[fusion-commits] r1643 - trunk/widgets
svn_fusion at osgeo.org
Thu Nov 6 13:32:54 EST 2008
Author: pagameba
Date: 2008-11-06 13:32:54 -0500 (Thu, 06 Nov 2008)
New Revision: 1643
trunk/widgets/Print.js
Fixes #153. Jx no longer provides the getObj interface, it was removed as unnecessary because getElementById is now supported on sub-elements by MooTools. The Print dialog code was not updated to remove the use of getObj.
Modified: trunk/widgets/Print.js
--- trunk/widgets/Print.js 2008-11-06 18:30:46 UTC (rev 1642)
+++ trunk/widgets/Print.js 2008-11-06 18:32:54 UTC (rev 1643)
@@ -84,13 +84,10 @@
label: OpenLayers.i18n('printTitle'),
contentURL : this.dialogContentURL,
- onContentLoad: OpenLayers.Function.bind(this.contentLoaded, this),
- imageBaseUrl: this.imageBaseUrl,
+ onContentLoaded: OpenLayers.Function.bind(this.contentLoaded, this),
width: 350,
height: 250,
resize: true,
- top: (size.height-250)/2,
- left: (size.width-350)/2,
toolbars: [toolbar]
var d = new Jx.Dialog(o);
@@ -130,29 +127,25 @@
contentLoaded: function(dialog) {
- dialog.registerIds(['dialogPrintShowtitle',
- 'dialogPrintTitle',
- 'dialogPrintShowlegend',
- 'dialogPrintShowNorthArrow'], dialog.content);
- dialog.getObj('dialogPrintShowtitle').checked = this.showTitle;
- dialog.getObj('dialogPrintTitle').value = this.pageTitle;
- dialog.getObj('dialogPrintTitle').disabled = !this.showTitle;
- dialog.getObj('dialogPrintShowlegend').checked = this.showLegend;
- dialog.getObj('dialogPrintShowNorthArrow').checked = this.showNorthArrow;
+ dialog.content.getElementById('dialogPrintShowtitle').checked = this.showTitle;
+ dialog.content.getElementById('dialogPrintTitle').value = this.pageTitle;
+ dialog.content.getElementById('dialogPrintTitle').disabled = !this.showTitle;
+ dialog.content.getElementById('dialogPrintShowlegend').checked = this.showLegend;
+ dialog.content.getElementById('dialogPrintShowNorthArrow').checked = this.showNorthArrow;
- OpenLayers.Event.observe(dialog.getObj('dialogPrintShowtitle'), 'click', OpenLayers.Function.bind(this.controlTitle, this));
+ OpenLayers.Event.observe(dialog.content.getElementById('dialogPrintShowtitle'), 'click', OpenLayers.Function.bind(this.controlTitle, this));
controlTitle: function() {
- this.dialog.getObj('dialogPrintTitle').disabled = !this.dialog.getObj('dialogPrintShowtitle').checked;
+ this.dialog.content.getElementById('dialogPrintTitle').disabled = !this.dialog.content.getElementById('dialogPrintShowtitle').checked;
generate: function() {
- this.showTitle = this.dialog.getObj('dialogPrintShowtitle').checked;
- this.pageTitle = this.dialog.getObj('dialogPrintTitle').value;
- this.showLegend = this.dialog.getObj('dialogPrintShowlegend').checked;
- this.showNorthArrow = this.dialog.getObj('dialogPrintShowNorthArrow').checked;
+ this.showTitle = this.dialog.content.getElementById('dialogPrintShowtitle').checked;
+ this.pageTitle = this.dialog.content.getElementById('dialogPrintTitle').value;
+ this.showLegend = this.dialog.content.getElementById('dialogPrintShowlegend').checked;
+ this.showNorthArrow = this.dialog.content.getElementById('dialogPrintShowNorthArrow').checked;
this.openPrintable();
More information about the fusion-commits
