[fusion-commits] r1409 - in trunk: MapServer/php common/php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Thu May 15 16:21:20 EDT 2008
Author: madair
Date: 2008-05-15 16:21:20 -0400 (Thu, 15 May 2008)
New Revision: 1409
   trunk/MapServer/php/LegendIcon.php
   trunk/common/php/Utilities.php
closes #66: remove config loading code from LegendIcon.php
Modified: trunk/MapServer/php/LegendIcon.php
--- trunk/MapServer/php/LegendIcon.php	2008-05-15 20:16:20 UTC (rev 1408)
+++ trunk/MapServer/php/LegendIcon.php	2008-05-15 20:21:20 UTC (rev 1409)
@@ -37,55 +37,37 @@
 $legendIconCacheFile = "";
 if (isset($_SESSION['maps']) && isset($_SESSION['maps'][$mapName])) {
-    /* json decode only in PHP 5.2 and later */
-    if (function_exists('json_decode')) {
-        $configFile = realpath(dirname(__FILE__)."/../../config.json");
-        if (file_exists($configFile)) {
-            $configStr = file_get_contents($configFile);
-            /* replace single quotes with double quotes */
-            $configStr = str_replace("'", '"', $configStr);
-            /* get rid of new lines, it just complicates things */
-            $configStr = str_replace("\n", '', $configStr);
-            /* get rid of embedded comments */
-            $configStr = preg_replace("/\/\*.*\*\//U", "", $configStr);
-            /* the regex after this one can't handle http: as a value, so mangle it. */
-            $configStr = preg_replace("/http:/U", "http_", $configStr);
-            /* quote unquoted attribute names */
-            $configStr = preg_replace("/[^\"]{1}(\w*):/U", "\"$1\":", $configStr);
-            /* decode the whole thing */
-            $configObj = json_decode($configStr, false);
-            /* if the legendIconCache dir is set */
-            if (isset($configObj->mapserver->legendIconCacheDir)) {
-              $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
+      $configObj = $_SESSION['fusionConfig'];
+      /* if the legendIconCache dir is set */
+      if (isset($configObj->mapserver->legendIconCacheDir)) {
+        $legendIconCacheDir = $configObj->mapserver->legendIconCacheDir;
-              // check for closing '/'
-              $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
-              if ( substr( $legendIconCacheDir, -1 ) != '/' )
-                  $legendIconCacheDir .= '/';
+        // check for closing '/'
+        $legendIconCacheDir = str_replace( '\\', '/', trim( $legendIconCacheDir ) );
+        if ( substr( $legendIconCacheDir, -1 ) != '/' )
+            $legendIconCacheDir .= '/';
-              $cacheLegendIcons = true;
-              $str = file_get_contents($_SESSION['maps'][$mapName]);
-              /* create a unique location for the map icons based on
-               * the content of the of map file.  If the content changes
-               * then the icons should be rebuilt anyway
-              $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
-              if (!is_dir($legendIconCacheDir)) {
-                mkdir($legendIconCacheDir);
-              /* TODO: can we figure out what the content type is? */
-              $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
-              /* if the icon exists, return it */
-              if (file_exists($legendIconCacheFile)) {
-                  header('Content-type: image/png');
-                  readfile($legendIconCacheFile);
-                  exit;
+        $cacheLegendIcons = true;
+        $str = file_get_contents($_SESSION['maps'][$mapName]);
+        /* create a unique location for the map icons based on
+         * the content of the of map file.  If the content changes
+         * then the icons should be rebuilt anyway
+        $legendIconCacheDir = $legendIconCacheDir.md5($str)."/";
+        if (!is_dir($legendIconCacheDir)) {
+          mkdir($legendIconCacheDir);
+        /* TODO: can we figure out what the content type is? */
+        $legendIconCacheFile = $legendIconCacheDir."_".$REQUEST_VARS['layername']."_".$REQUEST_VARS['classindex'].".png";
+        /* if the icon exists, return it */
+        if (file_exists($legendIconCacheFile)) {
+            header('Content-type: image/png');
+            readfile($legendIconCacheFile);
+            exit;
     $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
Modified: trunk/common/php/Utilities.php
--- trunk/common/php/Utilities.php	2008-05-15 20:16:20 UTC (rev 1408)
+++ trunk/common/php/Utilities.php	2008-05-15 20:21:20 UTC (rev 1409)
@@ -261,6 +261,7 @@
 function loadFusionConfig() {
+    /* json decode only in PHP 5.2 and later */
More information about the fusion-commits mailing list
