[fusion-commits] r1242 - trunk/templates/mapguide/standard
svn_fusion at osgeo.org
Thu Mar 13 10:50:05 EDT 2008
Author: pagameba
Date: 2008-03-13 10:50:05 -0400 (Thu, 13 Mar 2008)
New Revision: 1242
Removed:
trunk/templates/mapguide/standard/redirect.php
We cannot include redirect.php at this time.
Deleted: trunk/templates/mapguide/standard/redirect.php
--- trunk/templates/mapguide/standard/redirect.php 2008-03-13 14:45:31 UTC (rev 1241)
+++ trunk/templates/mapguide/standard/redirect.php 2008-03-13 14:50:05 UTC (rev 1242)
@@ -1,315 +0,0 @@
-<?php
- * @project Fusion
- * @revision $Id: redirect.php 704 2007-07-19 22:25:56Z madair $
- * @fileoverview this file redirects requests from the client to another
- * server
- * @author Paul Spencer (pspencer at dmsolutions.ca)
- * @copyright © 2006 DM Solutions Group Inc.
- * Copyright (c) 2006, DM Solutions Group Inc.
- * Permission is hereby granted, free of charge, to any person obtaining a
- * copy of this software and associated documentation files (the "Software"),
- * to deal in the Software without restriction, including without limitation
- * the rights to use, copy, modify, merge, publish, distribute, sublicense,
- * and/or sell copies of the Software, and to permit persons to whom the
- * Software is furnished to do so, subject to the following conditions:
- * The above copyright notice and this permission notice shall be included
- * in all copies or substantial portions of the Software.
- * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
- * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
- * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL
- * THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
- * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
- * FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER
- * DEALINGS IN THE SOFTWARE.
-/* uncomment and set as appropriate. If you leave it out, the default
- will be the Anonymous user */
-$username = 'Author';
-$password = 'Dent';
-/* very simple wrapper for redirecting requests */
-$server = parse_url($_REQUEST['s']);
-$scheme = $server['scheme'];
-if ($scheme == '') {
- $aResults = array('header'=>array(), 'body'=>file($_REQUEST['s']));
-} else {
- $host = str_replace('localhost','127.0.0.1',$server['host']);
- $method = isset($_REQUEST['method']) ? $_REQUEST['method'] : 'POST';//$_SERVER['REQUEST_METHOD']; //'POST';
- $port = isset($server['port'])?$server['port']:80;
- $path = $server['path'];
- $url = '';
- if ($scheme == 'https') {
- $url .= 'ssl://';
- $url .= $host;
- $data = array();
- $query = '';
- $sep = '';
- foreach ($_REQUEST as $key => $value) {
- if ($key != 's') {
- $query .= $sep . $key .'=' .urlencode($value);
- $sep = '&';
- $data[$key] = rawurldecode($value);
- if (isset($username) && isset($password)) {
- $data['username'] = $username;
- $data['password'] = $password;
- $aResults = parseContent(sendToHost($url, $port, $method, $path, $data));
-if (isset($_REQUEST['content-type']) &&
- $_REQUEST['content-type'] == 'json') {
- header('Content-type: text/plain');
- header('X-JSON: true');
- $xml = implode('',$aResults['body']);
- $document = DOMDocument::loadXML($xml);
- $root = $document->documentElement;
- $result = "{";
- $result .= '"'.$root->tagName.'":';
- $result .= xml2json($root);
- $result .= '}';
- echo $result;
-} else {
- //TODO: not necessarily xml!
- //header('Content-type: text/xml');
- foreach($aResults['header'] as $header) {
- header($header);
- echo implode("\n", $aResults['body']);
- * PS:
- * taken from
- * http://www.faqts.com/knowledge_base/view.phtml/aid/12039/fid/51
- * no apparent license or copyright.
- * modified to add $port
- * sendToHost
- * Params:
- * $host - Just the hostname. No http:// or
- /path/to/file.html portions
- * $method - get or post, case-insensitive
- * $path - The /path/to/file.html part
- * $data - The query string, without initial question mark
- * $useragent - If true, 'MSIE' will be sent as
- the User-Agent (optional)
- * Examples:
- * sendToHost('www.google.com','get','/search','q=php_imlib');
- * sendToHost('www.example.com','post','/some_script.cgi',
- * 'param=First+Param&second=Second+param');
-function sendToHost($host, $port, $method, $path, $data, $useragent=0) {
- // Supply a default method of GET if the one passed was empty
- if (empty($method)) {
- $method = 'GET';
- $method = strtoupper($method);
- $fp = fsockopen($host, $port);
- if (!$fp) {
- echo 'fsockopen failed<BR>';
- return;
- if ($method == 'GET') {
- $path .= '?' . $data;
- $header = '';
- $body = '';
- srand((double)microtime()*1000000);
- $boundary = "---------------------".substr(md5(rand(0,32000)),0,10);
- $header .= "$method $path HTTP/1.0\r\n";
- $header .= "Host: $host\r\n";
- $header .= "Content-type: multipart/form-data, boundary=$boundary\r\n";
- // attach post vars
- foreach($data as $index => $value){
- // if ($index == 'content') {
- // $fplog = fopen('C:\\preview.log', 'w');
- // fwrite($fplog, $value);
- // fclose($fp);
- $body .= "--$boundary\r\n";
- if (substr($value,0,5) == '<?xml') {
- $body .= "Content-Disposition: form-data; name=\"".$index."\"; filename=\"blah.xml\"\r\n";
- $body .= "Content-type: text/xml\r\n";
- } else if ($index == 'filename') {
- $body .= "Content-type: application/octet-stream\r\n";
- $h = fopen( $value, 'rb');
- while (!feof($h)) {
- $body.= fread($h, 4096);
- //$body .= fread($h, filesize($value));
- fclose($h);
- //write other form vars needed for file upload to mapagent
- $body .= "Content-Disposition: form-data; name=\"DATANAME\"; value=\"".$value."\"\r\n";
- $body .= "Content-Disposition: form-data; name=\"DATALENGTH\"; value=\"".filesize($value)."\"\r\n";
- continue;
- } else {
- $body .= "Content-Disposition: form-data; name=\"".$index."\"\r\n";
- //if (get_magic_quotes_gpc()) {
- $value = stripslashes($value);
- $body .= "\r\n".rawurldecode($value)."\r\n";
- $body .= "--$boundary--\r\n";
- $header .= "Content-length: " . strlen($body) . "\r\n";
- $header .= "Connection: close\r\n\r\n";
- fputs($fp, $header.$body);
- $buf = '';
- while (!feof($fp)) {
- $buf .= fgets($fp,4096);
- fclose($fp);
- return $buf;
-function parseContent( $r ) {
- $header = array();
- $body = array();
- $ar = explode("\n", $r);
- foreach($ar as $idx => $line) {
- if (trim($line) == '') {
- $header = array_slice( $ar, 0, $idx);
- $body = array_slice( $ar, $idx+1);
- break;
-// echo $r;
-// print_r($header);
-// print_r($body);
- return array( 'header' => $header, 'body' => $body );
-function xml2json($domElement) {
- $result = '';
- if ($domElement->nodeType == XML_COMMENT_NODE) {
- return '';
- if ($domElement->nodeType == XML_TEXT_NODE) {
- /* text node, just return content */
- $text = trim($domElement->textContent);
- if ($text != '') {
- $result = '"'.$text.'"';
- } else {
- $text = '""';
- } else {
- /* some other kind of node, needs to be processed */
- $aChildren = array();
- $aValues = array();
- /* attributes are considered child nodes with a special key name
- starting with @ */
- if ($domElement->hasAttributes()) {
- foreach($domElement->attributes as $key => $attr) {
- $len = array_push($aValues, array('"'.$attr->value.'"'));
- $aChildren['@'.$key] = $len-1;
- if ($domElement->hasChildNodes()) {
- //has children
- foreach($domElement->childNodes as $child) {
- if ($child->nodeType == XML_COMMENT_NODE) {
- continue;
- if ($child->nodeType == XML_TEXT_NODE) {
- $text = trim($child->textContent);
- if ($text == '') {
- continue;
- array_push($aValues, array('"'.$text.'"'));
- } else {
- $childTag = $child->tagName;
- $json = xml2json($child);
- if ($json == '') {
- continue;
- if (array_key_exists($childTag, $aChildren)) {
- array_push($aValues[$aChildren[$childTag]], $json);
- } else {
- $len = array_push($aValues, array($json));
- $aChildren[$childTag] = $len - 1;
- $nChildren = count($aChildren);
- $nValues = count($aValues);
- if ($nChildren == 0 && $nValues == 0) {
- return '';
- if ($nValues == 1 && $nChildren == 0) {
- $result .= $aValues[0][0];
- } else {
- $bIsObject = true;
- if ($nChildren != $nValues) {
- $bIsObject = false;
- $result .= $bIsObject ? '{' : '[';
- $sep = '';
- $aChildren = array_flip($aChildren);
- for ($i=0; $i<$nValues; $i++) {
- $aValue = $aValues[$i];
- $result .= $sep;
- if (isset($aChildren[$i])) {
- if (!$bIsObject) {
- $result .= '{';
- $result .= '"'.$aChildren[$i].'":';
- //if (count($aValue) > 1) {
- $result .= '[';
- $result .= implode(',', $aValue);
- $result .= ']';
- //} else {
- // $result .= $aValue[0];
- if (isset($aChildren[$i]) && !$bIsObject) {
- $result .= '}';
- $sep = ',';
- $result .= $bIsObject ? '}' : ']';
- return $result;
More information about the fusion-commits
