[fusion-commits] r1658 - in trunk/MapGuide: . php
svn_fusion at osgeo.org svn_fusion at osgeo.org
Mon Nov 10 15:40:13 EST 2008
Author: madair
Date: 2008-11-10 15:40:11 -0500 (Mon, 10 Nov 2008)
New Revision: 1658
   trunk/MapGuide/MapGuide.js
   trunk/MapGuide/php/CreateSession.php
   trunk/MapGuide/php/LoadMap.php
re #120: for backwards compatibility, set useOverlay to false for MG installs prior to v2.1.x;  move the PHP siteVersion element to LoadMap because opening a template from studio by-passes the CreateSesssion.php call
Modified: trunk/MapGuide/MapGuide.js
--- trunk/MapGuide/MapGuide.js	2008-11-10 19:39:52 UTC (rev 1657)
+++ trunk/MapGuide/MapGuide.js	2008-11-10 20:40:11 UTC (rev 1658)
@@ -73,8 +73,8 @@
         this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
         this.selectionColor = extension.SelectionColor ? extension.SelectionColor[0] : '';
         this.selectionFormat = extension.SelectionFormat ? extension.SelectionFormat[0] : 'PNG';
-        if (extension.SelectionAsOverlay && extension.SelectionAsOverlay[0] == 'true') {
-          this.selectionAsOverlay = true;
+        if (extension.SelectionAsOverlay && extension.SelectionAsOverlay[0] == 'false') {
+          this.selectionAsOverlay = false;
         this.ratio = extension.MapRatio ? extension.MapRatio[0] : 1.0;
@@ -147,13 +147,6 @@
             var o;
             eval('o='+xhr.responseText);
             this.session[0] = o.sessionId;
-            var version = o.siteVersion;
-            var bits = version.split('.');
-            this.siteVersion = new Array(parseInt(bits[0]),
-                                          parseInt(bits[1]),
-                                          parseInt(bits[2]),
-                                          parseInt(bits[3])
             this.triggerEvent(Fusion.Event.MAP_SESSION_CREATED);
@@ -240,6 +233,14 @@
             this.mapWidget.setBackgroundColor(o.backgroundColor);
             this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
+            var version = o.siteVersion;
+            var bits = version.split('.');
+            this.siteVersion = new Array(parseInt(bits[0]),
+                                          parseInt(bits[1]),
+                                          parseInt(bits[2]),
+                                          parseInt(bits[3])
             this.layerRoot.clear();
             this.layerRoot.legendLabel = this._sMapTitle;
@@ -547,11 +548,10 @@
      * Returns an OpenLayers MapGuide layer object
     createOLLayer: function(layerName, bIsBaseLayer, bSingleTile, behaviour) {
-      /* TODO : prevent the useOverlay flag based on site version
-      if ( !(this.siteVersion[0]>1 && this.siteVersion[2]>=0 && this.siteVersion[3]>2) ) { //v2.0.x or higher
+      /* TODO : prevent the useOverlay flag based on site version       */
+      if ( this.siteVersion[0] > 1 && this.siteVersion[1]<1 ) { //v2.0.x or higher
       var layerOptions = {
         units: this.units,
         isBaseLayer: bIsBaseLayer,
Modified: trunk/MapGuide/php/CreateSession.php
--- trunk/MapGuide/php/CreateSession.php	2008-11-10 19:39:52 UTC (rev 1657)
+++ trunk/MapGuide/php/CreateSession.php	2008-11-10 20:40:11 UTC (rev 1658)
@@ -36,14 +36,12 @@
     $site = $siteConnection->GetSite();
     $sessionId =  $site->CreateSession();
     $user->SetMgSessionId($sessionId);
-    $siteVersion = GetSiteVersion();
     header('Content-type: text/x-json');
     header('X-JSON: true');
     $result = null;
     $result->sessionId = $sessionId;
     $result->userName = $username;
-    $result->siteVersion = $siteVersion;
     echo var2json($result);
     /* start a php session in the web tier as well, using same session id */
Modified: trunk/MapGuide/php/LoadMap.php
--- trunk/MapGuide/php/LoadMap.php	2008-11-10 19:39:52 UTC (rev 1657)
+++ trunk/MapGuide/php/LoadMap.php	2008-11-10 20:40:11 UTC (rev 1658)
@@ -91,6 +91,7 @@
     $mapObj->sessionId = $sessionID;
     $mapObj->mapId = $mapid;
     $mapObj->metersPerUnit = $metersPerUnit;
+    $mapObj->siteVersion = GetSiteVersion();
     $mapObj->mapTitle=addslashes($mapTitle);
More information about the fusion-commits mailing list
