[fusion-commits] r1676 - in trunk: . layers/MapGuide
layers/MapServer
svn_fusion at osgeo.org
Wed Nov 19 14:37:40 EST 2008
Author: madair
Date: 2008-11-19 14:37:40 -0500 (Wed, 19 Nov 2008)
New Revision: 1676
trunk/build.xml
trunk/layers/MapGuide/MapGuide.js
trunk/layers/MapGuide/MapGuideViewerApi.js
trunk/layers/MapServer/MapServer.js
re #140: changes suggested by JSLint, remove extra commas in MapGuideViewerApi.js and remove that from the single file build
Modified: trunk/build.xml
--- trunk/build.xml 2008-11-19 17:56:45 UTC (rev 1675)
+++ trunk/build.xml 2008-11-19 19:37:40 UTC (rev 1676)
@@ -234,7 +234,7 @@
<!-- merge everything into a single file -->
<concat destfile="${buildOutput}.js" outputencoding="UTF-8" append="true">
<fileset dir="${build.home}/widgets" includes="**/*.js"/>
- <fileset dir="${build.home}/layers" includes="**/*.js" excludes="Layers.js"/>
+ <fileset dir="${build.home}/layers" includes="**/*.js" excludes="Layers.js MapGuide/MapGuideViewerApi.js"/>
</concat>
</target>
Modified: trunk/layers/MapGuide/MapGuide.js
--- trunk/layers/MapGuide/MapGuide.js 2008-11-19 17:56:45 UTC (rev 1675)
+++ trunk/layers/MapGuide/MapGuide.js 2008-11-19 19:37:40 UTC (rev 1676)
@@ -249,7 +249,7 @@
if (!this.bSingleTile) {
if (o.groups.length >0) {
this.bSingleTile = false;
- this.groupName = o.groups[0].groupName //assumes only one group for now
+ this.groupName = o.groups[0].groupName; //assumes only one group for now
this.mapWidget.registerForEvent(Fusion.Event.MAP_EXTENTS_CHANGED,
OpenLayers.Function.bind(this.mapExtentsChanged, this));
} else {
@@ -482,7 +482,9 @@
this.oLayerOL.mergeNewParams(params);
- if (this.queryLayer) this.queryLayer.redraw(true);
+ if (this.queryLayer) {
+ this.queryLayer.redraw(true);
@@ -778,7 +780,7 @@
if (zoomTo) {
- var ext = oNode.extents
+ var ext = oNode.extents;
var extents = new OpenLayers.Bounds(ext.minx, ext.miny, ext.maxx, ext.maxy);
this.zoomToSelection(extents);
@@ -815,7 +817,7 @@
'maxfeatures': options.maxFeatures || 0, //zero means select all features
'layers': options.layers || '',
'variant': options.selectionType || this.selectionType
if (options.filter) {
params.filter= options.filter;
Modified: trunk/layers/MapGuide/MapGuideViewerApi.js
--- trunk/layers/MapGuide/MapGuideViewerApi.js 2008-11-19 17:56:45 UTC (rev 1675)
+++ trunk/layers/MapGuide/MapGuideViewerApi.js 2008-11-19 19:37:40 UTC (rev 1676)
@@ -249,7 +249,7 @@
seg.to.updateGeo();
this.clearContext();
this.draw(this.context);
RectangleHandlers = Class.create();
@@ -317,7 +317,7 @@
this.seg4.from.updateGeo();
MultiPointHandlers = Class.create();
Modified: trunk/layers/MapServer/MapServer.js
--- trunk/layers/MapServer/MapServer.js 2008-11-19 17:56:45 UTC (rev 1675)
+++ trunk/layers/MapServer/MapServer.js 2008-11-19 19:37:40 UTC (rev 1676)
@@ -671,7 +671,7 @@
this.newSelection();
if (zoomTo) {
@@ -706,7 +706,7 @@
'maxfeatures': options.maxFeatures || -1, //-1 means select all features
'layers': layers,
params.filter = options.filter;
More information about the fusion-commits
