[fusion-commits] r1396 - in branches/fusion-1.0: . MapGuide MapGuide/php MapServer MapServer/php common/php jx/lib lib lib/OpenLayers/theme/default/img templates/mapguide/standard templates/mapguide/standard/images widgets widgets/BufferPanel widgets/Print widgets/Search widgets/SelectWithin
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu May 8 11:34:31 EDT 2008
Author: madair
Date: 2008-05-08 11:34:30 -0400 (Thu, 08 May 2008)
New Revision: 1396
Added:
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/blank.gif
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/editing_tool_bar.png
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/overview_replacement.gif
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_off.png
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_on.png
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_off.png
   branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_on.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_bg.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_b.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_bl.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_br.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_l.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_r.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_t.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tl.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tr.png
   branches/fusion-1.0/templates/mapguide/standard/images/dialog_resize.png
   branches/fusion-1.0/templates/mapguide/standard/images/icon_close.png
   branches/fusion-1.0/MapGuide/MapGuide.js
   branches/fusion-1.0/MapGuide/php/Buffer.php
   branches/fusion-1.0/MapGuide/php/Common.php
   branches/fusion-1.0/MapGuide/php/Query.php
   branches/fusion-1.0/MapGuide/php/SaveMap.php
   branches/fusion-1.0/MapServer/MapServer.js
   branches/fusion-1.0/MapServer/php/LegendIcon.php
   branches/fusion-1.0/MapServer/php/LoadMap.php
   branches/fusion-1.0/MapServer/php/Measure.php
   branches/fusion-1.0/MapServer/php/Query.php
   branches/fusion-1.0/common/php/Xml2JSON.php
   branches/fusion-1.0/config.json
   branches/fusion-1.0/jx/lib/jx_combined.js
   branches/fusion-1.0/lib/MGBroker.js
   branches/fusion-1.0/lib/Map.js
   branches/fusion-1.0/lib/fusion.js
   branches/fusion-1.0/templates/mapguide/standard/ApplicationDefinition.xml
   branches/fusion-1.0/templates/mapguide/standard/index.html
   branches/fusion-1.0/widgets/BufferPanel/Buffer.php
   branches/fusion-1.0/widgets/CenterSelection.js
   branches/fusion-1.0/widgets/CursorPosition.js
   branches/fusion-1.0/widgets/MapMenu.js
   branches/fusion-1.0/widgets/Maptip.js
   branches/fusion-1.0/widgets/Measure.js
   branches/fusion-1.0/widgets/Print/printablepage.templ
   branches/fusion-1.0/widgets/SaveMap.js
   branches/fusion-1.0/widgets/Search/Search.php
   branches/fusion-1.0/widgets/SelectRadiusValue.js
   branches/fusion-1.0/widgets/SelectWithin/SelectWithin.php
   branches/fusion-1.0/widgets/SelectWithin/SelectWithinPanel.templ
   branches/fusion-1.0/widgets/ViewSize.js
re #58: patches applied for 1.0.5 release (MapGuide)
Modified: branches/fusion-1.0/MapGuide/MapGuide.js
--- branches/fusion-1.0/MapGuide/MapGuide.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapGuide/MapGuide.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -51,6 +51,8 @@
     //the resource id of the current MapDefinition
     _sResourceId: null,
+    clientAgent: 'Fusion Viewer',
     initialize : function(map, mapTag, isMapWidgetLayer) {
         // console.log('MapGuide.initialize');
@@ -81,8 +83,8 @@
           if (ctrlClickEnabled) {
             this.map = this.mapWidget.oMapOL;
             this.handler = new OpenLayers.Handler.Click(this,
-                                  {click: this.mouseUpCRTLClick.bind(this)},
-                                  {keyMask: OpenLayers.Handler.MOD_CTRL});
+                {click: OpenLayers.Function.bind(this.mouseUpCRTLClick, this)},
+                {keyMask: OpenLayers.Handler.MOD_CTRL});
             this.handler.activate();
             this.nTolerance = 2; //pixels, default pixel tolernace for a point click; TBD make this configurable
@@ -119,21 +121,22 @@
             this.session[0] = this;
             var sl = Fusion.getScriptLanguage();
             var scriptURL = this.arch + '/' + sl + '/CreateSession.' + sl;
-            var options = {onComplete: this.createSessionCB.bind(this)};
+            var options = {onSuccess: OpenLayers.Function.bind(this.createSessionCB, this)};
             Fusion.ajaxRequest(scriptURL,options);
         if (this.session[0] instanceof Fusion.Maps.MapGuide) {
             // console.log('register for event');
-            this.session[0].registerForEvent(Fusion.Event.MAP_SESSION_CREATED, this.mapSessionCreated.bind(this));
+            this.session[0].registerForEvent(Fusion.Event.MAP_SESSION_CREATED,
+                OpenLayers.Function.bind(this.mapSessionCreated, this));
         } else {
             this.mapSessionCreated();
-    createSessionCB : function(r, json) {
-        if (r.status == 200 && json) {
+    createSessionCB : function(xhr) {
+        if (xhr.status == 200) {
             var o;
-            eval('o='+r.responseText);
+            eval('o='+xhr.responseText);
             this.session[0] = o.sessionId;
             this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
@@ -143,7 +146,7 @@
         if (this.sMapResourceId != '') {
             this.loadMap(this.sMapResourceId);
-        window.setInterval(this.pingServer.bind(this), this.keepAliveInterval * 1000);
+        window.setInterval(OpenLayers.Function.bind(this.pingServer, this), this.keepAliveInterval * 1000);
     sessionReady: function() {
@@ -204,20 +207,20 @@
         var sessionid = this.getSessionID();
-        var params = 'mapid='+resourceId+"&session="+sessionid;
-        var options = {onSuccess: this.mapLoaded.bind(this), parameters:params};
+        var params = {'mapid': resourceId, "session": sessionid};
+        var options = {onSuccess: OpenLayers.Function.bind(this.mapLoaded,this),
+                       parameters:params};
         Fusion.ajaxRequest(loadmapScript, options);
-    mapLoaded: function(r, json) {
-        if (json) {
+    mapLoaded: function(r) {
+        if (r.status == 200) {
             var o;
             this._sResourceId = o.mapId;
             this._sMapname = o.mapName;
             this._sMapTitle = o.mapTitle;
-            this._fMetersperunit = o.metersPerUnit;
-            this.mapWidget._fMetersperunit = this._fMetersperunit;
+            this.mapWidget.setMetersPerUnit(o.metersPerUnit);
             this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
@@ -284,7 +287,7 @@
             //set projection units and code if supplied
             //TODO: consider passing the metersPerUnit value into the framework
             //to allow for scaling that doesn't match any of the pre-canned units
-            this.units = this.getClosestUnits(o.metersPerUnit);
+            this.units = Fusion.getClosestUnits(o.metersPerUnit);
             //add in scales array if supplied
             if (o.FiniteDisplayScales && o.FiniteDisplayScales.length>0) {
@@ -315,29 +318,10 @@
               this.triggerEvent(Fusion.Event.MAP_LOADED);
             this.bMapLoaded = true;
-        } else {
-            Fusion.reportError( new Fusion.Error(Fusion.Error.FATAL,
-                OpenLayers.String.translate('mapLoadError', r.responseText)));
         this.mapWidget._removeWorker();
-    getClosestUnits: function(metrsPerUnit) {
-        var units = "degrees";
-        var minDiff = 100000000;
-        for (var key in OpenLayers.INCHES_PER_UNIT)
-            var newDiff = Math.abs((metrsPerUnit * 39.3701) - OpenLayers.INCHES_PER_UNIT[key]);
-            if(newDiff < minDiff)
-                minDiff = newDiff;
-                units = key;
-        return units;
 //TBD: this function not yet converted for OL
     reloadMap: function() {
@@ -357,13 +341,12 @@
-        var params = 'mapname='+this._sMapname+"&session="+sessionid;
-        var options = {onSuccess: this.mapReloaded.bind(this),
-                      onException: this.reloadFailed.bind(this),
-                      parameters: params};
+        var params = {'mapname': this._sMapname, 'session': sessionid};
+        var options = {
+              onSuccess: OpenLayers.Function.bind(this.mapReloaded,this),
+              onException: OpenLayers.Function.bind(this.reloadFailed, this),
+              parameters: params};
     reloadFailed: function(r) {
@@ -373,8 +356,8 @@
-    mapReloaded: function(r,json) {
-        if (json) {
+    mapReloaded: function(r) {
             var o;
             this.parseMapLayersAndGroups(o);
@@ -390,9 +373,6 @@
             this.oldLayers = null;
             this.mapWidget.triggerEvent(Fusion.Event.MAP_RELOADED);
             this.drawMap();
-        } else {
@@ -401,18 +381,20 @@
         var loadmapScript = this.arch + '/' + sl  + '/SetLayers.' + sl;
-        var sessionid = this.getSessionID();
+        var params = {
+            'mapname': this._sMapname,
+            'session': this.getSessionID(),
+            'layerindex': aLayerIndex.join()
-        params += '&layerindex=' + aLayerIndex.join();
-        var options = {onSuccess: this.mapLayersReset.bind(this, aLayerIndex),
+        var options = {
+            onSuccess: OpenLayers.Function.bind(this.mapLayersReset, this, aLayerIndex),
-    mapLayersReset: function(aLayerIndex,r,json) {
-      if (json) {
+    mapLayersReset: function(aLayerIndex,r) {
         var o;
             if (o.success) {
@@ -464,7 +446,8 @@
             return;
-        var options = {
+        var params = {
+          ts : (new Date()).getTime(),  //add a timestamp to prevent caching on the server
           showLayers : this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null,
           hideLayers : this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null,
           showGroups : this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null,
@@ -477,8 +460,7 @@
         this.aHideGroups = [];
         this.aRefreshLayers = [];
-        this.oLayerOL.addOptions(options);
-        this.oLayerOL.mergeNewParams({ts : (new Date()).getTime()});
+        this.oLayerOL.mergeNewParams(params);
         if (this.queryLayer) this.queryLayer.redraw();
@@ -511,18 +493,20 @@
       if ( bSingleTile ) {
         params = {        //single tile params
           session : this.getSessionID(),
-          mapname : this._sMapname
+          mapname : this._sMapname,
+          clientagent : this.clientAgent
-        layerOptions.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
-        layerOptions.hideLayers = this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null;
-        layerOptions.showGroups = this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null;
-        layerOptions.hideGroups = this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null;
-        layerOptions.refreshLayers = this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null;
+        params.showLayers = this.aShowLayers.length > 0 ? this.aShowLayers.toString() : null;
+        params.hideLayers = this.aHideLayers.length > 0 ? this.aHideLayers.toString() : null;
+        params.showGroups = this.aShowGroups.length > 0 ? this.aShowGroups.toString() : null;
+        params.hideGroups = this.aHideGroups.length > 0 ? this.aHideGroups.toString() : null;
+        params.refreshLayers = this.aRefreshLayers.length > 0 ? this.aRefreshLayers.toString() : null;
       } else {
         params = {      //tiled version
           mapdefinition: this._sResourceId,
-          basemaplayergroupname: this.groupName  //assumes only one group for now
+          basemaplayergroupname: this.groupName,  //assumes only one group for now
@@ -561,8 +545,8 @@
     hasSelection: function() { return this.bSelectionOn; },
-    getSelectionCB : function(userFunc, layers, startend, r, json) {
-      if (json)
+    getSelectionCB : function(userFunc, layers, startend, r) {
           var o;
           eval("o="+r.responseText);
@@ -641,10 +625,14 @@
       this.mapWidget._addWorker();
       var setSelectionScript = this.arch + '/' + sl  + '/SetSelection.' + sl;
-      var params = 'mapname='+this.getMapName()+"&session="+this.getSessionID();
-      params += '&selection=' + encodeURIComponent(selText);
-      params += '&seq=' + Math.random();
-      var options = {onSuccess: this.processQueryResults.bind(this, zoomTo), parameters:params, asynchronous:false};
+      var params = {
+          'mapname': this.getMapName(),
+          'selection': encodeURIComponent(selText),
+          'seq': Math.random()
+      var options = {onSuccess: OpenLayers.Function.bind(this.processQueryResults, this, zoomTo),
+                     parameters:params, asynchronous:false};
       Fusion.ajaxRequest(setSelectionScript, options);
@@ -681,9 +669,14 @@
           //this.mapWidget._addWorker();
           // this._bSelectionIsLoading = true;
           var s = this.arch + '/' + Fusion.getScriptLanguage() + "/Selection." + Fusion.getScriptLanguage() ;
-          var params = {parameters:'session='+this.getSessionID()+'&mapname='+ this._sMapname +'&layers='+layers+'&startcount='+startcount,
-                        onComplete: this.getSelectionCB.bind(this, userFunc, layers, startcount)};
-          Fusion.ajaxRequest(s, params);
+          var options = {
+              parameters: {'session': this.getSessionID(),
+                          'layers': layers,
+                          'startcount': startcount},
+              onSuccess: OpenLayers.Function.bind(this.getSelectionCB, this, userFunc, layers, startcount)
+          Fusion.ajaxRequest(s, options);
@@ -711,9 +704,13 @@
     clearSelection : function() {
       if (this.hasSelection()) {
-        var s = this.arch + '/' + Fusion.getScriptLanguage() + "/ClearSelection." + Fusion.getScriptLanguage() ;
-        var params = {parameters:'session='+this.getSessionID()+'&mapname='+ this._sMapname, onComplete: this.selectionCleared.bind(this)};
+          var s = this.arch + '/' + Fusion.getScriptLanguage() + "/ClearSelection." + Fusion.getScriptLanguage() ;
+          var options = {
+                          'mapname': this._sMapname},
+              onSuccess: OpenLayers.Function.bind(this.selectionCleared, this)
@@ -742,7 +739,8 @@
                 if (!this.queryLayer) {
                   this.queryLayer = this.createOLLayer("query layer", false, true);
                   this.mapWidget.oMapOL.addLayer(this.queryLayer);
-                  this.mapWidget.registerForEvent(Fusion.Event.MAP_LOADING, this.removeQueryLayer.bind(this));
+                  this.mapWidget.registerForEvent(Fusion.Event.MAP_LOADING,
+                        OpenLayers.Function.bind(this.removeQueryLayer, this));
                 } else {
                   this.queryLayer.setVisibility(true);
@@ -782,24 +780,32 @@
           this.aLayers[j].selectedFeatureCount = 0;
-        var geometry = options.geometry || '';
-        var maxFeatures = options.maxFeatures || 0; //zero means select all features
         var bPersistant = options.persistent || true;
-        var selectionType = options.selectionType || this.selectionType;
-        var filter = options.filter ? '&filter='+options.filter : '';
-        var layers = options.layers || '';
-        var extend = options.extendSelection ? '&extendselection=true' : '';
-        var computed = options.computedProperties ? '&computed=true' : '';
         var zoomTo = options.zoomTo ?  true : false;
         var loadmapScript = this.arch + '/' + sl  + '/Query.' + sl;
-        var params = 'mapname='+this._sMapname+"&session="+sessionid+'&spatialfilter='+geometry+'&maxfeatures='+maxFeatures+filter+'&layers='+layers+'&variant='+selectionType+extend+computed;
-        Fusion.ajaxRequest(loadmapScript, options);
+        var params = {
+            'spatialfilter': options.geometry || '',
+            'maxfeatures': options.maxFeatures || 0, //zero means select all features
+            'layers': options.layers || '',
+            'variant': options.selectionType || this.selectionType
+        if (options.filter) {
+            params.filter= options.filter;
+        if (options.extendSelection) {
+            params.extendselection = true;
+        if (options.computedProperties) {
+            params.computed = true;
+        var ajaxOptions = {
+            onSuccess: OpenLayers.Function.bind(this.processQueryResults, this, zoomTo),
+        Fusion.ajaxRequest(loadmapScript, ajaxOptions);
     processLayerEvents: function(layer, isEnabling) {
@@ -935,6 +941,7 @@
         var persist = 0;
         var selection = 'INTERSECTS';
         var layerNames = '';
+        var layerAttributeFilter = 3;
         var sep = '';
         for (var i=0; i<this.aLayers.length; ++i) {
           layerNames += sep + this.aLayers[i].layerName;
@@ -943,7 +950,8 @@
         var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.mapWidget.getSessionID(),
                                                             this._sMapname,
                                                             sGeometry,
-                                                            maxFeatures, persist, selection, layerNames);
+                                                            maxFeatures, persist, selection, layerNames,
+                                                            layerAttributeFilter);
         Fusion.oBroker.dispatchRequest(r, this.crtlClickDisplay.bind(this));
@@ -965,7 +973,7 @@
     pingServer: function() {
         var s = this.arch + '/' + Fusion.getScriptLanguage() + "/Common." + Fusion.getScriptLanguage() ;
         var params = {};
-        params.parameters = 'session='+this.getSessionID();
+        params.parameters = {'session': this.getSessionID()};
     getGroupInfoUrl: function(groupName) {
@@ -997,7 +1005,6 @@
 * Implements the map layer groups for MapGuide services
 Fusion.Maps.MapGuide.Group = Class.create();
 Fusion.Maps.MapGuide.Group.prototype = {
     oMap: null,
@@ -1142,7 +1149,6 @@
 * Implements a scale range object for MapGuide services
 Fusion.Maps.MapGuide.ScaleRange = Class.create();
 Fusion.Maps.MapGuide.ScaleRange.prototype = {
     styles: null,
@@ -1165,7 +1171,8 @@
     contains: function(fScale) {
-        return fScale >= this.minScale && fScale <= this.maxScale;
+        var testScale = Math.round(fScale);
+        return testScale >= this.minScale && testScale <= this.maxScale;
@@ -1177,6 +1184,7 @@
 Fusion.Maps.MapGuide.StyleItem = Class.create();
 Fusion.Maps.MapGuide.StyleItem.prototype = {
     initialize: function(o, staticIcon) {
         this.legendLabel = o.legendLabel;
         this.filter = o.filter;
@@ -1192,6 +1200,6 @@
     getLegendImageURL: function(fScale, layer) {
         var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
-        return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType;
+        return url + "OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID() + "&VERSION=1.0.0&SCALE=" + fScale + "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId) + "&THEMECATEGORY=" + this.categoryIndex + "&TYPE=" + this.geometryType + "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
Modified: branches/fusion-1.0/MapGuide/php/Buffer.php
--- branches/fusion-1.0/MapGuide/php/Buffer.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapGuide/php/Buffer.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -158,12 +158,10 @@
             $layerSrsWkt = $spatialContext->GetCoordinateSystemWkt();
             /* skip this layer if the srs is empty */
             if($layerSrsWkt == "") {
-                $excludedLayers ++;
                 continue;
         } else {
             /* skip this layer if there is no spatial context at all */
             continue;
@@ -182,7 +180,6 @@
         if(($arbitraryDsSrs != $arbitraryMapSrs) || ($arbitraryDsSrs && ($dsSrsUnits != $mapSrsUnits)))
             continue;
@@ -191,15 +188,19 @@
         $dist = $layerCs->ConvertMetersToCoordinateSystemUnits($distance);
         // calculate great circle unless data source srs is arbitrary
+        $verMajor = subStr(GetSiteVersion(), 0,1);
         if(!$arbitraryDsSrs) {
-            $measure = new MgCoordinateSystemMeasure($layerCs);
+            if ($verMajor == '1') {
+              $measure = new MgCoordinateSystemMeasure($layerCs);
+            } else {
+              $measure = $layerCs->GetMeasure();
         } else {
             $measure = null;
         // create a SRS transformer if necessary.
         if($layerSrsWkt != $srsDefMap) {
-            $verMajor = subStr(GetSiteVersion(), 0,1);
               $srsXform = new MgCoordinateSystemTransform($layerCs, $srsMap);
             } else {
Modified: branches/fusion-1.0/MapGuide/php/Common.php
--- branches/fusion-1.0/MapGuide/php/Common.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapGuide/php/Common.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -74,6 +74,8 @@
         $username = isset($_REQUEST['username']) ? $_REQUEST['username'] : 'Anonymous';
         $password = isset($_REQUEST['password']) ? $_REQUEST['password'] : '';
         $user = new MgUserInformation($username, $password);
+        $user->SetClientIp(GetClientIp());
+        $user->SetClientAgent(GetClientAgent());
         $siteConnection = new MgSiteConnection();
         $siteConnection->Open($user);
     } else {
@@ -90,9 +92,13 @@
         /* current user is re-authenticating or not? */
         if (isset($_REQUEST['username']) && isset($_REQUEST['password'])) {
             $user = new MgUserInformation($_REQUEST['username'], $_REQUEST['password']);
             $user->SetMgSessionId($sessionID);
         } else {
             $user = new MgUserInformation($sessionID);
         /* open a connection to the site.  This will generate exceptions if the user
@@ -118,7 +124,6 @@
     echo "</Exception>";
     exit;
 } catch (MgUserNotFoundException $unfe) {
-    header("HTTP/1.0 500 Internal Server Error");
     header('Content-type: text/xml');
     echo "<Exception>";
     echo "<Type>User Not Found</Type>";
@@ -256,5 +261,29 @@
     return $numberString;
+function GetClientIp()
+    $clientIp = '';
+    if (array_key_exists('HTTP_CLIENT_IP', $_SERVER)
+        && strcasecmp($_SERVER['HTTP_CLIENT_IP'], 'unknown') != 0)
+        $clientIp = $_SERVER['HTTP_CLIENT_IP'];
+    else if (array_key_exists('HTTP_X_FORWARDED_FOR', $_SERVER)
+        && strcasecmp($_SERVER['HTTP_X_FORWARDED_FOR'], 'unknown') != 0)
+        $clientIp = $_SERVER['HTTP_X_FORWARDED_FOR'];
+    else if (array_key_exists('REMOTE_ADDR', $_SERVER))
+        $clientIp = $_SERVER['REMOTE_ADDR'];
+    return $clientIp;
+function GetClientAgent()
+    return "Fusion Viewer";
Modified: branches/fusion-1.0/MapGuide/php/Query.php
--- branches/fusion-1.0/MapGuide/php/Query.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapGuide/php/Query.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -115,6 +115,7 @@
             $className = $layerObj->GetFeatureClassName();
             if (!$layerObj->GetSelectable() || !$layerObj->IsVisible() ||
+                $className=='RedlineSchema:Redline' ||
                 !$className || $className=='rasters:RasterType' ||$className=='') {
                 continue;
Modified: branches/fusion-1.0/MapGuide/php/SaveMap.php
--- branches/fusion-1.0/MapGuide/php/SaveMap.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapGuide/php/SaveMap.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -29,9 +29,14 @@
 include('Common.php');
-$format = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
-$layout = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
-$scale  = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : null;
+$format     = isset($_REQUEST['format']) ? $_REQUEST['format'] : 'png';
+$layout     = isset($_REQUEST['layout']) ? $_REQUEST['layout'] : null;
+$scale      = isset($_REQUEST['scale']) ? $_REQUEST['scale'] : null;
+$imgWidth   = isset($_REQUEST['width']) ? $_REQUEST['width'] : null;
+$imgHeight  = isset($_REQUEST['height']) ? $_REQUEST['height'] : null;
+$pageHeight = isset($_REQUEST['pageheight']) ? $_REQUEST['pageheight'] : 11;
+$pageWidth  = isset($_REQUEST['pagewidth']) ? $_REQUEST['pagewidth'] : 8.5;
+$aMargins = isset($_REQUEST['margins']) ? explode(',',$_REQUEST['margins']) : array(0,0,0,0);
 try
@@ -43,44 +48,41 @@
     $selection = new MgSelection($map);
     $selection->Open($resourceService, $mapName);
+    //compute center
+    $extent = $map->GetMapExtent();
+    $centerX = $extent->GetLowerLeftCoordinate()->GetX() + ($extent->GetWidth())/2;
+    $centerY = $extent->GetLowerLeftCoordinate()->GetY() + ($extent->GetHeight())/2;
+    $geomFactory = new MgGeometryFactory();
+    $center = $geomFactory->CreateCoordinateXY($centerX, $centerY);
     if ($format == 'DWF') {
-        $extent = $map->GetMapExtent();
         $oLayout = null;
         if ($layout) {
             $layoutId = new MgResourceIdentifier($layout);
             $layoutId->Validate();
             $oLayout = new MgLayout($layoutId,'Map', 'meters');
-        $oPlotSpec = new MgPlotSpecification(8.5,11,MgPageUnitsType::Inches);
+        $oPlotSpec = new MgPlotSpecification($pageWidth,$pageHeight,MgPageUnitsType::Inches,
+                                            $aMargins[0],
+                                            $aMargins[1],
+                                            $aMargins[2],
+                                            $aMargins[3]
         $dwfVersion = new MgDwfVersion('6.01','1.2');
         if ($scale) {
-            //compute center point and plot with the passed scale
-            $centerX = $extent->GetLowerLeftCoordinate()->GetX() + ($extent->GetWidth())/2;
-            $centerY = $extent->GetLowerLeftCoordinate()->GetY() + ($extent->GetHeight())/2;
-            $geomFactory = new MgGeometryFactory();
-            $center = $geomFactory->CreateCoordinateXY($centerX, $centerY);
+            //plot with the passed scale
-            //echo $centerX.", ".$centerY;exit;
-            //$metersPerUnit = $map->GetMetersPerUnit();
             $coordSysFactory = new MgCoordinateSystemFactory();
             $coordSystem = $coordSysFactory->Create($map->GetMapSRS());
             $metersPerUnit = $coordSystem->ConvertCoordinateSystemUnitsToMeters(1.0);
             $metersPerPixel = 1.0/(100.0 / 2.54 * $map->GetDisplayDpi());
-            //echo $metersPerPixel; exit;
             $height = $map->GetDisplayHeight();
             $width = $map->GetDisplayWidth();
             $mapWidth = $scale * $width * $metersPerPixel/$metersPerUnit;
             $mapHeight = $scale * $height * $metersPerPixel/$metersPerUnit;
-            //echo $mapWidth.", ".$mapHeight;exit;
-            // $lowerLeft = $geomFactory->CreateCoordinateXY($center->GetX() - 0.5*$mapWidth,
-            //                                               $center->GetY() - 0.5*$mapHeight);
-            // $topRight = $geomFactory->CreateCoordinateXY($center->GetX() + 0.5*$mapWidth,
-            //                                               $center->GetY() + 0.5*$mapHeight);
             $extent = new MgEnvelope(
                                       $center->GetY() - 0.5*$mapHeight,
@@ -113,8 +115,18 @@
                                               $dwfVersion);
     } else {
-        $oImg = $renderingService->RenderMap($map, $selection, $format);
+        //render as an image
+        if (isset($imgHeight) && isset($imgWidth)) {
+            $scale = $map->GetViewScale();
+            $oImg = $renderingService->RenderMap($map, $selection,
+                                                 $center, $scale,
+                                                 $imgWidth, $imgHeight,
+                                                 new MgColor(255,255,255),
+                                                 $format);
+        }else{
+            $oImg = $renderingService->RenderMap($map, $selection, $format);
 catch (MgException $e)
@@ -124,16 +136,8 @@
   exit;
+header("Cache-Control: no-store, no-cache, must-revalidate");  // HTTP/1.1
 header("Expires: Mon, 26 Jul 1997 05:00:00 GMT");    // Date in the past
-header("Last-Modified: " . gmdate("D, d M Y H:i:s") . " GMT");
-                                             // always modified
-header("Cache-Control: no-store, no-cache, must-revalidate");  // HTTP/1.1
-header("Cache-Control: post-check=0, pre-check=0", false);
-header("Pragma: no-cache");                          // HTTP/1.0
-header( "Content-type: application/octet-stream" );
-header( "Content-Disposition: attachment; filename=$mapName.png" );
 header( "Content-type: image/$format" );
 header( "Content-disposition: attachment; filename=$mapName.$format" );
Modified: branches/fusion-1.0/MapServer/MapServer.js
--- branches/fusion-1.0/MapServer/MapServer.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapServer/MapServer.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -24,7 +24,7 @@
- * Class: Fusion.Maps.MapServer
+ * Class: Fusion.Maps.MapServer
  * Implementation of the map widget for MapServer CGI interface services
@@ -48,17 +48,19 @@
     bMapLoaded : false,
     bIsMapWidgetLayer : true,  //Setthis to false for overview map layers
     bLayersReversed: true,     //MS returns layers bottom-most layer first, we treat layer order in reverse sense
+    mapMetadataKeys: null,
+    layerMetadataKeys: null,
     //the map file
     sMapFile: null,
     //imagetype
     _sImageType : 'png',
         //console.log('Fusion.Maps.MapServer.initialize');
         Object.inheritFrom(this, Fusion.Lib.EventMgr, []);
         this.registerEventID(Fusion.Event.MAP_SESSION_CREATED);
         this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
         this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
@@ -75,7 +77,7 @@
         var extension = mapTag.extension;
         this.ratio = extension.MapRatio ? extension.MapRatio[0] : '1.0';
         //this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
         rootOpts = {
           displayInLegend: this.bDisplayInLegend,
           expandInLegend: this.bExpandInLegend,
@@ -87,9 +89,12 @@
           //TODO: set other opts for group initialization as required
         this.layerRoot = new Fusion.Maps.MapServer.Group(rootOpts,this);
         this.sMapFile = extension.MapFile ? extension.MapFile[0] : '';
+        this.mapMetadataKeys = extension.MapMetadata ? extension.MapMetadata[0] : null;
+        this.layerMetadataKeys = extension.LayerMetadata ? extension.LayerMetadata[0] : null;
         this.bSingleTile = mapTag.singleTile;// this is set by the AppDef.Map object
         this.keepAliveInterval = parseInt(extension.KeepAliveInterval ? extension.KeepAliveInterval[0] : 300);
@@ -108,7 +113,7 @@
-            Fusion.ajaxRequest(scriptURL,options);
+            Fusion.ajaxRequest(scriptURL,options);
         if (this.session[0] instanceof Fusion.Maps.MapServer) {
@@ -116,7 +121,7 @@
             var o;
@@ -140,18 +145,18 @@
     getSessionID: function() {
         return this.session[0];
     getMapName: function() {
         return this._sMapname;
     getMapTitle: function() {
         return this._sMapTitle;
     loadMap: function(mapfile, options) {
         while (this.mapWidget.isBusy()) {
-	        this.mapWidget._removeWorker();
+	        this.mapWidget._removeWorker();
         this.bMapLoaded = false;
         //console.log('loadMap: ' + resourceId);
@@ -164,56 +169,64 @@
             this.sMapFile = mapfile;
             return;
         if (this.bIsMapWidgetLayer) {
             this.mapWidget.triggerEvent(Fusion.Event.MAP_LOADING);
         } else {
             this.triggerEvent(Fusion.Event.MAP_LOADING);
         this._fScale = -1;
         this._nDpi = 72;
         options = options || {};
         this._oMaxExtent = null;
         this.aVisibleLayers = options.showlayers || [];
         this.aVisibleGroups = options.showgroups || [];
         this.aLayers = [];
         this.oSelection = null;
         this.aSelectionCallbacks = [];
         this._bSelectionIsLoading = false;
         var loadmapScript = this.arch + '/' + sl  + '/LoadMap.' + sl;
-        var params = 'mapfile='+mapfile+"&session="+sessionid;
+        var metadata = '';
+        if (this.mapMetadataKeys) {
+            metadata += '&map_metadata='+this.mapMetadataKeys;
+        if (this.layerMetadataKeys) {
+            metadata += '&layer_metadata='+this.layerMetadataKeys;
+        var params = 'mapfile='+mapfile+"&session="+sessionid+metadata;
+        var options = {onSuccess: this.mapLoaded.bind(this),
-        if (json)
-            var o;
+        if (json)
+            var o;
+            eval('o='+r.responseText);
             this._sMapFile = o.mapId;
-            this._sMapname = o.mapName;
+            this._sMapname = o.mapName;
-            this._sImageType = o.imagetype;
+            this._sImageType = o.imagetype;
+            this.metadata = o.metadata;
-            this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
+            this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
             this.layerRoot.clear();
             this.layerRoot.legendLabel = this._sMapTitle;
             var minScale = 1.0e10;
@@ -229,37 +242,24 @@
             if (minScale <= 0) {
               minScale = 1.0;
             if (o.dpi) {
                 OpenLayers.DOTS_PER_INCH = o.dpi;
+            //to allow for scaling that doesn't match any of the pre-canned units
             var layerOptions = {
-      				singleTile: true,
+      				singleTile: true,
       				ratio: this.ratio,
+              units: this.units,
       				maxExtent : this._oMaxExtent,
               maxResolution : 'auto',
       				minScale : maxScale,	//OL interpretation of min/max scale is reversed from Fusion
       				maxScale : minScale
-            //set OpenLayer projection units and code if supplied (OL defaults units to degrees)
-            if (o.metersPerUnit == 0.0254)
-               layerOptions.units = 'inches';
-            else if (o.metersPerUnit == 0.3048)
-               layerOptions.units = 'ft';
-            else if (o.metersPerUnit == 1609.344)
-               layerOptions.units = 'mi';
-            else if (o.metersPerUnit == 1)
-               layerOptions.units = 'm';
-               //layerOptions.projection = 'EPSG:42304';  //TODO: not necessary, but can this be supplied by LoadMap?
-            else if (o.metersPerUnit == 1000)
-               layerOptions.units = 'km';
-            else if (o.metersPerUnit == 111118.7516)
-               layerOptions.units = 'dd';
-            //this.mapWidget.setMapOptions(oMapOptions);
             //create the OL layer for this Map layer
             var params = {
               layers: this.aVisibleLayers.join(' '),
@@ -293,15 +293,15 @@
-        else
+        else
+            Fusion.reportError( new Fusion.Error(Fusion.Error.FATAL,
 					'Failed to load requested map:\n'+r.responseText));
         this.aShowLayers = [];
@@ -311,22 +311,33 @@
         this.aLayers = [];
+        var params = 'mapname='+this._sMapname+"&session="+sessionid+metadata;
+        var options = {onSuccess: this.mapReloaded.bind(this),
     mapReloaded: function(r,json) {  /* update this with OL code */
         if (json) {
             var o;
+            //can metadata change?
+            //this.metadata = o.metadata;
             this.aVisibleLayers = [];
             for (var i=0; i<this.aLayers.length; i++) {
@@ -337,25 +348,25 @@
             this.drawMap();
         } else {
     reorderLayers: function(aLayerIndex) {
+        var options = {onSuccess: this.mapLayersReset.bind(this, aLayerIndex),
       if (json) {
         var o;
@@ -364,7 +375,7 @@
   				var layerCopy = this.aLayers.clone();
   				this.aLayers = [];
           for (var i=0; i<aLayerIndex.length; ++i) {
             this.aLayers.push( layerCopy[ aLayerIndex[i] ] );
             if (this.aLayers[i].visible) {
@@ -372,7 +383,7 @@
   				//this.layerRoot.clear();
   				this.drawMap();
   				this.triggerEvent(Fusion.Event.MAP_LAYER_ORDER_CHANGED);
   			} else {
@@ -380,7 +391,7 @@
     parseMapLayersAndGroups: function(o) {
         for (var i=0; i<o.groups.length; i++) {
             var group = new Fusion.Maps.MapServer.Group(o.groups[i], this);
@@ -408,7 +419,7 @@
      * Function: isMapLoaded
      * Returns true if the Map has been laoded succesfully form the server
     isMapLoaded: function() {
@@ -418,13 +429,13 @@
     getScale : function() {
         return this.mapWidget.getScale();
     updateLayer: function() {   //to be fleshed out, add query file to layer if selection, call this before draw
           this.oLayerOL.addOptions({queryfile: this._sQueryfile});
     drawMap: function() {
         if (!this.bMapLoaded || this.deferredDraw) {
             return;
@@ -444,7 +455,7 @@
     showLayer: function( sLayer ) {
         this.aVisibleLayers.push(sLayer);
         this.drawMap();
@@ -502,7 +513,7 @@
-      if (json)
+      if (json)
           var o;
@@ -511,7 +522,7 @@
           userFunc(oSelection);
      * advertise a new selection is available and redraw the map
@@ -569,25 +580,25 @@
      *        selection has loaded
      * @param layers {string} Optional parameter.  A comma separated
      *        list of layer names (Roads,Parcels). If it is not
-     *        given, all the layers that have a selection will be used
+     *        given, all the layers that have a selection will be used
      * @param startcount {string} Optional parameter.  A comma separated
      *        list of a statinh index and the number of features to be retured for
      *        each layer given in the layers parameter. Index starts at 0
      *        (eg: 0:4,2:6 : return 4 elements for the first layers starting at index 0 and
      *         six elements for layer 2 starting at index 6). If it is not
-     *        given, all the elemsnts will be returned.
+     *        given, all the elemsnts will be returned.
     getSelection : function(userFunc, layers, startcount) {
-        if (userFunc)
+        if (userFunc)
-            var params = {parameters:'session='+this.getSessionID()+'&mapname='+ this._sMapname+ '&layers='+layers+'&startcount='+startcount+'&queryfile='+this._sQueryfile,
+            var params = {parameters:'session='+this.getSessionID()+'&mapname='+ this._sMapname+ '&layers='+layers+'&startcount='+startcount+'&queryfile='+this._sQueryfile,
@@ -595,7 +606,7 @@
       if (!this.aLayers) return;
         //clear the selection count for the layers
         for (var j=0; j<this.aLayers.length; ++j) {
@@ -617,7 +628,7 @@
         if (json) {
             var o;
-            if (!o.hasSelection) {
+            if (!o.hasSelection) {
                 //this.drawMap();
                 return;
             } else {
@@ -644,7 +655,7 @@
     query : function(options) {
@@ -669,19 +680,19 @@
         var params = 'mapname='+this._sMapname+"&session="+sessionid+'&spatialfilter='+geometry+'&maxfeatures='+maxFeatures+filter+'&layers='+layers+'&variant='+selectionType+extend;
+        var options = {onSuccess: this.processQueryResults.bind(this, zoomTo),
     loadStart: function() {
     loadEnd: function() {
         var params = {};
@@ -695,11 +706,19 @@
     getLayerInfoUrl: function(layerName) {
       return null;
+  getMetadata: function(key) {
+      if (typeof this.metadata[key] != 'undefined') {
+          return this.metadata[key];
+      } else {
+          return '';
  * Class: Fusion.Maps.MapServer.Group
@@ -722,27 +741,27 @@
         this.visible = o.visible;
         this.actuallyVisible = o.actuallyVisible;
     clear: function() {
         Fusion.Widget.Map.Group.prototype.clear.apply(this, []);
         //this.oMap = null;
     show: function() {
+        this.visible = true;
         this.oMap.showGroup(this.groupName);
-        this.visible = true;
     hide: function() {
+        this.visible = false;
         this.oMap.hideGroup(this.groupName);
-        this.visible = false;
     isVisible: function() {
         var bParentVisible = (this.parentGroup && this.parentGroup.isVisible) ? this.parentGroup.isVisible() : true;
         return this.visible && bParentVisible;
 var MSLAYER_POINT_TYPE = 0;
@@ -759,11 +778,11 @@
 Fusion.Maps.MapServer.Layer = Class.create();
 Fusion.Maps.MapServer.Layer.prototype = {
     scaleRanges: null,
     oMap: null,
     initialize: function(o, oMap) {
         this.uniqueId = o.uniqueId;
         Object.inheritFrom(this, Fusion.Widget.Map.Layer.prototype, [this.uniqueId]);
@@ -781,6 +800,7 @@
         this.editable = o.editable;
         this.parentGroup = o.parentGroup;
         this.scaleRanges = [];
     		this.minScale = 1.0e10;
     		this.maxScale = 0;
@@ -791,13 +811,13 @@
       			this.maxScale = Math.max(this.maxScale, scaleRange.maxScale);
     clear: function() {
         Fusion.Widget.Map.Layer.prototype.clear.apply(this, []);
         this.oMap = null;
         this.legend = null;
     supportsType: function(type) {
         for (var i=0; i<this.layerTypes.length; i++) {
             if (this.layerTypes[i] == type) {
@@ -806,7 +826,7 @@
         return false;
     getScaleRange: function(fScale) {
         for (var i=0; i<this.scaleRanges.length; i++) {
             if (this.scaleRanges[i].contains(fScale)) {
@@ -817,18 +837,26 @@
     show: function() {
+        this.set('visible', true);
         this.oMap.showLayer(this.layerName);
-        this.set('visible', true);
     hide: function() {
+        this.set('visible',false);
         this.oMap.hideLayer(this.layerName);
-        this.set('visible',false);
         var bParentVisible = this.parentGroup ? this.parentGroup.isVisible() : true;
+        } else {
+            return '';
@@ -848,7 +876,7 @@
         if (!o.styles) {
             return;
         /*special case : if there are no classes and it is a raster layer
           we set it to use the default static raster icon*/
         if (o.styles.length == 0 && bRaster)
@@ -860,7 +888,7 @@
           tmpsyle.staticIcon = true;
           var styleItem = new Fusion.Maps.MapServer.StyleItem(tmpsyle, tmpsyle.staticIcon);
           this.styles.push(styleItem);
         else
           var staticIcon = o.styles.length>=1 ? false : bRaster;
@@ -871,7 +899,8 @@
Modified: branches/fusion-1.0/MapServer/php/LegendIcon.php
--- branches/fusion-1.0/MapServer/php/LegendIcon.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapServer/php/LegendIcon.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -25,7 +25,7 @@
- * Purpose: Draw a legend icon
+ * Purpose: Draw a legend icon
 include(dirname(__FILE__).'/Common.php');
@@ -57,6 +57,14 @@
             /* if the legendIconCache dir is set */
             if (isset($configObj->mapserver->legendIconCacheDir)) {
               $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
+              // check for closing '/'
+              $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
+              if ( substr( $legendIconCacheDir, -1 ) != '/' )
+                  $legendIconCacheDir .= '/';
               $cacheLegendIcons = true;
               $str = file_get_contents($_SESSION['maps'][$mapName]);
               /* create a unique location for the map icons based on
@@ -89,7 +97,7 @@
       $width = 16;
     if ($height <=0)
       $height = 16;
     $oImg = $oClass->createLegendIcon($width, $height);
     /* TODO: can we figure out what the content type is? */
     header('Content-type: image/png');
Modified: branches/fusion-1.0/MapServer/php/LoadMap.php
--- branches/fusion-1.0/MapServer/php/LoadMap.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapServer/php/LoadMap.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -41,16 +41,16 @@
 /* could potentially make this optional */
 $moveToSession = true;
    TODO make it possible to specify only a relative path
    in the WebLayout and have this code know where to
    look for it on the server somehow
 /* only do something if a mapfile was requested */
 if (isset($_REQUEST['mapfile'])) {
     $oMap = ms_newMapObj($_REQUEST['mapfile']);
     /* optionally move the mapfile to the session */
     if ($moveToSession) {
         //path to map file in the session is used by the client
@@ -70,7 +70,7 @@
             $oMap->setFontSet(realpath($fontSet));
         /* need to modify all image symbols reference in the map file
-         eg STYLE
+         eg STYLE
              SYMBOL "../etc/markers/target-7.gif" : this is relative to the map file
         for ($i=0; $i<$oMap->numlayers; $i++)
@@ -115,6 +115,14 @@
     $mapObj->sessionId = $sessionID;
     $mapObj->mapId = $mapId;
+    $mapObj->metadata = NULL;
+    if (isset($_REQUEST['map_metadata'])) {
+        $mapMetadataKeys = explode(',',$_REQUEST['map_metadata']);
+        foreach($mapMetadataKeys as $key) {
+            $mapObj->metadata->$key = $oMap->getMetadata($key);
     $mapObj->metersPerUnit = GetMetersPerUnit($oMap->units);
     $mapObj->dpi = $oMap->resolution;
@@ -126,7 +134,7 @@
     if (!isset($_SESSION['maps'][$mapObj->mapName])) {
         $_SESSION['maps'][$mapObj->mapName] = $mapId;
-    $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
+    $mapObj->extent = array( $oMap->extent->minx, $oMap->extent->miny,
                              $oMap->extent->maxx, $oMap->extent->maxy );
     $minScale = $oMap->web->minscale == -1 ? MIN_SCALE : $oMap->web->minscale;
     $maxScale = $oMap->web->maxscale == -1 ? MAX_SCALE : $oMap->web->maxscale;
@@ -138,6 +146,15 @@
          $layer=$oMap->GetLayer($i);
          $layerObj = NULL;
+         $layerObj->metadata = NULL;
+         if (isset($_REQUEST['layer_metadata'])) {
+             $layerMetadataKeys = explode(',',$_REQUEST['layer_metadata']);
+             foreach($layerMetadataKeys as $key) {
+                 $layerObj->metadata->$key = $layer->getMetadata($key);
          $layerObj->propertyMappings = '';
          $layerObj->uniqueId = $i;
          $layerObj->layerName = $layer->name;
@@ -159,42 +176,42 @@
                 $type = 0;
          $layerObj->layerTypes = array($type);
          $displayInLegend = strtolower($layer->getMetaData('displayInLegend'));
          $layerObj->displayInLegend = $displayInLegend == 'false' ? false : true;
          $expandInLegend = strtolower($layer->getMetaData('expandInLegend'));
          $layerObj->expandInLegend = $expandInLegend == 'false' ? false : true;
          $layerObj->resourceId = $layer->name;
          $layerObj->parentGroup = $layer->group;
          $legendLabel = $layer->getMetaData('legendLabel');
          if ($legendLabel == '') {
              $legendLabel = $layer->name;
          $layerObj->legendLabel = $legendLabel;
          $selectable = strtolower($layer->getMetaData('selectable'));
          $layerObj->selectable = $selectable == 'true' ? true : false;
          $layerObj->visible = ($layer->status == MS_ON || $layer->status == MS_DEFAULT);
          $layerObj->actuallyVisible = true;
          $editable = strtolower($layer->getMetaData('editable'));
          $layerObj->editable = $editable == 'true' ? true : false;
-         /* process the classes.  The legend expects things
+         /* process the classes.  The legend expects things
           * organized by scale range so we have to first
           * find all the scale breaks, then create ranges
           * for each scale break pair, then slot the classes
           * into the scale ranges that they apply to.
          $aScaleRanges = array();
          //create a default scale range for the layer as a whole
          $layerMin = $layer->minscale == -1 ? $minScale : $layer->minscale;
          $layerMax = $layer->maxscale == -1 ? $maxScale : $layer->maxscale;
-         //find all the unique scale breaks in this layer
+         //find all the unique scale breaks in this layer
          $aScaleBreaks = array($layerMin, $layerMax);
          for ($j=0; $j<$layer->numclasses; $j++) {
              $oClass = $layer->getClass($j);
@@ -209,7 +226,7 @@
          //sort them
          sort($aScaleBreaks);
          //create scale ranges for each pair of breaks
          for ($j=0; $j<count($aScaleBreaks)-1; $j++) {
              $scaleRange = NULL;
@@ -218,7 +235,7 @@
              $scaleRange->styles = array();
              array_push($aScaleRanges, $scaleRange);
          //create classes and slot them into the scale breaks
@@ -239,7 +256,7 @@
          $layerObj->scaleRanges = $aScaleRanges;
          array_push($mapObj->layers, $layerObj);
     $mapObj->groups = array();
     $aGroups = $oMap->getAllGroupNames();
     foreach($aGroups as $groupName) {
@@ -268,7 +285,7 @@
     $b = $layer->getMetaData('groupVisible');
     $group->visible = ($b == 'false') ? false : true;
     $group->actuallyVisible = $layer->isVisible();
     return $group;
Modified: branches/fusion-1.0/MapServer/php/Measure.php
--- branches/fusion-1.0/MapServer/php/Measure.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapServer/php/Measure.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -52,7 +52,7 @@
       /*this already returns a meter*/
       $distance = distHaversine($x1,$y1, $x2,$y2);
     else
         $distance = sqrt (pow(($x2 - $x1),2) + pow(($y2 - $y1),2));
         /*convert to meter*/
         $distance = GetMetersPerUnit($oMap->units)*$distance;
Modified: branches/fusion-1.0/MapServer/php/Query.php
--- branches/fusion-1.0/MapServer/php/Query.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/MapServer/php/Query.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -81,8 +81,8 @@
     $oMap->loadquery(getSessionSavePath()."query.qry");
-$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
+$bComputedProperties = isset($_REQUEST['computed']) && strcasecmp($_REQUEST['computed'], 'true') == 0;
 $bAllLayers = false;
 $nLayers = count($layers);
 $nSelections = 0;
@@ -102,8 +102,9 @@
     $oLayer->set('tolerance', 0);
     if ($oLayer->type ==  MS_LAYER_RASTER || $oLayer->type == MS_LAYER_QUERY ||
-        $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART)
-      continue;
+        $oLayer->type ==  MS_LAYER_CIRCLE ||  $oLayer->type == MS_LAYER_CHART) {
+        continue;
     if (@$oLayer->queryByShape($oSpatialFilter) == MS_SUCCESS) {
@@ -123,8 +124,7 @@
 header('Content-type: text/x-json');
 header('X-JSON: true');
-if ($result->hasSelection)
+if ($result->hasSelection) {
     $oMap->savequery(getSessionSavePath()."query.qry");
     $result->queryFile = getSessionSavePath()."query.qry";
@@ -139,15 +139,13 @@
     $bFirstElement = 1;
     $nLayers = $oMap->numlayers;
-    for ($i=0; $i<$nLayers; $i++)
+    for ($i=0; $i<$nLayers; $i++) {
         $oLayer = $oMap->GetLayer($i);
         $numResults = $oLayer->getNumResults();
-        if ($numResults == 0)
+        if ($numResults == 0){
           continue;
         $oLayer->open();
         $layerName = $oLayer->name != "" ? $oLayer->name : "Layer_".$i;
         array_push($properties->layers, $layerName);
@@ -169,21 +167,70 @@
         $oRes = $oLayer->getResult(0);
         $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
         $selFields = array();
-        while ( list($key,$val) = each($oShape->values) )
-            array_push($selFields, $key);
+        if (isset($_SESSION[$mapName][$layerName]['query_items'])) {
+            $aQueryItems = $_SESSION[$mapName][$layerName]['query_items'];
+        } else {
+            //token separator (for parsing displayed attributes on a query)
+            $tokenSeparator = ",";
+            // checking if metadata "query_include_items" is set
+            $metadataItems = $oLayer->getMetaData('query_include_items');
+            if ( ($metadataItems == "") || ($metadataItems == "all") ) {
+                while ( list($key,$val) = each($oShape->values) ) {
+                    $aQueryItems[$key]  = NULL;
+            } else {
+              $token = strtok($metadataItems, $tokenSeparator);
+              while ($token !== false) {
+                  $aQueryItems[trim($token)] = NULL;
+                  $token = strtok($tokenSeparator);
+            // checking if metadata "query_exclude_items" is set
+            $metadataItems = $oLayer->getMetaData('query_exclude_items');
+            if ($metadataItems != "") {
+                    if (array_key_exists($token, $aQueryItems)) {
+                        unset($aQueryItems[$token]);
+            // get all alias
+            while ( list($key,$val) = each($aQueryItems) ) {
+                $keyAlias = $oLayer->getMetaData("query_".$key."_alias");
+                trim($keyAlias);
+                if ($keyAlias != "") {
+                    $aQueryItems[$key] = $keyAlias;
+            $_SESSION[$mapName][$layerName]['query_items'] = $aQueryItems;
+        $oShape = $oLayer->getShape($oRes->tileindex,$oRes->shapeindex);
+            if (array_key_exists($key, $aQueryItems)) {
+                array_push($selFields, $key);
-            array_push($properties->$layerName->propertynames, $key);
-            //TODO : we should define away to give alias to field names
-            array_push($properties->$layerName->propertyvalues, $key);
+                //we check if an alias if provided
+                if (isset($aQueryItems[$key]) && ($aQueryItems[$key] != "")){
+                    $key = $aQueryItems[$key];
-            //TODO we do not know the types of the attributes in MS. Just output 0
-            //we shouls possibly use OGR to get the attributes
-            array_push($properties->$layerName->propertytypes, 0);
+                array_push($properties->$layerName->propertynames, $key);
+                //TODO : we should define away to give alias to field names
+                array_push($properties->$layerName->propertyvalues, $key);
+                //TODO we do not know the types of the attributes in MS. Just output 0
+                //we shouls possibly use OGR to get the attributes
+                array_push($properties->$layerName->propertytypes, 0);
-        for ($iRes=0; $iRes < $numResults; $iRes++)
+        for ($iRes=0; $iRes < $numResults; $iRes++) {
             $properties->$layerName->values[$iRes] = array();
             $properties->$layerName->metadata[$iRes] = array();
@@ -195,25 +242,26 @@
             $maxx =  $oShape->bounds->maxx;
             $maxy =  $oShape->bounds->maxy;
-            if ($bFirstElement)
+            if ($bFirstElement) {
                 $bFirstElement = 0;
                 $totalminx =  $minx;
                 $totalminy =  $miny;
                 $totalmaxx =  $maxx;
                 $totalmaxy =  $maxy;
+            } else {
+                if ($totalminx > $minx) {
+                    $totalminx = $minx;
+                if ($totalminy > $miny) {
+                    $totalminy = $miny;
+                if ($totalmaxx < $maxx) {
+                    $totalmaxx = $maxx;
+                if ($totalmaxy < $maxy) {
+                    $totalmaxy = $maxy;
-            else
-                if ($totalminx > $minx)
-                  $totalminx = $minx;
-                if ($totalminy > $miny)
-                  $totalminy = $miny;
-                if ($totalmaxx < $maxx)
-                  $totalmaxx = $maxx;
-                if ($totalmaxy < $maxy)
-                  $totalmaxy = $maxy;
             //metadata : TODO dimension, area, length and distance are not set
             $dimension = 0;
@@ -229,8 +277,7 @@
             array_push($properties->$layerName->metadata[$iRes], $length);
             //field values
-            for($iField=0; $iField < count($selFields); $iField++)
+            for($iField=0; $iField < count($selFields); $iField++) {
                 $value = $oShape->values[$selFields[$iField]];
                 //$value = preg_replace( "/\r?\n/", "<br>", $value );
                 $value = str_replace("'", "\'", $value);
Modified: branches/fusion-1.0/common/php/Xml2JSON.php
--- branches/fusion-1.0/common/php/Xml2JSON.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/common/php/Xml2JSON.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -30,15 +30,32 @@
 if (isset($_FILES['xml'])) {
     $xml = file_get_contents($_FILES['xml']['tmp_name']);
-} else {
+} elseif (isset($_SERVER['HTTP_HOST'])) {
     $REQUEST_VARS = array_merge($_GET, $_POST);
     if (!isset($REQUEST_VARS['xml'])) {
         die('xml not set');
+    header('Content-type: text/plain');
+    header('X-JSON: true');
     $xml = rawurldecode ($REQUEST_VARS['xml']);
     $xml = str_replace('\"', '"', $xml);
+    $xml = str_replace('&quot;', "'", $xml);
+} elseif (isset($argv)) {
+    $cliArgs = arguments($argv);
+    if (isset($cliArgs['obj'])) {
+        $jsObject = $cliArgs['obj'];
+    } else {
+        $jsObject = "Fusion.appDefJson";
+    if (isset($cliArgs['file'])) {
+        $xml = file_get_contents($cliArgs['file']);
+        if (!$xml) {
+            die('file not found:'.$cliArgs['file']);
+        echo $jsObject."=";
+} else {
+    die('no XML input');
 //print_r($xml);
 $document = DOMDocument::loadXML($xml);
@@ -46,8 +63,5 @@
     die ('/* invalid xml document:'.$xml.' */');
 $root = $document->documentElement;
-header('Content-type: text/plain');
-header('X-JSON: true');
-echo '{"' . $root->tagName . '":' . xml2json($root) . '}';
+echo '{"' . $root->tagName . '":' . xml2json($root) . '};';
\ No newline at end of file
Modified: branches/fusion-1.0/config.json
--- branches/fusion-1.0/config.json	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/config.json	2008-05-08 15:34:30 UTC (rev 1396)
@@ -1,21 +1,21 @@
 /* This is the fusion configuration file.  Adjust as necessary. */
-    /* The general section contains settings that are general to
+    /* The general section contains settings that are general to
        fusion as a whole. */
     "general": {
-	    /* PHP is the default and only script language supported.
+	    /* PHP is the default and only script language supported.
 	       Don"t change this. */
 	    "scriptLanguage": "php",
 	    /* A directory on this system that fusion can use for
 	       temporary files. */
 	    "temporaryDirectory": "/tmp"
-    /* The MapGuide section is required if you are installing
+    /* The MapGuide section is required if you are installing
        fusion for MapGuide. */
     "mapguide": {
-	    /* The WebTierURL is the url to mapguide, it should start
-	       with http and end with /mapguide.  If you have installed
+	    /* The WebTierURL is the url to mapguide, it should start
+	       with http and end with /mapguide.  If you have installed
 	       fusion inside the www directory of MapGuide, then you can
 	       leave this empty as it will be automatically calculated. */
            "webTierUrl": ""
@@ -29,6 +29,9 @@
 	        web-accessible temporary images. */
 	    "imagePath": "/tmp/ms_tmp",
 	    /* The URL to the image path configured above. */
-	    "imageUrl": "http://localhost/tmp/ms_tmp"
+	    "imageUrl": "http://localhost/tmp/ms_tmp",
+	    /* The file system path to where mapserver should put
+	        web-accessible temporary legend images. */
+	    "legendIconCacheDir":"/tmp/ms_tmp"
Modified: branches/fusion-1.0/jx/lib/jx_combined.js
--- branches/fusion-1.0/jx/lib/jx_combined.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/jx/lib/jx_combined.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -8253,7 +8253,9 @@
             if (options.parentObj) {
                 $(options.parentObj).appendChild(this.blanket);
             } else {
-                document.body.appendChild(this.blanket);
+                document.body.appendChild(this.blanket);
+                var temp = new Jx.Layout(this.blanket);
+                temp.resize();
Modified: branches/fusion-1.0/lib/MGBroker.js
--- branches/fusion-1.0/lib/MGBroker.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/lib/MGBroker.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -144,7 +144,7 @@
     initializeRequest : function() {
         this.options = { method:'post' };
-        this.parameters = { version : '1.0.0', locale : Fusion.locale };
+        this.parameters = { version : '1.0.0', locale : Fusion.locale, clientagent : 'Fusion Viewer' };
@@ -597,11 +597,13 @@
      * @param maxFeatures {integer} number of maximum results (-1 to indicate no maximum)
      * @param selectionPersist {boolean} save the selection (valid values are 0 and 1)
      * @param selectionVariant {String} indicates the spatial operation. Valid values are 'INTERSECTS', ...
-     *@param layerNames {String} comma separated list of layer names to include in the query
+     * @param layerNames {String} comma separated list of layer names to include in the query
+     * @param layerAttributeFilter {integer} bitmask determining layer selection behaviour (1=visible layers,
+     *          2=selectable layers, 4=layers with tooltips)
      * @return {Object} an instance of Fusion.Lib.MGRequest.MGQueryMapFeatures
-    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames )
+    initialize : function( sessionId, mapName, geometry, maxFeatures, persist, selectionVariant, layerNames, layerAttributeFilter )
         this.initializeRequest();
         this.setParams( {
@@ -612,7 +614,8 @@
             maxFeatures: maxFeatures,
             persist: persist,
             selectionVariant: selectionVariant,
-            layerNames: layerNames
+            layerNames: layerNames,
+            layerAttributeFilter: layerAttributeFilter
Modified: branches/fusion-1.0/lib/Map.js
--- branches/fusion-1.0/lib/Map.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/lib/Map.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -640,8 +640,36 @@
         return (nPixels*resolution);
+     * initializes the meters per unit values when a new map is loaded.  Some systems make different
+     * assumptions for the conversion of degrees to meters so this makes sure both Fusion and
+     * OpenLayers are using the same value.
+     * @param metersPerUnit the value returned by LoadMap.php for meters per unit
+    setMetersPerUnit: function(metersPerUnit) {
+        if (this._fMetersperunit < 0) {
+            Fusion.initUnits(metersPerUnit);
+            this._fMetersperunit = metersPerUnit;
+        } else {
+            Fusion.reportError(new Fusion.Error(Fusion.Error.WARNING,
+                                'meters per unit value already set'));
+     * returns the meters per unit value
+     * @return metersPerUnit the value as set when the map initialized
+    getMetersPerUnit: function() {
+        return this._fMetersperunit;
      * convert geographic into pixels.
      * @param fGeo float distance in geographic units
@@ -705,7 +733,7 @@
-    return Math.round(this.oMapOL.getScale());
+        return this.oMapOL.getScale();
     getResolution : function() {
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/blank.gif
(Binary files differ)
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/blank.gif
___________________________________________________________________
   + application/octet-stream
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/editing_tool_bar.png
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/editing_tool_bar.png
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/overview_replacement.gif
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/overview_replacement.gif
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_off.png
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_off.png
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_on.png
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_next_on.png
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_off.png
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_off.png
Added: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_on.png
Property changes on: branches/fusion-1.0/lib/OpenLayers/theme/default/img/view_previous_on.png
Modified: branches/fusion-1.0/lib/fusion.js
--- branches/fusion-1.0/lib/fusion.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/lib/fusion.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -892,6 +892,49 @@
         return false;
+    initUnits: function(metersPerUnit) {
+        var eps = 1000;
+        if (Math.abs(metersPerUnit-Fusion.aMeterPerUnit[Fusion.DEGREES]) < eps){
+            Fusion.aMeterPerUnit[Fusion.DEGREES] = metersPerUnit;
+            Fusion.aMeterPerUnit[Fusion.DECIMALDEGREES] = metersPerUnit;
+            Fusion.aMeterPerUnit[Fusion.DMX] = metersPerUnit;
+            var inverse = 1.0/metersPerUnit;
+            Fusion.aUnitPerMeter[Fusion.DEGREES] = inverse;
+            Fusion.aUnitPerMeter[Fusion.DECIMALDEGREES] = inverse;
+            Fusion.aUnitPerMeter[Fusion.DMX] = inverse;
+            var inPerUnit = OpenLayers.INCHES_PER_UNIT.m * metersPerUnit;
+            OpenLayers.INCHES_PER_UNIT["dd"] = inPerUnit;
+            OpenLayers.INCHES_PER_UNIT["degrees"] = inPerUnit;
+     * find the OpenLayers units identifier given the Fusion metersPerUnit value
+    getClosestUnits: function(metersPerUnit) {
+        var units = "degrees";
+        var minDiff = 100000000;
+        for (var key in OpenLayers.INCHES_PER_UNIT) {
+            var newDiff = Math.abs((metersPerUnit * 39.3701) - OpenLayers.INCHES_PER_UNIT[key]);
+            if(newDiff < minDiff)
+                minDiff = newDiff;
+                units = key;
+        return units;
     addWidgetStyleSheet: function(url) {
         var lnk = document.createElement('link');
Modified: branches/fusion-1.0/templates/mapguide/standard/ApplicationDefinition.xml
--- branches/fusion-1.0/templates/mapguide/standard/ApplicationDefinition.xml	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/templates/mapguide/standard/ApplicationDefinition.xml	2008-05-08 15:34:30 UTC (rev 1396)
@@ -277,6 +277,19 @@
       </Item>
     </Container>
+<!-- MAP -->
+    <MapWidget xsi:type="WidgetType">
+      <Name>Map</Name>
+      <Type>Map</Type>
+      <StatusItem>The map.</StatusItem>
+      <Extension xsi:type="CustomContentType">
+        <MenuContainer>MapContextMenu</MenuContainer>
+        <Scales>2000000 1000000 500000 250000 125000 50000</Scales>
+      </Extension>
+      <MapId>sheboygan</MapId>
+    </MapWidget>
 * Context Menu - Widgets
@@ -467,6 +480,13 @@
       <Name>menuSelectRadius</Name>
       <Type>SelectRadius</Type>
       <StatusItem>Click and drag to select all features inside a circle.</StatusItem>
+        <QueryActiveLayer>true</QueryActiveLayer>
+        <RadiusTooltipContainer>RadiusTip</RadiusTooltipContainer>
+        <RadiusTooltipType>Dynamic</RadiusTooltipType>
+        <DefaultRadius>5</DefaultRadius>
+        <Tolerance>1</Tolerance>
+      </Extension>
       <ImageUrl>images/icons/select-radius.png</ImageUrl>
       <ImageClass/>
       <Tooltip>Select Radius</Tooltip>
@@ -972,18 +992,6 @@
       <Disabled/>
     </Widget>
-<!-- MAP -->
-    <MapWidget xsi:type="WidgetType">
-      <Name>Map</Name>
-      <Type>Map</Type>
-      <StatusItem>The map.</StatusItem>
-      <Extension xsi:type="CustomContentType">
-        <MenuContainer>MapContextMenu</MenuContainer>
-      </Extension>
-      <MapId>sheboygan</MapId>
-    </MapWidget>
 <!-- OVERVIEW MAP -->
     <Widget xsi:type="WidgetType">
@@ -1029,8 +1037,18 @@
       <Disabled/>
     </Widget>
-    </WidgetSet>
+    <Widget xsi:type="WidgetType">
+      <Name>MapTip</Name>
+      <Type>Maptip</Type>
+      <Extension>
+        <Label>Map Tips</Label>
+        <Delay>350</Delay>
+        <Layer>Parcels</Layer>
+      </Extension>
+    </Widget>
+  </WidgetSet>
   <Extension/>
 </ApplicationDefinition>
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_bg.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_bg.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_b.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_b.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_bl.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_bl.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_br.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_br.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_l.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_l.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_r.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_r.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_t.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_t.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tl.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tl.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tr.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_glow_tr.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/dialog_resize.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/dialog_resize.png
Added: branches/fusion-1.0/templates/mapguide/standard/images/icon_close.png
Property changes on: branches/fusion-1.0/templates/mapguide/standard/images/icon_close.png
Modified: branches/fusion-1.0/templates/mapguide/standard/index.html
--- branches/fusion-1.0/templates/mapguide/standard/index.html	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/templates/mapguide/standard/index.html	2008-05-08 15:34:30 UTC (rev 1396)
@@ -14,6 +14,10 @@
         background-color: #999;
         cursor: 'col-resize';
+    body {
+      overflow: hidden;
     #Toolbar .jxToolbar {
         /*width: 100%;*/
@@ -128,6 +132,8 @@
   <div id="TaskPane"></div>
   <div id="Statusbar"></div>
+  <div id="MapTip"></div>
+  <div id="RadiusTip"></div>
   <div id="PoweredBy" class="statusBarItem">
     <a href="http://mapserver.gis.umn.edu.org/" target="_blank">
       <img src="images/PoweredBy_MapServer.gif" width="137" height="18" border="0">
Modified: branches/fusion-1.0/widgets/BufferPanel/Buffer.php
--- branches/fusion-1.0/widgets/BufferPanel/Buffer.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/BufferPanel/Buffer.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -282,9 +282,8 @@
                 while($features->ReadNext());
-                $features->Close();
+            $features->Close();
         if($merge)
Modified: branches/fusion-1.0/widgets/CenterSelection.js
--- branches/fusion-1.0/widgets/CenterSelection.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/CenterSelection.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -61,12 +61,13 @@
      * @param selection the active selection, or null if there is none
     centerSelection : function(selection) {
-        var extents = this.getMap().getCurrentExtents();
+        var map = this.getMap();
+        var extents = map.getCurrentExtents();
         var curWidth = extents[2] - extents[0];
         var curHeight = extents[3] - extents[1];
-        var ll = selection.getLowerLeftCoord();
-        var ur = selection.getUpperRightCoord();
+        var ll = selection[map.getMapName()].getLowerLeftCoord();
+        var ur = selection[map.getMapName()].getUpperRightCoord();
         var newWidth = ur.x - ll.x;
         var newHeight = ur.y - ll.y;
@@ -74,14 +75,14 @@
         if (newWidth < curWidth && newHeight < curHeight) {
             var cx = (ur.x + ll.x) / 2;
             var cy = (ur.y + ll.y) / 2;
-            this.getMap().zoom(cx,cy,1);
+            map.zoom(cx,cy,1);
         } else {
             var buffer = 0.1;
             var minx = ll.x-newWidth*buffer;
             var miny = ll.y-newHeight*buffer;
             var maxx = ur.x+newWidth*buffer;
             var maxy = ur.y+newHeight*buffer;
-            this.getMap().setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
+            map.setExtents(new OpenLayers.Bounds(minx,miny,maxx,maxy));
Modified: branches/fusion-1.0/widgets/CursorPosition.js
--- branches/fusion-1.0/widgets/CursorPosition.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/CursorPosition.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -111,8 +111,9 @@
             p = map.pixToGeo(p.x, p.y);
             if (p) {
                 if (this.units != Fusion.UNKNOWN) {
-                    p.x = Fusion.fromMeter(this.units, p.x * map._fMetersperunit);
-                    p.y = Fusion.fromMeter(this.units, p.y * map._fMetersperunit);
+                    var convFactor = map.getMetersPerUnit();
+                    p.x = Fusion.fromMeter(this.units, p.x * convFactor);
+                    p.y = Fusion.fromMeter(this.units, p.y * convFactor);
                 if (this.precision >= 0) {
                     var factor = Math.pow(10,this.precision);
@@ -123,7 +124,6 @@
         if (p) {
             var unitAbbr = Fusion.unitAbbr(this.units);
             this.domSpan.innerHTML = this.template.replace('{x}',p.x).replace('{y}',p.y).replace('{units}', unitAbbr).replace('{units}', unitAbbr);
Modified: branches/fusion-1.0/widgets/MapMenu.js
--- branches/fusion-1.0/widgets/MapMenu.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/MapMenu.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -36,6 +36,7 @@
     domObj: null,
     oMenu: null,
+    mapGroupData: null,
     sRootFolder: '',
     aMenus : null,
     initialize : function(widgetTag)
@@ -46,15 +47,26 @@
         this.enable();
         var json = widgetTag.extension;
+        //If no folder is specified for enumeration, build a menu
+        //from the mapgroup alone. Folders are only supported with MapGuide.
+        //Otherwise, create a hash of mapgroup resourceId to mapGroup data
+        //to be used to assign mapgroup extensions to enumerated maps.
         var mapGroups = Fusion.applicationDefinition.mapGroups;
+        this.mapGroupData = {};
         for (var i=0; i<mapGroups.length; i++) {
             var mapGroup = mapGroups[i];
-            var opt = {};
-            opt.label = mapGroup.mapId;
-            var data = mapGroup;
-            var action = new Jx.Action(this.switchMap.bind(this, data));
-            var menuItem = new Jx.MenuItem(action,opt);
-            this.oMenu.add(menuItem);
+            if (json.Folder) {
+                this.mapGroupData[mapGroup.maps[0].resourceId] = mapGroup;
+            } else {
+                var opt = {};
+                opt.label = mapGroup.mapId;
+                var data = mapGroup;
+                var action = new Jx.Action(this.switchMap.bind(this, data));
+                var menuItem = new Jx.MenuItem(action,opt);
+                this.oMenu.add(menuItem);
         //get the mapdefinitions as xml if there  is a folder specified
@@ -82,17 +94,32 @@
                 var sId = mapNode.getNodeText('ResourceId');
                 var sPath = sId.replace(this.sRootFolder, '');
-                sPath = sPath.slice(0, sPath.lastIndexOf('/'));
-                this.createFolders(sPath);
+                if (sPath.lastIndexOf('/') > -1) {
+                    sPath = sPath.slice(0, sPath.lastIndexOf('/'));
+                    this.createFolders(sPath);
+                } else {
+                    sPath = '';
                 var opt = {};
                 opt.label = mapNode.getNodeText('Name');
+                // check for mapgroup data and if there is none,
                 // create a maptag that will be passed to the map
-                // widget constructor
-                var data = {maps:[{'resourceId':mapNode.getNodeText('ResourceId'),
+                // widget constructor
+                var data = null;
+                if (this.mapGroupData[mapNode.getNodeText('ResourceId')]) {
+                    data = this.mapGroupData[mapNode.getNodeText('ResourceId')];
+                } else {
+                    data = {maps:[{'resourceId':mapNode.getNodeText('ResourceId'),
                             'singleTile':true,
                             'type': this.arch,
                             'extension':{'ResourceId': [mapNode.getNodeText('ResourceId')]}
+                    //set up needed accessor
+                    data.getInitialView = function() {
+                        return this.initialView;
@@ -133,7 +160,14 @@
         this.oMenu.show();
+    //change the map, preserving current extents
     switchMap: function(data) {
+        var ce = this.getMap().getCurrentExtents();
+        data.initialView = {minX:ce.left,
+                            minY:ce.bottom,
+                            maxX:ce.right,
+                            maxY:ce.top
         this.getMap().loadMapGroup(data);
Modified: branches/fusion-1.0/widgets/Maptip.js
--- branches/fusion-1.0/widgets/Maptip.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/Maptip.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -157,15 +157,17 @@
         var maxFeatures = 1;
         var persist = 0;
+        // only select visible layers with maptips defined (1+4)
+        var layerAttributeFilter = 5;
         var maps = this.getMap().getAllMaps();
         //TODO: possibly make the layer names configurable?
         var layerNames = this.aLayers.toString();
         var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(maps[0].getSessionID(),
                                         maps[0]._sMapname,
                                         sGeometry,
-        oBroker.dispatchRequest(r,
-        this._display.bind(this));
+        oBroker.dispatchRequest(r, this._display.bind(this));
     _display: function(r) {
@@ -229,7 +231,7 @@
       //console.log('maptip _hide');
         this.hideTimer = null;
         this.domObj.style.display = 'none';
-        this.oMapTipPosition = null;
+        //this.oMapTipPosition = null;
     mouseOverTip: function() {
Modified: branches/fusion-1.0/widgets/Measure.js
--- branches/fusion-1.0/widgets/Measure.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/Measure.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -84,7 +84,6 @@
         this.asCursor = ['crosshair'];
         this.units = (json.Units && (json.Units[0] != '')) ?  Fusion.unitFromName(json.Units[0]): this.units;
         this.distPrecision = json.DistancePrecision ? parseInt(json.DistancePrecision[0]) : 4;
         this.areaPrecision = json.AreaPrecision ? parseInt(json.AreaPrecision[0]) : 4;
@@ -397,7 +396,7 @@
               //var mapUnits = Fusion.unitFromName(this.getMap().getUnits());
               //if (mapUnits == Fusion.DEGREES || Fusion.DECIMALDEGREES)
               mapUnits = Fusion.METERS;
               if (mapUnits != this.units) {
                 o.distance = Fusion.convert(mapUnits, this.units, o.distance);
@@ -415,11 +414,11 @@
     updateDisplay: function(outputWin) {
         var outputDoc = outputWin.document;
         var tbody = outputDoc.getElementById('segmentTBody');
+        var value;
         if (tbody) {
             this.clearDisplay(outputWin);
             var totalDistance = 0;
             var units = Fusion.unitAbbr(this.units);
-            var value;
             for (var i=0; i<this.distanceMarkers.length; i++) {
                 var distance = this.distanceMarkers[i].getDistance();
                 totalDistance += distance;
@@ -500,6 +499,7 @@
     setParameter: function(param, value) {
+      //console.log('setParameter: ' + param + ' = ' + value);
         if (param == 'Units') {
             this.units = Fusion.unitFromName(value);
@@ -557,7 +557,7 @@
           value = this.distance.toPrecision(this.precision);
-      return this.label + ' ' + value + ' ' + this.unitAbbr;
+      return this.label + ' ' + value + ' ' + this.unitAbbr;
     setDistance: function(distance) {
Modified: branches/fusion-1.0/widgets/Print/printablepage.templ
--- branches/fusion-1.0/widgets/Print/printablepage.templ	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/Print/printablepage.templ	2008-05-08 15:34:30 UTC (rev 1396)
@@ -15,6 +15,7 @@
     var msie = agent.indexOf("msie") != -1;
     var safari = agent.indexOf("safari") != -1;
     var firefox = agent.indexOf("firefox") != -1;
+    var clientAgent = "Fusion Viewer";
     var webAgent = '%s';
     var scale = %s;
@@ -38,7 +39,7 @@
             var legendElt = document.getElementById("Legend");
             legendElt.style.width = "180px";
-            legendElt.innerHTML = "<img id=\"legendImage\" width=\"180\" height=\"" + mapHeight + "\" src=\"" + webAgent + "?OPERATION=GETMAPLEGENDIMAGE&VERSION=1.0.0&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&WIDTH=180&HEIGHT=" + mapHeight + "&FORMAT=PNG\" style=\"visibility: hidden\" onload=\"OnImageLoaded('legendImage');\">";
+            legendElt.innerHTML = "<img id=\"legendImage\" width=\"180\" height=\"" + mapHeight + "\" src=\"" + webAgent + "?OPERATION=GETMAPLEGENDIMAGE&VERSION=1.0.0&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&CLIENTAGENT=" + encodeURIComponent(clientAgent) + "&WIDTH=180&HEIGHT=" + mapHeight + "&FORMAT=PNG\" style=\"visibility: hidden\" onload=\"OnImageLoaded('legendImage');\">";
         else
             mapWidth += 180;
@@ -49,7 +50,7 @@
             document.getElementById("ScaleAndArrow").style.height = "0px";
-        var imgReq = webAgent + "?OPERATION=GETMAPIMAGE&VERSION=1.0.0&FORMAT=PNG&LOCALE="+locale+"&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&SETDISPLAYWIDTH=" + mapWidth + "&SETDISPLAYHEIGHT=" + mapHeight + "&SETDISPLAYDPI=" + dpi + "&SETVIEWSCALE=" + scale + "&SETVIEWCENTERX=" + centerX + "&SETVIEWCENTERY=" + centerY + "&SEQ=" + Math.random();
+        var imgReq = webAgent + "?OPERATION=GETMAPIMAGE&VERSION=1.0.0&FORMAT=PNG&LOCALE="+locale+"&MAPNAME=" + encodeURIComponent(mapName) + "&SESSION=" + sessionId + "&SETDISPLAYWIDTH=" + mapWidth + "&SETDISPLAYHEIGHT=" + mapHeight + "&SETDISPLAYDPI=" + dpi + "&SETVIEWSCALE=" + scale + "&SETVIEWCENTERX=" + centerX + "&SETVIEWCENTERY=" + centerY + "&SEQ=" + Math.random() + "&CLIENTAGENT=" + encodeURIComponent(clientAgent);
         var mapElt = document.getElementById("Map");
         mapElt.style.width = mapWidth + "px";
Modified: branches/fusion-1.0/widgets/SaveMap.js
--- branches/fusion-1.0/widgets/SaveMap.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/SaveMap.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -43,26 +43,67 @@
     iframe : null,
     printLayout : null,
     printScale : null,
+    imageWidth : null,
+    imageHeight : null,
     initialize : function(widgetTag) {
         Object.inheritFrom(this, Fusion.Widget.prototype, [widgetTag, false]);
-        Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
         this.format = (json.Format && json.Format[0] != '')?
                        json.Format[0] : 'png';
         //for DWF, parse printLayouts and build menu
-        if (this.format == 'DWF') {
-            if (json.ResourceId) {
-                this.printLayout = json.ResourceId[0];
-                if (json.Scale) {
-                    this.printScale =  json.Scale[0];
-            } else {
-                //TODO: Warning that the widget is improperly configured
-                //because we need  print layout for this to work.
-                //TODO: deactivate the widget?
+        if (this.format == 'DWF' && json.PrintLayout.length) {
+            Object.inheritFrom(this, Fusion.Tool.MenuBase.prototype, []);
+            var layouts = json.PrintLayout;
+            for (var i = 0; i < layouts.length; i++) {
+                var layout = layouts[i];
+                var opt = {};
+                opt.label = layout.Name[0];
+                var data = {rid:layout.ResourceId[0]};
+                if (layout.PageHeight) {
+                    data.pageHeight = layout.PageHeight[0];
+                if (layout.PageWidth) {
+                    data.pageWidth = layout.PageWidth[0];
+                if (layout.Margins) {
+                    data.margins = [layout.Margins[0].Top[0],
+                                    layout.Margins[0].Left[0],
+                                    layout.Margins[0].Right[0],
+                                    layout.Margins[0].Bottom[0]];
+                var menuItem = null;
+                if (layout.Scale) {
+                    //create entries for weblayout specified scales
+                    menuItem = new Jx.SubMenu(opt);
+                    for (var j=0; j < layout.Scale.length; j++) {
+                        data.scale = layout.Scale[j];
+                        var scaleAction = new Jx.Action(this.setLayout.bind(this, data));
+                        var subMenuItem = new Jx.MenuItem(scaleAction,{label:data.scale});
+                        menuItem.add(subMenuItem);
+                    //add an entry for current scale
+                    var currentScaleAction = new Jx.Action(this.setLayout.bind(this, data));
+                    var currentScaleItem = new Jx.MenuItem(currentScaleAction,
+                                                         {label:'Current Scale'});
+                    menuItem.add(currentScaleItem);
+                } else {
+                    //if there are no scales, the layout is used with current scale
+                    var action = new Jx.Action(this.setLayout.bind(this, data));
+                    menuItem = new Jx.MenuItem(action,opt);
+        } else {
+            Object.inheritFrom(this, Fusion.Tool.ButtonBase.prototype, []);
+            if (json.Width && json.Width[0] != '') {
+                this.imageWidth = json.Width[0];
+            if (json.Height && json.Height[0] != '') {
+                this.imageHeight = json.Height[0];
         this.enable = Fusion.Widget.SaveMap.prototype.enable;
@@ -72,6 +113,16 @@
         Fusion.Tool.ButtonBase.prototype.enable.apply(this, []);
+    setLayout: function(data) {
+        this.printScale = data.scale;
+        this.printLayout = data.rid;
+        this.pageHeight = data.pageHeight;
+        this.pageWidth = data.pageWidth;
+        this.pageMargins = data.margins;
+        this.activateTool();
      * called when the button is clicked by the Fusion.Tool.ButtonBase widget
      * prompts user to save the map.
@@ -85,28 +136,43 @@
         var szLayout = '';
         var szScale = '';
+        var szPageHeight = '';
+        var szPageWidth = '';
+        var szPageMargins = '';
         if (this.format === 'DWF') {
             if (this.printLayout) {
                 szLayout = '&layout=' + this.printLayout;
             } else {
-                //TODO: issue an error?
+                alert('DWF Save is not properly configured.');
                 return;
             if (this.printScale) {
                 szScale = '&scale=' + this.printScale;
+            if (this.pageHeight) {
+                szPageHeight = '&pageheight=' + this.pageHeight;
+            if (this.pageWidth) {
+                szPageWidth = '&pagewidth=' + this.pageWidth;
+            if (this.pageMargins) {
+                szPageMargins = '&margins=' + this.pageMargins.join(',');
-        //TODO: revisit Fusion.getWebAgentURL
-		var m = this.getMap().aMaps[0];
+        var szHeight = '';
+        if (this.imageHeight) {
+            szHeight = '&height=' + this.imageHeight;
+        var szWidth = '';
+        if (this.imageWidth) {
+            szWidth = '&width=' + this.imageWidth;
+        var m = this.getMap().aMaps[0];
         if(navigator.appVersion.match(/\bMSIE\b/)) {
-            //var url = Fusion.getWebAgentURL() + "OPERATION=GETDYNAMICMAPOVERLAYIMAGE&FORMAT=PNG&VERSION=1.0.0&SESSION=" + this.getMap().getSessionID() + "&MAPNAME=" + this.getMap().getMapName() + "&SEQ=" + Math.random();
-            var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout;
-            //this.iframe.src = url;
+            var url = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMapFrame." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             w = open(url, "Save", 'menubar=no,height=200,width=300');
         } else {
-            var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout;
-            //console.log(s);
+            var s = Fusion.fusionURL + '/' + m.arch + '/' + Fusion.getScriptLanguage() + "/SaveMap." + Fusion.getScriptLanguage() + '?session='+m.getSessionID() + '&mapname=' + m.getMapName() + '&format=' + this.format + szLayout + szWidth + szHeight + szPageHeight + szPageWidth + szPageMargins;
             this.iframe.src = s;
Modified: branches/fusion-1.0/widgets/Search/Search.php
--- branches/fusion-1.0/widgets/Search/Search.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/Search/Search.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -228,10 +228,20 @@
     catch(MgException $ae)
+        if($features)
+            // Close the feature reader
         OnError($searchError, $ae->GetDetails());
     catch(SearchError $e)
+        if($features)
         OnError($e->title, $e->getMessage());
Modified: branches/fusion-1.0/widgets/SelectRadiusValue.js
--- branches/fusion-1.0/widgets/SelectRadiusValue.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/SelectRadiusValue.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -47,15 +47,16 @@
         this.label = json.Label ? json.Label[0] : '';
         this.className = json.ClassName ? json.ClassName[0] : '';
-        /* a container for the widget */
-        //this.domObj = document.createElement('div');
-        //this.domObj.className = this.className;
+        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, this.mapLoaded.bind(this));
+        this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.mapExtentsChanged.bind(this));
+    draw: function() {
         /* put in the label */
+        var units = this.getMap().getAllMaps()[0].units;
         this.domLabel = document.createElement('label');
         this.domLabel.className = this.className;
-        this.domLabel.innerHTML = this.label;
-        //this.domObj.appendChild(label);
+        this.domLabel.innerHTML = this.label + '(' + units + ')';
         /* put in the input */
         this.input = document.createElement('input');
@@ -65,21 +66,32 @@
         /* put into page */
         this.domObj.appendChild(this.domLabel);
         Event.observe(this.input, 'blur', this.onBlur.bind(this));
-        this.getMap().registerForEvent(Fusion.Event.MAP_LOADED, this.mapLoaded.bind(this));
-        this.getMap().registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED, this.mapExtentsChanged.bind(this));
     mapLoaded: function() {
+        this.draw();
+        this.input.disabled = true;
         var widgets = Fusion.getWidgetsByType('SelectRadius');
         for (var i=0; i<widgets.length; i++) {
-            if (widgets[i].sName == this.radiusWidgetName) {
+            if (widgets[i].widgetTag.name == this.radiusWidgetName) {
                 this.widget = widgets[i];
+                this.widget.registerForEvent(Fusion.Event.RADIUS_WIDGET_ACTIVATED, this.dependantEnable.bind(this));
+                break;
         this.updateFromWidgetValue();
+    dependantEnable: function(eventId, active) {
+        if (this.widget) {
+            if (active) {
+                this.input.disabled = false;
+            } else {
     mapExtentsChanged: function() {
         this.updateWidgetValue();
@@ -90,14 +102,14 @@
     updateWidgetValue: function() {
         if (this.widget) {
-            var radius = this.getMap().geoToPixMeasure(this.input.getValue());
+            var radius = this.input.getValue();
             this.widget.setRadius(radius);
     updateFromWidgetValue: function() {
         if (this.widget) {
-            this.input.value = this.getMap().pixToGeoMeasure(this.widget.getRadius());
+            this.input.value = this.widget.getRadius();
Modified: branches/fusion-1.0/widgets/SelectWithin/SelectWithin.php
--- branches/fusion-1.0/widgets/SelectWithin/SelectWithin.php	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/SelectWithin/SelectWithin.php	2008-05-08 15:34:30 UTC (rev 1396)
@@ -173,6 +173,7 @@
                 $geomColl->Add($geom);
     if($geomColl->GetCount() == 0)
Modified: branches/fusion-1.0/widgets/SelectWithin/SelectWithinPanel.templ
--- branches/fusion-1.0/widgets/SelectWithin/SelectWithinPanel.templ	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/SelectWithin/SelectWithinPanel.templ	2008-05-08 15:34:30 UTC (rev 1396)
@@ -40,6 +40,7 @@
 var mapName = '%s';
 var sessionId = '%s';
+var zoomTo = false;
 function InitDocument()
@@ -83,11 +84,25 @@
     var mapWidget = GetParent().Fusion.getMapByName(mapName);
     var map = mapWidget.aMaps[0];
-    var params = "mapname=" + encodeURIComponent(mapName) + "&session=" + sessionId + "&layers=" + encodeURIComponent(layerSet);
-    var options = {onSuccess: map.processQueryResults.bind(map), onFailure: selectedError, parameters:params};
+    var params = {
+      "mapname": encodeURIComponent(mapName),
+      "session": sessionId,
+      "layers": encodeURIComponent(layerSet)
+    var options = {
+      onSuccess: selectedSuccess,
+      onFailure: selectedError,
+      parameters:params
     GetParent().Fusion.ajaxRequest(webAgent, options);
+function selectedSuccess(r) {
+    var mapWidget = GetParent().Fusion.getMapByName(mapName);
+    var map = mapWidget.aMaps[0];
+    map.processQueryResults(zoomTo, r);
 function selectedError(r) {
     alert(r.responseText);
Modified: branches/fusion-1.0/widgets/ViewSize.js
--- branches/fusion-1.0/widgets/ViewSize.js	2008-05-07 18:38:38 UTC (rev 1395)
+++ branches/fusion-1.0/widgets/ViewSize.js	2008-05-08 15:34:30 UTC (rev 1396)
@@ -67,8 +67,9 @@
             var gw = map.pixToGeoMeasure(p.w);
             var gh = map.pixToGeoMeasure(p.h);
-                gw = Fusion.fromMeter(this.units, gw * map._fMetersperunit);
-                gh = Fusion.fromMeter(this.units, gh * map._fMetersperunit);
+                gw = Fusion.fromMeter(this.units, gw * convFactor);
+                gh = Fusion.fromMeter(this.units, gh * convFactor);
More information about the fusion-commits mailing list
