[fusion-commits] r1344 - trunk
svn_fusion at osgeo.org
Thu Mar 27 11:58:43 EDT 2008
Author: wbronsema
Date: 2008-03-27 11:58:43 -0400 (Thu, 27 Mar 2008)
New Revision: 1344
trunk/config.json
fixes #41. Added the "legendIconCacheDir" to the mapserver section
Modified: trunk/config.json
--- trunk/config.json 2008-03-27 13:38:40 UTC (rev 1343)
+++ trunk/config.json 2008-03-27 15:58:43 UTC (rev 1344)
@@ -1,21 +1,21 @@
/* This is the fusion configuration file. Adjust as necessary. */
- /* The general section contains settings that are general to
+ /* The general section contains settings that are general to
fusion as a whole. */
"general": {
- /* PHP is the default and only script language supported.
+ /* PHP is the default and only script language supported.
Don"t change this. */
"scriptLanguage": "php",
/* A directory on this system that fusion can use for
temporary files. */
"temporaryDirectory": "/tmp"
- /* The MapGuide section is required if you are installing
+ /* The MapGuide section is required if you are installing
fusion for MapGuide. */
"mapguide": {
- /* The WebTierURL is the url to mapguide, it should start
- with http and end with /mapguide. If you have installed
+ /* The WebTierURL is the url to mapguide, it should start
+ with http and end with /mapguide. If you have installed
fusion inside the www directory of MapGuide, then you can
leave this empty as it will be automatically calculated. */
"webTierUrl": ""
@@ -30,5 +30,8 @@
"imagePath": "/tmp/ms_tmp",
/* The URL to the image path configured above. */
"imageUrl": "http://localhost/tmp/ms_tmp"
+ /* The file system path to where mapserver should put
+ web-accessible temporary legend images. */
+ "legendIconCacheDir":"/tmp/ms_tmp"
\ No newline at end of file
More information about the fusion-commits
