[fusion-commits] r1390 - in trunk: . lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Tue May 6 14:55:41 EDT 2008
Author: madair
Date: 2008-05-06 14:55:40 -0400 (Tue, 06 May 2008)
New Revision: 1390
   trunk/build.xml
   trunk/lib/fusion.js
closes #53: makes pre-parsing and including ApplicationDefinition optional.
Modified: trunk/build.xml
--- trunk/build.xml	2008-05-06 17:13:10 UTC (rev 1389)
+++ trunk/build.xml	2008-05-06 18:55:40 UTC (rev 1390)
@@ -79,7 +79,6 @@
   <property name="deploy.home" value="${env.HTDOCS}/${app.name}"/>
   <property name="dist.home" value="${basedir}/dist"/>
   <property name="docs.home" value="${build.home}/docs"/>
-  <property name="appDef" value="${basedir}/templates/mapguide/standard/ApplicationDefinition.xml"/>
 <!-- ==================== External Dependencies =========================== -->
@@ -171,10 +170,9 @@
           excludes="WidgetInfoTemplate.xml widgetInfo.xsl"/>
   </target>
-<!-- =================== single file build ================================== -->
-  <target description="single file build" name="singleFile" depends="prepare">
-    <echo message="preparing single file build for ${appDef}"/>
-    <delete dir="${build.home}/lib/fusionSF.js"/>
+<!-- =================== prepare AppDef for single file build ================================== -->
+  <target description="convert AppDef to JSON" name="appDef2Json" if="appDef">
+    <echo message="converting ${appDef} to JSON"/>
     <delete dir="${build.home}/appDefFileset.xml"/>
     <!-- generate the list of files for this Application and load as a property -->
@@ -187,12 +185,18 @@
     <!-- convert the application definition file to JSON -->
     <exec executable="php" os="Windows Vista, Windows XP"
-              dir="${build.home}\common\php"
               output="${build.home}/appDef.json">
-        <arg line="Xml2JSON.php --file='${appDef}'"/>
+        <arg line="common\php\Xml2JSON.php --file='${appDef}'"/>
     </exec>
-    <!-- now merge everything into a single file -->
+  </target>
+<!-- =================== single file build ================================== -->
+  <target description="single file build" name="singleFile" depends="clean,prepare,appDef2Json">
+    <echo message="preparing single file build for ${appDef}"/>
+    <delete dir="${build.home}/lib/fusionSF.js"/>
+    <!-- merge everything into a single file -->
     <concat destfile="${build.home}/lib/fusionSF.js" outputencoding="UTF-8">
         <filelist dir="${build.home}/lib"
                   files=" SingleFile.js
Modified: trunk/lib/fusion.js
--- trunk/lib/fusion.js	2008-05-06 17:13:10 UTC (rev 1389)
+++ trunk/lib/fusion.js	2008-05-06 18:55:40 UTC (rev 1390)
@@ -238,6 +238,7 @@
             var queryAppDef = this.getQueryParam('ApplicationDefinition');
             if (queryAppDef) {
                 this.applicationDefinitionURL = queryAppDef.split('+').join(' ');
+                this.appDefJson = null;   //wipe out any preloaded AppDef in a single file build
             } else {
                 this.applicationDefinitionURL = 'ApplicationDefinition.xml';
@@ -772,6 +773,14 @@
+    getSearchCategories: function() {
+        if (this.applicationDefinition) {
+            return this.applicationDefinition.searchCategories;
+        } else {
+            return {};
     getApplicationDefinitionURL: function() { return this.applicationDefinitionURL; },
@@ -805,7 +814,7 @@
     require: function(url) { this.queueScript(url); },
-    reportError: function(o) { this.triggerEvent(Fusion.Event.FUSION_ERROR, o); },
+    reportError: function(o) { console.log(o.message); this.triggerEvent(Fusion.Event.FUSION_ERROR, o); },
     unitFromName: function(unit) {
         switch(unit.toLowerCase()) {
More information about the fusion-commits mailing list
