[fusion-commits] r1412 - in trunk: MapGuide lib
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon May 26 14:52:23 EDT 2008
Author: madair
Date: 2008-05-26 14:52:23 -0400 (Mon, 26 May 2008)
New Revision: 1412
   trunk/MapGuide/MapGuide.js
   trunk/lib/Map.js
re #63: further refactoring of map.zoom() method
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js	2008-05-26 18:50:35 UTC (rev 1411)
+++ trunk/MapGuide/MapGuide.js	2008-05-26 18:52:23 UTC (rev 1412)
@@ -469,7 +469,7 @@
      * Returns an OpenLayers MapGuide layer object
-    createOLLayer: function(layerName, bIsBaseLayer, bSingleTile, bFractionalZoom) {
+    createOLLayer: function(layerName, bIsBaseLayer, bSingleTile) {
       var layerOptions = {
         units : this.units,
         isBaseLayer : bIsBaseLayer,
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2008-05-26 18:50:35 UTC (rev 1411)
+++ trunk/lib/Map.js	2008-05-26 18:52:23 UTC (rev 1412)
@@ -87,13 +87,13 @@
         if (widgetTag.extension.FractionalZoom) {
-          this.bFractionalZoom = widgetTag.extension.FractionalZoom[0]=='false'?false:true;
+          this.fractionalZoom = widgetTag.extension.FractionalZoom[0]=='false'?false:true;
         var scalesArray = null;
         if (widgetTag.extension.Scales) {
           scalesArray = widgetTag.extension.Scales[0].split(',');
-          this.bFractionalZoom = false;
+          this.fractionalZoom = false;
         OpenLayers.DOTS_PER_INCH = this._nDpi;
@@ -102,7 +102,7 @@
                 controls: [],
                 fallThrough: true,
                 scales: scalesArray,
-                fractionalZoom: this.bFractionalZoom
+                fractionalZoom: this.fractionalZoom
             if (widgetTag.extension.ConstrainMapExtent) {
               this.bRestrictExtent = widgetTag.extension.ConstrainMapExtent[0]=='true'?true:false;
@@ -561,42 +561,38 @@
     zoom : function(fX, fY, nFactor) {
         //do this differntly with OL code??
-        var extent = this.oMapOL.getExtent();
-        if (this.fractionalZoom) {
-            var fDeltaX = extent.right - extent.left;
-            var fDeltaY = extent.top - extent.bottom;
-            var fMinX,fMaxX,fMinY,fMaxY;
-            if (nFactor == 1 || nFactor == 0) {
-                /*recenter*/
-                fMinX = fX - (fDeltaX/2);
-                fMaxX = fX + (fDeltaX/2);
-                fMinY = fY - (fDeltaY/2);
-                fMaxY = fY + (fDeltaY/2);
-            } else if (nFactor > 0) {
-                /*zoomin*/
-                fMinX = fX - (fDeltaX/2 / nFactor);
-                fMaxX = fX + (fDeltaX/2 / nFactor);
-                fMinY = fY - (fDeltaY/2 / nFactor);
-                fMaxY = fY + (fDeltaY/2 / nFactor);
-            } else if (nFactor < 0) {
-                /*zoomout*/
-                fMinX = fX - ((fDeltaX/2) * Math.abs(nFactor));
-                fMaxX = fX + ((fDeltaX/2) * Math.abs(nFactor));
-                fMinY = fY - ((fDeltaY/2) * Math.abs(nFactor));
-                fMaxY = fY + ((fDeltaY/2) * Math.abs(nFactor));
-            this.setExtents(new OpenLayers.Bounds(fMinX, fMinY, fMaxX, fMaxY));
+        if (nFactor == 1 || nFactor == 0) {
+            /*recenter*/
+            this.oMapOL.panTo(new OpenLayers.LonLat(fX, fY));
         } else {
-            var currentZoomLevel = this.oMapOL.getZoom();
-                this.oMapOL.panTo(new OpenLayers.LonLat(fX, fY));
-            } else if (nFactor > 1) {
-                this.oMapOL.zoomTo(currentZoomLevel+1);
-            } else if (nFactor < 1) {
-                this.oMapOL.zoomTo(currentZoomLevel-1);
+            var extent = this.oMapOL.getExtent();
+            if (this.fractionalZoom) {
+                var fDeltaX = extent.right - extent.left;
+                var fDeltaY = extent.top - extent.bottom;
+                var fMinX,fMaxX,fMinY,fMaxY;
+                if (nFactor > 0) {
+                    /*zoomin*/
+                    fMinX = fX - (fDeltaX/2 / nFactor);
+                    fMaxX = fX + (fDeltaX/2 / nFactor);
+                    fMinY = fY - (fDeltaY/2 / nFactor);
+                    fMaxY = fY + (fDeltaY/2 / nFactor);
+                } else if (nFactor < 0) {
+                    /*zoomout*/
+                    fMinX = fX - ((fDeltaX/2) * Math.abs(nFactor));
+                    fMaxX = fX + ((fDeltaX/2) * Math.abs(nFactor));
+                    fMinY = fY - ((fDeltaY/2) * Math.abs(nFactor));
+                    fMaxY = fY + ((fDeltaY/2) * Math.abs(nFactor));
+                this.setExtents(new OpenLayers.Bounds(fMinX, fMinY, fMaxX, fMaxY));
+            } else {
+                var currentZoomLevel = this.oMapOL.getZoom();
+                if (nFactor > 1) {
+                    this.oMapOL.zoomTo(currentZoomLevel+1);
+                } else if (nFactor < 1) {
+                    this.oMapOL.zoomTo(currentZoomLevel-1);
     zoomToScale: function(fScale) {
More information about the fusion-commits mailing list
