[fusion-commits] r1414 - sandbox/aboudreault/widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Fri May 30 16:17:23 EDT 2008
Author: aboudreault
Date: 2008-05-30 16:17:23 -0400 (Fri, 30 May 2008)
New Revision: 1414
   sandbox/aboudreault/widgets/SelectionPanel.js
new abilities for the SelectionPanel widget
Modified: sandbox/aboudreault/widgets/SelectionPanel.js
--- sandbox/aboudreault/widgets/SelectionPanel.js	2008-05-29 14:21:40 UTC (rev 1413)
+++ sandbox/aboudreault/widgets/SelectionPanel.js	2008-05-30 20:17:23 UTC (rev 1414)
@@ -37,33 +37,232 @@
         //console.log('SelectionPanel.initialize');
         Fusion.Widget.prototype.initialize.apply(this, [widgetTag, false]);
         this.defPrevTaskIcon = 'images/icon_back.gif';
         this.defNextTaskIcon = 'images/icon_forward.gif';
         var json = widgetTag.extension;
-        this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
-                        OpenLayers.Function.bind(this.updateSelection, this));
-        this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
-                        OpenLayers.Function.bind(this.clearSelection, this));
+        this.iResultsPerPage = json.ResultsPerPage ? json.ResultsPerPage[0] : 0;
+        this.iResultsPerPage = parseInt(this.iResultsPerPage);
+        if (isNaN(this.iResultsPerPage))
+            this.iResultsPerPage = 0;
+        if (json.SelectionRenderer)
+        {   // todo: use OpenLayers.Util.Try ?
+            try {
+                var renderer = eval(json.SelectionRenderer[0]);
+                if (renderer.prototype.CLASS_NAME && renderer.prototype.CLASS_NAME == "Fusion.Widget.SelectionPanel.SelectionRenderer") {
+                    this.renderer = new renderer(this);
+                } else if (typeof renderer == "function") {
+                    var renderFunction = renderer;
+                    this.renderer = new Fusion.Widget.SelectionPanel.SelectionRenderer(this);
+                    this.renderer.updateSelection = function() {
+                        this.getMap().getSelection(
+                            OpenLayers.Function.bind(renderFunction));
+                    this.renderer.clearSelection = false;
+            catch (e) {}// this will occur if the renderer name provided is undefined.
+        } else {
+            this.renderer = new Fusion.Widget.SelectionPanel.SelectionRendererDefault(this);
+        this.iResultsPerPage = null; // handled by the renderer
+        if (this.renderer.updateSelection) {
+            this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_ON,
+                                           OpenLayers.Function.bind(this.renderer.updateSelection, this.renderer));
+        if (this.renderer.clearSelection) {
+            this.getMap().registerForEvent(Fusion.Event.MAP_SELECTION_OFF,
+                                           OpenLayers.Function.bind(this.renderer.clearSelection, this.renderer));
+/* Class: Fusion.Widget.SelectionPanel.SelectionRenderer
+ * This is a class designed to help users to create their own renderer
+ *     for customize display results.
+Fusion.Widget.SelectionPanel.SelectionRenderer = OpenLayers.Class(
+     * Property: oSelectionPanel
+     * {<Fusion.Widget.SelectionPanel>} The parent widget that uses
+     *                                  the renderer.
+    oSelection: null,
+     * Property: iCurrentIndex
+     * {int} The index of the current position for pagination
+    iCurrentIndex: 0,
+     * Property: iResultsPerPage
+     * {int} The number of results per page for pagination.
+    iResultsPerPage: 0,
+    /* Constructor: Fusion.Widget.SelectionPanel.SelectionRenderer
+     * Constructor for a new <Fusion.Widget.SelectionPanel.SelectionRenderer> instance.
+     * Parameters:
+     * selectionPanel - {<Fusion.Widget.SelectionPanel>} The parent widget that uses
+     *                                                   the renderer.
+    initialize: function(selectionPanel) {
+        this.oSelectionPanel = selectionPanel;
+        this.iResultsPerPage = selectionPanel.iResultsPerPage;
+     * Method: getNextPage
+     * Get the next batches of features. Wrapper of the getPage() method.
+     * Parameters:
+     * selectionLayer - {<Fusion.SelectionObject.Layer>} The layer that contains
+     *                                                   the set of features.
+     * Returns:
+     * {Array(Array)} An array of all features with their properties.
+    getNextPage: function(selectionLayer) {
+        if (selectionLayer && this.iCurrentIndex != selectionLayer.getNumElements()) {
+            var startIndex = 0;
+            var endIndex = selectionLayer.getNumElements();
+            if (this.iResultsPerPage != 0) {
+                var iTotalElement = endIndex;
+                startIndex = this.iCurrentIndex;
+                endIndex = startIndex + this.iResultsPerPage;
+                if (endIndex >= iTotalElement) {
+                    endIndex = iTotalElement;
+                this.iCurrentIndex = endIndex;
+            return this.getPage(selectionLayer, startIndex, endIndex);
+        return false;
+     * Method: getPreviousPage
+     * Get the previous batches of features. Wrapper of the getPage() method.
+     * Parameters:
+     * Returns:
+    getPreviousPage: function(selectionLayer) {
+        var page = false;
+        if (selectionLayer && this.iCurrentIndex != 0) {
+            var page = new Array();
+                startIndex = this.iCurrentIndex - (this.iResultsPerPage * 2);
+                endIndex = this.iCurrentIndex  - this.iResultsPerPage;
+                if (startIndex < 0) {
+                    startIndex = 0;
+        return page;
+     * Method: getMap
+     * Helper method to obtains the map.
+     * Returns:
+     * {<Fusion.Maps>} The map that uses the SelectionPanel Widget.
+    getMap: function() {
+        return this.oSelectionPanel.getMap();
+     * Method: getPage
+     * Get a batches of features in a selection.
+     * Parameters:
+     * startIndex - {int} The index of the first element.
+     * endIndex   - {int} The index of the last element.
+     * Returns:
+    getPage: function(selectionLayer, startIndex, endIndex) {
+        var page = false;
+        if (selectionLayer) {
+            var propNames = selectionLayer.getPropertyNames();
+            var index = 0;
+            for (var i=startIndex; i<endIndex; i++, index++) {
+                for (var j=0; j<propNames.length; j++) {
+                    page[index] = new Array();
+                    page[index][j] = selectionLayer.getElementValue(i, j);
+        return page;
+     * Method: updateSelection
+     * Abstract method that handle the event: Fusion.Event.MAP_SELECTION_ON. This method
+     *     should be implemented by all concrete class.
+    updateSelection: function() {},
+     * Method: clearSelection
+     * Abstract method that handle the event: Fusion.Event.MAP_SELECTION_OFF. This method
+    clearSelection: function() {},
+    CLASS_NAME: "Fusion.Widget.SelectionPanel.SelectionRenderer",
+/* Class: Fusion.Widget.SelectionPanel.SelectionRendererDefault
+ * This class provide a default behavior for the selection panel.
+Fusion.Widget.SelectionPanel.SelectionRendererDefault = OpenLayers.Class(Fusion.Widget.SelectionPanel.SelectionRenderer,
+    initialize : function(selectionPanel) {
+        Fusion.Widget.SelectionPanel.SelectionRenderer.prototype.initialize.apply(this, [selectionPanel]);
         var d = document.createElement('div');
         this.toolbar = document.createElement('div');
         this.toolbar.className = 'selectionPanelToolbar';
         this.layerList = document.createElement('select');
         this.layerList.className = 'layerSelector';
         this.toolbar.appendChild(this.layerList);
-        Event.observe(this.layerList, 'change',
-                  OpenLayers.Function.bind(this.renderSelectionFeatures, this));
+        Event.observe(this.layerList, 'change',
+                      OpenLayers.Function.bind(this.renderSelectionFeatures, this));
         this.featureList = document.createElement('select');
         this.featureList.className = 'featureSelector';
         this.toolbar.appendChild(this.featureList);
-        Event.observe(this.featureList, 'change',
-                  OpenLayers.Function.bind(this.renderFeature, this));
+        Event.observe(this.featureList, 'change',
+                      OpenLayers.Function.bind(this.renderFeature, this));
         this.featureDiv = document.createElement('div');
         this.featureDiv.className = 'selectionPanelContent';
@@ -71,12 +270,16 @@
         d.appendChild(this.toolbar);
         d.appendChild(this.featureDiv);
-        Fusion.addWidgetStyleSheet(widgetTag.location + 'SelectionPanel/SelectionPanel.css');
-        this.domObj.appendChild(d);
+        Fusion.addWidgetStyleSheet(this.oSelectionPanel.getLocation() + 'SelectionPanel/SelectionPanel.css');
+        this.oSelectionPanel.domObj.appendChild(d);
+            OpenLayers.Function.bind(this.renderSelectionLayers, this));
         this.layerList.options.length = 0;
         this.featureList.options.length = 0;
@@ -84,13 +287,7 @@
         Element.addClassName(this.featureDiv, 'noSelection');
         this.featureDiv.innerHTML = OpenLayers.i18n('noSelection');
-    updateSelection: function() {
-        //console.log('update selection');
-        this.getMap().getSelection(
-                    OpenLayers.Function.bind(this.renderSelectionLayers, this));
     renderSelectionLayers: function(oSelection) {
         //TODO: this just gets the first map, we need them all
         this.oSelection = null;
@@ -101,6 +298,7 @@
         if (!this.oSelection) {
             return;
         //clear the layer list select box of any previous selections
         Element.removeClassName(this.featureDiv, 'noSelection');
         while (this.layerList.length>0) {
@@ -124,7 +322,7 @@
         this.layerList.selectedIndex = 0;
         this.renderSelectionFeatures();
     renderSelectionFeatures: function() {
         var layerIdx = this.layerList.selectedIndex;
         //clear the feature list select box of any previous selections
@@ -140,14 +338,14 @@
         this.featureList.selectedIndex = 0;
         this.renderFeature();
     renderFeature: function() {
         var featureIdx = this.featureList.selectedIndex;
         var layerObj = this.oSelection.getLayer(layerIdx);
         var nProperties = layerObj.getNumProperties();
         var aNames = layerObj.getPropertyNames();
         var table = document.createElement('table');
         var thead = document.createElement('thead');
@@ -160,7 +358,7 @@
         tr.appendChild(th);
         thead.appendChild(tr);
         table.appendChild(thead);
         var tbody = document.createElement('tbody');
         table.appendChild(tbody);
         for (var i=0; i<nProperties; i++) {
@@ -179,4 +377,4 @@
         this.featureDiv.innerHTML = '';
         this.featureDiv.appendChild(table);
\ No newline at end of file
More information about the fusion-commits mailing list
