[fusion-commits] r1232 - in trunk: MapGuide lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Mar 10 13:07:46 EDT 2008
Author: pagameba
Date: 2008-03-10 13:07:46 -0400 (Mon, 10 Mar 2008)
New Revision: 1232
   trunk/MapGuide/MapGuide.js
   trunk/lib/ApplicationDefinition.js
Re #20.  Adding support for processing both layer and group events that can target either layers or groups.
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js	2008-03-10 16:55:37 UTC (rev 1231)
+++ trunk/MapGuide/MapGuide.js	2008-03-10 17:07:46 UTC (rev 1232)
@@ -799,56 +799,103 @@
         Fusion.ajaxRequest(loadmapScript, options);
-    showLayer: function( layer ) {
-        if (this.mapInfo && this.mapInfo.layerEvents[layer.layerName]) {
-            var layerEvent = this.mapInfo.layerEvents[layer.layerName];
-            for (var i=0; i<layerEvent.onEnable.length; i++) {
-                var l = this.layerRoot.findLayer(layerEvent.onEnable[i].name);
-                if (l) {
-                    if (layerEvent.onEnable[i].enable) {
-                        l.show();
-                    } else {
-                        l.hide();
+    processLayerEvents: function(layer, isEnabling) {
+        if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
+            var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
+            var events = isEnabling ? layerEvent.onEnable : layerEvent.onDisable;
+            for (var i=0; i<events.length; i++) {
+                var o = events[i];
+                if (o.type == 'layer') {
+                    var l = this.layerRoot.findLayer(o.name);
+                    if (l) {
+                        if (events[i].enable) {
+                            l.show(true);
+                        } else {
+                            l.hide(true);
+                } else if (o.type == 'group') {
+                    var g = this.layerRoot.findGroupByAtribute('groupName', o.name);
+                    if (g) {
+                        if (events.enable) {
+                            g.show(true);
+                        } else {
+                            g.hide(true);
-        this.aShowLayers.push(layer.uniqueId);
-        this.drawMap();
-    hideLayer: function( layer ) {
-            for (var i=0; i<layerEvent.onDisable.length; i++) {
-                var l = this.layerRoot.findLayer(layerEvent.onDisable[i].name);
-                if (l) {
-                    if (layerEvent.onDisable[i].enable) {
-                        l.show();
-                    } else {
-                        l.hide();
+    processGroupEvents: function(group, isEnabling) {
+        if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
+            var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
+            var events = isEnabling ? groupEvent.onEnable : groupEvent.onDisable;
+                    if (l) {
+                            l.show(true);
+                        } else {
+                            l.hide(true);
+                    if (g) {
+                            g.show(true);
+                        } else {
+                            g.hide(true);
+    showLayer: function( layer, noDraw ) {
+        this.processLayerEvents(layer, true);
+        this.aShowLayers.push(layer.uniqueId);
+        if (!noDraw) {
+            this.drawMap();
+    hideLayer: function( layer, noDraw ) {
+        this.processLayerEvents(layer, false);
         this.aHideLayers.push(layer.uniqueId);
-        this.drawMap();
+        if (!noDraw) {
+            this.drawMap();
-    showGroup: function( group ) {
-      if (group.groupName == 'layerRoot') {
-        this.oLayerOL.setVisibility(true);
-      } else {
-        this.aShowGroups.push(group.uniqueId);
-        this.drawMap();
+    showGroup: function( group, noDraw ) {
+        this.processGroupEvents(group, true);
+        if (group.groupName == 'layerRoot') {
+            this.oLayerOL.setVisibility(true);
+        } else {
+            this.aShowGroups.push(group.uniqueId);
+            if (!noDraw) {
+                this.drawMap();
-    hideGroup: function( group ) {
-        this.oLayerOL.setVisibility(false);
-      } else {
-        this.aHideGroups.push(group.uniqueId);
-        this.drawMap();
+    hideGroup: function( group, noDraw ) {
+        this.processGroupEvents(group, false);
+            this.oLayerOL.setVisibility(false);
+        } else {
+            this.aHideGroups.push(group.uniqueId);
+            if (!noDraw) {
+                this.drawMap();
     refreshLayer: function( layer ) {
         this.aRefreshLayers.push(layer.uniqueId);
@@ -921,22 +968,22 @@
         this.actuallyVisible = o.actuallyVisible;
-    show: function() {
+    show: function(noDraw) {
         if (this.visible) {
             return;
-        this.oMap.showGroup(this);
+        this.oMap.showGroup(this, noDraw ? true : false);
         this.visible = true;
         if (this.legend && this.legend.checkBox) {
             this.legend.checkBox.checked = true;
-    hide: function() {
+    hide: function(nodraw) {
         if (!this.visible) {
             return;
-        this.oMap.hideGroup(this);
+        this.oMap.hideGroup(this, noDraw ? true : false);
         this.visible = false;
             this.legend.checkBox.checked = false;
@@ -1016,22 +1063,22 @@
         return null;
         if (this.visible) {
             return;
-        this.oMap.showLayer(this);
+        this.oMap.showLayer(this, noDraw ? true : false);
         this.set('visible', true);
+    hide: function(noDraw) {
             return;
-        this.oMap.hideLayer(this);
+        this.oMap.hideLayer(this, noDraw ? true : false);
         this.set('visible',false);
Modified: trunk/lib/ApplicationDefinition.js
--- trunk/lib/ApplicationDefinition.js	2008-03-10 16:55:37 UTC (rev 1231)
+++ trunk/lib/ApplicationDefinition.js	2008-03-10 17:07:46 UTC (rev 1232)
@@ -419,7 +419,7 @@
             for (var i=0; i<jsonNode.Map.length; i++) {
                 var map = new Fusion.Lib.ApplicationDefinition.Map(jsonNode.Map[i]);
                 var links = {groups:[], layers:[]};
-                var layerEvents = {};
+                var mapevents = {layerEvents:{},groupEvents:{}};
                 if (jsonNode.Map[i].Extension) {
                     var extension = jsonNode.Map[i].Extension[0];
                     if (extension.Links) {
@@ -439,33 +439,42 @@
                     /* process layer events */
                     //TODO: Should this be called MapEvents?
-                    if (extension.LayerEvents) {
-                        if (extension.LayerEvents[0].Layer instanceof Array) {
-                            for (var j=0; j<extension.LayerEvents[0].Layer.length; j++) {
-                                var layer = extension.LayerEvents[0].Layer[j];
+                    if (extension.MapEvents) {
+                        if (extension.MapEvents[0].Layer instanceof Array) {
+                            for (var j=0; j<extension.MapEvents[0].Layer.length; j++) {
+                                var layer = extension.MapEvents[0].Layer[j];
                                 var layerObj = {};
                                 layerObj.name = layer.Name[0];
                                 layerObj.onEnable = [];
+                                if (layer.OnEnable instanceof Array) {
+                                    layerObj.onEnable = this.parseMapEventSubBlock(layer.onEnable[0]);
                                 layerObj.onDisable = [];
+                                if (layer.OnDisable instanceof Array) {
+                                    layerObj.onDisable = this.parseMapEventSubBlock(layer.onDisable[0]);
+                                mapEvents.layerEvents[layerObj.name] = layerObj;
+                        if (extension.MapEvents[0].Group instanceof Array) {
+                            for (var j=0; j<extension.MapEvents[0].Group.length; j++) {
+                                var group = extension.MapEvents[0].Group[j];
+                                var groupObj = {};
+                                groupObj.name = group.Name[0];
+                                groupObj.onEnable = [];
-                                    for (var k=0; k<layer.OnEnable[0].Layer.length; k++) {
-                                        var kLayer = layer.OnEnable[0].Layer[k];
-                                        layerObj.onEnable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                                    groupObj.onEnable = this.parseMapEventSubBlock(group.onEnable[0]);
+                                groupObj.onDisable = [];
-                                    for (var k=0; k<layer.OnDisable[0].Layer.length; k++) {
-                                        var kLayer = layer.OnDisable[0].Layer[k];
-                                        layerObj.onDisable.push({name:kLayer.Name[0], enable: kLayer.Enable[0] == 'true' ? true : false});
+                                    groupObj.onDisable = this.parseMapEventSubBlock(group.onDisable[0]);
-                                layerEvents[layerObj.name] = layerObj;
+                                mapEvents.groupEvents[groupObj.name] = groupObj;
-                map.mapInfo = {links: links, layerEvents: layerEvents};
+                map.mapInfo = {links: links, mapEvents: mapEvents};
                 this.maps.push(map);
         } else {
@@ -473,6 +482,23 @@
+    parseMapEventSubBlock: function(block) {
+        var a = [];
+        if (block.Layer) {
+            for (var i=0; i<block.Layer.length; i++) {
+                var layer = block.Layer[i];
+                a.push({type: 'layer', name:layer.Name[0], enable: layer.Enable[0] == 'true' ? true : false});
+        if (block.Group && block.Group instanceof Array) {
+            for (var i=0; i<block.Group.length; i++) {
+                var layer = block.Group[i];
+                a.push({type: 'group', name:group.Name[0], enable: group.Enable[0] == 'true' ? true : false});
+        return a;
     getInitialView: function() {
         return this.initialView;
More information about the fusion-commits mailing list
