[fusion-commits] r1666 - in branches/fusion-1.1/MapServer: . php
svn_fusion at osgeo.org
Fri Nov 14 10:45:43 EST 2008
Author: madair
Date: 2008-11-14 10:45:43 -0500 (Fri, 14 Nov 2008)
New Revision: 1666
branches/fusion-1.1/MapServer/MapServer.js
branches/fusion-1.1/MapServer/php/SetLayers.php
re #169: fix error in SetLayers response and build the aLayers array correctly for Mapserver
Modified: branches/fusion-1.1/MapServer/MapServer.js
--- branches/fusion-1.1/MapServer/MapServer.js 2008-11-12 21:46:54 UTC (rev 1665)
+++ branches/fusion-1.1/MapServer/MapServer.js 2008-11-14 15:45:43 UTC (rev 1666)
@@ -44,8 +44,8 @@
bDisplayInLegend: true, //TODO: set this in AppDef?
bExpandInLegend: true, //TODO: set this in AppDef?
oSelection: null,
- bMapLoaded : false,
- bIsMapWidgetLayer : true, //Setthis to false for overview map layers
+ bMapLoaded: false,
+ bIsMapWidgetLayer: true, //Setthis to false for overview map layers
bLayersReversed: true, //MS returns layers bottom-most layer first, we treat layer order in reverse sense
mapMetadataKeys: null,
layerMetadataKeys: null,
@@ -258,18 +258,18 @@
singleTile: true,
ratio: this.ratio,
units: this.units,
- maxExtent : this._oMaxExtent,
- maxResolution : 'auto',
- minScale : maxScale, //OL interpretation of min/max scale is reversed from Fusion
- maxScale : minScale
+ maxExtent: this._oMaxExtent,
+ maxResolution: 'auto',
+ minScale: maxScale, //OL interpretation of min/max scale is reversed from Fusion
+ maxScale: minScale
//create the OL layer for this Map layer
var params = {
layers: this.aVisibleLayers.join(' '),
- session : this.getSessionID(),
- map : this._sMapFile,
- map_imagetype : this._sImageType
+ session: this.getSessionID(),
+ map: this._sMapFile,
+ map_imagetype: this._sImageType
//remove this layer if it was already loaded
@@ -379,11 +379,16 @@
eval('o='+r.responseText);
if (o.success) {
var layerCopy = this.aLayers.clone();
+ var nLayers = layerCopy.length -1;
+ //Mapserver has list of layers reversed from MapGuide
+ aLayerIndex.reverse();
this.aLayers = [];
this.aVisibleLayers = [];
for (var i=0; i<aLayerIndex.length; ++i) {
- this.aLayers.push( layerCopy[ aLayerIndex[i] ] );
+ this.aLayers.push( layerCopy[ nLayers - aLayerIndex[i] ] );
if (this.aLayers[i].visible) {
this.aVisibleLayers.push(this.aLayers[i].layerName);
Modified: branches/fusion-1.1/MapServer/php/SetLayers.php
--- branches/fusion-1.1/MapServer/php/SetLayers.php 2008-11-12 21:46:54 UTC (rev 1665)
+++ branches/fusion-1.1/MapServer/php/SetLayers.php 2008-11-14 15:45:43 UTC (rev 1666)
@@ -70,9 +70,10 @@
if ($res) {
- $oMap->save($_SESSION['maps'][$mapName]);
- $currentLayers = $oMap->getlayersdrawingorder();
- echo "{success: true, layerindex: [".implode(",",$currentLayers)."]}";
+ $oMap->save($_SESSION['maps'][$mapName]);
+ $oMap = ms_newMapObj($_SESSION['maps'][$mapName]);
+ $newLayers = $oMap->getlayersdrawingorder();
+ echo "{success: true, layerindex: [".implode(",",$newLayers)."]}";
} else {
echo "{success: false, layerindex: [".$_REQUEST['layerindex']."]}";
More information about the fusion-commits
