[fusion-commits] r1645 - in trunk: lib widgets
svn_fusion at osgeo.org
Thu Nov 6 16:20:28 EST 2008
Author: pagameba
Date: 2008-11-06 16:20:28 -0500 (Thu, 06 Nov 2008)
New Revision: 1645
trunk/lib/Map.js
trunk/lib/jxlib.uncompressed.js
trunk/widgets/Legend.js
Re #151, Re #157. Fix up a bunch of legend behaviour including the context menu handler and toggling the state of themed layers. This needed a change in Jx TreeFolder to fix the problem with themed layers.
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js 2008-11-06 20:26:28 UTC (rev 1644)
+++ trunk/lib/Map.js 2008-11-06 21:20:28 UTC (rev 1645)
@@ -115,8 +115,7 @@
controls: [],
fallThrough: true,
scales: scalesArray,
- fractionalZoom: this.fractionalZoom,
- theme: null
+ fractionalZoom: this.fractionalZoom
if (widgetTag.extension.ConstrainMapExtent) {
this.bRestrictExtent = widgetTag.extension.ConstrainMapExtent[0]=='true'?true:false;
@@ -128,7 +127,6 @@
this.oMapOL = new OpenLayers.Map(this._sDomObj, options );
- Fusion.addWidgetStyleSheet(widgetTag.location + 'MapWidget/MapWidget.css');
this.oMapOL.viewPortDiv.style.position = 'absolute'; //not the top level container so set it to absolute
this.oMapOL.viewPortDiv.style.zIndex = 0; //must explicitly set the z-index for FF3
@@ -474,7 +472,9 @@
setActiveLayer: function( oLayer ) {
this.oActiveLayer = oLayer;
- this.oActiveMap = oLayer.map;
+ if (oLayer) {
+ this.oActiveMap = oLayer.map;
this.triggerEvent(Fusion.Event.MAP_ACTIVE_LAYER_CHANGED, oLayer);
Modified: trunk/lib/jxlib.uncompressed.js
--- trunk/lib/jxlib.uncompressed.js 2008-11-06 20:26:28 UTC (rev 1644)
+++ trunk/lib/jxlib.uncompressed.js 2008-11-06 21:20:28 UTC (rev 1645)
@@ -13210,7 +13210,7 @@
this.parent($merge(options,{type:'Branch'}));
$(this.domNode).addEvent('click', this.clicked.bindWithEvent(this));
- $(this.domLabel).addEvent('click', this.clicked.bindWithEvent(this));
+ this.addEvent('click', this.clicked.bindWithEvent(this));
this.nodes = [];
this.subDomObj = new Element('ul', {'class':'jxTree'});
Modified: trunk/widgets/Legend.js
--- trunk/widgets/Legend.js 2008-11-06 20:26:28 UTC (rev 1644)
+++ trunk/widgets/Legend.js 2008-11-06 21:20:28 UTC (rev 1645)
@@ -242,35 +242,6 @@
this.oTree = new Jx.Tree({parent:this.oLegend.domObj});
this.hideInvisibleLayers = (json.HideInvisibleLayers && json.HideInvisibleLayers[0]) == 'true' ? true : false;
- //console.log('hideInvisibleLayers ' + this.hideInvisibleLayers);
- this.refreshItem = new Jx.Menu.Item({
- label: OpenLayers.i18n('refresh'),
- onClick: OpenLayers.Function.bind(this.update, this)
- this.expandAllItem = new Jx.Menu.Item({
- label: OpenLayers.i18n('expandAll'),
- onClick: OpenLayers.Function.bind(this.expandAll, this)
- this.expandBranchItem = new Jx.Menu.Item({
- label: OpenLayers.i18n('expand'),
- onClick: OpenLayers.Function.bind(this.expandBranch, this)
- this.collapseAllItem = new Jx.Menu.Item({
- label: OpenLayers.i18n('collapseAll'),
- onClick: OpenLayers.Function.bind(this.collapseAll, this)
- this.collapseBranchItem = new Jx.Menu.Item({
- label: OpenLayers.i18n('collapse'),
- onClick: OpenLayers.Function.bind(this.collapseBranch, this)
- //this.collapseBranchItem.disable();
- this.contextMenu = new Jx.Menu.Context(this.name);
- this.contextMenu.add(this.collapseBranchItem,
- this.expandBranchItem,
- this.refreshItem,
- this.expandAllItem,
- this.collapseAllItem );
//don't show the root folder by default
this.showRootFolder = (json.ShowRootFolder && json.ShowRootFolder[0] == 'true') ? true:false;
//do show the map folder by default
@@ -283,34 +254,53 @@
'class':'fusionLegendFolder'
this.oRoot = new Jx.TreeFolder(opt);
- this.oRoot.contextMenu = this.contextMenu;
+ this.oRoot.contextMenu = this.getContextMenu(this.oRoot);
this.oTree.append(this.oRoot);
- OpenLayers.Event.observe(this.oRoot.domObj, 'mouseover', OpenLayers.Function.bind(this.setFolder, this, this.oRoot));
} else {
this.oRoot = this.oTree;
this.extentsChangedWatcher = this.update.bind(this);
- expandAll: function() {
+ getContextMenu: function(folder) {
+ return new Jx.Menu.Context(this.name).add(
+ new Jx.Menu.Item({
+ label: OpenLayers.i18n('collapse'),
+ onClick: OpenLayers.Function.bind(this.collapseBranch, this, folder)
+ label: OpenLayers.i18n('expand'),
+ onClick: OpenLayers.Function.bind(this.expandBranch, this, folder)
+ label: OpenLayers.i18n('refresh'),
+ onClick: OpenLayers.Function.bind(this.update, this, folder)
+ label: OpenLayers.i18n('collapseAll'),
+ onClick: OpenLayers.Function.bind(this.collapseAll, this, folder)
+ label: OpenLayers.i18n('expandAll'),
+ onClick: OpenLayers.Function.bind(this.expandAll, this, folder)
+ expandAll: function(folder) {
this.recurseTree('expand', this.oRoot);
- collapseAll: function() {
+ collapseAll: function(folder) {
this.recurseTree('collapse', this.oRoot);
- collapseBranch: function() {
- if (this.targetFolder && this.targetFolder instanceof Jx.TreeFolder) {
- this.targetFolder.collapse();
+ collapseBranch: function(folder) {
+ folder.collapse();
- expandBranch: function() {
- this.targetFolder.expand();
+ expandBranch: function(folder) {
+ folder.expand();
@@ -329,15 +319,6 @@
- * mouseover action handler for tree folders. Sets the folder to be collapsed/expanded for
- * collapsing individual branches. Adding a mouseout action handler to clear the target folder
- * doesn't work because the action of right clicking the context menu issues a mouseout.
- setFolder: function(folder) {
- this.targetFolder = folder;
scaleRangesLoaded: function() {
this.layerRoot = this.getMap().layerRoot;
this.renderLegend();
@@ -410,13 +391,13 @@
group.legend.treeItem = new Jx.TreeFolder(opt);
- group.legend.treeItem.contextMenu = this.contextMenu;
- group.legend.treeItem.data = group;
+ group.legend.treeItem.contextMenu = this.getContextMenu(group.legend.treeItem);
+ group.legend.treeItem.domObj.store('data', group);
folder.append(group.legend.treeItem);
group.legend.treeItem.checkBox.checked = group.visible?true:false;
OpenLayers.Event.observe(group.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, group));
- OpenLayers.Event.observe(group.legend.treeItem.domObj, 'mouseover', OpenLayers.Function.bind(this.setFolder, this, group.legend.treeItem));
var groupInfo = group.oMap.getGroupInfoUrl(group.groupName);
if (groupInfo) {
var a = document.createElement('a');
@@ -486,15 +467,16 @@
selectionChanged: function(o) {
if (this.currentNode) {
//console.log(this.currentNode);
- $(this.currentNode.domObj.childNodes[3]).addClass('jxTreeSelectedNode');
+ $(this.currentNode.domObj.childNodes[1]).removeClass('jxTreeItemSelected');
this.currentNode = o;
+ $(this.currentNode.domObj.childNodes[1]).addClass('jxTreeItemSelected');
- if (o.data instanceof Fusion.Widget.Map.Group) {
+ var data = o.domObj.retrieve('data');
+ if (data instanceof Fusion.Widget.Map.Group) {
this.getMap().setActiveLayer(null);
} else {
- this.getMap().setActiveLayer(o.data);
+ this.getMap().setActiveLayer(data);
updateGroupLayers: function(group, fScale) {
@@ -525,6 +507,7 @@
} else if (layer.legend.treeItem instanceof Jx.TreeItem) {
this.clearTreeItem(layer);
layer.legend.treeItem = this.createFolderItem(layer);
+ OpenLayers.Event.observe(layer.legend.treeItem.checkBox, 'click', OpenLayers.Function.bind(this.stateChanged, this, layer));
layer.parentGroup.legend.treeItem.append(layer.legend.treeItem);
} else {
while(layer.legend.treeItem.nodes.length > 0) {
@@ -583,6 +566,9 @@
layer.legend.treeItem = newTreeItem;
+ if (layer.legend.treeItem) {
+ layer.legend.treeItem.domObj.store('data', layer);
createFolderItem: function(layer) {
@@ -595,7 +581,7 @@
image: this.imgLayerThemeIcon
var folder = new Jx.TreeFolder(opt);
- folder.contextMenu = this.contextMenu;
+ folder.contextMenu = this.getContextMenu(folder);
var layerInfo = layer.oMap.getLayerInfoUrl(layer.layerName);
if (layerInfo) {
@@ -610,7 +596,6 @@
folder.domObj.insertBefore(a, folder.domObj.childNodes[4]);
folder.addEvent('click', OpenLayers.Function.bind(this.selectionChanged, this));
- OpenLayers.Event.observe(folder.domObj, 'mouseover', OpenLayers.Function.bind(this.setFolder, this, folder));
return folder;
@@ -635,7 +620,7 @@
var item = new Jx.TreeItem(opt);
- item.contextMenu = this.contextMenu;
+ item.contextMenu = this.getContextMenu(layer.parentGroup.legend.treeItem);
if (bCheckBox) {
//item.domObj.insertBefore(layer.legend.checkBox, item.domObj.childNodes[1]);
/* only need to add layer info if it has a check box too */
@@ -659,14 +644,14 @@
return item;
clearTreeItem: function(layer) {
- if (layer.legend.treeItem && layer.legend.treeItem.parent) {
- layer.legend.treeItem.parent.remove(layer.legend.treeItem);
+ if (layer.legend.treeItem && layer.legend.treeItem.owner) {
+ layer.legend.treeItem.domObj.store('data', null);
+ layer.legend.treeItem.owner.remove(layer.legend.treeItem);
layer.legend.treeItem.finalize();
layer.legend.treeItem = null;
- stateChanged: function(obj) {
- //console.log(obj);
+ stateChanged: function(obj, event) {
if (obj.legend && obj.legend.treeItem.checkBox) {
if (obj.legend.treeItem.checkBox.checked) {
obj.show();
@@ -674,6 +659,7 @@
obj.hide();
+ OpenLayers.Event.stop(event, true);
renderFolder: function() {
@@ -719,14 +705,17 @@
this.domImg.style.backgroundImage = 'url('+this.options.image+')';
- var domA = document.createElement('a');
- domA.className = 'fusionLegendItem';
- domA.href = 'javascript:void(0)';
- domA.innerHTML = this.options.label;
- OpenLayers.Event.observe(domA, 'click', this.selected, this);
- OpenLayers.Event.observe(domA, 'dblclick', this.selected, this);
- OpenLayers.Event.observe(domA, 'contextmenu', this.showMenu, this);
+ var domA = new Element('a',{
+ 'class': 'fusionLegendItem',
+ href:'javascript:void(0)',
+ html: this.options.label,
+ events: {
+ click: this.selected.bindWithEvent(this),
+ dblclick: this.selected.bindWithEvent(this),
+ contextmenu: this.showMenu.bindWithEvent(this)
domA.appendChild(this.domImg);
domLabel.appendChild(domA);
this.itemLabelobj = domA;
@@ -749,14 +738,17 @@
+ events: {
domLabel.appendChild(this.checkBox);
More information about the fusion-commits
