);}
@@ -594,61 +430,7 @@
 return layerPx;},getLonLatFromLayerPx:function(px){px=this.getViewPortPxFromLayerPx(px);return this.getLonLatFromViewPortPx(px);},getLayerPxFromLonLat:function(lonlat){var px=this.getPixelFromLonLat(lonlat);return this.getLayerPxFromViewPortPx(px);},CLASS_NAME:"OpenLayers.Map"});OpenLayers.Map.TILE_WIDTH=256;OpenLayers.Map.TILE_HEIGHT=256;OpenLayers.Marker=OpenLayers.Class({icon:null,lonlat:null,events:null,map:null,initialize:function(lonlat,icon){this.lonlat=lonlat;var newIcon=(icon)?icon:OpenLayers.Marker.defaultIcon();if(this.icon==null){this.icon=newIcon;}else{this.icon.url=newIcon.url;this.icon.size=newIcon.size;this.icon.offset=newIcon.offset;this.icon.calculateOffset=newIcon.calculateOffset;}
 this.events=new OpenLayers.Events(this,this.icon.imageDiv,null);},destroy:function(){this.map=null;this.events.destroy();this.events=null;if(this.icon!=null){this.icon.destroy();this.icon=null;}},draw:function(px){return this.icon.draw(px);},moveTo:function(px){if((px!=null)&&(this.icon!=null)){this.icon.moveTo(px);}
 this.lonlat=this.map.getLonLatFromLayerPx(px);},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Popup.AnchoredBubble=OpenLayers.Class(OpenLayers.Popup.Anchored,{rounded:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.padding=new OpenLayers.Bounds(0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,0,OpenLayers.Popup.AnchoredBubble.CORNER_SIZE);OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);},draw:function(px){OpenLayers.Popup.Anchored.prototype.draw.apply(this,arguments);this.setContentHTML();this.setBackgroundColor();this.setOpacity();return this.div;},updateRelativePosition:function(){this.setRicoCorners();},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.setRicoCorners();},setBackgroundColor:function(color){if(color!=undefined){this.backgroundColor=color;}
-if(this.div!=null){if(this.contentDiv!=null){this.div.style.background="transparent";OpenLayers.Rico.Corner.changeColor(this.groupDiv,this.backgroundColor);}}},setOpacity:function(opacity){OpenLayers.Popup.Anchored.prototype.setOpacity.call(this,opacity);if(this.div!=null){if(this.groupDiv!=null){OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,this.opacity);}}},setBorder:function(border){this.border=0;},setRicoCorners:function(){var corners=this.getCornersToRound(this.relativePosition);var options={corners:corners,color:this.backgroundColor,bgColor:"transparent",blend:false};if(!this.rounded){OpenLayers.Rico.Corner.round(this.div,options);this.rounded=true;}else{OpenLayers.Rico.Corner.reRound(this.groupDiv,options);this.setBackgroundColor();this.setOpacity();}},getCornersToRound:function(){var corners=['tl','tr','bl','br'];var corner=OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);OpenLayers.Util.removeItem(corners,corner);return corners.join(" ");},CLASS_NAME:"OpenLayers.Popup.AnchoredBubble"});OpenLayers.Popup.AnchoredBubble.CORNER_SIZE=5;OpenLayers.Popup.Framed=OpenLayers.Class(OpenLayers.Popup.Anchored,{imageSrc:null,imageSize:null,isAlphaImage:false,positionBlocks:null,blocks:null,fixedRelativePosition:false,initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){OpenLayers.Popup.Anchored.prototype.initialize.apply(this,arguments);if(this.fixedRelativePosition){this.updateRelativePosition();this.calculateRelativePosition=function(px){return this.relativePosition;};}
-this.contentDiv.style.position="absolute";this.contentDiv.style.zIndex=1;if(closeBox){this.closeDiv.style.zIndex=1;}
-this.groupDiv.style.position="absolute";this.groupDiv.style.top="0px";this.groupDiv.style.left="0px";this.groupDiv.style.height="100%";this.groupDiv.style.width="100%";},destroy:function(){this.imageSrc=null;this.imageSize=null;this.isAlphaImage=null;this.fixedRelativePosition=false;this.positionBlocks=null;for(var i=0;i<this.blocks.length;i++){var block=this.blocks[i];if(block.image){block.div.removeChild(block.image);}
-block.image=null;if(block.div){this.groupDiv.removeChild(block.div);}
-block.div=null;}
-this.blocks=null;OpenLayers.Popup.Anchored.prototype.destroy.apply(this,arguments);},setBackgroundColor:function(color){},setBorder:function(){},setOpacity:function(opacity){},setSize:function(size){OpenLayers.Popup.Anchored.prototype.setSize.apply(this,arguments);this.updateBlocks();},updateRelativePosition:function(){this.padding=this.positionBlocks[this.relativePosition].padding;if(this.closeDiv){var contentDivPadding=this.getContentDivPadding();this.closeDiv.style.right=contentDivPadding.right+
-this.padding.right+"px";this.closeDiv.style.top=contentDivPadding.top+
-this.padding.top+"px";}
-this.updateBlocks();},calculateNewPx:function(px){var newPx=OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(this,arguments);newPx=newPx.offset(this.positionBlocks[this.relativePosition].offset);return newPx;},createBlocks:function(){this.blocks=[];var firstPosition=null;for(var key in this.positionBlocks){firstPosition=key;break;}
-var position=this.positionBlocks[firstPosition];for(var i=0;i<position.blocks.length;i++){var block={};this.blocks.push(block);var divId=this.id+'_FrameDecorationDiv_'+i;block.div=OpenLayers.Util.createDiv(divId,null,null,null,"absolute",null,"hidden",null);var imgId=this.id+'_FrameDecorationImg_'+i;var imageCreator=(this.isAlphaImage)?OpenLayers.Util.createAlphaImageDiv:OpenLayers.Util.createImage;block.image=imageCreator(imgId,null,this.imageSize,this.imageSrc,"absolute",null,null,null);block.div.appendChild(block.image);this.groupDiv.appendChild(block.div);}},updateBlocks:function(){if(!this.blocks){this.createBlocks();}
-if(this.relativePosition){var position=this.positionBlocks[this.relativePosition];for(var i=0;i<position.blocks.length;i++){var positionBlock=position.blocks[i];var block=this.blocks[i];var l=positionBlock.anchor.left;var b=positionBlock.anchor.bottom;var r=positionBlock.anchor.right;var t=positionBlock.anchor.top;var w=(isNaN(positionBlock.size.w))?this.size.w-(r+l):positionBlock.size.w;var h=(isNaN(positionBlock.size.h))?this.size.h-(b+t):positionBlock.size.h;block.div.style.width=w+'px';block.div.style.height=h+'px';block.div.style.left=(l!=null)?l+'px':'';block.div.style.bottom=(b!=null)?b+'px':'';block.div.style.right=(r!=null)?r+'px':'';block.div.style.top=(t!=null)?t+'px':'';block.image.style.left=positionBlock.position.x+'px';block.image.style.top=positionBlock.position.y+'px';}
-this.contentDiv.style.left=this.padding.left+"px";this.contentDiv.style.top=this.padding.top+"px";}},CLASS_NAME:"OpenLayers.Popup.Framed"});OpenLayers.Renderer.SVG=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"http://www.w3.org/2000/svg",MAX_PIXEL:15000,localResolution:null,initialize:function(containerID){if(!this.supported()){return;}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){var svgFeature="http://www.w3.org/TR/SVG11/feature#";return(document.implementation&&(document.implementation.hasFeature("org.w3c.svg","1.0")||document.implementation.hasFeature(svgFeature+"SVG","1.1")||document.implementation.hasFeature(svgFeature+"BasicStructure","1.1")));},inValidRange:function(x,y){return(x>=-this.MAX_PIXEL&&x<=this.MAX_PIXEL&&y>=-this.MAX_PIXEL&&y<=this.MAX_PIXEL);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();if(!this.localResolution||resolution!=this.localResolution){this.left=-extent.left/resolution;this.top=extent.top/resolution;}
-var left=0;var top=0;if(this.localResolution&&resolution==this.localResolution){left=(this.left)-(-extent.left/resolution);top=(this.top)-(extent.top/resolution);}
-this.localResolution=resolution;var extentString=left+" "+top+" "+
-extent.getWidth()/resolution+" "+extent.getHeight()/resolution;this.rendererRoot.setAttributeNS(null,"viewBox",extentString);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.setAttributeNS(null,"width",this.size.w);this.rendererRoot.setAttributeNS(null,"height",this.size.h);},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"image":"circle";break;case"OpenLayers.Geometry.Rectangle":nodeType="rect";break;case"OpenLayers.Geometry.LineString":nodeType="polyline";break;case"OpenLayers.Geometry.LinearRing":nodeType="polygon";break;case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="path";break;default:break;}
-return nodeType;},setStyle:function(node,style,options){style=style||node._style;options=options||node._options;var r=parseFloat(node.getAttributeNS(null,"r"));if(node._geometryClass=="OpenLayers.Geometry.Point"&&r){if(style.externalGraphic){var x=parseFloat(node.getAttributeNS(null,"cx"));var y=parseFloat(node.getAttributeNS(null,"cy"));if(style.graphicWidth&&style.graphicHeight){node.setAttributeNS(null,"preserveAspectRatio","none");}
-var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);var opacity=style.graphicOpacity||style.fillOpacity;node.setAttributeNS(null,"x",(x+xOffset).toFixed());node.setAttributeNS(null,"y",(y+yOffset).toFixed());node.setAttributeNS(null,"width",width);node.setAttributeNS(null,"height",height);node.setAttributeNS("http://www.w3.org/1999/xlink","href",style.externalGraphic);node.setAttributeNS(null,"style","opacity: "+opacity);}else{node.setAttributeNS(null,"r",style.pointRadius);}}
-if(options.isFilled){node.setAttributeNS(null,"fill",style.fillColor);node.setAttributeNS(null,"fill-opacity",style.fillOpacity);}else{node.setAttributeNS(null,"fill","none");}
-if(options.isStroked){node.setAttributeNS(null,"stroke",style.strokeColor);node.setAttributeNS(null,"stroke-opacity",style.strokeOpacity);node.setAttributeNS(null,"stroke-width",style.strokeWidth);node.setAttributeNS(null,"stroke-linecap",style.strokeLinecap);}else{node.setAttributeNS(null,"stroke","none");}
-if(style.pointerEvents){node.setAttributeNS(null,"pointer-events",style.pointerEvents);}
-if(style.cursor!=null){node.setAttributeNS(null,"cursor",style.cursor);}
-return node;},createNode:function(type,id){var node=document.createElementNS(this.xmlns,type);if(id){node.setAttributeNS(null,"id",id);}
-return node;},nodeTypeCompare:function(node,type){return(type==node.nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_svgRoot","svg");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","g");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"cx",x);node.setAttributeNS(null,"cy",y);node.setAttributeNS(null,"r",radius);}else{node.setAttributeNS(null,"cx","");node.setAttributeNS(null,"cy","");node.setAttributeNS(null,"r",0);}},drawLineString:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawLinearRing:function(node,geometry){node.setAttributeNS(null,"points",this.getComponentsString(geometry.components));},drawPolygon:function(node,geometry){var d="";var draw=true;for(var j=0;j<geometry.components.length;j++){var linearRing=geometry.components[j];d+=" M";for(var i=0;i<linearRing.components.length;i++){var component=this.getShortString(linearRing.components[i]);if(component){d+=" "+component;}else{draw=false;}}}
-d+=" z";if(draw){node.setAttributeNS(null,"d",d);node.setAttributeNS(null,"fill-rule","evenodd");}else{node.setAttributeNS(null,"d","");}},drawRectangle:function(node,geometry){var resolution=this.getResolution();var x=(geometry.x/resolution+this.left);var y=(this.top-geometry.y/resolution);if(this.inValidRange(x,y)){node.setAttributeNS(null,"x",x);node.setAttributeNS(null,"y",y);node.setAttributeNS(null,"width",geometry.width/resolution);node.setAttributeNS(null,"height",geometry.height/resolution);}else{node.setAttributeNS(null,"x","");node.setAttributeNS(null,"y","");node.setAttributeNS(null,"width",0);node.setAttributeNS(null,"height",0);}},drawSurface:function(node,geometry){var d=null;var draw=true;for(var i=0;i<geometry.components.length;i++){if((i%3)==0&&(i/3)==0){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d="M "+component;}else if((i%3)==1){var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" C "+component;}else{var component=this.getShortString(geometry.components[i]);if(!component){draw=false;}
-d+=" "+component;}}
-d+=" Z";if(draw){node.setAttributeNS(null,"d",d);}else{node.setAttributeNS(null,"d","");}},getComponentsString:function(components){var strings=[];for(var i=0;i<components.length;i++){var component=this.getShortString(components[i]);if(component){strings.push(component);}}
-return strings.join(",");},getShortString:function(point){var resolution=this.getResolution();var x=(point.x/resolution+this.left);var y=(this.top-point.y/resolution);if(this.inValidRange(x,y)){return x+","+y;}else{return false;}},CLASS_NAME:"OpenLayers.Renderer.SVG"});OpenLayers.Renderer.VML=OpenLayers.Class(OpenLayers.Renderer.Elements,{xmlns:"urn:schemas-microsoft-com:vml",initialize:function(containerID){if(!this.supported()){return;}
-if(!document.namespaces.olv){document.namespaces.add("olv",this.xmlns);var style=document.createStyleSheet();style.addRule('olv\\:*',"behavior: url(#default#VML); "+"position: absolute; display: inline-block;");}
-OpenLayers.Renderer.Elements.prototype.initialize.apply(this,arguments);},destroy:function(){OpenLayers.Renderer.Elements.prototype.destroy.apply(this,arguments);},supported:function(){return!!(document.namespaces);},setExtent:function(extent){OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,arguments);var resolution=this.getResolution();var org=extent.left/resolution+" "+
-extent.top/resolution;this.root.setAttribute("coordorigin",org);var size=extent.getWidth()/resolution+" "+
--extent.getHeight()/resolution;this.root.setAttribute("coordsize",size);},setSize:function(size){OpenLayers.Renderer.prototype.setSize.apply(this,arguments);this.rendererRoot.style.width=this.size.w;this.rendererRoot.style.height=this.size.h;this.root.style.width=this.size.w;this.root.style.height=this.size.h;},getNodeType:function(geometry,style){var nodeType=null;switch(geometry.CLASS_NAME){case"OpenLayers.Geometry.Point":nodeType=style.externalGraphic?"olv:rect":"olv:oval";break;case"OpenLayers.Geometry.Rectangle":nodeType="olv:rect";break;case"OpenLayers.Geometry.LineString":case"OpenLayers.Geometry.LinearRing":case"OpenLayers.Geometry.Polygon":case"OpenLayers.Geometry.Curve":case"OpenLayers.Geometry.Surface":nodeType="olv:shape";break;default:break;}
-return nodeType;},setStyle:function(node,style,options,geometry){style=style||node._style;options=options||node._options;if(node._geometryClass=="OpenLayers.Geometry.Point"){if(style.externalGraphic){var width=style.graphicWidth||style.graphicHeight;var height=style.graphicHeight||style.graphicWidth;width=width?width:style.pointRadius*2;height=height?height:style.pointRadius*2;var resolution=this.getResolution();var xOffset=(style.graphicXOffset!=undefined)?style.graphicXOffset:-(0.5*width);var yOffset=(style.graphicYOffset!=undefined)?style.graphicYOffset:-(0.5*height);node.style.left=((geometry.x/resolution)+xOffset).toFixed();node.style.top=((geometry.y/resolution)-(yOffset+height)).toFixed();node.style.width=width;node.style.height=height;style.fillColor="none";options.isStroked=false;}else{this.drawCircle(node,geometry,style.pointRadius);}}
-if(options.isFilled){node.setAttribute("fillcolor",style.fillColor);}else{node.setAttribute("filled","false");}
-var fills=node.getElementsByTagName("fill");var fill=(fills.length==0)?null:fills[0];if(!options.isFilled){if(fill){node.removeChild(fill);}}else{if(!fill){fill=this.createNode('olv:fill',node.id+"_fill");}
-fill.setAttribute("opacity",style.fillOpacity);if(node._geometryClass=="OpenLayers.Geometry.Point"&&style.externalGraphic){if(style.graphicOpacity){fill.setAttribute("opacity",style.graphicOpacity);}
-fill.setAttribute("src",style.externalGraphic);fill.setAttribute("type","frame");node.style.flip="y";if(!(style.graphicWidth&&style.graphicHeight)){fill.aspect="atmost";}}
-if(fill.parentNode!=node){node.appendChild(fill);}}
-if(options.isStroked){node.setAttribute("strokecolor",style.strokeColor);node.setAttribute("strokeweight",style.strokeWidth+"px");}else{node.setAttribute("stroked","false");}
-var strokes=node.getElementsByTagName("stroke");var stroke=(strokes.length==0)?null:strokes[0];if(!options.isStroked){if(stroke){node.removeChild(stroke);}}else{if(!stroke){stroke=this.createNode('olv:stroke',node.id+"_stroke");node.appendChild(stroke);}
-stroke.setAttribute("opacity",style.strokeOpacity);stroke.setAttribute("endcap",!style.strokeLinecap||style.strokeLinecap=='butt'?'flat':style.strokeLinecap);}
-if(style.cursor!=null){node.style.cursor=style.cursor;}
-return node;},postDraw:function(node){var fillColor=node._style.fillColor;var strokeColor=node._style.strokeColor;if(fillColor=="none"&&node.getAttribute("fillcolor")!=fillColor){node.setAttribute("fillcolor",fillColor);}
-if(strokeColor=="none"&&node.getAttribute("strokecolor")!=strokeColor){node.setAttribute("strokecolor",strokeColor);}},setNodeDimension:function(node,geometry){var bbox=geometry.getBounds();if(bbox){var resolution=this.getResolution();var scaledBox=new OpenLayers.Bounds((bbox.left/resolution).toFixed(),(bbox.bottom/resolution).toFixed(),(bbox.right/resolution).toFixed(),(bbox.top/resolution).toFixed());node.style.left=scaledBox.left;node.style.top=scaledBox.top;node.style.width=scaledBox.getWidth();node.style.height=scaledBox.getHeight();node.coordorigin=scaledBox.left+" "+scaledBox.top;node.coordsize=scaledBox.getWidth()+" "+scaledBox.getHeight();}},createNode:function(type,id){var node=document.createElement(type);if(id){node.setAttribute('id',id);}
-node.setAttribute('unselectable','on',0);node.onselectstart=function(){return(false);};return node;},nodeTypeCompare:function(node,type){var subType=type;var splitIndex=subType.indexOf(":");if(splitIndex!=-1){subType=subType.substr(splitIndex+1);}
-var nodeName=node.nodeName;splitIndex=nodeName.indexOf(":");if(splitIndex!=-1){nodeName=nodeName.substr(splitIndex+1);}
-return(subType==nodeName);},createRenderRoot:function(){return this.nodeFactory(this.container.id+"_vmlRoot","div");},createRoot:function(){return this.nodeFactory(this.container.id+"_root","olv:group");},drawPoint:function(node,geometry){this.drawCircle(node,geometry,1);},drawCircle:function(node,geometry,radius){if(!isNaN(geometry.x)&&!isNaN(geometry.y)){var resolution=this.getResolution();node.style.left=(geometry.x/resolution).toFixed()-radius;node.style.top=(geometry.y/resolution).toFixed()-radius;var diameter=radius*2;node.style.width=diameter;node.style.height=diameter;}},drawLineString:function(node,geometry){this.drawLine(node,geometry,false);},drawLinearRing:function(node,geometry){this.drawLine(node,geometry,true);},drawLine:function(node,geometry,closeLine){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var numComponents=geometry.components.length;var parts=new Array(numComponents);var comp,x,y;for(var i=0;i<numComponents;i++){comp=geometry.components[i];x=(comp.x/resolution);y=(comp.y/resolution);parts[i]=" "+x.toFixed()+","+y.toFixed()+" l ";}
-var end=(closeLine)?" x e":" e";node.path="m"+parts.join("")+end;},drawPolygon:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var linearRing,i,comp,x,y;for(var j=0;j<geometry.components.length;j++){linearRing=geometry.components[j];path.push("m");for(i=0;i<linearRing.components.length;i++){comp=linearRing.components[i];x=comp.x/resolution;y=comp.y/resolution;path.push(" "+x.toFixed()+","+y.toFixed());if(i==0){path.push(" l");}}
-path.push(" x ");}
-path.push("e");node.path=path.join("");},drawRectangle:function(node,geometry){var resolution=this.getResolution();node.style.left=geometry.x/resolution;node.style.top=geometry.y/resolution;node.style.width=geometry.width/resolution;node.style.height=geometry.height/resolution;},drawSurface:function(node,geometry){this.setNodeDimension(node,geometry);var resolution=this.getResolution();var path=[];var comp,x,y;for(var i=0;i<geometry.components.length;i++){comp=geometry.components[i];x=comp.x/resolution;y=comp.y/resolution;if((i%3)==0&&(i/3)==0){path.push("m");}else if((i%3)==1){path.push(" c");}
-path.push(" "+x+","+y);}
-path.push(" x e");node.path=path.join("");},CLASS_NAME:"OpenLayers.Renderer.VML"});OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
+return onScreen;},inflate:function(inflate){if(this.icon){var newSize=new OpenLayers.Size(this.icon.size.w*inflate,this.icon.size.h*inflate);this.icon.setSize(newSize);}},setOpacity:function(opacity){this.icon.setOpacity(opacity);},setUrl:function(url){this.icon.setUrl(url);},display:function(display){this.icon.display(display);},CLASS_NAME:"OpenLayers.Marker"});OpenLayers.Marker.defaultIcon=function(){var url=OpenLayers.Util.getImagesLocation()+"marker.png";var size=new OpenLayers.Size(21,25);var calculateOffset=function(size){return new OpenLayers.Pixel(-(size.w/2),-size.h);};return new OpenLayers.Icon(url,size,null,calculateOffset);};OpenLayers.Tile.Image=OpenLayers.Class(OpenLayers.Tile,{url:null,imgDiv:null,frame:null,layerAlphaHack:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.frame=document.createElement('div');this.frame.style.overflow='hidden';this.frame.style.position='absolute';this.layerAlphaHack=this.layer.alpha&&OpenLayers.Util.alphaHack();},destroy:function(){if(this.imgDiv!=null){if(this.layerAlphaHack){OpenLayers.Event.stopObservingElement(this.imgDiv.childNodes[0].id);}else{OpenLayers.Event.stopObservingElement(this.imgDiv.id);}
 if(this.imgDiv.parentNode==this.frame){this.frame.removeChild(this.imgDiv);this.imgDiv.map=null;}}
 this.imgDiv=null;if((this.frame!=null)&&(this.frame.parentNode==this.layer.div)){this.layer.div.removeChild(this.frame);}
 this.frame=null;OpenLayers.Tile.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Tile.Image(this.layer,this.position,this.bounds,this.url,this.size);}
@@ -664,12 +446,7 @@
 var ratio=1;if(this.backBufferTile.resolution){ratio=this.backBufferTile.resolution/this.layer.getResolution();}
 if(ratio!=this.lastRatio){if(this.layer.transitionEffect=='resize'){var upperLeft=new OpenLayers.LonLat(this.backBufferTile.bounds.left,this.backBufferTile.bounds.top);var size=new OpenLayers.Size(this.backBufferTile.size.w*ratio,this.backBufferTile.size.h*ratio);var px=this.layer.map.getLayerPxFromLonLat(upperLeft);OpenLayers.Util.modifyDOMElement(this.backBufferTile.frame,null,px,size);var imageSize=this.backBufferTile.imageSize;imageSize=new OpenLayers.Size(imageSize.w*ratio,imageSize.h*ratio);var imageOffset=this.backBufferTile.imageOffset;if(imageOffset){imageOffset=new OpenLayers.Pixel(imageOffset.x*ratio,imageOffset.y*ratio);}
 OpenLayers.Util.modifyDOMElement(this.backBufferTile.imgDiv,null,imageOffset,imageSize);this.backBufferTile.show();}}else{if(this.layer.singleTile){this.backBufferTile.show();}else{this.backBufferTile.hide();}}
-this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Tile.WFS=OpenLayers.Class(OpenLayers.Tile,{features:null,url:null,request:null,initialize:function(layer,position,bounds,url,size){OpenLayers.Tile.prototype.initialize.apply(this,arguments);this.url=url;this.features=[];},destroy:function(){OpenLayers.Tile.prototype.destroy.apply(this,arguments);this.destroyAllFeatures();this.features=null;this.url=null;if(this.request){this.request.abort();this.request=null;}},clear:function(){this.destroyAllFeatures();},draw:function(){if(OpenLayers.Tile.prototype.draw.apply(this,arguments)){if(this.isLoading){this.events.triggerEvent("reload");}else{this.isLoading=true;this.events.triggerEvent("loadstart");}
-this.loadFeaturesForRegion(this.requestSuccess);}},loadFeaturesForRegion:function(success,failure){if(this.request){this.request.abort();}
-this.request=OpenLayers.loadURL(this.url,null,this,success);},requestSuccess:function(request){if(this.features){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(request.responseText);}
-if(this.layer.vectorMode){this.layer.addFeatures(this.layer.formatObject.read(doc));}else{var resultFeatures=OpenLayers.Ajax.getElementsByTagNameNS(doc,"http://www.opengis.net/gml","gml","featureMember");this.addResults(resultFeatures);}}
-if(this.events){this.events.triggerEvent("loadend");}
-this.request=null;},addResults:function(results){for(var i=0;i<results.length;i++){var feature=new this.layer.featureClass(this.layer,results[i]);this.features.push(feature);}},destroyAllFeatures:function(){while(this.features.length>0){var feature=this.features.shift();feature.destroy();}},CLASS_NAME:"OpenLayers.Tile.WFS"});OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
+this.lastRatio=ratio;},show:function(){this.frame.style.display='';if(OpenLayers.Util.indexOf(this.layer.SUPPORTED_TRANSITIONS,this.layer.transitionEffect)!=-1){if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.frame.scrollLeft=this.frame.scrollLeft;}}},hide:function(){this.frame.style.display='none';},CLASS_NAME:"OpenLayers.Tile.Image"});OpenLayers.Tile.Image.useBlankTile=(OpenLayers.Util.getBrowserName()=="safari"||OpenLayers.Util.getBrowserName()=="opera");OpenLayers.Control.OverviewMap=OpenLayers.Class(OpenLayers.Control,{element:null,ovmap:null,size:new OpenLayers.Size(180,90),layers:null,minRectSize:15,minRectDisplayClass:"RectReplacement",minRatio:8,maxRatio:32,mapOptions:null,handlers:null,initialize:function(options){this.layers=[];this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,[options]);},destroy:function(){if(!this.mapDiv){return;}
 this.handlers.click.destroy();this.mapDiv.removeChild(this.extentRectangle);this.extentRectangle=null;this.rectEvents.destroy();this.rectEvents=null;this.ovmap.destroy();this.ovmap=null;this.element.removeChild(this.mapDiv);this.mapDiv=null;this.div.removeChild(this.element);this.element=null;if(this.maximizeDiv){OpenLayers.Event.stopObservingElement(this.maximizeDiv);this.div.removeChild(this.maximizeDiv);this.maximizeDiv=null;}
 if(this.minimizeDiv){OpenLayers.Event.stopObservingElement(this.minimizeDiv);this.div.removeChild(this.minimizeDiv);this.minimizeDiv=null;}
 this.map.events.un({"moveend":this.update,"changebaselayer":this.baseLayerDraw,scope:this});OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){OpenLayers.Control.prototype.draw.apply(this,arguments);if(!(this.layers.length>0)){if(this.map.baseLayer){var layer=this.map.baseLayer.clone();this.layers=[layer];}else{this.map.events.register("changebaselayer",this,this.baseLayerDraw);return this.div;}}
@@ -681,44 +458,12 @@
 this.updateRectToMap();},isSuitableOverview:function(){var mapExtent=this.map.getExtent();var maxExtent=this.map.maxExtent;var testExtent=new OpenLayers.Bounds(Math.max(mapExtent.left,maxExtent.left),Math.max(mapExtent.bottom,maxExtent.bottom),Math.min(mapExtent.right,maxExtent.right),Math.min(mapExtent.top,maxExtent.top));var resRatio=this.ovmap.getResolution()/this.map.getResolution();return((resRatio>this.minRatio)&&(resRatio<=this.maxRatio)&&(this.ovmap.getExtent().containsBounds(testExtent)));},updateOverview:function(){var mapRes=this.map.getResolution();var targetRes=this.ovmap.getResolution();var resRatio=targetRes/mapRes;if(resRatio>this.maxRatio){targetRes=this.minRatio*mapRes;}else if(resRatio<=this.minRatio){targetRes=this.maxRatio*mapRes;}
 this.ovmap.setCenter(this.map.center,this.ovmap.getZoomForResolution(targetRes));this.updateRectToMap();},createMap:function(){var options=OpenLayers.Util.extend({controls:[],maxResolution:'auto',fallThrough:false},this.mapOptions);this.ovmap=new OpenLayers.Map(this.mapDiv,options);OpenLayers.Event.stopObserving(window,'unload',this.ovmap.unloadDestroy);this.ovmap.addLayers(this.layers);this.ovmap.zoomToMaxExtent();this.wComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-left-width'))+
 parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-right-width'));this.wComp=(this.wComp)?this.wComp:2;this.hComp=parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-top-width'))+
-parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.units!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
+parseInt(OpenLayers.Element.getStyle(this.extentRectangle,'border-bottom-width'));this.hComp=(this.hComp)?this.hComp:2;this.handlers.drag=new OpenLayers.Handler.Drag(this,{move:this.rectDrag,done:this.updateMapToRect},{map:this.ovmap});this.handlers.click=new OpenLayers.Handler.Click(this,{"click":this.mapDivClick},{"single":true,"double":false,"stopSingle":true,"stopDouble":true,"pixelTolerance":1,map:this.ovmap});this.handlers.click.activate();this.rectEvents=new OpenLayers.Events(this,this.extentRectangle,null,true);this.rectEvents.register("mouseover",this,function(e){if(!this.handlers.drag.active&&!this.map.dragging){this.handlers.drag.activate();}});this.rectEvents.register("mouseout",this,function(e){if(!this.handlers.drag.dragging){this.handlers.drag.deactivate();}});},updateRectToMap:function(){if(this.map.getUnits()!='degrees'){if(this.ovmap.getProjection()&&(this.map.getProjection()!=this.ovmap.getProjection())){alert(OpenLayers.i18n("sameProjection"));}}
 var pxBounds=this.getRectBoundsFromMapBounds(this.map.getExtent());if(pxBounds){this.setRectPxBounds(pxBounds);}},updateMapToRect:function(){var lonLatBounds=this.getMapBoundsFromRectBounds(this.rectPxBounds);this.map.panTo(lonLatBounds.getCenterLonLat());},setRectPxBounds:function(pxBounds){var top=Math.max(pxBounds.top,0);var left=Math.max(pxBounds.left,0);var bottom=Math.min(pxBounds.top+Math.abs(pxBounds.getHeight()),this.ovmap.size.h-this.hComp);var right=Math.min(pxBounds.left+pxBounds.getWidth(),this.ovmap.size.w-this.wComp);var width=Math.max(right-left,0);var height=Math.max(bottom-top,0);if(width<this.minRectSize||height<this.minRectSize){this.extentRectangle.className=this.displayClass+
 this.minRectDisplayClass;var rLeft=left+(width/2)-(this.minRectSize/2);var rTop=top+(height/2)-(this.minRectSize/2);this.extentRectangle.style.top=Math.round(rTop)+'px';this.extentRectangle.style.left=Math.round(rLeft)+'px';this.extentRectangle.style.height=this.minRectSize+'px';this.extentRectangle.style.width=this.minRectSize+'px';}else{this.extentRectangle.className=this.displayClass+'ExtentRectangle';this.extentRectangle.style.top=Math.round(top)+'px';this.extentRectangle.style.left=Math.round(left)+'px';this.extentRectangle.style.height=Math.round(height)+'px';this.extentRectangle.style.width=Math.round(width)+'px';}
 this.rectPxBounds=new OpenLayers.Bounds(Math.round(left),Math.round(bottom),Math.round(right),Math.round(top));},getRectBoundsFromMapBounds:function(lonLatBounds){var leftBottomLonLat=new OpenLayers.LonLat(lonLatBounds.left,lonLatBounds.bottom);var rightTopLonLat=new OpenLayers.LonLat(lonLatBounds.right,lonLatBounds.top);var leftBottomPx=this.getOverviewPxFromLonLat(leftBottomLonLat);var rightTopPx=this.getOverviewPxFromLonLat(rightTopLonLat);var bounds=null;if(leftBottomPx&&rightTopPx){bounds=new OpenLayers.Bounds(leftBottomPx.x,leftBottomPx.y,rightTopPx.x,rightTopPx.y);}
 return bounds;},getMapBoundsFromRectBounds:function(pxBounds){var leftBottomPx=new OpenLayers.Pixel(pxBounds.left,pxBounds.bottom);var rightTopPx=new OpenLayers.Pixel(pxBounds.right,pxBounds.top);var leftBottomLonLat=this.getLonLatFromOverviewPx(leftBottomPx);var rightTopLonLat=this.getLonLatFromOverviewPx(rightTopPx);return new OpenLayers.Bounds(leftBottomLonLat.lon,leftBottomLonLat.lat,rightTopLonLat.lon,rightTopLonLat.lat);},getLonLatFromOverviewPx:function(overviewMapPx){var size=this.ovmap.size;var res=this.ovmap.getResolution();var center=this.ovmap.getExtent().getCenterLonLat();var delta_x=overviewMapPx.x-(size.w/2);var delta_y=overviewMapPx.y-(size.h/2);return new OpenLayers.LonLat(center.lon+delta_x*res,center.lat-delta_y*res);},getOverviewPxFromLonLat:function(lonlat){var res=this.ovmap.getResolution();var extent=this.ovmap.getExtent();var px=null;if(extent){px=new OpenLayers.Pixel(Math.round(1/res*(lonlat.lon-extent.left)),Math.round(1/res*(extent.top-lonlat.lat)));}
-return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Feature=OpenLayers.Class({layer:null,id:null,lonlat:null,data:null,marker:null,popupClass:OpenLayers.Popup.AnchoredBubble,popup:null,initialize:function(layer,lonlat,data){this.layer=layer;this.lonlat=lonlat;this.data=(data!=null)?data:{};this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){if((this.layer!=null)&&(this.layer.map!=null)){if(this.popup!=null){this.layer.map.removePopup(this.popup);}}
-this.layer=null;this.id=null;this.lonlat=null;this.data=null;if(this.marker!=null){this.destroyMarker(this.marker);this.marker=null;}
-if(this.popup!=null){this.destroyPopup(this.popup);this.popup=null;}},onScreen:function(){var onScreen=false;if((this.layer!=null)&&(this.layer.map!=null)){var screenBounds=this.layer.map.getExtent();onScreen=screenBounds.containsLonLat(this.lonlat);}
-return onScreen;},createMarker:function(){if(this.lonlat!=null){this.marker=new OpenLayers.Marker(this.lonlat,this.data.icon);}
-return this.marker;},destroyMarker:function(){this.marker.destroy();},createPopup:function(closeBox){if(this.lonlat!=null){var id=this.id+"_popup";var anchor=(this.marker)?this.marker.icon:null;if(!this.popup){this.popup=new this.popupClass(id,this.lonlat,this.data.popupSize,this.data.popupContentHTML,anchor,closeBox);}
-if(this.data.overflow!=null){this.popup.contentDiv.style.overflow=this.data.overflow;}
-this.popup.feature=this;}
-return this.popup;},destroyPopup:function(){if(this.popup){this.popup.feature=null;this.popup.destroy();this.popup=null;}},CLASS_NAME:"OpenLayers.Feature"});OpenLayers.Format.WMC=OpenLayers.Class({defaultVersion:"1.1.0",version:null,layerOptions:null,parser:null,initialize:function(options){OpenLayers.Util.extend(this,options);this.options=options;},read:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMC parser for version "+
-version;}
-this.parser=new format(this.options);}
-var context=this.parser.read(data,options);var map;if(options.map){this.context=context;if(options.map instanceof OpenLayers.Map){map=this.mergeContextToMap(context,options.map);}else{map=this.contextToMap(context,options.map);}}else{map=context;}
-return map;},contextToMap:function(context,id){var map=new OpenLayers.Map(id,{maxExtent:context.maxExtent,projection:context.projection});map.addLayers(context.layers);map.setCenter(context.bounds.getCenterLonLat(),map.getZoomForExtent(context.bounds,true));return map;},mergeContextToMap:function(context,map){map.addLayers(context.layers);return map;},write:function(obj,options){if(obj.CLASS_NAME=="OpenLayers.Map"){obj=this.mapToContext(obj);}
-var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.WMC["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a WMS capabilities parser for version "+
-version;}
-var wmc=this.parser.write(obj,options);return wmc;},mapToContext:function(map){var context={bounds:map.getExtent(),maxExtent:map.maxExtent,projection:map.projection,layers:map.layers,size:map.getSize()};return context;},CLASS_NAME:"OpenLayers.Format.WMC"});OpenLayers.Format.WMC.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{ol:"http://openlayers.org/context",wmc:"http://www.opengis.net/context",sld:"http://www.opengis.net/sld",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},schemaLocation:"",getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){break;}}}
-return prefix;},defaultPrefix:"wmc",rootPrefix:null,defaultStyleName:"",defaultStyleTitle:"Default",initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;this.rootPrefix=root.prefix;var context={version:root.getAttribute("version")};this.runChildNodes(context,root);return context;},runChildNodes:function(obj,node){var children=node.childNodes;var childNode,processor,prefix,local;for(var i=0;i<children.length;++i){childNode=children[i];if(childNode.nodeType==1){prefix=this.getNamespacePrefix(childNode.namespaceURI);local=childNode.nodeName.split(":").pop();processor=this["read_"+prefix+"_"+local];if(processor){processor.apply(this,[obj,childNode]);}}}},read_wmc_General:function(context,node){this.runChildNodes(context,node);},read_wmc_BoundingBox:function(context,node){context.projection=node.getAttribute("SRS");context.bounds=new OpenLayers.Bounds(parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy")));},read_wmc_LayerList:function(context,node){context.layers=[];this.runChildNodes(context,node);},read_wmc_Layer:function(context,node){var layerInfo={params:{},options:{visibility:(node.getAttribute("hidden")!="1")},queryable:(node.getAttribute("queryable")=="1"),formats:[],styles:[]};this.runChildNodes(layerInfo,node);layerInfo.params.layers=layerInfo.name;layerInfo.options.maxExtent=layerInfo.maxExtent;var layer=this.getLayerFromInfo(layerInfo);context.layers.push(layer);},getLayerFromInfo:function(layerInfo){var options=layerInfo.options;if(this.layerOptions){OpenLayers.Util.applyDefaults(options,this.layerOptions);}
-var layer=new OpenLayers.Layer.WMS(layerInfo.title,layerInfo.href,layerInfo.params,options);return layer;},read_wmc_Extension:function(obj,node){this.runChildNodes(obj,node);},read_ol_units:function(layerInfo,node){layerInfo.options.units=this.getChildValue(node);},read_ol_maxExtent:function(obj,node){var bounds=new OpenLayers.Bounds(node.getAttribute("minx"),node.getAttribute("miny"),node.getAttribute("maxx"),node.getAttribute("maxy"));obj.maxExtent=bounds;},read_ol_transparent:function(layerInfo,node){layerInfo.params.transparent=this.getChildValue(node);},read_ol_numZoomLevels:function(layerInfo,node){layerInfo.options.numZoomLevels=parseInt(this.getChildValue(node));},read_ol_opacity:function(layerInfo,node){layerInfo.options.opacity=parseFloat(this.getChildValue(node));},read_ol_singleTile:function(layerInfo,node){layerInfo.options.singleTile=(this.getChildValue(node)=="true");},read_ol_isBaseLayer:function(layerInfo,node){layerInfo.options.isBaseLayer=(this.getChildValue(node)=="true");},read_ol_displayInLayerSwitcher:function(layerInfo,node){layerInfo.options.displayInLayerSwitcher=(this.getChildValue(node)=="true");},read_wmc_Server:function(layerInfo,node){layerInfo.params.version=node.getAttribute("version");this.runChildNodes(layerInfo,node);},read_wmc_FormatList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Format:function(layerInfo,node){var format=this.getChildValue(node);layerInfo.formats.push(format);if(node.getAttribute("current")=="1"){layerInfo.params.format=format;}},read_wmc_StyleList:function(layerInfo,node){this.runChildNodes(layerInfo,node);},read_wmc_Style:function(layerInfo,node){var style={};this.runChildNodes(style,node);if(node.getAttribute("current")=="1"){if(style.href){layerInfo.params.sld=style.href;}else if(style.body){layerInfo.params.sld_body=style.body;}else{layerInfo.params.styles=style.name;}}
-layerInfo.styles.push(style);},read_wmc_SLD:function(style,node){this.runChildNodes(style,node);},read_sld_StyledLayerDescriptor:function(sld,node){var xml=OpenLayers.Format.XML.prototype.write.apply(this,[node]);sld.body=xml;},read_wmc_OnlineResource:function(obj,node){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},read_wmc_Name:function(obj,node){var name=this.getChildValue(node);if(name){obj.name=name;}},read_wmc_Title:function(obj,node){var title=this.getChildValue(node);if(title){obj.title=title;}},read_wmc_Abstract:function(obj,node){var abst=this.getChildValue(node);if(abst){obj["abstract"]=abst;}},read_wmc_LatLonBoundingBox:function(layer,node){layer.llbbox=[parseFloat(node.getAttribute("minx")),parseFloat(node.getAttribute("miny")),parseFloat(node.getAttribute("maxx")),parseFloat(node.getAttribute("maxy"))];},read_wmc_LegendURL:function(style,node){var legend={width:node.getAttribute('width'),height:node.getAttribute('height')};var links=node.getElementsByTagName("OnlineResource");if(links.length>0){this.read_wmc_OnlineResource(legend,links[0]);}
-style.legend=legend;},write:function(context,options){var root=this.createElementDefaultNS("ViewContext");this.setAttributes(root,{version:this.VERSION,id:(options&&typeof options.id=="string")?options.id:OpenLayers.Util.createUniqueID("OpenLayers_Context_")});this.setAttributeNS(root,this.namespaces.xsi,"xsi:schemaLocation",this.schemaLocation);root.appendChild(this.write_wmc_General(context));root.appendChild(this.write_wmc_LayerList(context));return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},createElementDefaultNS:function(name,childValue,attributes){var node=this.createElementNS(this.namespaces[this.defaultPrefix],name);if(childValue){node.appendChild(this.createTextNode(childValue));}
-if(attributes){this.setAttributes(node,attributes);}
-return node;},setAttributes:function(node,obj){var value;for(var name in obj){value=obj[name].toString();if(value.match(/[A-Z]/)){this.setAttributeNS(node,null,name,value);}else{node.setAttribute(name,value);}}},write_wmc_General:function(context){var node=this.createElementDefaultNS("General");if(context.size){node.appendChild(this.createElementDefaultNS("Window",null,{width:context.size.w,height:context.size.h}));}
-var bounds=context.bounds;node.appendChild(this.createElementDefaultNS("BoundingBox",null,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10),SRS:context.projection}));node.appendChild(this.createElementDefaultNS("Title",context.title));node.appendChild(this.write_ol_MapExtension(context));return node;},write_ol_MapExtension:function(context){var node=this.createElementDefaultNS("Extension");var bounds=context.maxExtent;if(bounds){var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);}
-return node;},write_wmc_LayerList:function(context){var list=this.createElementDefaultNS("LayerList");var layer;for(var i=0;i<context.layers.length;++i){layer=context.layers[i];if(layer instanceof OpenLayers.Layer.WMS){list.appendChild(this.write_wmc_Layer(layer));}}
-return list;},write_wmc_Layer:function(layer){var node=this.createElementDefaultNS("Layer",null,{queryable:"1",hidden:layer.visibility?"0":"1"});node.appendChild(this.write_wmc_Server(layer));node.appendChild(this.createElementDefaultNS("Name",layer.params["LAYERS"]));node.appendChild(this.createElementDefaultNS("Title",layer.name));node.appendChild(this.write_wmc_FormatList(layer));node.appendChild(this.write_wmc_StyleList(layer));node.appendChild(this.write_wmc_LayerExtension(layer));return node;},write_wmc_LayerExtension:function(layer){var node=this.createElementDefaultNS("Extension");var bounds=layer.maxExtent;var maxExtent=this.createElementNS(this.namespaces.ol,"ol:maxExtent");this.setAttributes(maxExtent,{minx:bounds.left.toPrecision(10),miny:bounds.bottom.toPrecision(10),maxx:bounds.right.toPrecision(10),maxy:bounds.top.toPrecision(10)});node.appendChild(maxExtent);var param=layer.params["TRANSPARENT"];if(param){var trans=this.createElementNS(this.namespaces.ol,"ol:transparent");trans.appendChild(this.createTextNode(param));node.appendChild(trans);}
-var properties=["numZoomLevels","units","isBaseLayer","opacity","displayInLayerSwitcher","singleTile"];var child;for(var i=0;i<properties.length;++i){child=this.createOLPropertyNode(layer,properties[i]);if(child){node.appendChild(child);}}
-return node;},createOLPropertyNode:function(obj,prop){var node=null;if(obj[prop]!=null){node=this.createElementNS(this.namespaces.ol,"ol:"+prop);node.appendChild(this.createTextNode(obj[prop].toString()));}
-return node;},write_wmc_Server:function(layer){var node=this.createElementDefaultNS("Server");this.setAttributes(node,{service:"OGC:WMS",version:layer.params["VERSION"]});node.appendChild(this.write_wmc_OnlineResource(layer.url));return node;},write_wmc_FormatList:function(layer){var node=this.createElementDefaultNS("FormatList");node.appendChild(this.createElementDefaultNS("Format",layer.params["FORMAT"],{current:"1"}));return node;},write_wmc_StyleList:function(layer){var node=this.createElementDefaultNS("StyleList");var style=this.createElementDefaultNS("Style",null,{current:"1"});if(layer.params["SLD"]){var sld=this.createElementDefaultNS("SLD");var link=this.write_wmc_OnlineResource(layer.params["SLD"]);sld.appendChild(link);style.appendChild(sld);}else if(layer.params["SLD_BODY"]){var sld=this.createElementDefaultNS("SLD");var body=layer.params["SLD_BODY"];var doc=OpenLayers.Format.XML.prototype.read.apply(this,[body]);var imported=doc.documentElement;if(sld.ownerDocument&&sld.ownerDocument.importNode){imported=sld.ownerDocument.importNode(imported,true);}
-sld.appendChild(imported);style.appendChild(sld);}else{var name=layer.params["STYLES"]?layer.params["STYLES"]:this.defaultStyleName;style.appendChild(this.createElementDefaultNS("Name",name));style.appendChild(this.createElementDefaultNS("Title",this.defaultStyleTitle));}
-node.appendChild(style);return node;},write_wmc_OnlineResource:function(href){var node=this.createElementDefaultNS("OnlineResource");this.setAttributeNS(node,this.namespaces.xlink,"xlink:type","simple");this.setAttributeNS(node,this.namespaces.xlink,"xlink:href",href);return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1"});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
+return px;},CLASS_NAME:'OpenLayers.Control.OverviewMap'});OpenLayers.Handler.Click=OpenLayers.Class(OpenLayers.Handler,{delay:300,single:true,'double':false,pixelTolerance:0,stopSingle:false,stopDouble:false,timerId:null,down:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);if(this.pixelTolerance!=null){this.mousedown=function(evt){this.down=evt.xy;return true;};}},mousedown:null,dblclick:function(evt){if(this.passesTolerance(evt)){if(this["double"]){this.callback('dblclick',[evt]);}
 this.clearTimer();}
 return!this.stopDouble;},click:function(evt){if(this.passesTolerance(evt)){if(this.timerId!=null){this.clearTimer();}else{var clickEvent=this.single?OpenLayers.Util.extend({},evt):null;this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,clickEvent),this.delay);}}
 return!this.stopSingle;},passesTolerance:function(evt){var passes=true;if(this.pixelTolerance!=null&&this.down){var dpx=Math.sqrt(Math.pow(this.down.x-evt.xy.x,2)+
@@ -734,22 +479,7 @@
 if(document.onselectstart){document.onselectstart=this.oldOnselectstart;}}
 return true;},click:function(evt){return(this.start==this.last);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragging=false;activated=true;}
 return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.started=false;this.dragging=false;this.start=null;this.last=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.Feature=OpenLayers.Class(OpenLayers.Handler,{EVENTMAP:{'click':{'in':'click','out':'clickout'},'mousemove':{'in':'over','out':'out'},'dblclick':{'in':'dblclick','out':null},'mousedown':{'in':null,'out':null},'mouseup':{'in':null,'out':null}},feature:null,lastFeature:null,down:null,up:null,clickoutTolerance:4,geometryTypes:null,stopClick:true,stopDown:true,stopUp:true,layerIndex:null,initialize:function(control,layer,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.layer=layer;},mousedown:function(evt){this.down=evt.xy;return this.handle(evt)?!this.stopDown:true;},mouseup:function(evt){this.up=evt.xy;return this.handle(evt)?!this.stopUp:true;},click:function(evt){return this.handle(evt)?!this.stopClick:true;},mousemove:function(evt){this.handle(evt);return true;},dblclick:function(evt){return!this.handle(evt);},geometryTypeMatches:function(feature){return this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)>-1;},handle:function(evt){var type=evt.type;var handled=false;var previouslyIn=!!(this.feature);var click=(type=="click"||type=="dblclick");this.feature=this.layer.getFeatureFromEvent(evt);if(this.feature){var inNew=(this.feature!=this.lastFeature);if(this.geometryTypeMatches(this.feature)){if(previouslyIn&&inNew){this.triggerCallback(type,'out',[this.lastFeature]);this.triggerCallback(type,'in',[this.feature]);}else if(!previouslyIn||click){this.triggerCallback(type,'in',[this.feature]);}
-this.lastFeature=this.feature;handled=true;}else{if(previouslyIn&&inNew||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}
-this.feature=null;}}else{if(previouslyIn||(click&&this.lastFeature)){this.triggerCallback(type,'out',[this.lastFeature]);}}
-return handled;},triggerCallback:function(type,mode,args){var key=this.EVENTMAP[type][mode];if(key){if(type=='click'&&mode=='out'&&this.up&&this.down){var dpx=Math.sqrt(Math.pow(this.up.x-this.down.x,2)+
-Math.pow(this.up.y-this.down.y,2));if(dpx<=this.clickoutTolerance){this.callback(key,args);}}else{this.callback(key,args);}}},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.layerIndex=this.layer.div.style.zIndex;this.layer.div.style.zIndex=this.map.Z_INDEX_BASE['Popup']-1;activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){if(this.layer&&this.layer.div){this.layer.div.style.zIndex=this.layerIndex;}
-this.feature=null;this.lastFeature=null;this.down=null;this.up=null;deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Feature"});OpenLayers.Handler.Hover=OpenLayers.Class(OpenLayers.Handler,{delay:500,pixelTolerance:null,stopMove:false,px:null,timerId:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);},mousemove:function(evt){if(this.passesTolerance(evt.xy)){this.clearTimer();this.callback('move',[evt]);this.px=evt.xy;evt=OpenLayers.Util.extend({},evt);this.timerId=window.setTimeout(OpenLayers.Function.bind(this.delayedCall,this,evt),this.delay);}
-return!this.stopMove;},mouseout:function(evt){if(OpenLayers.Util.mouseLeft(evt,this.map.div)){this.clearTimer();this.callback('move',[evt]);}
-return true;},passesTolerance:function(px){var passes=true;if(this.pixelTolerance&&this.px){var dpx=Math.sqrt(Math.pow(this.px.x-px.x,2)+
-Math.pow(this.px.y-px.y,2));if(dpx<this.pixelTolerance){passes=false;}}
-return passes;},clearTimer:function(){if(this.timerId!=null){window.clearTimeout(this.timerId);this.timerId=null;}},delayedCall:function(evt){this.callback('pause',[evt]);},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.clearTimer();deactivated=true;}
-return deactivated;},CLASS_NAME:"OpenLayers.Handler.Hover"});OpenLayers.Handler.Keyboard=OpenLayers.Class(OpenLayers.Handler,{KEY_EVENTS:["keydown","keypress","keyup"],eventListener:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.eventListener=OpenLayers.Function.bindAsEventListener(this.handleKeyEvent,this);},destroy:function(){this.deactivate();this.eventListener=null;OpenLayers.Handler.prototype.destroy.apply(this,arguments);},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.observe(window,this.KEY_EVENTS[i],this.eventListener);}
-return true;}else{return false;}},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){for(var i=0;i<this.KEY_EVENTS.length;i++){OpenLayers.Event.stopObserving(window,this.KEY_EVENTS[i],this.eventListener);}
-deactivated=true;}
-return deactivated;},handleKeyEvent:function(evt){if(this.checkModifiers(evt)){this.callback(evt.type,[evt.charCode||evt.keyCode]);}},CLASS_NAME:"OpenLayers.Handler.Keyboard"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
+return deactivated;},CLASS_NAME:"OpenLayers.Handler.Drag"});OpenLayers.Handler.MouseWheel=OpenLayers.Class(OpenLayers.Handler,{wheelListener:null,mousePosition:null,initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);this.wheelListener=OpenLayers.Function.bindAsEventListener(this.onWheelEvent,this);},destroy:function(){OpenLayers.Handler.prototype.destroy.apply(this,arguments);this.wheelListener=null;},onWheelEvent:function(e){if(!this.map||!this.checkModifiers(e)){return;}
 var overScrollableDiv=false;var overLayerDiv=false;var overMapDiv=false;var elem=OpenLayers.Event.element(e);while((elem!=null)&&!overMapDiv&&!overScrollableDiv){if(!overScrollableDiv){try{if(elem.currentStyle){overflow=elem.currentStyle["overflow"];}else{var style=document.defaultView.getComputedStyle(elem,null);var overflow=style.getPropertyValue("overflow");}
 overScrollableDiv=(overflow&&(overflow=="auto")||(overflow=="scroll"));}catch(err){}}
 if(!overLayerDiv){for(var i=0;i<this.map.layers.length;i++){if(elem==this.map.layers[i].div||elem==this.map.layers[i].pane){overLayerDiv=true;break;}}}
@@ -797,103 +527,14 @@
 return bounds;},CLASS_NAME:"OpenLayers.Layer"});OpenLayers.Marker.Box=OpenLayers.Class(OpenLayers.Marker,{bounds:null,div:null,initialize:function(bounds,borderColor,borderWidth){this.bounds=bounds;this.div=OpenLayers.Util.createDiv();this.div.style.overflow='hidden';this.events=new OpenLayers.Events(this,this.div,null);this.setBorder(borderColor,borderWidth);},destroy:function(){this.bounds=null;this.div=null;OpenLayers.Marker.prototype.destroy.apply(this,arguments);},setBorder:function(color,width){if(!color){color="red";}
 if(!width){width=2;}
 this.div.style.border=width+"px solid "+color;},draw:function(px,sz){OpenLayers.Util.modifyDOMElement(this.div,null,px,sz);return this.div;},onScreen:function(){var onScreen=false;if(this.map){var screenBounds=this.map.getExtent();onScreen=screenBounds.containsBounds(this.bounds,true,true);}
-return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Popup.FramedCloud=OpenLayers.Class(OpenLayers.Popup.Framed,{autoSize:true,panMapIfOutOfView:true,imageSize:new OpenLayers.Size(676,736),isAlphaImage:false,fixedRelativePosition:false,positionBlocks:{"tl":{'offset':new OpenLayers.Pixel(44,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,80,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(0,-668)}]},"tr":{'offset':new OpenLayers.Pixel(-45,0),'padding':new OpenLayers.Bounds(8,40,8,9),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,51,22,0),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,50,0,0),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,32,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,32,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,0,null,null),position:new OpenLayers.Pixel(-215,-668)}]},"bl":{'offset':new OpenLayers.Pixel(45,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(null,null,0,0),position:new OpenLayers.Pixel(-101,-674)}]},"br":{'offset':new OpenLayers.Pixel(-44,0),'padding':new OpenLayers.Bounds(8,9,8,40),'blocks':[{size:new OpenLayers.Size('auto','auto'),anchor:new OpenLayers.Bounds(0,21,22,32),position:new OpenLayers.Pixel(0,0)},{size:new OpenLayers.Size(22,'auto'),anchor:new OpenLayers.Bounds(null,21,0,32),position:new OpenLayers.Pixel(-638,0)},{size:new OpenLayers.Size('auto',21),anchor:new OpenLayers.Bounds(0,0,22,null),position:new OpenLayers.Pixel(0,-629)},{size:new OpenLayers.Size(22,21),anchor:new OpenLayers.Bounds(null,0,0,null),position:new OpenLayers.Pixel(-638,-629)},{size:new OpenLayers.Size(81,54),anchor:new OpenLayers.Bounds(0,null,null,0),position:new OpenLayers.Pixel(-311,-674)}]}},minSize:new OpenLayers.Size(105,10),maxSize:new OpenLayers.Size(600,660),initialize:function(id,lonlat,size,contentHTML,anchor,closeBox,closeBoxCallback){this.imageSrc=OpenLayers.Util.getImagesLocation()+'cloud-popup-relative.png';OpenLayers.Popup.Framed.prototype.initialize.apply(this,arguments);this.contentDiv.className="olFramedCloudPopupContent";},destroy:function(){OpenLayers.Popup.Framed.prototype.destroy.apply(this,arguments);},CLASS_NAME:"OpenLayers.Popup.FramedCloud"});OpenLayers.Control.DragFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,onStart:function(feature,pixel){},onDrag:function(feature,pixel){},onComplete:function(feature,pixel){},layer:null,feature:null,dragCallbacks:{},featureCallbacks:{},lastPixel:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.handlers={drag:new OpenLayers.Handler.Drag(this,OpenLayers.Util.extend({down:this.downFeature,move:this.moveFeature,up:this.upFeature,out:this.cancel,done:this.doneDragging},this.dragCallbacks)),feature:new OpenLayers.Handler.Feature(this,this.layer,OpenLayers.Util.extend({over:this.overFeature,out:this.outFeature},this.featureCallbacks),{geometryTypes:this.geometryTypes})};},destroy:function(){this.layer=null;OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.handlers.feature.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){this.handlers.drag.deactivate();this.handlers.feature.deactivate();this.feature=null;this.dragging=false;this.lastPixel=null;return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},overFeature:function(feature){if(!this.handlers.drag.dragging){this.feature=feature;this.handlers.drag.activate();this.over=true;this.map.div.style.cursor="move";}else{if(this.feature.id==feature.id){this.over=true;}else{this.over=false;}}},downFeature:function(pixel){this.lastPixel=pixel;this.onStart(this.feature,pixel);},moveFeature:function(pixel){var res=this.map.getResolution();this.feature.geometry.move(res*(pixel.x-this.lastPixel.x),res*(this.lastPixel.y-pixel.y));this.layer.drawFeature(this.feature);this.lastPixel=pixel;this.onDrag(this.feature,pixel);},upFeature:function(pixel){if(!this.over){this.handlers.drag.deactivate();this.feature=null;this.map.div.style.cursor="default";}},doneDragging:function(pixel){this.onComplete(this.feature,pixel);},outFeature:function(feature){if(!this.handlers.drag.dragging){this.over=false;this.handlers.drag.deactivate();this.map.div.style.cursor="default";this.feature=null;}else{if(this.feature.id==feature.id){this.over=false;}}},cancel:function(){this.handlers.drag.deactivate();this.over=false;},setMap:function(map){this.handlers.drag.setMap(map);this.handlers.feature.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.DragFeature"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Control.KeyboardDefaults=OpenLayers.Class(OpenLayers.Control,{slideFactor:75,initialize:function(){OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){if(this.handler){this.handler.destroy();}
-this.handler=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},draw:function(){this.handler=new OpenLayers.Handler.Keyboard(this,{"keypress":this.defaultKeyPress});this.activate();},defaultKeyPress:function(code){switch(code){case OpenLayers.Event.KEY_LEFT:this.map.pan(-this.slideFactor,0);break;case OpenLayers.Event.KEY_RIGHT:this.map.pan(this.slideFactor,0);break;case OpenLayers.Event.KEY_UP:this.map.pan(0,-this.slideFactor);break;case OpenLayers.Event.KEY_DOWN:this.map.pan(0,this.slideFactor);break;case 33:var size=this.map.getSize();this.map.pan(0,-0.75*size.h);break;case 34:var size=this.map.getSize();this.map.pan(0,0.75*size.h);break;case 35:var size=this.map.getSize();this.map.pan(0.75*size.w,0);break;case 36:var size=this.map.getSize();this.map.pan(-0.75*size.w,0);break;case 43:this.map.zoomIn();break;case 45:this.map.zoomOut();break;case 107:this.map.zoomIn();break;case 109:this.map.zoomOut();break;}},CLASS_NAME:"OpenLayers.Control.KeyboardDefaults"});OpenLayers.State={UNKNOWN:'Unknown',INSERT:'Insert',UPDATE:'Update',DELETE:'Delete'};OpenLayers.Feature.Vector=OpenLayers.Class(OpenLayers.Feature,{fid:null,geometry:null,attributes:null,state:null,style:null,renderIntent:"default",initialize:function(geometry,attributes,style){OpenLayers.Feature.prototype.initialize.apply(this,[null,null,attributes]);this.lonlat=null;this.geometry=geometry;this.state=null;this.attributes={};if(attributes){this.attributes=OpenLayers.Util.extend(this.attributes,attributes);}
-this.style=style?style:null;},destroy:function(){if(this.layer){this.layer.removeFeatures(this);this.layer=null;}
-this.geometry=null;OpenLayers.Feature.prototype.destroy.apply(this,arguments);},clone:function(){return new OpenLayers.Feature.Vector(this.geometry.clone(),this.attributes,this.style);},onScreen:function(boundsOnly){var onScreen=false;if(this.layer&&this.layer.map){var screenBounds=this.layer.map.getExtent();if(boundsOnly){var featureBounds=this.geometry.getBounds();onScreen=screenBounds.intersectsBounds(featureBounds);}else{var screenPoly=screenBounds.toGeometry();onScreen=screenPoly.intersects(this.geometry);}}
-return onScreen;},createMarker:function(){return null;},destroyMarker:function(){},createPopup:function(){return null;},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;if(this.geometry){atPoint=this.geometry.atPoint(lonlat,toleranceLon,toleranceLat);}
-return atPoint;},destroyPopup:function(){},toState:function(state){if(state==OpenLayers.State.UPDATE){switch(this.state){case OpenLayers.State.UNKNOWN:case OpenLayers.State.DELETE:this.state=state;break;case OpenLayers.State.UPDATE:case OpenLayers.State.INSERT:break;}}else if(state==OpenLayers.State.INSERT){switch(this.state){case OpenLayers.State.UNKNOWN:break;default:this.state=state;break;}}else if(state==OpenLayers.State.DELETE){switch(this.state){case OpenLayers.State.INSERT:break;case OpenLayers.State.DELETE:break;case OpenLayers.State.UNKNOWN:case OpenLayers.State.UPDATE:this.state=state;break;}}else if(state==OpenLayers.State.UNKNOWN){this.state=state;}},CLASS_NAME:"OpenLayers.Feature.Vector"});OpenLayers.Feature.Vector.style={'default':{fillColor:"#ee9900",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"#ee9900",strokeOpacity:1,strokeWidth:1,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""},'select':{fillColor:"blue",fillOpacity:0.4,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"blue",strokeOpacity:1,strokeWidth:2,strokeLinecap:"round",hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:"pointer"},'temporary':{fillColor:"yellow",fillOpacity:0.2,hoverFillColor:"white",hoverFillOpacity:0.8,strokeColor:"yellow",strokeOpacity:1,strokeLinecap:"round",strokeWidth:4,hoverStrokeColor:"red",hoverStrokeOpacity:1,hoverStrokeWidth:0.2,pointRadius:6,hoverPointRadius:1,hoverPointUnit:"%",pointerEvents:"visiblePainted",cursor:""}};OpenLayers.Feature.WFS=OpenLayers.Class(OpenLayers.Feature,{initialize:function(layer,xmlNode){var newArguments=arguments;var data=this.processXMLNode(xmlNode);newArguments=new Array(layer,data.lonlat,data);OpenLayers.Feature.prototype.initialize.apply(this,newArguments);this.createMarker();this.layer.addMarker(this.marker);},destroy:function(){if(this.marker!=null){this.layer.removeMarker(this.marker);}
-OpenLayers.Feature.prototype.destroy.apply(this,arguments);},processXMLNode:function(xmlNode){var point=OpenLayers.Ajax.getElementsByTagNameNS(xmlNode,"http://www.opengis.net/gml","gml","Point");var text=OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0],"http://www.opengis.net/gml","gml","coordinates")[0]);var floats=text.split(",");return{lonlat:new OpenLayers.LonLat(parseFloat(floats[0]),parseFloat(floats[1])),id:null};},CLASS_NAME:"OpenLayers.Feature.WFS"});OpenLayers.Format.WMC.v1_0_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.WMC.v1_0_0"});OpenLayers.Format.WMC.v1_1_0=OpenLayers.Class(OpenLayers.Format.WMC.v1,{VERSION:"1.1.0",schemaLocation:"http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",initialize:function(options){OpenLayers.Format.WMC.v1.prototype.initialize.apply(this,[options]);},read_sld_MinScaleDenominator:function(layerInfo,node){layerInfo.options.maxScale=this.getChildValue(node);},read_sld_MaxScaleDenominator:function(layerInfo,node){layerInfo.options.minScale=this.getChildValue(node);},write_wmc_Layer:function(layer){var node=OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(this,[layer]);if(layer.options.resolutions||layer.options.scales||layer.options.minResolution||layer.options.maxScale){var minSD=this.createElementNS(this.namespaces.sld,"sld:MinScaleDenominator");minSD.appendChild(this.createTextNode(layer.maxScale.toPrecision(10)));node.insertBefore(minSD,node.childNodes[3]);}
-if(layer.options.resolutions||layer.options.scales||layer.options.maxResolution||layer.options.minScale){var maxSD=this.createElementNS(this.namespaces.sld,"sld:MaxScaleDenominator");maxSD.appendChild(this.createTextNode(layer.minScale.toPrecision(10)));node.insertBefore(maxSD,node.childNodes[4]);}
-return node;},CLASS_NAME:"OpenLayers.Format.WMC.v1_1_0"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var deltaX=Math.abs(this.dragHandler.start.x-xy.x);var deltaY=Math.abs(this.dragHandler.start.y-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";if(xy.x<this.dragHandler.start.x){this.zoomBox.style.left=xy.x+"px";}
-if(xy.y<this.dragHandler.start.y){this.zoomBox.style.top=xy.y+"px";}},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
-this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Handler.RegularPolygon=OpenLayers.Class(OpenLayers.Handler.Drag,{sides:4,radius:null,snapAngle:null,snapToggle:'shiftKey',persist:false,irregular:false,angle:null,fixedRadius:false,feature:null,layer:null,origin:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,[control,callbacks,options]);this.options=(options)?options:new Object();},setOptions:function(newOptions){OpenLayers.Util.extend(this.options,newOptions);OpenLayers.Util.extend(this,newOptions);},activate:function(){var activated=false;if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){var options={displayInLayerSwitcher:false};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);activated=true;}
-return activated;},deactivate:function(){var deactivated=false;if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this,arguments)){if(this.dragging){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);if(this.feature){this.feature.destroy();}}
-this.layer=null;this.feature=null;deactivated=true;}
-return deactivated;},down:function(evt){this.fixedRadius=!!(this.radius);var maploc=this.map.getLonLatFromPixel(evt.xy);this.origin=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(!this.fixedRadius||this.irregular){this.radius=this.map.getResolution();}
-if(this.persist){this.clear();}
-this.feature=new OpenLayers.Feature.Vector();this.createGeometry();this.layer.addFeatures([this.feature],{silent:true});this.layer.drawFeature(this.feature,this.style);},move:function(evt){var maploc=this.map.getLonLatFromPixel(evt.xy);var point=new OpenLayers.Geometry.Point(maploc.lon,maploc.lat);if(this.irregular){var ry=Math.sqrt(2)*Math.abs(point.y-this.origin.y)/2;this.radius=Math.max(this.map.getResolution()/2,ry);}else if(this.fixedRadius){this.origin=point;}else{this.calculateAngle(point,evt);this.radius=Math.max(this.map.getResolution()/2,point.distanceTo(this.origin));}
-this.modifyGeometry();if(this.irregular){var dx=point.x-this.origin.x;var dy=point.y-this.origin.y;var ratio;if(dy==0){ratio=dx/(this.radius*Math.sqrt(2));}else{ratio=dx/dy;}
-this.feature.geometry.resize(1,this.origin,ratio);this.feature.geometry.move(dx/2,dy/2);}
-this.layer.drawFeature(this.feature,this.style);},up:function(evt){this.finalize();},out:function(evt){this.finalize();},createGeometry:function(){this.angle=Math.PI*((1/this.sides)-(1/2));if(this.snapAngle){this.angle+=this.snapAngle*(Math.PI/180);}
-this.feature.geometry=OpenLayers.Geometry.Polygon.createRegularPolygon(this.origin,this.radius,this.sides,this.snapAngle);},modifyGeometry:function(){var angle,dx,dy,point;var ring=this.feature.geometry.components[0];if(ring.components.length!=(this.sides+1)){this.createGeometry();ring=this.feature.geometry.components[0];}
-for(var i=0;i<this.sides;++i){point=ring.components[i];angle=this.angle+(i*2*Math.PI/this.sides);point.x=this.origin.x+(this.radius*Math.cos(angle));point.y=this.origin.y+(this.radius*Math.sin(angle));point.clearBounds();}},calculateAngle:function(point,evt){var alpha=Math.atan2(point.y-this.origin.y,point.x-this.origin.x);if(this.snapAngle&&(this.snapToggle&&!evt[this.snapToggle])){var snapAngleRad=(Math.PI/180)*this.snapAngle;this.angle=Math.round(alpha/snapAngleRad)*snapAngleRad;}else{this.angle=alpha;}},cancel:function(){this.callback("cancel",null);this.finalize();},finalize:function(){this.origin=null;this.radius=this.options.radius;},clear:function(){this.layer.renderer.clear();this.layer.destroyFeatures();},callback:function(name,args){if(this.callbacks[name]){this.callbacks[name].apply(this.control,[this.feature.geometry.clone()]);}
-if(!this.persist&&(name=="done"||name=="cancel")){this.clear();}},CLASS_NAME:"OpenLayers.Handler.RegularPolygon"});OpenLayers.Layer.EventPane=OpenLayers.Class(OpenLayers.Layer,{smoothDragPan:true,isBaseLayer:true,isFixed:true,pane:null,mapObject:null,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(this.pane==null){this.pane=OpenLayers.Util.createDiv(this.div.id+"_EventPane");}},destroy:function(){this.mapObject=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;this.pane.style.display=this.div.style.display;this.pane.style.width="100%";this.pane.style.height="100%";if(OpenLayers.Util.getBrowserName()=="msie"){this.pane.style.background="url("+OpenLayers.Util.getImagesLocation()+"blank.gif)";}
-if(this.isFixed){this.map.viewPortDiv.appendChild(this.pane);}else{this.map.layerContainerDiv.appendChild(this.pane);}
-this.loadMapObject();if(this.mapObject==null){this.loadWarningMessage();}},removeMap:function(map){if(this.pane&&this.pane.parentNode){this.pane.parentNode.removeChild(this.pane);this.pane=null;}
-OpenLayers.Layer.prototype.removeMap.apply(this,arguments);},loadWarningMessage:function(){this.div.style.backgroundColor="darkblue";var viewSize=this.map.getSize();var msgW=Math.min(viewSize.w,300);var msgH=Math.min(viewSize.h,200);var size=new OpenLayers.Size(msgW,msgH);var centerPx=new OpenLayers.Pixel(viewSize.w/2,viewSize.h/2);var topLeft=centerPx.add(-size.w/2,-size.h/2);var div=OpenLayers.Util.createDiv(this.name+"_warning",topLeft,size,null,null,null,"auto");div.style.padding="7px";div.style.backgroundColor="yellow";div.innerHTML=this.getWarningHTML();this.div.appendChild(div);},getWarningHTML:function(){return"";},display:function(display){OpenLayers.Layer.prototype.display.apply(this,arguments);this.pane.style.display=this.div.style.display;},setZIndex:function(zIndex){OpenLayers.Layer.prototype.setZIndex.apply(this,arguments);this.pane.style.zIndex=parseInt(this.div.style.zIndex)+1;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(this.mapObject!=null){var newCenter=this.map.getCenter();var newZoom=this.map.getZoom();if(newCenter!=null){var moOldCenter=this.getMapObjectCenter();var oldCenter=this.getOLLonLatFromMapObjectLonLat(moOldCenter);var moOldZoom=this.getMapObjectZoom();var oldZoom=this.getOLZoomFromMapObjectZoom(moOldZoom);if(!(newCenter.equals(oldCenter))||!(newZoom==oldZoom)){if(dragging&&this.dragPanMapObject&&this.smoothDragPan){var oldPx=this.map.getViewPortPxFromLonLat(oldCenter);var newPx=this.map.getViewPortPxFromLonLat(newCenter);this.dragPanMapObject(newPx.x-oldPx.x,oldPx.y-newPx.y);}else{var center=this.getMapObjectLonLatFromOLLonLat(newCenter);var zoom=this.getMapObjectZoomFromOLZoom(newZoom);this.setMapObjectCenter(center,zoom,dragging);}}}}},getLonLatFromViewPortPx:function(viewPortPx){var lonlat=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moPixel=this.getMapObjectPixelFromOLPixel(viewPortPx);var moLonLat=this.getMapObjectLonLatFromMapObjectPixel(moPixel);lonlat=this.getOLLonLatFromMapObjectLonLat(moLonLat);}
-return lonlat;},getViewPortPxFromLonLat:function(lonlat){var viewPortPx=null;if((this.mapObject!=null)&&(this.getMapObjectCenter()!=null)){var moLonLat=this.getMapObjectLonLatFromOLLonLat(lonlat);var moPixel=this.getMapObjectPixelFromMapObjectLonLat(moLonLat);viewPortPx=this.getOLPixelFromMapObjectPixel(moPixel);}
-return viewPortPx;},getOLLonLatFromMapObjectLonLat:function(moLonLat){var olLonLat=null;if(moLonLat!=null){var lon=this.getLongitudeFromMapObjectLonLat(moLonLat);var lat=this.getLatitudeFromMapObjectLonLat(moLonLat);olLonLat=new OpenLayers.LonLat(lon,lat);}
-return olLonLat;},getMapObjectLonLatFromOLLonLat:function(olLonLat){var moLatLng=null;if(olLonLat!=null){moLatLng=this.getMapObjectLonLatFromLonLat(olLonLat.lon,olLonLat.lat);}
-return moLatLng;},getOLPixelFromMapObjectPixel:function(moPixel){var olPixel=null;if(moPixel!=null){var x=this.getXFromMapObjectPixel(moPixel);var y=this.getYFromMapObjectPixel(moPixel);olPixel=new OpenLayers.Pixel(x,y);}
-return olPixel;},getMapObjectPixelFromOLPixel:function(olPixel){var moPixel=null;if(olPixel!=null){moPixel=this.getMapObjectPixelFromXY(olPixel.x,olPixel.y);}
-return moPixel;},CLASS_NAME:"OpenLayers.Layer.EventPane"});OpenLayers.Layer.FixedZoomLevels=OpenLayers.Class({initialize:function(){},initResolutions:function(){var props=new Array('minZoomLevel','maxZoomLevel','numZoomLevels');for(var i=0;i<props.length;i++){var property=props[i];this[property]=(this.options[property]!=null)?this.options[property]:this.map[property];}
-if((this.minZoomLevel==null)||(this.minZoomLevel<this.MIN_ZOOM_LEVEL)){this.minZoomLevel=this.MIN_ZOOM_LEVEL;}
-var limitZoomLevels=this.MAX_ZOOM_LEVEL-this.minZoomLevel+1;if(this.numZoomLevels!=null){this.numZoomLevels=Math.min(this.numZoomLevels,limitZoomLevels);}else{if(this.maxZoomLevel!=null){var zoomDiff=this.maxZoomLevel-this.minZoomLevel+1;this.numZoomLevels=Math.min(zoomDiff,limitZoomLevels);}else{this.numZoomLevels=limitZoomLevels;}}
-this.maxZoomLevel=this.minZoomLevel+this.numZoomLevels-1;if(this.RESOLUTIONS!=null){var resolutionsIndex=0;this.resolutions=[];for(var i=this.minZoomLevel;i<=this.maxZoomLevel;i++){this.resolutions[resolutionsIndex++]=this.RESOLUTIONS[i];}
-this.maxResolution=this.resolutions[0];this.minResolution=this.resolutions[this.resolutions.length-1];}},getResolution:function(){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getResolution.apply(this,arguments);}else{var resolution=null;var viewSize=this.map.getSize();var extent=this.getExtent();if((viewSize!=null)&&(extent!=null)){resolution=Math.max(extent.getWidth()/viewSize.w,extent.getHeight()/viewSize.h);}
-return resolution;}},getExtent:function(){var extent=null;var size=this.map.getSize();var tlPx=new OpenLayers.Pixel(0,0);var tlLL=this.getLonLatFromViewPortPx(tlPx);var brPx=new OpenLayers.Pixel(size.w,size.h);var brLL=this.getLonLatFromViewPortPx(brPx);if((tlLL!=null)&&(brLL!=null)){extent=new OpenLayers.Bounds(tlLL.lon,brLL.lat,brLL.lon,tlLL.lat);}
-return extent;},getZoomForResolution:function(resolution){if(this.resolutions!=null){return OpenLayers.Layer.prototype.getZoomForResolution.apply(this,arguments);}else{var extent=OpenLayers.Layer.prototype.getExtent.apply(this,[]);return this.getZoomForExtent(extent);}},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=moZoom-this.minZoomLevel;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=olZoom+this.minZoomLevel;}
-return zoom;},CLASS_NAME:"FixedZoomLevels.js"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
+return onScreen;},display:function(display){this.div.style.display=(display)?"":"none";},CLASS_NAME:"OpenLayers.Marker.Box"});OpenLayers.Control.DragPan=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,panned:false,draw:function(){this.handler=new OpenLayers.Handler.Drag(this,{"move":this.panMap,"done":this.panMapDone});},panMap:function(xy){this.panned=true;this.map.pan(this.handler.last.x-xy.x,this.handler.last.y-xy.y,{dragging:this.handler.dragging,animate:false});},panMapDone:function(xy){if(this.panned){this.panMap(xy);this.panned=false;}},CLASS_NAME:"OpenLayers.Control.DragPan"});OpenLayers.Handler.Box=OpenLayers.Class(OpenLayers.Handler,{dragHandler:null,boxDivClassName:'olHandlerBoxZoomBox',initialize:function(control,callbacks,options){OpenLayers.Handler.prototype.initialize.apply(this,arguments);var callbacks={"down":this.startBox,"move":this.moveBox,"out":this.removeBox,"up":this.endBox};this.dragHandler=new OpenLayers.Handler.Drag(this,callbacks,{keyMask:this.keyMask});},setMap:function(map){OpenLayers.Handler.prototype.setMap.apply(this,arguments);if(this.dragHandler){this.dragHandler.setMap(map);}},startBox:function(xy){this.zoomBox=OpenLayers.Util.createDiv('zoomBox',this.dragHandler.start);this.zoomBox.className=this.boxDivClassName;this.zoomBox.style.zIndex=this.map.Z_INDEX_BASE["Popup"]-1;this.map.viewPortDiv.appendChild(this.zoomBox);this.map.div.style.cursor="crosshair";},moveBox:function(xy){var startX=this.dragHandler.start.x;var startY=this.dragHandler.start.y;var deltaX=Math.abs(startX-xy.x);var deltaY=Math.abs(startY-xy.y);this.zoomBox.style.width=Math.max(1,deltaX)+"px";this.zoomBox.style.height=Math.max(1,deltaY)+"px";this.zoomBox.style.left=xy.x<startX?xy.x+"px":startX+"px";this.zoomBox.style.top=xy.y<startY?xy.y+"px":startY+"px";},endBox:function(end){var result;if(Math.abs(this.dragHandler.start.x-end.x)>5||Math.abs(this.dragHandler.start.y-end.y)>5){var start=this.dragHandler.start;var top=Math.min(start.y,end.y);var bottom=Math.max(start.y,end.y);var left=Math.min(start.x,end.x);var right=Math.max(start.x,end.x);result=new OpenLayers.Bounds(left,bottom,right,top);}else{result=this.dragHandler.start.clone();}
+this.removeBox();this.map.div.style.cursor="";this.callback("done",[result]);},removeBox:function(){this.map.viewPortDiv.removeChild(this.zoomBox);this.zoomBox=null;},activate:function(){if(OpenLayers.Handler.prototype.activate.apply(this,arguments)){this.dragHandler.activate();return true;}else{return false;}},deactivate:function(){if(OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){this.dragHandler.deactivate();return true;}else{return false;}},CLASS_NAME:"OpenLayers.Handler.Box"});OpenLayers.Layer.HTTPRequest=OpenLayers.Class(OpenLayers.Layer,{URL_HASH_FACTOR:(Math.sqrt(5)-1)/2,url:null,params:null,reproject:false,initialize:function(name,url,params,options){var newArguments=arguments;newArguments=[name,options];OpenLayers.Layer.prototype.initialize.apply(this,newArguments);this.url=url;this.params=OpenLayers.Util.extend({},params);},destroy:function(){this.url=null;this.params=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.HTTPRequest(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setUrl:function(newUrl){this.url=newUrl;},mergeNewParams:function(newParams){this.params=OpenLayers.Util.extend(this.params,newParams);return this.redraw();},redraw:function(force){if(force){return this.mergeNewParams({"_olSalt":Math.random()});}else{return OpenLayers.Layer.prototype.redraw.apply(this,[]);}},selectUrl:function(paramString,urls){var product=1;for(var i=0;i<paramString.length;i++){product*=paramString.charCodeAt(i)*this.URL_HASH_FACTOR;product-=Math.floor(product);}
 return urls[Math.floor(product*urls.length)];},getFullRequestString:function(newParams,altUrl){var url=altUrl||this.url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Layer.Image=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:true,url:null,extent:null,size:null,tile:null,aspectRatio:null,initialize:function(name,url,extent,size,options){this.url=url;this.extent=extent;this.size=size;OpenLayers.Layer.prototype.initialize.apply(this,[name,options]);this.aspectRatio=(this.extent.getHeight()/this.size.h)/(this.extent.getWidth()/this.size.w);},destroy:function(){if(this.tile){this.tile.destroy();this.tile=null;}
-OpenLayers.Layer.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Image(this.name,this.url,this.extent,this.size,this.options);}
-obj=OpenLayers.Layer.prototype.clone.apply(this,[obj]);return obj;},setMap:function(map){if(this.options.maxResolution==null){this.options.maxResolution=this.aspectRatio*this.extent.getWidth()/this.size.w;}
-OpenLayers.Layer.prototype.setMap.apply(this,arguments);},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);var firstRendering=(this.tile==null);if(zoomChanged||firstRendering){this.setTileSize();var ul=new OpenLayers.LonLat(this.extent.left,this.extent.top);var ulPx=this.map.getLayerPxFromLonLat(ul);if(firstRendering){this.tile=new OpenLayers.Tile.Image(this,ulPx,this.extent,null,this.tileSize);}else{this.tile.size=this.tileSize.clone();this.tile.position=ulPx.clone();}
-this.tile.draw();}},setTileSize:function(){var tileWidth=this.extent.getWidth()/this.map.getResolution();var tileHeight=this.extent.getHeight()/this.map.getResolution();this.tileSize=new OpenLayers.Size(tileWidth,tileHeight);},setUrl:function(newUrl){this.url=newUrl;this.tile.draw();},getURL:function(bounds){return this.url;},CLASS_NAME:"OpenLayers.Layer.Image"});OpenLayers.Layer.Markers=OpenLayers.Class(OpenLayers.Layer,{isBaseLayer:false,markers:null,drawn:false,initialize:function(name,options){OpenLayers.Layer.prototype.initialize.apply(this,arguments);this.markers=[];},destroy:function(){this.clearMarkers();this.markers=null;OpenLayers.Layer.prototype.destroy.apply(this,arguments);},setOpacity:function(opacity){if(opacity!=this.opacity){this.opacity=opacity;for(var i=0;i<this.markers.length;i++){this.markers[i].setOpacity(this.opacity);}}},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(zoomChanged||!this.drawn){for(var i=0;i<this.markers.length;i++){this.drawMarker(this.markers[i]);}
-this.drawn=true;}},addMarker:function(marker){this.markers.push(marker);if(this.opacity!=null){marker.setOpacity(this.opacity);}
-if(this.map&&this.map.getExtent()){marker.map=this.map;this.drawMarker(marker);}},removeMarker:function(marker){if(this.markers&&this.markers.length){OpenLayers.Util.removeItem(this.markers,marker);if((marker.icon!=null)&&(marker.icon.imageDiv!=null)&&(marker.icon.imageDiv.parentNode==this.div)){this.div.removeChild(marker.icon.imageDiv);marker.drawn=false;}}},clearMarkers:function(){if(this.markers!=null){while(this.markers.length>0){this.removeMarker(this.markers[0]);}}},drawMarker:function(marker){var px=this.map.getLayerPxFromLonLat(marker.lonlat);if(px==null){marker.display(false);}else{var markerImg=marker.draw(px);if(!marker.drawn){this.div.appendChild(markerImg);marker.drawn=true;}}},getDataExtent:function(){var maxExtent=null;if(this.markers&&(this.markers.length>0)){var maxExtent=new OpenLayers.Bounds();for(var i=0;i<this.markers.length;i++){var marker=this.markers[i];maxExtent.extend(marker.lonlat);}}
-return maxExtent;},CLASS_NAME:"OpenLayers.Layer.Markers"});OpenLayers.Layer.SphericalMercator={getExtent:function(){var extent=null;if(this.sphericalMercator){extent=this.map.calculateBounds();}else{extent=OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);}
-return extent;},initMercatorParameters:function(){this.RESOLUTIONS=[];var maxResolution=156543.0339;for(var zoom=0;zoom<=this.MAX_ZOOM_LEVEL;++zoom){this.RESOLUTIONS[zoom]=maxResolution/Math.pow(2,zoom);}
-this.units="m";this.projection="EPSG:900913";},forwardMercator:function(lon,lat){var x=lon*20037508.34/180;var y=Math.log(Math.tan((90+lat)*Math.PI/360))/(Math.PI/180);y=y*20037508.34/180;return new OpenLayers.LonLat(x,y);},inverseMercator:function(x,y){var lon=(x/20037508.34)*180;var lat=(y/20037508.34)*180;lat=180/Math.PI*(2*Math.atan(Math.exp(lat*Math.PI/180))-Math.PI/2);return new OpenLayers.LonLat(lon,lat);},projectForward:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.forwardMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;},projectInverse:function(point){var lonlat=OpenLayers.Layer.SphericalMercator.inverseMercator(point.x,point.y);point.x=lonlat.lon;point.y=lonlat.lat;return point;}};OpenLayers.Projection.addTransform("EPSG:4326","EPSG:900913",OpenLayers.Layer.SphericalMercator.projectForward);OpenLayers.Projection.addTransform("EPSG:900913","EPSG:4326",OpenLayers.Layer.SphericalMercator.projectInverse);OpenLayers.Control.DrawFeature=OpenLayers.Class(OpenLayers.Control,{layer:null,callbacks:null,featureAdded:function(){},handlerOptions:null,initialize:function(layer,handler,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.callbacks=OpenLayers.Util.extend({done:this.drawFeature},this.callbacks);this.layer=layer;this.handler=new handler(this,this.callbacks,this.handlerOptions);},drawFeature:function(geometry){var feature=new OpenLayers.Feature.Vector(geometry);this.layer.addFeatures([feature]);this.featureAdded(feature);},CLASS_NAME:"OpenLayers.Control.DrawFeature"});OpenLayers.Control.SelectFeature=OpenLayers.Class(OpenLayers.Control,{multipleKey:null,toggleKey:null,multiple:false,clickout:true,toggle:false,hover:false,onSelect:function(){},onUnselect:function(){},geometryTypes:null,layer:null,callbacks:null,selectStyle:null,renderIntent:"select",handler:null,initialize:function(layer,options){OpenLayers.Control.prototype.initialize.apply(this,[options]);this.layer=layer;this.callbacks=OpenLayers.Util.extend({click:this.clickFeature,clickout:this.clickoutFeature,over:this.overFeature,out:this.outFeature},this.callbacks);var handlerOptions={geometryTypes:this.geometryTypes};this.handler=new OpenLayers.Handler.Feature(this,layer,this.callbacks,handlerOptions);},unselectAll:function(options){var feature;for(var i=this.layer.selectedFeatures.length-1;i>=0;--i){feature=this.layer.selectedFeatures[i];if(!options||options.except!=feature){this.unselect(feature);}}},clickFeature:function(feature){if(!this.hover){var selected=(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)>-1);if(selected){if(this.toggleSelect()){this.unselect(feature);}else if(!this.multipleSelect()){this.unselectAll({except:feature});}}else{if(!this.multipleSelect()){this.unselectAll({except:feature});}
-this.select(feature);}}},multipleSelect:function(){return this.multiple||this.handler.evt[this.multipleKey];},toggleSelect:function(){return this.toggle||this.handler.evt[this.toggleKey];},clickoutFeature:function(feature){if(!this.hover&&this.clickout){this.unselectAll();}},overFeature:function(feature){if(this.hover&&(OpenLayers.Util.indexOf(this.layer.selectedFeatures,feature)==-1)){this.select(feature);}},outFeature:function(feature){if(this.hover){this.unselect(feature);}},select:function(feature){this.layer.selectedFeatures.push(feature);var selectStyle=this.selectStyle||this.renderIntent;this.layer.drawFeature(feature,selectStyle);this.layer.events.triggerEvent("featureselected",{feature:feature});this.onSelect(feature);},unselect:function(feature){this.layer.drawFeature(feature,"default");OpenLayers.Util.removeItem(this.layer.selectedFeatures,feature);this.layer.events.triggerEvent("featureunselected",{feature:feature});this.onUnselect(feature);},setMap:function(map){this.handler.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.SelectFeature"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
-this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Format.WKT=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){this.regExes={'typeStr':/^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,'spaces':/\s+/,'parenComma':/\)\s*,\s*\(/,'doubleParenComma':/\)\s*\)\s*,\s*\(\s*\(/,'trimParens':/^\s*\(?(.*?)\)?\s*$/};OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(wkt){var features,type,str;var matches=this.regExes.typeStr.exec(wkt);if(matches){type=matches[1].toLowerCase();str=matches[2];if(this.parse[type]){features=this.parse[type].apply(this,[str]);}
-if(this.internalProjection&&this.externalProjection){if(features&&features.CLASS_NAME=="OpenLayers.Feature.Vector"){features.geometry.transform(this.externalProjection,this.internalProjection);}else if(features&&typeof features=="object"){for(var i=0;i<features.length;i++){var component=features[i];component.geometry.transform(this.externalProjection,this.internalProjection);}}}}
-return features;},write:function(features){var collection,geometry,type,data,isCollection;if(features.constructor==Array){collection=features;isCollection=true;}else{collection=[features];isCollection=false;}
-var pieces=[];if(isCollection){pieces.push('GEOMETRYCOLLECTION(');}
-for(var i=0;i<collection.length;++i){if(isCollection&&i>0){pieces.push(',');}
-geometry=collection[i].geometry;type=geometry.CLASS_NAME.split('.')[2].toLowerCase();if(!this.extract[type]){return null;}
-if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-data=this.extract[type].apply(this,[geometry]);pieces.push(type.toUpperCase()+'('+data+')');}
-if(isCollection){pieces.push(')');}
-return pieces.join('');},extract:{'point':function(point){return point.x+' '+point.y;},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array.join(',');},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array.join(',');},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[multilinestring.components[i]])+')');}
-return array.join(',');},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push('('+
-this.extract.linestring.apply(this,[polygon.components[i]])+')');}
-return array.join(',');},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push('('+
-this.extract.polygon.apply(this,[multipolygon.components[i]])+')');}
-return array.join(',');}},parse:{'point':function(str){var coords=OpenLayers.String.trim(str).split(this.regExes.spaces);return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(coords[0],coords[1]));},'multipoint':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPoint(components));},'linestring':function(str){var points=OpenLayers.String.trim(str).split(',');var components=[];for(var i=0;i<points.length;++i){components.push(this.parse.point.apply(this,[points[i]]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString(components));},'multilinestring':function(str){var line;var lines=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<lines.length;++i){line=lines[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.linestring.apply(this,[line]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiLineString(components));},'polygon':function(str){var ring,linestring,linearring;var rings=OpenLayers.String.trim(str).split(this.regExes.parenComma);var components=[];for(var i=0;i<rings.length;++i){ring=rings[i].replace(this.regExes.trimParens,'$1');linestring=this.parse.linestring.apply(this,[ring]).geometry;linearring=new OpenLayers.Geometry.LinearRing(linestring.components);components.push(linearring);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon(components));},'multipolygon':function(str){var polygon;var polygons=OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);var components=[];for(var i=0;i<polygons.length;++i){polygon=polygons[i].replace(this.regExes.trimParens,'$1');components.push(this.parse.polygon.apply(this,[polygon]).geometry);}
-return new OpenLayers.Feature.Vector(new OpenLayers.Geometry.MultiPolygon(components));},'geometrycollection':function(str){str=str.replace(/,\s*([A-Za-z])/g,'|$1');var wktArray=OpenLayers.String.trim(str).split('|');var components=[];for(var i=0;i<wktArray.length;++i){components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));}
-return components;}},CLASS_NAME:"OpenLayers.Format.WKT"});OpenLayers.Layer.Boxes=OpenLayers.Class(OpenLayers.Layer.Markers,{initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);},drawMarker:function(marker){var bounds=marker.bounds;var topleft=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.left,bounds.top));var botright=this.map.getLayerPxFromLonLat(new OpenLayers.LonLat(bounds.right,bounds.bottom));if(botright==null||topleft==null){marker.display(false);}else{var sz=new OpenLayers.Size(Math.max(1,botright.x-topleft.x),Math.max(1,botright.y-topleft.y));var markerDiv=marker.draw(topleft,sz);if(!marker.drawn){this.div.appendChild(markerDiv);marker.drawn=true;}}},removeMarker:function(marker){OpenLayers.Util.removeItem(this.markers,marker);if((marker.div!=null)&&(marker.div.parentNode==this.div)){this.div.removeChild(marker.div);}},CLASS_NAME:"OpenLayers.Layer.Boxes"});OpenLayers.Layer.GeoRSS=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,icon:null,popupSize:null,useFeedTitle:true,initialize:function(name,location,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,[name,options]);this.location=location;this.features=[];},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadRSS:function(){if(!this.loaded){this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData);this.loaded=true;}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadRSS();}},parseData:function(ajaxRequest){var doc=ajaxRequest.responseXML;if(!doc||!doc.documentElement){doc=OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);}
-if(this.useFeedTitle){var name=null;try{name=doc.getElementsByTagNameNS('*','title')[0].firstChild.nodeValue;}
-catch(e){name=doc.getElementsByTagName('title')[0].firstChild.nodeValue;}
-if(name){this.setName(name);}}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var format=new OpenLayers.Format.GeoRSS(options);var features=format.read(doc);for(var i=0;i<features.length;i++){var data={};var feature=features[i];if(!feature.geometry){continue;}
-var title=feature.attributes.title?feature.attributes.title:"Untitled";var description=feature.attributes.description?feature.attributes.description:"No description.";var link=feature.attributes.link?feature.attributes.link:"";var location=feature.geometry.getBounds().getCenterLonLat();data.icon=this.icon==null?OpenLayers.Marker.defaultIcon():this.icon.clone();data.popupSize=this.popupSize?this.popupSize.clone():new OpenLayers.Size(250,120);if(title||description){var contentHTML='<div class="olLayerGeoRSSClose">[x]</div>';contentHTML+='<div class="olLayerGeoRSSTitle">';if(link){contentHTML+='<a class="link" href="'+link+'" target="_blank">';}
-contentHTML+=title;if(link){contentHTML+='</a>';}
-contentHTML+='</div>';contentHTML+='<div style="" class="olLayerGeoRSSDescription">';contentHTML+=description;contentHTML+='</div>';data['popupContentHTML']=contentHTML;}
-var feature=new OpenLayers.Feature(this,location,data);this.features.push(feature);var marker=feature.createMarker();marker.events.register('click',feature,this.markerClick);this.addMarker(marker);}
-this.events.triggerEvent("loadend");},markerClick:function(evt){var sameMarkerClicked=(this==this.layer.selectedFeature);this.layer.selectedFeature=(!sameMarkerClicked)?this:null;for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}
-if(!sameMarkerClicked){var popup=this.createPopup();OpenLayers.Event.observe(popup.div,"click",OpenLayers.Function.bind(function(){for(var i=0;i<this.layer.map.popups.length;i++){this.layer.map.removePopup(this.layer.map.popups[i]);}},this));this.layer.map.addPopup(popup);}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.GeoRSS"});OpenLayers.Layer.Google=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:19,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125,0.00002145767211914062,0.00001072883605957031,0.00000536441802978515,0.00000268220901489257],type:null,sphericalMercator:false,dragObject:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);this.addContainerPxFunction();if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{this.mapObject=new GMap2(this.div);if(typeof this.mapObject.getDragObject=="function"){this.dragObject=this.mapObject.getDragObject();}else{this.dragPanMapObject=null;}
-var poweredBy=this.div.lastChild;this.div.removeChild(poweredBy);this.pane.appendChild(poweredBy);poweredBy.className="olLayerGooglePoweredBy gmnoprint";poweredBy.style.left="";poweredBy.style.bottom="";var termsOfUse=this.div.lastChild;this.div.removeChild(termsOfUse);this.pane.appendChild(termsOfUse);termsOfUse.className="olLayerGoogleCopyright";termsOfUse.style.right="";termsOfUse.style.bottom="";}catch(e){OpenLayers.Console.error(e);}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);if(this.type!=null){this.map.events.register("moveend",this,this.setMapType);}},setMapType:function(){if(this.mapObject.getCenter()!=null){if(OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),this.type)==-1){this.mapObject.addMapType(this.type);}
-this.mapObject.setMapType(this.type);this.map.events.unregister("moveend",this,this.setMapType);}},onMapResize:function(){this.mapObject.checkResize();},getOLBoundsFromMapObjectBounds:function(moBounds){var olBounds=null;if(moBounds!=null){var sw=moBounds.getSouthWest();var ne=moBounds.getNorthEast();if(this.sphericalMercator){sw=this.forwardMercator(sw.lng(),sw.lat());ne=this.forwardMercator(ne.lng(),ne.lat());}else{sw=new OpenLayers.LonLat(sw.lng(),sw.lat());ne=new OpenLayers.LonLat(ne.lng(),ne.lat());}
-olBounds=new OpenLayers.Bounds(sw.lon,sw.lat,ne.lon,ne.lat);}
-return olBounds;},getMapObjectBoundsFromOLBounds:function(olBounds){var moBounds=null;if(olBounds!=null){var sw=this.sphericalMercator?this.inverseMercator(olBounds.bottom,olBounds.left):new OpenLayers.LonLat(olBounds.bottom,olBounds.left);var ne=this.sphericalMercator?this.inverseMercator(olBounds.top,olBounds.right):new OpenLayers.LonLat(olBounds.top,olBounds.right);moBounds=new GLatLngBounds(new GLatLng(sw.lat,sw.lon),new GLatLng(ne.lat,ne.lon));}
-return moBounds;},addContainerPxFunction:function(){if((typeof GMap2!="undefined")&&!GMap2.prototype.fromLatLngToContainerPixel){GMap2.prototype.fromLatLngToContainerPixel=function(gLatLng){var gPoint=this.fromLatLngToDivPixel(gLatLng);var div=this.getContainer().firstChild.firstChild;gPoint.x+=div.offsetLeft;gPoint.y+=div.offsetTop;return gPoint;};}},getWarningHTML:function(){return OpenLayers.i18n("googleWarning");},setMapObjectCenter:function(center,zoom){this.mapObject.setCenter(center,zoom);},dragPanMapObject:function(dX,dY){this.dragObject.moveBy(new GSize(-dX,dY));},getMapObjectCenter:function(){return this.mapObject.getCenter();},getMapObjectZoom:function(){return this.mapObject.getZoom();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.fromContainerPixelToLatLng(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.fromLatLngToContainerPixel(moLonLat);},getMapObjectZoomFromMapObjectBounds:function(moBounds){return this.mapObject.getBoundsZoomLevel(moBounds);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lon:moLonLat.lng();},getLatitudeFromMapObjectLonLat:function(moLonLat){var lat=this.sphericalMercator?this.forwardMercator(moLonLat.lng(),moLonLat.lat()).lat:moLonLat.lat();return lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var gLatLng;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);gLatLng=new GLatLng(lonlat.lat,lonlat.lon);}else{gLatLng=new GLatLng(lat,lon);}
-return gLatLng;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new GPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.Google"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.HTTPRequest"});OpenLayers.Control.ZoomBox=OpenLayers.Class(OpenLayers.Control,{type:OpenLayers.Control.TYPE_TOOL,out:false,draw:function(){this.handler=new OpenLayers.Handler.Box(this,{done:this.zoomBox},{keyMask:this.keyMask});},zoomBox:function(position){if(position instanceof OpenLayers.Bounds){if(!this.out){var minXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.left,position.bottom));var maxXY=this.map.getLonLatFromPixel(new OpenLayers.Pixel(position.right,position.top));var bounds=new OpenLayers.Bounds(minXY.lon,minXY.lat,maxXY.lon,maxXY.lat);}else{var pixWidth=Math.abs(position.right-position.left);var pixHeight=Math.abs(position.top-position.bottom);var zoomFactor=Math.min((this.map.size.h/pixHeight),(this.map.size.w/pixWidth));var extent=this.map.getExtent();var center=this.map.getLonLatFromPixel(position.getCenterPixel());var xmin=center.lon-(extent.getWidth()/2)*zoomFactor;var xmax=center.lon+(extent.getWidth()/2)*zoomFactor;var ymin=center.lat-(extent.getHeight()/2)*zoomFactor;var ymax=center.lat+(extent.getHeight()/2)*zoomFactor;var bounds=new OpenLayers.Bounds(xmin,ymin,xmax,ymax);}
+this.map.zoomToExtent(bounds);}else{if(!this.out){this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()+1);}else{this.map.setCenter(this.map.getLonLatFromPixel(position),this.map.getZoom()-1);}}},CLASS_NAME:"OpenLayers.Control.ZoomBox"});OpenLayers.Layer.Grid=OpenLayers.Class(OpenLayers.Layer.HTTPRequest,{tileSize:null,grid:null,singleTile:false,ratio:1.5,buffer:2,numLoadingTiles:0,initialize:function(name,url,params,options){OpenLayers.Layer.HTTPRequest.prototype.initialize.apply(this,arguments);this.events.addEventType("tileloaded");this.grid=[];},destroy:function(){this.clearGrid();this.grid=null;this.tileSize=null;OpenLayers.Layer.HTTPRequest.prototype.destroy.apply(this,arguments);},clearGrid:function(){if(this.grid){for(var iRow=0;iRow<this.grid.length;iRow++){var row=this.grid[iRow];for(var iCol=0;iCol<row.length;iCol++){var tile=row[iCol];this.removeTileMonitoringHooks(tile);tile.destroy();}}
 this.grid=[];}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.Grid(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.HTTPRequest.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
 obj.grid=[];return obj;},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.HTTPRequest.prototype.moveTo.apply(this,arguments);bounds=bounds||this.map.getExtent();if(bounds!=null){var forceReTile=!this.grid.length||zoomChanged;var tilesBounds=this.getTilesBounds();if(this.singleTile){if(forceReTile||(!dragging&&!tilesBounds.containsBounds(bounds))){this.initSingleTile(bounds);}}else{if(forceReTile||!tilesBounds.containsBounds(bounds,true)){this.initGriddedTiles(bounds);}else{this.moveGriddedTiles(bounds);}}}},setTileSize:function(size){if(this.singleTile){size=this.map.getSize().clone();size.h=parseInt(size.h*this.ratio);size.w=parseInt(size.w*this.ratio);}
@@ -902,7 +543,7 @@
 var tile=this.grid[0][0];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);tile.draw();this.grid[0][0]=tile;}else{tile.moveTo(tileBounds,px);}
 this.removeExcessTiles(1,1);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=bounds.top-(extent.bottom+tilelat);var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-tilerowremain*this.tileSize.h;var tileoffsetlat=extent.bottom+tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},initGriddedTiles:function(bounds){var viewSize=this.map.getSize();var minRows=Math.ceil(viewSize.h/this.tileSize.h)+
 Math.max(1,2*this.buffer);var minCols=Math.ceil(viewSize.w/this.tileSize.w)+
-Math.max(1,2*this.buffer);var extent=this.map.getMaxExtent();var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
+Math.max(1,2*this.buffer);var extent=this.maxExtent;var resolution=this.map.getResolution();var tileLayout=this.calculateGridLayout(bounds,extent,resolution);var tileoffsetx=Math.round(tileLayout.tileoffsetx);var tileoffsety=Math.round(tileLayout.tileoffsety);var tileoffsetlon=tileLayout.tileoffsetlon;var tileoffsetlat=tileLayout.tileoffsetlat;var tilelon=tileLayout.tilelon;var tilelat=tileLayout.tilelat;this.origin=new OpenLayers.Pixel(tileoffsetx,tileoffsety);var startX=tileoffsetx;var startLon=tileoffsetlon;var rowidx=0;var layerContainerDivLeft=parseInt(this.map.layerContainerDiv.style.left);var layerContainerDivTop=parseInt(this.map.layerContainerDiv.style.top);do{var row=this.grid[rowidx++];if(!row){row=[];this.grid.push(row);}
 tileoffsetlon=startLon;tileoffsetx=startX;var colidx=0;do{var tileBounds=new OpenLayers.Bounds(tileoffsetlon,tileoffsetlat,tileoffsetlon+tilelon,tileoffsetlat+tilelat);var x=tileoffsetx;x-=layerContainerDivLeft;var y=tileoffsety;y-=layerContainerDivTop;var px=new OpenLayers.Pixel(x,y);var tile=row[colidx++];if(!tile){tile=this.addTile(tileBounds,px);this.addTileMonitoringHooks(tile);row.push(tile);}else{tile.moveTo(tileBounds,px,false);}
 tileoffsetlon+=tilelon;tileoffsetx+=this.tileSize.w;}while((tileoffsetlon<=bounds.right+tilelon*this.buffer)||colidx<minCols)
 tileoffsetlat-=tilelat;tileoffsety+=this.tileSize.h;}while((tileoffsetlat>=bounds.bottom-tilelat*this.buffer)||rowidx<minRows)
@@ -912,471 +553,23 @@
 for(var i=0;i<tileQueue.length;i++){var tile=tileQueue[i];tile.draw();tile.queued=false;}},addTile:function(bounds,position){},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this.numLoadingTiles==0){this.events.triggerEvent("loadstart");}
 this.numLoadingTiles++;};tile.events.register("loadstart",this,tile.onLoadStart);tile.onLoadEnd=function(){this.numLoadingTiles--;this.events.triggerEvent("tileloaded");if(this.numLoadingTiles==0){this.events.triggerEvent("loadend");}};tile.events.register("loadend",this,tile.onLoadEnd);tile.events.register("unload",this,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:this});},moveGriddedTiles:function(bounds){var buffer=this.buffer||1;while(true){var tlLayer=this.grid[0][0].position;var tlViewPort=this.map.getViewPortPxFromLayerPx(tlLayer);if(tlViewPort.x>-this.tileSize.w*(buffer-1)){this.shiftColumn(true);}else if(tlViewPort.x<-this.tileSize.w*buffer){this.shiftColumn(false);}else if(tlViewPort.y>-this.tileSize.h*(buffer-1)){this.shiftRow(true);}else if(tlViewPort.y<-this.tileSize.h*buffer){this.shiftRow(false);}else{break;}};},shiftRow:function(prepend){var modelRowIndex=(prepend)?0:(this.grid.length-1);var grid=this.grid;var modelRow=grid[modelRowIndex];var resolution=this.map.getResolution();var deltaY=(prepend)?-this.tileSize.h:this.tileSize.h;var deltaLat=resolution*-deltaY;var row=(prepend)?grid.pop():grid.shift();for(var i=0;i<modelRow.length;i++){var modelTile=modelRow[i];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.bottom=bounds.bottom+deltaLat;bounds.top=bounds.top+deltaLat;position.y=position.y+deltaY;row[i].moveTo(bounds,position);}
 if(prepend){grid.unshift(row);}else{grid.push(row);}},shiftColumn:function(prepend){var deltaX=(prepend)?-this.tileSize.w:this.tileSize.w;var resolution=this.map.getResolution();var deltaLon=resolution*deltaX;for(var i=0;i<this.grid.length;i++){var row=this.grid[i];var modelTileIndex=(prepend)?0:(row.length-1);var modelTile=row[modelTileIndex];var bounds=modelTile.bounds.clone();var position=modelTile.position.clone();bounds.left=bounds.left+deltaLon;bounds.right=bounds.right+deltaLon;position.x=position.x+deltaX;var tile=prepend?this.grid[i].pop():this.grid[i].shift();tile.moveTo(bounds,position);if(prepend){row.unshift(tile);}else{row.push(tile);}}},removeExcessTiles:function(rows,columns){while(this.grid.length>rows){var row=this.grid.pop();for(var i=0,l=row.length;i<l;i++){var tile=row[i];this.removeTileMonitoringHooks(tile);tile.destroy();}}
-while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.map.getMaxExtent();var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
+while(this.grid[0].length>columns){for(var i=0,l=this.grid.length;i<l;i++){var row=this.grid[i];var tile=row.pop();this.removeTileMonitoringHooks(tile);tile.destroy();}}},onMapResize:function(){if(this.singleTile){this.clearGrid();this.setTileSize();}},getTileBounds:function(viewPortPx){var maxExtent=this.maxExtent;var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=maxExtent.left+(tileMapWidth*Math.floor((mapPoint.lon-
 maxExtent.left)/tileMapWidth));var tileBottom=maxExtent.bottom+(tileMapHeight*Math.floor((mapPoint.lat-
-maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Layer.MultiMap=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[9,1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();this.RESOLUTIONS.unshift(10);}},loadMapObject:function(){try{this.mapObject=new MultimapViewer(this.div);}catch(e){}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':"MM",'layerLib':"MultiMap"});},setMapObjectCenter:function(center,zoom){this.mapObject.goToPosition(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCurrentPosition();},getMapObjectZoom:function(){return this.mapObject.getZoomFactor();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){moPixel.x=moPixel.x-(this.map.getSize().w/2);moPixel.y=moPixel.y-(this.map.getSize().h/2);return this.mapObject.getMapPositionAt(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.geoPosToContainerPixels(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lon:moLonLat.lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.lon,moLonLat.lat).lat:moLonLat.lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var mmLatLon;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);mmLatLon=new MMLatLon(lonlat.lat,lonlat.lon);}else{mmLatLon=new MMLatLon(lat,lon);}
-return mmLatLon;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new MMPoint(x,y);},CLASS_NAME:"OpenLayers.Layer.MultiMap"});OpenLayers.Layer.Text=OpenLayers.Class(OpenLayers.Layer.Markers,{location:null,features:null,formatOptions:null,selectedFeature:null,initialize:function(name,options){OpenLayers.Layer.Markers.prototype.initialize.apply(this,arguments);this.features=new Array();},destroy:function(){OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);this.clearFeatures();this.features=null;},loadText:function(){if(!this.loaded){if(this.location!=null){var onFail=function(e){this.events.triggerEvent("loadend");};this.events.triggerEvent("loadstart");OpenLayers.loadURL(this.location,null,this,this.parseData,onFail);this.loaded=true;}}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadText();}},parseData:function(ajaxRequest){var text=ajaxRequest.responseText;var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var parser=new OpenLayers.Format.Text(options);features=parser.read(text);for(var i=0;i<features.length;i++){var data={};var feature=features[i];var location;var iconSize,iconOffset;location=new OpenLayers.LonLat(feature.geometry.x,feature.geometry.y);if(feature.style.graphicWidth&&feature.style.graphicHeight){iconSize=new OpenLayers.Size(feature.style.graphicWidth,feature.style.graphicHeight);}
-if(feature.style.graphicXOffset&&feature.style.graphicYOffset){iconOffset=new OpenLayers.Pixel(feature.style.graphicXOffset,feature.style.graphicYOffset);}
-if(feature.style.externalGraphic!=null){data.icon=new OpenLayers.Icon(feature.style.externalGraphic,iconSize,iconOffset);}else{data.icon=OpenLayers.Marker.defaultIcon();if(iconSize!=null){data.icon.setSize(iconSize);}}
-if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){data['popupContentHTML']='<h2>'+feature.attributes.title+'</h2>'+'<p>'+feature.attributes.description+'</p>';}
-data['overflow']=feature.attributes.overflow||"auto";var markerFeature=new OpenLayers.Feature(this,location,data);this.features.push(markerFeature);var marker=markerFeature.createMarker();if((feature.attributes.title!=null)&&(feature.attributes.description!=null)){marker.events.register('click',markerFeature,this.markerClick);}
-this.addMarker(marker);}
-if(!sameMarkerClicked){this.layer.map.addPopup(this.createPopup());}
-OpenLayers.Event.stop(evt);},clearFeatures:function(){if(this.features!=null){while(this.features.length>0){var feature=this.features[0];OpenLayers.Util.removeItem(this.features,feature);feature.destroy();}}},CLASS_NAME:"OpenLayers.Layer.Text"});OpenLayers.Layer.VirtualEarth=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:1,MAX_ZOOM_LEVEL:17,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){var veDiv=OpenLayers.Util.createDiv(this.name);var sz=this.map.getSize();veDiv.style.width=sz.w;veDiv.style.height=sz.h;this.div.appendChild(veDiv);try{this.mapObject=new VEMap(this.name);}catch(e){}
-if(this.mapObject!=null){try{this.mapObject.LoadMap(null,null,this.type,true);this.mapObject.AttachEvent("onmousedown",function(){return true;});}catch(e){}
-this.mapObject.HideDashboard();}
-if(!this.mapObject||!this.mapObject.vemapcontrol||!this.mapObject.vemapcontrol.PanMap||(typeof this.mapObject.vemapcontrol.PanMap!="function")){this.dragPanMapObject=null;}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'VE','layerLib':'VirtualEarth'});},setMapObjectCenter:function(center,zoom){this.mapObject.SetCenterAndZoom(center,zoom);},getMapObjectCenter:function(){return this.mapObject.GetCenter();},dragPanMapObject:function(dX,dY){this.mapObject.vemapcontrol.PanMap(dX,-dY);},getMapObjectZoom:function(){return this.mapObject.GetZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.PixelToLatLong(moPixel.x,moPixel.y);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.LatLongToPixel(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lon:moLonLat.Longitude;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Longitude,moLonLat.Latitude).lat:moLonLat.Latitude;},getMapObjectLonLatFromLonLat:function(lon,lat){var veLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);veLatLong=new VELatLong(lonlat.lat,lonlat.lon);}else{veLatLong=new VELatLong(lat,lon);}
-return veLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new Msn.VE.Pixel(x,y);},CLASS_NAME:"OpenLayers.Layer.VirtualEarth"});OpenLayers.Layer.Yahoo=OpenLayers.Class(OpenLayers.Layer.EventPane,OpenLayers.Layer.FixedZoomLevels,{MIN_ZOOM_LEVEL:0,MAX_ZOOM_LEVEL:15,RESOLUTIONS:[1.40625,0.703125,0.3515625,0.17578125,0.087890625,0.0439453125,0.02197265625,0.010986328125,0.0054931640625,0.00274658203125,0.001373291015625,0.0006866455078125,0.00034332275390625,0.000171661376953125,0.0000858306884765625,0.00004291534423828125],type:null,sphericalMercator:false,initialize:function(name,options){OpenLayers.Layer.EventPane.prototype.initialize.apply(this,arguments);OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,arguments);if(this.sphericalMercator){OpenLayers.Util.extend(this,OpenLayers.Layer.SphericalMercator);this.initMercatorParameters();}},loadMapObject:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject=new YMap(this.div,this.type,size);this.mapObject.disableKeyControls();this.mapObject.disableDragMap();if(!this.mapObject.moveByXY||(typeof this.mapObject.moveByXY!="function")){this.dragPanMapObject=null;}}catch(e){}},onMapResize:function(){try{var size=this.getMapObjectSizeFromOLSize(this.map.getSize());this.mapObject.resizeTo(size);}catch(e){}},setMap:function(map){OpenLayers.Layer.EventPane.prototype.setMap.apply(this,arguments);this.map.events.register("moveend",this,this.fixYahooEventPane);},fixYahooEventPane:function(){var yahooEventPane=OpenLayers.Util.getElement("ygddfdiv");if(yahooEventPane!=null){if(yahooEventPane.parentNode!=null){yahooEventPane.parentNode.removeChild(yahooEventPane);}
-this.map.events.unregister("moveend",this,this.fixYahooEventPane);}},getWarningHTML:function(){return OpenLayers.i18n("getLayerWarning",{'layerType':'Yahoo','layerLib':'Yahoo'});},getOLZoomFromMapObjectZoom:function(moZoom){var zoom=null;if(moZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this,[moZoom]);zoom=18-zoom;}
-return zoom;},getMapObjectZoomFromOLZoom:function(olZoom){var zoom=null;if(olZoom!=null){zoom=OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this,[olZoom]);zoom=18-zoom;}
-return zoom;},setMapObjectCenter:function(center,zoom){this.mapObject.drawZoomAndCenter(center,zoom);},getMapObjectCenter:function(){return this.mapObject.getCenterLatLon();},dragPanMapObject:function(dX,dY){this.mapObject.moveByXY({'x':-dX,'y':dY});},getMapObjectZoom:function(){return this.mapObject.getZoomLevel();},getMapObjectLonLatFromMapObjectPixel:function(moPixel){return this.mapObject.convertXYLatLon(moPixel);},getMapObjectPixelFromMapObjectLonLat:function(moLonLat){return this.mapObject.convertLatLonXY(moLonLat);},getLongitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lon:moLonLat.Lon;},getLatitudeFromMapObjectLonLat:function(moLonLat){return this.sphericalMercator?this.forwardMercator(moLonLat.Lon,moLonLat.Lat).lat:moLonLat.Lat;},getMapObjectLonLatFromLonLat:function(lon,lat){var yLatLong;if(this.sphericalMercator){var lonlat=this.inverseMercator(lon,lat);yLatLong=new YGeoPoint(lonlat.lat,lonlat.lon);}else{yLatLong=new YGeoPoint(lat,lon);}
-return yLatLong;},getXFromMapObjectPixel:function(moPixel){return moPixel.x;},getYFromMapObjectPixel:function(moPixel){return moPixel.y;},getMapObjectPixelFromXY:function(x,y){return new YCoordPoint(x,y);},getMapObjectSizeFromOLSize:function(olSize){return new YSize(olSize.w,olSize.h);},CLASS_NAME:"OpenLayers.Layer.Yahoo"});OpenLayers.Style=OpenLayers.Class({name:null,title:null,description:null,layerName:null,isDefault:false,rules:null,context:null,defaultStyle:null,propertyStyles:null,initialize:function(style,options){this.rules=[];this.setDefaultStyle(style||OpenLayers.Feature.Vector.style["default"]);OpenLayers.Util.extend(this,options);},destroy:function(){for(var i=0;i<this.rules.length;i++){this.rules[i].destroy();this.rules[i]=null;}
-this.rules=null;this.defaultStyle=null;},createSymbolizer:function(feature){var style=this.createLiterals(OpenLayers.Util.extend({},this.defaultStyle),feature);var rules=this.rules;var rule,context;var elseRules=[];var appliedRules=false;for(var i=0;i<rules.length;i++){rule=rules[i];var applies=rule.evaluate(feature);if(applies){if(rule instanceof OpenLayers.Rule&&rule.elseFilter){elseRules.push(rule);}else{appliedRules=true;this.applySymbolizer(rule,style,feature);}}}
-if(appliedRules==false&&elseRules.length>0){appliedRules=true;for(var i=0;i<elseRules.length;i++){this.applySymbolizer(elseRules[i],style,feature);}}
-if(rules.length>0&&appliedRules==false){style.display="none";}else{style.display="";}
-return style;},applySymbolizer:function(rule,style,feature){var symbolizerPrefix=feature.geometry?this.getSymbolizerPrefix(feature.geometry):OpenLayers.Style.SYMBOLIZER_PREFIXES[0];var symbolizer=rule.symbolizer[symbolizerPrefix]||rule.symbolizer;return this.createLiterals(OpenLayers.Util.extend(style,symbolizer),feature);},createLiterals:function(style,feature){var context=this.context||feature.attributes||feature.data;for(var i in this.propertyStyles){style[i]=OpenLayers.Style.createLiteral(style[i],context,feature);}
-return style;},findPropertyStyles:function(){var propertyStyles={};var style=this.defaultStyle;this.addPropertyStyles(propertyStyles,style);var rules=this.rules;var symbolizer,value;for(var i=0;i<rules.length;i++){var symbolizer=rules[i].symbolizer;for(var key in symbolizer){value=symbolizer[key];if(typeof value=="object"){this.addPropertyStyles(propertyStyles,value);}else{this.addPropertyStyles(propertyStyles,symbolizer);break;}}}
-return propertyStyles;},addPropertyStyles:function(propertyStyles,symbolizer){var property;for(var key in symbolizer){property=symbolizer[key];if(typeof property=="string"&&property.match(/\$\{\w+\}/)){propertyStyles[key]=true;}}
-return propertyStyles;},addRules:function(rules){this.rules=this.rules.concat(rules);this.propertyStyles=this.findPropertyStyles();},setDefaultStyle:function(style){this.defaultStyle=style;this.propertyStyles=this.findPropertyStyles();},getSymbolizerPrefix:function(geometry){var prefixes=OpenLayers.Style.SYMBOLIZER_PREFIXES;for(var i=0;i<prefixes.length;i++){if(geometry.CLASS_NAME.indexOf(prefixes[i])!=-1){return prefixes[i];}}},CLASS_NAME:"OpenLayers.Style"});OpenLayers.Style.createLiteral=function(value,context,feature){if(typeof value=="string"&&value.indexOf("${")!=-1){value=OpenLayers.String.format(value,context,[feature]);value=(isNaN(value)||!value)?value:parseFloat(value);}
-return value;};OpenLayers.Style.SYMBOLIZER_PREFIXES=['Point','Line','Polygon'];OpenLayers.Control.ModifyFeature=OpenLayers.Class(OpenLayers.Control,{geometryTypes:null,clickout:true,toggle:true,layer:null,feature:null,vertices:null,virtualVertices:null,selectControl:null,dragControl:null,handlers:null,deleteCodes:null,virtualStyle:null,mode:null,radiusHandle:null,dragHandle:null,onModificationStart:function(){},onModification:function(){},onModificationEnd:function(){},initialize:function(layer,options){this.layer=layer;this.vertices=[];this.virtualVertices=[];this.virtualStyle=OpenLayers.Util.extend({},this.layer.style||this.layer.styleMap.createSymbolizer());this.virtualStyle.fillOpacity=0.3;this.virtualStyle.strokeOpacity=0.3;this.deleteCodes=[46,100];this.mode=OpenLayers.Control.ModifyFeature.RESHAPE;OpenLayers.Control.prototype.initialize.apply(this,[options]);if(!(this.deleteCodes instanceof Array)){this.deleteCodes=[this.deleteCodes];}
-var control=this;var selectOptions={geometryTypes:this.geometryTypes,clickout:this.clickout,toggle:this.toggle};this.selectControl=new OpenLayers.Control.SelectFeature(layer,selectOptions);this.layer.events.on({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});var dragOptions={geometryTypes:["OpenLayers.Geometry.Point"],snappingOptions:this.snappingOptions,onStart:function(feature,pixel){control.dragStart.apply(control,[feature,pixel]);},onDrag:function(feature){control.dragVertex.apply(control,[feature]);},onComplete:function(feature){control.dragComplete.apply(control,[feature]);}};this.dragControl=new OpenLayers.Control.DragFeature(layer,dragOptions);var keyboardOptions={keypress:this.handleKeypress};this.handlers={keyboard:new OpenLayers.Handler.Keyboard(this,keyboardOptions)};},destroy:function(){this.layer.events.un({"featureselected":this.selectFeature,"featureunselected":this.unselectFeature,scope:this});this.layer=null;this.selectControl.destroy();this.dragControl.destroy();OpenLayers.Control.prototype.destroy.apply(this,[]);},activate:function(){return(this.selectControl.activate()&&this.handlers.keyboard.activate()&&OpenLayers.Control.prototype.activate.apply(this,arguments));},deactivate:function(){var deactivated=false;if(OpenLayers.Control.prototype.deactivate.apply(this,arguments)){this.layer.removeFeatures(this.vertices);this.layer.removeFeatures(this.virtualVertices);this.vertices=[];this.dragControl.deactivate();if(this.feature&&this.feature.geometry){this.selectControl.unselect.apply(this.selectControl,[this.feature]);}
-this.selectControl.deactivate();this.handlers.keyboard.deactivate();deactivated=true;}
-return deactivated;},selectFeature:function(object){this.feature=object.feature;this.resetVertices();this.dragControl.activate();this.onModificationStart(this.feature);this.layer.events.triggerEvent("beforefeaturemodified",{feature:this.feature});},unselectFeature:function(object){this.layer.removeFeatures(this.vertices);this.vertices=[];this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);delete this.dragHandle;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);delete this.radiusHandle;}
-this.feature=null;this.dragControl.deactivate();this.onModificationEnd(object.feature);this.layer.events.triggerEvent("afterfeaturemodified",{feature:object.feature});},dragStart:function(feature,pixel){if(feature!=this.feature&&!feature.geometry.parent&&feature!=this.dragHandle&&feature!=this.radiusHandle){if(this.feature){this.selectControl.clickFeature.apply(this.selectControl,[this.feature]);}
-if(this.geometryTypes==null||OpenLayers.Util.indexOf(this.geometryTypes,feature.geometry.CLASS_NAME)!=-1){this.selectControl.clickFeature.apply(this.selectControl,[feature]);this.dragControl.overFeature.apply(this.dragControl,[feature]);this.dragControl.lastPixel=pixel;this.dragControl.handlers.drag.started=true;this.dragControl.handlers.drag.start=pixel;this.dragControl.handlers.drag.last=pixel;}}},dragVertex:function(vertex){if(this.feature.geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){if(this.feature!=vertex){this.feature=vertex;}}else{if(vertex._index){vertex.geometry.parent.addComponent(vertex.geometry,vertex._index);delete vertex._index;OpenLayers.Util.removeItem(this.virtualVertices,vertex);this.vertices.push(vertex);}else if(vertex==this.dragHandle){this.layer.removeFeatures(this.vertices);this.vertices=[];if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}}
-if(this.virtualVertices.length>0){this.layer.destroyFeatures(this.virtualVertices);this.virtualVertices=[];}
-this.layer.drawFeature(this.feature,this.selectControl.renderIntent);}
-this.layer.drawFeature(vertex);},dragComplete:function(vertex){this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});},resetVertices:function(){if(this.dragControl.feature){this.dragControl.outFeature(this.dragControl.feature);}
-if(this.vertices.length>0){this.layer.removeFeatures(this.vertices);this.vertices=[];}
-if(this.virtualVertices.length>0){this.layer.removeFeatures(this.virtualVertices);this.virtualVertices=[];}
-if(this.dragHandle){this.layer.destroyFeatures([this.dragHandle]);this.dragHandle=null;}
-if(this.radiusHandle){this.layer.destroyFeatures([this.radiusHandle]);this.radiusHandle=null;}
-if(this.feature&&this.feature.geometry.CLASS_NAME!="OpenLayers.Geometry.Point"){if((this.mode&OpenLayers.Control.ModifyFeature.DRAG)){this.collectDragHandle();}
-if((this.mode&(OpenLayers.Control.ModifyFeature.ROTATE|OpenLayers.Control.ModifyFeature.RESIZE))){this.collectRadiusHandle();}
-if((this.mode&OpenLayers.Control.ModifyFeature.RESHAPE)){this.collectVertices();}}},handleKeypress:function(code){if(this.feature&&OpenLayers.Util.indexOf(this.deleteCodes,code)!=-1){var vertex=this.dragControl.feature;if(vertex&&OpenLayers.Util.indexOf(this.vertices,vertex)!=-1&&!this.dragControl.handlers.drag.dragging&&vertex.geometry.parent){vertex.geometry.parent.removeComponent(vertex.geometry);this.layer.drawFeature(this.feature,this.selectControl.renderIntent);this.resetVertices();this.onModification(this.feature);this.layer.events.triggerEvent("featuremodified",{feature:this.feature});}}},collectVertices:function(){this.vertices=[];this.virtualVertices=[];var control=this;function collectComponentVertices(geometry){var i,vertex,component;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(geometry);control.vertices.push(vertex);}else{var numVert=geometry.components.length;if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){numVert-=1;}
-for(i=0;i<numVert;++i){component=geometry.components[i];if(component.CLASS_NAME=="OpenLayers.Geometry.Point"){vertex=new OpenLayers.Feature.Vector(component);control.vertices.push(vertex);}else{collectComponentVertices(component);}}
-if(geometry.CLASS_NAME!="OpenLayers.Geometry.MultiPoint"){for(i=0;i<geometry.components.length-1;++i){var prevVertex=geometry.components[i];var nextVertex=geometry.components[i+1];if(prevVertex.CLASS_NAME=="OpenLayers.Geometry.Point"&&nextVertex.CLASS_NAME=="OpenLayers.Geometry.Point"){var x=(prevVertex.x+nextVertex.x)/2;var y=(prevVertex.y+nextVertex.y)/2;var point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(x,y),null,control.virtualStyle);point.geometry.parent=geometry;point._index=i+1;control.virtualVertices.push(point);}}}}}
-collectComponentVertices.call(this,this.feature.geometry);this.layer.addFeatures(this.vertices,{silent:true});this.layer.addFeatures(this.virtualVertices,{silent:true});},collectDragHandle:function(){var geometry=this.feature.geometry;var center=geometry.getBounds().getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var origin=new OpenLayers.Feature.Vector(originGeometry);originGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);geometry.move(x,y);};this.dragHandle=origin;this.layer.addFeatures([this.dragHandle],{silent:true});},collectRadiusHandle:function(){var geometry=this.feature.geometry;var bounds=geometry.getBounds();var center=bounds.getCenterLonLat();var originGeometry=new OpenLayers.Geometry.Point(center.lon,center.lat);var radiusGeometry=new OpenLayers.Geometry.Point(bounds.right,bounds.bottom);var radius=new OpenLayers.Feature.Vector(radiusGeometry);var resize=(this.mode&OpenLayers.Control.ModifyFeature.RESIZE);var rotate=(this.mode&OpenLayers.Control.ModifyFeature.ROTATE);radiusGeometry.move=function(x,y){OpenLayers.Geometry.Point.prototype.move.call(this,x,y);var dx1=this.x-originGeometry.x;var dy1=this.y-originGeometry.y;var dx0=dx1-x;var dy0=dy1-y;if(rotate){var a0=Math.atan2(dy0,dx0);var a1=Math.atan2(dy1,dx1);var angle=a1-a0;angle*=180/Math.PI;geometry.rotate(angle,originGeometry);}
-if(resize){var l0=Math.sqrt((dx0*dx0)+(dy0*dy0));var l1=Math.sqrt((dx1*dx1)+(dy1*dy1));geometry.resize(l1/l0,originGeometry);}};this.radiusHandle=radius;this.layer.addFeatures([this.radiusHandle],{silent:true});},setMap:function(map){this.selectControl.setMap(map);this.dragControl.setMap(map);OpenLayers.Control.prototype.setMap.apply(this,arguments);},CLASS_NAME:"OpenLayers.Control.ModifyFeature"});OpenLayers.Control.ModifyFeature.RESHAPE=1;OpenLayers.Control.ModifyFeature.RESIZE=2;OpenLayers.Control.ModifyFeature.ROTATE=4;OpenLayers.Control.ModifyFeature.DRAG=8;OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
+maxExtent.bottom)/tileMapHeight));return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.Grid"});OpenLayers.Control.Navigation=OpenLayers.Class(OpenLayers.Control,{dragPan:null,zoomBox:null,zoomWheelEnabled:true,initialize:function(options){this.handlers={};OpenLayers.Control.prototype.initialize.apply(this,arguments);},destroy:function(){this.deactivate();if(this.dragPan){this.dragPan.destroy();}
 this.dragPan=null;if(this.zoomBox){this.zoomBox.destroy();}
 this.zoomBox=null;OpenLayers.Control.prototype.destroy.apply(this,arguments);},activate:function(){this.dragPan.activate();if(this.zoomWheelEnabled){this.handlers.wheel.activate();}
 this.handlers.click.activate();this.zoomBox.activate();return OpenLayers.Control.prototype.activate.apply(this,arguments);},deactivate:function(){this.zoomBox.deactivate();this.dragPan.deactivate();this.handlers.click.deactivate();this.handlers.wheel.deactivate();return OpenLayers.Control.prototype.deactivate.apply(this,arguments);},draw:function(){this.handlers.click=new OpenLayers.Handler.Click(this,{'dblclick':this.defaultDblClick},{'double':true,'stopDouble':true});this.dragPan=new OpenLayers.Control.DragPan({map:this.map});this.zoomBox=new OpenLayers.Control.ZoomBox({map:this.map,keyMask:OpenLayers.Handler.MOD_SHIFT});this.dragPan.draw();this.zoomBox.draw();this.handlers.wheel=new OpenLayers.Handler.MouseWheel(this,{"up":this.wheelUp,"down":this.wheelDown});this.activate();},defaultDblClick:function(evt){var newCenter=this.map.getLonLatFromViewPortPx(evt.xy);this.map.setCenter(newCenter,this.map.zoom+1);},wheelChange:function(evt,deltaZ){var newZoom=this.map.getZoom()+deltaZ;if(!this.map.isValidZoomLevel(newZoom)){return;}
-var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Filter=OpenLayers.Class({initialize:function(options){OpenLayers.Util.extend(this,options);},destroy:function(){},evaluate:function(context){return true;},CLASS_NAME:"OpenLayers.Filter"});OpenLayers.Geometry=OpenLayers.Class({id:null,parent:null,bounds:null,initialize:function(){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");},destroy:function(){this.id=null;this.bounds=null;},clone:function(){return new OpenLayers.Geometry();},setBounds:function(bounds){if(bounds){this.bounds=bounds.clone();}},clearBounds:function(){this.bounds=null;if(this.parent){this.parent.clearBounds();}},extendBounds:function(newBounds){var bounds=this.getBounds();if(!bounds){this.setBounds(newBounds);}else{this.bounds.extend(newBounds);}},getBounds:function(){if(this.bounds==null){this.calculateBounds();}
-return this.bounds;},calculateBounds:function(){},atPoint:function(lonlat,toleranceLon,toleranceLat){var atPoint=false;var bounds=this.getBounds();if((bounds!=null)&&(lonlat!=null)){var dX=(toleranceLon!=null)?toleranceLon:0;var dY=(toleranceLat!=null)?toleranceLat:0;var toleranceBounds=new OpenLayers.Bounds(this.bounds.left-dX,this.bounds.bottom-dY,this.bounds.right+dX,this.bounds.top+dY);atPoint=toleranceBounds.containsLonLat(lonlat);}
-return atPoint;},getLength:function(){return 0.0;},getArea:function(){return 0.0;},toString:function(){return OpenLayers.Format.WKT.prototype.write(new OpenLayers.Feature.Vector(this));},CLASS_NAME:"OpenLayers.Geometry"});OpenLayers.Geometry.segmentsIntersect=function(seg1,seg2,point){var intersection=false;var x11_21=seg1.x1-seg2.x1;var y11_21=seg1.y1-seg2.y1;var x12_11=seg1.x2-seg1.x1;var y12_11=seg1.y2-seg1.y1;var y22_21=seg2.y2-seg2.y1;var x22_21=seg2.x2-seg2.x1;var d=(y22_21*x12_11)-(x22_21*y12_11);var n1=(x22_21*y11_21)-(y22_21*x11_21);var n2=(x12_11*y11_21)-(y12_11*x11_21);if(d==0){if(n1==0&&n2==0){intersection=true;}}else{var along1=n1/d;var along2=n2/d;if(along1>=0&&along1<=1&&along2>=0&&along2<=1){if(!point){intersection=true;}else{var x=seg1.x1+(along1*x12_11);var y=seg1.y1+(along1*y12_11);intersection=new OpenLayers.Geometry.Point(x,y);}}}
-return intersection;};OpenLayers.Layer.KaMap=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,units:null,resolution:OpenLayers.DOTS_PER_INCH,DEFAULT_PARAMS:{i:'jpeg',map:''},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},getURL:function(bounds){bounds=this.adjustBounds(bounds);var mapRes=this.map.getResolution();var scale=Math.round((this.map.getScale()*10000))/10000;var pX=Math.round(bounds.left/mapRes);var pY=-Math.round(bounds.top/mapRes);return this.getFullRequestString({t:pY,l:pX,s:scale});},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=tilecol*tilelon;var offsetlat=bounds.top;var tilerow=Math.ceil(offsetlat/tilelat)+this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=-(tilerowremain+1)*this.tileSize.h;var tileoffsetlat=tilerow*tilelat;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.KaMap(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);if(this.tileSize!=null){obj.tileSize=this.tileSize.clone();}
-obj.grid=[];return obj;},getTileBounds:function(viewPortPx){var resolution=this.getResolution();var tileMapWidth=resolution*this.tileSize.w;var tileMapHeight=resolution*this.tileSize.h;var mapPoint=this.getLonLatFromViewPortPx(viewPortPx);var tileLeft=tileMapWidth*Math.floor(mapPoint.lon/tileMapWidth);var tileBottom=tileMapHeight*Math.floor(mapPoint.lat/tileMapHeight);return new OpenLayers.Bounds(tileLeft,tileBottom,tileLeft+tileMapWidth,tileBottom+tileMapHeight);},CLASS_NAME:"OpenLayers.Layer.KaMap"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
+var size=this.map.getSize();var deltaX=size.w/2-evt.xy.x;var deltaY=evt.xy.y-size.h/2;var newRes=this.map.baseLayer.getResolutionForZoom(newZoom);var zoomPoint=this.map.getLonLatFromPixel(evt.xy);var newCenter=new OpenLayers.LonLat(zoomPoint.lon+deltaX*newRes,zoomPoint.lat+deltaY*newRes);this.map.setCenter(newCenter,newZoom);},wheelUp:function(evt){this.wheelChange(evt,1);},wheelDown:function(evt){this.wheelChange(evt,-1);},disableZoomWheel:function(){this.zoomWheelEnabled=false;this.handlers.wheel.deactivate();},enableZoomWheel:function(){this.zoomWheelEnabled=true;if(this.active){this.handlers.wheel.activate();}},CLASS_NAME:"OpenLayers.Control.Navigation"});OpenLayers.Layer.MapGuide=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,singleTile:false,TILE_PARAMS:{operation:'GETTILEIMAGE',version:'1.2.0'},SINGLE_TILE_PARAMS:{operation:'GETMAPIMAGE',format:'PNG',locale:'en',clip:'1',version:'1.0.0'},defaultSize:new OpenLayers.Size(300,300),initialize:function(name,url,params,options){OpenLayers.Layer.Grid.prototype.initialize.apply(this,arguments);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.transparent!="true")&&(this.transparent!=true));}
 if(this.singleTile){OpenLayers.Util.applyDefaults(this.params,this.SINGLE_TILE_PARAMS);}else{OpenLayers.Util.applyDefaults(this.params,this.TILE_PARAMS);this.setTileSize(this.defaultSize);}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapGuide(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';getVisParams=OpenLayers.Util.extend(getVisParams,params);new OpenLayers.Ajax.Request(this.url,{parameters:getVisParams,method:'get',asynchronous:false});}
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){var url;var center=bounds.getCenterLonLat();var mapSize=this.map.getCurrentSize();if(this.singleTile){var params={};params.setdisplaydpi=OpenLayers.DOTS_PER_INCH;params.setdisplayheight=mapSize.h*this.ratio;params.setdisplaywidth=mapSize.w*this.ratio;params.setviewcenterx=center.lon;params.setviewcentery=center.lat;params.setviewscale=this.map.getScale();if(!this.isBaseLayer){this.params.operation="GETDYNAMICMAPOVERLAYIMAGE";var getVisParams={};getVisParams=OpenLayers.Util.extend(getVisParams,params);getVisParams.operation="GETVISIBLEMAPEXTENT";getVisParams.version="1.0.0";getVisParams.session=this.params.session;getVisParams.mapName=this.params.mapName;getVisParams.format='text/xml';url=this.getFullRequestString(getVisParams);OpenLayers.Request.GET({url:url,async:false});}
 url=this.getFullRequestString(params);}else{var currentRes=this.map.getResolution();var colidx=Math.floor((bounds.left-this.maxExtent.left)/currentRes);colidx=Math.round(colidx/this.tileSize.w);var rowidx=Math.floor((this.maxExtent.top-bounds.top)/currentRes);rowidx=Math.round(rowidx/this.tileSize.h);url=this.getFullRequestString({tilecol:colidx,tilerow:rowidx,scaleindex:this.resolutions.length-this.map.zoom-1});}
 return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;if(typeof url=="object"){url=url[Math.floor(Math.random()*url.length)];}
 var requestString=url;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getArgs(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 var paramsString=OpenLayers.Util.getParameterString(allParams);paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);if(arguments.length>0){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}
-if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
+return requestString;},calculateGridLayout:function(bounds,extent,resolution){var tilelon=resolution*this.tileSize.w;var tilelat=resolution*this.tileSize.h;var offsetlon=bounds.left-extent.left;var tilecol=Math.floor(offsetlon/tilelon)-this.buffer;var tilecolremain=offsetlon/tilelon-tilecol;var tileoffsetx=-tilecolremain*this.tileSize.w;var tileoffsetlon=extent.left+tilecol*tilelon;var offsetlat=extent.top-bounds.top+tilelat;var tilerow=Math.floor(offsetlat/tilelat)-this.buffer;var tilerowremain=tilerow-offsetlat/tilelat;var tileoffsety=tilerowremain*this.tileSize.h;var tileoffsetlat=extent.top-tilelat*tilerow;return{tilelon:tilelon,tilelat:tilelat,tileoffsetlon:tileoffsetlon,tileoffsetlat:tileoffsetlat,tileoffsetx:tileoffsetx,tileoffsety:tileoffsety};},CLASS_NAME:"OpenLayers.Layer.MapGuide"});OpenLayers.Layer.MapServer=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{mode:"map",map_imagetype:"png"},initialize:function(name,url,params,options){var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);if(options==null||options.isBaseLayer==null){this.isBaseLayer=((this.params.transparent!="true")&&(this.params.transparent!=true));}},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer(this.name,this.url,this.params,this.options);}
 obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getURL:function(bounds){bounds=this.adjustBounds(bounds);var extent=[bounds.left,bounds.bottom,bounds.right,bounds.top];var imageSize=this.getImageSize();var url=this.getFullRequestString({mapext:extent,imgext:extent,map_size:[imageSize.w,imageSize.h],imgx:imageSize.w/2,imgy:imageSize.h/2,imgxy:[imageSize.w,imageSize.h]});return url;},getFullRequestString:function(newParams,altUrl){var url=(altUrl==null)?this.url:altUrl;var allParams=OpenLayers.Util.extend({},this.params);allParams=OpenLayers.Util.extend(allParams,newParams);var paramsString=OpenLayers.Util.getParameterString(allParams);if(url instanceof Array){url=this.selectUrl(paramsString,url);}
 var urlParams=OpenLayers.Util.upperCaseObject(OpenLayers.Util.getParameters(url));for(var key in allParams){if(key.toUpperCase()in urlParams){delete allParams[key];}}
 paramsString=OpenLayers.Util.getParameterString(allParams);var requestString=url;paramsString=paramsString.replace(/,/g,"+");if(paramsString!=""){var lastServerChar=url.charAt(url.length-1);if((lastServerChar=="&")||(lastServerChar=="?")){requestString+=paramsString;}else{if(url.indexOf('?')==-1){requestString+='?'+paramsString;}else{requestString+='&'+paramsString;}}}
-return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.TMS=OpenLayers.Class(OpenLayers.Layer.Grid,{serviceVersion:"1.0.0",isBaseLayer:true,tileOrigin:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,url,{},options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TMS(this.name,this.url,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var res=this.map.getResolution();var x=Math.round((bounds.left-this.tileOrigin.lon)/(res*this.tileSize.w));var y=Math.round((bounds.bottom-this.tileOrigin.lat)/(res*this.tileSize.h));var z=this.map.getZoom();var path=this.serviceVersion+"/"+this.layername+"/"+z+"/"+x+"/"+y+"."+this.type;var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-return url+path;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TMS"});OpenLayers.Layer.TileCache=OpenLayers.Class(OpenLayers.Layer.Grid,{isBaseLayer:true,tileOrigin:null,format:'image/png',initialize:function(name,url,layername,options){this.layername=layername;OpenLayers.Layer.Grid.prototype.initialize.apply(this,[name,url,{},options]);this.extension=this.format.split('/')[1].toLowerCase();this.extension=(this.extension=='jpg')?'jpeg':this.extension;},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.TileCache(this.name,this.url,this.layername,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){var res=this.map.getResolution();var bbox=this.maxExtent;var size=this.tileSize;var tileX=Math.round((bounds.left-bbox.left)/(res*size.w));var tileY=Math.round((bounds.bottom-bbox.bottom)/(res*size.h));var tileZ=this.map.zoom;function zeroPad(number,length){number=String(number);var zeros=[];for(var i=0;i<length;++i){zeros.push('0');}
-return zeros.join('').substring(0,length-number.length)+number;}
-var components=[this.layername,zeroPad(tileZ,2),zeroPad(parseInt(tileX/1000000),3),zeroPad((parseInt(tileX/1000)%1000),3),zeroPad((parseInt(tileX)%1000),3),zeroPad(parseInt(tileY/1000000),3),zeroPad((parseInt(tileY/1000)%1000),3),zeroPad((parseInt(tileY)%1000),3)+'.'+this.extension];var path=components.join('/');var url=this.url;if(url instanceof Array){url=this.selectUrl(path,url);}
-url=(url.charAt(url.length-1)=='/')?url:url+'/';return url+path;},addTile:function(bounds,position){var url=this.getURL(bounds);return new OpenLayers.Tile.Image(this,position,bounds,url,this.tileSize);},setMap:function(map){OpenLayers.Layer.Grid.prototype.setMap.apply(this,arguments);if(!this.tileOrigin){this.tileOrigin=new OpenLayers.LonLat(this.map.maxExtent.left,this.map.maxExtent.bottom);}},CLASS_NAME:"OpenLayers.Layer.TileCache"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
+return requestString;},CLASS_NAME:"OpenLayers.Layer.MapServer"});OpenLayers.Layer.WMS=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{service:"WMS",version:"1.1.1",request:"GetMap",styles:"",exceptions:"application/vnd.ogc.se_inimage",format:"image/jpeg"},reproject:false,isBaseLayer:true,encodeBBOX:false,initialize:function(name,url,params,options){var newArguments=[];params=OpenLayers.Util.upperCaseObject(params);newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));if(this.params.TRANSPARENT&&this.params.TRANSPARENT.toString().toLowerCase()=="true"){if((options==null)||(!options.isBaseLayer)){this.isBaseLayer=false;}
 if(this.params.FORMAT=="image/jpeg"){this.params.FORMAT=OpenLayers.Util.alphaHack()?"image/gif":"image/png";}}},destroy:function(){OpenLayers.Layer.Grid.prototype.destroy.apply(this,arguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});OpenLayers.Layer.WorldWind=OpenLayers.Class(OpenLayers.Layer.Grid,{DEFAULT_PARAMS:{},isBaseLayer:true,lzd:null,zoomLevels:null,initialize:function(name,url,lzd,zoomLevels,params,options){this.lzd=lzd;this.zoomLevels=zoomLevels;var newArguments=[];newArguments.push(name,url,params,options);OpenLayers.Layer.Grid.prototype.initialize.apply(this,newArguments);this.params=(params?params:{});if(params){OpenLayers.Util.applyDefaults(this.params,this.DEFAULT_PARAMS);}},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},getZoom:function(){var zoom=this.map.getZoom();var extent=this.map.getMaxExtent();zoom=zoom-Math.log(this.maxResolution/(this.lzd/512))/Math.log(2);return zoom;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var zoom=this.getZoom();var extent=this.map.getMaxExtent();var deg=this.lzd/Math.pow(2,this.getZoom());var x=Math.floor((bounds.left-extent.left)/deg);var y=Math.floor((bounds.bottom-extent.bottom)/deg);if(this.map.getResolution()<=(this.lzd/512)&&this.getZoom()<=this.zoomLevels){return this.getFullRequestString({L:zoom,X:x,Y:y});}else{return OpenLayers.Util.getImagesLocation()+"blank.gif";}},CLASS_NAME:"OpenLayers.Layer.WorldWind"});OpenLayers.Rule=OpenLayers.Class({id:null,name:'default',title:null,description:null,context:null,filter:null,elseFilter:false,symbolizer:null,minScaleDenominator:null,maxScaleDenominator:null,initialize:function(options){this.id=OpenLayers.Util.createUniqueID(this.CLASS_NAME+"_");this.symbolizer={};OpenLayers.Util.extend(this,options);},destroy:function(){for(var i in this.symbolizer){this.symbolizer[i]=null;}
-this.symbolizer=null;},evaluate:function(feature){var context=this.getContext(feature);var applies=true;if(this.minScaleDenominator||this.maxScaleDenominator){var scale=feature.layer.map.getScale();}
-if(this.minScaleDenominator){applies=scale>=OpenLayers.Style.createLiteral(this.minScaleDenominator,context);}
-if(applies&&this.maxScaleDenominator){applies=scale<OpenLayers.Style.createLiteral(this.maxScaleDenominator,context);}
-if(applies&&this.filter){if(this.filter.CLASS_NAME=="OpenLayers.Filter.FeatureId"){applies=this.filter.evaluate(feature);}else{applies=this.filter.evaluate(context);}}
-return applies;},getContext:function(feature){var context=this.context;if(!context){context=feature.attributes||feature.data;}
-return context;},CLASS_NAME:"OpenLayers.Rule"});OpenLayers.StyleMap=OpenLayers.Class({styles:null,extendDefault:true,initialize:function(style,options){this.styles={"default":new OpenLayers.Style(OpenLayers.Feature.Vector.style["default"]),"select":new OpenLayers.Style(OpenLayers.Feature.Vector.style["select"]),"temporary":new OpenLayers.Style(OpenLayers.Feature.Vector.style["temporary"])};if(style instanceof OpenLayers.Style){this.styles["default"]=style;this.styles["select"]=style;this.styles["temporary"]=style;}else if(typeof style=="object"){for(var key in style){if(style[key]instanceof OpenLayers.Style){this.styles[key]=style[key];}else if(typeof style[key]=="object"){this.styles[key]=new OpenLayers.Style(style[key]);}else{this.styles["default"]=new OpenLayers.Style(style);this.styles["select"]=new OpenLayers.Style(style);this.styles["temporary"]=new OpenLayers.Style(style);break;}}}
-OpenLayers.Util.extend(this,options);},destroy:function(){for(var key in this.styles){this.styles[key].destroy();}
-this.styles=null;},createSymbolizer:function(feature,intent){if(!feature){feature=new OpenLayers.Feature.Vector();}
-if(!this.styles[intent]){intent="default";}
-feature.renderIntent=intent;var defaultSymbolizer={};if(this.extendDefault&&intent!="default"){defaultSymbolizer=this.styles["default"].createSymbolizer(feature);}
-return OpenLayers.Util.extend(defaultSymbolizer,this.styles[intent].createSymbolizer(feature));},addUniqueValueRules:function(renderIntent,property,symbolizers){var rules=[];for(var value in symbolizers){rules.push(new OpenLayers.Rule({symbolizer:symbolizers[value],filter:new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO,property:property,value:value})}));}
-this.styles[renderIntent].addRules(rules);},CLASS_NAME:"OpenLayers.StyleMap"});OpenLayers.Control.NavToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation(),new OpenLayers.Control.ZoomBox()]);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.NavToolbar"});OpenLayers.Filter.Comparison=OpenLayers.Class(OpenLayers.Filter,{type:null,property:null,value:null,lowerBoundary:null,upperBoundary:null,initialize:function(options){OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:case OpenLayers.Filter.Comparison.LESS_THAN:case OpenLayers.Filter.Comparison.GREATER_THAN:case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return this.binaryCompare(context,this.property,this.value);case OpenLayers.Filter.Comparison.BETWEEN:var result=context[this.property]>=this.lowerBoundary;result=result&&context[this.property]<=this.upperBoundary;return result;case OpenLayers.Filter.Comparison.LIKE:var regexp=new RegExp(this.value,"gi");return regexp.test(context[this.property]);}},value2regex:function(wildCard,singleChar,escapeChar){if(wildCard=="."){var msg="'.' is an unsupported wildCard character for "+"OpenLayers.Filter.Comparison";OpenLayers.Console.error(msg);return null;}
-wildCard=wildCard?wildCard:"*";singleChar=singleChar?singleChar:".";escapeChar=escapeChar?escapeChar:"!";this.value=this.value.replace(new RegExp("\\"+escapeChar,"g"),"\\");this.value=this.value.replace(new RegExp("\\"+singleChar,"g"),".");this.value=this.value.replace(new RegExp("\\"+wildCard,"g"),".*");this.value=this.value.replace(new RegExp("\\\\.\\*","g"),"\\"+wildCard);this.value=this.value.replace(new RegExp("\\\\\\.","g"),"\\"+singleChar);return this.value;},regex2value:function(){var value=this.value;value=value.replace(/!/g,"!!");value=value.replace(/(\\)?\\\./g,function($0,$1){return $1?$0:"!.";});value=value.replace(/(\\)?\\\*/g,function($0,$1){return $1?$0:"!*";});value=value.replace(/\\\\/g,"\\");value=value.replace(/\.\*/g,"*");return value;},binaryCompare:function(context,property,value){switch(this.type){case OpenLayers.Filter.Comparison.EQUAL_TO:return context[property]==value;case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:return context[property]!=value;case OpenLayers.Filter.Comparison.LESS_THAN:return context[property]<value;case OpenLayers.Filter.Comparison.GREATER_THAN:return context[property]>value;case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:return context[property]<=value;case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:return context[property]>=value;}},CLASS_NAME:"OpenLayers.Filter.Comparison"});OpenLayers.Filter.Comparison.EQUAL_TO="==";OpenLayers.Filter.Comparison.NOT_EQUAL_TO="!=";OpenLayers.Filter.Comparison.LESS_THAN="<";OpenLayers.Filter.Comparison.GREATER_THAN=">";OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO="<=";OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO=">=";OpenLayers.Filter.Comparison.BETWEEN="..";OpenLayers.Filter.Comparison.LIKE="~";OpenLayers.Filter.FeatureId=OpenLayers.Class(OpenLayers.Filter,{fids:null,initialize:function(options){this.fids=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},evaluate:function(feature){for(var i=0;i<this.fids.length;i++){var fid=feature.fid||feature.id;if(fid==this.fids[i]){return true;}}
-return false;},CLASS_NAME:"OpenLayers.Filter.FeatureId"});OpenLayers.Filter.Logical=OpenLayers.Class(OpenLayers.Filter,{filters:null,type:null,initialize:function(options){this.filters=[];OpenLayers.Filter.prototype.initialize.apply(this,[options]);},destroy:function(){this.filters=null;OpenLayers.Filter.prototype.destroy.apply(this);},evaluate:function(context){switch(this.type){case OpenLayers.Filter.Logical.AND:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==false){return false;}}
-return true;case OpenLayers.Filter.Logical.OR:for(var i=0;i<this.filters.length;i++){if(this.filters[i].evaluate(context)==true){return true;}}
-return false;case OpenLayers.Filter.Logical.NOT:return(!this.filters[0].evaluate(context));}},CLASS_NAME:"OpenLayers.Filter.Logical"});OpenLayers.Filter.Logical.AND="&&";OpenLayers.Filter.Logical.OR="||";OpenLayers.Filter.Logical.NOT="!";OpenLayers.Geometry.Collection=OpenLayers.Class(OpenLayers.Geometry,{components:null,componentTypes:null,initialize:function(components){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.components=[];if(components!=null){this.addComponents(components);}},destroy:function(){this.components.length=0;this.components=null;},clone:function(){var geometry=eval("new "+this.CLASS_NAME+"()");for(var i=0;i<this.components.length;i++){geometry.addComponent(this.components[i].clone());}
-OpenLayers.Util.applyDefaults(geometry,this);return geometry;},getComponentsString:function(){var strings=[];for(var i=0;i<this.components.length;i++){strings.push(this.components[i].toShortString());}
-return strings.join(",");},calculateBounds:function(){this.bounds=null;if(this.components&&this.components.length>0){this.setBounds(this.components[0].getBounds());for(var i=1;i<this.components.length;i++){this.extendBounds(this.components[i].getBounds());}}},addComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=0;i<components.length;i++){this.addComponent(components[i]);}},addComponent:function(component,index){var added=false;if(component){if(this.componentTypes==null||(OpenLayers.Util.indexOf(this.componentTypes,component.CLASS_NAME)>-1)){if(index!=null&&(index<this.components.length)){var components1=this.components.slice(0,index);var components2=this.components.slice(index,this.components.length);components1.push(component);this.components=components1.concat(components2);}else{this.components.push(component);}
-component.parent=this;this.clearBounds();added=true;}}
-return added;},removeComponents:function(components){if(!(components instanceof Array)){components=[components];}
-for(var i=components.length-1;i>=0;--i){this.removeComponent(components[i]);}},removeComponent:function(component){OpenLayers.Util.removeItem(this.components,component);this.clearBounds();},getLength:function(){var length=0.0;for(var i=0;i<this.components.length;i++){length+=this.components[i].getLength();}
-return length;},getArea:function(){var area=0.0;for(var i=0;i<this.components.length;i++){area+=this.components[i].getArea();}
-return area;},move:function(x,y){for(var i=0;i<this.components.length;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length;++i){this.components[i].resize(scale,origin,ratio);}},equals:function(geometry){var equivalent=true;if(!geometry||!geometry.CLASS_NAME||(this.CLASS_NAME!=geometry.CLASS_NAME)){equivalent=false;}else if(!(geometry.components instanceof Array)||(geometry.components.length!=this.components.length)){equivalent=false;}else{for(var i=0;i<this.components.length;++i){if(!this.components[i].equals(geometry.components[i])){equivalent=false;break;}}}
-return equivalent;},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},intersects:function(geometry){var intersect=false;for(var i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Collection"});OpenLayers.Geometry.Point=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,initialize:function(x,y){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=parseFloat(x);this.y=parseFloat(y);},clone:function(obj){if(obj==null){obj=new OpenLayers.Geometry.Point(this.x,this.y);}
-OpenLayers.Util.applyDefaults(obj,this);return obj;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x,this.y);},distanceTo:function(point){var distance=0.0;if((this.x!=null)&&(this.y!=null)&&(point!=null)&&(point.x!=null)&&(point.y!=null)){var dx2=Math.pow(this.x-point.x,2);var dy2=Math.pow(this.y-point.y,2);distance=Math.sqrt(dx2+dy2);}
-return distance;},equals:function(geom){var equals=false;if(geom!=null){equals=((this.x==geom.x&&this.y==geom.y)||(isNaN(this.x)&&isNaN(this.y)&&isNaN(geom.x)&&isNaN(geom.y)));}
-return equals;},toShortString:function(){return(this.x+", "+this.y);},move:function(x,y){this.x=this.x+x;this.y=this.y+y;this.clearBounds();},rotate:function(angle,origin){angle*=Math.PI/180;var radius=this.distanceTo(origin);var theta=angle+Math.atan2(this.y-origin.y,this.x-origin.x);this.x=origin.x+(radius*Math.cos(theta));this.y=origin.y+(radius*Math.sin(theta));this.clearBounds();},resize:function(scale,origin,ratio){ratio=(ratio==undefined)?1:ratio;this.x=origin.x+(scale*ratio*(this.x-origin.x));this.y=origin.y+(scale*(this.y-origin.y));this.clearBounds();},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.equals(geometry);}else{intersect=geometry.intersects(this);}
-return intersect;},transform:function(source,dest){if((source&&dest)){OpenLayers.Projection.transform(this,source,dest);}
-return this;},CLASS_NAME:"OpenLayers.Geometry.Point"});OpenLayers.Geometry.Rectangle=OpenLayers.Class(OpenLayers.Geometry,{x:null,y:null,width:null,height:null,initialize:function(x,y,width,height){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);this.x=x;this.y=y;this.width=width;this.height=height;},calculateBounds:function(){this.bounds=new OpenLayers.Bounds(this.x,this.y,this.x+this.width,this.y+this.height);},getLength:function(){var length=(2*this.width)+(2*this.height);return length;},getArea:function(){var area=this.width*this.height;return area;},CLASS_NAME:"OpenLayers.Geometry.Rectangle"});OpenLayers.Geometry.Surface=OpenLayers.Class(OpenLayers.Geometry,{initialize:function(){OpenLayers.Geometry.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.Surface"});OpenLayers.Layer.MapServer.Untiled=OpenLayers.Class(OpenLayers.Layer.MapServer,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.MapServer.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.MapServer.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.MapServer class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.MapServer.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.MapServer.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.MapServer.Untiled"});OpenLayers.Layer.Vector=OpenLayers.Class(OpenLayers.Layer,{EVENT_TYPES:["beforefeatureadded","featureadded","featuresadded","featureselected","featureunselected","beforefeaturemodified","featuremodified","afterfeaturemodified"],isBaseLayer:false,isFixed:false,isVector:true,features:null,selectedFeatures:null,reportError:true,style:null,styleMap:null,renderers:['SVG','VML'],renderer:null,geometryType:null,drawn:false,initialize:function(name,options){this.EVENT_TYPES=OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(OpenLayers.Layer.prototype.EVENT_TYPES);OpenLayers.Layer.prototype.initialize.apply(this,arguments);if(!this.renderer||!this.renderer.supported()){this.assignRenderer();}
-if(!this.renderer||!this.renderer.supported()){this.renderer=null;this.displayError();}
-if(!this.styleMap){this.styleMap=new OpenLayers.StyleMap();}
-this.features=[];this.selectedFeatures=[];},destroy:function(){OpenLayers.Layer.prototype.destroy.apply(this,arguments);this.destroyFeatures();this.features=null;this.selectedFeatures=null;if(this.renderer){this.renderer.destroy();}
-this.renderer=null;this.geometryType=null;this.drawn=null;},assignRenderer:function(){for(var i=0;i<this.renderers.length;i++){var rendererClass=OpenLayers.Renderer[this.renderers[i]];if(rendererClass&&rendererClass.prototype.supported()){this.renderer=new rendererClass(this.div);break;}}},displayError:function(){if(this.reportError){alert(OpenLayers.i18n("browserNotSupported",{'renderers':this.renderers.join("\n")}));}},setMap:function(map){OpenLayers.Layer.prototype.setMap.apply(this,arguments);if(!this.renderer){this.map.removeLayer(this);}else{this.renderer.map=this.map;this.renderer.setSize(this.map.getSize());}},onMapResize:function(){OpenLayers.Layer.prototype.onMapResize.apply(this,arguments);this.renderer.setSize(this.map.getSize());},moveTo:function(bounds,zoomChanged,dragging){OpenLayers.Layer.prototype.moveTo.apply(this,arguments);if(!dragging){this.renderer.root.style.visibility="hidden";if(navigator.userAgent.toLowerCase().indexOf("gecko")!=-1){this.div.scrollLeft=this.div.scrollLeft;}
-this.div.style.left=-parseInt(this.map.layerContainerDiv.style.left)+"px";this.div.style.top=-parseInt(this.map.layerContainerDiv.style.top)+"px";var extent=this.map.getExtent();this.renderer.setExtent(extent);this.renderer.root.style.visibility="visible";}
-if(!this.drawn||zoomChanged){this.drawn=true;for(var i=0;i<this.features.length;i++){var feature=this.features[i];this.drawFeature(feature);}}},addFeatures:function(features,options){if(!(features instanceof Array)){features=[features];}
-var notify=!options||!options.silent;for(var i=0;i<features.length;i++){var feature=features[i];if(this.geometryType&&!(feature.geometry instanceof this.geometryType)){var throwStr=OpenLayers.i18n('componentShouldBe',{'geomType':this.geometryType.prototype.CLASS_NAME});throw throwStr;}
-this.features.push(feature);feature.layer=this;if(!feature.style&&this.style){feature.style=OpenLayers.Util.extend({},this.style);}
-if(notify){this.events.triggerEvent("beforefeatureadded",{feature:feature});this.preFeatureInsert(feature);}
-if(this.drawn){this.drawFeature(feature);}
-if(notify){this.events.triggerEvent("featureadded",{feature:feature});this.onFeatureInsert(feature);}}
-if(notify){this.events.triggerEvent("featuresadded",{features:features});}},removeFeatures:function(features){if(!(features instanceof Array)){features=[features];}
-for(var i=features.length-1;i>=0;i--){var feature=features[i];this.features=OpenLayers.Util.removeItem(this.features,feature);if(feature.geometry){this.renderer.eraseGeometry(feature.geometry);}
-if(OpenLayers.Util.indexOf(this.selectedFeatures,feature)!=-1){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}}},destroyFeatures:function(features){var all=(features==undefined);if(all){features=this.features;this.selectedFeatures=[];}
-this.eraseFeatures(features);var feature;for(var i=features.length-1;i>=0;i--){feature=features[i];if(!all){OpenLayers.Util.removeItem(this.selectedFeatures,feature);}
-feature.destroy();}},drawFeature:function(feature,style){if(typeof style!="object"){var renderIntent=typeof style=="string"?style:feature.renderIntent;style=feature.style||this.style;if(!style){style=this.styleMap.createSymbolizer(feature,renderIntent);}}
-this.renderer.drawFeature(feature,style);},eraseFeatures:function(features){this.renderer.eraseFeatures(features);},getFeatureFromEvent:function(evt){if(!this.renderer){OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));return null;}
-var featureId=this.renderer.getFeatureIdFromEvent(evt);return this.getFeatureById(featureId);},getFeatureById:function(featureId){var feature=null;for(var i=0;i<this.features.length;++i){if(this.features[i].id==featureId){feature=this.features[i];break;}}
-return feature;},onFeatureInsert:function(feature){},preFeatureInsert:function(feature){},CLASS_NAME:"OpenLayers.Layer.Vector"});OpenLayers.Layer.WMS.Untiled=OpenLayers.Class(OpenLayers.Layer.WMS,{singleTile:true,initialize:function(name,url,params,options){OpenLayers.Layer.WMS.prototype.initialize.apply(this,arguments);var msg="The OpenLayers.Layer.WMS.Untiled class is deprecated and "+"will be removed in 3.0. Instead, you should use the "+"normal OpenLayers.Layer.WMS class, passing it the option "+"'singleTile' as true.";OpenLayers.Console.warn(msg);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WMS.Untiled(this.name,this.url,this.params,this.options);}
-obj=OpenLayers.Layer.WMS.prototype.clone.apply(this,[obj]);return obj;},CLASS_NAME:"OpenLayers.Layer.WMS.Untiled"});OpenLayers.Format.SLD=OpenLayers.Class(OpenLayers.Format.XML,{defaultVersion:"1.0.0",version:null,parser:null,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},write:function(sld,options){var version=(options&&options.version)||this.version||this.defaultVersion;if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-this.parser=new format(this.options);}
-var root=this.parser.write(sld);return OpenLayers.Format.XML.prototype.write.apply(this,[root]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var root=data.documentElement;var version=this.version;if(!version){version=root.getAttribute("version");if(!version){version=this.defaultVersion;}}
-if(!this.parser||this.parser.VERSION!=version){var format=OpenLayers.Format.SLD["v"+version.replace(/\./g,"_")];if(!format){throw"Can't find a SLD parser for version "+
-version;}
-var sld=this.parser.read(data);return sld;},CLASS_NAME:"OpenLayers.Format.SLD"});OpenLayers.Format.Text=OpenLayers.Class(OpenLayers.Format,{initialize:function(options){OpenLayers.Format.prototype.initialize.apply(this,[options]);},read:function(text){var lines=text.split('\n');var columns;var features=[];for(var lcv=0;lcv<(lines.length-1);lcv++){var currLine=lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');if(currLine.charAt(0)!='#'){if(!columns){columns=currLine.split('\t');}else{var vals=currLine.split('\t');var geometry=new OpenLayers.Geometry.Point(0,0);var attributes={};var style={};var icon,iconSize,iconOffset,overflow;var set=false;for(var valIndex=0;valIndex<vals.length;valIndex++){if(vals[valIndex]){if(columns[valIndex]=='point'){var coords=vals[valIndex].split(',');geometry.y=parseFloat(coords[0]);geometry.x=parseFloat(coords[1]);set=true;}else if(columns[valIndex]=='lat'){geometry.y=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='lon'){geometry.x=parseFloat(vals[valIndex]);set=true;}else if(columns[valIndex]=='title')
-attributes['title']=vals[valIndex];else if(columns[valIndex]=='image'||columns[valIndex]=='icon')
-style['externalGraphic']=vals[valIndex];else if(columns[valIndex]=='iconSize'){var size=vals[valIndex].split(',');style['graphicWidth']=parseFloat(size[0]);style['graphicHeight']=parseFloat(size[1]);}else if(columns[valIndex]=='iconOffset'){var offset=vals[valIndex].split(',');style['graphicXOffset']=parseFloat(offset[0]);style['graphicYOffset']=parseFloat(offset[1]);}else if(columns[valIndex]=='description'){attributes['description']=vals[valIndex];}else if(columns[valIndex]=='overflow'){attributes['overflow']=vals[valIndex];}}}
-if(set){if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes,style);features.push(feature);}}}}
-return features;},CLASS_NAME:"OpenLayers.Format.Text"});OpenLayers.Geometry.MultiLineString=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LineString"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiLineString"});OpenLayers.Geometry.MultiPoint=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},addPoint:function(point,index){this.addComponent(point,index);},removePoint:function(point){this.removeComponent(point);},CLASS_NAME:"OpenLayers.Geometry.MultiPoint"});OpenLayers.Geometry.MultiPolygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.Polygon"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},CLASS_NAME:"OpenLayers.Geometry.MultiPolygon"});OpenLayers.Geometry.Polygon=OpenLayers.Class(OpenLayers.Geometry.Collection,{componentTypes:["OpenLayers.Geometry.LinearRing"],initialize:function(components){OpenLayers.Geometry.Collection.prototype.initialize.apply(this,arguments);},getArea:function(){var area=0.0;if(this.components&&(this.components.length>0)){area+=Math.abs(this.components[0].getArea());for(var i=1;i<this.components.length;i++){area-=Math.abs(this.components[i].getArea());}}
-return area;},containsPoint:function(point){var numRings=this.components.length;var contained=false;if(numRings>0){contained=this.components[0].containsPoint(point);if(contained!==1){if(contained&&numRings>1){var hole;for(var i=1;i<numRings;++i){hole=this.components[i].containsPoint(point);if(hole){if(hole===1){contained=1;}else{contained=false;}
-break;}}}}}
-return contained;},intersects:function(geometry){var intersect=false;var i;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"||geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){for(i=0;i<this.components.length;++i){intersect=geometry.intersects(this.components[i]);if(intersect){break;}}
-if(!intersect){for(i=0;i<geometry.components.length;++i){intersect=this.containsPoint(geometry.components[i]);if(intersect){break;}}}}else{for(i=0;i<geometry.components.length;++i){intersect=this.intersects(geometry.components[i]);if(intersect){break;}}}
-if(!intersect&&geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){var ring=this.components[0];for(i=0;i<ring.components.length;++i){intersect=geometry.containsPoint(ring.components[i]);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.Polygon"});OpenLayers.Geometry.Polygon.createRegularPolygon=function(origin,radius,sides,rotation){var angle=Math.PI*((1/sides)-(1/2));if(rotation){angle+=(rotation/180)*Math.PI;}
-var rotatedAngle,x,y;var points=[];for(var i=0;i<sides;++i){rotatedAngle=angle+(i*2*Math.PI/sides);x=origin.x+(radius*Math.cos(rotatedAngle));y=origin.y+(radius*Math.sin(rotatedAngle));points.push(new OpenLayers.Geometry.Point(x,y));}
-var ring=new OpenLayers.Geometry.LinearRing(points);return new OpenLayers.Geometry.Polygon([ring]);};OpenLayers.Handler.Point=OpenLayers.Class(OpenLayers.Handler,{point:null,layer:null,drawing:false,mouseDown:false,lastDown:null,lastUp:null,initialize:function(control,callbacks,options){this.style=OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'],{});OpenLayers.Handler.prototype.initialize.apply(this,arguments);},activate:function(){if(!OpenLayers.Handler.prototype.activate.apply(this,arguments)){return false;}
-var options={displayInLayerSwitcher:false,calculateInRange:function(){return true;}};this.layer=new OpenLayers.Layer.Vector(this.CLASS_NAME,options);this.map.addLayer(this.layer);return true;},createFeature:function(){this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},deactivate:function(){if(!OpenLayers.Handler.prototype.deactivate.apply(this,arguments)){return false;}
-if(this.drawing){this.cancel();}
-if(this.layer.map!=null){this.layer.destroy(false);}
-this.layer=null;return true;},destroyFeature:function(){if(this.point){this.point.destroy();}
-this.point=null;},finalize:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("done",[this.geometryClone()]);this.destroyFeature();},cancel:function(){this.layer.renderer.clear();this.drawing=false;this.mouseDown=false;this.lastDown=null;this.lastUp=null;this.callback("cancel",[this.geometryClone()]);this.destroyFeature();},click:function(evt){OpenLayers.Event.stop(evt);return false;},dblclick:function(evt){OpenLayers.Event.stop(evt);return false;},drawFeature:function(){this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.point.geometry.clone();},mousedown:function(evt){if(!this.checkModifiers(evt)){return true;}
-if(this.lastDown&&this.lastDown.equals(evt.xy)){return true;}
-if(this.lastDown==null){this.createFeature();}
-this.lastDown=evt.xy;this.drawing=true;var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.drawFeature();return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;this.point.geometry.clearBounds();this.drawFeature();}
-return true;},mouseup:function(evt){if(this.drawing){this.finalize();return false;}else{return true;}},CLASS_NAME:"OpenLayers.Handler.Point"});OpenLayers.Layer.GML=OpenLayers.Class(OpenLayers.Layer.Vector,{loaded:false,format:null,formatOptions:null,initialize:function(name,url,options){var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);this.url=url;},setVisibility:function(visibility,noEvent){OpenLayers.Layer.Vector.prototype.setVisibility.apply(this,arguments);if(this.visibility&&!this.loaded){this.loadGML();}},moveTo:function(bounds,zoomChanged,minor){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);if(this.visibility&&!this.loaded){this.events.triggerEvent("loadstart");this.loadGML();}},loadGML:function(){if(!this.loaded){var results=OpenLayers.loadURL(this.url,null,this,this.requestSuccess,this.requestFailure);this.loaded=true;}},setUrl:function(url){this.url=url;this.destroyFeatures();this.loaded=false;this.events.triggerEvent("loadstart");this.loadGML();},requestSuccess:function(request){var doc=request.responseXML;if(!doc||!doc.documentElement){doc=request.responseText;}
-var options={};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-var gml=this.format?new this.format(options):new OpenLayers.Format.GML(options);this.addFeatures(gml.read(doc));this.events.triggerEvent("loadend");},requestFailure:function(request){alert(OpenLayers.i18n("errorLoadingGML",{'url':this.url}));this.events.triggerEvent("loadend");},CLASS_NAME:"OpenLayers.Layer.GML"});OpenLayers.Layer.PointTrack=OpenLayers.Class(OpenLayers.Layer.Vector,{dataFrom:null,initialize:function(name,options){OpenLayers.Layer.Vector.prototype.initialize.apply(this,arguments);},addNodes:function(pointFeatures){if(pointFeatures.length<2){OpenLayers.Console.error("At least two point features have to be added to create"+"a line from");return;}
-var lines=new Array(pointFeatures.length-1);var pointFeature,startPoint,endPoint;for(var i=0;i<pointFeatures.length;i++){pointFeature=pointFeatures[i];endPoint=pointFeature.geometry;if(!endPoint){var lonlat=pointFeature.lonlat;endPoint=new OpenLayers.Geometry.Point(lonlat.lon,lonlat.lat);}else if(endPoint.CLASS_NAME!="OpenLayers.Geometry.Point"){OpenLayers.Console.error("Only features with point geometries are supported.");return;}
-if(i>0){var attributes=(this.dataFrom!=null)?(pointFeatures[i+this.dataFrom].data||pointFeatures[i+this.dataFrom].attributes):null;var line=new OpenLayers.Geometry.LineString([startPoint,endPoint]);lines[i-1]=new OpenLayers.Feature.Vector(line,attributes);}
-startPoint=endPoint;}
-this.addFeatures(lines);},CLASS_NAME:"OpenLayers.Layer.PointTrack"});OpenLayers.Layer.PointTrack.dataFrom={'SOURCE_NODE':-1,'TARGET_NODE':0};OpenLayers.Layer.WFS=OpenLayers.Class(OpenLayers.Layer.Vector,OpenLayers.Layer.Markers,{isBaseLayer:false,tile:null,ratio:2,DEFAULT_PARAMS:{service:"WFS",version:"1.0.0",request:"GetFeature"},featureClass:null,format:null,formatObject:null,formatOptions:null,vectorMode:true,encodeBBOX:false,extractAttributes:false,initialize:function(name,url,params,options){if(options==undefined){options={};}
-if(options.featureClass||!OpenLayers.Layer.Vector||!OpenLayers.Feature.Vector){this.vectorMode=false;}
-OpenLayers.Util.extend(options,{'reportError':false});var newArguments=[];newArguments.push(name,options);OpenLayers.Layer.Vector.prototype.initialize.apply(this,newArguments);if(!this.renderer||!this.vectorMode){this.vectorMode=false;if(!options.featureClass){options.featureClass=OpenLayers.Feature.WFS;}
-OpenLayers.Layer.Markers.prototype.initialize.apply(this,newArguments);}
-if(this.params&&this.params.typename&&!this.options.typename){this.options.typename=this.params.typename;}
-if(!this.options.geometry_column){this.options.geometry_column="the_geom";}
-this.params=params;OpenLayers.Util.applyDefaults(this.params,OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS));this.url=url;},destroy:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.destroy.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.destroy.apply(this,arguments);}
-if(this.tile){this.tile.destroy();}
-this.tile=null;this.ratio=null;this.featureClass=null;this.format=null;if(this.formatObject&&this.formatObject.destroy){this.formatObject.destroy();}
-this.formatObject=null;this.formatOptions=null;this.vectorMode=null;this.encodeBBOX=null;this.extractAttributes=null;},setMap:function(map){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.setMap.apply(this,arguments);var options={'extractAttributes':this.extractAttributes};OpenLayers.Util.extend(options,this.formatOptions);if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.formatObject=this.format?new this.format(options):new OpenLayers.Format.GML(options);}else{OpenLayers.Layer.Markers.prototype.setMap.apply(this,arguments);}},moveTo:function(bounds,zoomChanged,dragging){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.moveTo.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.moveTo.apply(this,arguments);}
-if(dragging){return false;}
-if(zoomChanged){if(this.vectorMode){this.renderer.clear();}}
-if(this.options.minZoomLevel){OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));if(this.map.getZoom()<this.options.minZoomLevel){return null;}}
-if(bounds==null){bounds=this.map.getExtent();}
-var firstRendering=(this.tile==null);var outOfBounds=(!firstRendering&&!this.tile.bounds.containsBounds(bounds));if(zoomChanged||firstRendering||(!dragging&&outOfBounds)){var center=bounds.getCenterLonLat();var tileWidth=bounds.getWidth()*this.ratio;var tileHeight=bounds.getHeight()*this.ratio;var tileBounds=new OpenLayers.Bounds(center.lon-(tileWidth/2),center.lat-(tileHeight/2),center.lon+(tileWidth/2),center.lat+(tileHeight/2));var tileSize=this.map.getSize();tileSize.w=tileSize.w*this.ratio;tileSize.h=tileSize.h*this.ratio;var ul=new OpenLayers.LonLat(tileBounds.left,tileBounds.top);var pos=this.map.getLayerPxFromLonLat(ul);var url=this.getFullRequestString();var params={BBOX:this.encodeBBOX?tileBounds.toBBOX():tileBounds.toArray()};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){var projectedBounds=tileBounds.clone();projectedBounds.transform(this.map.getProjectionObject(),this.projection);params.BBOX=this.encodeBBOX?projectedBounds.toBBOX():projectedBounds.toArray();}
-url+="&"+OpenLayers.Util.getParameterString(params);if(!this.tile){this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}else{if(this.vectorMode){this.destroyFeatures();this.renderer.clear();}else{this.clearMarkers();}
-this.removeTileMonitoringHooks(this.tile);this.tile.destroy();this.tile=null;this.tile=new OpenLayers.Tile.WFS(this,pos,tileBounds,url,tileSize);this.addTileMonitoringHooks(this.tile);this.tile.draw();}}},addTileMonitoringHooks:function(tile){tile.onLoadStart=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("loadstart");}};tile.events.register("loadstart",tile,tile.onLoadStart);tile.onLoadEnd=function(){if(this==this.layer.tile){this.layer.events.triggerEvent("tileloaded");this.layer.events.triggerEvent("loadend");}};tile.events.register("loadend",tile,tile.onLoadEnd);tile.events.register("unload",tile,tile.onLoadEnd);},removeTileMonitoringHooks:function(tile){tile.unload();tile.events.un({"loadstart":tile.onLoadStart,"loadend":tile.onLoadEnd,"unload":tile.onLoadEnd,scope:tile});},onMapResize:function(){if(this.vectorMode){OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,arguments);}else{OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,arguments);}},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,newArguments);},clone:function(obj){if(obj==null){obj=new OpenLayers.Layer.WFS(this.name,this.url,this.params,this.options);}
-if(this.vectorMode){obj=OpenLayers.Layer.Vector.prototype.clone.apply(this,[obj]);}else{obj=OpenLayers.Layer.Markers.prototype.clone.apply(this,[obj]);}
-return obj;},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},commit:function(){if(!this.writer){var options={};if(this.map&&!this.projection.equals(this.map.getProjectionObject())){options.externalProjection=this.projection;options.internalProjection=this.map.getProjectionObject();}
-this.writer=new OpenLayers.Format.WFS(options,this);}
-var data=this.writer.write(this.features);var url=this.url;var success=OpenLayers.Function.bind(this.commitSuccess,this);var failure=OpenLayers.Function.bind(this.commitFailure,this);new OpenLayers.Ajax.Request(url,{method:'post',postBody:data,onComplete:success,onFailure:failure});},commitSuccess:function(request){var response=request.responseText;if(response.indexOf('SUCCESS')!=-1){this.commitReport(OpenLayers.i18n("commitSuccess",{'response':response}));for(var i=0;i<this.features.length;i++){this.features[i].state=null;}}else if(response.indexOf('FAILED')!=-1||response.indexOf('Exception')!=-1){this.commitReport(OpenLayers.i18n("commitFailed",{'response':response}));}},commitFailure:function(request){},commitReport:function(string,response){alert(string);},refresh:function(){if(this.tile){if(this.vectorMode){this.renderer.clear();this.features.length=0;}else{this.clearMarkers();this.markers.length=0;}
-this.tile.draw();}},CLASS_NAME:"OpenLayers.Layer.WFS"});OpenLayers.Format.SLD.v1=OpenLayers.Class(OpenLayers.Format.XML,{namespaces:{sld:"http://www.opengis.net/sld",ogc:"http://www.opengis.net/ogc",xlink:"http://www.w3.org/1999/xlink",xsi:"http://www.w3.org/2001/XMLSchema-instance"},defaultPrefix:"sld",schemaLocation:null,defaultSymbolizer:{fillColor:"#808080",fillOpacity:1,strokeColor:"#000000",strokeOpacity:1,strokeWidth:1,pointRadius:6},initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){var sld={namedLayers:{}};this.readChildNodes(data,sld);return sld;},readers:{"sld":{"StyledLayerDescriptor":function(node,sld){sld.version=node.getAttribute("version");this.readChildNodes(node,sld);},"Name":function(node,obj){obj.name=this.getChildValue(node);},"Title":function(node,obj){obj.title=this.getChildValue(node);},"Abstract":function(node,obj){obj.description=this.getChildValue(node);},"NamedLayer":function(node,sld){var layer={userStyles:[],namedStyles:[]};this.readChildNodes(node,layer);for(var i=0;i<layer.userStyles.length;++i){layer.userStyles[i].layerName=layer.name;}
-sld.namedLayers[layer.name]=layer;},"NamedStyle":function(node,layer){layer.namedStyles.push(this.getChildName(node.firstChild));},"UserStyle":function(node,layer){var style=new OpenLayers.Style(this.defaultSymbolizer);this.readChildNodes(node,style);layer.userStyles.push(style);},"IsDefault":function(node,style){if(this.getChildValue(node)=="1"){style.isDefault=true;}},"FeatureTypeStyle":function(node,style){var obj={rules:[]};this.readChildNodes(node,obj);style.rules=obj.rules;},"Rule":function(node,obj){var rule=new OpenLayers.Rule();this.readChildNodes(node,rule);obj.rules.push(rule);},"ElseFilter":function(node,rule){rule.elseFilter=true;},"MinScaleDenominator":function(node,rule){rule.minScaleDenominator=this.getChildValue(node);},"MaxScaleDenominator":function(node,rule){rule.maxScaleDenominator=this.getChildValue(node);},"LineSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Line"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Line"]=symbolizer;},"PolygonSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Polygon"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Polygon"]=symbolizer;},"PointSymbolizer":function(node,rule){var symbolizer=rule.symbolizer["Point"]||{};this.readChildNodes(node,symbolizer);rule.symbolizer["Point"]=symbolizer;},"Stroke":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"Fill":function(node,symbolizer){this.readChildNodes(node,symbolizer);},"CssParameter":function(node,symbolizer){var cssProperty=node.getAttribute("name");var symProperty=this.cssMap[cssProperty];if(symProperty){var value=this.readOgcExpression(node);if(value){symbolizer[symProperty]=value;}}},"Graphic":function(node,symbolizer){var graphic={};this.readChildNodes(node,graphic);var properties=["strokeColor","strokeWidth","strokeOpacity","strokeLinecap","fillColor","fillOpacity","graphicName","rotation","graphicFormat"];var prop,value;for(var i=0;i<properties.length;++i){prop=properties[i];value=graphic[prop];if(value!=undefined){symbolizer[prop]=value;}}
-if(graphic.opacity!=undefined){symbolizer.graphicOpacity=graphic.opacity;}
-if(graphic.size!=undefined){symbolizer.pointRadius=graphic.size;}
-if(graphic.href!=undefined){symbolizer.externalGraphic=graphic.href;}},"ExternalGraphic":function(node,graphic){this.readChildNodes(node,graphic);},"Mark":function(node,graphic){this.readChildNodes(node,graphic);},"WellKnownName":function(node,graphic){graphic.graphicName=this.getChildValue(node);},"Opacity":function(node,obj){var opacity=this.getChildValue(node);if(opacity){obj.opacity=opacity;}},"Size":function(node,obj){var size=this.getChildValue(node);if(size){obj.size=size;}},"Rotation":function(node,obj){var rotation=this.getChildValue(node);if(rotation){obj.rotation=rotation;}},"OnlineResource":function(node,obj){obj.href=this.getAttributeNS(node,this.namespaces.xlink,"href");},"Format":function(node,graphic){graphic.graphicFormat=this.getChildValue(node);}},"ogc":{"Filter":function(node,rule){var obj={fids:[],filters:[]};this.readChildNodes(node,obj);if(obj.fids.length>0){rule.filter=new OpenLayers.Filter.FeatureId({fids:obj.fids});}else if(obj.filters.length>0){rule.filter=obj.filters[0];}},"FeatureId":function(node,obj){var fid=node.getAttribute("fid");if(fid){obj.fids.push(fid);}},"And":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.AND});this.readChildNodes(node,filter);obj.filters.push(filter);},"Or":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.OR});this.readChildNodes(node,filter);obj.filters.push(filter);},"Not":function(node,obj){var filter=new OpenLayers.Filter.Logical({type:OpenLayers.Filter.Logical.NOT});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsNotEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.NOT_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThan":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLessThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsGreaterThanOrEqualTo":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsBetween":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.BETWEEN});this.readChildNodes(node,filter);obj.filters.push(filter);},"PropertyIsLike":function(node,obj){var filter=new OpenLayers.Filter.Comparison({type:OpenLayers.Filter.Comparison.LIKE});this.readChildNodes(node,filter);var wildCard=node.getAttribute("wildCard");var singleChar=node.getAttribute("singleChar");var esc=node.getAttribute("escape");filter.value2regex(wildCard,singleChar,esc);obj.filters.push(filter);},"Literal":function(node,obj){obj.value=this.getChildValue(node);},"PropertyName":function(node,filter){filter.property=this.getChildValue(node);},"LowerBoundary":function(node,filter){filter.lowerBoundary=this.readOgcExpression(node);},"UpperBoundary":function(node,filter){filter.upperBoundary=this.readOgcExpression(node);}}},readOgcExpression:function(node){var obj={};this.readChildNodes(node,obj);var value=obj.value;if(!value){value=this.getChildValue(node);}
-return value;},cssMap:{"stroke":"strokeColor","stroke-opacity":"strokeOpacity","stroke-width":"strokeWidth","stroke-linecap":"strokeLinecap","fill":"fillColor","fill-opacity":"fillOpacity"},getCssProperty:function(sym){var css=null;for(var prop in this.cssMap){if(this.cssMap[prop]==sym){css=prop;break;}}
-return css;},getGraphicFormat:function(href){var format,regex;for(var key in this.graphicFormats){if(this.graphicFormats[key].test(href)){format=key;break;}}
-return format||this.defautlGraphicFormat;},defaultGraphicFormat:"image/png",graphicFormats:{"image/jpeg":/\.jpe?g$/i,"image/gif":/\.gif$/i,"image/png":/\.png$/i},write:function(sld){return this.writers.sld.StyledLayerDescriptor.apply(this,[sld]);},writers:{"sld":{"StyledLayerDescriptor":function(sld){var root=this.createElementNSPlus("StyledLayerDescriptor",{attributes:{"version":this.VERSION,"xsi:schemaLocation":this.schemaLocation}});if(sld.name){this.writeNode(root,"Name",sld.name);}
-if(sld.title){this.writeNode(root,"Title",sld.title);}
-if(sld.description){this.writeNode(root,"Abstract",sld.description);}
-for(var name in sld.namedLayers){this.writeNode(root,"NamedLayer",sld.namedLayers[name]);}
-return root;},"Name":function(name){return this.createElementNSPlus("Name",{value:name});},"Title":function(title){return this.createElementNSPlus("Title",{value:title});},"Abstract":function(description){return this.createElementNSPlus("Abstract",{value:description});},"NamedLayer":function(layer){var node=this.createElementNSPlus("NamedLayer");this.writeNode(node,"Name",layer.name);if(layer.namedStyles){for(var i=0;i<layer.namedStyles.length;++i){this.writeNode(node,"NamedStyle",layer.namedStyles[i]);}}
-if(layer.userStyles){for(var i=0;i<layer.userStyles.length;++i){this.writeNode(node,"UserStyle",layer.userStyles[i]);}}
-return node;},"NamedStyle":function(name){var node=this.createElementNSPlus("NamedStyle");this.writeNode(node,"Name",name);return node;},"UserStyle":function(style){var node=this.createElementNSPlus("UserStyle");if(style.name){this.writeNode(node,"Name",style.name);}
-if(style.title){this.writeNode(node,"Title",style.title);}
-if(style.description){this.writeNode(node,"Abstract",style.description);}
-if(style.isDefault){this.writeNode(node,"IsDefault",style.isDefault);}
-this.writeNode(node,"FeatureTypeStyle",style);return node;},"IsDefault":function(bool){return this.createElementNSPlus("IsDefault",{value:(bool)?"1":"0"});},"FeatureTypeStyle":function(style){var node=this.createElementNSPlus("FeatureTypeStyle");for(var i=0;i<style.rules.length;++i){this.writeNode(node,"Rule",style.rules[i]);}
-return node;},"Rule":function(rule){var node=this.createElementNSPlus("Rule");if(rule.name){this.writeNode(node,"Name",rule.name);}
-if(rule.title){this.writeNode(node,"Title",rule.title);}
-if(rule.description){this.writeNode(node,"Abstract",rule.description);}
-if(rule.elseFilter){this.writeNode(node,"ElseFilter");}else if(rule.filter){this.writeNode(node,"ogc:Filter",rule.filter);}
-if(rule.minScaleDenominator!=undefined){this.writeNode(node,"MinScaleDenominator",rule.minScaleDenominator);}
-if(rule.maxScaleDenominator!=undefined){this.writeNode(node,"MaxScaleDenominator",rule.maxScaleDenominator);}
-var types=OpenLayers.Style.SYMBOLIZER_PREFIXES;var type,symbolizer;for(var i=0;i<types.length;++i){type=types[i];symbolizer=rule.symbolizer[type];if(symbolizer){this.writeNode(node,type+"Symbolizer",symbolizer);}}
-return node;},"ElseFilter":function(){return this.createElementNSPlus("ElseFilter");},"MinScaleDenominator":function(scale){return this.createElementNSPlus("MinScaleDenominator",{value:scale});},"MaxScaleDenominator":function(scale){return this.createElementNSPlus("MaxScaleDenominator",{value:scale});},"LineSymbolizer":function(symbolizer){var node=this.createElementNSPlus("LineSymbolizer");this.writeNode(node,"Stroke",symbolizer);return node;},"Stroke":function(symbolizer){var node=this.createElementNSPlus("Stroke");if(symbolizer.strokeColor!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeColor"});}
-if(symbolizer.strokeOpacity!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeOpacity"});}
-if(symbolizer.strokeWidth!=undefined){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"strokeWidth"});}
-return node;},"CssParameter":function(obj){return this.createElementNSPlus("CssParameter",{attributes:{name:this.getCssProperty(obj.key)},value:obj.symbolizer[obj.key]});},"PolygonSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PolygonSymbolizer");this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"Fill":function(symbolizer){var node=this.createElementNSPlus("Fill");if(symbolizer.fillColor){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillColor"});}
-if(symbolizer.fillOpacity){this.writeNode(node,"CssParameter",{symbolizer:symbolizer,key:"fillOpacity"});}
-return node;},"PointSymbolizer":function(symbolizer){var node=this.createElementNSPlus("PointSymbolizer");this.writeNode(node,"Graphic",symbolizer);return node;},"Graphic":function(symbolizer){var node=this.createElementNSPlus("Graphic");if(symbolizer.externalGraphic!=undefined){this.writeNode(node,"ExternalGraphic",symbolizer);}else if(symbolizer.graphicName){this.writeNode(node,"Mark",symbolizer);}
-if(symbolizer.graphicOpacity!=undefined){this.writeNode(node,"Opacity",symbolizer.graphicOpacity);}
-if(symbolizer.pointRadius!=undefined){this.writeNode(node,"Size",symbolizer.pointRadius);}
-if(symbolizer.rotation!=undefined){this.writeNode(node,"Rotation",symbolizer.rotation);}
-return node;},"ExternalGraphic":function(symbolizer){var node=this.createElementNSPlus("ExternalGraphic");this.writeNode(node,"OnlineResource",symbolizer.externalGraphic);var format=symbolizer.graphicFormat||this.getGraphicFormat(symbolizer.externalGraphic);this.writeNode(node,"Format",format);return node;},"Mark":function(symbolizer){var node=this.createElementNSPlus("Mark");this.writeNode(node,"WellKnownName",symbolizer.graphicName);this.writeNode(node,"Fill",symbolizer);this.writeNode(node,"Stroke",symbolizer);return node;},"WellKnownName":function(name){return this.createElementNSPlus("WellKnownName",{value:name});},"Opacity":function(value){return this.createElementNSPlus("Opacity",{value:value});},"Size":function(value){return this.createElementNSPlus("Size",{value:value});},"Rotation":function(value){return this.createElementNSPlus("Rotation",{value:value});},"OnlineResource":function(href){return this.createElementNSPlus("OnlineResource",{attributes:{"xlink:type":"simple","xlink:href":href}});},"Format":function(format){return this.createElementNSPlus("Format",{value:format});}},"ogc":{"Filter":function(filter){var node=this.createElementNSPlus("ogc:Filter");var sub=filter.CLASS_NAME.split(".").pop();if(sub=="FeatureId"){for(var i=0;i<filter.fids.length;++i){this.writeNode(node,"FeatureId",filter.fids[i]);}}else{this.writeNode(node,this.getFilterType(filter),filter);}
-return node;},"FeatureId":function(fid){return this.createElementNSPlus("ogc:FeatureId",{attributes:{fid:fid}});},"And":function(filter){var node=this.createElementNSPlus("ogc:And");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Or":function(filter){var node=this.createElementNSPlus("ogc:Or");var childFilter;for(var i=0;i<filter.filters.length;++i){childFilter=filter.filters[i];this.writeNode(node,this.getFilterType(childFilter),childFilter);}
-return node;},"Not":function(filter){var node=this.createElementNSPlus("ogc:Not");var childFilter=filter.filters[0];this.writeNode(node,this.getFilterType(childFilter),childFilter);return node;},"PropertyIsEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsNotEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsNotEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThan":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThan");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsLessThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsGreaterThanOrEqualTo":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.value);return node;},"PropertyIsBetween":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsBetween");this.writeNode(node,"PropertyName",filter);this.writeNode(node,"LowerBoundary",filter);this.writeNode(node,"UpperBoundary",filter);return node;},"PropertyIsLike":function(filter){var node=this.createElementNSPlus("ogc:PropertyIsLike",{attributes:{wildCard:"*",singleChar:".",escape:"!"}});this.writeNode(node,"PropertyName",filter);this.writeNode(node,"Literal",filter.regex2value());return node;},"PropertyName":function(filter){return this.createElementNSPlus("ogc:PropertyName",{value:filter.property});},"Literal":function(value){return this.createElementNSPlus("ogc:Literal",{value:value});},"LowerBoundary":function(filter){var node=this.createElementNSPlus("ogc:LowerBoundary");this.writeNode(node,"Literal",filter.lowerBoundary);return node;},"UpperBoundary":function(filter){var node=this.createElementNSPlus("ogc:UpperBoundary");this.writeNode(node,"Literal",filter.upperBoundary);return node;}}},getFilterType:function(filter){var filterType=this.filterMap[filter.type];if(!filterType){throw"SLD writing not supported for rule type: "+filter.type;}
-return filterType;},filterMap:{"&&":"And","||":"Or","!":"Not","==":"PropertyIsEqualTo","!=":"PropertyIsNotEqualTo","<":"PropertyIsLessThan",">":"PropertyIsGreaterThan","<=":"PropertyIsLessThanOrEqualTo",">=":"PropertyIsGreaterThanOrEqualTo","..":"PropertyIsBetween","~":"PropertyIsLike"},getNamespacePrefix:function(uri){var prefix=null;if(uri==null){prefix=this.namespaces[this.defaultPrefix];}else{var gotPrefix=false;for(prefix in this.namespaces){if(this.namespaces[prefix]==uri){gotPrefix=true;break;}}
-if(!gotPrefix){prefix=null;}}
-return prefix;},readChildNodes:function(node,obj){var children=node.childNodes;var child,group,reader,prefix,local;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){prefix=this.getNamespacePrefix(child.namespaceURI);local=child.nodeName.split(":").pop();group=this.readers[prefix];if(group){reader=group[local];if(reader){reader.apply(this,[child,obj]);}}}}},writeNode:function(parent,name,obj){var prefix,local;var split=name.indexOf(":");if(split>0){prefix=name.substring(0,split);local=name.substring(split+1);}else{prefix=this.getNamespacePrefix(parent.namespaceURI);local=name;}
-var child=this.writers[prefix][local].apply(this,[obj]);parent.appendChild(child);return child;},createElementNSPlus:function(name,options){options=options||{};var loc=name.indexOf(":");var uri=options.uri||this.namespaces[options.prefix];if(!uri){loc=name.indexOf(":");uri=this.namespaces[name.substring(0,loc)];}
-if(!uri){uri=this.namespaces[this.defaultPrefix];}
-var node=this.createElementNS(uri,name);if(options.attributes){this.setAttributes(node,options.attributes);}
-if(options.value){node.appendChild(this.createTextNode(options.value));}
-return node;},setAttributes:function(node,obj){var value,loc,alias,uri;for(var name in obj){value=obj[name].toString();uri=this.namespaces[name.substring(0,name.indexOf(":"))]||null;this.setAttributeNS(node,uri,name,value);}},CLASS_NAME:"OpenLayers.Format.SLD.v1"});OpenLayers.Geometry.Curve=OpenLayers.Class(OpenLayers.Geometry.MultiPoint,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,arguments);},getLength:function(){var length=0.0;if(this.components&&(this.components.length>1)){for(var i=1;i<this.components.length;i++){length+=this.components[i-1].distanceTo(this.components[i]);}}
-return length;},CLASS_NAME:"OpenLayers.Geometry.Curve"});OpenLayers.Format.SLD.v1_0_0=OpenLayers.Class(OpenLayers.Format.SLD.v1,{VERSION:"1.0.0",schemaLocation:"http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",initialize:function(options){OpenLayers.Format.SLD.v1.prototype.initialize.apply(this,[options]);},CLASS_NAME:"OpenLayers.Format.SLD.v1_0_0"});OpenLayers.Geometry.LineString=OpenLayers.Class(OpenLayers.Geometry.Curve,{initialize:function(points){OpenLayers.Geometry.Curve.prototype.initialize.apply(this,arguments);},removeComponent:function(point){if(this.components&&(this.components.length>2)){OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);}},intersects:function(geometry){var intersect=false;var type=geometry.CLASS_NAME;if(type=="OpenLayers.Geometry.LineString"||type=="OpenLayers.Geometry.LinearRing"||type=="OpenLayers.Geometry.Point"){var segs1=this.getSortedSegments();var segs2;if(type=="OpenLayers.Geometry.Point"){segs2=[{x1:geometry.x,y1:geometry.y,x2:geometry.x,y2:geometry.y}];}else{segs2=geometry.getSortedSegments();}
-var seg1,seg1x1,seg1x2,seg1y1,seg1y2,seg2,seg2y1,seg2y2;outer:for(var i=0;i<segs1.length;++i){seg1=segs1[i];seg1x1=seg1.x1;seg1x2=seg1.x2;seg1y1=seg1.y1;seg1y2=seg1.y2;inner:for(var j=0;j<segs2.length;++j){seg2=segs2[j];if(seg2.x1>seg1x2){break;}
-if(seg2.x2<seg1x1){continue;}
-seg2y1=seg2.y1;seg2y2=seg2.y2;if(Math.min(seg2y1,seg2y2)>Math.max(seg1y1,seg1y2)){continue;}
-if(Math.max(seg2y1,seg2y2)<Math.min(seg1y1,seg1y2)){continue;}
-if(OpenLayers.Geometry.segmentsIntersect(seg1,seg2)){intersect=true;break outer;}}}}else{intersect=geometry.intersects(this);}
-return intersect;},getSortedSegments:function(){var numSeg=this.components.length-1;var segments=new Array(numSeg);for(var i=0;i<numSeg;++i){point1=this.components[i];point2=this.components[i+1];if(point1.x<point2.x){segments[i]={x1:point1.x,y1:point1.y,x2:point2.x,y2:point2.y};}else{segments[i]={x1:point2.x,y1:point2.y,x2:point1.x,y2:point1.y};}}
-function byX1(seg1,seg2){return seg1.x1-seg2.x1;}
-return segments.sort(byX1);},CLASS_NAME:"OpenLayers.Geometry.LineString"});OpenLayers.Format.GML=OpenLayers.Class(OpenLayers.Format.XML,{featureNS:"http://mapserver.gis.umn.edu/mapserver",featurePrefix:"feature",featureName:"featureMember",layerName:"features",geometryName:"geometry",collectionName:"FeatureCollection",gmlns:"http://www.opengis.net/gml",extractAttributes:true,xy:true,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var featureNodes=this.getElementsByTagNameNS(data.documentElement,this.gmlns,this.featureName);var features=[];for(var i=0;i<featureNodes.length;i++){var feature=this.parseFeature(featureNodes[i]);if(feature){features.push(feature);}}
-return features;},parseFeature:function(node){var order=["MultiPolygon","Polygon","MultiLineString","LineString","MultiPoint","Point","Envelope"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];nodeList=this.getElementsByTagNameNS(node,this.gmlns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var attributes;if(this.extractAttributes){attributes=this.parseAttributes(node);}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var childNode=node.firstChild;var fid;while(childNode){if(childNode.nodeType==1){fid=childNode.getAttribute("fid")||childNode.getAttribute("id");if(fid){break;}}
-childNode=childNode.nextSibling;}
-feature.fid=fid;return feature;},parseGeometry:{point:function(node){var nodeList,coordString;var coords=[];var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"pos");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coord");if(nodeList.length>0){var xList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"X");var yList=this.getElementsByTagNameNS(nodeList[0],this.gmlns,"Y");if(xList.length>0&&yList.length>0){coords=[xList[0].firstChild.nodeValue,yList[0].firstChild.nodeValue];}}}
-if(coords.length==2){coords[2]=null;}
-if(this.xy){return new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}
-else{return new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}},multipoint:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Point");var components=[];if(nodeList.length>0){var point;for(var i=0;i<nodeList.length;++i){point=this.parseGeometry.point.apply(this,[nodeList[i]]);if(point){components.push(point);}}}
-return new OpenLayers.Geometry.MultiPoint(components);},linestring:function(node,ring){var nodeList,coordString;var coords=[];var points=[];nodeList=this.getElementsByTagNameNS(node,this.gmlns,"posList");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);var dim=parseInt(nodeList[0].getAttribute("dimension"));var j,x,y,z;for(var i=0;i<coords.length/dim;++i){j=i*dim;x=coords[j];y=coords[j+1];z=(dim==2)?null:coords[j+2];if(this.xy){points.push(new OpenLayers.Geometry.Point(x,y,z));}else{points.push(new OpenLayers.Geometry.Point(y,x,z));}}}
-if(coords.length==0){nodeList=this.getElementsByTagNameNS(node,this.gmlns,"coordinates");if(nodeList.length>0){coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);for(var i=0;i<pointList.length;++i){coords=pointList[i].split(",");if(coords.length==2){coords[2]=null;}
-if(this.xy){points.push(new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]));}else{points.push(new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]));}}}}
-var line=null;if(points.length!=0){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}
-return line;},multilinestring:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LineString");var components=[];if(nodeList.length>0){var line;for(var i=0;i<nodeList.length;++i){line=this.parseGeometry.linestring.apply(this,[nodeList[i]]);if(line){components.push(line);}}}
-return new OpenLayers.Geometry.MultiLineString(components);},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"LinearRing");var components=[];if(nodeList.length>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components.push(ring);}}}
-return new OpenLayers.Geometry.Polygon(components);},multipolygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.gmlns,"Polygon");var components=[];if(nodeList.length>0){var polygon;for(var i=0;i<nodeList.length;++i){polygon=this.parseGeometry.polygon.apply(this,[nodeList[i]]);if(polygon){components.push(polygon);}}}
-return new OpenLayers.Geometry.MultiPolygon(components);},envelope:function(node){var components=[];var coordString;var envelope;var lpoint=this.getElementsByTagNameNS(node,this.gmlns,"lowerCorner");if(lpoint.length>0){var coords=[];if(lpoint.length>0){coordString=lpoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var lowerPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var lowerPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-var upoint=this.getElementsByTagNameNS(node,this.gmlns,"upperCorner");if(upoint.length>0){var coords=[];if(upoint.length>0){coordString=upoint[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.trimSpace,"");coords=coordString.split(this.regExes.splitSpace);}
-if(this.xy){var upperPoint=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{var upperPoint=new OpenLayers.Geometry.Point(coords[1],coords[0],coords[2]);}}
-if(lowerPoint&&upperPoint){components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,lowerPoint.y));components.push(new OpenLayers.Geometry.Point(upperPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,upperPoint.y));components.push(new OpenLayers.Geometry.Point(lowerPoint.x,lowerPoint.y));var ring=new OpenLayers.Geometry.LinearRing(components);envelope=new OpenLayers.Geometry.Polygon([ring]);}
-return envelope;}},parseAttributes:function(node){var attributes={};var childNode=node.firstChild;var children,i,child,grandchildren,grandchild,name,value;while(childNode){if(childNode.nodeType==1){children=childNode.childNodes;for(i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1){grandchild=grandchildren[0];if(grandchild.nodeType==3||grandchild.nodeType==4){name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;value=grandchild.nodeValue.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}
-break;}
-return attributes;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var gml=this.createElementNS("http://www.opengis.net/wfs","wfs:"+this.collectionName);for(var i=0;i<features.length;i++){gml.appendChild(this.createFeatureXML(features[i]));}
-return OpenLayers.Format.XML.prototype.write.apply(this,[gml]);},createFeatureXML:function(feature){var geometry=feature.geometry;var geometryNode=this.buildGeometryNode(geometry);var geomContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.geometryName);geomContainer.appendChild(geometryNode);var featureNode=this.createElementNS(this.gmlns,"gml:"+this.featureName);var featureContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-this.layerName);var fid=feature.fid||feature.id;featureContainer.setAttribute("fid",fid);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr.substring(attr.lastIndexOf(":")+1);var attrContainer=this.createElementNS(this.featureNS,this.featurePrefix+":"+
-nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-featureNode.appendChild(featureContainer);return featureNode;},buildGeometryNode:function(geometry){if(this.externalProjection&&this.internalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];return builder.apply(this,[geometry]);},buildGeometry:{point:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Point");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multipoint:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPoint");var points=geometry.components;var pointMember,pointGeom;for(var i=0;i<points.length;i++){pointMember=this.createElementNS(this.gmlns,"gml:pointMember");pointGeom=this.buildGeometry.point.apply(this,[points[i]]);pointMember.appendChild(pointGeom);gml.appendChild(pointMember);}
-return gml;},linestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LineString");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},multilinestring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiLineString");var lines=geometry.components;var lineMember,lineGeom;for(var i=0;i<lines.length;++i){lineMember=this.createElementNS(this.gmlns,"gml:lineStringMember");lineGeom=this.buildGeometry.linestring.apply(this,[lines[i]]);lineMember.appendChild(lineGeom);gml.appendChild(lineMember);}
-return gml;},linearring:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:LinearRing");gml.appendChild(this.buildCoordinatesNode(geometry));return gml;},polygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.gmlns,"gml:"+type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);gml.appendChild(ringMember);}
-return gml;},multipolygon:function(geometry){var gml=this.createElementNS(this.gmlns,"gml:MultiPolygon");var polys=geometry.components;var polyMember,polyGeom;for(var i=0;i<polys.length;++i){polyMember=this.createElementNS(this.gmlns,"gml:polygonMember");polyGeom=this.buildGeometry.polygon.apply(this,[polys[i]]);polyMember.appendChild(polyGeom);gml.appendChild(polyMember);}
-return gml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.gmlns,"gml:coordinates");coordinatesNode.setAttribute("decimal",".");coordinatesNode.setAttribute("cs",",");coordinatesNode.setAttribute("ts"," ");var points=(geometry.components)?geometry.components:[geometry];var parts=[];for(var i=0;i<points.length;i++){parts.push(points[i].x+","+points[i].y);}
-var txtNode=this.createTextNode(parts.join(" "));coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.GML"});OpenLayers.Format.GeoJSON=OpenLayers.Class(OpenLayers.Format.JSON,{initialize:function(options){OpenLayers.Format.JSON.prototype.initialize.apply(this,[options]);},read:function(json,type,filter){type=(type)?type:"FeatureCollection";var results=null;var obj=null;if(typeof json=="string"){obj=OpenLayers.Format.JSON.prototype.read.apply(this,[json,filter]);}else{obj=json;}
-if(!obj){OpenLayers.Console.error("Bad JSON: "+json);}else if(typeof(obj.type)!="string"){OpenLayers.Console.error("Bad GeoJSON - no type: "+json);}else if(this.isValidType(obj,type)){switch(type){case"Geometry":try{results=this.parseGeometry(obj);}catch(err){OpenLayers.Console.error(err);}
-break;case"Feature":try{results=this.parseFeature(obj);results.type="Feature";}catch(err){OpenLayers.Console.error(err);}
-break;case"FeatureCollection":results=[];switch(obj.type){case"Feature":try{results.push(this.parseFeature(obj));}catch(err){results=null;OpenLayers.Console.error(err);}
-break;case"FeatureCollection":for(var i=0;i<obj.features.length;++i){try{results.push(this.parseFeature(obj.features[i]));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;default:try{var geom=this.parseGeometry(obj);results.push(new OpenLayers.Feature.Vector(geom));}catch(err){results=null;OpenLayers.Console.error(err);}}
-break;}}
-return results;},isValidType:function(obj,type){var valid=false;switch(type){case"Geometry":if(OpenLayers.Util.indexOf(["Point","MultiPoint","LineString","MultiLineString","Polygon","MultiPolygon","Box","GeometryCollection"],obj.type)==-1){OpenLayers.Console.error("Unsupported geometry type: "+
-obj.type);}else{valid=true;}
-break;case"FeatureCollection":valid=true;break;default:if(obj.type==type){valid=true;}else{OpenLayers.Console.error("Cannot convert types from "+
-obj.type+" to "+type);}}
-return valid;},parseFeature:function(obj){var feature,geometry,attributes;attributes=(obj.properties)?obj.properties:{};try{geometry=this.parseGeometry(obj.geometry);}catch(err){throw err;}
-feature=new OpenLayers.Feature.Vector(geometry,attributes);if(obj.id){feature.fid=obj.id;}
-return feature;},parseGeometry:function(obj){var geometry;if(obj.type=="GeometryCollection"){if(!(obj.geometries instanceof Array)){throw"GeometryCollection must have geometries array: "+obj;}
-var numGeom=obj.geometries.length;var components=new Array(numGeom);for(var i=0;i<numGeom;++i){components[i]=this.parseGeometry.apply(this,[obj.geometries[i]]);}
-geometry=new OpenLayers.Geometry.Collection(components);}else{if(!(obj.coordinates instanceof Array)){throw"Geometry must have coordinates array: "+obj;}
-if(!this.parseCoords[obj.type.toLowerCase()]){throw"Unsupported geometry type: "+obj.type;}
-try{geometry=this.parseCoords[obj.type.toLowerCase()].apply(this,[obj.coordinates]);}catch(err){throw err;}}
-if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},parseCoords:{"point":function(array){if(array.length!=2){throw"Only 2D points are supported: "+array;}
-return new OpenLayers.Geometry.Point(array[0],array[1]);},"multipoint":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.MultiPoint(points);},"linestring":function(array){var points=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["point"].apply(this,[array[i]]);}catch(err){throw err;}
-points.push(p);}
-return new OpenLayers.Geometry.LineString(points);},"multilinestring":function(array){var lines=[];var l=null;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-lines.push(l);}
-return new OpenLayers.Geometry.MultiLineString(lines);},"polygon":function(array){var rings=[];var r,l;for(var i=0;i<array.length;++i){try{l=this.parseCoords["linestring"].apply(this,[array[i]]);}catch(err){throw err;}
-r=new OpenLayers.Geometry.LinearRing(l.components);rings.push(r);}
-return new OpenLayers.Geometry.Polygon(rings);},"multipolygon":function(array){var polys=[];var p=null;for(var i=0;i<array.length;++i){try{p=this.parseCoords["polygon"].apply(this,[array[i]]);}catch(err){throw err;}
-polys.push(p);}
-return new OpenLayers.Geometry.MultiPolygon(polys);},"box":function(array){if(array.length!=2){throw"GeoJSON box coordinates must have 2 elements";}
-return new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing([new OpenLayers.Geometry.Point(array[0][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[0][1]),new OpenLayers.Geometry.Point(array[1][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[1][1]),new OpenLayers.Geometry.Point(array[0][0],array[0][1])])]);}},write:function(obj,pretty){var geojson={"type":null};if(obj instanceof Array){geojson.type="FeatureCollection";var numFeatures=obj.length;geojson.features=new Array(numFeatures);for(var i=0;i<numFeatures;++i){var element=obj[i];if(!element instanceof OpenLayers.Feature.Vector){var msg="FeatureCollection only supports collections "+"of features: "+element;throw msg;}
-geojson.features[i]=this.extract.feature.apply(this,[element]);}}else if(obj.CLASS_NAME.indexOf("OpenLayers.Geometry")==0){geojson=this.extract.geometry.apply(this,[obj]);}else if(obj instanceof OpenLayers.Feature.Vector){geojson=this.extract.feature.apply(this,[obj]);if(obj.layer&&obj.layer.projection){geojson.crs=this.createCRSObject(obj);}}
-return OpenLayers.Format.JSON.prototype.write.apply(this,[geojson,pretty]);},createCRSObject:function(object){var proj=object.layer.projection.toString();var crs={};if(proj.match(/epsg:/i)){var code=parseInt(proj.substring(proj.indexOf(":")+1));if(code==4326){crs={"type":"OGC","properties":{"urn":"urn:ogc:def:crs:OGC:1.3:CRS84"}};}else{crs={"type":"EPSG","properties":{"code":code}};}}
-return crs;},extract:{'feature':function(feature){var geom=this.extract.geometry.apply(this,[feature.geometry]);return{"type":"Feature","id":feature.fid==null?feature.id:feature.fid,"properties":feature.attributes,"geometry":geom};},'geometry':function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var geometryType=geometry.CLASS_NAME.split('.')[2];var data=this.extract[geometryType.toLowerCase()].apply(this,[geometry]);var json;if(geometryType=="Collection"){json={"type":"GeometryCollection","geometries":data};}else{json={"type":geometryType,"coordinates":data};}
-return json;},'point':function(point){return[point.x,point.y];},'multipoint':function(multipoint){var array=[];for(var i=0;i<multipoint.components.length;++i){array.push(this.extract.point.apply(this,[multipoint.components[i]]));}
-return array;},'linestring':function(linestring){var array=[];for(var i=0;i<linestring.components.length;++i){array.push(this.extract.point.apply(this,[linestring.components[i]]));}
-return array;},'multilinestring':function(multilinestring){var array=[];for(var i=0;i<multilinestring.components.length;++i){array.push(this.extract.linestring.apply(this,[multilinestring.components[i]]));}
-return array;},'polygon':function(polygon){var array=[];for(var i=0;i<polygon.components.length;++i){array.push(this.extract.linestring.apply(this,[polygon.components[i]]));}
-return array;},'multipolygon':function(multipolygon){var array=[];for(var i=0;i<multipolygon.components.length;++i){array.push(this.extract.polygon.apply(this,[multipolygon.components[i]]));}
-return array;},'collection':function(collection){var len=collection.components.length;var array=new Array(len);for(var i=0;i<len;++i){array[i]=this.extract.geometry.apply(this,[collection.components[i]]);}
-return array;}},CLASS_NAME:"OpenLayers.Format.GeoJSON"});OpenLayers.Format.GeoRSS=OpenLayers.Class(OpenLayers.Format.XML,{rssns:"http://backend.userland.com/rss2",featureNS:"http://mapserver.gis.umn.edu/mapserver",georssns:"http://www.georss.org/georss",geons:"http://www.w3.org/2003/01/geo/wgs84_pos#",featureTitle:"Untitled",featureDescription:"No Description",gmlParser:null,xy:false,initialize:function(options){OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},createGeometryFromItem:function(item){var point=this.getElementsByTagNameNS(item,this.georssns,"point");var lat=this.getElementsByTagNameNS(item,this.geons,'lat');var lon=this.getElementsByTagNameNS(item,this.geons,'long');var line=this.getElementsByTagNameNS(item,this.georssns,"line");var polygon=this.getElementsByTagNameNS(item,this.georssns,"polygon");var where=this.getElementsByTagNameNS(item,this.georssns,"where");if(point.length>0||(lat.length>0&&lon.length>0)){var location;if(point.length>0){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s+/);if(location.length!=2){location=OpenLayers.String.trim(point[0].firstChild.nodeValue).split(/\s*,\s*/);}}else{location=[parseFloat(lat[0].firstChild.nodeValue),parseFloat(lon[0].firstChild.nodeValue)];}
-var geometry=new OpenLayers.Geometry.Point(parseFloat(location[1]),parseFloat(location[0]));}else if(line.length>0){var coords=OpenLayers.String.trim(line[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.LineString(components);}else if(polygon.length>0){var coords=OpenLayers.String.trim(polygon[0].firstChild.nodeValue).split(/\s+/);var components=[];var point;for(var i=0;i<coords.length;i+=2){point=new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),parseFloat(coords[i]));components.push(point);}
-geometry=new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);}else if(where.length>0){if(!this.gmlParser){this.gmlParser=new OpenLayers.Format.GML({'xy':this.xy});}
-var feature=this.gmlParser.parseFeature(where[0]);geometry=feature.geometry;}
-if(geometry&&this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}
-return geometry;},createFeatureFromItem:function(item){var geometry=this.createGeometryFromItem(item);var title=this.getChildValue(item,"*","title",this.featureTitle);var description=this.getChildValue(item,"*","description",this.getChildValue(item,"*","content",this.featureDescription));var link=this.getChildValue(item,"*","link");if(!link){try{link=this.getElementsByTagNameNS(item,"*","link")[0].getAttribute("href");}catch(e){link=null;}}
-var id=this.getChildValue(item,"*","id",null);var data={"title":title,"description":description,"link":link};var feature=new OpenLayers.Feature.Vector(geometry,data);feature.fid=id;return feature;},getChildValue:function(node,nsuri,name,def){var value;try{value=this.getElementsByTagNameNS(node,nsuri,name)[0].firstChild.nodeValue;}catch(e){value=(def==undefined)?"":def;}
-return value;},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var itemlist=null;itemlist=this.getElementsByTagNameNS(doc,'*','item');if(itemlist.length==0){itemlist=this.getElementsByTagNameNS(doc,'*','entry');}
-var numItems=itemlist.length;var features=new Array(numItems);for(var i=0;i<numItems;i++){features[i]=this.createFeatureFromItem(itemlist[i]);}
-return features;},write:function(features){var georss;if(features instanceof Array){georss=this.createElementNS(this.rssns,"rss");for(var i=0;i<features.length;i++){georss.appendChild(this.createFeatureXML(features[i]));}}else{georss=this.createFeatureXML(features);}
-return OpenLayers.Format.XML.prototype.write.apply(this,[georss]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var featureNode=this.createElementNS(this.rssns,"item");var titleNode=this.createElementNS(this.rssns,"title");titleNode.appendChild(this.createTextNode(feature.attributes.title?feature.attributes.title:""));var descNode=this.createElementNS(this.rssns,"description");descNode.appendChild(this.createTextNode(feature.attributes.description?feature.attributes.description:""));featureNode.appendChild(titleNode);featureNode.appendChild(descNode);if(feature.attributes.link){var linkNode=this.createElementNS(this.rssns,"link");linkNode.appendChild(this.createTextNode(feature.attributes.link));featureNode.appendChild(linkNode);}
-for(var attr in feature.attributes){if(attr=="link"||attr=="title"||attr=="description"){continue;}
-var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureNode.appendChild(attrContainer);}
-featureNode.appendChild(geometryNode);return featureNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var node;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Polygon"){node=this.createElementNS(this.georssns,'georss:polygon');node.appendChild(this.buildCoordinatesNode(geometry.components[0]));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){node=this.createElementNS(this.georssns,'georss:line');node.appendChild(this.buildCoordinatesNode(geometry));}
-else if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){node=this.createElementNS(this.georssns,'georss:point');node.appendChild(this.buildCoordinatesNode(geometry));}else{throw"Couldn't parse "+geometry.CLASS_NAME;}
-return node;},buildCoordinatesNode:function(geometry){var points=null;if(geometry.components){points=geometry.components;}
-var path;if(points){var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;i++){parts[i]=points[i].y+" "+points[i].x;}
-path=parts.join(" ");}else{path=geometry.y+" "+geometry.x;}
-return this.createTextNode(path);},CLASS_NAME:"OpenLayers.Format.GeoRSS"});OpenLayers.Format.KML=OpenLayers.Class(OpenLayers.Format.XML,{kmlns:"http://earth.google.com/kml/2.0",placemarksDesc:"No description available",foldersName:"OpenLayers export",foldersDesc:"Exported on "+new Date(),extractAttributes:true,extractStyles:false,internalns:null,features:null,styles:null,styleBaseUrl:"",fetched:null,maxDepth:0,initialize:function(options){this.regExes={trimSpace:(/^\s*|\s*$/g),removeSpace:(/\s*/g),splitSpace:(/\s+/),trimComma:(/\s*,\s*/g),kmlColor:(/(\w{2})(\w{2})(\w{2})(\w{2})/),kmlIconPalette:(/root:\/\/icons\/palette-(\d+)(\.\w+)/),straightBracket:(/\$\[(.*?)\]/g)};OpenLayers.Format.XML.prototype.initialize.apply(this,[options]);},read:function(data){this.features=[];this.styles={};this.fetched={};var options={depth:this.maxDepth,styleBaseUrl:this.styleBaseUrl};return this.parseData(data,options);},parseData:function(data,options){if(typeof data=="string"){data=OpenLayers.Format.XML.prototype.read.apply(this,[data]);}
-var types=["Link","NetworkLink","Style","StyleMap","Placemark"];for(var i=0;i<types.length;++i){var type=types[i];var nodes=this.getElementsByTagNameNS(data,"*",type);if(nodes.length==0){continue;}
-switch(type.toLowerCase()){case"link":case"networklink":this.parseLinks(nodes,options);break;case"style":if(this.extractStyles){this.parseStyles(nodes,options);}
-break;case"stylemap":if(this.extractStyles){this.parseStyleMaps(nodes,options);}
-break;case"placemark":this.parseFeatures(nodes,options);break;}}
-return this.features;},parseLinks:function(nodes,options){if(options.depth>=this.maxDepth){return false;}
-var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;for(var i=0;i<nodes.length;i++){var href=this.parseProperty(nodes[i],"*","href");if(href&&!this.fetched[href]){this.fetched[href]=true;var data=this.fetchLink(href);if(data){this.parseData(data,newOptions);}}}},fetchLink:function(href){var request=new OpenLayers.Ajax.Request(href,{method:'get',asynchronous:false});if(request&&request.transport){return request.transport.responseText;}},parseStyles:function(nodes,options){for(var i=0;i<nodes.length;i++){var style=this.parseStyle(nodes[i]);if(style){styleName=(options.styleBaseUrl||"")+"#"+style.id;this.styles[styleName]=style;}}},parseStyle:function(node){var style={};var types=["LineStyle","PolyStyle","IconStyle","BalloonStyle"];var type,nodeList,geometry,parser;for(var i=0;i<types.length;++i){type=types[i];styleTypeNode=this.getElementsByTagNameNS(node,"*",type)[0];if(!styleTypeNode){continue;}
-switch(type.toLowerCase()){case"linestyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["strokeOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["strokeColor"]="#"+r+g+b;}
-var width=this.parseProperty(styleTypeNode,"*","width");if(width){style["strokeWidth"]=width;}
-case"polystyle":var color=this.parseProperty(styleTypeNode,"*","color");if(color){var matches=(color.toString()).match(this.regExes.kmlColor);var alpha=matches[1];style["fillOpacity"]=parseInt(alpha,16)/255;var b=matches[2];var g=matches[3];var r=matches[4];style["fillColor"]="#"+r+g+b;}
-break;case"iconstyle":var scale=parseFloat(this.parseProperty(styleTypeNode,"*","scale")||1);var width=32*scale;var height=32*scale;var iconNode=this.getElementsByTagNameNS(styleTypeNode,"*","Icon")[0];if(iconNode){var href=this.parseProperty(iconNode,"*","href");if(href){var w=this.parseProperty(iconNode,"*","w");var h=this.parseProperty(iconNode,"*","h");var google="http://maps.google.com/mapfiles/kml";if(OpenLayers.String.startsWith(href,google)&&!w&&!h){w=64;h=64;scale=scale/2;}
-w=w||h;h=h||w;if(w){width=parseInt(w)*scale;}
-if(h){height=parseInt(h)*scale;}
-var matches=href.match(this.regExes.kmlIconPalette);if(matches){var palette=matches[1];var file_extension=matches[2];var x=this.parseProperty(iconNode,"*","x");var y=this.parseProperty(iconNode,"*","y");var posX=x?x/32:0;var posY=y?(7-y/32):7;var pos=posY*8+posX;href="http://maps.google.com/mapfiles/kml/pal"
-+palette+"/icon"+pos+file_extension;}
-style["graphicOpacity"]=1;style["externalGraphic"]=href;}}
-var hotSpotNode=this.getElementsByTagNameNS(styleTypeNode,"*","hotSpot")[0];if(hotSpotNode){var x=parseFloat(hotSpotNode.getAttribute("x"));var y=parseFloat(hotSpotNode.getAttribute("y"));var xUnits=hotSpotNode.getAttribute("xunits");if(xUnits=="pixels"){style["graphicXOffset"]=-x*scale;}
-else if(xUnits=="insetPixels"){style["graphicXOffset"]=-width+(x*scale);}
-else if(xUnits=="fraction"){style["graphicXOffset"]=-width*x;}
-var yUnits=hotSpotNode.getAttribute("yunits");if(yUnits=="pixels"){style["graphicYOffset"]=-height+(y*scale)+1;}
-else if(yUnits=="insetPixels"){style["graphicYOffset"]=-(y*scale)+1;}
-else if(yUnits=="fraction"){style["graphicYOffset"]=-height*(1-y)+1;}}
-style["graphicWidth"]=width;style["graphicHeight"]=height;break;case"balloonstyle":var balloonStyle=OpenLayers.Util.getXmlNodeValue(styleTypeNode);if(balloonStyle){style["balloonStyle"]=balloonStyle.replace(this.regExes.straightBracket,"${$1}");}
-break;default:}}
-if(!style["strokeColor"]&&style["fillColor"]){style["strokeColor"]=style["fillColor"];}
-var id=node.getAttribute("id");if(id&&style){style.id=id;}
-return style;},parseStyleMaps:function(nodes,options){for(var i=0;i<nodes.length;i++){var node=nodes[i];var pairs=this.getElementsByTagNameNS(node,"*","Pair");var id=node.getAttribute("id");for(var j=0;j<pairs.length;j++){var pair=pairs[j];var key=this.parseProperty(pair,"*","key");var styleUrl=this.parseProperty(pair,"*","styleUrl");if(styleUrl&&key=="normal"){this.styles[(options.styleBaseUrl||"")+"#"+id]=this.styles[(options.styleBaseUrl||"")+styleUrl];}
-if(styleUrl&&key=="highlight"){}}}},parseFeatures:function(nodes,options){var features=new Array(nodes.length);for(var i=0;i<nodes.length;i++){var featureNode=nodes[i];var feature=this.parseFeature.apply(this,[featureNode]);if(feature){if(this.extractStyles&&feature.attributes&&feature.attributes.styleUrl){feature.style=this.getStyle(feature.attributes.styleUrl);}
-var inlineStyleNode=this.getElementsByTagNameNS(featureNode,"*","Style")[0];if(inlineStyleNode){var inlineStyle=this.parseStyle(inlineStyleNode);if(inlineStyle){feature.style=OpenLayers.Util.extend({},feature.style);OpenLayers.Util.extend(feature.style,inlineStyle);}}
-features[i]=feature;}else{throw"Bad Placemark: "+i;}}
-this.features=this.features.concat(features);},parseFeature:function(node){var order=["MultiGeometry","Polygon","LineString","Point"];var type,nodeList,geometry,parser;for(var i=0;i<order.length;++i){type=order[i];this.internalns=node.namespaceURI?node.namespaceURI:this.kmlns;nodeList=this.getElementsByTagNameNS(node,this.internalns,type);if(nodeList.length>0){var parser=this.parseGeometry[type.toLowerCase()];if(parser){geometry=parser.apply(this,[nodeList[0]]);if(this.internalProjection&&this.externalProjection){geometry.transform(this.externalProjection,this.internalProjection);}}else{OpenLayers.Console.error(OpenLayers.i18n("unsupportedGeometryType",{'geomType':type}));}
-break;}}
-var feature=new OpenLayers.Feature.Vector(geometry,attributes);var fid=node.getAttribute("id")||node.getAttribute("name");if(fid!=null){feature.fid=fid;}
-return feature;},getStyle:function(styleUrl,options){var styleBaseUrl=OpenLayers.Util.removeTail(styleUrl);var newOptions=OpenLayers.Util.extend({},options);newOptions.depth++;newOptions.styleBaseUrl=styleBaseUrl;if(!this.styles[styleUrl]&&!OpenLayers.String.startsWith(styleUrl,"#")&&newOptions.depth<=this.maxDepth&&!this.fetched[styleBaseUrl]){var data=this.fetchLink(styleBaseUrl);if(data){this.parseData(data,newOptions);}}
-var style=this.styles[styleUrl];return style;},parseGeometry:{point:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var coords=[];if(nodeList.length>0){var coordString=nodeList[0].firstChild.nodeValue;coordString=coordString.replace(this.regExes.removeSpace,"");coords=coordString.split(",");}
-var point=null;if(coords.length>1){if(coords.length==2){coords[2]=null;}
-point=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad coordinate string: "+coordString;}
-return point;},linestring:function(node,ring){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"coordinates");var line=null;if(nodeList.length>0){var coordString=this.concatChildValues(nodeList[0]);coordString=coordString.replace(this.regExes.trimSpace,"");coordString=coordString.replace(this.regExes.trimComma,",");var pointList=coordString.split(this.regExes.splitSpace);var numPoints=pointList.length;var points=new Array(numPoints);var coords,numCoords;for(var i=0;i<numPoints;++i){coords=pointList[i].split(",");numCoords=coords.length;if(numCoords>1){if(coords.length==2){coords[2]=null;}
-points[i]=new OpenLayers.Geometry.Point(coords[0],coords[1],coords[2]);}else{throw"Bad LineString point coordinates: "+
-pointList[i];}}
-if(numPoints){if(ring){line=new OpenLayers.Geometry.LinearRing(points);}else{line=new OpenLayers.Geometry.LineString(points);}}else{throw"Bad LineString coordinates: "+coordString;}}
-return line;},polygon:function(node){var nodeList=this.getElementsByTagNameNS(node,this.internalns,"LinearRing");var numRings=nodeList.length;var components=new Array(numRings);if(numRings>0){var ring;for(var i=0;i<nodeList.length;++i){ring=this.parseGeometry.linestring.apply(this,[nodeList[i],true]);if(ring){components[i]=ring;}else{throw"Bad LinearRing geometry: "+i;}}}
-return new OpenLayers.Geometry.Polygon(components);},multigeometry:function(node){var child,parser;var parts=[];var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){var type=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var parser=this.parseGeometry[type.toLowerCase()];if(parser){parts.push(parser.apply(this,[child]));}}}
-return new OpenLayers.Geometry.Collection(parts);}},parseAttributes:function(node){var attributes={};var child,grandchildren,grandchild;var children=node.childNodes;for(var i=0;i<children.length;++i){child=children[i];if(child.nodeType==1){grandchildren=child.childNodes;if(grandchildren.length==1||grandchildren.length==3){var grandchild;switch(grandchildren.length){case 1:grandchild=grandchildren[0];break;case 3:default:grandchild=grandchildren[1];break;}
-if(grandchild.nodeType==3||grandchild.nodeType==4){var name=(child.prefix)?child.nodeName.split(":")[1]:child.nodeName;var value=OpenLayers.Util.getXmlNodeValue(grandchild);if(value){value=value.replace(this.regExes.trimSpace,"");attributes[name]=value;}}}}}
-return attributes;},parseProperty:function(xmlNode,namespace,tagName){var value;var nodeList=this.getElementsByTagNameNS(xmlNode,namespace,tagName);try{value=OpenLayers.Util.getXmlNodeValue(nodeList[0]);}catch(e){value=null;}
-return value;},write:function(features){if(!(features instanceof Array)){features=[features];}
-var kml=this.createElementNS(this.kmlns,"kml");var folder=this.createFolderXML();for(var i=0;i<features.length;++i){folder.appendChild(this.createPlacemarkXML(features[i]));}
-kml.appendChild(folder);return OpenLayers.Format.XML.prototype.write.apply(this,[kml]);},createFolderXML:function(){var folderName=this.createElementNS(this.kmlns,"name");var folderNameText=this.createTextNode(this.foldersName);folderName.appendChild(folderNameText);var folderDesc=this.createElementNS(this.kmlns,"description");var folderDescText=this.createTextNode(this.foldersDesc);folderDesc.appendChild(folderDescText);var folder=this.createElementNS(this.kmlns,"Folder");folder.appendChild(folderName);folder.appendChild(folderDesc);return folder;},createPlacemarkXML:function(feature){var placemarkName=this.createElementNS(this.kmlns,"name");var name=(feature.attributes.name)?feature.attributes.name:feature.id;placemarkName.appendChild(this.createTextNode(name));var placemarkDesc=this.createElementNS(this.kmlns,"description");var desc=(feature.attributes.description)?feature.attributes.description:this.placemarksDesc;placemarkDesc.appendChild(this.createTextNode(desc));var placemarkNode=this.createElementNS(this.kmlns,"Placemark");if(feature.fid!=null){placemarkNode.setAttribute("id",feature.fid);}
-placemarkNode.appendChild(placemarkName);placemarkNode.appendChild(placemarkDesc);var geometryNode=this.buildGeometryNode(feature.geometry);placemarkNode.appendChild(geometryNode);return placemarkNode;},buildGeometryNode:function(geometry){if(this.internalProjection&&this.externalProjection){geometry=geometry.clone();geometry.transform(this.internalProjection,this.externalProjection);}
-var className=geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);var builder=this.buildGeometry[type.toLowerCase()];var node=null;if(builder){node=builder.apply(this,[geometry]);}
-return node;},buildGeometry:{point:function(geometry){var kml=this.createElementNS(this.kmlns,"Point");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multipoint:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linestring:function(geometry){var kml=this.createElementNS(this.kmlns,"LineString");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},multilinestring:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},linearring:function(geometry){var kml=this.createElementNS(this.kmlns,"LinearRing");kml.appendChild(this.buildCoordinatesNode(geometry));return kml;},polygon:function(geometry){var kml=this.createElementNS(this.kmlns,"Polygon");var rings=geometry.components;var ringMember,ringGeom,type;for(var i=0;i<rings.length;++i){type=(i==0)?"outerBoundaryIs":"innerBoundaryIs";ringMember=this.createElementNS(this.kmlns,type);ringGeom=this.buildGeometry.linearring.apply(this,[rings[i]]);ringMember.appendChild(ringGeom);kml.appendChild(ringMember);}
-return kml;},multipolygon:function(geometry){return this.buildGeometry.collection.apply(this,[geometry]);},collection:function(geometry){var kml=this.createElementNS(this.kmlns,"MultiGeometry");var child;for(var i=0;i<geometry.components.length;++i){child=this.buildGeometryNode.apply(this,[geometry.components[i]]);if(child){kml.appendChild(child);}}
-return kml;}},buildCoordinatesNode:function(geometry){var coordinatesNode=this.createElementNS(this.kmlns,"coordinates");var path;var points=geometry.components;if(points){var point;var numPoints=points.length;var parts=new Array(numPoints);for(var i=0;i<numPoints;++i){point=points[i];parts[i]=point.x+","+point.y;}
-path=parts.join(" ");}else{path=geometry.x+","+geometry.y;}
-var txtNode=this.createTextNode(path);coordinatesNode.appendChild(txtNode);return coordinatesNode;},CLASS_NAME:"OpenLayers.Format.KML"});OpenLayers.Format.OSM=OpenLayers.Class(OpenLayers.Format.XML,{checkTags:false,interestingTagsExclude:null,areaTags:null,initialize:function(options){var layer_defaults={'interestingTagsExclude':['source','source_ref','source:ref','history','attribution','created_by'],'areaTags':['area','building','leisure','tourism','ruins','historic','landuse','military','natural','sport']};layer_defaults=OpenLayers.Util.extend(layer_defaults,options);var interesting={};for(var i=0;i<layer_defaults.interestingTagsExclude.length;i++){interesting[layer_defaults.interestingTagsExclude[i]]=true;}
-layer_defaults.interestingTagsExclude=interesting;var area={};for(var i=0;i<layer_defaults.areaTags.length;i++){area[layer_defaults.areaTags[i]]=true;}
-layer_defaults.areaTags=area;OpenLayers.Format.XML.prototype.initialize.apply(this,[layer_defaults]);},read:function(doc){if(typeof doc=="string"){doc=OpenLayers.Format.XML.prototype.read.apply(this,[doc]);}
-var nodes=this.getNodes(doc);var ways=this.getWays(doc);var feat_list=new Array(ways.length);for(var i=0;i<ways.length;i++){var point_list=new Array(ways[i].nodes.length);var poly=this.isWayArea(ways[i])?1:0;for(var j=0;j<ways[i].nodes.length;j++){var node=nodes[ways[i].nodes[j]];var point=new OpenLayers.Geometry.Point(node.lon,node.lat);point.osm_id=parseInt(ways[i].nodes[j]);point_list[j]=point;node.used=true;}
-var geometry=null;if(poly){geometry=new OpenLayers.Geometry.Polygon(new OpenLayers.Geometry.LinearRing(point_list));}else{geometry=new OpenLayers.Geometry.LineString(point_list);}
-var feat=new OpenLayers.Feature.Vector(geometry,ways[i].tags);feat.osm_id=parseInt(ways[i].id);feat.fid="way."+feat.osm_id;feat_list[i]=feat;}
-for(var node_id in nodes){var node=nodes[node_id];if(!node.used||this.checkTags){var tags=null;if(this.checkTags){var result=this.getTags(node.node,true);if(node.used&&!result[1]){continue;}
-tags=result[0];}else{tags=this.getTags(node.node);}
-var feat=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point(node['lon'],node['lat']),tags);if(this.internalProjection&&this.externalProjection){feat.geometry.transform(this.externalProjection,this.internalProjection);}
-feat.osm_id=parseInt(node_id);feat.fid="node."+feat.osm_id;feat_list.push(feat);}
-node.node=null;}
-return feat_list;},getNodes:function(doc){var node_list=doc.getElementsByTagName("node");var nodes={};for(var i=0;i<node_list.length;i++){var node=node_list[i];var id=node.getAttribute("id");nodes[id]={'lat':node.getAttribute("lat"),'lon':node.getAttribute("lon"),'node':node};}
-return nodes;},getWays:function(doc){var way_list=doc.getElementsByTagName("way");var return_ways=[];for(var i=0;i<way_list.length;i++){var way=way_list[i];var way_object={id:way.getAttribute("id")};way_object.tags=this.getTags(way);var node_list=way.getElementsByTagName("nd");way_object.nodes=new Array(node_list.length);for(var j=0;j<node_list.length;j++){way_object.nodes[j]=node_list[j].getAttribute("ref");}
-return_ways.push(way_object);}
-return return_ways;},getTags:function(dom_node,interesting_tags){var tag_list=dom_node.getElementsByTagName("tag");var tags={};var interesting=false;for(var j=0;j<tag_list.length;j++){var key=tag_list[j].getAttribute("k");tags[key]=tag_list[j].getAttribute("v");if(interesting_tags){if(!this.interestingTagsExclude[key]){interesting=true;}}}
-return interesting_tags?[tags,interesting]:tags;},isWayArea:function(way){var poly_shaped=false;var poly_tags=false;if(way.nodes[0]==way.nodes[way.nodes.length-1]){poly_shaped=true;}
-if(this.checkTags){for(var key in way.tags){if(this.areaTags[key]){poly_tags=true;break;}}}
-return poly_shaped&&(this.checkTags?poly_tags:true);},write:function(features){if(!(features instanceof Array)){features=[features];}
-this.osm_id=1;this.created_nodes={};var root_node=this.createElementNS(null,"osm");root_node.setAttribute("version","0.5");root_node.setAttribute("generator","OpenLayers "+OpenLayers.VERSION_NUMBER);for(var i=features.length-1;i>=0;i--){var nodes=this.createFeatureNodes(features[i]);for(var j=0;j<nodes.length;j++){root_node.appendChild(nodes[j]);}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[root_node]);},createFeatureNodes:function(feature){var nodes=[];var className=feature.geometry.CLASS_NAME;var type=className.substring(className.lastIndexOf(".")+1);type=type.toLowerCase();var builder=this.createXML[type];if(builder){nodes=builder.apply(this,[feature]);}
-return nodes;},createXML:{'point':function(point){var id=null;var geometry=point.geometry?point.geometry:point;var already_exists=false;if(point.osm_id){id=point.osm_id;if(this.created_nodes[id]){already_exists=true;}}else{id=-this.osm_id;this.osm_id++;}
-if(already_exists){node=this.created_nodes[id];}else{var node=this.createElementNS(null,"node");}
-this.created_nodes[id]=node;node.setAttribute("id",id);node.setAttribute("lon",geometry.x);node.setAttribute("lat",geometry.y);if(point.attributes){this.serializeTags(point,node);}
-this.setState(point,node);return already_exists?[]:[node];},linestring:function(feature){var nodes=[];var geometry=feature.geometry;if(feature.osm_id){id=feature.osm_id;}else{id=-this.osm_id;this.osm_id++;}
-var way=this.createElementNS(null,"way");way.setAttribute("id",id);for(var i=0;i<geometry.components.length;i++){var node=this.createXML['point'].apply(this,[geometry.components[i]]);if(node.length){node=node[0];var node_ref=node.getAttribute("id");nodes.push(node);}else{node_ref=geometry.components[i].osm_id;node=this.created_nodes[node_ref];}
-this.setState(feature,node);var nd_dom=this.createElementNS(null,"nd");nd_dom.setAttribute("ref",node_ref);way.appendChild(nd_dom);}
-this.serializeTags(feature,way);nodes.push(way);return nodes;},polygon:function(feature){var attrs=OpenLayers.Util.extend({'area':'yes'},feature.attributes);var feat=new OpenLayers.Feature.Vector(feature.geometry.components[0],attrs);feat.osm_id=feature.osm_id;return this.createXML['linestring'].apply(this,[feat]);}},serializeTags:function(feature,node){for(var key in feature.attributes){var tag=this.createElementNS(null,"tag");tag.setAttribute("k",key);tag.setAttribute("v",feature.attributes[key]);node.appendChild(tag);}},setState:function(feature,node){if(feature.state){var state=null;switch(feature.state){case OpenLayers.State.UPDATE:state="modify";case OpenLayers.State.DELETE:state="delete";}
-if(state){node.setAttribute("action",state);}}},CLASS_NAME:"OpenLayers.Format.OSM"});OpenLayers.Geometry.LinearRing=OpenLayers.Class(OpenLayers.Geometry.LineString,{componentTypes:["OpenLayers.Geometry.Point"],initialize:function(points){OpenLayers.Geometry.LineString.prototype.initialize.apply(this,arguments);},addComponent:function(point,index){var added=false;var lastPoint=this.components.pop();if(index!=null||!point.equals(lastPoint)){added=OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,arguments);}
-var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);return added;},removeComponent:function(point){if(this.components.length>4){this.components.pop();OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,arguments);var firstPoint=this.components[0];OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,[firstPoint]);}},move:function(x,y){for(var i=0;i<this.components.length-1;i++){this.components[i].move(x,y);}},rotate:function(angle,origin){for(var i=0;i<this.components.length-1;++i){this.components[i].rotate(angle,origin);}},resize:function(scale,origin,ratio){for(var i=0;i<this.components.length-1;++i){this.components[i].resize(scale,origin,ratio);}},transform:function(source,dest){if(source&&dest){for(var i=0;i<this.components.length-1;i++){var component=this.components[i];component.transform(source,dest);}}
-return this;},getArea:function(){var area=0.0;if(this.components&&(this.components.length>2)){var sum=0.0;for(var i=0;i<this.components.length-1;i++){var b=this.components[i];var c=this.components[i+1];sum+=(b.x+c.x)*(c.y-b.y);}
-area=-sum/2.0;}
-return area;},containsPoint:function(point){var approx=OpenLayers.Number.limitSigDigs;var digs=14;var px=approx(point.x,digs);var py=approx(point.y,digs);function getX(y,x1,y1,x2,y2){return(((x1-x2)*y)+((x2*y1)-(x1*y2)))/(y1-y2);}
-var numSeg=this.components.length-1;var start,end,x1,y1,x2,y2,cx,cy;var crosses=0;for(var i=0;i<numSeg;++i){start=this.components[i];x1=approx(start.x,digs);y1=approx(start.y,digs);end=this.components[i+1];x2=approx(end.x,digs);y2=approx(end.y,digs);if(y1==y2){if(py==y1){if(x1<=x2&&(px>=x1&&px<=x2)||x1>=x2&&(px<=x1&&px>=x2)){crosses=-1;break;}}
-continue;}
-cx=approx(getX(py,x1,y1,x2,y2),digs);if(cx==px){if(y1<y2&&(py>=y1&&py<=y2)||y1>y2&&(py<=y1&&py>=y2)){crosses=-1;break;}}
-if(cx<=px){continue;}
-if(x1!=x2&&(cx<Math.min(x1,x2)||cx>Math.max(x1,x2))){continue;}
-if(y1<y2&&(py>=y1&&py<y2)||y1>y2&&(py<y1&&py>=y2)){++crosses;}}
-var contained=(crosses==-1)?1:!!(crosses&1);return contained;},intersects:function(geometry){var intersect=false;if(geometry.CLASS_NAME=="OpenLayers.Geometry.Point"){intersect=this.containsPoint(geometry);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LineString"){intersect=geometry.intersects(this);}else if(geometry.CLASS_NAME=="OpenLayers.Geometry.LinearRing"){intersect=OpenLayers.Geometry.LineString.prototype.intersects.apply(this,[geometry]);}else{for(var i=0;i<geometry.components.length;++i){intersect=geometry.components[i].intersects(this);if(intersect){break;}}}
-return intersect;},CLASS_NAME:"OpenLayers.Geometry.LinearRing"});OpenLayers.Handler.Path=OpenLayers.Class(OpenLayers.Handler.Point,{line:null,freehand:false,freehandToggle:'shiftKey',initialize:function(control,callbacks,options){OpenLayers.Handler.Point.prototype.initialize.apply(this,arguments);},createFeature:function(){this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LineString());this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);if(this.line){this.line.destroy();}
-this.line=null;},addPoint:function(){this.line.geometry.addComponent(this.point.geometry.clone(),this.line.geometry.components.length);this.callback("point",[this.point.geometry]);},freehandMode:function(evt){return(this.freehandToggle&&evt[this.freehandToggle])?!this.freehand:this.freehand;},modifyFeature:function(){var index=this.line.geometry.components.length-1;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.line,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.line.geometry.clone();},mousedown:function(evt){if(this.lastDown&&this.lastDown.equals(evt.xy)){return false;}
-if(this.lastDown==null){this.createFeature();}
-this.mouseDown=true;this.lastDown=evt.xy;var lonlat=this.control.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if((this.lastUp==null)||!this.lastUp.equals(evt.xy)){this.addPoint();}
-this.drawFeature();this.drawing=true;return false;},mousemove:function(evt){if(this.drawing){var lonlat=this.map.getLonLatFromPixel(evt.xy);this.point.geometry.x=lonlat.lon;this.point.geometry.y=lonlat.lat;if(this.mouseDown&&this.freehandMode(evt)){this.addPoint();}else{this.modifyFeature();}
-this.drawFeature();}
-return true;},mouseup:function(evt){this.mouseDown=false;if(this.drawing){if(this.freehandMode(evt)){this.finalize();}else{if(this.lastUp==null){this.addPoint();}
-this.lastUp=evt.xy;}
-return false;}
-return true;},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-1;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Path"});OpenLayers.Format.WFS=OpenLayers.Class(OpenLayers.Format.GML,{layer:null,wfsns:"http://www.opengis.net/wfs",ogcns:"http://www.opengis.net/ogc",initialize:function(options,layer){OpenLayers.Format.GML.prototype.initialize.apply(this,[options]);this.layer=layer;if(this.layer.featureNS){this.featureNS=this.layer.featureNS;}
-if(this.layer.options.geometry_column){this.geometryName=this.layer.options.geometry_column;}
-if(this.layer.options.typename){this.featureName=this.layer.options.typename;}},write:function(features){var transaction=this.createElementNS(this.wfsns,'wfs:Transaction');transaction.setAttribute("version","1.0.0");transaction.setAttribute("service","WFS");for(var i=0;i<features.length;i++){switch(features[i].state){case OpenLayers.State.INSERT:transaction.appendChild(this.insert(features[i]));break;case OpenLayers.State.UPDATE:transaction.appendChild(this.update(features[i]));break;case OpenLayers.State.DELETE:transaction.appendChild(this.remove(features[i]));break;}}
-return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);},createFeatureXML:function(feature){var geometryNode=this.buildGeometryNode(feature.geometry);var geomContainer=this.createElementNS(this.featureNS,"feature:"+this.geometryName);geomContainer.appendChild(geometryNode);var featureContainer=this.createElementNS(this.featureNS,"feature:"+this.featureName);featureContainer.appendChild(geomContainer);for(var attr in feature.attributes){var attrText=this.createTextNode(feature.attributes[attr]);var nodename=attr;if(attr.search(":")!=-1){nodename=attr.split(":")[1];}
-var attrContainer=this.createElementNS(this.featureNS,"feature:"+nodename);attrContainer.appendChild(attrText);featureContainer.appendChild(attrContainer);}
-return featureContainer;},insert:function(feature){var insertNode=this.createElementNS(this.wfsns,'wfs:Insert');insertNode.appendChild(this.createFeatureXML(feature));return insertNode;},update:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));}
-var updateNode=this.createElementNS(this.wfsns,'wfs:Update');updateNode.setAttribute("typeName",this.layerName);var propertyNode=this.createElementNS(this.wfsns,'wfs:Property');var nameNode=this.createElementNS(this.wfsns,'wfs:Name');var txtNode=this.createTextNode(this.geometryName);nameNode.appendChild(txtNode);propertyNode.appendChild(nameNode);var valueNode=this.createElementNS(this.wfsns,'wfs:Value');var geometryNode=this.buildGeometryNode(feature.geometry);if(feature.layer){geometryNode.setAttribute("srsName",feature.layer.projection.getCode());}
-valueNode.appendChild(geometryNode);propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);for(var propName in feature.attributes){propertyNode=this.createElementNS(this.wfsns,'wfs:Property');nameNode=this.createElementNS(this.wfsns,'wfs:Name');nameNode.appendChild(this.createTextNode(propName));propertyNode.appendChild(nameNode);valueNode=this.createElementNS(this.wfsns,'wfs:Value');valueNode.appendChild(this.createTextNode(feature.attributes[propName]));propertyNode.appendChild(valueNode);updateNode.appendChild(propertyNode);}
-var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);updateNode.appendChild(filterNode);return updateNode;},remove:function(feature){if(!feature.fid){alert(OpenLayers.i18n("noFID"));return false;}
-var deleteNode=this.createElementNS(this.wfsns,'wfs:Delete');deleteNode.setAttribute("typeName",this.layerName);var filterNode=this.createElementNS(this.ogcns,'ogc:Filter');var filterIdNode=this.createElementNS(this.ogcns,'ogc:FeatureId');filterIdNode.setAttribute("fid",feature.fid);filterNode.appendChild(filterIdNode);deleteNode.appendChild(filterNode);return deleteNode;},destroy:function(){this.layer=null;},CLASS_NAME:"OpenLayers.Format.WFS"});OpenLayers.Handler.Polygon=OpenLayers.Class(OpenLayers.Handler.Path,{polygon:null,initialize:function(control,callbacks,options){OpenLayers.Handler.Path.prototype.initialize.apply(this,arguments);},createFeature:function(){this.polygon=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Polygon());this.line=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.LinearRing());this.polygon.geometry.addComponent(this.line.geometry);this.point=new OpenLayers.Feature.Vector(new OpenLayers.Geometry.Point());},destroyFeature:function(){OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);if(this.polygon){this.polygon.destroy();}
-this.polygon=null;},modifyFeature:function(){var index=this.line.geometry.components.length-2;this.line.geometry.components[index].x=this.point.geometry.x;this.line.geometry.components[index].y=this.point.geometry.y;this.line.geometry.components[index].clearBounds();},drawFeature:function(){this.layer.drawFeature(this.polygon,this.style);this.layer.drawFeature(this.point,this.style);},geometryClone:function(){return this.polygon.geometry.clone();},dblclick:function(evt){if(!this.freehandMode(evt)){var index=this.line.geometry.components.length-2;this.line.geometry.removeComponent(this.line.geometry.components[index]);this.finalize();}
-return false;},CLASS_NAME:"OpenLayers.Handler.Polygon"});OpenLayers.Control.EditingToolbar=OpenLayers.Class(OpenLayers.Control.Panel,{initialize:function(layer,options){OpenLayers.Control.Panel.prototype.initialize.apply(this,[options]);this.addControls([new OpenLayers.Control.Navigation()]);var controls=[new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Point,{'displayClass':'olControlDrawFeaturePoint'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Path,{'displayClass':'olControlDrawFeaturePath'}),new OpenLayers.Control.DrawFeature(layer,OpenLayers.Handler.Polygon,{'displayClass':'olControlDrawFeaturePolygon'})];for(var i=0;i<controls.length;i++){controls[i].featureAdded=function(feature){feature.state=OpenLayers.State.INSERT;};}
-this.addControls(controls);},draw:function(){var div=OpenLayers.Control.Panel.prototype.draw.apply(this,arguments);this.activateControl(this.controls[0]);return div;},CLASS_NAME:"OpenLayers.Control.EditingToolbar"});
\ No newline at end of file
+obj=OpenLayers.Layer.Grid.prototype.clone.apply(this,[obj]);return obj;},getURL:function(bounds){bounds=this.adjustBounds(bounds);var imageSize=this.getImageSize();var newParams={'BBOX':this.encodeBBOX?bounds.toBBOX():bounds.toArray(),'WIDTH':imageSize.w,'HEIGHT':imageSize.h};var requestString=this.getFullRequestString(newParams);return requestString;},addTile:function(bounds,position){return new OpenLayers.Tile.Image(this,position,bounds,null,this.tileSize);},mergeNewParams:function(newParams){var upperParams=OpenLayers.Util.upperCaseObject(newParams);var newArguments=[upperParams];return OpenLayers.Layer.Grid.prototype.mergeNewParams.apply(this,newArguments);},getFullRequestString:function(newParams,altUrl){var projectionCode=this.map.getProjection();this.params.SRS=(projectionCode=="none")?null:projectionCode;return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(this,arguments);},CLASS_NAME:"OpenLayers.Layer.WMS"});
Modified: sandbox/olcore/lib/OpenLayers/OpenLayersUncompressed.js
--- sandbox/olcore/lib/OpenLayers/OpenLayersUncompressed.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/OpenLayers/OpenLayersUncompressed.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -43,6 +43,15 @@
+ * Contains XMLHttpRequest.js <http://code.google.com/p/xmlhttprequest/>
+ * Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+ * Licensed under the Apache License, Version 2.0 (the "License");
+ * you may not use this file except in compliance with the License.
+ * You may obtain a copy of the License at
+ * http://www.apache.org/licenses/LICENSE-2.0
     OpenLayers/SingleFile.js
@@ -146,6 +155,8 @@
             "Rico/Corner.js",
             "Rico/Color.js",
             "OpenLayers/Ajax.js",
+            "OpenLayers/Request.js",
+            "OpenLayers/Request/XMLHttpRequest.js",
             "OpenLayers/Events.js",
             "OpenLayers/Projection.js",
             "OpenLayers/Map.js",
@@ -303,7 +314,7 @@
  * Constant: VERSION_NUMBER
-OpenLayers.VERSION_NUMBER="$Revision: 6819 $";
+OpenLayers.VERSION_NUMBER="$Revision: 7335 $";
     OpenLayers/BaseTypes.js
@@ -444,6 +455,31 @@
         return tokens.join("");
+     * Property: OpenLayers.String.numberRegEx
+     * Used to test strings as numbers.
+    numberRegEx: /^([+-]?)(?=\d|\.\d)\d*(\.\d*)?([Ee]([+-]?\d+))?$/,
+     * APIFunction: OpenLayers.String.isNumeric
+     * Determine whether a string contains only a numeric value.
+     * Examples:
+     * (code)
+     * OpenLayers.String.isNumeric("6.02e23") // true
+     * OpenLayers.String.isNumeric("12 dozen") // false
+     * OpenLayers.String.isNumeric("4") // true
+     * OpenLayers.String.isNumeric(" 4 ") // false
+     * (end)
+     * Returns:
+     * {Boolean} String contains only a number.
+    isNumeric: function(value) {
+        return OpenLayers.String.numberRegEx.test(value);
@@ -927,7 +963,8 @@
  * {Object} The destination object.
 OpenLayers.Util.extend = function(destination, source) {
-    if(destination && source) {
+    destination = destination || {};
+    if(source) {
         for(var property in source) {
             var value = source[property];
             if(value !== undefined) {
@@ -1075,10 +1112,9 @@
  * Function: createDiv
  * Creates a new div and optionally set some standard attributes.
  * Null may be passed to each parameter if you do not wish to
- * set a particular attribute.d
+ * set a particular attribute.
+ * Note - zIndex is NOT set on the resulting div.
- * Note: zIndex is NOT set
  * Parameters:
  * id - {String} An identifier for this element.  If no id is
  *               passed an identifier will be created
@@ -1294,8 +1330,8 @@
                                                position, border, sizing,
                                                opacity) {
-    OpenLayers.Util.modifyDOMElement(div, id, px, sz,
-                                     null, null, null, opacity);
+    OpenLayers.Util.modifyDOMElement(div, id, px, sz, position,
+                                     null, null, opacity);
     var img = div.childNodes[0];
@@ -1306,8 +1342,9 @@
                                      "relative", border);
     if (OpenLayers.Util.alphaHack()) {
-        div.style.display = "inline-block";
+        if(div.style.display != "none") {
+            div.style.display = "inline-block";
         if (sizing == null) {
             sizing = "scale";
@@ -1400,7 +1437,7 @@
  *     in place and returned by this function.
 OpenLayers.Util.applyDefaults = function (to, from) {
+    to = to || {};
      * FF/Windows < 2.0.0.13 reports "Illegal operation on WrappedNative
      * prototype object" when calling hawOwnProperty if the source object is an
@@ -1811,7 +1848,7 @@
     'mi': 63360.0,
     'm': 39.3701,
     'km': 39370.1,
-    'dd': 4374754,
+    'dd': 4374754,    //4382659.48474508
     'yd': 36
 OpenLayers.INCHES_PER_UNIT["in"]= OpenLayers.INCHES_PER_UNIT.inches;
@@ -2242,7 +2279,7 @@
 OpenLayers.Util.getRenderedDimensions = function(contentHTML, size) {
-    var w = h = null;
+    var w, h;
     // create temp container div with restricted size
     var container = document.createElement("div");
@@ -2253,9 +2290,11 @@
     //fix a dimension, if specified.
     if (size) {
         if (size.w) {
-            w = container.style.width = size.w;
+            w = size.w;
+            container.style.width = w + "px";
         } else if (size.h) {
-            h = container.style.height = size.h;
+            h = size.h
+            container.style.height = h + "px";
@@ -2352,340 +2391,6 @@
     return scrollbarWidth;
-    Rico/Corner.js
- * This file has been edited substantially from the Rico-released
- * version by the OpenLayers development team.
- *  Copyright 2005 Sabre Airline Solutions
- *  Licensed under the Apache License, Version 2.0 (the "License");
- *  you may not use this file except in compliance with the
- *  License. You may obtain a copy of the License at
- *         http://www.apache.org/licenses/LICENSE-2.0
- * Unless required by applicable law or agreed to in writing, software
- * distributed under the * License is distributed on an "AS IS" BASIS,
- * WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, * either express or
- * implied. See the License for the specific language governing
- * permissions * and limitations under the License.
-OpenLayers.Rico = new Object();
-OpenLayers.Rico.Corner = {
-    round: function(e, options) {
-        e = OpenLayers.Util.getElement(e);
-        this._setOptions(options);
-        var color = this.options.color;
-        if ( this.options.color == "fromElement" ) {
-            color = this._background(e);
-        var bgColor = this.options.bgColor;
-        if ( this.options.bgColor == "fromParent" ) {
-            bgColor = this._background(e.offsetParent);
-        this._roundCornersImpl(e, color, bgColor);
-    /**   This is a helper function to change the background
-    *     color of <div> that has had Rico rounded corners added.
-    *     It seems we cannot just set the background color for the
-    *     outer <div> so each <span> element used to create the
-    *     corners must have its background color set individually.
-    * @param {DOM} theDiv - A child of the outer <div> that was
-    *                        supplied to the `round` method.
-    * @param {String} newColor - The new background color to use.
-    changeColor: function(theDiv, newColor) {
-        theDiv.style.backgroundColor = newColor;
-        var spanElements = theDiv.parentNode.getElementsByTagName("span");
-        for (var currIdx = 0; currIdx < spanElements.length; currIdx++) {
-            spanElements[currIdx].style.backgroundColor = newColor;
-    *     opacity of <div> that has had Rico rounded corners added.
-    *     See changeColor (above) for algorithm explanation
-    * @param {DOM} theDiv A child of the outer <div> that was
-    * @param {int} newOpacity The new opacity to use (0-1).
-    changeOpacity: function(theDiv, newOpacity) {
-        var mozillaOpacity = newOpacity;
-        var ieOpacity = 'alpha(opacity=' + newOpacity * 100 + ')';
-        theDiv.style.opacity = mozillaOpacity;
-        theDiv.style.filter = ieOpacity;
-            spanElements[currIdx].style.opacity = mozillaOpacity;
-            spanElements[currIdx].style.filter = ieOpacity;
-    /** this function takes care of redoing the rico cornering
-    *    you can't just call updateRicoCorners() again and pass it a
-    *    new options string. you have to first remove the divs that
-    *    rico puts on top and below the content div.
-    * @param {Object} options - list of options
-    reRound: function(theDiv, options) {
-        var topRico = theDiv.parentNode.childNodes[0];
-        //theDiv would be theDiv.parentNode.childNodes[1]
-        var bottomRico = theDiv.parentNode.childNodes[2];
-        theDiv.parentNode.removeChild(topRico);
-        theDiv.parentNode.removeChild(bottomRico);
-        this.round(theDiv.parentNode, options);
-   _roundCornersImpl: function(e, color, bgColor) {
-      if(this.options.border) {
-         this._renderBorder(e,bgColor);
-      if(this._isTopRounded()) {
-         this._roundTopCorners(e,color,bgColor);
-      if(this._isBottomRounded()) {
-         this._roundBottomCorners(e,color,bgColor);
-   _renderBorder: function(el,bgColor) {
-      var borderValue = "1px solid " + this._borderColor(bgColor);
-      var borderL = "border-left: "  + borderValue;
-      var borderR = "border-right: " + borderValue;
-      var style   = "style='" + borderL + ";" + borderR +  "'";
-      el.innerHTML = "<div " + style + ">" + el.innerHTML + "</div>";
-   _roundTopCorners: function(el, color, bgColor) {
-      var corner = this._createCorner(bgColor);
-      for(var i=0 ; i < this.options.numSlices ; i++ ) {
-         corner.appendChild(this._createCornerSlice(color,bgColor,i,"top"));
-      el.style.paddingTop = 0;
-      el.insertBefore(corner,el.firstChild);
-   _roundBottomCorners: function(el, color, bgColor) {
-      for(var i=(this.options.numSlices-1) ; i >= 0 ; i-- ) {
-         corner.appendChild(this._createCornerSlice(color,bgColor,i,"bottom"));
-      el.style.paddingBottom = 0;
-      el.appendChild(corner);
-   _createCorner: function(bgColor) {
-      var corner = document.createElement("div");
-      corner.style.backgroundColor = (this._isTransparent() ? "transparent" : bgColor);
-      return corner;
-   _createCornerSlice: function(color,bgColor, n, position) {
-      var slice = document.createElement("span");
-      var inStyle = slice.style;
-      inStyle.backgroundColor = color;
-      inStyle.display  = "block";
-      inStyle.height   = "1px";
-      inStyle.overflow = "hidden";
-      inStyle.fontSize = "1px";
-      var borderColor = this._borderColor(color,bgColor);
-      if ( this.options.border && n == 0 ) {
-         inStyle.borderTopStyle    = "solid";
-         inStyle.borderTopWidth    = "1px";
-         inStyle.borderLeftWidth   = "0px";
-         inStyle.borderRightWidth  = "0px";
-         inStyle.borderBottomWidth = "0px";
-         inStyle.height            = "0px"; // assumes css compliant box model
-         inStyle.borderColor       = borderColor;
-      else if(borderColor) {
-         inStyle.borderStyle = "solid";
-         inStyle.borderWidth = "0px 1px";
-      if ( !this.options.compact && (n == (this.options.numSlices-1)) ) {
-         inStyle.height = "2px";
-      this._setMargin(slice, n, position);
-      this._setBorder(slice, n, position);
-      return slice;
-   _setOptions: function(options) {
-      this.options = {
-         corners : "all",
-         color   : "fromElement",
-         bgColor : "fromParent",
-         blend   : true,
-         border  : false,
-         compact : false
-      OpenLayers.Util.extend(this.options, options || {});
-      this.options.numSlices = this.options.compact ? 2 : 4;
-      if ( this._isTransparent() ) {
-         this.options.blend = false;
-   _whichSideTop: function() {
-      if ( this._hasString(this.options.corners, "all", "top") ) {
-         return "";
-      if ( this.options.corners.indexOf("tl") >= 0 && this.options.corners.indexOf("tr") >= 0 ) {
-         return "";
-      if (this.options.corners.indexOf("tl") >= 0) {
-         return "left";
-      } else if (this.options.corners.indexOf("tr") >= 0) {
-          return "right";
-      return "";
-   _whichSideBottom: function() {
-      if ( this._hasString(this.options.corners, "all", "bottom") ) {
-         return "";
-      if ( this.options.corners.indexOf("bl")>=0 && this.options.corners.indexOf("br")>=0 ) {
-         return "";
-      if(this.options.corners.indexOf("bl") >=0) {
-         return "left";
-      } else if(this.options.corners.indexOf("br")>=0) {
-         return "right";
-      return "";
-   _borderColor : function(color,bgColor) {
-      if ( color == "transparent" ) {
-         return bgColor;
-      } else if ( this.options.border ) {
-         return this.options.border;
-      } else if ( this.options.blend ) {
-         return this._blend( bgColor, color );
-      } else {
-         return "";
-   _setMargin: function(el, n, corners) {
-      var marginSize = this._marginSize(n);
-      var whichSide = corners == "top" ? this._whichSideTop() : this._whichSideBottom();
-      if ( whichSide == "left" ) {
-         el.style.marginLeft = marginSize + "px"; el.style.marginRight = "0px";
-      else if ( whichSide == "right" ) {
-         el.style.marginRight = marginSize + "px"; el.style.marginLeft  = "0px";
-      else {
-         el.style.marginLeft = marginSize + "px"; el.style.marginRight = marginSize + "px";
-   _setBorder: function(el,n,corners) {
-      var borderSize = this._borderSize(n);
-         el.style.borderLeftWidth = borderSize + "px"; el.style.borderRightWidth = "0px";
-         el.style.borderRightWidth = borderSize + "px"; el.style.borderLeftWidth  = "0px";
-      else {
-         el.style.borderLeftWidth = borderSize + "px"; el.style.borderRightWidth = borderSize + "px";
-      if (this.options.border != false) {
-   _marginSize: function(n) {
-         return 0;
-      var marginSizes          = [ 5, 3, 2, 1 ];
-      var blendedMarginSizes   = [ 3, 2, 1, 0 ];
-      var compactMarginSizes   = [ 2, 1 ];
-      var smBlendedMarginSizes = [ 1, 0 ];
-      if ( this.options.compact && this.options.blend ) {
-         return smBlendedMarginSizes[n];
-      } else if ( this.options.compact ) {
-         return compactMarginSizes[n];
-         return blendedMarginSizes[n];
-      } else {
-         return marginSizes[n];
-   _borderSize: function(n) {
-      var transparentBorderSizes = [ 5, 3, 2, 1 ];
-      var blendedBorderSizes     = [ 2, 1, 1, 1 ];
-      var compactBorderSizes     = [ 1, 0 ];
-      var actualBorderSizes      = [ 0, 2, 0, 0 ];
-      if ( this.options.compact && (this.options.blend || this._isTransparent()) ) {
-         return 1;
-         return compactBorderSizes[n];
-         return blendedBorderSizes[n];
-         return actualBorderSizes[n];
-      } else if ( this._isTransparent() ) {
-         return transparentBorderSizes[n];
-      return 0;
-   _hasString: function(str) { for(var i=1 ; i<arguments.length ; i++) if (str.indexOf(arguments[i]) >= 0) { return true; } return false; },
-   _blend: function(c1, c2) { var cc1 = OpenLayers.Rico.Color.createFromHex(c1); cc1.blend(OpenLayers.Rico.Color.createFromHex(c2)); return cc1; },
-   _background: function(el) { try { return OpenLayers.Rico.Color.createColorFromBackground(el).asHex(); } catch(err) { return "#ffffff"; } },
-   _isTransparent: function() { return this.options.color == "transparent"; },
-   _isTopRounded: function() { return this._hasString(this.options.corners, "all", "top", "tl", "tr"); },
-   _isBottomRounded: function() { return this._hasString(this.options.corners, "all", "bottom", "bl", "br"); },
-   _hasSingleTextChild: function(el) { return el.childNodes.length == 1 && el.childNodes[0].nodeType == 3; }
     OpenLayers/Ajax.js
@@ -2693,6 +2398,9 @@
  * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
  * full text of the license. */
+ * @requires OpenLayers/Request/XMLHttpRequest.js
 OpenLayers.ProxyHost = "";
 //OpenLayers.ProxyHost = "examples/proxy.cgi?url=";
@@ -2721,52 +2429,53 @@
-* @param {} request
+ * Function: OpenLayers.nullHandler
+ * @param {} request
 OpenLayers.nullHandler = function(request) {
     alert(OpenLayers.i18n("unhandledRequest", {'statusText':request.statusText}));
  * Function: loadURL
- * Background load a document.
+ * Background load a document.  For more flexibility in using XMLHttpRequest,
+ *     see the <OpenLayers.Request> methods.
  * Parameters:
  * uri - {String} URI of source doc
- * params - {String} Params on get (doesnt seem to work)
+ * params - {String} or {Object} GET params. Either a string in the form
+ *     "?hello=world&foo=bar" (do not forget the leading question mark)
+ *     or an object in the form {'hello': 'world', 'foo': 'bar}
  * caller - {Object} object which gets callbacks
  * onComplete - {Function} Optional callback for success.  The callback
  *     will be called with this set to caller and will receive the request
- *     object as an argument.
+ *     object as an argument.  Note that if you do not specify an onComplete
+ *     function, <OpenLayers.nullHandler> will be called (which pops up an
+ *     alert dialog).
  * onFailure - {Function} Optional callback for failure.  In the event of
  *     a failure, the callback will be called with this set to caller and will
- *     receive the request object as an argument.
+ *     receive the request object as an argument.  Note that if you do not
+ *     specify an onComplete function, <OpenLayers.nullHandler> will be called
+ *     (which pops up an alert dialog).
  * Returns:
- * {XMLHttpRequest}  The request object.  To abort loading, call
- *     request.abort().
+ * {<OpenLayers.Request.XMLHttpRequest>}  The request object. To abort loading,
+ *     call request.abort().
 OpenLayers.loadURL = function(uri, params, caller,
                                   onComplete, onFailure) {
-    var success = (onComplete) ? OpenLayers.Function.bind(onComplete, caller)
-                                : OpenLayers.nullHandler;
-    var failure = (onFailure) ? OpenLayers.Function.bind(onFailure, caller)
-    // from prototype.js
-    var request = new OpenLayers.Ajax.Request(
-        uri,
-            method: 'get',
-            parameters: params,
-            onComplete: success,
-            onFailure: failure
-    return request.transport;
+    if(typeof params == 'string') {
+        params = OpenLayers.Util.getParameters(params);
+    var success = (onComplete) ? onComplete : OpenLayers.nullHandler;
+    var failure = (onFailure) ? onFailure : OpenLayers.nullHandler;
+    return OpenLayers.Request.GET({
+        url: uri, params: params,
+        success: success, failure: failure, scope: caller
@@ -2952,6 +2661,7 @@
  * Class: OpenLayers.Ajax.Request
+ * *Deprecated*.  Use <OpenLayers.Request> method instead.
  * Inherit:
  *  - <OpenLayers.Ajax.Base>
@@ -3361,6 +3071,328 @@
     return data;
+    OpenLayers/Console.js
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+ * Namespace: OpenLayers.Console
+ * The OpenLayers.Console namespace is used for debugging and error logging.
+ * If the Firebug Lite (../Firebug/firebug.js) is included before this script,
+ * calls to OpenLayers.Console methods will get redirected to window.console.
+ * This makes use of the Firebug extension where available and allows for
+ * cross-browser debugging Firebug style.
+ * Note:
+ * Note that behavior will differ with the Firebug extention and Firebug Lite.
+ * Most notably, the Firebug Lite console does not currently allow for
+ * hyperlinks to code or for clicking on object to explore their properties.
+OpenLayers.Console = {
+     * Create empty functions for all console methods.  The real value of these
+     * properties will be set if Firebug Lite (../Firebug/firebug.js script) is
+     * included.  We explicitly require the Firebug Lite script to trigger
+     * functionality of the OpenLayers.Console methods.
+     * APIFunction: log
+     * Log an object in the console.  The Firebug Lite console logs string
+     * representation of objects.  Given multiple arguments, they will
+     * be cast to strings and logged with a space delimiter.  If the first
+     * argument is a string with printf-like formatting, subsequent arguments
+     * will be used in string substitution.  Any additional arguments (beyond
+     * the number substituted in a format string) will be appended in a space-
+     * delimited line.
+     * Parameters:
+     * object - {Object}
+    log: function() {},
+     * APIFunction: debug
+     * Writes a message to the console, including a hyperlink to the line
+     * where it was called.
+     * May be called with multiple arguments as with OpenLayers.Console.log().
+     * Parameters:
+    debug: function() {},
+     * APIFunction: info
+     * Writes a message to the console with the visual "info" icon and color
+     * coding and a hyperlink to the line where it was called.
+     * Parameters:
+    info: function() {},
+     * APIFunction: warn
+     * Writes a message to the console with the visual "warning" icon and
+     * color coding and a hyperlink to the line where it was called.
+     * Parameters:
+    warn: function() {},
+     * APIFunction: error
+     * Writes a message to the console with the visual "error" icon and color
+     * Parameters:
+    error: function() {},
+     * APIFunction: assert
+     * Tests that an expression is true. If not, it will write a message to
+     * the console and throw an exception.
+     * Parameters:
+    assert: function() {},
+     * APIFunction: dir
+     * Prints an interactive listing of all properties of the object. This
+     * looks identical to the view that you would see in the DOM tab.
+     * Parameters:
+    dir: function() {},
+     * APIFunction: dirxml
+     * Prints the XML source tree of an HTML or XML element. This looks
+     * identical to the view that you would see in the HTML tab. You can click
+     * on any node to inspect it in the HTML tab.
+     * Parameters:
+    dirxml: function() {},
+     * APIFunction: trace
+     * Prints an interactive stack trace of JavaScript execution at the point
+     * where it is called.  The stack trace details the functions on the stack,
+     * as well as the values that were passed as arguments to each function.
+     * You can click each function to take you to its source in the Script tab,
+     * and click each argument value to inspect it in the DOM or HTML tabs.
+    trace: function() {},
+     * APIFunction: group
+     * Writes a message to the console and opens a nested block to indent all
+     * future messages sent to the console. Call OpenLayers.Console.groupEnd()
+     * to close the block.
+     * Parameters:
+    group: function() {},
+     * APIFunction: groupEnd
+     * Closes the most recently opened block created by a call to
+     * OpenLayers.Console.group
+    groupEnd: function() {},
+     * APIFunction: time
+     * Creates a new timer under the given name. Call
+     * OpenLayers.Console.timeEnd(name)
+     * with the same name to stop the timer and print the time elapsed.
+     * Parameters:
+     * name - {String}
+    time: function() {},
+     * APIFunction: timeEnd
+     * Stops a timer created by a call to OpenLayers.Console.time(name) and
+     * writes the time elapsed.
+     * Parameters:
+     * name - {String}
+    timeEnd: function() {},
+     * APIFunction: profile
+     * Turns on the JavaScript profiler. The optional argument title would
+     * contain the text to be printed in the header of the profile report.
+     * This function is not currently implemented in Firebug Lite.
+     * Parameters:
+     * title - {String} Optional title for the profiler
+    profile: function() {},
+     * APIFunction: profileEnd
+     * Turns off the JavaScript profiler and prints its report.
+    profileEnd: function() {},
+     * APIFunction: count
+     * Writes the number of times that the line of code where count was called
+     * was executed. The optional argument title will print a message in
+     * addition to the number of the count.
+     * Parameters:
+     * title - {String} Optional title to be printed with count
+    count: function() {},
+    CLASS_NAME: "OpenLayers.Console"
+ * Execute an anonymous function to extend the OpenLayers.Console namespace
+ * if the firebug.js script is included.  This closure is used so that the
+ * "scripts" and "i" variables don't pollute the global namespace.
+(function() {
+     * If Firebug Lite is included (before this script), re-route all
+     * OpenLayers.Console calls to the console object.
+    if(window.console) {
+        var scripts = document.getElementsByTagName("script");
+        for(var i=0; i<scripts.length; ++i) {
+            if(scripts[i].src.indexOf("firebug.js") != -1) {
+                OpenLayers.Util.extend(OpenLayers.Console, console);
+                break;
+    OpenLayers/BaseTypes/Size.js
+ * Class: OpenLayers.Size
+ * Instances of this class represent a width/height pair
+OpenLayers.Size = OpenLayers.Class({
+     * APIProperty: w
+     * {Number} width
+    w: 0.0,
+     * APIProperty: h
+     * {Number} height
+    h: 0.0,
+     * Constructor: OpenLayers.Size
+     * Create an instance of OpenLayers.Size
+     * Parameters:
+     * w - {Number} width
+     * h - {Number} height
+    initialize: function(w, h) {
+        this.w = parseFloat(w);
+        this.h = parseFloat(h);
+     * Method: toString
+     * Return the string representation of a size object
+     * Returns:
+     * {String} The string representation of OpenLayers.Size object.
+     * (ex. <i>"w=55,h=66"</i>)
+    toString:function() {
+        return ("w=" + this.w + ",h=" + this.h);
+     * APIMethod: clone
+     * Create a clone of this size object
+     * Returns:
+     * {<OpenLayers.Size>} A new OpenLayers.Size object with the same w and h
+     * values
+    clone:function() {
+        return new OpenLayers.Size(this.w, this.h);
+     * APIMethod: equals
+     * Determine where this size is equal to another
+     * Parameters:
+     * sz - {<OpenLayers.Size>}
+     * Returns:
+     * {Boolean} The passed in size has the same h and w properties as this one.
+     * Note that if sz passed in is null, returns false.
+    equals:function(sz) {
+        var equals = false;
+        if (sz != null) {
+            equals = ((this.w == sz.w && this.h == sz.h) ||
+                      (isNaN(this.w) && isNaN(this.h) && isNaN(sz.w) && isNaN(sz.h)));
+        return equals;
+    CLASS_NAME: "OpenLayers.Size"
     OpenLayers/BaseTypes/Bounds.js
@@ -4442,328 +4474,6 @@
     CLASS_NAME: "OpenLayers.Pixel"
-    OpenLayers/BaseTypes/Size.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * Class: OpenLayers.Size
- * Instances of this class represent a width/height pair
-OpenLayers.Size = OpenLayers.Class({
-     * APIProperty: w
-     * {Number} width
-    w: 0.0,
-     * APIProperty: h
-     * {Number} height
-    h: 0.0,
-     * Constructor: OpenLayers.Size
-     * Create an instance of OpenLayers.Size
-     * Parameters:
-     * w - {Number} width
-     * h - {Number} height
-    initialize: function(w, h) {
-        this.w = parseFloat(w);
-        this.h = parseFloat(h);
-     * Method: toString
-     * Return the string representation of a size object
-     * Returns:
-     * {String} The string representation of OpenLayers.Size object.
-     * (ex. <i>"w=55,h=66"</i>)
-    toString:function() {
-        return ("w=" + this.w + ",h=" + this.h);
-     * APIMethod: clone
-     * Create a clone of this size object
-     * Returns:
-     * {<OpenLayers.Size>} A new OpenLayers.Size object with the same w and h
-     * values
-    clone:function() {
-        return new OpenLayers.Size(this.w, this.h);
-     * APIMethod: equals
-     * Determine where this size is equal to another
-     * Parameters:
-     * sz - {<OpenLayers.Size>}
-     * Returns:
-     * {Boolean} The passed in size has the same h and w properties as this one.
-     * Note that if sz passed in is null, returns false.
-    equals:function(sz) {
-        var equals = false;
-        if (sz != null) {
-            equals = ((this.w == sz.w && this.h == sz.h) ||
-                      (isNaN(this.w) && isNaN(this.h) && isNaN(sz.w) && isNaN(sz.h)));
-        return equals;
-    CLASS_NAME: "OpenLayers.Size"
-    OpenLayers/Console.js
- * Namespace: OpenLayers.Console
- * The OpenLayers.Console namespace is used for debugging and error logging.
- * If the Firebug Lite (../Firebug/firebug.js) is included before this script,
- * calls to OpenLayers.Console methods will get redirected to window.console.
- * This makes use of the Firebug extension where available and allows for
- * cross-browser debugging Firebug style.
- * Note:
- * Note that behavior will differ with the Firebug extention and Firebug Lite.
- * Most notably, the Firebug Lite console does not currently allow for
- * hyperlinks to code or for clicking on object to explore their properties.
-OpenLayers.Console = {
-     * Create empty functions for all console methods.  The real value of these
-     * properties will be set if Firebug Lite (../Firebug/firebug.js script) is
-     * included.  We explicitly require the Firebug Lite script to trigger
-     * functionality of the OpenLayers.Console methods.
-     * APIFunction: log
-     * Log an object in the console.  The Firebug Lite console logs string
-     * representation of objects.  Given multiple arguments, they will
-     * be cast to strings and logged with a space delimiter.  If the first
-     * argument is a string with printf-like formatting, subsequent arguments
-     * will be used in string substitution.  Any additional arguments (beyond
-     * the number substituted in a format string) will be appended in a space-
-     * delimited line.
-     * Parameters:
-     * object - {Object}
-    log: function() {},
-     * APIFunction: debug
-     * Writes a message to the console, including a hyperlink to the line
-     * where it was called.
-     * May be called with multiple arguments as with OpenLayers.Console.log().
-     * Parameters:
-    debug: function() {},
-     * APIFunction: info
-     * Writes a message to the console with the visual "info" icon and color
-     * coding and a hyperlink to the line where it was called.
-     * Parameters:
-    info: function() {},
-     * APIFunction: warn
-     * Writes a message to the console with the visual "warning" icon and
-     * color coding and a hyperlink to the line where it was called.
-     * Parameters:
-    warn: function() {},
-     * APIFunction: error
-     * Writes a message to the console with the visual "error" icon and color
-     * Parameters:
-    error: function() {},
-     * APIFunction: assert
-     * Tests that an expression is true. If not, it will write a message to
-     * the console and throw an exception.
-     * Parameters:
-    assert: function() {},
-     * APIFunction: dir
-     * Prints an interactive listing of all properties of the object. This
-     * looks identical to the view that you would see in the DOM tab.
-     * Parameters:
-    dir: function() {},
-     * APIFunction: dirxml
-     * Prints the XML source tree of an HTML or XML element. This looks
-     * identical to the view that you would see in the HTML tab. You can click
-     * on any node to inspect it in the HTML tab.
-     * Parameters:
-    dirxml: function() {},
-     * APIFunction: trace
-     * Prints an interactive stack trace of JavaScript execution at the point
-     * where it is called.  The stack trace details the functions on the stack,
-     * as well as the values that were passed as arguments to each function.
-     * You can click each function to take you to its source in the Script tab,
-     * and click each argument value to inspect it in the DOM or HTML tabs.
-    trace: function() {},
-     * APIFunction: group
-     * Writes a message to the console and opens a nested block to indent all
-     * future messages sent to the console. Call OpenLayers.Console.groupEnd()
-     * to close the block.
-     * Parameters:
-    group: function() {},
-     * APIFunction: groupEnd
-     * Closes the most recently opened block created by a call to
-     * OpenLayers.Console.group
-    groupEnd: function() {},
-     * APIFunction: time
-     * Creates a new timer under the given name. Call
-     * OpenLayers.Console.timeEnd(name)
-     * with the same name to stop the timer and print the time elapsed.
-     * Parameters:
-     * name - {String}
-    time: function() {},
-     * APIFunction: timeEnd
-     * Stops a timer created by a call to OpenLayers.Console.time(name) and
-     * writes the time elapsed.
-     * Parameters:
-     * name - {String}
-    timeEnd: function() {},
-     * APIFunction: profile
-     * Turns on the JavaScript profiler. The optional argument title would
-     * contain the text to be printed in the header of the profile report.
-     * This function is not currently implemented in Firebug Lite.
-     * Parameters:
-     * title - {String} Optional title for the profiler
-    profile: function() {},
-     * APIFunction: profileEnd
-     * Turns off the JavaScript profiler and prints its report.
-    profileEnd: function() {},
-     * APIFunction: count
-     * Writes the number of times that the line of code where count was called
-     * was executed. The optional argument title will print a message in
-     * addition to the number of the count.
-     * Parameters:
-     * title - {String} Optional title to be printed with count
-    count: function() {},
-    CLASS_NAME: "OpenLayers.Console"
- * Execute an anonymous function to extend the OpenLayers.Console namespace
- * if the firebug.js script is included.  This closure is used so that the
- * "scripts" and "i" variables don't pollute the global namespace.
-(function() {
-     * If Firebug Lite is included (before this script), re-route all
-     * OpenLayers.Console calls to the console object.
-    if(window.console) {
-        var scripts = document.getElementsByTagName("script");
-        for(var i=0; i<scripts.length; ++i) {
-            if(scripts[i].src.indexOf("firebug.js") != -1) {
-                OpenLayers.Util.extend(OpenLayers.Console, console);
-                break;
     OpenLayers/Control.js
@@ -5434,1104 +5144,275 @@
 OpenLayers.i18n = OpenLayers.Lang.translate;
-    OpenLayers/Popup.js
+    OpenLayers/Request.js
- * Class: OpenLayers.Popup
- * A popup is a small div that can opened and closed on the map.
- * Typically opened in response to clicking on a marker.
- * See <OpenLayers.Marker>.  Popup's don't require their own
- * layer and are added the the map using the <OpenLayers.Map.addPopup>
- * method.
- * Example:
- * (code)
- * popup = new OpenLayers.Popup("chicken",
- *                    new OpenLayers.LonLat(5,40),
- *                    new OpenLayers.Size(200,200),
- *                    "example popup",
- *                    true);
- * map.addPopup(popup);
- * (end)
+ * Namespace: OpenLayers.Request
+ * The OpenLayers.Request namespace contains convenience methods for working
+ *     with XMLHttpRequests.  These methods work with a cross-browser
+ *     W3C compliant <OpenLayers.Request.XMLHttpRequest> class.
-OpenLayers.Popup = OpenLayers.Class({
-     * Property: events
-     * {<OpenLayers.Events>} custom event manager
-    events: null,
+OpenLayers.Request = {
-    /** Property: id
-     * {String} the unique identifier assigned to this popup.
-    id: "",
-     * Property: lonlat
-     * {<OpenLayers.LonLat>} the position of this popup on the map
-    lonlat: null,
-     * Property: div
-     * {DOMElement} the div that contains this popup.
-    div: null,
-     * Property: size
-     * {<OpenLayers.Size>} the width and height of the popup.
-    size: null,
-     * Property: contentHTML
-     * {String} The HTML that this popup displays.
-    contentHTML: "",
-     * Property: backgroundColor
-     * {String} the background color used by the popup.
-    backgroundColor: "",
-     * Property: opacity
-     * {float} the opacity of this popup (between 0.0 and 1.0)
-    opacity: "",
-     * Property: border
-     * {String} the border size of the popup.  (eg 2px)
-    border: "",
-     * Property: contentDiv
-     * {DOMElement} a reference to the element that holds the content of
-     *              the div.
-    contentDiv: null,
-     * Property: groupDiv
-     * {DOMElement} First and only child of 'div'. The group Div contains the
-     *     'contentDiv' and the 'closeDiv'.
-    groupDiv: null,
-     * Property: closeDiv
-     * {DOMElement} the optional closer image
-    closeDiv: null,
-     * APIProperty: autoSize
-     * {Boolean} Resize the popup to auto-fit the contents.
-     *     Default is false.
-    autoSize: false,
-     * APIProperty: minSize
-     * {<OpenLayers.Size>} Minimum size allowed for the popup's contents.
+     * Constant: DEFAULT_CONFIG
+     * {Object} Default configuration for all requests.
-    minSize: null,
-     * APIProperty: maxSize
-     * {<OpenLayers.Size>} Maximum size allowed for the popup's contents.
-    maxSize: null,
-     * Property: padding
-     * {int or <OpenLayers.Bounds>} An extra opportunity to specify internal
-     *     padding of the content div inside the popup. This was originally
-     *     confused with the css padding as specified in style.css's
-     *     'olPopupContent' class. We would like to get rid of this altogether,
-     *     except that it does come in handy for the framed and anchoredbubble
-     *     popups, who need to maintain yet another barrier between their
-     *     content and the outer border of the popup itself.
-     *     Note that in order to not break API, we must continue to support
-     *     this property being set as an integer. Really, though, we'd like to
-     *     have this specified as a Bounds object so that user can specify
-     *     distinct left, top, right, bottom paddings. With the 3.0 release
-     *     we can make this only a bounds.
-    padding: 0,
-     * Method: fixPadding
-     * To be removed in 3.0, this function merely helps us to deal with the
-     *     case where the user may have set an integer value for padding,
-     *     instead of an <OpenLayers.Bounds> object.
-    fixPadding: function() {
-        if (typeof this.padding == "number") {
-            this.padding = new OpenLayers.Bounds(
-                this.padding, this.padding, this.padding, this.padding
+    DEFAULT_CONFIG: {
+        method: "GET",
+        url: window.location.href,
+        async: true,
+        user: undefined,
+        password: undefined,
+        params: null,
+        proxy: OpenLayers.ProxyHost,
+        headers: {},
+        data: null,
+        callback: function() {},
+        success: null,
+        failure: null,
+        scope: null
-     * APIProperty: panMapIfOutOfView
-     * {Boolean} When drawn, pan map such that the entire popup is visible in
-     *     the current viewport (if necessary).
-    panMapIfOutOfView: false,
-     * Property: map
-     * {<OpenLayers.Map>} this gets set in Map.js when the popup is added to the map
-    map: null,
-    * Constructor: OpenLayers.Popup
-    * Create a popup.
-    * Parameters:
-    * id - {String} a unqiue identifier for this popup.  If null is passed
-    *               an identifier will be automatically generated.
-    * lonlat - {<OpenLayers.LonLat>}  The position on the map the popup will
-    *                                 be shown.
-    * size - {<OpenLayers.Size>}      The size of the popup.
-    * contentHTML - {String}          The HTML content to display inside the
-    *                                 popup.
-    * closeBox - {Boolean}            Whether to display a close box inside
-    *                                 the popup.
-    * closeBoxCallback - {Function}   Function to be called on closeBox click.
-    initialize:function(id, lonlat, size, contentHTML, closeBox, closeBoxCallback) {
-        if (id == null) {
-            id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
-        this.id = id;
-        this.lonlat = lonlat;
-        this.size = (size != null) ? size
-                                  : new OpenLayers.Size(
-                                                   OpenLayers.Popup.WIDTH,
-                                                   OpenLayers.Popup.HEIGHT);
-        if (contentHTML != null) {
-             this.contentHTML = contentHTML;
-        this.backgroundColor = OpenLayers.Popup.COLOR;
-        this.opacity = OpenLayers.Popup.OPACITY;
-        this.border = OpenLayers.Popup.BORDER;
-        this.div = OpenLayers.Util.createDiv(this.id, null, null,
-                                             null, null, null, "hidden");
-        this.div.className = 'olPopup';
-        var groupDivId = this.id + "_GroupDiv";
-        this.groupDiv = OpenLayers.Util.createDiv(groupDivId, null, null,
-                                                    null, "relative", null,
-                                                    "hidden");
-        var id = this.div.id + "_contentDiv";
-        this.contentDiv = OpenLayers.Util.createDiv(id, null, this.size.clone(),
-                                                    null, "relative");
-        this.contentDiv.className = 'olPopupContent';
-        this.groupDiv.appendChild(this.contentDiv);
-        this.div.appendChild(this.groupDiv);
-        if (closeBox) {
-            this.addCloseBox(closeBoxCallback);
-        this.registerEvents();
-     * Method: destroy
-     * nullify references to prevent circular references and memory leaks
-    destroy: function() {
-        this.id = null;
-        this.lonlat = null;
-        this.size = null;
-        this.contentHTML = null;
-        this.backgroundColor = null;
-        this.opacity = null;
-        this.border = null;
-        this.events.destroy();
-        this.events = null;
-        if (this.closeDiv) {
-            OpenLayers.Event.stopObservingElement(this.closeDiv);
-            this.groupDiv.removeChild(this.closeDiv);
-        this.closeDiv = null;
-        this.div.removeChild(this.groupDiv);
-        this.groupDiv = null;
-        if (this.map != null) {
-            this.map.removePopup(this);
-        this.map = null;
-        this.div = null;
-        this.autoSize = null;
-        this.minSize = null;
-        this.maxSize = null;
-        this.padding = null;
-        this.panMapIfOutOfView = null;
-    * Method: draw
-    * Constructs the elements that make up the popup.
-    * Parameters:
-    * px - {<OpenLayers.Pixel>} the position the popup in pixels.
-    * Returns:
-    * {DOMElement} Reference to a div that contains the drawn popup
-    draw: function(px) {
-        if (px == null) {
-            if ((this.lonlat != null) && (this.map != null)) {
-                px = this.map.getLayerPxFromLonLat(this.lonlat);
-        //listen to movestart, moveend to disable overflow (FF bug)
-        if (OpenLayers.Util.getBrowserName() == 'firefox') {
-            this.map.events.register("movestart", this, function() {
-                var style = document.defaultView.getComputedStyle(
-                    this.contentDiv, null
-                var currentOverflow = style.getPropertyValue("overflow");
-                if (currentOverflow != "hidden") {
-                    this.contentDiv._oldOverflow = currentOverflow;
-                    this.contentDiv.style.overflow = "hidden";
-            this.map.events.register("moveend", this, function() {
-                var oldOverflow = this.contentDiv._oldOverflow;
-                if (oldOverflow) {
-                    this.contentDiv.style.overflow = oldOverflow;
-                    this.contentDiv._oldOverflow = null;
-        this.moveTo(px);
-        if (!this.autoSize) {
-            this.setSize(this.size);
-        this.setBackgroundColor();
-        this.setOpacity();
-        this.setBorder();
-        this.setContentHTML();
-        if (this.panMapIfOutOfView) {
-            this.panIntoView();
-        return this.div;
-     * Method: updatePosition
-     * if the popup has a lonlat and its map members set,
-     * then have it move itself to its proper position
-    updatePosition: function() {
-        if ((this.lonlat) && (this.map)) {
-            var px = this.map.getLayerPxFromLonLat(this.lonlat);
-            if (px) {
-                this.moveTo(px);
-     * Method: moveTo
+     * APIMethod: issue
+     * Create a new XMLHttpRequest object, open it, set any headers, bind
+     *     a callback to done state, and send any data.
      * Parameters:
-     * px - {<OpenLayers.Pixel>} the top and left position of the popup div.
-    moveTo: function(px) {
-        if ((px != null) && (this.div != null)) {
-            this.div.style.left = px.x + "px";
-            this.div.style.top = px.y + "px";
-     * Method: visible
+     * config - {Object} Object containing properties for configuring the
+     *     request.  Allowed configuration properties are described below.
+     *     This object is modified and should not be reused.
-     * Returns:
-     * {Boolean} Boolean indicating whether or not the popup is visible
-    visible: function() {
-        return OpenLayers.Element.visible(this.div);
-     * Method: toggle
-     * Toggles visibility of the popup.
-    toggle: function() {
-        if (this.visible()) {
-            this.hide();
-        } else {
-            this.show();
-     * Method: show
-     * Makes the popup visible.
-    show: function() {
-        OpenLayers.Element.show(this.div);
-     * Method: hide
-     * Makes the popup invisible.
-    hide: function() {
-        OpenLayers.Element.hide(this.div);
-     * Method: setSize
-     * Used to adjust the size of the popup.
+     * Allowed config properties:
+     * method - {String} One of GET, POST, PUT, DELETE, HEAD, or
+     *     OPTIONS.  Default is GET.
+     * url - {String} URL for the request.
+     * async - {Boolean} Open an asynchronous request.  Default is true.
+     * user - {String} User for relevant authentication scheme.  Set
+     *     to null to clear current user.
+     * password - {String} Password for relevant authentication scheme.
+     *     Set to null to clear current password.
+     * proxy - {String} Optional proxy.  Defaults to
+     *     <OpenLayers.ProxyHost>.
+     * params - {Object} Any key:value pairs to be appended to the
+     *     url as a query string.  Assumes url doesn't already include a query
+     *     string or hash.  Parameter values that are arrays will be
+     *     concatenated with a comma (note that this goes against form-encoding)
+     *     as is done with <OpenLayers.Util.getParameterString>.
+     * headers - {Object} Object with header:value pairs to be set on
+     *     the request.
+     * data - {Object} Any data to send with the request.
+     * callback - {Function} Function to call when request is done.
+     *     To determine if the request failed, check request.status (200
+     *     indicates success).
+     * success - {Function} Optional function to call if request status is in
+     *     the 200s.  This will be called in addition to callback above and
+     *     would typically only be used as an alternative.
+     * failure - {Function} Optional function to call if request status is not
+     *     in the 200s.  This will be called in addition to callback above and
+     * scope - {Object} If callback is a public method on some object,
+     *     set the scope to that object.
-     * Parameters:
-     * size - {<OpenLayers.Size>} the new size of the popup's contents div
-     *     (in pixels).
+     * Returns:
+     * {XMLHttpRequest} Request object.  To abort the request before a response
+     *     is received, call abort() on the request object.
-    setSize:function(size) {
-        this.size = size;
+    issue: function(config) {
+        // apply default config - proxy host may have changed
+        var defaultConfig = OpenLayers.Util.extend(
+            this.DEFAULT_CONFIG,
+            {proxy: OpenLayers.ProxyHost}
+        config = OpenLayers.Util.applyDefaults(config, defaultConfig);
-        var contentSize = this.size.clone();
-        // if our contentDiv has a css 'padding' set on it by a stylesheet, we
-        //  must add that to the desired "size".
-        var contentDivPadding = this.getContentDivPadding();
-        var wPadding = contentDivPadding.left + contentDivPadding.right;
-        var hPadding = contentDivPadding.top + contentDivPadding.bottom;
-        // take into account the popup's 'padding' property
-        this.fixPadding();
-        wPadding += this.padding.left + this.padding.right;
-        hPadding += this.padding.top + this.padding.bottom;
-        // make extra space for the close div
-            var closeDivWidth = parseInt(this.closeDiv.style.width);
-            wPadding += closeDivWidth + contentDivPadding.right;
+        // create request, open, and set headers
+        var request = new OpenLayers.Request.XMLHttpRequest();
+        var url = config.url;
+        if(config.params) {
+            url += "?" + OpenLayers.Util.getParameterString(config.params);
-        //increase size of the main popup div to take into account the
-        // users's desired padding and close div.
-        this.size.w += wPadding;
-        this.size.h += hPadding;
-        //now if our browser is IE, we need to actually make the contents
-        // div itself bigger to take its own padding into effect. this makes
-        // me want to shoot someone, but so it goes.
-        if (OpenLayers.Util.getBrowserName() == "msie") {
-            contentSize.w += contentDivPadding.left + contentDivPadding.right;
-            contentSize.h += contentDivPadding.bottom + contentDivPadding.top;
+        if(config.proxy && (url.indexOf("http") == 0)) {
+            url = config.proxy + encodeURIComponent(url);
-        if (this.div != null) {
-            this.div.style.width = this.size.w + "px";
-            this.div.style.height = this.size.h + "px";
+        request.open(
+            config.method, url, config.async, config.user, config.password
+        for(var header in config.headers) {
+            request.setRequestHeader(header, config.headers[header]);
-        if (this.contentDiv != null){
-            this.contentDiv.style.width = contentSize.w + "px";
-            this.contentDiv.style.height = contentSize.h + "px";
-     * Method: setBackgroundColor
-     * Sets the background color of the popup.
-     * Parameters:
-     * color - {String} the background color.  eg "#FFBBBB"
-    setBackgroundColor:function(color) {
-        if (color != undefined) {
-            this.backgroundColor = color;
+        // bind callbacks to readyState 4 (done)
+        var complete = (config.scope) ?
+            OpenLayers.Function.bind(config.callback, config.scope) :
+            config.callback;
-            this.div.style.backgroundColor = this.backgroundColor;
+        // optional success callback
+        var success;
+        if(config.success) {
+            success = (config.scope) ?
+                OpenLayers.Function.bind(config.success, config.scope) :
+                config.success;
-     * Method: setOpacity
-     * Sets the opacity of the popup.
-     * Parameters:
-     * opacity - {float} A value between 0.0 (transparent) and 1.0 (solid).
-    setOpacity:function(opacity) {
-        if (opacity != undefined) {
-            this.opacity = opacity;
-            // for Mozilla and Safari
-            this.div.style.opacity = this.opacity;
-            // for IE
-            this.div.style.filter = 'alpha(opacity=' + this.opacity*100 + ')';
+        // optional failure callback
+        var failure;
+        if(config.failure) {
+            failure = (config.scope) ?
+                OpenLayers.Function.bind(config.failure, config.scope) :
+                config.failure;
-     * Method: setBorder
-     * Sets the border style of the popup.
-     * Parameters:
-     * border - {String} The border style value. eg 2px
-    setBorder:function(border) {
-        if (border != undefined) {
-            this.border = border;
+        request.onreadystatechange = function() {
+            if(request.readyState == OpenLayers.Request.XMLHttpRequest.DONE) {
+                complete(request);
+                if(success && request.status >= 200 && request.status < 300) {
+                    success(request);
+                if(failure && (request.status < 200 || request.status >= 300)) {
+                    failure(request);
-            this.div.style.border = this.border;
+        // send request (optionally with data) and return
+        request.send(config.data);
+        return request;
-     * Method: setContentHTML
-     * Allows the user to set the HTML content of the popup.
+     * APIMethod: GET
+     * Send an HTTP GET request.  Additional configuration properties are
+     *     documented in the <issue> method, with the method property set
+     *     to GET.
      * Parameters:
-     * contentHTML - {String} HTML for the div.
+     * config - {Object} Object with properties for configuring the request.
+     *     See the <issue> method for documentation of allowed properties.
+     * Returns:
-    setContentHTML:function(contentHTML) {
-        if (this.autoSize) {
-            // determine actual render dimensions of the contents
-            var realSize =
-                 OpenLayers.Util.getRenderedDimensions(this.contentHTML);
-            // is the "real" size of the div is safe to display in our map?
-            var safeSize = this.getSafeContentSize(realSize);
-            var newSize = null;
-            if (safeSize.equals(realSize)) {
-                //real size of content is small enough to fit on the map,
-                // so we use real size.
-                newSize = realSize;
-            } else {
-                //make a new OL.Size object with the clipped dimensions
-                // set or null if not clipped.
-                var fixedSize = new OpenLayers.Size();
-                fixedSize.w = (safeSize.w < realSize.w) ? safeSize.w : null;
-                fixedSize.h = (safeSize.h < realSize.h) ? safeSize.h : null;
-                if (fixedSize.w && fixedSize.h) {
-                    //content is too big in both directions, so we will use
-                    // max popup size (safeSize), knowing well that it will
-                    // overflow both ways.
-                    newSize = safeSize;
-                } else {
-                    //content is clipped in only one direction, so we need to
-                    // run getRenderedDimensions() again with a fixed dimension
-                    var clippedSize = OpenLayers.Util.getRenderedDimensions(
-                        this.contentHTML, fixedSize
-                    //if the clipped size is still the same as the safeSize,
-                    // that means that our content must be fixed in the
-                    // offending direction. If overflow is 'auto', this means
-                    // we are going to have a scrollbar for sure, so we must
-                    // adjust for that.
-                    var currentOverflow = OpenLayers.Element.getStyle(
-                        this.contentDiv, "overflow"
-                    if ( (currentOverflow != "hidden") &&
-                         (clippedSize.equals(safeSize)) ) {
-                        var scrollBar = OpenLayers.Util.getScrollbarWidth();
-                        if (fixedSize.w) {
-                            clippedSize.h += scrollBar;
-                        } else {
-                            clippedSize.w += scrollBar;
-                    newSize = this.getSafeContentSize(clippedSize);
-            this.setSize(newSize);
-        if (this.contentDiv != null) {
-            this.contentDiv.innerHTML = this.contentHTML;
+    GET: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "GET"});
+        return OpenLayers.Request.issue(config);
-     * APIMethod: getSafeContentSize
+     * APIMethod: POST
+     * Send a POST request.  Additional configuration properties are
+     *     to POST and "Content-Type" header set to "application/xml".
      * Parameters:
-     * size - {<OpenLayers.Size>} Desired size to make the popup.
+     *     See the <issue> method for documentation of allowed properties.  The
+     *     default "Content-Type" header will be set to "application-xml" if
+     *     none is provided.  This object is modified and should not be reused.
      * Returns:
-     * {<OpenLayers.Size>} A size to make the popup which is neither smaller
-     *     than the specified minimum size, nor bigger than the maximum
-     *     size (which is calculated relative to the size of the viewport).
-    getSafeContentSize: function(size) {
-        var safeContentSize = size.clone();
+    POST: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "POST"});
+        // set content type to application/xml if it isn't already set
+        config.headers = config.headers ? config.headers : {};
+        if(!("CONTENT-TYPE" in OpenLayers.Util.upperCaseObject(config.headers))) {
+            config.headers["Content-Type"] = "application/xml";
-        // prevent the popup from being smaller than a specified minimal size
-        if (this.minSize) {
-            safeContentSize.w = Math.max(safeContentSize.w,
-                (this.minSize.w - wPadding));
-            safeContentSize.h = Math.max(safeContentSize.h,
-                (this.minSize.h - hPadding));
-        // prevent the popup from being bigger than a specified maximum size
-        if (this.maxSize) {
-            safeContentSize.w = Math.min(safeContentSize.w,
-                (this.maxSize.w - wPadding));
-            safeContentSize.h = Math.min(safeContentSize.h,
-                (this.maxSize.h - hPadding));
-        //make sure the desired size to set doesn't result in a popup that
-        // is bigger than the map's viewport.
-        if (this.map && this.map.size) {
-            // Note that there *was* a reference to a
-            // 'OpenLayers.Popup.SCROLL_BAR_WIDTH' constant here, with special
-            // tolerance for it and everything... but it was never defined in
-            // the first place, so I don't know what to think.
-            var maxY = this.map.size.h -
-                this.map.paddingForPopups.top -
-                this.map.paddingForPopups.bottom -
-                hPadding;
-            var maxX = this.map.size.w -
-                this.map.paddingForPopups.left -
-                this.map.paddingForPopups.right -
-                wPadding;
-            safeContentSize.w = Math.min(safeContentSize.w, maxX);
-            safeContentSize.h = Math.min(safeContentSize.h, maxY);
-        return safeContentSize;
-     * Method: getContentDivPadding
-     * Glorious, oh glorious hack in order to determine the css 'padding' of
-     *     the contentDiv. IE/Opera return null here unless we actually add the
-     *     popup's main 'div' element (which contains contentDiv) to the DOM.
-     *     So we make it invisible and then add it to the document temporarily.
+     * APIMethod: PUT
+     * Send an HTTP PUT request.  Additional configuration properties are
+     *     to PUT and "Content-Type" header set to "application/xml".
-     *     Once we've taken the padding readings we need, we then remove it
-     *     from the DOM (it will actually get added to the DOM in
-     *     Map.js's addPopup)
-     * Returns:
-     * {<OpenLayers.Bounds>}
-    getContentDivPadding: function() {
-        //use cached value if we have it
-        var contentDivPadding = this._contentDivPadding;
-        if (!contentDivPadding) {
-            //make the div invisible and add it to the page
-            this.div.style.display = "none";
-            document.body.appendChild(this.div);
-            //read the padding settings from css, put them in an OL.Bounds
-            contentDivPadding = new OpenLayers.Bounds(
-                OpenLayers.Element.getStyle(this.contentDiv, "padding-left"),
-                OpenLayers.Element.getStyle(this.contentDiv, "padding-bottom"),
-                OpenLayers.Element.getStyle(this.contentDiv, "padding-right"),
-                OpenLayers.Element.getStyle(this.contentDiv, "padding-top")
-            //cache the value
-            this._contentDivPadding = contentDivPadding;
-            //remove the div from the page and make it visible again
-            document.body.removeChild(this.div);
-            this.div.style.display = "";
-        return contentDivPadding;
-     * Method: addCloseBox
      * Parameters:
-     * callback - {Function} The callback to be called when the close button
-     *     is clicked.
-    addCloseBox: function(callback) {
-        this.closeDiv = OpenLayers.Util.createDiv(
-            this.id + "_close", null, new OpenLayers.Size(17, 17)
-        this.closeDiv.className = "olPopupCloseBox";
-        // use the content div's css padding to determine if we should
-        //  padd the close div
-        this.closeDiv.style.right = contentDivPadding.right + "px";
-        this.closeDiv.style.top = contentDivPadding.top + "px";
-        this.groupDiv.appendChild(this.closeDiv);
-        var closePopup = callback || function(e) {
-            this.hide();
-            OpenLayers.Event.stop(e);
-        OpenLayers.Event.observe(this.closeDiv, "click",
-                OpenLayers.Function.bindAsEventListener(closePopup, this));
-     * Method: panIntoView
-     * Pans the map such that the popup is totaly viewable (if necessary)
-    panIntoView: function() {
-        var mapSize = this.map.getSize();
-        //start with the top left corner of the popup, in px,
-        // relative to the viewport
-        var origTL = this.map.getViewPortPxFromLayerPx( new OpenLayers.Pixel(
-            parseInt(this.div.style.left),
-            parseInt(this.div.style.top)
-        var newTL = origTL.clone();
-        //new left (compare to margins, using this.size to calculate right)
-        if (origTL.x < this.map.paddingForPopups.left) {
-            newTL.x = this.map.paddingForPopups.left;
-        } else
-        if ( (origTL.x + this.size.w) > (mapSize.w - this.map.paddingForPopups.right)) {
-            newTL.x = mapSize.w - this.map.paddingForPopups.right - this.size.w;
-        //new top (compare to margins, using this.size to calculate bottom)
-        if (origTL.y < this.map.paddingForPopups.top) {
-            newTL.y = this.map.paddingForPopups.top;
-        } else
-        if ( (origTL.y + this.size.h) > (mapSize.h - this.map.paddingForPopups.bottom)) {
-            newTL.y = mapSize.h - this.map.paddingForPopups.bottom - this.size.h;
-        var dx = origTL.x - newTL.x;
-        var dy = origTL.y - newTL.y;
-        this.map.pan(dx, dy);
-     * Method: registerEvents
-     * Registers events on the popup.
-     * Do this in a separate function so that subclasses can
-     *   choose to override it if they wish to deal differently
-     *   with mouse events
-     *   Note in the following handler functions that some special
-     *    care is needed to deal correctly with mousing and popups.
-     *   Because the user might select the zoom-rectangle option and
-     *    then drag it over a popup, we need a safe way to allow the
-     *    mousemove and mouseup events to pass through the popup when
-     *    they are initiated from outside.
-     *   Otherwise, we want to essentially kill the event propagation
-     *    for all other events, though we have to do so carefully,
-     *    without disabling basic html functionality, like clicking on
-     *    hyperlinks or drag-selecting text.
+     * Returns:
-     registerEvents:function() {
-        this.events = new OpenLayers.Events(this, this.div, null, true);
-        this.events.on({
-            "mousedown": this.onmousedown,
-            "mousemove": this.onmousemove,
-            "mouseup": this.onmouseup,
-            "click": this.onclick,
-            "mouseout": this.onmouseout,
-            "dblclick": this.ondblclick,
-            scope: this
-     * Method: onmousedown
-     * When mouse goes down within the popup, make a note of
-     *   it locally, and then do not propagate the mousedown
-     *   (but do so safely so that user can select text inside)
-     * Parameters:
-     * evt - {Event}
-    onmousedown: function (evt) {
-        this.mousedown = true;
-        OpenLayers.Event.stop(evt, true);
-     * Method: onmousemove
-     * If the drag was started within the popup, then
-     *   do not propagate the mousemove (but do so safely
-     *   so that user can select text inside)
-     * Parameters:
-     * evt - {Event}
-    onmousemove: function (evt) {
-        if (this.mousedown) {
+    PUT: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "PUT"});
-     * Method: onmouseup
-     * When mouse comes up within the popup, after going down
-     *   in it, reset the flag, and then (once again) do not
-     *   propagate the event, but do so safely so that user can
-     *   select text inside
-     * Parameters:
-     * evt - {Event}
-    onmouseup: function (evt) {
-            this.mousedown = false;
-     * Method: onclick
-     * Ignore clicks, but allowing default browser handling
-     * Parameters:
-     * evt - {Event}
-    onclick: function (evt) {
-     * Method: onmouseout
-     * When mouse goes out of the popup set the flag to false so that
-     *   if they let go and then drag back in, we won't be confused.
-     * Parameters:
-     * evt - {Event}
-    onmouseout: function (evt) {
-     * Method: ondblclick
-     * Ignore double-clicks, but allowing default browser handling
-     * Parameters:
-     * evt - {Event}
-    ondblclick: function (evt) {
-    CLASS_NAME: "OpenLayers.Popup"
-OpenLayers.Popup.WIDTH = 200;
-OpenLayers.Popup.HEIGHT = 200;
-OpenLayers.Popup.COLOR = "white";
-OpenLayers.Popup.OPACITY = 1;
-OpenLayers.Popup.BORDER = "0px";
-    OpenLayers/Renderer.js
- * Class: OpenLayers.Renderer
- * This is the base class for all renderers.
- * This is based on a merger code written by Paul Spencer and Bertil Chapuis.
- * It is largely composed of virtual functions that are to be implemented
- * in technology-specific subclasses, but there is some generic code too.
- * The functions that *are* implemented here merely deal with the maintenance
- *  of the size and extent variables, as well as the cached 'resolution'
- *  value.
- * A note to the user that all subclasses should use getResolution() instead
- *  of directly accessing this.resolution in order to correctly use the
- *  cacheing system.
-OpenLayers.Renderer = OpenLayers.Class({
-     * Property: container
-     * {DOMElement}
-    container: null,
-     * Property: extent
-    extent: null,
-     * Property: size
-    size: null,
-     * Property: resolution
-     * {Float} cache of current map resolution
-    resolution: null,
-     * Property: map
-     * {<OpenLayers.Map>} Reference to the map -- this is set in Vector's setMap()
-    map: null,
-     * Constructor: OpenLayers.Renderer
+     * APIMethod: DELETE
+     * Send an HTTP DELETE request.  Additional configuration properties are
+     *     to DELETE.
      * Parameters:
-     * containerID - {<String>}
-    initialize: function(containerID) {
-        this.container = OpenLayers.Util.getElement(containerID);
-     * APIMethod: destroy
-        this.container = null;
-        this.extent = null;
-        this.size =  null;
-        this.resolution = null;
-        this.map = null;
-     * APIMethod: supported
-     * This should be overridden by specific subclasses
      * Returns:
-     * {Boolean} Whether or not the browser supports the renderer class
-    supported: function() {
-        return false;
-     * Method: setExtent
-     * Set the visible part of the layer.
-     * Resolution has probably changed, so we nullify the resolution
-     * cache (this.resolution) -- this way it will be re-computed when
-     * next it is needed.
-     * Parameters:
-     * extent - {<OpenLayers.Bounds>}
-    setExtent: function(extent) {
-        this.extent = extent.clone();
+    DELETE: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "DELETE"});
-     * Method: setSize
-     * Sets the size of the drawing surface.
+     * APIMethod: HEAD
+     * Send an HTTP HEAD request.  Additional configuration properties are
+     *     to HEAD.
      * Parameters:
-    setSize: function(size) {
-        this.size = size.clone();
-     * Method: getResolution
-     * Uses cached copy of resolution if available to minimize computing
      * Returns:
-     * The current map's resolution
-    getResolution: function() {
-        this.resolution = this.resolution || this.map.getResolution();
-        return this.resolution;
+    HEAD: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "HEAD"});
-     * Method: drawFeature
-     * Draw the feature.  The optional style argument can be used
-     * to override the feature's own style.  This method should only
-     * be called from layer.drawFeature().
+     * APIMethod: OPTIONS
+     * Send an HTTP OPTIONS request.  Additional configuration properties are
+     *     to OPTIONS.
      * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>}
-     * style - {<Object>}
-    drawFeature: function(feature, style) {
-        if(style == null) {
-            style = feature.style;
-        if (feature.geometry) {
-            this.drawGeometry(feature.geometry, style, feature.id);
-     * Method: drawGeometry
-     * Draw a geometry.  This should only be called from the renderer itself.
-     * Use layer.drawFeature() from outside the renderer.
-     * virtual function
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-     * style - {Object}
-     * featureId - {<String>}
-    drawGeometry: function(geometry, style, featureId) {},
-     * Method: clear
-     * Clear all vectors from the renderer.
-     * virtual function.
-    clear: function() {},
-     * Method: getFeatureIdFromEvent
-     * Returns a feature id from an event on the renderer.
-     * How this happens is specific to the renderer.  This should be
-     * called from layer.getFeatureFromEvent().
-     * Virtual function.
-     * Parameters:
-     * evt - {<OpenLayers.Event>}
      * Returns:
-     * {String} A feature id or null.
-    getFeatureIdFromEvent: function(evt) {},
-     * Method: eraseFeatures
-     * This is called by the layer to erase features
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)}
-    eraseFeatures: function(features) {
-        if(!(features instanceof Array)) {
-            features = [features];
-        for(var i=0; i<features.length; ++i) {
-            this.eraseGeometry(features[i].geometry);
-     * Method: eraseGeometry
-     * Remove a geometry from the renderer (by id).
-     * Parameters:
-    eraseGeometry: function(geometry) {},
+    OPTIONS: function(config) {
+        config = OpenLayers.Util.extend(config, {method: "OPTIONS"});
-    CLASS_NAME: "OpenLayers.Renderer"
     OpenLayers/Tween.js
@@ -6855,254 +5736,6 @@
     CLASS_NAME: "OpenLayers.Easing.Quad"
-    Rico/Color.js
- * This file has been edited substantially from the Rico-released version by
- * the OpenLayers development team.
- * This file is licensed under the Apache License, Version 2.0.
-OpenLayers.Rico.Color = OpenLayers.Class({
-   initialize: function(red, green, blue) {
-      this.rgb = { r: red, g : green, b : blue };
-   setRed: function(r) {
-      this.rgb.r = r;
-   setGreen: function(g) {
-      this.rgb.g = g;
-   setBlue: function(b) {
-      this.rgb.b = b;
-   setHue: function(h) {
-      // get an HSB model, and set the new hue...
-      var hsb = this.asHSB();
-      hsb.h = h;
-      // convert back to RGB...
-      this.rgb = OpenLayers.Rico.Color.HSBtoRGB(hsb.h, hsb.s, hsb.b);
-   setSaturation: function(s) {
-      hsb.s = s;
-      // convert back to RGB and set values...
-   setBrightness: function(b) {
-      hsb.b = b;
-      this.rgb = OpenLayers.Rico.Color.HSBtoRGB( hsb.h, hsb.s, hsb.b );
-   darken: function(percent) {
-      this.rgb = OpenLayers.Rico.Color.HSBtoRGB(hsb.h, hsb.s, Math.max(hsb.b - percent,0));
-   brighten: function(percent) {
-      this.rgb = OpenLayers.Rico.Color.HSBtoRGB(hsb.h, hsb.s, Math.min(hsb.b + percent,1));
-   blend: function(other) {
-      this.rgb.r = Math.floor((this.rgb.r + other.rgb.r)/2);
-      this.rgb.g = Math.floor((this.rgb.g + other.rgb.g)/2);
-      this.rgb.b = Math.floor((this.rgb.b + other.rgb.b)/2);
-   isBright: function() {
-      return this.asHSB().b > 0.5;
-   isDark: function() {
-      return ! this.isBright();
-   asRGB: function() {
-      return "rgb(" + this.rgb.r + "," + this.rgb.g + "," + this.rgb.b + ")";
-   asHex: function() {
-      return "#" + this.rgb.r.toColorPart() + this.rgb.g.toColorPart() + this.rgb.b.toColorPart();
-   asHSB: function() {
-      return OpenLayers.Rico.Color.RGBtoHSB(this.rgb.r, this.rgb.g, this.rgb.b);
-   toString: function() {
-      return this.asHex();
-OpenLayers.Rico.Color.createFromHex = function(hexCode) {
-  if(hexCode.length==4) {
-    var shortHexCode = hexCode;
-    var hexCode = '#';
-    for(var i=1;i<4;i++) {
-        hexCode += (shortHexCode.charAt(i) +
-shortHexCode.charAt(i));
-   if ( hexCode.indexOf('#') == 0 ) {
-       hexCode = hexCode.substring(1);
-   var red   = hexCode.substring(0,2);
-   var green = hexCode.substring(2,4);
-   var blue  = hexCode.substring(4,6);
-   return new OpenLayers.Rico.Color( parseInt(red,16), parseInt(green,16), parseInt(blue,16) );
- * Factory method for creating a color from the background of
- * an HTML element.
-OpenLayers.Rico.Color.createColorFromBackground = function(elem) {
-   var actualColor =
-      RicoUtil.getElementsComputedStyle(OpenLayers.Util.getElement(elem),
-                                        "backgroundColor",
-                                        "background-color");
-   if ( actualColor == "transparent" && elem.parentNode ) {
-      return OpenLayers.Rico.Color.createColorFromBackground(elem.parentNode);
-   if ( actualColor == null ) {
-      return new OpenLayers.Rico.Color(255,255,255);
-   if ( actualColor.indexOf("rgb(") == 0 ) {
-      var colors = actualColor.substring(4, actualColor.length - 1 );
-      var colorArray = colors.split(",");
-      return new OpenLayers.Rico.Color( parseInt( colorArray[0] ),
-                            parseInt( colorArray[1] ),
-                            parseInt( colorArray[2] )  );
-   else if ( actualColor.indexOf("#") == 0 ) {
-      return OpenLayers.Rico.Color.createFromHex(actualColor);
-   else {
-OpenLayers.Rico.Color.HSBtoRGB = function(hue, saturation, brightness) {
-   var red   = 0;
-    var green = 0;
-    var blue  = 0;
-   if (saturation == 0) {
-      red = parseInt(brightness * 255.0 + 0.5);
-       green = red;
-       blue = red;
-    else {
-      var h = (hue - Math.floor(hue)) * 6.0;
-      var f = h - Math.floor(h);
-      var p = brightness * (1.0 - saturation);
-      var q = brightness * (1.0 - saturation * f);
-      var t = brightness * (1.0 - (saturation * (1.0 - f)));
-      switch (parseInt(h)) {
-         case 0:
-            red   = (brightness * 255.0 + 0.5);
-            green = (t * 255.0 + 0.5);
-            blue  = (p * 255.0 + 0.5);
-            break;
-         case 1:
-            red   = (q * 255.0 + 0.5);
-            green = (brightness * 255.0 + 0.5);
-            break;
-         case 2:
-            red   = (p * 255.0 + 0.5);
-            blue  = (t * 255.0 + 0.5);
-            break;
-         case 3:
-            green = (q * 255.0 + 0.5);
-            blue  = (brightness * 255.0 + 0.5);
-            break;
-         case 4:
-            red   = (t * 255.0 + 0.5);
-            green = (p * 255.0 + 0.5);
-            break;
-          case 5:
-            blue  = (q * 255.0 + 0.5);
-            break;
-   return { r : parseInt(red), g : parseInt(green) , b : parseInt(blue) };
-OpenLayers.Rico.Color.RGBtoHSB = function(r, g, b) {
-   var hue;
-   var saturation;
-   var brightness;
-   var cmax = (r > g) ? r : g;
-   if (b > cmax) {
-      cmax = b;
-   var cmin = (r < g) ? r : g;
-   if (b < cmin) {
-      cmin = b;
-   brightness = cmax / 255.0;
-   if (cmax != 0) {
-      saturation = (cmax - cmin)/cmax;
-   } else {
-      saturation = 0;
-      hue = 0;
-   } else {
-      var redc   = (cmax - r)/(cmax - cmin);
-        var greenc = (cmax - g)/(cmax - cmin);
-        var bluec  = (cmax - b)/(cmax - cmin);
-        if (r == cmax) {
-           hue = bluec - greenc;
-        } else if (g == cmax) {
-           hue = 2.0 + redc - bluec;
-      } else {
-           hue = 4.0 + greenc - redc;
-        hue = hue / 6.0;
-        if (hue < 0) {
-           hue = hue + 1.0;
-   return { h : hue, s : saturation, b : brightness };
     OpenLayers/Control/ArgParser.js
@@ -7266,1144 +5899,6 @@
     CLASS_NAME: "OpenLayers.Control.ArgParser"
-    OpenLayers/Control/Attribution.js
- * @requires OpenLayers/Control.js
- * Class: OpenLayers.Control.Attribution
- * Add attribution from layers to the map display. Uses 'attribution' property
- * of each layer.
-OpenLayers.Control.Attribution =
-  OpenLayers.Class(OpenLayers.Control, {
-     * APIProperty: seperator
-     * {String} String used to seperate layers.
-    separator: ", ",
-     * Constructor: OpenLayers.Control.Attribution
-     * Parameters:
-     * options - {Object} Options for control.
-    initialize: function(options) {
-        OpenLayers.Control.prototype.initialize.apply(this, arguments);
-     * Method: destroy
-     * Destroy control.
-        this.map.events.un({
-            "removelayer": this.updateAttribution,
-            "addlayer": this.updateAttribution,
-            "changelayer": this.updateAttribution,
-            "changebaselayer": this.updateAttribution,
-            scope: this
-        OpenLayers.Control.prototype.destroy.apply(this, arguments);
-     * Method: draw
-     * Initialize control.
-     * Returns:
-     * {DOMElement} A reference to the DIV DOMElement containing the control
-    draw: function() {
-        OpenLayers.Control.prototype.draw.apply(this, arguments);
-        this.map.events.on({
-            'changebaselayer': this.updateAttribution,
-            'changelayer': this.updateAttribution,
-            'addlayer': this.updateAttribution,
-            'removelayer': this.updateAttribution,
-            scope: this
-        this.updateAttribution();
-        return this.div;
-     * Method: updateAttribution
-     * Update attribution string.
-    updateAttribution: function() {
-        var attributions = [];
-        if (this.map && this.map.layers) {
-            for(var i=0; i < this.map.layers.length; i++) {
-                var layer = this.map.layers[i];
-                if (layer.attribution && layer.getVisibility()) {
-                    attributions.push( layer.attribution );
-            this.div.innerHTML = attributions.join(this.separator);
-    CLASS_NAME: "OpenLayers.Control.Attribution"
-    OpenLayers/Control/Button.js
-/* Copyright (c) 2006-2007 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * for the full text of the license. */
- * Class: OpenLayers.Control.Button
- * A very simple button controlfor use with <OpenLayers.Control.Panel>.
- * When clicked, the function trigger() is executed.
- * Inherits from:
- *  - <OpenLayers.Control>
- * Use:
- * (code)
- * var button = new OpenLayers.Control.Button({
- *     displayClass: "MyButton", trigger: myFunction
- * panel.addControls([button]);
- * (end)
- * Will create a button with CSS class MyButtonItemInactive, that
- *     will call the function MyFunction() when clicked.
-OpenLayers.Control.Button = OpenLayers.Class(OpenLayers.Control, {
-     * Property: type
-     * {Integer} OpenLayers.Control.TYPE_BUTTON.
-    type: OpenLayers.Control.TYPE_BUTTON,
-     * Method: trigger
-     * Called by a control panel when the button is clicked.
-    trigger: function() {},
-    CLASS_NAME: "OpenLayers.Control.Button"
-    OpenLayers/Control/LayerSwitcher.js
- * Class: OpenLayers.Control.LayerSwitcher
- * Inherits from:
-OpenLayers.Control.LayerSwitcher =
-     * Property: activeColor
-     * {String}
-    activeColor: "darkblue",
-     * Property: layerStates
-     * {Array(Object)} Basically a copy of the "state" of the map's layers
-     *     the last time the control was drawn. We have this in order to avoid
-     *     unnecessarily redrawing the control.
-    layerStates: null,
-  // DOM Elements
-     * Property: layersDiv
-     * {DOMElement}
-    layersDiv: null,
-     * Property: baseLayersDiv
-     * {DOMElement}
-    baseLayersDiv: null,
-     * {Array(<OpenLayers.Layer>)}
-    baseLayers: null,
-     * Property: dataLbl
-     * {DOMElement}
-    dataLbl: null,
-     * Property: dataLayersDiv
-     * {DOMElement}
-    dataLayersDiv: null,
-    dataLayers: null,
-     * Property: minimizeDiv
-     * {DOMElement}
-    minimizeDiv: null,
-     * Property: maximizeDiv
-     * {DOMElement}
-    maximizeDiv: null,
-     * APIProperty: ascending
-     * {Boolean}
-    ascending: true,
-     * Constructor: OpenLayers.Control.LayerSwitcher
-     * Parameters:
-        this.layerStates = [];
-        OpenLayers.Event.stopObservingElement(this.div);
-        OpenLayers.Event.stopObservingElement(this.minimizeDiv);
-        OpenLayers.Event.stopObservingElement(this.maximizeDiv);
-        //clear out layers info and unregister their events
-        this.clearLayersArray("base");
-        this.clearLayersArray("data");
-            "addlayer": this.redraw,
-            "changelayer": this.redraw,
-            "removelayer": this.redraw,
-            "changebaselayer": this.redraw,
-            scope: this
-     * Method: setMap
-     * Properties:
-     * map - {<OpenLayers.Map>}
-    setMap: function(map) {
-        OpenLayers.Control.prototype.setMap.apply(this, arguments);
-            scope: this
-     * Method: draw
-     * Returns:
-     *     switcher tabs.
-        OpenLayers.Control.prototype.draw.apply(this);
-        // create layout divs
-        this.loadContents();
-        // set mode to minimize
-        if(!this.outsideViewport) {
-            this.minimizeControl();
-        // populate div with current info
-        this.redraw();
-        return this.div;
-     * Method: clearLayersArray
-     * User specifies either "base" or "data". we then clear all the
-     *     corresponding listeners, the div, and reinitialize a new array.
-     * Parameters:
-     * layersType - {String}
-    clearLayersArray: function(layersType) {
-        var layers = this[layersType + "Layers"];
-        if (layers) {
-            for(var i=0; i < layers.length; i++) {
-                var layer = layers[i];
-                OpenLayers.Event.stopObservingElement(layer.inputElem);
-                OpenLayers.Event.stopObservingElement(layer.labelSpan);
-        this[layersType + "LayersDiv"].innerHTML = "";
-        this[layersType + "Layers"] = [];
-     * Method: checkRedraw
-     * Checks if the layer state has changed since the last redraw() call.
-     * Returns:
-     * {Boolean} The layer state changed since the last redraw() call.
-    checkRedraw: function() {
-        var redraw = false;
-        if ( !this.layerStates.length ||
-             (this.map.layers.length != this.layerStates.length) ) {
-            redraw = true;
-        } else {
-            for (var i=0; i < this.layerStates.length; i++) {
-                var layerState = this.layerStates[i];
-                if ( (layerState.name != layer.name) ||
-                     (layerState.inRange != layer.inRange) ||
-                     (layerState.id != layer.id) ||
-                     (layerState.visibility != layer.visibility) ) {
-                    redraw = true;
-                    break;
-        return redraw;
-     * Method: redraw
-     * Goes through and takes the current state of the Map and rebuilds the
-     *     control to display that state. Groups base layers into a
-     *     radio-button group and lists each data layer with a checkbox.
-     * Returns:
-    redraw: function() {
-        //if the state hasn't changed since last redraw, no need
-        // to do anything. Just return the existing div.
-        if (!this.checkRedraw()) {
-            return this.div;
-        //clear out previous layers
-        var containsOverlays = false;
-        var containsBaseLayers = false;
-        // Save state -- for checking layer if the map state changed.
-        // We save this before redrawing, because in the process of redrawing
-        // we will trigger more visibility changes, and we want to not redraw
-        // and enter an infinite loop.
-        this.layerStates = new Array(this.map.layers.length);
-        for (var i = 0; i < this.map.layers.length; i++) {
-            this.layerStates[i] = {
-                'name': layer.name,
-                'visibility': layer.visibility,
-                'inRange': layer.inRange,
-                'id': layer.id
-        var layers = this.map.layers.slice();
-        if (!this.ascending) { layers.reverse(); }
-        for( var i = 0; i < layers.length; i++) {
-            var baseLayer = layer.isBaseLayer;
-            if (layer.displayInLayerSwitcher) {
-                if (baseLayer) {
-                    containsBaseLayers = true;
-                } else {
-                    containsOverlays = true;
-                // only check a baselayer if it is *the* baselayer, check data
-                //  layers if they are visible
-                var checked = (baseLayer) ? (layer == this.map.baseLayer)
-                                          : layer.getVisibility();
-                // create input element
-                var inputElem = document.createElement("input");
-                inputElem.id = "input_" + layer.name;
-                inputElem.name = (baseLayer) ? "baseLayers" : layer.name;
-                inputElem.type = (baseLayer) ? "radio" : "checkbox";
-                inputElem.value = layer.name;
-                inputElem.checked = checked;
-                inputElem.defaultChecked = checked;
-                if (!baseLayer && !layer.inRange) {
-                    inputElem.disabled = true;
-                var context = {
-                    'inputElem': inputElem,
-                    'layer': layer,
-                    'layerSwitcher': this
-                OpenLayers.Event.observe(inputElem, "mouseup",
-                    OpenLayers.Function.bindAsEventListener(this.onInputClick,
-                                                            context)
-                // create span
-                var labelSpan = document.createElement("span");
-                    labelSpan.style.color = "gray";
-                labelSpan.innerHTML = layer.name;
-                labelSpan.style.verticalAlign = (baseLayer) ? "bottom"
-                                                            : "baseline";
-                OpenLayers.Event.observe(labelSpan, "click",
-                                                            context)
-                // create line break
-                var br = document.createElement("br");
-                var groupArray = (baseLayer) ? this.baseLayers
-                                             : this.dataLayers;
-                groupArray.push({
-                    'layer': layer,
-                    'labelSpan': labelSpan
-                var groupDiv = (baseLayer) ? this.baseLayersDiv
-                                           : this.dataLayersDiv;
-                groupDiv.appendChild(inputElem);
-                groupDiv.appendChild(labelSpan);
-                groupDiv.appendChild(br);
-        // if no overlays, dont display the overlay label
-        this.dataLbl.style.display = (containsOverlays) ? "" : "none";
-        // if no baselayers, dont display the baselayer label
-        this.baseLbl.style.display = (containsBaseLayers) ? "" : "none";
-        return this.div;
-     * Method:
-     * A label has been clicked, check or uncheck its corresponding input
-     * Parameters:
-     * e - {Event}
-     * Context:
-     *  - {DOMElement} inputElem
-     *  - {<OpenLayers.Control.LayerSwitcher>} layerSwitcher
-     *  - {<OpenLayers.Layer>} layer
-    onInputClick: function(e) {
-        if (!this.inputElem.disabled) {
-            if (this.inputElem.type == "radio") {
-                this.inputElem.checked = true;
-                this.layer.map.setBaseLayer(this.layer);
-            } else {
-                this.inputElem.checked = !this.inputElem.checked;
-                this.layerSwitcher.updateMap();
-     * Method: onLayerClick
-     * Need to update the map accordingly whenever user clicks in either of
-     *     the layers.
-     * Parameters:
-     * e - {Event}
-    onLayerClick: function(e) {
-        this.updateMap();
-     * Method: updateMap
-     * Cycles through the loaded data and base layer input arrays and makes
-     *     the necessary calls to the Map object such that that the map's
-     *     visual state corresponds to what the user has selected in
-     *     the control.
-    updateMap: function() {
-        // set the newly selected base layer
-        for(var i=0; i < this.baseLayers.length; i++) {
-            var layerEntry = this.baseLayers[i];
-            if (layerEntry.inputElem.checked) {
-                this.map.setBaseLayer(layerEntry.layer, false);
-        // set the correct visibilities for the overlays
-        for(var i=0; i < this.dataLayers.length; i++) {
-            var layerEntry = this.dataLayers[i];
-            layerEntry.layer.setVisibility(layerEntry.inputElem.checked);
-     * Method: maximizeControl
-     * Set up the labels and divs for the control
-     * Parameters:
-     * e - {Event}
-    maximizeControl: function(e) {
-        //HACK HACK HACK - find a way to auto-size this layerswitcher
-        this.div.style.width = "20em";
-        this.div.style.height = "";
-        this.showControls(false);
-        if (e != null) {
-     * Method: minimizeControl
-     * Hide all the contents of the control, shrink the size,
-     *     add the maximize icon
-     * Parameters:
-     * e - {Event}
-    minimizeControl: function(e) {
-        this.div.style.width = "0px";
-        this.div.style.height = "0px";
-        this.showControls(true);
-        if (e != null) {
-     * Method: showControls
-     * Hide/Show all LayerSwitcher controls depending on whether we are
-     *     minimized or not
-     * Parameters:
-     * minimize - {Boolean}
-    showControls: function(minimize) {
-        this.maximizeDiv.style.display = minimize ? "" : "none";
-        this.minimizeDiv.style.display = minimize ? "none" : "";
-        this.layersDiv.style.display = minimize ? "none" : "";
-     * Method: loadContents
-    loadContents: function() {
-        //configure main div
-        this.div.style.position = "absolute";
-        this.div.style.top = "25px";
-        this.div.style.right = "0px";
-        this.div.style.left = "";
-        this.div.style.fontFamily = "sans-serif";
-        this.div.style.fontWeight = "bold";
-        this.div.style.marginTop = "3px";
-        this.div.style.marginLeft = "3px";
-        this.div.style.marginBottom = "3px";
-        this.div.style.fontSize = "smaller";
-        this.div.style.color = "white";
-        this.div.style.backgroundColor = "transparent";
-        OpenLayers.Event.observe(this.div, "mouseup",
-            OpenLayers.Function.bindAsEventListener(this.mouseUp, this));
-        OpenLayers.Event.observe(this.div, "click",
-                      this.ignoreEvent);
-        OpenLayers.Event.observe(this.div, "mousedown",
-            OpenLayers.Function.bindAsEventListener(this.mouseDown, this));
-        OpenLayers.Event.observe(this.div, "dblclick", this.ignoreEvent);
-        // layers list div
-        this.layersDiv = document.createElement("div");
-        this.layersDiv.id = "layersDiv";
-        this.layersDiv.style.paddingTop = "5px";
-        this.layersDiv.style.paddingLeft = "10px";
-        this.layersDiv.style.paddingBottom = "5px";
-        this.layersDiv.style.paddingRight = "75px";
-        this.layersDiv.style.backgroundColor = this.activeColor;
-        // had to set width/height to get transparency in IE to work.
-        // thanks -- http://jszen.blogspot.com/2005/04/ie6-opacity-filter-caveat.html
-        this.layersDiv.style.width = "100%";
-        this.layersDiv.style.height = "100%";
-        this.baseLbl = document.createElement("div");
-        this.baseLbl.innerHTML = OpenLayers.i18n("baseLayer");
-        this.baseLbl.style.marginTop = "3px";
-        this.baseLbl.style.marginLeft = "3px";
-        this.baseLbl.style.marginBottom = "3px";
-        this.baseLayersDiv = document.createElement("div");
-        this.baseLayersDiv.style.paddingLeft = "10px";
-        /*OpenLayers.Event.observe(this.baseLayersDiv, "click",
-            OpenLayers.Function.bindAsEventListener(this.onLayerClick, this));
-        this.dataLbl = document.createElement("div");
-        this.dataLbl.innerHTML = OpenLayers.i18n("overlays");
-        this.dataLbl.style.marginTop = "3px";
-        this.dataLbl.style.marginLeft = "3px";
-        this.dataLbl.style.marginBottom = "3px";
-        this.dataLayersDiv = document.createElement("div");
-        this.dataLayersDiv.style.paddingLeft = "10px";
-        if (this.ascending) {
-            this.layersDiv.appendChild(this.baseLbl);
-            this.layersDiv.appendChild(this.baseLayersDiv);
-            this.layersDiv.appendChild(this.dataLbl);
-            this.layersDiv.appendChild(this.dataLayersDiv);
-        } else {
-        this.div.appendChild(this.layersDiv);
-        OpenLayers.Rico.Corner.round(this.div, {corners: "tl bl",
-                                        bgColor: "transparent",
-                                        color: this.activeColor,
-                                        blend: false});
-        OpenLayers.Rico.Corner.changeOpacity(this.layersDiv, 0.75);
-        var imgLocation = OpenLayers.Util.getImagesLocation();
-        var sz = new OpenLayers.Size(18,18);
-        // maximize button div
-        var img = imgLocation + 'layer-switcher-maximize.png';
-        this.maximizeDiv = OpenLayers.Util.createAlphaImageDiv(
-                                    "OpenLayers_Control_MaximizeDiv",
-                                    null,
-                                    sz,
-                                    img,
-                                    "absolute");
-        this.maximizeDiv.style.top = "5px";
-        this.maximizeDiv.style.right = "0px";
-        this.maximizeDiv.style.left = "";
-        this.maximizeDiv.style.display = "none";
-        OpenLayers.Event.observe(this.maximizeDiv, "click",
-            OpenLayers.Function.bindAsEventListener(this.maximizeControl, this)
-        this.div.appendChild(this.maximizeDiv);
-        // minimize button div
-        var img = imgLocation + 'layer-switcher-minimize.png';
-        this.minimizeDiv = OpenLayers.Util.createAlphaImageDiv(
-                                    "OpenLayers_Control_MinimizeDiv",
-                                    null,
-                                    sz,
-                                    img,
-                                    "absolute");
-        this.minimizeDiv.style.top = "5px";
-        this.minimizeDiv.style.right = "0px";
-        this.minimizeDiv.style.left = "";
-        this.minimizeDiv.style.display = "none";
-        OpenLayers.Event.observe(this.minimizeDiv, "click",
-            OpenLayers.Function.bindAsEventListener(this.minimizeControl, this)
-        this.div.appendChild(this.minimizeDiv);
-     * Method: ignoreEvent
-     * Parameters:
-     * evt - {Event}
-    ignoreEvent: function(evt) {
-        OpenLayers.Event.stop(evt);
-     * Method: mouseDown
-     * Register a local 'mouseDown' flag so that we'll know whether or not
-     *     to ignore a mouseUp event
-     * Parameters:
-     * evt - {Event}
-    mouseDown: function(evt) {
-        this.isMouseDown = true;
-        this.ignoreEvent(evt);
-     * Method: mouseUp
-     * If the 'isMouseDown' flag has been set, that means that the drag was
-     *     started from within the LayerSwitcher control, and thus we can
-     *     ignore the mouseup. Otherwise, let the Event continue.
-     * Parameters:
-     * evt - {Event}
-    mouseUp: function(evt) {
-        if (this.isMouseDown) {
-            this.isMouseDown = false;
-    CLASS_NAME: "OpenLayers.Control.LayerSwitcher"
-    OpenLayers/Control/MouseDefaults.js
- * Class: OpenLayers.Control.MouseDefaults
- * Inherits from:
-OpenLayers.Control.MouseDefaults = OpenLayers.Class(OpenLayers.Control, {
-    /** WARNING WARNING WARNING!!!
-        This class is DEPRECATED in 2.4 and will be removed by 3.0.
-        If you need this functionality, use Control.Navigation instead!!! */
-     * Property: performedDrag
-     * {Boolean}
-    performedDrag: false,
-     * Property: wheelObserver
-     * {Function}
-    wheelObserver: null,
-     * Constructor: OpenLayers.Control.MouseDefaults
-    initialize: function() {
-        if (this.handler) {
-            this.handler.destroy();
-        this.handler = null;
-            "click": this.defaultClick,
-            "dblclick": this.defaultDblClick,
-            "mousedown": this.defaultMouseDown,
-            "mouseup": this.defaultMouseUp,
-            "mousemove": this.defaultMouseMove,
-            "mouseout": this.defaultMouseOut,
-            scope: this
-        //unregister mousewheel events specifically on the window and document
-        OpenLayers.Event.stopObserving(window, "DOMMouseScroll",
-                                        this.wheelObserver);
-        OpenLayers.Event.stopObserving(window, "mousewheel",
-        OpenLayers.Event.stopObserving(document, "mousewheel",
-        this.wheelObserver = null;
-     * Method: draw
-            scope: this
-        this.registerWheelEvents();
-     * Method: registerWheelEvents
-    registerWheelEvents: function() {
-        this.wheelObserver = OpenLayers.Function.bindAsEventListener(
-            this.onWheelEvent, this
-        //register mousewheel events specifically on the window and document
-        OpenLayers.Event.observe(window, "DOMMouseScroll", this.wheelObserver);
-        OpenLayers.Event.observe(window, "mousewheel", this.wheelObserver);
-        OpenLayers.Event.observe(document, "mousewheel", this.wheelObserver);
-     * Method: defaultClick
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {Boolean}
-    defaultClick: function (evt) {
-        if (!OpenLayers.Event.isLeftClick(evt)) {
-            return;
-        var notAfterDrag = !this.performedDrag;
-        this.performedDrag = false;
-        return notAfterDrag;
-     * Method: defaultDblClick
-     * Parameters:
-     * evt - {Event}
-    defaultDblClick: function (evt) {
-        var newCenter = this.map.getLonLatFromViewPortPx( evt.xy );
-        this.map.setCenter(newCenter, this.map.zoom + 1);
-        return false;
-     * Method: defaultMouseDown
-     * Parameters:
-     * evt - {Event}
-    defaultMouseDown: function (evt) {
-            return;
-        this.mouseDragStart = evt.xy.clone();
-        if (evt.shiftKey) {
-            this.map.div.style.cursor = "crosshair";
-            this.zoomBox = OpenLayers.Util.createDiv('zoomBox',
-                                                     this.mouseDragStart,
-                                                     null,
-                                                     null,
-                                                     "absolute",
-                                                     "2px solid red");
-            this.zoomBox.style.backgroundColor = "white";
-            this.zoomBox.style.filter = "alpha(opacity=50)"; // IE
-            this.zoomBox.style.opacity = "0.50";
-            this.zoomBox.style.fontSize = "1px";
-            this.zoomBox.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
-            this.map.viewPortDiv.appendChild(this.zoomBox);
-        document.onselectstart=function() { return false; };
-     * Method: defaultMouseMove
-     * Parameters:
-     * evt - {Event}
-    defaultMouseMove: function (evt) {
-        // record the mouse position, used in onWheelEvent
-        this.mousePosition = evt.xy.clone();
-        if (this.mouseDragStart != null) {
-            if (this.zoomBox) {
-                var deltaX = Math.abs(this.mouseDragStart.x - evt.xy.x);
-                var deltaY = Math.abs(this.mouseDragStart.y - evt.xy.y);
-                this.zoomBox.style.width = Math.max(1, deltaX) + "px";
-                this.zoomBox.style.height = Math.max(1, deltaY) + "px";
-                if (evt.xy.x < this.mouseDragStart.x) {
-                    this.zoomBox.style.left = evt.xy.x+"px";
-                if (evt.xy.y < this.mouseDragStart.y) {
-                    this.zoomBox.style.top = evt.xy.y+"px";
-            } else {
-                var deltaX = this.mouseDragStart.x - evt.xy.x;
-                var deltaY = this.mouseDragStart.y - evt.xy.y;
-                var size = this.map.getSize();
-                var newXY = new OpenLayers.Pixel(size.w / 2 + deltaX,
-                                                 size.h / 2 + deltaY);
-                var newCenter = this.map.getLonLatFromViewPortPx( newXY );
-                this.map.setCenter(newCenter, null, true);
-                this.map.div.style.cursor = "move";
-            this.performedDrag = true;
-     * Method: defaultMouseUp
-     * Parameters:
-    defaultMouseUp: function (evt) {
-            return;
-            this.zoomBoxEnd(evt);
-        } else {
-            if (this.performedDrag) {
-                this.map.setCenter(this.map.center);
-        document.onselectstart=null;
-        this.mouseDragStart = null;
-        this.map.div.style.cursor = "";
-     * Method: defaultMouseOut
-     * Parameters:
-     * evt - {Event}
-    defaultMouseOut: function (evt) {
-        if (this.mouseDragStart != null &&
-            OpenLayers.Util.mouseLeft(evt, this.map.div)) {
-                this.removeZoomBox();
-     * Method: defaultWheelUp
-     * User spun scroll wheel up
-    defaultWheelUp: function(evt) {
-        if (this.map.getZoom() <= this.map.getNumZoomLevels()) {
-            this.map.setCenter(this.map.getLonLatFromPixel(evt.xy),
-                               this.map.getZoom() + 1);
-     * Method: defaultWheelDown
-     * User spun scroll wheel down
-    defaultWheelDown: function(evt) {
-        if (this.map.getZoom() > 0) {
-                               this.map.getZoom() - 1);
-     * Method: zoomBoxEnd
-     * Zoombox function.
-    zoomBoxEnd: function(evt) {
-            if (Math.abs(this.mouseDragStart.x - evt.xy.x) > 5 ||
-                Math.abs(this.mouseDragStart.y - evt.xy.y) > 5) {
-                var start = this.map.getLonLatFromViewPortPx( this.mouseDragStart );
-                var end = this.map.getLonLatFromViewPortPx( evt.xy );
-                var top = Math.max(start.lat, end.lat);
-                var bottom = Math.min(start.lat, end.lat);
-                var left = Math.min(start.lon, end.lon);
-                var right = Math.max(start.lon, end.lon);
-                var bounds = new OpenLayers.Bounds(left, bottom, right, top);
-                this.map.zoomToExtent(bounds);
-            } else {
-                this.map.setCenter(new OpenLayers.LonLat(
-                  (end.lon),
-                  (end.lat)
-                 ), this.map.getZoom() + 1);
-     * Method: removeZoomBox
-     * Remove the zoombox from the screen and nullify our reference to it.
-    removeZoomBox: function() {
-        this.map.viewPortDiv.removeChild(this.zoomBox);
-        this.zoomBox = null;
- *  Mouse ScrollWheel code thanks to http://adomas.org/javascript-mouse-wheel/
-     * Method: onWheelEvent
-     * Catch the wheel event and handle it xbrowserly
-     * Parameters:
-     * e - {Event}
-    onWheelEvent: function(e){
-        // first determine whether or not the wheeling was inside the map
-        var inMap = false;
-        var elem = OpenLayers.Event.element(e);
-        while(elem != null) {
-            if (this.map && elem == this.map.div) {
-                inMap = true;
-                break;
-            elem = elem.parentNode;
-        if (inMap) {
-            var delta = 0;
-            if (!e) {
-                e = window.event;
-            if (e.wheelDelta) {
-                delta = e.wheelDelta/120;
-                if (window.opera && window.opera.version() < 9.2) {
-                    delta = -delta;
-            } else if (e.detail) {
-                delta = -e.detail / 3;
-            if (delta) {
-                // add the mouse position to the event because mozilla has a bug
-                // with clientX and clientY (see https://bugzilla.mozilla.org/show_bug.cgi?id=352179)
-                // getLonLatFromViewPortPx(e) returns wrong values
-                e.xy = this.mousePosition;
-                if (delta < 0) {
-                   this.defaultWheelDown(e);
-                } else {
-                   this.defaultWheelUp(e);
-            //only wheel the map, not the window
-    CLASS_NAME: "OpenLayers.Control.MouseDefaults"
     OpenLayers/Control/MousePosition.js
@@ -8449,7 +5944,7 @@
      * APIProperty: numDigits
      * {Integer}
-    numdigits: 5,
+    numDigits: 5,
      * APIProperty: granularity
@@ -8553,7 +6048,7 @@
      * lonLat - {<OpenLayers.LonLat>} Location to display
     formatOutput: function(lonLat) {
-        var digits = parseInt(this.numdigits);
+        var digits = parseInt(this.numDigits);
         var newHtml =
             this.prefix +
             lonLat.lon.toFixed(digits) +
@@ -8574,408 +6069,6 @@
     CLASS_NAME: "OpenLayers.Control.MousePosition"
-    OpenLayers/Control/NavigationHistory.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * Class: OpenLayers.Control.NavigationHistory
- * A navigation history control.  This is a meta-control, that creates two
- *     dependent controls: <previous> and <next>.  Call the trigger method
- *     on the <previous> and <next> controls to restore previous and next
- *     history states.  The previous and next controls will become active
- *     when there are available states to restore and will become deactive
- *     when there are no states to restore.
- * Inherits from:
-OpenLayers.Control.NavigationHistory = OpenLayers.Class(OpenLayers.Control, {
-     * Property: type
-     * {String} Note that this control is not intended to be added directly
-     *     to a control panel.  Instead, add the sub-controls previous and
-     *     next.  These sub-controls are button type controls that activate
-     *     and deactivate themselves.  If this parent control is added to
-     *     a panel, it will act as a toggle.
-    type: OpenLayers.Control.TYPE_TOGGLE,
-     * APIProperty: previous
-     * {<OpenLayers.Control>} A button type control whose trigger method restores
-     *     the previous state managed by this control.
-    previous: null,
-     * APIProperty: previousOptions
-     * {Object} Set this property on the options argument of the constructor
-     *     to set optional properties on the <previous> control.
-    previousOptions: null,
-     * APIProperty: next
-     *     the next state managed by this control.
-    next: null,
-     * APIProperty: nextOptions
-     *     to set optional properties on the <next> control.
-    nextOptions: null,
-     * APIProperty: limit
-     * {Integer} Optional limit on the number of history items to retain.  If
-     *     null, there is no limit.  Default is 50.
-    limit: 50,
-     * Property: activateOnDraw
-     * {Boolean} Activate the control when it is first added to the map.
-     *     Default is true.
-    activateOnDraw: true,
-     * Property: clearOnDeactivate
-     * {Boolean} Clear the history when the control is deactivated.  Default
-     *     is false.
-    clearOnDeactivate: false,
-     * Property: registry
-     * {Object} An object with keys corresponding to event types.  Values
-     *     are functions that return an object representing the current state.
-    registry: null,
-     * Property: nextStack
-     * {Array} Array of items in the history.
-    nextStack: null,
-     * Property: previousStack
-     * {Array} List of items in the history.  First item represents the current
-     *     state.
-    previousStack: null,
-     * Property: listeners
-     * {Object} An object containing properties corresponding to event types.
-     *     This object is used to configure the control and is modified on
-     *     construction.
-    listeners: null,
-     * Property: restoring
-     * {Boolean} Currently restoring a history state.  This is set to true
-     *     before calling restore and set to false after restore returns.
-    restoring: false,
-     * Constructor: OpenLayers.Control.NavigationHistory
-     * Parameters:
-     * options - {Object} An optional object whose properties will be used
-     *     to extend the control.
-        OpenLayers.Control.prototype.initialize.apply(this, [options]);
-        this.registry = OpenLayers.Util.extend({
-            "moveend": function() {
-                return {
-                    center: this.map.getCenter(),
-                    resolution: this.map.getResolution()
-        }, this.registry);
-        this.clear();
-        var previousOptions = {
-            trigger: OpenLayers.Function.bind(this.previousTrigger, this),
-            displayClass: this.displayClass + "Previous"
-        OpenLayers.Util.extend(previousOptions, this.previousOptions);
-        this.previous = new OpenLayers.Control.Button(previousOptions);
-        var nextOptions = {
-            trigger: OpenLayers.Function.bind(this.nextTrigger, this),
-            displayClass: this.displayClass + "Next"
-        OpenLayers.Util.extend(nextOptions, this.nextOptions);
-        this.next = new OpenLayers.Control.Button(nextOptions);
-     * Method: onPreviousChange
-     * Called when the previous history stack changes.
-     * Parameters:
-     * state - {Object} An object representing the state to be restored
-     *     if previous is triggered again or null if no previous states remain.
-     * length - {Integer} The number of remaining previous states that can
-     *     be restored.
-    onPreviousChange: function(state, length) {
-        if(state && !this.previous.active) {
-            this.previous.activate();
-        } else if(!state && this.previous.active) {
-            this.previous.deactivate();
-     * Method: onNextChange
-     * Called when the next history stack changes.
-     * Parameters:
-     *     if next is triggered again or null if no next states remain.
-     * length - {Integer} The number of remaining next states that can
-     *     be restored.
-    onNextChange: function(state, length) {
-        if(state && !this.next.active) {
-            this.next.activate();
-        } else if(!state && this.next.active) {
-            this.next.deactivate();
-     * Destroy the control.
-        OpenLayers.Control.prototype.destroy.apply(this);
-        this.previous.destroy();
-        this.next.destroy();
-        this.deactivate();
-        for(var prop in this) {
-            this[prop] = null;
-     * Method: setMap
-     * Set the map property for the control and <previous> and <next> child
-     *     controls.
-     * Parameters:
-        this.map = map;
-        this.next.setMap(map);
-        this.previous.setMap(map);
-     * Method: draw
-     * Called when the control is added to the map.
-        this.next.draw();
-        this.previous.draw();
-        if(this.activateOnDraw) {
-            this.activate();
-     * Method: previousTrigger
-     * Restore the previous state.  If no items are in the previous history
-     *     stack, this has no effect.
-     * Returns:
-     * {Object} Item representing state that was restored.  Undefined if no
-     *     items are in the previous history stack.
-    previousTrigger: function() {
-        var current = this.previousStack.shift();
-        var state = this.previousStack.shift();
-        if(state != undefined) {
-            this.nextStack.unshift(current);
-            this.previousStack.unshift(state);
-            this.restoring = true;
-            this.restore(state);
-            this.restoring = false;
-            this.onNextChange(this.nextStack[0], this.nextStack.length);
-            this.onPreviousChange(
-                this.previousStack[1], this.previousStack.length - 1
-        } else {
-            this.previousStack.unshift(current);
-        return state;
-     * APIMethod: nextTrigger
-     * Restore the next state.  If no items are in the next history
-     *     stack, this has no effect.  The next history stack is populated
-     *     as states are restored from the previous history stack.
-     * Returns:
-     *     items are in the next history stack.
-    nextTrigger: function() {
-        var state = this.nextStack.shift();
-        return state;
-     * APIMethod: clear
-     * Clear history.
-        this.previousStack = [];
-        this.nextStack = [];
-     * Method: restore
-     * Update the state with the given object.
-     * Parameters:
-     * state - {Object} An object representing the state to restore.
-    restore: function(state) {
-        var zoom = this.map.getZoomForResolution(state.resolution);
-        this.map.setCenter(state.center, zoom);
-     * Method: setListeners
-     * Sets functions to be registered in the listeners object.
-    setListeners: function() {
-        this.listeners = {};
-        for(var type in this.registry) {
-            this.listeners[type] = OpenLayers.Function.bind(function() {
-                if(!this.restoring) {
-                    var state = this.registry[type].apply(this, arguments);
-                    if(this.previousStack.length > 1) {
-                    if(this.previousStack.length > (this.limit + 1)) {
-                        this.previousStack.pop();
-                    if(this.nextStack.length > 0) {
-                        this.onNextChange(null, 0);
-                return true;
-            }, this);
-     * APIMethod: activate
-     * Activate the control.  This registers any listeners.
-     * Returns:
-     * {Boolean} Control successfully activated.
-    activate: function() {
-        var activated = false;
-        if(this.map) {
-            if(OpenLayers.Control.prototype.activate.apply(this)) {
-                if(this.listeners == null) {
-                    this.setListeners();
-                for(var type in this.listeners) {
-                    this.map.events.register(type, this, this.listeners[type]);
-                activated = true;
-                if(this.previousStack.length == 0) {
-                    this.initStack();
-        return activated;
-     * Method: initStack
-     * Called after the control is activated if the previous history stack is
-     *     empty.
-    initStack: function() {
-        if(this.map.getCenter()) {
-            this.listeners.moveend();
-     * APIMethod: deactivate
-     * Deactivate the control.  This unregisters any listeners.
-     * Returns:
-     * {Boolean} Control successfully deactivated.
-    deactivate: function() {
-        var deactivated = false;
-        if(this.map) {
-            if(OpenLayers.Control.prototype.deactivate.apply(this)) {
-                    this.map.events.unregister(
-                        type, this, this.listeners[type]
-                if(this.clearOnDeactivate) {
-                    this.clear();
-                deactivated = true;
-        return deactivated;
-    CLASS_NAME: "OpenLayers.Control.NavigationHistory"
     OpenLayers/Control/PanZoom.js
@@ -9180,550 +6273,6 @@
 OpenLayers.Control.PanZoom.Y = 4;
-    OpenLayers/Control/Panel.js
- * Class: OpenLayers.Control.Panel
- * Inherits from:
-OpenLayers.Control.Panel = OpenLayers.Class(OpenLayers.Control, {
-     * Property: controls
-     * {Array(<OpenLayers.Control>)}
-    controls: null,
-     * APIProperty: defaultControl
-     * <OpenLayers.Control> The control which is activated when the control is
-     * activated (turned on), which also happens at instantiation.
-    defaultControl: null,
-     * Constructor: OpenLayers.Control.Panel
-     * Create a new control panel.
-     * Parameters:
-        this.controls = [];
-    destroy: function() {
-        for(var i = this.controls.length - 1 ; i >= 0; i--) {
-            if(this.controls[i].events) {
-                this.controls[i].events.un({
-                    "activate": this.redraw,
-                    "deactivate": this.redraw,
-                    scope: this
-            OpenLayers.Event.stopObservingElement(this.controls[i].panel_div);
-            this.controls[i].panel_div = null;
-        if (OpenLayers.Control.prototype.activate.apply(this, arguments)) {
-            for(var i = 0; i < this.controls.length; i++) {
-                if (this.controls[i] == this.defaultControl) {
-                    this.controls[i].activate();
-            this.redraw();
-            return true;
-        } else {
-            return false;
-        if (OpenLayers.Control.prototype.deactivate.apply(this, arguments)) {
-                this.controls[i].deactivate();
-            return true;
-        } else {
-            return false;
-     * Method: draw
-     * Returns:
-     * {DOMElement}
-        for (var i = 0; i < this.controls.length; i++) {
-            this.map.addControl(this.controls[i]);
-            this.controls[i].events.on({
-                scope: this
-        this.activate();
-        return this.div;
-     * Method: redraw
-        this.div.innerHTML = "";
-        if (this.active) {
-                var element = this.controls[i].panel_div;
-                if (this.controls[i].active) {
-                    element.className = this.controls[i].displayClass + "ItemActive";
-                } else {
-                    element.className = this.controls[i].displayClass + "ItemInactive";
-                this.div.appendChild(element);
-     * APIMethod: activateControl
-     * Parameters:
-     * control - {<OpenLayers.Control>}
-    activateControl: function (control) {
-        if (!this.active) { return false; }
-        if (control.type == OpenLayers.Control.TYPE_BUTTON) {
-            control.trigger();
-            return;
-        if (control.type == OpenLayers.Control.TYPE_TOGGLE) {
-            if (control.active) {
-                control.deactivate();
-            } else {
-                control.activate();
-            return;
-            if (this.controls[i] != control) {
-                if (this.controls[i].type != OpenLayers.Control.TYPE_TOGGLE) {
-     * APIMethod: addControls
-     * To build a toolbar, you add a set of controls to it. addControls
-     * lets you add a single control or a list of controls to the
-     * Control Panel.
-     * Parameters:
-     * controls - {<OpenLayers.Control>}
-    addControls: function(controls) {
-        if (!(controls instanceof Array)) {
-            controls = [controls];
-        this.controls = this.controls.concat(controls);
-        // Give each control a panel_div which will be used later.
-        // Access to this div is via the panel_div attribute of the
-        // control added to the panel.
-        // Also, stop mousedowns and clicks, but don't stop mouseup,
-        // since they need to pass through.
-        for (var i = 0; i < controls.length; i++) {
-            var element = document.createElement("div");
-            var textNode = document.createTextNode(" ");
-            controls[i].panel_div = element;
-            if (controls[i].title != "") {
-                controls[i].panel_div.title = controls[i].title;
-            OpenLayers.Event.observe(controls[i].panel_div, "click",
-                OpenLayers.Function.bind(this.onClick, this, controls[i]));
-            OpenLayers.Event.observe(controls[i].panel_div, "mousedown",
-                OpenLayers.Function.bindAsEventListener(OpenLayers.Event.stop));
-        if (this.map) { // map.addControl() has already been called on the panel
-                this.map.addControl(controls[i]);
-                controls[i].deactivate();
-                controls[i].events.on({
-                    scope: this
-            this.redraw();
-     * Method: onClick
-    onClick: function (ctrl, evt) {
-        OpenLayers.Event.stop(evt ? evt : window.event);
-        this.activateControl(ctrl);
-     * APIMethod: getControlsBy
-     * Get a list of controls with properties matching the given criteria.
-     * Parameter:
-     * property - {String} A control property to be matched.
-     * match - {String | Object} A string to match.  Can also be a regular
-     *     expression literal or object.  In addition, it can be any object
-     *     with a method named test.  For reqular expressions or other, if
-     *     match.test(control[property]) evaluates to true, the control will be
-     *     included in the array returned.  If no controls are found, an empty
-     *     array is returned.
-     * Returns:
-     * {Array(<OpenLayers.Control>)} A list of controls matching the given criteria.
-     *     An empty array is returned if no matches are found.
-    getControlsBy: function(property, match) {
-        var test = (typeof match.test == "function");
-        var found = OpenLayers.Array.filter(this.controls, function(item) {
-            return item[property] == match || (test && match.test(item[property]));
-        return found;
-     * APIMethod: getControlsByName
-     * Get a list of contorls with names matching the given name.
-     * Parameter:
-     * match - {String | Object} A control name.  The name can also be a regular
-     *     name.test(control.name) evaluates to true, the control will be included
-     *     in the list of controls returned.  If no controls are found, an empty
-     * Returns:
-     * {Array(<OpenLayers.Control>)} A list of controls matching the given name.
-    getControlsByName: function(match) {
-        return this.getControlsBy("name", match);
-     * APIMethod: getControlsByClass
-     * Get a list of controls of a given type (CLASS_NAME).
-     * Parameter:
-     * match - {String | Object} A control class name.  The type can also be a
-     *     regular expression literal or object.  In addition, it can be any
-     *     object with a method named test.  For reqular expressions or other,
-     *     if type.test(control.CLASS_NAME) evaluates to true, the control will
-     *     be included in the list of controls returned.  If no controls are
-     *     found, an empty array is returned.
-     * Returns:
-     * {Array(<OpenLayers.Control>)} A list of controls matching the given type.
-    getControlsByClass: function(match) {
-        return this.getControlsBy("CLASS_NAME", match);
-    CLASS_NAME: "OpenLayers.Control.Panel"
-    OpenLayers/Control/Permalink.js
- * Class: OpenLayers.Control.Permalink
- * Inherits from:
-OpenLayers.Control.Permalink = OpenLayers.Class(OpenLayers.Control, {
-     * Property: element
-     * {DOMElement}
-    element: null,
-     * APIProperty: base
-     * {String}
-    base: '',
-     * APIProperty: displayProjection
-     * {<OpenLayers.Projection>} Requires proj4js support.  Projection used
-     *     when creating the coordinates in the link. This will reproject the
-     *     map coordinates into display coordinates. If you are using this
-     *     functionality, the permalink which is last added to the map will
-     *     determine the coordinate type which is read from the URL, which
-     *     means you should not add permalinks with different
-     *     displayProjections to the same map.
-    displayProjection: null,
-     * Constructor: OpenLayers.Control.Permalink
-     * Parameters:
-     * element - {DOMElement}
-     * base - {String}
-     * options - {Object} options to the control.
-    initialize: function(element, base, options) {
-        this.element = OpenLayers.Util.getElement(element);
-        this.base = base || document.location.href;
-        if (this.element.parentNode == this.div) {
-            this.div.removeChild(this.element);
-        this.element = null;
-        this.map.events.unregister('moveend', this, this.updateLink);
-     * Method: setMap
-     * Set the map property for the control.
-     * Parameters:
-        //make sure we have an arg parser attached
-        for(var i=0; i< this.map.controls.length; i++) {
-            var control = this.map.controls[i];
-            if (control.CLASS_NAME == "OpenLayers.Control.ArgParser") {
-                // If a permalink is added to the map, and an ArgParser already
-                // exists, we override the displayProjection to be the one
-                // on the permalink.
-                if (control.displayProjection != this.displayProjection) {
-                    this.displayProjection = control.displayProjection;
-                break;
-        if (i == this.map.controls.length) {
-            this.map.addControl(new OpenLayers.Control.ArgParser(
-                { 'displayProjection': this.displayProjection }));
-     * Method: draw
-     * Returns:
-     * {DOMElement}
-        if (!this.element) {
-            this.element = document.createElement("a");
-            this.element.innerHTML = OpenLayers.i18n("permalink");
-            this.element.href="";
-            this.div.appendChild(this.element);
-            'moveend': this.updateLink,
-            'changelayer': this.updateLink,
-            'changebaselayer': this.updateLink,
-            scope: this
-        return this.div;
-     * Method: updateLink
-    updateLink: function() {
-        var center = this.map.getCenter();
-        // Map not initialized yet. Break out of this function.
-        if (!center) {
-            return;
-        var params = OpenLayers.Util.getParameters(this.base);
-        params.zoom = this.map.getZoom();
-        var lat = center.lat;
-        var lon = center.lon;
-        if (this.displayProjection) {
-            var mapPosition = OpenLayers.Projection.transform(
-              { x: lon, y: lat },
-              this.map.getProjectionObject(),
-              this.displayProjection );
-            lon = mapPosition.x;
-            lat = mapPosition.y;
-        params.lat = Math.round(lat*100000)/100000;
-        params.lon = Math.round(lon*100000)/100000;
-        params.layers = '';
-        for(var i=0; i< this.map.layers.length; i++) {
-            if (layer.isBaseLayer) {
-                params.layers += (layer == this.map.baseLayer) ? "B" : "0";
-            } else {
-                params.layers += (layer.getVisibility()) ? "T" : "F";
-        var href = this.base;
-        if( href.indexOf('?') != -1 ){
-            href = href.substring( 0, href.indexOf('?') );
-        href += '?' + OpenLayers.Util.getParameterString(params);
-        this.element.href = href;
-    CLASS_NAME: "OpenLayers.Control.Permalink"
-    OpenLayers/Control/Scale.js
- * Class: OpenLayers.Control.Scale
- * Display a small scale indicator on the map.
- * Inherits from:
-OpenLayers.Control.Scale = OpenLayers.Class(OpenLayers.Control, {
-     * Parameter: element
-     * {DOMElement}
-    element: null,
-     * Constructor: OpenLayers.Control.Scale
-     * Parameters:
-    initialize: function(element, options) {
-     * Method: draw
-     * Returns:
-     * {DOMElement}
-            this.element = document.createElement("div");
-        this.map.events.register( 'moveend', this, this.updateScale);
-        this.updateScale();
-        return this.div;
-     * Method: updateScale
-    updateScale: function() {
-        var scale = this.map.getScale();
-        if (!scale) {
-            return;
-        if (scale >= 9500 && scale <= 950000) {
-            scale = Math.round(scale / 1000) + "K";
-        } else if (scale >= 950000) {
-            scale = Math.round(scale / 1000000) + "M";
-        } else {
-            scale = Math.round(scale);
-        this.element.innerHTML = OpenLayers.i18n("scale", {'scaleDenom':scale});
-    CLASS_NAME: "OpenLayers.Control.Scale"
     OpenLayers/Control/ScaleLine.js
@@ -9882,7 +6431,7 @@
             return;
-        var curMapUnits = this.map.units;
+        var curMapUnits = this.map.getUnits();
         var inches = OpenLayers.INCHES_PER_UNIT;
         // convert maxWidth to map units
@@ -9928,45 +6477,6 @@
-    OpenLayers/Control/ZoomToMaxExtent.js
- * Class: OpenLayers.Control.ZoomToMaxExtent
- * Imlements a very simple button control. Designed to be used with a
- * <OpenLayers.Control.Panel>.
- * Inherits from:
-OpenLayers.Control.ZoomToMaxExtent = OpenLayers.Class(OpenLayers.Control, {
-     * Property: type
-     * TYPE_BUTTON.
-     * Method: trigger
-     * Do the zoom.
-        if (this.map) {
-            this.map.zoomToMaxExtent();
-    CLASS_NAME: "OpenLayers.Control.ZoomToMaxExtent"
     OpenLayers/Events.js
@@ -10699,99 +7209,6 @@
     CLASS_NAME: "OpenLayers.Events"
-    OpenLayers/Format.js
- * @requires OpenLayers/Util.js
- * Class: OpenLayers.Format
- * Base class for format reading/writing a variety of formats.  Subclasses
- *     of OpenLayers.Format are expected to have read and write methods.
-OpenLayers.Format = OpenLayers.Class({
-     * APIProperty: externalProjection
-     * {<OpenLayers.Projection>} When passed a externalProjection and
-     *     internalProjection, the format will reproject the geometries it
-     *     reads or writes. The externalProjection is the projection used by
-     *     the content which is passed into read or which comes out of write.
-     *     In order to reproject, a projection transformation function for the
-     *     specified projections must be available. This support may be
-     *     provided via proj4js or via a custom transformation function. See
-     *     {<OpenLayers.Projection.addTransform>} for more information on
-     *     custom transformations.
-    externalProjection: null,
-     * APIProperty: internalProjection
-     *     reads or writes. The internalProjection is the projection used by
-     *     the geometries which are returned by read or which are passed into
-     *     write.  In order to reproject, a projection transformation function
-     *     for the specified projections must be available. This support may be
-    internalProjection: null,
-     * Constructor: OpenLayers.Format
-     * Instances of this class are not useful.  See one of the subclasses.
-     * Parameters:
-     * options - {Object} An optional object with properties to set on the
-     *           format
-     * Returns:
-     * An instance of OpenLayers.Format
-        OpenLayers.Util.extend(this, options);
-     * Method: read
-     * Read data from a string, and return an object whose type depends on the
-     * subclass.
-     * Parameters:
-     * data - {string} Data to read/parse.
-     * Returns:
-     * Depends on the subclass
-    read: function(data) {
-        alert(OpenLayers.i18n("readNotImplemented"));
-     * Method: write
-     * Accept an object, and return a string.
-     * Parameters:
-     * object - {Object} Object to be serialized
-     * Returns:
-     * {String} A string representation of the object.
-    write: function(object) {
-        alert(OpenLayers.i18n("writeNotImplemented"));
-    CLASS_NAME: "OpenLayers.Format"
     OpenLayers/Lang/en.js
@@ -10872,7 +7289,7 @@
         "To get rid of this message, select a new BaseLayer " +
         "in the layer switcher in the upper-right corner.<br><br>" +
         "Most likely, this is because the ${layerLib} library " +
-        "script was either not correctly included.<br><br>" +
+        "script was not correctly included.<br><br>" +
         "Developers: For help getting this working correctly, " +
         "<a href='http://trac.openlayers.org/wiki/${layerLib}' " +
         "target='_blank'>click here</a>",
@@ -10916,188 +7333,6 @@
     'end': ''
-    OpenLayers/Popup/Anchored.js
- * @requires OpenLayers/Popup.js
- * Class: OpenLayers.Popup.Anchored
- * Inherits from:
- *  - <OpenLayers.Popup>
-OpenLayers.Popup.Anchored =
-  OpenLayers.Class(OpenLayers.Popup, {
-     * Parameter: relativePosition
-     * {String} Relative position of the popup ("lr", "ll", "tr", or "tl").
-    relativePosition: null,
-     * Parameter: anchor
-     * {Object} Object to which we'll anchor the popup. Must expose a
-     *     'size' (<OpenLayers.Size>) and 'offset' (<OpenLayers.Pixel>).
-    anchor: null,
-    * Constructor: OpenLayers.Popup.Anchored
-    * Parameters:
-    * id - {String}
-    * lonlat - {<OpenLayers.LonLat>}
-    * size - {<OpenLayers.Size>}
-    * contentHTML - {String}
-    * anchor - {Object} Object which must expose a 'size' <OpenLayers.Size>
-    *     and 'offset' <OpenLayers.Pixel> (generally an <OpenLayers.Icon>).
-    * closeBox - {Boolean}
-    * closeBoxCallback - {Function} Function to be called on closeBox click.
-    initialize:function(id, lonlat, size, contentHTML, anchor, closeBox,
-                        closeBoxCallback) {
-        var newArguments = new Array(id, lonlat, size, contentHTML, closeBox,
-                                     closeBoxCallback);
-        OpenLayers.Popup.prototype.initialize.apply(this, newArguments);
-        this.anchor = (anchor != null) ? anchor
-                                       : { size: new OpenLayers.Size(0,0),
-                                           offset: new OpenLayers.Pixel(0,0)};
-        this.anchor = null;
-        this.relativePosition = null;
-        OpenLayers.Popup.prototype.destroy.apply(this, arguments);
-     * APIMethod: show
-     * Overridden from Popup since user might hide popup and then show() it
-     *     in a new location (meaning we might want to update the relative
-     *     position on the show)
-    show: function() {
-        this.updatePosition();
-        OpenLayers.Popup.prototype.show.apply(this, arguments);
-     * Method: moveTo
-     * Since the popup is moving to a new px, it might need also to be moved
-     *     relative to where the marker is. We first calculate the new
-     *     relativePosition, and then we calculate the new px where we will
-     *     put the popup, based on the new relative position.
-     *     If the relativePosition has changed, we must also call
-     *     updateRelativePosition() to make any visual changes to the popup
-     *     which are associated with putting it in a new relativePosition.
-     * Parameters:
-     * px - {<OpenLayers.Pixel>}
-    moveTo: function(px) {
-        var oldRelativePosition = this.relativePosition;
-        this.relativePosition = this.calculateRelativePosition(px);
-        var newPx = this.calculateNewPx(px);
-        var newArguments = new Array(newPx);
-        OpenLayers.Popup.prototype.moveTo.apply(this, newArguments);
-        //if this move has caused the popup to change its relative position,
-        // we need to make the appropriate cosmetic changes.
-        if (this.relativePosition != oldRelativePosition) {
-            this.updateRelativePosition();
-     * APIMethod: setSize
-     * Parameters:
-    setSize:function(size) {
-        OpenLayers.Popup.prototype.setSize.apply(this, arguments);
-        if ((this.lonlat) && (this.map)) {
-            var px = this.map.getLayerPxFromLonLat(this.lonlat);
-            this.moveTo(px);
-     * Method: calculateRelativePosition
-     * Parameters:
-     * Returns:
-     * {String} The relative position ("br" "tr" "tl "bl") at which the popup
-     *     should be placed.
-    calculateRelativePosition:function(px) {
-        var lonlat = this.map.getLonLatFromLayerPx(px);
-        var extent = this.map.getExtent();
-        var quadrant = extent.determineQuadrant(lonlat);
-        return OpenLayers.Bounds.oppositeQuadrant(quadrant);
-     * Method: updateRelativePosition
-     * The popup has been moved to a new relative location, so we may want to
-     *     make some cosmetic adjustments to it.
-     *     Note that in the classic Anchored popup, there is nothing to do
-     *     here, since the popup looks exactly the same in all four positions.
-     *     Subclasses such as the AnchoredBubble and Framed, however, will
-     *     want to do something special here.
-    updateRelativePosition: function() {
-        //to be overridden by subclasses
-     * Method: calculateNewPx
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Pixel>} The the new px position of the popup on the screen
-     *     relative to the passed-in px.
-    calculateNewPx:function(px) {
-        var newPx = px.offset(this.anchor.offset);
-        var top = (this.relativePosition.charAt(0) == 't');
-        newPx.y += (top) ? -this.size.h : this.anchor.size.h;
-        var left = (this.relativePosition.charAt(1) == 'l');
-        newPx.x += (left) ? -this.size.w : this.anchor.size.w;
-        return newPx;
-    CLASS_NAME: "OpenLayers.Popup.Anchored"
     OpenLayers/Projection.js
@@ -11277,384 +7512,322 @@
     return point;
-    OpenLayers/Renderer/Elements.js
+    OpenLayers/Request/XMLHttpRequest.js
+// Copyright 2007 Sergey Ilinsky (http://www.ilinsky.com)
+// Licensed under the Apache License, Version 2.0 (the "License");
+// you may not use this file except in compliance with the License.
+// You may obtain a copy of the License at
+//   http://www.apache.org/licenses/LICENSE-2.0
+// Unless required by applicable law or agreed to in writing, software
+// distributed under the License is distributed on an "AS IS" BASIS,
+// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+// See the License for the specific language governing permissions and
+// limitations under the License.
- * @requires OpenLayers/Renderer.js
+ * @requires OpenLayers/Request.js
- * Class: OpenLayers.Renderer.Elements
- * This is another virtual class in that it should never be instantiated by
- *  itself as a Renderer. It exists because there is *tons* of shared
- *  functionality between different vector libraries which use nodes/elements
- *  as a base for rendering vectors.
- * The highlevel bits of code that are implemented here are the adding and
- *  removing of geometries, which is essentially the same for any
- *  element-based renderer. The details of creating each node and drawing the
- *  paths are of course different, but the machinery is the same.
- * Inherits:
- *  - <OpenLayers.Renderer>
-OpenLayers.Renderer.Elements = OpenLayers.Class(OpenLayers.Renderer, {
+(function () {
-     * Property: rendererRoot
-     * {DOMElement}
-    rendererRoot: null,
-     * Property: root
-     * {DOMElement}
-    root: null,
+    // Save reference to earlier defined object implementation (if any)
+    var oXMLHttpRequest    = window.XMLHttpRequest;
-     * Property: xmlns
-     * {String}
-    xmlns: null,
-     * Property: minimumSymbolizer
-     * {Object}
-    minimumSymbolizer: {
-        strokeLinecap: "round",
-        strokeOpacity: 1,
-        fillOpacity: 1,
-        pointRadius: 0
-     * Constructor: OpenLayers.Renderer.Elements
-     * Parameters:
-     * containerID - {String}
-    initialize: function(containerID) {
-        OpenLayers.Renderer.prototype.initialize.apply(this, arguments);
+    // Define on browser type
+    var bGecko    = !!window.controllers,
+        bIE        = window.document.all && !window.opera;
-        this.rendererRoot = this.createRenderRoot();
-        this.root = this.createRoot();
-        this.rendererRoot.appendChild(this.root);
-        this.container.appendChild(this.rendererRoot);
-     * Method: destroy
+    // Constructor
+    function cXMLHttpRequest() {
+        this._object    = oXMLHttpRequest ? new oXMLHttpRequest : new window.ActiveXObject('Microsoft.XMLHTTP');
-        this.clear();
+    // BUGFIX: Firefox with Firebug installed would break pages if not executed
+    if (bGecko && oXMLHttpRequest.wrapped)
+        cXMLHttpRequest.wrapped    = oXMLHttpRequest.wrapped;
-        this.rendererRoot = null;
-        this.root = null;
-        this.xmlns = null;
+    // Constants
+    cXMLHttpRequest.UNSENT                = 0;
+    cXMLHttpRequest.OPENED                = 1;
+    cXMLHttpRequest.HEADERS_RECEIVED    = 2;
+    cXMLHttpRequest.LOADING                = 3;
+    cXMLHttpRequest.DONE                = 4;
-        OpenLayers.Renderer.prototype.destroy.apply(this, arguments);
-     * Method: clear
-     * Remove all the elements from the root
-        if (this.root) {
-            while (this.root.childNodes.length > 0) {
-                this.root.removeChild(this.root.firstChild);
+    // Public Properties
+    cXMLHttpRequest.prototype.readyState    = cXMLHttpRequest.UNSENT;
+    cXMLHttpRequest.prototype.responseText    = "";
+    cXMLHttpRequest.prototype.responseXML    = null;
+    cXMLHttpRequest.prototype.status        = 0;
+    cXMLHttpRequest.prototype.statusText    = "";
+    // Instance-level Events Handlers
+    cXMLHttpRequest.prototype.onreadystatechange    = null;
+    // Class-level Events Handlers
+    cXMLHttpRequest.onreadystatechange    = null;
+    cXMLHttpRequest.onopen                = null;
+    cXMLHttpRequest.onsend                = null;
+    cXMLHttpRequest.onabort                = null;
+    // Public Methods
+    cXMLHttpRequest.prototype.open    = function(sMethod, sUrl, bAsync, sUser, sPassword) {
+        // Save async parameter for fixing Gecko bug with missing readystatechange in synchronous requests
+        this._async        = bAsync;
+        // Set the onreadystatechange handler
+        var oRequest    = this,
+            nState        = this.readyState;
+        // BUGFIX: IE - memory leak on page unload (inter-page leak)
+        if (bIE) {
+            var fOnUnload    = function() {
+                if (oRequest._object.readyState != cXMLHttpRequest.DONE)
+                    fCleanTransport(oRequest);
+            if (bAsync)
+                window.attachEvent("onunload", fOnUnload);
-     * Method: getNodeType
-     * This function is in charge of asking the specific renderer which type
-     *     of node to create for the given geometry and style. All geometries
-     *     in an Elements-based renderer consist of one node and some
-     *     attributes. We have the nodeFactory() function which creates a node
-     *     for us, but it takes a 'type' as input, and that is precisely what
-     *     this function tells us.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-     * style - {Object}
-     * Returns:
-     * {String} The corresponding node type for the specified geometry
-    getNodeType: function(geometry, style) { },
+        this._object.onreadystatechange    = function() {
+            if (bGecko && !bAsync)
+                return;
-     * Method: drawGeometry
-     * Draw the geometry, creating new nodes, setting paths, setting style,
-     *     setting featureId on the node.  This method should only be called
-     *     by the renderer itself.
-     * Parameters:
-     * featureId - {String}
-    drawGeometry: function(geometry, style, featureId) {
-        var className = geometry.CLASS_NAME;
-        if ((className == "OpenLayers.Geometry.Collection") ||
-            (className == "OpenLayers.Geometry.MultiPoint") ||
-            (className == "OpenLayers.Geometry.MultiLineString") ||
-            (className == "OpenLayers.Geometry.MultiPolygon")) {
-            for (var i = 0; i < geometry.components.length; i++) {
-                this.drawGeometry(geometry.components[i], style, featureId);
-            return;
+            // Synchronize state
+            oRequest.readyState        = oRequest._object.readyState;
-        if (style.display != "none") {
-            //first we create the basic node and add it to the root
-            var nodeType = this.getNodeType(geometry, style);
-            var node = this.nodeFactory(geometry.id, nodeType);
-            node._featureId = featureId;
-            node._geometryClass = geometry.CLASS_NAME;
-            node._style = style;
-            //now actually draw the node, and style it
-            node = this.drawGeometryNode(node, geometry);
-            // append the node to root (but only if it's new)
-            if (node.parentNode != this.root) {
-                this.root.appendChild(node);
+            fSynchronizeValues(oRequest);
+            // BUGFIX: Firefox fires unneccesary DONE when aborting
+            if (oRequest._aborted) {
+                // Reset readyState to UNSENT
+                oRequest.readyState    = cXMLHttpRequest.UNSENT;
+                // Return now
+                return;
-            this.postDraw(node);
-        } else {
-            node = OpenLayers.Util.getElement(geometry.id);
-            if (node) {
-                node.parentNode.removeChild(node);
-     * Method: drawGeometryNode
-     * Given a node, draw a geometry on the specified layer.
-     *     node and geometry are required arguments, style is optional.
-     *     This method is only called by the render itself.
-     * Parameters:
-     * node - {DOMElement}
-    drawGeometryNode: function(node, geometry, style) {
-        style = style || node._style;
-        OpenLayers.Util.applyDefaults(style, this.minimumSymbolizer);
+            if (oRequest.readyState == cXMLHttpRequest.DONE) {
+// Uncomment this block if you need a fix for IE cache
+                // BUGFIX: IE - cache issue
+                if (!oRequest._object.getResponseHeader("Date")) {
+                    // Save object to cache
+                    oRequest._cached    = oRequest._object;
-        var options = {
-            'isFilled': true,
-            'isStroked': !!style.strokeWidth
-        switch (geometry.CLASS_NAME) {
-            case "OpenLayers.Geometry.Point":
-                this.drawPoint(node, geometry);
-                break;
-            case "OpenLayers.Geometry.LineString":
-                options.isFilled = false;
-                this.drawLineString(node, geometry);
-                break;
-            case "OpenLayers.Geometry.LinearRing":
-                this.drawLinearRing(node, geometry);
-                break;
-            case "OpenLayers.Geometry.Polygon":
-                this.drawPolygon(node, geometry);
-                break;
-            case "OpenLayers.Geometry.Surface":
-                this.drawSurface(node, geometry);
-                break;
-            case "OpenLayers.Geometry.Rectangle":
-                this.drawRectangle(node, geometry);
-                break;
-            default:
-                break;
+                    // Instantiate a new transport object
+                    cXMLHttpRequest.call(oRequest);
-        node._options = options;
+                    // Re-send request
+                    oRequest._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
+                    oRequest._object.setRequestHeader("If-Modified-Since", oRequest._cached.getResponseHeader("Last-Modified") || new window.Date(0));
+                    // Copy headers set
+                    if (oRequest._headers)
+                        for (var sHeader in oRequest._headers)
+                            if (typeof oRequest._headers[sHeader] == "string")    // Some frameworks prototype objects with functions
+                                oRequest._object.setRequestHeader(sHeader, oRequest._headers[sHeader]);
-        //set style
-        //TBD simplify this
-        return this.setStyle(node, style, options, geometry);
-     * Method: postDraw
-     * Things that have do be done after the geometry node is appended
-     * to its parent node. To be overridden by subclasses.
-     * Parameters:
-    postDraw: function(node) {},
-     * Method: drawPoint
-     * Virtual function for drawing Point Geometry.
-     * Should be implemented by subclasses.
-     * This method is only called by the renderer itself.
-     * Parameters:
-    drawPoint: function(node, geometry) {},
+                    oRequest._object.onreadystatechange    = function() {
-     * Method: drawLineString
-     * Virtual function for drawing LineString Geometry.
-     * Parameters:
-    drawLineString: function(node, geometry) {},
-     * Method: drawLinearRing
-     * Virtual function for drawing LinearRing Geometry.
-     * Parameters:
-    drawLinearRing: function(node, geometry) {},
+                            // Return
+                            return;
-     * Method: drawPolygon
-     * Virtual function for drawing Polygon Geometry.
-     * Parameters:
-    drawPolygon: function(node, geometry) {},
+                            // Clean Object
-     * Method: drawRectangle
-     * Virtual function for drawing Rectangle Geometry.
-     * Parameters:
-    drawRectangle: function(node, geometry) {},
+                            // get cached request
+                            if (oRequest.status == 304)
+                                oRequest._object    = oRequest._cached;
-     * Method: drawCircle
-     * Virtual function for drawing Circle Geometry.
-     * Parameters:
-    drawCircle: function(node, geometry) {},
+                            delete oRequest._cached;
-     * Method: drawSurface
-     * Virtual function for drawing Surface Geometry.
-     * Parameters:
-    drawSurface: function(node, geometry) {},
-     * Method: getFeatureIdFromEvent
-     * Parameters:
-     * evt - {Object} An <OpenLayers.Event> object
-     * Returns:
-     * {<OpenLayers.Geometry>} A geometry from an event that
-     *                         happened on a layer
-    getFeatureIdFromEvent: function(evt) {
-        var node = evt.target || evt.srcElement;
-        return node._featureId;
+                            fReadyStateChange(oRequest);
-     * Method: eraseGeometry
-     * Erase a geometry from the renderer. In the case of a multi-geometry,
-     *     we cycle through and recurse on ourselves. Otherwise, we look for a
-     *     node with the geometry.id, destroy its geometry, and remove it from
-     *     the DOM.
-     * Parameters:
-    eraseGeometry: function(geometry) {
-        if ((geometry.CLASS_NAME == "OpenLayers.Geometry.MultiPoint") ||
-            (geometry.CLASS_NAME == "OpenLayers.Geometry.MultiLineString") ||
-            (geometry.CLASS_NAME == "OpenLayers.Geometry.MultiPolygon")) {
-                this.eraseGeometry(geometry.components[i]);
+                            // BUGFIX: IE - memory leak in interrupted
+                            if (bIE && bAsync)
+                                window.detachEvent("onunload", fOnUnload);
+                    oRequest._object.send(null);
+                    // Return now - wait untill re-sent request is finished
+                    return;
-        } else {
-            var element = OpenLayers.Util.getElement(geometry.id);
-            if (element && element.parentNode) {
-                element.parentNode.removeChild(element);
+            // BUGFIX: Some browsers (Internet Explorer, Gecko) fire OPEN readystate twice
+            if (nState != oRequest.readyState)
+            nState    = oRequest.readyState;
+        // Add method sniffer
+        if (cXMLHttpRequest.onopen)
+            cXMLHttpRequest.onopen.apply(this, arguments);
+        this._object.open(sMethod, sUrl, bAsync, sUser, sPassword);
+        // BUGFIX: Gecko - missing readystatechange calls in synchronous requests
+        if (!bAsync && bGecko) {
+            this.readyState    = cXMLHttpRequest.OPENED;
+            fReadyStateChange(this);
+    cXMLHttpRequest.prototype.send    = function(vData) {
+        if (cXMLHttpRequest.onsend)
+            cXMLHttpRequest.onsend.apply(this, arguments);
-     * Method: nodeFactory
-     * Create new node of the specified type, with the (optional) specified id.
-     * If node already exists with same ID and type, we remove it and then
-     *  call ourselves again to recreate it.
-     * Parameters:
-     * id - {String}
-     * type - {String} type Kind of node to draw
-     * Returns:
-     * {DOMElement} A new node of the given type and id
-    nodeFactory: function(id, type) {
-        var node = OpenLayers.Util.getElement(id);
-        if (node) {
-            if (!this.nodeTypeCompare(node, type)) {
-                node = this.nodeFactory(id, type);
+        // BUGFIX: Safari - fails sending documents created/modified dynamically, so an explicit serialization required
+        // BUGFIX: IE - rewrites any custom mime-type to "text/xml" in case an XMLNode is sent
+        // BUGFIX: Gecko - fails sending Element (this is up to the implementation either to standard)
+        if (vData && vData.nodeType) {
+            vData    = window.XMLSerializer ? new window.XMLSerializer().serializeToString(vData) : vData.xml;
+            if (!this._headers["Content-Type"])
+                this._object.setRequestHeader("Content-Type", "application/xml");
+        this._object.send(vData);
+        if (bGecko && !this._async) {
+            fSynchronizeValues(this);
+            // Simulate missing states
+            while (this.readyState < cXMLHttpRequest.DONE) {
+                this.readyState++;
+                // Check if we are aborted
+                if (this._aborted)
+                    return;
-        } else {
-            node = this.createNode(type, id);
-        return node;
+    cXMLHttpRequest.prototype.abort    = function() {
+        if (cXMLHttpRequest.onabort)
+            cXMLHttpRequest.onabort.apply(this, arguments);
-    CLASS_NAME: "OpenLayers.Renderer.Elements"
+        // BUGFIX: Gecko - unneccesary DONE when aborting
+        if (this.readyState > cXMLHttpRequest.UNSENT)
+            this._aborted    = true;
+        this._object.abort();
+        fCleanTransport(this);
+    cXMLHttpRequest.prototype.getAllResponseHeaders    = function() {
+        return this._object.getAllResponseHeaders();
+    cXMLHttpRequest.prototype.getResponseHeader    = function(sName) {
+        return this._object.getResponseHeader(sName);
+    cXMLHttpRequest.prototype.setRequestHeader    = function(sName, sValue) {
+        if (!this._headers)
+            this._headers    = {};
+        this._headers[sName]    = sValue;
+        return this._object.setRequestHeader(sName, sValue);
+    cXMLHttpRequest.prototype.toString    = function() {
+        return '[' + "object" + ' ' + "XMLHttpRequest" + ']';
+    cXMLHttpRequest.toString    = function() {
+        return '[' + "XMLHttpRequest" + ']';
+    // Helper function
+    function fReadyStateChange(oRequest) {
+        // Execute onreadystatechange
+        if (oRequest.onreadystatechange)
+            oRequest.onreadystatechange.apply(oRequest);
+        // Sniffing code
+        if (cXMLHttpRequest.onreadystatechange)
+            cXMLHttpRequest.onreadystatechange.apply(oRequest);
+    function fGetDocument(oRequest) {
+        var oDocument    = oRequest.responseXML;
+        // Try parsing responseText
+        if (bIE && oDocument && !oDocument.documentElement && oRequest.getResponseHeader("Content-Type").match(/[^\/]+\/[^\+]+\+xml/)) {
+            oDocument    = new ActiveXObject('Microsoft.XMLDOM');
+            oDocument.loadXML(oRequest.responseText);
+        // Check if there is no error in document
+        if (oDocument)
+            if ((bIE && oDocument.parseError != 0) || (oDocument.documentElement && oDocument.documentElement.tagName == "parsererror"))
+                return null;
+        return oDocument;
+    function fSynchronizeValues(oRequest) {
+        try {    oRequest.responseText    = oRequest._object.responseText;    } catch (e) {}
+        try {    oRequest.responseXML    = fGetDocument(oRequest._object);    } catch (e) {}
+        try {    oRequest.status            = oRequest._object.status;            } catch (e) {}
+        try {    oRequest.statusText        = oRequest._object.statusText;        } catch (e) {}
+    function fCleanTransport(oRequest) {
+        // BUGFIX: IE - memory leak (on-page leak)
+        oRequest._object.onreadystatechange    = new window.Function;
+        // Delete private properties
+        delete oRequest._headers;
+    // Internet Explorer 5.0 (missing apply)
+    if (!window.Function.prototype.apply) {
+        window.Function.prototype.apply    = function(oRequest, oArguments) {
+            if (!oArguments)
+                oArguments    = [];
+            oRequest.__func    = this;
+            oRequest.__func(oArguments[0], oArguments[1], oArguments[2], oArguments[3], oArguments[4]);
+            delete oRequest.__func;
+    // Register new object with window
+     * Class: OpenLayers.Request.XMLHttpRequest
+     * Standard-compliant (W3C) cross-browser implementation of the
+     *     XMLHttpRequest object.  From
+     *     http://code.google.com/p/xmlhttprequest/.
+    OpenLayers.Request.XMLHttpRequest = cXMLHttpRequest;
     OpenLayers/Tile.js
@@ -12065,1542 +8238,6 @@
     CLASS_NAME: "OpenLayers.Tile"
-    OpenLayers/Control/MouseToolbar.js
- * @requires OpenLayers/Control.js
- * @requires OpenLayers/Control/MouseDefaults.js
- * Class: OpenLayers.Control.MouseToolbar
- * This class is DEPRECATED in 2.4 and will be removed by 3.0.
- * If you need this functionality, use Control.NavToolbar instead!!!
-OpenLayers.Control.MouseToolbar = OpenLayers.Class(
-                                            OpenLayers.Control.MouseDefaults, {
-     * Property: mode
-    mode: null,
-     * Property: buttons
-    buttons: null,
-     * APIProperty: direction
-     * {String} 'vertical' or 'horizontal'
-    direction: "vertical",
-     * Property: buttonClicked
-     * {String}
-    buttonClicked: null,
-     * Constructor: OpenLayers.Control.MouseToolbar
-     * Parameters:
-     * position - {<OpenLayers.Pixel>}
-     * direction - {String}
-    initialize: function(position, direction) {
-        OpenLayers.Control.prototype.initialize.apply(this, arguments);
-        this.position = new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,
-                                             OpenLayers.Control.MouseToolbar.Y);
-        if (position) {
-            this.position = position;
-        if (direction) {
-            this.direction = direction;
-        this.measureDivs = [];
-     * APIMethod: destroy
-        for( var btnId in this.buttons) {
-            var btn = this.buttons[btnId];
-            btn.map = null;
-            btn.events.destroy();
-        OpenLayers.Control.MouseDefaults.prototype.destroy.apply(this,
-        arguments);
-     * Method: draw
-    draw: function() {
-        OpenLayers.Control.prototype.draw.apply(this, arguments);
-        OpenLayers.Control.MouseDefaults.prototype.draw.apply(this, arguments);
-        this.buttons = {};
-        var sz = new OpenLayers.Size(28,28);
-        var centered = new OpenLayers.Pixel(OpenLayers.Control.MouseToolbar.X,0);
-        this._addButton("zoombox", "drag-rectangle-off.png", "drag-rectangle-on.png", centered, sz, "Shift->Drag to zoom to area");
-        centered = centered.add((this.direction == "vertical" ? 0 : sz.w), (this.direction == "vertical" ? sz.h : 0));
-        this._addButton("pan", "panning-hand-off.png", "panning-hand-on.png", centered, sz, "Drag the map to pan.");
-        this.switchModeTo("pan");
-        return this.div;
-     * Method: _addButton
-    _addButton:function(id, img, activeImg, xy, sz, title) {
-        var imgLocation = OpenLayers.Util.getImagesLocation() + img;
-        var activeImgLocation = OpenLayers.Util.getImagesLocation() + activeImg;
-        // var btn = new ol.AlphaImage("_"+id, imgLocation, xy, sz);
-        var btn = OpenLayers.Util.createAlphaImageDiv(
-                                    "OpenLayers_Control_MouseToolbar_" + id,
-                                    xy, sz, imgLocation, "absolute");
-        //we want to add the outer div
-        this.div.appendChild(btn);
-        btn.imgLocation = imgLocation;
-        btn.activeImgLocation = activeImgLocation;
-        btn.events = new OpenLayers.Events(this, btn, null, true);
-        btn.events.on({
-            "mousedown": this.buttonDown,
-            "mouseup": this.buttonUp,
-            "dblclick": OpenLayers.Event.stop,
-            scope: this
-        btn.action = id;
-        btn.title = title;
-        btn.alt = title;
-        btn.map = this.map;
-        //we want to remember/reference the outer div
-        this.buttons[id] = btn;
-        return btn;
-     * Method: buttonDown
-     * Parameters:
-     * evt - {Event}
-    buttonDown: function(evt) {
-            return;
-        this.buttonClicked = evt.element.action;
-     * Method: buttonUp
-     * Parameters:
-     * evt - {Event}
-    buttonUp: function(evt) {
-            return;
-        if (this.buttonClicked != null) {
-            if (this.buttonClicked == evt.element.action) {
-                this.switchModeTo(evt.element.action);
-            this.buttonClicked = null;
-     * Parameters:
-     * evt - {Event}
-        return false;
-     * Parameters:
-     * evt - {Event}
-            return;
-        this.startViaKeyboard = false;
-        if (evt.shiftKey && this.mode !="zoombox") {
-            this.switchModeTo("zoombox");
-            this.startViaKeyboard = true;
-        } else if (evt.altKey && this.mode !="measure") {
-            this.switchModeTo("measure");
-        } else if (!this.mode) {
-        switch (this.mode) {
-            case "zoombox":
-                                                         null,
-                                                         null,
-                                                         "absolute",
-                                                         "2px solid red");
-                break;
-            case "measure":
-                var distance = "";
-                if (this.measureStart) {
-                    var measureEnd = this.map.getLonLatFromViewPortPx(this.mouseDragStart);
-                    distance = OpenLayers.Util.distVincenty(this.measureStart, measureEnd);
-                    distance = Math.round(distance * 100) / 100;
-                    distance = distance + "km";
-                    this.measureStartBox = this.measureBox;
-                this.measureStart = this.map.getLonLatFromViewPortPx(this.mouseDragStart);;
-                this.measureBox = OpenLayers.Util.createDiv(null,
-                                                         this.mouseDragStart.add(
-                                                           -2-parseInt(this.map.layerContainerDiv.style.left),
-                                                           -2-parseInt(this.map.layerContainerDiv.style.top)),
-                                                         null,
-                                                         null,
-                                                         "absolute");
-                this.measureBox.style.width="4px";
-                this.measureBox.style.height="4px";
-                this.measureBox.style.fontSize = "1px";
-                this.measureBox.style.backgroundColor="red";
-                this.measureBox.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
-                this.map.layerContainerDiv.appendChild(this.measureBox);
-                if (distance) {
-                    this.measureBoxDistance = OpenLayers.Util.createDiv(null,
-                                                           2-parseInt(this.map.layerContainerDiv.style.top)),
-                                                         null,
-                                                         null,
-                                                         "absolute");
-                    this.measureBoxDistance.innerHTML = distance;
-                    this.measureBoxDistance.style.zIndex = this.map.Z_INDEX_BASE["Popup"] - 1;
-                    this.map.layerContainerDiv.appendChild(this.measureBoxDistance);
-                    this.measureDivs.push(this.measureBoxDistance);
-                this.measureDivs.push(this.measureBox);
-                break;
-            default:
-                break;
-        document.onselectstart = function() { return false; };
-     * Method: switchModeTo
-     * Parameters:
-     * mode - {String}
-    switchModeTo: function(mode) {
-        if (mode != this.mode) {
-            if (this.mode && this.buttons[this.mode]) {
-                OpenLayers.Util.modifyAlphaImageDiv(this.buttons[this.mode], null, null, null, this.buttons[this.mode].imgLocation);
-            if (this.mode == "measure" && mode != "measure") {
-                for(var i = 0; i < this.measureDivs.length; i++) {
-                    if (this.measureDivs[i]) {
-                        this.map.layerContainerDiv.removeChild(this.measureDivs[i]);
-                this.measureStart = null;
-            this.mode = mode;
-            if (this.buttons[mode]) {
-                OpenLayers.Util.modifyAlphaImageDiv(this.buttons[mode], null, null, null, this.buttons[mode].activeImgLocation);
-                case "zoombox":
-                    break;
-                default:
-                    break;
-     * Method: leaveMode
-    leaveMode: function() {
-     * Parameters:
-     * evt - {Event}
-                case "zoombox":
-                    break;
-                default:
-     * Parameters:
-     * evt - {Event}
-            return;
-            case "zoombox":
-                if (this.startViaKeyboard) {
-                    this.leaveMode();
-                break;
-            case "pan":
-        document.onselectstart = null;
-        this.map.div.style.cursor = "default";
-     * Parameters:
-     * evt - {Event}
-            && OpenLayers.Util.mouseLeft(evt, this.map.div)) {
-                    this.leaveMode();
-     * Parameters:
-     * evt - {Event}
-            return false;
-    CLASS_NAME: "OpenLayers.Control.MouseToolbar"
-OpenLayers.Control.MouseToolbar.X = 6;
-OpenLayers.Control.MouseToolbar.Y = 300;
-    OpenLayers/Control/PanZoomBar.js
- * @requires OpenLayers/Control/PanZoom.js
- * Class: OpenLayers.Control.PanZoomBar
- * Inherits from:
- *  - <OpenLayers.Control.PanZoom>
-OpenLayers.Control.PanZoomBar = OpenLayers.Class(OpenLayers.Control.PanZoom, {
-     * APIProperty: zoomStopWidth
-    zoomStopWidth: 18,
-     * APIProperty: zoomStopHeight
-    zoomStopHeight: 11,
-     * Property: slider
-    slider: null,
-     * Property: sliderEvents
-     * {<OpenLayers.Events>}
-    sliderEvents: null,
-     * Property: zoomBarDiv
-     * {DOMElement}
-    zoomBarDiv: null,
-     * Property: divEvents
-    divEvents: null,
-     * Property: zoomWorldIcon
-     * {Boolean}
-    zoomWorldIcon: false,
-     * Constructor: OpenLayers.Control.PanZoomBar
-        OpenLayers.Control.PanZoom.prototype.initialize.apply(this, arguments);
-        this.div.removeChild(this.slider);
-        this.slider = null;
-        this.sliderEvents.destroy();
-        this.sliderEvents = null;
-        this.div.removeChild(this.zoombarDiv);
-        this.zoomBarDiv = null;
-        this.divEvents.destroy();
-        this.divEvents = null;
-        this.map.events.un({
-            "zoomend": this.moveZoomBar,
-            "changebaselayer": this.redraw,
-            scope: this
-        OpenLayers.Control.PanZoom.prototype.destroy.apply(this, arguments);
-     * Method: setMap
-     * Parameters:
-     * map - {<OpenLayers.Map>}
-    setMap: function(map) {
-        OpenLayers.Control.PanZoom.prototype.setMap.apply(this, arguments);
-        this.map.events.register("changebaselayer", this, this.redraw);
-     * Method: redraw
-     * clear the div and start over.
-    redraw: function() {
-        if (this.div != null) {
-        this.draw();
-    * Method: draw
-    * Parameters:
-    draw: function(px) {
-        // initialize our internal div
-        px = this.position.clone();
-        // place the controls
-        this.buttons = [];
-        var sz = new OpenLayers.Size(18,18);
-        var centered = new OpenLayers.Pixel(px.x+sz.w/2, px.y);
-        var wposition = sz.w;
-        if (this.zoomWorldIcon) {
-            centered = new OpenLayers.Pixel(px.x+sz.w, px.y);
-        this._addButton("panup", "north-mini.png", centered, sz);
-        px.y = centered.y+sz.h;
-        this._addButton("panleft", "west-mini.png", px, sz);
-            this._addButton("zoomworld", "zoom-world-mini.png", px.add(sz.w, 0), sz);
-            wposition *= 2;
-        this._addButton("panright", "east-mini.png", px.add(wposition, 0), sz);
-        this._addButton("pandown", "south-mini.png", centered.add(0, sz.h*2), sz);
-        this._addButton("zoomin", "zoom-plus-mini.png", centered.add(0, sz.h*3+5), sz);
-        centered = this._addZoomBar(centered.add(0, sz.h*4 + 5));
-        this._addButton("zoomout", "zoom-minus-mini.png", centered, sz);
-        return this.div;
-    * Method: _addZoomBar
-    * Parameters:
-    * location - {<OpenLayers.Pixel>} where zoombar drawing is to start.
-    _addZoomBar:function(centered) {
-        var imgLocation = OpenLayers.Util.getImagesLocation();
-        var id = "OpenLayers_Control_PanZoomBar_Slider" + this.map.id;
-        var zoomsToEnd = this.map.getNumZoomLevels() - 1 - this.map.getZoom();
-        var slider = OpenLayers.Util.createAlphaImageDiv(id,
-                       centered.add(-1, zoomsToEnd * this.zoomStopHeight),
-                       new OpenLayers.Size(20,9),
-                       imgLocation+"slider.png",
-                       "absolute");
-        this.slider = slider;
-        this.sliderEvents = new OpenLayers.Events(this, slider, null, true);
-        this.sliderEvents.on({
-            "mousedown": this.zoomBarDown,
-            "mousemove": this.zoomBarDrag,
-            "mouseup": this.zoomBarUp,
-            "dblclick": this.doubleClick,
-            "click": this.doubleClick
-        var sz = new OpenLayers.Size();
-        sz.h = this.zoomStopHeight * this.map.getNumZoomLevels();
-        sz.w = this.zoomStopWidth;
-        var div = null;
-        if (OpenLayers.Util.alphaHack()) {
-            var id = "OpenLayers_Control_PanZoomBar" + this.map.id;
-            div = OpenLayers.Util.createAlphaImageDiv(id, centered,
-                                      new OpenLayers.Size(sz.w,
-                                              this.zoomStopHeight),
-                                      imgLocation + "zoombar.png",
-                                      "absolute", null, "crop");
-            div.style.height = sz.h;
-        } else {
-            div = OpenLayers.Util.createDiv(
-                        'OpenLayers_Control_PanZoomBar_Zoombar' + this.map.id,
-                        centered,
-                        sz,
-                        imgLocation+"zoombar.png");
-        this.zoombarDiv = div;
-        this.divEvents = new OpenLayers.Events(this, div, null, true);
-        this.divEvents.on({
-            "mousedown": this.divClick,
-            "mousemove": this.passEventToSlider,
-        this.div.appendChild(div);
-        this.startTop = parseInt(div.style.top);
-        this.div.appendChild(slider);
-        this.map.events.register("zoomend", this, this.moveZoomBar);
-        centered = centered.add(0,
-            this.zoomStopHeight * this.map.getNumZoomLevels());
-        return centered;
-     * Method: passEventToSlider
-     * This function is used to pass events that happen on the div, or the map,
-     * through to the slider, which then does its moving thing.
-     * Parameters:
-     * evt - {<OpenLayers.Event>}
-    passEventToSlider:function(evt) {
-        this.sliderEvents.handleBrowserEvent(evt);
-     * Method: divClick
-     * Picks up on clicks directly on the zoombar div
-     *           and sets the zoom level appropriately.
-    divClick: function (evt) {
-        if (!OpenLayers.Event.isLeftClick(evt)) {
-            return;
-        var y = evt.xy.y;
-        var top = OpenLayers.Util.pagePosition(evt.object)[1];
-        var levels = (y - top)/this.zoomStopHeight;
-        if(!this.map.fractionalZoom) {
-            levels = Math.floor(levels);
-        var zoom = (this.map.getNumZoomLevels() - 1) - levels;
-        zoom = Math.min(Math.max(zoom, 0), this.map.getNumZoomLevels() - 1);
-        this.map.zoomTo(zoom);
-        OpenLayers.Event.stop(evt);
-     * Method: zoomBarDown
-     * event listener for clicks on the slider
-     * Parameters:
-    zoomBarDown:function(evt) {
-            return;
-        this.map.events.on({
-            "mouseup": this.passEventToSlider,
-            scope: this
-        this.mouseDragStart = evt.xy.clone();
-        this.zoomStart = evt.xy.clone();
-        this.div.style.cursor = "move";
-        // reset the div offsets just in case the div moved
-        this.zoombarDiv.offsets = null;
-     * Method: zoomBarDrag
-     * This is what happens when a click has occurred, and the client is
-     * dragging.  Here we must ensure that the slider doesn't go beyond the
-     * bottom/top of the zoombar div, as well as moving the slider to its new
-     * visual location
-     * Parameters:
-    zoomBarDrag:function(evt) {
-            var offsets = OpenLayers.Util.pagePosition(this.zoombarDiv);
-            if ((evt.clientY - offsets[1]) > 0 &&
-                (evt.clientY - offsets[1]) < parseInt(this.zoombarDiv.style.height) - 2) {
-                var newTop = parseInt(this.slider.style.top) - deltaY;
-                this.slider.style.top = newTop+"px";
-     * Method: zoomBarUp
-     * Perform cleanup when a mouseup event is received -- discover new zoom
-     * level and switch to it.
-     * Parameters:
-    zoomBarUp:function(evt) {
-            return;
-        if (this.zoomStart) {
-            this.div.style.cursor="";
-                scope: this
-            var deltaY = this.zoomStart.y - evt.xy.y;
-            var zoomLevel = this.map.zoom;
-            if (this.map.fractionalZoom) {
-                zoomLevel += deltaY/this.zoomStopHeight;
-                zoomLevel = Math.min(Math.max(zoomLevel, 0),
-                                     this.map.getNumZoomLevels() - 1);
-            } else {
-                zoomLevel += Math.round(deltaY/this.zoomStopHeight);
-            this.map.zoomTo(zoomLevel);
-            this.moveZoomBar();
-    * Method: moveZoomBar
-    * Change the location of the slider to match the current zoom level.
-    moveZoomBar:function() {
-        var newTop =
-            ((this.map.getNumZoomLevels()-1) - this.map.getZoom()) *
-            this.zoomStopHeight + this.startTop + 1;
-        this.slider.style.top = newTop + "px";
-    CLASS_NAME: "OpenLayers.Control.PanZoomBar"
-    OpenLayers/Format/JSON.js
- * Note:
- * This work draws heavily from the public domain JSON serializer/deserializer
- *     at http://www.json.org/json.js. Rewritten so that it doesn't modify
- *     basic data prototypes.
- * @requires OpenLayers/Format.js
- * Class: OpenLayers.Format.JSON
- * A parser to read/write JSON safely.  Create a new instance with the
- *     <OpenLayers.Format.JSON> constructor.
- * Inherits from:
- *  - <OpenLayers.Format>
-OpenLayers.Format.JSON = OpenLayers.Class(OpenLayers.Format, {
-     * APIProperty: indent
-     * {String} For "pretty" printing, the indent string will be used once for
-     *     each indentation level.
-    indent: "    ",
-     * APIProperty: space
-     * {String} For "pretty" printing, the space string will be used after
-     *     the ":" separating a name/value pair.
-    space: " ",
-     * APIProperty: newline
-     * {String} For "pretty" printing, the newline string will be used at the
-     *     end of each name/value pair or array item.
-    newline: "\n",
-     * Property: level
-     * {Integer} For "pretty" printing, this is incremented/decremented during
-     *     serialization.
-    level: 0,
-     * Property: pretty
-     * {Boolean} Serialize with extra whitespace for structure.  This is set
-     *     by the <write> method.
-    pretty: false,
-     * Constructor: OpenLayers.Format.JSON
-     * Create a new parser for JSON.
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.prototype.initialize.apply(this, [options]);
-     * APIMethod: read
-     * Deserialize a json string.
-     * Parameters:
-     * json - {String} A JSON string
-     * filter - {Function} A function which will be called for every key and
-     *     value at every level of the final result. Each value will be
-     *     replaced by the result of the filter function. This can be used to
-     *     reform generic objects into instances of classes, or to transform
-     *     date strings into Date objects.
-     * Returns:
-     * {Object} An object, array, string, or number .
-    read: function(json, filter) {
-         * Parsing happens in three stages. In the first stage, we run the text
-         *     against a regular expression which looks for non-JSON
-         *     characters. We are especially concerned with '()' and 'new'
-         *     because they can cause invocation, and '=' because it can cause
-         *     mutation. But just to be safe, we will reject all unexpected
-         *     characters.
-        try {
-            if (/^[\],:{}\s]*$/.test(json.replace(/\\["\\\/bfnrtu]/g, '@').
-                                replace(/"[^"\\\n\r]*"|true|false|null|-?\d+(?:\.\d*)?(?:[eE][+\-]?\d+)?/g, ']').
-                                replace(/(?:^|:|,)(?:\s*\[)+/g, ''))) {
-                 * In the second stage we use the eval function to compile the
-                 *     text into a JavaScript structure. The '{' operator is
-                 *     subject to a syntactic ambiguity in JavaScript - it can
-                 *     begin a block or an object literal. We wrap the text in
-                 *     parens to eliminate the ambiguity.
-                var object = eval('(' + json + ')');
-                 * In the optional third stage, we recursively walk the new
-                 *     structure, passing each name/value pair to a filter
-                 *     function for possible transformation.
-                if(typeof filter === 'function') {
-                    function walk(k, v) {
-                        if(v && typeof v === 'object') {
-                            for(var i in v) {
-                                if(v.hasOwnProperty(i)) {
-                                    v[i] = walk(i, v[i]);
-                        return filter(k, v);
-                    object = walk('', object);
-                return object;
-        } catch(e) {
-            // Fall through if the regexp test fails.
-        return null;
-     * APIMethod: write
-     * Serialize an object into a JSON string.
-     * Parameters:
-     * value - {String} The object, array, string, number, boolean or date
-     *     to be serialized.
-     * pretty - {Boolean} Structure the output with newlines and indentation.
-     *     Default is false.
-     * Returns:
-     * {String} The JSON string representation of the input value.
-    write: function(value, pretty) {
-        this.pretty = !!pretty;
-        var json = null;
-        var type = typeof value;
-        if(this.serialize[type]) {
-            json = this.serialize[type].apply(this, [value]);
-        return json;
-     * Method: writeIndent
-     * Output an indentation string depending on the indentation level.
-     * Returns:
-     * {String} An appropriate indentation string.
-    writeIndent: function() {
-        var pieces = [];
-        if(this.pretty) {
-            for(var i=0; i<this.level; ++i) {
-                pieces.push(this.indent);
-        return pieces.join('');
-     * Method: writeNewline
-     * Output a string representing a newline if in pretty printing mode.
-     * Returns:
-     * {String} A string representing a new line.
-    writeNewline: function() {
-        return (this.pretty) ? this.newline : '';
-     * Method: writeSpace
-     * Output a string representing a space if in pretty printing mode.
-     * Returns:
-     * {String} A space.
-    writeSpace: function() {
-        return (this.pretty) ? this.space : '';
-     * Property: serialize
-     * Object with properties corresponding to the serializable data types.
-     *     Property values are functions that do the actual serializing.
-    serialize: {
-         * Method: serialize.object
-         * Transform an object into a JSON string.
-         * Parameters:
-         * object - {Object} The object to be serialized.
-         * Returns:
-         * {String} A JSON string representing the object.
-        'object': function(object) {
-            // three special objects that we want to treat differently
-            if(object == null) {
-                return "null";
-            if(object.constructor == Date) {
-                return this.serialize.date.apply(this, [object]);
-            if(object.constructor == Array) {
-                return this.serialize.array.apply(this, [object]);
-            var pieces = ['{'];
-            this.level += 1;
-            var key, keyJSON, valueJSON;
-            var addComma = false;
-            for(key in object) {
-                if(object.hasOwnProperty(key)) {
-                    // recursive calls need to allow for sub-classing
-                    keyJSON = OpenLayers.Format.JSON.prototype.write.apply(this,
-                                                    [key, this.pretty]);
-                    valueJSON = OpenLayers.Format.JSON.prototype.write.apply(this,
-                                                    [object[key], this.pretty]);
-                    if(keyJSON != null && valueJSON != null) {
-                        if(addComma) {
-                            pieces.push(',');
-                        pieces.push(this.writeNewline(), this.writeIndent(),
-                                    keyJSON, ':', this.writeSpace(), valueJSON);
-                        addComma = true;
-            this.level -= 1;
-            pieces.push(this.writeNewline(), this.writeIndent(), '}');
-         * Method: serialize.array
-         * Transform an array into a JSON string.
-         * Parameters:
-         * array - {Array} The array to be serialized
-         * Returns:
-         * {String} A JSON string representing the array.
-        'array': function(array) {
-            var json;
-            var pieces = ['['];
-            this.level += 1;
-            for(var i=0; i<array.length; ++i) {
-                json = OpenLayers.Format.JSON.prototype.write.apply(this,
-                                                    [array[i], this.pretty]);
-                if(json != null) {
-                    if(i > 0) {
-                        pieces.push(',');
-                    pieces.push(this.writeNewline(), this.writeIndent(), json);
-            this.level -= 1;
-            pieces.push(this.writeNewline(), this.writeIndent(), ']');
-         * Method: serialize.string
-         * Transform a string into a JSON string.
-         * Parameters:
-         * string - {String} The string to be serialized
-         * Returns:
-         * {String} A JSON string representing the string.
-        'string': function(string) {
-            // If the string contains no control characters, no quote characters, and no
-            // backslash characters, then we can simply slap some quotes around it.
-            // Otherwise we must also replace the offending characters with safe
-            // sequences.
-            var m = {
-                '\b': '\\b',
-                '\t': '\\t',
-                '\n': '\\n',
-                '\f': '\\f',
-                '\r': '\\r',
-            if(/["\\\x00-\x1f]/.test(string)) {
-                return '"' + string.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-                    var c = m[b];
-                    if(c) {
-                        return c;
-                    c = b.charCodeAt();
-                    return '\\u00' +
-                        Math.floor(c / 16).toString(16) +
-                        (c % 16).toString(16);
-            return '"' + string + '"';
-         * Method: serialize.number
-         * Transform a number into a JSON string.
-         * Parameters:
-         * number - {Number} The number to be serialized.
-         * Returns:
-         * {String} A JSON string representing the number.
-        'number': function(number) {
-            return isFinite(number) ? String(number) : "null";
-         * Method: serialize.boolean
-         * Transform a boolean into a JSON string.
-         * Parameters:
-         * bool - {Boolean} The boolean to be serialized.
-         * Returns:
-         * {String} A JSON string representing the boolean.
-        'boolean': function(bool) {
-            return String(bool);
-         * Transform a date into a JSON string.
-         * Parameters:
-         * date - {Date} The date to be serialized.
-         * Returns:
-         * {String} A JSON string representing the date.
-        'date': function(date) {
-            function format(number) {
-                // Format integers to have at least two digits.
-                return (number < 10) ? '0' + number : number;
-            return '"' + date.getFullYear() + '-' +
-                    format(date.getMonth() + 1) + '-' +
-                    format(date.getDate()) + 'T' +
-                    format(date.getHours()) + ':' +
-                    format(date.getMinutes()) + ':' +
-                    format(date.getSeconds()) + '"';
-    CLASS_NAME: "OpenLayers.Format.JSON"
-    OpenLayers/Format/XML.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * Class: OpenLayers.Format.XML
- * Read and write XML.  For cross-browser XML generation, use methods on an
- *     instance of the XML format class instead of on <code>document<end>.
- *     The DOM creation and traversing methods exposed here all mimic the
- *     W3C XML DOM methods.  Create a new parser with the
- *     <OpenLayers.Format.XML> constructor.
- * Inherits from:
-OpenLayers.Format.XML = OpenLayers.Class(OpenLayers.Format, {
-     * Property: xmldom
-     * {XMLDom} If this browser uses ActiveX, this will be set to a XMLDOM
-     *     object.  It is not intended to be a browser sniffing property.
-     *     Instead, the xmldom property is used instead of <code>document<end>
-     *     where namespaced node creation methods are not supported. In all
-     *     other browsers, this remains null.
-    xmldom: null,
-     * Constructor: OpenLayers.Format.XML
-     * Construct an XML parser.  The parser is used to read and write XML.
-     *     Reading XML from a string returns a DOM element.  Writing XML from
-     *     a DOM element returns a string.
-     * Parameters:
-     * options - {Object} Optional object whose properties will be set on
-     *     the object.
-        if(window.ActiveXObject) {
-            this.xmldom = new ActiveXObject("Microsoft.XMLDOM");
-     * APIMethod: read
-     * Deserialize a XML string and return a DOM node.
-     * Parameters:
-     * text - {String} A XML string
-     * Returns:
-     * {DOMElement} A DOM node
-    read: function(text) {
-        var index = text.indexOf('<');
-        if(index > 0) {
-            text = text.substring(index);
-        var node = OpenLayers.Util.Try(
-            OpenLayers.Function.bind((
-                function() {
-                    var xmldom;
-                     * Since we want to be able to call this method on the prototype
-                     * itself, this.xmldom may not exist even if in IE.
-                    if(window.ActiveXObject && !this.xmldom) {
-                        xmldom = new ActiveXObject("Microsoft.XMLDOM");
-                    } else {
-                        xmldom = this.xmldom;
-                    xmldom.loadXML(text);
-                    return xmldom;
-            ), this),
-            function() {
-                return new DOMParser().parseFromString(text, 'text/xml');
-            function() {
-                var req = new XMLHttpRequest();
-                req.open("GET", "data:" + "text/xml" +
-                         ";charset=utf-8," + encodeURIComponent(text), false);
-                if(req.overrideMimeType) {
-                    req.overrideMimeType("text/xml");
-                req.send(null);
-                return req.responseXML;
-        return node;
-     * Serialize a DOM node into a XML string.
-     * Parameters:
-     * node - {DOMElement} A DOM node.
-     * Returns:
-     * {String} The XML string representation of the input node.
-    write: function(node) {
-        var data;
-        if(this.xmldom) {
-            data = node.xml;
-        } else {
-            var serializer = new XMLSerializer();
-            if (node.nodeType == 1) {
-                // Add nodes to a document before serializing. Everything else
-                // is serialized as is. This may need more work. See #1218 .
-                var doc = document.implementation.createDocument("", "", null);
-                if (doc.importNode) {
-                    node = doc.importNode(node, true);
-                doc.appendChild(node);
-                data = serializer.serializeToString(doc);
-            } else {
-                data = serializer.serializeToString(node);
-        return data;
-     * APIMethod: createElementNS
-     * Create a new element with namespace.  This node can be appended to
-     *     another node with the standard node.appendChild method.  For
-     *     cross-browser support, this method must be used instead of
-     *     document.createElementNS.
-     * Parameters:
-     * uri - {String} Namespace URI for the element.
-     * name - {String} The qualified name of the element (prefix:localname).
-     * Returns:
-     * {Element} A DOM element with namespace.
-    createElementNS: function(uri, name) {
-        var element;
-        if(this.xmldom) {
-            if(typeof uri == "string") {
-                element = this.xmldom.createNode(1, name, uri);
-            } else {
-                element = this.xmldom.createNode(1, name, "");
-        } else {
-            element = document.createElementNS(uri, name);
-        return element;
-     * APIMethod: createTextNode
-     * Create a text node.  This node can be appended to another node with
-     *     the standard node.appendChild method.  For cross-browser support,
-     *     this method must be used instead of document.createTextNode.
-     * Parameters:
-     * text - {String} The text of the node.
-     * Returns:
-     * {DOMElement} A DOM text node.
-    createTextNode: function(text) {
-        var node;
-        if(this.xmldom) {
-            node = this.xmldom.createTextNode(text);
-        } else {
-            node = document.createTextNode(text);
-        return node;
-     * APIMethod: getElementsByTagNameNS
-     * Get a list of elements on a node given the namespace URI and local name.
-     *     To return all nodes in a given namespace, use '*' for the name
-     *     argument.  To return all nodes of a given (local) name, regardless
-     *     of namespace, use '*' for the uri argument.
-     * Parameters:
-     * node - {Element} Node on which to search for other nodes.
-     * uri - {String} Namespace URI.
-     * name - {String} Local name of the tag (without the prefix).
-     * Returns:
-     * {NodeList} A node list or array of elements.
-    getElementsByTagNameNS: function(node, uri, name) {
-        var elements = [];
-        if(node.getElementsByTagNameNS) {
-            elements = node.getElementsByTagNameNS(uri, name);
-        } else {
-            // brute force method
-            var allNodes = node.getElementsByTagName("*");
-            var potentialNode, fullName;
-            for(var i=0; i<allNodes.length; ++i) {
-                potentialNode = allNodes[i];
-                fullName = (potentialNode.prefix) ?
-                           (potentialNode.prefix + ":" + name) : name;
-                if((name == "*") || (fullName == potentialNode.nodeName)) {
-                    if((uri == "*") || (uri == potentialNode.namespaceURI)) {
-                        elements.push(potentialNode);
-        return elements;
-     * APIMethod: getAttributeNodeNS
-     * Get an attribute node given the namespace URI and local name.
-     * Parameters:
-     * node - {Element} Node on which to search for attribute nodes.
-     * name - {String} Local name of the attribute (without the prefix).
-     * Returns:
-     * {DOMElement} An attribute node or null if none found.
-    getAttributeNodeNS: function(node, uri, name) {
-        var attributeNode = null;
-        if(node.getAttributeNodeNS) {
-            attributeNode = node.getAttributeNodeNS(uri, name);
-        } else {
-            var attributes = node.attributes;
-            for(var i=0; i<attributes.length; ++i) {
-                potentialNode = attributes[i];
-                if(potentialNode.namespaceURI == uri) {
-                    if(fullName == potentialNode.nodeName) {
-                        attributeNode = potentialNode;
-                        break;
-        return attributeNode;
-     * APIMethod: getAttributeNS
-     * Get an attribute value given the namespace URI and local name.
-     * Parameters:
-     * node - {Element} Node on which to search for an attribute.
-     * Returns:
-     * {String} An attribute value or and empty string if none found.
-    getAttributeNS: function(node, uri, name) {
-        var attributeValue = "";
-        if(node.getAttributeNS) {
-            attributeValue = node.getAttributeNS(uri, name) || "";
-        } else {
-            var attributeNode = this.getAttributeNodeNS(node, uri, name);
-            if(attributeNode) {
-                attributeValue = attributeNode.nodeValue;
-        return attributeValue;
-     * APIMethod: getChildValue
-     * Get the value of the first child node if it exists, or return an
-     *     optional default string.  Returns an empty string if no first child
-     *     exists and no default value is supplied.
-     * Parameters:
-     * node - {DOMElement} The element used to look for a first child value.
-     * def - {String} Optional string to return in the event that no
-     *     first child value exists.
-     * Returns:
-     * {String} The value of the first child of the given node.
-    getChildValue: function(node, def) {
-        var value;
-        try {
-            value = node.firstChild.nodeValue;
-        } catch(e) {
-            value = (def != undefined) ? def : "";
-        return value;
-     * APIMethod: concatChildValues
-     * Concatenate the value of all child nodes if any exist, or return an
-     *     optional default string.  Returns an empty string if no children
-     *     exist and no default value is supplied.  Not optimized for large
-     *     numbers of child nodes.
-     * Parameters:
-     * node - {DOMElement} The element used to look for child values.
-     *     child exist.
-     * Returns:
-     * {String} The concatenated value of all child nodes of the given node.
-    concatChildValues: function(node, def) {
-        var value = "";
-        var child = node.firstChild;
-        var childValue;
-        while(child) {
-            childValue = child.nodeValue;
-            if(childValue) {
-                value += childValue;
-            child = child.nextSibling;
-        if(value == "" && def != undefined) {
-            value = def;
-        return value;
-     * APIMethod: hasAttributeNS
-     * Determine whether a node has a particular attribute matching the given
-     *     name and namespace.
-     * Parameters:
-     * Returns:
-     * {Boolean} The node has an attribute matching the name and namespace.
-    hasAttributeNS: function(node, uri, name) {
-        var found = false;
-        if(node.hasAttributeNS) {
-            found = node.hasAttributeNS(uri, name);
-        } else {
-            found = !!this.getAttributeNodeNS(node, uri, name);
-        return found;
-     * APIMethod: setAttributeNS
-     * Adds a new attribute or changes the value of an attribute with the given
-     *     namespace and name.
-     * Parameters:
-     * node - {Element} Element node on which to set the attribute.
-     * uri - {String} Namespace URI for the attribute.
-     * name - {String} Qualified name (prefix:localname) for the attribute.
-     * value - {String} Attribute value.
-    setAttributeNS: function(node, uri, name, value) {
-        if(node.setAttributeNS) {
-            node.setAttributeNS(uri, name, value);
-        } else {
-            if(this.xmldom) {
-                if(uri) {
-                    var attribute = node.ownerDocument.createNode(
-                        2, name, uri
-                    attribute.nodeValue = value;
-                    node.setAttributeNode(attribute);
-                } else {
-                    node.setAttribute(name, value);
-            } else {
-                throw "setAttributeNS not implemented";
-    CLASS_NAME: "OpenLayers.Format.XML"
     OpenLayers/Handler.js
@@ -13958,6 +8595,7 @@
      *  - *movestart* triggered after the start of a drag, pan, or zoom
      *  - *move* triggered after each drag, pan, or zoom
      *  - *moveend* triggered after a drag, pan, or zoom completes
+     *  - *zoomend* triggered after a zoom completes
      *  - *popupopen* triggered after a popup opens
      *  - *popupclose* triggered after a popup opens
      *  - *addmarker* triggered after a marker has been added
@@ -14848,7 +9486,7 @@
      * Paremeters:
      * layer - {<OpenLayers.Layer>}
-     * idx - {int}
+     * delta - {int}
     raiseLayer: function (layer, delta) {
         var idx = this.getLayerIndex(layer) + delta;
@@ -15229,11 +9867,7 @@
      *    false.
     pan: function(dx, dy, options) {
-        // this should be pushed to applyDefaults and extend
-        if (!options) {
-            options = {};
-        OpenLayers.Util.applyDefaults(options, {
+        options = OpenLayers.Util.applyDefaults(options, {
             animate: true,
             dragging: false
@@ -15269,6 +9903,13 @@
                 this.panTween = new OpenLayers.Tween(this.panMethod);
             var center = this.getCenter();
+            // center will not change, don't do nothing
+            if (lonlat.lon == center.lon &&
+                lonlat.lat == center.lat) {
+                return;
             var from = {
                 lon: center.lon,
                 lat: center.lat
@@ -15654,6 +10295,21 @@
         return resolution;
+     * APIMethod: getUnits
+     * Returns:
+     * {Float} The current units of the map.
+     *         If no baselayer is set, returns null.
+    getUnits: function () {
+        var units = null;
+        if (this.baseLayer != null) {
+            units = this.baseLayer.units;
+        return units;
       * APIMethod: getScale
@@ -16102,9 +10758,9 @@
      * Constructor: OpenLayers.Marker
-     * Paraemeters:
-     * icon - {<OpenLayers.Icon>}  the icon for this marker
+     * Parameters:
      * lonlat - {<OpenLayers.LonLat>} the position of this marker
+     * icon - {<OpenLayers.Icon>}  the icon for this marker
     initialize: function(lonlat, icon) {
         this.lonlat = lonlat;
@@ -16256,1623 +10912,6 @@
-    OpenLayers/Popup/AnchoredBubble.js
- * @requires OpenLayers/Popup/Anchored.js
- * Class: OpenLayers.Popup.AnchoredBubble
- * Inherits from:
- *  - <OpenLayers.Popup.Anchored>
-OpenLayers.Popup.AnchoredBubble =
-  OpenLayers.Class(OpenLayers.Popup.Anchored, {
-     * Property: rounded
-     * {Boolean} Has the popup been rounded yet?
-    rounded: false,
-     * Constructor: OpenLayers.Popup.AnchoredBubble
-     * Parameters:
-     * id - {String}
-     * anchor - {Object} Object to which we'll anchor the popup. Must expose
-     *     a 'size' (<OpenLayers.Size>) and 'offset' (<OpenLayers.Pixel>)
-     *     (Note that this is generally an <OpenLayers.Icon>).
-        this.padding = new OpenLayers.Bounds(
-            0, OpenLayers.Popup.AnchoredBubble.CORNER_SIZE,
-        OpenLayers.Popup.Anchored.prototype.initialize.apply(this, arguments);
-     * Method: draw
-     * Parameters:
-     * Returns:
-     * {DOMElement} Reference to a div that contains the drawn popup.
-        OpenLayers.Popup.Anchored.prototype.draw.apply(this, arguments);
-        this.setContentHTML();
-        //set the popup color and opacity
-        this.setBackgroundColor();
-        this.setOpacity();
-        return this.div;
-     * The popup has been moved to a new relative location, in which case
-     *     we will want to re-do the rico corners.
-        this.setRicoCorners();
-     * Parameters:
-        OpenLayers.Popup.Anchored.prototype.setSize.apply(this, arguments);
-     * APIMethod: setBackgroundColor
-     * Parameters:
-     * color - {String}
-    setBackgroundColor:function(color) {
-        if (color != undefined) {
-            this.backgroundColor = color;
-            if (this.contentDiv != null) {
-                this.div.style.background = "transparent";
-                OpenLayers.Rico.Corner.changeColor(this.groupDiv,
-                                                   this.backgroundColor);
-     * APIMethod: setOpacity
-     * Parameters:
-     * opacity - {float}
-    setOpacity:function(opacity) {
-        OpenLayers.Popup.Anchored.prototype.setOpacity.call(this, opacity);
-            if (this.groupDiv != null) {
-                OpenLayers.Rico.Corner.changeOpacity(this.groupDiv,
-                                                     this.opacity);
-     * Method: setBorder
-     * Always sets border to 0. Bubble Popups can not have a border.
-     * Parameters:
-     * border - {Integer}
-    setBorder:function(border) {
-        this.border = 0;
-     * Method: setRicoCorners
-     * Update RICO corners according to the popup's current relative postion.
-    setRicoCorners:function() {
-        var corners = this.getCornersToRound(this.relativePosition);
-        var options = {corners: corners,
-                         color: this.backgroundColor,
-                       bgColor: "transparent",
-                         blend: false};
-        if (!this.rounded) {
-            OpenLayers.Rico.Corner.round(this.div, options);
-            this.rounded = true;
-        } else {
-            OpenLayers.Rico.Corner.reRound(this.groupDiv, options);
-     * Method: getCornersToRound
-     * Returns:
-     * {String} The proper corners string ("tr tl bl br") for rico to round.
-    getCornersToRound:function() {
-        var corners = ['tl', 'tr', 'bl', 'br'];
-        //we want to round all the corners _except_ the opposite one.
-        var corner = OpenLayers.Bounds.oppositeQuadrant(this.relativePosition);
-        OpenLayers.Util.removeItem(corners, corner);
-        return corners.join(" ");
-    CLASS_NAME: "OpenLayers.Popup.AnchoredBubble"
- * Constant: CORNER_SIZE
- * {Integer} 5. Border space for the RICO corners.
-OpenLayers.Popup.AnchoredBubble.CORNER_SIZE = 5;
-    OpenLayers/Popup/Framed.js
- * Class: OpenLayers.Popup.Framed
- * Inherits from:
-OpenLayers.Popup.Framed =
-     * Property: imageSrc
-     * {String} location of the image to be used as the popup frame
-    imageSrc: null,
-     * Property: imageSize
-     * {<OpenLayers.Size>} Size (measured in pixels) of the image located
-     *     by the 'imageSrc' property.
-    imageSize: null,
-     * APIProperty: isAlphaImage
-     * {Boolean} The image has some alpha and thus needs to use the alpha
-     *     image hack. Note that setting this to true will have no noticeable
-     *     effect in FF or IE7 browsers, but will all but crush the ie6
-     *     browser.
-    isAlphaImage: false,
-     * Property: positionBlocks
-     * {Object} Hash of different position blocks (Object/Hashs). Each block
-     *     will be keyed by a two-character 'relativePosition'
-     *     code string (ie "tl", "tr", "bl", "br"). Block properties are
-     *     'offset', 'padding' (self-explanatory), and finally the 'blocks'
-     *     parameter, which is an array of the block objects.
-     *     Each block object must have 'size', 'anchor', and 'position'
-     *     properties.
-     *     Note that positionBlocks should never be modified at runtime.
-    positionBlocks: null,
-     * Property: blocks
-     * {Array[Object]} Array of objects, each of which is one "block" of the
-     *     popup. Each block has a 'div' and an 'image' property, both of
-     *     which are DOMElements, and the latter of which is appended to the
-     *     former. These are reused as the popup goes changing positions for
-     *     great economy and elegance.
-    blocks: null,
-     * APIProperty: fixedRelativePosition
-     * {Boolean} We want the framed popup to work dynamically placed relative
-     *     to its anchor but also in just one fixed position. A well designed
-     *     framed popup will have the pixels and logic to display itself in
-     *     any of the four relative positions, but (understandably), this will
-     *     not be the case for all of them. By setting this property to 'true',
-     *     framed popup will not recalculate for the best placement each time
-     *     it's open, but will always open the same way.
-     *     Note that if this is set to true, it is generally advisable to also
-     *     set the 'panIntoView' property to true so that the popup can be
-     *     scrolled into view (since it will often be offscreen on open)
-    fixedRelativePosition: false,
-     * Constructor: OpenLayers.Popup.Framed
-     * Parameters:
-     * id - {String}
-        if (this.fixedRelativePosition) {
-            //based on our decided relativePostion, set the current padding
-            // this keeps us from getting into trouble
-            //make calculateRelativePosition always returnt the specified
-            // fiexed position.
-            this.calculateRelativePosition = function(px) {
-                return this.relativePosition;
-        this.contentDiv.style.position = "absolute";
-        this.contentDiv.style.zIndex = 1;
-        if (closeBox) {
-            this.closeDiv.style.zIndex = 1;
-        this.groupDiv.style.position = "absolute";
-        this.groupDiv.style.top = "0px";
-        this.groupDiv.style.left = "0px";
-        this.groupDiv.style.height = "100%";
-        this.groupDiv.style.width = "100%";
-    destroy: function() {
-        this.imageSrc = null;
-        this.imageSize = null;
-        this.isAlphaImage = null;
-        this.fixedRelativePosition = false;
-        this.positionBlocks = null;
-        //remove our blocks
-        for(var i = 0; i < this.blocks.length; i++) {
-            var block = this.blocks[i];
-            if (block.image) {
-                block.div.removeChild(block.image);
-            block.image = null;
-            if (block.div) {
-                this.groupDiv.removeChild(block.div);
-            block.div = null;
-        this.blocks = null;
-        OpenLayers.Popup.Anchored.prototype.destroy.apply(this, arguments);
-        //does nothing since the framed popup's entire scheme is based on a
-        // an image -- changing the background color makes no sense.
-     * APIMethod: setBorder
-    setBorder:function() {
-        // an image -- changing the popup's border makes no sense.
-     * Method: setOpacity
-     * Sets the opacity of the popup.
-     * Parameters:
-     * opacity - {float} A value between 0.0 (transparent) and 1.0 (solid).
-        //does nothing since we suppose that we'll never apply an opacity
-        // to a framed popup
-     * Overridden here, because we need to update the blocks whenever the size
-     *     of the popup has changed.
-     * Parameters:
-     * size - {<OpenLayers.Size>}
-        this.updateBlocks();
-     * When the relative position changes, we need to set the new padding
-     *     BBOX on the popup, reposition the close div, and update the blocks.
-        //update the padding
-        this.padding = this.positionBlocks[this.relativePosition].padding;
-        //update the position of our close box to new padding
-        if (this.closeDiv) {
-            // use the content div's css padding to determine if we should
-            //  padd the close div
-            var contentDivPadding = this.getContentDivPadding();
-            this.closeDiv.style.right = contentDivPadding.right +
-                                        this.padding.right + "px";
-            this.closeDiv.style.top = contentDivPadding.top +
-                                      this.padding.top + "px";
-     * Besides the standard offset as determined by the Anchored class, our
-     *     Framed popups have a special 'offset' property for each of their
-     *     positions, which is used to offset the popup relative to its anchor.
-     * Parameters:
-     * px - {<OpenLayers.Pixel>}
-     * Returns:
-        var newPx = OpenLayers.Popup.Anchored.prototype.calculateNewPx.apply(
-            this, arguments
-        newPx = newPx.offset(this.positionBlocks[this.relativePosition].offset);
-        return newPx;
-     * Method: createBlocks
-    createBlocks: function() {
-        this.blocks = [];
-        //since all positions contain the same number of blocks, we can
-        // just pick the first position and use its blocks array to create
-        // our blocks array
-        var firstPosition = null;
-        for(var key in this.positionBlocks) {
-            firstPosition = key;
-            break;
-        var position = this.positionBlocks[firstPosition];
-        for (var i = 0; i < position.blocks.length; i++) {
-            var block = {};
-            this.blocks.push(block);
-            var divId = this.id + '_FrameDecorationDiv_' + i;
-            block.div = OpenLayers.Util.createDiv(divId,
-                null, null, null, "absolute", null, "hidden", null
-            var imgId = this.id + '_FrameDecorationImg_' + i;
-            var imageCreator =
-                (this.isAlphaImage) ? OpenLayers.Util.createAlphaImageDiv
-                                    : OpenLayers.Util.createImage;
-            block.image = imageCreator(imgId,
-                null, this.imageSize, this.imageSrc,
-                "absolute", null, null, null
-            block.div.appendChild(block.image);
-            this.groupDiv.appendChild(block.div);
-     * Method: updateBlocks
-     * Internal method, called on initialize and when the popup's relative
-     *     position has changed. This function takes care of re-positioning
-     *     the popup's blocks in their appropropriate places.
-    updateBlocks: function() {
-        if (!this.blocks) {
-            this.createBlocks();
-        if (this.relativePosition) {
-            var position = this.positionBlocks[this.relativePosition];
-                var positionBlock = position.blocks[i];
-                // adjust sizes
-                var l = positionBlock.anchor.left;
-                var b = positionBlock.anchor.bottom;
-                var r = positionBlock.anchor.right;
-                var t = positionBlock.anchor.top;
-                //note that we use the isNaN() test here because if the
-                // size object is initialized with a "auto" parameter, the
-                // size constructor calls parseFloat() on the string,
-                // which will turn it into NaN
-                var w = (isNaN(positionBlock.size.w)) ? this.size.w - (r + l)
-                                                      : positionBlock.size.w;
-                var h = (isNaN(positionBlock.size.h)) ? this.size.h - (b + t)
-                                                      : positionBlock.size.h;
-                block.div.style.width = w + 'px';
-                block.div.style.height = h + 'px';
-                block.div.style.left = (l != null) ? l + 'px' : '';
-                block.div.style.bottom = (b != null) ? b + 'px' : '';
-                block.div.style.right = (r != null) ? r + 'px' : '';
-                block.div.style.top = (t != null) ? t + 'px' : '';
-                block.image.style.left = positionBlock.position.x + 'px';
-                block.image.style.top = positionBlock.position.y + 'px';
-            this.contentDiv.style.left = this.padding.left + "px";
-            this.contentDiv.style.top = this.padding.top + "px";
-    CLASS_NAME: "OpenLayers.Popup.Framed"
-    OpenLayers/Renderer/SVG.js
- * @requires OpenLayers/Renderer/Elements.js
- * Class: OpenLayers.Renderer.SVG
- * Inherits:
- *  - <OpenLayers.Renderer.Elements>
-OpenLayers.Renderer.SVG = OpenLayers.Class(OpenLayers.Renderer.Elements, {
-     * Property: xmlns
-     * {String}
-    xmlns: "http://www.w3.org/2000/svg",
-     * Constant: MAX_PIXEL
-     * {Integer} Firefox has a limitation where values larger or smaller than
-     *           about 15000 in an SVG document lock the browser up. This
-     *           works around it.
-    MAX_PIXEL: 15000,
-     * Property: localResolution
-     * {Float}
-    localResolution: null,
-     * Constructor: OpenLayers.Renderer.SVG
-     * Parameters:
-        if (!this.supported()) {
-            return;
-        OpenLayers.Renderer.Elements.prototype.initialize.apply(this,
-        arguments);
-        OpenLayers.Renderer.Elements.prototype.destroy.apply(this, arguments);
-     * APIMethod: supported
-     * Returns:
-     * {Boolean} Whether or not the browser supports the SVG renderer
-    supported: function() {
-        var svgFeature = "http://www.w3.org/TR/SVG11/feature#";
-        return (document.implementation &&
-           (document.implementation.hasFeature("org.w3c.svg", "1.0") ||
-            document.implementation.hasFeature(svgFeature + "SVG", "1.1") ||
-            document.implementation.hasFeature(svgFeature + "BasicStructure", "1.1") ));
-     * Method: inValidRange
-     * See #669 for more information
-     * Parameters:
-     * x - {Integer}
-     * y - {Integer}
-     * Returns:
-     * {Boolean} Whether or not the 'x' and 'y' coordinates are in the
-     *           valid range.
-    inValidRange: function(x, y) {
-        return (x >= -this.MAX_PIXEL && x <= this.MAX_PIXEL &&
-                y >= -this.MAX_PIXEL && y <= this.MAX_PIXEL);
-     * Method: setExtent
-     * Parameters:
-     * extent - {<OpenLayers.Bounds>}
-    setExtent: function(extent) {
-        OpenLayers.Renderer.Elements.prototype.setExtent.apply(this,
-                                                               arguments);
-        var resolution = this.getResolution();
-        // If the resolution has changed, start over changing the corner, because
-        // the features will redraw.
-        if (!this.localResolution || resolution != this.localResolution) {
-            this.left = -extent.left / resolution;
-            this.top = extent.top / resolution;
-        var left = 0;
-        var top = 0;
-        // If the resolution has not changed, we already have features, and we need
-        // to adjust the viewbox to fit them.
-        if (this.localResolution && resolution == this.localResolution) {
-            left = (this.left) - (-extent.left / resolution);
-            top  = (this.top) - (extent.top / resolution);
-        // Store resolution for use later.
-        this.localResolution = resolution;
-        // Set the viewbox -- the left/top will be pixels-dragged-since-res change,
-        // the width/height will be pixels.
-        var extentString = left + " " + top + " " +
-                             extent.getWidth() / resolution + " " + extent.getHeight() / resolution;
-        //var extentString = extent.left / resolution + " " + -extent.top / resolution + " " +
-        this.rendererRoot.setAttributeNS(null, "viewBox", extentString);
-     * Method: setSize
-     * Sets the size of the drawing surface.
-     * Parameters:
-     * size - {<OpenLayers.Size>} The size of the drawing surface
-    setSize: function(size) {
-        OpenLayers.Renderer.prototype.setSize.apply(this, arguments);
-        this.rendererRoot.setAttributeNS(null, "width", this.size.w);
-        this.rendererRoot.setAttributeNS(null, "height", this.size.h);
-     * Parameters:
-     * Returns:
-        var nodeType = null;
-                nodeType = style.externalGraphic ? "image" : "circle";
-                break;
-                nodeType = "rect";
-                break;
-                nodeType = "polyline";
-                break;
-                nodeType = "polygon";
-                break;
-            case "OpenLayers.Geometry.Curve":
-                nodeType = "path";
-                break;
-            default:
-                break;
-        return nodeType;
-     * Method: setStyle
-     * Use to set all the style attributes to a SVG node.
-     * Takes care to adjust stroke width and point radius to be
-     * resolution-relative
-     * Parameters:
-     * node - {SVGDomElement} An SVG element to decorate
-     * options - {Object} Currently supported options include
-     *                              'isFilled' {Boolean} and
-     *                              'isStroked' {Boolean}
-    setStyle: function(node, style, options) {
-        options = options || node._options;
-        var r = parseFloat(node.getAttributeNS(null, "r"));
-        if (node._geometryClass == "OpenLayers.Geometry.Point" && r) {
-            if (style.externalGraphic) {
-                var x = parseFloat(node.getAttributeNS(null, "cx"));
-                var y = parseFloat(node.getAttributeNS(null, "cy"));
-                if (style.graphicWidth && style.graphicHeight) {
-                  node.setAttributeNS(null, "preserveAspectRatio", "none");
-                var width = style.graphicWidth || style.graphicHeight;
-                var height = style.graphicHeight || style.graphicWidth;
-                width = width ? width : style.pointRadius*2;
-                height = height ? height : style.pointRadius*2;
-                var xOffset = (style.graphicXOffset != undefined) ?
-                    style.graphicXOffset : -(0.5 * width);
-                var yOffset = (style.graphicYOffset != undefined) ?
-                    style.graphicYOffset : -(0.5 * height);
-                var opacity = style.graphicOpacity || style.fillOpacity;
-                node.setAttributeNS(null, "x", (x + xOffset).toFixed());
-                node.setAttributeNS(null, "y", (y + yOffset).toFixed());
-                node.setAttributeNS(null, "width", width);
-                node.setAttributeNS(null, "height", height);
-                node.setAttributeNS("http://www.w3.org/1999/xlink", "href", style.externalGraphic);
-                node.setAttributeNS(null, "style", "opacity: "+opacity);
-            } else {
-                node.setAttributeNS(null, "r", style.pointRadius);
-        if (options.isFilled) {
-            node.setAttributeNS(null, "fill", style.fillColor);
-            node.setAttributeNS(null, "fill-opacity", style.fillOpacity);
-        } else {
-            node.setAttributeNS(null, "fill", "none");
-        if (options.isStroked) {
-            node.setAttributeNS(null, "stroke", style.strokeColor);
-            node.setAttributeNS(null, "stroke-opacity", style.strokeOpacity);
-            node.setAttributeNS(null, "stroke-width", style.strokeWidth);
-            node.setAttributeNS(null, "stroke-linecap", style.strokeLinecap);
-        } else {
-            node.setAttributeNS(null, "stroke", "none");
-        if (style.pointerEvents) {
-            node.setAttributeNS(null, "pointer-events", style.pointerEvents);
-        if (style.cursor != null) {
-            node.setAttributeNS(null, "cursor", style.cursor);
-        return node;
-     * Method: createNode
-     * Parameters:
-     * type - {String} Kind of node to draw
-     * id - {String} Id for node
-     * Returns:
-    createNode: function(type, id) {
-        var node = document.createElementNS(this.xmlns, type);
-        if (id) {
-            node.setAttributeNS(null, "id", id);
-        return node;
-     * Method: nodeTypeCompare
-     * Parameters:
-     * Returns:
-     * {Boolean} Whether or not the specified node is of the specified type
-    nodeTypeCompare: function(node, type) {
-        return (type == node.nodeName);
-     * Method: createRenderRoot
-     * Returns:
-     * {DOMElement} The specific render engine's root element
-    createRenderRoot: function() {
-        return this.nodeFactory(this.container.id + "_svgRoot", "svg");
-     * Method: createRoot
-     * Returns:
-     * {DOMElement} The main root element to which we'll add vectors
-    createRoot: function() {
-        return this.nodeFactory(this.container.id + "_root", "g");
-     *     GEOMETRY DRAWING FUNCTIONS     *
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-        this.drawCircle(node, geometry, 1);
-     * Parameters:
-     * radius - {Float}
-    drawCircle: function(node, geometry, radius) {
-        var x = (geometry.x / resolution + this.left);
-        var y = (this.top - geometry.y / resolution);
-        if (this.inValidRange(x, y)) {
-            node.setAttributeNS(null, "cx", x);
-            node.setAttributeNS(null, "cy", y);
-            node.setAttributeNS(null, "r", radius);
-        } else {
-            node.setAttributeNS(null, "cx", "");
-            node.setAttributeNS(null, "cy", "");
-            node.setAttributeNS(null, "r", 0);
-     * Parameters:
-        node.setAttributeNS(null, "points",
-                            this.getComponentsString(geometry.components));
-    /**v
-     * Parameters:
-     * Parameters:
-        var d = "";
-        var draw = true;
-        for (var j = 0; j < geometry.components.length; j++) {
-            var linearRing = geometry.components[j];
-            d += " M";
-            for (var i = 0; i < linearRing.components.length; i++) {
-                var component = this.getShortString(linearRing.components[i]);
-                if (component) {
-                    d += " " + component;
-                } else {
-                    draw = false;
-        d += " z";
-        if (draw) {
-            node.setAttributeNS(null, "d", d);
-            node.setAttributeNS(null, "fill-rule", "evenodd");
-        } else {
-            node.setAttributeNS(null, "d", "");
-     * This method is only called by the renderer itself.
-     * Parameters:
-            node.setAttributeNS(null, "x", x);
-            node.setAttributeNS(null, "y", y);
-            node.setAttributeNS(null, "width", geometry.width / resolution);
-            node.setAttributeNS(null, "height", geometry.height / resolution);
-        } else {
-            node.setAttributeNS(null, "x", "");
-            node.setAttributeNS(null, "y", "");
-            node.setAttributeNS(null, "width", 0);
-            node.setAttributeNS(null, "height", 0);
-     * Parameters:
-        // create the svg path string representation
-        var d = null;
-        var draw = true;
-        for (var i = 0; i < geometry.components.length; i++) {
-            if ((i%3) == 0 && (i/3) == 0) {
-                var component = this.getShortString(geometry.components[i]);
-                if (!component) { draw = false; }
-                d = "M " + component;
-            } else if ((i%3) == 1) {
-                d += " C " + component;
-            } else {
-        d += " Z";
-        if (draw) {
-        } else {
-     * Method: getComponentString
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry.Point>)} Array of points
-    getComponentsString: function(components) {
-        var strings = [];
-        for(var i = 0; i < components.length; i++) {
-            var component = this.getShortString(components[i]);
-            if (component) {
-                strings.push(component);
-        return strings.join(",");
-     * Method: getShortString
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>}
-     * Returns:
-     * {String}
-    getShortString: function(point) {
-        var x = (point.x / resolution + this.left);
-        var y = (this.top - point.y / resolution);
-            return x + "," + y;
-        } else {
-            return false;
-    CLASS_NAME: "OpenLayers.Renderer.SVG"
-    OpenLayers/Renderer/VML.js
- * Class: OpenLayers.Renderer.VML
- * Render vector features in browsers with VML capability.  Construct a new
- * VML renderer with the <OpenLayers.Renderer.VML> constructor.
- * Note that for all calculations in this class, we use toFixed() to round a
- * float value to an integer. This is done because it seems that VML doesn't
- * support float values.
- * Inherits from:
-OpenLayers.Renderer.VML = OpenLayers.Class(OpenLayers.Renderer.Elements, {
-     * Property: xmlns
-     * {String} XML Namespace URN
-    xmlns: "urn:schemas-microsoft-com:vml",
-     * Constructor: OpenLayers.Renderer.VML
-     * Create a new VML renderer.
-     * Parameters:
-     * containerID - {String} The id for the element that contains the renderer
-    initialize: function(containerID) {
-            return;
-        if (!document.namespaces.olv) {
-            document.namespaces.add("olv", this.xmlns);
-            var style = document.createStyleSheet();
-            style.addRule('olv\\:*', "behavior: url(#default#VML); " +
-                                   "position: absolute; display: inline-block;");
-        arguments);
-     * Deconstruct the renderer.
-     * Determine whether a browser supports this renderer.
-     * Returns:
-     * {Boolean} The browser supports the VML renderer
-        return !!(document.namespaces);
-     * Set the renderer's extent
-     * Parameters:
-                                                               arguments);
-        var org = extent.left/resolution + " " +
-                    extent.top/resolution;
-        this.root.setAttribute("coordorigin", org);
-        var size = extent.getWidth()/resolution + " " +
-                    -extent.getHeight()/resolution;
-        this.root.setAttribute("coordsize", size);
-     * Method: setSize
-     * Set the size of the drawing surface
-     * Parameters:
-     * size - {<OpenLayers.Size>} the size of the drawing surface
-        this.rendererRoot.style.width = this.size.w;
-        this.rendererRoot.style.height = this.size.h;
-        this.root.style.width = this.size.w;
-        this.root.style.height = this.size.h;
-     * Method: getNodeType
-     * Get the node type for a geometry and style
-     * Parameters:
-     * style - {Object}
-     * Returns:
-     * {String} The corresponding node type for the specified geometry
-    getNodeType: function(geometry, style) {
-        switch (geometry.CLASS_NAME) {
-            case "OpenLayers.Geometry.Point":
-                nodeType = style.externalGraphic ? "olv:rect" : "olv:oval";
-                break;
-            case "OpenLayers.Geometry.Rectangle":
-                nodeType = "olv:rect";
-                break;
-            case "OpenLayers.Geometry.LineString":
-            case "OpenLayers.Geometry.LinearRing":
-            case "OpenLayers.Geometry.Polygon":
-            case "OpenLayers.Geometry.Surface":
-                nodeType = "olv:shape";
-                break;
-            default:
-                break;
-        return nodeType;
-     * Use to set all the style attributes to a VML node.
-     * Parameters:
-     * node - {DOMElement} An VML element to decorate
-    setStyle: function(node, style, options, geometry) {
-        style = style  || node._style;
-        if (node._geometryClass == "OpenLayers.Geometry.Point") {
-                node.style.left = ((geometry.x/resolution)+xOffset).toFixed();
-                node.style.top = ((geometry.y/resolution)-(yOffset+height)).toFixed();
-                node.style.width = width;
-                node.style.height = height;
-                // modify style/options for fill and stroke styling below
-                style.fillColor = "none";
-                options.isStroked = false;
-            } else {
-                this.drawCircle(node, geometry, style.pointRadius);
-        // fill
-            node.setAttribute("fillcolor", style.fillColor);
-        } else {
-            node.setAttribute("filled", "false");
-        var fills = node.getElementsByTagName("fill");
-        var fill = (fills.length == 0) ? null : fills[0];
-        if (!options.isFilled) {
-            if (fill) {
-                node.removeChild(fill);
-        } else {
-            if (!fill) {
-                fill = this.createNode('olv:fill', node.id + "_fill");
-            fill.setAttribute("opacity", style.fillOpacity);
-                    style.externalGraphic) {
-                // override fillOpacity
-                if (style.graphicOpacity) {
-                    fill.setAttribute("opacity", style.graphicOpacity);
-                fill.setAttribute("src", style.externalGraphic);
-                fill.setAttribute("type", "frame");
-                node.style.flip = "y";
-                if (!(style.graphicWidth && style.graphicHeight)) {
-                  fill.aspect = "atmost";
-            if (fill.parentNode != node) {
-                node.appendChild(fill);
-        // stroke
-            node.setAttribute("strokecolor", style.strokeColor);
-            node.setAttribute("strokeweight", style.strokeWidth + "px");
-        } else {
-            node.setAttribute("stroked", "false");
-        var strokes = node.getElementsByTagName("stroke");
-        var stroke = (strokes.length == 0) ? null : strokes[0];
-        if (!options.isStroked) {
-            if (stroke) {
-                node.removeChild(stroke);
-        } else {
-            if (!stroke) {
-                stroke = this.createNode('olv:stroke', node.id + "_stroke");
-                node.appendChild(stroke);
-            stroke.setAttribute("opacity", style.strokeOpacity);
-            stroke.setAttribute("endcap", !style.strokeLinecap || style.strokeLinecap == 'butt' ? 'flat' : style.strokeLinecap);
-            node.style.cursor = style.cursor;
-        return node;
-     * Method: postDraw
-     * Some versions of Internet Explorer seem to be unable to set fillcolor
-     * and strokecolor to "none" correctly before the fill node is appended to
-     * a visible vml node. This method takes care of that and sets fillcolor
-     * and strokecolor again if needed.
-     * Parameters:
-    postDraw: function(node) {
-        var fillColor = node._style.fillColor;
-        var strokeColor = node._style.strokeColor;
-        if (fillColor == "none" &&
-                node.getAttribute("fillcolor") != fillColor) {
-            node.setAttribute("fillcolor", fillColor);
-        if (strokeColor == "none" &&
-                node.getAttribute("strokecolor") != strokeColor) {
-            node.setAttribute("strokecolor", strokeColor);
-     * Method: setNodeDimension
-     * Get the geometry's bounds, convert it to our vml coordinate system,
-     * then set the node's position, size, and local coordinate system.
-     * Parameters:
-    setNodeDimension: function(node, geometry) {
-        var bbox = geometry.getBounds();
-        if(bbox) {
-            var scaledBox =
-                new OpenLayers.Bounds((bbox.left/resolution).toFixed(),
-                                      (bbox.bottom/resolution).toFixed(),
-                                      (bbox.right/resolution).toFixed(),
-                                      (bbox.top/resolution).toFixed());
-            // Set the internal coordinate system to draw the path
-            node.style.left = scaledBox.left;
-            node.style.top = scaledBox.top;
-            node.style.width = scaledBox.getWidth();
-            node.style.height = scaledBox.getHeight();
-            node.coordorigin = scaledBox.left + " " + scaledBox.top;
-            node.coordsize = scaledBox.getWidth()+ " " + scaledBox.getHeight();
-     * Create a new node
-     * Parameters:
-     * Returns:
-     * {DOMElement} A new node of the given type and id
-        var node = document.createElement(type);
-        if (id) {
-            node.setAttribute('id', id);
-        // IE hack to make elements unselectable, to prevent 'blue flash'
-        // while dragging vectors; #1410
-        node.setAttribute('unselectable', 'on', 0);
-        node.onselectstart = function() { return(false); };
-        return node;
-     * Determine whether a node is of a given type
-     * Parameters:
-     * Returns:
-        //split type
-        var subType = type;
-        var splitIndex = subType.indexOf(":");
-        if (splitIndex != -1) {
-            subType = subType.substr(splitIndex+1);
-        //split nodeName
-        var nodeName = node.nodeName;
-        splitIndex = nodeName.indexOf(":");
-            nodeName = nodeName.substr(splitIndex+1);
-        return (subType == nodeName);
-     * Create the renderer root
-     * Returns:
-        return this.nodeFactory(this.container.id + "_vmlRoot", "div");
-     * Create the main root element
-     * Returns:
-        return this.nodeFactory(this.container.id + "_root", "olv:group");
-     * Method: drawPoint
-     * Render a point
-     * Parameters:
-    drawPoint: function(node, geometry) {
-     * Method: drawCircle
-     * Render a circle.
-     * Size and Center a circle given geometry (x,y center) and radius
-     * Parameters:
-     * radius - {float}
-        if(!isNaN(geometry.x)&& !isNaN(geometry.y)) {
-            node.style.left = (geometry.x /resolution).toFixed() - radius;
-            node.style.top = (geometry.y /resolution).toFixed() - radius;
-            var diameter = radius * 2;
-            node.style.width = diameter;
-            node.style.height = diameter;
-     * Method: drawLineString
-     * Render a linestring.
-     * Parameters:
-    drawLineString: function(node, geometry) {
-        this.drawLine(node, geometry, false);
-     * Method: drawLinearRing
-     * Render a linearring
-     * Parameters:
-    drawLinearRing: function(node, geometry) {
-        this.drawLine(node, geometry, true);
-     * Method: DrawLine
-     * Render a line.
-     * Parameters:
-     * closeLine - {Boolean} Close the line? (make it a ring?)
-    drawLine: function(node, geometry, closeLine) {
-        this.setNodeDimension(node, geometry);
-        var numComponents = geometry.components.length;
-        var parts = new Array(numComponents);
-        var comp, x, y;
-        for (var i = 0; i < numComponents; i++) {
-            comp = geometry.components[i];
-            x = (comp.x/resolution);
-            y = (comp.y/resolution);
-            parts[i] = " " + x.toFixed() + "," + y.toFixed() + " l ";
-        var end = (closeLine) ? " x e" : " e";
-        node.path = "m" + parts.join("") + end;
-     * Method: drawPolygon
-     * Render a polygon
-     * Parameters:
-    drawPolygon: function(node, geometry) {
-        var path = [];
-        var linearRing, i, comp, x, y;
-            linearRing = geometry.components[j];
-            path.push("m");
-            for (i = 0; i < linearRing.components.length; i++) {
-                comp = linearRing.components[i];
-                x = comp.x / resolution;
-                y = comp.y / resolution;
-                path.push(" " + x.toFixed() + "," + y.toFixed());
-                if (i==0) {
-                    path.push(" l");
-            path.push(" x ");
-        path.push("e");
-        node.path = path.join("");
-     * Method: drawRectangle
-     * Render a rectangle
-     * Parameters:
-    drawRectangle: function(node, geometry) {
-        node.style.left = geometry.x/resolution;
-        node.style.top = geometry.y/resolution;
-        node.style.width = geometry.width/resolution;
-        node.style.height = geometry.height/resolution;
-     * Method: drawSurface
-     * Parameters:
-    drawSurface: function(node, geometry) {
-        var path = [];
-        var comp, x, y;
-            if ((i%3)==0 && (i/3)==0) {
-                path.push("m");
-            } else if ((i%3)==1) {
-                path.push(" c");
-            path.push(" " + x + "," + y);
-        path.push(" x e");
-    CLASS_NAME: "OpenLayers.Renderer.VML"
     OpenLayers/Tile/Image.js
@@ -18296,192 +11335,6 @@
     OpenLayers.Util.getBrowserName() == "safari" ||
     OpenLayers.Util.getBrowserName() == "opera");
-    OpenLayers/Tile/WFS.js
- * @requires OpenLayers/Tile.js
- * Class: OpenLayers.Tile.WFS
- * Instances of OpenLayers.Tile.WFS are used to manage the image tiles
- * used by various layers.  Create a new image tile with the
- * <OpenLayers.Tile.WFS> constructor.
- * Inherits from:
- *  - <OpenLayers.Tile>
-OpenLayers.Tile.WFS = OpenLayers.Class(OpenLayers.Tile, {
-     * Property: features
-     * {Array(<OpenLayers.Feature>)} list of features in this tile
-    features: null,
-     * Property: url
-     * {String}
-    url: null,
-     * Property: request
-     * {OpenLayers.Ajax.Request}
-    request: null,
-    /** TBD 3.0 - reorder the parameters to the init function to put URL
-     *             as last, so we can continue to call tile.initialize()
-     *             without changing the arguments.
-     * Constructor: OpenLayers.Tile.WFS
-     * Constructor for a new <OpenLayers.Tile.WFS> instance.
-     * Parameters:
-     * layer - {<OpenLayers.Layer>} layer that the tile will go in.
-     * position - {<OpenLayers.Pixel>}
-     * bounds - {<OpenLayers.Bounds>}
-     * url - {<String>}
-    initialize: function(layer, position, bounds, url, size) {
-        OpenLayers.Tile.prototype.initialize.apply(this, arguments);
-        this.url = url;
-        this.features = [];
-     * APIMethod: destroy
-     * nullify references to prevent circular references and memory leaks
-        OpenLayers.Tile.prototype.destroy.apply(this, arguments);
-        this.destroyAllFeatures();
-        this.features = null;
-        this.url = null;
-        if(this.request) {
-            this.request.abort();
-            //this.request.destroy();
-            this.request = null;
-     * Method: clear
-     *  Clear the tile of any bounds/position-related data so that it can
-     *   be reused in a new location.
-    clear: function() {
-     * Method: draw
-     * Check that a tile should be drawn, and load features for it.
-    draw:function() {
-        if (OpenLayers.Tile.prototype.draw.apply(this, arguments)) {
-            if (this.isLoading) {
-                //if already loading, send 'reload' instead of 'loadstart'.
-                this.events.triggerEvent("reload");
-            } else {
-                this.isLoading = true;
-                this.events.triggerEvent("loadstart");
-            this.loadFeaturesForRegion(this.requestSuccess);
-    * Method: loadFeaturesForRegion
-    * get the full request string from the ds and the tile params
-    *     and call the AJAX loadURL().
-    * Input are function pointers for what to do on success and failure.
-    * Parameters:
-    * success - {function}
-    * failure - {function}
-    loadFeaturesForRegion:function(success, failure) {
-        this.request = OpenLayers.loadURL(this.url, null, this, success);
-    * Method: requestSuccess
-    * Called on return from request succcess. Adds results via
-    * layer.addFeatures in vector mode, addResults otherwise.
-    * Parameters:
-    * request - {XMLHttpRequest}
-    requestSuccess:function(request) {
-        if (this.features) {
-            var doc = request.responseXML;
-            if (!doc || !doc.documentElement) {
-                doc = OpenLayers.Format.XML.prototype.read(request.responseText);
-            if (this.layer.vectorMode) {
-                this.layer.addFeatures(this.layer.formatObject.read(doc));
-            } else {
-                var resultFeatures = OpenLayers.Ajax.getElementsByTagNameNS(
-                    doc, "http://www.opengis.net/gml", "gml", "featureMember"
-                this.addResults(resultFeatures);
-        if (this.events) {
-            this.events.triggerEvent("loadend");
-        //request produced with success, we can delete the request object.
-     * Method: addResults
-     * Construct new feature via layer featureClass constructor, and add to
-     * this.features.
-     * Parameters:
-     * results - {Object}
-    addResults: function(results) {
-        for (var i=0; i < results.length; i++) {
-            var feature = new this.layer.featureClass(this.layer,
-                                                      results[i]);
-            this.features.push(feature);
-     * Method: destroyAllFeatures
-     * Iterate through and call destroy() on each feature, removing it from
-     *   the local array
-    destroyAllFeatures: function() {
-        while(this.features.length > 0) {
-            var feature = this.features.shift();
-            feature.destroy();
-    CLASS_NAME: "OpenLayers.Tile.WFS"
     OpenLayers/Control/OverviewMap.js
@@ -18982,7 +11835,7 @@
     updateRectToMap: function() {
         // The base layer for overview map needs to be in the same projection
         // as the base layer for the main map.  This should be made more robust.
-        if(this.map.units != 'degrees') {
+        if(this.map.getUnits() != 'degrees') {
             if(this.ovmap.getProjection() && (this.map.getProjection() != this.ovmap.getProjection())) {
                 alert(OpenLayers.i18n("sameProjection"));
@@ -19138,1268 +11991,6 @@
     CLASS_NAME: 'OpenLayers.Control.OverviewMap'
-    OpenLayers/Feature.js
- * @requires OpenLayers/Util.js
- * @requires OpenLayers/Marker.js
- * @requires OpenLayers/Popup/AnchoredBubble.js
- * Class: OpenLayers.Feature
- * Features are combinations of geography and attributes. The OpenLayers.Feature
- *     class specifically combines a marker and a lonlat.
-OpenLayers.Feature = OpenLayers.Class({
-     * Property: layer
-     * {<OpenLayers.Layer>}
-    layer: null,
-     * Property: id
-     * {String}
-    id: null,
-     * Property: lonlat
-     * {<OpenLayers.LonLat>}
-    lonlat: null,
-     * Property: data
-     * {Object}
-    data: null,
-     * Property: marker
-     * {<OpenLayers.Marker>}
-    marker: null,
-     * APIProperty: popupClass
-     * {<OpenLayers.Class>} The class which will be used to instantiate
-     *     a new Popup. Default is <OpenLayers.Popup.AnchoredBubble>.
-    popupClass: OpenLayers.Popup.AnchoredBubble,
-     * Property: popup
-     * {<OpenLayers.Popup>}
-    popup: null,
-     * Constructor: OpenLayers.Feature
-     * Constructor for features.
-     * Parameters:
-     * lonlat - {<OpenLayers.LonLat>}
-     * data - {Object}
-     * Returns:
-     * {<OpenLayers.Feature>}
-    initialize: function(layer, lonlat, data) {
-        this.layer = layer;
-        this.lonlat = lonlat;
-        this.data = (data != null) ? data : {};
-        this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
-     * Method: destroy
-        //remove the popup from the map
-        if ((this.layer != null) && (this.layer.map != null)) {
-            if (this.popup != null) {
-                this.layer.map.removePopup(this.popup);
-        this.layer = null;
-        this.id = null;
-        this.lonlat = null;
-        this.data = null;
-        if (this.marker != null) {
-            this.destroyMarker(this.marker);
-            this.marker = null;
-            this.destroyPopup(this.popup);
-            this.popup = null;
-     * Method: onScreen
-     * Returns:
-     * {Boolean} Whether or not the feature is currently visible on screen
-     *           (based on its 'lonlat' property)
-    onScreen:function() {
-        var onScreen = false;
-            var screenBounds = this.layer.map.getExtent();
-            onScreen = screenBounds.containsLonLat(this.lonlat);
-        return onScreen;
-     * Method: createMarker
-     * Based on the data associated with the Feature, create and return a marker object.
-     * Returns:
-     * {<OpenLayers.Marker>} A Marker Object created from the 'lonlat' and 'icon' properties
-     *          set in this.data. If no 'lonlat' is set, returns null. If no
-     *          'icon' is set, OpenLayers.Marker() will load the default image.
-     *          Note - this.marker is set to return value
-    createMarker: function() {
-        if (this.lonlat != null) {
-            this.marker = new OpenLayers.Marker(this.lonlat, this.data.icon);
-        return this.marker;
-     * Method: destroyMarker
-     * Destroys marker.
-     * If user overrides the createMarker() function, s/he should be able
-     *   to also specify an alternative function for destroying it
-    destroyMarker: function() {
-        this.marker.destroy();
-     * Method: createPopup
-     * Creates a popup object created from the 'lonlat', 'popupSize',
-     *     and 'popupContentHTML' properties set in this.data. It uses
-     *     this.marker.icon as default anchor.
-     *  If no 'lonlat' is set, returns null.
-     *  If no this.marker has been created, no anchor is sent.
-     *  Note - the returned popup object is 'owned' by the feature, so you
-     *      cannot use the popup's destroy method to discard the popup.
-     *      Instead, you must use the feature's destroyPopup
-     *  Note - this.popup is set to return value
-     * Parameters:
-     * closeBox - {Boolean} create popup with closebox or not
-     * Returns:
-     * {<OpenLayers.Popup>} Returns the created popup, which is also set
-     *     as 'popup' property of this feature. Will be of whatever type
-     *     specified by this feature's 'popupClass' property, but must be
-     *     of type <OpenLayers.Popup>.
-    createPopup: function(closeBox) {
-            var id = this.id + "_popup";
-            var anchor = (this.marker) ? this.marker.icon : null;
-            if (!this.popup) {
-                this.popup = new this.popupClass(id,
-                                                 this.lonlat,
-                                                 this.data.popupSize,
-                                                 this.data.popupContentHTML,
-                                                 anchor,
-                                                 closeBox);
-            if (this.data.overflow != null) {
-                this.popup.contentDiv.style.overflow = this.data.overflow;
-            this.popup.feature = this;
-        return this.popup;
-     * Method: destroyPopup
-     * Destroys the popup created via createPopup.
-     * As with the marker, if user overrides the createPopup() function, s/he
-     *   should also be able to override the destruction
-    destroyPopup: function() {
-        if (this.popup) {
-            this.popup.feature = null;
-            this.popup.destroy();
-    CLASS_NAME: "OpenLayers.Feature"
-    OpenLayers/Format/WMC.js
- * @requires OpenLayers/Format/XML.js
- * Class: OpenLayers.Format.WMC
- * Read and write Web Map Context documents.
- * Inherits from:
- *  - <OpenLayers.Format.XML>
-OpenLayers.Format.WMC = OpenLayers.Class({
-     * APIProperty: defaultVersion
-     * {String} Version number to assume if none found.  Default is "1.1.0".
-    defaultVersion: "1.1.0",
-     * APIProperty: version
-     * {String} Specify a version string if one is known.
-    version: null,
-     * Property: layerOptions
-     * {Object} Default options for layers created by the parser. These
-     *     options are overridden by the options which are read from the
-     *     capabilities document.
-    layerOptions: null,
-     * Property: parser
-     * {Object} Instance of the versioned parser.  Cached for multiple read and
-     *     write calls of the same version.
-    parser: null,
-     * Constructor: OpenLayers.Format.WMC
-     * Create a new parser for WMC docs.
-     * Parameters:
-     *     this instance.
-        OpenLayers.Util.extend(this, options);
-        this.options = options;
-     * APIMethod: read
-     * Read WMC data from a string, and return an object with map properties
-     *     and a list of layers.
-     * Parameters:
-     * data - {String} or {DOMElement} data to read/parse.
-     * options - {Object} The options object must contain a map property.  If
-     *     the map property is a string, it must be the id of a dom element
-     *     where the new map will be placed.  If the map property is an
-     *     <OpenLayers.Map>, the layers from the context document will be added
-     *     to the map.
-     * Returns:
-     * {<OpenLayers.Map>} A map based on the context.
-    read: function(data, options) {
-        if(typeof data == "string") {
-            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
-        var root = data.documentElement;
-        var version = this.version;
-        if(!version) {
-            version = root.getAttribute("version");
-            if(!version) {
-                version = this.defaultVersion;
-        if(!this.parser || this.parser.VERSION != version) {
-            var format = OpenLayers.Format.WMC[
-                "v" + version.replace(/\./g, "_")
-            if(!format) {
-                throw "Can't find a WMC parser for version " +
-                      version;
-            this.parser = new format(this.options);
-        var context = this.parser.read(data, options);
-        var map;
-        if(options.map) {
-            this.context = context;
-            if(options.map instanceof OpenLayers.Map) {
-                map = this.mergeContextToMap(context, options.map);
-            } else {
-                map = this.contextToMap(context, options.map);
-        } else {
-            // not documented as part of the API, provided as a non-API option
-            map = context;
-        return map;
-     * Method: contextToMap
-     * Create a map given a context object.
-     * Parameters:
-     * context - {Object} The context object.
-     * id - {String | Element} The dom element or element id that will contain
-     *     the map.
-     * Returns:
-     * {<OpenLayers.Map>} A map based on the context object.
-    contextToMap: function(context, id) {
-        var map = new OpenLayers.Map(id, {
-            maxExtent: context.maxExtent,
-            projection: context.projection
-        map.addLayers(context.layers);
-        map.setCenter(
-            context.bounds.getCenterLonLat(),
-            map.getZoomForExtent(context.bounds, true)
-        return map;
-     * Method: mergeContextToMap
-     * Add layers from a context object to a map.
-     * Parameters:
-     * map - {<OpenLayers.Map>} The map.
-     * Returns:
-     * {<OpenLayers.Map>} The same map with layers added.
-    mergeContextToMap: function(context, map) {
-        return map;
-     * Write a WMC document given a map.
-     * Parameters:
-     * obj - {<OpenLayers.Map> | Object} A map or context object.
-     * options - {Object} Optional configuration object.
-     * Returns:
-     * {String} A WMC document string.
-    write: function(obj, options) {
-        if(obj.CLASS_NAME == "OpenLayers.Map") {
-            obj = this.mapToContext(obj);
-        var version = (options && options.version) ||
-                      this.version || this.defaultVersion;
-            if(!format) {
-                throw "Can't find a WMS capabilities parser for version " +
-                      version;
-        var wmc = this.parser.write(obj, options);
-        return wmc;
-     * Method: mapToContext
-     * Create a context object given a map.
-     * Parameters:
-     * Returns:
-     * {Object} A context object.
-    mapToContext: function(map) {
-        var context = {
-            bounds: map.getExtent(),
-            maxExtent: map.maxExtent,
-            projection: map.projection,
-            layers: map.layers,
-            size: map.getSize()
-        return context;
-    CLASS_NAME: "OpenLayers.Format.WMC"
-    OpenLayers/Format/WMC/v1.js
- * Class: OpenLayers.Format.WMC.v1
- * Superclass for WMC version 1 parsers.
- * Inherits from:
-OpenLayers.Format.WMC.v1 = OpenLayers.Class(OpenLayers.Format.XML, {
-     * Property: namespaces
-     * {Object} Mapping of namespace aliases to namespace URIs.
-    namespaces: {
-        ol: "http://openlayers.org/context",
-        wmc: "http://www.opengis.net/context",
-        sld: "http://www.opengis.net/sld",
-        xlink: "http://www.w3.org/1999/xlink",
-        xsi: "http://www.w3.org/2001/XMLSchema-instance"
-     * Property: schemaLocation
-     * {String} Schema location for a particular minor version.
-    schemaLocation: "",
-     * Method: getNamespacePrefix
-     * Get the namespace prefix for a given uri from the <namespaces> object.
-     * Returns:
-     * {String} A namespace prefix or null if none found.
-    getNamespacePrefix: function(uri) {
-        var prefix = null;
-        if(uri == null) {
-            prefix = this.namespaces[this.defaultPrefix];
-        } else {
-            for(prefix in this.namespaces) {
-                if(this.namespaces[prefix] == uri) {
-                    break;
-        return prefix;
-     * Property: defaultPrefix
-    defaultPrefix: "wmc",
-     * Property: rootPrefix
-     * {String} Prefix on the root node that maps to the context namespace URI.
-    rootPrefix: null,
-     * Property: defaultStyleName
-     * {String} Style name used if layer has no style param.  Default is "".
-    defaultStyleName: "",
-     * Property: defaultStyleTitle
-     * {String} Default style title.  Default is "Default".
-    defaultStyleTitle: "Default",
-     * Constructor: OpenLayers.Format.WMC.v1
-     * Instances of this class are not created directly.  Use the
-     *     <OpenLayers.Format.WMC> constructor instead.
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
-     * Method: read
-     * Read capabilities data from a string, and return a list of layers.
-     * Parameters:
-     * Returns:
-     * {Array} List of named layers.
-    read: function(data) {
-        this.rootPrefix = root.prefix;
-        var context = {
-            version: root.getAttribute("version")
-        this.runChildNodes(context, root);
-        return context;
-     * Method: runChildNodes
-    runChildNodes: function(obj, node) {
-        var children = node.childNodes;
-        var childNode, processor, prefix, local;
-        for(var i=0; i<children.length; ++i) {
-            childNode = children[i];
-            if(childNode.nodeType == 1) {
-                prefix = this.getNamespacePrefix(childNode.namespaceURI);
-                local = childNode.nodeName.split(":").pop();
-                processor = this["read_" + prefix + "_" + local];
-                if(processor) {
-                    processor.apply(this, [obj, childNode]);
-     * Method: read_wmc_General
-    read_wmc_General: function(context, node) {
-        this.runChildNodes(context, node);
-     * Method: read_wmc_BoundingBox
-    read_wmc_BoundingBox: function(context, node) {
-        context.projection = node.getAttribute("SRS");
-        context.bounds = new OpenLayers.Bounds(
-            parseFloat(node.getAttribute("minx")),
-            parseFloat(node.getAttribute("miny")),
-            parseFloat(node.getAttribute("maxx")),
-            parseFloat(node.getAttribute("maxy"))
-     * Method: read_wmc_LayerList
-    read_wmc_LayerList: function(context, node) {
-        context.layers = [];
-    read_wmc_Layer: function(context, node) {
-        var layerInfo = {
-            params: {},
-            options: {
-                visibility: (node.getAttribute("hidden") != "1")
-            queryable: (node.getAttribute("queryable") == "1"),
-            formats: [],
-            styles: []
-        this.runChildNodes(layerInfo, node);
-        // set properties common to multiple objects on layer options/params
-        layerInfo.params.layers = layerInfo.name;
-        layerInfo.options.maxExtent = layerInfo.maxExtent;
-        // create the layer
-        var layer = this.getLayerFromInfo(layerInfo);
-        context.layers.push(layer);
-     * Method: getLayerFromInfo
-     * Create a WMS layer from a layerInfo object.
-     * Parameters:
-     * layerInfo - {Object} An object representing a WMS layer.
-     * Returns:
-     * {<OpenLayers.Layer.WMS>} A WMS layer.
-    getLayerFromInfo: function(layerInfo) {
-        var options = layerInfo.options;
-        if (this.layerOptions) {
-            OpenLayers.Util.applyDefaults(options, this.layerOptions);
-        var layer = new OpenLayers.Layer.WMS(
-            layerInfo.title,
-            layerInfo.href,
-            layerInfo.params,
-            options
-        return layer;
-     * Method: read_wmc_Extension
-    read_wmc_Extension: function(obj, node) {
-        this.runChildNodes(obj, node);
-     * Method: read_ol_units
-    read_ol_units: function(layerInfo, node) {
-        layerInfo.options.units = this.getChildValue(node);
-     * Method: read_ol_maxExtent
-    read_ol_maxExtent: function(obj, node) {
-        var bounds = new OpenLayers.Bounds(
-            node.getAttribute("minx"), node.getAttribute("miny"),
-            node.getAttribute("maxx"), node.getAttribute("maxy")
-        obj.maxExtent = bounds;
-     * Method: read_ol_transparent
-    read_ol_transparent: function(layerInfo, node) {
-        layerInfo.params.transparent = this.getChildValue(node);
-     * Method: read_ol_numZoomLevels
-    read_ol_numZoomLevels: function(layerInfo, node) {
-        layerInfo.options.numZoomLevels = parseInt(this.getChildValue(node));
-     * Method: read_ol_opacity
-    read_ol_opacity: function(layerInfo, node) {
-        layerInfo.options.opacity = parseFloat(this.getChildValue(node));
-     * Method: read_ol_singleTile
-    read_ol_singleTile: function(layerInfo, node) {
-        layerInfo.options.singleTile = (this.getChildValue(node) == "true");
-     * Method: read_ol_isBaseLayer
-    read_ol_isBaseLayer: function(layerInfo, node) {
-        layerInfo.options.isBaseLayer = (this.getChildValue(node) == "true");
-     * Method: read_ol_displayInLayerSwitcher
-    read_ol_displayInLayerSwitcher: function(layerInfo, node) {
-        layerInfo.options.displayInLayerSwitcher =
-            (this.getChildValue(node) == "true");
-     * Method: read_wmc_Server
-    read_wmc_Server: function(layerInfo, node) {
-        layerInfo.params.version = node.getAttribute("version");
-     * Method: read_wmc_FormatList
-    read_wmc_FormatList: function(layerInfo, node) {
-    read_wmc_Format: function(layerInfo, node) {
-        var format = this.getChildValue(node);
-        layerInfo.formats.push(format);
-        if(node.getAttribute("current") == "1") {
-            layerInfo.params.format = format;
-     * Method: read_wmc_StyleList
-    read_wmc_StyleList: function(layerInfo, node) {
-    read_wmc_Style: function(layerInfo, node) {
-        var style = {};
-        this.runChildNodes(style, node);
-            // three style types to consider
-            // 1) linked SLD
-            // 2) inline SLD
-            // 3) named style
-            // running child nodes always gets name, optionally gets href or body
-            if(style.href) {
-                layerInfo.params.sld = style.href;
-            } else if(style.body) {
-                layerInfo.params.sld_body = style.body;
-            } else {
-                layerInfo.params.styles = style.name;
-        layerInfo.styles.push(style);
-     * Method: read_wmc_SLD
-    read_wmc_SLD: function(style, node) {
-        // style either comes back with an href or a body property
-     * Method: read_sld_StyledLayerDescriptor
-    read_sld_StyledLayerDescriptor: function(sld, node) {
-        var xml = OpenLayers.Format.XML.prototype.write.apply(this, [node]);
-        sld.body = xml;
-     * Method: read_wmc_OnlineResource
-    read_wmc_OnlineResource: function(obj, node) {
-        obj.href = this.getAttributeNS(
-            node, this.namespaces.xlink, "href"
-     * Method: read_wmc_Name
-    read_wmc_Name: function(obj, node) {
-        var name = this.getChildValue(node);
-        if(name) {
-            obj.name = name;
-     * Method: read_wmc_Title
-    read_wmc_Title: function(obj, node) {
-        var title = this.getChildValue(node);
-        if(title) {
-            obj.title = title;
-     * Method: read_wmc_Abstract
-    read_wmc_Abstract: function(obj, node) {
-        var abst = this.getChildValue(node);
-        if(abst) {
-            obj["abstract"] = abst;
-     * Method: read_wmc_LatLonBoundingBox
-    read_wmc_LatLonBoundingBox: function(layer, node) {
-        layer.llbbox = [
-     * Method: read_wmc_LegendURL
-    read_wmc_LegendURL: function(style, node) {
-        var legend = {
-            width: node.getAttribute('width'),
-            height: node.getAttribute('height')
-        var links = node.getElementsByTagName("OnlineResource");
-        if(links.length > 0) {
-            this.read_wmc_OnlineResource(legend, links[0]);
-        style.legend = legend;
-     * Method: write
-     * Parameters:
-     * context - {Object} An object representing the map context.
-     * options - {Object} Optional object.
-     * Returns:
-    write: function(context, options) {
-        var root = this.createElementDefaultNS("ViewContext");
-        this.setAttributes(root, {
-            version: this.VERSION,
-            id: (options && typeof options.id == "string") ?
-                    options.id :
-                    OpenLayers.Util.createUniqueID("OpenLayers_Context_")
-        // add schemaLocation attribute
-        this.setAttributeNS(
-            root, this.namespaces.xsi,
-            "xsi:schemaLocation", this.schemaLocation
-        // required General element
-        root.appendChild(this.write_wmc_General(context));
-        // required LayerList element
-        root.appendChild(this.write_wmc_LayerList(context));
-        return OpenLayers.Format.XML.prototype.write.apply(this, [root]);
-     * Method: createElementDefaultNS
-     * Shorthand for createElementNS with namespace from <defaultPrefix>.
-     *     Can optionally be used to set attributes and a text child value.
-     * Parameters:
-     * name - {String} The qualified node name.
-     * childValue - {String} Optional value for text child node.
-     * attributes - {Object} Optional object representing attributes.
-     * Returns:
-     * {Element} An element node.
-    createElementDefaultNS: function(name, childValue, attributes) {
-        var node = this.createElementNS(
-            this.namespaces[this.defaultPrefix],
-            name
-        if(childValue) {
-            node.appendChild(this.createTextNode(childValue));
-        if(attributes) {
-            this.setAttributes(node, attributes);
-        return node;
-     * Method: setAttributes
-     * Set multiple attributes given key value pairs from an object.
-     * Parameters:
-     * node - {Element} An element node.
-     * obj - {Object} An object whose properties represent attribute names and
-     *     values represent attribute values.
-    setAttributes: function(node, obj) {
-        var value;
-        for(var name in obj) {
-            value = obj[name].toString();
-            if(value.match(/[A-Z]/)) {
-                // safari lowercases attributes with setAttribute
-                this.setAttributeNS(node, null, name, value);
-            } else {
-     * Method: write_wmc_General
-     * Create a General node given an context object.
-     * Parameters:
-     * context - {Object} Context object.
-     * Returns:
-     * {Element} A WMC General element node.
-    write_wmc_General: function(context) {
-        var node = this.createElementDefaultNS("General");
-        // optional Window element
-        if(context.size) {
-            node.appendChild(this.createElementDefaultNS(
-                "Window", null,
-                    width: context.size.w,
-                    height: context.size.h
-        // required BoundingBox element
-        var bounds = context.bounds;
-            "BoundingBox", null,
-                minx: bounds.left.toPrecision(10),
-                miny: bounds.bottom.toPrecision(10),
-                maxx: bounds.right.toPrecision(10),
-                maxy: bounds.top.toPrecision(10),
-                SRS: context.projection
-        // required Title element
-            "Title", context.title
-        // OpenLayers specific map properties
-        node.appendChild(this.write_ol_MapExtension(context));
-        return node;
-     * Method: write_ol_MapExtension
-    write_ol_MapExtension: function(context) {
-        var node = this.createElementDefaultNS("Extension");
-        var bounds = context.maxExtent;
-        if(bounds) {
-            var maxExtent = this.createElementNS(
-                this.namespaces.ol, "ol:maxExtent"
-            this.setAttributes(maxExtent, {
-            node.appendChild(maxExtent);
-        return node;
-     * Method: write_wmc_LayerList
-     * Create a LayerList node given an context object.
-     * Parameters:
-     * Returns:
-     * {Element} A WMC LayerList element node.
-    write_wmc_LayerList: function(context) {
-        var list = this.createElementDefaultNS("LayerList");
-        var layer;
-        for(var i=0; i<context.layers.length; ++i) {
-            layer = context.layers[i];
-            if(layer instanceof OpenLayers.Layer.WMS) {
-                list.appendChild(this.write_wmc_Layer(layer));
-        return list;
-     * Create a Layer node given a layer object.
-     * Parameters:
-     * layer - {<OpenLayers.Layer.WMS>} Layer object.
-     * Returns:
-     * {Element} A WMC Layer element node.
-    write_wmc_Layer: function(layer) {
-            "Layer", null, {
-                queryable: "1",
-                hidden: layer.visibility ? "0" : "1"
-        // required Server element
-        node.appendChild(this.write_wmc_Server(layer));
-        // required Name element
-            "Name", layer.params["LAYERS"]
-            "Title", layer.name
-        // optional FormatList element
-        node.appendChild(this.write_wmc_FormatList(layer));
-        // optional StyleList element
-        node.appendChild(this.write_wmc_StyleList(layer));
-        // OpenLayers specific properties go in an Extension element
-        node.appendChild(this.write_wmc_LayerExtension(layer));
-        return node;
-     * Method: write_wmc_LayerExtension
-     * Add OpenLayers specific layer parameters to an Extension element.
-     * Parameters:
-     * layer - {<OpenLayers.Layer.WMS>} A WMS layer.
-     * Returns:
-     * {Element} A WMC Extension element (for a layer).
-    write_wmc_LayerExtension: function(layer) {
-        var bounds = layer.maxExtent;
-        var param = layer.params["TRANSPARENT"];
-        if(param) {
-            var trans = this.createElementNS(
-                this.namespaces.ol, "ol:transparent"
-            trans.appendChild(this.createTextNode(param));
-            node.appendChild(trans);
-        var properties = [
-            "numZoomLevels", "units", "isBaseLayer",
-            "opacity", "displayInLayerSwitcher", "singleTile"
-        var child;
-        for(var i=0; i<properties.length; ++i) {
-            child = this.createOLPropertyNode(layer, properties[i]);
-            if(child) {
-                node.appendChild(child);
-        return node;
-     * Method: createOLPropertyNode
-     * Create a node representing an OpenLayers property.  If the property is
-     *     null or undefined, null will be returned.
-     * Parameters:
-     * object - {Object} An object.
-     * prop - {String} A property.
-     * Returns:
-     * {Element} A property node.
-    createOLPropertyNode: function(obj, prop) {
-        var node = null;
-        if(obj[prop] != null) {
-            node = this.createElementNS(this.namespaces.ol, "ol:" + prop);
-            node.appendChild(this.createTextNode(obj[prop].toString()));
-        return node;
-     * Method: write_wmc_Server
-     * Create a Server node given a layer object.
-     * Parameters:
-     * Returns:
-     * {Element} A WMC Server element node.
-    write_wmc_Server: function(layer) {
-        var node = this.createElementDefaultNS("Server");
-        this.setAttributes(node, {
-            service: "OGC:WMS",
-            version: layer.params["VERSION"]
-        // required OnlineResource element
-        node.appendChild(this.write_wmc_OnlineResource(layer.url));
-        return node;
-     * Method: write_wmc_FormatList
-     * Create a FormatList node given a layer.
-     * Parameters:
-     * Returns:
-     * {Element} A WMC FormatList element node.
-    write_wmc_FormatList: function(layer) {
-        var node = this.createElementDefaultNS("FormatList");
-            "Format", layer.params["FORMAT"], {current: "1"}
-        return node;
-     * Method: write_wmc_StyleList
-     * Create a StyleList node given a layer.
-     * Parameters:
-     * Returns:
-     * {Element} A WMC StyleList element node.
-    write_wmc_StyleList: function(layer) {
-        var node = this.createElementDefaultNS("StyleList");
-        var style = this.createElementDefaultNS(
-            "Style", null, {current: "1"}
-        // Style can come from one of three places (prioritized as below):
-        // 1) an SLD parameter
-        // 2) and SLD_BODY parameter
-        // 3) the STYLES parameter
-        if(layer.params["SLD"]) {
-            // create link from SLD parameter
-            var sld = this.createElementDefaultNS("SLD");
-            var link = this.write_wmc_OnlineResource(layer.params["SLD"]);
-            sld.appendChild(link);
-            style.appendChild(sld);
-        } else if(layer.params["SLD_BODY"]) {
-            // include sld fragment from SLD_BODY parameter
-            var body = layer.params["SLD_BODY"];
-            // read in body as xml doc - assume proper namespace declarations
-            var doc = OpenLayers.Format.XML.prototype.read.apply(this, [body]);
-            // append to StyledLayerDescriptor node
-            var imported = doc.documentElement;
-            if(sld.ownerDocument && sld.ownerDocument.importNode) {
-                imported = sld.ownerDocument.importNode(imported, true);
-            sld.appendChild(imported);
-        } else {
-            // use name(s) from STYLES parameter
-            var name = layer.params["STYLES"] ?
-                layer.params["STYLES"] : this.defaultStyleName;
-            style.appendChild(this.createElementDefaultNS("Name", name));
-                "Title", this.defaultStyleTitle
-        node.appendChild(style);
-        return node;
-     * Method: write_wmc_OnlineResource
-     * Create an OnlineResource node given a URL.
-     * Parameters:
-     * href - {String} URL for the resource.
-     * Returns:
-     * {Element} A WMC OnlineResource element node.
-    write_wmc_OnlineResource: function(href) {
-        var node = this.createElementDefaultNS("OnlineResource");
-        this.setAttributeNS(node, this.namespaces.xlink, "xlink:type", "simple");
-        this.setAttributeNS(node, this.namespaces.xlink, "xlink:href", href);
-        return node;
-    CLASS_NAME: "OpenLayers.Format.WMC.v1"
     OpenLayers/Handler/Click.js
@@ -20967,637 +12558,6 @@
     CLASS_NAME: "OpenLayers.Handler.Drag"
-    OpenLayers/Handler/Feature.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Handler.js
- * Class: OpenLayers.Handler.Feature
- * Handler to respond to mouse events related to a drawn feature.  Callbacks
- *     with the following keys will be notified of the following events
- *     associated with features: click, clickout, over, out, and dblclick.
- * This handler stops event propagation for mousedown and mouseup if those
- *     browser events target features that can be selected.
-OpenLayers.Handler.Feature = OpenLayers.Class(OpenLayers.Handler, {
-     * Property: EVENTMAP
-     * {Object} A object mapping the browser events to objects with callback
-     *     keys for in and out.
-    EVENTMAP: {
-        'click': {'in': 'click', 'out': 'clickout'},
-        'mousemove': {'in': 'over', 'out': 'out'},
-        'dblclick': {'in': 'dblclick', 'out': null},
-        'mousedown': {'in': null, 'out': null},
-        'mouseup': {'in': null, 'out': null}
-     * {<OpenLayers.Feature.Vector>} The last feature that was hovered.
-    feature: null,
-     * Property: lastFeature
-     * {<OpenLayers.Feature.Vector>} The last feature that was handled.
-    lastFeature: null,
-     * Property: down
-     * {<OpenLayers.Pixel>} The location of the last mousedown.
-    down: null,
-     * Property: up
-     * {<OpenLayers.Pixel>} The location of the last mouseup.
-    up: null,
-     * Property: clickoutTolerance
-     * {Number} The number of pixels the mouse can move during a click that
-     *     still constitutes a click out.  When dragging the map, clicks should
-     *     not trigger the clickout property unless this tolerance is reached.
-     *     Default is 4.
-    clickoutTolerance: 4,
-     * Property: geometryTypes
-     * To restrict dragging to a limited set of geometry types, send a list
-     * of strings corresponding to the geometry class names.
-     * @type Array(String)
-    geometryTypes: null,
-     * Property: stopClick
-     * {Boolean} If stopClick is set to true, handled clicks do not
-     *      propagate to other click listeners. Otherwise, handled clicks
-     *      do propagate. Unhandled clicks always propagate, whatever the
-     *      value of stopClick. Defaults to true.
-    stopClick: true,
-     * Property: stopDown
-     * {Boolean} If stopDown is set to true, handled mousedowns do not
-     *      propagate to other mousedown listeners. Otherwise, handled
-     *      mousedowns do propagate. Unhandled mousedowns always propagate,
-     *      whatever the value of stopDown. Defaults to true.
-    stopDown: true,
-     * Property: stopUp
-     * {Boolean} If stopUp is set to true, handled mouseups do not
-     *      propagate to other mouseup listeners. Otherwise, handled mouseups
-     *      do propagate. Unhandled mouseups always propagate, whatever the
-     *      value of stopUp. Defaults to true.
-    stopUp: true,
-     * Property: layerIndex
-     * {Int}
-    layerIndex: null,
-     * Constructor: OpenLayers.Handler.Feature
-     * Parameters:
-     * control - {<OpenLayers.Control>}
-     * layers - {Array(<OpenLayers.Layer.Vector>)}
-     * callbacks - {Object} An object with a 'over' property whos value is
-     *     a function to be called when the mouse is over a feature. The
-     *     callback should expect to recieve a single argument, the feature.
-    initialize: function(control, layer, callbacks, options) {
-        OpenLayers.Handler.prototype.initialize.apply(this, [control, callbacks, options]);
-     * Method: mousedown
-     * Handle mouse down.  Stop propagation if a feature is targeted by this
-     *     event (stops map dragging during feature selection).
-     * Parameters:
-     * evt - {Event}
-    mousedown: function(evt) {
-        this.down = evt.xy;
-        return this.handle(evt) ? !this.stopDown : true;
-     * Method: mouseup
-     * Handle mouse up.  Stop propagation if a feature is targeted by this
-     *     event.
-     * Parameters:
-     * evt - {Event}
-    mouseup: function(evt) {
-        this.up = evt.xy;
-        return this.handle(evt) ? !this.stopUp : true;
-     * Method: click
-     * Handle click.  Call the "click" callback if click on a feature,
-     *     or the "clickout" callback if click outside any feature.
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {Boolean}
-    click: function(evt) {
-        return this.handle(evt) ? !this.stopClick : true;
-     * Method: mousemove
-     * Handle mouse moves.  Call the "over" callback if moving in to a feature,
-     *     or the "out" callback if moving out of a feature.
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {Boolean}
-    mousemove: function(evt) {
-        this.handle(evt);
-        return true;
-     * Method: dblclick
-     * Handle dblclick.  Call the "dblclick" callback if dblclick on a feature.
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {Boolean}
-    dblclick: function(evt) {
-        return !this.handle(evt);
-     * Method: geometryTypeMatches
-     * Return true if the geometry type of the passed feature matches
-     *     one of the geometry types in the geometryTypes array.
-     * Parameters:
-     * feature - {<OpenLayers.Vector.Feature>}
-     * Returns:
-     * {Boolean}
-    geometryTypeMatches: function(feature) {
-        return this.geometryTypes == null ||
-            OpenLayers.Util.indexOf(this.geometryTypes,
-                                    feature.geometry.CLASS_NAME) > -1;
-     * Method: handle
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {Boolean} The event occurred over a relevant feature.
-    handle: function(evt) {
-        var type = evt.type;
-        var handled = false;
-        var previouslyIn = !!(this.feature); // previously in a feature
-        var click = (type == "click" || type == "dblclick");
-        this.feature = this.layer.getFeatureFromEvent(evt);
-        if(this.feature) {
-            var inNew = (this.feature != this.lastFeature);
-            if(this.geometryTypeMatches(this.feature)) {
-                // in to a feature
-                if(previouslyIn && inNew) {
-                    // out of last feature and in to another
-                    this.triggerCallback(type, 'out', [this.lastFeature]);
-                    this.triggerCallback(type, 'in', [this.feature]);
-                } else if(!previouslyIn || click) {
-                    // in feature for the first time
-                this.lastFeature = this.feature;
-                handled = true;
-            } else {
-                // not in to a feature
-                if(previouslyIn && inNew || (click && this.lastFeature)) {
-                    // out of last feature for the first time
-                // next time the mouse goes in a feature whose geometry type
-                // doesn't match we don't want to call the 'out' callback
-                // again, so let's set this.feature to null so that
-                // previouslyIn will evaluate to false the next time
-                // we enter handle. Yes, a bit hackish...
-                this.feature = null;
-        } else {
-            if(previouslyIn || (click && this.lastFeature)) {
-        return handled;
-     * Method: triggerCallback
-     * Call the callback keyed in the event map with the supplied arguments.
-     *     For click out, the <clickoutTolerance> is checked first.
-     * Parameters:
-     * type - {String}
-    triggerCallback: function(type, mode, args) {
-        var key = this.EVENTMAP[type][mode];
-        if(key) {
-            if(type == 'click' && mode == 'out' && this.up && this.down) {
-                // for clickout, only trigger callback if tolerance is met
-                var dpx = Math.sqrt(
-                    Math.pow(this.up.x - this.down.x, 2) +
-                    Math.pow(this.up.y - this.down.y, 2)
-                if(dpx <= this.clickoutTolerance) {
-                    this.callback(key, args);
-            } else {
-     * Method: activate
-     * Turn on the handler.  Returns false if the handler was already active.
-     * Returns:
-     * {Boolean}
-    activate: function() {
-        var activated = false;
-        if(OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
-            this.layerIndex = this.layer.div.style.zIndex;
-            this.layer.div.style.zIndex = this.map.Z_INDEX_BASE['Popup'] - 1;
-            activated = true;
-        return activated;
-     * Turn of the handler.  Returns false if the handler was already active.
-     * Returns:
-     * {Boolean}
-    deactivate: function() {
-        var deactivated = false;
-        if(OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
-            if (this.layer && this.layer.div) {
-                this.layer.div.style.zIndex = this.layerIndex;
-            this.lastFeature = null;
-            this.down = null;
-            this.up = null;
-            deactivated = true;
-        return deactivated;
-    CLASS_NAME: "OpenLayers.Handler.Feature"
-    OpenLayers/Handler/Hover.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt
- * for the full text of the license. */
- * Class: OpenLayers.Handler.Hover
- * The hover handler is to be used to emulate mouseovers on objects
- *      on the map that aren't DOM elements. For example one can use
- *      this handler to send WMS/GetFeatureInfo requests as the user
- *      moves the mouve over the map.
- * Inherits from:
- *  - <OpenLayers.Handler>
-OpenLayers.Handler.Hover = OpenLayers.Class(OpenLayers.Handler, {
-     * APIProperty: delay
-     * {Integer} - Number of milliseconds between mousemoves before
-     *      the event is considered a hover. Default is 500.
-    delay: 500,
-     * APIProperty: pixelTolerance
-     * {Integer} - Maximum number of pixels between mousemoves for
-     *      an event to be considered a hover. Default is null.
-    pixelTolerance: null,
-     * APIProperty: stopMove
-     * {Boolean} Stop other listeners from being notified on mousemoves.
-     *      Default is false.
-    stopMove: false,
-     * Property: px
-     * {<OpenLayers.Pixel>} The location of the last mousemove, expressed
-     *      in pixels.
-    px: null,
-     * Property: timerId
-     * {Number} The id of the timer.
-    timerId: null,
-     * Constructor: OpenLayers.Handler.Hover
-     * Construct a hover handler.
-     * Parameters:
-     * control - {<OpenLayers.Control>} The control that initialized this
-     *     handler.  The control is assumed to have a valid map property; that
-     *     map is used in the handler's own setMap method.
-     * callbacks - {Object} An object whose properties correspond to abstracted
-     *     events or sequences of browser events.  The values for these
-     *     properties are functions defined by the control that get called by
-     *     the handler.
-     *     the handler.
-    initialize: function(control, callbacks, options) {
-        OpenLayers.Handler.prototype.initialize.apply(this, arguments);
-     * Called when the mouse moves on the map.
-     * Parameters:
-     * evt - {<OpenLayers.Event>}
-     * Returns:
-     * {Boolean} Continue propagating this event.
-        if(this.passesTolerance(evt.xy)) {
-            this.clearTimer();
-            this.callback('move', [evt]);
-            this.px = evt.xy;
-            // clone the evt so original properties can be accessed even
-            // if the browser deletes them during the delay
-            evt = OpenLayers.Util.extend({}, evt);
-            this.timerId = window.setTimeout(
-                OpenLayers.Function.bind(this.delayedCall, this, evt),
-                this.delay
-        return !this.stopMove;
-     * Method: mouseout
-     * Called when the mouse goes out of the map.
-     * Parameters:
-     * Returns:
-    mouseout: function(evt) {
-        if (OpenLayers.Util.mouseLeft(evt, this.map.div)) {
-        return true;
-     * Method: passesTolerance
-     * Determine whether the mouse move is within the optional pixel tolerance.
-     * Parameters:
-     * px - {<OpenLayers.Pixel>}
-     * Returns:
-     * {Boolean} The mouse move is within the pixel tolerance.
-    passesTolerance: function(px) {
-        var passes = true;
-        if(this.pixelTolerance && this.px) {
-                Math.pow(this.px.x - px.x, 2) +
-                Math.pow(this.px.y - px.y, 2)
-            if(dpx < this.pixelTolerance) {
-                passes = false;
-        return passes;
-     * Method: clearTimer
-     * Clear the timer and set <timerId> to null.
-    clearTimer: function() {
-        if(this.timerId != null) {
-            window.clearTimeout(this.timerId);
-            this.timerId = null;
-     * Method: delayedCall
-     * Triggers pause callback.
-     * Parameters:
-    delayedCall: function(evt) {
-        this.callback('pause', [evt]);
-     * APIMethod: deactivate
-     * Deactivate the handler.
-     * Returns:
-     * {Boolean} The handler was successfully deactivated.
-    CLASS_NAME: "OpenLayers.Handler.Hover"
-    OpenLayers/Handler/Keyboard.js
- * @requires OpenLayers/Events.js
- * Class: OpenLayers.handler.Keyboard
- * A handler for keyboard events.  Create a new instance with the
- *     <OpenLayers.Handler.Keyboard> constructor.
- * Inherits from:
-OpenLayers.Handler.Keyboard = OpenLayers.Class(OpenLayers.Handler, {
-    /* http://www.quirksmode.org/js/keys.html explains key x-browser
-        key handling quirks in pretty nice detail */
-     * Constant: KEY_EVENTS
-     * keydown, keypress, keyup
-    KEY_EVENTS: ["keydown", "keypress", "keyup"],
-    * Property: eventListener
-    * {Function}
-    eventListener: null,
-     * Constructor: OpenLayers.Handler.Keyboard
-     * Returns a new keyboard handler.
-     * Parameters:
-     * control - {<OpenLayers.Control>} The control that is making use of
-     *     this handler.  If a handler is being used without a control, the
-     *     handlers setMap method must be overridden to deal properly with
-     *     the map.
-     * callbacks - {Object} An object containing a single function to be
-     *     called when the drag operation is finished. The callback should
-     *     expect to recieve a single argument, the pixel location of the event.
-     *     Callbacks for 'keydown', 'keypress', and 'keyup' are supported.
-     * options - {Object} Optional object whose properties will be set on the
-     *     handler.
-        // cache the bound event listener method so it can be unobserved later
-        this.eventListener = OpenLayers.Function.bindAsEventListener(
-            this.handleKeyEvent, this
-     * Method: destroy
-    destroy: function() {
-        this.deactivate();
-        this.eventListener = null;
-        OpenLayers.Handler.prototype.destroy.apply(this, arguments);
-        if (OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
-            for (var i = 0; i < this.KEY_EVENTS.length; i++) {
-                OpenLayers.Event.observe(
-                    window, this.KEY_EVENTS[i], this.eventListener);
-            return true;
-        } else {
-            return false;
-     * Method: deactivate
-        if (OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
-                OpenLayers.Event.stopObserving(
-     * Method: handleKeyEvent
-    handleKeyEvent: function (evt) {
-        if (this.checkModifiers(evt)) {
-            this.callback(evt.type, [evt.charCode || evt.keyCode]);
-    CLASS_NAME: "OpenLayers.Handler.Keyboard"
     OpenLayers/Handler/MouseWheel.js
@@ -23057,532 +14017,6 @@
-    OpenLayers/Popup/FramedCloud.js
- * @requires OpenLayers/Popup/Framed.js
- * Class: OpenLayers.Popup.FramedCloud
- * Inherits from:
- *  - <OpenLayers.Popup.Framed>
-OpenLayers.Popup.FramedCloud =
-  OpenLayers.Class(OpenLayers.Popup.Framed, {
-     * APIProperty: autoSize
-     * {Boolean} Framed Cloud is autosizing by default.
-    autoSize: true,
-     * APIProperty: panMapIfOutOfView
-     * {Boolean} Framed Cloud does pan into view by default.
-    panMapIfOutOfView: true,
-     * APIProperty: imageSize
-     * {<OpenLayers.Size>}
-    imageSize: new OpenLayers.Size(676, 736),
-     * APIProperty: isAlphaImage
-     * {Boolean} The FramedCloud does not use an alpha image (in honor of the
-     *     good ie6 folk out there)
-    isAlphaImage: false,
-     * APIProperty: fixedRelativePosition
-     * {Boolean} The Framed Cloud popup works in just one fixed position.
-    fixedRelativePosition: false,
-     * Property: positionBlocks
-     * {Object} Hash of differen position blocks, keyed by relativePosition
-     *     two-character code string (ie "tl", "tr", "bl", "br")
-    positionBlocks: {
-        "tl": {
-            'offset': new OpenLayers.Pixel(44, 0),
-            'padding': new OpenLayers.Bounds(8, 40, 8, 9),
-            'blocks': [
-                { // top-left
-                    size: new OpenLayers.Size('auto', 'auto'),
-                    anchor: new OpenLayers.Bounds(0, 51, 22, 0),
-                    position: new OpenLayers.Pixel(0, 0)
-                { //top-right
-                    size: new OpenLayers.Size(22, 'auto'),
-                    anchor: new OpenLayers.Bounds(null, 50, 0, 0),
-                    position: new OpenLayers.Pixel(-638, 0)
-                { //bottom-left
-                    size: new OpenLayers.Size('auto', 21),
-                    anchor: new OpenLayers.Bounds(0, 32, 80, null),
-                    position: new OpenLayers.Pixel(0, -629)
-                { //bottom-right
-                    size: new OpenLayers.Size(22, 21),
-                    anchor: new OpenLayers.Bounds(null, 32, 0, null),
-                    position: new OpenLayers.Pixel(-638, -629)
-                { // stem
-                    size: new OpenLayers.Size(81, 54),
-                    anchor: new OpenLayers.Bounds(null, 0, 0, null),
-                    position: new OpenLayers.Pixel(0, -668)
-        "tr": {
-            'offset': new OpenLayers.Pixel(-45, 0),
-            'blocks': [
-                { // top-left
-                { //top-right
-                { //bottom-left
-                    anchor: new OpenLayers.Bounds(0, 32, 22, null),
-                { //bottom-right
-                { // stem
-                    anchor: new OpenLayers.Bounds(0, 0, null, null),
-                    position: new OpenLayers.Pixel(-215, -668)
-        "bl": {
-            'offset': new OpenLayers.Pixel(45, 0),
-            'padding': new OpenLayers.Bounds(8, 9, 8, 40),
-            'blocks': [
-                { // top-left
-                    anchor: new OpenLayers.Bounds(0, 21, 22, 32),
-                { //top-right
-                    anchor: new OpenLayers.Bounds(null, 21, 0, 32),
-                { //bottom-left
-                    anchor: new OpenLayers.Bounds(0, 0, 22, null),
-                { //bottom-right
-                { // stem
-                    anchor: new OpenLayers.Bounds(null, null, 0, 0),
-                    position: new OpenLayers.Pixel(-101, -674)
-        "br": {
-            'offset': new OpenLayers.Pixel(-44, 0),
-            'blocks': [
-                { // top-left
-                { //top-right
-                { //bottom-left
-                { //bottom-right
-                { // stem
-                    anchor: new OpenLayers.Bounds(0, null, null, 0),
-                    position: new OpenLayers.Pixel(-311, -674)
-     * APIProperty: minSize
-    minSize: new OpenLayers.Size(105, 10),
-     * APIProperty: maxSize
-    maxSize: new OpenLayers.Size(600, 660),
-     * Constructor: OpenLayers.Popup.FramedCloud
-     * Parameters:
-     * id - {String}
-     * contentHTML - {String}
-     * anchor - {Object} Object to which we'll anchor the popup. Must expose
-     *     a 'size' (<OpenLayers.Size>) and 'offset' (<OpenLayers.Pixel>)
-     *     (Note that this is generally an <OpenLayers.Icon>).
-     * closeBoxCallback - {Function} Function to be called on closeBox click.
-    initialize:function(id, lonlat, size, contentHTML, anchor, closeBox,
-                        closeBoxCallback) {
-        this.imageSrc = OpenLayers.Util.getImagesLocation() + 'cloud-popup-relative.png';
-        OpenLayers.Popup.Framed.prototype.initialize.apply(this, arguments);
-        this.contentDiv.className = "olFramedCloudPopupContent";
-        OpenLayers.Popup.Framed.prototype.destroy.apply(this, arguments);
-    CLASS_NAME: "OpenLayers.Popup.FramedCloud"
-    OpenLayers/Control/DragFeature.js
- * @requires OpenLayers/Control.js
- * @requires OpenLayers/Handler/Drag.js
- * @requires OpenLayers/Handler/Feature.js
- * Class: OpenLayers.Control.DragFeature
- * Move a feature with a drag.  Create a new control with the
- *     <OpenLayers.Control.DragFeature> constructor.
- * Inherits From:
- *  - <OpenLayers.Control>
-OpenLayers.Control.DragFeature = OpenLayers.Class(OpenLayers.Control, {
-     * APIProperty: geometryTypes
-     * {Array(String)} To restrict dragging to a limited set of geometry types,
-     *     send a list of strings corresponding to the geometry class names.
-     * APIProperty: onStart
-     * {Function} Define this function if you want to know when a drag starts.
-     *     The function should expect to receive two arguments: the feature
-     *     that is about to be dragged and the pixel location of the mouse.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The feature that is about to be
-     *     dragged.
-     * pixel - {<OpenLayers.Pixel>} The pixel location of the mouse.
-    onStart: function(feature, pixel) {},
-     * APIProperty: onDrag
-     * {Function} Define this function if you want to know about each move of a
-     *     feature. The function should expect to receive two arguments: the
-     *     feature that is being dragged and the pixel location of the mouse.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The feature that was dragged.
-    onDrag: function(feature, pixel) {},
-     * APIProperty: onComplete
-     * {Function} Define this function if you want to know when a feature is
-     *     done dragging. The function should expect to receive two arguments:
-     *     the feature that is being dragged and the pixel location of the
-     *     mouse.
-     * Parameters:
-    onComplete: function(feature, pixel) {},
-     * Property: layer
-     * {<OpenLayers.Layer.Vector>}
-    layer: null,
-    feature: null,
-     * Property: dragCallbacks
-     * {Object} The functions that are sent to the drag handler for callback.
-    dragCallbacks: {},
-     * Property: featureCallbacks
-     * {Object} The functions that are sent to the feature handler for callback.
-    featureCallbacks: {},
-     * Property: lastPixel
-    lastPixel: null,
-     * Constructor: OpenLayers.Control.DragFeature
-     * Create a new control to drag features.
-     * Parameters:
-     * layer - {<OpenLayers.Layer.Vector>} The layer containing features to be
-     *     dragged.
-     *     control.
-    initialize: function(layer, options) {
-        OpenLayers.Control.prototype.initialize.apply(this, [options]);
-        this.handlers = {
-            drag: new OpenLayers.Handler.Drag(
-                this, OpenLayers.Util.extend({
-                    down: this.downFeature,
-                    move: this.moveFeature,
-                    up: this.upFeature,
-                    out: this.cancel,
-                    done: this.doneDragging
-                }, this.dragCallbacks)
-            feature: new OpenLayers.Handler.Feature(
-                this, this.layer, OpenLayers.Util.extend({
-                    over: this.overFeature,
-                    out: this.outFeature
-                }, this.featureCallbacks),
-                {geometryTypes: this.geometryTypes}
-     * Take care of things that are not handled in superclass
-        OpenLayers.Control.prototype.destroy.apply(this, []);
-     * APIMethod: activate
-     * Activate the control and the feature handler.
-     * Returns:
-     * {Boolean} Successfully activated the control and feature handler.
-        return (this.handlers.feature.activate() &&
-                OpenLayers.Control.prototype.activate.apply(this, arguments));
-     * Deactivate the control and all handlers.
-     * Returns:
-     * {Boolean} Successfully deactivated the control.
-        // the return from the handlers is unimportant in this case
-        this.handlers.drag.deactivate();
-        this.handlers.feature.deactivate();
-        this.dragging = false;
-        this.lastPixel = null;
-        return OpenLayers.Control.prototype.deactivate.apply(this, arguments);
-     * Method: overFeature
-     * Called when the feature handler detects a mouse-over on a feature.
-     *     This activates the drag handler.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The selected feature.
-    overFeature: function(feature) {
-        if(!this.handlers.drag.dragging) {
-            this.feature = feature;
-            this.handlers.drag.activate();
-            this.over = true;
-            // TBD replace with CSS classes
-            this.map.div.style.cursor = "move";
-        } else {
-            if(this.feature.id == feature.id) {
-                this.over = true;
-            } else {
-                this.over = false;
-     * Method: downFeature
-     * Called when the drag handler detects a mouse-down.
-     * Parameters:
-     * pixel - {<OpenLayers.Pixel>} Location of the mouse event.
-    downFeature: function(pixel) {
-        this.lastPixel = pixel;
-        this.onStart(this.feature, pixel);
-     * Method: moveFeature
-     * Called when the drag handler detects a mouse-move.  Also calls the
-     *     optional onDrag method.
-     * Parameters:
-    moveFeature: function(pixel) {
-        var res = this.map.getResolution();
-        this.feature.geometry.move(res * (pixel.x - this.lastPixel.x),
-                                   res * (this.lastPixel.y - pixel.y));
-        this.layer.drawFeature(this.feature);
-        this.onDrag(this.feature, pixel);
-     * Method: upFeature
-     * Called when the drag handler detects a mouse-up.  Also calls the
-     *     optional onComplete method.
-     * Parameters:
-    upFeature: function(pixel) {
-        if(!this.over) {
-            this.map.div.style.cursor = "default";
-     * Method: doneDragging
-     * Called when the drag handler is done dragging.
-     * Parameters:
-     * pixel - {<OpenLayers.Pixel>} The last event pixel location.  If this event
-     *     came from a mouseout, this may not be in the map viewport.
-    doneDragging: function(pixel) {
-        this.onComplete(this.feature, pixel);
-     * Method: outFeature
-     * Called when the feature handler detects a mouse-out on a feature.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The feature that the mouse left.
-    outFeature: function(feature) {
-        } else {
-     * Method: cancel
-     * Called when the drag handler detects a mouse-out (from the map viewport).
-    cancel: function() {
-     * Method: setMap
-     * Set the map property for the control and all handlers.
-     * Parameters:
-     * map - {<OpenLayers.Map>} The control's map.
-    setMap: function(map) {
-        this.handlers.drag.setMap(map);
-        this.handlers.feature.setMap(map);
-        OpenLayers.Control.prototype.setMap.apply(this, arguments);
-    CLASS_NAME: "OpenLayers.Control.DragFeature"
     OpenLayers/Control/DragPan.js
@@ -23659,733 +14093,6 @@
     CLASS_NAME: "OpenLayers.Control.DragPan"
-    OpenLayers/Control/KeyboardDefaults.js
- * @requires OpenLayers/Handler/Keyboard.js
- * Class: OpenLayers.Control.KeyboardDefaults
- * Inherits from:
-OpenLayers.Control.KeyboardDefaults = OpenLayers.Class(OpenLayers.Control, {
-     * APIProperty: slideFactor
-     * Pixels to slide by.
-    slideFactor: 75,
-     * Constructor: OpenLayers.Control.KeyboardDefaults
-    initialize: function() {
-        OpenLayers.Control.prototype.initialize.apply(this, arguments);
-        if (this.handler) {
-            this.handler.destroy();
-        this.handler = null;
-        OpenLayers.Control.prototype.destroy.apply(this, arguments);
-     * Method: draw
-     * Create handler.
-    draw: function() {
-        this.handler = new OpenLayers.Handler.Keyboard( this, {
-                                "keypress": this.defaultKeyPress });
-        this.activate();
-     * Method: defaultKeyPress
-     * Parameters:
-     * code - {Integer}
-    defaultKeyPress: function (code) {
-        switch(code) {
-            case OpenLayers.Event.KEY_LEFT:
-                this.map.pan(-this.slideFactor, 0);
-                break;
-            case OpenLayers.Event.KEY_RIGHT:
-                this.map.pan(this.slideFactor, 0);
-                break;
-            case OpenLayers.Event.KEY_UP:
-                this.map.pan(0, -this.slideFactor);
-                break;
-            case OpenLayers.Event.KEY_DOWN:
-                this.map.pan(0, this.slideFactor);
-                break;
-            case 33: // Page Up
-                var size = this.map.getSize();
-                this.map.pan(0, -0.75*size.h);
-                break;
-            case 34: // Page Down
-                this.map.pan(0, 0.75*size.h);
-                break;
-            case 35: // End
-                this.map.pan(0.75*size.w, 0);
-                break;
-            case 36: // Pos1
-                this.map.pan(-0.75*size.w, 0);
-                break;
-            case 43: // +
-                this.map.zoomIn();
-                break;
-            case 45: // -
-                this.map.zoomOut();
-                break;
-            case 107: // + (IE only)
-                break;
-            case 109: // - (IE only)
-                break;
-    CLASS_NAME: "OpenLayers.Control.KeyboardDefaults"
-    OpenLayers/Feature/Vector.js
-// TRASH THIS
-OpenLayers.State = {
-    /** states */
-    UNKNOWN: 'Unknown',
-    INSERT: 'Insert',
-    UPDATE: 'Update',
-    DELETE: 'Delete'
- * @requires OpenLayers/Feature.js
- * Class: OpenLayers.Feature.Vector
- * Vector features use the OpenLayers.Geometry classes as geometry description.
- * They have an 'attributes' property, which is the data object, and a 'style'
- * property, the default values of which are defined in the
- * <OpenLayers.Feature.Vector.style> objects.
- * Inherits from:
- *  - <OpenLayers.Feature>
-OpenLayers.Feature.Vector = OpenLayers.Class(OpenLayers.Feature, {
-     * Property: fid
-     * {String}
-    fid: null,
-     * {<OpenLayers.Geometry>}
-    geometry: null,
-     * APIProperty: attributes
-     * {Object} This object holds arbitrary properties that describe the
-     *     feature.
-    attributes: null,
-     * Property: state
-     * {String}
-    state: null,
-     * APIProperty: style
-     * {Object}
-    style: null,
-     * Property: renderIntent
-     * {String} rendering intent currently being used
-    renderIntent: "default",
-     * Constructor: OpenLayers.Feature.Vector
-     * Create a vector feature.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>} The geometry that this feature
-     *     represents.
-     * attributes - {Object} An optional object that will be mapped to the
-     *     <attributes> property.
-     * style - {Object} An optional style object.
-    initialize: function(geometry, attributes, style) {
-        OpenLayers.Feature.prototype.initialize.apply(this,
-                                                      [null, null, attributes]);
-        this.geometry = geometry;
-        this.state = null;
-        this.attributes = {};
-        if (attributes) {
-            this.attributes = OpenLayers.Util.extend(this.attributes,
-                                                     attributes);
-        this.style = style ? style : null;
-     * Method: destroy
-        if (this.layer) {
-            this.layer.removeFeatures(this);
-        this.geometry = null;
-        OpenLayers.Feature.prototype.destroy.apply(this, arguments);
-     * Method: clone
-     * Create a clone of this vector feature.  Does not set any non-standard
-     *     properties.
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} An exact clone of this vector feature.
-    clone: function () {
-        return new OpenLayers.Feature.Vector(this.geometry.clone(),
-                                             this.attributes,
-                                             this.style);
-     * Determine whether the feature is within the map viewport.  This method
-     *     tests for an intersection between the geometry and the viewport
-     *     bounds.  If a more effecient but less precise geometry bounds
-     *     intersection is desired, call the method with the boundsOnly
-     *     parameter true.
-     * Parameters:
-     * boundsOnly - {Boolean} Only test whether a feature's bounds intersects
-     *     the viewport bounds.  Default is false.  If false, the feature's
-     *     geometry must intersect the viewport for onScreen to return true.
-     * Returns:
-     * {Boolean} The feature is currently visible on screen (optionally
-     *     based on its bounds if boundsOnly is true).
-    onScreen:function(boundsOnly) {
-        if(this.layer && this.layer.map) {
-            if(boundsOnly) {
-                var featureBounds = this.geometry.getBounds();
-                onScreen = screenBounds.intersectsBounds(featureBounds);
-            } else {
-                var screenPoly = screenBounds.toGeometry();
-                onScreen = screenPoly.intersects(this.geometry);
-        return onScreen;
-     * HACK - we need to decide if all vector features should be able to
-     *     create markers
-     * Returns:
-     * {<OpenLayers.Marker>} For now just returns null
-        return null;
-     *     delete markers
-        // pass
-     *     create popups
-     * Returns:
-     * {<OpenLayers.Popup>} For now just returns null
-    createPopup: function() {
-        return null;
-     * Method: atPoint
-     * Determins whether the feature intersects with the specified location.
-     * Parameters:
-     * toleranceLon - {float} Optional tolerance in Geometric Coords
-     * toleranceLat - {float} Optional tolerance in Geographic Coords
-     * Returns:
-     * {Boolean} Whether or not the feature is at the specified location
-    atPoint: function(lonlat, toleranceLon, toleranceLat) {
-        var atPoint = false;
-        if(this.geometry) {
-            atPoint = this.geometry.atPoint(lonlat, toleranceLon,
-                                                    toleranceLat);
-        return atPoint;
-     * delete popups
-        // pass
-     * Method: toState
-     * Sets the new state
-     * Parameters:
-     * state - {String}
-    toState: function(state) {
-        if (state == OpenLayers.State.UPDATE) {
-            switch (this.state) {
-                case OpenLayers.State.UNKNOWN:
-                case OpenLayers.State.DELETE:
-                    this.state = state;
-                    break;
-                case OpenLayers.State.UPDATE:
-                case OpenLayers.State.INSERT:
-                    break;
-        } else if (state == OpenLayers.State.INSERT) {
-                    break;
-                default:
-                    break;
-        } else if (state == OpenLayers.State.DELETE) {
-                    // the feature should be destroyed
-                    break;
-                    break;
-                    break;
-        } else if (state == OpenLayers.State.UNKNOWN) {
-    CLASS_NAME: "OpenLayers.Feature.Vector"
- * Constant: OpenLayers.Feature.Vector.style
- * OpenLayers features can have a number of style attributes. The 'default'
- *     style will typically be used if no other style is specified.
- * Default style properties:
- *  - fillColor: "#ee9900",
- *  - fillOpacity: 0.4,
- *  - hoverFillColor: "white",
- *  - hoverFillOpacity: 0.8,
- *  - strokeColor: "#ee9900",
- *  - strokeOpacity: 1,
- *  - strokeWidth: 1,
- *  - strokeLinecap: "round",
- *  - hoverStrokeColor: "red",
- *  - hoverStrokeOpacity: 1,
- *  - hoverStrokeWidth: 0.2,
- *  - pointRadius: 6,
- *  - hoverPointRadius: 1,
- *  - hoverPointUnit: "%",
- *  - pointerEvents: "visiblePainted"
- *  - cursor: ""
- * Other style properties that have no default values:
- *  - externalGraphic,
- *  - graphicWidth,
- *  - graphicHeight,
- *  - graphicOpacity
- *  - graphicXOffset
- *  - graphicYOffset
- *  - display
-OpenLayers.Feature.Vector.style = {
-    'default': {
-        fillOpacity: 0.4,
-        strokeOpacity: 1,
-        strokeWidth: 1,
-        pointRadius: 6,
-        pointerEvents: "visiblePainted",
-        cursor: ""
-    'select': {
-        fillColor: "blue",
-        fillOpacity: 0.4,
-        strokeColor: "blue",
-        strokeOpacity: 1,
-        strokeWidth: 2,
-        pointRadius: 6,
-        cursor: "pointer"
-    'temporary': {
-        fillColor: "yellow",
-        fillOpacity: 0.2,
-        strokeColor: "yellow",
-        strokeOpacity: 1,
-        strokeWidth: 4,
-        pointRadius: 6,
-        cursor: ""
-    OpenLayers/Feature/WFS.js
- * Class: OpenLayers.Feature.WFS
- * WFS handling class, for use as a featureClass on the WFS layer for handling
- * 'point' WFS types. Good for subclassing when creating a custom WFS like
- * XML application.
- * Inherits from:
-OpenLayers.Feature.WFS = OpenLayers.Class(OpenLayers.Feature, {
-     * Constructor: OpenLayers.Feature.WFS
-     * Create a WFS feature.
-     * Parameters:
-     * layer - {<OpenLayers.Layer>}
-     * xmlNode - {XMLNode}
-    initialize: function(layer, xmlNode) {
-        var newArguments = arguments;
-        var data = this.processXMLNode(xmlNode);
-        newArguments = new Array(layer, data.lonlat, data);
-        OpenLayers.Feature.prototype.initialize.apply(this, newArguments);
-        this.createMarker();
-        this.layer.addMarker(this.marker);
-     * Method: destroy
-     * nullify references to prevent circular references and memory leaks
-            this.layer.removeMarker(this.marker);
-     * Method: processXMLNode
-     * When passed an xmlNode, parses it for a GML point, and passes
-     * back an object describing that point.
-     * For subclasses of Feature.WFS, this is the feature to change.
-     * Parameters:
-     * Returns:
-     * {Object} Data Object with 'id', 'lonlat', and private properties set
-    processXMLNode: function(xmlNode) {
-        //this should be overridden by subclasses
-        // must return an Object with 'id' and 'lonlat' values set
-        var point = OpenLayers.Ajax.getElementsByTagNameNS(xmlNode, "http://www.opengis.net/gml", "gml", "Point");
-        var text  = OpenLayers.Util.getXmlNodeValue(OpenLayers.Ajax.getElementsByTagNameNS(point[0], "http://www.opengis.net/gml","gml", "coordinates")[0]);
-        var floats = text.split(",");
-        return {lonlat: new OpenLayers.LonLat(parseFloat(floats[0]),
-                                              parseFloat(floats[1])),
-                id: null};
-    CLASS_NAME: "OpenLayers.Feature.WFS"
-    OpenLayers/Format/WMC/v1_0_0.js
- * @requires OpenLayers/Format/WMC/v1.js
- * Class: OpenLayers.Format.WMC.v1_0_0
- * Read and write WMC version 1.0.0.
- * Inherits from:
- *  - <OpenLayers.Format.WMC.v1>
-OpenLayers.Format.WMC.v1_0_0 = OpenLayers.Class(
-    OpenLayers.Format.WMC.v1, {
-     * Constant: VERSION
-     * {String} 1.0.0
-    VERSION: "1.0.0",
-     * {String} http://www.opengis.net/context
-     *     http://schemas.opengis.net/context/1.0.0/context.xsd
-    schemaLocation: "http://www.opengis.net/context http://schemas.opengis.net/context/1.0.0/context.xsd",
-     * Constructor: OpenLayers.Format.WMC.v1_0_0
-     * Parameters:
-     *     this instance.
-        OpenLayers.Format.WMC.v1.prototype.initialize.apply(
-            this, [options]
-    CLASS_NAME: "OpenLayers.Format.WMC.v1_0_0"
-    OpenLayers/Format/WMC/v1_1_0.js
- * Class: OpenLayers.Format.WMC.v1_1_0
- * Read and write WMC version 1.1.0.
- * Differences between 1.1.0 and 1.0.0:
- *     - 1.1.0 Layers have optional sld:MinScaleDenominator and
- *       sld:MaxScaleDenominator
- * Inherits from:
-OpenLayers.Format.WMC.v1_1_0 = OpenLayers.Class(
-     * {String} 1.1.0
-    VERSION: "1.1.0",
-     *     http://schemas.opengis.net/context/1.1.0/context.xsd
-    schemaLocation: "http://www.opengis.net/context http://schemas.opengis.net/context/1.1.0/context.xsd",
-     * Constructor: OpenLayers.Format.WMC.v1_1_0
-     * Parameters:
-     *     this instance.
-            this, [options]
-     * Method: read_sld_MinScaleDenominator
-     * Read a sld:MinScaleDenominator node.
-     * Parameters:
-     * layerInfo - {Object} An object representing a layer.
-    read_sld_MinScaleDenominator: function(layerInfo, node) {
-        layerInfo.options.maxScale = this.getChildValue(node);
-     * Method: read_sld_MaxScaleDenominator
-     * Read a sld:MaxScaleDenominator node.
-     * Parameters:
-    read_sld_MaxScaleDenominator: function(layerInfo, node) {
-        layerInfo.options.minScale = this.getChildValue(node);
-     * Create a Layer node given a layer object.  This method adds elements
-     *     specific to version 1.1.0.
-     * Parameters:
-     * Returns:
-        var node = OpenLayers.Format.WMC.v1.prototype.write_wmc_Layer.apply(
-            this, [layer]
-        // min/max scale denominator elements go before the 4th element in v1
-        if(layer.options.resolutions || layer.options.scales ||
-           layer.options.minResolution || layer.options.maxScale) {
-            var minSD = this.createElementNS(
-                this.namespaces.sld, "sld:MinScaleDenominator"
-            minSD.appendChild(this.createTextNode(layer.maxScale.toPrecision(10)));
-            node.insertBefore(minSD, node.childNodes[3]);
-           layer.options.maxResolution || layer.options.minScale) {
-            var maxSD = this.createElementNS(
-                this.namespaces.sld, "sld:MaxScaleDenominator"
-            maxSD.appendChild(this.createTextNode(layer.minScale.toPrecision(10)));
-            node.insertBefore(maxSD, node.childNodes[4]);
-        return node;
-    CLASS_NAME: "OpenLayers.Format.WMC.v1_1_0"
     OpenLayers/Handler/Box.js
@@ -24475,16 +14182,14 @@
     * Method: moveBox
     moveBox: function (xy) {
-        var deltaX = Math.abs(this.dragHandler.start.x - xy.x);
-        var deltaY = Math.abs(this.dragHandler.start.y - xy.y);
+        var startX = this.dragHandler.start.x;
+        var startY = this.dragHandler.start.y;
+        var deltaX = Math.abs(startX - xy.x);
+        var deltaY = Math.abs(startY - xy.y);
         this.zoomBox.style.width = Math.max(1, deltaX) + "px";
         this.zoomBox.style.height = Math.max(1, deltaY) + "px";
-        if (xy.x < this.dragHandler.start.x) {
-            this.zoomBox.style.left = xy.x+"px";
-        if (xy.y < this.dragHandler.start.y) {
-            this.zoomBox.style.top = xy.y+"px";
+        this.zoomBox.style.left = xy.x < startX ? xy.x+"px" : startX+"px";
+        this.zoomBox.style.top = xy.y < startY ? xy.y+"px" : startY+"px";
@@ -24547,1080 +14252,6 @@
     CLASS_NAME: "OpenLayers.Handler.Box"
-    OpenLayers/Handler/RegularPolygon.js
- * Class: OpenLayers.Handler.RegularPolygon
- * Handler to draw a regular polygon on the map.  Polygon is displayed on mouse
- *     down, moves or is modified on mouse move, and is finished on mouse up.
- *     The handler triggers callbacks for 'done' and 'cancel'.  Create a new
- *     instance with the <OpenLayers.Handler.RegularPolygon> constructor.
- * Inherits from:
-OpenLayers.Handler.RegularPolygon = OpenLayers.Class(OpenLayers.Handler.Drag, {
-     * APIProperty: sides
-     * {Integer} Number of sides for the regular polygon.  Needs to be greater
-     *     than 2.  Defaults to 4.
-    sides: 4,
-     * APIProperty: radius
-     * {Float} Optional radius in map units of the regular polygon.  If this is
-     *     set to some non-zero value, a polygon with a fixed radius will be
-     *     drawn and dragged with mose movements.  If this property is not
-     *     set, dragging changes the radius of the polygon.  Set to null by
-     *     default.
-    radius: null,
-     * APIProperty: snapAngle
-     * {Float} If set to a non-zero value, the handler will snap the polygon
-     *     rotation to multiples of the snapAngle.  Value is an angle measured
-     *     in degrees counterclockwise from the positive x-axis.
-    snapAngle: null,
-     * APIProperty: snapToggle
-     * {String} If set, snapToggle is checked on mouse events and will set
-     *     the snap mode to the opposite of what it currently is.  To disallow
-     *     toggling between snap and non-snap mode, set freehandToggle to
-     *     null.  Acceptable toggle values are 'shiftKey', 'ctrlKey', and
-     *     'altKey'. Snap mode is only possible if this.snapAngle is set to a
-     *     non-zero value.
-    snapToggle: 'shiftKey',
-     * APIProperty: persist
-     * {Boolean} Leave the feature rendered until clear is called.  Default
-     *     is false.  If set to true, the feature remains rendered until
-     *     clear is called, typically by deactivating the handler or starting
-     *     another drawing.
-    persist: false,
-     * APIProperty: irregular
-     * {Boolean} Draw an irregular polygon instead of a regular polygon.
-     *     Default is false.  If true, the initial mouse down will represent
-     *     one corner of the polygon bounds and with each mouse movement, the
-     *     polygon will be stretched so the opposite corner of its bounds
-     *     follows the mouse position.  This property takes precedence over
-     *     the radius property.  If set to true, the radius property will
-     *     be ignored.
-    irregular: false,
-     * Property: angle
-     * {Float} The angle from the origin (mouse down) to the current mouse
-     *     position, in radians.  This is measured counterclockwise from the
-     *     positive x-axis.
-    angle: null,
-     * Property: fixedRadius
-     * {Boolean} The polygon has a fixed radius.  True if a radius is set before
-     *     drawing begins.  False otherwise.
-    fixedRadius: false,
-     * {<OpenLayers.Feature.Vector>} The currently drawn polygon feature
-    feature: null,
-     * Property: layer
-     * {<OpenLayers.Layer.Vector>} The temporary drawing layer
-    layer: null,
-     * Property: origin
-     * {<OpenLayers.Geometry.Point>} Location of the first mouse down
-    origin: null,
-     * Constructor: OpenLayers.Handler.RegularPolygon
-     * Create a new regular polygon handler.
-     * Parameters:
-     * control - {<OpenLayers.Control>} The control that owns this handler
-     * callbacks - {Array} An object with a 'done' property whos value is a
-     *     function to be called when the polygon drawing is finished.
-     *     The callback should expect to recieve a single argument,
-     *     the polygon geometry.  If the callbacks object contains a
-     *     'cancel' property, this function will be called when the
-     *     handler is deactivated while drawing.  The cancel should
-     *     expect to receive a geometry.
-     * options - {Object} An object with properties to be set on the handler.
-     *     If the options.sides property is not specified, the number of sides
-     *     will default to 4.
-        this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
-                                                [control, callbacks, options]);
-        this.options = (options) ? options : new Object();
-     * APIMethod: setOptions
-     * Parameters:
-     * newOptions - {Object}
-    setOptions: function (newOptions) {
-        OpenLayers.Util.extend(this.options, newOptions);
-        OpenLayers.Util.extend(this, newOptions);
-     * Return:
-     * {Boolean} The handler was successfully activated
-            // create temporary vector layer for rendering geometry sketch
-            var options = {displayInLayerSwitcher: false};
-            this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
-            this.map.addLayer(this.layer);
-            activated = true;
-        return activated;
-     * Turn off the handler.
-     * Return:
-        if(OpenLayers.Handler.Drag.prototype.deactivate.apply(this, arguments)) {
-            // call the cancel callback if mid-drawing
-            if(this.dragging) {
-                this.cancel();
-            // If a layer's map property is set to null, it means that that
-            // layer isn't added to the map. Since we ourself added the layer
-            // to the map in activate(), we can assume that if this.layer.map
-            // is null it means that the layer has been destroyed (as a result
-            // of map.destroy() for example.
-            if (this.layer.map != null) {
-                this.layer.destroy(false);
-                if (this.feature) {
-                    this.feature.destroy();
-            this.layer = null;
-     * Start drawing a new feature
-     * Parameters:
-     * evt - {Event} The drag start event
-    down: function(evt) {
-        this.fixedRadius = !!(this.radius);
-        var maploc = this.map.getLonLatFromPixel(evt.xy);
-        this.origin = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
-        // create the new polygon
-        if(!this.fixedRadius || this.irregular) {
-            // smallest radius should not be less one pixel in map units
-            // VML doesn't behave well with smaller
-            this.radius = this.map.getResolution();
-        if(this.persist) {
-            this.clear();
-        this.feature = new OpenLayers.Feature.Vector();
-        this.createGeometry();
-        this.layer.addFeatures([this.feature], {silent: true});
-        this.layer.drawFeature(this.feature, this.style);
-     * Method: move
-     * Respond to drag move events
-     * Parameters:
-     * evt - {Evt} The move event
-    move: function(evt) {
-        var point = new OpenLayers.Geometry.Point(maploc.lon, maploc.lat);
-        if(this.irregular) {
-            var ry = Math.sqrt(2) * Math.abs(point.y - this.origin.y) / 2;
-            this.radius = Math.max(this.map.getResolution() / 2, ry);
-        } else if(this.fixedRadius) {
-            this.origin = point;
-        } else {
-            this.calculateAngle(point, evt);
-                                   point.distanceTo(this.origin));
-        this.modifyGeometry();
-            var dx = point.x - this.origin.x;
-            var dy = point.y - this.origin.y;
-            var ratio;
-            if(dy == 0) {
-                ratio = dx / (this.radius * Math.sqrt(2));
-            } else {
-                ratio = dx / dy;
-            this.feature.geometry.resize(1, this.origin, ratio);
-            this.feature.geometry.move(dx / 2, dy / 2);
-     * Method: up
-     * Finish drawing the feature
-     * Parameters:
-     * evt - {Event} The mouse up event
-    up: function(evt) {
-        this.finalize();
-     * Method: out
-     * Finish drawing the feature.
-     * Parameters:
-     * evt - {Event} The mouse out event
-    out: function(evt) {
-        this.finalize();
-     * Method: createGeometry
-     * Create the new polygon geometry.  This is called at the start of the
-     *     drag and at any point during the drag if the number of sides
-     *     changes.
-    createGeometry: function() {
-        this.angle = Math.PI * ((1/this.sides) - (1/2));
-        if(this.snapAngle) {
-            this.angle += this.snapAngle * (Math.PI / 180);
-        this.feature.geometry = OpenLayers.Geometry.Polygon.createRegularPolygon(
-            this.origin, this.radius, this.sides, this.snapAngle
-     * Method: modifyGeometry
-     * Modify the polygon geometry in place.
-    modifyGeometry: function() {
-        var angle, dx, dy, point;
-        var ring = this.feature.geometry.components[0];
-        // if the number of sides ever changes, create a new geometry
-        if(ring.components.length != (this.sides + 1)) {
-             ring = this.feature.geometry.components[0];
-        for(var i=0; i<this.sides; ++i) {
-            point = ring.components[i];
-            angle = this.angle + (i * 2 * Math.PI / this.sides);
-            point.x = this.origin.x + (this.radius * Math.cos(angle));
-            point.y = this.origin.y + (this.radius * Math.sin(angle));
-            point.clearBounds();
-     * Method: calculateAngle
-     * Calculate the angle based on settings.
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>}
-     * evt - {Event}
-    calculateAngle: function(point, evt) {
-        var alpha = Math.atan2(point.y - this.origin.y,
-                               point.x - this.origin.x);
-        if(this.snapAngle && (this.snapToggle && !evt[this.snapToggle])) {
-            var snapAngleRad = (Math.PI / 180) * this.snapAngle;
-            this.angle = Math.round(alpha / snapAngleRad) * snapAngleRad;
-        } else {
-            this.angle = alpha;
-     * APIMethod: cancel
-     * Finish the geometry and call the "cancel" callback.
-        // the polygon geometry gets cloned in the callback method
-        this.callback("cancel", null);
-        this.finalize();
-     * Method: finalize
-     * Finish the geometry and call the "done" callback.
-    finalize: function() {
-        this.origin = null;
-        this.radius = this.options.radius;
-     * APIMethod: clear
-     * Clear any rendered features on the temporary layer.  This is called
-     *     when the handler is deactivated, canceled, or done (unless persist
-     *     is true).
-    clear: function() {
-        this.layer.renderer.clear();
-        this.layer.destroyFeatures();
-     * Method: callback
-     * Trigger the control's named callback with the given arguments
-     * Parameters:
-     * name - {String} The key for the callback that is one of the properties
-     *     of the handler's callbacks object.
-     * args - {Array} An array of arguments with which to call the callback
-     *     (defined by the control).
-    callback: function (name, args) {
-        // override the callback method to always send the polygon geometry
-        if (this.callbacks[name]) {
-            this.callbacks[name].apply(this.control,
-                                       [this.feature.geometry.clone()]);
-        // since sketch features are added to the temporary layer
-        // they must be cleared here if done or cancel
-        if(!this.persist && (name == "done" || name == "cancel")) {
-            this.clear();
-    CLASS_NAME: "OpenLayers.Handler.RegularPolygon"
-    OpenLayers/Layer/EventPane.js
- * @requires OpenLayers/Layer.js
- * @requires OpenLayers/Util.js
- * Class: OpenLayers.Layer.EventPane
- * Base class for 3rd party layers.  Create a new event pane layer with the
- * <OpenLayers.Layer.EventPane> constructor.
- * Inherits from:
- *  - <OpenLayers.Layer>
-OpenLayers.Layer.EventPane = OpenLayers.Class(OpenLayers.Layer, {
-     * APIProperty: smoothDragPan
-     * {Boolean} smoothDragPan determines whether non-public/internal API
-     *     methods are used for better performance while dragging EventPane
-     *     layers. When not in sphericalMercator mode, the smoother dragging
-     *     doesn't actually move north/south directly with the number of
-     *     pixels moved, resulting in a slight offset when you drag your mouse
-     *     north south with this option on. If this visual disparity bothers
-     *     you, you should turn this option off, or use spherical mercator.
-     *     Default is on.
-    smoothDragPan: true,
-     * Property: isBaseLayer
-     * {Boolean} EventPaned layers are always base layers, by necessity.
-    isBaseLayer: true,
-     * APIProperty: isFixed
-     * {Boolean} EventPaned layers are fixed by default.
-    isFixed: true,
-     * Property: pane
-     * {DOMElement} A reference to the element that controls the events.
-    pane: null,
-     * Property: mapObject
-     * {Object} This is the object which will be used to load the 3rd party library
-     * in the case of the google layer, this will be of type GMap,
-     * in the case of the ve layer, this will be of type VEMap
-    mapObject: null,
-     * Constructor: OpenLayers.Layer.EventPane
-     * Create a new event pane layer
-     * Parameters:
-     * name - {String}
-     * options - {Object} Hashtable of extra options to tag onto the layer
-    initialize: function(name, options) {
-        OpenLayers.Layer.prototype.initialize.apply(this, arguments);
-        if (this.pane == null) {
-            this.pane = OpenLayers.Util.createDiv(this.div.id + "_EventPane");
-     * APIMethod: destroy
-     * Deconstruct this layer.
-        this.mapObject = null;
-        OpenLayers.Layer.prototype.destroy.apply(this, arguments);
-     * Method: setMap
-     * Set the map property for the layer. This is done through an accessor
-     * so that subclasses can override this and take special action once
-     * they have their map variable set.
-     * Parameters:
-        OpenLayers.Layer.prototype.setMap.apply(this, arguments);
-        this.pane.style.zIndex = parseInt(this.div.style.zIndex) + 1;
-        this.pane.style.display = this.div.style.display;
-        this.pane.style.width="100%";
-        this.pane.style.height="100%";
-        if (OpenLayers.Util.getBrowserName() == "msie") {
-            this.pane.style.background =
-                "url(" + OpenLayers.Util.getImagesLocation() + "blank.gif)";
-        if (this.isFixed) {
-            this.map.viewPortDiv.appendChild(this.pane);
-        } else {
-            this.map.layerContainerDiv.appendChild(this.pane);
-        // once our layer has been added to the map, we can load it
-        this.loadMapObject();
-        // if map didn't load, display warning
-        if (this.mapObject == null) {
-            this.loadWarningMessage();
-     * APIMethod: removeMap
-     * On being removed from the map, we'll like to remove the invisible 'pane'
-     *     div that we added to it on creation.
-     * Parameters:
-    removeMap: function(map) {
-        if (this.pane && this.pane.parentNode) {
-            this.pane.parentNode.removeChild(this.pane);
-            this.pane = null;
-        OpenLayers.Layer.prototype.removeMap.apply(this, arguments);
-     * Method: loadWarningMessage
-     * If we can't load the map lib, then display an error message to the
-     *     user and tell them where to go for help.
-     *     This function sets up the layout for the warning message. Each 3rd
-     *     party layer must implement its own getWarningHTML() function to
-     *     provide the actual warning message.
-    loadWarningMessage:function() {
-        this.div.style.backgroundColor = "darkblue";
-        var viewSize = this.map.getSize();
-        var msgW = Math.min(viewSize.w, 300);
-        var msgH = Math.min(viewSize.h, 200);
-        var size = new OpenLayers.Size(msgW, msgH);
-        var centerPx = new OpenLayers.Pixel(viewSize.w/2, viewSize.h/2);
-        var topLeft = centerPx.add(-size.w/2, -size.h/2);
-        var div = OpenLayers.Util.createDiv(this.name + "_warning",
-                                            topLeft,
-                                            size,
-                                            null,
-                                            null,
-                                            null,
-                                            "auto");
-        div.style.padding = "7px";
-        div.style.backgroundColor = "yellow";
-        div.innerHTML = this.getWarningHTML();
-        this.div.appendChild(div);
-     * Method: getWarningHTML
-     * To be implemented by subclasses.
-     * Returns:
-     * {String} String with information on why layer is broken, how to get
-     *          it working.
-    getWarningHTML:function() {
-        //should be implemented by subclasses
-        return "";
-     * Method: display
-     * Set the display on the pane
-     * Parameters:
-     * display - {Boolean}
-    display: function(display) {
-        OpenLayers.Layer.prototype.display.apply(this, arguments);
-     * Method: setZIndex
-     * Set the z-index order for the pane.
-     * Parameters:
-     * zIndex - {int}
-    setZIndex: function (zIndex) {
-        OpenLayers.Layer.prototype.setZIndex.apply(this, arguments);
-     * Method: moveTo
-     * Handle calls to move the layer.
-     * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
-     * zoomChanged - {Boolean}
-     * dragging - {Boolean}
-    moveTo:function(bounds, zoomChanged, dragging) {
-        OpenLayers.Layer.prototype.moveTo.apply(this, arguments);
-        if (this.mapObject != null) {
-            var newCenter = this.map.getCenter();
-            var newZoom = this.map.getZoom();
-            if (newCenter != null) {
-                var moOldCenter = this.getMapObjectCenter();
-                var oldCenter = this.getOLLonLatFromMapObjectLonLat(moOldCenter);
-                var moOldZoom = this.getMapObjectZoom();
-                var oldZoom= this.getOLZoomFromMapObjectZoom(moOldZoom);
-                if ( !(newCenter.equals(oldCenter)) ||
-                     !(newZoom == oldZoom) ) {
-                    if (dragging && this.dragPanMapObject &&
-                        this.smoothDragPan) {
-                        var oldPx = this.map.getViewPortPxFromLonLat(oldCenter);
-                        var newPx = this.map.getViewPortPxFromLonLat(newCenter);
-                        this.dragPanMapObject(newPx.x-oldPx.x, oldPx.y-newPx.y);
-                    } else {
-                        var center = this.getMapObjectLonLatFromOLLonLat(newCenter);
-                        var zoom = this.getMapObjectZoomFromOLZoom(newZoom);
-                        this.setMapObjectCenter(center, zoom, dragging);
-  /*                 Baselayer Functions                  */
-     * Method: getLonLatFromViewPortPx
-     * Get a map location from a pixel location
-     * Parameters:
-     * viewPortPx - {<OpenLayers.Pixel>}
-     * Returns:
-     *  {<OpenLayers.LonLat>} An OpenLayers.LonLat which is the passed-in view
-     *  port OpenLayers.Pixel, translated into lon/lat by map lib
-     *  If the map lib is not loaded or not centered, returns null
-    getLonLatFromViewPortPx: function (viewPortPx) {
-        var lonlat = null;
-        if ( (this.mapObject != null) &&
-             (this.getMapObjectCenter() != null) ) {
-            var moPixel = this.getMapObjectPixelFromOLPixel(viewPortPx);
-            var moLonLat = this.getMapObjectLonLatFromMapObjectPixel(moPixel);
-            lonlat = this.getOLLonLatFromMapObjectLonLat(moLonLat);
-        return lonlat;
-     * Method: getViewPortPxFromLonLat
-     * Get a pixel location from a map location
-     * Parameters:
-     * lonlat - {<OpenLayers.LonLat>}
-     * Returns:
-     * {<OpenLayers.Pixel>} An OpenLayers.Pixel which is the passed-in
-     * OpenLayers.LonLat, translated into view port pixels by map lib
-     * If map lib is not loaded or not centered, returns null
-    getViewPortPxFromLonLat: function (lonlat) {
-        var viewPortPx = null;
-            var moLonLat = this.getMapObjectLonLatFromOLLonLat(lonlat);
-            var moPixel = this.getMapObjectPixelFromMapObjectLonLat(moLonLat);
-            viewPortPx = this.getOLPixelFromMapObjectPixel(moPixel);
-        return viewPortPx;
-  /*               Translation Functions                  */
-  /*   The following functions translate Map Object and   */
-  /*            OL formats for Pixel, LonLat              */
-  // TRANSLATION: MapObject LatLng <-> OpenLayers.LonLat
-     * Method: getOLLonLatFromMapObjectLonLat
-     * Get an OL style map location from a 3rd party style map location
-     * Parameters
-     * moLonLat - {Object}
-     * Returns:
-     * {<OpenLayers.LonLat>} An OpenLayers.LonLat, translated from the passed in
-     *          MapObject LonLat
-     *          Returns null if null value is passed in
-    getOLLonLatFromMapObjectLonLat: function(moLonLat) {
-        var olLonLat = null;
-        if (moLonLat != null) {
-            var lon = this.getLongitudeFromMapObjectLonLat(moLonLat);
-            var lat = this.getLatitudeFromMapObjectLonLat(moLonLat);
-            olLonLat = new OpenLayers.LonLat(lon, lat);
-        return olLonLat;
-     * Method: getMapObjectLonLatFromOLLonLat
-     * Get a 3rd party map location from an OL map location.
-     * Parameters:
-     * olLonLat - {<OpenLayers.LonLat>}
-     * Returns:
-     * {Object} A MapObject LonLat, translated from the passed in
-    getMapObjectLonLatFromOLLonLat: function(olLonLat) {
-        var moLatLng = null;
-        if (olLonLat != null) {
-            moLatLng = this.getMapObjectLonLatFromLonLat(olLonLat.lon,
-                                                         olLonLat.lat);
-        return moLatLng;
-  // TRANSLATION: MapObject Pixel <-> OpenLayers.Pixel
-     * Method: getOLPixelFromMapObjectPixel
-     * Get an OL pixel location from a 3rd party pixel location.
-     * Parameters:
-     * moPixel - {Object}
-     * Returns:
-     * {<OpenLayers.Pixel>} An OpenLayers.Pixel, translated from the passed in
-     *          MapObject Pixel
-    getOLPixelFromMapObjectPixel: function(moPixel) {
-        var olPixel = null;
-        if (moPixel != null) {
-            var x = this.getXFromMapObjectPixel(moPixel);
-            var y = this.getYFromMapObjectPixel(moPixel);
-            olPixel = new OpenLayers.Pixel(x, y);
-        return olPixel;
-     * Method: getMapObjectPixelFromOLPixel
-     * Get a 3rd party pixel location from an OL pixel location
-     * Parameters:
-     * olPixel - {<OpenLayers.Pixel>}
-     * Returns:
-     * {Object} A MapObject Pixel, translated from the passed in
-     *          OpenLayers.Pixel
-    getMapObjectPixelFromOLPixel: function(olPixel) {
-        var moPixel = null;
-        if (olPixel != null) {
-            moPixel = this.getMapObjectPixelFromXY(olPixel.x, olPixel.y);
-        return moPixel;
-    CLASS_NAME: "OpenLayers.Layer.EventPane"
-    OpenLayers/Layer/FixedZoomLevels.js
- * Class: OpenLayers.Layer.FixedZoomLevels
- *   Some Layers will already have established zoom levels (like google
- *    or ve). Instead of trying to determine them and populate a resolutions[]
- *    Array with those values, we will hijack the resolution functionality
- *    here.
- *   When you subclass FixedZoomLevels:
- *   The initResolutions() call gets nullified, meaning no resolutions[] array
- *    is set up. Which would be a big problem getResolution() in Layer, since
- *    it merely takes map.zoom and indexes into resolutions[]... but....
- *   The getResolution() call is also overridden. Instead of using the
- *    resolutions[] array, we simply calculate the current resolution based
- *    on the current extent and the current map size. But how will we be able
- *    to calculate the current extent without knowing the resolution...?
- *   The getExtent() function is also overridden. Instead of calculating extent
- *    based on the center point and the current resolution, we instead
- *    calculate the extent by getting the lonlats at the top-left and
- *    bottom-right by using the getLonLatFromViewPortPx() translation function,
- *    taken from the pixel locations (0,0) and the size of the map. But how
- *    will we be able to do lonlat-px translation without resolution....?
- *   The getZoomForResolution() method is overridden. Instead of indexing into
- *    the resolutions[] array, we call OpenLayers.Layer.getExent(), passing in
- *    the desired resolution. With this extent, we then call getZoomForExtent()
- *   Whenever you implement a layer using OpenLayers.Layer.FixedZoomLevels,
- *    it is your responsibility to provide the following three functions:
- *   - getLonLatFromViewPortPx
- *   - getViewPortPxFromLonLat
- *   - getZoomForExtent
- *  ...those three functions should generally be provided by any reasonable
- *  API that you might be working from.
-OpenLayers.Layer.FixedZoomLevels = OpenLayers.Class({
-  /*    The following functions must all be implemented   */
-  /*                  by all base layers                  */
-     * Constructor: OpenLayers.Layer.FixedZoomLevels
-     * Create a new fixed zoom levels layer.
-        //this class is only just to add the following functions...
-        // nothing to actually do here... but it is probably a good
-        // idea to have layers that use these functions call this
-        // inititalize() anyways, in case at some point we decide we
-        // do want to put some functionality or state in here.
-     * Method: initResolutions
-     * Populate the resolutions array
-    initResolutions: function() {
-        var props = new Array('minZoomLevel', 'maxZoomLevel', 'numZoomLevels');
-        for(var i=0; i < props.length; i++) {
-            var property = props[i];
-            this[property] = (this.options[property] != null)
-                                     ? this.options[property]
-                                     : this.map[property];
-        if ( (this.minZoomLevel == null) ||
-             (this.minZoomLevel < this.MIN_ZOOM_LEVEL) ){
-            this.minZoomLevel = this.MIN_ZOOM_LEVEL;
-        var limitZoomLevels = this.MAX_ZOOM_LEVEL - this.minZoomLevel + 1;
-        if (this.numZoomLevels != null) {
-            this.numZoomLevels = Math.min(this.numZoomLevels, limitZoomLevels);
-        } else {
-            if (this.maxZoomLevel != null) {
-                var zoomDiff = this.maxZoomLevel - this.minZoomLevel + 1;
-                this.numZoomLevels = Math.min(zoomDiff, limitZoomLevels);
-            } else {
-                this.numZoomLevels = limitZoomLevels;
-        this.maxZoomLevel = this.minZoomLevel + this.numZoomLevels - 1;
-        if (this.RESOLUTIONS != null) {
-            var resolutionsIndex = 0;
-            this.resolutions = [];
-            for(var i= this.minZoomLevel; i <= this.maxZoomLevel; i++) {
-                this.resolutions[resolutionsIndex++] = this.RESOLUTIONS[i];
-            this.maxResolution = this.resolutions[0];
-            this.minResolution = this.resolutions[this.resolutions.length - 1];
-     * APIMethod: getResolution
-     * Get the current map resolution
-     * Returns:
-     * {Float} Map units per Pixel
-    getResolution: function() {
-        if (this.resolutions != null) {
-            return OpenLayers.Layer.prototype.getResolution.apply(this, arguments);
-        } else {
-            var resolution = null;
-            var extent = this.getExtent();
-            if ((viewSize != null) && (extent != null)) {
-                resolution = Math.max( extent.getWidth()  / viewSize.w,
-                                       extent.getHeight() / viewSize.h );
-            return resolution;
-     * APIMethod: getExtent
-     * Calculates using px-> lonlat translation functions on tl and br
-     *     corners of viewport
-     * Returns:
-     * {<OpenLayers.Bounds>} A Bounds object which represents the lon/lat
-     *                       bounds of the current viewPort.
-    getExtent: function () {
-        var extent = null;
-        var tlPx = new OpenLayers.Pixel(0,0);
-        var tlLL = this.getLonLatFromViewPortPx(tlPx);
-        var brPx = new OpenLayers.Pixel(size.w, size.h);
-        var brLL = this.getLonLatFromViewPortPx(brPx);
-        if ((tlLL != null) && (brLL != null)) {
-            extent = new OpenLayers.Bounds(tlLL.lon,
-                                       brLL.lat,
-                                       brLL.lon,
-                                       tlLL.lat);
-        return extent;
-     * Method: getZoomForResolution
-     * Get the zoom level for a given resolution
-     * Parameters:
-     * resolution - {Float}
-     * Returns:
-     * {Integer} A suitable zoom level for the specified resolution.
-     *           If no baselayer is set, returns null.
-    getZoomForResolution: function(resolution) {
-            return OpenLayers.Layer.prototype.getZoomForResolution.apply(this, arguments);
-        } else {
-            var extent = OpenLayers.Layer.prototype.getExtent.apply(this, []);
-            return this.getZoomForExtent(extent);
-    /*    The following functions translate GMaps and OL    */
-    /*     formats for Pixel, LonLat, Bounds, and Zoom      */
-    // TRANSLATION: MapObject Zoom <-> OpenLayers Zoom
-     * Method: getOLZoomFromMapObjectZoom
-     * Get the OL zoom index from the map object zoom level
-     * Parameters:
-     * moZoom - {Integer}
-     * Returns:
-     * {Integer} An OpenLayers Zoom level, translated from the passed in zoom
-    getOLZoomFromMapObjectZoom: function(moZoom) {
-        var zoom = null;
-        if (moZoom != null) {
-            zoom = moZoom - this.minZoomLevel;
-        return zoom;
-     * Method: getMapObjectZoomFromOLZoom
-     * Get the map object zoom level from the OL zoom level
-     * Parameters:
-     * olZoom - {Integer}
-     * Returns:
-     * {Integer} A MapObject level, translated from the passed in olZoom
-    getMapObjectZoomFromOLZoom: function(olZoom) {
-        var zoom = null;
-        if (olZoom != null) {
-            zoom = olZoom + this.minZoomLevel;
-        return zoom;
-    CLASS_NAME: "FixedZoomLevels.js"
     OpenLayers/Layer/HTTPRequest.js
@@ -25865,948 +14496,6 @@
     CLASS_NAME: "OpenLayers.Layer.HTTPRequest"
-    OpenLayers/Layer/Image.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Tile/Image.js
- * Class: OpenLayers.Layer.Image
- * Instances of OpenLayers.Layer.Image are used to display data from a web
- * accessible image as a map layer.  Create a new image layer with the
- * <OpenLayers.Layer.Image> constructor.  Inherits from <OpenLayers.Layer>.
-OpenLayers.Layer.Image = OpenLayers.Class(OpenLayers.Layer, {
-     * {Boolean} The layer is a base layer.  Default is true.  Set this property
-     * in the layer options
-     * Property: url
-     * {String} URL of the image to use
-    url: null,
-     * Property: extent
-     * {<OpenLayers.Bounds>} The image bounds in map units
-    extent: null,
-     * Property: size
-     * {<OpenLayers.Size>} The image size in pixels
-    size: null,
-     * Property: tile
-     * {<OpenLayers.Tile.Image>}
-    tile: null,
-     * Property: aspectRatio
-     * {Float} The ratio of height/width represented by a single pixel in the
-     * graphic
-    aspectRatio: null,
-     * Constructor: OpenLayers.Layer.Image
-     * Create a new image layer
-     * Parameters:
-     * name - {String} A name for the layer.
-     * url - {String} Relative or absolute path to the image
-     * extent - {<OpenLayers.Bounds>} The extent represented by the image
-     * size - {<OpenLayers.Size>} The size (in pixels) of the image
-    initialize: function(name, url, extent, size, options) {
-        this.url = url;
-        this.extent = extent;
-        this.size = size;
-        OpenLayers.Layer.prototype.initialize.apply(this, [name, options]);
-        this.aspectRatio = (this.extent.getHeight() / this.size.h) /
-                           (this.extent.getWidth() / this.size.w);
-     * Method: destroy
-     * Destroy this layer
-        if (this.tile) {
-            this.tile.destroy();
-            this.tile = null;
-     * Method: clone
-     * Create a clone of this layer
-     * Paramters:
-     * obj - {Object} An optional layer (is this ever used?)
-     * Returns:
-     * {<OpenLayers.Layer.Image>} An exact copy of this layer
-    clone: function(obj) {
-        if(obj == null) {
-            obj = new OpenLayers.Layer.Image(this.name,
-                                               this.url,
-                                               this.extent,
-                                               this.size,
-                                               this.options);
-        //get all additions from superclasses
-        obj = OpenLayers.Layer.prototype.clone.apply(this, [obj]);
-        // copy/set any non-init, non-simple values here
-        return obj;
-     * APIMethod: setMap
-     * Parameters:
-         * If nothing to do with resolutions has been set, assume a single
-         * resolution determined by ratio*extent/size - if an image has a
-         * pixel aspect ratio different than one (as calculated above), the
-         * image will be stretched in one dimension only.
-        if( this.options.maxResolution == null ) {
-            this.options.maxResolution = this.aspectRatio *
-                                         this.extent.getWidth() /
-                                         this.size.w;
-     * Method: moveTo
-     * Create the tile for the image or resize it for the new resolution
-     * Parameters:
-        var firstRendering = (this.tile == null);
-        if(zoomChanged || firstRendering) {
-            //determine new tile size
-            this.setTileSize();
-            //determine new position (upper left corner of new bounds)
-            var ul = new OpenLayers.LonLat(this.extent.left, this.extent.top);
-            var ulPx = this.map.getLayerPxFromLonLat(ul);
-            if(firstRendering) {
-                //create the new tile
-                this.tile = new OpenLayers.Tile.Image(this, ulPx, this.extent,
-                                                      null, this.tileSize);
-            } else {
-                //just resize the tile and set it's new position
-                this.tile.size = this.tileSize.clone();
-                this.tile.position = ulPx.clone();
-            this.tile.draw();
-     * Set the tile size based on the map size.
-    setTileSize: function() {
-        var tileWidth = this.extent.getWidth() / this.map.getResolution();
-        var tileHeight = this.extent.getHeight() / this.map.getResolution();
-        this.tileSize = new OpenLayers.Size(tileWidth, tileHeight);
-     * APIMethod: setUrl
-     * Parameters:
-     * newUrl - {String}
-    setUrl: function(newUrl) {
-        this.url = newUrl;
-        this.tile.draw();
-     * APIMethod: getURL
-     * The url we return is always the same (the image itself never changes)
-     *     so we can ignore the bounds parameter (it will always be the same,
-     *     anyways)
-     * Parameters:
-    getURL: function(bounds) {
-        return this.url;
-    CLASS_NAME: "OpenLayers.Layer.Image"
-    OpenLayers/Layer/Markers.js
- * Class: OpenLayers.Layer.Markers
- * Inherits from:
-OpenLayers.Layer.Markers = OpenLayers.Class(OpenLayers.Layer, {
-     * APIProperty: isBaseLayer
-     * {Boolean} Markers layer is never a base layer.
-    isBaseLayer: false,
-     * Property: markers
-     * {Array(<OpenLayers.Marker>)} internal marker list
-    markers: null,
-     * Property: drawn
-     * {Boolean} internal state of drawing. This is a workaround for the fact
-     * that the map does not call moveTo with a zoomChanged when the map is
-     * first starting up. This lets us catch the case where we have *never*
-     * drawn the layer, and draw it even if the zoom hasn't changed.
-    drawn: false,
-     * Constructor: OpenLayers.Layer.Markers
-     * Create a Markers layer.
-     * Parameters:
-     * name - {String}
-        this.markers = [];
-        this.clearMarkers();
-        this.markers = null;
-     * APIMethod: setOpacity
-     * Sets the opacity for all the markers.
-     * Parameter:
-     * opacity - {Float}
-    setOpacity: function(opacity) {
-        if (opacity != this.opacity) {
-            this.opacity = opacity;
-            for (var i = 0; i < this.markers.length; i++) {
-                this.markers[i].setOpacity(this.opacity);
-     * Method: moveTo
-     * Parameters:
-        if (zoomChanged || !this.drawn) {
-            for(var i=0; i < this.markers.length; i++) {
-                this.drawMarker(this.markers[i]);
-            this.drawn = true;
-     * APIMethod: addMarker
-     * Parameters:
-     * marker - {<OpenLayers.Marker>}
-    addMarker: function(marker) {
-        this.markers.push(marker);
-        if (this.opacity != null) {
-            marker.setOpacity(this.opacity);
-        if (this.map && this.map.getExtent()) {
-            marker.map = this.map;
-            this.drawMarker(marker);
-     * APIMethod: removeMarker
-     * Parameters:
-    removeMarker: function(marker) {
-        if (this.markers && this.markers.length) {
-            OpenLayers.Util.removeItem(this.markers, marker);
-            if ((marker.icon != null) && (marker.icon.imageDiv != null) &&
-                (marker.icon.imageDiv.parentNode == this.div) ) {
-                this.div.removeChild(marker.icon.imageDiv);
-                marker.drawn = false;
-     * Method: clearMarkers
-     * This method removes all markers from a layer. The markers are not
-     * destroyed by this function, but are removed from the list of markers.
-    clearMarkers: function() {
-        if (this.markers != null) {
-            while(this.markers.length > 0) {
-                this.removeMarker(this.markers[0]);
-     * Method: drawMarker
-     * Calculate the pixel location for the marker, create it, and
-     *    add it to the layer's div
-     * Parameters:
-    drawMarker: function(marker) {
-        var px = this.map.getLayerPxFromLonLat(marker.lonlat);
-        if (px == null) {
-            marker.display(false);
-        } else {
-            var markerImg = marker.draw(px);
-            if (!marker.drawn) {
-                this.div.appendChild(markerImg);
-                marker.drawn = true;
-     * APIMethod: getDataExtent
-     * Calculates the max extent which includes all of the markers.
-     * Returns:
-    getDataExtent: function () {
-        var maxExtent = null;
-        if ( this.markers && (this.markers.length > 0)) {
-            var maxExtent = new OpenLayers.Bounds();
-                var marker = this.markers[i];
-                maxExtent.extend(marker.lonlat);
-        return maxExtent;
-    CLASS_NAME: "OpenLayers.Layer.Markers"
-    OpenLayers/Layer/SphericalMercator.js
- * @requires OpenLayers/Projection.js
- * Class: OpenLayers.Layer.SphericalMercator
- * A mixin for layers that wraps up the pieces neccesary to have a coordinate
- *     conversion for working with commercial APIs which use a spherical
- *     mercator projection.  Using this layer as a base layer, additional
- *     layers can be used as overlays if they are in the same projection.
- * A layer is given properties of this object by setting the sphericalMercator
- *     property to true.
- * More projection information:
- *  - http://spatialreference.org/ref/user/google-projection/
- * Proj4 Text:
- *     +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
- *     +k=1.0 +units=m +nadgrids=@null +no_defs
- * WKT:
- *     900913=PROJCS["WGS84 / Simple Mercator", GEOGCS["WGS 84",
- *     DATUM["WGS_1984", SPHEROID["WGS_1984", 6378137.0, 298.257223563]],
- *     PRIMEM["Greenwich", 0.0], UNIT["degree", 0.017453292519943295],
- *     AXIS["Longitude", EAST], AXIS["Latitude", NORTH]],
- *     PROJECTION["Mercator_1SP_Google"],
- *     PARAMETER["latitude_of_origin", 0.0], PARAMETER["central_meridian", 0.0],
- *     PARAMETER["scale_factor", 1.0], PARAMETER["false_easting", 0.0],
- *     PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["x", EAST],
- *     AXIS["y", NORTH], AUTHORITY["EPSG","900913"]]
-OpenLayers.Layer.SphericalMercator = {
-     * Method: getExtent
-     * Get the map's extent.
-     * Returns:
-     * {<OpenLayers.Bounds>} The map extent.
-    getExtent: function() {
-        if (this.sphericalMercator) {
-            extent = this.map.calculateBounds();
-        } else {
-            extent = OpenLayers.Layer.FixedZoomLevels.prototype.getExtent.apply(this);
-        return extent;
-     * Method: initMercatorParameters
-     * Set up the mercator parameters on the layer: resolutions,
-     *     projection, units.
-    initMercatorParameters: function() {
-        // set up properties for Mercator - assume EPSG:900913
-        this.RESOLUTIONS = [];
-        var maxResolution = 156543.0339;
-        for(var zoom=0; zoom<=this.MAX_ZOOM_LEVEL; ++zoom) {
-            this.RESOLUTIONS[zoom] = maxResolution / Math.pow(2, zoom);
-        this.units = "m";
-        this.projection = "EPSG:900913";
-     * APIMethod: forwardMercator
-     * Given a lon,lat in EPSG:4326, return a point in Spherical Mercator.
-     * Parameters:
-     * lon - {float}
-     * lat - {float}
-     * Returns:
-     * {<OpenLayers.LonLat>} The coordinates transformed to Mercator.
-    forwardMercator: function(lon, lat) {
-        var x = lon * 20037508.34 / 180;
-        var y = Math.log(Math.tan((90 + lat) * Math.PI / 360)) / (Math.PI / 180);
-        y = y * 20037508.34 / 180;
-        return new OpenLayers.LonLat(x, y);
-     * APIMethod: inverseMercator
-     * Given a x,y in Spherical Mercator, return a point in EPSG:4326.
-     * Parameters:
-     * x - {float} A map x in Spherical Mercator.
-     * y - {float} A map y in Spherical Mercator.
-     * Returns:
-     * {<OpenLayers.LonLat>} The coordinates transformed to EPSG:4326.
-    inverseMercator: function(x, y) {
-        var lon = (x / 20037508.34) * 180;
-        var lat = (y / 20037508.34) * 180;
-        lat = 180/Math.PI * (2 * Math.atan(Math.exp(lat * Math.PI / 180)) - Math.PI / 2);
-        return new OpenLayers.LonLat(lon, lat);
-     * Method: projectForward
-     * Given an object with x and y properties in EPSG:4326, modify the x,y
-     * properties on the object to be the Spherical Mercator projected
-     * coordinates.
-     * Parameters:
-     * point - {Object} An object with x and y properties.
-     * Returns:
-     * {Object} The point, with the x and y properties transformed to spherical
-     * mercator.
-    projectForward: function(point) {
-        var lonlat = OpenLayers.Layer.SphericalMercator.forwardMercator(point.x, point.y);
-        point.x = lonlat.lon;
-        point.y = lonlat.lat;
-        return point;
-     * Method: projectInverse
-     * Given an object with x and y properties in Spherical Mercator, modify
-     * the x,y properties on the object to be the unprojected coordinates.
-     * Parameters:
-     * Returns:
-     * {Object} The point, with the x and y properties transformed from
-     * spherical mercator to unprojected coordinates..
-    projectInverse: function(point) {
-        var lonlat = OpenLayers.Layer.SphericalMercator.inverseMercator(point.x, point.y);
-        return point;
- * Note: Two transforms declared
- * Transforms from EPSG:4326 to EPSG:900913 and from EPSG:900913 to EPSG:4326
- *     are set by this class.
-OpenLayers.Projection.addTransform("EPSG:4326", "EPSG:900913",
-    OpenLayers.Layer.SphericalMercator.projectForward);
-OpenLayers.Projection.addTransform("EPSG:900913", "EPSG:4326",
-    OpenLayers.Layer.SphericalMercator.projectInverse);
-    OpenLayers/Control/DrawFeature.js
- * @requires OpenLayers/Feature/Vector.js
- * Class: OpenLayers.Control.DrawFeature
- * Draws features on a vector layer when active.
- * Inherits from:
-OpenLayers.Control.DrawFeature = OpenLayers.Class(OpenLayers.Control, {
-     * Property: layer
-    layer: null,
-     * Property: callbacks
-     * {Object} The functions that are sent to the handler for callback
-    callbacks: null,
-     * APIProperty: featureAdded
-     * {Function} Called after each feature is added
-    featureAdded: function() {},
-     * APIProperty: handlerOptions
-     * {Object} Used to set non-default properties on the control's handler
-    handlerOptions: null,
-     * Constructor: OpenLayers.Control.DrawFeature
-     * Parameters:
-     * handler - {<OpenLayers.Handler>}
-    initialize: function(layer, handler, options) {
-        this.callbacks = OpenLayers.Util.extend({done: this.drawFeature},
-                                                this.callbacks);
-        this.layer = layer;
-        this.handler = new handler(this, this.callbacks, this.handlerOptions);
-     * Method: drawFeature
-    drawFeature: function(geometry) {
-        var feature = new OpenLayers.Feature.Vector(geometry);
-        this.layer.addFeatures([feature]);
-        this.featureAdded(feature);
-    CLASS_NAME: "OpenLayers.Control.DrawFeature"
-    OpenLayers/Control/SelectFeature.js
- * Class: OpenLayers.Control.SelectFeature
- * Selects vector features from a given layer on click or hover.
- * Inherits from:
-OpenLayers.Control.SelectFeature = OpenLayers.Class(OpenLayers.Control, {
-     * Property: multipleKey
-     * {String} An event modifier ('altKey' or 'shiftKey') that temporarily sets
-     *     the <multiple> property to true.  Default is null.
-    multipleKey: null,
-     * Property: toggleKey
-     *     the <toggle> property to true.  Default is null.
-    toggleKey: null,
-     * APIProperty: multiple
-     * {Boolean} Allow selection of multiple geometries.  Default is false.
-    multiple: false,
-     * APIProperty: clickout
-     * {Boolean} Unselect features when clicking outside any feature.
-     *     Default is true.
-    clickout: true,
-     * APIProperty: toggle
-     * {Boolean} Unselect a selected feature on click.  Default is false.  Only
-     *     has meaning if hover is false.
-    toggle: false,
-     * APIProperty: hover
-     * {Boolean} Select on mouse over and deselect on mouse out.  If true, this
-     * ignores clicks and only listens to mouse moves.
-    hover: false,
-     * APIProperty: onSelect
-     * {Function} Optional function to be called when a feature is selected.
-     * The function should expect to be called with a feature.
-    onSelect: function() {},
-     * APIProperty: onUnselect
-     * {Function} Optional function to be called when a feature is unselected.
-    onUnselect: function() {},
-     * {Array(String)} To restrict selecting to a limited set of geometry types,
-    geometryTypes: null,
-     * Property: layer
-    layer: null,
-     * APIProperty: callbacks
-    callbacks: null,
-     * APIProperty: selectStyle
-     * {Object} Hash of styles
-    selectStyle: null,
-     * {String} key used to retrieve the select style from the layer's
-     * style map.
-    renderIntent: "select",
-     * Property: handler
-     * {<OpenLayers.Handler.Feature>}
-    handler: null,
-     * Constructor: <OpenLayers.Control.SelectFeature>
-     * Parameters:
-                                                  click: this.clickFeature,
-                                                  clickout: this.clickoutFeature,
-                                                }, this.callbacks);
-        var handlerOptions = { geometryTypes: this.geometryTypes};
-        this.handler = new OpenLayers.Handler.Feature(this, layer,
-                                                      this.callbacks,
-                                                      handlerOptions);
-     * Method: unselectAll
-     * Unselect all selected features.  To unselect all except for a single
-     *     feature, set the options.except property to the feature.
-     * Parameters:
-     * options - {Object} Optional configuration object.
-    unselectAll: function(options) {
-        // we'll want an option to supress notification here
-        var feature;
-        for(var i=this.layer.selectedFeatures.length-1; i>=0; --i) {
-            feature = this.layer.selectedFeatures[i];
-            if(!options || options.except != feature) {
-                this.unselect(feature);
-     * Method: clickFeature
-     * Called on click in a feature
-     * Only responds if this.hover is false.
-     * Parameters:
-    clickFeature: function(feature) {
-        if(!this.hover) {
-            var selected = (OpenLayers.Util.indexOf(this.layer.selectedFeatures,
-                                                    feature) > -1);
-            if(selected) {
-                if(this.toggleSelect()) {
-                } else if(!this.multipleSelect()) {
-                    this.unselectAll({except: feature});
-            } else {
-                if(!this.multipleSelect()) {
-                this.select(feature);
-     * Method: multipleSelect
-     * Allow for multiple selected features based on <multiple> property and
-     *     <multipleKey> event modifier.
-     * Returns:
-     * {Boolean} Allow for multiple selected features.
-    multipleSelect: function() {
-        return this.multiple || this.handler.evt[this.multipleKey];
-     * Method: toggleSelect
-     * Event should toggle the selected state of a feature based on <toggle>
-     *     property and <toggleKey> event modifier.
-     * Returns:
-     * {Boolean} Toggle the selected state of a feature.
-    toggleSelect: function() {
-        return this.toggle || this.handler.evt[this.toggleKey];
-     * Method: clickoutFeature
-     * Called on click outside a previously clicked (selected) feature.
-     * Parameters:
-     * feature - {<OpenLayers.Vector.Feature>}
-    clickoutFeature: function(feature) {
-        if(!this.hover && this.clickout) {
-            this.unselectAll();
-     * Called on over a feature.
-     * Only responds if this.hover is true.
-     * Parameters:
-        if(this.hover &&
-           (OpenLayers.Util.indexOf(this.layer.selectedFeatures, feature) == -1)) {
-     * Called on out of a selected feature.
-     * Parameters:
-        if(this.hover) {
-     * Method: select
-     * Add feature to the layer's selectedFeature array, render the feature as
-     * selected, and call the onSelect function.
-     * Parameters:
-    select: function(feature) {
-        this.layer.selectedFeatures.push(feature);
-        var selectStyle = this.selectStyle || this.renderIntent;
-        this.layer.drawFeature(feature, selectStyle);
-        this.layer.events.triggerEvent("featureselected", {feature: feature});
-        this.onSelect(feature);
-     * Remove feature from the layer's selectedFeature array, render the feature as
-     * normal, and call the onUnselect function.
-     * Parameters:
-    unselect: function(feature) {
-        // Store feature style for restoration later
-        this.layer.drawFeature(feature, "default");
-        OpenLayers.Util.removeItem(this.layer.selectedFeatures, feature);
-        this.layer.events.triggerEvent("featureunselected", {feature: feature});
-        this.onUnselect(feature);
-     * Method: setMap
-     * Set the map property for the control.
-     * Parameters:
-        this.handler.setMap(map);
-    CLASS_NAME: "OpenLayers.Control.SelectFeature"
     OpenLayers/Control/ZoomBox.js
@@ -26890,1232 +14579,6 @@
     CLASS_NAME: "OpenLayers.Control.ZoomBox"
-    OpenLayers/Format/WKT.js
- * @requires OpenLayers/Format.js
- * Class: OpenLayers.Format.WKT
- * Class for reading and writing Well-Known Text.  Create a new instance
- * with the <OpenLayers.Format.WKT> constructor.
- * Inherits from:
- *  - <OpenLayers.Format>
-OpenLayers.Format.WKT = OpenLayers.Class(OpenLayers.Format, {
-     * Constructor: OpenLayers.Format.WKT
-     * Create a new parser for WKT
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *           this instance
-     * Returns:
-     * {<OpenLayers.Format.WKT>} A new WKT parser.
-    initialize: function(options) {
-        this.regExes = {
-            'typeStr': /^\s*(\w+)\s*\(\s*(.*)\s*\)\s*$/,
-            'spaces': /\s+/,
-            'parenComma': /\)\s*,\s*\(/,
-            'doubleParenComma': /\)\s*\)\s*,\s*\(\s*\(/,  // can't use {2} here
-            'trimParens': /^\s*\(?(.*?)\)?\s*$/
-        OpenLayers.Format.prototype.initialize.apply(this, [options]);
-     * Method: read
-     * Deserialize a WKT string and return a vector feature or an
-     * array of vector features.  Supports WKT for POINT, MULTIPOINT,
-     * LINESTRING, MULTILINESTRING, POLYGON, MULTIPOLYGON, and
-     * GEOMETRYCOLLECTION.
-     * Parameters:
-     * wkt - {String} A WKT string
-     * Returns:
-     * {<OpenLayers.Feature.Vector>|Array} A feature or array of features for
-     * GEOMETRYCOLLECTION WKT.
-    read: function(wkt) {
-        var features, type, str;
-        var matches = this.regExes.typeStr.exec(wkt);
-        if(matches) {
-            type = matches[1].toLowerCase();
-            str = matches[2];
-            if(this.parse[type]) {
-                features = this.parse[type].apply(this, [str]);
-            if (this.internalProjection && this.externalProjection) {
-                if (features &&
-                    features.CLASS_NAME == "OpenLayers.Feature.Vector") {
-                    features.geometry.transform(this.externalProjection,
-                                                this.internalProjection);
-                } else if (features && typeof features == "object") {
-                    for (var i = 0; i < features.length; i++) {
-                        var component = features[i];
-                        component.geometry.transform(this.externalProjection,
-        return features;
-     * Method: write
-     * Serialize a feature or array of features into a WKT string.
-     * Parameters:
-     * features - {<OpenLayers.Feature.Vector>|Array} A feature or array of
-     *            features
-     * Returns:
-     * {String} The WKT string representation of the input geometries
-    write: function(features) {
-        var collection, geometry, type, data, isCollection;
-        if(features.constructor == Array) {
-            collection = features;
-            isCollection = true;
-        } else {
-            collection = [features];
-            isCollection = false;
-        var pieces = [];
-        if(isCollection) {
-            pieces.push('GEOMETRYCOLLECTION(');
-        for(var i=0; i<collection.length; ++i) {
-            if(isCollection && i>0) {
-                pieces.push(',');
-            geometry = collection[i].geometry;
-            type = geometry.CLASS_NAME.split('.')[2].toLowerCase();
-            if(!this.extract[type]) {
-                return null;
-                geometry = geometry.clone();
-                geometry.transform(this.internalProjection,
-                                   this.externalProjection);
-            data = this.extract[type].apply(this, [geometry]);
-            pieces.push(type.toUpperCase() + '(' + data + ')');
-            pieces.push(')');
-        return pieces.join('');
-     * Object with properties corresponding to the geometry types.
-     * Property values are functions that do the actual data extraction.
-    extract: {
-         * Return a space delimited string of point coordinates.
-         * @param {<OpenLayers.Geometry.Point>} point
-         * @returns {String} A string of coordinates representing the point
-        'point': function(point) {
-            return point.x + ' ' + point.y;
-         * Return a comma delimited string of point coordinates from a multipoint.
-         * @param {<OpenLayers.Geometry.MultiPoint>} multipoint
-         * @returns {String} A string of point coordinate strings representing
-         *                  the multipoint
-        'multipoint': function(multipoint) {
-            var array = [];
-            for(var i=0; i<multipoint.components.length; ++i) {
-                array.push(this.extract.point.apply(this, [multipoint.components[i]]));
-            return array.join(',');
-         * Return a comma delimited string of point coordinates from a line.
-         * @param {<OpenLayers.Geometry.LineString>} linestring
-         *                  the linestring
-        'linestring': function(linestring) {
-            var array = [];
-            for(var i=0; i<linestring.components.length; ++i) {
-                array.push(this.extract.point.apply(this, [linestring.components[i]]));
-         * Return a comma delimited string of linestring strings from a multilinestring.
-         * @param {<OpenLayers.Geometry.MultiLineString>} multilinestring
-         * @returns {String} A string of of linestring strings representing
-         *                  the multilinestring
-        'multilinestring': function(multilinestring) {
-            var array = [];
-            for(var i=0; i<multilinestring.components.length; ++i) {
-                array.push('(' +
-                           this.extract.linestring.apply(this, [multilinestring.components[i]]) +
-         * Return a comma delimited string of linear ring arrays from a polygon.
-         * @param {<OpenLayers.Geometry.Polygon>} polygon
-         * @returns {String} An array of linear ring arrays representing the polygon
-        'polygon': function(polygon) {
-            var array = [];
-            for(var i=0; i<polygon.components.length; ++i) {
-                array.push('(' +
-                           this.extract.linestring.apply(this, [polygon.components[i]]) +
-         * Return an array of polygon arrays from a multipolygon.
-         * @param {<OpenLayers.Geometry.MultiPolygon>} multipolygon
-         * @returns {Array} An array of polygon arrays representing
-         *                  the multipolygon
-        'multipolygon': function(multipolygon) {
-            var array = [];
-            for(var i=0; i<multipolygon.components.length; ++i) {
-                array.push('(' +
-                           this.extract.polygon.apply(this, [multipolygon.components[i]]) +
-     * Property values are functions that do the actual parsing.
-    parse: {
-         * Return point feature given a point WKT fragment.
-         * @param {String} str A WKT fragment representing the point
-         * @returns {<OpenLayers.Feature.Vector>} A point feature
-         * @private
-        'point': function(str) {
-            var coords = OpenLayers.String.trim(str).split(this.regExes.spaces);
-                new OpenLayers.Geometry.Point(coords[0], coords[1])
-         * Return a multipoint feature given a multipoint WKT fragment.
-         * @param {String} A WKT fragment representing the multipoint
-         * @returns {<OpenLayers.Feature.Vector>} A multipoint feature
-         * @private
-        'multipoint': function(str) {
-            var points = OpenLayers.String.trim(str).split(',');
-            var components = [];
-            for(var i=0; i<points.length; ++i) {
-                components.push(this.parse.point.apply(this, [points[i]]).geometry);
-                new OpenLayers.Geometry.MultiPoint(components)
-         * Return a linestring feature given a linestring WKT fragment.
-         * @param {String} A WKT fragment representing the linestring
-         * @returns {<OpenLayers.Feature.Vector>} A linestring feature
-         * @private
-        'linestring': function(str) {
-                new OpenLayers.Geometry.LineString(components)
-         * Return a multilinestring feature given a multilinestring WKT fragment.
-         * @param {String} A WKT fragment representing the multilinestring
-         * @returns {<OpenLayers.Feature.Vector>} A multilinestring feature
-         * @private
-        'multilinestring': function(str) {
-            var line;
-            var lines = OpenLayers.String.trim(str).split(this.regExes.parenComma);
-            for(var i=0; i<lines.length; ++i) {
-                line = lines[i].replace(this.regExes.trimParens, '$1');
-                components.push(this.parse.linestring.apply(this, [line]).geometry);
-            return new OpenLayers.Feature.Vector(
-                new OpenLayers.Geometry.MultiLineString(components)
-         * Return a polygon feature given a polygon WKT fragment.
-         * @param {String} A WKT fragment representing the polygon
-         * @returns {<OpenLayers.Feature.Vector>} A polygon feature
-         * @private
-        'polygon': function(str) {
-            var ring, linestring, linearring;
-            var rings = OpenLayers.String.trim(str).split(this.regExes.parenComma);
-            for(var i=0; i<rings.length; ++i) {
-                ring = rings[i].replace(this.regExes.trimParens, '$1');
-                linestring = this.parse.linestring.apply(this, [ring]).geometry;
-                linearring = new OpenLayers.Geometry.LinearRing(linestring.components);
-                components.push(linearring);
-                new OpenLayers.Geometry.Polygon(components)
-         * Return a multipolygon feature given a multipolygon WKT fragment.
-         * @param {String} A WKT fragment representing the multipolygon
-         * @returns {<OpenLayers.Feature.Vector>} A multipolygon feature
-         * @private
-        'multipolygon': function(str) {
-            var polygon;
-            var polygons = OpenLayers.String.trim(str).split(this.regExes.doubleParenComma);
-            for(var i=0; i<polygons.length; ++i) {
-                polygon = polygons[i].replace(this.regExes.trimParens, '$1');
-                components.push(this.parse.polygon.apply(this, [polygon]).geometry);
-                new OpenLayers.Geometry.MultiPolygon(components)
-         * Return an array of features given a geometrycollection WKT fragment.
-         * @param {String} A WKT fragment representing the geometrycollection
-         * @returns {Array} An array of OpenLayers.Feature.Vector
-         * @private
-        'geometrycollection': function(str) {
-            // separate components of the collection with |
-            str = str.replace(/,\s*([A-Za-z])/g, '|$1');
-            var wktArray = OpenLayers.String.trim(str).split('|');
-            for(var i=0; i<wktArray.length; ++i) {
-                components.push(OpenLayers.Format.WKT.prototype.read.apply(this,[wktArray[i]]));
-            return components;
-    CLASS_NAME: "OpenLayers.Format.WKT"
-    OpenLayers/Layer/Boxes.js
- * @requires OpenLayers/Layer/Markers.js
- * Class: OpenLayers.Layer.Boxes
- * Draw divs as 'boxes' on the layer.
- * Inherits from:
- *  - <OpenLayers.Layer.Markers>
-OpenLayers.Layer.Boxes = OpenLayers.Class(OpenLayers.Layer.Markers, {
-     * Constructor: OpenLayers.Layer.Boxes
-     * Parameters:
-     * name - {String}
-    initialize: function (name, options) {
-        OpenLayers.Layer.Markers.prototype.initialize.apply(this, arguments);
-     * Parameters:
-     * marker - {<OpenLayers.Marker.Box>}
-        var bounds   = marker.bounds;
-        var topleft  = this.map.getLayerPxFromLonLat(
-                            new OpenLayers.LonLat(bounds.left,  bounds.top));
-        var botright = this.map.getLayerPxFromLonLat(
-                             new OpenLayers.LonLat(bounds.right, bounds.bottom));
-        if (botright == null || topleft == null) {
-        } else {
-            var sz = new OpenLayers.Size(
-                Math.max(1, botright.x - topleft.x),
-                Math.max(1, botright.y - topleft.y));
-            var markerDiv = marker.draw(topleft, sz);
-                this.div.appendChild(markerDiv);
-     * Parameters:
-        if ((marker.div != null) &&
-            (marker.div.parentNode == this.div) ) {
-            this.div.removeChild(marker.div);
-    CLASS_NAME: "OpenLayers.Layer.Boxes"
-    OpenLayers/Layer/GeoRSS.js
- * @requires OpenLayers/Ajax.js
- * Class: OpenLayers.Layer.GeoRSS
- * Add GeoRSS Point features to your map.
- * Inherits from:
-OpenLayers.Layer.GeoRSS = OpenLayers.Class(OpenLayers.Layer.Markers, {
-     * Property: location
-     * {String} store url of text file
-     * Property: features
-     * {Array(<OpenLayers.Feature>)}
-    features: null,
-     * APIProperty: formatOptions
-     * {Object} Hash of options which should be passed to the format when it is
-     * created. Must be passed in the constructor.
-    formatOptions: null,
-     * Property: selectedFeature
-     * {<OpenLayers.Feature>}
-    selectedFeature: null,
-     * APIProperty: icon
-     * {<OpenLayers.Icon>}. This determines the Icon to be used on the map
-     * for this GeoRSS layer.
-    icon: null,
-     * APIProperty: popupSize
-     * {<OpenLayers.Size>} This determines the size of GeoRSS popups. If
-     * not provided, defaults to 250px by 120px.
-    popupSize: null,
-     * APIProperty: useFeedTitle
-     * {Boolean} Set layer.name to the first <title> element in the feed. Default is true.
-    useFeedTitle: true,
-    * Constructor: OpenLayers.Layer.GeoRSS
-    * Create a GeoRSS Layer.
-    * Parameters:
-    * name - {String}
-    * location - {String}
-    initialize: function(name, location, options) {
-        OpenLayers.Layer.Markers.prototype.initialize.apply(this, [name, options]);
-        this.location = location;
-        this.features = [];
-     * Method: destroy
-    destroy: function() {
-        // Warning: Layer.Markers.destroy() must be called prior to calling
-        // clearFeatures() here, otherwise we leak memory. Indeed, if
-        // Layer.Markers.destroy() is called after clearFeatures(), it won't be
-        // able to remove the marker image elements from the layer's div since
-        // the markers will have been destroyed by clearFeatures().
-        OpenLayers.Layer.Markers.prototype.destroy.apply(this, arguments);
-        this.clearFeatures();
-        this.features = null;
-     * Method: loadRSS
-     * Start the load of the RSS data. Don't do this when we first add the layer,
-     * since we may not be visible at any point, and it would therefore be a waste.
-    loadRSS: function() {
-        if (!this.loaded) {
-            this.events.triggerEvent("loadstart");
-            OpenLayers.loadURL(this.location, null, this, this.parseData);
-            this.loaded = true;
-     * Method: moveTo
-     * If layer is visible and RSS has not been loaded, load RSS.
-     * Parameters:
-     * bounds - {Object}
-     * zoomChanged - {Object}
-     * minor - {Object}
-    moveTo:function(bounds, zoomChanged, minor) {
-        OpenLayers.Layer.Markers.prototype.moveTo.apply(this, arguments);
-        if(this.visibility && !this.loaded){
-            this.loadRSS();
-     * Method: parseData
-     * Parse the data returned from the Events call.
-     * Parameters:
-     * ajaxRequest - {XMLHttpRequest}
-    parseData: function(ajaxRequest) {
-        var doc = ajaxRequest.responseXML;
-        if (!doc || !doc.documentElement) {
-            doc = OpenLayers.Format.XML.prototype.read(ajaxRequest.responseText);
-        if (this.useFeedTitle) {
-            var name = null;
-            try {
-                name = doc.getElementsByTagNameNS('*', 'title')[0].firstChild.nodeValue;
-            catch (e) {
-                name = doc.getElementsByTagName('title')[0].firstChild.nodeValue;
-            if (name) {
-                this.setName(name);
-        var options = {};
-        OpenLayers.Util.extend(options, this.formatOptions);
-        if (this.map && !this.projection.equals(this.map.getProjectionObject())) {
-            options.externalProjection = this.projection;
-            options.internalProjection = this.map.getProjectionObject();
-        var format = new OpenLayers.Format.GeoRSS(options);
-        var features = format.read(doc);
-            var data = {};
-            var feature = features[i];
-            // we don't support features with no geometry in the GeoRSS
-            // layer at this time.
-            if (!feature.geometry) {
-                continue;
-            var title = feature.attributes.title ?
-                         feature.attributes.title : "Untitled";
-            var description = feature.attributes.description ?
-                         feature.attributes.description : "No description.";
-            var link = feature.attributes.link ? feature.attributes.link : "";
-            var location = feature.geometry.getBounds().getCenterLonLat();
-            data.icon = this.icon == null ?
-                                     OpenLayers.Marker.defaultIcon() :
-                                     this.icon.clone();
-            data.popupSize = this.popupSize ?
-                             this.popupSize.clone() :
-                             new OpenLayers.Size(250, 120);
-            if (title || description) {
-                var contentHTML = '<div class="olLayerGeoRSSClose">[x]</div>';
-                contentHTML += '<div class="olLayerGeoRSSTitle">';
-                if (link) {
-                    contentHTML += '<a class="link" href="'+link+'" target="_blank">';
-                contentHTML += title;
-                if (link) {
-                    contentHTML += '</a>';
-                contentHTML += '</div>';
-                contentHTML += '<div style="" class="olLayerGeoRSSDescription">';
-                contentHTML += description;
-                data['popupContentHTML'] = contentHTML;
-            var feature = new OpenLayers.Feature(this, location, data);
-            this.features.push(feature);
-            var marker = feature.createMarker();
-            marker.events.register('click', feature, this.markerClick);
-            this.addMarker(marker);
-        this.events.triggerEvent("loadend");
-     * Method: markerClick
-     * Parameters:
-     * evt - {Event}
-    markerClick: function(evt) {
-        var sameMarkerClicked = (this == this.layer.selectedFeature);
-        this.layer.selectedFeature = (!sameMarkerClicked) ? this : null;
-        for(var i=0; i < this.layer.map.popups.length; i++) {
-            this.layer.map.removePopup(this.layer.map.popups[i]);
-        if (!sameMarkerClicked) {
-            var popup = this.createPopup();
-            OpenLayers.Event.observe(popup.div, "click",
-                OpenLayers.Function.bind(function() {
-                }, this)
-            this.layer.map.addPopup(popup);
-        OpenLayers.Event.stop(evt);
-     * Method: clearFeatures
-     * Destroy all features in this layer.
-    clearFeatures: function() {
-        if (this.features != null) {
-            while(this.features.length > 0) {
-                var feature = this.features[0];
-                OpenLayers.Util.removeItem(this.features, feature);
-                feature.destroy();
-    CLASS_NAME: "OpenLayers.Layer.GeoRSS"
-    OpenLayers/Layer/Google.js
- * @requires OpenLayers/Layer/SphericalMercator.js
- * @requires OpenLayers/Layer/EventPane.js
- * @requires OpenLayers/Layer/FixedZoomLevels.js
- * Class: OpenLayers.Layer.Google
- * Inherits from:
- *  - <OpenLayers.Layer.SphericalMercator>
- *  - <OpenLayers.Layer.EventPane>
- *  - <OpenLayers.Layer.FixedZoomLevels>
-OpenLayers.Layer.Google = OpenLayers.Class(
-    OpenLayers.Layer.EventPane,
-    OpenLayers.Layer.FixedZoomLevels, {
-     * Constant: MIN_ZOOM_LEVEL
-     * {Integer} 0
-    MIN_ZOOM_LEVEL: 0,
-     * Constant: MAX_ZOOM_LEVEL
-     * {Integer} 19
-    MAX_ZOOM_LEVEL: 19,
-     * Constant: RESOLUTIONS
-     * {Array(Float)} Hardcode these resolutions so that they are more closely
-     *                tied with the standard wms projection
-    RESOLUTIONS: [
-        1.40625,
-        0.703125,
-        0.3515625,
-        0.17578125,
-        0.087890625,
-        0.0439453125,
-        0.02197265625,
-        0.010986328125,
-        0.0054931640625,
-        0.00274658203125,
-        0.001373291015625,
-        0.0006866455078125,
-        0.00034332275390625,
-        0.000171661376953125,
-        0.0000858306884765625,
-        0.00004291534423828125,
-        0.00002145767211914062,
-        0.00001072883605957031,
-        0.00000536441802978515,
-        0.00000268220901489257
-     * APIProperty: type
-     * {GMapType}
-    type: null,
-     * APIProperty: sphericalMercator
-     * {Boolean} Should the map act as a mercator-projected map? This will
-     *     cause all interactions with the map to be in the actual map
-     *     projection, which allows support for vector drawing, overlaying
-     *     other maps, etc.
-    sphericalMercator: false,
-     * Property: dragObject
-     * {GDraggableObject} Since 2.93, Google has exposed the ability to get
-     *     the maps GDraggableObject. We can now use this for smooth panning
-    dragObject: null,
-     * Constructor: OpenLayers.Layer.Google
-     * Parameters:
-     *     on the layer.
-        OpenLayers.Layer.EventPane.prototype.initialize.apply(this, arguments);
-        OpenLayers.Layer.FixedZoomLevels.prototype.initialize.apply(this,
-        arguments);
-        this.addContainerPxFunction();
-            OpenLayers.Util.extend(this, OpenLayers.Layer.SphericalMercator);
-            this.initMercatorParameters();
-     * Method: loadMapObject
-     * Load the GMap and register appropriate event listeners. If we can't
-     *     load GMap2, then display a warning message.
-    loadMapObject:function() {
-        //has gmaps library has been loaded?
-        try {
-            // create GMap, hide nav controls
-            this.mapObject = new GMap2( this.div );
-            //since v 2.93 getDragObject is now available.
-            if(typeof this.mapObject.getDragObject == "function") {
-                this.dragObject = this.mapObject.getDragObject();
-            } else {
-                this.dragPanMapObject = null;
-            // move the ToS and branding stuff up to the pane
-            // thanks a *mil* Erik for thinking of this
-            var poweredBy = this.div.lastChild;
-            this.div.removeChild(poweredBy);
-            this.pane.appendChild(poweredBy);
-            poweredBy.className = "olLayerGooglePoweredBy gmnoprint";
-            poweredBy.style.left = "";
-            poweredBy.style.bottom = "";
-            var termsOfUse = this.div.lastChild;
-            this.div.removeChild(termsOfUse);
-            this.pane.appendChild(termsOfUse);
-            termsOfUse.className = "olLayerGoogleCopyright";
-            termsOfUse.style.right = "";
-            termsOfUse.style.bottom = "";
-        } catch (e) {
-            OpenLayers.Console.error(e);
-     * Overridden from EventPane because if a map type has been specified,
-     *     we need to attach a listener for the first moveend -- this is how
-     *     we will know that the map has been centered. Only once the map has
-     *     been centered is it safe to change the gmap object's map type.
-     * Parameters:
-     * map - {<OpenLayers.Map>}
-    setMap: function(map) {
-        OpenLayers.Layer.EventPane.prototype.setMap.apply(this, arguments);
-        if (this.type != null) {
-            this.map.events.register("moveend", this, this.setMapType);
-     * Method: setMapType
-     * The map has been centered, and a map type was specified, so we
-     *     set the map type on the gmap object, then unregister the listener
-     *     so that we dont keep doing this every time the map moves.
-    setMapType: function() {
-        if (this.mapObject.getCenter() != null) {
-            // Support for custom map types.
-            if (OpenLayers.Util.indexOf(this.mapObject.getMapTypes(),
-                                        this.type) == -1) {
-                this.mapObject.addMapType(this.type);
-            this.mapObject.setMapType(this.type);
-            this.map.events.unregister("moveend", this, this.setMapType);
-     * APIMethod: onMapResize
-     * Parameters:
-     * evt - {Event}
-    onMapResize: function() {
-        this.mapObject.checkResize();
-     * APIMethod: getZoomForExtent
-     * Parameters:
-     * Returns:
-     * {Integer} Corresponding zoom level for a specified Bounds.
-     *           If mapObject is not loaded or not centered, returns null
-    getZoomForExtent: function (bounds) {
-        var zoom = null;
-            var moBounds = this.getMapObjectBoundsFromOLBounds(bounds);
-            var moZoom = this.getMapObjectZoomFromMapObjectBounds(moBounds);
-            //make sure zoom is within bounds
-            var moZoom = Math.min(Math.max(moZoom, this.minZoomLevel),
-                                 this.maxZoomLevel);
-            zoom = this.getOLZoomFromMapObjectZoom(moZoom);
-        return zoom;
-  // TRANSLATION: MapObject Bounds <-> OpenLayers.Bounds
-     * APIMethod: getOLBoundsFromMapObjectBounds
-     * Parameters:
-     * moBounds - {Object}
-     * Returns:
-     * {<OpenLayers.Bounds>} An <OpenLayers.Bounds>, translated from the
-     *                       passed-in MapObject Bounds.
-     *                       Returns null if null value is passed in.
-    getOLBoundsFromMapObjectBounds: function(moBounds) {
-        var olBounds = null;
-        if (moBounds != null) {
-            var sw = moBounds.getSouthWest();
-            var ne = moBounds.getNorthEast();
-                sw = this.forwardMercator(sw.lng(), sw.lat());
-                ne = this.forwardMercator(ne.lng(), ne.lat());
-            } else {
-                sw = new OpenLayers.LonLat(sw.lng(), sw.lat());
-                ne = new OpenLayers.LonLat(ne.lng(), ne.lat());
-            olBounds = new OpenLayers.Bounds(sw.lon,
-                                             sw.lat,
-                                             ne.lon,
-                                             ne.lat );
-        return olBounds;
-     * APIMethod: getMapObjectBoundsFromOLBounds
-     * Parameters:
-     * olBounds - {<OpenLayers.Bounds>}
-     * Returns:
-     * {Object} A MapObject Bounds, translated from olBounds
-    getMapObjectBoundsFromOLBounds: function(olBounds) {
-        var moBounds = null;
-        if (olBounds != null) {
-            var sw = this.sphericalMercator ?
-              this.inverseMercator(olBounds.bottom, olBounds.left) :
-              new OpenLayers.LonLat(olBounds.bottom, olBounds.left);
-            var ne = this.sphericalMercator ?
-              this.inverseMercator(olBounds.top, olBounds.right) :
-              new OpenLayers.LonLat(olBounds.top, olBounds.right);
-            moBounds = new GLatLngBounds(new GLatLng(sw.lat, sw.lon),
-                                         new GLatLng(ne.lat, ne.lon));
-        return moBounds;
-     * Method: addContainerPxFunction
-     * Hack-on function because GMAPS does not give it to us
-     * Parameters:
-     * gLatLng - {GLatLng}
-     * Returns:
-     * {GPoint} A GPoint specifying gLatLng translated into "Container" coords
-    addContainerPxFunction: function() {
-        if ( (typeof GMap2 != "undefined") &&
-             !GMap2.prototype.fromLatLngToContainerPixel) {
-            GMap2.prototype.fromLatLngToContainerPixel = function(gLatLng) {
-                // first we translate into "DivPixel"
-                var gPoint = this.fromLatLngToDivPixel(gLatLng);
-                // locate the sliding "Div" div
-                var div = this.getContainer().firstChild.firstChild;
-                // adjust by the offset of "Div" and voila!
-                gPoint.x += div.offsetLeft;
-                gPoint.y += div.offsetTop;
-                return gPoint;
-     * APIMethod: getWarningHTML
-     * Returns:
-     *          it working.
-        return OpenLayers.i18n("googleWarning");
-     *   MapObject Interface Controls   *
-  // Get&Set Center, Zoom
-     * APIMethod: setMapObjectCenter
-     * Set the mapObject to the specified center and zoom
-     * Parameters:
-     * center - {Object} MapObject LonLat format
-     * zoom - {int} MapObject zoom format
-    setMapObjectCenter: function(center, zoom) {
-        this.mapObject.setCenter(center, zoom);
-     * APIMethod: dragPanMapObject
-     * Parameters:
-     * dX - {Integer}
-     * dY - {Integer}
-    dragPanMapObject: function(dX, dY) {
-        this.dragObject.moveBy(new GSize(-dX, dY));
-     * APIMethod: getMapObjectCenter
-     * Returns:
-     * {Object} The mapObject's current center in Map Object format
-    getMapObjectCenter: function() {
-        return this.mapObject.getCenter();
-     * APIMethod: getMapObjectZoom
-     * Returns:
-     * {Integer} The mapObject's current zoom, in Map Object format
-    getMapObjectZoom: function() {
-        return this.mapObject.getZoom();
-  // LonLat - Pixel Translation
-     * APIMethod: getMapObjectLonLatFromMapObjectPixel
-     * Parameters:
-     * moPixel - {Object} MapObject Pixel format
-     * Returns:
-     * {Object} MapObject LonLat translated from MapObject Pixel
-    getMapObjectLonLatFromMapObjectPixel: function(moPixel) {
-        return this.mapObject.fromContainerPixelToLatLng(moPixel);
-     * APIMethod: getMapObjectPixelFromMapObjectLonLat
-     * Parameters:
-     * moLonLat - {Object} MapObject LonLat format
-     * Returns:
-     * {Object} MapObject Pixel transtlated from MapObject LonLat
-    getMapObjectPixelFromMapObjectLonLat: function(moLonLat) {
-        return this.mapObject.fromLatLngToContainerPixel(moLonLat);
-  // Bounds
-     * APIMethod: getMapObjectZoomFromMapObjectBounds
-     * Parameters:
-     * moBounds - {Object} MapObject Bounds format
-     * Returns:
-     * {Object} MapObject Zoom for specified MapObject Bounds
-    getMapObjectZoomFromMapObjectBounds: function(moBounds) {
-        return this.mapObject.getBoundsZoomLevel(moBounds);
-     *       MapObject Primitives       *
-  // LonLat
-     * APIMethod: getLongitudeFromMapObjectLonLat
-     * Parameters:
-     * Returns:
-     * {Float} Longitude of the given MapObject LonLat
-    getLongitudeFromMapObjectLonLat: function(moLonLat) {
-        return this.sphericalMercator ?
-          this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lon :
-          moLonLat.lng();
-     * APIMethod: getLatitudeFromMapObjectLonLat
-     * Parameters:
-     * Returns:
-     * {Float} Latitude of the given MapObject LonLat
-    getLatitudeFromMapObjectLonLat: function(moLonLat) {
-        var lat = this.sphericalMercator ?
-          this.forwardMercator(moLonLat.lng(), moLonLat.lat()).lat :
-          moLonLat.lat();
-        return lat;
-     * APIMethod: getMapObjectLonLatFromLonLat
-     * Parameters:
-     * lon - {Float}
-     * lat - {Float}
-     * Returns:
-     * {Object} MapObject LonLat built from lon and lat params
-    getMapObjectLonLatFromLonLat: function(lon, lat) {
-        var gLatLng;
-        if(this.sphericalMercator) {
-            var lonlat = this.inverseMercator(lon, lat);
-            gLatLng = new GLatLng(lonlat.lat, lonlat.lon);
-        } else {
-            gLatLng = new GLatLng(lat, lon);
-        return gLatLng;
-  // Pixel
-     * APIMethod: getXFromMapObjectPixel
-     * Parameters:
-     * Returns:
-     * {Integer} X value of the MapObject Pixel
-    getXFromMapObjectPixel: function(moPixel) {
-        return moPixel.x;
-     * APIMethod: getYFromMapObjectPixel
-     * Parameters:
-     * Returns:
-     * {Integer} Y value of the MapObject Pixel
-    getYFromMapObjectPixel: function(moPixel) {
-        return moPixel.y;
-     * APIMethod: getMapObjectPixelFromXY
-     * Parameters:
-     * x - {Integer}
-     * y - {Integer}
-     * Returns:
-     * {Object} MapObject Pixel from x and y parameters
-    getMapObjectPixelFromXY: function(x, y) {
-        return new GPoint(x, y);
-    CLASS_NAME: "OpenLayers.Layer.Google"
     OpenLayers/Layer/Grid.js
@@ -28474,7 +14937,7 @@
         var minCols = Math.ceil(viewSize.w/this.tileSize.w) +
                       Math.max(1, 2 * this.buffer);
-        var extent = this.map.getMaxExtent();
+        var extent = this.maxExtent;
         var resolution = this.map.getResolution();
         var tileLayout = this.calculateGridLayout(bounds, extent, resolution);
@@ -28840,7 +15303,7 @@
      * {<OpenLayers.Bounds>} Bounds of the tile at the given pixel location.
     getTileBounds: function(viewPortPx) {
-        var maxExtent = this.map.getMaxExtent();
+        var maxExtent = this.maxExtent;
         var resolution = this.getResolution();
         var tileMapWidth = resolution * this.tileSize.w;
         var tileMapHeight = resolution * this.tileSize.h;
@@ -28861,2345 +15324,6 @@
     CLASS_NAME: "OpenLayers.Layer.Grid"
-    OpenLayers/Layer/MultiMap.js
- * Class: OpenLayers.Layer.MultiMap
- * Note that MultiMap does not fully support the sphericalMercator
- * option. See Ticket #953 for more details.
- * Inherits from:
-OpenLayers.Layer.MultiMap = OpenLayers.Class(
-  OpenLayers.Layer.EventPane, OpenLayers.Layer.FixedZoomLevels, {
-     * {Integer} 1
-    MIN_ZOOM_LEVEL: 1,
-     * {Integer} 17
-    MAX_ZOOM_LEVEL: 17,
-    RESOLUTIONS: [
-        9,
-        1.40625,
-        0.703125,
-        0.3515625,
-        0.17578125,
-        0.087890625,
-        0.0439453125,
-        0.02197265625,
-        0.010986328125,
-        0.0054931640625,
-        0.00274658203125,
-    type: null,
-     * Constructor: OpenLayers.Layer.MultiMap
-     * Parameters:
-     * name - {String}
-    initialize: function(name, options) {
-        arguments);
-            this.RESOLUTIONS.unshift(10);
-        try { //crash proofing
-            this.mapObject = new MultimapViewer(this.div);
-        } catch (e) { }
-     * Returns:
-     *          it working.
-            "getLayerWarning", {'layerType':"MM", 'layerLib':"MultiMap"}
-     * Parameters:
-        this.mapObject.goToPosition(center, zoom);
-     * Returns:
-        return this.mapObject.getCurrentPosition();
-     * Returns:
-        return this.mapObject.getZoomFactor();
-     * Parameters:
-     * Returns:
-        moPixel.x = moPixel.x - (this.map.getSize().w/2);
-        moPixel.y = moPixel.y - (this.map.getSize().h/2);
-        return this.mapObject.getMapPositionAt(moPixel);
-     * Parameters:
-     * Returns:
-        return this.mapObject.geoPosToContainerPixels(moLonLat);
-  // LonLat
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.lon, moLonLat.lat).lon :
-            moLonLat.lon;
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.lon, moLonLat.lat).lat :
-            moLonLat.lat;
-     * Parameters:
-     * lon - {Float}
-     * lat - {Float}
-     * Returns:
-        var mmLatLon;
-            mmLatLon = new MMLatLon(lonlat.lat, lonlat.lon);
-        } else {
-            mmLatLon = new MMLatLon(lat, lon);
-        return mmLatLon;
-  // Pixel
-     * Parameters:
-     * Returns:
-        return moPixel.x;
-     * Parameters:
-     * Returns:
-        return moPixel.y;
-     * Parameters:
-     * x - {Integer}
-     * y - {Integer}
-     * Returns:
-        return new MMPoint(x, y);
-    CLASS_NAME: "OpenLayers.Layer.MultiMap"
-    OpenLayers/Layer/Text.js
- * Class: OpenLayers.Layer.Text
- * This layer creates markers given data in a text file.  The <location>
- *     property of the layer (specified as a property of the options argument
- *     in the <OpenLayers.Layer.Text> constructor) points to a tab delimited
- *     file with data used to create markers.
- * The first row of the data file should be a header line with the column names
- *     of the data. Each column should be delimited by a tab space. The
- *     possible columns are:
- *      - *point* lat,lon of the point where a marker is to be placed
- *      - *lat*  Latitude of the point where a marker is to be placed
- *      - *lon*  Longitude of the point where a marker is to be placed
- *      - *iconURL* URL of marker icon to use.
- *      - *iconSize* Size of Icon to use.
- *      - *iconOffset* Where the top-left corner of the icon is to be placed
- *            relative to the latitude and longitude of the point.
- *      - *title* The text of the 'title' is placed inside an 'h2' marker
- *            inside a popup, which opens when the marker is clicked.
- *      - *description* The text of the 'description' is placed below the h2
- *            in the popup. this can be plain text or HTML.
- * Example text file:
- * (code)
- * lat	lon	title	description	iconSize	iconOffset	icon
- * 10	20	title	description	21,25		-10,-25		http://www.openlayers.org/dev/img/marker.png
- * (end)
- * Inherits from:
-OpenLayers.Layer.Text = OpenLayers.Class(OpenLayers.Layer.Markers, {
-     * APIProperty: location
-     * {String} URL of text file.  Must be specified in the "options" argument
-     *   of the constructor. Can not be changed once passed in.
-    features: null,
-     * Constructor: OpenLayers.Layer.Text
-     * Create a text layer.
-     * Parameters:
-     * name - {String}
-     * options - {Object} Object with properties to be set on the layer.
-     *     Must include <location> property.
-        this.features = new Array();
-     * APIMethod: destroy
-     * Method: loadText
-     * Start the load of the Text data. Don't do this when we first add the layer,
-    loadText: function() {
-            if (this.location != null) {
-                var onFail = function(e) {
-                                   this, this.parseData, onFail);
-     * Method: moveTo
-     * If layer is visible and Text has not been loaded, load Text.
-     * Parameters:
-            this.loadText();
-     * Parameters:
-        var text = ajaxRequest.responseText;
-        var options = {};
-        var parser = new OpenLayers.Format.Text(options);
-        features = parser.read(text);
-            var data = {};
-            var location;
-            var iconSize, iconOffset;
-            location = new OpenLayers.LonLat(feature.geometry.x,
-                                             feature.geometry.y);
-            if (feature.style.graphicWidth
-                && feature.style.graphicHeight) {
-                iconSize = new OpenLayers.Size(
-                    feature.style.graphicWidth,
-                    feature.style.graphicHeight);
-            // FIXME: At the moment, we only use this if we have an
-            // externalGraphic, because icon has no setOffset API Method.
-            if (feature.style.graphicXOffset
-                && feature.style.graphicYOffset) {
-                iconOffset = new OpenLayers.Pixel(
-                    feature.style.graphicXOffset,
-                    feature.style.graphicYOffset);
-            if (feature.style.externalGraphic != null) {
-                data.icon = new OpenLayers.Icon(feature.style.externalGraphic,
-                                                iconSize,
-                                                iconOffset);
-            } else {
-                data.icon = OpenLayers.Marker.defaultIcon();
-                //allows for the case where the image url is not
-                // specified but the size is. use a default icon
-                // but change the size
-                if (iconSize != null) {
-                    data.icon.setSize(iconSize);
-            if ((feature.attributes.title != null)
-                && (feature.attributes.description != null)) {
-                    '<h2>'+feature.attributes.title+'</h2>' +
-                    '<p>'+feature.attributes.description+'</p>';
-            data['overflow'] = feature.attributes.overflow || "auto";
-            var markerFeature = new OpenLayers.Feature(this, location, data);
-            this.features.push(markerFeature);
-            var marker = markerFeature.createMarker();
-              marker.events.register('click', markerFeature, this.markerClick);
-     * Property: markerClick
-     * Parameters:
-     * evt - {Event}
-            this.layer.map.addPopup(this.createPopup());
-    CLASS_NAME: "OpenLayers.Layer.Text"
-    OpenLayers/Layer/VirtualEarth.js
- * Class: OpenLayers.Layer.VirtualEarth
- * Inherits from:
-OpenLayers.Layer.VirtualEarth = OpenLayers.Class(
-     * {Integer} 1
-     * {Integer} 17
-    RESOLUTIONS: [
-        1.40625,
-        0.703125,
-        0.3515625,
-        0.17578125,
-        0.087890625,
-        0.0439453125,
-        0.02197265625,
-        0.010986328125,
-        0.0054931640625,
-        0.00274658203125,
-     * {VEMapType}
-    type: null,
-     * Constructor: OpenLayers.Layer.VirtualEarth
-     * Parameters:
-     * name - {String}
-        arguments);
-        // create div and set to same size as map
-        var veDiv = OpenLayers.Util.createDiv(this.name);
-        var sz = this.map.getSize();
-        veDiv.style.width = sz.w;
-        veDiv.style.height = sz.h;
-        this.div.appendChild(veDiv);
-        try { // crash prevention
-            this.mapObject = new VEMap(this.name);
-        } catch (e) { }
-        if (this.mapObject != null) {
-            try { // this is to catch a Mozilla bug without falling apart
-                // The fourth argument is whether the map is 'fixed' -- not
-                // draggable. See:
-                // http://blogs.msdn.com/virtualearth/archive/2007/09/28/locking-a-virtual-earth-map.aspx
-                this.mapObject.LoadMap(null, null, this.type, true);
-                this.mapObject.AttachEvent("onmousedown", function() {return true; });
-            } catch (e) { }
-            this.mapObject.HideDashboard();
-        //can we do smooth panning? this is an unpublished method, so we need
-        // to be careful
-        if ( !this.mapObject ||
-             !this.mapObject.vemapcontrol ||
-             !this.mapObject.vemapcontrol.PanMap ||
-             (typeof this.mapObject.vemapcontrol.PanMap != "function")) {
-     * Returns:
-     * {String} String with information on why layer is broken, how to get
-     *          it working.
-    getWarningHTML:function() {
-            "getLayerWarning", {'layerType':'VE', 'layerLib':'VirtualEarth'}
-     * Parameters:
-        this.mapObject.SetCenterAndZoom(center, zoom);
-     * Returns:
-        return this.mapObject.GetCenter();
-     * Parameters:
-     * dX - {Integer}
-     * dY - {Integer}
-        this.mapObject.vemapcontrol.PanMap(dX, -dY);
-     * Returns:
-        return this.mapObject.GetZoomLevel();
-     * Parameters:
-     * Returns:
-        return this.mapObject.PixelToLatLong(moPixel.x, moPixel.y);
-     * Parameters:
-     * Returns:
-        return this.mapObject.LatLongToPixel(moLonLat);
-  // LonLat
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.Longitude, moLonLat.Latitude).lon :
-            moLonLat.Longitude;
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.Longitude, moLonLat.Latitude).lat :
-            moLonLat.Latitude;
-     * Parameters:
-     * lon - {Float}
-     * lat - {Float}
-     * Returns:
-        var veLatLong;
-            veLatLong = new VELatLong(lonlat.lat, lonlat.lon);
-        } else {
-            veLatLong = new VELatLong(lat, lon);
-        return veLatLong;
-  // Pixel
-     * Parameters:
-     * Returns:
-        return moPixel.x;
-     * Parameters:
-     * Returns:
-        return moPixel.y;
-     * Parameters:
-     * x - {Integer}
-     * y - {Integer}
-     * Returns:
-        return new Msn.VE.Pixel(x, y);
-    CLASS_NAME: "OpenLayers.Layer.VirtualEarth"
-    OpenLayers/Layer/Yahoo.js
- * Class: OpenLayers.Layer.Yahoo
- * Inherits from:
-OpenLayers.Layer.Yahoo = OpenLayers.Class(
-     * {Integer} 0
-     * {Integer} 15
-    MAX_ZOOM_LEVEL: 15,
-    RESOLUTIONS: [
-        1.40625,
-        0.703125,
-        0.3515625,
-        0.17578125,
-        0.087890625,
-        0.0439453125,
-        0.02197265625,
-        0.010986328125,
-        0.0054931640625,
-        0.00274658203125,
-     * {YahooMapType}
-    type: null,
-     * cause all interactions with the map to be in the actual map projection,
-     * which allows support for vector drawing, overlaying other maps, etc.
-     * Constructor: OpenLayers.Layer.Yahoo
-     * Parameters:
-     * name - {String}
-        arguments);
-        try { //do not crash!
-            var size = this.getMapObjectSizeFromOLSize(this.map.getSize());
-            this.mapObject = new YMap(this.div, this.type, size);
-            this.mapObject.disableKeyControls();
-            this.mapObject.disableDragMap();
-            //can we do smooth panning? (moveByXY is not an API function)
-            if ( !this.mapObject.moveByXY ||
-                 (typeof this.mapObject.moveByXY != "function" ) ) {
-        } catch(e) {}
-     * Method: onMapResize
-        try {
-            this.mapObject.resizeTo(size);
-        } catch(e) {}
-     * Overridden from EventPane because we need to remove this yahoo event
-     *     pane which prohibits our drag and drop, and we can only do this
-     *     once the map has been loaded and centered.
-     * Parameters:
-        this.map.events.register("moveend", this, this.fixYahooEventPane);
-     * Method: fixYahooEventPane
-     * The map has been centered, so the mysterious yahoo eventpane has been
-     *     added. we remove it so that it doesnt mess with *our* event pane.
-    fixYahooEventPane: function() {
-        var yahooEventPane = OpenLayers.Util.getElement("ygddfdiv");
-        if (yahooEventPane != null) {
-            if (yahooEventPane.parentNode != null) {
-                yahooEventPane.parentNode.removeChild(yahooEventPane);
-                                       this.fixYahooEventPane);
-     * Returns:
-     *          it working.
-            "getLayerWarning", {'layerType':'Yahoo', 'layerLib':'Yahoo'}
-  /*             Translation Functions                    */
-     * APIMethod: getOLZoomFromMapObjectZoom
-     * Parameters:
-     * gZoom - {Integer}
-     * Returns:
-     * {Integer} An OpenLayers Zoom level, translated from the passed in gZoom
-        var zoom = null;
-            zoom = OpenLayers.Layer.FixedZoomLevels.prototype.getOLZoomFromMapObjectZoom.apply(this, [moZoom]);
-            zoom = 18 - zoom;
-        return zoom;
-     * APIMethod: getMapObjectZoomFromOLZoom
-     * Parameters:
-     * Returns:
-        var zoom = null;
-            zoom = OpenLayers.Layer.FixedZoomLevels.prototype.getMapObjectZoomFromOLZoom.apply(this, [olZoom]);
-            zoom = 18 - zoom;
-        return zoom;
-     * Parameters:
-        this.mapObject.drawZoomAndCenter(center, zoom);
-     * Returns:
-        return this.mapObject.getCenterLatLon();
-     * Parameters:
-     * dX - {Integer}
-     * dY - {Integer}
-        this.mapObject.moveByXY({
-            'x': -dX,
-            'y': dY
-     * Returns:
-        return this.mapObject.getZoomLevel();
-     * Parameters:
-     * Returns:
-        return this.mapObject.convertXYLatLon(moPixel);
-     * Parameters:
-     * Returns:
-        return this.mapObject.convertLatLonXY(moLonLat);
-  // LonLat
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.Lon, moLonLat.Lat).lon :
-            moLonLat.Lon;
-     * Parameters:
-     * Returns:
-            this.forwardMercator(moLonLat.Lon, moLonLat.Lat).lat :
-            moLonLat.Lat;
-     * Parameters:
-     * lon - {Float}
-     * lat - {Float}
-     * Returns:
-        var yLatLong;
-            yLatLong = new YGeoPoint(lonlat.lat, lonlat.lon);
-        } else {
-            yLatLong = new YGeoPoint(lat, lon);
-        return yLatLong;
-  // Pixel
-     * Parameters:
-     * Returns:
-        return moPixel.x;
-     * Parameters:
-     * Returns:
-        return moPixel.y;
-     * Parameters:
-     * x - {Integer}
-     * y - {Integer}
-     * Returns:
-        return new YCoordPoint(x, y);
-  // Size
-     * APIMethod: getMapObjectSizeFromOLSize
-     * Parameters:
-     * olSize - {<OpenLayers.Size>}
-     * Returns:
-     * {Object} MapObject Size from olSize parameter
-    getMapObjectSizeFromOLSize: function(olSize) {
-        return new YSize(olSize.w, olSize.h);
-    CLASS_NAME: "OpenLayers.Layer.Yahoo"
-    OpenLayers/Style.js
- * @requires OpenLayers/Util.js
- * Class: OpenLayers.Style
- * This class represents a UserStyle obtained
- *     from a SLD, containing styling rules.
-OpenLayers.Style = OpenLayers.Class({
-     * APIProperty: name
-     * {String}
-    name: null,
-     * Property: title
-     * {String} Title of this style (set if included in SLD)
-    title: null,
-     * Property: description
-     * {String} Description of this style (set if abstract is included in SLD)
-    description: null,
-     * APIProperty: layerName
-     * {<String>} name of the layer that this style belongs to, usually
-     * according to the NamedLayer attribute of an SLD document.
-    layerName: null,
-     * APIProperty: isDefault
-     * {Boolean}
-    isDefault: false,
-     * Property: rules
-     * {Array(<OpenLayers.Rule>)}
-    rules: null,
-     * Property: context
-     * {Object} An optional object with properties that symbolizers' property
-     * values should be evaluatad against. If no context is specified,
-     * feature.attributes will be used
-    context: null,
-     * Property: defaultStyle
-     * {Object} hash of style properties to use as default for merging
-     * rule-based style symbolizers onto. If no rules are defined,
-     * createSymbolizer will return this style.
-    defaultStyle: null,
-     * Property: propertyStyles
-     * {Hash of Boolean} cache of style properties that need to be parsed for
-     * propertyNames. Property names are keys, values won't be used.
-    propertyStyles: null,
-     * Constructor: OpenLayers.Style
-     * Creates a UserStyle.
-     * Parameters:
-     * style        - {Object} Optional hash of style properties that will be
-     *                used as default style for this style object. This style
-     *                applies if no rules are specified. Symbolizers defined in
-     *                rules will extend this default style.
-     * options      - {Object} An optional object with properties to set on the
-     *                userStyle
-     * Return:
-     * {<OpenLayers.Style>}
-    initialize: function(style, options) {
-        this.rules = [];
-        // use the default style from OpenLayers.Feature.Vector if no style
-        // was given in the constructor
-        this.setDefaultStyle(style ||
-                OpenLayers.Feature.Vector.style["default"]);
-        OpenLayers.Util.extend(this, options);
-     * nullify references to prevent circular references and memory leaks
-        for (var i=0; i<this.rules.length; i++) {
-            this.rules[i].destroy();
-            this.rules[i] = null;
-        this.rules = null;
-        this.defaultStyle = null;
-     * Method: createSymbolizer
-     * creates a style by applying all feature-dependent rules to the base
-     * style.
-     * Parameters:
-     * feature - {<OpenLayers.Feature>} feature to evaluate rules for
-     * Returns:
-     * {Object} symbolizer hash
-    createSymbolizer: function(feature) {
-        var style = this.createLiterals(
-            OpenLayers.Util.extend({}, this.defaultStyle), feature);
-        var rules = this.rules;
-        var rule, context;
-        var elseRules = [];
-        var appliedRules = false;
-        for(var i=0; i<rules.length; i++) {
-            rule = rules[i];
-            // does the rule apply?
-            var applies = rule.evaluate(feature);
-            if(applies) {
-                if(rule instanceof OpenLayers.Rule && rule.elseFilter) {
-                    elseRules.push(rule);
-                } else {
-                    appliedRules = true;
-                    this.applySymbolizer(rule, style, feature);
-        // if no other rules apply, apply the rules with else filters
-        if(appliedRules == false && elseRules.length > 0) {
-            for(var i=0; i<elseRules.length; i++) {
-                this.applySymbolizer(elseRules[i], style, feature);
-        // don't display if there were rules but none applied
-        if(rules.length > 0 && appliedRules == false) {
-            style.display = "none";
-        } else {
-            style.display = "";
-        return style;
-     * Method: applySymbolizer
-     * Parameters:
-     * rule - {OpenLayers.Rule}
-     * feature - {<OpenLayer.Feature.Vector>}
-     * Returns:
-     * {Object} A style with new symbolizer applied.
-    applySymbolizer: function(rule, style, feature) {
-        var symbolizerPrefix = feature.geometry ?
-                this.getSymbolizerPrefix(feature.geometry) :
-                OpenLayers.Style.SYMBOLIZER_PREFIXES[0];
-        var symbolizer = rule.symbolizer[symbolizerPrefix] || rule.symbolizer;
-        // merge the style with the current style
-        return this.createLiterals(
-                OpenLayers.Util.extend(style, symbolizer), feature);
-     * Method: createLiterals
-     * creates literals for all style properties that have an entry in
-     * <this.propertyStyles>.
-     * Parameters:
-     * style   - {Object} style to create literals for. Will be modified
-     *           inline.
-     * feature - {Object}
-     * Returns:
-     * {Object} the modified style
-    createLiterals: function(style, feature) {
-        var context = this.context || feature.attributes || feature.data;
-        for (var i in this.propertyStyles) {
-            style[i] = OpenLayers.Style.createLiteral(style[i], context, feature);
-        return style;
-     * Method: findPropertyStyles
-     * Looks into all rules for this style and the defaultStyle to collect
-     * all the style hash property names containing ${...} strings that have
-     * to be replaced using the createLiteral method before returning them.
-     * Returns:
-     * {Object} hash of property names that need createLiteral parsing. The
-     * name of the property is the key, and the value is true;
-    findPropertyStyles: function() {
-        var propertyStyles = {};
-        // check the default style
-        var style = this.defaultStyle;
-        this.addPropertyStyles(propertyStyles, style);
-        // walk through all rules to check for properties in their symbolizer
-        var symbolizer, value;
-        for (var i=0; i<rules.length; i++) {
-            var symbolizer = rules[i].symbolizer;
-            for (var key in symbolizer) {
-                value = symbolizer[key];
-                if (typeof value == "object") {
-                    // symbolizer key is "Point", "Line" or "Polygon"
-                    this.addPropertyStyles(propertyStyles, value);
-                } else {
-                    // symbolizer is a hash of style properties
-                    this.addPropertyStyles(propertyStyles, symbolizer);
-                    break;
-        return propertyStyles;
-     * Method: addPropertyStyles
-     * Parameters:
-     * propertyStyles - {Object} hash to add new property styles to. Will be
-     *                  modified inline
-     * symbolizer     - {Object} search this symbolizer for property styles
-     * Returns:
-     * {Object} propertyStyles hash
-    addPropertyStyles: function(propertyStyles, symbolizer) {
-        var property;
-            property = symbolizer[key];
-            if (typeof property == "string" &&
-                    property.match(/\$\{\w+\}/)) {
-                propertyStyles[key] = true;
-     * APIMethod: addRules
-     * Adds rules to this style.
-     * Parameters:
-     * rules - {Array(<OpenLayers.Rule>)}
-    addRules: function(rules) {
-        this.rules = this.rules.concat(rules);
-        this.propertyStyles = this.findPropertyStyles();
-     * APIMethod: setDefaultStyle
-     * Sets the default style for this style object.
-     * Parameters:
-     * style - {Object} Hash of style properties
-    setDefaultStyle: function(style) {
-        this.defaultStyle = style;
-     * Method: getSymbolizerPrefix
-     * Returns the correct symbolizer prefix according to the
-     * geometry type of the passed geometry
-     * Parameters:
-     * geometry {<OpenLayers.Geometry>}
-     * Returns:
-     * {String} key of the according symbolizer
-    getSymbolizerPrefix: function(geometry) {
-        var prefixes = OpenLayers.Style.SYMBOLIZER_PREFIXES;
-        for (var i=0; i<prefixes.length; i++) {
-            if (geometry.CLASS_NAME.indexOf(prefixes[i]) != -1) {
-                return prefixes[i];
-    CLASS_NAME: "OpenLayers.Style"
- * Function: createLiteral
- * converts a style value holding a combination of PropertyName and Literal
- * into a Literal, taking the property values from the passed features.
- * Parameters:
- * value - {String} value to parse. If this string contains a construct like
- *         "foo ${bar}", then "foo " will be taken as literal, and "${bar}"
- *         will be replaced by the value of the "bar" attribute of the passed
- *         feature.
- * context - {Object} context to take attribute values from
- * feature - {OpenLayers.Feature.Vector} The feature that will be passed
- *     to <OpenLayers.String.format> for evaluating functions in the context.
- * Returns:
- * {String} the parsed value. In the example of the value parameter above, the
- * result would be "foo valueOfBar", assuming that the passed feature has an
- * attribute named "bar" with the value "valueOfBar".
-OpenLayers.Style.createLiteral = function(value, context, feature) {
-    if (typeof value == "string" && value.indexOf("${") != -1) {
-        value = OpenLayers.String.format(value, context, [feature]);
-        value = (isNaN(value) || !value) ? value : parseFloat(value);
-    return value;
- * Constant: OpenLayers.Style.SYMBOLIZER_PREFIXES
- * {Array} prefixes of the sld symbolizers. These are the
- * same as the main geometry types
-OpenLayers.Style.SYMBOLIZER_PREFIXES = ['Point', 'Line', 'Polygon'];
-    OpenLayers/Control/ModifyFeature.js
-/* Copyright (c) 2006 MetaCarta, Inc., published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt
- * for the full text of the license. */
- * @requires OpenLayers/Control/DragFeature.js
- * @requires OpenLayers/Control/SelectFeature.js
- * @requires OpenLayers/Handler/Keyboard.js
- * Class: OpenLayers.Control.ModifyFeature
- * Control to modify features.  When activated, a click renders the vertices
- *     of a feature - these vertices can then be dragged.  By default, the
- *     delete key will delete the vertex under the mouse.  New features are
- *     added by dragging "virtual vertices" between vertices.  Create a new
- *     control with the <OpenLayers.Control.ModifyFeature> constructor.
- * Inherits From:
- *  - <OpenLayers.Control>
-OpenLayers.Control.ModifyFeature = OpenLayers.Class(OpenLayers.Control, {
-     * APIProperty: geometryTypes
-     * {Array(String)} To restrict modification to a limited set of geometry
-     *     types, send a list of strings corresponding to the geometry class
-     *     names.
-    clickout: true,
-    toggle: true,
-     * Property: layer
-     * {<OpenLayers.Layer.Vector>}
-    layer: null,
-     * {<OpenLayers.Feature.Vector>} Feature currently available for modification.
-    feature: null,
-     * Property: vertices
-     * {Array(<OpenLayers.Feature.Vector>)} Verticies currently available
-     *     for dragging.
-    vertices: null,
-     * Property: virtualVertices
-     * {Array(<OpenLayers.Feature.Vector>)} Virtual vertices in the middle
-     *     of each edge.
-    virtualVertices: null,
-     * Property: selectControl
-     * {<OpenLayers.Control.SelectFeature>}
-    selectControl: null,
-     * Property: dragControl
-     * {<OpenLayers.Control.DragFeature>}
-    dragControl: null,
-     * Property: handlers
-     * {Object}
-    handlers: null,
-     * APIProperty: deleteCodes
-     * {Array(Integer)} Keycodes for deleting verticies.  Set to null to disable
-     *     vertex deltion by keypress.  If non-null, keypresses with codes
-     *     in this array will delete vertices under the mouse. Default
-     *     is 46 and 100, the 'delete' and lowercase 'd' keys.
-    deleteCodes: null,
-     * APIProperty: virtualStyle
-     * {Object} A symbolizer to be used for virtual vertices.
-    virtualStyle: null,
-     * APIProperty: mode
-     * {Integer} Bitfields specifying the modification mode. Defaults to
-     *      OpenLayers.Control.ModifyFeature.RESHAPE. To set the mode to a
-     *      combination of options, use the | operator. or example, to allow
-     *      the control to both resize and rotate features, use the following
-     *      syntax
-     * (code)
-     * control.mode = OpenLayers.Control.ModifyFeature.RESIZE |
-     *                OpenLayers.Control.ModifyFeature.ROTATE;
-     *  (end)
-    mode: null,
-     * Property: radiusHandle
-     * {<OpenLayers.Feature.Vector>} A handle for rotating/resizing a feature.
-    radiusHandle: null,
-     * Property: dragHandle
-     * {<OpenLayers.Feature.Vector>} A handle for dragging a feature.
-    dragHandle: null,
-     * APIProperty: onModificationStart
-     * {Function} *Deprecated*.  Register for "beforefeaturemodified" instead.
-     *     The "beforefeaturemodified" event is triggered on the layer before
-     *     any modification begins.
-     * Optional function to be called when a feature is selected
-     *     to be modified. The function should expect to be called with a
-     *     feature.  This could be used for example to allow to lock the
-     *     feature on server-side.
-    onModificationStart: function() {},
-     * {Function} *Deprecated*.  Register for "featuremodified" instead.
-     *     The "featuremodified" event is triggered on the layer with each
-     *     feature modification.
-     * Optional function to be called when a feature has been
-     *     modified.  The function should expect to be called with a feature.
-    onModification: function() {},
-     * APIProperty: onModificationEnd
-     * {Function} *Deprecated*.  Register for "afterfeaturemodified" instead.
-     *     The "afterfeaturemodified" event is triggered on the layer after
-     *     a feature has been modified.
-     * Optional function to be called when a feature is finished
-     *     being modified.  The function should expect to be called with a
-     *     feature.
-    onModificationEnd: function() {},
-     * Constructor: OpenLayers.Control.ModifyFeature
-     * Create a new modify feature control.
-     * Parameters:
-     * layer - {<OpenLayers.Layer.Vector>} Layer that contains features that
-     *     will be modified.
-     * options - {Object} Optional object whose properties will be set on the
-     *     control.
-    initialize: function(layer, options) {
-        this.vertices = [];
-        this.virtualVertices = [];
-        this.virtualStyle = OpenLayers.Util.extend({},
-            this.layer.style || this.layer.styleMap.createSymbolizer());
-        this.virtualStyle.fillOpacity = 0.3;
-        this.virtualStyle.strokeOpacity = 0.3;
-        this.deleteCodes = [46, 100];
-        this.mode = OpenLayers.Control.ModifyFeature.RESHAPE;
-        OpenLayers.Control.prototype.initialize.apply(this, [options]);
-        if(!(this.deleteCodes instanceof Array)) {
-            this.deleteCodes = [this.deleteCodes];
-        var control = this;
-        // configure the select control
-        var selectOptions = {
-            geometryTypes: this.geometryTypes,
-            clickout: this.clickout,
-            toggle: this.toggle
-        this.selectControl = new OpenLayers.Control.SelectFeature(
-            layer, selectOptions
-        this.layer.events.on({
-            "featureselected": this.selectFeature,
-            "featureunselected": this.unselectFeature,
-            scope: this
-        // configure the drag control
-        var dragOptions = {
-            geometryTypes: ["OpenLayers.Geometry.Point"],
-            snappingOptions: this.snappingOptions,
-            onStart: function(feature, pixel) {
-                control.dragStart.apply(control, [feature, pixel]);
-            onDrag: function(feature) {
-                control.dragVertex.apply(control, [feature]);
-            onComplete: function(feature) {
-                control.dragComplete.apply(control, [feature]);
-        this.dragControl = new OpenLayers.Control.DragFeature(
-            layer, dragOptions
-        // configure the keyboard handler
-        var keyboardOptions = {
-            keypress: this.handleKeypress
-        this.handlers = {
-            keyboard: new OpenLayers.Handler.Keyboard(this, keyboardOptions)
-     * Take care of things that are not handled in superclass.
-        this.layer.events.un({
-            scope: this
-        this.layer = null;
-        this.selectControl.destroy();
-        this.dragControl.destroy();
-        OpenLayers.Control.prototype.destroy.apply(this, []);
-     * APIMethod: activate
-     * Activate the control and the feature handler.
-     * Returns:
-     * {Boolean} Successfully activated the control and feature handler.
-    activate: function() {
-        return (this.selectControl.activate() &&
-                this.handlers.keyboard.activate() &&
-                OpenLayers.Control.prototype.activate.apply(this, arguments));
-     * APIMethod: deactivate
-     * Deactivate the controls.
-     * Returns:
-     * {Boolean} Successfully deactivated the control.
-    deactivate: function() {
-        var deactivated = false;
-        // the return from the controls is unimportant in this case
-        if(OpenLayers.Control.prototype.deactivate.apply(this, arguments)) {
-            this.layer.removeFeatures(this.vertices);
-            this.layer.removeFeatures(this.virtualVertices);
-            this.dragControl.deactivate();
-            if(this.feature && this.feature.geometry) {
-                this.selectControl.unselect.apply(this.selectControl,
-                                                  [this.feature]);
-            this.selectControl.deactivate();
-            this.handlers.keyboard.deactivate();
-            deactivated = true;
-        return deactivated;
-     * Method: selectFeature
-     * Called when the select feature control selects a feature.
-     * Parameters:
-     * object - {Object} Object with a feature property referencing the
-     *     selected feature.
-    selectFeature: function(object) {
-        this.feature = object.feature;
-        this.resetVertices();
-        this.dragControl.activate();
-        this.onModificationStart(this.feature);
-        this.layer.events.triggerEvent("beforefeaturemodified",
-                                       {feature: this.feature});
-     * Method: unselectFeature
-     * Called when the select feature control unselects a feature.
-     * Parameters:
-     *     unselected feature.
-    unselectFeature: function(object) {
-        this.layer.destroyFeatures(this.virtualVertices);
-        if(this.dragHandle) {
-            this.layer.destroyFeatures([this.dragHandle]);
-            delete this.dragHandle;
-        if(this.radiusHandle) {
-            this.layer.destroyFeatures([this.radiusHandle]);
-            delete this.radiusHandle;
-        this.feature = null;
-        this.onModificationEnd(object.feature);
-        this.layer.events.triggerEvent("afterfeaturemodified",
-                                       {feature: object.feature});
-     * Method: dragStart
-     * Called by the drag feature control with before a feature is dragged.
-     *     This method is used to differentiate between points and vertices
-     *     of higher order geometries.  This respects the <geometryTypes>
-     *     property and forces a select of points when the drag control is
-     *     already active (and stops events from propagating to the select
-     *     control).
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The point or vertex about to be
-     *     dragged.
-     * pixel - {<OpenLayers.Pixel>} Pixel location of the mouse event.
-    dragStart: function(feature, pixel) {
-        // only change behavior if the feature is not in the vertices array
-        if(feature != this.feature && !feature.geometry.parent &&
-           feature != this.dragHandle && feature != this.radiusHandle) {
-            if(this.feature) {
-                // unselect the currently selected feature
-                this.selectControl.clickFeature.apply(this.selectControl,
-                                                      [this.feature]);
-            // check any constraints on the geometry type
-            if(this.geometryTypes == null ||
-               OpenLayers.Util.indexOf(this.geometryTypes,
-                                       feature.geometry.CLASS_NAME) != -1) {
-                // select the point
-                                                      [feature]);
-                 * TBD: These lines improve workflow by letting the user
-                 *     immediately start dragging after the mouse down.
-                 *     However, it is very ugly to be messing with controls
-                 *     and their handlers in this way.  I'd like a better
-                 *     solution if the workflow change is necessary.
-                // prepare the point for dragging
-                this.dragControl.overFeature.apply(this.dragControl,
-                                                   [feature]);
-                this.dragControl.lastPixel = pixel;
-                this.dragControl.handlers.drag.started = true;
-                this.dragControl.handlers.drag.start = pixel;
-                this.dragControl.handlers.drag.last = pixel;
-     * Method: dragVertex
-     * Called by the drag feature control with each drag move of a vertex.
-     * Parameters:
-     * vertex - {<OpenLayers.Feature.Vector>} The vertex being dragged.
-    dragVertex: function(vertex) {
-         * Five cases:
-         * 1) dragging a simple point
-         * 2) dragging a virtual vertex
-         * 3) dragging a drag handle
-         * 4) dragging a radius handle
-         * 5) dragging a real vertex
-        if(this.feature.geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
-            // dragging a simple point
-            if(this.feature != vertex) {
-                this.feature = vertex;
-        } else {
-            if(vertex._index) {
-                // dragging a virtual vertex
-                vertex.geometry.parent.addComponent(vertex.geometry,
-                                                    vertex._index);
-                // move from virtual to real vertex
-                delete vertex._index;
-                OpenLayers.Util.removeItem(this.virtualVertices, vertex);
-                this.vertices.push(vertex);
-            } else if(vertex == this.dragHandle) {
-                // dragging a drag handle
-                    this.radiusHandle = null;
-            // dragging a radius handle - no special treatment
-            // dragging a real vertex - no special treatment
-            if(this.virtualVertices.length > 0) {
-            this.layer.drawFeature(this.feature, this.selectControl.renderIntent);
-        // keep the vertex on top so it gets the mouseout after dragging
-        // this should be removed in favor of an option to draw under or
-        // maintain node z-index
-        this.layer.drawFeature(vertex);
-     * Method: dragComplete
-     * Called by the drag feature control when the feature dragging is complete.
-     * Parameters:
-    dragComplete: function(vertex) {
-        this.onModification(this.feature);
-        this.layer.events.triggerEvent("featuremodified",
-     * Method: resetVertices
-    resetVertices: function() {
-        // if coming from a drag complete we're about to destroy the vertex
-        // that was just dragged. For that reason, the drag feature control
-        // will never detect a mouse-out on that vertex, meaning that the drag
-        // handler won't be deactivated. This can cause errors because the drag
-        // feature control still has a feature to drag but that feature is
-        // destroyed. To prevent this, we call outFeature on the drag feature
-        // control if the control actually has a feature to drag.
-        if(this.dragControl.feature) {
-            this.dragControl.outFeature(this.dragControl.feature);
-        if(this.vertices.length > 0) {
-            this.dragHandle = null;
-           this.feature.geometry.CLASS_NAME != "OpenLayers.Geometry.Point") {
-            if((this.mode & OpenLayers.Control.ModifyFeature.DRAG)) {
-                this.collectDragHandle();
-            if((this.mode & (OpenLayers.Control.ModifyFeature.ROTATE |
-                             OpenLayers.Control.ModifyFeature.RESIZE))) {
-                this.collectRadiusHandle();
-            if((this.mode & OpenLayers.Control.ModifyFeature.RESHAPE)) {
-                this.collectVertices();
-     * Method: handleKeypress
-     * Called by the feature handler on keypress.  This is used to delete
-     *     vertices and point features.  If the <deleteCode> property is set,
-     *     vertices and points will be deleted when a feature is selected
-     *     for modification and the mouse is over a vertex.
-     * Parameters:
-     * {Integer} Key code corresponding to the keypress event.
-    handleKeypress: function(code) {
-        // check for delete key
-           OpenLayers.Util.indexOf(this.deleteCodes, code) != -1) {
-            var vertex = this.dragControl.feature;
-            if(vertex &&
-               OpenLayers.Util.indexOf(this.vertices, vertex) != -1 &&
-               !this.dragControl.handlers.drag.dragging &&
-               vertex.geometry.parent) {
-                // remove the vertex
-                vertex.geometry.parent.removeComponent(vertex.geometry);
-                                       this.selectControl.renderIntent);
-     * Method: collectVertices
-     * Collect the vertices from the modifiable feature's geometry and push
-     *     them on to the control's vertices array.
-    collectVertices: function() {
-        function collectComponentVertices(geometry) {
-            var i, vertex, component;
-            if(geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
-                vertex = new OpenLayers.Feature.Vector(geometry);
-                control.vertices.push(vertex);
-            } else {
-                var numVert = geometry.components.length;
-                if(geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing") {
-                    numVert -= 1;
-                for(i=0; i<numVert; ++i) {
-                    component = geometry.components[i];
-                    if(component.CLASS_NAME == "OpenLayers.Geometry.Point") {
-                        vertex = new OpenLayers.Feature.Vector(component);
-                    } else {
-                        collectComponentVertices(component);
-                // add virtual vertices in the middle of each edge
-                if(geometry.CLASS_NAME != "OpenLayers.Geometry.MultiPoint") {
-                    for(i=0; i<geometry.components.length-1; ++i) {
-                        var prevVertex = geometry.components[i];
-                        var nextVertex = geometry.components[i + 1];
-                        if(prevVertex.CLASS_NAME == "OpenLayers.Geometry.Point" &&
-                           nextVertex.CLASS_NAME == "OpenLayers.Geometry.Point") {
-                            var x = (prevVertex.x + nextVertex.x) / 2;
-                            var y = (prevVertex.y + nextVertex.y) / 2;
-                            var point = new OpenLayers.Feature.Vector(
-                                new OpenLayers.Geometry.Point(x, y),
-                                null, control.virtualStyle
-                            // set the virtual parent and intended index
-                            point.geometry.parent = geometry;
-                            point._index = i + 1;
-                            control.virtualVertices.push(point);
-        collectComponentVertices.call(this, this.feature.geometry);
-        this.layer.addFeatures(this.vertices, {silent: true});
-        this.layer.addFeatures(this.virtualVertices, {silent: true});
-     * Method: collectDragHandle
-     * Collect the drag handle for the selected geometry.
-    collectDragHandle: function() {
-        var geometry = this.feature.geometry;
-        var center = geometry.getBounds().getCenterLonLat();
-        var originGeometry = new OpenLayers.Geometry.Point(
-            center.lon, center.lat
-        var origin = new OpenLayers.Feature.Vector(originGeometry);
-        originGeometry.move = function(x, y) {
-            OpenLayers.Geometry.Point.prototype.move.call(this, x, y);
-            geometry.move(x, y);
-        this.dragHandle = origin;
-        this.layer.addFeatures([this.dragHandle], {silent: true});
-     * Method: collectRadiusHandle
-     * Collect the radius handle for the selected geometry.
-    collectRadiusHandle: function() {
-        var bounds = geometry.getBounds();
-        var center = bounds.getCenterLonLat();
-        var radiusGeometry = new OpenLayers.Geometry.Point(
-            bounds.right, bounds.bottom
-        var radius = new OpenLayers.Feature.Vector(radiusGeometry);
-        var resize = (this.mode & OpenLayers.Control.ModifyFeature.RESIZE);
-        var rotate = (this.mode & OpenLayers.Control.ModifyFeature.ROTATE);
-        radiusGeometry.move = function(x, y) {
-            var dx1 = this.x - originGeometry.x;
-            var dy1 = this.y - originGeometry.y;
-            var dx0 = dx1 - x;
-            var dy0 = dy1 - y;
-            if(rotate) {
-                var a0 = Math.atan2(dy0, dx0);
-                var a1 = Math.atan2(dy1, dx1);
-                var angle = a1 - a0;
-                angle *= 180 / Math.PI;
-                geometry.rotate(angle, originGeometry);
-            if(resize) {
-                var l0 = Math.sqrt((dx0 * dx0) + (dy0 * dy0));
-                var l1 = Math.sqrt((dx1 * dx1) + (dy1 * dy1));
-                geometry.resize(l1 / l0, originGeometry);
-        this.radiusHandle = radius;
-        this.layer.addFeatures([this.radiusHandle], {silent: true});
-     * Method: setMap
-     * Set the map property for the control and all handlers.
-     * Parameters:
-     * map - {<OpenLayers.Map>} The control's map.
-        this.selectControl.setMap(map);
-        this.dragControl.setMap(map);
-        OpenLayers.Control.prototype.setMap.apply(this, arguments);
-    CLASS_NAME: "OpenLayers.Control.ModifyFeature"
- * Constant: RESHAPE
- * {Integer} Constant used to make the control work in reshape mode
-OpenLayers.Control.ModifyFeature.RESHAPE = 1;
- * Constant: RESIZE
- * {Integer} Constant used to make the control work in resize mode
-OpenLayers.Control.ModifyFeature.RESIZE = 2;
- * Constant: ROTATE
- * {Integer} Constant used to make the control work in rotate mode
-OpenLayers.Control.ModifyFeature.ROTATE = 4;
- * Constant: DRAG
- * {Integer} Constant used to make the control work in drag mode
-OpenLayers.Control.ModifyFeature.DRAG = 8;
     OpenLayers/Control/Navigation.js
@@ -31405,550 +15529,6 @@
     CLASS_NAME: "OpenLayers.Control.Navigation"
-    OpenLayers/Filter.js
-/* Copyright (c) 2006 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * @requires OpenLayers/Style.js
- * Class: OpenLayers.Filter
- * This class represents an OGC Filter.
-OpenLayers.Filter = OpenLayers.Class({
-     * Constructor: OpenLayers.Filter
-     * This is an abstract class.  Create an instance of a filter subclass.
-     * Parameters:
-     *     instance.
-     * Returns:
-     * {<OpenLayers.Filter>}
-    initialize: function(options) {
-     * Remove reference to anything added.
-     * APIMethod: evaluate
-     * Evaluates this filter in a specific context.  Should be implemented by
-     *     subclasses.
-     * Parameters:
-     * context - {Object} Context to use in evaluating the filter.
-     * Returns:
-     * {Boolean} The filter applies.
-    evaluate: function(context) {
-        return true;
-    CLASS_NAME: "OpenLayers.Filter"
-    OpenLayers/Geometry.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Format/WKT.js
- * @requires OpenLayers/Feature/Vector.js
- * Class: OpenLayers.Geometry
- * A Geometry is a description of a geographic object.  Create an instance of
- * this class with the <OpenLayers.Geometry> constructor.  This is a base class,
- * typical geometry types are described by subclasses of this class.
-OpenLayers.Geometry = OpenLayers.Class({
-     * Property: id
-     * {String} A unique identifier for this geometry.
-    id: null,
-     * Property: parent
-     * {<OpenLayers.Geometry>}This is set when a Geometry is added as component
-     * of another geometry
-    parent: null,
-     * Property: bounds
-     * {<OpenLayers.Bounds>} The bounds of this geometry
-    bounds: null,
-     * Constructor: OpenLayers.Geometry
-     * Creates a geometry object.
-    initialize: function() {
-        this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME+ "_");
-     * Method: destroy
-     * Destroy this geometry.
-        this.id = null;
-        this.bounds = null;
-     * APIMethod: clone
-     * Create a clone of this geometry.  Does not set any non-standard
-     *     properties of the cloned geometry.
-     * Returns:
-     * {<OpenLayers.Geometry>} An exact clone of this geometry.
-    clone: function() {
-        return new OpenLayers.Geometry();
-     * Set the bounds for this Geometry.
-     * Parameters:
-     * object - {<OpenLayers.Bounds>}
-    setBounds: function(bounds) {
-        if (bounds) {
-            this.bounds = bounds.clone();
-     * Method: clearBounds
-     * Nullify this components bounds and that of its parent as well.
-    clearBounds: function() {
-        if (this.parent) {
-            this.parent.clearBounds();
-     * Method: extendBounds
-     * Extend the existing bounds to include the new bounds.
-     * If geometry's bounds is not yet set, then set a new Bounds.
-     * Parameters:
-     * newBounds - {<OpenLayers.Bounds>}
-    extendBounds: function(newBounds){
-        var bounds = this.getBounds();
-        if (!bounds) {
-            this.setBounds(newBounds);
-        } else {
-            this.bounds.extend(newBounds);
-     * APIMethod: getBounds
-     * Get the bounds for this Geometry. If bounds is not set, it
-     * is calculated again, this makes queries faster.
-     * Returns:
-    getBounds: function() {
-        if (this.bounds == null) {
-            this.calculateBounds();
-        return this.bounds;
-     * APIMethod: calculateBounds
-     * Recalculate the bounds for the geometry.
-    calculateBounds: function() {
-        // This should be overridden by subclasses.
-     * Method: atPoint
-     * Note - This is only an approximation based on the bounds of the
-     * geometry.
-     * Parameters:
-     * lonlat - {<OpenLayers.LonLat>}
-     * toleranceLon - {float} Optional tolerance in Geometric Coords
-     * toleranceLat - {float} Optional tolerance in Geographic Coords
-     * Returns:
-     * {Boolean} Whether or not the geometry is at the specified location
-    atPoint: function(lonlat, toleranceLon, toleranceLat) {
-        var atPoint = false;
-        if ((bounds != null) && (lonlat != null)) {
-            var dX = (toleranceLon != null) ? toleranceLon : 0;
-            var dY = (toleranceLat != null) ? toleranceLat : 0;
-            var toleranceBounds =
-                new OpenLayers.Bounds(this.bounds.left - dX,
-                                      this.bounds.bottom - dY,
-                                      this.bounds.right + dX,
-                                      this.bounds.top + dY);
-            atPoint = toleranceBounds.containsLonLat(lonlat);
-        return atPoint;
-     * Method: getLength
-     * Calculate the length of this geometry. This method is defined in
-     * subclasses.
-     * Returns:
-     * {Float} The length of the collection by summing its parts
-    getLength: function() {
-        //to be overridden by geometries that actually have a length
-        return 0.0;
-     * Method: getArea
-     * Calculate the area of this geometry. This method is defined in subclasses.
-     * Returns:
-     * {Float} The area of the collection by summing its parts
-    getArea: function() {
-        //to be overridden by geometries that actually have an area
-        return 0.0;
-     * Method: toString
-     * Returns the Well-Known Text representation of a geometry
-     * Returns:
-     * {String} Well-Known Text
-    toString: function() {
-        return OpenLayers.Format.WKT.prototype.write(
-            new OpenLayers.Feature.Vector(this)
-    CLASS_NAME: "OpenLayers.Geometry"
- * Method: OpenLayers.Geometry.segmentsIntersect
- * Determine whether two line segments intersect.  Optionally calculates
- *     and returns the intersection point.  This function is optimized for
- *     cases where seg1.x2 >= seg2.x1 || seg2.x2 >= seg1.x1.  In those
- *     obvious cases where there is no intersection, the function should
- *     not be called.
- * Parameters:
- * seg1 - {Object} Object representing a segment with properties x1, y1, x2,
- *     and y2.  The start point is represented by x1 and y1.  The end point
- *     is represented by x2 and y2.  Start and end are ordered so that x1 < x2.
- * seg2 - {Object} Object representing a segment with properties x1, y1, x2,
- * point - {Boolean} Return the intersection point.  If false, the actual
- *     intersection point will not be calculated.  If true and the segments
- *     intersect, the intersection point will be returned.  If true and
- *     the segments do not intersect, false will be returned.  If true and
- *     the segments are coincident, true will be returned.
- * Returns:
- * {Boolean | <OpenLayers.Geometry.Point>}  The two segments intersect.
- *     If the point argument is true, the return will be the intersection
- *     point or false if none exists.  If point is true and the segments
- *     are coincident, return will be true (and the instersection is equal
- *     to the shorter segment).
-OpenLayers.Geometry.segmentsIntersect = function(seg1, seg2, point) {
-    var intersection = false;
-    var x11_21 = seg1.x1 - seg2.x1;
-    var y11_21 = seg1.y1 - seg2.y1;
-    var x12_11 = seg1.x2 - seg1.x1;
-    var y12_11 = seg1.y2 - seg1.y1;
-    var y22_21 = seg2.y2 - seg2.y1;
-    var x22_21 = seg2.x2 - seg2.x1;
-    var d = (y22_21 * x12_11) - (x22_21 * y12_11);
-    var n1 = (x22_21 * y11_21) - (y22_21 * x11_21);
-    var n2 = (x12_11 * y11_21) - (y12_11 * x11_21);
-    if(d == 0) {
-        // parallel
-        if(n1 == 0 && n2 == 0) {
-            // coincident
-            intersection = true;
-    } else {
-        var along1 = n1 / d;
-        var along2 = n2 / d;
-        if(along1 >= 0 && along1 <= 1 && along2 >=0 && along2 <= 1) {
-            // intersect
-            if(!point) {
-            } else {
-                // calculate the intersection point
-                var x = seg1.x1 + (along1 * x12_11);
-                var y = seg1.y1 + (along1 * y12_11);
-                intersection = new OpenLayers.Geometry.Point(x, y);
-    return intersection;
-    OpenLayers/Layer/KaMap.js
- * @requires OpenLayers/Layer/Grid.js
- * Class: OpenLayers.Layer.KaMap
- * Inherits from:
- *  - <OpenLayers.Layer.Grid>
-OpenLayers.Layer.KaMap = OpenLayers.Class(OpenLayers.Layer.Grid, {
-     * APIProperty: isBaseLayer
-     * {Boolean} KaMap Layer is always a base layer
-    isBaseLayer: true,
-     * APIProperty: units
-    units: null,
-     * APIProperty: resolution
-     * {Float}
-    resolution: OpenLayers.DOTS_PER_INCH,
-     * Constant: DEFAULT_PARAMS
-     * {Object} parameters set by default. The default parameters set
-     * the format via the 'i' parameter to 'jpeg'.
-    DEFAULT_PARAMS: {
-        i: 'jpeg',
-        map: ''
-     * Constructor: OpenLayers.Layer.KaMap
-     * Parameters:
-     * name - {String}
-     * url - {String}
-     * params - {Object} Parameters to be sent to the HTTP server in the
-     *    query string for the tile. The format can be set via the 'i'
-     *    parameter (defaults to jpg) , and the map should be set via
-     *    the 'map' parameter. It has been reported that ka-Map may behave
-     *    inconsistently if your format parameter does not match the format
-     *    parameter configured in your config.php. (See ticket #327 for more
-     *    information.)
-     * options - {Object} Additional options for the layer. Any of the
-     *     APIProperties listed on this layer, and any layer types it
-     *     extends, can be overridden through the options parameter.
-    initialize: function(name, url, params, options) {
-        var newArguments = [];
-        newArguments.push(name, url, params, options);
-        OpenLayers.Layer.Grid.prototype.initialize.apply(this, newArguments);
-        this.params = (params ? params : {});
-        if (params) {
-            OpenLayers.Util.applyDefaults(
-                           this.params,
-                           this.DEFAULT_PARAMS
-     * Method: getURL
-     * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
-     * Returns:
-     * {String} A string with the layer's url and parameters and also the
-     *          passed-in bounds and appropriate tile size specified as
-     *          parameters
-    getURL: function (bounds) {
-        bounds = this.adjustBounds(bounds);
-        var mapRes = this.map.getResolution();
-        var scale = Math.round((this.map.getScale() * 10000)) / 10000;
-        var pX = Math.round(bounds.left / mapRes);
-        var pY = -Math.round(bounds.top / mapRes);
-        return this.getFullRequestString(
-                      { t: pY,
-                        l: pX,
-                        s: scale
-     * Method: addTile
-     * Parameters:
-     * position - {<OpenLayers.Pixel>}
-     * Returns:
-     * {<OpenLayers.Tile.Image>}
-    addTile:function(bounds,position) {
-        var url = this.getURL(bounds);
-        return new OpenLayers.Tile.Image(this, position, bounds,
-                                             url, this.tileSize);
-     * Method: calculateGridLayout
-     * ka-Map uses the center point of the map as an origin for
-     * its tiles. Override calculateGridLayout to center tiles
-     * correctly for this case.
-     * Parameters:
-     * bounds - {<OpenLayers.Bound>}
-     * extent - {<OpenLayers.Bounds>}
-     * resolution - {Number}
-     * Returns:
-     * Object containing properties tilelon, tilelat, tileoffsetlat,
-     * tileoffsetlat, tileoffsetx, tileoffsety
-    calculateGridLayout: function(bounds, extent, resolution) {
-        var tilelon = resolution*this.tileSize.w;
-        var tilelat = resolution*this.tileSize.h;
-        var offsetlon = bounds.left;
-        var tilecol = Math.floor(offsetlon/tilelon) - this.buffer;
-        var tilecolremain = offsetlon/tilelon - tilecol;
-        var tileoffsetx = -tilecolremain * this.tileSize.w;
-        var tileoffsetlon = tilecol * tilelon;
-        var offsetlat = bounds.top;
-        var tilerow = Math.ceil(offsetlat/tilelat) + this.buffer;
-        var tilerowremain = tilerow - offsetlat/tilelat;
-        var tileoffsety = -(tilerowremain+1) * this.tileSize.h;
-        var tileoffsetlat = tilerow * tilelat;
-        return {
-          tilelon: tilelon, tilelat: tilelat,
-          tileoffsetlon: tileoffsetlon, tileoffsetlat: tileoffsetlat,
-          tileoffsetx: tileoffsetx, tileoffsety: tileoffsety
-     * Parameters:
-     * obj - {Object}
-     * Returns:
-     * {<OpenLayers.Layer.Kamap>} An exact clone of this OpenLayers.Layer.KaMap
-    clone: function (obj) {
-        if (obj == null) {
-            obj = new OpenLayers.Layer.KaMap(this.name,
-                                            this.url,
-                                            this.params,
-                                            this.options);
-        //get all additions from superclasses
-        obj = OpenLayers.Layer.Grid.prototype.clone.apply(this, [obj]);
-        // copy/set any non-init, non-simple values here
-        if (this.tileSize != null) {
-            obj.tileSize = this.tileSize.clone();
-        // we do not want to copy reference to grid, so we make a new array
-        obj.grid = [];
-        return obj;
-     * APIMethod: getTileBounds
-     * Returns The tile bounds for a layer given a pixel location.
-     * Parameters:
-     * viewPortPx - {<OpenLayers.Pixel>} The location in the viewport.
-     * Returns:
-     * {<OpenLayers.Bounds>} Bounds of the tile at the given pixel location.
-    getTileBounds: function(viewPortPx) {
-        var resolution = this.getResolution();
-        var tileMapWidth = resolution * this.tileSize.w;
-        var tileMapHeight = resolution * this.tileSize.h;
-        var mapPoint = this.getLonLatFromViewPortPx(viewPortPx);
-        var tileLeft = tileMapWidth * Math.floor(mapPoint.lon / tileMapWidth);
-        var tileBottom = tileMapHeight * Math.floor(mapPoint.lat / tileMapHeight);
-        return new OpenLayers.Bounds(tileLeft, tileBottom,
-                                     tileLeft + tileMapWidth,
-                                     tileBottom + tileMapHeight);
-    CLASS_NAME: "OpenLayers.Layer.KaMap"
     OpenLayers/Layer/MapGuide.js
@@ -31957,7 +15537,7 @@
- * @requires OpenLayers/Ajax.js
+ * @requires OpenLayers/Request/XMLHttpRequest.js
@@ -32149,19 +15729,17 @@
             this.params.operation = "GETDYNAMICMAPOVERLAYIMAGE";
             //but we first need to call GETVISIBLEMAPEXTENT to set the extent
+            //var getVisParams = OpenLayers.Util.extend({}, this.params);
             var getVisParams = {};
+            getVisParams = OpenLayers.Util.extend(getVisParams, params);
             getVisParams.operation = "GETVISIBLEMAPEXTENT";
             getVisParams.version = "1.0.0";
             getVisParams.session = this.params.session;
             getVisParams.mapName = this.params.mapName;
             getVisParams.format = 'text/xml';
-            getVisParams = OpenLayers.Util.extend(getVisParams, params);
-            new OpenLayers.Ajax.Request(this.url,
-                  { parameters: getVisParams,
-                    method: 'get',
-                    asynchronous: false   //must be synchronous call to return control here
+            url = this.getFullRequestString( getVisParams );
+            OpenLayers.Request.GET({url: url, async: false});
           //construct the full URL
@@ -32336,12 +15914,9 @@
-        if (arguments.length > 0) {
-                           this.params,
+        this.params = OpenLayers.Util.applyDefaults(
+            this.params, this.DEFAULT_PARAMS
         // unless explicitly set in options, if the layer is transparent,
         // it will be an overlay
@@ -32494,334 +16069,6 @@
     CLASS_NAME: "OpenLayers.Layer.MapServer"
-    OpenLayers/Layer/TMS.js
- * licence.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * Class: OpenLayers.Layer.TMS
- * Inherits from:
-OpenLayers.Layer.TMS = OpenLayers.Class(OpenLayers.Layer.Grid, {
-     * APIProperty: serviceVersion
-     * {String}
-    serviceVersion: "1.0.0",
-     * {Boolean}
-     * APIProperty: tileOrigin
-     * {<OpenLayers.Pixel>}
-    tileOrigin: null,
-     * Constructor: OpenLayers.Layer.TMS
-     * Parameters:
-     * name - {String}
-     * url - {String}
-     * options - {Object} Hashtable of extra options to tag onto the layer
-    initialize: function(name, url, options) {
-        newArguments.push(name, url, {}, options);
-     * APIMethod:destroy
-    destroy: function() {
-        // for now, nothing special to do here.
-        OpenLayers.Layer.Grid.prototype.destroy.apply(this, arguments);
-     * Parameters:
-     * obj - {Object}
-     * Returns:
-     * {<OpenLayers.Layer.TMS>} An exact clone of this <OpenLayers.Layer.TMS>
-            obj = new OpenLayers.Layer.TMS(this.name,
-                                           this.url,
-                                           this.options);
-        return obj;
-     * Method: getURL
-     * Parameters:
-     * Returns:
-     *          parameters
-        var res = this.map.getResolution();
-        var x = Math.round((bounds.left - this.tileOrigin.lon) / (res * this.tileSize.w));
-        var y = Math.round((bounds.bottom - this.tileOrigin.lat) / (res * this.tileSize.h));
-        var z = this.map.getZoom();
-        var path = this.serviceVersion + "/" + this.layername + "/" + z + "/" + x + "/" + y + "." + this.type;
-        var url = this.url;
-        if (url instanceof Array) {
-            url = this.selectUrl(path, url);
-        return url + path;
-     * Method: addTile
-     * addTile creates a tile, initializes it, and adds it to the layer div.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Tile.Image>} The added OpenLayers.Tile.Image
-                                         null, this.tileSize);
-     * When the layer is added to a map, then we can fetch our origin
-     *    (if we don't have one.)
-     * Parameters:
-    setMap: function(map) {
-        OpenLayers.Layer.Grid.prototype.setMap.apply(this, arguments);
-        if (!this.tileOrigin) {
-            this.tileOrigin = new OpenLayers.LonLat(this.map.maxExtent.left,
-                                                this.map.maxExtent.bottom);
-    CLASS_NAME: "OpenLayers.Layer.TMS"
-    OpenLayers/Layer/TileCache.js
- * Class: OpenLayers.Layer.TileCache
- * A read only TileCache layer.  Used to requests tiles cached by TileCache in
- *     a web accessible cache.  This means that you have to pre-populate your
- *     cache before this layer can be used.  It is meant only to read tiles
- *     created by TileCache, and not to make calls to TileCache for tile
- *     creation.  Create a new instance with the
- *     <OpenLayers.Layer.TileCache> constructor.
- * Inherits from:
-OpenLayers.Layer.TileCache = OpenLayers.Class(OpenLayers.Layer.Grid, {
-     * {Boolean} Treat this layer as a base layer.  Default is true.
-     * {<OpenLayers.LonLat>} Location of the tile lattice origin.  Default is
-     *     bottom left of the maxExtent.
-    tileOrigin: null,
-     * APIProperty: format
-     * {String} Mime type of the images returned.  Default is image/png.
-    format: 'image/png',
-     * Constructor: OpenLayers.Layer.TileCache
-     * Create a new read only TileCache layer.
-     * Parameters:
-     * name - {String} Name of the layer displayed in the interface
-     * url - {String} Location of the web accessible cache (not the location of
-     *     your tilecache script!)
-     * layername - {String} Layer name as defined in the TileCache
-     *     configuration
-     * options - {Object} Optional object with properties to be set on the
-     *     layer.  Note that you should speficy your resolutions to match
-     *     your TileCache configuration.  This can be done by setting
-     *     the resolutions array directly (here or on the map), by setting
-     *     maxResolution and numZoomLevels, or by using scale based properties.
-    initialize: function(name, url, layername, options) {
-        this.layername = layername;
-                                                         [name, url, {}, options]);
-        this.extension = this.format.split('/')[1].toLowerCase();
-        this.extension = (this.extension == 'jpg') ? 'jpeg' : this.extension;
-     * obj - {Object}
-     * Returns:
-     * {<OpenLayers.Layer.TileCache>} An exact clone of this
-            obj = new OpenLayers.Layer.TileCache(this.name,
-                                                 this.url,
-                                                 this.layername,
-                                                 this.options);
-        return obj;
-     * Method: getURL
-     * Parameters:
-     * Returns:
-     *     passed-in bounds and appropriate tile size specified as parameters.
-    getURL: function(bounds) {
-        var bbox = this.maxExtent;
-        var size = this.tileSize;
-        var tileX = Math.round((bounds.left - bbox.left) / (res * size.w));
-        var tileY = Math.round((bounds.bottom - bbox.bottom) / (res * size.h));
-        var tileZ = this.map.zoom;
-         * Zero-pad a positive integer.
-         * number - {Int}
-         * length - {Int}
-         * Returns:
-         * {String} A zero-padded string
-        function zeroPad(number, length) {
-            number = String(number);
-            var zeros = [];
-            for(var i=0; i<length; ++i) {
-                zeros.push('0');
-            return zeros.join('').substring(0, length - number.length) + number;
-        var components = [
-            this.layername,
-            zeroPad(tileZ, 2),
-            zeroPad(parseInt(tileX / 1000000), 3),
-            zeroPad((parseInt(tileX / 1000) % 1000), 3),
-            zeroPad((parseInt(tileX) % 1000), 3),
-            zeroPad(parseInt(tileY / 1000000), 3),
-            zeroPad((parseInt(tileY / 1000) % 1000), 3),
-            zeroPad((parseInt(tileY) % 1000), 3) + '.' + this.extension
-        var path = components.join('/');
-        url = (url.charAt(url.length - 1) == '/') ? url : url + '/';
-     * Method: addTile
-     * Create a tile, initialize it, and add it to the layer div.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Tile.Image>} The added <OpenLayers.Tile.Image>
-    addTile:function(bounds, position) {
-     * Method: setMap
-     * Parameters:
-    CLASS_NAME: "OpenLayers.Layer.TileCache"
     OpenLayers/Layer/WMS.js
@@ -33013,7 +16260,8 @@
      * Catch changeParams and uppercase the new params to be merged in
      *     before calling changeParams on the super class.
-     *     Once params have been changed, we will need to re-init our tiles.
+     *     Once params have been changed, the tiles will be reloaded with
+     *     the new parameters.
      * Parameters:
      * newParams - {Object} Hashtable of new params to use
@@ -33026,7 +16274,7 @@
-     * Method: getFullRequestString
+     * APIMethod: getFullRequestString
      * Combine the layer's url with its params and these newParams.
      *     Add the SRS parameter from projection -- this is probably
@@ -33050,10042 +16298,3 @@
     CLASS_NAME: "OpenLayers.Layer.WMS"
-    OpenLayers/Layer/WorldWind.js
- * Class: OpenLayers.Layer.WorldWind
- * Inherits from:
-OpenLayers.Layer.WorldWind = OpenLayers.Class(OpenLayers.Layer.Grid, {
-    DEFAULT_PARAMS: {
-     * WorldWind layer is a base layer by default.
-     * APIProperty: lzd
-     * LevelZeroTileSizeDegrees
-    lzd: null,
-     * APIProperty: zoomLevels
-     * Number of zoom levels.
-    zoomLevels: null,
-     * Constructor: OpenLayers.Layer.WorldWind
-     * Parameters:
-     * name - {String} Name of Layer
-     * url - {String} Base URL
-     * lzd - {Float} Level zero tile size degrees
-     * zoomLevels - {Int} number of zoom levels
-     * params - {Object} additional parameters
-     * options - {Object} additional options
-    initialize: function(name, url, lzd, zoomLevels, params, options) {
-        this.lzd = lzd;
-        this.zoomLevels = zoomLevels;
-        if (params) {
-                           this.params,
-     * Method: addTile
-     * Parameters:
-     * Returns:
-     * Method: getZoom
-     * Convert map zoom to WW zoom.
-    getZoom: function () {
-        var zoom = this.map.getZoom();
-        var extent = this.map.getMaxExtent();
-        zoom = zoom - Math.log(this.maxResolution / (this.lzd/512))/Math.log(2);
-        return zoom;
-     * Method: getURL
-     * Parameters:
-     * Returns:
-     *           parameters
-        var zoom = this.getZoom();
-        var deg = this.lzd/Math.pow(2,this.getZoom());
-        var x = Math.floor((bounds.left - extent.left)/deg);
-        var y = Math.floor((bounds.bottom - extent.bottom)/deg);
-        if (this.map.getResolution() <= (this.lzd/512)
-            && this.getZoom() <= this.zoomLevels) {
-              { L: zoom,
-                X: x,
-                Y: y
-        } else {
-            return OpenLayers.Util.getImagesLocation() + "blank.gif";
-    CLASS_NAME: "OpenLayers.Layer.WorldWind"
-    OpenLayers/Rule.js
- * Class: OpenLayers.Rule
- * This class represents an SLD Rule, as being used for rule-based SLD styling.
-OpenLayers.Rule = OpenLayers.Class({
-     * Property: id
-     * {String} A unique id for this session.
-    id: null,
-     * {String} name of this rule
-    name: 'default',
-     * Property: title
-     * {String} Title of this rule (set if included in SLD)
-    title: null,
-     * {String} Description of this rule (set if abstract is included in SLD)
-     * {Object} An optional object with properties that the rule should be
-     * evaluatad against. If no context is specified, feature.attributes will
-     * be used.
-    context: null,
-     * Property: filter
-     * {<OpenLayers.Filter>} Optional filter for the rule.
-    filter: null,
-     * Property: elseFilter
-     * {Boolean} Determines whether this rule is only to be applied only if
-     * no other rules match (ElseFilter according to the SLD specification).
-     * Default is false.  For instances of OpenLayers.Rule, if elseFilter is
-     * false, the rule will always apply.  For subclasses, the else property is
-     * ignored.
-    elseFilter: false,
-     * Property: symbolizer
-     * {Object} Symbolizer or hash of symbolizers for this rule. If hash of
-     * symbolizers, keys are one or more of ["Point", "Line", "Polygon"]
-    symbolizer: null,
-     * APIProperty: minScaleDenominator
-     * {Number} or {String} minimum scale at which to draw the feature.
-     * In the case of a String, this can be a combination of text and
-     * propertyNames in the form "literal ${propertyName}"
-    minScaleDenominator: null,
-     * APIProperty: maxScaleDenominator
-     * {Number} or {String} maximum scale at which to draw the feature.
-    maxScaleDenominator: null,
-     * Constructor: OpenLayers.Rule
-     * Creates a Rule.
-     * Parameters:
-     *           rule
-     * Returns:
-     * {<OpenLayers.Rule>}
-        this.id = OpenLayers.Util.createUniqueID(this.CLASS_NAME + "_");
-        this.symbolizer = {};
-        for (var i in this.symbolizer) {
-            this.symbolizer[i] = null;
-        this.symbolizer = null;
-     * evaluates this rule for a specific feature
-     * Parameters:
-     * feature - {<OpenLayers.Feature>} feature to apply the rule to.
-     * Returns:
-     * {Boolean} true if the rule applies, false if it does not.
-     * This rule is the default rule and always returns true.
-    evaluate: function(feature) {
-        var context = this.getContext(feature);
-        var applies = true;
-        if (this.minScaleDenominator || this.maxScaleDenominator) {
-            var scale = feature.layer.map.getScale();
-        // check if within minScale/maxScale bounds
-        if (this.minScaleDenominator) {
-            applies = scale >= OpenLayers.Style.createLiteral(
-                    this.minScaleDenominator, context);
-        if (applies && this.maxScaleDenominator) {
-            applies = scale < OpenLayers.Style.createLiteral(
-                    this.maxScaleDenominator, context);
-        // check if optional filter applies
-        if(applies && this.filter) {
-            // feature id filters get the feature, others get the context
-            if(this.filter.CLASS_NAME == "OpenLayers.Filter.FeatureId") {
-                applies = this.filter.evaluate(feature);
-            } else {
-                applies = this.filter.evaluate(context);
-        return applies;
-     * Method: getContext
-     * Gets the context for evaluating this rule
-     * Paramters:
-     * feature - {<OpenLayers.Feature>} feature to take the context from if
-     *           none is specified.
-    getContext: function(feature) {
-        var context = this.context;
-        if (!context) {
-            context = feature.attributes || feature.data;
-        return context;
-    CLASS_NAME: "OpenLayers.Rule"
-    OpenLayers/StyleMap.js
- * Class: OpenLayers.StyleMap
-OpenLayers.StyleMap = OpenLayers.Class({
-     * Property: styles
-     * Hash of {<OpenLayers.Style>}, keyed by names of well known
-     * rendering intents (e.g. "default", "temporary", "select").
-    styles: null,
-     * Property: extendDefault
-     * {Boolean} if true, every render intent will extend the symbolizers
-     * specified for the "default" intent at rendering time. Otherwise, every
-     * rendering intent will be treated as a completely independent style.
-    extendDefault: true,
-     * Constructor: OpenLayers.StyleMap
-     * Parameters:
-     * style   - {Object} Optional. Either a style hash, or a style object, or
-     *           a hash of style objects (style hashes) keyed by rendering
-     *           intent. If just one style hash or style object is passed,
-     *           this will be used for all known render intents (default,
-     *           select, temporary)
-     * options - {Object} optional hash of additional options for this
-     *           instance
-    initialize: function (style, options) {
-        this.styles = {
-            "default": new OpenLayers.Style(
-                OpenLayers.Feature.Vector.style["default"]),
-            "select": new OpenLayers.Style(
-                OpenLayers.Feature.Vector.style["select"]),
-            "temporary": new OpenLayers.Style(
-                OpenLayers.Feature.Vector.style["temporary"])
-        // take whatever the user passed as style parameter and convert it
-        // into parts of stylemap.
-        if(style instanceof OpenLayers.Style) {
-            // user passed a style object
-            this.styles["default"] = style;
-            this.styles["select"] = style;
-            this.styles["temporary"] = style;
-        } else if(typeof style == "object") {
-            for(var key in style) {
-                if(style[key] instanceof OpenLayers.Style) {
-                    // user passed a hash of style objects
-                    this.styles[key] = style[key];
-                } else if(typeof style[key] == "object") {
-                    // user passsed a hash of style hashes
-                    this.styles[key] = new OpenLayers.Style(style[key]);
-                } else {
-                    // user passed a style hash (i.e. symbolizer)
-                    this.styles["default"] = new OpenLayers.Style(style);
-                    this.styles["select"] = new OpenLayers.Style(style);
-                    this.styles["temporary"] = new OpenLayers.Style(style);
-                    break;
-     * Method: destroy
-        for(var key in this.styles) {
-            this.styles[key].destroy();
-        this.styles = null;
-     * Creates the symbolizer for a feature for a render intent.
-     * Parameters:
-     * feature - {<OpenLayers.Feature>} The feature to evaluate the rules
-     *           of the intended style against.
-     * intent  - {String} The intent determines the symbolizer that will be
-     *           used to draw the feature. Well known intents are "default"
-     *           (for just drawing the features), "select" (for selected
-     *           features) and "temporary" (for drawing features).
-     * Returns:
-    createSymbolizer: function(feature, intent) {
-        if(!feature) {
-            feature = new OpenLayers.Feature.Vector();
-        if(!this.styles[intent]) {
-            intent = "default";
-        feature.renderIntent = intent;
-        var defaultSymbolizer = {};
-        if(this.extendDefault && intent != "default") {
-            defaultSymbolizer = this.styles["default"].createSymbolizer(feature);
-        return OpenLayers.Util.extend(defaultSymbolizer,
-            this.styles[intent].createSymbolizer(feature));
-     * Method: addUniqueValueRules
-     * Convenience method to create comparison rules for unique values of a
-     * property. The rules will be added to the style object for a specified
-     * rendering intent. This method is a shortcut for creating something like
-     * the "unique value legends" familiar from well known desktop GIS systems
-     * Parameters:
-     * renderIntent - {String} rendering intent to add the rules to
-     * property     - {String} values of feature attributes to create the
-     *                rules for
-     * symbolizers  - {Object} Hash of symbolizers, keyed by the desired
-     *                property values
-    addUniqueValueRules: function(renderIntent, property, symbolizers) {
-        var rules = [];
-        for (var value in symbolizers) {
-            rules.push(new OpenLayers.Rule({
-                symbolizer: symbolizers[value],
-                filter: new OpenLayers.Filter.Comparison({
-                    type: OpenLayers.Filter.Comparison.EQUAL_TO,
-                    property: property,
-                    value: value
-        this.styles[renderIntent].addRules(rules);
-    CLASS_NAME: "OpenLayers.StyleMap"
-    OpenLayers/Control/NavToolbar.js
- * @requires OpenLayers/Control/Panel.js
- * @requires OpenLayers/Control/Navigation.js
- * @requires OpenLayers/Control/ZoomBox.js
- * Class: OpenLayers.Control.NavToolbar
- * Inherits from:
- *  - <OpenLayers.Control.Panel>
-OpenLayers.Control.NavToolbar = OpenLayers.Class(OpenLayers.Control.Panel, {
-     * Constructor: OpenLayers.Control.NavToolbar
-     * Add our two mousedefaults controls.
-     * Parameters:
-     * options - {Object} An optional object whose properties will be used
-     *     to extend the control.
-        OpenLayers.Control.Panel.prototype.initialize.apply(this, [options]);
-        this.addControls([
-          new OpenLayers.Control.Navigation(),
-          new OpenLayers.Control.ZoomBox()
-     * Method: draw
-     * calls the default draw, and then activates mouse defaults.
-    draw: function() {
-        var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
-        this.activateControl(this.controls[0]);
-        return div;
-    CLASS_NAME: "OpenLayers.Control.NavToolbar"
-    OpenLayers/Filter/Comparison.js
- * @requires OpenLayers/Filter.js
- * Class: OpenLayers.Filter.Comparison
- * This class represents a comparison filter.
- * Inherits from
- * - <OpenLayers.Filter>
-OpenLayers.Filter.Comparison = OpenLayers.Class(OpenLayers.Filter, {
-     * APIProperty: type
-     * {String} type: type of the comparison. This is one of
-     * - OpenLayers.Filter.Comparison.EQUAL_TO                 = "==";
-     * - OpenLayers.Filter.Comparison.NOT_EQUAL_TO             = "!=";
-     * - OpenLayers.Filter.Comparison.LESS_THAN                = "<";
-     * - OpenLayers.Filter.Comparison.GREATER_THAN             = ">";
-     * - OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO    = "<=";
-     * - OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO = ">=";
-     * - OpenLayers.Filter.Comparison.BETWEEN                  = "..";
-     * - OpenLayers.Filter.Comparison.LIKE                     = "~";
-    type: null,
-     * APIProperty: property
-     * {String}
-     * name of the context property to compare
-    property: null,
-     * APIProperty: value
-     * comparison value for binary comparisons. In the case of a String, this
-     * can be a combination of text and propertyNames in the form
-     * "literal ${propertyName}"
-    value: null,
-     * APIProperty: lowerBoundary
-     * lower boundary for between comparisons. In the case of a String, this
-    lowerBoundary: null,
-     * APIProperty: upperBoundary
-     * upper boundary for between comparisons. In the case of a String, this
-    upperBoundary: null,
-     * Constructor: OpenLayers.Filter.Comparison
-     * Creates a comparison rule.
-     * Parameters:
-     *           rule
-     * Returns:
-     * {<OpenLayers.Filter.Comparison>}
-        OpenLayers.Filter.prototype.initialize.apply(this, [options]);
-     *     subclasses.
-     * Parameters:
-     * Returns:
-        switch(this.type) {
-            case OpenLayers.Filter.Comparison.EQUAL_TO:
-            case OpenLayers.Filter.Comparison.LESS_THAN:
-            case OpenLayers.Filter.Comparison.GREATER_THAN:
-            case OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO:
-            case OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO:
-                return this.binaryCompare(context, this.property, this.value);
-            case OpenLayers.Filter.Comparison.BETWEEN:
-                var result =
-                        context[this.property] >= this.lowerBoundary;
-                result = result &&
-                        context[this.property] <= this.upperBoundary;
-                return result;
-            case OpenLayers.Filter.Comparison.LIKE:
-                var regexp = new RegExp(this.value,
-                                "gi");
-                return regexp.test(context[this.property]);
-     * APIMethod: value2regex
-     * Converts the value of this rule into a regular expression string,
-     * according to the wildcard characters specified. This method has to
-     * be called after instantiation of this class, if the value is not a
-     * regular expression already.
-     * Parameters:
-     * wildCard   - {<Char>} wildcard character in the above value, default
-     *              is "*"
-     * singleChar - {<Char>) single-character wildcard in the above value
-     *              default is "."
-     * escape     - {<Char>) escape character in the above value, default is
-     * Returns:
-     * {String} regular expression string
-    value2regex: function(wildCard, singleChar, escapeChar) {
-        if (wildCard == ".") {
-            var msg = "'.' is an unsupported wildCard character for "+
-                    "OpenLayers.Filter.Comparison";
-            OpenLayers.Console.error(msg);
-            return null;
-        // set UMN MapServer defaults for unspecified parameters
-        wildCard = wildCard ? wildCard : "*";
-        singleChar = singleChar ? singleChar : ".";
-        escapeChar = escapeChar ? escapeChar : "!";
-        this.value = this.value.replace(
-                new RegExp("\\"+escapeChar, "g"), "\\");
-                new RegExp("\\"+singleChar, "g"), ".");
-                new RegExp("\\"+wildCard, "g"), ".*");
-                new RegExp("\\\\.\\*", "g"), "\\"+wildCard);
-                new RegExp("\\\\\\.", "g"), "\\"+singleChar);
-        return this.value;
-     * Method: regex2value
-     * Convert the value of this rule from a regular expression string into an
-     *     ogc literal string using a wildCard of *, a singleChar of ., and an
-     *     escape of !.  Leaves the <value> property unmodified.
-     * Returns:
-     * {String} A string value.
-    regex2value: function() {
-        var value = this.value;
-        // replace ! with !!
-        value = value.replace(/!/g, "!!");
-        // replace \. with !. (watching out for \\.)
-        value = value.replace(/(\\)?\\\./g, function($0, $1) {
-            return $1 ? $0 : "!.";
-        // replace \* with #* (watching out for \\*)
-        value = value.replace(/(\\)?\\\*/g, function($0, $1) {
-            return $1 ? $0 : "!*";
-        // replace \\ with \
-        value = value.replace(/\\\\/g, "\\");
-        // convert .* to * (the sequence #.* is not allowed)
-        value = value.replace(/\.\*/g, "*");
-        return value;
-     * Function: binaryCompare
-     * Compares a feature property to a rule value
-     * Parameters:
-     * property - {String} or {Number}
-     * value    - {String} or {Number}, same as property
-     * Returns:
-     * {Boolean}
-    binaryCompare: function(context, property, value) {
-        switch (this.type) {
-                return context[property] == value;
-            case OpenLayers.Filter.Comparison.NOT_EQUAL_TO:
-                return context[property] != value;
-                return context[property] < value;
-                return context[property] > value;
-                return context[property] <= value;
-                return context[property] >= value;
-    CLASS_NAME: "OpenLayers.Filter.Comparison"
-OpenLayers.Filter.Comparison.EQUAL_TO                 = "==";
-OpenLayers.Filter.Comparison.NOT_EQUAL_TO             = "!=";
-OpenLayers.Filter.Comparison.LESS_THAN                = "<";
-OpenLayers.Filter.Comparison.GREATER_THAN             = ">";
-OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO    = "<=";
-OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO = ">=";
-OpenLayers.Filter.Comparison.BETWEEN                  = "..";
-OpenLayers.Filter.Comparison.LIKE                     = "~";
-    OpenLayers/Filter/FeatureId.js
- * Class: OpenLayers.Filter.FeatureId
- * This class represents a ogc:FeatureId Filter, as being used for rule-based SLD
- * styling
- * Inherits from
-OpenLayers.Filter.FeatureId = OpenLayers.Class(OpenLayers.Filter, {
-     * APIProperty: fids
-     * {Array(String)} Feature Ids to evaluate this rule against. To be passed
-     * To be passed inside the params object.
-    fids: null,
-     * Constructor: OpenLayers.Filter.FeatureId
-     * Creates an ogc:FeatureId rule.
-     * Parameters:
-     * options - {Object} An optional object with properties to set on the
-     *           rule
-     * Returns:
-     * {<OpenLayers.Filter.FeatureId>}
-        this.fids = [];
-     * Parameters:
-     *           For vector features, the check is run against the fid,
-     *           for plain features against the id.
-     * Returns:
-        for (var i=0; i<this.fids.length; i++) {
-            var fid = feature.fid || feature.id;
-            if (fid == this.fids[i]) {
-                return true;
-        return false;
-    CLASS_NAME: "OpenLayers.Filter.FeatureId"
-    OpenLayers/Filter/Logical.js
- * Class: OpenLayers.Filter.Logical
- * This class represents ogc:And, ogc:Or and ogc:Not rules.
- * Inherits from
-OpenLayers.Filter.Logical = OpenLayers.Class(OpenLayers.Filter, {
-     * APIProperty: filters
-     * {Array(<OpenLayers.Filter>)} Child filters for this filter.
-    filters: null,
-     * {String} type of logical operator. Available types are:
-     * - OpenLayers.Filter.Locical.AND = "&&";
-     * - OpenLayers.Filter.Logical.OR  = "||";
-     * - OpenLayers.Filter.Logical.NOT = "!";
-    type: null,
-     * Constructor: OpenLayers.Filter.Logical
-     * Creates a logical filter (And, Or, Not).
-     * Parameters:
-     *     filter.
-     * Returns:
-     * {<OpenLayers.Filter.Logical>}
-        this.filters = [];
-     * APIMethod: destroy
-     * Remove reference to child filters.
-        this.filters = null;
-        OpenLayers.Filter.prototype.destroy.apply(this);
-     *     subclasses.
-     * Parameters:
-     * Returns:
-            case OpenLayers.Filter.Logical.AND:
-                for (var i=0; i<this.filters.length; i++) {
-                    if (this.filters[i].evaluate(context) == false) {
-                        return false;
-                return true;
-            case OpenLayers.Filter.Logical.OR:
-                    if (this.filters[i].evaluate(context) == true) {
-                        return true;
-                return false;
-            case OpenLayers.Filter.Logical.NOT:
-                return (!this.filters[0].evaluate(context));
-    CLASS_NAME: "OpenLayers.Filter.Logical"
-OpenLayers.Filter.Logical.AND = "&&";
-OpenLayers.Filter.Logical.OR  = "||";
-OpenLayers.Filter.Logical.NOT = "!";
-    OpenLayers/Geometry/Collection.js
- * @requires OpenLayers/Geometry.js
- * Class: OpenLayers.Geometry.Collection
- * A Collection is exactly what it sounds like: A collection of different
- * Geometries. These are stored in the local parameter <components> (which
- * can be passed as a parameter to the constructor).
- * As new geometries are added to the collection, they are NOT cloned.
- * When removing geometries, they need to be specified by reference (ie you
- * have to pass in the *exact* geometry to be removed).
- * The <getArea> and <getLength> functions here merely iterate through
- * the components, summing their respective areas and lengths.
- * Create a new instance with the <OpenLayers.Geometry.Collection> constructor.
- * Inerhits from:
- *  - <OpenLayers.Geometry>
-OpenLayers.Geometry.Collection = OpenLayers.Class(OpenLayers.Geometry, {
-     * APIProperty: components
-     * {Array(<OpenLayers.Geometry>)} The component parts of this geometry
-    components: null,
-     * Property: componentTypes
-     * {Array(String)} An array of class names representing the types of
-     * components that the collection can include.  A null value means the
-     * component types are not restricted.
-    componentTypes: null,
-     * Constructor: OpenLayers.Geometry.Collection
-     * Creates a Geometry Collection -- a list of geoms.
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry>)} Optional array of geometries
-    initialize: function (components) {
-        OpenLayers.Geometry.prototype.initialize.apply(this, arguments);
-        this.components = [];
-        if (components != null) {
-            this.addComponents(components);
-    destroy: function () {
-        this.components.length = 0;
-        this.components = null;
-     * Clone this geometry.
-     * Returns:
-     * {<OpenLayers.Geometry.Collection>} An exact clone of this collection
-        var geometry = eval("new " + this.CLASS_NAME + "()");
-        for(var i=0; i<this.components.length; i++) {
-            geometry.addComponent(this.components[i].clone());
-        // catch any randomly tagged-on properties
-        OpenLayers.Util.applyDefaults(geometry, this);
-        return geometry;
-     * Method: getComponentsString
-     * Get a string representing the components for this collection
-     * Returns:
-     * {String} A string representation of the components of this geometry
-    getComponentsString: function(){
-        var strings = [];
-        for(var i = 0; i < this.components.length; i++) {
-            strings.push(this.components[i].toShortString());
-        return strings.join(",");
-     * Recalculate the bounds by iterating through the components and
-     * calling calling extendBounds() on each item.
-        if ( this.components && this.components.length > 0) {
-            this.setBounds(this.components[0].getBounds());
-            for (var i = 1; i < this.components.length; i++) {
-                this.extendBounds(this.components[i].getBounds());
-     * APIMethod: addComponents
-     * Add components to this geometry.
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry>)} An array of geometries to add
-    addComponents: function(components){
-        if(!(components instanceof Array)) {
-            components = [components];
-        for(var i=0; i < components.length; i++) {
-            this.addComponent(components[i]);
-     * Method: addComponent
-     * Add a new component (geometry) to the collection.  If this.componentTypes
-     * is set, then the component class name must be in the componentTypes array.
-     * The bounds cache is reset.
-     * Parameters:
-     * component - {<OpenLayers.Geometry>} A geometry to add
-     * index - {int} Optional index into the array to insert the component
-     * Returns:
-     * {Boolean} The component geometry was successfully added
-    addComponent: function(component, index) {
-        var added = false;
-        if(component) {
-            if(this.componentTypes == null ||
-               (OpenLayers.Util.indexOf(this.componentTypes,
-                                        component.CLASS_NAME) > -1)) {
-                if(index != null && (index < this.components.length)) {
-                    var components1 = this.components.slice(0, index);
-                    var components2 = this.components.slice(index,
-                                                           this.components.length);
-                    components1.push(component);
-                    this.components = components1.concat(components2);
-                } else {
-                    this.components.push(component);
-                component.parent = this;
-                this.clearBounds();
-                added = true;
-        return added;
-     * APIMethod: removeComponents
-     * Remove components from this geometry.
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry>)} The components to be removed
-    removeComponents: function(components) {
-        for(var i=components.length-1; i>=0; --i) {
-            this.removeComponent(components[i]);
-     * Method: removeComponent
-     * Remove a component from this geometry.
-     * Parameters:
-    removeComponent: function(component) {
-        OpenLayers.Util.removeItem(this.components, component);
-        // clearBounds() so that it gets recalculated on the next call
-        // to this.getBounds();
-     * APIMethod: getLength
-     * Returns:
-     * {Float} The length of the geometry
-        var length = 0.0;
-        for (var i = 0; i < this.components.length; i++) {
-            length += this.components[i].getLength();
-        return length;
-     * APIMethod: getArea
-     * Calculate the area of this geometry. Note how this function is overridden
-     * in <OpenLayers.Geometry.Polygon>.
-     * Returns:
-        var area = 0.0;
-            area += this.components[i].getArea();
-        return area;
-     * APIMethod: move
-     * Moves a collection in place
-     * Parameters:
-     * x - {Float} The x-displacement (in map units)
-     * y - {Float} The y-displacement (in map units)
-    move: function(x, y) {
-            this.components[i].move(x, y);
-     * APIMethod: rotate
-     * Rotate a geometry around some origin
-     * Parameters:
-     * angle - {Float} Rotation angle in degrees (measured counterclockwise
-     *                 from the positive x-axis)
-     * origin - {<OpenLayers.Geometry.Point>} Center point for the rotation
-    rotate: function(angle, origin) {
-        for(var i=0; i<this.components.length; ++i) {
-            this.components[i].rotate(angle, origin);
-     * APIMethod: resize
-     * Resize a geometry relative to some origin.  Use this method to apply
-     *     a uniform scaling to a geometry.
-     * Parameters:
-     * scale - {Float} Factor by which to scale the geometry.  A scale of 2
-     *                 doubles the size of the geometry in each dimension
-     *                 (lines, for example, will be twice as long, and polygons
-     *                 will have four times the area).
-     * origin - {<OpenLayers.Geometry.Point>} Point of origin for resizing
-     * ratio - {Float} Optional x:y ratio for resizing.  Default ratio is 1.
-    resize: function(scale, origin, ratio) {
-            this.components[i].resize(scale, origin, ratio);
-     * APIMethod: equals
-     * Tests for equivalent geometries
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-     * Returns:
-     * {Boolean} The coordinates are equivalent
-    equals: function(geometry) {
-        var equivalent = true;
-        if(!geometry || !geometry.CLASS_NAME ||
-           (this.CLASS_NAME != geometry.CLASS_NAME)) {
-            equivalent = false;
-        } else if(!(geometry.components instanceof Array) ||
-                  (geometry.components.length != this.components.length)) {
-        } else {
-                if(!this.components[i].equals(geometry.components[i])) {
-                    break;
-        return equivalent;
-     * APIMethod: transform
-     * Reproject the components geometry from source to dest.
-     * Parameters:
-     * source - {<OpenLayers.Projection>}
-     * dest - {<OpenLayers.Projection>}
-     * Returns:
-    transform: function(source, dest) {
-        if (source && dest) {
-                var component = this.components[i];
-                component.transform(source, dest);
-        return this;
-     * APIMethod: intersects
-     * Determine if the input geometry intersects this one.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>} Any type of geometry.
-     * Returns:
-     * {Boolean} The input geometry intersects this one.
-    intersects: function(geometry) {
-        var intersect = false;
-        for(var i=0; i<this.components.length; ++ i) {
-            intersect = geometry.intersects(this.components[i]);
-            if(intersect) {
-                break;
-        return intersect;
-    /** @final @type String */
-    CLASS_NAME: "OpenLayers.Geometry.Collection"
-    OpenLayers/Geometry/Point.js
- * Class: OpenLayers.Geometry.Point
- * Point geometry class.
- * Inherits from:
-OpenLayers.Geometry.Point = OpenLayers.Class(OpenLayers.Geometry, {
-     * APIProperty: x
-     * {float}
-    x: null,
-     * APIProperty: y
-     * {float}
-    y: null,
-     * Constructor: OpenLayers.Geometry.Point
-     * Construct a point geometry.
-     * Parameters:
-     * x - {float}
-     * y - {float}
-    initialize: function(x, y) {
-        this.x = parseFloat(x);
-        this.y = parseFloat(y);
-     * Returns:
-     * {<OpenLayers.Geometry.Point>} An exact clone of this OpenLayers.Geometry.Point
-    clone: function(obj) {
-            obj = new OpenLayers.Geometry.Point(this.x, this.y);
-        OpenLayers.Util.applyDefaults(obj, this);
-        return obj;
-     * Method: calculateBounds
-     * Create a new Bounds based on the lon/lat
-    calculateBounds: function () {
-        this.bounds = new OpenLayers.Bounds(this.x, this.y,
-                                            this.x, this.y);
-     * APIMethod: distanceTo
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>}
-    distanceTo: function(point) {
-        var distance = 0.0;
-        if ( (this.x != null) && (this.y != null) &&
-             (point != null) && (point.x != null) && (point.y != null) ) {
-             var dx2 = Math.pow(this.x - point.x, 2);
-             var dy2 = Math.pow(this.y - point.y, 2);
-             distance = Math.sqrt( dx2 + dy2 );
-        return distance;
-    * Parameters:
-    * xy - {<OpenLayers.Geometry>}
-    * Returns:
-    * {Boolean} Boolean value indicating whether the passed-in
-    *          {<OpenLayers.Geometry>} object has the same  components as this
-    *          note that if ll passed in is null, returns false
-    equals:function(geom) {
-        var equals = false;
-        if (geom != null) {
-            equals = ((this.x == geom.x && this.y == geom.y) ||
-                      (isNaN(this.x) && isNaN(this.y) && isNaN(geom.x) && isNaN(geom.y)));
-        return equals;
-     * Method: toShortString
-     * Returns:
-     * {String} Shortened String representation of Point object.
-     *         (ex. <i>"5, 42"</i>)
-    toShortString: function() {
-        return (this.x + ", " + this.y);
-     * APIMethod: move
-     * Moves a point in place
-     * Parameters:
-     * x - {Float}
-     * y - {Float}
-        this.x = this.x + x;
-        this.y = this.y + y;
-     * Rotate a point around another.
-     * Parameters:
-        angle *= Math.PI / 180;
-        var radius = this.distanceTo(origin);
-        var theta = angle + Math.atan2(this.y - origin.y, this.x - origin.x);
-        this.x = origin.x + (radius * Math.cos(theta));
-        this.y = origin.y + (radius * Math.sin(theta));
-     * Resize a point relative to some origin.  For points, this has the effect
-     *     of scaling a vector (from the origin to the point).  This method is
-     *     more useful on geometry collection subclasses.
-     * Parameters:
-     * scale - {Float} Ratio of the new distance from the origin to the old
-     *                 distance from the origin.  A scale of 2 doubles the
-     *                 distance between the point and origin.
-        ratio = (ratio == undefined) ? 1 : ratio;
-        this.x = origin.x + (scale * ratio * (this.x - origin.x));
-        this.y = origin.y + (scale * (this.y - origin.y));
-     * Parameters:
-     * Returns:
-            intersect = this.equals(geometry);
-        } else {
-            intersect = geometry.intersects(this);
-        return intersect;
-     * Translate the x,y properties of the point from source to dest.
-     * Parameters:
-     * Returns:
-        if ((source && dest)) {
-            OpenLayers.Projection.transform(
-                this, source, dest);
-        return this;
-    CLASS_NAME: "OpenLayers.Geometry.Point"
-    OpenLayers/Geometry/Rectangle.js
- * Class: OpenLayers.Geometry.Rectangle
- * This class is *not supported*, and probably isn't what you're looking for.
- *     Instead, most users probably want something like:
- *     (code)
- *     var poly = new OpenLayers.Bounds(0,0,10,10).toGeometry();
- *     (end)
- *     This will create a rectangular Polygon geometry.
- * Inherits:
-OpenLayers.Geometry.Rectangle = OpenLayers.Class(OpenLayers.Geometry, {
-     * Property: x
-     * {Float}
-    x: null,
-     * Property: y
-     * {Float}
-    y: null,
-     * Property: width
-     * {Float}
-    width: null,
-     * Property: height
-     * {Float}
-    height: null,
-     * Constructor: OpenLayers.Geometry.Rectangle
-     * Parameters:
-     * points - {Array(<OpenLayers.Geometry.Point>}
-    initialize: function(x, y, width, height) {
-        this.x = x;
-        this.y = y;
-        this.width = width;
-        this.height = height;
-                                            this.x + this.width,
-                                            this.y + this.height);
-     * Returns:
-        var length = (2 * this.width) + (2 * this.height);
-        return length;
-     * Returns:
-     * {Float} The area of the geometry
-        var area = this.width * this.height;
-        return area;
-    CLASS_NAME: "OpenLayers.Geometry.Rectangle"
-    OpenLayers/Geometry/Surface.js
-OpenLayers.Geometry.Surface = OpenLayers.Class(OpenLayers.Geometry, {
-    CLASS_NAME: "OpenLayers.Geometry.Surface"
-    OpenLayers/Layer/MapServer/Untiled.js
-/* Copyright 2006-2008 MetaCarta, Inc., published under the Clear BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/license.txt for the full text
- * of the license. */
- * @requires OpenLayers/Layer/MapServer.js
- * Class: OpenLayers.Layer.MapServer.Untiled
- * *Deprecated*.  To be removed in 3.0.  Instead use OpenLayers.Layer.MapServer
- *     and pass the option 'singleTile' as true.
- * Inherits from:
- *  - <OpenLayers.Layer.MapServer>
-OpenLayers.Layer.MapServer.Untiled = OpenLayers.Class(OpenLayers.Layer.MapServer, {
-     * APIProperty: singleTile
-     * {singleTile} Always true for untiled.
-    singleTile: true,
-     * Constructor: OpenLayers.Layer.MapServer.Untiled
-     * Parameters:
-     * name - {String}
-     * url - {String}
-        OpenLayers.Layer.MapServer.prototype.initialize.apply(this, arguments);
-        var msg = "The OpenLayers.Layer.MapServer.Untiled class is deprecated and " +
-                  "will be removed in 3.0. Instead, you should use the " +
-                  "normal OpenLayers.Layer.MapServer class, passing it the option " +
-                  "'singleTile' as true.";
-        OpenLayers.Console.warn(msg);
-     * Method: clone
-     * Create a clone of this layer
-     * Returns:
-     * {<OpenLayers.Layer.MapServer.Untiled>} An exact clone of this layer
-            obj = new OpenLayers.Layer.MapServer.Untiled(this.name,
-                                                         this.url,
-                                                         this.params,
-                                                         this.options);
-        obj = OpenLayers.Layer.MapServer.prototype.clone.apply(this, [obj]);
-        return obj;
-    CLASS_NAME: "OpenLayers.Layer.MapServer.Untiled"
-    OpenLayers/Layer/Vector.js
- * @requires OpenLayers/Layer.js
- * @requires OpenLayers/Renderer.js
- * @requires OpenLayers/StyleMap.js
- * Class: OpenLayers.Layer.Vector
- * Instances of OpenLayers.Layer.Vector are used to render vector data from
- * a variety of sources. Create a new image layer with the
- * <OpenLayers.Layer.Vector> constructor.
- * Inherits from:
- *  - <OpenLayers.Layer>
-OpenLayers.Layer.Vector = OpenLayers.Class(OpenLayers.Layer, {
-     * Constant: EVENT_TYPES
-     * {Array(String)} Supported application event types.  Register a listener
-     *     for a particular event with the following syntax:
-     * (code)
-     * layer.events.register(type, obj, listener);
-     * (end)
-     * Listeners will be called with a reference to an event object.  The
-     *     properties of this event depends on exactly what happened.
-     * All event objects have at least the following properties:
-     *  - *object* {Object} A reference to layer.events.object.
-     *  - *element* {DOMElement} A reference to layer.events.element.
-     * Supported map event types (in addition to those from <OpenLayers.Layer>):
-     *  - *beforefeatureadded* Triggered before a feature is added.  Listeners
-     *      will receive an object with a *feature* property referencing the
-     *      feature to be added.
-     *  - *featureadded* Triggered after a feature is added.  The event
-     *      object passed to listeners will have a *feature* property with a
-     *      reference to the added feature.
-     *  - *featuresadded* Triggered after features are added.  The event
-     *      object passed to listeners will have a *features* property with a
-     *      reference to an array of added features.
-     *  - *featureselected* Triggered after a feature is selected.  Listeners
-     *      selected feature.
-     *  - *featureunselected* Triggered after a feature is unselected.
-     *      Listeners will receive an object with a *feature* property
-     *      referencing the unselected feature.
-     *  - *beforefeaturemodified* Triggered when a feature is selected to
-     *      be modified.  Listeners will receive an object with a *feature*
-     *      property referencing the selected feature.
-     *  - *featuremodified* Triggered when a feature has been modified.
-     *      Listeners will receive an object with a *feature* property referencing
-     *      the modified feature.
-     *  - *afterfeaturemodified* Triggered when a feature is finished being modified.
-    EVENT_TYPES: ["beforefeatureadded", "featureadded",
-                  "featuresadded", "featureselected", "featureunselected",
-                  "beforefeaturemodified", "featuremodified", "afterfeaturemodified"],
-     * {Boolean} The layer is a base layer.  Default is true.  Set this property
-     * in the layer options
-    isBaseLayer: false,
-     * APIProperty: isFixed
-     * {Boolean} Whether the layer remains in one place while dragging the
-     * map.
-    isFixed: false,
-     * APIProperty: isVector
-     * {Boolean} Whether the layer is a vector layer.
-    isVector: true,
-     * APIProperty: features
-     * {Array(<OpenLayers.Feature.Vector>)}
-    features: null,
-     * Property: selectedFeatures
-    selectedFeatures: null,
-     * APIProperty: reportError
-     * {Boolean} report error message via alert() when loading of renderers
-     * fails.
-    reportError: true,
-     * APIProperty: style
-     * {Object} Default style for the layer
-    style: null,
-     * Property: styleMap
-     * {<OpenLayers.StyleMap>}
-    styleMap: null,
-     * Property: renderers
-     * {Array(String)} List of supported Renderer classes. Add to this list to
-     * add support for additional renderers. This list is ordered:
-     * the first renderer which returns true for the  'supported()'
-     * method will be used, if not defined in the 'renderer' option.
-    renderers: ['SVG', 'VML'],
-     * {<OpenLayers.Renderer>}
-    renderer: null,
-     * APIProperty: geometryType
-     * {String} geometryType allows you to limit the types of geometries this
-     * layer supports. This should be set to something like
-     * "OpenLayers.Geometry.Point" to limit types.
-    geometryType: null,
-     * Property: drawn
-     * {Boolean} Whether the Vector Layer features have been drawn yet.
-    drawn: false,
-     * Constructor: OpenLayers.Layer.Vector
-     * Create a new vector layer
-     * Parameters:
-     * name - {String} A name for the layer
-     * options - {Object} options Object with non-default properties to set on
-     *           the layer.
-     * Returns:
-     * {<OpenLayers.Layer.Vector>} A new vector layer
-    initialize: function(name, options) {
-        // concatenate events specific to vector with those from the base
-        this.EVENT_TYPES =
-            OpenLayers.Layer.Vector.prototype.EVENT_TYPES.concat(
-            OpenLayers.Layer.prototype.EVENT_TYPES
-        OpenLayers.Layer.prototype.initialize.apply(this, arguments);
-        // allow user-set renderer, otherwise assign one
-        if (!this.renderer || !this.renderer.supported()) {
-            this.assignRenderer();
-        // if no valid renderer found, display error
-            this.renderer = null;
-            this.displayError();
-        if (!this.styleMap) {
-            this.styleMap = new OpenLayers.StyleMap();
-        this.features = [];
-        this.selectedFeatures = [];
-     * Destroy this layer
-        OpenLayers.Layer.prototype.destroy.apply(this, arguments);
-        this.destroyFeatures();
-        this.features = null;
-        this.selectedFeatures = null;
-        if (this.renderer) {
-            this.renderer.destroy();
-        this.geometryType = null;
-        this.drawn = null;
-     * Method: assignRenderer
-     * Iterates through the available renderer implementations and selects
-     * and assigns the first one whose "supported()" function returns true.
-    assignRenderer: function()  {
-        for (var i = 0; i < this.renderers.length; i++) {
-            var rendererClass = OpenLayers.Renderer[this.renderers[i]];
-            if (rendererClass && rendererClass.prototype.supported()) {
-               this.renderer = new rendererClass(this.div);
-               break;
-     * Method: displayError
-     * Let the user know their browser isn't supported.
-    displayError: function() {
-        if (this.reportError) {
-            alert(OpenLayers.i18n("browserNotSupported",
-                                     {'renderers':this.renderers.join("\n")}));
-     * Method: setMap
-     * The layer has been added to the map.
-     * If there is no renderer set, the layer can't be used. Remove it.
-     * Otherwise, give the renderer a reference to the map and set its size.
-     * Parameters:
-        OpenLayers.Layer.prototype.setMap.apply(this, arguments);
-        if (!this.renderer) {
-            this.map.removeLayer(this);
-        } else {
-            this.renderer.map = this.map;
-            this.renderer.setSize(this.map.getSize());
-     * Method: onMapResize
-     * Notify the renderer of the change in size.
-    onMapResize: function() {
-        OpenLayers.Layer.prototype.onMapResize.apply(this, arguments);
-     * Method: moveTo
-     *  Reset the vector layer's div so that it once again is lined up with
-     *   the map. Notify the renderer of the change of extent, and in the
-     *   case of a change of zoom level (resolution), have the
-     *   renderer redraw features.
-     *  If the layer has not yet been drawn, cycle through the layer's
-     *   features and draw each one.
-     * Parameters:
-     * zoomChanged - {Boolean}
-     * dragging - {Boolean}
-    moveTo: function(bounds, zoomChanged, dragging) {
-        OpenLayers.Layer.prototype.moveTo.apply(this, arguments);
-        if (!dragging) {
-            this.renderer.root.style.visibility = "hidden";
-            // force a reflow on gecko based browsers to actually hide the svg
-            if (navigator.userAgent.toLowerCase().indexOf("gecko") != -1) {
-                this.div.scrollLeft = this.div.scrollLeft;
-            this.div.style.left = -parseInt(this.map.layerContainerDiv.style.left) + "px";
-            this.div.style.top = -parseInt(this.map.layerContainerDiv.style.top) + "px";
-            var extent = this.map.getExtent();
-            this.renderer.setExtent(extent);
-            this.renderer.root.style.visibility = "visible";
-        if (!this.drawn || zoomChanged) {
-            this.drawn = true;
-            for(var i = 0; i < this.features.length; i++) {
-                var feature = this.features[i];
-                this.drawFeature(feature);
-     * APIMethod: addFeatures
-     * Add Features to the layer.
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)}
-    addFeatures: function(features, options) {
-        if (!(features instanceof Array)) {
-            features = [features];
-        var notify = !options || !options.silent;
-        for (var i = 0; i < features.length; i++) {
-            var feature = features[i];
-            if (this.geometryType &&
-              !(feature.geometry instanceof this.geometryType)) {
-                var throwStr = OpenLayers.i18n('componentShouldBe',
-                          {'geomType':this.geometryType.prototype.CLASS_NAME});
-                throw throwStr;
-            this.features.push(feature);
-            //give feature reference to its layer
-            feature.layer = this;
-            if (!feature.style && this.style) {
-                feature.style = OpenLayers.Util.extend({}, this.style);
-            if (notify) {
-                this.events.triggerEvent("beforefeatureadded", {
-                    feature: feature
-                this.preFeatureInsert(feature);
-            if (this.drawn) {
-            if (notify) {
-                this.events.triggerEvent("featureadded", {
-                    feature: feature
-                this.onFeatureInsert(feature);
-        if(notify) {
-            this.events.triggerEvent("featuresadded", {features: features});
-     * APIMethod: removeFeatures
-     * Parameters:
-    removeFeatures: function(features) {
-        for (var i = features.length - 1; i >= 0; i--) {
-            this.features = OpenLayers.Util.removeItem(this.features, feature);
-            if (feature.geometry) {
-                this.renderer.eraseGeometry(feature.geometry);
-            //in the case that this feature is one of the selected features,
-            // remove it from that array as well.
-            if (OpenLayers.Util.indexOf(this.selectedFeatures, feature) != -1){
-                OpenLayers.Util.removeItem(this.selectedFeatures, feature);
-     * APIMethod: destroyFeatures
-     * Erase and destroy features on the layer.
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)} An optional array of
-     *     features to destroy.  If not supplied, all features on the layer
-     *     will be destroyed.
-    destroyFeatures: function(features) {
-        var all = (features == undefined);
-        if(all) {
-            features = this.features;
-        this.eraseFeatures(features);
-        var feature;
-        for(var i=features.length-1; i>=0; i--) {
-            feature = features[i];
-            if(!all) {
-            feature.destroy();
-     * APIMethod: drawFeature
-     * Draw (or redraw) a feature on the layer.  If the optional style argument
-     * is included, this style will be used.  If no style is included, the
-     * feature's style will be used.  If the feature doesn't have a style,
-     * the layer's style will be used.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>}
-     * style - {Object} Symbolizer hash or {String} renderIntent
-    drawFeature: function(feature, style) {
-        if (typeof style != "object") {
-            var renderIntent = typeof style == "string" ?
-                style : feature.renderIntent;
-            style = feature.style || this.style;
-            if (!style) {
-                style = this.styleMap.createSymbolizer(feature, renderIntent);
-        this.renderer.drawFeature(feature, style);
-     * Method: eraseFeatures
-     * Erase features from the layer.
-     * Parameters:
-    eraseFeatures: function(features) {
-        this.renderer.eraseFeatures(features);
-     * Method: getFeatureFromEvent
-     * Given an event, return a feature if the event occurred over one.
-     * Otherwise, return null.
-     * Parameters:
-     * evt - {Event}
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} A feature if one was under the event.
-    getFeatureFromEvent: function(evt) {
-            OpenLayers.Console.error(OpenLayers.i18n("getFeatureError"));
-            return null;
-        var featureId = this.renderer.getFeatureIdFromEvent(evt);
-        return this.getFeatureById(featureId);
-     * APIMethod: getFeatureById
-     * Given a feature id, return the feature if it exists in the features array
-     * Parameters:
-     * featureId - {String}
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} A feature corresponding to the given
-     * featureId
-    getFeatureById: function(featureId) {
-        //TBD - would it be more efficient to use a hash for this.features?
-        var feature = null;
-        for(var i=0; i<this.features.length; ++i) {
-            if(this.features[i].id == featureId) {
-                feature = this.features[i];
-                break;
-        return feature;
-     * Unselect the selected features
-     * i.e. clears the featureSelection array
-     * change the style back
-    clearSelection: function() {
-       var vectorLayer = this.map.vectorLayer;
-        for (var i = 0; i < this.map.featureSelection.length; i++) {
-            var featureSelection = this.map.featureSelection[i];
-            vectorLayer.drawFeature(featureSelection, vectorLayer.style);
-        this.map.featureSelection = [];
-     * APIMethod: onFeatureInsert
-     * method called after a feature is inserted.
-     * Does nothing by default. Override this if you
-     * need to do something on feature updates.
-     * Paarameters:
-    onFeatureInsert: function(feature) {
-     * APIMethod: preFeatureInsert
-     * method called before a feature is inserted.
-     * need to do something when features are first added to the
-     * layer, but before they are drawn, such as adjust the style.
-     * Parameters:
-    preFeatureInsert: function(feature) {
-    CLASS_NAME: "OpenLayers.Layer.Vector"
-    OpenLayers/Layer/WMS/Untiled.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Layer/WMS.js
- * Class: OpenLayers.Layer.WMS.Untiled
- * *Deprecated*.  To be removed in 3.0.  Instead use OpenLayers.Layer.WMS and
- *     pass the option 'singleTile' as true.
- * Inherits from:
- *  - <OpenLayers.Layer.WMS>
-OpenLayers.Layer.WMS.Untiled = OpenLayers.Class(OpenLayers.Layer.WMS, {
-    singleTile: true,
-     * Constructor: OpenLayers.Layer.WMS.Untiled
-     * Parameters:
-     * name - {String}
-     * url - {String}
-        OpenLayers.Layer.WMS.prototype.initialize.apply(this, arguments);
-        var msg = "The OpenLayers.Layer.WMS.Untiled class is deprecated and " +
-                  "normal OpenLayers.Layer.WMS class, passing it the option " +
-     * Method: clone
-     * Returns:
-     * {<OpenLayers.Layer.WMS.Untiled>} An exact clone of this layer
-            obj = new OpenLayers.Layer.WMS.Untiled(this.name,
-                                                   this.url,
-                                                   this.params,
-                                                   this.options);
-        obj = OpenLayers.Layer.WMS.prototype.clone.apply(this, [obj]);
-        return obj;
-    CLASS_NAME: "OpenLayers.Layer.WMS.Untiled"
-    OpenLayers/Format/SLD.js
-/* Copyright (c) 2006 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * for the full text of the license. */
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Style.js
- * @requires OpenLayers/Filter/FeatureId.js
- * @requires OpenLayers/Filter/Logical.js
- * @requires OpenLayers/Filter/Comparison.js
- * Class: OpenLayers.Format.SLD
- * Read/Wite SLD. Create a new instance with the <OpenLayers.Format.SLD>
- *     constructor.
- * Inherits from:
- *  - <OpenLayers.Format.XML>
-OpenLayers.Format.SLD = OpenLayers.Class(OpenLayers.Format.XML, {
-     * APIProperty: defaultVersion
-     * {String} Version number to assume if none found.  Default is "1.0.0".
-    defaultVersion: "1.0.0",
-     * APIProperty: version
-     * {String} Specify a version string if one is known.
-    version: null,
-     * Property: parser
-     * {Object} Instance of the versioned parser.  Cached for multiple read and
-     *     write calls of the same version.
-    parser: null,
-     * Constructor: OpenLayers.Format.SLD
-     * Create a new parser for SLD.
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
-     * APIMethod: write
-     * Write a SLD document given a list of styles.
-     * Parameters:
-     * sld - {Object} An object representing the SLD.
-     * options - {Object} Optional configuration object.
-     * Returns:
-     * {String} An SLD document string.
-    write: function(sld, options) {
-        var version = (options && options.version) ||
-                      this.version || this.defaultVersion;
-        if(!this.parser || this.parser.VERSION != version) {
-            var format = OpenLayers.Format.SLD[
-                "v" + version.replace(/\./g, "_")
-            if(!format) {
-                throw "Can't find a SLD parser for version " +
-                      version;
-            this.parser = new format(this.options);
-        var root = this.parser.write(sld);
-        return OpenLayers.Format.XML.prototype.write.apply(this, [root]);
-     * APIMethod: read
-     * Read and SLD doc and return an object representing the SLD.
-     * Parameters:
-     * data - {String | DOMElement} Data to read.
-     * Returns:
-     * {Object} An object representing the SLD.
-    read: function(data) {
-        if(typeof data == "string") {
-            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
-        var root = data.documentElement;
-        var version = this.version;
-        if(!version) {
-            version = root.getAttribute("version");
-            if(!version) {
-                version = this.defaultVersion;
-            if(!format) {
-                      version;
-        var sld = this.parser.read(data);
-        return sld;
-    CLASS_NAME: "OpenLayers.Format.SLD"
-    OpenLayers/Format/Text.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under a modified BSD license.
- * @requires OpenLayers/Feature/Vector.js
- * @requires OpenLayers/Geometry/Point.js
- * Class: OpenLayers.Format.Text
- * Read Text format. Create a new instance with the <OpenLayers.Format.Text>
- *     constructor. This reads text which is formatted like CSV text, using
- *     tabs as the seperator by default. It provides parsing of data originally
- *     used in the MapViewerService, described on the wiki. This Format is used
- *     by the <OpenLayers.Layer.Text> class.
- * Inherits from:
- *  - <OpenLayers.Format>
-OpenLayers.Format.Text = OpenLayers.Class(OpenLayers.Format, {
-     * Constructor: OpenLayers.Format.Text
-     * Create a new parser for TSV Text.
-     * Parameters:
-     *     this instance.
-        OpenLayers.Format.prototype.initialize.apply(this, [options]);
-     * APIMethod: read
-     * Return a list of features from a Tab Seperated Values text string.
-     * Parameters:
-     * data - {String}
-     * Returns:
-     * An Array of <OpenLayers.Feature.Vector>s
-    read: function(text) {
-        var lines = text.split('\n');
-        var columns;
-        var features = [];
-        // length - 1 to allow for trailing new line
-        for (var lcv = 0; lcv < (lines.length - 1); lcv++) {
-            var currLine = lines[lcv].replace(/^\s*/,'').replace(/\s*$/,'');
-            if (currLine.charAt(0) != '#') { /* not a comment */
-                if (!columns) {
-                    //First line is columns
-                    columns = currLine.split('\t');
-                } else {
-                    var vals = currLine.split('\t');
-                    var geometry = new OpenLayers.Geometry.Point(0,0);
-                    var attributes = {};
-                    var style = {};
-                    var icon, iconSize, iconOffset, overflow;
-                    var set = false;
-                    for (var valIndex = 0; valIndex < vals.length; valIndex++) {
-                        if (vals[valIndex]) {
-                            if (columns[valIndex] == 'point') {
-                                var coords = vals[valIndex].split(',');
-                                geometry.y = parseFloat(coords[0]);
-                                geometry.x = parseFloat(coords[1]);
-                                set = true;
-                            } else if (columns[valIndex] == 'lat') {
-                                geometry.y = parseFloat(vals[valIndex]);
-                                set = true;
-                            } else if (columns[valIndex] == 'lon') {
-                                geometry.x = parseFloat(vals[valIndex]);
-                                set = true;
-                            } else if (columns[valIndex] == 'title')
-                                attributes['title'] = vals[valIndex];
-                            else if (columns[valIndex] == 'image' ||
-                                     columns[valIndex] == 'icon')
-                                style['externalGraphic'] = vals[valIndex];
-                            else if (columns[valIndex] == 'iconSize') {
-                                var size = vals[valIndex].split(',');
-                                style['graphicWidth'] = parseFloat(size[0]);
-                                style['graphicHeight'] = parseFloat(size[1]);
-                            } else if (columns[valIndex] == 'iconOffset') {
-                                var offset = vals[valIndex].split(',');
-                                style['graphicXOffset'] = parseFloat(offset[0]);
-                                style['graphicYOffset'] = parseFloat(offset[1]);
-                            } else if (columns[valIndex] == 'description') {
-                                attributes['description'] = vals[valIndex];
-                            } else if (columns[valIndex] == 'overflow') {
-                                attributes['overflow'] = vals[valIndex];
-                    if (set) {
-                      if (this.internalProjection && this.externalProjection) {
-                          geometry.transform(this.externalProjection,
-                                             this.internalProjection);
-                      var feature = new OpenLayers.Feature.Vector(geometry, attributes, style);
-                      features.push(feature);
-        return features;
-    CLASS_NAME: "OpenLayers.Format.Text"
-    OpenLayers/Geometry/MultiLineString.js
- * @requires OpenLayers/Geometry/Collection.js
- * Class: OpenLayers.Geometry.MultiLineString
- * A MultiLineString is a geometry with multiple <OpenLayers.Geometry.LineString>
- * components.
- * Inherits from:
- *  - <OpenLayers.Geometry.Collection>
-OpenLayers.Geometry.MultiLineString = OpenLayers.Class(
-  OpenLayers.Geometry.Collection, {
-    componentTypes: ["OpenLayers.Geometry.LineString"],
-     * Constructor: OpenLayers.Geometry.MultiLineString
-     * Constructor for a MultiLineString Geometry.
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry.LineString>)}
-    initialize: function(components) {
-        OpenLayers.Geometry.Collection.prototype.initialize.apply(this,
-        arguments);
-    CLASS_NAME: "OpenLayers.Geometry.MultiLineString"
-    OpenLayers/Geometry/MultiPoint.js
- * Class: OpenLayers.Geometry.MultiPoint
- * MultiPoint is a collection of Points.  Create a new instance with the
- * <OpenLayers.Geometry.MultiPoint> constructor.
- * Inherits from:
-OpenLayers.Geometry.MultiPoint = OpenLayers.Class(
-    componentTypes: ["OpenLayers.Geometry.Point"],
-     * Constructor: OpenLayers.Geometry.MultiPoint
-     * Create a new MultiPoint Geometry
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry.Point>)}
-     * Returns:
-     * {<OpenLayers.Geometry.MultiPoint>}
-        arguments);
-     * APIMethod: addPoint
-     * Wrapper for <OpenLayers.Geometry.Collection.addComponent>
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>} Point to be added
-     * index - {Integer} Optional index
-    addPoint: function(point, index) {
-        this.addComponent(point, index);
-     * APIMethod: removePoint
-     * Wrapper for <OpenLayers.Geometry.Collection.removeComponent>
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>} Point to be removed
-    removePoint: function(point){
-        this.removeComponent(point);
-    CLASS_NAME: "OpenLayers.Geometry.MultiPoint"
-    OpenLayers/Geometry/MultiPolygon.js
- * Class: OpenLayers.Geometry.MultiPolygon
- * MultiPolygon is a geometry with multiple <OpenLayers.Geometry.Polygon>
- * components.  Create a new instance with the <OpenLayers.Geometry.MultiPolygon>
- * constructor.
- * Inherits from:
-OpenLayers.Geometry.MultiPolygon = OpenLayers.Class(
-    componentTypes: ["OpenLayers.Geometry.Polygon"],
-     * Constructor: OpenLayers.Geometry.MultiPolygon
-     * Create a new MultiPolygon geometry
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry.Polygon>)} An array of polygons
-     *              used to generate the MultiPolygon
-        arguments);
-    CLASS_NAME: "OpenLayers.Geometry.MultiPolygon"
-    OpenLayers/Geometry/Polygon.js
- * Class: OpenLayers.Geometry.Polygon
- * Polygon is a collection of Geometry.LinearRings.
- * Inherits from:
-OpenLayers.Geometry.Polygon = OpenLayers.Class(
-    componentTypes: ["OpenLayers.Geometry.LinearRing"],
-     * Constructor: OpenLayers.Geometry.Polygon
-     * Constructor for a Polygon geometry.
-     * The first ring (this.component[0])is the outer bounds of the polygon and
-     * all subsequent rings (this.component[1-n]) are internal holes.
-     * Parameters:
-     * components - {Array(<OpenLayers.Geometry.LinearRing>)}
-        arguments);
-     * Calculated by subtracting the areas of the internal holes from the
-     *   area of the outer hole.
-     * Returns:
-     * {float} The area of the geometry
-    getArea: function() {
-        var area = 0.0;
-        if ( this.components && (this.components.length > 0)) {
-            area += Math.abs(this.components[0].getArea());
-                area -= Math.abs(this.components[i].getArea());
-        return area;
-     * Method: containsPoint
-     * Test if a point is inside a polygon.  Points on a polygon edge are
-     *     considered inside.
-     * Parameters:
-     * Returns:
-     * {Boolean | Number} The point is inside the polygon.  Returns 1 if the
-     *     point is on an edge.  Returns boolean otherwise.
-    containsPoint: function(point) {
-        var numRings = this.components.length;
-        var contained = false;
-        if(numRings > 0) {
-            // check exterior ring - 1 means on edge, boolean otherwise
-            contained = this.components[0].containsPoint(point);
-            if(contained !== 1) {
-                if(contained && numRings > 1) {
-                    // check interior rings
-                    var hole;
-                    for(var i=1; i<numRings; ++i) {
-                        hole = this.components[i].containsPoint(point);
-                        if(hole) {
-                            if(hole === 1) {
-                                // on edge
-                                contained = 1;
-                            } else {
-                                // in hole
-                                contained = false;
-                            break;
-        return contained;
-     * Parameters:
-     * Returns:
-        var i;
-        if(geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
-            intersect = this.containsPoint(geometry);
-        } else if(geometry.CLASS_NAME == "OpenLayers.Geometry.LineString" ||
-                  geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing") {
-            // check if rings/linestrings intersect
-            for(i=0; i<this.components.length; ++i) {
-                if(intersect) {
-                    break;
-            if(!intersect) {
-                // check if this poly contains points of the ring/linestring
-                for(i=0; i<geometry.components.length; ++i) {
-                    intersect = this.containsPoint(geometry.components[i]);
-                    if(intersect) {
-                        break;
-        } else {
-            for(i=0; i<geometry.components.length; ++ i) {
-                intersect = this.intersects(geometry.components[i]);
-                if(intersect) {
-                    break;
-        // check case where this poly is wholly contained by another
-        if(!intersect && geometry.CLASS_NAME == "OpenLayers.Geometry.Polygon") {
-            // exterior ring points will be contained in the other geometry
-            var ring = this.components[0];
-            for(i=0; i<ring.components.length; ++i) {
-                intersect = geometry.containsPoint(ring.components[i]);
-                if(intersect) {
-                    break;
-        return intersect;
-    CLASS_NAME: "OpenLayers.Geometry.Polygon"
- * APIMethod: createRegularPolygon
- * Create a regular polygon around a radius. Useful for creating circles
- * and the like.
- * Parameters:
- * origin - {<OpenLayers.Geometry.Point>} center of polygon.
- * radius - {Float} distance to vertex, in map units.
- * sides - {Integer} Number of sides. 20 approximates a circle.
- * rotation - {Float} original angle of rotation, in degrees.
-OpenLayers.Geometry.Polygon.createRegularPolygon = function(origin, radius, sides, rotation) {
-    var angle = Math.PI * ((1/sides) - (1/2));
-    if(rotation) {
-        angle += (rotation / 180) * Math.PI;
-    var rotatedAngle, x, y;
-    var points = [];
-    for(var i=0; i<sides; ++i) {
-        rotatedAngle = angle + (i * 2 * Math.PI / sides);
-        x = origin.x + (radius * Math.cos(rotatedAngle));
-        y = origin.y + (radius * Math.sin(rotatedAngle));
-        points.push(new OpenLayers.Geometry.Point(x, y));
-    var ring = new OpenLayers.Geometry.LinearRing(points);
-    return new OpenLayers.Geometry.Polygon([ring]);
-    OpenLayers/Handler/Point.js
- * @requires OpenLayers/Handler.js
- * Class: OpenLayers.Handler.Point
- * Handler to draw a point on the map.  Point is displayed on mouse down,
- * moves on mouse move, and is finished on mouse up.  The handler triggers
- * callbacks for 'done' and 'cancel'.  Create a new instance with the
- * <OpenLayers.Handler.Point> constructor.
- * Inherits from:
- *  - <OpenLayers.Handler>
-OpenLayers.Handler.Point = OpenLayers.Class(OpenLayers.Handler, {
-     * Property: point
-     * {<OpenLayers.Feature.Vector>} The currently drawn point
-    point: null,
-     * Property: layer
-     * {<OpenLayers.Layer.Vector>} The temporary drawing layer
-    layer: null,
-     * Property: drawing
-     * {Boolean} A point is being drawn
-    drawing: false,
-     * Property: mouseDown
-     * {Boolean} The mouse is down
-    mouseDown: false,
-     * Property: lastDown
-     * {<OpenLayers.Pixel>} Location of the last mouse down
-    lastDown: null,
-     * Property: lastUp
-    lastUp: null,
-     * Constructor: OpenLayers.Handler.Point
-     * Create a new point handler.
-     * Parameters:
-     * control - {<OpenLayers.Control>} The control that owns this handler
-     * callbacks - {Object} An object with a 'done' property whose value is a
-     *             function to be called when the point drawing is finished.
-     *             The callback should expect to recieve a single argument,
-     *             the point geometry.  If the callbacks object contains a
-     *             'cancel' property, this function will be called when the
-     *             handler is deactivated while drawing.  The cancel should
-     *             expect to receive a geometry.
-     * options - {Object} An optional object with properties to be set on the
-     *           handler
-    initialize: function(control, callbacks, options) {
-        // TBD: deal with style
-        this.style = OpenLayers.Util.extend(OpenLayers.Feature.Vector.style['default'], {});
-        OpenLayers.Handler.prototype.initialize.apply(this, arguments);
-     * APIMethod: activate
-     * turn on the handler
-    activate: function() {
-        if(!OpenLayers.Handler.prototype.activate.apply(this, arguments)) {
-            return false;
-        // create temporary vector layer for rendering geometry sketch
-        // TBD: this could be moved to initialize/destroy - setting visibility here
-        var options = {
-            displayInLayerSwitcher: false,
-            // indicate that the temp vector layer will never be out of range
-            // without this, resolution properties must be specified at the
-            // map-level for this temporary layer to init its resolutions
-            // correctly
-            calculateInRange: function() { return true; }
-        this.layer = new OpenLayers.Layer.Vector(this.CLASS_NAME, options);
-        this.map.addLayer(this.layer);
-        return true;
-     * Method: createFeature
-     * Add temporary features
-    createFeature: function() {
-        this.point = new OpenLayers.Feature.Vector(
-                                              new OpenLayers.Geometry.Point());
-     * APIMethod: deactivate
-     * turn off the handler
-    deactivate: function() {
-        if(!OpenLayers.Handler.prototype.deactivate.apply(this, arguments)) {
-            return false;
-        // call the cancel callback if mid-drawing
-        if(this.drawing) {
-            this.cancel();
-        // If a layer's map property is set to null, it means that that layer
-        // isn't added to the map. Since we ourself added the layer to the map
-        // in activate(), we can assume that if this.layer.map is null it means
-        // that the layer has been destroyed (as a result of map.destroy() for
-        // example.
-        if (this.layer.map != null) {
-            this.layer.destroy(false);
-        this.layer = null;
-        return true;
-     * Method: destroyFeature
-     * Destroy the temporary geometries
-    destroyFeature: function() {
-        if(this.point) {
-            this.point.destroy();
-        this.point = null;
-     * Method: finalize
-     * Finish the geometry and call the "done" callback.
-    finalize: function() {
-        this.layer.renderer.clear();
-        this.drawing = false;
-        this.mouseDown = false;
-        this.lastDown = null;
-        this.lastUp = null;
-        this.callback("done", [this.geometryClone()]);
-        this.destroyFeature();
-     * APIMethod: cancel
-     * Finish the geometry and call the "cancel" callback.
-    cancel: function() {
-        this.callback("cancel", [this.geometryClone()]);
-     * Method: click
-     * Handle clicks.  Clicks are stopped from propagating to other listeners
-     *     on map.events or other dom elements.
-     * Parameters:
-     * evt - {Event} The browser event
-     * Returns:
-     * {Boolean} Allow event propagation
-    click: function(evt) {
-        OpenLayers.Event.stop(evt);
-        return false;
-     * Method: dblclick
-     * Handle double-clicks.  Double-clicks are stopped from propagating to other
-     *     listeners on map.events or other dom elements.
-     * Parameters:
-     * Returns:
-    dblclick: function(evt) {
-        return false;
-     * Method: drawFeature
-     * Render features on the temporary layer.
-    drawFeature: function() {
-        this.layer.drawFeature(this.point, this.style);
-     * Method: geometryClone
-     * Return a clone of the relevant geometry.
-     * Returns:
-    geometryClone: function() {
-        return this.point.geometry.clone();
-     * Method: mousedown
-     * Handle mouse down.  Adjust the geometry and redraw.
-     * Return determines whether to propagate the event on the map.
-     * Parameters:
-     * Returns:
-    mousedown: function(evt) {
-        // check keyboard modifiers
-        if(!this.checkModifiers(evt)) {
-            return true;
-        // ignore double-clicks
-        if(this.lastDown && this.lastDown.equals(evt.xy)) {
-            return true;
-        if(this.lastDown == null) {
-            this.createFeature();
-        this.lastDown = evt.xy;
-        this.drawing = true;
-        var lonlat = this.map.getLonLatFromPixel(evt.xy);
-        this.point.geometry.x = lonlat.lon;
-        this.point.geometry.y = lonlat.lat;
-        this.drawFeature();
-        return false;
-     * Method: mousemove
-     * Handle mouse move.  Adjust the geometry and redraw.
-     * Parameters:
-     * Returns:
-    mousemove: function (evt) {
-            this.point.geometry.clearBounds();
-        return true;
-     * Method: mouseup
-     * Handle mouse up.  Send the latest point in the geometry to the control.
-     * Parameters:
-     * Returns:
-    mouseup: function (evt) {
-            this.finalize();
-            return false;
-        } else {
-            return true;
-    CLASS_NAME: "OpenLayers.Handler.Point"
-    OpenLayers/Layer/GML.js
- * @requires OpenLayers/Layer/Vector.js
- * @requires OpenLayers/Ajax.js
- * Class: OpenLayers.Layer.GML
- * Create a vector layer by parsing a GML file. The GML file is
- *     passed in as a parameter.
- * Inherits from:
- *  - <OpenLayers.Layer.Vector>
-OpenLayers.Layer.GML = OpenLayers.Class(OpenLayers.Layer.Vector, {
-      * Property: loaded
-      * {Boolean} Flag for whether the GML data has been loaded yet.
-    loaded: false,
-      * APIProperty: format
-      * {<OpenLayers.Format>} The format you want the data to be parsed with.
-    format: null,
-     * APIProperty: formatOptions
-     * {Object} Hash of options which should be passed to the format when it is
-     * created. Must be passed in the constructor.
-    formatOptions: null,
-     * Constructor: OpenLayers.Layer.GML
-     * Load and parse a single file on the web, according to the format
-     * provided via the 'format' option, defaulting to GML.
-     * Parameters:
-     * name - {String}
-     * url - {String} URL of a GML file.
-     * options - {Object} Hashtable of extra options to tag onto the layer.
-     initialize: function(name, url, options) {
-        var newArguments = [];
-        newArguments.push(name, options);
-        OpenLayers.Layer.Vector.prototype.initialize.apply(this, newArguments);
-        this.url = url;
-     * APIMethod: setVisibility
-     * Set the visibility flag for the layer and hide/show&redraw accordingly.
-     * Fire event unless otherwise specified
-     * GML will be loaded if the layer is being made visible for the first
-     * time.
-     * Parameters:
-     * visible - {Boolean} Whether or not to display the layer
-     *                          (if in range)
-     * noEvent - {Boolean}
-    setVisibility: function(visibility, noEvent) {
-        OpenLayers.Layer.Vector.prototype.setVisibility.apply(this, arguments);
-        if(this.visibility && !this.loaded){
-            // Load the GML
-            this.loadGML();
-     * Method: moveTo
-     * If layer is visible and GML has not been loaded, load GML, then load GML
-     * and call OpenLayers.Layer.Vector.moveTo() to redraw at the new location.
-     * Parameters:
-     * bounds - {Object}
-     * zoomChanged - {Object}
-     * minor - {Object}
-    moveTo:function(bounds, zoomChanged, minor) {
-        OpenLayers.Layer.Vector.prototype.moveTo.apply(this, arguments);
-        // Wait until initialisation is complete before loading GML
-        // otherwise we can get a race condition where the root HTML DOM is
-        // loaded after the GML is paited.
-        // See http://trac.openlayers.org/ticket/404
-            this.events.triggerEvent("loadstart");
-            this.loadGML();
-     * Method: loadGML
-    loadGML: function() {
-        if (!this.loaded) {
-            var results = OpenLayers.loadURL(this.url, null, this, this.requestSuccess, this.requestFailure);
-            this.loaded = true;
-     * Method: setUrl
-     * Change the URL and reload the GML
-     * Parameters:
-    setUrl:function(url) {
-        this.url = url;
-        this.loaded = false;
-        this.loadGML();
-     * Method: requestSuccess
-     * Process GML after it has been loaded.
-     * Called by initialise() and loadUrl() after the GML has been loaded.
-     * Parameters:
-     * request - {String}
-    requestSuccess:function(request) {
-        var doc = request.responseXML;
-        if (!doc || !doc.documentElement) {
-            doc = request.responseText;
-        var options = {};
-        OpenLayers.Util.extend(options, this.formatOptions);
-        if (this.map && !this.projection.equals(this.map.getProjectionObject())) {
-            options.externalProjection = this.projection;
-            options.internalProjection = this.map.getProjectionObject();
-        var gml = this.format ? new this.format(options) : new OpenLayers.Format.GML(options);
-        this.addFeatures(gml.read(doc));
-        this.events.triggerEvent("loadend");
-     * Method: requestFailure
-     * Process a failed loading of GML.
-     * Called by initialise() and loadUrl() if there was a problem loading GML.
-     * Parameters:
-    requestFailure: function(request) {
-        alert(OpenLayers.i18n("errorLoadingGML", {'url':this.url}));
-    CLASS_NAME: "OpenLayers.Layer.GML"
-    OpenLayers/Layer/PointTrack.js
-/* Copyright (c) 2006-2007 MetaCarta, Inc., published under the Clear BSD
- * Class: OpenLayers.Layer.PointTrack
- * Vector layer to display ordered point features as a line, creating one
- * LineString feature for each pair of two points.
- * Inherits from:
-OpenLayers.Layer.PointTrack = OpenLayers.Class(OpenLayers.Layer.Vector, {
-     * APIProperty:
-     * dataFrom  - {<OpenLayers.Layer.PointTrack.dataFrom>} optional. If the
-     *             lines should get the data/attributes from one of the two
-     *             points, creating it, which one should it be?
-    dataFrom: null,
-     * Constructor: OpenLayers.PointTrack
-     * Constructor for a new OpenLayers.PointTrack instance.
-     * Parameters:
-     * name     - {String} name of the layer
-     * options  - {Object} Optional object with properties to tag onto the
-     *            instance.
-        OpenLayers.Layer.Vector.prototype.initialize.apply(this, arguments);
-     * APIMethod: addNodes
-     * Adds point features that will be used to create lines from, using point
-     * pairs. The first point of a pair will be the source node, the second
-     * will be the target node.
-     * Parameters:
-     * pointFeatures - {Array(<OpenLayers.Feature>)}
-    addNodes: function(pointFeatures) {
-        if (pointFeatures.length < 2) {
-                    "At least two point features have to be added to create" +
-                    "a line from");
-            return;
-        var lines = new Array(pointFeatures.length-1);
-        var pointFeature, startPoint, endPoint;
-        for(var i = 0; i < pointFeatures.length; i++) {
-            pointFeature = pointFeatures[i];
-            endPoint = pointFeature.geometry;
-            if (!endPoint) {
-              var lonlat = pointFeature.lonlat;
-              endPoint = new OpenLayers.Geometry.Point(lonlat.lon, lonlat.lat);
-            } else if(endPoint.CLASS_NAME != "OpenLayers.Geometry.Point") {
-                        "Only features with point geometries are supported.");
-                return;
-            if(i > 0) {
-                var attributes = (this.dataFrom != null) ?
-                        (pointFeatures[i+this.dataFrom].data ||
-                                pointFeatures[i+this.dataFrom].attributes) :
-                        null;
-                var line = new OpenLayers.Geometry.LineString([startPoint,
-                        endPoint]);
-                lines[i-1] = new OpenLayers.Feature.Vector(line, attributes);
-            startPoint = endPoint;
-        this.addFeatures(lines);
-    CLASS_NAME: "OpenLayers.Layer.PointTrack"
- * Constant: OpenLayers.Layer.PointTrack.dataFrom
- * {Object} with the following keys
- * - SOURCE_NODE: take data/attributes from the source node of the line
- * - TARGET_NODE: take data/attributes from the target node of the line
-OpenLayers.Layer.PointTrack.dataFrom = {'SOURCE_NODE': -1, 'TARGET_NODE': 0};
-    OpenLayers/Layer/WFS.js
- * @requires OpenLayers/Layer/Markers.js
- * Class: OpenLayers.Layer.WFS
- * Inherits from:
- *  - <OpenLayers.Layer.Markers>
-OpenLayers.Layer.WFS = OpenLayers.Class(
-  OpenLayers.Layer.Vector, OpenLayers.Layer.Markers, {
-     * APIProperty: isBaseLayer
-     * {Boolean} WFS layer is not a base layer by default.
-     * Property: tile
-     * {<OpenLayers.Tile.WFS>}
-    tile: null,
-     * APIProperty: ratio
-     * {Float} the ratio of image/tile size to map size (this is the untiled
-     *     buffer)
-    ratio: 2,
-     * Property: DEFAULT_PARAMS
-     * {Object} Hashtable of default key/value parameters
-    DEFAULT_PARAMS: { service: "WFS",
-                      version: "1.0.0",
-                      request: "GetFeature"
-     * APIProperty: featureClass
-     * {<OpenLayers.Feature>} If featureClass is defined, an old-style markers
-     *     based WFS layer is created instead of a new-style vector layer. If
-     *     sent, this should be a subclass of OpenLayers.Feature
-    featureClass: null,
-      * Must be passed in the constructor. Should be a class, not an instance.
-    format: null,
-     * Property: formatObject
-     * {<OpenLayers.Format>} Internally created/managed format object, used by
-     * the Tile to parse data.
-    formatObject: null,
-     * Property: vectorMode
-     * {Boolean} Should be calculated automatically.
-    vectorMode: true,
-     * APIProperty: encodeBBOX
-     * {Boolean} Should the BBOX commas be encoded? The WMS spec says 'no',
-     *     but some services want it that way. Default false.
-    encodeBBOX: false,
-     * APIProperty: extractAttributes
-     * {Boolean} Should the WFS layer parse attributes from the retrieved
-     *     GML? Defaults to false. If enabled, parsing is slower, but
-     *     attributes are available in the attributes property of
-     *     layer features.
-    extractAttributes: false,
-     * Constructor: OpenLayers.Layer.WFS
-     * Parameters:
-     * name - {String}
-     * url - {String}
-     * params - {Object}
-    initialize: function(name, url, params, options) {
-        if (options == undefined) { options = {}; }
-        if (options.featureClass ||
-            !OpenLayers.Layer.Vector ||
-            !OpenLayers.Feature.Vector) {
-            this.vectorMode = false;
-        // Turn off error reporting, browsers like Safari may work
-        // depending on the setup, and we don't want an unneccesary alert.
-        OpenLayers.Util.extend(options, {'reportError': false});
-        if (!this.renderer || !this.vectorMode) {
-            if (!options.featureClass) {
-                options.featureClass = OpenLayers.Feature.WFS;
-            OpenLayers.Layer.Markers.prototype.initialize.apply(this,
-        newArguments);
-        if (this.params && this.params.typename && !this.options.typename) {
-            this.options.typename = this.params.typename;
-        if (!this.options.geometry_column) {
-            this.options.geometry_column = "the_geom";
-        this.params = params;
-                       this.params,
-                       OpenLayers.Util.upperCaseObject(this.DEFAULT_PARAMS)
-        this.url = url;
-    destroy: function() {
-        if (this.vectorMode) {
-            OpenLayers.Layer.Vector.prototype.destroy.apply(this, arguments);
-        } else {
-            OpenLayers.Layer.Markers.prototype.destroy.apply(this, arguments);
-        if (this.tile) {
-            this.tile.destroy();
-        this.tile = null;
-        this.ratio = null;
-        this.featureClass = null;
-        this.format = null;
-        if (this.formatObject && this.formatObject.destroy) {
-            this.formatObject.destroy();
-        this.formatObject = null;
-        this.formatOptions = null;
-        this.vectorMode = null;
-        this.encodeBBOX = null;
-        this.extractAttributes = null;
-     * Method: setMap
-     * Parameters:
-     * map - {<OpenLayers.Map>}
-    setMap: function(map) {
-            OpenLayers.Layer.Vector.prototype.setMap.apply(this, arguments);
-            var options = {
-              'extractAttributes': this.extractAttributes
-            this.formatObject = this.format ? new this.format(options) : new OpenLayers.Format.GML(options);
-        } else {
-            OpenLayers.Layer.Markers.prototype.setMap.apply(this, arguments);
-     * Method: moveTo
-     * Parameters:
-     * bounds - {<OpenLayers.Bounds>}
-    moveTo:function(bounds, zoomChanged, dragging) {
-        } else {
-            OpenLayers.Layer.Markers.prototype.moveTo.apply(this, arguments);
-        // don't load wfs features while dragging, wait for drag end
-        if (dragging) {
-            // TBD try to hide the vector layer while dragging
-            // this.setVisibility(false);
-            // this will probably help for panning performances
-            return false;
-        if ( zoomChanged ) {
-                this.renderer.clear();
-    //DEPRECATED - REMOVE IN 3.0
-        // don't load data if current zoom level doesn't match
-        if (this.options.minZoomLevel) {
-            OpenLayers.Console.warn(OpenLayers.i18n('minZoomLevelError'));
-            if (this.map.getZoom() < this.options.minZoomLevel) {
-                return null;
-        if (bounds == null) {
-            bounds = this.map.getExtent();
-        var firstRendering = (this.tile == null);
-        //does the new bounds to which we need to move fall outside of the
-        // current tile's bounds?
-        var outOfBounds = (!firstRendering &&
-                           !this.tile.bounds.containsBounds(bounds));
-        if (zoomChanged || firstRendering || (!dragging && outOfBounds)) {
-            //determine new tile bounds
-            var center = bounds.getCenterLonLat();
-            var tileWidth = bounds.getWidth() * this.ratio;
-            var tileHeight = bounds.getHeight() * this.ratio;
-            var tileBounds =
-                new OpenLayers.Bounds(center.lon - (tileWidth / 2),
-                                      center.lat - (tileHeight / 2),
-                                      center.lon + (tileWidth / 2),
-                                      center.lat + (tileHeight / 2));
-            //determine new tile size
-            var tileSize = this.map.getSize();
-            tileSize.w = tileSize.w * this.ratio;
-            tileSize.h = tileSize.h * this.ratio;
-            //determine new position (upper left corner of new bounds)
-            var ul = new OpenLayers.LonLat(tileBounds.left, tileBounds.top);
-            var pos = this.map.getLayerPxFromLonLat(ul);
-            //formulate request url string
-            var url = this.getFullRequestString();
-            var params = {BBOX: this.encodeBBOX ? tileBounds.toBBOX()
-                                                : tileBounds.toArray()};
-                var projectedBounds = tileBounds.clone();
-                projectedBounds.transform(this.map.getProjectionObject(),
-                                          this.projection);
-                params.BBOX = this.encodeBBOX ? projectedBounds.toBBOX()
-                                              : projectedBounds.toArray();
-            url += "&" + OpenLayers.Util.getParameterString(params);
-            if (!this.tile) {
-                this.tile = new OpenLayers.Tile.WFS(this, pos, tileBounds,
-                                                     url, tileSize);
-                this.addTileMonitoringHooks(this.tile);
-                this.tile.draw();
-            } else {
-                } else {
-                    this.clearMarkers();
-                this.removeTileMonitoringHooks(this.tile);
-                this.tile = null;
-                                                     url, tileSize);
-                this.tile.draw();
-     * Method: addTileMonitoringHooks
-     * This function takes a tile as input and adds the appropriate hooks to
-     *     the tile so that the layer can keep track of the loading tile
-     *     (making sure to check that the tile is always the layer's current
-     *     tile before taking any action).
-     * Parameters:
-     * tile - {<OpenLayers.Tile>}
-    addTileMonitoringHooks: function(tile) {
-        tile.onLoadStart = function() {
-            //if this is the the layer's current tile, then trigger
-            // a 'loadstart'
-            if (this == this.layer.tile) {
-                this.layer.events.triggerEvent("loadstart");
-        tile.events.register("loadstart", tile, tile.onLoadStart);
-        tile.onLoadEnd = function() {
-            // a 'tileloaded' and 'loadend'
-                this.layer.events.triggerEvent("tileloaded");
-                this.layer.events.triggerEvent("loadend");
-        tile.events.register("loadend", tile, tile.onLoadEnd);
-        tile.events.register("unload", tile, tile.onLoadEnd);
-     * Method: removeTileMonitoringHooks
-     * This function takes a tile as input and removes the tile hooks
-     *     that were added in addTileMonitoringHooks()
-     * Parameters:
-    removeTileMonitoringHooks: function(tile) {
-        tile.unload();
-        tile.events.un({
-            "loadstart": tile.onLoadStart,
-            "loadend": tile.onLoadEnd,
-            "unload": tile.onLoadEnd,
-            scope: tile
-     * Call the onMapResize method of the appropriate parent class.
-        if(this.vectorMode) {
-            OpenLayers.Layer.Vector.prototype.onMapResize.apply(this,
-        arguments);
-        } else {
-            OpenLayers.Layer.Markers.prototype.onMapResize.apply(this,
-        arguments);
-     * APIMethod: mergeNewParams
-     * Modify parameters for the layer and redraw.
-     * Parameters:
-     * newParams - {Object}
-    mergeNewParams:function(newParams) {
-        var upperParams = OpenLayers.Util.upperCaseObject(newParams);
-        var newArguments = [upperParams];
-        return OpenLayers.Layer.HTTPRequest.prototype.mergeNewParams.apply(this,
-        newArguments);
-     * APIMethod: clone
-     * Parameters:
-     * obj - {Object}
-     * Returns:
-     * {<OpenLayers.Layer.WFS>} An exact clone of this OpenLayers.Layer.WFS
-    clone: function (obj) {
-        if (obj == null) {
-            obj = new OpenLayers.Layer.WFS(this.name,
-                                           this.url,
-                                           this.params,
-                                           this.options);
-        //get all additions from superclasses
-            obj = OpenLayers.Layer.Vector.prototype.clone.apply(this, [obj]);
-        } else {
-            obj = OpenLayers.Layer.Markers.prototype.clone.apply(this, [obj]);
-        // copy/set any non-init, non-simple values here
-        return obj;
-     * APIMethod: getFullRequestString
-     * combine the layer's url with its params and these newParams.
-     *    Add the SRS parameter from 'projection' -- this is probably
-     *     more eloquently done via a setProjection() method, but this
-     *     works for now and always.
-     * Parameters:
-     * altUrl - {String} Use this as the url instead of the layer's url
-    getFullRequestString:function(newParams, altUrl) {
-        var projectionCode = this.map.getProjection();
-        this.params.SRS = (projectionCode == "none") ? null : projectionCode;
-        return OpenLayers.Layer.Grid.prototype.getFullRequestString.apply(
-                                                    this, arguments);
-     * APIMethod: commit
-     * Write out the data to a WFS server.
-    commit: function() {
-        if (!this.writer) {
-            var options = {};
-            this.writer = new OpenLayers.Format.WFS(options,this);
-        var data = this.writer.write(this.features);
-        var url = this.url;
-        var success = OpenLayers.Function.bind(this.commitSuccess, this);
-        var failure = OpenLayers.Function.bind(this.commitFailure, this);
-        // from prototype.js
-        new OpenLayers.Ajax.Request(url,
-                         {   method: 'post',
-                             postBody: data,
-                             onComplete: success,
-                             onFailure: failure
-     * Method: commitSuccess
-     * Called when the Ajax request returns a response
-     * Parameters:
-     * response - {XmlNode} from server
-    commitSuccess: function(request) {
-        var response = request.responseText;
-        if (response.indexOf('SUCCESS') != -1) {
-            this.commitReport(OpenLayers.i18n("commitSuccess", {'response':response}));
-                this.features[i].state = null;
-            // TBD redraw the layer or reset the state of features
-            // foreach features: set state to null
-        } else if (response.indexOf('FAILED') != -1 ||
-            response.indexOf('Exception') != -1) {
-            this.commitReport(OpenLayers.i18n("commitFailed", {'response':response}));
-     * Method: commitFailure
-     * Called when the Ajax request fails
-     * Parameters:
-    commitFailure: function(request) {},
-     * APIMethod: commitReport
-     * Called with a 'success' message if the commit succeeded, otherwise
-     *     a failure message, and the full request text as a second parameter.
-     *     Override this function to provide custom transaction reporting.
-     * string - {String} reporting string
-     * response - {String} full XML response
-    commitReport: function(string, response) {
-        alert(string);
-     * APIMethod: refresh
-     * Refreshes all the features of the layer
-    refresh: function() {
-        if (this.tile) {
-                this.features.length = 0;
-            } else {
-                this.markers.length = 0;
-            this.tile.draw();
-    CLASS_NAME: "OpenLayers.Layer.WFS"
-    OpenLayers/Format/SLD/v1.js
- * @requires OpenLayers/Format/SLD.js
- * Class: OpenLayers.Format.SLD.v1
- * Superclass for SLD version 1 parsers.
- * Inherits from:
-OpenLayers.Format.SLD.v1 = OpenLayers.Class(OpenLayers.Format.XML, {
-     * Property: namespaces
-     * {Object} Mapping of namespace aliases to namespace URIs.
-    namespaces: {
-        sld: "http://www.opengis.net/sld",
-        ogc: "http://www.opengis.net/ogc",
-        xlink: "http://www.w3.org/1999/xlink",
-        xsi: "http://www.w3.org/2001/XMLSchema-instance"
-     * Property: defaultPrefix
-    defaultPrefix: "sld",
-     * Property: schemaLocation
-     * {String} Schema location for a particular minor version.
-    schemaLocation: null,
-     * APIProperty: defaultSymbolizer.
-     * {Object} A symbolizer with the SLD defaults.
-    defaultSymbolizer: {
-        fillColor: "#808080",
-        fillOpacity: 1,
-        strokeColor: "#000000",
-        strokeOpacity: 1,
-        strokeWidth: 1,
-        pointRadius: 6
-     * Constructor: OpenLayers.Format.SLD.v1
-     * Instances of this class are not created directly.  Use the
-     *     <OpenLayers.Format.SLD> constructor instead.
-     * Parameters:
-     *     this instance.
-     * Method: read
-     * Parameters:
-     * data - {DOMElement} An SLD document element.
-     * Returns:
-        var sld = {
-            namedLayers: {}
-        this.readChildNodes(data, sld);
-        return sld;
-     * Property: readers
-     * Contains public functions, grouped by namespace prefix, that will
-     *     be applied when a namespaced node is found matching the function
-     *     name.  The function will be applied in the scope of this parser
-     *     with two arguments: the node being read and a context object passed
-     *     from the parent.
-    readers: {
-        "sld": {
-            "StyledLayerDescriptor": function(node, sld) {
-                sld.version = node.getAttribute("version");
-                this.readChildNodes(node, sld);
-            "Name": function(node, obj) {
-                obj.name = this.getChildValue(node);
-            "Title": function(node, obj) {
-                obj.title = this.getChildValue(node);
-            "Abstract": function(node, obj) {
-                obj.description = this.getChildValue(node);
-            "NamedLayer": function(node, sld) {
-                var layer = {
-                    userStyles: [],
-                    namedStyles: []
-                this.readChildNodes(node, layer);
-                // give each of the user styles this layer name
-                for(var i=0; i<layer.userStyles.length; ++i) {
-                    layer.userStyles[i].layerName = layer.name;
-                sld.namedLayers[layer.name] = layer;
-            "NamedStyle": function(node, layer) {
-                layer.namedStyles.push(
-                    this.getChildName(node.firstChild)
-            "UserStyle": function(node, layer) {
-                var style = new OpenLayers.Style(this.defaultSymbolizer);
-                this.readChildNodes(node, style);
-                layer.userStyles.push(style);
-            "IsDefault": function(node, style) {
-                if(this.getChildValue(node) == "1") {
-                    style.isDefault = true;
-            "FeatureTypeStyle": function(node, style) {
-                // OpenLayers doesn't have a place for FeatureTypeStyle
-                // Name, Title, Abstract, FeatureTypeName, or
-                // SemanticTypeIdentifier so, we make a temporary object
-                // and later just use the Rule(s).
-                var obj = {
-                    rules: []
-                this.readChildNodes(node, obj);
-                style.rules = obj.rules;
-            "Rule": function(node, obj) {
-                var rule = new OpenLayers.Rule();
-                this.readChildNodes(node, rule);
-                obj.rules.push(rule);
-            "ElseFilter": function(node, rule) {
-                rule.elseFilter = true;
-            "MinScaleDenominator": function(node, rule) {
-                rule.minScaleDenominator = this.getChildValue(node);
-            "MaxScaleDenominator": function(node, rule) {
-                rule.maxScaleDenominator = this.getChildValue(node);
-            "LineSymbolizer": function(node, rule) {
-                // OpenLayers doens't do painter's order, instead we extend
-                var symbolizer = rule.symbolizer["Line"] || {};
-                this.readChildNodes(node, symbolizer);
-                // in case it didn't exist before
-                rule.symbolizer["Line"] = symbolizer;
-            "PolygonSymbolizer": function(node, rule) {
-                var symbolizer = rule.symbolizer["Polygon"] || {};
-                rule.symbolizer["Polygon"] = symbolizer;
-            "PointSymbolizer": function(node, rule) {
-                var symbolizer = rule.symbolizer["Point"] || {};
-                rule.symbolizer["Point"] = symbolizer;
-            "Stroke": function(node, symbolizer) {
-            "Fill": function(node, symbolizer) {
-            "CssParameter": function(node, symbolizer) {
-                var cssProperty = node.getAttribute("name");
-                var symProperty = this.cssMap[cssProperty];
-                if(symProperty) {
-                    // Limited support for parsing of OGC expressions
-                    var value = this.readOgcExpression(node);
-                    // always string, could be an empty string
-                    if(value) {
-                        symbolizer[symProperty] = value;
-            "Graphic": function(node, symbolizer) {
-                var graphic = {};
-                // painter's order not respected here, clobber previous with next
-                this.readChildNodes(node, graphic);
-                // directly properties with names that match symbolizer properties
-                var properties = [
-                    "strokeColor", "strokeWidth", "strokeOpacity",
-                    "strokeLinecap", "fillColor", "fillOpacity",
-                    "graphicName", "rotation", "graphicFormat"
-                var prop, value;
-                for(var i=0; i<properties.length; ++i) {
-                    prop = properties[i];
-                    value = graphic[prop];
-                    if(value != undefined) {
-                        symbolizer[prop] = value;
-                // set other generic properties with specific graphic property names
-                if(graphic.opacity != undefined) {
-                    symbolizer.graphicOpacity = graphic.opacity;
-                if(graphic.size != undefined) {
-                    symbolizer.pointRadius = graphic.size;
-                if(graphic.href != undefined) {
-                    symbolizer.externalGraphic = graphic.href;
-            "ExternalGraphic": function(node, graphic) {
-            "Mark": function(node, graphic) {
-            "WellKnownName": function(node, graphic) {
-                graphic.graphicName = this.getChildValue(node);
-            "Opacity": function(node, obj) {
-                // No support for parsing of OGC expressions
-                var opacity = this.getChildValue(node);
-                // always string, could be empty string
-                if(opacity) {
-                    obj.opacity = opacity;
-            "Size": function(node, obj) {
-                var size = this.getChildValue(node);
-                if(size) {
-                    obj.size = size;
-            "Rotation": function(node, obj) {
-                var rotation = this.getChildValue(node);
-                if(rotation) {
-                    obj.rotation = rotation;
-            "OnlineResource": function(node, obj) {
-                obj.href = this.getAttributeNS(
-                    node, this.namespaces.xlink, "href"
-            "Format": function(node, graphic) {
-                graphic.graphicFormat = this.getChildValue(node);
-        "ogc": {
-            "Filter": function(node, rule) {
-                // Filters correspond to subclasses of OpenLayers.Filter.
-                // Since they contain information we don't persist, we
-                // create a temporary object and then pass on the filter
-                // (ogc:Filter) to the parent rule (sld:Rule).
-                var obj = {
-                    fids: [],
-                    filters: []
-                if(obj.fids.length > 0) {
-                    rule.filter = new OpenLayers.Filter.FeatureId({
-                        fids: obj.fids
-                } else if(obj.filters.length > 0) {
-                    rule.filter = obj.filters[0];
-            "FeatureId": function(node, obj) {
-                var fid = node.getAttribute("fid");
-                if(fid) {
-                    obj.fids.push(fid);
-            "And": function(node, obj) {
-                var filter = new OpenLayers.Filter.Logical({
-                    type: OpenLayers.Filter.Logical.AND
-                this.readChildNodes(node, filter);
-                obj.filters.push(filter);
-            "Or": function(node, obj) {
-                    type: OpenLayers.Filter.Logical.OR
-            "Not": function(node, obj) {
-                    type: OpenLayers.Filter.Logical.NOT
-            "PropertyIsEqualTo": function(node, obj) {
-                var filter = new OpenLayers.Filter.Comparison({
-                    type: OpenLayers.Filter.Comparison.EQUAL_TO
-            "PropertyIsNotEqualTo": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.NOT_EQUAL_TO
-            "PropertyIsLessThan": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.LESS_THAN
-            "PropertyIsGreaterThan": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.GREATER_THAN
-            "PropertyIsLessThanOrEqualTo": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.LESS_THAN_OR_EQUAL_TO
-            "PropertyIsGreaterThanOrEqualTo": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.GREATER_THAN_OR_EQUAL_TO
-            "PropertyIsBetween": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.BETWEEN
-            "PropertyIsLike": function(node, obj) {
-                    type: OpenLayers.Filter.Comparison.LIKE
-                var wildCard = node.getAttribute("wildCard");
-                var singleChar = node.getAttribute("singleChar");
-                var esc = node.getAttribute("escape");
-                filter.value2regex(wildCard, singleChar, esc);
-            "Literal": function(node, obj) {
-                obj.value = this.getChildValue(node);
-            "PropertyName": function(node, filter) {
-                filter.property = this.getChildValue(node);
-            "LowerBoundary": function(node, filter) {
-                filter.lowerBoundary = this.readOgcExpression(node);
-            "UpperBoundary": function(node, filter) {
-                filter.upperBoundary = this.readOgcExpression(node);
-     * Method: readOgcExpression
-     * Limited support for OGC expressions.
-     * Parameters:
-     * node - {DOMElement} A DOM element that contains an ogc:expression.
-     * Returns:
-     * {String} A value to be used in a symbolizer.
-    readOgcExpression: function(node) {
-        var obj = {};
-        var value = obj.value;
-        if(!value) {
-            value = this.getChildValue(node);
-        return value;
-     * Property: cssMap
-     * {Object} Object mapping supported css property names to OpenLayers
-     *     symbolizer property names.
-    cssMap: {
-        "stroke": "strokeColor",
-        "stroke-opacity": "strokeOpacity",
-        "stroke-width": "strokeWidth",
-        "stroke-linecap": "strokeLinecap",
-        "fill": "fillColor",
-        "fill-opacity": "fillOpacity"
-     * Method: getCssProperty
-     * Given a symbolizer property, get the corresponding CSS property
-     *     from the <cssMap>.
-     * Parameters:
-     * sym - {String} A symbolizer property name.
-     * Returns:
-     * {String} A CSS property name or null if none found.
-    getCssProperty: function(sym) {
-        var css = null;
-        for(var prop in this.cssMap) {
-            if(this.cssMap[prop] == sym) {
-                css = prop;
-                break;
-        return css;
-     * Method: getGraphicFormat
-     * Given a href for an external graphic, try to determine the mime-type.
-     *     This method doesn't try too hard, and will fall back to
-     *     <defautlGraphicFormat> if one of the known <graphicFormats> is not
-     *     the file extension of the provided href.
-     * Parameters:
-     * href - {String}
-     * Returns:
-     * {String} The graphic format.
-    getGraphicFormat: function(href) {
-        var format, regex;
-        for(var key in this.graphicFormats) {
-            if(this.graphicFormats[key].test(href)) {
-                format = key;
-                break;
-        return format || this.defautlGraphicFormat;
-     * Property: defaultGraphicFormat
-     * {String} If none other can be determined from <getGraphicFormat>, this
-     *     default will be returned.
-    defaultGraphicFormat: "image/png",
-     * Property: graphicFormats
-     * {Object} Mapping of image mime-types to regular extensions matching
-     *     well-known file extensions.
-    graphicFormats: {
-        "image/jpeg": /\.jpe?g$/i,
-        "image/gif": /\.gif$/i,
-        "image/png": /\.png$/i
-     * Method: write
-     * Parameters:
-     * Returns:
-     * {DOMElement} The root of an SLD document.
-    write: function(sld) {
-        return this.writers.sld.StyledLayerDescriptor.apply(this, [sld]);
-     * Property: writers
-     * As a compliment to the readers property, this structure contains public
-     *     writing functions grouped by namespace alias and named like the
-     *     node names they produce.
-    writers: {
-        "sld": {
-            "StyledLayerDescriptor": function(sld) {
-                var root = this.createElementNSPlus(
-                    "StyledLayerDescriptor",
-                    {attributes: {
-                        "version": this.VERSION,
-                        "xsi:schemaLocation": this.schemaLocation
-                // add in optional name
-                if(sld.name) {
-                    this.writeNode(root, "Name", sld.name);
-                // add in optional title
-                if(sld.title) {
-                    this.writeNode(root, "Title", sld.title);
-                // add in optional description
-                if(sld.description) {
-                    this.writeNode(root, "Abstract", sld.description);
-                // add in named layers
-                for(var name in sld.namedLayers) {
-                    this.writeNode(root, "NamedLayer", sld.namedLayers[name]);
-                return root;
-            "Name": function(name) {
-                return this.createElementNSPlus("Name", {value: name});
-            "Title": function(title) {
-                return this.createElementNSPlus("Title", {value: title});
-            "Abstract": function(description) {
-                    "Abstract", {value: description}
-            "NamedLayer": function(layer) {
-                var node = this.createElementNSPlus("NamedLayer");
-                // add in required name
-                this.writeNode(node, "Name", layer.name);
-                // optional sld:LayerFeatureConstraints here
-                // add in named styles
-                if(layer.namedStyles) {
-                    for(var i=0; i<layer.namedStyles.length; ++i) {
-                        this.writeNode(
-                            node, "NamedStyle", layer.namedStyles[i]
-                // add in user styles
-                if(layer.userStyles) {
-                        this.writeNode(
-                            node, "UserStyle", layer.userStyles[i]
-                return node;
-            "NamedStyle": function(name) {
-                var node = this.createElementNSPlus("NamedStyle");
-                this.writeNode(node, "Name", name);
-                return node;
-            "UserStyle": function(style) {
-                var node = this.createElementNSPlus("UserStyle");
-                if(style.name) {
-                    this.writeNode(node, "Name", style.name);
-                if(style.title) {
-                    this.writeNode(node, "Title", style.title);
-                if(style.description) {
-                    this.writeNode(node, "Abstract", style.description);
-                // add isdefault
-                if(style.isDefault) {
-                    this.writeNode(node, "IsDefault", style.isDefault);
-                // add FeatureTypeStyles
-                this.writeNode(node, "FeatureTypeStyle", style);
-                return node;
-            "IsDefault": function(bool) {
-                    "IsDefault", {value: (bool) ? "1" : "0"}
-            "FeatureTypeStyle": function(style) {
-                var node = this.createElementNSPlus("FeatureTypeStyle");
-                // OpenLayers currently stores no Name, Title, Abstract,
-                // FeatureTypeName, or SemanticTypeIdentifier information
-                // related to FeatureTypeStyle
-                // add in rules
-                for(var i=0; i<style.rules.length; ++i) {
-                    this.writeNode(node, "Rule", style.rules[i]);
-                return node;
-            "Rule": function(rule) {
-                var node = this.createElementNSPlus("Rule");
-                if(rule.name) {
-                    this.writeNode(node, "Name", rule.name);
-                if(rule.title) {
-                    this.writeNode(node, "Title", rule.title);
-                if(rule.description) {
-                    this.writeNode(node, "Abstract", rule.description);
-                // add in LegendGraphic here
-                // add in optional filters
-                if(rule.elseFilter) {
-                    this.writeNode(node, "ElseFilter");
-                } else if(rule.filter) {
-                    this.writeNode(node, "ogc:Filter", rule.filter);
-                // add in scale limits
-                if(rule.minScaleDenominator != undefined) {
-                    this.writeNode(
-                        node, "MinScaleDenominator", rule.minScaleDenominator
-                if(rule.maxScaleDenominator != undefined) {
-                    this.writeNode(
-                        node, "MaxScaleDenominator", rule.maxScaleDenominator
-                // add in symbolizers (relies on geometry type keys)
-                var types = OpenLayers.Style.SYMBOLIZER_PREFIXES;
-                var type, symbolizer;
-                for(var i=0; i<types.length; ++i) {
-                    type = types[i];
-                    symbolizer = rule.symbolizer[type];
-                    if(symbolizer) {
-                        this.writeNode(
-                            node, type + "Symbolizer", symbolizer
-                return node;
-            "ElseFilter": function() {
-                return this.createElementNSPlus("ElseFilter");
-            "MinScaleDenominator": function(scale) {
-                    "MinScaleDenominator", {value: scale}
-            "MaxScaleDenominator": function(scale) {
-                    "MaxScaleDenominator", {value: scale}
-            "LineSymbolizer": function(symbolizer) {
-                var node = this.createElementNSPlus("LineSymbolizer");
-                this.writeNode(node, "Stroke", symbolizer);
-                return node;
-            "Stroke": function(symbolizer) {
-                var node = this.createElementNSPlus("Stroke");
-                // GraphicFill here
-                // GraphicStroke here
-                // add in CssParameters
-                if(symbolizer.strokeColor != undefined) {
-                    this.writeNode(
-                        node, "CssParameter",
-                        {symbolizer: symbolizer, key: "strokeColor"}
-                if(symbolizer.strokeOpacity != undefined) {
-                    this.writeNode(
-                        {symbolizer: symbolizer, key: "strokeOpacity"}
-                if(symbolizer.strokeWidth != undefined) {
-                    this.writeNode(
-                        {symbolizer: symbolizer, key: "strokeWidth"}
-                return node;
-            "CssParameter": function(obj) {
-                // not handling ogc:expressions for now
-                return this.createElementNSPlus("CssParameter", {
-                    attributes: {name: this.getCssProperty(obj.key)},
-                    value: obj.symbolizer[obj.key]
-            "PolygonSymbolizer": function(symbolizer) {
-                var node = this.createElementNSPlus("PolygonSymbolizer");
-                this.writeNode(node, "Fill", symbolizer);
-                return node;
-            "Fill": function(symbolizer) {
-                var node = this.createElementNSPlus("Fill");
-                if(symbolizer.fillColor) {
-                    this.writeNode(
-                        {symbolizer: symbolizer, key: "fillColor"}
-                if(symbolizer.fillOpacity) {
-                    this.writeNode(
-                        {symbolizer: symbolizer, key: "fillOpacity"}
-                return node;
-            "PointSymbolizer": function(symbolizer) {
-                var node = this.createElementNSPlus("PointSymbolizer");
-                this.writeNode(node, "Graphic", symbolizer);
-                return node;
-            "Graphic": function(symbolizer) {
-                var node = this.createElementNSPlus("Graphic");
-                if(symbolizer.externalGraphic != undefined) {
-                    this.writeNode(node, "ExternalGraphic", symbolizer);
-                } else if(symbolizer.graphicName) {
-                    this.writeNode(node, "Mark", symbolizer);
-                if(symbolizer.graphicOpacity != undefined) {
-                    this.writeNode(node, "Opacity", symbolizer.graphicOpacity);
-                if(symbolizer.pointRadius != undefined) {
-                    this.writeNode(node, "Size", symbolizer.pointRadius);
-                if(symbolizer.rotation != undefined) {
-                    this.writeNode(node, "Rotation", symbolizer.rotation);
-                return node;
-            "ExternalGraphic": function(symbolizer) {
-                var node = this.createElementNSPlus("ExternalGraphic");
-                this.writeNode(
-                    node, "OnlineResource", symbolizer.externalGraphic
-                var format = symbolizer.graphicFormat ||
-                             this.getGraphicFormat(symbolizer.externalGraphic);
-                this.writeNode(node, "Format", format);
-                return node;
-            "Mark": function(symbolizer) {
-                var node = this.createElementNSPlus("Mark");
-                this.writeNode(node, "WellKnownName", symbolizer.graphicName);
-                return node;
-            "WellKnownName": function(name) {
-                return this.createElementNSPlus("WellKnownName", {
-                    value: name
-            "Opacity": function(value) {
-                return this.createElementNSPlus("Opacity", {
-                    value: value
-            "Size": function(value) {
-                return this.createElementNSPlus("Size", {
-                    value: value
-            "Rotation": function(value) {
-                return this.createElementNSPlus("Rotation", {
-                    value: value
-            "OnlineResource": function(href) {
-                return this.createElementNSPlus("OnlineResource", {
-                    attributes: {
-                        "xlink:type": "simple",
-                        "xlink:href": href
-            "Format": function(format) {
-                return this.createElementNSPlus("Format", {
-                    value: format
-        "ogc": {
-            "Filter": function(filter) {
-                var node = this.createElementNSPlus("ogc:Filter");
-                var sub = filter.CLASS_NAME.split(".").pop();
-                if(sub == "FeatureId") {
-                    for(var i=0; i<filter.fids.length; ++i) {
-                        this.writeNode(node, "FeatureId", filter.fids[i]);
-                } else {
-                    this.writeNode(node, this.getFilterType(filter), filter);
-                return node;
-            "FeatureId": function(fid) {
-                return this.createElementNSPlus("ogc:FeatureId", {
-                    attributes: {fid: fid}
-            "And": function(filter) {
-                var node = this.createElementNSPlus("ogc:And");
-                var childFilter;
-                for(var i=0; i<filter.filters.length; ++i) {
-                    childFilter = filter.filters[i];
-                    this.writeNode(
-                        node, this.getFilterType(childFilter), childFilter
-                return node;
-            "Or": function(filter) {
-                var node = this.createElementNSPlus("ogc:Or");
-                var childFilter;
-                    this.writeNode(
-                return node;
-            "Not": function(filter) {
-                var node = this.createElementNSPlus("ogc:Not");
-                var childFilter = filter.filters[0];
-                this.writeNode(
-                return node;
-            "PropertyIsEqualTo": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsEqualTo");
-                // no ogc:expression handling for now
-                this.writeNode(node, "PropertyName", filter);
-                this.writeNode(node, "Literal", filter.value);
-                return node;
-            "PropertyIsNotEqualTo": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsNotEqualTo");
-                return node;
-            "PropertyIsLessThan": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsLessThan");
-                return node;
-            "PropertyIsGreaterThan": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsGreaterThan");
-                return node;
-            "PropertyIsLessThanOrEqualTo": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsLessThanOrEqualTo");
-                return node;
-            "PropertyIsGreaterThanOrEqualTo": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsGreaterThanOrEqualTo");
-                return node;
-            "PropertyIsBetween": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsBetween");
-                this.writeNode(node, "LowerBoundary", filter);
-                this.writeNode(node, "UpperBoundary", filter);
-                return node;
-            "PropertyIsLike": function(filter) {
-                var node = this.createElementNSPlus("ogc:PropertyIsLike", {
-                    attributes: {
-                        wildCard: "*", singleChar: ".", escape: "!"
-                // convert regex string to ogc string
-                this.writeNode(node, "Literal", filter.regex2value());
-                return node;
-            "PropertyName": function(filter) {
-                return this.createElementNSPlus("ogc:PropertyName", {
-                    value: filter.property
-            "Literal": function(value) {
-                return this.createElementNSPlus("ogc:Literal", {
-                    value: value
-            "LowerBoundary": function(filter) {
-                var node = this.createElementNSPlus("ogc:LowerBoundary");
-                this.writeNode(node, "Literal", filter.lowerBoundary);
-                return node;
-            "UpperBoundary": function(filter) {
-                var node = this.createElementNSPlus("ogc:UpperBoundary");
-                this.writeNode(node, "Literal", filter.upperBoundary);
-                return node;
-     * Method: getFilterType
-    getFilterType: function(filter) {
-        var filterType = this.filterMap[filter.type];
-        if(!filterType) {
-            throw "SLD writing not supported for rule type: " + filter.type;
-        return filterType;
-     * Property: filterMap
-     * {Object} Contains a member for each filter type.  Values are node names
-     *     for corresponding OGC Filter child elements.
-    filterMap: {
-        "&&": "And",
-        "||": "Or",
-        "!": "Not",
-        "==": "PropertyIsEqualTo",
-        "!=": "PropertyIsNotEqualTo",
-        "<": "PropertyIsLessThan",
-        ">": "PropertyIsGreaterThan",
-        "<=": "PropertyIsLessThanOrEqualTo",
-        ">=": "PropertyIsGreaterThanOrEqualTo",
-        "..": "PropertyIsBetween",
-        "~": "PropertyIsLike"
-     * Methods below this point are of general use for versioned XML parsers.
-     * These are candidates for an abstract class.
-     * Method: getNamespacePrefix
-     * Get the namespace prefix for a given uri from the <namespaces> object.
-     * Returns:
-     * {String} A namespace prefix or null if none found.
-    getNamespacePrefix: function(uri) {
-        var prefix = null;
-        if(uri == null) {
-            prefix = this.namespaces[this.defaultPrefix];
-        } else {
-            var gotPrefix = false;
-            for(prefix in this.namespaces) {
-                if(this.namespaces[prefix] == uri) {
-                    gotPrefix = true;
-                    break;
-            if(!gotPrefix) {
-                prefix = null;
-        return prefix;
-     * Method: readChildNodes
-    readChildNodes: function(node, obj) {
-        var children = node.childNodes;
-        var child, group, reader, prefix, local;
-        for(var i=0; i<children.length; ++i) {
-            child = children[i];
-            if(child.nodeType == 1) {
-                prefix = this.getNamespacePrefix(child.namespaceURI);
-                local = child.nodeName.split(":").pop();
-                group = this.readers[prefix];
-                if(group) {
-                    reader = group[local];
-                    if(reader) {
-                        reader.apply(this, [child, obj]);
-     * Method: writeNode
-     * Shorthand for applying one of the named writers and appending the
-     *     results to a node.  If a qualified name is not provided for the
-     *     second argument (and a local name is used instead), the namespace
-     *     of the parent node will be assumed.
-     * Parameters:
-     * parent - {DOMElement} Result will be appended to this node.
-     * name - {String} The name of a node to generate.  If a qualified name
-     *     (e.g. "pre:Name") is used, the namespace prefix is assumed to be
-     *     in the <writers> group.  If a local name is used (e.g. "Name") then
-     *     the namespace of the parent is assumed.
-     * obj - {Object} Structure containing data for the writer.
-     * Returns:
-     * {DOMElement} The child node.
-    writeNode: function(parent, name, obj) {
-        var prefix, local;
-        var split = name.indexOf(":");
-        if(split > 0) {
-            prefix = name.substring(0, split);
-            local = name.substring(split + 1);
-        } else {
-            prefix = this.getNamespacePrefix(parent.namespaceURI);
-            local = name;
-        var child = this.writers[prefix][local].apply(this, [obj]);
-        parent.appendChild(child);
-        return child;
-     * Method: createElementNSPlus
-     * Shorthand for creating namespaced elements with optional attributes and
-     *     child text nodes.
-     * Parameters:
-     * name - {String} The qualified node name.
-     * options - {Object} Optional object for node configuration.
-     * Returns:
-     * {Element} An element node.
-    createElementNSPlus: function(name, options) {
-        options = options || {};
-        var loc = name.indexOf(":");
-        // order of prefix preference
-        // 1. in the uri option
-        // 2. in the prefix option
-        // 3. in the qualified name
-        // 4. from the defaultPrefix
-        var uri = options.uri || this.namespaces[options.prefix];
-        if(!uri) {
-            loc = name.indexOf(":");
-            uri = this.namespaces[name.substring(0, loc)];
-        if(!uri) {
-            uri = this.namespaces[this.defaultPrefix];
-        var node = this.createElementNS(uri, name);
-        if(options.attributes) {
-            this.setAttributes(node, options.attributes);
-        if(options.value) {
-            node.appendChild(this.createTextNode(options.value));
-        return node;
-     * Method: setAttributes
-     * Set multiple attributes given key value pairs from an object.
-     * Parameters:
-     * node - {Element} An element node.
-     * obj - {Object || Array} An object whose properties represent attribute
-     *     names and values represent attribute values.  If an attribute name
-     *     is a qualified name ("prefix:local"), the prefix will be looked up
-     *     in the parsers {namespaces} object.  If the prefix is found,
-     *     setAttributeNS will be used instead of setAttribute.
-    setAttributes: function(node, obj) {
-        var value, loc, alias, uri;
-        for(var name in obj) {
-            value = obj[name].toString();
-            // check for qualified attribute name ("prefix:local")
-            uri = this.namespaces[name.substring(0, name.indexOf(":"))] || null;
-            this.setAttributeNS(node, uri, name, value);
-    CLASS_NAME: "OpenLayers.Format.SLD.v1"
-    OpenLayers/Geometry/Curve.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * @requires OpenLayers/Geometry/MultiPoint.js
- * Class: OpenLayers.Geometry.Curve
- * A Curve is a MultiPoint, whose points are assumed to be connected. To
- * this end, we provide a "getLength()" function, which iterates through
- * the points, summing the distances between them.
- * Inherits:
- *  - <OpenLayers.Geometry.MultiPoint>
-OpenLayers.Geometry.Curve = OpenLayers.Class(OpenLayers.Geometry.MultiPoint, {
-     * Property: componentTypes
-     * {Array(String)} An array of class names representing the types of
-     *                 components that the collection can include.  A null
-     *                 value means the component types are not restricted.
-     * Constructor: OpenLayers.Geometry.Curve
-     * Parameters:
-     * point - {Array(<OpenLayers.Geometry.Point>)}
-    initialize: function(points) {
-        OpenLayers.Geometry.MultiPoint.prototype.initialize.apply(this,
-        arguments);
-     * APIMethod: getLength
-     * Returns:
-     * {Float} The length of the curve
-    getLength: function() {
-        var length = 0.0;
-        if ( this.components && (this.components.length > 1)) {
-            for(var i=1; i < this.components.length; i++) {
-                length += this.components[i-1].distanceTo(this.components[i]);
-        return length;
-    CLASS_NAME: "OpenLayers.Geometry.Curve"
-    OpenLayers/Format/SLD/v1_0_0.js
- * @requires OpenLayers/Format/SLD/v1.js
- * Class: OpenLayers.Format.SLD.v1_0_0
- * Write SLD version 1.0.0.
- * Inherits from:
- *  - <OpenLayers.Format.SLD.v1>
-OpenLayers.Format.SLD.v1_0_0 = OpenLayers.Class(
-    OpenLayers.Format.SLD.v1, {
-     * Constant: VERSION
-     * {String} 1.0.0
-    VERSION: "1.0.0",
-     * {String} http://www.opengis.net/sld
-     *   http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd
-    schemaLocation: "http://www.opengis.net/sld http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd",
-     * Constructor: OpenLayers.Format.SLD.v1_0_0
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        OpenLayers.Format.SLD.v1.prototype.initialize.apply(
-            this, [options]
-    CLASS_NAME: "OpenLayers.Format.SLD.v1_0_0"
-    OpenLayers/Geometry/LineString.js
- * @requires OpenLayers/Geometry/Curve.js
- * Class: OpenLayers.Geometry.LineString
- * A LineString is a Curve which, once two points have been added to it, can
- * never be less than two points long.
- * Inherits from:
- *  - <OpenLayers.Geometry.Curve>
-OpenLayers.Geometry.LineString = OpenLayers.Class(OpenLayers.Geometry.Curve, {
-     * Constructor: OpenLayers.Geometry.LineString
-     * Create a new LineString geometry
-     * Parameters:
-     * points - {Array(<OpenLayers.Geometry.Point>)} An array of points used to
-     *          generate the linestring
-        OpenLayers.Geometry.Curve.prototype.initialize.apply(this, arguments);
-     * APIMethod: removeComponent
-     * Only allows removal of a point if there are three or more points in
-     * the linestring. (otherwise the result would be just a single point)
-     * Parameters:
-     * point - {<OpenLayers.Geometry.Point>} The point to be removed
-    removeComponent: function(point) {
-        if ( this.components && (this.components.length > 2)) {
-            OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,
-        arguments);
-     * APIMethod: intersects
-     * Test for instersection between two geometries.  This is a cheapo
-     *     implementation of the Bently-Ottmann algorigithm.  It doesn't
-     *     really keep track of a sweep line data structure.  It is closer
-     *     to the brute force method, except that segments are sorted and
-     *     potential intersections are only calculated when bounding boxes
-     *     intersect.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-     * Returns:
-     * {Boolean} The input geometry intersects this geometry.
-    intersects: function(geometry) {
-        var intersect = false;
-        var type = geometry.CLASS_NAME;
-        if(type == "OpenLayers.Geometry.LineString" ||
-           type == "OpenLayers.Geometry.LinearRing" ||
-           type == "OpenLayers.Geometry.Point") {
-            var segs1 = this.getSortedSegments();
-            var segs2;
-            if(type == "OpenLayers.Geometry.Point") {
-                segs2 = [{
-                    x1: geometry.x, y1: geometry.y,
-                    x2: geometry.x, y2: geometry.y
-            } else {
-                segs2 = geometry.getSortedSegments();
-            var seg1, seg1x1, seg1x2, seg1y1, seg1y2,
-                seg2, seg2y1, seg2y2;
-            // sweep right
-            outer: for(var i=0; i<segs1.length; ++i) {
-                seg1 = segs1[i];
-                seg1x1 = seg1.x1;
-                seg1x2 = seg1.x2;
-                seg1y1 = seg1.y1;
-                seg1y2 = seg1.y2;
-                inner: for(var j=0; j<segs2.length; ++j) {
-                    seg2 = segs2[j];
-                    if(seg2.x1 > seg1x2) {
-                        // seg1 still left of seg2
-                        break;
-                    if(seg2.x2 < seg1x1) {
-                        // seg2 still left of seg1
-                        continue;
-                    seg2y1 = seg2.y1;
-                    seg2y2 = seg2.y2;
-                    if(Math.min(seg2y1, seg2y2) > Math.max(seg1y1, seg1y2)) {
-                        // seg2 above seg1
-                        continue;
-                    if(Math.max(seg2y1, seg2y2) < Math.min(seg1y1, seg1y2)) {
-                        // seg2 below seg1
-                        continue;
-                    if(OpenLayers.Geometry.segmentsIntersect(seg1, seg2)) {
-                        intersect = true;
-                        break outer;
-        } else {
-            intersect = geometry.intersects(this);
-        return intersect;
-     * Method: getSortedSegments
-     * Returns:
-     * {Array} An array of segment objects.  Segment objects have properties
-     *     x1, y1, x2, and y2.  The start point is represented by x1 and y1.
-     *     The end point is represented by x2 and y2.  Start and end are
-     *     ordered so that x1 < x2.
-    getSortedSegments: function() {
-        var numSeg = this.components.length - 1;
-        var segments = new Array(numSeg);
-        for(var i=0; i<numSeg; ++i) {
-            point1 = this.components[i];
-            point2 = this.components[i + 1];
-            if(point1.x < point2.x) {
-                segments[i] = {
-                    x1: point1.x,
-                    y1: point1.y,
-                    x2: point2.x,
-                    y2: point2.y
-            } else {
-                segments[i] = {
-                    x1: point2.x,
-                    y1: point2.y,
-                    x2: point1.x,
-                    y2: point1.y
-        // more efficient to define this somewhere static
-        function byX1(seg1, seg2) {
-            return seg1.x1 - seg2.x1;
-        return segments.sort(byX1);
-    CLASS_NAME: "OpenLayers.Geometry.LineString"
-    OpenLayers/Format/GML.js
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Feature/Vector.js
- * @requires OpenLayers/Geometry/Point.js
- * @requires OpenLayers/Geometry/LineString.js
- * @requires OpenLayers/Geometry/MultiLineString.js
- * @requires OpenLayers/Geometry/Polygon.js
- * @requires OpenLayers/Geometry/MultiPolygon.js
- * Class: OpenLayers.Format.GML
- * Read/Wite GML. Create a new instance with the <OpenLayers.Format.GML>
- *     constructor.  Supports the GML simple features profile.
- * Inherits from:
- *  - <OpenLayers.Format>
-OpenLayers.Format.GML = OpenLayers.Class(OpenLayers.Format.XML, {
-     * APIProperty: featureNS
-     * {String} Namespace used for feature attributes.  Default is
-     *     "http://mapserver.gis.umn.edu/mapserver".
-    featureNS: "http://mapserver.gis.umn.edu/mapserver",
-     * APIProperty: featurePrefix
-     * {String} Namespace alias (or prefix) for feature nodes.  Default is
-     *     "feature".
-    featurePrefix: "feature",
-     * APIProperty: featureName
-     * {String} Element name for features. Default is "featureMember".
-    featureName: "featureMember",
-     * APIProperty: layerName
-     * {String} Name of data layer. Default is "features".
-    layerName: "features",
-     * APIProperty: geometry
-     * {String} Name of geometry element.  Defaults to "geometry".
-    geometryName: "geometry",
-     * APIProperty: collectionName
-     * {String} Name of featureCollection element.
-    collectionName: "FeatureCollection",
-     * APIProperty: gmlns
-     * {String} GML Namespace.
-    gmlns: "http://www.opengis.net/gml",
-     * {Boolean} Extract attributes from GML.
-    extractAttributes: true,
-     * APIProperty: xy
-     * {Boolean} Order of the GML coordinate true:(x,y) or false:(y,x)
-     * Changing is not recommended, a new Format should be instantiated.
-    xy: true,
-     * Constructor: OpenLayers.Format.GML
-     * Create a new parser for GML.
-     * Parameters:
-     *     this instance.
-        // compile regular expressions once instead of every time they are used
-        this.regExes = {
-            trimSpace: (/^\s*|\s*$/g),
-            removeSpace: (/\s*/g),
-            splitSpace: (/\s+/),
-            trimComma: (/\s*,\s*/g)
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [options]);
-     * APIMethod: read
-     * Read data from a string, and return a list of features.
-     * Parameters:
-     * data - {String} or {DOMElement} data to read/parse.
-     * Returns:
-     * {Array(<OpenLayers.Feature.Vector>)} An array of features.
-    read: function(data) {
-        if(typeof data == "string") {
-            data = OpenLayers.Format.XML.prototype.read.apply(this, [data]);
-        var featureNodes = this.getElementsByTagNameNS(data.documentElement,
-                                                       this.gmlns,
-                                                       this.featureName);
-        var features = [];
-        for(var i=0; i<featureNodes.length; i++) {
-            var feature = this.parseFeature(featureNodes[i]);
-            if(feature) {
-                features.push(feature);
-        return features;
-     * Method: parseFeature
-     * This function is the core of the GML parsing code in OpenLayers.
-     *    It creates the geometries that are then attached to the returned
-     *    feature, and calls parseAttributes() to get attribute data out.
-     * Parameters:
-     * node - {DOMElement} A GML feature node.
-    parseFeature: function(node) {
-        // only accept on geometry per feature - look for highest "order"
-        var order = ["MultiPolygon", "Polygon",
-                     "MultiLineString", "LineString",
-                     "MultiPoint", "Point", "Envelope"];
-        var type, nodeList, geometry, parser;
-        for(var i=0; i<order.length; ++i) {
-            type = order[i];
-            nodeList = this.getElementsByTagNameNS(node, this.gmlns, type);
-            if(nodeList.length > 0) {
-                // only deal with first geometry of this type
-                var parser = this.parseGeometry[type.toLowerCase()];
-                if(parser) {
-                    geometry = parser.apply(this, [nodeList[0]]);
-                    if (this.internalProjection && this.externalProjection) {
-                        geometry.transform(this.externalProjection,
-                                           this.internalProjection);
-                } else {
-                    OpenLayers.Console.error(OpenLayers.i18n(
-                                "unsupportedGeometryType", {'geomType':type}));
-                // stop looking for different geometry types
-                break;
-        // construct feature (optionally with attributes)
-        var attributes;
-        if(this.extractAttributes) {
-            attributes = this.parseAttributes(node);
-        var feature = new OpenLayers.Feature.Vector(geometry, attributes);
-        // assign fid - this can come from a "fid" or "id" attribute
-        var childNode = node.firstChild;
-        var fid;
-        while(childNode) {
-            if(childNode.nodeType == 1) {
-                fid = childNode.getAttribute("fid") ||
-                      childNode.getAttribute("id");
-                if(fid) {
-                    break;
-            childNode = childNode.nextSibling;
-        feature.fid = fid;
-        return feature;
-     * Property: parseGeometry
-     * Properties of this object are the functions that parse geometries based
-     *     on their type.
-    parseGeometry: {
-         * Method: parseGeometry.point
-         * Given a GML node representing a point geometry, create an OpenLayers
-         *     point geometry.
-         * Parameters:
-         * node - {DOMElement} A GML node.
-         * Returns:
-         * {<OpenLayers.Geometry.Point>} A point geometry.
-        point: function(node) {
-             * Three coordinate variations to consider:
-             * 1) <gml:pos>x y z</gml:pos>
-             * 2) <gml:coordinates>x, y, z</gml:coordinates>
-             * 3) <gml:coord><gml:X>x</gml:X><gml:Y>y</gml:Y></gml:coord>
-            var nodeList, coordString;
-            var coords = [];
-            // look for <gml:pos>
-            var nodeList = this.getElementsByTagNameNS(node, this.gmlns, "pos");
-                coordString = nodeList[0].firstChild.nodeValue;
-                coordString = coordString.replace(this.regExes.trimSpace, "");
-                coords = coordString.split(this.regExes.splitSpace);
-            // look for <gml:coordinates>
-            if(coords.length == 0) {
-                                                       "coordinates");
-                    coordString = coordString.replace(this.regExes.removeSpace,
-                    coords = coordString.split(",");
-            // look for <gml:coord>
-                                                       "coord");
-                    var xList = this.getElementsByTagNameNS(nodeList[0],
-                                                            this.gmlns, "X");
-                    var yList = this.getElementsByTagNameNS(nodeList[0],
-                                                            this.gmlns, "Y");
-                    if(xList.length > 0 && yList.length > 0) {
-                        coords = [xList[0].firstChild.nodeValue,
-                                  yList[0].firstChild.nodeValue];
-            // preserve third dimension
-            if(coords.length == 2) {
-                coords[2] = null;
-            if (this.xy) {
-                return new OpenLayers.Geometry.Point(coords[0], coords[1],
-                                                 coords[2]);
-            else{
-                return new OpenLayers.Geometry.Point(coords[1], coords[0],
-                                                 coords[2]);
-         * Method: parseGeometry.multipoint
-         * Given a GML node representing a multipoint geometry, create an
-         *     OpenLayers multipoint geometry.
-         * Parameters:
-         * Returns:
-         * {<OpenLayers.Geometry.MultiPoint>} A multipoint geometry.
-        multipoint: function(node) {
-                                                       "Point");
-            var components = [];
-                var point;
-                for(var i=0; i<nodeList.length; ++i) {
-                    point = this.parseGeometry.point.apply(this, [nodeList[i]]);
-                    if(point) {
-                        components.push(point);
-            return new OpenLayers.Geometry.MultiPoint(components);
-         * Method: parseGeometry.linestring
-         * Given a GML node representing a linestring geometry, create an
-         *     OpenLayers linestring geometry.
-         * Parameters:
-         * Returns:
-         * {<OpenLayers.Geometry.LineString>} A linestring geometry.
-        linestring: function(node, ring) {
-             * Two coordinate variations to consider:
-             * 1) <gml:posList dimension="d">x0 y0 z0 x1 y1 z1</gml:posList>
-             * 2) <gml:coordinates>x0, y0, z0 x1, y1, z1</gml:coordinates>
-            var coords = [];
-            var points = [];
-            // look for <gml:posList>
-            nodeList = this.getElementsByTagNameNS(node, this.gmlns, "posList");
-                coordString = this.concatChildValues(nodeList[0]);
-                var dim = parseInt(nodeList[0].getAttribute("dimension"));
-                var j, x, y, z;
-                for(var i=0; i<coords.length/dim; ++i) {
-                    j = i * dim;
-                    x = coords[j];
-                    y = coords[j+1];
-                    z = (dim == 2) ? null : coords[j+2];
-                    if (this.xy) {
-                        points.push(new OpenLayers.Geometry.Point(x, y, z));
-                    } else {
-                        points.push(new OpenLayers.Geometry.Point(y, x, z));
-                                                       "coordinates");
-                    coordString = coordString.replace(this.regExes.trimComma,
-                    var pointList = coordString.split(this.regExes.splitSpace);
-                    for(var i=0; i<pointList.length; ++i) {
-                        coords = pointList[i].split(",");
-                            coords[2] = null;
-                        if (this.xy) {
-                            points.push(new OpenLayers.Geometry.Point(coords[0],
-        coords[1],
-        coords[2]));
-                        } else {
-                            points.push(new OpenLayers.Geometry.Point(coords[1],
-        coords[0],
-        coords[2]));
-            var line = null;
-            if(points.length != 0) {
-                if(ring) {
-                    line = new OpenLayers.Geometry.LinearRing(points);
-                } else {
-                    line = new OpenLayers.Geometry.LineString(points);
-            return line;
-         * Method: parseGeometry.multilinestring
-         * Given a GML node representing a multilinestring geometry, create an
-         *     OpenLayers multilinestring geometry.
-         * Parameters:
-         * Returns:
-         * {<OpenLayers.Geometry.MultiLineString>} A multilinestring geometry.
-        multilinestring: function(node) {
-                                                       "LineString");
-                var line;
-                    line = this.parseGeometry.linestring.apply(this,
-                                                               [nodeList[i]]);
-                    if(line) {
-                        components.push(line);
-            return new OpenLayers.Geometry.MultiLineString(components);
-         * Method: parseGeometry.polygon
-         * Given a GML node representing a polygon geometry, create an
-         *     OpenLayers polygon geometry.
-         * Parameters:
-         * Returns:
-         * {<OpenLayers.Geometry.Polygon>} A polygon geometry.
-        polygon: function(node) {
-                                                       "LinearRing");
-                // this assumes exterior ring first, inner rings after
-                var ring;
-                    ring = this.parseGeometry.linestring.apply(this,
-                                                        [nodeList[i], true]);
-                    if(ring) {
-                        components.push(ring);
-            return new OpenLayers.Geometry.Polygon(components);
-         * Method: parseGeometry.multipolygon
-         * Given a GML node representing a multipolygon geometry, create an
-         *     OpenLayers multipolygon geometry.
-         * Parameters:
-         * Returns:
-         * {<OpenLayers.Geometry.MultiPolygon>} A multipolygon geometry.
-        multipolygon: function(node) {
-                                                       "Polygon");
-                var polygon;
-                    polygon = this.parseGeometry.polygon.apply(this,
-                                                               [nodeList[i]]);
-                    if(polygon) {
-                        components.push(polygon);
-            return new OpenLayers.Geometry.MultiPolygon(components);
-        envelope: function(node) {
-            var coordString;
-            var envelope;
-            var lpoint = this.getElementsByTagNameNS(node, this.gmlns, "lowerCorner");
-            if (lpoint.length > 0) {
-                var coords = [];
-                if(lpoint.length > 0) {
-                    coordString = lpoint[0].firstChild.nodeValue;
-                    coords[2] = null;
-                if (this.xy) {
-                    var lowerPoint = new OpenLayers.Geometry.Point(coords[0], coords[1],coords[2]);
-                } else {
-                    var lowerPoint = new OpenLayers.Geometry.Point(coords[1], coords[0],coords[2]);
-            var upoint = this.getElementsByTagNameNS(node, this.gmlns, "upperCorner");
-            if (upoint.length > 0) {
-                var coords = [];
-                if(upoint.length > 0) {
-                    coordString = upoint[0].firstChild.nodeValue;
-                    coords[2] = null;
-                if (this.xy) {
-                    var upperPoint = new OpenLayers.Geometry.Point(coords[0], coords[1],coords[2]);
-                } else {
-                    var upperPoint = new OpenLayers.Geometry.Point(coords[1], coords[0],coords[2]);
-            if (lowerPoint && upperPoint) {
-                components.push(new OpenLayers.Geometry.Point(lowerPoint.x, lowerPoint.y));
-                components.push(new OpenLayers.Geometry.Point(upperPoint.x, lowerPoint.y));
-                components.push(new OpenLayers.Geometry.Point(upperPoint.x, upperPoint.y));
-                components.push(new OpenLayers.Geometry.Point(lowerPoint.x, upperPoint.y));
-                var ring = new OpenLayers.Geometry.LinearRing(components);
-                envelope = new OpenLayers.Geometry.Polygon([ring]);
-            return envelope;
-     * Method: parseAttributes
-     * Parameters:
-     * node - {<DOMElement>}
-     * Returns:
-     * {Object} An attributes object.
-    parseAttributes: function(node) {
-        var attributes = {};
-        // assume attributes are children of the first type 1 child
-        var children, i, child, grandchildren, grandchild, name, value;
-                // attributes are type 1 children with one type 3 child
-                children = childNode.childNodes;
-                for(i=0; i<children.length; ++i) {
-                        grandchildren = child.childNodes;
-                        if(grandchildren.length == 1) {
-                            grandchild = grandchildren[0];
-                            if(grandchild.nodeType == 3 ||
-                               grandchild.nodeType == 4) {
-                                name = (child.prefix) ?
-                                        child.nodeName.split(":")[1] :
-                                        child.nodeName;
-                                value = grandchild.nodeValue.replace(
-                                                this.regExes.trimSpace, "");
-                                attributes[name] = value;
-                break;
-        return attributes;
-     * APIMethod: write
-     * Generate a GML document string given a list of features.
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)} List of features to
-     *     serialize into a string.
-     * Returns:
-     * {String} A string representing the GML document.
-    write: function(features) {
-        if(!(features instanceof Array)) {
-            features = [features];
-        var gml = this.createElementNS("http://www.opengis.net/wfs",
-                                       "wfs:" + this.collectionName);
-        for(var i=0; i<features.length; i++) {
-            gml.appendChild(this.createFeatureXML(features[i]));
-        return OpenLayers.Format.XML.prototype.write.apply(this, [gml]);
-     * Method: createFeatureXML
-     * Accept an OpenLayers.Feature.Vector, and build a GML node for it.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>} The feature to be built as GML.
-     * Returns:
-     * {DOMElement} A node reprensting the feature in GML.
-    createFeatureXML: function(feature) {
-        var geometry = feature.geometry;
-        var geometryNode = this.buildGeometryNode(geometry);
-        var geomContainer = this.createElementNS(this.featureNS,
-                                                 this.featurePrefix + ":" +
-                                                 this.geometryName);
-        geomContainer.appendChild(geometryNode);
-        var featureNode = this.createElementNS(this.gmlns,
-                                               "gml:" + this.featureName);
-        var featureContainer = this.createElementNS(this.featureNS,
-                                                    this.layerName);
-        var fid = feature.fid || feature.id;
-        featureContainer.setAttribute("fid", fid);
-        featureContainer.appendChild(geomContainer);
-        for(var attr in feature.attributes) {
-            var attrText = this.createTextNode(feature.attributes[attr]);
-            var nodename = attr.substring(attr.lastIndexOf(":") + 1);
-            var attrContainer = this.createElementNS(this.featureNS,
-                                                     nodename);
-            attrContainer.appendChild(attrText);
-            featureContainer.appendChild(attrContainer);
-        featureNode.appendChild(featureContainer);
-        return featureNode;
-     * APIMethod: buildGeometryNode
-    buildGeometryNode: function(geometry) {
-        if (this.externalProjection && this.internalProjection) {
-            geometry = geometry.clone();
-            geometry.transform(this.internalProjection,
-                               this.externalProjection);
-        var className = geometry.CLASS_NAME;
-        var type = className.substring(className.lastIndexOf(".") + 1);
-        var builder = this.buildGeometry[type.toLowerCase()];
-        return builder.apply(this, [geometry]);
-     * Property: buildGeometry
-     * Object containing methods to do the actual geometry node building
-     *     based on geometry type.
-    buildGeometry: {
-        // TBD retrieve the srs from layer
-        // srsName is non-standard, so not including it until it's right.
-        // gml.setAttribute("srsName",
-        //                  "http://www.opengis.net/gml/srs/epsg.xml#4326");
-         * Method: buildGeometry.point
-         * Given an OpenLayers point geometry, create a GML point.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Point>} A point geometry.
-         * Returns:
-         * {DOMElement} A GML point node.
-        point: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:Point");
-            gml.appendChild(this.buildCoordinatesNode(geometry));
-            return gml;
-         * Method: buildGeometry.multipoint
-         * Given an OpenLayers multipoint geometry, create a GML multipoint.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.MultiPoint>} A multipoint geometry.
-         * Returns:
-         * {DOMElement} A GML multipoint node.
-        multipoint: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:MultiPoint");
-            var points = geometry.components;
-            var pointMember, pointGeom;
-            for(var i=0; i<points.length; i++) {
-                pointMember = this.createElementNS(this.gmlns,
-                                                   "gml:pointMember");
-                pointGeom = this.buildGeometry.point.apply(this,
-                                                               [points[i]]);
-                pointMember.appendChild(pointGeom);
-                gml.appendChild(pointMember);
-            return gml;
-         * Method: buildGeometry.linestring
-         * Given an OpenLayers linestring geometry, create a GML linestring.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.LineString>} A linestring geometry.
-         * Returns:
-         * {DOMElement} A GML linestring node.
-        linestring: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:LineString");
-            return gml;
-         * Method: buildGeometry.multilinestring
-         * Given an OpenLayers multilinestring geometry, create a GML
-         *     multilinestring.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.MultiLineString>} A multilinestring
-         *     geometry.
-         * Returns:
-         * {DOMElement} A GML multilinestring node.
-        multilinestring: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:MultiLineString");
-            var lines = geometry.components;
-            var lineMember, lineGeom;
-            for(var i=0; i<lines.length; ++i) {
-                lineMember = this.createElementNS(this.gmlns,
-                                                  "gml:lineStringMember");
-                lineGeom = this.buildGeometry.linestring.apply(this,
-        [lines[i]]);
-                lineMember.appendChild(lineGeom);
-                gml.appendChild(lineMember);
-            return gml;
-         * Method: buildGeometry.linearring
-         * Given an OpenLayers linearring geometry, create a GML linearring.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.LinearRing>} A linearring geometry.
-         * Returns:
-         * {DOMElement} A GML linearring node.
-        linearring: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:LinearRing");
-            return gml;
-         * Method: buildGeometry.polygon
-         * Given an OpenLayers polygon geometry, create a GML polygon.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Polygon>} A polygon geometry.
-         * Returns:
-         * {DOMElement} A GML polygon node.
-        polygon: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:Polygon");
-            var rings = geometry.components;
-            var ringMember, ringGeom, type;
-            for(var i=0; i<rings.length; ++i) {
-                type = (i==0) ? "outerBoundaryIs" : "innerBoundaryIs";
-                ringMember = this.createElementNS(this.gmlns,
-                                                  "gml:" + type);
-                ringGeom = this.buildGeometry.linearring.apply(this,
-        [rings[i]]);
-                ringMember.appendChild(ringGeom);
-                gml.appendChild(ringMember);
-            return gml;
-         * Method: buildGeometry.multipolygon
-         * Given an OpenLayers multipolygon geometry, create a GML multipolygon.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.MultiPolygon>} A multipolygon
-         *     geometry.
-         * Returns:
-         * {DOMElement} A GML multipolygon node.
-        multipolygon: function(geometry) {
-            var gml = this.createElementNS(this.gmlns, "gml:MultiPolygon");
-            var polys = geometry.components;
-            var polyMember, polyGeom;
-            for(var i=0; i<polys.length; ++i) {
-                polyMember = this.createElementNS(this.gmlns,
-                                                  "gml:polygonMember");
-                polyGeom = this.buildGeometry.polygon.apply(this,
-        [polys[i]]);
-                polyMember.appendChild(polyGeom);
-                gml.appendChild(polyMember);
-            return gml;
-     * Method: buildCoordinates
-     * builds the coordinates XmlNode
-     * (code)
-     * <gml:coordinates decimal="." cs="," ts=" ">...</gml:coordinates>
-     * (end)
-     * Parameters:
-     * Returns:
-     * {XmlNode} created xmlNode
-    buildCoordinatesNode: function(geometry) {
-        var coordinatesNode = this.createElementNS(this.gmlns,
-                                                   "gml:coordinates");
-        coordinatesNode.setAttribute("decimal", ".");
-        coordinatesNode.setAttribute("cs", ",");
-        coordinatesNode.setAttribute("ts", " ");
-        var points = (geometry.components) ? geometry.components : [geometry];
-        var parts = [];
-            parts.push(points[i].x + "," + points[i].y);
-        var txtNode = this.createTextNode(parts.join(" "));
-        coordinatesNode.appendChild(txtNode);
-        return coordinatesNode;
-    CLASS_NAME: "OpenLayers.Format.GML"
-    OpenLayers/Format/GeoJSON.js
- * @requires OpenLayers/Format/JSON.js
- * Class: OpenLayers.Format.GeoJSON
- * Read and write GeoJSON. Create a new parser with the
- *     <OpenLayers.Format.GeoJSON> constructor.
- * Inherits from:
- *  - <OpenLayers.Format.JSON>
-OpenLayers.Format.GeoJSON = OpenLayers.Class(OpenLayers.Format.JSON, {
-     * Constructor: OpenLayers.Format.GeoJSON
-     * Create a new parser for GeoJSON.
-     * Parameters:
-     *     this instance.
-        OpenLayers.Format.JSON.prototype.initialize.apply(this, [options]);
-     * APIMethod: read
-     * Deserialize a GeoJSON string.
-     * Parameters:
-     * json - {String} A GeoJSON string
-     * type - {String} Optional string that determines the structure of
-     *     the output.  Supported values are "Geometry", "Feature", and
-     *     "FeatureCollection".  If absent or null, a default of
-     *     "FeatureCollection" is assumed.
-     * filter - {Function} A function which will be called for every key and
-     *     value at every level of the final result. Each value will be
-     *     replaced by the result of the filter function. This can be used to
-     *     reform generic objects into instances of classes, or to transform
-     *     date strings into Date objects.
-     * Returns:
-     * {Object} The return depends on the value of the type argument. If type
-     *     is "FeatureCollection" (the default), the return will be an array
-     *     of <OpenLayers.Feature.Vector>. If type is "Geometry", the input json
-     *     must represent a single geometry, and the return will be an
-     *     <OpenLayers.Geometry>.  If type is "Feature", the input json must
-     *     represent a single feature, and the return will be an
-     *     <OpenLayers.Feature.Vector>.
-    read: function(json, type, filter) {
-        type = (type) ? type : "FeatureCollection";
-        var results = null;
-        var obj = null;
-        if (typeof json == "string") {
-            obj = OpenLayers.Format.JSON.prototype.read.apply(this,
-                                                              [json, filter]);
-        } else {
-            obj = json;
-        if(!obj) {
-            OpenLayers.Console.error("Bad JSON: " + json);
-        } else if(typeof(obj.type) != "string") {
-            OpenLayers.Console.error("Bad GeoJSON - no type: " + json);
-        } else if(this.isValidType(obj, type)) {
-            switch(type) {
-                case "Geometry":
-                    try {
-                        results = this.parseGeometry(obj);
-                    } catch(err) {
-                        OpenLayers.Console.error(err);
-                    break;
-                case "Feature":
-                    try {
-                        results = this.parseFeature(obj);
-                        results.type = "Feature";
-                    } catch(err) {
-                    break;
-                case "FeatureCollection":
-                    // for type FeatureCollection, we allow input to be any type
-                    results = [];
-                    switch(obj.type) {
-                        case "Feature":
-                            try {
-                                results.push(this.parseFeature(obj));
-                            } catch(err) {
-                                results = null;
-                            break;
-                            for(var i=0; i<obj.features.length; ++i) {
-                                try {
-                                    results.push(this.parseFeature(obj.features[i]));
-                                } catch(err) {
-                                    results = null;
-                            break;
-                        default:
-                            try {
-                                var geom = this.parseGeometry(obj);
-                                results.push(new OpenLayers.Feature.Vector(geom));
-                            } catch(err) {
-                                results = null;
-                break;
-        return results;
-     * Method: isValidType
-     * Check if a GeoJSON object is a valid representative of the given type.
-     * Returns:
-     * {Boolean} The object is valid GeoJSON object of the given type.
-    isValidType: function(obj, type) {
-        var valid = false;
-        switch(type) {
-            case "Geometry":
-                if(OpenLayers.Util.indexOf(
-                    ["Point", "MultiPoint", "LineString", "MultiLineString",
-                     "Polygon", "MultiPolygon", "Box", "GeometryCollection"],
-                    obj.type) == -1) {
-                    // unsupported geometry type
-                    OpenLayers.Console.error("Unsupported geometry type: " +
-                                              obj.type);
-                } else {
-                    valid = true;
-                break;
-                // allow for any type to be converted to a feature collection
-                valid = true;
-                break;
-            default:
-                // for Feature types must match
-                if(obj.type == type) {
-                    valid = true;
-                } else {
-                    OpenLayers.Console.error("Cannot convert types from " +
-                                              obj.type + " to " + type);
-        return valid;
-     * Convert a feature object from GeoJSON into an
-     * Parameters:
-     * obj - {Object} An object created from a GeoJSON object
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} A feature.
-    parseFeature: function(obj) {
-        var feature, geometry, attributes;
-        attributes = (obj.properties) ? obj.properties : {};
-        try {
-            geometry = this.parseGeometry(obj.geometry);
-        } catch(err) {
-            // deal with bad geometries
-            throw err;
-        feature = new OpenLayers.Feature.Vector(geometry, attributes);
-        if(obj.id) {
-            feature.fid = obj.id;
-        return feature;
-     * Convert a geometry object from GeoJSON into an <OpenLayers.Geometry>.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Geometry>} A geometry.
-    parseGeometry: function(obj) {
-        var geometry;
-        if(obj.type == "GeometryCollection") {
-            if(!(obj.geometries instanceof Array)) {
-                throw "GeometryCollection must have geometries array: " + obj;
-            var numGeom = obj.geometries.length;
-            var components = new Array(numGeom);
-            for(var i=0; i<numGeom; ++i) {
-                components[i] = this.parseGeometry.apply(
-                    this, [obj.geometries[i]]
-            geometry = new OpenLayers.Geometry.Collection(components);
-        } else {
-            if(!(obj.coordinates instanceof Array)) {
-                throw "Geometry must have coordinates array: " + obj;
-            if(!this.parseCoords[obj.type.toLowerCase()]) {
-                throw "Unsupported geometry type: " + obj.type;
-            try {
-                geometry = this.parseCoords[obj.type.toLowerCase()].apply(
-                    this, [obj.coordinates]
-            } catch(err) {
-                // deal with bad coordinates
-                throw err;
-        return geometry;
-     * Property: parseCoords
-     * Object with properties corresponding to the GeoJSON geometry types.
-     *     Property values are functions that do the actual parsing.
-    parseCoords: {
-         * Method: parseCoords.point
-         * Convert a coordinate array from GeoJSON into an
-         * Parameters:
-         * array - {Object} The coordinates array from the GeoJSON fragment.
-         * Returns:
-        "point": function(array) {
-            if(array.length != 2) {
-                throw "Only 2D points are supported: " + array;
-            return new OpenLayers.Geometry.Point(array[0], array[1]);
-         * Method: parseCoords.multipoint
-         * Parameters:
-         * array {Object} The coordinates array from the GeoJSON fragment.
-         * Returns:
-        "multipoint": function(array) {
-            var points = [];
-            var p = null;
-            for(var i=0; i<array.length; ++i) {
-                try {
-                    p = this.parseCoords["point"].apply(this, [array[i]]);
-                } catch(err) {
-                    throw err;
-                points.push(p);
-            return new OpenLayers.Geometry.MultiPoint(points);
-         * Method: parseCoords.linestring
-         * Parameters:
-         * Returns:
-        "linestring": function(array) {
-            var points = [];
-            var p = null;
-                try {
-                } catch(err) {
-                    throw err;
-                points.push(p);
-            return new OpenLayers.Geometry.LineString(points);
-         * Method: parseCoords.multilinestring
-         * Parameters:
-         * Returns:
-        "multilinestring": function(array) {
-            var lines = [];
-            var l = null;
-                try {
-                    l = this.parseCoords["linestring"].apply(this, [array[i]]);
-                } catch(err) {
-                    throw err;
-                lines.push(l);
-            return new OpenLayers.Geometry.MultiLineString(lines);
-         * Method: parseCoords.polygon
-         * Returns:
-        "polygon": function(array) {
-            var rings = [];
-            var r, l;
-                try {
-                } catch(err) {
-                    throw err;
-                r = new OpenLayers.Geometry.LinearRing(l.components);
-                rings.push(r);
-            return new OpenLayers.Geometry.Polygon(rings);
-         * Method: parseCoords.multipolygon
-         * Parameters:
-         * Returns:
-        "multipolygon": function(array) {
-            var polys = [];
-            var p = null;
-                try {
-                    p = this.parseCoords["polygon"].apply(this, [array[i]]);
-                } catch(err) {
-                    throw err;
-                polys.push(p);
-            return new OpenLayers.Geometry.MultiPolygon(polys);
-         * Method: parseCoords.box
-         * Parameters:
-         * Returns:
-        "box": function(array) {
-                throw "GeoJSON box coordinates must have 2 elements";
-            return new OpenLayers.Geometry.Polygon([
-                new OpenLayers.Geometry.LinearRing([
-                    new OpenLayers.Geometry.Point(array[0][0], array[0][1]),
-                    new OpenLayers.Geometry.Point(array[1][0], array[0][1]),
-                    new OpenLayers.Geometry.Point(array[1][0], array[1][1]),
-                    new OpenLayers.Geometry.Point(array[0][0], array[1][1]),
-     * Serialize a feature, geometry, array of features into a GeoJSON string.
-     * Parameters:
-     * obj - {Object} An <OpenLayers.Feature.Vector>, <OpenLayers.Geometry>,
-     *     or an array of features.
-     * pretty - {Boolean} Structure the output with newlines and indentation.
-     *     Default is false.
-     * Returns:
-     * {String} The GeoJSON string representation of the input geometry,
-     *     features, or array of features.
-    write: function(obj, pretty) {
-        var geojson = {
-            "type": null
-        if(obj instanceof Array) {
-            geojson.type = "FeatureCollection";
-            var numFeatures = obj.length;
-            geojson.features = new Array(numFeatures);
-            for(var i=0; i<numFeatures; ++i) {
-                var element = obj[i];
-                if(!element instanceof OpenLayers.Feature.Vector) {
-                    var msg = "FeatureCollection only supports collections " +
-                              "of features: " + element;
-                    throw msg;
-                geojson.features[i] = this.extract.feature.apply(
-                    this, [element]
-        } else if (obj.CLASS_NAME.indexOf("OpenLayers.Geometry") == 0) {
-            geojson = this.extract.geometry.apply(this, [obj]);
-        } else if (obj instanceof OpenLayers.Feature.Vector) {
-            geojson = this.extract.feature.apply(this, [obj]);
-            if(obj.layer && obj.layer.projection) {
-                geojson.crs = this.createCRSObject(obj);
-        return OpenLayers.Format.JSON.prototype.write.apply(this,
-                                                            [geojson, pretty]);
-     * Method: createCRSObject
-     * Create the CRS object for an object.
-     * Parameters:
-     * object - {<OpenLayers.Feature.Vector>}
-     * Returns:
-     * {Object} An object which can be assigned to the crs property
-     * of a GeoJSON object.
-    createCRSObject: function(object) {
-       var proj = object.layer.projection.toString();
-       var crs = {};
-       if (proj.match(/epsg:/i)) {
-           var code = parseInt(proj.substring(proj.indexOf(":") + 1));
-           if (code == 4326) {
-               crs = {
-                   "type": "OGC",
-                   "properties": {
-                       "urn": "urn:ogc:def:crs:OGC:1.3:CRS84"
-           } else {
-               crs = {
-                   "type": "EPSG",
-                   "properties": {
-                       "code": code
-       return crs;
-     * Property: extract
-     * Object with properties corresponding to the GeoJSON types.
-     *     Property values are functions that do the actual value extraction.
-    extract: {
-         * Method: extract.feature
-         * Return a partial GeoJSON object representing a single feature.
-         * Parameters:
-         * Returns:
-         * {Object} An object representing the point.
-        'feature': function(feature) {
-            var geom = this.extract.geometry.apply(this, [feature.geometry]);
-            return {
-                "type": "Feature",
-                "id": feature.fid == null ? feature.id : feature.fid,
-                "properties": feature.attributes,
-                "geometry": geom
-         * Method: extract.geometry
-         * Return a GeoJSON object representing a single geometry.
-         * Parameters:
-         * Returns:
-         * {Object} An object representing the geometry.
-        'geometry': function(geometry) {
-            var geometryType = geometry.CLASS_NAME.split('.')[2];
-            var data = this.extract[geometryType.toLowerCase()].apply(this, [geometry]);
-            var json;
-            if(geometryType == "Collection") {
-                json = {
-                    "type": "GeometryCollection",
-                    "geometries": data
-            } else {
-                json = {
-                    "type": geometryType,
-                    "coordinates": data
-            return json;
-         * Method: extract.point
-         * Return an array of coordinates from a point.
-         * Parameters:
-         * Returns:
-         * {Array} An array of coordinates representing the point.
-        'point': function(point) {
-            return [point.x, point.y];
-         * Method: extract.multipoint
-         * Return an array of point coordinates from a multipoint.
-         * Parameters:
-         * multipoint - {<OpenLayers.Geometry.MultiPoint>}
-         * Returns:
-         * {Array} An array of point coordinate arrays representing
-         *     the multipoint.
-        'multipoint': function(multipoint) {
-            var array = [];
-            for(var i=0; i<multipoint.components.length; ++i) {
-                array.push(this.extract.point.apply(this, [multipoint.components[i]]));
-            return array;
-         * Method: extract.linestring
-         * Return an array of coordinate arrays from a linestring.
-         * Parameters:
-         * linestring - {<OpenLayers.Geometry.LineString>}
-         * Returns:
-         * {Array} An array of coordinate arrays representing
-         *     the linestring.
-        'linestring': function(linestring) {
-            var array = [];
-            for(var i=0; i<linestring.components.length; ++i) {
-                array.push(this.extract.point.apply(this, [linestring.components[i]]));
-            return array;
-         * Method: extract.multilinestring
-         * Return an array of linestring arrays from a linestring.
-         * Parameters:
-         * linestring - {<OpenLayers.Geometry.MultiLineString>}
-         * Returns:
-         * {Array} An array of linestring arrays representing
-         *     the multilinestring.
-        'multilinestring': function(multilinestring) {
-            var array = [];
-            for(var i=0; i<multilinestring.components.length; ++i) {
-                array.push(this.extract.linestring.apply(this, [multilinestring.components[i]]));
-            return array;
-         * Method: extract.polygon
-         * Return an array of linear ring arrays from a polygon.
-         * Parameters:
-         * polygon - {<OpenLayers.Geometry.Polygon>}
-         * Returns:
-         * {Array} An array of linear ring arrays representing the polygon.
-        'polygon': function(polygon) {
-            var array = [];
-            for(var i=0; i<polygon.components.length; ++i) {
-                array.push(this.extract.linestring.apply(this, [polygon.components[i]]));
-            return array;
-         * Method: extract.multipolygon
-         * Return an array of polygon arrays from a multipolygon.
-         * Parameters:
-         * multipolygon - {<OpenLayers.Geometry.MultiPolygon>}
-         * Returns:
-         * {Array} An array of polygon arrays representing
-         *     the multipolygon
-        'multipolygon': function(multipolygon) {
-            var array = [];
-            for(var i=0; i<multipolygon.components.length; ++i) {
-                array.push(this.extract.polygon.apply(this, [multipolygon.components[i]]));
-            return array;
-         * Method: extract.collection
-         * Return an array of geometries from a geometry collection.
-         * Parameters:
-         * collection - {<OpenLayers.Geometry.Collection>}
-         * Returns:
-         * {Array} An array of geometry objects representing the geometry
-         *     collection.
-        'collection': function(collection) {
-            var len = collection.components.length;
-            var array = new Array(len);
-            for(var i=0; i<len; ++i) {
-                array[i] = this.extract.geometry.apply(
-                    this, [collection.components[i]]
-            return array;
-    CLASS_NAME: "OpenLayers.Format.GeoJSON"
-    OpenLayers/Format/GeoRSS.js
- * Class: OpenLayers.Format.GeoRSS
- * Read/write GeoRSS parser. Create a new instance with the
- *     <OpenLayers.Format.GeoRSS> constructor.
- * Inherits from:
- *  - <OpenLayers.Format.XML>
-OpenLayers.Format.GeoRSS = OpenLayers.Class(OpenLayers.Format.XML, {
-     * APIProperty: rssns
-     * {String} RSS namespace to use. Defaults to
-     *   "http://backend.userland.com/rss2"
-    rssns: "http://backend.userland.com/rss2",
-     * APIProperty: featurens
-     * {String} Feature Attributes namespace.  Defaults to
-     * APIProperty: georssns
-     * {String} GeoRSS namespace to use.  Defaults to
-     *     "http://www.georss.org/georss"
-    georssns: "http://www.georss.org/georss",
-     * APIProperty: geons
-     * {String} W3C Geo namespace to use.  Defaults to
-     *     "http://www.w3.org/2003/01/geo/wgs84_pos#"
-    geons: "http://www.w3.org/2003/01/geo/wgs84_pos#",
-     * APIProperty: featureTitle
-     * {String} Default title for features.  Defaults to "Untitled"
-    featureTitle: "Untitled",
-     * APIProperty: featureDescription
-     * {String} Default description for features.  Defaults to "No Description"
-    featureDescription: "No Description",
-     * Property: gmlParse
-     * {Object} GML Format object for parsing features
-     * Non-API and only created if necessary
-    gmlParser: null,
-     * APIProperty: xy
-     * {Boolean} Order of the GML coordinate: true:(x,y) or false:(y,x)
-     * For GeoRSS the default is (y,x), therefore: false
-    xy: false,
-     * Constructor: OpenLayers.Format.GeoRSS
-     * Create a new parser for GeoRSS.
-     * Parameters:
-     *     this instance.
-     * Method: createGeometryFromItem
-     * Return a geometry from a GeoRSS Item.
-     * Parameters:
-     * item - {DOMElement} A GeoRSS item node.
-     * Returns:
-     * {<OpenLayers.Geometry>} A geometry representing the node.
-    createGeometryFromItem: function(item) {
-        var point = this.getElementsByTagNameNS(item, this.georssns, "point");
-        var lat = this.getElementsByTagNameNS(item, this.geons, 'lat');
-        var lon = this.getElementsByTagNameNS(item, this.geons, 'long');
-        var line = this.getElementsByTagNameNS(item,
-                                                this.georssns,
-                                                "line");
-        var polygon = this.getElementsByTagNameNS(item,
-                                                this.georssns,
-                                                "polygon");
-        var where = this.getElementsByTagNameNS(item,
-                                                this.georssns,
-                                                "where");
-        if (point.length > 0 || (lat.length > 0 && lon.length > 0)) {
-            var location;
-            if (point.length > 0) {
-                location = OpenLayers.String.trim(
-                                point[0].firstChild.nodeValue).split(/\s+/);
-                if (location.length !=2) {
-                                point[0].firstChild.nodeValue).split(/\s*,\s*/);
-            } else {
-                location = [parseFloat(lat[0].firstChild.nodeValue),
-                                parseFloat(lon[0].firstChild.nodeValue)];
-            var geometry = new OpenLayers.Geometry.Point(parseFloat(location[1]),
-                                                         parseFloat(location[0]));
-        } else if (line.length > 0) {
-            var coords = OpenLayers.String.trim(line[0].firstChild.nodeValue).split(/\s+/);
-            var point;
-            for (var i=0; i < coords.length; i+=2) {
-                point = new OpenLayers.Geometry.Point(parseFloat(coords[i+1]),
-                                                     parseFloat(coords[i]));
-            geometry = new OpenLayers.Geometry.LineString(components);
-        } else if (polygon.length > 0) {
-            var coords = OpenLayers.String.trim(polygon[0].firstChild.nodeValue).split(/\s+/);
-            var point;
-            geometry = new OpenLayers.Geometry.Polygon([new OpenLayers.Geometry.LinearRing(components)]);
-        } else if (where.length > 0) {
-            if (!this.gmlParser) {
-              this.gmlParser = new OpenLayers.Format.GML({'xy': this.xy});
-            var feature = this.gmlParser.parseFeature(where[0]);
-            geometry = feature.geometry;
-        if (geometry && this.internalProjection && this.externalProjection) {
-        return geometry;
-     * Method: createFeatureFromItem
-     * Return a feature from a GeoRSS Item.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} A feature representing the item.
-    createFeatureFromItem: function(item) {
-        var geometry = this.createGeometryFromItem(item);
-        /* Provide defaults for title and description */
-        var title = this.getChildValue(item, "*", "title", this.featureTitle);
-        /* First try RSS descriptions, then Atom summaries */
-        var description = this.getChildValue(
-            item, "*", "description",
-            this.getChildValue(item, "*", "content", this.featureDescription)
-        /* If no link URL is found in the first child node, try the
-           href attribute */
-        var link = this.getChildValue(item, "*", "link");
-        if(!link) {
-            try {
-                link = this.getElementsByTagNameNS(item, "*", "link")[0].getAttribute("href");
-            } catch(e) {
-                link = null;
-        var id = this.getChildValue(item, "*", "id", null);
-        var data = {
-            "title": title,
-            "description": description,
-            "link": link
-        var feature = new OpenLayers.Feature.Vector(geometry, data);
-        feature.fid = id;
-        return feature;
-     * Method: getChildValue
-     * Parameters:
-     * nsuri - {String} Child node namespace uri ("*" for any).
-     * name - {String} Child node name.
-     * def - {String} Optional string default to return if no child found.
-     * Returns:
-     * {String} The value of the first child with the given tag name.  Returns
-     *     default value or empty string if none found.
-    getChildValue: function(node, nsuri, name, def) {
-        var value;
-        try {
-            value = this.getElementsByTagNameNS(node, nsuri, name)[0].firstChild.nodeValue;
-        } catch(e) {
-            value = (def == undefined) ? "" : def;
-        return value;
-     * APIMethod: read
-     * Return a list of features from a GeoRSS doc
-     * Parameters:
-     * data - {Element}
-     * Returns:
-     * An Array of <OpenLayers.Feature.Vector>s
-    read: function(doc) {
-        if (typeof doc == "string") {
-            doc = OpenLayers.Format.XML.prototype.read.apply(this, [doc]);
-        /* Try RSS items first, then Atom entries */
-        var itemlist = null;
-        itemlist = this.getElementsByTagNameNS(doc, '*', 'item');
-        if (itemlist.length == 0) {
-            itemlist = this.getElementsByTagNameNS(doc, '*', 'entry');
-        var numItems = itemlist.length;
-        var features = new Array(numItems);
-        for(var i=0; i<numItems; i++) {
-            features[i] = this.createFeatureFromItem(itemlist[i]);
-        return features;
-     * Accept Feature Collection, and return a string.
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>)} List of features to serialize into a string.
-        var georss;
-        if(features instanceof Array) {
-            georss = this.createElementNS(this.rssns, "rss");
-            for(var i=0; i < features.length; i++) {
-                georss.appendChild(this.createFeatureXML(features[i]));
-        } else {
-            georss = this.createFeatureXML(features);
-        return OpenLayers.Format.XML.prototype.write.apply(this, [georss]);
-     * Accept an <OpenLayers.Feature.Vector>, and build a geometry for it.
-     * Parameters:
-     * Returns:
-     * {DOMElement}
-        var geometryNode = this.buildGeometryNode(feature.geometry);
-        var featureNode = this.createElementNS(this.rssns, "item");
-        var titleNode = this.createElementNS(this.rssns, "title");
-        titleNode.appendChild(this.createTextNode(feature.attributes.title ? feature.attributes.title : ""));
-        var descNode = this.createElementNS(this.rssns, "description");
-        descNode.appendChild(this.createTextNode(feature.attributes.description ? feature.attributes.description : ""));
-        featureNode.appendChild(titleNode);
-        featureNode.appendChild(descNode);
-        if (feature.attributes.link) {
-            var linkNode = this.createElementNS(this.rssns, "link");
-            linkNode.appendChild(this.createTextNode(feature.attributes.link));
-            featureNode.appendChild(linkNode);
-            if (attr == "link" || attr == "title" || attr == "description") { continue; }
-            var nodename = attr;
-            if (attr.search(":") != -1) {
-                nodename = attr.split(":")[1];
-            var attrContainer = this.createElementNS(this.featureNS, "feature:"+nodename);
-            featureNode.appendChild(attrContainer);
-        featureNode.appendChild(geometryNode);
-     * Method: buildGeometryNode
-     * builds a GeoRSS node with a given geometry
-     * Parameters:
-     * Returns:
-     * {DOMElement} A gml node.
-        var node;
-        // match Polygon
-        if (geometry.CLASS_NAME == "OpenLayers.Geometry.Polygon") {
-            node = this.createElementNS(this.georssns, 'georss:polygon');
-            node.appendChild(this.buildCoordinatesNode(geometry.components[0]));
-        // match LineString
-        else if (geometry.CLASS_NAME == "OpenLayers.Geometry.LineString") {
-            node = this.createElementNS(this.georssns, 'georss:line');
-            node.appendChild(this.buildCoordinatesNode(geometry));
-        // match Point
-        else if (geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
-            node = this.createElementNS(this.georssns, 'georss:point');
-        } else {
-            throw "Couldn't parse " + geometry.CLASS_NAME;
-        return node;
-     * Method: buildCoordinatesNode
-     * Parameters:
-        var points = null;
-        if (geometry.components) {
-            points = geometry.components;
-        var path;
-        if (points) {
-            var numPoints = points.length;
-            var parts = new Array(numPoints);
-            for (var i = 0; i < numPoints; i++) {
-                parts[i] = points[i].y + " " + points[i].x;
-            path = parts.join(" ");
-        } else {
-            path = geometry.y + " " + geometry.x;
-        return this.createTextNode(path);
-    CLASS_NAME: "OpenLayers.Format.GeoRSS"
-    OpenLayers/Format/KML.js
- * @requires OpenLayers/Geometry/Collection.js
- * Class: OpenLayers.Format.KML
- * Read/Wite KML. Create a new instance with the <OpenLayers.Format.KML>
- *     constructor.
- * Inherits from:
-OpenLayers.Format.KML = OpenLayers.Class(OpenLayers.Format.XML, {
-     * APIProperty: kmlns
-     * {String} KML Namespace to use. Defaults to 2.0 namespace.
-    kmlns: "http://earth.google.com/kml/2.0",
-     * APIProperty: placemarksDesc
-     * {String} Name of the placemarks.  Default is "No description available."
-    placemarksDesc: "No description available",
-     * APIProperty: foldersName
-     * {String} Name of the folders.  Default is "OpenLayers export."
-    foldersName: "OpenLayers export",
-     * APIProperty: foldersDesc
-     * {String} Description of the folders. Default is "Exported on [date]."
-    foldersDesc: "Exported on " + new Date(),
-     * APIProperty: extractAttributes
-     * {Boolean} Extract attributes from KML.  Default is true.
-     *           Extracting styleUrls requires this to be set to true
-     * Property: extractStyles
-     * {Boolean} Extract styles from KML.  Default is false.
-     *           Extracting styleUrls also requires extractAttributes to be
-     *           set to true
-    extractStyles: false,
-     * Property: internalns
-     * {String} KML Namespace to use -- defaults to the namespace of the
-     *     Placemark node being parsed, but falls back to kmlns.
-    internalns: null,
-     * Property: features
-     * {Array} Array of features
-    features: null,
-     * Property: styles
-     * {Object} Storage of style objects
-    styles: null,
-     * Property: styleBaseUrl
-     * {String}
-    styleBaseUrl: "",
-     * Property: fetched
-     * {Object} Storage of KML URLs that have been fetched before
-     *     in order to prevent reloading them.
-    fetched: null,
-     * APIProperty: maxDepth
-     * {Integer} Maximum depth for recursive loading external KML URLs
-     *           Defaults to 0: do no external fetching
-    maxDepth: 0,
-     * Constructor: OpenLayers.Format.KML
-     * Create a new parser for KML.
-     * Parameters:
-     *     this instance.
-        this.regExes = {
-            trimComma: (/\s*,\s*/g),
-            kmlColor: (/(\w{2})(\w{2})(\w{2})(\w{2})/),
-            kmlIconPalette: (/root:\/\/icons\/palette-(\d+)(\.\w+)/),
-            straightBracket: (/\$\[(.*?)\]/g)
-     * APIMethod: read
-     * Parameters:
-     * Returns:
-     * {Array(<OpenLayers.Feature.Vector>)} List of features.
-        this.features = [];
-        this.styles   = {};
-        this.fetched  = {};
-        // Set default options
-        var options = {
-            depth: this.maxDepth,
-            styleBaseUrl: this.styleBaseUrl
-        return this.parseData(data, options);
-     * Method: parseData
-     * Parameters:
-     * options - {Object} Hash of options
-     * Returns:
-    parseData: function(data, options) {
-        // Loop throught the following node types in this order and
-        // process the nodes found
-        var types = ["Link", "NetworkLink", "Style", "StyleMap", "Placemark"];
-        for(var i=0; i<types.length; ++i) {
-            var type = types[i];
-            var nodes = this.getElementsByTagNameNS(data, "*", type);
-            // skip to next type if no nodes are found
-            if(nodes.length == 0) {
-                continue;
-            switch (type.toLowerCase()) {
-                // Fetch external links
-                case "link":
-                case "networklink":
-                    this.parseLinks(nodes, options);
-                    break;
-                // parse style information
-                case "style":
-                    if (this.extractStyles) {
-                        this.parseStyles(nodes, options);
-                    break;
-                case "stylemap":
-                        this.parseStyleMaps(nodes, options);
-                    break;
-                // parse features
-                case "placemark":
-                    this.parseFeatures(nodes, options);
-                    break;
-        return this.features;
-     * Method: parseLinks
-     * Finds URLs of linked KML documents and fetches them
-     * Parameters:
-     * nodes   - {Array} of {DOMElement} data to read/parse.
-    parseLinks: function(nodes, options) {
-        // Fetch external links <NetworkLink> and <Link>
-        // Don't do anything if we have reached our maximum depth for recursion
-        if (options.depth >= this.maxDepth) {
-            return false;
-        // increase depth
-        var newOptions = OpenLayers.Util.extend({}, options);
-        newOptions.depth++;
-        for(var i=0; i < nodes.length; i++) {
-            var href = this.parseProperty(nodes[i], "*", "href");
-            if(href && !this.fetched[href]) {
-                this.fetched[href] = true; // prevent reloading the same urls
-                var data = this.fetchLink(href);
-                if (data) {
-                    this.parseData(data, newOptions);
-     * Method: fetchLink
-     * Fetches a URL and returns the result
-     * Parameters:
-     * href  - {String} url to be fetched
-    fetchLink: function(href) {
-        var request = new OpenLayers.Ajax.Request(href,
-                      {method: 'get', asynchronous: false });
-        if (request && request.transport) {
-            return request.transport.responseText;
-     * Method: parseStyles
-     * Looks for <Style> nodes in the data and parses them
-     * Also parses <StyleMap> nodes, but only uses the 'normal' key
-     * Parameters:
-    parseStyles: function(nodes, options) {
-            var style = this.parseStyle(nodes[i]);
-            if(style) {
-                styleName = (options.styleBaseUrl || "") + "#" + style.id;
-                this.styles[styleName] = style;
-     * Parses the children of a <Style> node and builds the style hash
-     * accordingly
-     * Parameters:
-     * node - {DOMElement} <Style> node
-    parseStyle: function(node) {
-        var style = {};
-        var types = ["LineStyle", "PolyStyle", "IconStyle", "BalloonStyle"];
-            type = types[i];
-            styleTypeNode = this.getElementsByTagNameNS(node,
-                                                   "*", type)[0];
-            if(!styleTypeNode) {
-                continue;
-                case "linestyle":
-                    var color = this.parseProperty(styleTypeNode, "*", "color");
-                    if (color) {
-                        var matches = (color.toString()).match(
-                                                         this.regExes.kmlColor);
-                        // transparency
-                        var alpha = matches[1];
-                        style["strokeOpacity"] = parseInt(alpha, 16) / 255;
-                        // rgb colors (google uses bgr)
-                        var b = matches[2];
-                        var g = matches[3];
-                        var r = matches[4];
-                        style["strokeColor"] = "#" + r + g + b;
-                    var width = this.parseProperty(styleTypeNode, "*", "width");
-                    if (width) {
-                        style["strokeWidth"] = width;
-                case "polystyle":
-                    if (color) {
-                        // transparency
-                        style["fillOpacity"] = parseInt(alpha, 16) / 255;
-                        style["fillColor"] = "#" + r + g + b;
-                    break;
-                case "iconstyle":
-                    // set scale
-                    var scale = parseFloat(this.parseProperty(styleTypeNode,
-                                                          "*", "scale") || 1);
-                    // set default width and height of icon
-                    var width = 32 * scale;
-                    var height = 32 * scale;
-                    var iconNode = this.getElementsByTagNameNS(styleTypeNode,
-                                               "Icon")[0];
-                    if (iconNode) {
-                        var href = this.parseProperty(iconNode, "*", "href");
-                        if (href) {
-                            var w = this.parseProperty(iconNode, "*", "w");
-                            var h = this.parseProperty(iconNode, "*", "h");
-                            // Settings for Google specific icons that are 64x64
-                            // We set the width and height to 64 and halve the
-                            // scale to prevent icons from being too big
-                            var google = "http://maps.google.com/mapfiles/kml";
-                            if (OpenLayers.String.startsWith(
-                                                 href, google) && !w && !h) {
-                                w = 64;
-                                h = 64;
-                                scale = scale / 2;
-                            // if only dimension is defined, make sure the
-                            // other one has the same value
-                            w = w || h;
-                            h = h || w;
-                            if (w) {
-                                width = parseInt(w) * scale;
-                            if (h) {
-                                height = parseInt(h) * scale;
-                            // support for internal icons
-                            //    (/root://icons/palette-x.png)
-                            // x and y tell the position on the palette:
-                            // - in pixels
-                            // - starting from the left bottom
-                            // We translate that to a position in the list
-                            // and request the appropriate icon from the
-                            // google maps website
-                            var matches = href.match(this.regExes.kmlIconPalette);
-                            if (matches)  {
-                                var palette = matches[1];
-                                var file_extension = matches[2];
-                                var x = this.parseProperty(iconNode, "*", "x");
-                                var y = this.parseProperty(iconNode, "*", "y");
-                                var posX = x ? x/32 : 0;
-                                var posY = y ? (7 - y/32) : 7;
-                                var pos = posY * 8 + posX;
-                                href = "http://maps.google.com/mapfiles/kml/pal"
-                                     + palette + "/icon" + pos + file_extension;
-                            style["graphicOpacity"] = 1; // fully opaque
-                            style["externalGraphic"] = href;
-                    // hotSpots define the offset for an Icon
-                    var hotSpotNode = this.getElementsByTagNameNS(styleTypeNode,
-                                               "hotSpot")[0];
-                    if (hotSpotNode) {
-                        var x = parseFloat(hotSpotNode.getAttribute("x"));
-                        var y = parseFloat(hotSpotNode.getAttribute("y"));
-                        var xUnits = hotSpotNode.getAttribute("xunits");
-                        if (xUnits == "pixels") {
-                            style["graphicXOffset"] = -x * scale;
-                        else if (xUnits == "insetPixels") {
-                            style["graphicXOffset"] = -width + (x * scale);
-                        else if (xUnits == "fraction") {
-                            style["graphicXOffset"] = -width * x;
-                        var yUnits = hotSpotNode.getAttribute("yunits");
-                        if (yUnits == "pixels") {
-                            style["graphicYOffset"] = -height + (y * scale) + 1;
-                        else if (yUnits == "insetPixels") {
-                            style["graphicYOffset"] = -(y * scale) + 1;
-                        else if (yUnits == "fraction") {
-                            style["graphicYOffset"] =  -height * (1 - y) + 1;
-                    style["graphicWidth"] = width;
-                    style["graphicHeight"] = height;
-                    break;
-                case "balloonstyle":
-                    var balloonStyle = OpenLayers.Util.getXmlNodeValue(
-                                            styleTypeNode);
-                    if (balloonStyle) {
-                        style["balloonStyle"] = balloonStyle.replace(
-                                       this.regExes.straightBracket, "${$1}");
-                    break;
-                default:
-        // Some polygons have no line color, so we use the fillColor for that
-        if (!style["strokeColor"] && style["fillColor"]) {
-            style["strokeColor"] = style["fillColor"];
-        var id = node.getAttribute("id");
-        if (id && style) {
-            style.id = id;
-        return style;
-     * Method: parseStyleMaps
-     * Parameters:
-    parseStyleMaps: function(nodes, options) {
-        // Only the default or "normal" part of the StyleMap is processed now
-        // To do the select or "highlight" bit, we'd need to change lots more
-            var node = nodes[i];
-            var pairs = this.getElementsByTagNameNS(node, "*",
-                            "Pair");
-            for (var j=0; j<pairs.length; j++) {
-                var pair = pairs[j];
-                // Use the shortcut in the SLD format to quickly retrieve the
-                // value of a node. Maybe it's good to have a method in
-                // Format.XML to do this
-                var key = this.parseProperty(pair, "*", "key");
-                var styleUrl = this.parseProperty(pair, "*", "styleUrl");
-                if (styleUrl && key == "normal") {
-                    this.styles[(options.styleBaseUrl || "") + "#" + id] =
-                        this.styles[(options.styleBaseUrl || "") + styleUrl];
-                if (styleUrl && key == "highlight") {
-                    // TODO: implement the "select" part
-     * Method: parseFeatures
-     * Loop through all Placemark nodes and parse them.
-     * Will create a list of features
-     * Parameters:
-    parseFeatures: function(nodes, options) {
-        var features = new Array(nodes.length);
-            var featureNode = nodes[i];
-            var feature = this.parseFeature.apply(this,[featureNode]) ;
-            if(feature) {
-                // Create reference to styleUrl
-                if (this.extractStyles && feature.attributes &&
-                    feature.attributes.styleUrl) {
-                    feature.style = this.getStyle(feature.attributes.styleUrl);
-                // Make sure that <Style> nodes within a placemark are
-                // processed as well
-                var inlineStyleNode = this.getElementsByTagNameNS(featureNode,
-                                                       "Style")[0];
-                if (inlineStyleNode) {
-                    var inlineStyle= this.parseStyle(inlineStyleNode);
-                    if (inlineStyle) {
-                        feature.style = OpenLayers.Util.extend({},
-                                            feature.style);
-                        OpenLayers.Util.extend(feature.style, inlineStyle);
-                // add feature to list of features
-                features[i] = feature;
-            } else {
-                throw "Bad Placemark: " + i;
-        // add new features to existing feature list
-        this.features = this.features.concat(features);
-     * This function is the core of the KML parsing code in OpenLayers.
-     * Parameters:
-     * Returns:
-     * {<OpenLayers.Feature.Vector>} A vector feature.
-        // only accept one geometry per feature - look for highest "order"
-        var order = ["MultiGeometry", "Polygon", "LineString", "Point"];
-            type = order[i];
-            this.internalns = node.namespaceURI ?
-                    node.namespaceURI : this.kmlns;
-                                                   this.internalns, type);
-                if(parser) {
-                } else {
-                break;
-        var attributes;
-        var fid = node.getAttribute("id") || node.getAttribute("name");
-        if(fid != null) {
-        return feature;
-     * Method: getStyle
-     * Retrieves a style from a style hash using styleUrl as the key
-     * If the styleUrl doesn't exist yet, we try to fetch it
-     * Internet
-     * Parameters:
-     * styleUrl  - {String} URL of style
-     * Returns:
-     * {Object}  - (reference to) Style hash
-    getStyle: function(styleUrl, options) {
-        var styleBaseUrl = OpenLayers.Util.removeTail(styleUrl);
-        newOptions.styleBaseUrl = styleBaseUrl;
-        // Fetch remote Style URLs (if not fetched before)
-        if (!this.styles[styleUrl]
-                && !OpenLayers.String.startsWith(styleUrl, "#")
-                && newOptions.depth <= this.maxDepth
-                && !this.fetched[styleBaseUrl] ) {
-            var data = this.fetchLink(styleBaseUrl);
-            if (data) {
-        // return requested style
-        var style = this.styles[styleUrl];
-        return style;
-     *     on their type.
-    parseGeometry: {
-         * Given a KML node representing a point geometry, create an OpenLayers
-         *     point geometry.
-         * Parameters:
-         * node - {DOMElement} A KML Point node.
-         * Returns:
-            var nodeList = this.getElementsByTagNameNS(node, this.internalns,
-                                                       "coordinates");
-            var coords = [];
-                var coordString = nodeList[0].firstChild.nodeValue;
-                coordString = coordString.replace(this.regExes.removeSpace, "");
-            var point = null;
-            if(coords.length > 1) {
-                    coords[2] = null;
-                point = new OpenLayers.Geometry.Point(coords[0], coords[1],
-                                                      coords[2]);
-            } else {
-                throw "Bad coordinate string: " + coordString;
-            return point;
-         * Given a KML node representing a linestring geometry, create an
-         * Parameters:
-         * node - {DOMElement} A KML LineString node.
-         * Returns:
-                                                       "coordinates");
-            var line = null;
-                var coordString = this.concatChildValues(nodeList[0]);
-                var numPoints = pointList.length;
-                var points = new Array(numPoints);
-                var coords, numCoords;
-                for(var i=0; i<numPoints; ++i) {
-                    numCoords = coords.length;
-                    if(numCoords > 1) {
-                            coords[2] = null;
-                        points[i] = new OpenLayers.Geometry.Point(coords[0],
-        coords[1],
-        coords[2]);
-                    } else {
-                        throw "Bad LineString point coordinates: " +
-                              pointList[i];
-                if(numPoints) {
-                    if(ring) {
-                    } else {
-                } else {
-                    throw "Bad LineString coordinates: " + coordString;
-            return line;
-         * Given a KML node representing a polygon geometry, create an
-         * Parameters:
-         * node - {DOMElement} A KML Polygon node.
-         * Returns:
-                                                       "LinearRing");
-            var numRings = nodeList.length;
-            var components = new Array(numRings);
-            if(numRings > 0) {
-                var ring;
-                    if(ring) {
-                        components[i] = ring;
-                    } else {
-                        throw "Bad LinearRing geometry: " + i;
-         * Method: parseGeometry.multigeometry
-         * Given a KML node representing a multigeometry, create an
-         *     OpenLayers geometry collection.
-         * Parameters:
-         * node - {DOMElement} A KML MultiGeometry node.
-         * Returns:
-         * {<OpenLayers.Geometry.Collection>} A geometry collection.
-        multigeometry: function(node) {
-            var child, parser;
-            var parts = [];
-            var children = node.childNodes;
-            for(var i=0; i<children.length; ++i ) {
-                child = children[i];
-                if(child.nodeType == 1) {
-                    var type = (child.prefix) ?
-                            child.nodeName;
-                    if(parser) {
-                        parts.push(parser.apply(this, [child]));
-            return new OpenLayers.Geometry.Collection(parts);
-     * Parameters:
-     * Returns:
-        // assume attribute nodes are type 1 children with a type 3 or 4 child
-        var child, grandchildren, grandchild;
-        for(var i=0; i<children.length; ++i) {
-                if(grandchildren.length == 1 || grandchildren.length == 3) {
-                    var grandchild;
-                    switch (grandchildren.length) {
-                        case 1:
-                            break;
-                        case 3:
-                        default:
-                            grandchild = grandchildren[1];
-                            break;
-                    if(grandchild.nodeType == 3 || grandchild.nodeType == 4) {
-                        var name = (child.prefix) ?
-                                child.nodeName;
-                        var value = OpenLayers.Util.getXmlNodeValue(grandchild);
-                        if (value) {
-                            value = value.replace(this.regExes.trimSpace, "");
-     * Method: parseProperty
-     * Convenience method to find a node and return its value
-     * Parameters:
-     * xmlNode    - {<DOMElement>}
-     * namespace  - {String} namespace of the node to find
-     * tagName    - {String} name of the property to parse
-     * Returns:
-     * {String} The value for the requested property (defaults to null)
-    parseProperty: function(xmlNode, namespace, tagName) {
-        var value;
-        var nodeList = this.getElementsByTagNameNS(xmlNode, namespace, tagName);
-        try {
-            value = OpenLayers.Util.getXmlNodeValue(nodeList[0]);
-        } catch(e) {
-            value = null;
-        return value;
-     * Parameters:
-     * features - {Array(<OpenLayers.Feature.Vector>} An array of features.
-     * Returns:
-     * {String} A KML string.
-        var kml = this.createElementNS(this.kmlns, "kml");
-        var folder = this.createFolderXML();
-        for(var i=0; i<features.length; ++i) {
-            folder.appendChild(this.createPlacemarkXML(features[i]));
-        kml.appendChild(folder);
-        return OpenLayers.Format.XML.prototype.write.apply(this, [kml]);
-     * Method: createFolderXML
-     * Creates and returns a KML folder node
-     * Returns:
-     * {DOMElement}
-    createFolderXML: function() {
-        // Folder name
-        var folderName = this.createElementNS(this.kmlns, "name");
-        var folderNameText = this.createTextNode(this.foldersName);
-        folderName.appendChild(folderNameText);
-        // Folder description
-        var folderDesc = this.createElementNS(this.kmlns, "description");
-        var folderDescText = this.createTextNode(this.foldersDesc);
-        folderDesc.appendChild(folderDescText);
-        // Folder
-        var folder = this.createElementNS(this.kmlns, "Folder");
-        folder.appendChild(folderName);
-        folder.appendChild(folderDesc);
-        return folder;
-     * Method: createPlacemarkXML
-     * Creates and returns a KML placemark node representing the given feature.
-     * Parameters:
-     * Returns:
-     * {DOMElement}
-    createPlacemarkXML: function(feature) {
-        // Placemark name
-        var placemarkName = this.createElementNS(this.kmlns, "name");
-        var name = (feature.attributes.name) ?
-                    feature.attributes.name : feature.id;
-        placemarkName.appendChild(this.createTextNode(name));
-        // Placemark description
-        var placemarkDesc = this.createElementNS(this.kmlns, "description");
-        var desc = (feature.attributes.description) ?
-                    feature.attributes.description : this.placemarksDesc;
-        placemarkDesc.appendChild(this.createTextNode(desc));
-        // Placemark
-        var placemarkNode = this.createElementNS(this.kmlns, "Placemark");
-        if(feature.fid != null) {
-            placemarkNode.setAttribute("id", feature.fid);
-        placemarkNode.appendChild(placemarkName);
-        placemarkNode.appendChild(placemarkDesc);
-        // Geometry node (Point, LineString, etc. nodes)
-        placemarkNode.appendChild(geometryNode);
-        // TBD - deal with remaining (non name/description) attributes.
-        return placemarkNode;
-     * Builds and returns a KML geometry node with the given geometry.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>}
-     * Returns:
-     * {DOMElement}
-        var node = null;
-        if(builder) {
-            node = builder.apply(this, [geometry]);
-        return node;
-    buildGeometry: {
-        // TBD: Anybody care about namespace aliases here (these nodes have
-        //    no prefixes)?
-         * Given an OpenLayers point geometry, create a KML point.
-         * Parameters:
-         * Returns:
-         * {DOMElement} A KML point node.
-            var kml = this.createElementNS(this.kmlns, "Point");
-            kml.appendChild(this.buildCoordinatesNode(geometry));
-            return kml;
-         * Given an OpenLayers multipoint geometry, create a KML
-         *     GeometryCollection.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Point>} A multipoint geometry.
-         * Returns:
-         * {DOMElement} A KML GeometryCollection node.
-            return this.buildGeometry.collection.apply(this, [geometry]);
-         * Given an OpenLayers linestring geometry, create a KML linestring.
-         * Parameters:
-         * Returns:
-         * {DOMElement} A KML linestring node.
-            var kml = this.createElementNS(this.kmlns, "LineString");
-            return kml;
-         * Given an OpenLayers multilinestring geometry, create a KML
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Point>} A multilinestring geometry.
-         * Returns:
-         * Given an OpenLayers linearring geometry, create a KML linearring.
-         * Parameters:
-         * Returns:
-         * {DOMElement} A KML linearring node.
-            var kml = this.createElementNS(this.kmlns, "LinearRing");
-            return kml;
-         * Given an OpenLayers polygon geometry, create a KML polygon.
-         * Parameters:
-         * Returns:
-         * {DOMElement} A KML polygon node.
-            var kml = this.createElementNS(this.kmlns, "Polygon");
-                ringMember = this.createElementNS(this.kmlns, type);
-                                                               [rings[i]]);
-                kml.appendChild(ringMember);
-            return kml;
-         * Given an OpenLayers multipolygon geometry, create a KML
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Point>} A multipolygon geometry.
-         * Returns:
-         * Method: buildGeometry.collection
-         * Given an OpenLayers geometry collection, create a KML MultiGeometry.
-         * Parameters:
-         * geometry - {<OpenLayers.Geometry.Collection>} A geometry collection.
-         * Returns:
-         * {DOMElement} A KML MultiGeometry node.
-        collection: function(geometry) {
-            var kml = this.createElementNS(this.kmlns, "MultiGeometry");
-            var child;
-            for(var i=0; i<geometry.components.length; ++i) {
-                child = this.buildGeometryNode.apply(this,
-                                                     [geometry.components[i]]);
-                if(child) {
-                    kml.appendChild(child);
-            return kml;
-     * Builds and returns the KML coordinates node with the given geometry
-     * <coordinates>...</coordinates>
-     * Parameters:
-     * Return:
-     * {DOMElement}
-        var coordinatesNode = this.createElementNS(this.kmlns, "coordinates");
-        var path;
-        if(points) {
-            // LineString or LinearRing
-            var point;
-                point = points[i];
-                parts[i] = point.x + "," + point.y;
-        } else {
-            // Point
-            path = geometry.x + "," + geometry.y;
-        var txtNode = this.createTextNode(path);
-    CLASS_NAME: "OpenLayers.Format.KML"
-    OpenLayers/Format/OSM.js
-/* Copyright (c) 2006-2007 MetaCarta, Inc., published under a modified BSD license.
- * See http://svn.openlayers.org/trunk/openlayers/repository-license.txt
- * for the full text of the license. */
- * @requires OpenLayers/Format/XML.js
- * @requires OpenLayers/Feature/Vector.js
- * @requires OpenLayers/Geometry/Point.js
- * @requires OpenLayers/Geometry/LineString.js
- * @requires OpenLayers/Geometry/Polygon.js
- * Class: OpenLayers.Format.OSM
- * OSM parser. Create a new instance with the
- *     <OpenLayers.Format.OSM> constructor.
- * Inherits from:
-OpenLayers.Format.OSM = OpenLayers.Class(OpenLayers.Format.XML, {
-     * APIProperty: checkTags
-     * {Boolean} Should tags be checked to determine whether something
-     * should be treated as a seperate node. Will slow down parsing.
-    checkTags: false,
-     * Property: interestingTagsExclude
-     * {Array} List of tags to exclude from 'interesting' checks on nodes.
-     * Must be set when creating the format. Will only be used if checkTags
-     * is set.
-    interestingTagsExclude: null,
-     * APIProperty: areaTags
-     * {Array} List of tags indicating that something is an area.
-     * checkTags is true.
-    areaTags: null,
-     * Constructor: OpenLayers.Format.OSM
-     * Create a new parser for OSM.
-     * Parameters:
-     * options - {Object} An optional object whose properties will be set on
-     *     this instance.
-    initialize: function(options) {
-        var layer_defaults = {
-          'interestingTagsExclude': ['source', 'source_ref',
-              'source:ref', 'history', 'attribution', 'created_by'],
-          'areaTags': ['area', 'building', 'leisure', 'tourism', 'ruins',
-              'historic', 'landuse', 'military', 'natural', 'sport']
-        layer_defaults = OpenLayers.Util.extend(layer_defaults, options);
-        var interesting = {};
-        for (var i = 0; i < layer_defaults.interestingTagsExclude.length; i++) {
-            interesting[layer_defaults.interestingTagsExclude[i]] = true;
-        layer_defaults.interestingTagsExclude = interesting;
-        var area = {};
-        for (var i = 0; i < layer_defaults.areaTags.length; i++) {
-            area[layer_defaults.areaTags[i]] = true;
-        layer_defaults.areaTags = area;
-        OpenLayers.Format.XML.prototype.initialize.apply(this, [layer_defaults]);
-     * APIMethod: read
-     * Return a list of features from a OSM doc
-     * Parameters:
-     * Returns:
-        var nodes = this.getNodes(doc);
-        var ways = this.getWays(doc);
-        // Geoms will contain at least ways.length entries.
-        var feat_list = new Array(ways.length);
-        for (var i = 0; i < ways.length; i++) {
-            // We know the minimal of this one ahead of time. (Could be -1
-            // due to areas/polygons)
-            var point_list = new Array(ways[i].nodes.length);
-            var poly = this.isWayArea(ways[i]) ? 1 : 0;
-            for (var j = 0; j < ways[i].nodes.length; j++) {
-               var node = nodes[ways[i].nodes[j]];
-               var point = new OpenLayers.Geometry.Point(node.lon, node.lat);
-               // Since OSM is topological, we stash the node ID internally.
-               point.osm_id = parseInt(ways[i].nodes[j]);
-               point_list[j] = point;
-               // We don't display nodes if they're used inside other
-               // elements.
-               node.used = true;
-            var geometry = null;
-            if (poly) {
-                    new OpenLayers.Geometry.LinearRing(point_list));
-            } else {
-                geometry = new OpenLayers.Geometry.LineString(point_list);
-            if (this.internalProjection && this.externalProjection) {
-                geometry.transform(this.externalProjection,
-                    this.internalProjection);
-            var feat = new OpenLayers.Feature.Vector(geometry,
-                ways[i].tags);
-            feat.osm_id = parseInt(ways[i].id);
-            feat.fid = "way." + feat.osm_id;
-            feat_list[i] = feat;
-        for (var node_id in nodes) {
-            var node = nodes[node_id];
-            if (!node.used || this.checkTags) {
-                var tags = null;
-                if (this.checkTags) {
-                    var result = this.getTags(node.node, true);
-                    if (node.used && !result[1]) {
-                        continue;
-                    tags = result[0];
-                } else {
-                    tags = this.getTags(node.node);
-                    new OpenLayers.Geometry.Point(node['lon'], node['lat']),
-                    tags);
-                    feat.geometry.transform(this.externalProjection,
-                feat.osm_id = parseInt(node_id);
-                feat.fid = "node." + feat.osm_id;
-                feat_list.push(feat);
-            // Memory cleanup
-            node.node = null;
-        return feat_list;
-     * Method: getNodes
-     * Return the node items from a doc.
-     * Parameters:
-     * node - {DOMElement} node to parse tags from
-    getNodes: function(doc) {
-        var node_list = doc.getElementsByTagName("node");
-        var nodes = {};
-        for (var i = 0; i < node_list.length; i++) {
-            var node = node_list[i];
-            nodes[id] = {
-                'lat': node.getAttribute("lat"),
-                'lon': node.getAttribute("lon"),
-                'node': node
-        return nodes;
-     * Method: getWays
-     * Return the way items from a doc.
-     * Parameters:
-    getWays: function(doc) {
-        var way_list = doc.getElementsByTagName("way");
-        var return_ways = [];
-        for (var i = 0; i < way_list.length; i++) {
-            var way = way_list[i];
-            var way_object = {
-              id: way.getAttribute("id")
-            way_object.tags = this.getTags(way);
-            var node_list = way.getElementsByTagName("nd");
-            way_object.nodes = new Array(node_list.length);
-            for (var j = 0; j < node_list.length; j++) {
-                way_object.nodes[j] = node_list[j].getAttribute("ref");
-            return_ways.push(way_object);
-        return return_ways;
-     * Method: getTags
-     * Return the tags list attached to a specific DOM element.
-     * Parameters:
-     * interesting_tags - {Boolean} whether the return from this function should
-     *    return a boolean indicating that it has 'interesting tags' --
-     *    tags like attribution and source are ignored. (To change the list
-     *    of tags, see interestingTagsExclude)
-     * Returns:
-     * tags - {Object} hash of tags
-     * interesting - {Boolean} if interesting_tags is passed, returns
-     *     whether there are any interesting tags on this element.
-    getTags: function(dom_node, interesting_tags) {
-        var tag_list = dom_node.getElementsByTagName("tag");
-        var tags = {};
-        var interesting = false;
-        for (var j = 0; j < tag_list.length; j++) {
-            var key = tag_list[j].getAttribute("k");
-            tags[key] = tag_list[j].getAttribute("v");
-            if (interesting_tags) {
-                if (!this.interestingTagsExclude[key]) {
-                    interesting = true;
-        return interesting_tags ? [tags, interesting] : tags;
-     * Method: isWayArea
-     * Given a way object from getWays, check whether the tags and geometry
-     * indicate something is an area.
-     * Returns:
-     * {Boolean}
-    isWayArea: function(way) {
-        var poly_shaped = false;
-        var poly_tags = false;
-        if (way.nodes[0] == way.nodes[way.nodes.length - 1]) {
-            poly_shaped = true;
-            for(var key in way.tags) {
-                if (this.areaTags[key]) {
-                    poly_tags = true;
-                    break;
-        return poly_shaped && (this.checkTags ? poly_tags : true);
-     * Takes a list of features, returns a serialized OSM format file for use
-     * in tools like JOSM.
-     * Parameters:
-        if (!(features instanceof Array)) {
-        this.osm_id = 1;
-        this.created_nodes = {};
-        var root_node = this.createElementNS(null, "osm");
-        root_node.setAttribute("version", "0.5");
-        root_node.setAttribute("generator", "OpenLayers "+ OpenLayers.VERSION_NUMBER);
-        // Loop backwards, because the deserializer puts nodes last, and
-        // we want them first if possible
-        for(var i = features.length - 1; i >= 0; i--) {
-            var nodes = this.createFeatureNodes(features[i]);
-            for (var j = 0; j < nodes.length; j++) {
-                root_node.appendChild(nodes[j]);
-        return OpenLayers.Format.XML.prototype.write.apply(this, [root_node]);
-     * Method: createFeatureNodes
-     * Takes a feature, returns a list of nodes from size 0->n.
-     * Will include all pieces of the serialization that are required which
-     * have not already been created. Calls out to createXML based on geometry
-     * type.
-     * Parameters:
-    createFeatureNodes: function(feature) {
-        var nodes = [];
-        var className = feature.geometry.CLASS_NAME;
-        type = type.toLowerCase();
-        var builder = this.createXML[type];
-        if (builder) {
-            nodes = builder.apply(this, [feature]);
-        return nodes;
-     * Method: createXML
-     * Parameters:
-    createXML: {
-            var id = null;
-            var geometry = point.geometry ? point.geometry : point;
-            var already_exists = false; // We don't return anything if the node
-                                        // has already been created
-            if (point.osm_id) {
-                id = point.osm_id;
-                if (this.created_nodes[id]) {
-                    already_exists = true;
-            } else {
-               id = -this.osm_id;
-               this.osm_id++;
-            if (already_exists) {
-                node = this.created_nodes[id];
-            } else {
-                var node = this.createElementNS(null, "node");
-            this.created_nodes[id] = node;
-            node.setAttribute("id", id);
-            node.setAttribute("lon", geometry.x);
-            node.setAttribute("lat", geometry.y);
-            if (point.attributes) {
-                this.serializeTags(point, node);
-            this.setState(point, node);
-            return already_exists ? [] : [node];
-        linestring: function(feature) {
-            var nodes = [];
-            if (feature.osm_id) {
-                id = feature.osm_id;
-            } else {
-               this.osm_id++;
-            var way = this.createElementNS(null, "way");
-            way.setAttribute("id", id);
-            for (var i = 0; i < geometry.components.length; i++) {
-                var node = this.createXML['point'].apply(this, [geometry.components[i]]);
-                if (node.length) {
-                    node = node[0];
-                    var node_ref = node.getAttribute("id");
-                    nodes.push(node);
-                } else {
-                    node_ref = geometry.components[i].osm_id;
-                    node = this.created_nodes[node_ref];
-                this.setState(feature, node);
-                var nd_dom = this.createElementNS(null, "nd");
-                nd_dom.setAttribute("ref", node_ref);
-                way.appendChild(nd_dom);
-            this.serializeTags(feature, way);
-            nodes.push(way);
-            return nodes;
-        polygon: function(feature) {
-            var attrs = OpenLayers.Util.extend({'area':'yes'}, feature.attributes);
-            var feat = new OpenLayers.Feature.Vector(feature.geometry.components[0], attrs);
-            feat.osm_id = feature.osm_id;
-            return this.createXML['linestring'].apply(this, [feat]);
-     * Method: serializeTags
-     * Given a feature, serialize the attributes onto the given node.
-     * Parameters:
-     * node - {DOMNode}
-    serializeTags: function(feature, node) {
-        for (var key in feature.attributes) {
-            var tag = this.createElementNS(null, "tag");
-            tag.setAttribute("k", key);
-            tag.setAttribute("v", feature.attributes[key]);
-            node.appendChild(tag);
-     * Method: setState
-     * OpenStreetMap has a convention that 'state' is stored for modification or deletion.
-     * This allows the file to be uploaded via JOSM or the bulk uploader tool.
-     * Parameters:
-     * feature - {<OpenLayers.Feature.Vector>}
-    setState: function(feature, node) {
-        if (feature.state) {
-            var state = null;
-            switch(feature.state) {
-                case OpenLayers.State.UPDATE:
-                    state = "modify";
-                case OpenLayers.State.DELETE:
-                    state = "delete";
-            if (state) {
-                node.setAttribute("action", state);
-    CLASS_NAME: "OpenLayers.Format.OSM"
-    OpenLayers/Geometry/LinearRing.js
-/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
- * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
- * full text of the license. */
- * Class: OpenLayers.Geometry.LinearRing
- * A Linear Ring is a special LineString which is closed. It closes itself
- * automatically on every addPoint/removePoint by adding a copy of the first
- * point as the last point.
- * Also, as it is the first in the line family to close itself, a getArea()
- * function is defined to calculate the enclosed area of the linearRing
- * Inherits:
- *  - <OpenLayers.Geometry.LineString>
-OpenLayers.Geometry.LinearRing = OpenLayers.Class(
-  OpenLayers.Geometry.LineString, {
-     * Property: componentTypes
-     * {Array(String)} An array of class names representing the types of
-     *                 components that the collection can include.  A null
-     *                 value means the component types are not restricted.
-    componentTypes: ["OpenLayers.Geometry.Point"],
-     * Constructor: OpenLayers.Geometry.LinearRing
-     * Linear rings are constructed with an array of points.  This array
-     *     can represent a closed or open ring.  If the ring is open (the last
-     *     point does not equal the first point), the constructor will close
-     *     the ring.  If the ring is already closed (the last point does equal
-     *     the first point), it will be left closed.
-     * Parameters:
-     * points - {Array(<OpenLayers.Geometry.Point>)} points
-    initialize: function(points) {
-        OpenLayers.Geometry.LineString.prototype.initialize.apply(this,
-        arguments);
-     * APIMethod: addComponent
-     * Adds a point to geometry components.  If the point is to be added to
-     *     the end of the components array and it is the same as the last point
-     *     already in that array, the duplicate point is not added.  This has
-     *     the effect of closing the ring if it is not already closed, and
-     *     doing the right thing if it is already closed.  This behavior can
-     *     be overridden by calling the method with a non-null index as the
-     *     second argument.
-     * Parameter:
-     * point - {<OpenLayers.Geometry.Point>}
-     * index - {Integer} Index into the array to insert the component
-     * Returns:
-     * {Boolean} Was the Point successfully added?
-    addComponent: function(point, index) {
-        var added = false;
-        //remove last point
-        var lastPoint = this.components.pop();
-        // given an index, add the point
-        // without an index only add non-duplicate points
-        if(index != null || !point.equals(lastPoint)) {
-            added = OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,
-        arguments);
-        //append copy of first point
-        var firstPoint = this.components[0];
-        OpenLayers.Geometry.Collection.prototype.addComponent.apply(this,
-        [firstPoint]);
-        return added;
-     * APIMethod: removeComponent
-     * Removes a point from geometry components.
-     * Parameters:
-    removeComponent: function(point) {
-        if (this.components.length > 4) {
-            this.components.pop();
-            //remove our point
-            OpenLayers.Geometry.Collection.prototype.removeComponent.apply(this,
-        arguments);
-        [firstPoint]);
-     * APIMethod: move
-     * Moves a collection in place
-     * Parameters:
-     * x - {Float} The x-displacement (in map units)
-     * y - {Float} The y-displacement (in map units)
-    move: function(x, y) {
-        for(var i = 0; i < this.components.length - 1; i++) {
-            this.components[i].move(x, y);
-     * APIMethod: rotate
-     * Rotate a geometry around some origin
-     * Parameters:
-     * angle - {Float} Rotation angle in degrees (measured counterclockwise
-     *                 from the positive x-axis)
-     * origin - {<OpenLayers.Geometry.Point>} Center point for the rotation
-    rotate: function(angle, origin) {
-        for(var i=0; i<this.components.length - 1; ++i) {
-            this.components[i].rotate(angle, origin);
-     * APIMethod: resize
-     * Resize a geometry relative to some origin.  Use this method to apply
-     *     a uniform scaling to a geometry.
-     * Parameters:
-     * scale - {Float} Factor by which to scale the geometry.  A scale of 2
-     *                 doubles the size of the geometry in each dimension
-     *                 (lines, for example, will be twice as long, and polygons
-     *                 will have four times the area).
-     * origin - {<OpenLayers.Geometry.Point>} Point of origin for resizing
-     * ratio - {Float} Optional x:y ratio for resizing.  Default ratio is 1.
-    resize: function(scale, origin, ratio) {
-            this.components[i].resize(scale, origin, ratio);
-     * APIMethod: transform
-     * Reproject the components geometry from source to dest.
-     * Parameters:
-     * source - {<OpenLayers.Projection>}
-     * dest - {<OpenLayers.Projection>}
-     * Returns:
-    transform: function(source, dest) {
-        if (source && dest) {
-            for (var i = 0; i < this.components.length - 1; i++) {
-                var component = this.components[i];
-                component.transform(source, dest);
-        return this;
-     * APIMethod: getArea
-     * Note - The area is positive if the ring is oriented CW, otherwise
-     *         it will be negative.
-     * Returns:
-     * {Float} The signed area for a ring.
-    getArea: function() {
-        var area = 0.0;
-        if ( this.components && (this.components.length > 2)) {
-            var sum = 0.0;
-                var b = this.components[i];
-                var c = this.components[i+1];
-                sum += (b.x + c.x) * (c.y - b.y);
-            area = - sum / 2.0;
-        return area;
-     * Method: containsPoint
-     * Test if a point is inside a linear ring.  For the case where a point
-     *     is coincident with a linear ring edge, returns 1.  Otherwise,
-     *     returns boolean.
-     * Parameters:
-     * Returns:
-     * {Boolean | Number} The point is inside the linear ring.  Returns 1 if
-     *     the point is coincident with an edge.  Returns boolean otherwise.
-    containsPoint: function(point) {
-        var approx = OpenLayers.Number.limitSigDigs;
-        var digs = 14;
-        var px = approx(point.x, digs);
-        var py = approx(point.y, digs);
-        function getX(y, x1, y1, x2, y2) {
-            return (((x1 - x2) * y) + ((x2 * y1) - (x1 * y2))) / (y1 - y2);
-        var numSeg = this.components.length - 1;
-        var start, end, x1, y1, x2, y2, cx, cy;
-        var crosses = 0;
-        for(var i=0; i<numSeg; ++i) {
-            start = this.components[i];
-            x1 = approx(start.x, digs);
-            y1 = approx(start.y, digs);
-            end = this.components[i + 1];
-            x2 = approx(end.x, digs);
-            y2 = approx(end.y, digs);
-             * The following conditions enforce five edge-crossing rules:
-             *    1. points coincident with edges are considered contained;
-             *    2. an upward edge includes its starting endpoint, and
-             *    excludes its final endpoint;
-             *    3. a downward edge excludes its starting endpoint, and
-             *    includes its final endpoint;
-             *    4. horizontal edges are excluded; and
-             *    5. the edge-ray intersection point must be strictly right
-             *    of the point P.
-            if(y1 == y2) {
-                // horizontal edge
-                if(py == y1) {
-                    // point on horizontal line
-                    if(x1 <= x2 && (px >= x1 && px <= x2) || // right or vert
-                       x1 >= x2 && (px <= x1 && px >= x2)) { // left or vert
-                        // point on edge
-                        crosses = -1;
-                        break;
-                // ignore other horizontal edges
-                continue;
-            cx = approx(getX(py, x1, y1, x2, y2), digs);
-            if(cx == px) {
-                // point on line
-                if(y1 < y2 && (py >= y1 && py <= y2) || // upward
-                   y1 > y2 && (py <= y1 && py >= y2)) { // downward
-                    // point on edge
-                    crosses = -1;
-                    break;
-            if(cx <= px) {
-                // no crossing to the right
-                continue;
-            if(x1 != x2 && (cx < Math.min(x1, x2) || cx > Math.max(x1, x2))) {
-                // no crossing
-                continue;
-            if(y1 < y2 && (py >= y1 && py < y2) || // upward
-               y1 > y2 && (py < y1 && py >= y2)) { // downward
-                ++crosses;
-        var contained = (crosses == -1) ?
-            // on edge
-            1 :
-            // even (out) or odd (in)
-            !!(crosses & 1);
-        return contained;
-     * APIMethod: intersects
-     * Determine if the input geometry intersects this one.
-     * Parameters:
-     * geometry - {<OpenLayers.Geometry>} Any type of geometry.
-     * Returns:
-     * {Boolean} The input geometry intersects this one.
-    intersects: function(geometry) {
-        var intersect = false;
-        if(geometry.CLASS_NAME == "OpenLayers.Geometry.Point") {
-            intersect = this.containsPoint(geometry);
-        } else if(geometry.CLASS_NAME == "OpenLayers.Geometry.LineString") {
-            intersect = geometry.intersects(this);
-        } else if(geometry.CLASS_NAME == "OpenLayers.Geometry.LinearRing") {
-            intersect = OpenLayers.Geometry.LineString.prototype.intersects.apply(
-                this, [geometry]
-        } else {
-            // check for component intersections
-            for(var i=0; i<geometry.components.length; ++ i) {
-                intersect = geometry.components[i].intersects(this);
-                if(intersect) {
-                    break;
-        return intersect;
-    CLASS_NAME: "OpenLayers.Geometry.LinearRing"
-    OpenLayers/Handler/Path.js
- * @requires OpenLayers/Handler/Point.js
- * Class: OpenLayers.Handler.Path
- * Handler to draw a path on the map.  Path is displayed on mouse down,
- * moves on mouse move, and is finished on mouse up.
- * Inherits from:
- *  - <OpenLayers.Handler.Point>
-OpenLayers.Handler.Path = OpenLayers.Class(OpenLayers.Handler.Point, {
-     * Property: line
-    line: null,
-     * Property: freehand
-     * {Boolean} In freehand mode, the handler starts the path on mouse down,
-     * adds a point for every mouse move, and finishes the path on mouse up.
-     * Outside of freehand mode, a point is added to the path on every mouse
-     * click and double-click finishes the path.
-    freehand: false,
-     * Property: freehandToggle
-     * {String} If set, freehandToggle is checked on mouse events and will set
-     * the freehand mode to the opposite of this.freehand.  To disallow
-     * toggling between freehand and non-freehand mode, set freehandToggle to
-     * null.  Acceptable toggle values are 'shiftKey', 'ctrlKey', and 'altKey'.
-    freehandToggle: 'shiftKey',
-     * Constructor: OpenLayers.Handler.Path
-     * Create a new path hander
-     * Parameters:
-     * control - {<OpenLayers.Control>}
-     * callbacks - {Object} An object with a 'done' property whos value is a
-     *     function to be called when the path drawing is finished. The
-     *     callback should expect to recieve a single argument, the line
-     *     string geometry. If the callbacks object contains a 'point'
-     *     property, this function will be sent each point as they are added.
-     *     If the callbacks object contains a 'cancel' property, this function
-     *     will be called when the handler is deactivated while drawing. The
-     *     cancel should expect to receive a geometry.
-     * options - {Object} An optional object with properties to be set on the
-     *           handler
-    initialize: function(control, callbacks, options) {
-        OpenLayers.Handler.Point.prototype.initialize.apply(this, arguments);
-     * Add temporary geometries
-    createFeature: function() {
-        this.line = new OpenLayers.Feature.Vector(
-                                        new OpenLayers.Geometry.LineString());
-        this.point = new OpenLayers.Feature.Vector(
-                                        new OpenLayers.Geometry.Point());
-     * Method: destroyFeature
-     * Destroy temporary geometries
-    destroyFeature: function() {
-        OpenLayers.Handler.Point.prototype.destroyFeature.apply(this);
-        if(this.line) {
-            this.line.destroy();
-        this.line = null;
-     * Method: addPoint
-     * Add point to geometry.  Send the point index to override
-     * the behavior of LinearRing that disregards adding duplicate points.
-    addPoint: function() {
-        this.line.geometry.addComponent(this.point.geometry.clone(),
-                                        this.line.geometry.components.length);
-        this.callback("point", [this.point.geometry]);
-     * Method: freehandMode
-     * Determine whether to behave in freehand mode or not.
-     * Returns:
-     * {Boolean}
-    freehandMode: function(evt) {
-        return (this.freehandToggle && evt[this.freehandToggle]) ?
-                    !this.freehand : this.freehand;
-     * Method: modifyFeature
-     * Modify the existing geometry given the new point
-    modifyFeature: function() {
-        var index = this.line.geometry.components.length - 1;
-        this.line.geometry.components[index].x = this.point.geometry.x;
-        this.line.geometry.components[index].y = this.point.geometry.y;
-        this.line.geometry.components[index].clearBounds();
-     * Method: drawFeature
-     * Render geometries on the temporary layer.
-    drawFeature: function() {
-        this.layer.drawFeature(this.line, this.style);
-        this.layer.drawFeature(this.point, this.style);
-     * Method: geometryClone
-     * Return a clone of the relevant geometry.
-     * Returns:
-     * {<OpenLayers.Geometry.LineString>}
-    geometryClone: function() {
-        return this.line.geometry.clone();
-     * Method: mousedown
-     * Handle mouse down.  Add a new point to the geometry and
-     * render it. Return determines whether to propagate the event on the map.
-     * Parameters:
-     * evt - {Event} The browser event
-     * Returns:
-     * {Boolean} Allow event propagation
-    mousedown: function(evt) {
-        // ignore double-clicks
-        if (this.lastDown && this.lastDown.equals(evt.xy)) {
-            return false;
-        if(this.lastDown == null) {
-            this.createFeature();
-        this.mouseDown = true;
-        this.lastDown = evt.xy;
-        var lonlat = this.control.map.getLonLatFromPixel(evt.xy);
-        this.point.geometry.x = lonlat.lon;
-        this.point.geometry.y = lonlat.lat;
-        if((this.lastUp == null) || !this.lastUp.equals(evt.xy)) {
-            this.addPoint();
-        this.drawFeature();
-        this.drawing = true;
-        return false;
-     * Method: mousemove
-     * Handle mouse move.  Adjust the geometry and redraw.
-     * Return determines whether to propagate the event on the map.
-     * Parameters:
-     * Returns:
-    mousemove: function (evt) {
-        if(this.drawing) {
-            var lonlat = this.map.getLonLatFromPixel(evt.xy);
-            if(this.mouseDown && this.freehandMode(evt)) {
-                this.addPoint();
-            } else {
-                this.modifyFeature();
-        return true;
-     * Method: mouseup
-     * Handle mouse up.  Send the latest point in the geometry to
-     * the control. Return determines whether to propagate the event on the map.
-     * Parameters:
-     * Returns:
-    mouseup: function (evt) {
-        this.mouseDown = false;
-            if(this.freehandMode(evt)) {
-                this.finalize();
-            } else {
-                if(this.lastUp == null) {
-                   this.addPoint();
-                this.lastUp = evt.xy;
-            return false;
-        return true;
-     * Method: dblclick
-     * Handle double-clicks.  Finish the geometry and send it back
-     * to the control.
-     * Parameters:
-     * Returns:
-    dblclick: function(evt) {
-        if(!this.freehandMode(evt)) {
-            this.line.geometry.removeComponent(this.line.geometry.components[index]);
-            this.finalize();
-        return false;
-    CLASS_NAME: "OpenLayers.Handler.Path"
-    OpenLayers/Format/WFS.js
- * @requires OpenLayers/Format/GML.js
- * Class: OpenLayers.Format.WFS
- * Read/Write WFS.
-OpenLayers.Format.WFS = OpenLayers.Class(OpenLayers.Format.GML, {
-     * Property: layer
-    layer: null,
-     * APIProperty: wfsns
-    wfsns: "http://www.opengis.net/wfs",
-     * Property: ogcns
-    ogcns: "http://www.opengis.net/ogc",
-     * Constructor: OpenLayers.Format.WFS
-     * Create a WFS-T formatter. This requires a layer: that layer should
-     * have two properties: geometry_column and typename. The parser
-     * for this format is subclassed entirely from GML: There is a writer
-     * only, which uses most of the code from the GML layer, and wraps
-     * it in transactional elements.
-     * Parameters:
-     * layer - {<OpenLayers.Layer>}
-    initialize: function(options, layer) {
-        OpenLayers.Format.GML.prototype.initialize.apply(this, [options]);
-        this.layer = layer;
-        if (this.layer.featureNS) {
-            this.featureNS = this.layer.featureNS;
-        if (this.layer.options.geometry_column) {
-            this.geometryName = this.layer.options.geometry_column;
-        if (this.layer.options.typename) {
-            this.featureName = this.layer.options.typename;
-     * Method: write
-     * Takes a feature list, and generates a WFS-T Transaction
-     * Parameters:
-    write: function(features) {
-        var transaction = this.createElementNS(this.wfsns, 'wfs:Transaction');
-        transaction.setAttribute("version","1.0.0");
-        transaction.setAttribute("service","WFS");
-        for (var i=0; i < features.length; i++) {
-            switch (features[i].state) {
-                case OpenLayers.State.INSERT:
-                    transaction.appendChild(this.insert(features[i]));
-                    break;
-                    transaction.appendChild(this.update(features[i]));
-                    break;
-                    transaction.appendChild(this.remove(features[i]));
-                    break;
-        return OpenLayers.Format.XML.prototype.write.apply(this,[transaction]);
-     * Method: createFeatureXML
-     * Parameters:
-    createFeatureXML: function(feature) {
-        var geomContainer = this.createElementNS(this.featureNS, "feature:" + this.geometryName);
-        geomContainer.appendChild(geometryNode);
-        var featureContainer = this.createElementNS(this.featureNS, "feature:" + this.featureName);
-        featureContainer.appendChild(geomContainer);
-        for(var attr in feature.attributes) {
-            var attrText = this.createTextNode(feature.attributes[attr]);
-            var attrContainer = this.createElementNS(this.featureNS, "feature:" + nodename);
-            attrContainer.appendChild(attrText);
-            featureContainer.appendChild(attrContainer);
-        return featureContainer;
-     * Method: insert
-     * Takes a feature, and generates a WFS-T Transaction "Insert"
-     * Parameters:
-    insert: function(feature) {
-        var insertNode = this.createElementNS(this.wfsns, 'wfs:Insert');
-        insertNode.appendChild(this.createFeatureXML(feature));
-        return insertNode;
-     * Method: update
-     * Takes a feature, and generates a WFS-T Transaction "Update"
-     * Parameters:
-    update: function(feature) {
-        if (!feature.fid) { alert(OpenLayers.i18n("noFID")); }
-        var updateNode = this.createElementNS(this.wfsns, 'wfs:Update');
-        updateNode.setAttribute("typeName", this.layerName);
-        var propertyNode = this.createElementNS(this.wfsns, 'wfs:Property');
-        var nameNode = this.createElementNS(this.wfsns, 'wfs:Name');
-        var txtNode = this.createTextNode(this.geometryName);
-        nameNode.appendChild(txtNode);
-        propertyNode.appendChild(nameNode);
-        var valueNode = this.createElementNS(this.wfsns, 'wfs:Value');
-        if(feature.layer){
-            geometryNode.setAttribute(
-                "srsName", feature.layer.projection.getCode()
-        valueNode.appendChild(geometryNode);
-        propertyNode.appendChild(valueNode);
-        updateNode.appendChild(propertyNode);
-         // add in attributes
-        for(var propName in feature.attributes) {
-            propertyNode = this.createElementNS(this.wfsns, 'wfs:Property');
-            nameNode = this.createElementNS(this.wfsns, 'wfs:Name');
-            nameNode.appendChild(this.createTextNode(propName));
-            valueNode = this.createElementNS(this.wfsns, 'wfs:Value');
-            valueNode.appendChild(this.createTextNode(feature.attributes[propName]));
-        var filterNode = this.createElementNS(this.ogcns, 'ogc:Filter');
-        var filterIdNode = this.createElementNS(this.ogcns, 'ogc:FeatureId');
-        filterIdNode.setAttribute("fid", feature.fid);
-        filterNode.appendChild(filterIdNode);
-        updateNode.appendChild(filterNode);
-        return updateNode;
-     * Method: remove
-     * Takes a feature, and generates a WFS-T Transaction "Delete"
-     * Parameters:
-    remove: function(feature) {
-            alert(OpenLayers.i18n("noFID"));
-            return false;
-        var deleteNode = this.createElementNS(this.wfsns, 'wfs:Delete');
-        deleteNode.setAttribute("typeName", this.layerName);
-        deleteNode.appendChild(filterNode);
-        return deleteNode;
-     * APIMethod: destroy
-     * Remove ciruclar ref to layer
-    destroy: function() {
-        this.layer = null;
-    CLASS_NAME: "OpenLayers.Format.WFS"
-    OpenLayers/Handler/Polygon.js
- * @requires OpenLayers/Handler/Path.js
- * Class: OpenLayers.Handler.Polygon
- * Handler to draw a polygon on the map.  Polygon is displayed on mouse down,
- * Inherits from:
- *  - <OpenLayers.Handler.Path>
- *  - <OpenLayers.Handler>
-OpenLayers.Handler.Polygon = OpenLayers.Class(OpenLayers.Handler.Path, {
-     * Parameter: polygon
-    polygon: null,
-     * Constructor: OpenLayers.Handler.Polygon
-     * Create a Polygon Handler.
-     * Parameters:
-     *                          a function to be called when the path drawing is
-     *                          finished. The callback should expect to recieve a
-     *                          single argument, the polygon geometry.
-     *                          If the callbacks object contains a 'point'
-     *                          as they are added.  If the callbacks object contains
-     *                          a 'cancel' property, this function will be called when
-     *                          the handler is deactivated while drawing.  The cancel
-     *                          should expect to receive a geometry.
-        OpenLayers.Handler.Path.prototype.initialize.apply(this, arguments);
-        this.polygon = new OpenLayers.Feature.Vector(
-                                        new OpenLayers.Geometry.Polygon());
-                                        new OpenLayers.Geometry.LinearRing());
-        this.polygon.geometry.addComponent(this.line.geometry);
-        OpenLayers.Handler.Path.prototype.destroyFeature.apply(this);
-        if(this.polygon) {
-            this.polygon.destroy();
-        this.polygon = null;
-        var index = this.line.geometry.components.length - 2;
-        this.layer.drawFeature(this.polygon, this.style);
-     * Returns:
-     * {<OpenLayers.Geometry.Polygon>}
-        return this.polygon.geometry.clone();
-     * to the control.
-     * Parameters:
-     * evt - {Event}
-            // remove the penultimate point
-            this.finalize();
-        return false;
-    CLASS_NAME: "OpenLayers.Handler.Polygon"
-    OpenLayers/Control/EditingToolbar.js
- * @requires OpenLayers/Control/Panel.js
- * @requires OpenLayers/Control/Navigation.js
- * @requires OpenLayers/Control/DrawFeature.js
- * @requires OpenLayers/Handler/Polygon.js
- * Class: OpenLayers.Control.EditingToolbar
-OpenLayers.Control.EditingToolbar = OpenLayers.Class(
-  OpenLayers.Control.Panel, {
-     * Constructor: OpenLayers.Control.EditingToolbar
-     * Create an editing toolbar for a given layer.
-     * Parameters:
-     * layer - {<OpenLayers.Layer.Vector>}
-    initialize: function(layer, options) {
-        OpenLayers.Control.Panel.prototype.initialize.apply(this, [options]);
-        this.addControls(
-          [ new OpenLayers.Control.Navigation() ]
-        var controls = [
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Point, {'displayClass': 'olControlDrawFeaturePoint'}),
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Path, {'displayClass': 'olControlDrawFeaturePath'}),
-          new OpenLayers.Control.DrawFeature(layer, OpenLayers.Handler.Polygon, {'displayClass': 'olControlDrawFeaturePolygon'})
-        for (var i = 0; i < controls.length; i++) {
-            controls[i].featureAdded = function(feature) { feature.state = OpenLayers.State.INSERT; };
-        this.addControls(controls);
-     * Method: draw
-     * calls the default draw, and then activates mouse defaults.
-     * Returns:
-     * {DOMElement}
-    draw: function() {
-        var div = OpenLayers.Control.Panel.prototype.draw.apply(this, arguments);
-        this.activateControl(this.controls[0]);
-        return div;
-    CLASS_NAME: "OpenLayers.Control.EditingToolbar"
Copied: sandbox/olcore/lib/SingleFile.js (from rev 1438, trunk/lib/SingleFile.js)
--- sandbox/olcore/lib/SingleFile.js	                        (rev 0)
+++ sandbox/olcore/lib/SingleFile.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -0,0 +1,9 @@
+/* Copyright (c) 2006-2008 MetaCarta, Inc., published under the Clear BSD
+ * license.  See http://svn.openlayers.org/trunk/openlayers/license.txt for the
+ * full text of the license. */
+var Fusion = {
+    singleFile: true
Modified: sandbox/olcore/lib/fusion.js
--- sandbox/olcore/lib/fusion.js	2008-07-17 17:36:05 UTC (rev 1441)
+++ sandbox/olcore/lib/fusion.js	2008-07-22 15:00:30 UTC (rev 1442)
@@ -29,103 +29,50 @@
 var Jx = {};
- * declare global namespace object for Fusion library to use
-var Fusion = {};
-/* set to true if you want to use the compressed version of the core files,
- * currently this saves about 100kb and quite a few HTTP connections so it is
- * faster, but less convenient if you want to debug one of the core files
-Fusion.useCompressed = false;
-if (Fusion.useCompressed) {
-    Fusion.coreScripts = ['lib/OpenLayers/OpenLayers.js',
-                        'jx/lib/jx_compressed.js',
-                        'lib/fusion-compressed.js',
-                        'lib/excanvas/excanvas-compressed.js'];
-} else {
-                        'jx/lib/jx_combined.js',
-                        'lib/excanvas/excanvas-compressed.js',
-                        'lib/Error.js',
-                        'lib/ApplicationDefinition.js',
-                        'lib/MGBroker.js',
-                        'lib/Widget.js',
-                        'lib/ButtonBase.js',
-                        'lib/MenuBase.js',
-                        'lib/ButtonTool.js',
-                        'lib/CanvasTool.js',
-                        'lib/ClickTool.js',
-                        'lib/RectTool.js',
-                        'lib/Map.js',
-                        'layers/Layers.js',
-                        'lib/Search.js',
-                        'text/en/strings.json'];
-/* bootstrap function that gets everything Fusion needs, loaded */
-Fusion.bootstrap = function() {
-    //determine the language to use and add resource bundles to be loaded to the core scripts
-    var locale = navigator.language ?
-                  navigator.language.substring(0,2):    //e.g. en-CA becomes just en
-                  navigator.userLanguage.substring(0,2);//only use the prefix part for now,
-    var s=window.location.search.toLowerCase();
-    var idx = s.indexOf('locale=');
-    if (idx>0) {
-      locale = s.substring(idx+7,idx+9);
-    if ( locale!='en' ) {
-      Fusion.coreScripts.push('lib/OpenLayers/Lang/'+locale+'.js');
-      Fusion.coreScripts.push('text/'+locale+'/strings.json');
-    window._FusionLocale = locale;
-    var aScripts = document.getElementsByTagName('SCRIPT');
-    var gszFusionURL = '';
-    for (var i=0; i<aScripts.length; i++) {
-        var s = aScripts[i].src;
-        var n = s.indexOf('lib/fusion.js');
-        if (n != -1) {
-            gszFusionURL = s.substring(0,n);
-            FusionScriptObject = aScripts[i];
-            /* import the compressed version of jx and its CSS */
-            Jx.baseURL = gszFusionURL + 'jx/';
-            Jx.COMBINED_CSS = true;
-            for (var j=0; j<Fusion.coreScripts.length; j++) {
-                document.write('<script type="text/javascript" src="'+gszFusionURL+Fusion.coreScripts[j]+'"></script>');
-            break;
-Fusion.bootstrap();
  * reverse inheritance logic to allow for delayed loading of dependencies.
  * Under normal circumstances, Object.extend from Prototype would be used,
  * but in Fusion, widget code is loaded before base class code and the
  * extend function won't work until all the base class code is available.
+ * DEPRECATED
 Object.inheritFrom = function(destination, source, args) {
-    for (property in source) {
+    var parent;
+    if(typeof source == "function") {
+        // get the prototype of the superclass
+        parent = source.prototype;
+    } else {
+        // in this case we're extending with the prototype
+        parent = source;
+    for (property in parent) {
         if (typeof destination[property] == 'undefined') {
-            destination[property] = source[property];
+            destination[property] = parent[property];
-    source.initialize.apply(destination, args);
+    parent.initialize.apply(destination, args);
-/* now we can safely replace the global fusion object */
-* Class: Fusion
-* The main global object for Fusion applications.
+(function() {
+     * Before creating the OpenLayers namespace, check to see if
+     * OpenLayers.singleFile is true.  This occurs if the
+     * OpenLayers/SingleFile.js script is included before this one - as is the
+     * case with single file builds.
+    var singleFile = (typeof Fusion == "object" && Fusion.singleFile);
+    /* set to true if you want to use the compressed version of the core files,
+     * currently this sav
