[fusion-commits] r1392 - in trunk: MapGuide MapGuide/php lib
widgets/Print
svn_fusion at osgeo.org
Tue May 6 15:21:00 EDT 2008
Author: madair
Date: 2008-05-06 15:21:00 -0400 (Tue, 06 May 2008)
New Revision: 1392
trunk/MapGuide/MapGuide.js
trunk/MapGuide/php/Common.php
trunk/lib/MGBroker.js
trunk/widgets/Print/printablepage.templ
closes #55: patch applied to trunk
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js 2008-05-06 19:15:55 UTC (rev 1391)
+++ trunk/MapGuide/MapGuide.js 2008-05-06 19:21:00 UTC (rev 1392)
@@ -50,6 +50,8 @@
//the resource id of the current MapDefinition
_sResourceId: null,
+ clientAgent: 'Fusion Viewer',
initialize : function(map, mapTag, isMapWidgetLayer) {
// console.log('MapGuide.initialize');
@@ -490,7 +492,8 @@
if ( bSingleTile ) {
params = { //single tile params
session : this.getSessionID(),
- mapName : this._sMapname
+ mapname : this._sMapname,
+ clientagent : this.clientAgent
params.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
params.hideLayers = this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null;
@@ -504,7 +507,8 @@
} else {
params = { //tiled version
mapdefinition: this._sResourceId,
- basemaplayergroupname: this.groupName //assumes only one group for now
+ basemaplayergroupname: this.groupName, //assumes only one group for now
@@ -1180,6 +1184,7 @@
Fusion.Maps.MapGuide.StyleItem = OpenLayers.Class({
initialize: function(o, staticIcon) {
this.legendLabel = o.legendLabel;
this.filter = o.filter;
@@ -1195,6 +1200,6 @@
getLegendImageURL: function(fScale, layer) {
var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
- return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType;
+ return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType + "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
Modified: trunk/MapGuide/php/Common.php
--- trunk/MapGuide/php/Common.php 2008-05-06 19:15:55 UTC (rev 1391)
+++ trunk/MapGuide/php/Common.php 2008-05-06 19:21:00 UTC (rev 1392)
@@ -74,6 +74,8 @@
$username = isset($_REQUEST['username']) ? $_REQUEST['username'] : 'Anonymous';
$password = isset($_REQUEST['password']) ? $_REQUEST['password'] : '';
$user = new MgUserInformation($username, $password);
+ $user->SetClientIp(GetClientIp());
+ $user->SetClientAgent(GetClientAgent());
$siteConnection = new MgSiteConnection();
$siteConnection->Open($user);
} else {
@@ -90,9 +92,13 @@
/* current user is re-authenticating or not? */
if (isset($_REQUEST['username']) && isset($_REQUEST['password'])) {
$user = new MgUserInformation($_REQUEST['username'], $_REQUEST['password']);
$user->SetMgSessionId($sessionID);
} else {
$user = new MgUserInformation($sessionID);
/* open a connection to the site. This will generate exceptions if the user
@@ -255,5 +261,29 @@
return $numberString;
+function GetClientIp()
+ $clientIp = '';
+ if (array_key_exists('HTTP_CLIENT_IP', $_SERVER)
+ && strcasecmp($_SERVER['HTTP_CLIENT_IP'], 'unknown') != 0)
+ $clientIp = $_SERVER['HTTP_CLIENT_IP'];
+ else if (array_key_exists('HTTP_X_FORWARDED_FOR', $_SERVER)
+ && strcasecmp($_SERVER['HTTP_X_FORWARDED_FOR'], 'unknown') != 0)
+ $clientIp = $_SERVER['HTTP_X_FORWARDED_FOR'];
+ else if (array_key_exists('REMOTE_ADDR', $_SERVER))
+ $clientIp = $_SERVER['REMOTE_ADDR'];
+ return $clientIp;
+function GetClientAgent()
+ return "Fusion Viewer";
Modified: trunk/lib/MGBroker.js
--- trunk/lib/MGBroker.js 2008-05-06 19:15:55 UTC (rev 1391)
+++ trunk/lib/MGBroker.js 2008-05-06 19:21:00 UTC (rev 1392)
@@ -142,7 +142,7 @@
initializeRequest : function() {
this.options = { method:'post' };
- this.parameters = { version : '1.0.0', locale : Fusion.locale };
+ this.parameters = { version : '1.0.0', locale : Fusion.locale, clientagent : 'Fusion Viewer' };
Modified: trunk/widgets/Print/printablepage.templ
--- trunk/widgets/Print/printablepage.templ 2008-05-06 19:15:55 UTC (rev 1391)
+++ trunk/widgets/Print/printablepage.templ 2008-05-06 19:21:00 UTC (rev 1392)
@@ -15,6 +15,7 @@
var msie = agent.indexOf("msie") != -1;
var safari = agent.indexOf("safari") != -1;
var firefox = agent.indexOf("firefox") != -1;
+ var clientAgent = "Fusion Viewer";
var webAgent = '%s';
var scale = %s;
@@ -38,7 +39,7 @@
var legendElt = document.getElementById("Legend");
legendElt.style.width = "180px";
- legendElt.innerHTML = "<img id=\"legendImage\" width=\"180\" height=\"" + mapHeight + "\" src=\"" + webAgent + "?OPERATION=GETMAPLEGENDIMAGE&VERSION=1.0.0&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&WIDTH=180&HEIGHT=" + mapHeight + "&FORMAT=PNG\" style=\"visibility: hidden\" onload=\"OnImageLoaded('legendImage');\">";
+ legendElt.innerHTML = "<img id=\"legendImage\" width=\"180\" height=\"" + mapHeight + "\" src=\"" + webAgent + "?OPERATION=GETMAPLEGENDIMAGE&VERSION=1.0.0&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&CLIENTAGENT=" + encodeURIComponent(clientAgent) + "&WIDTH=180&HEIGHT=" + mapHeight + "&FORMAT=PNG\" style=\"visibility: hidden\" onload=\"OnImageLoaded('legendImage');\">";
else
mapWidth += 180;
@@ -49,7 +50,7 @@
document.getElementById("ScaleAndArrow").style.height = "0px";
- var imgReq = webAgent + "?OPERATION=GETMAPIMAGE&VERSION=1.0.0&FORMAT=PNG&LOCALE="+locale+"&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&SETDISPLAYWIDTH=" + mapWidth + "&SETDISPLAYHEIGHT=" + mapHeight + "&SETDISPLAYDPI=" + dpi + "&SETVIEWSCALE=" + scale + "&SETVIEWCENTERX=" + centerX + "&SETVIEWCENTERY=" + centerY + "&SEQ=" + Math.random();
+ var imgReq = webAgent + "?OPERATION=GETMAPIMAGE&VERSION=1.0.0&FORMAT=PNG&LOCALE="+locale+"&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&SETDISPLAYWIDTH=" + mapWidth + "&SETDISPLAYHEIGHT=" + mapHeight + "&SETDISPLAYDPI=" + dpi + "&SETVIEWSCALE=" + scale + "&SETVIEWCENTERX=" + centerX + "&SETVIEWCENTERY=" + centerY + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeURIComponent(clientAgent);
var mapElt = document.getElementById("Map");
mapElt.style.width = mapWidth + "px";
More information about the fusion-commits
