[fusion-commits] r1664 - in trunk/layers/MapGuide: . php
svn_fusion at osgeo.org
Wed Nov 12 16:41:01 EST 2008
Author: madair
Date: 2008-11-12 16:41:00 -0500 (Wed, 12 Nov 2008)
New Revision: 1664
trunk/layers/MapGuide/MapGuide.js
trunk/layers/MapGuide/php/Common.php
trunk/layers/MapGuide/php/CreateSession.php
trunk/layers/MapGuide/php/LoadMap.php
trunk/layers/MapGuide/php/LoadScaleRanges.php
trunk/layers/MapGuide/php/MapMenu.php
trunk/layers/MapGuide/php/Query.php
trunk/layers/MapGuide/php/Selection.php
trunk/layers/MapGuide/php/SetLayers.php
trunk/layers/MapGuide/php/SetSelection.php
re #140: update of MapGuide layer to new directory
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/MapGuide.js 2008-11-12 21:41:00 UTC (rev 1664)
@@ -1,5 +1,5 @@
- * Fusion.Maps.MapGuide
+ * Fusion.Layers.MapGuide
* $Id$
@@ -24,15 +24,14 @@
-* Class: Fusion.Maps.MapGuide
+* Class: Fusion.Layers.MapGuide
* Implements the map widget for MapGuide Open Source services.
-Fusion.Maps.MapGuide = OpenLayers.Class(Fusion.Lib.EventMgr, {
+Fusion.Layers.MapGuide = OpenLayers.Class(Fusion.Layers, {
arch: 'MapGuide',
session: [null],
- bSingleTile: null,
aShowLayers: null,
aHideLayers: null,
aShowGroups: null,
@@ -42,46 +41,34 @@
selectionType: 'INTERSECTS',
bSelectionOn: false,
oSelection: null,
- bDisplayInLegend: true, //TODO: set this in AppDef?
- bExpandInLegend: true, //TODO: set this in AppDef?
- bMapLoaded: false,
- bIsMapWidgetLayer: true, //Set this to false for overview map layers
- bLayersReversed: false, //MGOS returns layers top-most layer first
selectionAsOverlay: true,
- //the resource id of the current MapDefinition
- _sResourceId: null,
- clientAgent: 'Fusion Viewer',
initialize: function(map, mapTag, isMapWidgetLayer) {
// console.log('MapGuide.initialize');
- this.registerEventID(Fusion.Event.MAP_SESSION_CREATED);
- this.registerEventID(Fusion.Event.MAP_SELECTION_ON);
- this.registerEventID(Fusion.Event.MAP_SELECTION_OFF);
- this.registerEventID(Fusion.Event.MAP_LOADED);
- this.registerEventID(Fusion.Event.MAP_LOADING);
- this.mapWidget = map;
- this.oSelection = null;
- if (isMapWidgetLayer != null) {
- this.bIsMapWidgetLayer = isMapWidgetLayer;
+ Fusion.Layers.prototype.initialize.apply(this, arguments);
+ var newTheme = Fusion.getQueryParam('theme');
+ if (newTheme != '') {
+ this.sMapResourceId = newTheme;
+ this.registerEventID(Fusion.Event.MAP_SESSION_CREATED);
this.mapInfo = mapTag.mapInfo;
- var extension = mapTag.extension; //TBD: this belongs in layer tag?
- this.selectionType = extension.SelectionType ? extension.SelectionType[0] : 'INTERSECTS';
- this.selectionColor = extension.SelectionColor ? extension.SelectionColor[0] : '';
- this.selectionFormat = extension.SelectionFormat ? extension.SelectionFormat[0] : 'PNG';
- if (extension.SelectionAsOverlay && extension.SelectionAsOverlay[0] == 'false') {
+ this.selectionType = mapTag.extension.SelectionType ? mapTag.extension.SelectionType[0] : 'INTERSECTS';
+ this.selectionColor = mapTag.extension.SelectionColor ? mapTag.extension.SelectionColor[0] : '';
+ this.selectionFormat = mapTag.extension.SelectionFormat ? mapTag.extension.SelectionFormat[0] : 'PNG';
+ if (mapTag.extension.SelectionAsOverlay && mapTag.extension.SelectionAsOverlay[0] == 'false') {
this.selectionAsOverlay = false;
- this.ratio = extension.MapRatio ? extension.MapRatio[0] : 1.0;
+ if (this.bIsMapWidgetLayer) {
+ this.selectionAsOverlay = false;
//add in the handler for CTRL-click actions for the map, not an overviewmap
var ctrlClickEnabled = true;
- if (extension.DisableCtrlClick && extension.DisableCtrlClick[0] == 'true') {
+ if (mapTag.extension.DisableCtrlClick && mapTag.extension.DisableCtrlClick[0] == 'true') {
ctrlClickEnabled = false;
if (ctrlClickEnabled) {
@@ -93,27 +80,20 @@
this.nTolerance = 2; //pixels, default pixel tolernace for a point click; TBD make this configurable
- var newTheme = Fusion.getQueryParam('theme');
- if (newTheme != '') {
- this.sMapResourceId = newTheme;
- } else {
- this.sMapResourceId = mapTag.resourceId ? mapTag.resourceId : '';
rootOpts = {
displayInLegend: this.bDisplayInLegend,
expandInLegend: this.bExpandInLegend,
legendLabel: this._sMapname,
- groupName: 'layerRoot'
+ uniqueId: 'layerRoot',
+ groupName: 'layerRoot',
+ visible: true,
+ actuallyVisible: true
//TODO: set other opts for group initialization as required
- this.layerRoot = new Fusion.Maps.MapGuide.Group(rootOpts,this);
+ this.layerRoot = new Fusion.Layers.Group(rootOpts,this);
- this.bSingleTile = mapTag.singleTile; //this is set in thhe AppDef.Map class
- this.keepAliveInterval = parseInt(extension.KeepAliveInterval ? extension.KeepAliveInterval[0] : 300);
+ this.keepAliveInterval = parseInt(mapTag.extension.KeepAliveInterval ? mapTag.extension.KeepAliveInterval[0] : 300);
var sid = Fusion.sessionId;
if (sid) {
this.session[0] = sid;
@@ -121,19 +101,17 @@
} else {
this.createSession();
createSession: function() {
if (!this.session[0]) {
this.session[0] = this;
var sl = Fusion.getScriptLanguage();
- var scriptURL = this.arch + '/' + sl + '/CreateSession.' + sl;
+ var scriptURL = 'layers/' + this.arch + '/' + sl + '/CreateSession.' + sl;
var options = {onSuccess: OpenLayers.Function.bind(this.createSessionCB, this)};
- Fusion.ajaxRequest(scriptURL,options);
+ Fusion.ajaxRequest(scriptURL, options);
- if (this.session[0] instanceof Fusion.Maps.MapGuide) {
+ if (this.session[0] instanceof Fusion.Layers.MapGuide) {
// console.log('register for event');
this.session[0].registerForEvent(Fusion.Event.MAP_SESSION_CREATED,
OpenLayers.Function.bind(this.mapSessionCreated, this));
@@ -166,32 +144,15 @@
return this.session[0];
- getMapName: function() {
- return this._sMapname;
- getMapTitle: function() {
- return this._sMapTitle;
loadMap: function(resourceId, options) {
this.bMapLoaded = false;
- /* don't do anything if the map is already loaded? */
- if (this._sResourceId == resourceId) {
- return;
if (!this.sessionReady()) {
this.sMapResourceId = resourceId;
return;
- if (this.bIsMapWidgetLayer) {
- this.mapWidget.triggerEvent(Fusion.Event.MAP_LOADING);
- } else {
- this.triggerEvent(Fusion.Event.MAP_LOADING);
+ this.triggerEvent(Fusion.Event.LAYER_LOADING);
this.mapWidget._addWorker();
this._fScale = -1;
@@ -199,7 +160,6 @@
options = options || {};
- this._oMaxExtent = null;
this.aShowLayers = options.showlayers || [];
this.aHideLayers = options.hidelayers || [];
this.aShowGroups = options.showgroups || [];
@@ -212,7 +172,7 @@
this._bSelectionIsLoading = false;
- var loadmapScript = this.arch + '/' + sl + '/LoadMap.' + sl;
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadMap.' + sl;
var sessionid = this.getSessionID();
@@ -230,17 +190,9 @@
this._sMapname = o.mapName;
this._sMapTitle = o.mapTitle;
this.mapWidget.setMetersPerUnit(o.metersPerUnit);
- this.mapWidget.setBackgroundColor(o.backgroundColor);
- this._oMaxExtent = OpenLayers.Bounds.fromArray(o.extent);
- var version = o.siteVersion;
- var bits = version.split('.');
- this.siteVersion = new Array(parseInt(bits[0]),
- parseInt(bits[1]),
- parseInt(bits[2]),
- parseInt(bits[3])
+ this.mapTag.layerOptions.maxExtent = OpenLayers.Bounds.fromArray(o.extent);
this.layerRoot.clear();
this.layerRoot.legendLabel = this._sMapTitle;
@@ -323,7 +275,7 @@
this.oLayerOL.destroy();
- this.oLayerOL = this.createOLLayer(this._sMapname, true, this.bSingleTile,2);
+ this.oLayerOL = this.createOLLayer(this._sMapname, this.bIsBaseLayer, this.bSingleTile,2);
this.oLayerOL.events.register("loadstart", this, this.loadStart);
this.oLayerOL.events.register("loadend", this, this.loadEnd);
this.oLayerOL.events.register("loadcancel", this, this.loadEnd);
@@ -332,15 +284,10 @@
this.bMapLoaded = true;
this.mapWidget.addMap(this);
- this.mapWidget.oMapOL.setBaseLayer(this.oLayerOL);
- var initialExtent = this.mapWidget.setInitialExtents();
- this.mapWidget.setExtents(initialExtent);
- this.mapWidget.triggerEvent(Fusion.Event.MAP_LOADED);
- } else {
- this.triggerEvent(Fusion.Event.MAP_LOADED);
this.mapWidget._removeWorker();
+ this.triggerEvent(Fusion.Event.LAYER_LOADED);
@@ -359,7 +306,7 @@
this.aLayers = [];
@@ -387,7 +334,7 @@
loadScaleRanges: function(userFunc) {
- var loadmapScript = this.arch + '/' + sl + '/LoadScaleRanges.' + sl;
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/LoadScaleRanges.' + sl;
@@ -413,7 +360,7 @@
oLayer.scaleRanges = [];
for (var j=0; j<o.layers[i].scaleRanges.length; j++)
- var scaleRange = new Fusion.Maps.MapGuide.ScaleRange(o.layers[i].scaleRanges[j],
+ var scaleRange = new Fusion.Layers.ScaleRange(o.layers[i].scaleRanges[j],
oLayer.layerType);
oLayer.scaleRanges.push(scaleRange);
@@ -449,7 +396,7 @@
reorderLayers: function(aLayerIndex) {
- var loadmapScript = this.arch + '/' + sl + '/SetLayers.' + sl;
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/SetLayers.' + sl;
var params = {
'mapname': this._sMapname,
@@ -488,7 +435,7 @@
parseMapLayersAndGroups: function(o) {
for (var i=0; i<o.groups.length; i++) {
- var group = new Fusion.Maps.MapGuide.Group(o.groups[i], this);
+ var group = new Fusion.Layers.Group(o.groups[i], this);
var parent;
if (group.parentUniqueId != '') {
parent = this.layerRoot.findGroupByAttribute('uniqueId', group.parentUniqueId);
@@ -499,7 +446,7 @@
for (var i=0; i<o.layers.length; i++) {
- var layer = new Fusion.Maps.MapGuide.Layer(o.layers[i], this);
+ var layer = new Fusion.Layers.Layer(o.layers[i], this);
var parent;
if (layer.parentGroup != '') {
parent = this.layerRoot.findGroupByAttribute('uniqueId', layer.parentGroup);
@@ -532,15 +479,9 @@
this.aRefreshLayers = [];
this.oLayerOL.mergeNewParams(params);
+ if (this.queryLayer) this.queryLayer.redraw(true);
- drawSelection: function() {
- if (this.queryLayer) {
- this.queryLayer.redraw(true);
- } else {
- this.drawMap();
* Function: createOLLayer
@@ -548,19 +489,14 @@
* Returns an OpenLayers MapGuide layer object
createOLLayer: function(layerName, bIsBaseLayer, bSingleTile, behaviour) {
- /* TODO : prevent the useOverlay flag based on site version */
- if ( this.siteVersion[0] > 1 && this.siteVersion[1]<1 ) { //v2.0.x or higher
- this.selectionAsOverlay = false;
var layerOptions = {
units: this.units,
isBaseLayer: bIsBaseLayer,
- maxExtent: this._oMaxExtent,
maxResolution: 'auto',
useOverlay: this.selectionAsOverlay,
ratio: this.ratio
- if (behaviour != 1 && !/WebKit/.test(navigator.userAgent)) {
+ if (!/WebKit/.test(navigator.userAgent)) {
layerOptions.transitionEffect = 'resize';
@@ -581,6 +517,7 @@
layerOptions.singleTile = bSingleTile;
+ OpenLayers.Util.extend(layerOptions, this.mapTag.layerOptions);
var params = {};
if ( bSingleTile ) {
@@ -597,10 +534,11 @@
if (behaviour != null) {
params.behavior = behaviour;
+ params.version = "2.0.0";
params.selectioncolor = this.selectionColor;
params.format = this.selectionFormat;
} else {
params = { //tiled version
mapdefinition: this._sResourceId,
@@ -654,29 +592,6 @@
- * Function: isMapLoaded
- * Returns true if the Map has been laoded succesfully form the server
- isMapLoaded: function() {
- return this.bMapLoaded;
- hasSelection: function() { return this.bSelectionOn; },
- getSelectionCB : function(userFunc, layers, startend, r) {
- if (r.status == 200)
- var o;
- eval("o="+r.responseText);
- var oSelection = new Fusion.SelectionObject(o);
- userFunc(oSelection);
* advertise a new selection is available and redraw the map
newSelection: function() {
@@ -684,7 +599,7 @@
this.bSelectionOn = true;
- this.drawSelection();
+ this.drawMap();
this.triggerEvent(Fusion.Event.MAP_SELECTION_ON);
@@ -725,25 +640,10 @@
return layers;
- * Function: zoomToSelection
- * sets a Selection XML back to the server
- zoomToSelection: function(extent) {
- var center = extent.getCenterPixel();
- var size = extent.getSize();
- extent.left = center.x - 2*size.w;
- extent.right = center.x + 2*size.w;
- extent.bottom = center.y - 2*size.h;
- extent.top = center.y + 2*size.h;
- this.mapWidget.setExtents(extent);
setSelection: function (selText, zoomTo) {
- var setSelectionScript = this.arch + '/' + sl + '/SetSelection.' + sl;
+ var setSelectionScript = 'layers/' + this.arch + '/' + sl + '/SetSelection.' + sl;
var params = {
'mapname': this.getMapName(),
'session': this.getSessionID(),
@@ -787,7 +687,7 @@
//this.mapWidget._addWorker();
// this._bSelectionIsLoading = true;
- var s = this.arch + '/' + Fusion.getScriptLanguage() + "/Selection." + Fusion.getScriptLanguage() ;
+ var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + "/Selection." + Fusion.getScriptLanguage() ;
var options = {
parameters: {'session': this.getSessionID(),
@@ -814,7 +714,7 @@
this.queryLayer.setVisibility(false);
this.triggerEvent(Fusion.Event.MAP_SELECTION_OFF);
+ this.drawMap();
@@ -823,7 +723,7 @@
clearSelection : function() {
if (this.hasSelection()) {
- var s = this.arch + '/' + Fusion.getScriptLanguage() + "/ClearSelection." + Fusion.getScriptLanguage() ;
+ var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + "/ClearSelection." + Fusion.getScriptLanguage() ;
var options = {
'mapname': this._sMapname},
@@ -902,7 +802,7 @@
var bPersistant = options.persistent || true;
var zoomTo = options.zoomTo ? true : false;
- var loadmapScript = this.arch + '/' + sl + '/Query.' + sl;
+ var loadmapScript = 'layers/' + this.arch + '/' + sl + '/Query.' + sl;
var params = {
@@ -929,66 +829,6 @@
Fusion.ajaxRequest(loadmapScript, ajaxOptions);
- processLayerEvents: function(layer, isEnabling) {
- if (this.mapInfo && this.mapInfo.mapEvents.layerEvents[layer.layerName]) {
- var layerEvent = this.mapInfo.mapEvents.layerEvents[layer.layerName];
- var events = isEnabling ? layerEvent.onEnable : layerEvent.onDisable;
- for (var i=0; i<events.length; i++) {
- var o = events[i];
- if (o.type == 'layer') {
- var l = this.layerRoot.findLayer(o.name);
- if (l) {
- if (o.enable) {
- l.show(true);
- } else {
- l.hide(true);
- } else if (o.type == 'group') {
- var g = this.layerRoot.findGroupByAttribute('groupName', o.name);
- if (g) {
- if (o.enable) {
- g.show(true);
- } else {
- g.hide(true);
- processGroupEvents: function(group, isEnabling) {
- if (this.mapInfo && this.mapInfo.mapEvents.groupEvents[group.groupName]) {
- var groupEvent = this.mapInfo.mapEvents.groupEvents[group.groupName];
- var events = isEnabling ? groupEvent.onEnable : groupEvent.onDisable;
- if (l) {
- if (o.enable) {
- l.show(true);
- } else {
- l.hide(true);
- if (g) {
- if (o.enable) {
- g.show(true);
- } else {
- g.hide(true);
showLayer: function( layer, noDraw ) {
this.processLayerEvents(layer, true);
this.aShowLayers.push(layer.uniqueId);
@@ -1031,19 +871,6 @@
this.aRefreshLayers.push(layer.uniqueId);
this.drawMap();
- setParameter : function(param, value) {
- if (param == 'SelectionType') {
- this.selectionType = value;
- loadStart: function() {
- this.mapWidget._addWorker();
- loadEnd: function() {
- this.mapWidget._removeWorker();
* called when there is a click on the map holding the CTRL key: query features at that postion.
@@ -1088,17 +915,7 @@
eval('o='+xhr.responseText);
var h = o['FeatureInformation']['Hyperlink'];
if (h) {
- var linkURL;
- if (h[0].indexOf('href=') > 0) {
- //MGOS allows full anchor tag as the hyperlink, extract the href
- var tempDiv = document.createElement('div');
- tempDiv.innerHTML = h[0];
- linkURL = tempDiv.firstChild.href;
- tempDiv = null;
- } else {
- linkURL = h[0];
- window.open(linkURL, "");
+ window.open(h[0], "");
@@ -1121,248 +938,25 @@
pingServer: function() {
- var s = this.arch + '/' + Fusion.getScriptLanguage() + "/Common." + Fusion.getScriptLanguage() ;
+ var s = 'layers/' + this.arch + '/' + Fusion.getScriptLanguage() + "/Common." + Fusion.getScriptLanguage() ;
var params = {};
params.parameters = {'session': this.getSessionID()};
Fusion.ajaxRequest(s, params);
- getGroupInfoUrl: function(groupName) {
- if (this.mapInfo) {
- var groups = this.mapInfo.links.groups;
- for (var i=0; i<groups.length; i++) {
- if (groups[i].name == groupName) {
- return groups[i].url;
- return null;
- getLayerInfoUrl: function(layerName) {
- var layers = this.mapInfo.links.layers;
- for (var i=0; i<layers.length; i++) {
- if (layers[i].name == layerName) {
- return layers[i].url;
- return null;
-* Class: Fusion.Maps.MapGuide.Group
-* Implements the map layer groups for MapGuide services
-Fusion.Maps.MapGuide.Group = OpenLayers.Class(Fusion.Widget.Map.Group, {
- oMap: null,
- initialize: function(o, oMap) {
- this.uniqueId = o.uniqueId;
- Fusion.Widget.Map.Group.prototype.initialize.apply(this, [o.groupName]);
- this.oMap = oMap;
- this.groupName = o.groupName;
- this.legendLabel = o.legendLabel;
- this.parentUniqueId = o.parentUniqueId;
- this.groupType = o.groupType;
- this.displayInLegend = o.displayInLegend;
- this.expandInLegend = o.expandInLegend;
- this.visible = o.visible;
- this.actuallyVisible = o.actuallyVisible;
- show: function(noDraw) {
- if (this.visible) {
- return;
- this.oMap.showGroup(this, noDraw ? true : false);
- this.visible = true;
- if (this.legend && this.legend.checkBox) {
- this.legend.checkBox.checked = true;
- hide: function(noDraw) {
- if (!this.visible) {
- return;
- this.oMap.hideGroup(this, noDraw ? true : false);
- this.visible = false;
- this.legend.checkBox.checked = false;
- isVisible: function() {
- return this.visible;
+ getLegendImageURL: function(fScale, layer, style) {
+ var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
+ url += "?OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
+ url += "&VERSION=1.0.0&SCALE=" + fScale;
+ url += "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId);
+ url += "&THEMECATEGORY=" + style.categoryIndex;
+ url += "&TYPE=" + style.geometryType;
+ url += "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
+ if (layer.noCache) {
+ url += "&TS=" + (new Date()).getTime();
+ return url;
-* Implements individual map legend layers for MapGuide services
-Fusion.Maps.MapGuide.Layer = OpenLayers.Class(Fusion.Widget.Map.Layer, {
- scaleRanges: null,
- oMap: null,
- Fusion.Widget.Map.Layer.prototype.initialize.apply(this, [o.layerName]);
- this.oMap = oMap;
- this.layerName = o.layerName;
- this.resourceId = o.resourceId;
- this.selectable = o.selectable;
- this.selectedFeatureCount = 0;
- this.layerTypes = [].concat(o.layerTypes);
- this.editable = o.editable;
- //determine the layer type so that the correct icon can be displayed in the legend
- this.layerType = null;
- if (this.supportsType(Fusion.Constant.LAYER_RASTER_TYPE)) { //raster layers
- this.layerType = Fusion.Constant.LAYER_RASTER_TYPE;
- } else if (this.supportsType(Fusion.Constant.LAYER_DWF_TYPE)) { //DWF layers
- this.layerType = Fusion.Constant.LAYER_DWF_TYPE;
- this.parentGroup = o.parentGroup;
- this.minScale = o.minScale;
- this.maxScale = o.maxScale;
- if (this.maxScale == 'infinity') {
- this.maxScale = Infinity;
- this.scaleRanges = [];
- if (o.scaleRanges)
- for (var i=0; i<o.scaleRanges.length; i++) {
- var scaleRange = new Fusion.Maps.MapGuide.ScaleRange(o.scaleRanges[i],
- this.layerType);
- this.scaleRanges.push(scaleRange);
- supportsType: function(type) {
- for (var i=0; i<this.layerTypes.length; i++) {
- if (this.layerTypes[i] == type) {
- return true;
- return false;
- getScaleRange: function(fScale) {
- for (var i=0; i<this.scaleRanges.length; i++) {
- if (this.scaleRanges[i].contains(fScale)) {
- return this.scaleRanges[i];
- return null;
- return;
- this.oMap.showLayer(this, noDraw ? true : false);
- this.set('visible', true);
- return;
- this.oMap.hideLayer(this, noDraw ? true : false);
- this.set('visible',false);
-* Implements a scale range object for MapGuide services
-Fusion.Maps.MapGuide.ScaleRange = OpenLayers.Class({
- styles: null,
- initialize: function(o, layerType) {
- this.styles = [];
- if (!o.styles) {
- var styleItem = new Fusion.Maps.MapGuide.StyleItem({legendLabel:'DWF'}, layerType);
- this.styles.push(styleItem);
- return;
- var staticIcon = o.styles.length>1 ? false : layerType;
- for (var i=0; i<o.styles.length; i++) {
- var styleItem = new Fusion.Maps.MapGuide.StyleItem(o.styles[i], staticIcon);
- contains: function(fScale) {
- var testScale = Math.round(fScale);
- return testScale >= this.minScale && testScale <= this.maxScale;
-* Implements the legend style items to get a legend icon from the server
-Fusion.Maps.MapGuide.StyleItem = OpenLayers.Class({
- initialize: function(o, staticIcon) {
- this.filter = o.filter;
- this.geometryType = o.geometryType;
- if (this.geometryType == '') {
- this.geometryType = -1;
- this.categoryIndex = o.categoryIndex;
- if (this.categoryindex == '') {
- this.categoryindex = -1;
- this.staticIcon = staticIcon;
- getLegendImageURL: function(fScale, layer) {
- var url = Fusion.getConfigurationItem('mapguide', 'mapAgentUrl');
- url += "?OPERATION=GETLEGENDIMAGE&SESSION=" + layer.oMap.getSessionID();
- url += "&VERSION=1.0.0&SCALE=" + fScale;
- url += "&LAYERDEFINITION=" + encodeURIComponent(layer.resourceId);
- url += "&THEMECATEGORY=" + this.categoryIndex;
- url += "&TYPE=" + this.geometryType;
- url += "&CLIENTAGENT=" + encodeURIComponent(this.clientAgent);
- if (layer.noCache) {
- url += "&TS=" + (new Date()).getTime();
- return url;
Modified: trunk/layers/MapGuide/php/Common.php
--- trunk/layers/MapGuide/php/Common.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/Common.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -36,7 +36,7 @@
* this file to configure Fusion.
-$defaultInstallDir = dirname(__FILE__)."/../../../../../";
+$defaultInstallDir = dirname(__FILE__)."/../../../../../../";
$defaultExtensionDir = realpath($defaultInstallDir . "webserverextensions/www/");
Modified: trunk/layers/MapGuide/php/CreateSession.php
--- trunk/layers/MapGuide/php/CreateSession.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/CreateSession.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -30,7 +30,7 @@
include('Common.php');
include('Utilities.php');
-include('../../common/php/Utilities.php');
+include('../../../common/php/Utilities.php');
try {
$site = $siteConnection->GetSite();
Modified: trunk/layers/MapGuide/php/LoadMap.php
--- trunk/layers/MapGuide/php/LoadMap.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/LoadMap.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -28,7 +28,7 @@
* Purpose: get map initial information
-include(dirname(__FILE__).'/../../common/php/Utilities.php');
+include(dirname(__FILE__).'/../../../common/php/Utilities.php');
Modified: trunk/layers/MapGuide/php/LoadScaleRanges.php
--- trunk/layers/MapGuide/php/LoadScaleRanges.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/LoadScaleRanges.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -32,7 +32,7 @@
include ("Common.php");
Modified: trunk/layers/MapGuide/php/MapMenu.php
--- trunk/layers/MapGuide/php/MapMenu.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/MapMenu.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -29,7 +29,7 @@
//Get the folder to search within
$root = (isset($_REQUEST['folder']))?$_REQUEST['folder']:'Library://';
Modified: trunk/layers/MapGuide/php/Query.php
--- trunk/layers/MapGuide/php/Query.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/Query.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -32,7 +32,7 @@
try {
/* set up the session */
- include('../../common/php/Utilities.php');
+ include('../../../common/php/Utilities.php');
/* the name of the layer in the map to query */
Modified: trunk/layers/MapGuide/php/Selection.php
--- trunk/layers/MapGuide/php/Selection.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/Selection.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -30,7 +30,7 @@
$result = NULL;
Modified: trunk/layers/MapGuide/php/SetLayers.php
--- trunk/layers/MapGuide/php/SetLayers.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/SetLayers.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -37,7 +37,7 @@
try {
Modified: trunk/layers/MapGuide/php/SetSelection.php
--- trunk/layers/MapGuide/php/SetSelection.php 2008-11-12 21:28:01 UTC (rev 1663)
+++ trunk/layers/MapGuide/php/SetSelection.php 2008-11-12 21:41:00 UTC (rev 1664)
@@ -25,7 +25,7 @@
$selText = "";
More information about the fusion-commits
