[fusion-commits] r1673 - in trunk: layers layers/Generic layers/MapGuide layers/MapServer lib templates/mapserver/standard widgets
svn_fusion at osgeo.org svn_fusion at osgeo.org
Wed Nov 19 11:26:40 EST 2008
Author: madair
Date: 2008-11-19 11:26:40 -0500 (Wed, 19 Nov 2008)
New Revision: 1673
   trunk/layers/Generic/Generic.js
   trunk/layers/Layers.js
   trunk/layers/MapGuide/MapGuide.js
   trunk/layers/MapServer/MapServer.js
   trunk/lib/Map.js
   trunk/templates/mapserver/standard/ApplicationDefinition.xml
   trunk/widgets/TaskPane.js
re #140: fixes to get Google layer working; allow caching for tiled maps
Modified: trunk/layers/Generic/Generic.js
--- trunk/layers/Generic/Generic.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/layers/Generic/Generic.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -105,8 +105,11 @@
                 this.mapTag.layerOptions.type = G_NORMAL_MAP;
                 break;
+            this.mapTag.layerOptions.maxExtent = null;    //maxExtent not allowed on Google layers
             this.oLayerOL = new OpenLayers.Layer.Google(this.getMapName(), this.mapTag.layerOptions );
-            break;
+            this.mapWidget.fractionalZoom = false;        //fractionalZoom not permitted with Google layers
+            this.mapWidget.oMapOL.setOptions({fractionalZoom: false});
+           break;
           default:
             this.oLayerOL = new OpenLayers.Layer[this.layerType](
                                   this.getMapName(),
@@ -126,7 +129,7 @@
         //this.triggerEvent(Fusion.Event.LAYER_LOADED);
-        window.setTimeout(OpenLayers.Function.bind(this.asyncTrigger, this),1000);
+        window.setTimeout(OpenLayers.Function.bind(this.asyncTrigger, this),1);
     asyncTrigger: function() {
Modified: trunk/layers/Layers.js
--- trunk/layers/Layers.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/layers/Layers.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -45,6 +45,7 @@
     sMapResourceId: null,    //pointer to the resource that defines the map (URL, MapFile, MGOS, etc)
     sImageType: 'png',      //TODO: set this in AppDef?
     clientAgent: 'Fusion Viewer',
+    noCache: false,
     _sMapTitle: null,
     _sMapname: null,
@@ -65,6 +66,9 @@
         this.mapTag = mapTag;
+        if (!this.mapTag.layerOptions) {
+          this.mapTag.layerOptions = {};
         this.ratio = this.mapTag.layerOptions.MapRatio ? this.extension.MapRatio[0] : 1.0;
         this.bSingleTile = mapTag.singleTile; //this is set in thhe AppDef.Map class
         this.bIsBaseLayer = mapTag.isBaseLayer;
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/layers/MapGuide/MapGuide.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -94,6 +94,8 @@
         this.layerRoot = new Fusion.Layers.Group(rootOpts,this);
         this.keepAliveInterval = parseInt(mapTag.extension.KeepAliveInterval ? mapTag.extension.KeepAliveInterval[0] : 300);
+        this.noCache = true;
         var sid = Fusion.sessionId;
         if (sid) {
             this.session[0] = sid;
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/layers/MapServer/MapServer.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -69,6 +69,7 @@
         if (mapTag.sid) {
             this.session[0] = mapTag.sid;
Modified: trunk/lib/Map.js
--- trunk/lib/Map.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/lib/Map.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -68,7 +68,7 @@
     mapsLoaded: false,
     layerRoot: null,
     singleTile: true,
-    fractionalZoom: true,  //TODO: set this in AppDef?
+    fractionalZoom: true,
     maxScale: null, //set this to a large number in AppDef to zoom out beyond maxExtent, e.g. 1 billion
@@ -344,7 +344,8 @@
           this.oMapOL.setOptions({
                   maxExtent: this.maxExtent,
                   units: map.units,
-                  projection: this.projection});
+                  projection: this.projection
         //if bRestrictExtent is null, use the default OL behaviour with somewhat restricted map navigation
@@ -608,7 +609,7 @@
         //update the timestamp param to prevent caching
         for (var i=0; i<this.aMaps.length; i++ ) {
-          if (this.aMaps[i].oLayerOL.params) {
+          if (this.aMaps[i].oLayerOL.params && this.aMaps[i].noCache) {
             this.aMaps[i].oLayerOL.params.ts = (new Date()).getTime();
@@ -660,7 +661,7 @@
         return (this._oCurrentExtents) ? true : false;
-    zoom : function(fX, fY, nFactor) {
+    zoom: function(fX, fY, nFactor) {
         //do this differntly with OL code??
         if (nFactor == 1 || nFactor == 0) {
             /*recenter*/
Modified: trunk/templates/mapserver/standard/ApplicationDefinition.xml
--- trunk/templates/mapserver/standard/ApplicationDefinition.xml	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/templates/mapserver/standard/ApplicationDefinition.xml	2008-11-19 16:26:40 UTC (rev 1673)
@@ -86,9 +86,6 @@
           <Options>
             <name>GoogleLayer</name>
             <type>G_PHYSICAL_MAP</type>
-            <isBaseLayer>true</isBaseLayer>
-            <sphericalMercator>true</sphericalMercator>
-            <maxExtent>-141,41,-43,90</maxExtent>
           </Options>
         </Extension>
       </Map>
@@ -1126,7 +1123,7 @@
       <MapId>reliance-roads</MapId>
     </MapWidget>
-<!-- OVERVIEW MAP     -->
+<!-- OVERVIEW MAP
     <Widget xsi:type="WidgetType">
@@ -1134,10 +1131,10 @@
       <Type>OverviewMap</Type>
       <Description/>
       <Extension xsi:type="CustomContentType">
-        <!--MapId>mapserverKeymap</MapId-->
+        <MapId>mapserverKeymap</MapId>
       </Extension>
     </Widget>
 <!-- PRINT -->
     <Widget xsi:type="UiWidgetType">
Modified: trunk/widgets/TaskPane.js
--- trunk/widgets/TaskPane.js	2008-11-19 15:58:49 UTC (rev 1672)
+++ trunk/widgets/TaskPane.js	2008-11-19 16:26:40 UTC (rev 1673)
@@ -56,8 +56,6 @@
             initialTask = url + initialTask;
-        console.log(homeIcon);
         homeIcon  = json.HomeIcon  ? json.HomeIcon[0]  : homeIcon;
         homeClass = json.HomeClass ? json.HomeClass[0] : homeClass;
         prevIcon  = json.PreviousIcon  ? json.PreviousIcon[0]  : prevIcon;
More information about the fusion-commits mailing list
